My Tiburon
General Info:
Height: 128 cm (4,1 ft).
Length: 434 cm (14,2 ft).
Width: 173 cm (5,6 ft).
Weight: 1377 kg (3035,7 lbs).
Layout: Front engine / F.W.D.
Powertrain: 2 Shafts 5 speed (manual).
Brakes: Vented with A.B.S.
Fuel tank capacity: 55 lt (14,5 gallons) unleaded gasoline 100+ octane.
Max range: 510 km (316,8 miles).
City circle: 330 km (205 miles).
Value: N/A.
Engine:
Model: G4GR.
Displacement: 1599 cc.
Max wheel power: 204,6 kw (274,3 hp) @ 5811 rpm.
Max torque: 343,6 nm (253,6 ft-lbs) @ 5666 rpm.
Redline: 6,500 rpm.
Idle rpm: 850.
Cylinders: 4 in line.
Oil tank capacity: 3,7 lt (0,9 gallons).
Cooling type: Water.
Fuel system: M.P.I.
Performance:
0-100 km/h (0-62 mph): 6,5 sec.
0-400 m (1/4 mile): 14,5 sec @ 172,7 km/h (106,6 mph).
Top speed: 221 km/h (137,3 mph).
Braking distance 100-0 km/h (62-0 mph): 39 m (127,92 ft).
Sound pressure level: 133 db.
Interior modifications:
01. Black leather seats, doors inside and shift boot.
02. Foliatec black window tint.
03. Auto Gauge meters (Air / Fuel, Voltage & Oil Pressure).
04. G-Tech Pro RR performance meter.
05. Chrome pedals, footrest, side steps, headrest pillow suspension, air vents, handbrake, shift gate frame and speaker covers.
06. Chrome short shift.
07. Custom chrome switch panel with three aircraft style red led switches.
08. Tuscani steering wheel emblem and HHCC Shark emblem.
09. Rubber front and rear mats.
10. Trunk net.
11. Cobra XRS 9700 radar and laser detector.
12. Autometer nitrous oxide bottle pressure gauge.
13. NOS purge button.
14. NOS nitrous oxide 10 lb bottle with safety blow valve.
15. Two fire extinguishers.
16. Tire pressure and temperature monitoring system.
17. Thermometer.
18. Direct plug in three socket.
Exterior modifications:
19. Chrome handle door covers.
20. Black altezza rear lights.
21. Osram cool blue & PIAA plasma spark blue front lamps.
22. Automatic radio antenna.
23. Aston Martin chrome led signals.
24. Lampa red neon tubes (front, rear, left & right).
25. Two Extreme Autostyling window decals (front & rear) and one HHCC window decal (rear).
26. Front light masks.
27. Two spoilers.
28. Carcept Ferrari F-50 hood.
29. Two tone (red - black) flakes paint.
30. Two three way windshield washer nozzles.
31. All factory emblems removed and I have added two Tiburon (left, right) and one NOS (rear).
32. Chrome tire valve caps.
33. Front signal lights painted.
34. Chrome windshield wipers (front & rear).
Engine modifications:
35. BMC cold air intake system.
36. Denso double platinum spark plugs.
37. XD/GT cams.
38. R-Side lightweight and adjustable intake and exhaust cam sprockets.
39. Engine parts painted red.
40. NOS nitrous oxide kit with dual purge.
41. Custom chrome air-ram intake manifold.
42. R-Side 61mm chrome throttle body.
43. Forged Pistons.
44. Green exhalation filter.
45. J-Speed lightweight underdrive pulley.
46. JDM titanium voltage stabilizer.
47. ECU upgraded.
48. HKS titanium N1 exhaust system.
I.C.E modifications:
49. Source unit: Rockford Fosgate RFX9220R.
50. Front speakers : MB Quart QSD 213.
51. Middle speakers: Rockford Fosgate FRC4269.
52. Amplifier: Lightning Audio Bolt 2.400.4.
53. Subwoofer: Rockford Fosgate P210S8.
54. Capacitor: Lightning Audio Bolt 10-03.
55. Wiring: Lightning Audio PWR1-0-50.
56. Security: Elser.
Suspension, brake and wheel modifications:
57. KYB shocks with stock springs.
58. Wilwood forged billet superlite four piston calipers with Brembo slotted rotors, Wilwood polymatrix type B brake pads, Goodridge stainless steel brake lines, custom caliper adaptors and custom 5mm spacers.
59. OZ racing superturismo GT rims with Fulda carat exelero tires (215/40/16).
Photos:
Videos:
Interior
Purge
Value: N/A.
Engine:
Model: G4GR.
Redline: 6,500 rpm.
Idle rpm: 850.
Fuel system: M.P.I.
Performance:
10. Trunk net.
17. Thermometer.
27. Two spoilers.
37. XD/GT cams.
43. Forged Pistons.
47. ECU upgraded.
Photos:
Videos:
Interior
Purge
<div class='quotetop'>QUOTE (Braker @ Oct 8 2005, 04:11 PM)</div><div class='quotemain'>41. Custom chrome air-ram intake manifold.</div>
Got any close-up pics?
<div class='quotetop'>QUOTE (Braker @ Oct 8 2005, 04:11 PM)</div><div class='quotemain'>58. Wilwood forged billet superlite four piston calipers... Wilwood polymatrix type B brake pads...</div>
Vehicle: 1997 Hyundai Tiburon
<div class='quotetop'>QUOTE (mb1604 @ Oct 8 2005, 09:29 AM)</div><div class='quotemain'>purge video didnt work for me
just copy the link and erase the link up to www.braker1.com/tiburon/videos/purge.mpg <<or click that
i always thought that europian cars where right hand drivers only am i wrong?
<div class='quotetop'>QUOTE (SilentSecret @ Oct 8 2005, 08:51 PM)</div><div class='quotemain'>i always thought that europian cars where right hand drivers only am i wrong?</div>
Actually only the cars in England and Cyprus are right hand. All other countries (Greece, Italy, France, Germany, Spain etc) are left.
Thank you all for you nice comments. I’m glad you liked my car.
PS: here is the link for the purge video: http://www.braker1.com/tiburon/videos/purge.mpg
