Vendor's Booth: General
96-01 Tiburon Bbk
Old Mar 23, 2007 | 03:27 PM
tdonnell's Avatar
Hello guys,
Just wondering if the rotors that are in the pictures here:
http://www.kdmstuff.com/shop/step1.php?number=716
are the ACTUAL rotors that you recieve? They would need to be 4 lug (114.3x4) to work, I would assume you must have the non-captive swap as well right? Do the 2 piston calipers bolt up to the stock mounting points and still clear the rotors?
Would this kit fit under a 16" wheel?
Also, my goodrich brake lines will bolt up right?
Old Mar 23, 2007 | 03:56 PM
xxxmonoxidechild's Avatar
this has been covered so much, its not even funny.
i cant believe im saying this, but your really should have searched being a older member....
you need to either redrill the rotors to a 4 lug, or use kia spectra5 rotors which are slightly smaller, but still work, and are a bolt on
Old Mar 23, 2007 | 04:02 PM
tdonnell's Avatar
My apologies, thanks for the info.
I figured maybe the company would have re-drilled them.
Old Mar 23, 2007 | 05:23 PM
Actually, if you buy the kit from us, and you buy it for the RD series, I'm about 90% sure they come in drilled for you.
Let me find out for sure though.
I will actually have this kit in the next month or 2 on my car, unless I get some decent pricing in for the lightweight kit that Dennist sells.
Old Mar 23, 2007 | 09:38 PM
Seoulfulracing's Avatar
Vehicle: 2003/Hyundai/New Tiburon
Our BBK kit for Tiburons or other vehicles with 4 lugs will be pre-drilled here and ready to be installed
Thanks
Old Mar 23, 2007 | 10:44 PM
tdonnell's Avatar
SSWWEEEETTT!!!
It is clear that I will need a non-captive swap for the front, but what about fitting under my 16" gram light wheels that will be arriving within a month or so (backordered)?
Thanks so much, front rotors are starting to crack and warp, these would look SICK. Then I will get some ebay drilled rotors for the rear. smile.gif
I will be ordering these hopefully soon, should I PM you when I am ready redz or kdmguy? Or just buy it from the site?
Also, is there anyway you could get ahold of a new non-captive hub? It is just the spindles right, not the entire knuckle? Tiburons are very difficult to find in junkyards and they rip you off so if you could somehow manage to get me a set just let me know the price.
Old Mar 23, 2007 | 10:53 PM
Yes, just buy it through the site.
We can't do the hubs, they are too heavy to send. Check out Car-part.com and your local junkers, and the guys parting out on the site.
Old Mar 25, 2007 | 07:00 PM
tdonnell's Avatar
Thanks. Could you please tell me if this kit will fit under my 16's? And whether the calipers will bolt directly up, and the brake line compadibility?
Thanks so much.
Old Mar 26, 2007 | 09:26 AM
I've got 16's and he said it'd fit fine.
The lines go on fine too.
Old Mar 28, 2007 | 07:22 PM
tdonnell's Avatar
Ok thanks.
Oh yeah, what year calipers are in the kit, I would assume 03+? I was wondering what year they were so I could get some hawk hp+ pads for them when I get them for the rear.
Or are the pads included in the kit already badass? I just assume they are stock.
Thanks for any help here.
Just purchased these from the store. Paid already via paypal.
Could you let me know on the brake pad year?
You have them in stock correct?
Do you still need to drill the 4 lug pattern out?
Do you balance them after drilling?
When might they ship out?
Thanks so much.
