My car is driving me nuts, turbo questions, etc
do you still have the stock injectors by any chance? You could swap them in just to see if the car runs.. Scale the injectors back properly in the FIC and see what happens.. If that doesn't work, you can put the bypass plug in the FIC and see if it it at least drives.
If the car drives better with the injectors scaled back AND the FIC, you can point to the 750cc injectors.
If the car doesn't drive fine with the FIC active but drives somewhat fine with the bypass plug in, point your finger at the FIC and/or injectors.
Obviously don't try and build much boost. DON'T GO 50%+ THROTTLE.
With the RRFPR and the fuel maps, if you boost a few lbs (on stock injectors) a couple times to see if the injectors are the problem, you will be ok.
Went to do a leak test, reached in to spin the turbo
It's locked up
Time to start shopping
It's locked up
Took it to river city turbo out here and was informed that the reason it failed was cuz I didn't set the housing right
$400 to take it apart, balance the components and check for bends
One bearing had a score so they gotta replace it
He thinks it's gonna be fine though
Gotta love holsets
Gotta love holsets
BLAH more bad news...the turbine shaft had a score in it which made him nervous
he polished the shaft out and went to balance it and its WAY off balance so its time to replace
the stock shaft is something like 250 bux new his machinist gawked at that and said lets replace it with a larger shaft
so im lookin at like 500 bux now but it comes with a upgraded turbine wheel....hmnmmmmmmmmmmm or i can get a aftermarket CHRA for 300 bux
Vehicle: 2000 tib
Had mine rebuilt,.. (GT307R).over $ 600 ......no regrets!...Just got back from an awesome 800 km weekend trip and over 5000kms so far since the rebuild .
my regrets are still dumping money in to this pile
thats my regret, ugh i just wish it was done already
here it is the long awaited logfile
if i scale the injectors to the proper size, the car wont even turn over so here is one with as close as i can figure it out to be, usually at approx 3200 rpm it will buck a few times for some odd reason
its a whole lot of text so ill put it in a spoiler tag so its not all huge post is huge
Time/s Engine Speed Throttle Fuel trim Ignition trim Maf in Maf out Battery O2 bank1 O2 bank2 Engine Load Sw 12Vdc Inj1 % Inj2 % Inj3 % Inj4 % Inj5 % Inj6 % AFR AnalogA in AnalogB in AnalogA out AnalogB out
0.000 2061.00000 20.0000 -44.53125 0.00000 1.55600 1.55600 12.90000 1.06600 0.97900 5.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.6000 0.000 0.000 0.000 0.000
0.010 2061.00000 20.0000 -44.53125 0.00000 1.55600 1.55600 12.90000 1.06600 0.97900 5.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.6000 0.000 0.000 0.000 0.000
0.020 2087.00000 20.3000 -44.53125 0.00000 1.58500 1.58500 13.40000 0.90600 1.01100 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
0.030 2087.00000 20.3000 -44.53125 0.00000 1.58500 1.58500 13.40000 0.90600 1.01100 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
0.040 2087.00000 20.3000 -44.53125 0.00000 1.58500 1.58500 13.40000 0.90600 1.01100 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
0.050 2087.00000 20.3000 -44.53125 0.00000 1.58500 1.58500 13.40000 0.90600 1.01100 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
0.060 2087.00000 20.3000 -44.53125 0.00000 1.58500 1.58500 13.40000 0.90600 1.01100 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
0.070 2076.00000 20.1000 -44.53125 0.00000 1.54400 1.54400 12.70000 0.90600 1.01100 5.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
0.080 2076.00000 20.1000 -44.53125 0.00000 1.54400 1.54400 12.70000 0.90600 1.01100 5.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
0.090 2076.00000 20.1000 -44.53125 0.00000 1.54400 1.54400 12.70000 0.90600 1.01100 5.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
0.100 2076.00000 20.1000 -44.53125 0.00000 1.54400 1.54400 12.70000 0.90600 1.01100 5.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
0.110 2076.00000 20.1000 -44.53125 0.00000 1.54400 1.54400 12.70000 0.90600 1.01100 5.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
0.120 2101.00000 19.8000 -44.53125 0.00000 1.54400 1.54400 13.50000 0.90600 1.01100 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
0.130 2101.00000 19.8000 -44.53125 0.00000 1.54400 1.54400 13.50000 0.90600 1.01100 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
0.140 2101.00000 19.8000 -44.53125 0.00000 1.54400 1.54400 13.50000 0.90600 1.01100 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
0.150 2101.00000 19.8000 -44.53125 0.00000 1.54400 1.54400 13.50000 0.90600 1.01100 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
0.160 2101.00000 19.8000 -44.53125 0.00000 1.54400 1.54400 13.50000 0.90600 1.01100 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
0.170 2101.00000 19.8000 -44.53125 0.00000 1.54400 1.54400 13.50000 0.90600 1.01100 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
0.180 2101.00000 19.8000 -44.53125 0.00000 1.54400 1.54400 13.50000 0.90600 1.01100 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
0.190 2101.00000 19.8000 -44.53125 0.00000 1.54400 1.54400 13.50000 0.90600 1.01100 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
0.200 2101.00000 19.8000 -44.53125 0.00000 1.54400 1.54400 13.50000 0.90600 1.01100 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
0.210 2101.00000 19.8000 -44.53125 0.00000 1.54400 1.54400 13.50000 0.90600 1.01100 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
0.220 2090.00000 19.8000 -44.53125 0.00000 1.54400 1.54400 12.90000 0.93200 0.98900 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
0.230 2090.00000 19.8000 -44.53125 0.00000 1.54400 1.54400 12.90000 0.93200 0.98900 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
0.240 2090.00000 19.8000 -44.53125 0.00000 1.54400 1.54400 12.90000 0.93200 0.98900 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
0.250 2090.00000 19.8000 -44.53125 0.00000 1.54400 1.54400 12.90000 0.93200 0.98900 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
0.260 2090.00000 19.8000 -44.53125 0.00000 1.54400 1.54400 12.90000 0.93200 0.98900 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
0.270 2090.00000 19.8000 -44.53125 0.00000 1.54400 1.54400 12.90000 0.93200 0.98900 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
0.280 2090.00000 19.8000 -44.53125 0.00000 1.54400 1.54400 12.90000 0.93200 0.98900 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
0.290 2090.00000 19.8000 -44.53125 0.00000 1.54400 1.54400 12.90000 0.93200 0.98900 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
0.300 2090.00000 19.8000 -44.53125 0.00000 1.54400 1.54400 12.90000 0.93200 0.98900 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
0.310 2090.00000 19.8000 -44.53125 0.00000 1.54400 1.54400 12.90000 0.93200 0.98900 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
0.320 2085.00000 20.3000 -44.53125 0.00000 1.57900 1.57900 12.40000 0.93200 0.98900 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
0.330 2085.00000 20.3000 -44.53125 0.00000 1.57900 1.57900 12.40000 0.93200 0.98900 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
0.340 2085.00000 20.3000 -44.53125 0.00000 1.57900 1.57900 12.40000 0.93200 0.98900 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
0.350 2085.00000 20.3000 -44.53125 0.00000 1.57900 1.57900 12.40000 0.93200 0.98900 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
0.360 2085.00000 20.3000 -44.53125 0.00000 1.57900 1.57900 12.40000 0.93200 0.98900 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
0.370 2103.00000 20.0000 -44.53125 0.00000 1.57900 1.57900 13.50000 0.93200 0.98900 5.60000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
0.380 2103.00000 20.0000 -44.53125 0.00000 1.57900 1.57900 13.50000 0.93200 0.98900 5.60000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
0.390 2103.00000 20.0000 -44.53125 0.00000 1.57900 1.57900 13.50000 0.93200 0.98900 5.60000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
0.400 2103.00000 20.0000 -44.53125 0.00000 1.57900 1.57900 13.50000 0.93200 0.98900 5.60000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
0.410 2103.00000 20.0000 -44.53125 0.00000 1.57900 1.57900 13.50000 0.93200 0.98900 5.60000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
0.420 2066.00000 20.0000 -44.53125 0.00000 1.53900 1.53900 13.30000 0.93200 0.98900 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
0.430 2066.00000 20.0000 -44.53125 0.00000 1.53900 1.53900 13.30000 0.93200 0.98900 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
0.440 2066.00000 20.0000 -44.53125 0.00000 1.53900 1.53900 13.30000 0.93200 0.98900 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
0.450 2066.00000 20.0000 -44.53125 0.00000 1.53900 1.53900 13.30000 0.93200 0.98900 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
0.460 2066.00000 20.0000 -44.53125 0.00000 1.53900 1.53900 13.30000 0.93200 0.98900 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
0.470 2066.00000 20.0000 -44.53125 0.00000 1.53900 1.53900 13.30000 0.93200 0.98900 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
0.480 2066.00000 20.0000 -44.53125 0.00000 1.53900 1.53900 13.30000 0.93200 0.98900 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
0.490 2066.00000 20.0000 -44.53125 0.00000 1.53900 1.53900 13.30000 0.93200 0.98900 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
0.500 2066.00000 20.0000 -44.53125 0.00000 1.53900 1.53900 13.30000 0.93200 0.98900 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
0.510 2066.00000 20.0000 -44.53125 0.00000 1.53900 1.53900 13.30000 0.93200 0.98900 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
0.520 2066.00000 20.0000 -44.53125 0.00000 1.53900 1.53900 13.30000 0.93200 0.98900 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
0.530 2066.00000 20.0000 -44.53125 0.00000 1.53900 1.53900 13.30000 0.93200 0.98900 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
0.540 2066.00000 20.0000 -44.53125 0.00000 1.53900 1.53900 13.30000 0.93200 0.98900 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
0.550 2066.00000 20.0000 -44.53125 0.00000 1.53900 1.53900 13.30000 0.93200 0.98900 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
0.560 2066.00000 20.0000 -44.53125 0.00000 1.53900 1.53900 13.30000 0.93200 0.98900 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
0.570 2066.00000 20.0000 -44.53125 0.00000 1.53900 1.53900 13.30000 0.93200 0.98900 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
0.580 2066.00000 20.0000 -44.53125 0.00000 1.53900 1.53900 13.30000 0.93200 0.98900 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
0.590 2066.00000 20.0000 -44.53125 0.00000 1.53900 1.53900 13.30000 0.93200 0.98900 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
0.600 2066.00000 20.0000 -44.53125 0.00000 1.53900 1.53900 13.30000 0.93200 0.98900 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
0.610 2066.00000 20.0000 -44.53125 0.00000 1.53900 1.53900 13.30000 0.93200 0.98900 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
0.620 2066.00000 20.0000 -44.53125 0.00000 1.53900 1.53900 13.30000 0.93200 0.98900 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
0.630 2066.00000 20.0000 -44.53125 0.00000 1.53900 1.53900 13.30000 0.93200 0.98900 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
0.640 2066.00000 20.0000 -44.53125 0.00000 1.53900 1.53900 13.30000 0.93200 0.98900 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
0.650 2066.00000 20.0000 -44.53125 0.00000 1.53900 1.53900 13.30000 0.93200 0.98900 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
0.660 2066.00000 20.0000 -44.53125 0.00000 1.53900 1.53900 13.30000 0.93200 0.98900 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
0.670 2081.00000 20.1000 -44.53125 0.00000 1.52100 1.52100 13.20000 0.34100 0.98600 5.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
0.680 2081.00000 20.1000 -44.53125 0.00000 1.52100 1.52100 13.20000 0.34100 0.98600 5.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
0.690 2081.00000 20.1000 -44.53125 0.00000 1.52100 1.52100 13.20000 0.34100 0.98600 5.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
0.700 2081.00000 20.1000 -44.53125 0.00000 1.52100 1.52100 13.20000 0.34100 0.98600 5.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
0.710 2081.00000 20.1000 -44.53125 0.00000 1.52100 1.52100 13.20000 0.34100 0.98600 5.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
0.720 2081.00000 20.1000 -44.53125 0.00000 1.52100 1.52100 13.20000 0.34100 0.98600 5.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
0.730 2081.00000 20.1000 -44.53125 0.00000 1.52100 1.52100 13.20000 0.34100 0.98600 5.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
0.740 2081.00000 20.1000 -44.53125 0.00000 1.52100 1.52100 13.20000 0.34100 0.98600 5.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
0.750 2081.00000 20.1000 -44.53125 0.00000 1.52100 1.52100 13.20000 0.34100 0.98600 5.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
0.760 2081.00000 20.1000 -44.53125 0.00000 1.52100 1.52100 13.20000 0.34100 0.98600 5.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
0.770 2081.00000 20.1000 -44.53125 0.00000 1.52100 1.52100 13.20000 0.34100 0.98600 5.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
0.780 2081.00000 20.1000 -44.53125 0.00000 1.52100 1.52100 13.20000 0.34100 0.98600 5.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
0.790 2081.00000 20.1000 -44.53125 0.00000 1.52100 1.52100 13.20000 0.34100 0.98600 5.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
0.800 2081.00000 20.1000 -44.53125 0.00000 1.52100 1.52100 13.20000 0.34100 0.98600 5.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
0.810 2081.00000 20.1000 -44.53125 0.00000 1.52100 1.52100 13.20000 0.34100 0.98600 5.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
0.820 2081.00000 20.1000 -44.53125 0.00000 1.52100 1.52100 13.20000 0.34100 0.98600 5.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
0.830 2081.00000 20.1000 -44.53125 0.00000 1.52100 1.52100 13.20000 0.34100 0.98600 5.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
0.840 2081.00000 20.1000 -44.53125 0.00000 1.52100 1.52100 13.20000 0.34100 0.98600 5.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
0.850 2081.00000 20.1000 -44.53125 0.00000 1.52100 1.52100 13.20000 0.34100 0.98600 5.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
0.860 2081.00000 20.1000 -44.53125 0.00000 1.52100 1.52100 13.20000 0.34100 0.98600 5.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
0.870 2081.00000 20.1000 -44.53125 0.00000 1.52100 1.52100 13.20000 0.34100 0.98600 5.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
0.880 2081.00000 20.1000 -44.53125 0.00000 1.52100 1.52100 13.20000 0.34100 0.98600 5.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
0.890 2081.00000 20.1000 -44.53125 0.00000 1.52100 1.52100 13.20000 0.34100 0.98600 5.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
0.900 2081.00000 20.1000 -44.53125 0.00000 1.52100 1.52100 13.20000 0.34100 0.98600 5.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
0.910 2081.00000 20.1000 -44.53125 0.00000 1.52100 1.52100 13.20000 0.34100 0.98600 5.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
0.920 2128.00000 20.3000 -44.53125 0.00000 1.57400 1.57400 13.10000 0.34100 0.98600 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
0.930 2128.00000 20.3000 -44.53125 0.00000 1.57400 1.57400 13.10000 0.34100 0.98600 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
0.940 2128.00000 20.3000 -44.53125 0.00000 1.57400 1.57400 13.10000 0.34100 0.98600 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
0.950 2128.00000 20.3000 -44.53125 0.00000 1.57400 1.57400 13.10000 0.34100 0.98600 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
0.960 2128.00000 20.3000 -44.53125 0.00000 1.57400 1.57400 13.10000 0.34100 0.98600 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
0.970 2068.00000 20.1000 -44.53125 0.00000 1.57400 1.57400 13.40000 0.34100 0.98600 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
0.980 2068.00000 20.1000 -44.53125 0.00000 1.57400 1.57400 13.40000 0.34100 0.98600 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
0.990 2068.00000 20.1000 -44.53125 0.00000 1.57400 1.57400 13.40000 0.34100 0.98600 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
1.000 2068.00000 20.1000 -44.53125 0.00000 1.57400 1.57400 13.40000 0.34100 0.98600 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
1.010 2068.00000 20.1000 -44.53125 0.00000 1.57400 1.57400 13.40000 0.34100 0.98600 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
1.020 2067.00000 19.8000 -44.53125 0.00000 1.56200 1.56200 13.00000 0.34100 0.98600 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
1.030 2067.00000 19.8000 -44.53125 0.00000 1.56200 1.56200 13.00000 0.34100 0.98600 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
1.040 2067.00000 19.8000 -44.53125 0.00000 1.56200 1.56200 13.00000 0.34100 0.98600 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
1.050 2067.00000 19.8000 -44.53125 0.00000 1.56200 1.56200 13.00000 0.34100 0.98600 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
1.060 2067.00000 19.8000 -44.53125 0.00000 1.56200 1.56200 13.00000 0.34100 0.98600 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
1.070 2093.00000 20.0000 -44.53125 0.00000 1.57400 1.57400 12.60000 0.34700 0.96000 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
1.080 2093.00000 20.0000 -44.53125 0.00000 1.57400 1.57400 12.60000 0.34700 0.96000 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
1.090 2093.00000 20.0000 -44.53125 0.00000 1.57400 1.57400 12.60000 0.34700 0.96000 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
1.100 2093.00000 20.0000 -44.53125 0.00000 1.57400 1.57400 12.60000 0.34700 0.96000 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
1.110 2093.00000 20.0000 -44.53125 0.00000 1.57400 1.57400 12.60000 0.34700 0.96000 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
1.120 2135.00000 20.0000 -44.53125 0.00000 1.56800 1.56800 13.30000 0.34700 0.96000 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
1.130 2135.00000 20.0000 -44.53125 0.00000 1.56800 1.56800 13.30000 0.34700 0.96000 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
1.140 2135.00000 20.0000 -44.53125 0.00000 1.56800 1.56800 13.30000 0.34700 0.96000 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
1.150 2135.00000 20.0000 -44.53125 0.00000 1.56800 1.56800 13.30000 0.34700 0.96000 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
1.160 2135.00000 20.0000 -44.53125 0.00000 1.56800 1.56800 13.30000 0.34700 0.96000 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
1.170 2066.00000 19.7000 -44.53125 0.00000 1.52700 1.52700 13.20000 0.34700 0.96000 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
1.180 2066.00000 19.7000 -44.53125 0.00000 1.52700 1.52700 13.20000 0.34700 0.96000 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
1.190 2066.00000 19.7000 -44.53125 0.00000 1.52700 1.52700 13.20000 0.34700 0.96000 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
1.200 2066.00000 19.7000 -44.53125 0.00000 1.52700 1.52700 13.20000 0.34700 0.96000 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
1.210 2066.00000 19.7000 -44.53125 0.00000 1.52700 1.52700 13.20000 0.34700 0.96000 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
1.220 2065.00000 20.3000 -44.53125 0.00000 1.55600 1.55600 12.70000 0.34700 0.96000 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
1.230 2065.00000 20.3000 -44.53125 0.00000 1.55600 1.55600 12.70000 0.34700 0.96000 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
1.240 2065.00000 20.3000 -44.53125 0.00000 1.55600 1.55600 12.70000 0.34700 0.96000 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
1.250 2065.00000 20.3000 -44.53125 0.00000 1.55600 1.55600 12.70000 0.34700 0.96000 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
1.260 2065.00000 20.3000 -44.53125 0.00000 1.55600 1.55600 12.70000 0.34700 0.96000 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
1.270 2134.00000 20.1000 -44.53125 0.00000 1.58500 1.58500 13.20000 0.56800 0.88700 5.60000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
1.280 2134.00000 20.1000 -44.53125 0.00000 1.58500 1.58500 13.20000 0.56800 0.88700 5.60000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
1.290 2134.00000 20.1000 -44.53125 0.00000 1.58500 1.58500 13.20000 0.56800 0.88700 5.60000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
1.300 2134.00000 20.1000 -44.53125 0.00000 1.58500 1.58500 13.20000 0.56800 0.88700 5.60000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
1.310 2134.00000 20.1000 -44.53125 0.00000 1.58500 1.58500 13.20000 0.56800 0.88700 5.60000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
1.320 2088.00000 20.3000 -44.53125 0.00000 1.56800 1.56800 13.60000 0.56800 0.88700 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
1.330 2088.00000 20.3000 -44.53125 0.00000 1.56800 1.56800 13.60000 0.56800 0.88700 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
1.340 2088.00000 20.3000 -44.53125 0.00000 1.56800 1.56800 13.60000 0.56800 0.88700 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
1.350 2088.00000 20.3000 -44.53125 0.00000 1.56800 1.56800 13.60000 0.56800 0.88700 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
1.360 2088.00000 20.3000 -44.53125 0.00000 1.56800 1.56800 13.60000 0.56800 0.88700 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
1.370 2064.00000 20.0000 -44.53125 0.00000 1.53900 1.53900 12.80000 0.56800 0.88700 5.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
1.380 2064.00000 20.0000 -44.53125 0.00000 1.53900 1.53900 12.80000 0.56800 0.88700 5.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
1.390 2064.00000 20.0000 -44.53125 0.00000 1.53900 1.53900 12.80000 0.56800 0.88700 5.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
1.400 2064.00000 20.0000 -44.53125 0.00000 1.53900 1.53900 12.80000 0.56800 0.88700 5.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
1.410 2064.00000 20.0000 -44.53125 0.00000 1.53900 1.53900 12.80000 0.56800 0.88700 5.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
1.420 2138.00000 19.8000 -44.53125 0.00000 1.55600 1.55600 13.30000 0.56800 0.88700 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
1.430 2138.00000 19.8000 -44.53125 0.00000 1.55600 1.55600 13.30000 0.56800 0.88700 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
1.440 2138.00000 19.8000 -44.53125 0.00000 1.55600 1.55600 13.30000 0.56800 0.88700 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
1.450 2138.00000 19.8000 -44.53125 0.00000 1.55600 1.55600 13.30000 0.56800 0.88700 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
1.460 2138.00000 19.8000 -44.53125 0.00000 1.55600 1.55600 13.30000 0.56800 0.88700 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
1.470 2097.00000 20.3000 -44.53125 0.00000 1.56800 1.56800 13.30000 1.04000 0.75600 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
1.480 2097.00000 20.3000 -44.53125 0.00000 1.56800 1.56800 13.30000 1.04000 0.75600 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
1.490 2097.00000 20.3000 -44.53125 0.00000 1.56800 1.56800 13.30000 1.04000 0.75600 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
1.500 2097.00000 20.3000 -44.53125 0.00000 1.56800 1.56800 13.30000 1.04000 0.75600 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
1.510 2097.00000 20.3000 -44.53125 0.00000 1.56800 1.56800 13.30000 1.04000 0.75600 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
1.520 2075.00000 20.1000 -44.53125 0.00000 1.55600 1.55600 13.40000 1.04000 0.75600 5.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
1.530 2075.00000 20.1000 -44.53125 0.00000 1.55600 1.55600 13.40000 1.04000 0.75600 5.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
1.540 2075.00000 20.1000 -44.53125 0.00000 1.55600 1.55600 13.40000 1.04000 0.75600 5.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
1.550 2075.00000 20.1000 -44.53125 0.00000 1.55600 1.55600 13.40000 1.04000 0.75600 5.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
1.560 2075.00000 20.1000 -44.53125 0.00000 1.55600 1.55600 13.40000 1.04000 0.75600 5.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
1.570 2070.00000 20.0000 -44.53125 0.00000 1.53300 1.53300 12.90000 1.04000 0.75600 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.6000 0.000 0.000 0.000 0.000
1.580 2070.00000 20.0000 -44.53125 0.00000 1.53300 1.53300 12.90000 1.04000 0.75600 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.6000 0.000 0.000 0.000 0.000
1.590 2070.00000 20.0000 -44.53125 0.00000 1.53300 1.53300 12.90000 1.04000 0.75600 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.6000 0.000 0.000 0.000 0.000
1.600 2070.00000 20.0000 -44.53125 0.00000 1.53300 1.53300 12.90000 1.04000 0.75600 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.6000 0.000 0.000 0.000 0.000
1.610 2070.00000 20.0000 -44.53125 0.00000 1.53300 1.53300 12.90000 1.04000 0.75600 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.6000 0.000 0.000 0.000 0.000
1.620 2132.00000 19.7000 -44.53125 0.00000 1.56200 1.56200 13.30000 1.04000 0.75600 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
1.630 2132.00000 19.7000 -44.53125 0.00000 1.56200 1.56200 13.30000 1.04000 0.75600 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
1.640 2132.00000 19.7000 -44.53125 0.00000 1.56200 1.56200 13.30000 1.04000 0.75600 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
1.650 2132.00000 19.7000 -44.53125 0.00000 1.56200 1.56200 13.30000 1.04000 0.75600 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
1.660 2132.00000 19.7000 -44.53125 0.00000 1.56200 1.56200 13.30000 1.04000 0.75600 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
1.670 2103.00000 20.1000 -44.53125 0.00000 1.57900 1.57900 13.50000 1.05300 0.72400 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
1.680 2103.00000 20.1000 -44.53125 0.00000 1.57900 1.57900 13.50000 1.05300 0.72400 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
1.690 2103.00000 20.1000 -44.53125 0.00000 1.57900 1.57900 13.50000 1.05300 0.72400 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
1.700 2103.00000 20.1000 -44.53125 0.00000 1.57900 1.57900 13.50000 1.05300 0.72400 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
1.710 2103.00000 20.1000 -44.53125 0.00000 1.57900 1.57900 13.50000 1.05300 0.72400 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
1.720 2077.00000 20.1000 -44.53125 0.00000 1.59700 1.59700 13.50000 1.05300 0.72400 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
1.730 2077.00000 20.1000 -44.53125 0.00000 1.59700 1.59700 13.50000 1.05300 0.72400 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
1.740 2077.00000 20.1000 -44.53125 0.00000 1.59700 1.59700 13.50000 1.05300 0.72400 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
1.750 2077.00000 20.1000 -44.53125 0.00000 1.59700 1.59700 13.50000 1.05300 0.72400 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
1.760 2077.00000 20.1000 -44.53125 0.00000 1.59700 1.59700 13.50000 1.05300 0.72400 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
1.770 2109.00000 19.8000 -44.53125 0.00000 1.51500 1.51500 13.40000 1.05300 0.72400 5.70000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
1.780 2109.00000 19.8000 -44.53125 0.00000 1.51500 1.51500 13.40000 1.05300 0.72400 5.70000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
1.790 2109.00000 19.8000 -44.53125 0.00000 1.51500 1.51500 13.40000 1.05300 0.72400 5.70000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
1.800 2109.00000 19.8000 -44.53125 0.00000 1.51500 1.51500 13.40000 1.05300 0.72400 5.70000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
1.810 2109.00000 19.8000 -44.53125 0.00000 1.51500 1.51500 13.40000 1.05300 0.72400 5.70000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
1.820 2089.00000 19.8000 -44.53125 0.00000 1.54400 1.54400 13.60000 1.05300 0.72400 5.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
1.830 2089.00000 19.8000 -44.53125 0.00000 1.54400 1.54400 13.60000 1.05300 0.72400 5.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
1.840 2089.00000 19.8000 -44.53125 0.00000 1.54400 1.54400 13.60000 1.05300 0.72400 5.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
1.850 2089.00000 19.8000 -44.53125 0.00000 1.54400 1.54400 13.60000 1.05300 0.72400 5.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
1.860 2089.00000 19.8000 -44.53125 0.00000 1.54400 1.54400 13.60000 1.05300 0.72400 5.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
1.870 2108.00000 20.1000 -44.53125 0.00000 1.58500 1.58500 13.40000 1.01800 0.92800 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
1.880 2108.00000 20.1000 -44.53125 0.00000 1.58500 1.58500 13.40000 1.01800 0.92800 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
1.890 2108.00000 20.1000 -44.53125 0.00000 1.58500 1.58500 13.40000 1.01800 0.92800 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
1.900 2108.00000 20.1000 -44.53125 0.00000 1.58500 1.58500 13.40000 1.01800 0.92800 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
1.910 2108.00000 20.1000 -44.53125 0.00000 1.58500 1.58500 13.40000 1.01800 0.92800 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
1.920 2088.00000 20.1000 -44.53125 0.00000 1.56200 1.56200 12.20000 1.01800 0.92800 5.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
1.930 2088.00000 20.1000 -44.53125 0.00000 1.56200 1.56200 12.20000 1.01800 0.92800 5.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
1.940 2088.00000 20.1000 -44.53125 0.00000 1.56200 1.56200 12.20000 1.01800 0.92800 5.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
1.950 2088.00000 20.1000 -44.53125 0.00000 1.56200 1.56200 12.20000 1.01800 0.92800 5.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
1.960 2088.00000 20.1000 -44.53125 0.00000 1.56200 1.56200 12.20000 1.01800 0.92800 5.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
1.970 2109.00000 20.0000 -44.53125 0.00000 1.56800 1.56800 13.20000 1.01800 0.92800 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
1.980 2109.00000 20.0000 -44.53125 0.00000 1.56800 1.56800 13.20000 1.01800 0.92800 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
1.990 2109.00000 20.0000 -44.53125 0.00000 1.56800 1.56800 13.20000 1.01800 0.92800 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
2.000 2109.00000 20.0000 -44.53125 0.00000 1.56800 1.56800 13.20000 1.01800 0.92800 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
2.010 2109.00000 20.0000 -44.53125 0.00000 1.56800 1.56800 13.20000 1.01800 0.92800 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
2.020 2117.00000 20.0000 -44.53125 0.00000 1.56800 1.56800 13.50000 1.01800 0.92800 5.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
2.030 2117.00000 20.0000 -44.53125 0.00000 1.56800 1.56800 13.50000 1.01800 0.92800 5.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
2.040 2117.00000 20.0000 -44.53125 0.00000 1.56800 1.56800 13.50000 1.01800 0.92800 5.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
2.050 2117.00000 20.0000 -44.53125 0.00000 1.56800 1.56800 13.50000 1.01800 0.92800 5.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
2.060 2117.00000 20.0000 -44.53125 0.00000 1.56800 1.56800 13.50000 1.01800 0.92800 5.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
2.070 2100.00000 20.1000 -44.53125 0.00000 1.57400 1.57400 13.10000 0.98600 0.98300 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
2.080 2100.00000 20.1000 -44.53125 0.00000 1.57400 1.57400 13.10000 0.98600 0.98300 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
2.090 2100.00000 20.1000 -44.53125 0.00000 1.57400 1.57400 13.10000 0.98600 0.98300 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
2.100 2100.00000 20.1000 -44.53125 0.00000 1.57400 1.57400 13.10000 0.98600 0.98300 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
2.110 2100.00000 20.1000 -44.53125 0.00000 1.57400 1.57400 13.10000 0.98600 0.98300 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
2.120 2112.00000 20.1000 -44.53125 0.00000 1.59100 1.59100 13.40000 0.98600 0.98300 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
2.130 2112.00000 20.1000 -44.53125 0.00000 1.59100 1.59100 13.40000 0.98600 0.98300 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
2.140 2112.00000 20.1000 -44.53125 0.00000 1.59100 1.59100 13.40000 0.98600 0.98300 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
2.150 2112.00000 20.1000 -44.53125 0.00000 1.59100 1.59100 13.40000 0.98600 0.98300 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
2.160 2112.00000 20.1000 -44.53125 0.00000 1.59100 1.59100 13.40000 0.98600 0.98300 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
2.170 2087.00000 19.8000 -44.53125 0.00000 1.54400 1.54400 13.10000 0.98600 0.98300 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
2.180 2087.00000 19.8000 -44.53125 0.00000 1.54400 1.54400 13.10000 0.98600 0.98300 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
2.190 2087.00000 19.8000 -44.53125 0.00000 1.54400 1.54400 13.10000 0.98600 0.98300 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
2.200 2087.00000 19.8000 -44.53125 0.00000 1.54400 1.54400 13.10000 0.98600 0.98300 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
2.210 2087.00000 19.8000 -44.53125 0.00000 1.54400 1.54400 13.10000 0.98600 0.98300 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
2.220 2091.00000 20.0000 -44.53125 0.00000 1.56800 1.56800 13.20000 0.98600 0.98300 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
2.230 2091.00000 20.0000 -44.53125 0.00000 1.56800 1.56800 13.20000 0.98600 0.98300 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
2.240 2091.00000 20.0000 -44.53125 0.00000 1.56800 1.56800 13.20000 0.98600 0.98300 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
2.250 2091.00000 20.0000 -44.53125 0.00000 1.56800 1.56800 13.20000 0.98600 0.98300 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
2.260 2091.00000 20.0000 -44.53125 0.00000 1.56800 1.56800 13.20000 0.98600 0.98300 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
2.270 2159.00000 20.1000 -44.53125 0.00000 1.59700 1.59700 12.10000 0.95100 0.99900 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
2.280 2159.00000 20.1000 -44.53125 0.00000 1.59700 1.59700 12.10000 0.95100 0.99900 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
2.290 2159.00000 20.1000 -44.53125 0.00000 1.59700 1.59700 12.10000 0.95100 0.99900 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
2.300 2159.00000 20.1000 -44.53125 0.00000 1.59700 1.59700 12.10000 0.95100 0.99900 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
2.310 2159.00000 20.1000 -44.53125 0.00000 1.59700 1.59700 12.10000 0.95100 0.99900 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
2.320 2094.00000 20.1000 -44.53125 0.00000 1.55600 1.55600 13.20000 0.95100 0.99900 5.70000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
2.330 2094.00000 20.1000 -44.53125 0.00000 1.55600 1.55600 13.20000 0.95100 0.99900 5.70000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
2.340 2094.00000 20.1000 -44.53125 0.00000 1.55600 1.55600 13.20000 0.95100 0.99900 5.70000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
2.350 2094.00000 20.1000 -44.53125 0.00000 1.55600 1.55600 13.20000 0.95100 0.99900 5.70000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
2.360 2094.00000 20.1000 -44.53125 0.00000 1.55600 1.55600 13.20000 0.95100 0.99900 5.70000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
2.370 2077.00000 19.8000 -44.53125 0.00000 1.58500 1.58500 13.60000 0.95100 0.99900 5.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
2.380 2077.00000 19.8000 -44.53125 0.00000 1.58500 1.58500 13.60000 0.95100 0.99900 5.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
2.390 2077.00000 19.8000 -44.53125 0.00000 1.58500 1.58500 13.60000 0.95100 0.99900 5.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
2.400 2077.00000 19.8000 -44.53125 0.00000 1.58500 1.58500 13.60000 0.95100 0.99900 5.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
2.410 2077.00000 19.8000 -44.53125 0.00000 1.58500 1.58500 13.60000 0.95100 0.99900 5.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
2.420 2097.00000 20.0000 -44.53125 0.00000 1.57400 1.57400 13.10000 0.95100 0.99900 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
2.430 2097.00000 20.0000 -44.53125 0.00000 1.57400 1.57400 13.10000 0.95100 0.99900 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
2.440 2097.00000 20.0000 -44.53125 0.00000 1.57400 1.57400 13.10000 0.95100 0.99900 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
2.450 2097.00000 20.0000 -44.53125 0.00000 1.57400 1.57400 13.10000 0.95100 0.99900 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
2.460 2097.00000 20.0000 -44.53125 0.00000 1.57400 1.57400 13.10000 0.95100 0.99900 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
2.470 2152.00000 20.3000 -44.53125 0.00000 1.56800 1.56800 12.70000 0.43000 0.97300 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
2.480 2152.00000 20.3000 -44.53125 0.00000 1.56800 1.56800 12.70000 0.43000 0.97300 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
2.490 2152.00000 20.3000 -44.53125 0.00000 1.56800 1.56800 12.70000 0.43000 0.97300 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
2.500 2152.00000 20.3000 -44.53125 0.00000 1.56800 1.56800 12.70000 0.43000 0.97300 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
2.510 2152.00000 20.3000 -44.53125 0.00000 1.56800 1.56800 12.70000 0.43000 0.97300 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
2.520 2098.00000 20.1000 -44.53125 0.00000 1.56800 1.56800 13.50000 0.43000 0.97300 5.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
2.530 2098.00000 20.1000 -44.53125 0.00000 1.56800 1.56800 13.50000 0.43000 0.97300 5.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
2.540 2098.00000 20.1000 -44.53125 0.00000 1.56800 1.56800 13.50000 0.43000 0.97300 5.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
2.550 2098.00000 20.1000 -44.53125 0.00000 1.56800 1.56800 13.50000 0.43000 0.97300 5.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
2.560 2098.00000 20.1000 -44.53125 0.00000 1.56800 1.56800 13.50000 0.43000 0.97300 5.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
2.570 2086.00000 19.8000 -44.53125 0.00000 1.53300 1.53300 13.20000 0.43000 0.97300 5.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
2.580 2086.00000 19.8000 -44.53125 0.00000 1.53300 1.53300 13.20000 0.43000 0.97300 5.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
2.590 2086.00000 19.8000 -44.53125 0.00000 1.53300 1.53300 13.20000 0.43000 0.97300 5.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
2.600 2086.00000 19.8000 -44.53125 0.00000 1.53300 1.53300 13.20000 0.43000 0.97300 5.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
2.610 2086.00000 19.8000 -44.53125 0.00000 1.53300 1.53300 13.20000 0.43000 0.97300 5.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
2.620 2107.00000 20.1000 -44.53125 0.00000 1.55600 1.55600 13.30000 0.43000 0.97300 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
2.630 2107.00000 20.1000 -44.53125 0.00000 1.55600 1.55600 13.30000 0.43000 0.97300 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
2.640 2107.00000 20.1000 -44.53125 0.00000 1.55600 1.55600 13.30000 0.43000 0.97300 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
