Any interest in FIC diagrams?
Well, I know there are alot of alphas that are boosted on here, not sure what you guys are running for fuel management if anything.
Anyway, I was wondering if there would be a good interest for a nice wiring diagram for the AEM FIC. The AEM FIC has more ability than any other piggyback in my opinion.
For example, Its the ONLY extensive piggyback that can control the primary fuel injectors. The Emanage and SMT-6 need either the add-on turbo box/ignition box or a dual fuel rail setup.
Radu has a 2000 Turbo Tib and is running OBD-II compliant with ZERO CELs with the AEM FIC.
You can control the fueling, injector scaling, retard timing, modify MAF maps, modify O2 maps, log wideband, etc.
If there is a good amount of interest, I will be willing to do this for the 2.7L v6, Beta II, 2.0t Gen coupe, Alpha, etc.
Here is the beta wiring diagram:
<div class='quotetop'>QUOTE </div><div class='quotemain'>AEM FIC diagram PDF
The PDF is much better quality and can be printed on any size paper you would like, while retaining quality if you are wanting to print it out.
heres a jpg version.
</div>
</div>
