Turbo installation help.
Alright. My turbo project is just about ready to be installed. I have a few questions before i start.
1) I work at Lowes and we have every type of SS braided hose there you could ever want. So for the oil lines what diameter should i be going for?
2)I have a the concept of how everything should be done, but i know i will run into some prolems installing. So does anyone know of a trusted website or write-up on installation?
3) The way everything is going to work out, i will prolly need to get my exhuast done this week. I dont think that ill be able to install all the turbo stuff before then, so will tims downpipe line up with where the stock exhuast is now? Or will i have get everything in first to line it all up?
Thanks guys...Aaron
Thanks guys...Aaron
This website has a lot of information on installing a turbo:
http://www.cse.uconn.edu/~yelevich/turbo/turbo.html
Just don't pay attention to the MAP sensor stuff.
Vehicle: 2004 Acura TL
I dunno about the exhaust lining up. I doubt it cause the dp that I have from Tim meet's up with the flex pipe. I would say just wait a little bit on the exhaust cause it would suck to pay twice.
As for the lines. For the return, if I remember Corky Bell right, I think 1/4 is preferred. You don't want to have any resistance in that line because unless you have a pump, you are dealing with gravity only. So the bigger the better IMO.
a_gut. I have read that before, but some people responded saying that they hope nobody bases everything off of what he said. SO i wasnt fure if everything he was saying was right. But thank you.
1/4 Oil line ID right?
Yeah, wait til I get home I'll look it up in the bible (Maximum Boost) and check for sure, it may be 1/2 too, like I said bigger is normally better. Less Resistance. I have to do this part of my project too, so I'll know very soon.
QUOTE (a_gut)
thanks for the site!! lots of usefull info. laugh.gif:
QUOTE (Corky Bell's "Maximum Boost")
Where possible, a minimum inside diameter of 1/2" should be observed. I is frequently necessart to compromise 1/2" ID, and this is permissible when other factors are favorable. Keep in mind that no oil pressure exists after the bearing, and low-pressure flow requires much greater flow area for equal flow rates.
Sorry I was way off, Hamhead is right. 1/2" is the minimum ID.
