Turbo Info And Options
#21
How does it mount? I saw it, looks allright.
Gonna be lots of splicing still right?
Anything it doesn't control that we need?
#22
Guest
Posts: n/a
are you talking about the ultimate?? if you are, i mounted mine right under my radio in the second din.
i am sure flyryde could make us some harnesses to plug in the stock ECU like mine does..
its more of what 'can't' the ultimate do.. this thing has some crazy options.. check out.. mohd parts and look for the emanage ultimate. dl the software and see the things you can do.. you can eliminate the MAF, block off sensor readings to the ECU so it wont be able to read certain things. etc. etc.
#23
if you guys are talking about the flyryde kit... we still arent 100% sure.. its still in its designing phase. Ill be meeting with Mr hot shot himself and giving him an earful of common mistakes, special considerations, and beneficial options.
Ive seen/owned 2 kits (alpine/speed factor), owned 5 different turbo manifolds, and ive seen some custom kits... ill make sure that kit is the best offered.
The emanage ultimate should control everything you need to be crazy boosted..
#24
Vehicle: 1998 hyundai tiburon fx
I will take a look at the emanage ultimate when I get home, will you be able to control spark timing with out the need to get an msd and all that good stuff? also loike the PRS4 will I still be able to convert it to map?
#25
QUOTE (98_tibby @ Oct 10 2005, 02:31 PM)
yo people im lookin to get a tubo project goin soon smile.gif if i could find out how to get a speed factor kit it would be a big help or even some info on the new alpine kit
With my car I bought all the parts and organised the mechanic and tuner to put it together.
The turbo kit you had to pay for the whole lot at once.
But with this list, you can purchase them one by one.
hyundai turbo manifold
garrett gt28rs turbo
apex full gasket kit
rpw decompression gasket
obx adjustable cam gear
hybrid intercooler
hks ssqv bov
oil catch can
ngk iridium spark plugs
capa fuel injectors
haltech e6x ecu and loom
intercooler rubber piping repair
Pirtek turbo lines and fittings
255litres fuel pump
exhaust technology JUN BL system
sard fuel pressure regulator
rpw performance stage 2 camshaft
