Vaccum Lines
Old Jul 16, 2005 | 09:45 AM
00tibby's Avatar
no one is able to explain to me how these work and what they hook up to. could someone explain to me how the extreme factor kit hooks up to these?
Old Jul 17, 2005 | 03:45 PM
Viper966's Avatar
can you be any more vague?... please elaborate
Old Jul 17, 2005 | 05:51 PM
Arctic Seraph's Avatar
If you're having to ask all these questions, then you're not qualified to install the kit...or it'll take you a really long time to get it installed.
Your intake manifold has a vacuum line (I'm going by memory...and I'm bound to be wrong...but it should be somewhere along the backside of the IM). You'll need vaccum line "tees" to "T" off the stock vacuum lines. There is a vacuum line connected from the stock FPR to the IM. If you're using an FMU, you'll need to make a "T" and run a line to the FMU.
Normally, what I would do...is go the extra mile and get a vacuum box (Golden Eagle is the expensive version, while McMaster Carr has the inexpensive version).
You would connect the vacuum box to the brake booster, which will allow you to connect a wastegate, BoV, boost gauge, FPR, MAP sensor, etc to. Not necessary, but it's an option that I think is rather convenient to have.
EDIT: Oh yeah...your WG, BoV, boost gauge have to be hooked up to a vacuum source...but that should be a given, after I stated the comment above ^^.
Old Jul 17, 2005 | 06:05 PM
Running a vacuum box is a great idea, AC. It would certainly cut down some on the amount of lines that run willynilly all over the engine compartment.
Old Jul 18, 2005 | 09:50 AM
Golden Eagle Vacuum Manifold
Robear Racing is a bit more expensive than other sites that I've found....but the unit is less than $50, and that's the price including Nylon fittings you'll need.
Old Jul 18, 2005 | 10:24 AM
supercow's Avatar
thanks for that link arctic, those blue vacuum manifolds look very nice fing02.gif
Old Jul 19, 2005 | 04:08 PM
Double_A's Avatar
WOw, so when using that box all you have to do is hook the one port up to the vaccum line behind the IM and then from there, whatever needs a vaccum line just hooks into the box? If so, thats sweetness.
Old Jul 20, 2005 | 06:20 AM
JonGTR's Avatar
QUOTE (ArcticChill @ Jul 17 2005, 06:51 PM)
If you're having to ask all these questions, then you're not qualified to install the kit......
Agreed.
I was thinking about getting one of those also. But I'm also gonna convert to stainless steel hoses everywhere for the looks and longevity under the extreme heat.
Old Jul 22, 2005 | 09:44 PM
baraboab's Avatar
Just let me know where are you buying the stainless steel hoses, i am also searcing for that
Old Jul 22, 2005 | 09:53 PM
Look on eBay dude. They've got plenty of people selling SS braided hosing...
