Smt6 Insatll
sorry i tried searching cant find anyone know hoe to hook up the smt6 and map bar is it the same as safc and ill also be running duel rails any ideas thanx or diagrams
Wiring diagram:
http://www.hyundaiaftermarket.com/noncgi/u...t=000426#000000
I have issues with how the crank signals are wired though. In that diagram crank signal B is going into IG2IN, but I believe the CAM signal is supposed to go there. I'm currently working on getting traces for these to prove it fing02.gif That diagram will work though for airflow tuning.
Something that may also be of use to everyone (don't be fooled by the GST-Zero, it's an SMT-6!):
http://www.public.asu.edu/~aigutie/T...l%20Manual.pdf (if someone could back this up on another server I'd appreciate it wink1.gif )
I think page 8 would be of most interest to you. The "AMP" signal going into the SMT6 is the signal from a MAP sensor. Then connect the injectors as shown and you should be good to run your double fuel rail.
another diagram is on tibsunited.
http://www.tibsunited.com/viewtopic.php?t=12
its a turbo install topic, but has the smt-6 diagram at the bottom of the first post.
also, ill try to get some pics when i do my wiring saturday or sunday