2.650 2107.00000 20.1000 -44.53125 0.00000 1.55600 1.55600 13.30000 0.43000 0.97300 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
2.660 2107.00000 20.1000 -44.53125 0.00000 1.55600 1.55600 13.30000 0.43000 0.97300 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
2.670 2098.00000 20.3000 -44.53125 0.00000 1.60900 1.60900 13.00000 0.34100 0.93500 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
2.680 2098.00000 20.3000 -44.53125 0.00000 1.60900 1.60900 13.00000 0.34100 0.93500 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
2.690 2098.00000 20.3000 -44.53125 0.00000 1.60900 1.60900 13.00000 0.34100 0.93500 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
2.700 2098.00000 20.3000 -44.53125 0.00000 1.60900 1.60900 13.00000 0.34100 0.93500 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
2.710 2098.00000 20.3000 -44.53125 0.00000 1.60900 1.60900 13.00000 0.34100 0.93500 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
2.720 2086.00000 20.0000 -44.53125 0.00000 1.55000 1.55000 13.40000 0.34100 0.93500 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
2.730 2086.00000 20.0000 -44.53125 0.00000 1.55000 1.55000 13.40000 0.34100 0.93500 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
2.740 2086.00000 20.0000 -44.53125 0.00000 1.55000 1.55000 13.40000 0.34100 0.93500 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
2.750 2086.00000 20.0000 -44.53125 0.00000 1.55000 1.55000 13.40000 0.34100 0.93500 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
2.760 2086.00000 20.0000 -44.53125 0.00000 1.55000 1.55000 13.40000 0.34100 0.93500 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
2.770 2150.00000 19.8000 -44.53125 0.00000 1.53900 1.53900 13.30000 0.34100 0.93500 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
2.780 2150.00000 19.8000 -44.53125 0.00000 1.53900 1.53900 13.30000 0.34100 0.93500 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
2.790 2150.00000 19.8000 -44.53125 0.00000 1.53900 1.53900 13.30000 0.34100 0.93500 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
2.800 2150.00000 19.8000 -44.53125 0.00000 1.53900 1.53900 13.30000 0.34100 0.93500 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
2.810 2150.00000 19.8000 -44.53125 0.00000 1.53900 1.53900 13.30000 0.34100 0.93500 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
2.820 2117.00000 20.3000 -44.53125 0.00000 1.56800 1.56800 13.50000 0.34100 0.93500 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
2.830 2117.00000 20.3000 -44.53125 0.00000 1.56800 1.56800 13.50000 0.34100 0.93500 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
2.840 2117.00000 20.3000 -44.53125 0.00000 1.56800 1.56800 13.50000 0.34100 0.93500 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
2.850 2117.00000 20.3000 -44.53125 0.00000 1.56800 1.56800 13.50000 0.34100 0.93500 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
2.860 2117.00000 20.3000 -44.53125 0.00000 1.56800 1.56800 13.50000 0.34100 0.93500 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
2.870 2094.00000 20.1000 -44.53125 0.00000 1.55000 1.55000 13.20000 0.40200 0.77800 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
2.880 2094.00000 20.1000 -44.53125 0.00000 1.55000 1.55000 13.20000 0.40200 0.77800 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
2.890 2094.00000 20.1000 -44.53125 0.00000 1.55000 1.55000 13.20000 0.40200 0.77800 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
2.900 2094.00000 20.1000 -44.53125 0.00000 1.55000 1.55000 13.20000 0.40200 0.77800 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
2.910 2094.00000 20.1000 -44.53125 0.00000 1.55000 1.55000 13.20000 0.40200 0.77800 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
2.920 2087.00000 19.8000 -44.53125 0.00000 1.53900 1.53900 13.40000 0.40200 0.77800 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
2.930 2087.00000 19.8000 -44.53125 0.00000 1.53900 1.53900 13.40000 0.40200 0.77800 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
2.940 2087.00000 19.8000 -44.53125 0.00000 1.53900 1.53900 13.40000 0.40200 0.77800 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
2.950 2087.00000 19.8000 -44.53125 0.00000 1.53900 1.53900 13.40000 0.40200 0.77800 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
2.960 2087.00000 19.8000 -44.53125 0.00000 1.53900 1.53900 13.40000 0.40200 0.77800 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
2.970 2151.00000 20.0000 -44.53125 0.00000 1.51500 1.51500 12.90000 0.40200 0.77800 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
2.980 2151.00000 20.0000 -44.53125 0.00000 1.51500 1.51500 12.90000 0.40200 0.77800 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
2.990 2151.00000 20.0000 -44.53125 0.00000 1.51500 1.51500 12.90000 0.40200 0.77800 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
3.000 2151.00000 20.0000 -44.53125 0.00000 1.51500 1.51500 12.90000 0.40200 0.77800 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
3.010 2151.00000 20.0000 -44.53125 0.00000 1.51500 1.51500 12.90000 0.40200 0.77800 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
3.020 2120.00000 20.1000 -44.53125 0.00000 1.57400 1.57400 13.40000 0.40200 0.77800 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
3.030 2120.00000 20.1000 -44.53125 0.00000 1.57400 1.57400 13.40000 0.40200 0.77800 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
3.040 2120.00000 20.1000 -44.53125 0.00000 1.57400 1.57400 13.40000 0.40200 0.77800 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
3.050 2120.00000 20.1000 -44.53125 0.00000 1.57400 1.57400 13.40000 0.40200 0.77800 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
3.060 2120.00000 20.1000 -44.53125 0.00000 1.57400 1.57400 13.40000 0.40200 0.77800 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
3.070 2099.00000 20.0000 -44.53125 0.00000 1.56800 1.56800 13.00000 0.99500 0.59000 5.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
3.080 2099.00000 20.0000 -44.53125 0.00000 1.56800 1.56800 13.00000 0.99500 0.59000 5.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
3.090 2099.00000 20.0000 -44.53125 0.00000 1.56800 1.56800 13.00000 0.99500 0.59000 5.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
3.100 2099.00000 20.0000 -44.53125 0.00000 1.56800 1.56800 13.00000 0.99500 0.59000 5.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
3.110 2099.00000 20.0000 -44.53125 0.00000 1.56800 1.56800 13.00000 0.99500 0.59000 5.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
3.120 2133.00000 19.8000 -44.53125 0.00000 1.53300 1.53300 13.00000 0.99500 0.59000 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
3.130 2133.00000 19.8000 -44.53125 0.00000 1.53300 1.53300 13.00000 0.99500 0.59000 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
3.140 2133.00000 19.8000 -44.53125 0.00000 1.53300 1.53300 13.00000 0.99500 0.59000 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
3.150 2133.00000 19.8000 -44.53125 0.00000 1.53300 1.53300 13.00000 0.99500 0.59000 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
3.160 2133.00000 19.8000 -44.53125 0.00000 1.53300 1.53300 13.00000 0.99500 0.59000 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
3.170 2107.00000 19.8000 -44.53125 0.00000 1.55000 1.55000 13.20000 0.99500 0.59000 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
3.180 2107.00000 19.8000 -44.53125 0.00000 1.55000 1.55000 13.20000 0.99500 0.59000 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
3.190 2107.00000 19.8000 -44.53125 0.00000 1.55000 1.55000 13.20000 0.99500 0.59000 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
3.200 2107.00000 19.8000 -44.53125 0.00000 1.55000 1.55000 13.20000 0.99500 0.59000 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
3.210 2107.00000 19.8000 -44.53125 0.00000 1.55000 1.55000 13.20000 0.99500 0.59000 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
3.220 2100.00000 20.3000 -44.53125 0.00000 1.57400 1.57400 13.10000 0.99500 0.59000 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
3.230 2100.00000 20.3000 -44.53125 0.00000 1.57400 1.57400 13.10000 0.99500 0.59000 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
3.240 2100.00000 20.3000 -44.53125 0.00000 1.57400 1.57400 13.10000 0.99500 0.59000 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
3.250 2100.00000 20.3000 -44.53125 0.00000 1.57400 1.57400 13.10000 0.99500 0.59000 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
3.260 2100.00000 20.3000 -44.53125 0.00000 1.57400 1.57400 13.10000 0.99500 0.59000 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
3.270 2129.00000 19.8000 -44.53125 0.00000 1.55600 1.55600 13.30000 1.04300 0.49100 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
3.280 2129.00000 19.8000 -44.53125 0.00000 1.55600 1.55600 13.30000 1.04300 0.49100 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
3.290 2129.00000 19.8000 -44.53125 0.00000 1.55600 1.55600 13.30000 1.04300 0.49100 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
3.300 2129.00000 19.8000 -44.53125 0.00000 1.55600 1.55600 13.30000 1.04300 0.49100 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
3.310 2129.00000 19.8000 -44.53125 0.00000 1.55600 1.55600 13.30000 1.04300 0.49100 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
3.320 2113.00000 19.8000 -44.53125 0.00000 1.57400 1.57400 13.30000 1.04300 0.49100 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
3.330 2113.00000 19.8000 -44.53125 0.00000 1.57400 1.57400 13.30000 1.04300 0.49100 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
3.340 2113.00000 19.8000 -44.53125 0.00000 1.57400 1.57400 13.30000 1.04300 0.49100 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
3.350 2113.00000 19.8000 -44.53125 0.00000 1.57400 1.57400 13.30000 1.04300 0.49100 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
3.360 2113.00000 19.8000 -44.53125 0.00000 1.57400 1.57400 13.30000 1.04300 0.49100 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
3.370 2127.00000 20.4000 -44.53125 0.00000 1.60300 1.60300 12.90000 1.04300 0.49100 5.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
3.380 2127.00000 20.4000 -44.53125 0.00000 1.60300 1.60300 12.90000 1.04300 0.49100 5.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
3.390 2127.00000 20.4000 -44.53125 0.00000 1.60300 1.60300 12.90000 1.04300 0.49100 5.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
3.400 2127.00000 20.4000 -44.53125 0.00000 1.60300 1.60300 12.90000 1.04300 0.49100 5.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
3.410 2127.00000 20.4000 -44.53125 0.00000 1.60300 1.60300 12.90000 1.04300 0.49100 5.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
3.420 2107.00000 20.4000 -44.53125 0.00000 1.61400 1.61400 12.90000 1.04300 0.49100 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
3.430 2107.00000 20.4000 -44.53125 0.00000 1.61400 1.61400 12.90000 1.04300 0.49100 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
3.440 2107.00000 20.4000 -44.53125 0.00000 1.61400 1.61400 12.90000 1.04300 0.49100 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
3.450 2107.00000 20.4000 -44.53125 0.00000 1.61400 1.61400 12.90000 1.04300 0.49100 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
3.460 2107.00000 20.4000 -44.53125 0.00000 1.61400 1.61400 12.90000 1.04300 0.49100 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
3.470 2132.00000 19.7000 -44.53125 0.00000 1.53900 1.53900 13.00000 0.99900 0.49100 5.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
3.480 2132.00000 19.7000 -44.53125 0.00000 1.53900 1.53900 13.00000 0.99900 0.49100 5.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
3.490 2132.00000 19.7000 -44.53125 0.00000 1.53900 1.53900 13.00000 0.99900 0.49100 5.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
3.500 2132.00000 19.7000 -44.53125 0.00000 1.53900 1.53900 13.00000 0.99900 0.49100 5.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
3.510 2132.00000 19.7000 -44.53125 0.00000 1.53900 1.53900 13.00000 0.99900 0.49100 5.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
3.520 2111.00000 19.7000 -44.53125 0.00000 1.53300 1.53300 13.50000 0.99900 0.49100 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
3.530 2111.00000 19.7000 -44.53125 0.00000 1.53300 1.53300 13.50000 0.99900 0.49100 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
3.540 2111.00000 19.7000 -44.53125 0.00000 1.53300 1.53300 13.50000 0.99900 0.49100 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
3.550 2111.00000 19.7000 -44.53125 0.00000 1.53300 1.53300 13.50000 0.99900 0.49100 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
3.560 2111.00000 19.7000 -44.53125 0.00000 1.53300 1.53300 13.50000 0.99900 0.49100 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
3.570 2132.00000 20.3000 -44.53125 0.00000 1.58500 1.58500 13.00000 0.99900 0.49100 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
3.580 2132.00000 20.3000 -44.53125 0.00000 1.58500 1.58500 13.00000 0.99900 0.49100 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
3.590 2132.00000 20.3000 -44.53125 0.00000 1.58500 1.58500 13.00000 0.99900 0.49100 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
3.600 2132.00000 20.3000 -44.53125 0.00000 1.58500 1.58500 13.00000 0.99900 0.49100 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
3.610 2132.00000 20.3000 -44.53125 0.00000 1.58500 1.58500 13.00000 0.99900 0.49100 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
3.620 2154.00000 20.0000 -44.53125 0.00000 1.57900 1.57900 13.40000 0.99900 0.49100 5.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
3.630 2154.00000 20.0000 -44.53125 0.00000 1.57900 1.57900 13.40000 0.99900 0.49100 5.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
3.640 2154.00000 20.0000 -44.53125 0.00000 1.57900 1.57900 13.40000 0.99900 0.49100 5.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
3.650 2154.00000 20.0000 -44.53125 0.00000 1.57900 1.57900 13.40000 0.99900 0.49100 5.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
3.660 2154.00000 20.0000 -44.53125 0.00000 1.57900 1.57900 13.40000 0.99900 0.49100 5.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
3.670 2081.00000 19.4000 -44.53125 0.00000 1.51500 1.51500 13.60000 0.54500 0.53600 5.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
3.680 2081.00000 19.4000 -44.53125 0.00000 1.51500 1.51500 13.60000 0.54500 0.53600 5.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
3.690 2081.00000 19.4000 -44.53125 0.00000 1.51500 1.51500 13.60000 0.54500 0.53600 5.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
3.700 2081.00000 19.4000 -44.53125 0.00000 1.51500 1.51500 13.60000 0.54500 0.53600 5.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
3.710 2081.00000 19.4000 -44.53125 0.00000 1.51500 1.51500 13.60000 0.54500 0.53600 5.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
3.720 2100.00000 19.4000 -44.53125 0.00000 1.50400 1.50400 12.90000 0.54500 0.53600 5.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
3.730 2100.00000 19.4000 -44.53125 0.00000 1.50400 1.50400 12.90000 0.54500 0.53600 5.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
3.740 2100.00000 19.4000 -44.53125 0.00000 1.50400 1.50400 12.90000 0.54500 0.53600 5.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
3.750 2100.00000 19.4000 -44.53125 0.00000 1.50400 1.50400 12.90000 0.54500 0.53600 5.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
3.760 2100.00000 19.4000 -44.53125 0.00000 1.50400 1.50400 12.90000 0.54500 0.53600 5.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
3.770 2149.00000 19.5000 -44.53125 0.00000 1.50900 1.50900 13.00000 0.54500 0.53600 4.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
3.780 2149.00000 19.5000 -44.53125 0.00000 1.50900 1.50900 13.00000 0.54500 0.53600 4.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
3.790 2149.00000 19.5000 -44.53125 0.00000 1.50900 1.50900 13.00000 0.54500 0.53600 4.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
3.800 2149.00000 19.5000 -44.53125 0.00000 1.50900 1.50900 13.00000 0.54500 0.53600 4.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
3.810 2149.00000 19.5000 -44.53125 0.00000 1.50900 1.50900 13.00000 0.54500 0.53600 4.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
3.820 2082.00000 19.5000 -44.53125 0.00000 1.52700 1.52700 13.20000 0.54500 0.53600 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
3.830 2082.00000 19.5000 -44.53125 0.00000 1.52700 1.52700 13.20000 0.54500 0.53600 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
3.840 2082.00000 19.5000 -44.53125 0.00000 1.52700 1.52700 13.20000 0.54500 0.53600 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
3.850 2082.00000 19.5000 -44.53125 0.00000 1.52700 1.52700 13.20000 0.54500 0.53600 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
3.860 2082.00000 19.5000 -44.53125 0.00000 1.52700 1.52700 13.20000 0.54500 0.53600 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
3.870 2090.00000 19.2000 -44.53125 0.00000 1.54400 1.54400 13.50000 0.75600 0.59600 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
3.880 2090.00000 19.2000 -44.53125 0.00000 1.54400 1.54400 13.50000 0.75600 0.59600 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
3.890 2090.00000 19.2000 -44.53125 0.00000 1.54400 1.54400 13.50000 0.75600 0.59600 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
3.900 2090.00000 19.2000 -44.53125 0.00000 1.54400 1.54400 13.50000 0.75600 0.59600 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
3.910 2090.00000 19.2000 -44.53125 0.00000 1.54400 1.54400 13.50000 0.75600 0.59600 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
3.920 2165.00000 19.2000 -44.53125 0.00000 1.48600 1.48600 13.00000 0.75600 0.59600 4.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
3.930 2165.00000 19.2000 -44.53125 0.00000 1.48600 1.48600 13.00000 0.75600 0.59600 4.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
3.940 2165.00000 19.2000 -44.53125 0.00000 1.48600 1.48600 13.00000 0.75600 0.59600 4.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
3.950 2165.00000 19.2000 -44.53125 0.00000 1.48600 1.48600 13.00000 0.75600 0.59600 4.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
3.960 2165.00000 19.2000 -44.53125 0.00000 1.48600 1.48600 13.00000 0.75600 0.59600 4.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
3.970 2117.00000 19.4000 -44.53125 0.00000 1.51500 1.51500 13.40000 0.75600 0.59600 4.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
3.980 2117.00000 19.4000 -44.53125 0.00000 1.51500 1.51500 13.40000 0.75600 0.59600 4.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
3.990 2117.00000 19.4000 -44.53125 0.00000 1.51500 1.51500 13.40000 0.75600 0.59600 4.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
4.000 2117.00000 19.4000 -44.53125 0.00000 1.51500 1.51500 13.40000 0.75600 0.59600 4.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
4.010 2117.00000 19.4000 -44.53125 0.00000 1.51500 1.51500 13.40000 0.75600 0.59600 4.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
4.020 2089.00000 19.4000 -44.53125 0.00000 1.51500 1.51500 12.60000 0.75600 0.59600 4.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
4.030 2089.00000 19.4000 -44.53125 0.00000 1.51500 1.51500 12.60000 0.75600 0.59600 4.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
4.040 2089.00000 19.4000 -44.53125 0.00000 1.51500 1.51500 12.60000 0.75600 0.59600 4.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
4.050 2089.00000 19.4000 -44.53125 0.00000 1.51500 1.51500 12.60000 0.75600 0.59600 4.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
4.060 2089.00000 19.4000 -44.53125 0.00000 1.51500 1.51500 12.60000 0.75600 0.59600 4.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
4.070 2089.00000 19.2000 -44.53125 0.00000 1.50900 1.50900 13.00000 1.06200 0.53300 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
4.080 2089.00000 19.2000 -44.53125 0.00000 1.50900 1.50900 13.00000 1.06200 0.53300 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
4.090 2089.00000 19.2000 -44.53125 0.00000 1.50900 1.50900 13.00000 1.06200 0.53300 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
4.100 2089.00000 19.2000 -44.53125 0.00000 1.50900 1.50900 13.00000 1.06200 0.53300 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
4.110 2089.00000 19.2000 -44.53125 0.00000 1.50900 1.50900 13.00000 1.06200 0.53300 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
4.120 2161.00000 19.4000 -44.53125 0.00000 1.50400 1.50400 13.20000 1.06200 0.53300 4.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
4.130 2161.00000 19.4000 -44.53125 0.00000 1.50400 1.50400 13.20000 1.06200 0.53300 4.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
4.140 2161.00000 19.4000 -44.53125 0.00000 1.50400 1.50400 13.20000 1.06200 0.53300 4.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
4.150 2161.00000 19.4000 -44.53125 0.00000 1.50400 1.50400 13.20000 1.06200 0.53300 4.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
4.160 2161.00000 19.4000 -44.53125 0.00000 1.50400 1.50400 13.20000 1.06200 0.53300 4.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
4.170 2120.00000 19.4000 -44.53125 0.00000 1.52700 1.52700 13.40000 1.06200 0.53300 4.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
4.180 2120.00000 19.4000 -44.53125 0.00000 1.52700 1.52700 13.40000 1.06200 0.53300 4.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
4.190 2120.00000 19.4000 -44.53125 0.00000 1.52700 1.52700 13.40000 1.06200 0.53300 4.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
4.200 2120.00000 19.4000 -44.53125 0.00000 1.52700 1.52700 13.40000 1.06200 0.53300 4.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
4.210 2120.00000 19.4000 -44.53125 0.00000 1.52700 1.52700 13.40000 1.06200 0.53300 4.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
4.220 2089.00000 19.2000 -44.53125 0.00000 1.49800 1.49800 12.50000 1.06200 0.53300 4.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
4.230 2089.00000 19.2000 -44.53125 0.00000 1.49800 1.49800 12.50000 1.06200 0.53300 4.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
4.240 2089.00000 19.2000 -44.53125 0.00000 1.49800 1.49800 12.50000 1.06200 0.53300 4.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
4.250 2089.00000 19.2000 -44.53125 0.00000 1.49800 1.49800 12.50000 1.06200 0.53300 4.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
4.260 2089.00000 19.2000 -44.53125 0.00000 1.49800 1.49800 12.50000 1.06200 0.53300 4.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
4.270 2082.00000 18.9000 -44.53125 0.00000 1.46900 1.46900 13.30000 1.09400 0.44000 5.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
4.280 2082.00000 18.9000 -44.53125 0.00000 1.46900 1.46900 13.30000 1.09400 0.44000 5.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
4.290 2082.00000 18.9000 -44.53125 0.00000 1.46900 1.46900 13.30000 1.09400 0.44000 5.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
4.300 2082.00000 18.9000 -44.53125 0.00000 1.46900 1.46900 13.30000 1.09400 0.44000 5.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
4.310 2082.00000 18.9000 -44.53125 0.00000 1.46900 1.46900 13.30000 1.09400 0.44000 5.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
4.320 2146.00000 18.9000 -44.53125 0.00000 1.48600 1.48600 13.20000 1.09400 0.44000 4.60000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
4.330 2146.00000 18.9000 -44.53125 0.00000 1.48600 1.48600 13.20000 1.09400 0.44000 4.60000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
4.340 2146.00000 18.9000 -44.53125 0.00000 1.48600 1.48600 13.20000 1.09400 0.44000 4.60000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
4.350 2146.00000 18.9000 -44.53125 0.00000 1.48600 1.48600 13.20000 1.09400 0.44000 4.60000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
4.360 2146.00000 18.9000 -44.53125 0.00000 1.48600 1.48600 13.20000 1.09400 0.44000 4.60000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
4.370 2092.00000 19.1000 -44.53125 0.00000 1.48600 1.48600 13.30000 1.09400 0.44000 4.70000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.4000 0.000 0.000 0.000 0.000
4.380 2092.00000 19.1000 -44.53125 0.00000 1.48600 1.48600 13.30000 1.09400 0.44000 4.70000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.4000 0.000 0.000 0.000 0.000
4.390 2092.00000 19.1000 -44.53125 0.00000 1.48600 1.48600 13.30000 1.09400 0.44000 4.70000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.4000 0.000 0.000 0.000 0.000
4.400 2092.00000 19.1000 -44.53125 0.00000 1.48600 1.48600 13.30000 1.09400 0.44000 4.70000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.4000 0.000 0.000 0.000 0.000
4.410 2092.00000 19.1000 -44.53125 0.00000 1.48600 1.48600 13.30000 1.09400 0.44000 4.70000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.4000 0.000 0.000 0.000 0.000
4.420 2123.00000 19.1000 -44.53125 0.00000 1.42800 1.42800 12.50000 1.09400 0.44000 5.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
4.430 2123.00000 19.1000 -44.53125 0.00000 1.42800 1.42800 12.50000 1.09400 0.44000 5.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
4.440 2123.00000 19.1000 -44.53125 0.00000 1.42800 1.42800 12.50000 1.09400 0.44000 5.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
4.450 2123.00000 19.1000 -44.53125 0.00000 1.42800 1.42800 12.50000 1.09400 0.44000 5.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
4.460 2123.00000 19.1000 -44.53125 0.00000 1.42800 1.42800 12.50000 1.09400 0.44000 5.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
4.470 2094.00000 18.7000 -44.53125 0.00000 1.45700 1.45700 13.20000 1.09100 0.52300 4.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
4.480 2094.00000 18.7000 -44.53125 0.00000 1.45700 1.45700 13.20000 1.09100 0.52300 4.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
4.490 2094.00000 18.7000 -44.53125 0.00000 1.45700 1.45700 13.20000 1.09100 0.52300 4.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
4.500 2094.00000 18.7000 -44.53125 0.00000 1.45700 1.45700 13.20000 1.09100 0.52300 4.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
4.510 2094.00000 18.7000 -44.53125 0.00000 1.45700 1.45700 13.20000 1.09100 0.52300 4.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
4.520 2107.00000 18.7000 -44.53125 0.00000 1.43400 1.43400 12.90000 1.09100 0.52300 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
4.530 2107.00000 18.7000 -44.53125 0.00000 1.43400 1.43400 12.90000 1.09100 0.52300 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
4.540 2107.00000 18.7000 -44.53125 0.00000 1.43400 1.43400 12.90000 1.09100 0.52300 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
4.550 2107.00000 18.7000 -44.53125 0.00000 1.43400 1.43400 12.90000 1.09100 0.52300 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
4.560 2107.00000 18.7000 -44.53125 0.00000 1.43400 1.43400 12.90000 1.09100 0.52300 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
4.570 2089.00000 18.7000 -44.53125 0.00000 1.45700 1.45700 13.00000 1.09100 0.52300 4.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
4.580 2089.00000 18.7000 -44.53125 0.00000 1.45700 1.45700 13.00000 1.09100 0.52300 4.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
4.590 2089.00000 18.7000 -44.53125 0.00000 1.45700 1.45700 13.00000 1.09100 0.52300 4.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
4.600 2089.00000 18.7000 -44.53125 0.00000 1.45700 1.45700 13.00000 1.09100 0.52300 4.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
4.610 2089.00000 18.7000 -44.53125 0.00000 1.45700 1.45700 13.00000 1.09100 0.52300 4.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
4.620 2118.00000 18.7000 -44.53125 0.00000 1.44500 1.44500 13.10000 1.09100 0.52300 4.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.1000 0.000 0.000 0.000 0.000
4.630 2118.00000 18.7000 -44.53125 0.00000 1.44500 1.44500 13.10000 1.09100 0.52300 4.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.1000 0.000 0.000 0.000 0.000
4.640 2118.00000 18.7000 -44.53125 0.00000 1.44500 1.44500 13.10000 1.09100 0.52300 4.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.1000 0.000 0.000 0.000 0.000
4.650 2118.00000 18.7000 -44.53125 0.00000 1.44500 1.44500 13.10000 1.09100 0.52300 4.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.1000 0.000 0.000 0.000 0.000
4.660 2118.00000 18.7000 -44.53125 0.00000 1.44500 1.44500 13.10000 1.09100 0.52300 4.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.1000 0.000 0.000 0.000 0.000
4.670 2085.00000 18.6000 -44.53125 0.00000 1.42200 1.42200 13.30000 1.05900 0.95400 4.60000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
4.680 2085.00000 18.6000 -44.53125 0.00000 1.42200 1.42200 13.30000 1.05900 0.95400 4.60000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
4.690 2085.00000 18.6000 -44.53125 0.00000 1.42200 1.42200 13.30000 1.05900 0.95400 4.60000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
4.700 2085.00000 18.6000 -44.53125 0.00000 1.42200 1.42200 13.30000 1.05900 0.95400 4.60000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
4.710 2085.00000 18.6000 -44.53125 0.00000 1.42200 1.42200 13.30000 1.05900 0.95400 4.60000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
4.720 2099.00000 18.7000 -44.53125 0.00000 1.42200 1.42200 13.60000 1.05900 0.95400 4.60000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
4.730 2099.00000 18.7000 -44.53125 0.00000 1.42200 1.42200 13.60000 1.05900 0.95400 4.60000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
4.740 2099.00000 18.7000 -44.53125 0.00000 1.42200 1.42200 13.60000 1.05900 0.95400 4.60000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
4.750 2099.00000 18.7000 -44.53125 0.00000 1.42200 1.42200 13.60000 1.05900 0.95400 4.60000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
4.760 2099.00000 18.7000 -44.53125 0.00000 1.42200 1.42200 13.60000 1.05900 0.95400 4.60000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
4.770 2093.00000 18.9000 -44.53125 0.00000 1.46300 1.46300 12.00000 1.05900 0.95400 4.60000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
4.780 2093.00000 18.9000 -44.53125 0.00000 1.46300 1.46300 12.00000 1.05900 0.95400 4.60000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
4.790 2093.00000 18.9000 -44.53125 0.00000 1.46300 1.46300 12.00000 1.05900 0.95400 4.60000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
4.800 2093.00000 18.9000 -44.53125 0.00000 1.46300 1.46300 12.00000 1.05900 0.95400 4.60000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
4.810 2093.00000 18.9000 -44.53125 0.00000 1.46300 1.46300 12.00000 1.05900 0.95400 4.60000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
4.820 2108.00000 18.6000 -44.53125 0.00000 1.42800 1.42800 13.40000 1.05900 0.95400 4.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.4000 0.000 0.000 0.000 0.000
4.830 2108.00000 18.6000 -44.53125 0.00000 1.42800 1.42800 13.40000 1.05900 0.95400 4.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.4000 0.000 0.000 0.000 0.000
4.840 2108.00000 18.6000 -44.53125 0.00000 1.42800 1.42800 13.40000 1.05900 0.95400 4.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.4000 0.000 0.000 0.000 0.000
4.850 2108.00000 18.6000 -44.53125 0.00000 1.42800 1.42800 13.40000 1.05900 0.95400 4.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.4000 0.000 0.000 0.000 0.000
4.860 2108.00000 18.6000 -44.53125 0.00000 1.42800 1.42800 13.40000 1.05900 0.95400 4.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.4000 0.000 0.000 0.000 0.000
4.870 2078.00000 18.6000 -44.53125 0.00000 1.43400 1.43400 13.20000 0.92800 1.02700 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.4000 0.000 0.000 0.000 0.000
4.880 2078.00000 18.6000 -44.53125 0.00000 1.43400 1.43400 13.20000 0.92800 1.02700 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.4000 0.000 0.000 0.000 0.000
4.890 2078.00000 18.6000 -44.53125 0.00000 1.43400 1.43400 13.20000 0.92800 1.02700 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.4000 0.000 0.000 0.000 0.000
4.900 2078.00000 18.6000 -44.53125 0.00000 1.43400 1.43400 13.20000 0.92800 1.02700 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.4000 0.000 0.000 0.000 0.000
4.910 2078.00000 18.6000 -44.53125 0.00000 1.43400 1.43400 13.20000 0.92800 1.02700 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.4000 0.000 0.000 0.000 0.000
4.920 2087.00000 18.6000 -44.53125 0.00000 1.45100 1.45100 13.20000 0.92800 1.02700 4.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
4.930 2087.00000 18.6000 -44.53125 0.00000 1.45100 1.45100 13.20000 0.92800 1.02700 4.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
4.940 2087.00000 18.6000 -44.53125 0.00000 1.45100 1.45100 13.20000 0.92800 1.02700 4.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
4.950 2087.00000 18.6000 -44.53125 0.00000 1.45100 1.45100 13.20000 0.92800 1.02700 4.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
4.960 2087.00000 18.6000 -44.53125 0.00000 1.45100 1.45100 13.20000 0.92800 1.02700 4.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
4.970 2132.00000 18.7000 -44.53125 0.00000 1.43400 1.43400 13.30000 0.92800 1.02700 4.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
4.980 2132.00000 18.7000 -44.53125 0.00000 1.43400 1.43400 13.30000 0.92800 1.02700 4.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
4.990 2132.00000 18.7000 -44.53125 0.00000 1.43400 1.43400 13.30000 0.92800 1.02700 4.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
5.000 2132.00000 18.7000 -44.53125 0.00000 1.43400 1.43400 13.30000 0.92800 1.02700 4.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
5.010 2132.00000 18.7000 -44.53125 0.00000 1.43400 1.43400 13.30000 0.92800 1.02700 4.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
5.020 2061.00000 18.6000 -44.53125 0.00000 1.38700 1.38700 13.40000 0.92800 1.02700 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
5.030 2061.00000 18.6000 -44.53125 0.00000 1.38700 1.38700 13.40000 0.92800 1.02700 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
5.040 2061.00000 18.6000 -44.53125 0.00000 1.38700 1.38700 13.40000 0.92800 1.02700 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
5.050 2061.00000 18.6000 -44.53125 0.00000 1.38700 1.38700 13.40000 0.92800 1.02700 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
5.060 2061.00000 18.6000 -44.53125 0.00000 1.38700 1.38700 13.40000 0.92800 1.02700 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
5.070 2070.00000 18.6000 -44.53125 0.00000 1.38100 1.38100 13.40000 0.43400 1.03700 4.70000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
5.080 2070.00000 18.6000 -44.53125 0.00000 1.38100 1.38100 13.40000 0.43400 1.03700 4.70000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
5.090 2070.00000 18.6000 -44.53125 0.00000 1.38100 1.38100 13.40000 0.43400 1.03700 4.70000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
5.100 2070.00000 18.6000 -44.53125 0.00000 1.38100 1.38100 13.40000 0.43400 1.03700 4.70000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
5.110 2070.00000 18.6000 -44.53125 0.00000 1.38100 1.38100 13.40000 0.43400 1.03700 4.70000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
5.120 2118.00000 18.6000 -44.53125 0.00000 1.40400 1.40400 13.20000 0.43400 1.03700 4.70000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
5.130 2118.00000 18.6000 -44.53125 0.00000 1.40400 1.40400 13.20000 0.43400 1.03700 4.70000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
5.140 2118.00000 18.6000 -44.53125 0.00000 1.40400 1.40400 13.20000 0.43400 1.03700 4.70000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
5.150 2118.00000 18.6000 -44.53125 0.00000 1.40400 1.40400 13.20000 0.43400 1.03700 4.70000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
5.160 2118.00000 18.6000 -44.53125 0.00000 1.40400 1.40400 13.20000 0.43400 1.03700 4.70000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
5.170 2071.00000 18.6000 -44.53125 0.00000 1.40400 1.40400 13.50000 0.43400 1.03700 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
5.180 2071.00000 18.6000 -44.53125 0.00000 1.40400 1.40400 13.50000 0.43400 1.03700 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
5.190 2071.00000 18.6000 -44.53125 0.00000 1.40400 1.40400 13.50000 0.43400 1.03700 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
5.200 2071.00000 18.6000 -44.53125 0.00000 1.40400 1.40400 13.50000 0.43400 1.03700 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
5.210 2071.00000 18.6000 -44.53125 0.00000 1.40400 1.40400 13.50000 0.43400 1.03700 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
5.220 2057.00000 18.6000 -44.53125 0.00000 1.44500 1.44500 13.00000 0.43400 1.03700 4.60000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
5.230 2057.00000 18.6000 -44.53125 0.00000 1.44500 1.44500 13.00000 0.43400 1.03700 4.60000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
5.240 2057.00000 18.6000 -44.53125 0.00000 1.44500 1.44500 13.00000 0.43400 1.03700 4.60000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
5.250 2057.00000 18.6000 -44.53125 0.00000 1.44500 1.44500 13.00000 0.43400 1.03700 4.60000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
5.260 2057.00000 18.6000 -44.53125 0.00000 1.44500 1.44500 13.00000 0.43400 1.03700 4.60000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
5.270 2102.00000 18.6000 -44.53125 0.00000 1.43400 1.43400 12.70000 0.33100 1.01500 4.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
5.280 2102.00000 18.6000 -44.53125 0.00000 1.43400 1.43400 12.70000 0.33100 1.01500 4.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
5.290 2102.00000 18.6000 -44.53125 0.00000 1.43400 1.43400 12.70000 0.33100 1.01500 4.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
5.300 2102.00000 18.6000 -44.53125 0.00000 1.43400 1.43400 12.70000 0.33100 1.01500 4.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
5.310 2102.00000 18.6000 -44.53125 0.00000 1.43400 1.43400 12.70000 0.33100 1.01500 4.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
5.320 2065.00000 18.6000 -44.53125 0.00000 1.41000 1.41000 13.20000 0.33100 1.01500 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
5.330 2065.00000 18.6000 -44.53125 0.00000 1.41000 1.41000 13.20000 0.33100 1.01500 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
5.340 2065.00000 18.6000 -44.53125 0.00000 1.41000 1.41000 13.20000 0.33100 1.01500 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
5.350 2065.00000 18.6000 -44.53125 0.00000 1.41000 1.41000 13.20000 0.33100 1.01500 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
5.360 2065.00000 18.6000 -44.53125 0.00000 1.41000 1.41000 13.20000 0.33100 1.01500 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
5.370 2064.00000 18.7000 -44.53125 0.00000 1.43900 1.43900 13.10000 0.33100 1.01500 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
5.380 2064.00000 18.7000 -44.53125 0.00000 1.43900 1.43900 13.10000 0.33100 1.01500 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
5.390 2064.00000 18.7000 -44.53125 0.00000 1.43900 1.43900 13.10000 0.33100 1.01500 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
5.400 2064.00000 18.7000 -44.53125 0.00000 1.43900 1.43900 13.10000 0.33100 1.01500 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
5.410 2064.00000 18.7000 -44.53125 0.00000 1.43900 1.43900 13.10000 0.33100 1.01500 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
5.420 2054.00000 19.1000 -44.53125 0.00000 1.44500 1.44500 13.30000 0.33100 1.01500 4.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
