What about this turbo?
I got a great offer for a IHI Turbo from an 87-88 Ford Thunderbird. Will this work with our turbo manifold? Is it a T3 style? I don't know much about this brand that came with those year Thunderbirds. :confused: I do know however that it is watercooled and may be an IHI-52 model.
<div class='quotetop'>QUOTE</div><div class='quotemain'>JonGTR:
Will this work with our turbo manifold? Is it a T3 style?</div>i didn't know SR had a turbo manifold to be called *our*? |
I think what he means by ''our'' is a turbo manifold that will fit Tiburons smile.gif Who knows though, I have been known to be delirious
Ok, I mean the two that are out: Champion/KORE. The guy says it ran stock 15 psi.
I picked up a turbo off of a 87 Thunderbird, and it was a T3. I currently have it connected to my Accent, and it does do 15 PSI (the turbo that is). The main problem that I am having is trying to get the boost down lower so I don't blown this lil 1.6L in two :D .
I read somewhere that some of the 87's were Garretts and later that year changed to intercooled with IHI's.
This is the exeption... the IHI turbo used on t-birds uses an exaust flange very similar to the regular garret flange,so yes it will bolt on to a t-3 manifold,flow will be partially blocked because the IHI turbo has a D shaped inlet a bit of porting with a dremel should take care of the bad shape
Denis |
<div class='quotetop'>QUOTE</div><div class='quotemain'>Denisst99:
This is the exeption... the IHI turbo used on t-birds uses an exaust flange very similar to the regular garret flange,so yes it will bolt on to a t-3 manifold,flow will be partially blocked because the IHI turbo has a D shaped inlet a bit of porting with a dremel should take care of the bad shape Denis</div>And I just bought a professional dremel too. :D Anything else I should know about this type? Any specs? I can't find any specs whatsoever. Everyone just has ?? in the spec spaces. rolleyes.gif Some people say the max psi is 18, some say 20. Thanks. |
Originally Posted by JonGTR
(Post 25784)
Funny how only the Champion manifold (sold by KORE) was available at the time. The Alpine had to come with the kit. And oh how rare turbo building information was back then. :inot: |
Um....wow! How about that for some internal reflecting Buddha sh1t! lmao
Here's one for you, I had the first GK Tiburon in the US running Alpine's POS Turbo kit with a Mitsu TD04-15T Turbo and their janky non-tuneable piggy back ECU and the WIE (Worst Idea EVER) decompression spacer plate. I did ALL their R&D for the GK and guess how much discount I got on the kit? LMAO I actually paid more for the kit than people who bought the production ready one! Oh and I co-signed on a Business Line of credit to help them relocate to Colorado where they lived off that line of credit for months and decided sell my Mustang Dyno out from under me and move back to South Africa without so much as a Fvck Off... :( |
