Oil Issues
Old Aug 24, 2005 | 03:26 PM
99silvertibby's Avatar
Hey fellas,
I'm having oil issues its leaking from everywhere. I got the fitting in the block with the sender unit and the feed line. Its leakin from the exhaust side and the housing what is going on. Please help me out with whats going on.
Old Aug 24, 2005 | 04:01 PM
turbo seals are dead.
Old Aug 24, 2005 | 04:03 PM
SpeedRacer's Avatar
Yep. Was the turbo new or used? If the seals were new you may have too much oil pressure going to the turbo blowing out the seals, or too little to keep them lubricated.
Old Aug 24, 2005 | 07:09 PM
So when you say seals are you meaning gaskets or what. If so what do I have to do to get it fixed. Or is it f***ed. mad.gif
Old Aug 24, 2005 | 08:04 PM
SpeedRacer's Avatar
Your turbo is fed oil from the block. Inside the turbo is seals to keep the oil where it belongs. Those seals going bad blow oil into all types of place you really don't want oil going. Sounds like the turbo needs new seals. Any local performance shop you trust could probably do it, or there's several well recognized online turbo rebuilders you can sent it off to. Don't freak man, it happens to EVERY turbo eventually.
Back to my original question...did you buy the turbo new or used? Also how many miles or on it?
Old Aug 25, 2005 | 09:46 AM
JonGTR's Avatar
Searching.........
QUOTE (99silvertibby)
Hey i got a problem i got Speedfactors kit from someone and i am haveing problems with the oil line.
Hmmmmm.....