5.430 2054.00000 19.1000 -44.53125 0.00000 1.44500 1.44500 13.30000 0.33100 1.01500 4.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
5.440 2054.00000 19.1000 -44.53125 0.00000 1.44500 1.44500 13.30000 0.33100 1.01500 4.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
5.450 2054.00000 19.1000 -44.53125 0.00000 1.44500 1.44500 13.30000 0.33100 1.01500 4.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
5.460 2054.00000 19.1000 -44.53125 0.00000 1.44500 1.44500 13.30000 0.33100 1.01500 4.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
5.470 2090.00000 18.9000 -44.53125 0.00000 1.46300 1.46300 13.10000 0.35400 0.97300 4.60000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
5.480 2090.00000 18.9000 -44.53125 0.00000 1.46300 1.46300 13.10000 0.35400 0.97300 4.60000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
5.490 2090.00000 18.9000 -44.53125 0.00000 1.46300 1.46300 13.10000 0.35400 0.97300 4.60000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
5.500 2090.00000 18.9000 -44.53125 0.00000 1.46300 1.46300 13.10000 0.35400 0.97300 4.60000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
5.510 2090.00000 18.9000 -44.53125 0.00000 1.46300 1.46300 13.10000 0.35400 0.97300 4.60000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
5.520 2042.00000 18.9000 -44.53125 0.00000 1.45100 1.45100 13.60000 0.35400 0.97300 4.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
5.530 2042.00000 18.9000 -44.53125 0.00000 1.45100 1.45100 13.60000 0.35400 0.97300 4.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
5.540 2042.00000 18.9000 -44.53125 0.00000 1.45100 1.45100 13.60000 0.35400 0.97300 4.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
5.550 2042.00000 18.9000 -44.53125 0.00000 1.45100 1.45100 13.60000 0.35400 0.97300 4.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
5.560 2042.00000 18.9000 -44.53125 0.00000 1.45100 1.45100 13.60000 0.35400 0.97300 4.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
5.570 2062.00000 18.9000 -44.53125 0.00000 1.41000 1.41000 12.50000 0.35400 0.97300 4.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
5.580 2062.00000 18.9000 -44.53125 0.00000 1.41000 1.41000 12.50000 0.35400 0.97300 4.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
5.590 2062.00000 18.9000 -44.53125 0.00000 1.41000 1.41000 12.50000 0.35400 0.97300 4.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
5.600 2062.00000 18.9000 -44.53125 0.00000 1.41000 1.41000 12.50000 0.35400 0.97300 4.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
5.610 2062.00000 18.9000 -44.53125 0.00000 1.41000 1.41000 12.50000 0.35400 0.97300 4.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
5.620 2074.00000 18.7000 -44.53125 0.00000 1.45100 1.45100 13.10000 0.35400 0.97300 4.60000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
5.630 2074.00000 18.7000 -44.53125 0.00000 1.45100 1.45100 13.10000 0.35400 0.97300 4.60000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
5.640 2074.00000 18.7000 -44.53125 0.00000 1.45100 1.45100 13.10000 0.35400 0.97300 4.60000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
5.650 2074.00000 18.7000 -44.53125 0.00000 1.45100 1.45100 13.10000 0.35400 0.97300 4.60000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
5.660 2074.00000 18.7000 -44.53125 0.00000 1.45100 1.45100 13.10000 0.35400 0.97300 4.60000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
5.670 2094.00000 18.7000 -44.53125 0.00000 1.45700 1.45700 13.40000 0.67300 0.88400 4.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
5.680 2094.00000 18.7000 -44.53125 0.00000 1.45700 1.45700 13.40000 0.67300 0.88400 4.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
5.690 2094.00000 18.7000 -44.53125 0.00000 1.45700 1.45700 13.40000 0.67300 0.88400 4.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
5.700 2094.00000 18.7000 -44.53125 0.00000 1.45700 1.45700 13.40000 0.67300 0.88400 4.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
5.710 2094.00000 18.7000 -44.53125 0.00000 1.45700 1.45700 13.40000 0.67300 0.88400 4.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
5.720 2036.00000 18.7000 -44.53125 0.00000 1.45100 1.45100 13.60000 0.67300 0.88400 4.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
5.730 2036.00000 18.7000 -44.53125 0.00000 1.45100 1.45100 13.60000 0.67300 0.88400 4.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
5.740 2036.00000 18.7000 -44.53125 0.00000 1.45100 1.45100 13.60000 0.67300 0.88400 4.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
5.750 2036.00000 18.7000 -44.53125 0.00000 1.45100 1.45100 13.60000 0.67300 0.88400 4.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
5.760 2036.00000 18.7000 -44.53125 0.00000 1.45100 1.45100 13.60000 0.67300 0.88400 4.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
5.770 2036.00000 19.5000 -44.53125 0.00000 1.46300 1.46300 13.40000 0.67300 0.88400 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
5.780 2036.00000 19.5000 -44.53125 0.00000 1.46300 1.46300 13.40000 0.67300 0.88400 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
5.790 2036.00000 19.5000 -44.53125 0.00000 1.46300 1.46300 13.40000 0.67300 0.88400 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
5.800 2036.00000 19.5000 -44.53125 0.00000 1.46300 1.46300 13.40000 0.67300 0.88400 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
5.810 2036.00000 19.5000 -44.53125 0.00000 1.46300 1.46300 13.40000 0.67300 0.88400 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
5.820 2061.00000 20.1000 -44.53125 0.00000 1.53900 1.53900 13.10000 0.67300 0.88400 5.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
5.830 2061.00000 20.1000 -44.53125 0.00000 1.53900 1.53900 13.10000 0.67300 0.88400 5.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
5.840 2061.00000 20.1000 -44.53125 0.00000 1.53900 1.53900 13.10000 0.67300 0.88400 5.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
5.850 2061.00000 20.1000 -44.53125 0.00000 1.53900 1.53900 13.10000 0.67300 0.88400 5.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
5.860 2061.00000 20.1000 -44.53125 0.00000 1.53900 1.53900 13.10000 0.67300 0.88400 5.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
5.870 2041.00000 20.1000 -44.53125 0.00000 1.56800 1.56800 13.60000 1.06900 0.70500 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
5.880 2041.00000 20.1000 -44.53125 0.00000 1.56800 1.56800 13.60000 1.06900 0.70500 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
5.890 2041.00000 20.1000 -44.53125 0.00000 1.56800 1.56800 13.60000 1.06900 0.70500 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
5.900 2041.00000 20.1000 -44.53125 0.00000 1.56800 1.56800 13.60000 1.06900 0.70500 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
5.910 2041.00000 20.1000 -44.53125 0.00000 1.56800 1.56800 13.60000 1.06900 0.70500 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
5.920 2026.00000 20.1000 -44.53125 0.00000 1.54400 1.54400 13.10000 1.06900 0.70500 5.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
5.930 2026.00000 20.1000 -44.53125 0.00000 1.54400 1.54400 13.10000 1.06900 0.70500 5.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
5.940 2026.00000 20.1000 -44.53125 0.00000 1.54400 1.54400 13.10000 1.06900 0.70500 5.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
5.950 2026.00000 20.1000 -44.53125 0.00000 1.54400 1.54400 13.10000 1.06900 0.70500 5.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
5.960 2026.00000 20.1000 -44.53125 0.00000 1.54400 1.54400 13.10000 1.06900 0.70500 5.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
5.970 2092.00000 20.4000 -44.53125 0.00000 1.55600 1.55600 12.40000 1.06900 0.70500 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
5.980 2092.00000 20.4000 -44.53125 0.00000 1.55600 1.55600 12.40000 1.06900 0.70500 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
5.990 2092.00000 20.4000 -44.53125 0.00000 1.55600 1.55600 12.40000 1.06900 0.70500 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
6.000 2092.00000 20.4000 -44.53125 0.00000 1.55600 1.55600 12.40000 1.06900 0.70500 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
6.010 2092.00000 20.4000 -44.53125 0.00000 1.55600 1.55600 12.40000 1.06900 0.70500 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
6.020 2077.00000 20.4000 -44.53125 0.00000 1.57400 1.57400 13.30000 1.06900 0.70500 5.70000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
6.030 2077.00000 20.4000 -44.53125 0.00000 1.57400 1.57400 13.30000 1.06900 0.70500 5.70000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
6.040 2077.00000 20.4000 -44.53125 0.00000 1.57400 1.57400 13.30000 1.06900 0.70500 5.70000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
6.050 2077.00000 20.4000 -44.53125 0.00000 1.57400 1.57400 13.30000 1.06900 0.70500 5.70000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
6.060 2077.00000 20.4000 -44.53125 0.00000 1.57400 1.57400 13.30000 1.06900 0.70500 5.70000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
6.070 2064.00000 20.4000 -44.53125 0.00000 1.57900 1.57900 13.50000 0.93800 0.64100 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.6000 0.000 0.000 0.000 0.000
6.080 2064.00000 20.4000 -44.53125 0.00000 1.57900 1.57900 13.50000 0.93800 0.64100 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.6000 0.000 0.000 0.000 0.000
6.090 2064.00000 20.4000 -44.53125 0.00000 1.57900 1.57900 13.50000 0.93800 0.64100 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.6000 0.000 0.000 0.000 0.000
6.100 2064.00000 20.4000 -44.53125 0.00000 1.57900 1.57900 13.50000 0.93800 0.64100 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.6000 0.000 0.000 0.000 0.000
6.110 2064.00000 20.4000 -44.53125 0.00000 1.57900 1.57900 13.50000 0.93800 0.64100 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.6000 0.000 0.000 0.000 0.000
6.120 2030.00000 20.4000 -44.53125 0.00000 1.58500 1.58500 12.50000 0.93800 0.64100 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
6.130 2030.00000 20.4000 -44.53125 0.00000 1.58500 1.58500 12.50000 0.93800 0.64100 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
6.140 2030.00000 20.4000 -44.53125 0.00000 1.58500 1.58500 12.50000 0.93800 0.64100 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
6.150 2030.00000 20.4000 -44.53125 0.00000 1.58500 1.58500 12.50000 0.93800 0.64100 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
6.160 2030.00000 20.4000 -44.53125 0.00000 1.58500 1.58500 12.50000 0.93800 0.64100 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
6.170 2070.00000 20.4000 -44.53125 0.00000 1.58500 1.58500 13.30000 0.93800 0.64100 5.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
6.180 2070.00000 20.4000 -44.53125 0.00000 1.58500 1.58500 13.30000 0.93800 0.64100 5.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
6.190 2070.00000 20.4000 -44.53125 0.00000 1.58500 1.58500 13.30000 0.93800 0.64100 5.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
6.200 2070.00000 20.4000 -44.53125 0.00000 1.58500 1.58500 13.30000 0.93800 0.64100 5.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
6.210 2070.00000 20.4000 -44.53125 0.00000 1.58500 1.58500 13.30000 0.93800 0.64100 5.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
6.220 2052.00000 20.9000 -44.53125 0.00000 1.60300 1.60300 13.10000 0.93800 0.64100 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
6.230 2052.00000 20.9000 -44.53125 0.00000 1.60300 1.60300 13.10000 0.93800 0.64100 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
6.240 2052.00000 20.9000 -44.53125 0.00000 1.60300 1.60300 13.10000 0.93800 0.64100 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
6.250 2052.00000 20.9000 -44.53125 0.00000 1.60300 1.60300 13.10000 0.93800 0.64100 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
6.260 2052.00000 20.9000 -44.53125 0.00000 1.60300 1.60300 13.10000 0.93800 0.64100 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
6.270 2059.00000 20.9000 -44.53125 0.00000 1.58500 1.58500 12.60000 0.31900 0.80400 5.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
6.280 2059.00000 20.9000 -44.53125 0.00000 1.58500 1.58500 12.60000 0.31900 0.80400 5.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
6.290 2059.00000 20.9000 -44.53125 0.00000 1.58500 1.58500 12.60000 0.31900 0.80400 5.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
6.300 2059.00000 20.9000 -44.53125 0.00000 1.58500 1.58500 12.60000 0.31900 0.80400 5.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
6.310 2059.00000 20.9000 -44.53125 0.00000 1.58500 1.58500 12.60000 0.31900 0.80400 5.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
6.320 2080.00000 20.7000 -44.53125 0.00000 1.59100 1.59100 12.90000 0.31900 0.80400 5.50000 1.00000 4.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
6.330 2080.00000 20.7000 -44.53125 0.00000 1.59100 1.59100 12.90000 0.31900 0.80400 5.50000 1.00000 4.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
6.340 2080.00000 20.7000 -44.53125 0.00000 1.59100 1.59100 12.90000 0.31900 0.80400 5.50000 1.00000 4.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
6.350 2080.00000 20.7000 -44.53125 0.00000 1.59100 1.59100 12.90000 0.31900 0.80400 5.50000 1.00000 4.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
6.360 2080.00000 20.7000 -44.53125 0.00000 1.59100 1.59100 12.90000 0.31900 0.80400 5.50000 1.00000 4.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
6.370 2023.00000 21.0000 -44.53125 0.00000 1.56200 1.56200 12.90000 0.31900 0.80400 5.70000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
6.380 2023.00000 21.0000 -44.53125 0.00000 1.56200 1.56200 12.90000 0.31900 0.80400 5.70000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
6.390 2023.00000 21.0000 -44.53125 0.00000 1.56200 1.56200 12.90000 0.31900 0.80400 5.70000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
6.400 2023.00000 21.0000 -44.53125 0.00000 1.56200 1.56200 12.90000 0.31900 0.80400 5.70000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
6.410 2023.00000 21.0000 -44.53125 0.00000 1.56200 1.56200 12.90000 0.31900 0.80400 5.70000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
6.420 2046.00000 21.3000 -44.53125 0.00000 1.62600 1.62600 13.30000 0.31900 0.80400 5.90000 1.00000 3.00000 3.00000 3.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
6.430 2046.00000 21.3000 -44.53125 0.00000 1.62600 1.62600 13.30000 0.31900 0.80400 5.90000 1.00000 3.00000 3.00000 3.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
6.440 2046.00000 21.3000 -44.53125 0.00000 1.62600 1.62600 13.30000 0.31900 0.80400 5.90000 1.00000 3.00000 3.00000 3.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
6.450 2046.00000 21.3000 -44.53125 0.00000 1.62600 1.62600 13.30000 0.31900 0.80400 5.90000 1.00000 3.00000 3.00000 3.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
6.460 2046.00000 21.3000 -44.53125 0.00000 1.62600 1.62600 13.30000 0.31900 0.80400 5.90000 1.00000 3.00000 3.00000 3.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
6.470 2065.00000 21.3000 -44.53125 0.00000 1.64900 1.64900 13.00000 0.30900 0.93200 5.70000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
6.480 2065.00000 21.3000 -44.53125 0.00000 1.64900 1.64900 13.00000 0.30900 0.93200 5.70000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
6.490 2065.00000 21.3000 -44.53125 0.00000 1.64900 1.64900 13.00000 0.30900 0.93200 5.70000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
6.500 2065.00000 21.3000 -44.53125 0.00000 1.64900 1.64900 13.00000 0.30900 0.93200 5.70000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
6.510 2065.00000 21.3000 -44.53125 0.00000 1.64900 1.64900 13.00000 0.30900 0.93200 5.70000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
6.520 2088.00000 21.2000 -44.53125 0.00000 1.64400 1.64400 13.20000 0.30900 0.93200 6.10000 1.00000 3.00000 4.00000 3.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
6.530 2088.00000 21.2000 -44.53125 0.00000 1.64400 1.64400 13.20000 0.30900 0.93200 6.10000 1.00000 3.00000 4.00000 3.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
6.540 2088.00000 21.2000 -44.53125 0.00000 1.64400 1.64400 13.20000 0.30900 0.93200 6.10000 1.00000 3.00000 4.00000 3.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
6.550 2088.00000 21.2000 -44.53125 0.00000 1.64400 1.64400 13.20000 0.30900 0.93200 6.10000 1.00000 3.00000 4.00000 3.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
6.560 2088.00000 21.2000 -44.53125 0.00000 1.64400 1.64400 13.20000 0.30900 0.93200 6.10000 1.00000 3.00000 4.00000 3.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
6.570 2031.00000 21.2000 -44.53125 0.00000 1.64400 1.64400 13.40000 0.30900 0.93200 6.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
6.580 2031.00000 21.2000 -44.53125 0.00000 1.64400 1.64400 13.40000 0.30900 0.93200 6.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
6.590 2031.00000 21.2000 -44.53125 0.00000 1.64400 1.64400 13.40000 0.30900 0.93200 6.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
6.600 2031.00000 21.2000 -44.53125 0.00000 1.64400 1.64400 13.40000 0.30900 0.93200 6.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
6.610 2031.00000 21.2000 -44.53125 0.00000 1.64400 1.64400 13.40000 0.30900 0.93200 6.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
6.620 2047.00000 21.5000 -44.53125 0.00000 1.60900 1.60900 12.50000 0.30900 0.93200 5.60000 1.00000 4.00000 3.00000 4.00000 3.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
6.630 2047.00000 21.5000 -44.53125 0.00000 1.60900 1.60900 12.50000 0.30900 0.93200 5.60000 1.00000 4.00000 3.00000 4.00000 3.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
6.640 2047.00000 21.5000 -44.53125 0.00000 1.60900 1.60900 12.50000 0.30900 0.93200 5.60000 1.00000 4.00000 3.00000 4.00000 3.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
6.650 2047.00000 21.5000 -44.53125 0.00000 1.60900 1.60900 12.50000 0.30900 0.93200 5.60000 1.00000 4.00000 3.00000 4.00000 3.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
6.660 2047.00000 21.5000 -44.53125 0.00000 1.60900 1.60900 12.50000 0.30900 0.93200 5.60000 1.00000 4.00000 3.00000 4.00000 3.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
6.670 2044.00000 21.5000 -44.53125 0.00000 1.63800 1.63800 11.90000 0.32500 0.51700 6.00000 1.00000 4.00000 4.00000 3.00000 4.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
6.680 2044.00000 21.5000 -44.53125 0.00000 1.63800 1.63800 11.90000 0.32500 0.51700 6.00000 1.00000 4.00000 4.00000 3.00000 4.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
6.690 2044.00000 21.5000 -44.53125 0.00000 1.63800 1.63800 11.90000 0.32500 0.51700 6.00000 1.00000 4.00000 4.00000 3.00000 4.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
6.700 2044.00000 21.5000 -44.53125 0.00000 1.63800 1.63800 11.90000 0.32500 0.51700 6.00000 1.00000 4.00000 4.00000 3.00000 4.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
6.710 2044.00000 21.5000 -44.53125 0.00000 1.63800 1.63800 11.90000 0.32500 0.51700 6.00000 1.00000 4.00000 4.00000 3.00000 4.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
6.720 2028.00000 21.0000 -44.53125 0.00000 1.62600 1.62600 13.40000 0.32500 0.51700 6.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
6.730 2028.00000 21.0000 -44.53125 0.00000 1.62600 1.62600 13.40000 0.32500 0.51700 6.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
6.740 2028.00000 21.0000 -44.53125 0.00000 1.62600 1.62600 13.40000 0.32500 0.51700 6.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
6.750 2028.00000 21.0000 -44.53125 0.00000 1.62600 1.62600 13.40000 0.32500 0.51700 6.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
6.760 2028.00000 21.0000 -44.53125 0.00000 1.62600 1.62600 13.40000 0.32500 0.51700 6.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
6.770 2041.00000 21.3000 -44.53125 0.00000 1.64400 1.64400 13.00000 0.32500 0.51700 5.90000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
6.780 2041.00000 21.3000 -44.53125 0.00000 1.64400 1.64400 13.00000 0.32500 0.51700 5.90000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
6.790 2041.00000 21.3000 -44.53125 0.00000 1.64400 1.64400 13.00000 0.32500 0.51700 5.90000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
6.800 2041.00000 21.3000 -44.53125 0.00000 1.64400 1.64400 13.00000 0.32500 0.51700 5.90000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
6.810 2041.00000 21.3000 -44.53125 0.00000 1.64400 1.64400 13.00000 0.32500 0.51700 5.90000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
6.820 2111.00000 21.8000 -44.53125 0.00000 1.64900 1.64900 12.10000 0.32500 0.51700 6.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.8000 0.000 0.000 0.000 0.000
6.830 2111.00000 21.8000 -44.53125 0.00000 1.64900 1.64900 12.10000 0.32500 0.51700 6.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.8000 0.000 0.000 0.000 0.000
6.840 2111.00000 21.8000 -44.53125 0.00000 1.64900 1.64900 12.10000 0.32500 0.51700 6.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.8000 0.000 0.000 0.000 0.000
6.850 2111.00000 21.8000 -44.53125 0.00000 1.64900 1.64900 12.10000 0.32500 0.51700 6.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.8000 0.000 0.000 0.000 0.000
6.860 2111.00000 21.8000 -44.53125 0.00000 1.64900 1.64900 12.10000 0.32500 0.51700 6.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.8000 0.000 0.000 0.000 0.000
6.870 2049.00000 21.5000 -44.53125 0.00000 1.62000 1.62000 13.10000 0.32800 0.34100 5.90000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
6.880 2049.00000 21.5000 -44.53125 0.00000 1.62000 1.62000 13.10000 0.32800 0.34100 5.90000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
6.890 2049.00000 21.5000 -44.53125 0.00000 1.62000 1.62000 13.10000 0.32800 0.34100 5.90000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
6.900 2049.00000 21.5000 -44.53125 0.00000 1.62000 1.62000 13.10000 0.32800 0.34100 5.90000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
6.910 2049.00000 21.5000 -44.53125 0.00000 1.62000 1.62000 13.10000 0.32800 0.34100 5.90000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
6.920 2020.00000 21.3000 -44.53125 0.00000 1.57900 1.57900 13.40000 0.32800 0.34100 6.00000 1.00000 3.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
6.930 2020.00000 21.3000 -44.53125 0.00000 1.57900 1.57900 13.40000 0.32800 0.34100 6.00000 1.00000 3.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
6.940 2020.00000 21.3000 -44.53125 0.00000 1.57900 1.57900 13.40000 0.32800 0.34100 6.00000 1.00000 3.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
6.950 2020.00000 21.3000 -44.53125 0.00000 1.57900 1.57900 13.40000 0.32800 0.34100 6.00000 1.00000 3.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
6.960 2020.00000 21.3000 -44.53125 0.00000 1.57900 1.57900 13.40000 0.32800 0.34100 6.00000 1.00000 3.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
6.970 2035.00000 21.7000 -44.53125 0.00000 1.63800 1.63800 13.10000 0.32800 0.34100 6.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
6.980 2035.00000 21.7000 -44.53125 0.00000 1.63800 1.63800 13.10000 0.32800 0.34100 6.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
6.990 2035.00000 21.7000 -44.53125 0.00000 1.63800 1.63800 13.10000 0.32800 0.34100 6.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
7.000 2035.00000 21.7000 -44.53125 0.00000 1.63800 1.63800 13.10000 0.32800 0.34100 6.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
7.010 2035.00000 21.7000 -44.53125 0.00000 1.63800 1.63800 13.10000 0.32800 0.34100 6.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
7.020 2105.00000 22.0000 -44.53125 0.00000 1.72500 1.72500 13.20000 0.32800 0.34100 6.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
7.030 2105.00000 22.0000 -44.53125 0.00000 1.72500 1.72500 13.20000 0.32800 0.34100 6.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
7.040 2105.00000 22.0000 -44.53125 0.00000 1.72500 1.72500 13.20000 0.32800 0.34100 6.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
7.050 2105.00000 22.0000 -44.53125 0.00000 1.72500 1.72500 13.20000 0.32800 0.34100 6.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
7.060 2105.00000 22.0000 -44.53125 0.00000 1.72500 1.72500 13.20000 0.32800 0.34100 6.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
7.070 2053.00000 22.0000 -44.53125 0.00000 1.68400 1.68400 13.50000 0.33500 0.33500 6.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
7.080 2053.00000 22.0000 -44.53125 0.00000 1.68400 1.68400 13.50000 0.33500 0.33500 6.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
7.090 2053.00000 22.0000 -44.53125 0.00000 1.68400 1.68400 13.50000 0.33500 0.33500 6.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
7.100 2053.00000 22.0000 -44.53125 0.00000 1.68400 1.68400 13.50000 0.33500 0.33500 6.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
7.110 2053.00000 22.0000 -44.53125 0.00000 1.68400 1.68400 13.50000 0.33500 0.33500 6.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
7.120 2022.00000 22.0000 -44.53125 0.00000 1.66100 1.66100 13.30000 0.33500 0.33500 6.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
7.130 2022.00000 22.0000 -44.53125 0.00000 1.66100 1.66100 13.30000 0.33500 0.33500 6.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
7.140 2022.00000 22.0000 -44.53125 0.00000 1.66100 1.66100 13.30000 0.33500 0.33500 6.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
7.150 2022.00000 22.0000 -44.53125 0.00000 1.66100 1.66100 13.30000 0.33500 0.33500 6.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
7.160 2022.00000 22.0000 -44.53125 0.00000 1.66100 1.66100 13.30000 0.33500 0.33500 6.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
7.170 2077.00000 22.0000 -44.53125 0.00000 1.73100 1.73100 12.90000 0.33500 0.33500 6.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
7.180 2077.00000 22.0000 -44.53125 0.00000 1.73100 1.73100 12.90000 0.33500 0.33500 6.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
7.190 2077.00000 22.0000 -44.53125 0.00000 1.73100 1.73100 12.90000 0.33500 0.33500 6.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
7.200 2077.00000 22.0000 -44.53125 0.00000 1.73100 1.73100 12.90000 0.33500 0.33500 6.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
7.210 2077.00000 22.0000 -44.53125 0.00000 1.73100 1.73100 12.90000 0.33500 0.33500 6.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
7.220 2072.00000 22.1000 -44.53125 0.00000 1.70200 1.70200 13.40000 0.33500 0.33500 6.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
7.230 2072.00000 22.1000 -44.53125 0.00000 1.70200 1.70200 13.40000 0.33500 0.33500 6.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
7.240 2072.00000 22.1000 -44.53125 0.00000 1.70200 1.70200 13.40000 0.33500 0.33500 6.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
7.250 2072.00000 22.1000 -44.53125 0.00000 1.70200 1.70200 13.40000 0.33500 0.33500 6.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
7.260 2072.00000 22.1000 -44.53125 0.00000 1.70200 1.70200 13.40000 0.33500 0.33500 6.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
7.270 2067.00000 21.8000 -44.53125 0.00000 1.67800 1.67800 13.50000 0.40500 0.34100 6.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
7.280 2067.00000 21.8000 -44.53125 0.00000 1.67800 1.67800 13.50000 0.40500 0.34100 6.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
7.290 2067.00000 21.8000 -44.53125 0.00000 1.67800 1.67800 13.50000 0.40500 0.34100 6.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
7.300 2067.00000 21.8000 -44.53125 0.00000 1.67800 1.67800 13.50000 0.40500 0.34100 6.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
7.310 2067.00000 21.8000 -44.53125 0.00000 1.67800 1.67800 13.50000 0.40500 0.34100 6.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
7.320 2034.00000 21.7000 -44.53125 0.00000 1.67300 1.67300 12.90000 0.40500 0.34100 6.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
7.330 2034.00000 21.7000 -44.53125 0.00000 1.67300 1.67300 12.90000 0.40500 0.34100 6.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
7.340 2034.00000 21.7000 -44.53125 0.00000 1.67300 1.67300 12.90000 0.40500 0.34100 6.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
7.350 2034.00000 21.7000 -44.53125 0.00000 1.67300 1.67300 12.90000 0.40500 0.34100 6.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
7.360 2034.00000 21.7000 -44.53125 0.00000 1.67300 1.67300 12.90000 0.40500 0.34100 6.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
7.370 2075.00000 22.1000 -44.53125 0.00000 1.69600 1.69600 12.50000 0.40500 0.34100 6.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
7.380 2075.00000 22.1000 -44.53125 0.00000 1.69600 1.69600 12.50000 0.40500 0.34100 6.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
7.390 2075.00000 22.1000 -44.53125 0.00000 1.69600 1.69600 12.50000 0.40500 0.34100 6.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
7.400 2075.00000 22.1000 -44.53125 0.00000 1.69600 1.69600 12.50000 0.40500 0.34100 6.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
7.410 2075.00000 22.1000 -44.53125 0.00000 1.69600 1.69600 12.50000 0.40500 0.34100 6.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
7.420 2057.00000 22.6000 -44.53125 0.00000 1.73100 1.73100 13.50000 0.40500 0.34100 6.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
7.430 2057.00000 22.6000 -44.53125 0.00000 1.73100 1.73100 13.50000 0.40500 0.34100 6.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
7.440 2057.00000 22.6000 -44.53125 0.00000 1.73100 1.73100 13.50000 0.40500 0.34100 6.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
7.450 2057.00000 22.6000 -44.53125 0.00000 1.73100 1.73100 13.50000 0.40500 0.34100 6.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
7.460 2057.00000 22.6000 -44.53125 0.00000 1.73100 1.73100 13.50000 0.40500 0.34100 6.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
7.470 2057.00000 22.4000 -44.53125 0.00000 1.70200 1.70200 12.90000 1.02100 0.34700 6.40000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
7.480 2057.00000 22.4000 -44.53125 0.00000 1.70200 1.70200 12.90000 1.02100 0.34700 6.40000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
7.490 2057.00000 22.4000 -44.53125 0.00000 1.70200 1.70200 12.90000 1.02100 0.34700 6.40000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
7.500 2057.00000 22.4000 -44.53125 0.00000 1.70200 1.70200 12.90000 1.02100 0.34700 6.40000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
7.510 2057.00000 22.4000 -44.53125 0.00000 1.70200 1.70200 12.90000 1.02100 0.34700 6.40000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
7.520 2032.00000 22.4000 -44.53125 0.00000 1.71300 1.71300 13.00000 1.02100 0.34700 6.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
7.530 2032.00000 22.4000 -44.53125 0.00000 1.71300 1.71300 13.00000 1.02100 0.34700 6.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
7.540 2032.00000 22.4000 -44.53125 0.00000 1.71300 1.71300 13.00000 1.02100 0.34700 6.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
7.550 2032.00000 22.4000 -44.53125 0.00000 1.71300 1.71300 13.00000 1.02100 0.34700 6.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
7.560 2032.00000 22.4000 -44.53125 0.00000 1.71300 1.71300 13.00000 1.02100 0.34700 6.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
7.570 2066.00000 22.1000 -44.53125 0.00000 1.72500 1.72500 13.40000 1.02100 0.34700 6.40000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
7.580 2066.00000 22.1000 -44.53125 0.00000 1.72500 1.72500 13.40000 1.02100 0.34700 6.40000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
7.590 2066.00000 22.1000 -44.53125 0.00000 1.72500 1.72500 13.40000 1.02100 0.34700 6.40000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
7.600 2066.00000 22.1000 -44.53125 0.00000 1.72500 1.72500 13.40000 1.02100 0.34700 6.40000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
7.610 2066.00000 22.1000 -44.53125 0.00000 1.72500 1.72500 13.40000 1.02100 0.34700 6.40000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
7.620 2061.00000 22.4000 -44.53125 0.00000 1.72500 1.72500 12.80000 1.02100 0.34700 6.40000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
7.630 2061.00000 22.4000 -44.53125 0.00000 1.72500 1.72500 12.80000 1.02100 0.34700 6.40000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
7.640 2061.00000 22.4000 -44.53125 0.00000 1.72500 1.72500 12.80000 1.02100 0.34700 6.40000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
7.650 2061.00000 22.4000 -44.53125 0.00000 1.72500 1.72500 12.80000 1.02100 0.34700 6.40000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
7.660 2061.00000 22.4000 -44.53125 0.00000 1.72500 1.72500 12.80000 1.02100 0.34700 6.40000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
7.670 2082.00000 22.3000 -44.53125 0.00000 1.73700 1.73700 13.20000 1.02700 0.37000 6.90000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
7.680 2082.00000 22.3000 -44.53125 0.00000 1.73700 1.73700 13.20000 1.02700 0.37000 6.90000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
7.690 2082.00000 22.3000 -44.53125 0.00000 1.73700 1.73700 13.20000 1.02700 0.37000 6.90000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
7.700 2082.00000 22.3000 -44.53125 0.00000 1.73700 1.73700 13.20000 1.02700 0.37000 6.90000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
7.710 2082.00000 22.3000 -44.53125 0.00000 1.73700 1.73700 13.20000 1.02700 0.37000 6.90000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
7.720 2035.00000 22.6000 -44.53125 0.00000 1.76000 1.76000 13.50000 1.02700 0.37000 6.40000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
7.730 2035.00000 22.6000 -44.53125 0.00000 1.76000 1.76000 13.50000 1.02700 0.37000 6.40000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
7.740 2035.00000 22.6000 -44.53125 0.00000 1.76000 1.76000 13.50000 1.02700 0.37000 6.40000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
7.750 2035.00000 22.6000 -44.53125 0.00000 1.76000 1.76000 13.50000 1.02700 0.37000 6.40000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
7.760 2035.00000 22.6000 -44.53125 0.00000 1.76000 1.76000 13.50000 1.02700 0.37000 6.40000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
7.770 2059.00000 22.3000 -44.53125 0.00000 1.71900 1.71900 13.70000 1.02700 0.37000 6.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
7.780 2059.00000 22.3000 -44.53125 0.00000 1.71900 1.71900 13.70000 1.02700 0.37000 6.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
7.790 2059.00000 22.3000 -44.53125 0.00000 1.71900 1.71900 13.70000 1.02700 0.37000 6.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
7.800 2059.00000 22.3000 -44.53125 0.00000 1.71900 1.71900 13.70000 1.02700 0.37000 6.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
7.810 2059.00000 22.3000 -44.53125 0.00000 1.71900 1.71900 13.70000 1.02700 0.37000 6.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
7.820 2067.00000 22.6000 -44.53125 0.00000 1.74800 1.74800 13.40000 1.02700 0.37000 6.80000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
7.830 2067.00000 22.6000 -44.53125 0.00000 1.74800 1.74800 13.40000 1.02700 0.37000 6.80000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
7.840 2067.00000 22.6000 -44.53125 0.00000 1.74800 1.74800 13.40000 1.02700 0.37000 6.80000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
7.850 2067.00000 22.6000 -44.53125 0.00000 1.74800 1.74800 13.40000 1.02700 0.37000 6.80000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
7.860 2067.00000 22.6000 -44.53125 0.00000 1.74800 1.74800 13.40000 1.02700 0.37000 6.80000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
7.870 2081.00000 22.7000 -44.53125 0.00000 1.78300 1.78300 13.10000 0.96000 0.41800 6.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
7.880 2081.00000 22.7000 -44.53125 0.00000 1.78300 1.78300 13.10000 0.96000 0.41800 6.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
7.890 2081.00000 22.7000 -44.53125 0.00000 1.78300 1.78300 13.10000 0.96000 0.41800 6.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
7.900 2081.00000 22.7000 -44.53125 0.00000 1.78300 1.78300 13.10000 0.96000 0.41800 6.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
7.910 2081.00000 22.7000 -44.53125 0.00000 1.78300 1.78300 13.10000 0.96000 0.41800 6.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
7.920 2036.00000 22.7000 -44.53125 0.00000 1.80100 1.80100 13.20000 0.96000 0.41800 7.10000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
7.930 2036.00000 22.7000 -44.53125 0.00000 1.80100 1.80100 13.20000 0.96000 0.41800 7.10000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
7.940 2036.00000 22.7000 -44.53125 0.00000 1.80100 1.80100 13.20000 0.96000 0.41800 7.10000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
7.950 2036.00000 22.7000 -44.53125 0.00000 1.80100 1.80100 13.20000 0.96000 0.41800 7.10000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
7.960 2036.00000 22.7000 -44.53125 0.00000 1.80100 1.80100 13.20000 0.96000 0.41800 7.10000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
7.970 2064.00000 23.3000 -44.53125 0.00000 1.78900 1.78900 13.30000 0.96000 0.41800 7.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
7.980 2064.00000 23.3000 -44.53125 0.00000 1.78900 1.78900 13.30000 0.96000 0.41800 7.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
7.990 2064.00000 23.3000 -44.53125 0.00000 1.78900 1.78900 13.30000 0.96000 0.41800 7.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
8.000 2064.00000 23.3000 -44.53125 0.00000 1.78900 1.78900 13.30000 0.96000 0.41800 7.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
8.010 2064.00000 23.3000 -44.53125 0.00000 1.78900 1.78900 13.30000 0.96000 0.41800 7.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
8.020 2119.00000 23.6000 -44.53125 0.00000 1.88300 1.88300 12.80000 0.96000 0.41800 6.90000 1.00000 5.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
8.030 2119.00000 23.6000 -44.53125 0.00000 1.88300 1.88300 12.80000 0.96000 0.41800 6.90000 1.00000 5.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
8.040 2119.00000 23.6000 -44.53125 0.00000 1.88300 1.88300 12.80000 0.96000 0.41800 6.90000 1.00000 5.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
8.050 2119.00000 23.6000 -44.53125 0.00000 1.88300 1.88300 12.80000 0.96000 0.41800 6.90000 1.00000 5.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
8.060 2119.00000 23.6000 -44.53125 0.00000 1.88300 1.88300 12.80000 0.96000 0.41800 6.90000 1.00000 5.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
8.070 2061.00000 23.2000 -44.53125 0.00000 1.82400 1.82400 13.70000 0.46600 0.45000 7.40000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
8.080 2061.00000 23.2000 -44.53125 0.00000 1.82400 1.82400 13.70000 0.46600 0.45000 7.40000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
8.090 2061.00000 23.2000 -44.53125 0.00000 1.82400 1.82400 13.70000 0.46600 0.45000 7.40000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
8.100 2061.00000 23.2000 -44.53125 0.00000 1.82400 1.82400 13.70000 0.46600 0.45000 7.40000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
8.110 2061.00000 23.2000 -44.53125 0.00000 1.82400 1.82400 13.70000 0.46600 0.45000 7.40000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
8.120 2058.00000 23.2000 -44.53125 0.00000 1.81300 1.81300 13.60000 0.46600 0.45000 7.40000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
8.130 2058.00000 23.2000 -44.53125 0.00000 1.81300 1.81300 13.60000 0.46600 0.45000 7.40000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
