My turbo Setup
Whats up everyone....Im just starting a turbo project..Should be done in about 12 months...I have a 2000 tiburon automatic
I figured i would post and tell everyone what is going on... The 1st thing i am doing is building up my Tranny..It is in the shop as we speak being rebuilt to handle around 450 HP.. its costing me around $2500 thats it for now...Anything you wanna know just respond... -Jordan |
Turbo/manifold/wastegate/downpipe/injectors/engine management details??? :confused:
:D :D :D |
Well actually lets start with that tranny. do have the details of what you are getting for that $2500? Are you going through Level10.com or have you sourced something localy?
Ya let us know about the tranny!I'm not sure if i want upgrade my auto tranny,or go for a 5 speed swap?I hear it is better to just upgrade the auto.Well let us know how it goes :D
Yeah, Tranny info! :D
As fo the tranny...i was thinking about Level 10, but they wanted $3200...For pretty much the same thing...
I went to a local shop that builds transmissions.. My transmission: Valvebody Recalibrated, Upgrading Torque converter, heavy duty peformance clutches and reaction plates etc.. -Jordan |
Turbo: T4 (most likely)
T4 .58 turbine housing Stage 2 Turbine T4 shaft Water cooled center core 360 degree thrust Anodized back plate, AR60 comp housing 60-1 comp wheel Manifold: Ballistic Racing Stainless steel with flanges and studs (polished) Incl W/gate port WasteGate:Ballistic wastegate DownPipe: Ballistic Racing 63mm Down Pipe with drilled flange ECU: Haltech E6K Injectors: Not sure exactly. Between 550cc and 840cc Fuel Pump: 10 BAR -Jordan |
