Turbo Question
Ok... yesterday I was trying to heard something..... When I pushed the gas pedal, the turbo gauge begin to raise until 10 PSI... it looks that it don't goes up as fast as a week ago... the weird thing is that a week ago, the boost goes up at 14 PSI and the damm boost leak lower the PSI at 7-8PSI...
At 9 or 10 PSI I heard like the sound make by a cat or sound like "buuuiiiiiii"
Is that means that My turbo died??? or maybe it don't have enoguh oil to lubricate??
Ok.-. I just take out the air filter pipe of the Turbine side..... The blades and everything inside has oil in it...... Is that a very bad sign.... right???
So i'm planing to buy this kit:
T3 Rebuild Kit
BTW... how do I know if my turbo is a "CARBON SEAL ASSEMBLY" type
T3 Rebuild Kit
im going to take a stab here and say yes!
i cant tell you what to do, but i'll tell you what I would do. i would take your turbo and the rebuild kit to a reputable shop and ask them to rebuild it for you.
but...thats what i would do only due to the fact that i've never rebuilt a turbo before and i have a certain lack of knowledge when it comes to rebuilding a turbo. i'm pretty sure once you do it, it'll be ok, but say you rebuild it yourself. how will you test it? slap it back on and pray that it doesnt come apart and shatter?
in truth u cant just rebuild the turbo yourself. the turbo needs to be balanced by a shop in order to last. think of it this way, when ur tires on your car arent balenced. the car shakes like hell. now keep in mind the turbo spins over 5X faster then your wheels. its very important that its balenced.
