Power Readings.
Old Jan 20, 2006 | 08:06 PM
renante's Avatar
In Australia the dyno that we have reads in KW kilowatts.
whats the calculation to converts to these various HP measurements
bhp
hp
crank hp
flywheel hp
Old Jan 20, 2006 | 08:43 PM
'treezy's Avatar
If you had 220KW you would have 164HP
HP-->KW multiply by .7457
HP-->Watts multiply by 745.7
Old Jan 21, 2006 | 02:15 AM
Dmitry's Avatar
Vehicle: Elantra HD / 2007
not really.
1 KWT is 1.36 HP
simply multiply KTW by 1.36.
btw, you can have KWT from crank, from wheels.
Old Jan 21, 2006 | 03:05 AM
I've always used the following:
1kW = 1.341hp (roughly)
1hp = 0.746kW (roughly)
bhp just means brake horsepower, i.e.: horsepower at the engine/crank/flywheel (someone will correct me if I'm wrong).
So... Whatever kW number you got needs to be multiplied by 1.341 to get the hp number.
If you are wanting to convert hp numbers into kW, you just need to divide the number by 1.341 (or multiply by 0.746).
For example: 172kW = 172 x 1.341 = 230.6hp
Another example: 214hp = 214 / 1.341 = 159.6kW