8.140 2058.00000 23.2000 -44.53125 0.00000 1.81300 1.81300 13.60000 0.46600 0.45000 7.40000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
8.150 2058.00000 23.2000 -44.53125 0.00000 1.81300 1.81300 13.60000 0.46600 0.45000 7.40000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
8.160 2058.00000 23.2000 -44.53125 0.00000 1.81300 1.81300 13.60000 0.46600 0.45000 7.40000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
8.170 2075.00000 23.3000 -44.53125 0.00000 1.79500 1.79500 13.10000 0.46600 0.45000 7.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
8.180 2075.00000 23.3000 -44.53125 0.00000 1.79500 1.79500 13.10000 0.46600 0.45000 7.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
8.190 2075.00000 23.3000 -44.53125 0.00000 1.79500 1.79500 13.10000 0.46600 0.45000 7.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
8.200 2075.00000 23.3000 -44.53125 0.00000 1.79500 1.79500 13.10000 0.46600 0.45000 7.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
8.210 2075.00000 23.3000 -44.53125 0.00000 1.79500 1.79500 13.10000 0.46600 0.45000 7.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
8.220 2131.00000 23.9000 -44.53125 0.00000 1.86500 1.86500 13.50000 0.46600 0.45000 7.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
8.230 2131.00000 23.9000 -44.53125 0.00000 1.86500 1.86500 13.50000 0.46600 0.45000 7.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
8.240 2131.00000 23.9000 -44.53125 0.00000 1.86500 1.86500 13.50000 0.46600 0.45000 7.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
8.250 2131.00000 23.9000 -44.53125 0.00000 1.86500 1.86500 13.50000 0.46600 0.45000 7.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
8.260 2131.00000 23.9000 -44.53125 0.00000 1.86500 1.86500 13.50000 0.46600 0.45000 7.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
8.270 2070.00000 23.5000 -44.53125 0.00000 1.90000 1.90000 13.00000 0.40800 0.41400 7.90000 1.00000 4.00000 4.00000 5.00000 5.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
8.280 2070.00000 23.5000 -44.53125 0.00000 1.90000 1.90000 13.00000 0.40800 0.41400 7.90000 1.00000 4.00000 4.00000 5.00000 5.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
8.290 2070.00000 23.5000 -44.53125 0.00000 1.90000 1.90000 13.00000 0.40800 0.41400 7.90000 1.00000 4.00000 4.00000 5.00000 5.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
8.300 2070.00000 23.5000 -44.53125 0.00000 1.90000 1.90000 13.00000 0.40800 0.41400 7.90000 1.00000 4.00000 4.00000 5.00000 5.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
8.310 2070.00000 23.5000 -44.53125 0.00000 1.90000 1.90000 13.00000 0.40800 0.41400 7.90000 1.00000 4.00000 4.00000 5.00000 5.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
8.320 2053.00000 23.3000 -44.53125 0.00000 1.82400 1.82400 12.90000 0.40800 0.41400 7.40000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
8.330 2053.00000 23.3000 -44.53125 0.00000 1.82400 1.82400 12.90000 0.40800 0.41400 7.40000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
8.340 2053.00000 23.3000 -44.53125 0.00000 1.82400 1.82400 12.90000 0.40800 0.41400 7.40000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
8.350 2053.00000 23.3000 -44.53125 0.00000 1.82400 1.82400 12.90000 0.40800 0.41400 7.40000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
8.360 2053.00000 23.3000 -44.53125 0.00000 1.82400 1.82400 12.90000 0.40800 0.41400 7.40000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
8.370 2139.00000 23.3000 -44.53125 0.00000 1.82400 1.82400 12.90000 0.40800 0.41400 7.30000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
8.380 2139.00000 23.3000 -44.53125 0.00000 1.82400 1.82400 12.90000 0.40800 0.41400 7.30000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
8.390 2139.00000 23.3000 -44.53125 0.00000 1.82400 1.82400 12.90000 0.40800 0.41400 7.30000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
8.400 2139.00000 23.3000 -44.53125 0.00000 1.82400 1.82400 12.90000 0.40800 0.41400 7.30000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
8.410 2139.00000 23.3000 -44.53125 0.00000 1.82400 1.82400 12.90000 0.40800 0.41400 7.30000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
8.420 2081.00000 24.1000 -44.53125 0.00000 1.95800 1.95800 12.60000 0.40800 0.41400 7.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
8.430 2081.00000 24.1000 -44.53125 0.00000 1.95800 1.95800 12.60000 0.40800 0.41400 7.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
8.440 2081.00000 24.1000 -44.53125 0.00000 1.95800 1.95800 12.60000 0.40800 0.41400 7.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
8.450 2081.00000 24.1000 -44.53125 0.00000 1.95800 1.95800 12.60000 0.40800 0.41400 7.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
8.460 2081.00000 24.1000 -44.53125 0.00000 1.95800 1.95800 12.60000 0.40800 0.41400 7.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
8.470 2056.00000 23.5000 -44.53125 0.00000 1.88300 1.88300 13.30000 1.05000 0.35400 8.00000 1.00000 4.00000 4.00000 4.00000 5.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
8.480 2056.00000 23.5000 -44.53125 0.00000 1.88300 1.88300 13.30000 1.05000 0.35400 8.00000 1.00000 4.00000 4.00000 4.00000 5.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
8.490 2056.00000 23.5000 -44.53125 0.00000 1.88300 1.88300 13.30000 1.05000 0.35400 8.00000 1.00000 4.00000 4.00000 4.00000 5.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
8.500 2056.00000 23.5000 -44.53125 0.00000 1.88300 1.88300 13.30000 1.05000 0.35400 8.00000 1.00000 4.00000 4.00000 4.00000 5.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
8.510 2056.00000 23.5000 -44.53125 0.00000 1.88300 1.88300 13.30000 1.05000 0.35400 8.00000 1.00000 4.00000 4.00000 4.00000 5.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
8.520 2113.00000 23.2000 -44.53125 0.00000 1.78300 1.78300 12.70000 1.05000 0.35400 7.30000 1.00000 5.00000 4.00000 4.00000 5.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
8.530 2113.00000 23.2000 -44.53125 0.00000 1.78300 1.78300 12.70000 1.05000 0.35400 7.30000 1.00000 5.00000 4.00000 4.00000 5.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
8.540 2113.00000 23.2000 -44.53125 0.00000 1.78300 1.78300 12.70000 1.05000 0.35400 7.30000 1.00000 5.00000 4.00000 4.00000 5.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
8.550 2113.00000 23.2000 -44.53125 0.00000 1.78300 1.78300 12.70000 1.05000 0.35400 7.30000 1.00000 5.00000 4.00000 4.00000 5.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
8.560 2113.00000 23.2000 -44.53125 0.00000 1.78300 1.78300 12.70000 1.05000 0.35400 7.30000 1.00000 5.00000 4.00000 4.00000 5.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
8.570 2094.00000 23.6000 -44.53125 0.00000 1.86500 1.86500 13.50000 1.05000 0.35400 7.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
8.580 2094.00000 23.6000 -44.53125 0.00000 1.86500 1.86500 13.50000 1.05000 0.35400 7.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
8.590 2094.00000 23.6000 -44.53125 0.00000 1.86500 1.86500 13.50000 1.05000 0.35400 7.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
8.600 2094.00000 23.6000 -44.53125 0.00000 1.86500 1.86500 13.50000 1.05000 0.35400 7.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
8.610 2094.00000 23.6000 -44.53125 0.00000 1.86500 1.86500 13.50000 1.05000 0.35400 7.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
8.620 2082.00000 24.3000 -44.53125 0.00000 1.94700 1.94700 12.70000 1.05000 0.35400 8.10000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.5000 0.000 0.000 0.000 0.000
8.630 2082.00000 24.3000 -44.53125 0.00000 1.94700 1.94700 12.70000 1.05000 0.35400 8.10000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.5000 0.000 0.000 0.000 0.000
8.640 2082.00000 24.3000 -44.53125 0.00000 1.94700 1.94700 12.70000 1.05000 0.35400 8.10000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.5000 0.000 0.000 0.000 0.000
8.650 2082.00000 24.3000 -44.53125 0.00000 1.94700 1.94700 12.70000 1.05000 0.35400 8.10000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.5000 0.000 0.000 0.000 0.000
8.660 2082.00000 24.3000 -44.53125 0.00000 1.94700 1.94700 12.70000 1.05000 0.35400 8.10000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.5000 0.000 0.000 0.000 0.000
8.670 2056.00000 23.6000 -44.53125 0.00000 1.89400 1.89400 13.20000 1.04000 0.39500 7.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.5000 0.000 0.000 0.000 0.000
8.680 2056.00000 23.6000 -44.53125 0.00000 1.89400 1.89400 13.20000 1.04000 0.39500 7.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.5000 0.000 0.000 0.000 0.000
8.690 2056.00000 23.6000 -44.53125 0.00000 1.89400 1.89400 13.20000 1.04000 0.39500 7.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.5000 0.000 0.000 0.000 0.000
8.700 2056.00000 23.6000 -44.53125 0.00000 1.89400 1.89400 13.20000 1.04000 0.39500 7.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.5000 0.000 0.000 0.000 0.000
8.710 2056.00000 23.6000 -44.53125 0.00000 1.89400 1.89400 13.20000 1.04000 0.39500 7.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.5000 0.000 0.000 0.000 0.000
8.720 2116.00000 23.5000 -44.53125 0.00000 1.81300 1.81300 12.70000 1.04000 0.39500 7.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.6000 0.000 0.000 0.000 0.000
8.730 2116.00000 23.5000 -44.53125 0.00000 1.81300 1.81300 12.70000 1.04000 0.39500 7.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.6000 0.000 0.000 0.000 0.000
8.740 2116.00000 23.5000 -44.53125 0.00000 1.81300 1.81300 12.70000 1.04000 0.39500 7.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.6000 0.000 0.000 0.000 0.000
8.750 2116.00000 23.5000 -44.53125 0.00000 1.81300 1.81300 12.70000 1.04000 0.39500 7.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.6000 0.000 0.000 0.000 0.000
8.760 2116.00000 23.5000 -44.53125 0.00000 1.81300 1.81300 12.70000 1.04000 0.39500 7.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.6000 0.000 0.000 0.000 0.000
8.770 2107.00000 23.8000 -44.53125 0.00000 1.79500 1.79500 13.00000 1.04000 0.39500 7.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.5000 0.000 0.000 0.000 0.000
8.780 2107.00000 23.8000 -44.53125 0.00000 1.79500 1.79500 13.00000 1.04000 0.39500 7.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.5000 0.000 0.000 0.000 0.000
8.790 2107.00000 23.8000 -44.53125 0.00000 1.79500 1.79500 13.00000 1.04000 0.39500 7.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.5000 0.000 0.000 0.000 0.000
8.800 2107.00000 23.8000 -44.53125 0.00000 1.79500 1.79500 13.00000 1.04000 0.39500 7.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.5000 0.000 0.000 0.000 0.000
8.810 2107.00000 23.8000 -44.53125 0.00000 1.79500 1.79500 13.00000 1.04000 0.39500 7.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.5000 0.000 0.000 0.000 0.000
8.820 2107.00000 23.8000 -44.53125 0.00000 1.83000 1.83000 12.90000 1.04000 0.39500 7.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
8.830 2107.00000 23.8000 -44.53125 0.00000 1.83000 1.83000 12.90000 1.04000 0.39500 7.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
8.840 2107.00000 23.8000 -44.53125 0.00000 1.83000 1.83000 12.90000 1.04000 0.39500 7.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
8.850 2107.00000 23.8000 -44.53125 0.00000 1.83000 1.83000 12.90000 1.04000 0.39500 7.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
8.860 2107.00000 23.8000 -44.53125 0.00000 1.83000 1.83000 12.90000 1.04000 0.39500 7.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
8.870 2103.00000 23.2000 -44.53125 0.00000 1.84800 1.84800 12.80000 0.65400 0.59300 7.10000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
8.880 2103.00000 23.2000 -44.53125 0.00000 1.84800 1.84800 12.80000 0.65400 0.59300 7.10000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
8.890 2103.00000 23.2000 -44.53125 0.00000 1.84800 1.84800 12.80000 0.65400 0.59300 7.10000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
8.900 2103.00000 23.2000 -44.53125 0.00000 1.84800 1.84800 12.80000 0.65400 0.59300 7.10000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
8.910 2103.00000 23.2000 -44.53125 0.00000 1.84800 1.84800 12.80000 0.65400 0.59300 7.10000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
8.920 2146.00000 23.2000 -44.53125 0.00000 1.82400 1.82400 13.60000 0.65400 0.59300 7.50000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
8.930 2146.00000 23.2000 -44.53125 0.00000 1.82400 1.82400 13.60000 0.65400 0.59300 7.50000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
8.940 2146.00000 23.2000 -44.53125 0.00000 1.82400 1.82400 13.60000 0.65400 0.59300 7.50000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
8.950 2146.00000 23.2000 -44.53125 0.00000 1.82400 1.82400 13.60000 0.65400 0.59300 7.50000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
8.960 2146.00000 23.2000 -44.53125 0.00000 1.82400 1.82400 13.60000 0.65400 0.59300 7.50000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
8.970 2126.00000 23.5000 -44.53125 0.00000 1.83000 1.83000 12.10000 0.65400 0.59300 7.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
8.980 2126.00000 23.5000 -44.53125 0.00000 1.83000 1.83000 12.10000 0.65400 0.59300 7.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
8.990 2126.00000 23.5000 -44.53125 0.00000 1.83000 1.83000 12.10000 0.65400 0.59300 7.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
9.000 2126.00000 23.5000 -44.53125 0.00000 1.83000 1.83000 12.10000 0.65400 0.59300 7.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
9.010 2126.00000 23.5000 -44.53125 0.00000 1.83000 1.83000 12.10000 0.65400 0.59300 7.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
9.020 2177.00000 23.2000 -44.53125 0.00000 1.81800 1.81800 12.80000 0.65400 0.59300 7.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
9.030 2177.00000 23.2000 -44.53125 0.00000 1.81800 1.81800 12.80000 0.65400 0.59300 7.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
9.040 2177.00000 23.2000 -44.53125 0.00000 1.81800 1.81800 12.80000 0.65400 0.59300 7.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
9.050 2177.00000 23.2000 -44.53125 0.00000 1.81800 1.81800 12.80000 0.65400 0.59300 7.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
9.060 2177.00000 23.2000 -44.53125 0.00000 1.81800 1.81800 12.80000 0.65400 0.59300 7.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
9.070 2123.00000 23.0000 -44.53125 0.00000 1.84800 1.84800 13.40000 0.44300 0.83300 7.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
9.080 2123.00000 23.0000 -44.53125 0.00000 1.84800 1.84800 13.40000 0.44300 0.83300 7.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
9.090 2123.00000 23.0000 -44.53125 0.00000 1.84800 1.84800 13.40000 0.44300 0.83300 7.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
9.100 2123.00000 23.0000 -44.53125 0.00000 1.84800 1.84800 13.40000 0.44300 0.83300 7.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
9.110 2123.00000 23.0000 -44.53125 0.00000 1.84800 1.84800 13.40000 0.44300 0.83300 7.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
9.120 2138.00000 22.9000 -44.53125 0.00000 1.80700 1.80700 13.50000 0.44300 0.83300 7.10000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
9.130 2138.00000 22.9000 -44.53125 0.00000 1.80700 1.80700 13.50000 0.44300 0.83300 7.10000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
9.140 2138.00000 22.9000 -44.53125 0.00000 1.80700 1.80700 13.50000 0.44300 0.83300 7.10000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
9.150 2138.00000 22.9000 -44.53125 0.00000 1.80700 1.80700 13.50000 0.44300 0.83300 7.10000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
9.160 2138.00000 22.9000 -44.53125 0.00000 1.80700 1.80700 13.50000 0.44300 0.83300 7.10000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
9.170 2162.00000 23.2000 -44.53125 0.00000 1.83000 1.83000 13.00000 0.44300 0.83300 7.10000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
9.180 2162.00000 23.2000 -44.53125 0.00000 1.83000 1.83000 13.00000 0.44300 0.83300 7.10000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
9.190 2162.00000 23.2000 -44.53125 0.00000 1.83000 1.83000 13.00000 0.44300 0.83300 7.10000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
9.200 2162.00000 23.2000 -44.53125 0.00000 1.83000 1.83000 13.00000 0.44300 0.83300 7.10000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
9.210 2162.00000 23.2000 -44.53125 0.00000 1.83000 1.83000 13.00000 0.44300 0.83300 7.10000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
9.220 2201.00000 23.2000 -44.53125 0.00000 1.88800 1.88800 13.20000 0.44300 0.83300 7.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
9.230 2201.00000 23.2000 -44.53125 0.00000 1.88800 1.88800 13.20000 0.44300 0.83300 7.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
9.240 2201.00000 23.2000 -44.53125 0.00000 1.88800 1.88800 13.20000 0.44300 0.83300 7.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
9.250 2201.00000 23.2000 -44.53125 0.00000 1.88800 1.88800 13.20000 0.44300 0.83300 7.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
9.260 2201.00000 23.2000 -44.53125 0.00000 1.88800 1.88800 13.20000 0.44300 0.83300 7.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
9.270 2134.00000 23.0000 -44.53125 0.00000 1.81800 1.81800 13.20000 0.93200 0.67000 7.50000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
9.280 2134.00000 23.0000 -44.53125 0.00000 1.81800 1.81800 13.20000 0.93200 0.67000 7.50000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
9.290 2134.00000 23.0000 -44.53125 0.00000 1.81800 1.81800 13.20000 0.93200 0.67000 7.50000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
9.300 2134.00000 23.0000 -44.53125 0.00000 1.81800 1.81800 13.20000 0.93200 0.67000 7.50000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
9.310 2134.00000 23.0000 -44.53125 0.00000 1.81800 1.81800 13.20000 0.93200 0.67000 7.50000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
9.320 2137.00000 23.5000 -44.53125 0.00000 1.85300 1.85300 13.30000 0.93200 0.67000 7.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
9.330 2137.00000 23.5000 -44.53125 0.00000 1.85300 1.85300 13.30000 0.93200 0.67000 7.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
9.340 2137.00000 23.5000 -44.53125 0.00000 1.85300 1.85300 13.30000 0.93200 0.67000 7.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
9.350 2137.00000 23.5000 -44.53125 0.00000 1.85300 1.85300 13.30000 0.93200 0.67000 7.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
9.360 2137.00000 23.5000 -44.53125 0.00000 1.85300 1.85300 13.30000 0.93200 0.67000 7.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
9.370 2216.00000 24.3000 -44.53125 0.00000 1.91200 1.91200 13.10000 0.93200 0.67000 7.40000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
9.380 2216.00000 24.3000 -44.53125 0.00000 1.91200 1.91200 13.10000 0.93200 0.67000 7.40000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
9.390 2216.00000 24.3000 -44.53125 0.00000 1.91200 1.91200 13.10000 0.93200 0.67000 7.40000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
9.400 2216.00000 24.3000 -44.53125 0.00000 1.91200 1.91200 13.10000 0.93200 0.67000 7.40000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
9.410 2216.00000 24.3000 -44.53125 0.00000 1.91200 1.91200 13.10000 0.93200 0.67000 7.40000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
9.420 2186.00000 24.3000 -44.53125 0.00000 2.01100 2.01100 13.30000 0.93200 0.67000 7.40000 1.00000 5.00000 4.00000 5.00000 5.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
9.430 2186.00000 24.3000 -44.53125 0.00000 2.01100 2.01100 13.30000 0.93200 0.67000 7.40000 1.00000 5.00000 4.00000 5.00000 5.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
9.440 2186.00000 24.3000 -44.53125 0.00000 2.01100 2.01100 13.30000 0.93200 0.67000 7.40000 1.00000 5.00000 4.00000 5.00000 5.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
9.450 2186.00000 24.3000 -44.53125 0.00000 2.01100 2.01100 13.30000 0.93200 0.67000 7.40000 1.00000 5.00000 4.00000 5.00000 5.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
9.460 2186.00000 24.3000 -44.53125 0.00000 2.01100 2.01100 13.30000 0.93200 0.67000 7.40000 1.00000 5.00000 4.00000 5.00000 5.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
9.470 2160.00000 22.9000 -44.53125 0.00000 1.88300 1.88300 12.70000 0.97600 0.57700 7.60000 1.00000 4.00000 4.00000 5.00000 4.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
9.480 2160.00000 22.9000 -44.53125 0.00000 1.88300 1.88300 12.70000 0.97600 0.57700 7.60000 1.00000 4.00000 4.00000 5.00000 4.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
9.490 2160.00000 22.9000 -44.53125 0.00000 1.88300 1.88300 12.70000 0.97600 0.57700 7.60000 1.00000 4.00000 4.00000 5.00000 4.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
9.500 2160.00000 22.9000 -44.53125 0.00000 1.88300 1.88300 12.70000 0.97600 0.57700 7.60000 1.00000 4.00000 4.00000 5.00000 4.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
9.510 2160.00000 22.9000 -44.53125 0.00000 1.88300 1.88300 12.70000 0.97600 0.57700 7.60000 1.00000 4.00000 4.00000 5.00000 4.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
9.520 2243.00000 22.6000 -44.53125 0.00000 1.80100 1.80100 13.20000 0.97600 0.57700 7.40000 1.00000 5.00000 5.00000 5.00000 4.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
9.530 2243.00000 22.6000 -44.53125 0.00000 1.80100 1.80100 13.20000 0.97600 0.57700 7.40000 1.00000 5.00000 5.00000 5.00000 4.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
9.540 2243.00000 22.6000 -44.53125 0.00000 1.80100 1.80100 13.20000 0.97600 0.57700 7.40000 1.00000 5.00000 5.00000 5.00000 4.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
9.550 2243.00000 22.6000 -44.53125 0.00000 1.80100 1.80100 13.20000 0.97600 0.57700 7.40000 1.00000 5.00000 5.00000 5.00000 4.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
9.560 2243.00000 22.6000 -44.53125 0.00000 1.80100 1.80100 13.20000 0.97600 0.57700 7.40000 1.00000 5.00000 5.00000 5.00000 4.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
9.570 2215.00000 22.4000 -44.53125 0.00000 1.74800 1.74800 13.40000 0.97600 0.57700 7.10000 1.00000 4.00000 4.00000 5.00000 5.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
9.580 2215.00000 22.4000 -44.53125 0.00000 1.74800 1.74800 13.40000 0.97600 0.57700 7.10000 1.00000 4.00000 4.00000 5.00000 5.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
9.590 2215.00000 22.4000 -44.53125 0.00000 1.74800 1.74800 13.40000 0.97600 0.57700 7.10000 1.00000 4.00000 4.00000 5.00000 5.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
9.600 2215.00000 22.4000 -44.53125 0.00000 1.74800 1.74800 13.40000 0.97600 0.57700 7.10000 1.00000 4.00000 4.00000 5.00000 5.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
9.610 2215.00000 22.4000 -44.53125 0.00000 1.74800 1.74800 13.40000 0.97600 0.57700 7.10000 1.00000 4.00000 4.00000 5.00000 5.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
9.620 2191.00000 22.6000 -44.53125 0.00000 1.76600 1.76600 12.20000 0.97600 0.57700 6.90000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
9.630 2191.00000 22.6000 -44.53125 0.00000 1.76600 1.76600 12.20000 0.97600 0.57700 6.90000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
9.640 2191.00000 22.6000 -44.53125 0.00000 1.76600 1.76600 12.20000 0.97600 0.57700 6.90000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
9.650 2191.00000 22.6000 -44.53125 0.00000 1.76600 1.76600 12.20000 0.97600 0.57700 6.90000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
9.660 2191.00000 22.6000 -44.53125 0.00000 1.76600 1.76600 12.20000 0.97600 0.57700 6.90000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
9.670 2191.00000 22.6000 -44.53125 0.00000 1.76600 1.76600 12.20000 0.97600 0.57700 6.90000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
9.680 2173.00000 21.3000 -44.53125 0.00000 1.65500 1.65500 13.30000 0.42700 0.57700 6.80000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
9.690 2173.00000 21.3000 -44.53125 0.00000 1.65500 1.65500 13.30000 0.42700 0.57700 6.80000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
9.700 2173.00000 21.3000 -44.53125 0.00000 1.65500 1.65500 13.30000 0.42700 0.57700 6.80000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
9.710 2173.00000 21.3000 -44.53125 0.00000 1.65500 1.65500 13.30000 0.42700 0.57700 6.80000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
9.720 2173.00000 21.3000 -44.53125 0.00000 1.65500 1.65500 13.30000 0.42700 0.57700 6.80000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
9.730 2228.00000 21.5000 -44.53125 0.00000 1.60900 1.60900 13.20000 0.42700 0.57700 6.40000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
9.740 2228.00000 21.5000 -44.53125 0.00000 1.60900 1.60900 13.20000 0.42700 0.57700 6.40000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
9.750 2228.00000 21.5000 -44.53125 0.00000 1.60900 1.60900 13.20000 0.42700 0.57700 6.40000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
9.760 2228.00000 21.5000 -44.53125 0.00000 1.60900 1.60900 13.20000 0.42700 0.57700 6.40000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
9.770 2228.00000 21.5000 -44.53125 0.00000 1.60900 1.60900 13.20000 0.42700 0.57700 6.40000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
9.780 2206.00000 21.5000 -44.53125 0.00000 1.69000 1.69000 13.20000 0.42700 0.57700 6.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
9.790 2206.00000 21.5000 -44.53125 0.00000 1.69000 1.69000 13.20000 0.42700 0.57700 6.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
9.800 2206.00000 21.5000 -44.53125 0.00000 1.69000 1.69000 13.20000 0.42700 0.57700 6.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
9.810 2206.00000 21.5000 -44.53125 0.00000 1.69000 1.69000 13.20000 0.42700 0.57700 6.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
9.820 2206.00000 21.5000 -44.53125 0.00000 1.69000 1.69000 13.20000 0.42700 0.57700 6.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
9.830 2225.00000 21.0000 -44.53125 0.00000 1.60900 1.60900 13.10000 0.42700 0.57700 5.90000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
9.840 2225.00000 21.0000 -44.53125 0.00000 1.60900 1.60900 13.10000 0.42700 0.57700 5.90000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
9.850 2225.00000 21.0000 -44.53125 0.00000 1.60900 1.60900 13.10000 0.42700 0.57700 5.90000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
9.860 2225.00000 21.0000 -44.53125 0.00000 1.60900 1.60900 13.10000 0.42700 0.57700 5.90000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
9.870 2225.00000 21.0000 -44.53125 0.00000 1.60900 1.60900 13.10000 0.42700 0.57700 5.90000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
9.880 2204.00000 20.9000 -44.53125 0.00000 1.53900 1.53900 13.30000 1.06900 0.44000 5.80000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
9.890 2204.00000 20.9000 -44.53125 0.00000 1.53900 1.53900 13.30000 1.06900 0.44000 5.80000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
9.900 2204.00000 20.9000 -44.53125 0.00000 1.53900 1.53900 13.30000 1.06900 0.44000 5.80000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
9.910 2204.00000 20.9000 -44.53125 0.00000 1.53900 1.53900 13.30000 1.06900 0.44000 5.80000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
9.920 2204.00000 20.9000 -44.53125 0.00000 1.53900 1.53900 13.30000 1.06900 0.44000 5.80000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
9.930 2249.00000 21.2000 -44.53125 0.00000 1.62000 1.62000 12.80000 1.06900 0.44000 5.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
9.940 2249.00000 21.2000 -44.53125 0.00000 1.62000 1.62000 12.80000 1.06900 0.44000 5.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
9.950 2249.00000 21.2000 -44.53125 0.00000 1.62000 1.62000 12.80000 1.06900 0.44000 5.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
9.960 2249.00000 21.2000 -44.53125 0.00000 1.62000 1.62000 12.80000 1.06900 0.44000 5.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
9.970 2249.00000 21.2000 -44.53125 0.00000 1.62000 1.62000 12.80000 1.06900 0.44000 5.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
9.980 2242.00000 21.2000 -44.53125 0.00000 1.67300 1.67300 13.10000 1.06900 0.44000 5.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
9.990 2242.00000 21.2000 -44.53125 0.00000 1.67300 1.67300 13.10000 1.06900 0.44000 5.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
10.000 2242.00000 21.2000 -44.53125 0.00000 1.67300 1.67300 13.10000 1.06900 0.44000 5.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
10.010 2242.00000 21.2000 -44.53125 0.00000 1.67300 1.67300 13.10000 1.06900 0.44000 5.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
10.020 2242.00000 21.2000 -44.53125 0.00000 1.67300 1.67300 13.10000 1.06900 0.44000 5.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
10.030 2253.00000 20.9000 -44.53125 0.00000 1.63200 1.63200 13.50000 1.06900 0.44000 5.80000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
10.040 2253.00000 20.9000 -44.53125 0.00000 1.63200 1.63200 13.50000 1.06900 0.44000 5.80000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
10.050 2253.00000 20.9000 -44.53125 0.00000 1.63200 1.63200 13.50000 1.06900 0.44000 5.80000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
10.060 2253.00000 20.9000 -44.53125 0.00000 1.63200 1.63200 13.50000 1.06900 0.44000 5.80000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
10.070 2253.00000 20.9000 -44.53125 0.00000 1.63200 1.63200 13.50000 1.06900 0.44000 5.80000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
10.080 2254.00000 21.0000 -44.53125 0.00000 1.64400 1.64400 13.00000 0.84500 0.42100 5.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
10.090 2254.00000 21.0000 -44.53125 0.00000 1.64400 1.64400 13.00000 0.84500 0.42100 5.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
10.100 2254.00000 21.0000 -44.53125 0.00000 1.64400 1.64400 13.00000 0.84500 0.42100 5.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
10.110 2254.00000 21.0000 -44.53125 0.00000 1.64400 1.64400 13.00000 0.84500 0.42100 5.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
10.120 2254.00000 21.0000 -44.53125 0.00000 1.64400 1.64400 13.00000 0.84500 0.42100 5.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
10.130 2268.00000 21.2000 -44.53125 0.00000 1.63800 1.63800 13.30000 0.84500 0.42100 5.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
10.140 2268.00000 21.2000 -44.53125 0.00000 1.63800 1.63800 13.30000 0.84500 0.42100 5.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
10.150 2268.00000 21.2000 -44.53125 0.00000 1.63800 1.63800 13.30000 0.84500 0.42100 5.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
10.160 2268.00000 21.2000 -44.53125 0.00000 1.63800 1.63800 13.30000 0.84500 0.42100 5.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
10.170 2268.00000 21.2000 -44.53125 0.00000 1.63800 1.63800 13.30000 0.84500 0.42100 5.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
10.180 2280.00000 21.0000 -44.53125 0.00000 1.63200 1.63200 13.10000 0.84500 0.42100 5.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
10.190 2280.00000 21.0000 -44.53125 0.00000 1.63200 1.63200 13.10000 0.84500 0.42100 5.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
10.200 2280.00000 21.0000 -44.53125 0.00000 1.63200 1.63200 13.10000 0.84500 0.42100 5.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
10.210 2280.00000 21.0000 -44.53125 0.00000 1.63200 1.63200 13.10000 0.84500 0.42100 5.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
10.220 2280.00000 21.0000 -44.53125 0.00000 1.63200 1.63200 13.10000 0.84500 0.42100 5.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
10.230 2219.00000 21.0000 -44.53125 0.00000 1.61400 1.61400 13.40000 0.84500 0.42100 5.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
10.240 2219.00000 21.0000 -44.53125 0.00000 1.61400 1.61400 13.40000 0.84500 0.42100 5.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
10.250 2219.00000 21.0000 -44.53125 0.00000 1.61400 1.61400 13.40000 0.84500 0.42100 5.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
10.260 2219.00000 21.0000 -44.53125 0.00000 1.61400 1.61400 13.40000 0.84500 0.42100 5.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
10.270 2219.00000 21.0000 -44.53125 0.00000 1.61400 1.61400 13.40000 0.84500 0.42100 5.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
10.280 2243.00000 21.0000 -44.53125 0.00000 1.62000 1.62000 12.60000 0.33800 0.53600 5.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
10.290 2243.00000 21.0000 -44.53125 0.00000 1.62000 1.62000 12.60000 0.33800 0.53600 5.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
10.300 2243.00000 21.0000 -44.53125 0.00000 1.62000 1.62000 12.60000 0.33800 0.53600 5.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
10.310 2243.00000 21.0000 -44.53125 0.00000 1.62000 1.62000 12.60000 0.33800 0.53600 5.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
10.320 2243.00000 21.0000 -44.53125 0.00000 1.62000 1.62000 12.60000 0.33800 0.53600 5.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
10.330 2315.00000 21.3000 -44.53125 0.00000 1.66100 1.66100 13.20000 0.33800 0.53600 5.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
10.340 2315.00000 21.3000 -44.53125 0.00000 1.66100 1.66100 13.20000 0.33800 0.53600 5.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
10.350 2315.00000 21.3000 -44.53125 0.00000 1.66100 1.66100 13.20000 0.33800 0.53600 5.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
10.360 2315.00000 21.3000 -44.53125 0.00000 1.66100 1.66100 13.20000 0.33800 0.53600 5.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
10.370 2315.00000 21.3000 -44.53125 0.00000 1.66100 1.66100 13.20000 0.33800 0.53600 5.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
10.380 2252.00000 21.0000 -44.53125 0.00000 1.64400 1.64400 13.60000 0.33800 0.53600 5.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
10.390 2252.00000 21.0000 -44.53125 0.00000 1.64400 1.64400 13.60000 0.33800 0.53600 5.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
10.400 2252.00000 21.0000 -44.53125 0.00000 1.64400 1.64400 13.60000 0.33800 0.53600 5.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
10.410 2252.00000 21.0000 -44.53125 0.00000 1.64400 1.64400 13.60000 0.33800 0.53600 5.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
10.420 2252.00000 21.0000 -44.53125 0.00000 1.64400 1.64400 13.60000 0.33800 0.53600 5.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
10.430 2246.00000 21.2000 -44.53125 0.00000 1.65500 1.65500 13.20000 0.33800 0.53600 5.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
10.440 2246.00000 21.2000 -44.53125 0.00000 1.65500 1.65500 13.20000 0.33800 0.53600 5.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
10.450 2246.00000 21.2000 -44.53125 0.00000 1.65500 1.65500 13.20000 0.33800 0.53600 5.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
10.460 2246.00000 21.2000 -44.53125 0.00000 1.65500 1.65500 13.20000 0.33800 0.53600 5.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
10.470 2246.00000 21.2000 -44.53125 0.00000 1.65500 1.65500 13.20000 0.33800 0.53600 5.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
10.480 2319.00000 21.3000 -44.53125 0.00000 1.63200 1.63200 13.40000 0.34100 0.47200 5.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
10.490 2319.00000 21.3000 -44.53125 0.00000 1.63200 1.63200 13.40000 0.34100 0.47200 5.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
10.500 2319.00000 21.3000 -44.53125 0.00000 1.63200 1.63200 13.40000 0.34100 0.47200 5.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
10.510 2319.00000 21.3000 -44.53125 0.00000 1.63200 1.63200 13.40000 0.34100 0.47200 5.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
10.520 2319.00000 21.3000 -44.53125 0.00000 1.63200 1.63200 13.40000 0.34100 0.47200 5.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
10.530 2270.00000 21.3000 -44.53125 0.00000 1.66100 1.66100 13.20000 0.34100 0.47200 5.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
10.540 2270.00000 21.3000 -44.53125 0.00000 1.66100 1.66100 13.20000 0.34100 0.47200 5.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
10.550 2270.00000 21.3000 -44.53125 0.00000 1.66100 1.66100 13.20000 0.34100 0.47200 5.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
10.560 2270.00000 21.3000 -44.53125 0.00000 1.66100 1.66100 13.20000 0.34100 0.47200 5.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
10.570 2270.00000 21.3000 -44.53125 0.00000 1.66100 1.66100 13.20000 0.34100 0.47200 5.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
10.580 2249.00000 21.3000 -44.53125 0.00000 1.68400 1.68400 12.90000 0.34100 0.47200 5.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
10.590 2249.00000 21.3000 -44.53125 0.00000 1.68400 1.68400 12.90000 0.34100 0.47200 5.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
10.600 2249.00000 21.3000 -44.53125 0.00000 1.68400 1.68400 12.90000 0.34100 0.47200 5.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
10.610 2249.00000 21.3000 -44.53125 0.00000 1.68400 1.68400 12.90000 0.34100 0.47200 5.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
10.620 2249.00000 21.3000 -44.53125 0.00000 1.68400 1.68400 12.90000 0.34100 0.47200 5.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
10.630 2299.00000 21.3000 -44.53125 0.00000 1.67300 1.67300 12.90000 0.34100 0.47200 5.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
10.640 2299.00000 21.3000 -44.53125 0.00000 1.67300 1.67300 12.90000 0.34100 0.47200 5.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
10.650 2299.00000 21.3000 -44.53125 0.00000 1.67300 1.67300 12.90000 0.34100 0.47200 5.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
10.660 2299.00000 21.3000 -44.53125 0.00000 1.67300 1.67300 12.90000 0.34100 0.47200 5.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
10.670 2299.00000 21.3000 -44.53125 0.00000 1.67300 1.67300 12.90000 0.34100 0.47200 5.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
10.680 2275.00000 21.5000 -44.53125 0.00000 1.66100 1.66100 13.40000 0.33800 0.35100 5.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
10.690 2275.00000 21.5000 -44.53125 0.00000 1.66100 1.66100 13.40000 0.33800 0.35100 5.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
10.700 2275.00000 21.5000 -44.53125 0.00000 1.66100 1.66100 13.40000 0.33800 0.35100 5.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
10.710 2275.00000 21.5000 -44.53125 0.00000 1.66100 1.66100 13.40000 0.33800 0.35100 5.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
10.720 2275.00000 21.5000 -44.53125 0.00000 1.66100 1.66100 13.40000 0.33800 0.35100 5.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
10.730 2257.00000 21.3000 -44.53125 0.00000 1.67800 1.67800 13.40000 0.33800 0.35100 5.50000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
10.740 2257.00000 21.3000 -44.53125 0.00000 1.67800 1.67800 13.40000 0.33800 0.35100 5.50000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
10.750 2257.00000 21.3000 -44.53125 0.00000 1.67800 1.67800 13.40000 0.33800 0.35100 5.50000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
10.760 2257.00000 21.3000 -44.53125 0.00000 1.67800 1.67800 13.40000 0.33800 0.35100 5.50000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
10.770 2257.00000 21.3000 -44.53125 0.00000 1.67800 1.67800 13.40000 0.33800 0.35100 5.50000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
10.780 2306.00000 21.5000 -44.53125 0.00000 1.71300 1.71300 13.30000 0.33800 0.35100 5.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
