Vendor's Booth: General
Beta1 vs Beta2 pistons
Old Mar 9, 2005 | 07:35 AM
Shadohh's Avatar
Default Beta1 vs Beta2 pistons
What is the difference between the Beta1 and beta2 piston?
Most USA oem parts claim them to be interchangable.
so what has tigerlilly changed to clarify a difference between the two piston types?
Old Mar 9, 2005 | 08:54 AM
OdessitPashka's Avatar
pretty sure that they are exactly the same man.
Old Mar 9, 2005 | 09:21 AM
Jaws021's Avatar
they are not identical.
they are interchangeable.
I currently have the beta II pistons on a beta I block, crank, and rods.
Old Mar 9, 2005 | 09:23 AM
Shadohh's Avatar
So what is the difference ^^
That is what I want to know.
Old Mar 9, 2005 | 10:33 AM
LarryMcFly's Avatar
delete, sorry.
Old Mar 9, 2005 | 10:54 AM
01roller's Avatar
couldnt get on webtech but carpoint says
3.23 X 3.68 beta1 bore & stroke
3.22 X 3.68 beta2 bore & stroke
Old Mar 9, 2005 | 11:05 AM
Shadohh's Avatar
I am thinking it a differen valve relief.
Since the beta 2 is MLA. They may need a deeper valve releif.
My wish list would say, they move the pivot point of the pivot high up to the top, so they use a longer rod and means a better rod/stroke ratio smile.gif
I am starting to think its just a marketing thing for the idiot impaired. They could be the same piston.
Old Mar 9, 2005 | 11:36 AM
LarryMcFly's Avatar
Compression difference?
Old Mar 9, 2005 | 12:00 PM
Jaws021's Avatar
QUOTE (Shadohh)
No..
QUOTE (Shadohh)
They are not identical.. but swappable..
Like i said.. i have beta II pistons on a beta I block, rod, crank, in the same bore,..
Larry:
The compression is raised slightly.. just by looking at the two pistons..
Old Mar 9, 2005 | 01:13 PM
LarryMcFly's Avatar
Slightly ...more or less than with 1.8l pistons in a beta1?
