Hyundai Aftermarket
-   Turbo & Supercharge (Forced Induction) (https://www.hyundaiaftermarket.org/forum/turbo-supercharge-forced-induction-29/)
-   -   Narrowband to wideband? (https://www.hyundaiaftermarket.org/forum/turbo-supercharge-forced-induction-29/narrowband-wideband-25948/)
OdessitPashka Jan 25, 2005 08:10 PM
o2 simulators, rewiring, addind resistors, addint microchips, adding other crap smile.gif
hamhead Jan 25, 2005 09:48 PM
Trouble is finding an eliminator that works... are you turbocharging or what...?
OdessitPashka Jan 25, 2005 09:58 PM
<div class='quotetop'>QUOTE (hamhead)</div><div class='quotemain'>Trouble is finding an eliminator that works... are you turbocharging or what...?</div>
hamhead Jan 25, 2005 10:28 PM
It'll suck if you spend like 130 bucks to get it to work and could've got a Carsound hi-flow for 80.00. What I ran on my GSX for a while was this, relocated the cat for better flow... I saw no diff when I took the cat off:
| ___________________________________________
______CAT____________________________________Muffl er
Thats the way it normally is. I put it like this
_______________________________CAT___________Muffl er
The exhaust hits it going straight and slides right through it easily.
Casper Jan 25, 2005 10:36 PM
? Does that allow the cat to get warm enough to function? The reason the cat is usually right off the downpipe is because it needs the heat to convert the pollutants.
OdessitPashka Jan 25, 2005 10:41 PM
<div class='quotetop'>QUOTE (Casper)</div><div class='quotemain'>? Does that allow the cat to get warm enough to function? The reason the cat is usually right off the downpipe is because it needs the heat to convert the pollutants.</div>
good point casper, and I have something in the place of my old cat so I cant put a high-flow down there.
hamhead Jan 26, 2005 06:00 AM
If your running stainless steel and maybe mild steel it should keep the heat long enough for the gas to travel another foot or two. Either way, running that one hi-flow down there I didn't throw a CEL, without it I did. I needed some major wire extension though. smile.gif
OdessitPashka Jan 26, 2005 07:16 AM
<div class='quotetop'>QUOTE (hamhead)</div><div class='quotemain'>If your running stainless steel and maybe mild steel it should keep the heat long enough for the gas to travel another foot or two. Either way, running that one hi-flow down there I didn't throw a CEL, without it I did. I needed some major wire extension though. smile.gif</div>
we'll see if I can fix the CEL in the 1st place, if I can't then I'll just get a cat.