10.790 2306.00000 21.5000 -44.53125 0.00000 1.71300 1.71300 13.30000 0.33800 0.35100 5.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
10.800 2306.00000 21.5000 -44.53125 0.00000 1.71300 1.71300 13.30000 0.33800 0.35100 5.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
10.810 2306.00000 21.5000 -44.53125 0.00000 1.71300 1.71300 13.30000 0.33800 0.35100 5.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
10.820 2306.00000 21.5000 -44.53125 0.00000 1.71300 1.71300 13.30000 0.33800 0.35100 5.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
10.830 2284.00000 21.5000 -44.53125 0.00000 1.67800 1.67800 13.20000 0.33800 0.35100 5.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
10.840 2284.00000 21.5000 -44.53125 0.00000 1.67800 1.67800 13.20000 0.33800 0.35100 5.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
10.850 2284.00000 21.5000 -44.53125 0.00000 1.67800 1.67800 13.20000 0.33800 0.35100 5.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
10.860 2284.00000 21.5000 -44.53125 0.00000 1.67800 1.67800 13.20000 0.33800 0.35100 5.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
10.870 2284.00000 21.5000 -44.53125 0.00000 1.67800 1.67800 13.20000 0.33800 0.35100 5.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
10.880 2287.00000 21.5000 -44.53125 0.00000 1.65500 1.65500 13.20000 0.47800 0.34400 5.90000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
10.890 2287.00000 21.5000 -44.53125 0.00000 1.65500 1.65500 13.20000 0.47800 0.34400 5.90000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
10.900 2287.00000 21.5000 -44.53125 0.00000 1.65500 1.65500 13.20000 0.47800 0.34400 5.90000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
10.910 2287.00000 21.5000 -44.53125 0.00000 1.65500 1.65500 13.20000 0.47800 0.34400 5.90000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
10.920 2287.00000 21.5000 -44.53125 0.00000 1.65500 1.65500 13.20000 0.47800 0.34400 5.90000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
10.930 2277.00000 21.5000 -44.53125 0.00000 1.70800 1.70800 13.30000 0.47800 0.34400 6.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
10.940 2277.00000 21.5000 -44.53125 0.00000 1.70800 1.70800 13.30000 0.47800 0.34400 6.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
10.950 2277.00000 21.5000 -44.53125 0.00000 1.70800 1.70800 13.30000 0.47800 0.34400 6.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
10.960 2277.00000 21.5000 -44.53125 0.00000 1.70800 1.70800 13.30000 0.47800 0.34400 6.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
10.970 2277.00000 21.5000 -44.53125 0.00000 1.70800 1.70800 13.30000 0.47800 0.34400 6.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
10.980 2288.00000 21.3000 -44.53125 0.00000 1.66700 1.66700 13.30000 0.47800 0.34400 6.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
10.990 2288.00000 21.3000 -44.53125 0.00000 1.66700 1.66700 13.30000 0.47800 0.34400 6.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
11.000 2288.00000 21.3000 -44.53125 0.00000 1.66700 1.66700 13.30000 0.47800 0.34400 6.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
11.010 2288.00000 21.3000 -44.53125 0.00000 1.66700 1.66700 13.30000 0.47800 0.34400 6.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
11.020 2288.00000 21.3000 -44.53125 0.00000 1.66700 1.66700 13.30000 0.47800 0.34400 6.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
11.030 2284.00000 21.5000 -44.53125 0.00000 1.69600 1.69600 13.00000 0.47800 0.34400 6.10000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
11.040 2284.00000 21.5000 -44.53125 0.00000 1.69600 1.69600 13.00000 0.47800 0.34400 6.10000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
11.050 2284.00000 21.5000 -44.53125 0.00000 1.69600 1.69600 13.00000 0.47800 0.34400 6.10000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
11.060 2284.00000 21.5000 -44.53125 0.00000 1.69600 1.69600 13.00000 0.47800 0.34400 6.10000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
11.070 2284.00000 21.5000 -44.53125 0.00000 1.69600 1.69600 13.00000 0.47800 0.34400 6.10000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
11.080 2284.00000 21.5000 -44.53125 0.00000 1.69600 1.69600 13.00000 0.47800 0.34400 6.10000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
11.090 2321.00000 21.5000 -44.53125 0.00000 1.67300 1.67300 13.00000 0.95100 0.36300 6.10000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
11.100 2321.00000 21.5000 -44.53125 0.00000 1.67300 1.67300 13.00000 0.95100 0.36300 6.10000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
11.110 2321.00000 21.5000 -44.53125 0.00000 1.67300 1.67300 13.00000 0.95100 0.36300 6.10000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
11.120 2321.00000 21.5000 -44.53125 0.00000 1.67300 1.67300 13.00000 0.95100 0.36300 6.10000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
11.130 2321.00000 21.5000 -44.53125 0.00000 1.67300 1.67300 13.00000 0.95100 0.36300 6.10000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
11.140 2277.00000 21.3000 -44.53125 0.00000 1.67300 1.67300 13.60000 0.95100 0.36300 6.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
11.150 2277.00000 21.3000 -44.53125 0.00000 1.67300 1.67300 13.60000 0.95100 0.36300 6.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
11.160 2277.00000 21.3000 -44.53125 0.00000 1.67300 1.67300 13.60000 0.95100 0.36300 6.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
11.170 2277.00000 21.3000 -44.53125 0.00000 1.67300 1.67300 13.60000 0.95100 0.36300 6.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
11.180 2277.00000 21.3000 -44.53125 0.00000 1.67300 1.67300 13.60000 0.95100 0.36300 6.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
11.190 2277.00000 21.3000 -44.53125 0.00000 1.67300 1.67300 13.60000 0.95100 0.36300 6.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
11.200 2324.00000 21.3000 -44.53125 0.00000 1.70200 1.70200 12.40000 0.95100 0.36300 6.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
11.210 2324.00000 21.3000 -44.53125 0.00000 1.70200 1.70200 12.40000 0.95100 0.36300 6.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
11.220 2324.00000 21.3000 -44.53125 0.00000 1.70200 1.70200 12.40000 0.95100 0.36300 6.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
11.230 2324.00000 21.3000 -44.53125 0.00000 1.70200 1.70200 12.40000 0.95100 0.36300 6.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
11.240 2324.00000 21.3000 -44.53125 0.00000 1.70200 1.70200 12.40000 0.95100 0.36300 6.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
11.250 2324.00000 21.3000 -44.53125 0.00000 1.70200 1.70200 12.40000 0.95100 0.36300 6.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
11.260 2324.00000 21.3000 -44.53125 0.00000 1.70200 1.70200 12.40000 0.95100 0.36300 6.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
11.270 2324.00000 21.3000 -44.53125 0.00000 1.70200 1.70200 12.40000 0.95100 0.36300 6.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
11.280 2324.00000 21.3000 -44.53125 0.00000 1.70200 1.70200 12.40000 0.95100 0.36300 6.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
11.290 2324.00000 21.3000 -44.53125 0.00000 1.70200 1.70200 12.40000 0.95100 0.36300 6.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
11.300 2282.00000 21.8000 -44.53125 0.00000 1.73700 1.73700 12.90000 1.05300 0.36700 6.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
11.310 2282.00000 21.8000 -44.53125 0.00000 1.73700 1.73700 12.90000 1.05300 0.36700 6.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
11.320 2282.00000 21.8000 -44.53125 0.00000 1.73700 1.73700 12.90000 1.05300 0.36700 6.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
11.330 2282.00000 21.8000 -44.53125 0.00000 1.73700 1.73700 12.90000 1.05300 0.36700 6.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
11.340 2282.00000 21.8000 -44.53125 0.00000 1.73700 1.73700 12.90000 1.05300 0.36700 6.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
11.350 2305.00000 22.1000 -44.53125 0.00000 1.67300 1.67300 12.40000 1.05300 0.36700 6.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
11.360 2305.00000 22.1000 -44.53125 0.00000 1.67300 1.67300 12.40000 1.05300 0.36700 6.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
11.370 2305.00000 22.1000 -44.53125 0.00000 1.67300 1.67300 12.40000 1.05300 0.36700 6.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
11.380 2305.00000 22.1000 -44.53125 0.00000 1.67300 1.67300 12.40000 1.05300 0.36700 6.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
11.390 2305.00000 22.1000 -44.53125 0.00000 1.67300 1.67300 12.40000 1.05300 0.36700 6.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
11.400 2308.00000 22.0000 -44.53125 0.00000 1.73100 1.73100 11.80000 1.05300 0.36700 6.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
11.410 2308.00000 22.0000 -44.53125 0.00000 1.73100 1.73100 11.80000 1.05300 0.36700 6.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
11.420 2308.00000 22.0000 -44.53125 0.00000 1.73100 1.73100 11.80000 1.05300 0.36700 6.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
11.430 2308.00000 22.0000 -44.53125 0.00000 1.73100 1.73100 11.80000 1.05300 0.36700 6.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
11.440 2308.00000 22.0000 -44.53125 0.00000 1.73100 1.73100 11.80000 1.05300 0.36700 6.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
11.450 2287.00000 21.5000 -44.53125 0.00000 1.64900 1.64900 13.00000 1.05300 0.36700 5.90000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
11.460 2287.00000 21.5000 -44.53125 0.00000 1.64900 1.64900 13.00000 1.05300 0.36700 5.90000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
11.470 2287.00000 21.5000 -44.53125 0.00000 1.64900 1.64900 13.00000 1.05300 0.36700 5.90000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
11.480 2287.00000 21.5000 -44.53125 0.00000 1.64900 1.64900 13.00000 1.05300 0.36700 5.90000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
11.490 2287.00000 21.5000 -44.53125 0.00000 1.64900 1.64900 13.00000 1.05300 0.36700 5.90000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
11.500 2300.00000 21.5000 -44.53125 0.00000 1.64400 1.64400 12.60000 0.96700 0.40500 6.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
11.510 2300.00000 21.5000 -44.53125 0.00000 1.64400 1.64400 12.60000 0.96700 0.40500 6.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
11.520 2300.00000 21.5000 -44.53125 0.00000 1.64400 1.64400 12.60000 0.96700 0.40500 6.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
11.530 2300.00000 21.5000 -44.53125 0.00000 1.64400 1.64400 12.60000 0.96700 0.40500 6.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
11.540 2300.00000 21.5000 -44.53125 0.00000 1.64400 1.64400 12.60000 0.96700 0.40500 6.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
11.550 2350.00000 22.0000 -44.53125 0.00000 1.67800 1.67800 13.60000 0.96700 0.40500 6.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
11.560 2350.00000 22.0000 -44.53125 0.00000 1.67800 1.67800 13.60000 0.96700 0.40500 6.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
11.570 2350.00000 22.0000 -44.53125 0.00000 1.67800 1.67800 13.60000 0.96700 0.40500 6.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
11.580 2350.00000 22.0000 -44.53125 0.00000 1.67800 1.67800 13.60000 0.96700 0.40500 6.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
11.590 2350.00000 22.0000 -44.53125 0.00000 1.67800 1.67800 13.60000 0.96700 0.40500 6.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
11.600 2285.00000 22.0000 -44.53125 0.00000 1.72500 1.72500 13.10000 0.96700 0.40500 5.90000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
11.610 2285.00000 22.0000 -44.53125 0.00000 1.72500 1.72500 13.10000 0.96700 0.40500 5.90000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
11.620 2285.00000 22.0000 -44.53125 0.00000 1.72500 1.72500 13.10000 0.96700 0.40500 5.90000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
11.630 2285.00000 22.0000 -44.53125 0.00000 1.72500 1.72500 13.10000 0.96700 0.40500 5.90000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
11.640 2285.00000 22.0000 -44.53125 0.00000 1.72500 1.72500 13.10000 0.96700 0.40500 5.90000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
11.650 2276.00000 22.1000 -44.53125 0.00000 1.71900 1.71900 13.00000 0.96700 0.40500 6.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
11.660 2276.00000 22.1000 -44.53125 0.00000 1.71900 1.71900 13.00000 0.96700 0.40500 6.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
11.670 2276.00000 22.1000 -44.53125 0.00000 1.71900 1.71900 13.00000 0.96700 0.40500 6.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
11.680 2276.00000 22.1000 -44.53125 0.00000 1.71900 1.71900 13.00000 0.96700 0.40500 6.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
11.690 2276.00000 22.1000 -44.53125 0.00000 1.71900 1.71900 13.00000 0.96700 0.40500 6.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
11.700 2348.00000 22.1000 -44.53125 0.00000 1.71300 1.71300 13.00000 0.90900 0.47200 5.90000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
11.710 2348.00000 22.1000 -44.53125 0.00000 1.71300 1.71300 13.00000 0.90900 0.47200 5.90000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
11.720 2348.00000 22.1000 -44.53125 0.00000 1.71300 1.71300 13.00000 0.90900 0.47200 5.90000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
11.730 2348.00000 22.1000 -44.53125 0.00000 1.71300 1.71300 13.00000 0.90900 0.47200 5.90000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
11.740 2348.00000 22.1000 -44.53125 0.00000 1.71300 1.71300 13.00000 0.90900 0.47200 5.90000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
11.750 2289.00000 22.0000 -44.53125 0.00000 1.74300 1.74300 12.90000 0.90900 0.47200 5.90000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
11.760 2289.00000 22.0000 -44.53125 0.00000 1.74300 1.74300 12.90000 0.90900 0.47200 5.90000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
11.770 2289.00000 22.0000 -44.53125 0.00000 1.74300 1.74300 12.90000 0.90900 0.47200 5.90000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
11.780 2289.00000 22.0000 -44.53125 0.00000 1.74300 1.74300 12.90000 0.90900 0.47200 5.90000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
11.790 2289.00000 22.0000 -44.53125 0.00000 1.74300 1.74300 12.90000 0.90900 0.47200 5.90000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
11.800 2278.00000 22.0000 -44.53125 0.00000 1.73100 1.73100 13.20000 0.90900 0.47200 6.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
11.810 2278.00000 22.0000 -44.53125 0.00000 1.73100 1.73100 13.20000 0.90900 0.47200 6.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
11.820 2278.00000 22.0000 -44.53125 0.00000 1.73100 1.73100 13.20000 0.90900 0.47200 6.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
11.830 2278.00000 22.0000 -44.53125 0.00000 1.73100 1.73100 13.20000 0.90900 0.47200 6.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
11.840 2278.00000 22.0000 -44.53125 0.00000 1.73100 1.73100 13.20000 0.90900 0.47200 6.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
11.850 2343.00000 22.0000 -44.53125 0.00000 1.73700 1.73700 13.20000 0.90900 0.47200 6.40000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
11.860 2343.00000 22.0000 -44.53125 0.00000 1.73700 1.73700 13.20000 0.90900 0.47200 6.40000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
11.870 2343.00000 22.0000 -44.53125 0.00000 1.73700 1.73700 13.20000 0.90900 0.47200 6.40000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
11.880 2343.00000 22.0000 -44.53125 0.00000 1.73700 1.73700 13.20000 0.90900 0.47200 6.40000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
11.890 2343.00000 22.0000 -44.53125 0.00000 1.73700 1.73700 13.20000 0.90900 0.47200 6.40000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
11.900 2343.00000 22.0000 -44.53125 0.00000 1.73700 1.73700 13.20000 0.90900 0.47200 6.40000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
11.910 2295.00000 22.0000 -44.53125 0.00000 1.73700 1.73700 13.00000 0.32200 0.49400 6.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
11.920 2295.00000 22.0000 -44.53125 0.00000 1.73700 1.73700 13.00000 0.32200 0.49400 6.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
11.930 2295.00000 22.0000 -44.53125 0.00000 1.73700 1.73700 13.00000 0.32200 0.49400 6.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
11.940 2295.00000 22.0000 -44.53125 0.00000 1.73700 1.73700 13.00000 0.32200 0.49400 6.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
11.950 2295.00000 22.0000 -44.53125 0.00000 1.73700 1.73700 13.00000 0.32200 0.49400 6.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
11.960 2275.00000 22.0000 -44.53125 0.00000 1.69600 1.69600 12.70000 0.32200 0.49400 6.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
11.970 2275.00000 22.0000 -44.53125 0.00000 1.69600 1.69600 12.70000 0.32200 0.49400 6.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
11.980 2275.00000 22.0000 -44.53125 0.00000 1.69600 1.69600 12.70000 0.32200 0.49400 6.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
11.990 2275.00000 22.0000 -44.53125 0.00000 1.69600 1.69600 12.70000 0.32200 0.49400 6.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
12.000 2275.00000 22.0000 -44.53125 0.00000 1.69600 1.69600 12.70000 0.32200 0.49400 6.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
12.010 2334.00000 21.8000 -44.53125 0.00000 1.70200 1.70200 13.40000 0.32200 0.49400 6.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
12.020 2334.00000 21.8000 -44.53125 0.00000 1.70200 1.70200 13.40000 0.32200 0.49400 6.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
12.030 2334.00000 21.8000 -44.53125 0.00000 1.70200 1.70200 13.40000 0.32200 0.49400 6.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
12.040 2334.00000 21.8000 -44.53125 0.00000 1.70200 1.70200 13.40000 0.32200 0.49400 6.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
12.050 2334.00000 21.8000 -44.53125 0.00000 1.70200 1.70200 13.40000 0.32200 0.49400 6.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
12.060 2307.00000 22.0000 -44.53125 0.00000 1.74800 1.74800 12.90000 0.33800 0.36000 6.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
12.070 2307.00000 22.0000 -44.53125 0.00000 1.74800 1.74800 12.90000 0.33800 0.36000 6.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
12.080 2307.00000 22.0000 -44.53125 0.00000 1.74800 1.74800 12.90000 0.33800 0.36000 6.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
12.090 2307.00000 22.0000 -44.53125 0.00000 1.74800 1.74800 12.90000 0.33800 0.36000 6.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
12.100 2307.00000 22.0000 -44.53125 0.00000 1.74800 1.74800 12.90000 0.33800 0.36000 6.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
12.110 2299.00000 22.1000 -44.53125 0.00000 1.67800 1.67800 12.60000 0.33800 0.36000 6.40000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
12.120 2299.00000 22.1000 -44.53125 0.00000 1.67800 1.67800 12.60000 0.33800 0.36000 6.40000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
12.130 2299.00000 22.1000 -44.53125 0.00000 1.67800 1.67800 12.60000 0.33800 0.36000 6.40000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
12.140 2299.00000 22.1000 -44.53125 0.00000 1.67800 1.67800 12.60000 0.33800 0.36000 6.40000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
12.150 2299.00000 22.1000 -44.53125 0.00000 1.67800 1.67800 12.60000 0.33800 0.36000 6.40000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
12.160 2280.00000 22.1000 -44.53125 0.00000 1.76000 1.76000 12.20000 0.33800 0.36000 6.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
12.170 2280.00000 22.1000 -44.53125 0.00000 1.76000 1.76000 12.20000 0.33800 0.36000 6.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
12.180 2280.00000 22.1000 -44.53125 0.00000 1.76000 1.76000 12.20000 0.33800 0.36000 6.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
12.190 2280.00000 22.1000 -44.53125 0.00000 1.76000 1.76000 12.20000 0.33800 0.36000 6.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
12.200 2280.00000 22.1000 -44.53125 0.00000 1.76000 1.76000 12.20000 0.33800 0.36000 6.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
12.210 2311.00000 22.0000 -44.53125 0.00000 1.70800 1.70800 13.60000 0.33800 0.36000 6.10000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
12.220 2311.00000 22.0000 -44.53125 0.00000 1.70800 1.70800 13.60000 0.33800 0.36000 6.10000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
12.230 2311.00000 22.0000 -44.53125 0.00000 1.70800 1.70800 13.60000 0.33800 0.36000 6.10000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
12.240 2311.00000 22.0000 -44.53125 0.00000 1.70800 1.70800 13.60000 0.33800 0.36000 6.10000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
12.250 2311.00000 22.0000 -44.53125 0.00000 1.70800 1.70800 13.60000 0.33800 0.36000 6.10000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
12.260 2314.00000 22.3000 -44.53125 0.00000 1.74800 1.74800 13.20000 0.37600 0.35100 6.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
12.270 2314.00000 22.3000 -44.53125 0.00000 1.74800 1.74800 13.20000 0.37600 0.35100 6.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
12.280 2314.00000 22.3000 -44.53125 0.00000 1.74800 1.74800 13.20000 0.37600 0.35100 6.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
12.290 2314.00000 22.3000 -44.53125 0.00000 1.74800 1.74800 13.20000 0.37600 0.35100 6.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
12.300 2314.00000 22.3000 -44.53125 0.00000 1.74800 1.74800 13.20000 0.37600 0.35100 6.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
12.310 2347.00000 22.4000 -44.53125 0.00000 1.76600 1.76600 13.50000 0.37600 0.35100 6.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
12.320 2347.00000 22.4000 -44.53125 0.00000 1.76600 1.76600 13.50000 0.37600 0.35100 6.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
12.330 2347.00000 22.4000 -44.53125 0.00000 1.76600 1.76600 13.50000 0.37600 0.35100 6.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
12.340 2347.00000 22.4000 -44.53125 0.00000 1.76600 1.76600 13.50000 0.37600 0.35100 6.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
12.350 2347.00000 22.4000 -44.53125 0.00000 1.76600 1.76600 13.50000 0.37600 0.35100 6.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
12.360 2297.00000 22.3000 -44.53125 0.00000 1.75400 1.75400 13.00000 0.37600 0.35100 6.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
12.370 2297.00000 22.3000 -44.53125 0.00000 1.75400 1.75400 13.00000 0.37600 0.35100 6.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
12.380 2297.00000 22.3000 -44.53125 0.00000 1.75400 1.75400 13.00000 0.37600 0.35100 6.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
12.390 2297.00000 22.3000 -44.53125 0.00000 1.75400 1.75400 13.00000 0.37600 0.35100 6.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
12.400 2297.00000 22.3000 -44.53125 0.00000 1.75400 1.75400 13.00000 0.37600 0.35100 6.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
12.410 2320.00000 22.4000 -44.53125 0.00000 1.78300 1.78300 13.40000 0.37600 0.35100 6.10000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
12.420 2320.00000 22.4000 -44.53125 0.00000 1.78300 1.78300 13.40000 0.37600 0.35100 6.10000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
12.430 2320.00000 22.4000 -44.53125 0.00000 1.78300 1.78300 13.40000 0.37600 0.35100 6.10000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
12.440 2320.00000 22.4000 -44.53125 0.00000 1.78300 1.78300 13.40000 0.37600 0.35100 6.10000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
12.450 2320.00000 22.4000 -44.53125 0.00000 1.78300 1.78300 13.40000 0.37600 0.35100 6.10000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
12.460 2361.00000 22.6000 -44.53125 0.00000 1.78300 1.78300 13.50000 0.57400 0.34700 6.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
12.470 2361.00000 22.6000 -44.53125 0.00000 1.78300 1.78300 13.50000 0.57400 0.34700 6.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
12.480 2361.00000 22.6000 -44.53125 0.00000 1.78300 1.78300 13.50000 0.57400 0.34700 6.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
12.490 2361.00000 22.6000 -44.53125 0.00000 1.78300 1.78300 13.50000 0.57400 0.34700 6.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
12.500 2361.00000 22.6000 -44.53125 0.00000 1.78300 1.78300 13.50000 0.57400 0.34700 6.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
12.510 2308.00000 23.0000 -44.53125 0.00000 1.84200 1.84200 12.80000 0.57400 0.34700 6.90000 1.00000 4.00000 4.00000 4.00000 5.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
12.520 2308.00000 23.0000 -44.53125 0.00000 1.84200 1.84200 12.80000 0.57400 0.34700 6.90000 1.00000 4.00000 4.00000 4.00000 5.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
12.530 2308.00000 23.0000 -44.53125 0.00000 1.84200 1.84200 12.80000 0.57400 0.34700 6.90000 1.00000 4.00000 4.00000 4.00000 5.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
12.540 2308.00000 23.0000 -44.53125 0.00000 1.84200 1.84200 12.80000 0.57400 0.34700 6.90000 1.00000 4.00000 4.00000 4.00000 5.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
12.550 2308.00000 23.0000 -44.53125 0.00000 1.84200 1.84200 12.80000 0.57400 0.34700 6.90000 1.00000 4.00000 4.00000 4.00000 5.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
12.560 2318.00000 23.3000 -44.53125 0.00000 1.85900 1.85900 12.30000 0.57400 0.34700 6.90000 1.00000 4.00000 4.00000 4.00000 5.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
12.570 2318.00000 23.3000 -44.53125 0.00000 1.85900 1.85900 12.30000 0.57400 0.34700 6.90000 1.00000 4.00000 4.00000 4.00000 5.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
12.580 2318.00000 23.3000 -44.53125 0.00000 1.85900 1.85900 12.30000 0.57400 0.34700 6.90000 1.00000 4.00000 4.00000 4.00000 5.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
12.590 2318.00000 23.3000 -44.53125 0.00000 1.85900 1.85900 12.30000 0.57400 0.34700 6.90000 1.00000 4.00000 4.00000 4.00000 5.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
12.600 2318.00000 23.3000 -44.53125 0.00000 1.85900 1.85900 12.30000 0.57400 0.34700 6.90000 1.00000 4.00000 4.00000 4.00000 5.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
12.610 2324.00000 23.9000 -44.53125 0.00000 1.92300 1.92300 12.90000 0.57400 0.34700 6.90000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
12.620 2324.00000 23.9000 -44.53125 0.00000 1.92300 1.92300 12.90000 0.57400 0.34700 6.90000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
12.630 2324.00000 23.9000 -44.53125 0.00000 1.92300 1.92300 12.90000 0.57400 0.34700 6.90000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
12.640 2324.00000 23.9000 -44.53125 0.00000 1.92300 1.92300 12.90000 0.57400 0.34700 6.90000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
12.650 2324.00000 23.9000 -44.53125 0.00000 1.92300 1.92300 12.90000 0.57400 0.34700 6.90000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
12.660 2354.00000 25.2000 -44.53125 0.00000 2.04000 2.04000 13.30000 1.04000 0.36700 7.50000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
12.670 2354.00000 25.2000 -44.53125 0.00000 2.04000 2.04000 13.30000 1.04000 0.36700 7.50000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
12.680 2354.00000 25.2000 -44.53125 0.00000 2.04000 2.04000 13.30000 1.04000 0.36700 7.50000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
12.690 2354.00000 25.2000 -44.53125 0.00000 2.04000 2.04000 13.30000 1.04000 0.36700 7.50000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
12.700 2354.00000 25.2000 -44.53125 0.00000 2.04000 2.04000 13.30000 1.04000 0.36700 7.50000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
12.710 2333.00000 26.2000 -44.53125 0.00000 2.12700 2.12700 13.10000 1.04000 0.36700 7.90000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
12.720 2333.00000 26.2000 -44.53125 0.00000 2.12700 2.12700 13.10000 1.04000 0.36700 7.90000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
12.730 2333.00000 26.2000 -44.53125 0.00000 2.12700 2.12700 13.10000 1.04000 0.36700 7.90000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
12.740 2333.00000 26.2000 -44.53125 0.00000 2.12700 2.12700 13.10000 1.04000 0.36700 7.90000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
12.750 2333.00000 26.2000 -44.53125 0.00000 2.12700 2.12700 13.10000 1.04000 0.36700 7.90000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
12.760 2398.00000 27.3000 -44.53125 0.00000 2.22600 2.22600 13.00000 1.04000 0.36700 8.30000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
12.770 2398.00000 27.3000 -44.53125 0.00000 2.22600 2.22600 13.00000 1.04000 0.36700 8.30000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
12.780 2398.00000 27.3000 -44.53125 0.00000 2.22600 2.22600 13.00000 1.04000 0.36700 8.30000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
12.790 2398.00000 27.3000 -44.53125 0.00000 2.22600 2.22600 13.00000 1.04000 0.36700 8.30000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
12.800 2398.00000 27.3000 -44.53125 0.00000 2.22600 2.22600 13.00000 1.04000 0.36700 8.30000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
12.810 2332.00000 29.0000 -44.53125 0.00000 2.34900 2.34900 13.10000 1.04000 0.36700 9.40000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
12.820 2332.00000 29.0000 -44.53125 0.00000 2.34900 2.34900 13.10000 1.04000 0.36700 9.40000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
12.830 2332.00000 29.0000 -44.53125 0.00000 2.34900 2.34900 13.10000 1.04000 0.36700 9.40000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
12.840 2332.00000 29.0000 -44.53125 0.00000 2.34900 2.34900 13.10000 1.04000 0.36700 9.40000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
12.850 2332.00000 29.0000 -44.53125 0.00000 2.34900 2.34900 13.10000 1.04000 0.36700 9.40000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
12.860 2323.00000 31.7000 -44.53125 0.00000 2.44800 2.44800 13.10000 0.47200 0.40500 10.70000 1.00000 7.00000 7.00000 6.00000 2.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
12.870 2323.00000 31.7000 -44.53125 0.00000 2.44800 2.44800 13.10000 0.47200 0.40500 10.70000 1.00000 7.00000 7.00000 6.00000 2.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
12.880 2323.00000 31.7000 -44.53125 0.00000 2.44800 2.44800 13.10000 0.47200 0.40500 10.70000 1.00000 7.00000 7.00000 6.00000 2.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
12.890 2323.00000 31.7000 -44.53125 0.00000 2.44800 2.44800 13.10000 0.47200 0.40500 10.70000 1.00000 7.00000 7.00000 6.00000 2.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
12.900 2323.00000 31.7000 -44.53125 0.00000 2.44800 2.44800 13.10000 0.47200 0.40500 10.70000 1.00000 7.00000 7.00000 6.00000 2.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
12.910 2349.00000 35.9000 -44.53125 0.00000 2.71000 2.71000 12.30000 0.47200 0.40500 11.90000 1.00000 2.00000 9.00000 8.00000 2.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
12.920 2349.00000 35.9000 -44.53125 0.00000 2.71000 2.71000 12.30000 0.47200 0.40500 11.90000 1.00000 2.00000 9.00000 8.00000 2.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
12.930 2349.00000 35.9000 -44.53125 0.00000 2.71000 2.71000 12.30000 0.47200 0.40500 11.90000 1.00000 2.00000 9.00000 8.00000 2.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
12.940 2349.00000 35.9000 -44.53125 0.00000 2.71000 2.71000 12.30000 0.47200 0.40500 11.90000 1.00000 2.00000 9.00000 8.00000 2.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
12.950 2349.00000 35.9000 -44.53125 0.00000 2.71000 2.71000 12.30000 0.47200 0.40500 11.90000 1.00000 2.00000 9.00000 8.00000 2.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
12.960 2408.00000 38.2000 -44.53125 0.00000 2.73400 2.73400 12.90000 0.47200 0.40500 13.00000 1.00000 8.00000 10.00000 2.00000 2.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
12.970 2408.00000 38.2000 -44.53125 0.00000 2.73400 2.73400 12.90000 0.47200 0.40500 13.00000 1.00000 8.00000 10.00000 2.00000 2.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
12.980 2408.00000 38.2000 -44.53125 0.00000 2.73400 2.73400 12.90000 0.47200 0.40500 13.00000 1.00000 8.00000 10.00000 2.00000 2.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
12.990 2408.00000 38.2000 -44.53125 0.00000 2.73400 2.73400 12.90000 0.47200 0.40500 13.00000 1.00000 8.00000 10.00000 2.00000 2.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
13.000 2408.00000 38.2000 -44.53125 0.00000 2.73400 2.73400 12.90000 0.47200 0.40500 13.00000 1.00000 8.00000 10.00000 2.00000 2.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
13.010 2377.00000 38.5000 -44.53125 0.00000 2.60500 2.60500 13.30000 0.47200 0.40500 13.00000 1.00000 10.00000 10.00000 2.00000 10.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
13.020 2377.00000 38.5000 -44.53125 0.00000 2.60500 2.60500 13.30000 0.47200 0.40500 13.00000 1.00000 10.00000 10.00000 2.00000 10.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
13.030 2377.00000 38.5000 -44.53125 0.00000 2.60500 2.60500 13.30000 0.47200 0.40500 13.00000 1.00000 10.00000 10.00000 2.00000 10.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
13.040 2377.00000 38.5000 -44.53125 0.00000 2.60500 2.60500 13.30000 0.47200 0.40500 13.00000 1.00000 10.00000 10.00000 2.00000 10.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
13.050 2377.00000 38.5000 -44.53125 0.00000 2.60500 2.60500 13.30000 0.47200 0.40500 13.00000 1.00000 10.00000 10.00000 2.00000 10.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
13.060 2405.00000 38.8000 -44.53125 0.00000 2.60500 2.60500 13.60000 1.08200 0.37300 14.30000 1.00000 10.00000 10.00000 10.00000 10.00000 0.00000 0.00000 15.8000 0.000 0.000 0.000 0.000
13.070 2405.00000 38.8000 -44.53125 0.00000 2.60500 2.60500 13.60000 1.08200 0.37300 14.30000 1.00000 10.00000 10.00000 10.00000 10.00000 0.00000 0.00000 15.8000 0.000 0.000 0.000 0.000
13.080 2405.00000 38.8000 -44.53125 0.00000 2.60500 2.60500 13.60000 1.08200 0.37300 14.30000 1.00000 10.00000 10.00000 10.00000 10.00000 0.00000 0.00000 15.8000 0.000 0.000 0.000 0.000
13.090 2405.00000 38.8000 -44.53125 0.00000 2.60500 2.60500 13.60000 1.08200 0.37300 14.30000 1.00000 10.00000 10.00000 10.00000 10.00000 0.00000 0.00000 15.8000 0.000 0.000 0.000 0.000
13.100 2405.00000 38.8000 -44.53125 0.00000 2.60500 2.60500 13.60000 1.08200 0.37300 14.30000 1.00000 10.00000 10.00000 10.00000 10.00000 0.00000 0.00000 15.8000 0.000 0.000 0.000 0.000
13.110 2385.00000 38.8000 -44.53125 0.00000 2.59400 2.59400 12.90000 1.08200 0.37300 13.60000 1.00000 9.00000 9.00000 9.00000 9.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
13.120 2385.00000 38.8000 -44.53125 0.00000 2.59400 2.59400 12.90000 1.08200 0.37300 13.60000 1.00000 9.00000 9.00000 9.00000 9.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
13.130 2385.00000 38.8000 -44.53125 0.00000 2.59400 2.59400 12.90000 1.08200 0.37300 13.60000 1.00000 9.00000 9.00000 9.00000 9.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
13.140 2385.00000 38.8000 -44.53125 0.00000 2.59400 2.59400 12.90000 1.08200 0.37300 13.60000 1.00000 9.00000 9.00000 9.00000 9.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
13.150 2385.00000 38.8000 -44.53125 0.00000 2.59400 2.59400 12.90000 1.08200 0.37300 13.60000 1.00000 9.00000 9.00000 9.00000 9.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
13.160 2421.00000 38.6000 -44.53125 0.00000 2.72800 2.72800 13.50000 1.08200 0.37300 13.60000 1.00000 9.00000 9.00000 10.00000 9.00000 0.00000 0.00000 13.1000 0.000 0.000 0.000 0.000
13.170 2421.00000 38.6000 -44.53125 0.00000 2.72800 2.72800 13.50000 1.08200 0.37300 13.60000 1.00000 9.00000 9.00000 10.00000 9.00000 0.00000 0.00000 13.1000 0.000 0.000 0.000 0.000
13.180 2421.00000 38.6000 -44.53125 0.00000 2.72800 2.72800 13.50000 1.08200 0.37300 13.60000 1.00000 9.00000 9.00000 10.00000 9.00000 0.00000 0.00000 13.1000 0.000 0.000 0.000 0.000
13.190 2421.00000 38.6000 -44.53125 0.00000 2.72800 2.72800 13.50000 1.08200 0.37300 13.60000 1.00000 9.00000 9.00000 10.00000 9.00000 0.00000 0.00000 13.1000 0.000 0.000 0.000 0.000
13.200 2421.00000 38.6000 -44.53125 0.00000 2.72800 2.72800 13.50000 1.08200 0.37300 13.60000 1.00000 9.00000 9.00000 10.00000 9.00000 0.00000 0.00000 13.1000 0.000 0.000 0.000 0.000
13.210 2470.00000 38.9000 -44.53125 0.00000 2.57600 2.57600 13.20000 1.08200 0.37300 14.00000 1.00000 10.00000 10.00000 10.00000 9.00000 0.00000 0.00000 13.1000 0.000 0.000 0.000 0.000
13.220 2470.00000 38.9000 -44.53125 0.00000 2.57600 2.57600 13.20000 1.08200 0.37300 14.00000 1.00000 10.00000 10.00000 10.00000 9.00000 0.00000 0.00000 13.1000 0.000 0.000 0.000 0.000
13.230 2470.00000 38.9000 -44.53125 0.00000 2.57600 2.57600 13.20000 1.08200 0.37300 14.00000 1.00000 10.00000 10.00000 10.00000 9.00000 0.00000 0.00000 13.1000 0.000 0.000 0.000 0.000
13.240 2470.00000 38.9000 -44.53125 0.00000 2.57600 2.57600 13.20000 1.08200 0.37300 14.00000 1.00000 10.00000 10.00000 10.00000 9.00000 0.00000 0.00000 13.1000 0.000 0.000 0.000 0.000
13.250 2470.00000 38.9000 -44.53125 0.00000 2.57600 2.57600 13.20000 1.08200 0.37300 14.00000 1.00000 10.00000 10.00000 10.00000 9.00000 0.00000 0.00000 13.1000 0.000 0.000 0.000 0.000
13.260 2427.00000 39.7000 -44.53125 0.00000 2.73400 2.73400 12.70000 1.07200 0.97900 14.30000 1.00000 9.00000 9.00000 10.00000 9.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
13.270 2427.00000 39.7000 -44.53125 0.00000 2.73400 2.73400 12.70000 1.07200 0.97900 14.30000 1.00000 9.00000 9.00000 10.00000 9.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
13.280 2427.00000 39.7000 -44.53125 0.00000 2.73400 2.73400 12.70000 1.07200 0.97900 14.30000 1.00000 9.00000 9.00000 10.00000 9.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
13.290 2427.00000 39.7000 -44.53125 0.00000 2.73400 2.73400 12.70000 1.07200 0.97900 14.30000 1.00000 9.00000 9.00000 10.00000 9.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
13.300 2427.00000 39.7000 -44.53125 0.00000 2.73400 2.73400 12.70000 1.07200 0.97900 14.30000 1.00000 9.00000 9.00000 10.00000 9.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
13.310 2439.00000 41.1000 -44.53125 0.00000 2.71600 2.71600 13.00000 1.07200 0.97900 14.00000 1.00000 9.00000 9.00000 10.00000 9.00000 0.00000 0.00000 13.4000 0.000 0.000 0.000 0.000
13.320 2439.00000 41.1000 -44.53125 0.00000 2.71600 2.71600 13.00000 1.07200 0.97900 14.00000 1.00000 9.00000 9.00000 10.00000 9.00000 0.00000 0.00000 13.4000 0.000 0.000 0.000 0.000
13.330 2439.00000 41.1000 -44.53125 0.00000 2.71600 2.71600 13.00000 1.07200 0.97900 14.00000 1.00000 9.00000 9.00000 10.00000 9.00000 0.00000 0.00000 13.4000 0.000 0.000 0.000 0.000
13.340 2439.00000 41.1000 -44.53125 0.00000 2.71600 2.71600 13.00000 1.07200 0.97900 14.00000 1.00000 9.00000 9.00000 10.00000 9.00000 0.00000 0.00000 13.4000 0.000 0.000 0.000 0.000
13.350 2439.00000 41.1000 -44.53125 0.00000 2.71600 2.71600 13.00000 1.07200 0.97900 14.00000 1.00000 9.00000 9.00000 10.00000 9.00000 0.00000 0.00000 13.4000 0.000 0.000 0.000 0.000
13.360 2533.00000 43.8000 -44.53125 0.00000 2.67500 2.67500 13.70000 1.07200 0.97900 15.10000 1.00000 10.00000 10.00000 10.00000 10.00000 0.00000 0.00000 13.4000 0.000 0.000 0.000 0.000
13.370 2533.00000 43.8000 -44.53125 0.00000 2.67500 2.67500 13.70000 1.07200 0.97900 15.10000 1.00000 10.00000 10.00000 10.00000 10.00000 0.00000 0.00000 13.4000 0.000 0.000 0.000 0.000
