Quick Question
Old Apr 11, 2005 | 01:15 PM
a_gut's Avatar
What size allen wrench do I use for oil line key hole (turbo oil line)? I have a 5.0, but it seems a bit loose and I dont want to strip it.
Also, how does the oil pan come out? I got all the bolts off, even the ones by the flywheel, and that mug is stuck on there like no other.
Edit: Okay I got the oil pan off and got a surprise. Found these inside:
I have a feeling those aren't supposed to be sitting inside the oil pan wink1.gif So, what are they?
Old Apr 11, 2005 | 03:13 PM
albert's Avatar
The oil pan is "stuck" on with adhesive, so you'll need to pry it off.
The allen is a 5.5 if I remember right. It's also soft brass stuck on with locktite. You'll need to take a blowtorch to the brass fitting and heat it to over 300 degrees to break/cook the locktite off.
