Turbo Diffusor
thats just the part of the downpipe that bolts onto the turbo that collects exhaust gas from the wastegate (internal) and the gas that went through the turbine and combines them into one pipe.
A diffuser is a device for utilizing part of the kinetic energy of a fluid passing through a machine by gradually increasing the cross-sectional area of the channel or chamber through which it flows so as to decrease its speed and increase its pressure. I think what SFR's kit is calling a "turbo diffuser" is just a Y-pipe that joins two airflows (exhaust flows) into one flow, "diffusing" them... rolleyes.gif
If your turbo isnt internally gated then you can just get a flange that will bolt up to the turbo and block off the hole that is there to allow you to bolt up to a internal wastegate adapter.
a flange like this
t3 turbo flange
it says t3/t4, but anybody who knows anything about turbos knows that a t3/t4 uses a turbine housing from a t3 and a compressor housing of a t4, so this would meet the demands of your t3
then weld the flange to your downpipe in the correct position
a flange like this
t3 turbo flange
You can also get the diffuser with a dump pipe welded on there for external wastegate setup.Im getting the kit by the end of the week and thats what i ordered...
Also the diffuser flange is made for the Garrett BB turbos which are the Gt28-gt35 BB.Possily the GT40 as well might have the same flnage smile.gif
Well, I have a Garrett T3 Super 60 with an upgraded Turbonetics compressor housing. It is oil and water cooled, I will take a few pics of it tomorrow and hopefully you can guide me as to what to do with it Alex. My g/f really frowns on the fact that I keep dumping money into the tib, but I love the thing. And after seeing what a difference just a header and exhaust made after my other mods, a turbo would be sex. Pure sex.
