Back to a better time...
Old Mar 31, 2004 | 11:17 PM
hyundaijvx's Avatar
Vehicle: Honda
Back then...
- My sunroof worked
- I had an aftermarket head unit
- My driver side door handle didn't have a crack on it
- I had stock tires (I have better ones now)
- My clock worked
- The center console had a top that worked
- I had a cupholder
- I still had my front "H"
[/i]
Old Apr 1, 2004 | 12:54 AM
1. Fix your sunroof.
2. Get some more head. (Heh heh)
3. Superglue your door handle or get another from the junkyard.
4. What are you b****ing about?
5. Take the clock back apart, clean it, trim the plastic around the buttons a bit, or buy my extra one.
6. Take it in and get it fixed for free, they fixed mine for free.
7. WTF happened to your cupholder? Get a new one or open up yours and clean it.
8. Order a new H.
See? Easy, and for under 50 bucks most likely.
Old Apr 1, 2004 | 01:29 AM
hyundaijvx's Avatar
Vehicle: Honda
5. The clock reads the wrong time. Then when I fix it, it just goes back to whatever it wants. It stuck at 1:20 for about 3 days.
Old Apr 1, 2004 | 06:43 AM
Clean2k1Shark's Avatar
Wow. Your sunroof and clock stopped working too? All of a sudden mine started to work again when I removed and moved a bunch of wires I had sprawled around the car.
Old Apr 1, 2004 | 07:00 AM
Sparticus's Avatar
Vehicle: 97 Tiburon
there's a tool that came with the car so you can manually use the sunroof (if the problem you are having is electrical)
Old Apr 1, 2004 | 07:42 AM
cdogtibby1's Avatar
soo... is this a gripe or are you showing off your car...???
Old Apr 1, 2004 | 08:08 AM
Djnevamind's Avatar
Yeah he is showing of it's a new thing now broken car shows check it out some time heh :-)
