~finally Got My Tiburon Replacement!~
yup, after all this time of sitting on the insurence money, i flew out to NYC over the past weekend and looked at a mazda 626 GT hatchback. very rare car, that ive been obsessed with for awhile.
mods are as follows....
Engine:
Mazda FE-DOHC.
-Venolia forged pistons 9:1 compression ratio
-ARP head studs
-VR6 valve springs
-Intake keepers on the exhaust valves (to correct an inherent design flaw)
-Balanced bottom end
-New hydraulic lifters
-FE3N intake and exhaust cams
-Turbonetics T3 60 trim, .48 a/r exhaust (starts building boost at 2k rpm), turbonetics dual port wastegate actuator. Polished compressor housing.
-Custom built ceramic coated log-style manifold and downpipe.
-Polished (not internally, just for aesthetics) intake manifold.
-HKS SSQBOV
-Catco 2.5" cat. converter
-Pacesetter cat-back exhaust w/straight through muffler
-FC RX-7 550cc injectors
-Walbro 190lph fuel pump
-Flex-a-lite electric cooling fan
Transmission:
-Phantom grip
-Pacesetter shifter
-Southbend OFE clutch disk w/DXD pressure plate
-Redline MTL fluid
Electronics/instrumentation:
-Megasquirt v2.2 board, running MSNS 024.s19 code
-Crane Hi-6 ignition
-AEM Wideband gauge/controller (linked to MS)
-Autometer ultra-lite 1600f EGT gauge
-Autometer ultra-lite 20psi boost gauge
-KnocksenseMS knock indicator (linked to MS for knock retard)
-Apexi AVC-R boost controller
-Optima red-top battery mounted in trunk
Suspension:
-H&R sport springs
-Tokico blue struts (2ndgen in front for added susp. travel)
-Addco endlinks
-PGT 18mm rear sway bar
-OEM rear strut tower brace
-AWR front strut tower brace
Interior/Exterior/accessories:
-Momo Runner steering wheel
-Momo shift knob
-MX-6 front seats.
-Power drivers seat.
-Auto dimming rearview mirror
-Keyless entry
-Hella 550 Fog lamps
-FOHA rear spoiler (rare euro only part)
-Cerwin Vega 10" bandpass w/mtx amp.
keep in mind the engine int he car is a VERY rare JDM DOHC FE-3. this motor never came to america, and there are maybe 6-10 total in the states. the wing on the car is also a VERY rare optional mazda wing in europe. on all the mazda forums, this is for sure the only one that is known about in america.
Engine:
Mazda FE-DOHC.
-ARP head studs
-VR6 valve springs
-HKS SSQBOV
Transmission:
-Phantom grip
-Pacesetter shifter
-Redline MTL fluid
Suspension:
-H&R sport springs
-Addco endlinks
-Momo shift knob
-MX-6 front seats.
-Keyless entry
not my style in exteriors but the preformance is there. i'm sure its one hell of a ride, you gotta take me for a spin in the spring when i come out there.
looks like a sleeper to me! why were they selling, looks like alot of work there?
When I was scrolling down through the pics at first glance I thought you were doing a burnout in the cemetary. I was thinking dang! Thats disrespect!!!
"I hate you, when you die I'll spit on your grave... no I do a burnout on it!!!"
