Tapping Oil Pan, Question.
Old Mar 31, 2006 | 05:49 AM
If you are going to weld the bung onto the pan.. I would consider dropping the whole thing from the bottom of the engine and carefully using a Unibit to make the hole the perfect size. No need to worry about metal shavings and the like in your engine.
You might also want to consider getting a Beta2 pan.. some of those are aluminum instead of pressed steel.
Old Apr 2, 2006 | 08:53 PM
hmm the beta 2 oil pan sounds like a nice idea. i just dont think it would be very easy to get one.
Old Apr 2, 2006 | 09:14 PM
Alex01tib's Avatar
you could probably order one from a dealer. and it would make life alot easier, because when you take your old pan off, you could possibly bend it and such (like i did). And when you take the old one off youll have to clean it and straighten it out if you bent it. If you got a new beta II oil pan you could just rip the old one off and throw it in the garbage, and work with a new clean not bent aluminum pan.