13.380 2533.00000 43.8000 -44.53125 0.00000 2.67500 2.67500 13.70000 1.07200 0.97900 15.10000 1.00000 10.00000 10.00000 10.00000 10.00000 0.00000 0.00000 13.4000 0.000 0.000 0.000 0.000
13.390 2533.00000 43.8000 -44.53125 0.00000 2.67500 2.67500 13.70000 1.07200 0.97900 15.10000 1.00000 10.00000 10.00000 10.00000 10.00000 0.00000 0.00000 13.4000 0.000 0.000 0.000 0.000
13.400 2533.00000 43.8000 -44.53125 0.00000 2.67500 2.67500 13.70000 1.07200 0.97900 15.10000 1.00000 10.00000 10.00000 10.00000 10.00000 0.00000 0.00000 13.4000 0.000 0.000 0.000 0.000
13.410 2487.00000 44.7000 -44.53125 0.00000 2.81500 2.81500 13.60000 1.07200 0.97900 14.60000 1.00000 10.00000 9.00000 9.00000 10.00000 0.00000 0.00000 13.4000 0.000 0.000 0.000 0.000
13.420 2487.00000 44.7000 -44.53125 0.00000 2.81500 2.81500 13.60000 1.07200 0.97900 14.60000 1.00000 10.00000 9.00000 9.00000 10.00000 0.00000 0.00000 13.4000 0.000 0.000 0.000 0.000
13.430 2487.00000 44.7000 -44.53125 0.00000 2.81500 2.81500 13.60000 1.07200 0.97900 14.60000 1.00000 10.00000 9.00000 9.00000 10.00000 0.00000 0.00000 13.4000 0.000 0.000 0.000 0.000
13.440 2487.00000 44.7000 -44.53125 0.00000 2.81500 2.81500 13.60000 1.07200 0.97900 14.60000 1.00000 10.00000 9.00000 9.00000 10.00000 0.00000 0.00000 13.4000 0.000 0.000 0.000 0.000
13.450 2487.00000 44.7000 -44.53125 0.00000 2.81500 2.81500 13.60000 1.07200 0.97900 14.60000 1.00000 10.00000 9.00000 9.00000 10.00000 0.00000 0.00000 13.4000 0.000 0.000 0.000 0.000
13.460 2478.00000 44.9000 -44.53125 0.00000 2.79200 2.79200 13.50000 1.06900 1.02400 14.30000 1.00000 10.00000 10.00000 10.00000 10.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
13.470 2478.00000 44.9000 -44.53125 0.00000 2.79200 2.79200 13.50000 1.06900 1.02400 14.30000 1.00000 10.00000 10.00000 10.00000 10.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
13.480 2478.00000 44.9000 -44.53125 0.00000 2.79200 2.79200 13.50000 1.06900 1.02400 14.30000 1.00000 10.00000 10.00000 10.00000 10.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
13.490 2478.00000 44.9000 -44.53125 0.00000 2.79200 2.79200 13.50000 1.06900 1.02400 14.30000 1.00000 10.00000 10.00000 10.00000 10.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
13.500 2478.00000 44.9000 -44.53125 0.00000 2.79200 2.79200 13.50000 1.06900 1.02400 14.30000 1.00000 10.00000 10.00000 10.00000 10.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
13.510 2506.00000 45.3000 -44.53125 0.00000 2.84400 2.84400 12.80000 1.06900 1.02400 14.50000 1.00000 10.00000 10.00000 10.00000 10.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
13.520 2506.00000 45.3000 -44.53125 0.00000 2.84400 2.84400 12.80000 1.06900 1.02400 14.50000 1.00000 10.00000 10.00000 10.00000 10.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
13.530 2506.00000 45.3000 -44.53125 0.00000 2.84400 2.84400 12.80000 1.06900 1.02400 14.50000 1.00000 10.00000 10.00000 10.00000 10.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
13.540 2506.00000 45.3000 -44.53125 0.00000 2.84400 2.84400 12.80000 1.06900 1.02400 14.50000 1.00000 10.00000 10.00000 10.00000 10.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
13.550 2506.00000 45.3000 -44.53125 0.00000 2.84400 2.84400 12.80000 1.06900 1.02400 14.50000 1.00000 10.00000 10.00000 10.00000 10.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
13.560 2525.00000 45.8000 -44.53125 0.00000 2.75100 2.75100 13.40000 1.06900 1.02400 14.30000 1.00000 10.00000 10.00000 10.00000 10.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
13.570 2525.00000 45.8000 -44.53125 0.00000 2.75100 2.75100 13.40000 1.06900 1.02400 14.30000 1.00000 10.00000 10.00000 10.00000 10.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
13.580 2525.00000 45.8000 -44.53125 0.00000 2.75100 2.75100 13.40000 1.06900 1.02400 14.30000 1.00000 10.00000 10.00000 10.00000 10.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
13.590 2525.00000 45.8000 -44.53125 0.00000 2.75100 2.75100 13.40000 1.06900 1.02400 14.30000 1.00000 10.00000 10.00000 10.00000 10.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
13.600 2525.00000 45.8000 -44.53125 0.00000 2.75100 2.75100 13.40000 1.06900 1.02400 14.30000 1.00000 10.00000 10.00000 10.00000 10.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
13.610 2531.00000 46.6000 -44.53125 0.00000 2.84400 2.84400 12.80000 1.06900 1.02400 14.50000 1.00000 10.00000 10.00000 10.00000 10.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
13.620 2531.00000 46.6000 -44.53125 0.00000 2.84400 2.84400 12.80000 1.06900 1.02400 14.50000 1.00000 10.00000 10.00000 10.00000 10.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
13.630 2531.00000 46.6000 -44.53125 0.00000 2.84400 2.84400 12.80000 1.06900 1.02400 14.50000 1.00000 10.00000 10.00000 10.00000 10.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
13.640 2531.00000 46.6000 -44.53125 0.00000 2.84400 2.84400 12.80000 1.06900 1.02400 14.50000 1.00000 10.00000 10.00000 10.00000 10.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
13.650 2531.00000 46.6000 -44.53125 0.00000 2.84400 2.84400 12.80000 1.06900 1.02400 14.50000 1.00000 10.00000 10.00000 10.00000 10.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
13.660 2562.00000 46.4000 -44.53125 0.00000 2.81500 2.81500 13.30000 1.07500 1.03700 14.60000 1.00000 10.00000 10.00000 10.00000 10.00000 0.00000 0.00000 13.8000 0.000 0.000 0.000 0.000
13.670 2562.00000 46.4000 -44.53125 0.00000 2.81500 2.81500 13.30000 1.07500 1.03700 14.60000 1.00000 10.00000 10.00000 10.00000 10.00000 0.00000 0.00000 13.8000 0.000 0.000 0.000 0.000
13.680 2562.00000 46.4000 -44.53125 0.00000 2.81500 2.81500 13.30000 1.07500 1.03700 14.60000 1.00000 10.00000 10.00000 10.00000 10.00000 0.00000 0.00000 13.8000 0.000 0.000 0.000 0.000
13.690 2562.00000 46.4000 -44.53125 0.00000 2.81500 2.81500 13.30000 1.07500 1.03700 14.60000 1.00000 10.00000 10.00000 10.00000 10.00000 0.00000 0.00000 13.8000 0.000 0.000 0.000 0.000
13.700 2562.00000 46.4000 -44.53125 0.00000 2.81500 2.81500 13.30000 1.07500 1.03700 14.60000 1.00000 10.00000 10.00000 10.00000 10.00000 0.00000 0.00000 13.8000 0.000 0.000 0.000 0.000
13.710 2539.00000 47.2000 -44.53125 0.00000 2.92000 2.92000 13.20000 1.07500 1.03700 15.00000 1.00000 10.00000 10.00000 10.00000 10.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
13.720 2539.00000 47.2000 -44.53125 0.00000 2.92000 2.92000 13.20000 1.07500 1.03700 15.00000 1.00000 10.00000 10.00000 10.00000 10.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
13.730 2539.00000 47.2000 -44.53125 0.00000 2.92000 2.92000 13.20000 1.07500 1.03700 15.00000 1.00000 10.00000 10.00000 10.00000 10.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
13.740 2539.00000 47.2000 -44.53125 0.00000 2.92000 2.92000 13.20000 1.07500 1.03700 15.00000 1.00000 10.00000 10.00000 10.00000 10.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
13.750 2539.00000 47.2000 -44.53125 0.00000 2.92000 2.92000 13.20000 1.07500 1.03700 15.00000 1.00000 10.00000 10.00000 10.00000 10.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
13.760 2565.00000 48.1000 -44.53125 0.00000 2.83300 2.83300 13.40000 1.07500 1.03700 14.60000 1.00000 10.00000 10.00000 10.00000 10.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
13.770 2565.00000 48.1000 -44.53125 0.00000 2.83300 2.83300 13.40000 1.07500 1.03700 14.60000 1.00000 10.00000 10.00000 10.00000 10.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
13.780 2565.00000 48.1000 -44.53125 0.00000 2.83300 2.83300 13.40000 1.07500 1.03700 14.60000 1.00000 10.00000 10.00000 10.00000 10.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
13.790 2565.00000 48.1000 -44.53125 0.00000 2.83300 2.83300 13.40000 1.07500 1.03700 14.60000 1.00000 10.00000 10.00000 10.00000 10.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
13.800 2565.00000 48.1000 -44.53125 0.00000 2.83300 2.83300 13.40000 1.07500 1.03700 14.60000 1.00000 10.00000 10.00000 10.00000 10.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
13.810 2614.00000 48.2000 -44.53125 0.00000 2.95500 2.95500 13.20000 1.07500 1.03700 15.00000 1.00000 11.00000 10.00000 11.00000 11.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
13.820 2614.00000 48.2000 -44.53125 0.00000 2.95500 2.95500 13.20000 1.07500 1.03700 15.00000 1.00000 11.00000 10.00000 11.00000 11.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
13.830 2614.00000 48.2000 -44.53125 0.00000 2.95500 2.95500 13.20000 1.07500 1.03700 15.00000 1.00000 11.00000 10.00000 11.00000 11.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
13.840 2614.00000 48.2000 -44.53125 0.00000 2.95500 2.95500 13.20000 1.07500 1.03700 15.00000 1.00000 11.00000 10.00000 11.00000 11.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
13.850 2614.00000 48.2000 -44.53125 0.00000 2.95500 2.95500 13.20000 1.07500 1.03700 15.00000 1.00000 11.00000 10.00000 11.00000 11.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
13.860 2614.00000 48.2000 -44.53125 0.00000 2.95500 2.95500 13.20000 1.07500 1.03700 15.00000 1.00000 11.00000 10.00000 11.00000 11.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
13.870 2614.00000 48.2000 -44.53125 0.00000 2.95500 2.95500 13.20000 1.07500 1.03700 15.00000 1.00000 11.00000 10.00000 11.00000 11.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
13.880 2583.00000 48.7000 -44.53125 0.00000 2.87400 2.87400 13.00000 1.07500 1.03400 14.90000 1.00000 12.00000 11.00000 11.00000 11.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
13.890 2583.00000 48.7000 -44.53125 0.00000 2.87400 2.87400 13.00000 1.07500 1.03400 14.90000 1.00000 12.00000 11.00000 11.00000 11.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
13.900 2583.00000 48.7000 -44.53125 0.00000 2.87400 2.87400 13.00000 1.07500 1.03400 14.90000 1.00000 12.00000 11.00000 11.00000 11.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
13.910 2583.00000 48.7000 -44.53125 0.00000 2.87400 2.87400 13.00000 1.07500 1.03400 14.90000 1.00000 12.00000 11.00000 11.00000 11.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
13.920 2583.00000 48.7000 -44.53125 0.00000 2.87400 2.87400 13.00000 1.07500 1.03400 14.90000 1.00000 12.00000 11.00000 11.00000 11.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
13.930 2602.00000 48.7000 -44.53125 0.00000 2.93200 2.93200 13.40000 1.07500 1.03400 15.10000 1.00000 12.00000 12.00000 12.00000 11.00000 0.00000 0.00000 13.8000 0.000 0.000 0.000 0.000
13.940 2602.00000 48.7000 -44.53125 0.00000 2.93200 2.93200 13.40000 1.07500 1.03400 15.10000 1.00000 12.00000 12.00000 12.00000 11.00000 0.00000 0.00000 13.8000 0.000 0.000 0.000 0.000
13.950 2602.00000 48.7000 -44.53125 0.00000 2.93200 2.93200 13.40000 1.07500 1.03400 15.10000 1.00000 12.00000 12.00000 12.00000 11.00000 0.00000 0.00000 13.8000 0.000 0.000 0.000 0.000
13.960 2602.00000 48.7000 -44.53125 0.00000 2.93200 2.93200 13.40000 1.07500 1.03400 15.10000 1.00000 12.00000 12.00000 12.00000 11.00000 0.00000 0.00000 13.8000 0.000 0.000 0.000 0.000
13.970 2602.00000 48.7000 -44.53125 0.00000 2.93200 2.93200 13.40000 1.07500 1.03400 15.10000 1.00000 12.00000 12.00000 12.00000 11.00000 0.00000 0.00000 13.8000 0.000 0.000 0.000 0.000
13.980 2618.00000 48.6000 -42.18750 -0.12500 2.96700 2.96700 12.70000 1.07500 1.03400 15.70000 1.00000 11.00000 11.00000 12.00000 11.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
13.990 2618.00000 48.6000 -42.18750 -0.12500 2.96700 2.96700 12.70000 1.07500 1.03400 15.70000 1.00000 11.00000 11.00000 12.00000 11.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
14.000 2618.00000 48.6000 -42.18750 -0.12500 2.96700 2.96700 12.70000 1.07500 1.03400 15.70000 1.00000 11.00000 11.00000 12.00000 11.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
14.010 2618.00000 48.6000 -42.18750 -0.12500 2.96700 2.96700 12.70000 1.07500 1.03400 15.70000 1.00000 11.00000 11.00000 12.00000 11.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
14.020 2618.00000 48.6000 -42.18750 -0.12500 2.96700 2.96700 12.70000 1.07500 1.03400 15.70000 1.00000 11.00000 11.00000 12.00000 11.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
14.030 2626.00000 49.0000 -44.53125 0.00000 2.94900 2.94900 12.80000 1.07500 1.03400 15.10000 1.00000 12.00000 12.00000 12.00000 12.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
14.040 2626.00000 49.0000 -44.53125 0.00000 2.94900 2.94900 12.80000 1.07500 1.03400 15.10000 1.00000 12.00000 12.00000 12.00000 12.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
14.050 2626.00000 49.0000 -44.53125 0.00000 2.94900 2.94900 12.80000 1.07500 1.03400 15.10000 1.00000 12.00000 12.00000 12.00000 12.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
14.060 2626.00000 49.0000 -44.53125 0.00000 2.94900 2.94900 12.80000 1.07500 1.03400 15.10000 1.00000 12.00000 12.00000 12.00000 12.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
14.070 2626.00000 49.0000 -44.53125 0.00000 2.94900 2.94900 12.80000 1.07500 1.03400 15.10000 1.00000 12.00000 12.00000 12.00000 12.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
14.080 2630.00000 49.0000 -43.75000 0.00000 3.02500 3.02500 13.80000 1.09800 1.06900 15.40000 1.00000 12.00000 12.00000 12.00000 12.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
14.090 2630.00000 49.0000 -43.75000 0.00000 3.02500 3.02500 13.80000 1.09800 1.06900 15.40000 1.00000 12.00000 12.00000 12.00000 12.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
14.100 2630.00000 49.0000 -43.75000 0.00000 3.02500 3.02500 13.80000 1.09800 1.06900 15.40000 1.00000 12.00000 12.00000 12.00000 12.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
14.110 2630.00000 49.0000 -43.75000 0.00000 3.02500 3.02500 13.80000 1.09800 1.06900 15.40000 1.00000 12.00000 12.00000 12.00000 12.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
14.120 2630.00000 49.0000 -43.75000 0.00000 3.02500 3.02500 13.80000 1.09800 1.06900 15.40000 1.00000 12.00000 12.00000 12.00000 12.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
14.130 2635.00000 49.2000 -42.18750 -0.12500 3.08300 3.08300 13.30000 1.09800 1.06900 15.80000 1.00000 12.00000 12.00000 13.00000 12.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
14.140 2635.00000 49.2000 -42.18750 -0.12500 3.08300 3.08300 13.30000 1.09800 1.06900 15.80000 1.00000 12.00000 12.00000 13.00000 12.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
14.150 2635.00000 49.2000 -42.18750 -0.12500 3.08300 3.08300 13.30000 1.09800 1.06900 15.80000 1.00000 12.00000 12.00000 13.00000 12.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
14.160 2635.00000 49.2000 -42.18750 -0.12500 3.08300 3.08300 13.30000 1.09800 1.06900 15.80000 1.00000 12.00000 12.00000 13.00000 12.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
14.170 2635.00000 49.2000 -42.18750 -0.12500 3.08300 3.08300 13.30000 1.09800 1.06900 15.80000 1.00000 12.00000 12.00000 13.00000 12.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
14.180 2715.00000 49.6000 -39.06250 -0.12500 2.98400 2.98400 13.50000 1.09800 1.06900 16.60000 1.00000 13.00000 12.00000 13.00000 13.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
14.190 2715.00000 49.6000 -39.06250 -0.12500 2.98400 2.98400 13.50000 1.09800 1.06900 16.60000 1.00000 13.00000 12.00000 13.00000 13.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
14.200 2715.00000 49.6000 -39.06250 -0.12500 2.98400 2.98400 13.50000 1.09800 1.06900 16.60000 1.00000 13.00000 12.00000 13.00000 13.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
14.210 2715.00000 49.6000 -39.06250 -0.12500 2.98400 2.98400 13.50000 1.09800 1.06900 16.60000 1.00000 13.00000 12.00000 13.00000 13.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
14.220 2715.00000 49.6000 -39.06250 -0.12500 2.98400 2.98400 13.50000 1.09800 1.06900 16.60000 1.00000 13.00000 12.00000 13.00000 13.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
14.230 2705.00000 50.5000 -42.18750 -0.12500 2.99000 2.99000 12.90000 1.09800 1.06900 15.60000 1.00000 12.00000 13.00000 12.00000 13.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
14.240 2705.00000 50.5000 -42.18750 -0.12500 2.99000 2.99000 12.90000 1.09800 1.06900 15.60000 1.00000 12.00000 13.00000 12.00000 13.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
14.250 2705.00000 50.5000 -42.18750 -0.12500 2.99000 2.99000 12.90000 1.09800 1.06900 15.60000 1.00000 12.00000 13.00000 12.00000 13.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
14.260 2705.00000 50.5000 -42.18750 -0.12500 2.99000 2.99000 12.90000 1.09800 1.06900 15.60000 1.00000 12.00000 13.00000 12.00000 13.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
14.270 2705.00000 50.5000 -42.18750 -0.12500 2.99000 2.99000 12.90000 1.09800 1.06900 15.60000 1.00000 12.00000 13.00000 12.00000 13.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
14.280 2700.00000 49.9000 -42.96875 -0.12500 3.04300 3.04300 13.20000 1.11000 1.09400 15.50000 1.00000 12.00000 13.00000 13.00000 12.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
14.290 2700.00000 49.9000 -42.96875 -0.12500 3.04300 3.04300 13.20000 1.11000 1.09400 15.50000 1.00000 12.00000 13.00000 13.00000 12.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
14.300 2700.00000 49.9000 -42.96875 -0.12500 3.04300 3.04300 13.20000 1.11000 1.09400 15.50000 1.00000 12.00000 13.00000 13.00000 12.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
14.310 2700.00000 49.9000 -42.96875 -0.12500 3.04300 3.04300 13.20000 1.11000 1.09400 15.50000 1.00000 12.00000 13.00000 13.00000 12.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
14.320 2700.00000 49.9000 -42.96875 -0.12500 3.04300 3.04300 13.20000 1.11000 1.09400 15.50000 1.00000 12.00000 13.00000 13.00000 12.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
14.330 2744.00000 50.1000 -42.18750 -0.12500 3.17700 3.17700 13.40000 1.11000 1.09400 15.70000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 12.0000 0.000 0.000 0.000 0.000
14.340 2744.00000 50.1000 -42.18750 -0.12500 3.17700 3.17700 13.40000 1.11000 1.09400 15.70000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 12.0000 0.000 0.000 0.000 0.000
14.350 2744.00000 50.1000 -42.18750 -0.12500 3.17700 3.17700 13.40000 1.11000 1.09400 15.70000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 12.0000 0.000 0.000 0.000 0.000
14.360 2744.00000 50.1000 -42.18750 -0.12500 3.17700 3.17700 13.40000 1.11000 1.09400 15.70000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 12.0000 0.000 0.000 0.000 0.000
14.370 2744.00000 50.1000 -42.18750 -0.12500 3.17700 3.17700 13.40000 1.11000 1.09400 15.70000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 12.0000 0.000 0.000 0.000 0.000
14.380 2756.00000 49.6000 -42.18750 -0.12500 3.20000 3.20000 13.40000 1.11000 1.09400 15.70000 1.00000 12.00000 13.00000 13.00000 13.00000 0.00000 0.00000 12.2000 0.000 0.000 0.000 0.000
14.390 2756.00000 49.6000 -42.18750 -0.12500 3.20000 3.20000 13.40000 1.11000 1.09400 15.70000 1.00000 12.00000 13.00000 13.00000 13.00000 0.00000 0.00000 12.2000 0.000 0.000 0.000 0.000
14.400 2756.00000 49.6000 -42.18750 -0.12500 3.20000 3.20000 13.40000 1.11000 1.09400 15.70000 1.00000 12.00000 13.00000 13.00000 13.00000 0.00000 0.00000 12.2000 0.000 0.000 0.000 0.000
14.410 2756.00000 49.6000 -42.18750 -0.12500 3.20000 3.20000 13.40000 1.11000 1.09400 15.70000 1.00000 12.00000 13.00000 13.00000 13.00000 0.00000 0.00000 12.2000 0.000 0.000 0.000 0.000
14.420 2756.00000 49.6000 -42.18750 -0.12500 3.20000 3.20000 13.40000 1.11000 1.09400 15.70000 1.00000 12.00000 13.00000 13.00000 13.00000 0.00000 0.00000 12.2000 0.000 0.000 0.000 0.000
14.430 2751.00000 50.1000 -41.40625 -0.25000 3.20600 3.20600 12.40000 1.11000 1.09400 16.10000 1.00000 12.00000 12.00000 12.00000 12.00000 0.00000 0.00000 12.0000 0.000 0.000 0.000 0.000
14.440 2751.00000 50.1000 -41.40625 -0.25000 3.20600 3.20600 12.40000 1.11000 1.09400 16.10000 1.00000 12.00000 12.00000 12.00000 12.00000 0.00000 0.00000 12.0000 0.000 0.000 0.000 0.000
14.450 2751.00000 50.1000 -41.40625 -0.25000 3.20600 3.20600 12.40000 1.11000 1.09400 16.10000 1.00000 12.00000 12.00000 12.00000 12.00000 0.00000 0.00000 12.0000 0.000 0.000 0.000 0.000
14.460 2751.00000 50.1000 -41.40625 -0.25000 3.20600 3.20600 12.40000 1.11000 1.09400 16.10000 1.00000 12.00000 12.00000 12.00000 12.00000 0.00000 0.00000 12.0000 0.000 0.000 0.000 0.000
14.470 2751.00000 50.1000 -41.40625 -0.25000 3.20600 3.20600 12.40000 1.11000 1.09400 16.10000 1.00000 12.00000 12.00000 12.00000 12.00000 0.00000 0.00000 12.0000 0.000 0.000 0.000 0.000
14.480 2767.00000 50.1000 -40.62500 -0.25000 3.19400 3.19400 12.90000 1.08500 1.08200 16.10000 1.00000 12.00000 12.00000 12.00000 12.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
14.490 2767.00000 50.1000 -40.62500 -0.25000 3.19400 3.19400 12.90000 1.08500 1.08200 16.10000 1.00000 12.00000 12.00000 12.00000 12.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
14.500 2767.00000 50.1000 -40.62500 -0.25000 3.19400 3.19400 12.90000 1.08500 1.08200 16.10000 1.00000 12.00000 12.00000 12.00000 12.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
14.510 2767.00000 50.1000 -40.62500 -0.25000 3.19400 3.19400 12.90000 1.08500 1.08200 16.10000 1.00000 12.00000 12.00000 12.00000 12.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
14.520 2767.00000 50.1000 -40.62500 -0.25000 3.19400 3.19400 12.90000 1.08500 1.08200 16.10000 1.00000 12.00000 12.00000 12.00000 12.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
14.530 2777.00000 49.8000 -39.84375 -0.25000 3.20000 3.20000 12.00000 1.08500 1.08200 16.50000 1.00000 12.00000 13.00000 12.00000 12.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
14.540 2777.00000 49.8000 -39.84375 -0.25000 3.20000 3.20000 12.00000 1.08500 1.08200 16.50000 1.00000 12.00000 13.00000 12.00000 12.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
14.550 2777.00000 49.8000 -39.84375 -0.25000 3.20000 3.20000 12.00000 1.08500 1.08200 16.50000 1.00000 12.00000 13.00000 12.00000 12.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
14.560 2777.00000 49.8000 -39.84375 -0.25000 3.20000 3.20000 12.00000 1.08500 1.08200 16.50000 1.00000 12.00000 13.00000 12.00000 12.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
14.570 2777.00000 49.8000 -39.84375 -0.25000 3.20000 3.20000 12.00000 1.08500 1.08200 16.50000 1.00000 12.00000 13.00000 12.00000 12.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
14.580 2813.00000 49.9000 -39.84375 -0.25000 3.21800 3.21800 12.80000 1.08500 1.08200 16.40000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
14.590 2813.00000 49.9000 -39.84375 -0.25000 3.21800 3.21800 12.80000 1.08500 1.08200 16.40000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
14.600 2813.00000 49.9000 -39.84375 -0.25000 3.21800 3.21800 12.80000 1.08500 1.08200 16.40000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
14.610 2813.00000 49.9000 -39.84375 -0.25000 3.21800 3.21800 12.80000 1.08500 1.08200 16.40000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
14.620 2813.00000 49.9000 -39.84375 -0.25000 3.21800 3.21800 12.80000 1.08500 1.08200 16.40000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
14.630 2829.00000 49.9000 -39.84375 -0.25000 3.26400 3.26400 12.50000 1.08500 1.08200 16.50000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
14.640 2829.00000 49.9000 -39.84375 -0.25000 3.26400 3.26400 12.50000 1.08500 1.08200 16.50000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
14.650 2829.00000 49.9000 -39.84375 -0.25000 3.26400 3.26400 12.50000 1.08500 1.08200 16.50000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
14.660 2829.00000 49.9000 -39.84375 -0.25000 3.26400 3.26400 12.50000 1.08500 1.08200 16.50000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
14.670 2829.00000 49.9000 -39.84375 -0.25000 3.26400 3.26400 12.50000 1.08500 1.08200 16.50000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
14.680 2889.00000 49.5000 -40.62500 -0.25000 3.25300 3.25300 12.50000 1.07200 1.06600 16.20000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 12.9000 0.000 0.000 0.000 0.000
14.690 2889.00000 49.5000 -40.62500 -0.25000 3.25300 3.25300 12.50000 1.07200 1.06600 16.20000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 12.9000 0.000 0.000 0.000 0.000
14.700 2889.00000 49.5000 -40.62500 -0.25000 3.25300 3.25300 12.50000 1.07200 1.06600 16.20000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 12.9000 0.000 0.000 0.000 0.000
14.710 2889.00000 49.5000 -40.62500 -0.25000 3.25300 3.25300 12.50000 1.07200 1.06600 16.20000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 12.9000 0.000 0.000 0.000 0.000
14.720 2889.00000 49.5000 -40.62500 -0.25000 3.25300 3.25300 12.50000 1.07200 1.06600 16.20000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 12.9000 0.000 0.000 0.000 0.000
14.730 2838.00000 49.2000 -40.62500 -0.25000 3.27600 3.27600 12.80000 1.07200 1.06600 16.30000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
14.740 2838.00000 49.2000 -40.62500 -0.25000 3.27600 3.27600 12.80000 1.07200 1.06600 16.30000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
14.750 2838.00000 49.2000 -40.62500 -0.25000 3.27600 3.27600 12.80000 1.07200 1.06600 16.30000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
14.760 2838.00000 49.2000 -40.62500 -0.25000 3.27600 3.27600 12.80000 1.07200 1.06600 16.30000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
14.770 2838.00000 49.2000 -40.62500 -0.25000 3.27600 3.27600 12.80000 1.07200 1.06600 16.30000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
14.780 2892.00000 49.8000 -40.62500 -0.25000 3.36300 3.36300 13.70000 1.07200 1.06600 16.10000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
14.790 2892.00000 49.8000 -40.62500 -0.25000 3.36300 3.36300 13.70000 1.07200 1.06600 16.10000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
14.800 2892.00000 49.8000 -40.62500 -0.25000 3.36300 3.36300 13.70000 1.07200 1.06600 16.10000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
14.810 2892.00000 49.8000 -40.62500 -0.25000 3.36300 3.36300 13.70000 1.07200 1.06600 16.10000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
14.820 2892.00000 49.8000 -40.62500 -0.25000 3.36300 3.36300 13.70000 1.07200 1.06600 16.10000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
14.830 2953.00000 49.5000 -39.84375 -0.25000 3.27600 3.27600 13.00000 1.07200 1.06600 16.40000 1.00000 14.00000 14.00000 14.00000 14.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
14.840 2953.00000 49.5000 -39.84375 -0.25000 3.27600 3.27600 13.00000 1.07200 1.06600 16.40000 1.00000 14.00000 14.00000 14.00000 14.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
14.850 2953.00000 49.5000 -39.84375 -0.25000 3.27600 3.27600 13.00000 1.07200 1.06600 16.40000 1.00000 14.00000 14.00000 14.00000 14.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
14.860 2953.00000 49.5000 -39.84375 -0.25000 3.27600 3.27600 13.00000 1.07200 1.06600 16.40000 1.00000 14.00000 14.00000 14.00000 14.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
14.870 2953.00000 49.5000 -39.84375 -0.25000 3.27600 3.27600 13.00000 1.07200 1.06600 16.40000 1.00000 14.00000 14.00000 14.00000 14.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
14.880 2901.00000 49.6000 -39.06250 -0.37500 3.24100 3.24100 13.20000 1.08800 1.05300 16.60000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
14.890 2901.00000 49.6000 -39.06250 -0.37500 3.24100 3.24100 13.20000 1.08800 1.05300 16.60000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
14.900 2901.00000 49.6000 -39.06250 -0.37500 3.24100 3.24100 13.20000 1.08800 1.05300 16.60000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
14.910 2901.00000 49.6000 -39.06250 -0.37500 3.24100 3.24100 13.20000 1.08800 1.05300 16.60000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
14.920 2901.00000 49.6000 -39.06250 -0.37500 3.24100 3.24100 13.20000 1.08800 1.05300 16.60000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
14.930 2993.00000 50.5000 -37.50000 -0.37500 3.31100 3.31100 13.70000 1.08800 1.05300 17.20000 1.00000 14.00000 14.00000 14.00000 14.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
14.940 2993.00000 50.5000 -37.50000 -0.37500 3.31100 3.31100 13.70000 1.08800 1.05300 17.20000 1.00000 14.00000 14.00000 14.00000 14.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
14.950 2993.00000 50.5000 -37.50000 -0.37500 3.31100 3.31100 13.70000 1.08800 1.05300 17.20000 1.00000 14.00000 14.00000 14.00000 14.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
14.960 2993.00000 50.5000 -37.50000 -0.37500 3.31100 3.31100 13.70000 1.08800 1.05300 17.20000 1.00000 14.00000 14.00000 14.00000 14.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
14.970 2993.00000 50.5000 -37.50000 -0.37500 3.31100 3.31100 13.70000 1.08800 1.05300 17.20000 1.00000 14.00000 14.00000 14.00000 14.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
14.980 2953.00000 49.8000 -38.28125 -0.37500 3.38700 3.38700 11.60000 1.08800 1.05300 16.90000 1.00000 14.00000 14.00000 13.00000 14.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
14.990 2953.00000 49.8000 -38.28125 -0.37500 3.38700 3.38700 11.60000 1.08800 1.05300 16.90000 1.00000 14.00000 14.00000 13.00000 14.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
15.000 2953.00000 49.8000 -38.28125 -0.37500 3.38700 3.38700 11.60000 1.08800 1.05300 16.90000 1.00000 14.00000 14.00000 13.00000 14.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
15.010 2953.00000 49.8000 -38.28125 -0.37500 3.38700 3.38700 11.60000 1.08800 1.05300 16.90000 1.00000 14.00000 14.00000 13.00000 14.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
15.020 2953.00000 49.8000 -38.28125 -0.37500 3.38700 3.38700 11.60000 1.08800 1.05300 16.90000 1.00000 14.00000 14.00000 13.00000 14.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
15.030 2961.00000 49.5000 -39.06250 -0.37500 3.37500 3.37500 12.80000 1.08800 1.05300 16.60000 1.00000 13.00000 13.00000 13.00000 14.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
15.040 2961.00000 49.5000 -39.06250 -0.37500 3.37500 3.37500 12.80000 1.08800 1.05300 16.60000 1.00000 13.00000 13.00000 13.00000 14.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
15.050 2961.00000 49.5000 -39.06250 -0.37500 3.37500 3.37500 12.80000 1.08800 1.05300 16.60000 1.00000 13.00000 13.00000 13.00000 14.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
15.060 2961.00000 49.5000 -39.06250 -0.37500 3.37500 3.37500 12.80000 1.08800 1.05300 16.60000 1.00000 13.00000 13.00000 13.00000 14.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
15.070 2961.00000 49.5000 -39.06250 -0.37500 3.37500 3.37500 12.80000 1.08800 1.05300 16.60000 1.00000 13.00000 13.00000 13.00000 14.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
15.080 2973.00000 49.5000 -38.28125 -0.37500 3.26400 3.26400 13.30000 1.05600 1.05300 17.00000 1.00000 13.00000 13.00000 14.00000 13.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
15.090 2973.00000 49.5000 -38.28125 -0.37500 3.26400 3.26400 13.30000 1.05600 1.05300 17.00000 1.00000 13.00000 13.00000 14.00000 13.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
15.100 2973.00000 49.5000 -38.28125 -0.37500 3.26400 3.26400 13.30000 1.05600 1.05300 17.00000 1.00000 13.00000 13.00000 14.00000 13.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
15.110 2973.00000 49.5000 -38.28125 -0.37500 3.26400 3.26400 13.30000 1.05600 1.05300 17.00000 1.00000 13.00000 13.00000 14.00000 13.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
15.120 2973.00000 49.5000 -38.28125 -0.37500 3.26400 3.26400 13.30000 1.05600 1.05300 17.00000 1.00000 13.00000 13.00000 14.00000 13.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
15.130 2989.00000 49.2000 -36.71875 -0.50000 3.35700 3.35700 11.80000 1.05600 1.05300 17.30000 1.00000 14.00000 14.00000 14.00000 14.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
15.140 2989.00000 49.2000 -36.71875 -0.50000 3.35700 3.35700 11.80000 1.05600 1.05300 17.30000 1.00000 14.00000 14.00000 14.00000 14.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
15.150 2989.00000 49.2000 -36.71875 -0.50000 3.35700 3.35700 11.80000 1.05600 1.05300 17.30000 1.00000 14.00000 14.00000 14.00000 14.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
15.160 2989.00000 49.2000 -36.71875 -0.50000 3.35700 3.35700 11.80000 1.05600 1.05300 17.30000 1.00000 14.00000 14.00000 14.00000 14.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
15.170 2989.00000 49.2000 -36.71875 -0.50000 3.35700 3.35700 11.80000 1.05600 1.05300 17.30000 1.00000 14.00000 14.00000 14.00000 14.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
15.180 3008.00000 49.3000 -38.28125 -0.37500 3.35700 3.35700 12.90000 1.05600 1.05300 16.90000 1.00000 14.00000 14.00000 14.00000 14.00000 0.00000 0.00000 13.4000 0.000 0.000 0.000 0.000
15.190 3008.00000 49.3000 -38.28125 -0.37500 3.35700 3.35700 12.90000 1.05600 1.05300 16.90000 1.00000 14.00000 14.00000 14.00000 14.00000 0.00000 0.00000 13.4000 0.000 0.000 0.000 0.000
15.200 3008.00000 49.3000 -38.28125 -0.37500 3.35700 3.35700 12.90000 1.05600 1.05300 16.90000 1.00000 14.00000 14.00000 14.00000 14.00000 0.00000 0.00000 13.4000 0.000 0.000 0.000 0.000
15.210 3008.00000 49.3000 -38.28125 -0.37500 3.35700 3.35700 12.90000 1.05600 1.05300 16.90000 1.00000 14.00000 14.00000 14.00000 14.00000 0.00000 0.00000 13.4000 0.000 0.000 0.000 0.000
15.220 3008.00000 49.3000 -38.28125 -0.37500 3.35700 3.35700 12.90000 1.05600 1.05300 16.90000 1.00000 14.00000 14.00000 14.00000 14.00000 0.00000 0.00000 13.4000 0.000 0.000 0.000 0.000
15.230 3026.00000 49.8000 -35.93750 -0.50000 3.42200 3.42200 12.60000 1.05600 1.05300 17.60000 1.00000 14.00000 13.00000 14.00000 14.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
15.240 3026.00000 49.8000 -35.93750 -0.50000 3.42200 3.42200 12.60000 1.05600 1.05300 17.60000 1.00000 14.00000 13.00000 14.00000 14.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
15.250 3026.00000 49.8000 -35.93750 -0.50000 3.42200 3.42200 12.60000 1.05600 1.05300 17.60000 1.00000 14.00000 13.00000 14.00000 14.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
15.260 3026.00000 49.8000 -35.93750 -0.50000 3.42200 3.42200 12.60000 1.05600 1.05300 17.60000 1.00000 14.00000 13.00000 14.00000 14.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
15.270 3026.00000 49.8000 -35.93750 -0.50000 3.42200 3.42200 12.60000 1.05600 1.05300 17.60000 1.00000 14.00000 13.00000 14.00000 14.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
15.280 3116.00000 49.5000 -38.28125 -0.37500 3.48600 3.48600 13.80000 1.04300 1.05000 17.00000 1.00000 15.00000 15.00000 14.00000 14.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
15.290 3116.00000 49.5000 -38.28125 -0.37500 3.48600 3.48600 13.80000 1.04300 1.05000 17.00000 1.00000 15.00000 15.00000 14.00000 14.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
15.300 3116.00000 49.5000 -38.28125 -0.37500 3.48600 3.48600 13.80000 1.04300 1.05000 17.00000 1.00000 15.00000 15.00000 14.00000 14.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
15.310 3116.00000 49.5000 -38.28125 -0.37500 3.48600 3.48600 13.80000 1.04300 1.05000 17.00000 1.00000 15.00000 15.00000 14.00000 14.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
15.320 3116.00000 49.5000 -38.28125 -0.37500 3.48600 3.48600 13.80000 1.04300 1.05000 17.00000 1.00000 15.00000 15.00000 14.00000 14.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
15.330 3077.00000 49.8000 -36.71875 -0.50000 3.43300 3.43300 12.70000 1.04300 1.05000 17.50000 1.00000 14.00000 14.00000 14.00000 14.00000 0.00000 0.00000 13.6000 0.000 0.000 0.000 0.000
15.340 3077.00000 49.8000 -36.71875 -0.50000 3.43300 3.43300 12.70000 1.04300 1.05000 17.50000 1.00000 14.00000 14.00000 14.00000 14.00000 0.00000 0.00000 13.6000 0.000 0.000 0.000 0.000
15.350 3077.00000 49.8000 -36.71875 -0.50000 3.43300 3.43300 12.70000 1.04300 1.05000 17.50000 1.00000 14.00000 14.00000 14.00000 14.00000 0.00000 0.00000 13.6000 0.000 0.000 0.000 0.000
15.360 3077.00000 49.8000 -36.71875 -0.50000 3.43300 3.43300 12.70000 1.04300 1.05000 17.50000 1.00000 14.00000 14.00000 14.00000 14.00000 0.00000 0.00000 13.6000 0.000 0.000 0.000 0.000
15.370 3077.00000 49.8000 -36.71875 -0.50000 3.43300 3.43300 12.70000 1.04300 1.05000 17.50000 1.00000 14.00000 14.00000 14.00000 14.00000 0.00000 0.00000 13.6000 0.000 0.000 0.000 0.000
15.380 3087.00000 49.6000 -37.50000 -0.50000 3.46200 3.46200 13.20000 1.04300 1.05000 17.00000 1.00000 14.00000 14.00000 14.00000 14.00000 0.00000 0.00000 13.6000 0.000 0.000 0.000 0.000
15.390 3087.00000 49.6000 -37.50000 -0.50000 3.46200 3.46200 13.20000 1.04300 1.05000 17.00000 1.00000 14.00000 14.00000 14.00000 14.00000 0.00000 0.00000 13.6000 0.000 0.000 0.000 0.000
15.400 3087.00000 49.6000 -37.50000 -0.50000 3.46200 3.46200 13.20000 1.04300 1.05000 17.00000 1.00000 14.00000 14.00000 14.00000 14.00000 0.00000 0.00000 13.6000 0.000 0.000 0.000 0.000
15.410 3087.00000 49.6000 -37.50000 -0.50000 3.46200 3.46200 13.20000 1.04300 1.05000 17.00000 1.00000 14.00000 14.00000 14.00000 14.00000 0.00000 0.00000 13.6000 0.000 0.000 0.000 0.000
15.420 3087.00000 49.6000 -37.50000 -0.50000 3.46200 3.46200 13.20000 1.04300 1.05000 17.00000 1.00000 14.00000 14.00000 14.00000 14.00000 0.00000 0.00000 13.6000 0.000 0.000 0.000 0.000
15.430 3131.00000 49.9000 -35.15625 -0.62500 3.50900 3.50900 12.90000 1.04300 1.05000 17.80000 1.00000 14.00000 15.00000 14.00000 14.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
15.440 3131.00000 49.9000 -35.15625 -0.62500 3.50900 3.50900 12.90000 1.04300 1.05000 17.80000 1.00000 14.00000 15.00000 14.00000 14.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
15.450 3131.00000 49.9000 -35.15625 -0.62500 3.50900 3.50900 12.90000 1.04300 1.05000 17.80000 1.00000 14.00000 15.00000 14.00000 14.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
15.460 3131.00000 49.9000 -35.15625 -0.62500 3.50900 3.50900 12.90000 1.04300 1.05000 17.80000 1.00000 14.00000 15.00000 14.00000 14.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
15.470 3131.00000 49.9000 -35.15625 -0.62500 3.50900 3.50900 12.90000 1.04300 1.05000 17.80000 1.00000 14.00000 15.00000 14.00000 14.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
15.480 3139.00000 49.8000 -37.50000 -0.50000 3.60200 3.60200 13.20000 1.03400 1.03400 17.20000 1.00000 15.00000 14.00000 15.00000 14.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
15.490 3139.00000 49.8000 -37.50000 -0.50000 3.60200 3.60200 13.20000 1.03400 1.03400 17.20000 1.00000 15.00000 14.00000 15.00000 14.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
15.500 3139.00000 49.8000 -37.50000 -0.50000 3.60200 3.60200 13.20000 1.03400 1.03400 17.20000 1.00000 15.00000 14.00000 15.00000 14.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
15.510 3139.00000 49.8000 -37.50000 -0.50000 3.60200 3.60200 13.20000 1.03400 1.03400 17.20000 1.00000 15.00000 14.00000 15.00000 14.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
15.520 3139.00000 49.8000 -37.50000 -0.50000 3.60200 3.60200 13.20000 1.03400 1.03400 17.20000 1.00000 15.00000 14.00000 15.00000 14.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
15.530 3156.00000 49.6000 -34.37500 -0.62500 3.57900 3.57900 12.70000 1.03400 1.03400 18.20000 1.00000 15.00000 14.00000 15.00000 15.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
15.540 3156.00000 49.6000 -34.37500 -0.62500 3.57900 3.57900 12.70000 1.03400 1.03400 18.20000 1.00000 15.00000 14.00000 15.00000 15.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
