My Home Made Shifter
Old Jan 30, 2009 | 06:13 PM
stealth's Avatar
Vehicle: 2000/Hyundai/Tiburon
well i decided since i had my stock shifter just sitting around, i would modify it to make my own little "homemade short shifter"
got it in the car today and since my shifter didnt come with the bottom bushing i was able to use the stock bushing with the stock shifter and it got rid of all the slop i had with my IS short throw
heres a few pics, probably took me 15 mins at the most
its the same height as my IS shifter but next week im going to drop it a little bit more, worked great and if you have access to a welder makes it easier/cheaper than going out and buying one
Old Jan 30, 2009 | 07:06 PM
Role Reversal's Avatar
Vehicle: 05 Subaru WRX
A for effort, but its not a short throw shifter.
Old Jan 30, 2009 | 07:29 PM
stealth's Avatar
^^ ok well would someone explain what the real difference is other than the "block" design of a sts?
Old Jan 30, 2009 | 07:41 PM
UrS0NvS's Avatar
a short throw is the distance between gears, not the heigth of your lever.
in essence, if you shorten the distance in your gear pattern you can shifter faster which leads to faster times.
btw, i know you got a boot cover but damn, at least smooth down that eagle terd of a weld you stuck that back together with ,lol. lmao.gif
Old Jan 30, 2009 | 07:45 PM
stealth's Avatar
honestly i notice no ifference in the distance i have to go from my stocker right now compared to my import shark shifter
but by shortening the height it reduces the arc that you have to move the shifter to get it into gear = short gear distance
dont worry about the crappy welding job i ground that all down, it was that big because my welder couldnt go up any higher to penetrate all the way into the metal so i had to put a thick layer on
Old Jan 30, 2009 | 07:51 PM
An actual short throw shifter will move the pivot point up making the lower portion longer and simultaniously making top shorter. thus decreasing the angle needed between gears. just hacking the top apart isnt doing anything for the lower portion.
Old Jan 30, 2009 | 07:55 PM
stealth's Avatar
well its not do anything for the lower portion other than making the entire pivot point smaller
like i had said you dont have to rotate the shifter as far by making it shorter which will make the distance shorter between your gears as you move
Old Jan 30, 2009 | 07:58 PM
There is a difference between distance and angle, just so you know.
Old Jan 30, 2009 | 08:03 PM
stealth's Avatar
i do know that
but lets say you have a stock shifter with a 6 in radius, in order to put it in gear you move it 30 degrees that means you're moving the top of the knob roughly 6 inches
now lets say you cut off 2 inches from the radius, you're still moving 30 degrees into gear but now you only have to move it rouchly 4 inches = shorter distance into gears
Old Jan 30, 2009 | 08:06 PM
Im SOOO sorry to underestimate your knowledge.
