Narrowband to wideband?
Old Jan 25, 2005 | 08:10 PM
OdessitPashka's Avatar
o2 simulators, rewiring, addind resistors, addint microchips, adding other crap smile.gif
Old Jan 25, 2005 | 09:48 PM
hamhead's Avatar
Trouble is finding an eliminator that works... are you turbocharging or what...?
Old Jan 25, 2005 | 09:58 PM
QUOTE (hamhead)
Old Jan 25, 2005 | 10:28 PM
hamhead's Avatar
It'll suck if you spend like 130 bucks to get it to work and could've got a Carsound hi-flow for 80.00. What I ran on my GSX for a while was this, relocated the cat for better flow... I saw no diff when I took the cat off:
| ___________________________________________
______CAT____________________________________Muffl er
Thats the way it normally is. I put it like this
_______________________________CAT___________Muffl er
The exhaust hits it going straight and slides right through it easily.
Old Jan 25, 2005 | 10:36 PM
Casper's Avatar
? Does that allow the cat to get warm enough to function? The reason the cat is usually right off the downpipe is because it needs the heat to convert the pollutants.
Old Jan 25, 2005 | 10:41 PM
QUOTE (Casper)
good point casper, and I have something in the place of my old cat so I cant put a high-flow down there.
Old Jan 26, 2005 | 06:00 AM
hamhead's Avatar
If your running stainless steel and maybe mild steel it should keep the heat long enough for the gas to travel another foot or two. Either way, running that one hi-flow down there I didn't throw a CEL, without it I did. I needed some major wire extension though. smile.gif
Old Jan 26, 2005 | 07:16 AM
QUOTE (hamhead)
we'll see if I can fix the CEL in the 1st place, if I can't then I'll just get a cat.
