Vehicle: Hyundai RD Coupe Cup Car (1997)
Name: Hyundai RD Coupe Cup Car (1997)
Date Added: 18 February 2014 - 12:19 PM Owner: rob40 Short Description: Gen1 Coupe Cup Car View Vehicle Interior: Strip interior, including all sound proofing & sunroof Disable door locks Strip door internals Remove steering lock Remove aircon and blower fan units Fit Roll Cage Fit fire extuinguisher system Fit ally panel over sunroof hole Fit Racing seat & harness Fit new switches Make new switch panel Fit cut-off switch Fit aftermarket blower for a bit of demist ability Mechanicals: Remove air con system Remove cruise control system Remove standard radiator fans & cowling Remove thermostat from cooling system Remove washer bottle and replace with washer bag (lighter) Remove unused fuses and relays (140grams saved) :icon-biggrin: Remove wheel arch spats Remove one of the tow eyes at the front (1/2kg saved) Change gearbox oil Give engine basic service Fit braided brake hoses Fit uprated suspension Fit series approved brakes all round Replace power steering drive belt Change front suspension top mounts (rubber's perished) Change noisy front wheel bearings Change brake & clutch fluid for Dot 5.1 Cut exhaust back box off and replace with straight pipe Move battery from engine bay to inside car Replace n/s rear brake caliper Replace front to rear brake pipe on n/s Replace ARB drop links all round Replace both front lower wishbones Body: Remove standard bonnet / boot catches & cables Remove excess weight from bonnet (about 4kgs) Fit bonnet & boot pins Remove rear wiper system Remove rear spoiler & fit series approved spoiler Remove front fog lights (used 1 as cold air feed) Sort slight rust on both rear arches Prep & re-spray Fit rain light The above was done during the original build, since then I've changed the gearbox as lost all gears and have spent this closed season building a fresh engine ready for the 2014 season. Engines have to stay within Hyundai specs for the standard 2.0l and no aftermarket/evo cams or other tuning is allowed. |
:thumbup:
Very nice!
nice to see more people with the RD platform.
