Turbo ? for random...
Old Mar 22, 2002 | 03:16 AM
xpressedhyundai's Avatar
Default Turbo ? for random...
I was wondering if you have had any tranny problem since u have turboed the car. I will be turboin my 99-00 elantra 5 spd. if all is well i will be runnin between 6-10 psi street and 12-16 track. i am rebuildin the bottom end but a little concerned about my tranny. have u replaced or rebuilt? which clutch did u use?
[ March 22, 2002, 10:16 AM: Message edited by: xpressedhyundai ]
Old Mar 22, 2002 | 03:51 AM
My tranny and axles are 100% stock. The clutch is a "stage 3" from Clutchmasters. at $515 its not cheap.
KORE, HVE and RPW have clutches for cheaper.
Old Mar 22, 2002 | 04:01 AM
how much boost are you pushing.? what is your 1/4 times?
Old Mar 22, 2002 | 06:14 AM
Compression is down to 9:1 via a thicker head gasket (less than ideal)
Boost is limited to 9psi currently.
Best time is 15.3 at 3000 Ft.
Old Mar 22, 2002 | 11:03 AM
Curtas's Avatar
Hey Random, do you think my meager 200 crank HP project will require a new clutch? I'm assuming I'll need one for 200 WHP, but would like to put that off as long as possible.
thanks,
ac
Old Mar 22, 2002 | 03:03 PM
You could always keep the stock clutch till you fry it...but worse case senario is that it might take out your tranny when it goes.
Old Mar 23, 2002 | 02:37 AM
Curtas's Avatar
I'll probably risk it. I'm really easy on my clutch. I rev match on almost every shift, in fact the only time I chew the clutch is in first and reverse. Once the turbo goes on, though, I'll definitely put a new clutch at the top of the to-buy list.
ac
Old Mar 23, 2002 | 04:52 AM
Do you happpen to still have the model number for the clutch. just to make it easier to find. also did u replace to flywheel, whas it included?? My turbo tech is having a problem finding a tork plate for the bottom end. currently hes waiting for kenny tran to call him back. did u replace yours?
