Safc Help!
ok please somebody help me i have a safc on my tib pushing 6 pounds of boost on stock compression and have 310cc injectors i need help with a fuel map for the piggyback, anyone?
i took it to the dyno with the first setup and they sent me away, saying thyey wouldnt tune it , i need help please,and i have searched but to no avail.could some one point me in the right direction?
jon
jon
they told me they didnt want to tune it cause it was to much work for them, at th time i was having compressor/turbo/hose problems i called them back went up there with the new setup and they said unnn no! not again.... is there any old base fuel maps floating arround? i need a number to base all this off of. please i need help! i need to get it somewhat dialed in before i go to abq! ps when im idling it idles fine with the controler on it without it runs like crap , with my autometer a/f gauge light magiger it says im at a constant stoik leval a bit rich for my taste but stoik then when i drive it starts to towards the lean side then when boost kicks in it goes full rich.
my fuel maps go like this,
-13,-10,-8,-6,-3,0,1,3,4,5,6,5(high)
-13,-11,-8,-5,-2,-1,0,0,0,0,0,0 (low)
does that look about right?
thats from 800-5500, ish its an safc2
every number is six hundred rpms
Keep your fuel pressure at 38psi@idle with vacuum line attached.
Put all your lows at -21%
Put your highs at +5 across.
Don't floor it alot and get a wideband. Even with tuning the SAFC, you're still gonna run lean. Get a Perfect Power PRS standalone, it costs just as much and won't blow your motor. You can wire it yourself if you can wire a SAFC.
