ultimate turbo set up
Old Dec 25, 2004 | 11:38 PM
  #41
Slipstream's Avatar
Default Re: best nitrous system
hmmm. lets see now.
ceramic coated tubular manifold
ceramic coated turbonetics t54 turbo with ceramic bearings
72mm tb
hks super sequencial racing bov
hks super fmic
turbonetics racing wastegate
radial cut valves
new valves, notched and deshrouded
high tension springs
port and polished head and reshaped chambers.
entire engine blueprinted
tigerlily surege tank, honed and ported
9.5:1 forged pistons
forged Rods
forged crank
296 cams
nx ntercooler kit
nos direct port kit
prs8 with wideband o2s
and a whole lot of heatwrap
Old Jan 3, 2005 | 05:52 AM
  #42
MechaniX_034's Avatar
Vehicle: Lancer Evo IX
Default Re: Favorite car magazine?
The ultimate turbo setup, let's see...
Basic equipment:
-HKS 3037S
-Custom tubular manifold matched to port dia, integrating merge collector shaped to mate with flange, gusseted to resist cracking
-HKS Racing Wastegate integrated into turbine side [depending on our workload, this is extremely time-consuming]
-Custom DP, 3 1/2" mated to Blitz Spec-R NUR exhaust system w/decat
Engine internals:
-Eagle rods
-Venolia, JUN or Ross pistons
-Stock crank, blueprinted
-HKS 272 cams
-HKS Adj. cam gears
-HKS head gasket
-HKS head bolt set
-HKS Valve Spring set
-HKS retainers and top caps
-SARD 800cc injectors
-Full core blueprint and balancing, core has been deburred and resealed, heads ported, valves radial cut and leakdown tested at 4.0BAR
Intake system:
-HKS Kansai intake manifold/supplied BBTB
-HKS hardpipes kit
-HKS GT intercooler[possible upgrade to DRAG type]
-WURTH hose clamps all the way through
-BMC filter
-Custom inlet pipe
-Custom airbox
Management:
-Motec M800 Pro/ OEM plugin w/ advanced options loaded
-Antilag @ 1.2BAR/toggle
-Launch control
-Full-throttle shift
Anticipated output to breach 300kW to the wheels on 4WD platform.
:twisted:
