Stock fuel pressure
Most certainly takes a bit of cranking to fire.
Also be sure to let it run and look for leaks, as it stinks and leaking fuel in a engine bay can be very costly, maybe your life, just to add a little prespective. So make sure you get it all checked out, beofore you take off anywhere.
the fuel pressure, stock is ~38 psi with vac line connected and 42psi without it connected..
After the install, the car should pretty much crank right up after a second..
turn the car on ACC, look at the FPR gauge, see what it reads.. Fire it up.. voila..
I fixed it. It was the fuel line had a hole in it. Weird n Neva hadtgt happen b4 but w e. It started No leaks. Runs smooth Kwakiutl is loud n whimsy. A fixed (::
turbo socks, yes i did (; car runs great, good looks on the fuel rail, i want some injectors when i can afford it i just fixed my car from recent accident now im saving