15.550 3156.00000 49.6000 -34.37500 -0.62500 3.57900 3.57900 12.70000 1.03400 1.03400 18.20000 1.00000 15.00000 14.00000 15.00000 15.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
15.560 3156.00000 49.6000 -34.37500 -0.62500 3.57900 3.57900 12.70000 1.03400 1.03400 18.20000 1.00000 15.00000 14.00000 15.00000 15.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
15.570 3156.00000 49.6000 -34.37500 -0.62500 3.57900 3.57900 12.70000 1.03400 1.03400 18.20000 1.00000 15.00000 14.00000 15.00000 15.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
15.580 3184.00000 49.3000 -35.15625 -0.62500 3.50900 3.50900 13.40000 1.03400 1.03400 17.80000 1.00000 15.00000 15.00000 15.00000 15.00000 0.00000 0.00000 14.0000 0.000 0.000 0.000 0.000
15.590 3184.00000 49.3000 -35.15625 -0.62500 3.50900 3.50900 13.40000 1.03400 1.03400 17.80000 1.00000 15.00000 15.00000 15.00000 15.00000 0.00000 0.00000 14.0000 0.000 0.000 0.000 0.000
15.600 3184.00000 49.3000 -35.15625 -0.62500 3.50900 3.50900 13.40000 1.03400 1.03400 17.80000 1.00000 15.00000 15.00000 15.00000 15.00000 0.00000 0.00000 14.0000 0.000 0.000 0.000 0.000
15.610 3184.00000 49.3000 -35.15625 -0.62500 3.50900 3.50900 13.40000 1.03400 1.03400 17.80000 1.00000 15.00000 15.00000 15.00000 15.00000 0.00000 0.00000 14.0000 0.000 0.000 0.000 0.000
15.620 3184.00000 49.3000 -35.15625 -0.62500 3.50900 3.50900 13.40000 1.03400 1.03400 17.80000 1.00000 15.00000 15.00000 15.00000 15.00000 0.00000 0.00000 14.0000 0.000 0.000 0.000 0.000
15.630 3254.00000 49.2000 -36.71875 -0.50000 3.60800 3.60800 13.40000 1.03400 1.03400 17.50000 1.00000 15.00000 15.00000 15.00000 15.00000 0.00000 0.00000 14.0000 0.000 0.000 0.000 0.000
15.640 3254.00000 49.2000 -36.71875 -0.50000 3.60800 3.60800 13.40000 1.03400 1.03400 17.50000 1.00000 15.00000 15.00000 15.00000 15.00000 0.00000 0.00000 14.0000 0.000 0.000 0.000 0.000
15.650 3254.00000 49.2000 -36.71875 -0.50000 3.60800 3.60800 13.40000 1.03400 1.03400 17.50000 1.00000 15.00000 15.00000 15.00000 15.00000 0.00000 0.00000 14.0000 0.000 0.000 0.000 0.000
15.660 3254.00000 49.2000 -36.71875 -0.50000 3.60800 3.60800 13.40000 1.03400 1.03400 17.50000 1.00000 15.00000 15.00000 15.00000 15.00000 0.00000 0.00000 14.0000 0.000 0.000 0.000 0.000
15.670 3254.00000 49.2000 -36.71875 -0.50000 3.60800 3.60800 13.40000 1.03400 1.03400 17.50000 1.00000 15.00000 15.00000 15.00000 15.00000 0.00000 0.00000 14.0000 0.000 0.000 0.000 0.000
15.680 3221.00000 49.6000 -34.37500 -0.75000 3.63100 3.63100 12.40000 1.02100 1.02400 18.20000 1.00000 15.00000 15.00000 15.00000 15.00000 0.00000 0.00000 14.1000 0.000 0.000 0.000 0.000
15.690 3221.00000 49.6000 -34.37500 -0.75000 3.63100 3.63100 12.40000 1.02100 1.02400 18.20000 1.00000 15.00000 15.00000 15.00000 15.00000 0.00000 0.00000 14.1000 0.000 0.000 0.000 0.000
15.700 3221.00000 49.6000 -34.37500 -0.75000 3.63100 3.63100 12.40000 1.02100 1.02400 18.20000 1.00000 15.00000 15.00000 15.00000 15.00000 0.00000 0.00000 14.1000 0.000 0.000 0.000 0.000
15.710 3221.00000 49.6000 -34.37500 -0.75000 3.63100 3.63100 12.40000 1.02100 1.02400 18.20000 1.00000 15.00000 15.00000 15.00000 15.00000 0.00000 0.00000 14.1000 0.000 0.000 0.000 0.000
15.720 3221.00000 49.6000 -34.37500 -0.75000 3.63100 3.63100 12.40000 1.02100 1.02400 18.20000 1.00000 15.00000 15.00000 15.00000 15.00000 0.00000 0.00000 14.1000 0.000 0.000 0.000 0.000
15.730 3295.00000 49.5000 -32.03125 -0.75000 3.59700 3.59700 12.70000 1.02100 1.02400 19.00000 1.00000 15.00000 15.00000 16.00000 15.00000 0.00000 0.00000 14.0000 0.000 0.000 0.000 0.000
15.740 3295.00000 49.5000 -32.03125 -0.75000 3.59700 3.59700 12.70000 1.02100 1.02400 19.00000 1.00000 15.00000 15.00000 16.00000 15.00000 0.00000 0.00000 14.0000 0.000 0.000 0.000 0.000
15.750 3295.00000 49.5000 -32.03125 -0.75000 3.59700 3.59700 12.70000 1.02100 1.02400 19.00000 1.00000 15.00000 15.00000 16.00000 15.00000 0.00000 0.00000 14.0000 0.000 0.000 0.000 0.000
15.760 3295.00000 49.5000 -32.03125 -0.75000 3.59700 3.59700 12.70000 1.02100 1.02400 19.00000 1.00000 15.00000 15.00000 16.00000 15.00000 0.00000 0.00000 14.0000 0.000 0.000 0.000 0.000
15.770 3295.00000 49.5000 -32.03125 -0.75000 3.59700 3.59700 12.70000 1.02100 1.02400 19.00000 1.00000 15.00000 15.00000 16.00000 15.00000 0.00000 0.00000 14.0000 0.000 0.000 0.000 0.000
15.780 3239.00000 48.9000 -35.15625 -0.62500 3.59100 3.59100 12.10000 1.02100 1.02400 18.00000 1.00000 15.00000 15.00000 15.00000 15.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
15.790 3239.00000 48.9000 -35.15625 -0.62500 3.59100 3.59100 12.10000 1.02100 1.02400 18.00000 1.00000 15.00000 15.00000 15.00000 15.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
15.800 3239.00000 48.9000 -35.15625 -0.62500 3.59100 3.59100 12.10000 1.02100 1.02400 18.00000 1.00000 15.00000 15.00000 15.00000 15.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
15.810 3239.00000 48.9000 -35.15625 -0.62500 3.59100 3.59100 12.10000 1.02100 1.02400 18.00000 1.00000 15.00000 15.00000 15.00000 15.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
15.820 3239.00000 48.9000 -35.15625 -0.62500 3.59100 3.59100 12.10000 1.02100 1.02400 18.00000 1.00000 15.00000 15.00000 15.00000 15.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
15.830 3350.00000 49.3000 -34.37500 -0.75000 3.67200 3.67200 12.90000 1.02100 1.02400 18.10000 1.00000 16.00000 16.00000 16.00000 16.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
15.840 3350.00000 49.3000 -34.37500 -0.75000 3.67200 3.67200 12.90000 1.02100 1.02400 18.10000 1.00000 16.00000 16.00000 16.00000 16.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
15.850 3350.00000 49.3000 -34.37500 -0.75000 3.67200 3.67200 12.90000 1.02100 1.02400 18.10000 1.00000 16.00000 16.00000 16.00000 16.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
15.860 3350.00000 49.3000 -34.37500 -0.75000 3.67200 3.67200 12.90000 1.02100 1.02400 18.10000 1.00000 16.00000 16.00000 16.00000 16.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
15.870 3350.00000 49.3000 -34.37500 -0.75000 3.67200 3.67200 12.90000 1.02100 1.02400 18.10000 1.00000 16.00000 16.00000 16.00000 16.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
15.880 3294.00000 48.7000 -35.15625 -0.75000 3.66600 3.66600 12.20000 0.99900 1.00500 17.80000 1.00000 16.00000 16.00000 15.00000 15.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
15.890 3294.00000 48.7000 -35.15625 -0.75000 3.66600 3.66600 12.20000 0.99900 1.00500 17.80000 1.00000 16.00000 16.00000 15.00000 15.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
15.900 3294.00000 48.7000 -35.15625 -0.75000 3.66600 3.66600 12.20000 0.99900 1.00500 17.80000 1.00000 16.00000 16.00000 15.00000 15.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
15.910 3294.00000 48.7000 -35.15625 -0.75000 3.66600 3.66600 12.20000 0.99900 1.00500 17.80000 1.00000 16.00000 16.00000 15.00000 15.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
15.920 3294.00000 48.7000 -35.15625 -0.75000 3.66600 3.66600 12.20000 0.99900 1.00500 17.80000 1.00000 16.00000 16.00000 15.00000 15.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
15.930 3410.00000 49.5000 -34.37500 -0.75000 3.77700 3.77700 12.50000 0.99900 1.00500 18.00000 1.00000 16.00000 16.00000 16.00000 16.00000 0.00000 0.00000 14.5000 0.000 0.000 0.000 0.000
15.940 3410.00000 49.5000 -34.37500 -0.75000 3.77700 3.77700 12.50000 0.99900 1.00500 18.00000 1.00000 16.00000 16.00000 16.00000 16.00000 0.00000 0.00000 14.5000 0.000 0.000 0.000 0.000
15.950 3410.00000 49.5000 -34.37500 -0.75000 3.77700 3.77700 12.50000 0.99900 1.00500 18.00000 1.00000 16.00000 16.00000 16.00000 16.00000 0.00000 0.00000 14.5000 0.000 0.000 0.000 0.000
15.960 3410.00000 49.5000 -34.37500 -0.75000 3.77700 3.77700 12.50000 0.99900 1.00500 18.00000 1.00000 16.00000 16.00000 16.00000 16.00000 0.00000 0.00000 14.5000 0.000 0.000 0.000 0.000
15.970 3410.00000 49.5000 -34.37500 -0.75000 3.77700 3.77700 12.50000 0.99900 1.00500 18.00000 1.00000 16.00000 16.00000 16.00000 16.00000 0.00000 0.00000 14.5000 0.000 0.000 0.000 0.000
15.980 3348.00000 48.9000 -33.59375 -0.75000 3.72500 3.72500 12.80000 0.99900 1.00500 18.40000 1.00000 16.00000 16.00000 16.00000 16.00000 0.00000 0.00000 14.4000 0.000 0.000 0.000 0.000
15.990 3348.00000 48.9000 -33.59375 -0.75000 3.72500 3.72500 12.80000 0.99900 1.00500 18.40000 1.00000 16.00000 16.00000 16.00000 16.00000 0.00000 0.00000 14.4000 0.000 0.000 0.000 0.000
16.000 3348.00000 48.9000 -33.59375 -0.75000 3.72500 3.72500 12.80000 0.99900 1.00500 18.40000 1.00000 16.00000 16.00000 16.00000 16.00000 0.00000 0.00000 14.4000 0.000 0.000 0.000 0.000
16.010 3348.00000 48.9000 -33.59375 -0.75000 3.72500 3.72500 12.80000 0.99900 1.00500 18.40000 1.00000 16.00000 16.00000 16.00000 16.00000 0.00000 0.00000 14.4000 0.000 0.000 0.000 0.000
16.020 3348.00000 48.9000 -33.59375 -0.75000 3.72500 3.72500 12.80000 0.99900 1.00500 18.40000 1.00000 16.00000 16.00000 16.00000 16.00000 0.00000 0.00000 14.4000 0.000 0.000 0.000 0.000
16.030 3431.00000 48.7000 -34.37500 -0.75000 3.81200 3.81200 13.00000 0.99900 1.00500 18.00000 1.00000 16.00000 16.00000 16.00000 17.00000 0.00000 0.00000 14.6000 0.000 0.000 0.000 0.000
16.040 3431.00000 48.7000 -34.37500 -0.75000 3.81200 3.81200 13.00000 0.99900 1.00500 18.00000 1.00000 16.00000 16.00000 16.00000 17.00000 0.00000 0.00000 14.6000 0.000 0.000 0.000 0.000
16.050 3431.00000 48.7000 -34.37500 -0.75000 3.81200 3.81200 13.00000 0.99900 1.00500 18.00000 1.00000 16.00000 16.00000 16.00000 17.00000 0.00000 0.00000 14.6000 0.000 0.000 0.000 0.000
16.060 3431.00000 48.7000 -34.37500 -0.75000 3.81200 3.81200 13.00000 0.99900 1.00500 18.00000 1.00000 16.00000 16.00000 16.00000 17.00000 0.00000 0.00000 14.6000 0.000 0.000 0.000 0.000
16.070 3431.00000 48.7000 -34.37500 -0.75000 3.81200 3.81200 13.00000 0.99900 1.00500 18.00000 1.00000 16.00000 16.00000 16.00000 17.00000 0.00000 0.00000 14.6000 0.000 0.000 0.000 0.000
16.080 3384.00000 48.6000 -33.59375 -0.87500 3.84100 3.84100 12.40000 0.98900 0.99500 18.60000 1.00000 16.00000 16.00000 16.00000 16.00000 0.00000 0.00000 14.4000 0.000 0.000 0.000 0.000
16.090 3384.00000 48.6000 -33.59375 -0.87500 3.84100 3.84100 12.40000 0.98900 0.99500 18.60000 1.00000 16.00000 16.00000 16.00000 16.00000 0.00000 0.00000 14.4000 0.000 0.000 0.000 0.000
16.100 3384.00000 48.6000 -33.59375 -0.87500 3.84100 3.84100 12.40000 0.98900 0.99500 18.60000 1.00000 16.00000 16.00000 16.00000 16.00000 0.00000 0.00000 14.4000 0.000 0.000 0.000 0.000
16.110 3384.00000 48.6000 -33.59375 -0.87500 3.84100 3.84100 12.40000 0.98900 0.99500 18.60000 1.00000 16.00000 16.00000 16.00000 16.00000 0.00000 0.00000 14.4000 0.000 0.000 0.000 0.000
16.120 3384.00000 48.6000 -33.59375 -0.87500 3.84100 3.84100 12.40000 0.98900 0.99500 18.60000 1.00000 16.00000 16.00000 16.00000 16.00000 0.00000 0.00000 14.4000 0.000 0.000 0.000 0.000
16.130 3476.00000 48.9000 -33.59375 -0.75000 3.82400 3.82400 11.40000 0.98900 0.99500 18.40000 1.00000 16.00000 17.00000 16.00000 17.00000 0.00000 0.00000 14.5000 0.000 0.000 0.000 0.000
16.140 3476.00000 48.9000 -33.59375 -0.75000 3.82400 3.82400 11.40000 0.98900 0.99500 18.40000 1.00000 16.00000 17.00000 16.00000 17.00000 0.00000 0.00000 14.5000 0.000 0.000 0.000 0.000
16.150 3476.00000 48.9000 -33.59375 -0.75000 3.82400 3.82400 11.40000 0.98900 0.99500 18.40000 1.00000 16.00000 17.00000 16.00000 17.00000 0.00000 0.00000 14.5000 0.000 0.000 0.000 0.000
16.160 3476.00000 48.9000 -33.59375 -0.75000 3.82400 3.82400 11.40000 0.98900 0.99500 18.40000 1.00000 16.00000 17.00000 16.00000 17.00000 0.00000 0.00000 14.5000 0.000 0.000 0.000 0.000
16.170 3476.00000 48.9000 -33.59375 -0.75000 3.82400 3.82400 11.40000 0.98900 0.99500 18.40000 1.00000 16.00000 17.00000 16.00000 17.00000 0.00000 0.00000 14.5000 0.000 0.000 0.000 0.000
16.180 3424.00000 49.0000 -33.59375 -0.87500 3.81800 3.81800 12.60000 0.98900 0.99500 18.50000 1.00000 17.00000 16.00000 16.00000 16.00000 0.00000 0.00000 14.5000 0.000 0.000 0.000 0.000
16.190 3424.00000 49.0000 -33.59375 -0.87500 3.81800 3.81800 12.60000 0.98900 0.99500 18.50000 1.00000 17.00000 16.00000 16.00000 16.00000 0.00000 0.00000 14.5000 0.000 0.000 0.000 0.000
16.200 3424.00000 49.0000 -33.59375 -0.87500 3.81800 3.81800 12.60000 0.98900 0.99500 18.50000 1.00000 17.00000 16.00000 16.00000 16.00000 0.00000 0.00000 14.5000 0.000 0.000 0.000 0.000
16.210 3424.00000 49.0000 -33.59375 -0.87500 3.81800 3.81800 12.60000 0.98900 0.99500 18.50000 1.00000 17.00000 16.00000 16.00000 16.00000 0.00000 0.00000 14.5000 0.000 0.000 0.000 0.000
16.220 3424.00000 49.0000 -33.59375 -0.87500 3.81800 3.81800 12.60000 0.98900 0.99500 18.50000 1.00000 17.00000 16.00000 16.00000 16.00000 0.00000 0.00000 14.5000 0.000 0.000 0.000 0.000
16.230 3414.00000 48.2000 -33.59375 -0.87500 3.74800 3.74800 12.60000 0.98900 0.99500 18.50000 1.00000 21.00000 21.00000 22.00000 21.00000 0.00000 0.00000 14.6000 0.000 0.000 0.000 0.000
16.240 3414.00000 48.2000 -33.59375 -0.87500 3.74800 3.74800 12.60000 0.98900 0.99500 18.50000 1.00000 21.00000 21.00000 22.00000 21.00000 0.00000 0.00000 14.6000 0.000 0.000 0.000 0.000
16.250 3414.00000 48.2000 -33.59375 -0.87500 3.74800 3.74800 12.60000 0.98900 0.99500 18.50000 1.00000 21.00000 21.00000 22.00000 21.00000 0.00000 0.00000 14.6000 0.000 0.000 0.000 0.000
16.260 3414.00000 48.2000 -33.59375 -0.87500 3.74800 3.74800 12.60000 0.98900 0.99500 18.50000 1.00000 21.00000 21.00000 22.00000 21.00000 0.00000 0.00000 14.6000 0.000 0.000 0.000 0.000
16.270 3414.00000 48.2000 -33.59375 -0.87500 3.74800 3.74800 12.60000 0.98900 0.99500 18.50000 1.00000 21.00000 21.00000 22.00000 21.00000 0.00000 0.00000 14.6000 0.000 0.000 0.000 0.000
16.280 3473.00000 47.2000 -32.81250 -0.87500 3.77700 3.77700 13.70000 0.82000 0.95100 18.80000 1.00000 21.00000 22.00000 21.00000 21.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
16.290 3473.00000 47.2000 -32.81250 -0.87500 3.77700 3.77700 13.70000 0.82000 0.95100 18.80000 1.00000 21.00000 22.00000 21.00000 21.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
16.300 3473.00000 47.2000 -32.81250 -0.87500 3.77700 3.77700 13.70000 0.82000 0.95100 18.80000 1.00000 21.00000 22.00000 21.00000 21.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
16.310 3473.00000 47.2000 -32.81250 -0.87500 3.77700 3.77700 13.70000 0.82000 0.95100 18.80000 1.00000 21.00000 22.00000 21.00000 21.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
16.320 3473.00000 47.2000 -32.81250 -0.87500 3.77700 3.77700 13.70000 0.82000 0.95100 18.80000 1.00000 21.00000 22.00000 21.00000 21.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
16.330 3646.00000 50.5000 -28.90625 -1.00000 3.91100 3.91100 13.10000 0.82000 0.95100 19.90000 1.00000 22.00000 22.00000 22.00000 22.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
16.340 3646.00000 50.5000 -28.90625 -1.00000 3.91100 3.91100 13.10000 0.82000 0.95100 19.90000 1.00000 22.00000 22.00000 22.00000 22.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
16.350 3646.00000 50.5000 -28.90625 -1.00000 3.91100 3.91100 13.10000 0.82000 0.95100 19.90000 1.00000 22.00000 22.00000 22.00000 22.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
16.360 3646.00000 50.5000 -28.90625 -1.00000 3.91100 3.91100 13.10000 0.82000 0.95100 19.90000 1.00000 22.00000 22.00000 22.00000 22.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
16.370 3646.00000 50.5000 -28.90625 -1.00000 3.91100 3.91100 13.10000 0.82000 0.95100 19.90000 1.00000 22.00000 22.00000 22.00000 22.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
16.380 3555.00000 49.2000 -32.03125 -1.00000 3.91100 3.91100 12.50000 0.82000 0.95100 19.10000 1.00000 22.00000 23.00000 22.00000 22.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
16.390 3555.00000 49.2000 -32.03125 -1.00000 3.91100 3.91100 12.50000 0.82000 0.95100 19.10000 1.00000 22.00000 23.00000 22.00000 22.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
16.400 3555.00000 49.2000 -32.03125 -1.00000 3.91100 3.91100 12.50000 0.82000 0.95100 19.10000 1.00000 22.00000 23.00000 22.00000 22.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
16.410 3555.00000 49.2000 -32.03125 -1.00000 3.91100 3.91100 12.50000 0.82000 0.95100 19.10000 1.00000 22.00000 23.00000 22.00000 22.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
16.420 3555.00000 49.2000 -32.03125 -1.00000 3.91100 3.91100 12.50000 0.82000 0.95100 19.10000 1.00000 22.00000 23.00000 22.00000 22.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
16.430 3503.00000 48.7000 -31.25000 -1.00000 3.86500 3.86500 12.60000 0.82000 0.95100 19.30000 1.00000 22.00000 22.00000 22.00000 22.00000 0.00000 0.00000 13.2000 0.000 0.000 0.000 0.000
16.440 3503.00000 48.7000 -31.25000 -1.00000 3.86500 3.86500 12.60000 0.82000 0.95100 19.30000 1.00000 22.00000 22.00000 22.00000 22.00000 0.00000 0.00000 13.2000 0.000 0.000 0.000 0.000
16.450 3503.00000 48.7000 -31.25000 -1.00000 3.86500 3.86500 12.60000 0.82000 0.95100 19.30000 1.00000 22.00000 22.00000 22.00000 22.00000 0.00000 0.00000 13.2000 0.000 0.000 0.000 0.000
16.460 3503.00000 48.7000 -31.25000 -1.00000 3.86500 3.86500 12.60000 0.82000 0.95100 19.30000 1.00000 22.00000 22.00000 22.00000 22.00000 0.00000 0.00000 13.2000 0.000 0.000 0.000 0.000
16.470 3503.00000 48.7000 -31.25000 -1.00000 3.86500 3.86500 12.60000 0.82000 0.95100 19.30000 1.00000 22.00000 22.00000 22.00000 22.00000 0.00000 0.00000 13.2000 0.000 0.000 0.000 0.000
16.480 3540.00000 48.6000 -28.12500 -1.25000 3.84700 3.84700 12.80000 1.08500 1.03700 20.00000 1.00000 23.00000 22.00000 22.00000 23.00000 0.00000 0.00000 13.2000 0.000 0.000 0.000 0.000
16.490 3540.00000 48.6000 -28.12500 -1.25000 3.84700 3.84700 12.80000 1.08500 1.03700 20.00000 1.00000 23.00000 22.00000 22.00000 23.00000 0.00000 0.00000 13.2000 0.000 0.000 0.000 0.000
16.500 3540.00000 48.6000 -28.12500 -1.25000 3.84700 3.84700 12.80000 1.08500 1.03700 20.00000 1.00000 23.00000 22.00000 22.00000 23.00000 0.00000 0.00000 13.2000 0.000 0.000 0.000 0.000
16.510 3540.00000 48.6000 -28.12500 -1.25000 3.84700 3.84700 12.80000 1.08500 1.03700 20.00000 1.00000 23.00000 22.00000 22.00000 23.00000 0.00000 0.00000 13.2000 0.000 0.000 0.000 0.000
16.520 3540.00000 48.6000 -28.12500 -1.25000 3.84700 3.84700 12.80000 1.08500 1.03700 20.00000 1.00000 23.00000 22.00000 22.00000 23.00000 0.00000 0.00000 13.2000 0.000 0.000 0.000 0.000
16.530 3599.00000 48.9000 -30.46875 -1.12500 3.95200 3.95200 13.40000 1.08500 1.03700 19.50000 1.00000 23.00000 23.00000 24.00000 23.00000 0.00000 0.00000 13.2000 0.000 0.000 0.000 0.000
16.540 3599.00000 48.9000 -30.46875 -1.12500 3.95200 3.95200 13.40000 1.08500 1.03700 19.50000 1.00000 23.00000 23.00000 24.00000 23.00000 0.00000 0.00000 13.2000 0.000 0.000 0.000 0.000
16.550 3599.00000 48.9000 -30.46875 -1.12500 3.95200 3.95200 13.40000 1.08500 1.03700 19.50000 1.00000 23.00000 23.00000 24.00000 23.00000 0.00000 0.00000 13.2000 0.000 0.000 0.000 0.000
16.560 3599.00000 48.9000 -30.46875 -1.12500 3.95200 3.95200 13.40000 1.08500 1.03700 19.50000 1.00000 23.00000 23.00000 24.00000 23.00000 0.00000 0.00000 13.2000 0.000 0.000 0.000 0.000
16.570 3599.00000 48.9000 -30.46875 -1.12500 3.95200 3.95200 13.40000 1.08500 1.03700 19.50000 1.00000 23.00000 23.00000 24.00000 23.00000 0.00000 0.00000 13.2000 0.000 0.000 0.000 0.000
16.580 3688.00000 48.7000 -29.68750 -1.12500 4.01600 4.01600 12.80000 1.08500 1.03700 19.70000 1.00000 25.00000 23.00000 23.00000 24.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
16.590 3688.00000 48.7000 -29.68750 -1.12500 4.01600 4.01600 12.80000 1.08500 1.03700 19.70000 1.00000 25.00000 23.00000 23.00000 24.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
16.600 3688.00000 48.7000 -29.68750 -1.12500 4.01600 4.01600 12.80000 1.08500 1.03700 19.70000 1.00000 25.00000 23.00000 23.00000 24.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
16.610 3650.00000 48.1000 -29.68750 -1.12500 3.97500 3.97500 12.90000 1.10700 1.08800 19.70000 1.00000 23.00000 25.00000 24.00000 23.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
16.620 3650.00000 48.1000 -29.68750 -1.12500 3.97500 3.97500 12.90000 1.10700 1.08800 19.70000 1.00000 23.00000 25.00000 24.00000 23.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
16.630 3650.00000 48.1000 -29.68750 -1.12500 3.97500 3.97500 12.90000 1.10700 1.08800 19.70000 1.00000 23.00000 25.00000 24.00000 23.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
16.640 3650.00000 48.1000 -29.68750 -1.12500 3.97500 3.97500 12.90000 1.10700 1.08800 19.70000 1.00000 23.00000 25.00000 24.00000 23.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
16.650 3650.00000 48.1000 -29.68750 -1.12500 3.97500 3.97500 12.90000 1.10700 1.08800 19.70000 1.00000 23.00000 25.00000 24.00000 23.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
16.660 3650.00000 48.1000 -29.68750 -1.12500 3.97500 3.97500 12.90000 1.10700 1.08800 19.70000 1.00000 23.00000 25.00000 24.00000 23.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
16.670 3650.00000 48.1000 -29.68750 -1.12500 3.97500 3.97500 12.90000 1.10700 1.08800 19.70000 1.00000 23.00000 25.00000 24.00000 23.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
16.680 3676.00000 48.7000 -28.90625 -1.12500 4.07500 4.07500 12.80000 1.10700 1.08800 19.90000 1.00000 24.00000 25.00000 24.00000 23.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
16.690 3676.00000 48.7000 -28.90625 -1.12500 4.07500 4.07500 12.80000 1.10700 1.08800 19.90000 1.00000 24.00000 25.00000 24.00000 23.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
16.700 3676.00000 48.7000 -28.90625 -1.12500 4.07500 4.07500 12.80000 1.10700 1.08800 19.90000 1.00000 24.00000 25.00000 24.00000 23.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
16.710 3676.00000 48.7000 -28.90625 -1.12500 4.07500 4.07500 12.80000 1.10700 1.08800 19.90000 1.00000 24.00000 25.00000 24.00000 23.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
16.720 3676.00000 48.7000 -28.90625 -1.12500 4.07500 4.07500 12.80000 1.10700 1.08800 19.90000 1.00000 24.00000 25.00000 24.00000 23.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
16.730 3708.00000 48.7000 -25.00000 -1.37500 4.05100 4.05100 12.70000 1.10700 1.08800 20.70000 1.00000 25.00000 25.00000 25.00000 25.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
16.740 3708.00000 48.7000 -25.00000 -1.37500 4.05100 4.05100 12.70000 1.10700 1.08800 20.70000 1.00000 25.00000 25.00000 25.00000 25.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
16.750 3708.00000 48.7000 -25.00000 -1.37500 4.05100 4.05100 12.70000 1.10700 1.08800 20.70000 1.00000 25.00000 25.00000 25.00000 25.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
16.760 3708.00000 48.7000 -25.00000 -1.37500 4.05100 4.05100 12.70000 1.10700 1.08800 20.70000 1.00000 25.00000 25.00000 25.00000 25.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
16.770 3708.00000 48.7000 -25.00000 -1.37500 4.05100 4.05100 12.70000 1.10700 1.08800 20.70000 1.00000 25.00000 25.00000 25.00000 25.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
16.780 3708.00000 48.7000 -25.00000 -1.37500 4.05100 4.05100 12.70000 1.10700 1.08800 20.70000 1.00000 25.00000 25.00000 25.00000 25.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
16.790 3708.00000 48.7000 -25.00000 -1.37500 4.05100 4.05100 12.70000 1.10700 1.08800 20.70000 1.00000 25.00000 25.00000 25.00000 25.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
16.800 3708.00000 48.7000 -25.00000 -1.37500 4.05100 4.05100 12.70000 1.10700 1.08800 20.70000 1.00000 25.00000 25.00000 25.00000 25.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
16.810 3708.00000 48.7000 -25.00000 -1.37500 4.05100 4.05100 12.70000 1.10700 1.08800 20.70000 1.00000 25.00000 25.00000 25.00000 25.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
16.820 3708.00000 48.7000 -25.00000 -1.37500 4.05100 4.05100 12.70000 1.10700 1.08800 20.70000 1.00000 25.00000 25.00000 25.00000 25.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
16.830 3774.00000 48.4000 -28.12500 -1.25000 4.06900 4.06900 11.90000 1.10700 1.08800 20.10000 1.00000 20.00000 17.00000 25.00000 26.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
16.840 3774.00000 48.4000 -28.12500 -1.25000 4.06900 4.06900 11.90000 1.10700 1.08800 20.10000 1.00000 20.00000 17.00000 25.00000 26.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
16.850 3774.00000 48.4000 -28.12500 -1.25000 4.06900 4.06900 11.90000 1.10700 1.08800 20.10000 1.00000 20.00000 17.00000 25.00000 26.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
16.860 3774.00000 48.4000 -28.12500 -1.25000 4.06900 4.06900 11.90000 1.10700 1.08800 20.10000 1.00000 20.00000 17.00000 25.00000 26.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
16.870 3774.00000 48.4000 -28.12500 -1.25000 4.06900 4.06900 11.90000 1.10700 1.08800 20.10000 1.00000 20.00000 17.00000 25.00000 26.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
16.880 3720.00000 49.0000 -17.96875 -1.37500 4.17900 4.17900 11.50000 1.12000 1.10400 22.20000 1.00000 20.00000 18.00000 18.00000 19.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
16.890 3720.00000 49.0000 -17.96875 -1.37500 4.17900 4.17900 11.50000 1.12000 1.10400 22.20000 1.00000 20.00000 18.00000 18.00000 19.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
16.900 3720.00000 49.0000 -17.96875 -1.37500 4.17900 4.17900 11.50000 1.12000 1.10400 22.20000 1.00000 20.00000 18.00000 18.00000 19.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
16.910 3720.00000 49.0000 -17.96875 -1.37500 4.17900 4.17900 11.50000 1.12000 1.10400 22.20000 1.00000 20.00000 18.00000 18.00000 19.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
16.920 3720.00000 49.0000 -17.96875 -1.37500 4.17900 4.17900 11.50000 1.12000 1.10400 22.20000 1.00000 20.00000 18.00000 18.00000 19.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
16.930 3893.00000 49.0000 -23.43750 -1.37500 4.16200 4.16200 13.30000 1.12000 1.10400 21.10000 1.00000 20.00000 19.00000 19.00000 20.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
16.940 3893.00000 49.0000 -23.43750 -1.37500 4.16200 4.16200 13.30000 1.12000 1.10400 21.10000 1.00000 20.00000 19.00000 19.00000 20.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
16.950 3893.00000 49.0000 -23.43750 -1.37500 4.16200 4.16200 13.30000 1.12000 1.10400 21.10000 1.00000 20.00000 19.00000 19.00000 20.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
16.960 3893.00000 49.0000 -23.43750 -1.37500 4.16200 4.16200 13.30000 1.12000 1.10400 21.10000 1.00000 20.00000 19.00000 19.00000 20.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
16.970 3893.00000 49.0000 -23.43750 -1.37500 4.16200 4.16200 13.30000 1.12000 1.10400 21.10000 1.00000 20.00000 19.00000 19.00000 20.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
16.980 3843.00000 48.1000 -28.12500 -1.25000 4.12700 4.12700 12.70000 1.12000 1.10400 20.10000 1.00000 19.00000 20.00000 21.00000 19.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
16.990 3843.00000 48.1000 -28.12500 -1.25000 4.12700 4.12700 12.70000 1.12000 1.10400 20.10000 1.00000 19.00000 20.00000 21.00000 19.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
17.000 3843.00000 48.1000 -28.12500 -1.25000 4.12700 4.12700 12.70000 1.12000 1.10400 20.10000 1.00000 19.00000 20.00000 21.00000 19.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
17.010 3843.00000 48.1000 -28.12500 -1.25000 4.12700 4.12700 12.70000 1.12000 1.10400 20.10000 1.00000 19.00000 20.00000 21.00000 19.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
17.020 3843.00000 48.1000 -28.12500 -1.25000 4.12700 4.12700 12.70000 1.12000 1.10400 20.10000 1.00000 19.00000 20.00000 21.00000 19.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
17.030 3906.00000 47.6000 -27.34375 -1.25000 4.13900 4.13900 13.60000 1.12000 1.10400 20.20000 1.00000 20.00000 20.00000 21.00000 20.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
17.040 3906.00000 47.6000 -27.34375 -1.25000 4.13900 4.13900 13.60000 1.12000 1.10400 20.20000 1.00000 20.00000 20.00000 21.00000 20.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
17.050 3906.00000 47.6000 -27.34375 -1.25000 4.13900 4.13900 13.60000 1.12000 1.10400 20.20000 1.00000 20.00000 20.00000 21.00000 20.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
17.060 3906.00000 47.6000 -27.34375 -1.25000 4.13900 4.13900 13.60000 1.12000 1.10400 20.20000 1.00000 20.00000 20.00000 21.00000 20.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
17.070 3906.00000 47.6000 -27.34375 -1.25000 4.13900 4.13900 13.60000 1.12000 1.10400 20.20000 1.00000 20.00000 20.00000 21.00000 20.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
17.080 3836.00000 46.9000 -27.34375 -1.25000 4.28400 4.28400 13.40000 1.06600 1.09100 20.30000 1.00000 20.00000 19.00000 19.00000 21.00000 0.00000 0.00000 12.2000 0.000 0.000 0.000 0.000
17.090 3836.00000 46.9000 -27.34375 -1.25000 4.28400 4.28400 13.40000 1.06600 1.09100 20.30000 1.00000 20.00000 19.00000 19.00000 21.00000 0.00000 0.00000 12.2000 0.000 0.000 0.000 0.000
17.100 3836.00000 46.9000 -27.34375 -1.25000 4.28400 4.28400 13.40000 1.06600 1.09100 20.30000 1.00000 20.00000 19.00000 19.00000 21.00000 0.00000 0.00000 12.2000 0.000 0.000 0.000 0.000
17.110 3836.00000 46.9000 -27.34375 -1.25000 4.28400 4.28400 13.40000 1.06600 1.09100 20.30000 1.00000 20.00000 19.00000 19.00000 21.00000 0.00000 0.00000 12.2000 0.000 0.000 0.000 0.000
17.120 3836.00000 46.9000 -27.34375 -1.25000 4.28400 4.28400 13.40000 1.06600 1.09100 20.30000 1.00000 20.00000 19.00000 19.00000 21.00000 0.00000 0.00000 12.2000 0.000 0.000 0.000 0.000
17.130 3861.00000 47.0000 -22.65625 -1.50000 4.23800 4.23800 14.00000 1.06600 1.09100 21.30000 1.00000 20.00000 20.00000 20.00000 21.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
17.140 3861.00000 47.0000 -22.65625 -1.50000 4.23800 4.23800 14.00000 1.06600 1.09100 21.30000 1.00000 20.00000 20.00000 20.00000 21.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
17.150 3861.00000 47.0000 -22.65625 -1.50000 4.23800 4.23800 14.00000 1.06600 1.09100 21.30000 1.00000 20.00000 20.00000 20.00000 21.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
17.160 3861.00000 47.0000 -22.65625 -1.50000 4.23800 4.23800 14.00000 1.06600 1.09100 21.30000 1.00000 20.00000 20.00000 20.00000 21.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
17.170 3861.00000 47.0000 -22.65625 -1.50000 4.23800 4.23800 14.00000 1.06600 1.09100 21.30000 1.00000 20.00000 20.00000 20.00000 21.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
17.180 3910.00000 47.6000 -19.53125 -1.37500 4.27900 4.27900 12.40000 1.06600 1.09100 21.80000 1.00000 20.00000 21.00000 21.00000 19.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
17.190 3910.00000 47.6000 -19.53125 -1.37500 4.27900 4.27900 12.40000 1.06600 1.09100 21.80000 1.00000 20.00000 21.00000 21.00000 19.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
17.200 3910.00000 47.6000 -19.53125 -1.37500 4.27900 4.27900 12.40000 1.06600 1.09100 21.80000 1.00000 20.00000 21.00000 21.00000 19.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
17.210 3910.00000 47.6000 -19.53125 -1.37500 4.27900 4.27900 12.40000 1.06600 1.09100 21.80000 1.00000 20.00000 21.00000 21.00000 19.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
17.220 3910.00000 47.6000 -19.53125 -1.37500 4.27900 4.27900 12.40000 1.06600 1.09100 21.80000 1.00000 20.00000 21.00000 21.00000 19.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
17.230 3901.00000 46.7000 -17.96875 -1.37500 4.31400 4.31400 13.20000 1.06600 1.09100 22.30000 1.00000 21.00000 20.00000 19.00000 22.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
17.240 3901.00000 46.7000 -17.96875 -1.37500 4.31400 4.31400 13.20000 1.06600 1.09100 22.30000 1.00000 21.00000 20.00000 19.00000 22.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
17.250 3901.00000 46.7000 -17.96875 -1.37500 4.31400 4.31400 13.20000 1.06600 1.09100 22.30000 1.00000 21.00000 20.00000 19.00000 22.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
17.260 3901.00000 46.7000 -17.96875 -1.37500 4.31400 4.31400 13.20000 1.06600 1.09100 22.30000 1.00000 21.00000 20.00000 19.00000 22.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
17.270 3901.00000 46.7000 -17.96875 -1.37500 4.31400 4.31400 13.20000 1.06600 1.09100 22.30000 1.00000 21.00000 20.00000 19.00000 22.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
17.280 3916.00000 46.9000 -18.75000 -1.50000 4.28400 4.28400 12.40000 0.96300 1.03700 22.10000 1.00000 19.00000 21.00000 22.00000 20.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
17.290 3916.00000 46.9000 -18.75000 -1.50000 4.28400 4.28400 12.40000 0.96300 1.03700 22.10000 1.00000 19.00000 21.00000 22.00000 20.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
17.300 3916.00000 46.9000 -18.75000 -1.50000 4.28400 4.28400 12.40000 0.96300 1.03700 22.10000 1.00000 19.00000 21.00000 22.00000 20.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
17.310 3916.00000 46.9000 -18.75000 -1.50000 4.28400 4.28400 12.40000 0.96300 1.03700 22.10000 1.00000 19.00000 21.00000 22.00000 20.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
17.320 3916.00000 46.9000 -18.75000 -1.50000 4.28400 4.28400 12.40000 0.96300 1.03700 22.10000 1.00000 19.00000 21.00000 22.00000 20.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
17.330 3980.00000 46.6000 -20.31250 -1.37500 4.33700 4.33700 13.40000 0.96300 1.03700 21.70000 1.00000 22.00000 19.00000 20.00000 21.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
17.340 3980.00000 46.6000 -20.31250 -1.37500 4.33700 4.33700 13.40000 0.96300 1.03700 21.70000 1.00000 22.00000 19.00000 20.00000 21.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
17.350 3980.00000 46.6000 -20.31250 -1.37500 4.33700 4.33700 13.40000 0.96300 1.03700 21.70000 1.00000 22.00000 19.00000 20.00000 21.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
17.360 3980.00000 46.6000 -20.31250 -1.37500 4.33700 4.33700 13.40000 0.96300 1.03700 21.70000 1.00000 22.00000 19.00000 20.00000 21.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
17.370 3980.00000 46.6000 -20.31250 -1.37500 4.33700 4.33700 13.40000 0.96300 1.03700 21.70000 1.00000 22.00000 19.00000 20.00000 21.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
17.380 4091.00000 46.7000 -25.00000 -1.37500 4.40700 4.40700 13.30000 0.96300 1.03700 20.70000 1.00000 21.00000 20.00000 23.00000 21.00000 0.00000 0.00000 14.6000 0.000 0.000 0.000 0.000
17.390 4091.00000 46.7000 -25.00000 -1.37500 4.40700 4.40700 13.30000 0.96300 1.03700 20.70000 1.00000 21.00000 20.00000 23.00000 21.00000 0.00000 0.00000 14.6000 0.000 0.000 0.000 0.000
17.400 4091.00000 46.7000 -25.00000 -1.37500 4.40700 4.40700 13.30000 0.96300 1.03700 20.70000 1.00000 21.00000 20.00000 23.00000 21.00000 0.00000 0.00000 14.6000 0.000 0.000 0.000 0.000
17.410 4091.00000 46.7000 -25.00000 -1.37500 4.40700 4.40700 13.30000 0.96300 1.03700 20.70000 1.00000 21.00000 20.00000 23.00000 21.00000 0.00000 0.00000 14.6000 0.000 0.000 0.000 0.000
17.420 4091.00000 46.7000 -25.00000 -1.37500 4.40700 4.40700 13.30000 0.96300 1.03700 20.70000 1.00000 21.00000 20.00000 23.00000 21.00000 0.00000 0.00000 14.6000 0.000 0.000 0.000 0.000
17.430 3998.00000 46.4000 -27.34375 -1.25000 4.35400 4.35400 13.40000 0.96300 1.03700 20.30000 1.00000 20.00000 21.00000 21.00000 20.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
17.440 3998.00000 46.4000 -27.34375 -1.25000 4.35400 4.35400 13.40000 0.96300 1.03700 20.30000 1.00000 20.00000 21.00000 21.00000 20.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
17.450 3998.00000 46.4000 -27.34375 -1.25000 4.35400 4.35400 13.40000 0.96300 1.03700 20.30000 1.00000 20.00000 21.00000 21.00000 20.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
17.460 3998.00000 46.4000 -27.34375 -1.25000 4.35400 4.35400 13.40000 0.96300 1.03700 20.30000 1.00000 20.00000 21.00000 21.00000 20.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
17.470 3998.00000 46.4000 -27.34375 -1.25000 4.35400 4.35400 13.40000 0.96300 1.03700 20.30000 1.00000 20.00000 21.00000 21.00000 20.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
17.480 4126.00000 46.9000 -27.34375 -1.50000 4.34300 4.34300 13.80000 0.98300 0.98900 20.20000 1.00000 22.00000 22.00000 20.00000 20.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
17.490 4126.00000 46.9000 -27.34375 -1.50000 4.34300 4.34300 13.80000 0.98300 0.98900 20.20000 1.00000 22.00000 22.00000 20.00000 20.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
17.500 4126.00000 46.9000 -27.34375 -1.50000 4.34300 4.34300 13.80000 0.98300 0.98900 20.20000 1.00000 22.00000 22.00000 20.00000 20.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
17.510 4126.00000 46.9000 -27.34375 -1.50000 4.34300 4.34300 13.80000 0.98300 0.98900 20.20000 1.00000 22.00000 22.00000 20.00000 20.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
17.520 4126.00000 46.9000 -27.34375 -1.50000 4.34300 4.34300 13.80000 0.98300 0.98900 20.20000 1.00000 22.00000 22.00000 20.00000 20.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
17.530 4154.00000 46.0000 -19.53125 -1.62500 4.34300 4.34300 12.80000 0.98300 0.98900 21.90000 1.00000 23.00000 20.00000 20.00000 20.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
17.540 4154.00000 46.0000 -19.53125 -1.62500 4.34300 4.34300 12.80000 0.98300 0.98900 21.90000 1.00000 23.00000 20.00000 20.00000 20.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
17.550 4154.00000 46.0000 -19.53125 -1.62500 4.34300 4.34300 12.80000 0.98300 0.98900 21.90000 1.00000 23.00000 20.00000 20.00000 20.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
17.560 4154.00000 46.0000 -19.53125 -1.62500 4.34300 4.34300 12.80000 0.98300 0.98900 21.90000 1.00000 23.00000 20.00000 20.00000 20.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
17.570 4154.00000 46.0000 -19.53125 -1.62500 4.34300 4.34300 12.80000 0.98300 0.98900 21.90000 1.00000 23.00000 20.00000 20.00000 20.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
17.580 4105.00000 46.1000 -17.96875 -1.50000 4.36600 4.36600 13.40000 0.98300 0.98900 22.30000 1.00000 22.00000 20.00000 20.00000 21.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
17.590 4105.00000 46.1000 -17.96875 -1.50000 4.36600 4.36600 13.40000 0.98300 0.98900 22.30000 1.00000 22.00000 20.00000 20.00000 21.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
17.600 4105.00000 46.1000 -17.96875 -1.50000 4.36600 4.36600 13.40000 0.98300 0.98900 22.30000 1.00000 22.00000 20.00000 20.00000 21.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
17.610 4105.00000 46.1000 -17.96875 -1.50000 4.36600 4.36600 13.40000 0.98300 0.98900 22.30000 1.00000 22.00000 20.00000 20.00000 21.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
17.620 4105.00000 46.1000 -17.96875 -1.50000 4.36600 4.36600 13.40000 0.98300 0.98900 22.30000 1.00000 22.00000 20.00000 20.00000 21.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
17.630 4200.00000 46.6000 -25.78125 -1.37500 4.38400 4.38400 13.30000 0.98300 0.98900 20.50000 1.00000 23.00000 20.00000 22.00000 21.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
17.640 4200.00000 46.6000 -25.78125 -1.37500 4.38400 4.38400 13.30000 0.98300 0.98900 20.50000 1.00000 23.00000 20.00000 22.00000 21.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
17.650 4200.00000 46.6000 -25.78125 -1.37500 4.38400 4.38400 13.30000 0.98300 0.98900 20.50000 1.00000 23.00000 20.00000 22.00000 21.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
