Smt6 And Msd
Old Jul 9, 2005 | 03:45 PM
deestibo's Avatar
hi i was wondering im going to be running like 300whp will i need a msd hooked up to with the smt6 or will the smt6 work fine with the timing
Old Jul 10, 2005 | 02:53 PM
silvertibbs's Avatar
Vehicle: 2004 Acura TL
I think it would be a good idea to have the MSD unit to control timing. I think that the smt6 has been limited to +-5 in timing which is pretty poor. I'm really not for sure though, I know that you can adjust it but not by much.
Definitely get an MSD, you'll have more, if not total, control.
Old Jul 10, 2005 | 03:42 PM
Agarwal's Avatar
You do not have the +-7 degrees limitation with the SMT6 if you use an external igniter (you bypass the stock ecu completely), from a 2g Eclipse for example.
Old Jul 10, 2005 | 03:59 PM
Really? Cool, I didn't know that.
But it is true then that you're limited to the +- 7 with JUST the smt6 right?