17.660 4200.00000 46.6000 -25.78125 -1.37500 4.38400 4.38400 13.30000 0.98300 0.98900 20.50000 1.00000 23.00000 20.00000 22.00000 21.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
17.670 4200.00000 46.6000 -25.78125 -1.37500 4.38400 4.38400 13.30000 0.98300 0.98900 20.50000 1.00000 23.00000 20.00000 22.00000 21.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
17.680 4123.00000 46.6000 -21.87500 -1.50000 4.34900 4.34900 13.00000 0.77200 0.90000 21.40000 1.00000 23.00000 20.00000 20.00000 22.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
17.690 4123.00000 46.6000 -21.87500 -1.50000 4.34900 4.34900 13.00000 0.77200 0.90000 21.40000 1.00000 23.00000 20.00000 20.00000 22.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
17.700 4123.00000 46.6000 -21.87500 -1.50000 4.34900 4.34900 13.00000 0.77200 0.90000 21.40000 1.00000 23.00000 20.00000 20.00000 22.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
17.710 4123.00000 46.6000 -21.87500 -1.50000 4.34900 4.34900 13.00000 0.77200 0.90000 21.40000 1.00000 23.00000 20.00000 20.00000 22.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
17.720 4123.00000 46.6000 -21.87500 -1.50000 4.34900 4.34900 13.00000 0.77200 0.90000 21.40000 1.00000 23.00000 20.00000 20.00000 22.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
17.730 4226.00000 46.3000 -18.75000 -1.50000 4.37800 4.37800 12.70000 0.77200 0.90000 22.10000 1.00000 21.00000 20.00000 20.00000 23.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
17.740 4226.00000 46.3000 -18.75000 -1.50000 4.37800 4.37800 12.70000 0.77200 0.90000 22.10000 1.00000 21.00000 20.00000 20.00000 23.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
17.750 4226.00000 46.3000 -18.75000 -1.50000 4.37800 4.37800 12.70000 0.77200 0.90000 22.10000 1.00000 21.00000 20.00000 20.00000 23.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
17.760 4226.00000 46.3000 -18.75000 -1.50000 4.37800 4.37800 12.70000 0.77200 0.90000 22.10000 1.00000 21.00000 20.00000 20.00000 23.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
17.770 4226.00000 46.3000 -18.75000 -1.50000 4.37800 4.37800 12.70000 0.77200 0.90000 22.10000 1.00000 21.00000 20.00000 20.00000 23.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
17.780 4212.00000 46.3000 -27.34375 -1.50000 4.37800 4.37800 13.30000 0.77200 0.90000 20.20000 1.00000 21.00000 22.00000 20.00000 20.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
17.790 4212.00000 46.3000 -27.34375 -1.50000 4.37800 4.37800 13.30000 0.77200 0.90000 20.20000 1.00000 21.00000 22.00000 20.00000 20.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
17.800 4212.00000 46.3000 -27.34375 -1.50000 4.37800 4.37800 13.30000 0.77200 0.90000 20.20000 1.00000 21.00000 22.00000 20.00000 20.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
17.810 4212.00000 46.3000 -27.34375 -1.50000 4.37800 4.37800 13.30000 0.77200 0.90000 20.20000 1.00000 21.00000 22.00000 20.00000 20.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
17.820 4212.00000 46.3000 -27.34375 -1.50000 4.37800 4.37800 13.30000 0.77200 0.90000 20.20000 1.00000 21.00000 22.00000 20.00000 20.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
17.830 4212.00000 46.3000 -27.34375 -1.50000 4.37800 4.37800 13.30000 0.77200 0.90000 20.20000 1.00000 21.00000 22.00000 20.00000 20.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
17.840 4219.00000 46.6000 -26.56250 -1.50000 4.37200 4.37200 13.20000 0.77200 0.90000 20.40000 1.00000 22.00000 21.00000 22.00000 21.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
17.850 4219.00000 46.6000 -26.56250 -1.50000 4.37200 4.37200 13.20000 0.77200 0.90000 20.40000 1.00000 22.00000 21.00000 22.00000 21.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
17.860 4219.00000 46.6000 -26.56250 -1.50000 4.37200 4.37200 13.20000 0.77200 0.90000 20.40000 1.00000 22.00000 21.00000 22.00000 21.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
17.870 4219.00000 46.6000 -26.56250 -1.50000 4.37200 4.37200 13.20000 0.77200 0.90000 20.40000 1.00000 22.00000 21.00000 22.00000 21.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
17.880 4219.00000 46.6000 -26.56250 -1.50000 4.37200 4.37200 13.20000 0.77200 0.90000 20.40000 1.00000 22.00000 21.00000 22.00000 21.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
17.890 4281.00000 46.1000 -16.40625 -1.50000 4.41900 4.41900 13.70000 0.30900 0.75000 22.50000 1.00000 20.00000 21.00000 21.00000 23.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
17.900 4281.00000 46.1000 -16.40625 -1.50000 4.41900 4.41900 13.70000 0.30900 0.75000 22.50000 1.00000 20.00000 21.00000 21.00000 23.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
17.910 4281.00000 46.1000 -16.40625 -1.50000 4.41900 4.41900 13.70000 0.30900 0.75000 22.50000 1.00000 20.00000 21.00000 21.00000 23.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
17.920 4281.00000 46.1000 -16.40625 -1.50000 4.41900 4.41900 13.70000 0.30900 0.75000 22.50000 1.00000 20.00000 21.00000 21.00000 23.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
17.930 4281.00000 46.1000 -16.40625 -1.50000 4.41900 4.41900 13.70000 0.30900 0.75000 22.50000 1.00000 20.00000 21.00000 21.00000 23.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
17.940 4214.00000 46.3000 -28.12500 -1.50000 4.44800 4.44800 13.40000 0.30900 0.75000 20.10000 1.00000 22.00000 22.00000 20.00000 20.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
17.950 4214.00000 46.3000 -28.12500 -1.50000 4.44800 4.44800 13.40000 0.30900 0.75000 20.10000 1.00000 22.00000 22.00000 20.00000 20.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
17.960 4214.00000 46.3000 -28.12500 -1.50000 4.44800 4.44800 13.40000 0.30900 0.75000 20.10000 1.00000 22.00000 22.00000 20.00000 20.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
17.970 4214.00000 46.3000 -28.12500 -1.50000 4.44800 4.44800 13.40000 0.30900 0.75000 20.10000 1.00000 22.00000 22.00000 20.00000 20.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
17.980 4214.00000 46.3000 -28.12500 -1.50000 4.44800 4.44800 13.40000 0.30900 0.75000 20.10000 1.00000 22.00000 22.00000 20.00000 20.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
17.990 4371.00000 47.6000 -21.09375 -1.50000 4.56400 4.45000 13.10000 0.30900 0.75000 21.50000 1.00000 21.00000 21.00000 24.00000 22.00000 0.00000 0.00000 15.9000 0.000 0.000 0.000 0.000
18.000 4371.00000 47.6000 -21.09375 -1.50000 4.56400 4.45000 13.10000 0.30900 0.75000 21.50000 1.00000 21.00000 21.00000 24.00000 22.00000 0.00000 0.00000 15.9000 0.000 0.000 0.000 0.000
18.010 4371.00000 47.6000 -21.09375 -1.50000 4.56400 4.45000 13.10000 0.30900 0.75000 21.50000 1.00000 21.00000 21.00000 24.00000 22.00000 0.00000 0.00000 15.9000 0.000 0.000 0.000 0.000
18.020 4371.00000 47.6000 -21.09375 -1.50000 4.56400 4.45000 13.10000 0.30900 0.75000 21.50000 1.00000 21.00000 21.00000 24.00000 22.00000 0.00000 0.00000 15.9000 0.000 0.000 0.000 0.000
18.030 4371.00000 47.6000 -21.09375 -1.50000 4.56400 4.45000 13.10000 0.30900 0.75000 21.50000 1.00000 21.00000 21.00000 24.00000 22.00000 0.00000 0.00000 15.9000 0.000 0.000 0.000 0.000
18.040 4415.00000 47.5000 -12.50000 -1.62500 4.47700 4.45000 12.70000 0.30900 0.75000 23.40000 1.00000 23.00000 22.00000 21.00000 22.00000 0.00000 0.00000 15.8000 0.000 0.000 0.000 0.000
18.050 4415.00000 47.5000 -12.50000 -1.62500 4.47700 4.45000 12.70000 0.30900 0.75000 23.40000 1.00000 23.00000 22.00000 21.00000 22.00000 0.00000 0.00000 15.8000 0.000 0.000 0.000 0.000
18.060 4415.00000 47.5000 -12.50000 -1.62500 4.47700 4.45000 12.70000 0.30900 0.75000 23.40000 1.00000 23.00000 22.00000 21.00000 22.00000 0.00000 0.00000 15.8000 0.000 0.000 0.000 0.000
18.070 4415.00000 47.5000 -12.50000 -1.62500 4.47700 4.45000 12.70000 0.30900 0.75000 23.40000 1.00000 23.00000 22.00000 21.00000 22.00000 0.00000 0.00000 15.8000 0.000 0.000 0.000 0.000
18.080 4415.00000 47.5000 -12.50000 -1.62500 4.47700 4.45000 12.70000 0.30900 0.75000 23.40000 1.00000 23.00000 22.00000 21.00000 22.00000 0.00000 0.00000 15.8000 0.000 0.000 0.000 0.000
18.090 4331.00000 46.1000 -27.34375 -1.50000 4.40100 4.40100 12.20000 0.27700 0.32200 20.30000 1.00000 21.00000 22.00000 21.00000 23.00000 0.00000 0.00000 15.9000 0.000 0.000 0.000 0.000
18.100 4331.00000 46.1000 -27.34375 -1.50000 4.40100 4.40100 12.20000 0.27700 0.32200 20.30000 1.00000 21.00000 22.00000 21.00000 23.00000 0.00000 0.00000 15.9000 0.000 0.000 0.000 0.000
18.110 4331.00000 46.1000 -27.34375 -1.50000 4.40100 4.40100 12.20000 0.27700 0.32200 20.30000 1.00000 21.00000 22.00000 21.00000 23.00000 0.00000 0.00000 15.9000 0.000 0.000 0.000 0.000
18.120 4331.00000 46.1000 -27.34375 -1.50000 4.40100 4.40100 12.20000 0.27700 0.32200 20.30000 1.00000 21.00000 22.00000 21.00000 23.00000 0.00000 0.00000 15.9000 0.000 0.000 0.000 0.000
18.130 4331.00000 46.1000 -27.34375 -1.50000 4.40100 4.40100 12.20000 0.27700 0.32200 20.30000 1.00000 21.00000 22.00000 21.00000 23.00000 0.00000 0.00000 15.9000 0.000 0.000 0.000 0.000
18.140 4412.00000 44.9000 -25.78125 -1.37500 4.50600 4.45000 13.30000 0.27700 0.32200 20.60000 1.00000 21.00000 21.00000 21.00000 21.00000 0.00000 0.00000 15.9000 0.000 0.000 0.000 0.000
18.150 4412.00000 44.9000 -25.78125 -1.37500 4.50600 4.45000 13.30000 0.27700 0.32200 20.60000 1.00000 21.00000 21.00000 21.00000 21.00000 0.00000 0.00000 15.9000 0.000 0.000 0.000 0.000
18.160 4412.00000 44.9000 -25.78125 -1.37500 4.50600 4.45000 13.30000 0.27700 0.32200 20.60000 1.00000 21.00000 21.00000 21.00000 21.00000 0.00000 0.00000 15.9000 0.000 0.000 0.000 0.000
18.170 4412.00000 44.9000 -25.78125 -1.37500 4.50600 4.45000 13.30000 0.27700 0.32200 20.60000 1.00000 21.00000 21.00000 21.00000 21.00000 0.00000 0.00000 15.9000 0.000 0.000 0.000 0.000
18.180 4412.00000 44.9000 -25.78125 -1.37500 4.50600 4.45000 13.30000 0.27700 0.32200 20.60000 1.00000 21.00000 21.00000 21.00000 21.00000 0.00000 0.00000 15.9000 0.000 0.000 0.000 0.000
18.190 4378.00000 18.0000 -44.53125 -0.62500 2.57000 2.57000 13.40000 0.27700 0.32200 13.70000 1.00000 12.00000 13.00000 11.00000 7.00000 0.00000 0.00000 15.9000 0.000 0.000 0.000 0.000
18.200 4378.00000 18.0000 -44.53125 -0.62500 2.57000 2.57000 13.40000 0.27700 0.32200 13.70000 1.00000 12.00000 13.00000 11.00000 7.00000 0.00000 0.00000 15.9000 0.000 0.000 0.000 0.000
18.210 4378.00000 18.0000 -44.53125 -0.62500 2.57000 2.57000 13.40000 0.27700 0.32200 13.70000 1.00000 12.00000 13.00000 11.00000 7.00000 0.00000 0.00000 15.9000 0.000 0.000 0.000 0.000
18.220 4378.00000 18.0000 -44.53125 -0.62500 2.57000 2.57000 13.40000 0.27700 0.32200 13.70000 1.00000 12.00000 13.00000 11.00000 7.00000 0.00000 0.00000 15.9000 0.000 0.000 0.000 0.000
18.230 4378.00000 18.0000 -44.53125 -0.62500 2.57000 2.57000 13.40000 0.27700 0.32200 13.70000 1.00000 12.00000 13.00000 11.00000 7.00000 0.00000 0.00000 15.9000 0.000 0.000 0.000 0.000
18.240 4357.00000 15.2000 -44.53125 0.00000 1.64900 1.64900 13.80000 0.27700 0.32200 8.00000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 16.0000 0.000 0.000 0.000 0.000
18.250 4357.00000 15.2000 -44.53125 0.00000 1.64900 1.64900 13.80000 0.27700 0.32200 8.00000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 16.0000 0.000 0.000 0.000 0.000
18.260 4357.00000 15.2000 -44.53125 0.00000 1.64900 1.64900 13.80000 0.27700 0.32200 8.00000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 16.0000 0.000 0.000 0.000 0.000
18.270 4357.00000 15.2000 -44.53125 0.00000 1.64900 1.64900 13.80000 0.27700 0.32200 8.00000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 16.0000 0.000 0.000 0.000 0.000
18.280 4357.00000 15.2000 -44.53125 0.00000 1.64900 1.64900 13.80000 0.27700 0.32200 8.00000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 16.0000 0.000 0.000 0.000 0.000
18.290 4146.00000 15.2000 -44.53125 0.00000 1.66100 1.66100 12.10000 1.08200 0.29300 5.60000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
18.300 4146.00000 15.2000 -44.53125 0.00000 1.66100 1.66100 12.10000 1.08200 0.29300 5.60000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
18.310 4146.00000 15.2000 -44.53125 0.00000 1.66100 1.66100 12.10000 1.08200 0.29300 5.60000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
18.320 4146.00000 15.2000 -44.53125 0.00000 1.66100 1.66100 12.10000 1.08200 0.29300 5.60000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
18.330 4146.00000 15.2000 -44.53125 0.00000 1.66100 1.66100 12.10000 1.08200 0.29300 5.60000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
18.340 4010.00000 15.2000 -44.53125 0.00000 2.79200 2.79200 13.20000 1.08200 0.29300 4.70000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
18.350 4010.00000 15.2000 -44.53125 0.00000 2.79200 2.79200 13.20000 1.08200 0.29300 4.70000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
18.360 4010.00000 15.2000 -44.53125 0.00000 2.79200 2.79200 13.20000 1.08200 0.29300 4.70000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
18.370 4010.00000 15.2000 -44.53125 0.00000 2.79200 2.79200 13.20000 1.08200 0.29300 4.70000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
18.380 4010.00000 15.2000 -44.53125 0.00000 2.79200 2.79200 13.20000 1.08200 0.29300 4.70000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
18.390 4350.00000 15.1000 -44.53125 0.00000 2.87400 2.87400 13.60000 1.08200 0.29300 4.70000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
18.400 4350.00000 15.1000 -44.53125 0.00000 2.87400 2.87400 13.60000 1.08200 0.29300 4.70000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
18.410 4350.00000 15.1000 -44.53125 0.00000 2.87400 2.87400 13.60000 1.08200 0.29300 4.70000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
18.420 4350.00000 15.1000 -44.53125 0.00000 2.87400 2.87400 13.60000 1.08200 0.29300 4.70000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
18.430 4350.00000 15.1000 -44.53125 0.00000 2.87400 2.87400 13.60000 1.08200 0.29300 4.70000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
18.440 4180.00000 15.2000 -44.53125 0.00000 2.24400 2.24400 12.80000 1.08200 0.29300 4.30000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 10.8000 0.000 0.000 0.000 0.000
18.450 4180.00000 15.2000 -44.53125 0.00000 2.24400 2.24400 12.80000 1.08200 0.29300 4.30000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 10.8000 0.000 0.000 0.000 0.000
18.460 4180.00000 15.2000 -44.53125 0.00000 2.24400 2.24400 12.80000 1.08200 0.29300 4.30000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 10.8000 0.000 0.000 0.000 0.000
18.470 4180.00000 15.2000 -44.53125 0.00000 2.24400 2.24400 12.80000 1.08200 0.29300 4.30000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 10.8000 0.000 0.000 0.000 0.000
18.480 4180.00000 15.2000 -44.53125 0.00000 2.24400 2.24400 12.80000 1.08200 0.29300 4.30000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 10.8000 0.000 0.000 0.000 0.000
18.490 4085.00000 15.5000 -44.53125 0.00000 2.24400 2.24400 11.90000 0.94400 1.09100 4.10000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 10.7000 0.000 0.000 0.000 0.000
18.500 4085.00000 15.5000 -44.53125 0.00000 2.24400 2.24400 11.90000 0.94400 1.09100 4.10000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 10.7000 0.000 0.000 0.000 0.000
18.510 4085.00000 15.5000 -44.53125 0.00000 2.24400 2.24400 11.90000 0.94400 1.09100 4.10000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 10.7000 0.000 0.000 0.000 0.000
18.520 4085.00000 15.5000 -44.53125 0.00000 2.24400 2.24400 11.90000 0.94400 1.09100 4.10000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 10.7000 0.000 0.000 0.000 0.000
18.530 4085.00000 15.5000 -44.53125 0.00000 2.24400 2.24400 11.90000 0.94400 1.09100 4.10000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 10.7000 0.000 0.000 0.000 0.000
18.540 3996.00000 15.4000 -44.53125 0.00000 2.08100 2.08100 12.50000 0.94400 1.09100 4.10000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 10.7000 0.000 0.000 0.000 0.000
18.550 3996.00000 15.4000 -44.53125 0.00000 2.08100 2.08100 12.50000 0.94400 1.09100 4.10000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 10.7000 0.000 0.000 0.000 0.000
18.560 3996.00000 15.4000 -44.53125 0.00000 2.08100 2.08100 12.50000 0.94400 1.09100 4.10000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 10.7000 0.000 0.000 0.000 0.000
18.570 3996.00000 15.4000 -44.53125 0.00000 2.08100 2.08100 12.50000 0.94400 1.09100 4.10000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 10.7000 0.000 0.000 0.000 0.000
18.580 3996.00000 15.4000 -44.53125 0.00000 2.08100 2.08100 12.50000 0.94400 1.09100 4.10000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 10.7000 0.000 0.000 0.000 0.000
18.590 3915.00000 15.4000 -44.53125 0.00000 1.80100 1.80100 12.80000 0.94400 1.09100 4.00000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
18.600 3915.00000 15.4000 -44.53125 0.00000 1.80100 1.80100 12.80000 0.94400 1.09100 4.00000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
18.610 3915.00000 15.4000 -44.53125 0.00000 1.80100 1.80100 12.80000 0.94400 1.09100 4.00000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
18.620 3915.00000 15.4000 -44.53125 0.00000 1.80100 1.80100 12.80000 0.94400 1.09100 4.00000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
18.630 3915.00000 15.4000 -44.53125 0.00000 1.80100 1.80100 12.80000 0.94400 1.09100 4.00000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
18.640 3841.00000 15.4000 -44.53125 0.00000 1.91200 1.91200 13.10000 0.94400 1.09100 4.00000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
18.650 3841.00000 15.4000 -44.53125 0.00000 1.91200 1.91200 13.10000 0.94400 1.09100 4.00000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
18.660 3841.00000 15.4000 -44.53125 0.00000 1.91200 1.91200 13.10000 0.94400 1.09100 4.00000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
18.670 3841.00000 15.4000 -44.53125 0.00000 1.91200 1.91200 13.10000 0.94400 1.09100 4.00000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
18.680 3841.00000 15.4000 -44.53125 0.00000 1.91200 1.91200 13.10000 0.94400 1.09100 4.00000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
18.690 3752.00000 15.2000 -44.53125 0.00000 1.95200 1.95200 13.40000 0.98600 1.11000 4.10000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
18.700 3752.00000 15.2000 -44.53125 0.00000 1.95200 1.95200 13.40000 0.98600 1.11000 4.10000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
18.710 3752.00000 15.2000 -44.53125 0.00000 1.95200 1.95200 13.40000 0.98600 1.11000 4.10000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
18.720 3752.00000 15.2000 -44.53125 0.00000 1.95200 1.95200 13.40000 0.98600 1.11000 4.10000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
18.730 3752.00000 15.2000 -44.53125 0.00000 1.95200 1.95200 13.40000 0.98600 1.11000 4.10000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
18.740 3744.00000 15.4000 -44.53125 0.00000 2.21500 2.21500 12.50000 0.98600 1.11000 4.00000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
18.750 3744.00000 15.4000 -44.53125 0.00000 2.21500 2.21500 12.50000 0.98600 1.11000 4.00000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
18.760 3744.00000 15.4000 -44.53125 0.00000 2.21500 2.21500 12.50000 0.98600 1.11000 4.00000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
18.770 3744.00000 15.4000 -44.53125 0.00000 2.21500 2.21500 12.50000 0.98600 1.11000 4.00000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
18.780 3744.00000 15.4000 -44.53125 0.00000 2.21500 2.21500 12.50000 0.98600 1.11000 4.00000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
18.790 3602.00000 15.2000 -44.53125 0.00000 2.14500 2.14500 12.90000 0.98600 1.11000 4.10000 1.00000 4.00000 4.00000 4.00000 5.00000 0.00000 0.00000 13.1000 0.000 0.000 0.000 0.000
18.800 3602.00000 15.2000 -44.53125 0.00000 2.14500 2.14500 12.90000 0.98600 1.11000 4.10000 1.00000 4.00000 4.00000 4.00000 5.00000 0.00000 0.00000 13.1000 0.000 0.000 0.000 0.000
18.810 3602.00000 15.2000 -44.53125 0.00000 2.14500 2.14500 12.90000 0.98600 1.11000 4.10000 1.00000 4.00000 4.00000 4.00000 5.00000 0.00000 0.00000 13.1000 0.000 0.000 0.000 0.000
18.820 3602.00000 15.2000 -44.53125 0.00000 2.14500 2.14500 12.90000 0.98600 1.11000 4.10000 1.00000 4.00000 4.00000 4.00000 5.00000 0.00000 0.00000 13.1000 0.000 0.000 0.000 0.000
18.830 3602.00000 15.2000 -44.53125 0.00000 2.14500 2.14500 12.90000 0.98600 1.11000 4.10000 1.00000 4.00000 4.00000 4.00000 5.00000 0.00000 0.00000 13.1000 0.000 0.000 0.000 0.000
18.840 3608.00000 15.2000 -44.53125 0.00000 1.69600 1.69600 13.40000 0.98600 1.11000 4.00000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
18.850 3608.00000 15.2000 -44.53125 0.00000 1.69600 1.69600 13.40000 0.98600 1.11000 4.00000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
18.860 3608.00000 15.2000 -44.53125 0.00000 1.69600 1.69600 13.40000 0.98600 1.11000 4.00000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
18.870 3608.00000 15.2000 -44.53125 0.00000 1.69600 1.69600 13.40000 0.98600 1.11000 4.00000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
18.880 3608.00000 15.2000 -44.53125 0.00000 1.69600 1.69600 13.40000 0.98600 1.11000 4.00000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
18.890 3473.00000 15.2000 -44.53125 0.00000 2.04600 2.04600 13.40000 1.02700 1.05900 4.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 13.1000 0.000 0.000 0.000 0.000
18.900 3473.00000 15.2000 -44.53125 0.00000 2.04600 2.04600 13.40000 1.02700 1.05900 4.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 13.1000 0.000 0.000 0.000 0.000
18.910 3473.00000 15.2000 -44.53125 0.00000 2.04600 2.04600 13.40000 1.02700 1.05900 4.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 13.1000 0.000 0.000 0.000 0.000
18.920 3473.00000 15.2000 -44.53125 0.00000 2.04600 2.04600 13.40000 1.02700 1.05900 4.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 13.1000 0.000 0.000 0.000 0.000
18.930 3473.00000 15.2000 -44.53125 0.00000 2.04600 2.04600 13.40000 1.02700 1.05900 4.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 13.1000 0.000 0.000 0.000 0.000
18.940 3511.00000 15.2000 -44.53125 0.00000 2.06300 2.06300 13.40000 1.02700 1.05900 4.00000 1.00000 4.00000 5.00000 4.00000 5.00000 0.00000 0.00000 13.1000 0.000 0.000 0.000 0.000
18.950 3511.00000 15.2000 -44.53125 0.00000 2.06300 2.06300 13.40000 1.02700 1.05900 4.00000 1.00000 4.00000 5.00000 4.00000 5.00000 0.00000 0.00000 13.1000 0.000 0.000 0.000 0.000
18.960 3511.00000 15.2000 -44.53125 0.00000 2.06300 2.06300 13.40000 1.02700 1.05900 4.00000 1.00000 4.00000 5.00000 4.00000 5.00000 0.00000 0.00000 13.1000 0.000 0.000 0.000 0.000
18.970 3511.00000 15.2000 -44.53125 0.00000 2.06300 2.06300 13.40000 1.02700 1.05900 4.00000 1.00000 4.00000 5.00000 4.00000 5.00000 0.00000 0.00000 13.1000 0.000 0.000 0.000 0.000
18.980 3511.00000 15.2000 -44.53125 0.00000 2.06300 2.06300 13.40000 1.02700 1.05900 4.00000 1.00000 4.00000 5.00000 4.00000 5.00000 0.00000 0.00000 13.1000 0.000 0.000 0.000 0.000
18.990 3374.00000 15.4000 -44.53125 0.00000 1.94700 1.94700 12.70000 1.02700 1.05900 4.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
19.000 3374.00000 15.4000 -44.53125 0.00000 1.94700 1.94700 12.70000 1.02700 1.05900 4.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
19.010 3374.00000 15.4000 -44.53125 0.00000 1.94700 1.94700 12.70000 1.02700 1.05900 4.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
19.020 3374.00000 15.4000 -44.53125 0.00000 1.94700 1.94700 12.70000 1.02700 1.05900 4.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
19.030 3374.00000 15.4000 -44.53125 0.00000 1.94700 1.94700 12.70000 1.02700 1.05900 4.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
19.040 3322.00000 15.2000 -44.53125 0.00000 1.99300 1.99300 13.40000 1.02700 1.05900 4.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 12.7000 0.000 0.000 0.000 0.000
19.050 3322.00000 15.2000 -44.53125 0.00000 1.99300 1.99300 13.40000 1.02700 1.05900 4.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 12.7000 0.000 0.000 0.000 0.000
19.060 3322.00000 15.2000 -44.53125 0.00000 1.99300 1.99300 13.40000 1.02700 1.05900 4.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 12.7000 0.000 0.000 0.000 0.000
19.070 3322.00000 15.2000 -44.53125 0.00000 1.99300 1.99300 13.40000 1.02700 1.05900 4.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 12.7000 0.000 0.000 0.000 0.000
19.080 3322.00000 15.2000 -44.53125 0.00000 1.99300 1.99300 13.40000 1.02700 1.05900 4.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 12.7000 0.000 0.000 0.000 0.000
19.090 3186.00000 15.2000 -44.53125 0.00000 1.76600 1.76600 13.70000 1.07200 1.06600 4.10000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 12.7000 0.000 0.000 0.000 0.000
19.100 3186.00000 15.2000 -44.53125 0.00000 1.76600 1.76600 13.70000 1.07200 1.06600 4.10000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 12.7000 0.000 0.000 0.000 0.000
19.110 3186.00000 15.2000 -44.53125 0.00000 1.76600 1.76600 13.70000 1.07200 1.06600 4.10000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 12.7000 0.000 0.000 0.000 0.000
19.120 3186.00000 15.2000 -44.53125 0.00000 1.76600 1.76600 13.70000 1.07200 1.06600 4.10000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 12.7000 0.000 0.000 0.000 0.000
19.130 3186.00000 15.2000 -44.53125 0.00000 1.76600 1.76600 13.70000 1.07200 1.06600 4.10000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 12.7000 0.000 0.000 0.000 0.000
19.140 3040.00000 15.2000 -44.53125 0.00000 2.44200 2.44200 13.30000 1.07200 1.06600 4.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 12.7000 0.000 0.000 0.000 0.000
19.150 3040.00000 15.2000 -44.53125 0.00000 2.44200 2.44200 13.30000 1.07200 1.06600 4.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 12.7000 0.000 0.000 0.000 0.000
19.160 3040.00000 15.2000 -44.53125 0.00000 2.44200 2.44200 13.30000 1.07200 1.06600 4.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 12.7000 0.000 0.000 0.000 0.000
19.170 3040.00000 15.2000 -44.53125 0.00000 2.44200 2.44200 13.30000 1.07200 1.06600 4.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 12.7000 0.000 0.000 0.000 0.000
19.180 3040.00000 15.2000 -44.53125 0.00000 2.44200 2.44200 13.30000 1.07200 1.06600 4.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 12.7000 0.000 0.000 0.000 0.000
19.190 2890.00000 15.2000 -44.53125 0.00000 1.60300 1.60300 13.20000 1.07200 1.06600 4.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 12.9000 0.000 0.000 0.000 0.000
19.200 2890.00000 15.2000 -44.53125 0.00000 1.60300 1.60300 13.20000 1.07200 1.06600 4.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 12.9000 0.000 0.000 0.000 0.000
19.210 2890.00000 15.2000 -44.53125 0.00000 1.60300 1.60300 13.20000 1.07200 1.06600 4.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 12.9000 0.000 0.000 0.000 0.000
19.220 2890.00000 15.2000 -44.53125 0.00000 1.60300 1.60300 13.20000 1.07200 1.06600 4.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 12.9000 0.000 0.000 0.000 0.000
19.230 2890.00000 15.2000 -44.53125 0.00000 1.60300 1.60300 13.20000 1.07200 1.06600 4.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 12.9000 0.000 0.000 0.000 0.000
19.240 2807.00000 15.2000 -44.53125 0.00000 1.81300 1.81300 13.00000 1.07200 1.06600 4.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 12.9000 0.000 0.000 0.000 0.000
19.250 2807.00000 15.2000 -44.53125 0.00000 1.81300 1.81300 13.00000 1.07200 1.06600 4.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 12.9000 0.000 0.000 0.000 0.000
19.260 2807.00000 15.2000 -44.53125 0.00000 1.81300 1.81300 13.00000 1.07200 1.06600 4.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 12.9000 0.000 0.000 0.000 0.000
19.270 2807.00000 15.2000 -44.53125 0.00000 1.81300 1.81300 13.00000 1.07200 1.06600 4.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 12.9000 0.000 0.000 0.000 0.000
19.280 2807.00000 15.2000 -44.53125 0.00000 1.81300 1.81300 13.00000 1.07200 1.06600 4.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 12.9000 0.000 0.000 0.000 0.000
19.290 2787.00000 15.2000 -44.53125 0.00000 1.30500 1.30500 13.30000 0.25500 1.07200 4.10000 1.00000 3.00000 4.00000 3.00000 4.00000 0.00000 0.00000 12.9000 0.000 0.000 0.000 0.000
19.300 2787.00000 15.2000 -44.53125 0.00000 1.30500 1.30500 13.30000 0.25500 1.07200 4.10000 1.00000 3.00000 4.00000 3.00000 4.00000 0.00000 0.00000 12.9000 0.000 0.000 0.000 0.000
19.310 2787.00000 15.2000 -44.53125 0.00000 1.30500 1.30500 13.30000 0.25500 1.07200 4.10000 1.00000 3.00000 4.00000 3.00000 4.00000 0.00000 0.00000 12.9000 0.000 0.000 0.000 0.000
19.320 2787.00000 15.2000 -44.53125 0.00000 1.30500 1.30500 13.30000 0.25500 1.07200 4.10000 1.00000 3.00000 4.00000 3.00000 4.00000 0.00000 0.00000 12.9000 0.000 0.000 0.000 0.000
19.330 2787.00000 15.2000 -44.53125 0.00000 1.30500 1.30500 13.30000 0.25500 1.07200 4.10000 1.00000 3.00000 4.00000 3.00000 4.00000 0.00000 0.00000 12.9000 0.000 0.000 0.000 0.000
19.340 2568.00000 15.4000 -44.53125 0.00000 1.31100 1.31100 12.70000 0.25500 1.07200 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 16.6000 0.000 0.000 0.000 0.000
19.350 2568.00000 15.4000 -44.53125 0.00000 1.31100 1.31100 12.70000 0.25500 1.07200 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 16.6000 0.000 0.000 0.000 0.000
19.360 2568.00000 15.4000 -44.53125 0.00000 1.31100 1.31100 12.70000 0.25500 1.07200 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 16.6000 0.000 0.000 0.000 0.000
19.370 2568.00000 15.4000 -44.53125 0.00000 1.31100 1.31100 12.70000 0.25500 1.07200 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 16.6000 0.000 0.000 0.000 0.000
19.380 2568.00000 15.4000 -44.53125 0.00000 1.31100 1.31100 12.70000 0.25500 1.07200 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 16.6000 0.000 0.000 0.000 0.000
19.390 2479.00000 15.2000 -44.53125 0.00000 1.65500 1.65500 13.50000 0.25500 1.07200 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
19.400 2479.00000 15.2000 -44.53125 0.00000 1.65500 1.65500 13.50000 0.25500 1.07200 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
19.410 2479.00000 15.2000 -44.53125 0.00000 1.65500 1.65500 13.50000 0.25500 1.07200 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
19.420 2479.00000 15.2000 -44.53125 0.00000 1.65500 1.65500 13.50000 0.25500 1.07200 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
19.430 2479.00000 15.2000 -44.53125 0.00000 1.65500 1.65500 13.50000 0.25500 1.07200 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
19.440 2441.00000 15.2000 -44.53125 0.00000 1.76000 1.76000 13.60000 0.25500 1.07200 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
19.450 2441.00000 15.2000 -44.53125 0.00000 1.76000 1.76000 13.60000 0.25500 1.07200 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
19.460 2441.00000 15.2000 -44.53125 0.00000 1.76000 1.76000 13.60000 0.25500 1.07200 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
19.470 2441.00000 15.2000 -44.53125 0.00000 1.76000 1.76000 13.60000 0.25500 1.07200 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
19.480 2441.00000 15.2000 -44.53125 0.00000 1.76000 1.76000 13.60000 0.25500 1.07200 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
19.490 2304.00000 15.2000 -44.53125 0.00000 1.67300 1.67300 12.50000 0.24500 1.07200 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
19.500 2304.00000 15.2000 -44.53125 0.00000 1.67300 1.67300 12.50000 0.24500 1.07200 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
19.510 2304.00000 15.2000 -44.53125 0.00000 1.67300 1.67300 12.50000 0.24500 1.07200 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
19.520 2304.00000 15.2000 -44.53125 0.00000 1.67300 1.67300 12.50000 0.24500 1.07200 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
19.530 2304.00000 15.2000 -44.53125 0.00000 1.67300 1.67300 12.50000 0.24500 1.07200 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
19.540 2209.00000 15.2000 -44.53125 0.00000 1.47400 1.47400 12.80000 0.24500 1.07200 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
19.550 2209.00000 15.2000 -44.53125 0.00000 1.47400 1.47400 12.80000 0.24500 1.07200 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
19.560 2209.00000 15.2000 -44.53125 0.00000 1.47400 1.47400 12.80000 0.24500 1.07200 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
19.570 2209.00000 15.2000 -44.53125 0.00000 1.47400 1.47400 12.80000 0.24500 1.07200 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
19.580 2209.00000 15.2000 -44.53125 0.00000 1.47400 1.47400 12.80000 0.24500 1.07200 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
19.590 2114.00000 15.2000 -44.53125 0.00000 1.63800 1.63800 13.00000 0.24500 1.07200 4.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
19.600 2114.00000 15.2000 -44.53125 0.00000 1.63800 1.63800 13.00000 0.24500 1.07200 4.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
19.610 2114.00000 15.2000 -44.53125 0.00000 1.63800 1.63800 13.00000 0.24500 1.07200 4.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
19.620 2114.00000 15.2000 -44.53125 0.00000 1.63800 1.63800 13.00000 0.24500 1.07200 4.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
19.630 2114.00000 15.2000 -44.53125 0.00000 1.63800 1.63800 13.00000 0.24500 1.07200 4.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
19.640 2075.00000 15.2000 -44.53125 0.00000 2.14500 2.14500 13.20000 0.24500 1.07200 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
19.650 2075.00000 15.2000 -44.53125 0.00000 2.14500 2.14500 13.20000 0.24500 1.07200 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
19.660 2075.00000 15.2000 -44.53125 0.00000 2.14500 2.14500 13.20000 0.24500 1.07200 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
19.670 2075.00000 15.2000 -44.53125 0.00000 2.14500 2.14500 13.20000 0.24500 1.07200 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
19.680 2075.00000 15.2000 -44.53125 0.00000 2.14500 2.14500 13.20000 0.24500 1.07200 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
19.690 2010.00000 15.4000 -44.53125 0.00000 1.53900 1.53900 12.50000 0.24500 1.05900 4.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
19.700 2010.00000 15.4000 -44.53125 0.00000 1.53900 1.53900 12.50000 0.24500 1.05900 4.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
19.710 2010.00000 15.4000 -44.53125 0.00000 1.53900 1.53900 12.50000 0.24500 1.05900 4.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
19.720 2010.00000 15.4000 -44.53125 0.00000 1.53900 1.53900 12.50000 0.24500 1.05900 4.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
19.730 2010.00000 15.4000 -44.53125 0.00000 1.53900 1.53900 12.50000 0.24500 1.05900 4.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
19.740 2050.00000 15.2000 -44.53125 0.00000 1.61400 1.61400 13.50000 0.24500 1.05900 4.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
19.750 2050.00000 15.2000 -44.53125 0.00000 1.61400 1.61400 13.50000 0.24500 1.05900 4.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
19.760 2050.00000 15.2000 -44.53125 0.00000 1.61400 1.61400 13.50000 0.24500 1.05900 4.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
19.770 2050.00000 15.2000 -44.53125 0.00000 1.61400 1.61400 13.50000 0.24500 1.05900 4.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
19.780 2050.00000 15.2000 -44.53125 0.00000 1.61400 1.61400 13.50000 0.24500 1.05900 4.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
19.790 1997.00000 15.2000 -44.53125 0.00000 1.92900 1.92900 13.70000 0.24500 1.05900 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
19.800 1997.00000 15.2000 -44.53125 0.00000 1.92900 1.92900 13.70000 0.24500 1.05900 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
19.810 1997.00000 15.2000 -44.53125 0.00000 1.92900 1.92900 13.70000 0.24500 1.05900 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
19.820 1997.00000 15.2000 -44.53125 0.00000 1.92900 1.92900 13.70000 0.24500 1.05900 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
19.830 1997.00000 15.2000 -44.53125 0.00000 1.92900 1.92900 13.70000 0.24500 1.05900 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
19.840 1989.00000 15.2000 -44.53125 0.00000 1.18300 1.18300 13.00000 0.24500 1.05900 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
19.850 1989.00000 15.2000 -44.53125 0.00000 1.18300 1.18300 13.00000 0.24500 1.05900 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
19.860 1989.00000 15.2000 -44.53125 0.00000 1.18300 1.18300 13.00000 0.24500 1.05900 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
19.870 1989.00000 15.2000 -44.53125 0.00000 1.18300 1.18300 13.00000 0.24500 1.05900 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
19.880 1989.00000 15.2000 -44.53125 0.00000 1.18300 1.18300 13.00000 0.24500 1.05900 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
19.890 1976.00000 15.2000 -44.53125 0.00000 1.81300 1.81300 13.50000 0.26800 0.57100 4.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
19.900 1976.00000 15.2000 -44.53125 0.00000 1.81300 1.81300 13.50000 0.26800 0.57100 4.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
19.910 1976.00000 15.2000 -44.53125 0.00000 1.81300 1.81300 13.50000 0.26800 0.57100 4.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
19.920 1976.00000 15.2000 -44.53125 0.00000 1.81300 1.81300 13.50000 0.26800 0.57100 4.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
19.930 1976.00000 15.2000 -44.53125 0.00000 1.81300 1.81300 13.50000 0.26800 0.57100 4.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
19.940 2004.00000 15.2000 -44.53125 0.00000 1.49800 1.49800 12.80000 0.26800 0.57100 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
19.950 2004.00000 15.2000 -44.53125 0.00000 1.49800 1.49800 12.80000 0.26800 0.57100 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
19.960 2004.00000 15.2000 -44.53125 0.00000 1.49800 1.49800 12.80000 0.26800 0.57100 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
19.970 2004.00000 15.2000 -44.53125 0.00000 1.49800 1.49800 12.80000 0.26800 0.57100 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
19.980 2004.00000 15.2000 -44.53125 0.00000 1.49800 1.49800 12.80000 0.26800 0.57100 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
19.990 1947.00000 15.2000 -44.53125 0.00000 1.71900 1.71900 13.30000 0.26800 0.57100 4.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
20.000 1947.00000 15.2000 -44.53125 0.00000 1.71900 1.71900 13.30000 0.26800 0.57100 4.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
20.010 1947.00000 15.2000 -44.53125 0.00000 1.71900 1.71900 13.30000 0.26800 0.57100 4.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
20.020 1947.00000 15.2000 -44.53125 0.00000 1.71900 1.71900 13.30000 0.26800 0.57100 4.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
20.030 1947.00000 15.2000 -44.53125 0.00000 1.71900 1.71900 13.30000 0.26800 0.57100 4.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
20.040 1923.00000 15.1000 -44.53125 0.00000 1.50400 1.50400 13.10000 0.26800 0.57100 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
20.050 1923.00000 15.1000 -44.53125 0.00000 1.50400 1.50400 13.10000 0.26800 0.57100 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
20.060 1923.00000 15.1000 -44.53125 0.00000 1.50400 1.50400 13.10000 0.26800 0.57100 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
20.070 1923.00000 15.1000 -44.53125 0.00000 1.50400 1.50400 13.10000 0.26800 0.57100 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
20.080 1923.00000 15.1000 -44.53125 0.00000 1.50400 1.50400 13.10000 0.26800 0.57100 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
20.090 1941.00000 15.2000 -44.53125 0.00000 1.84800 1.84800 13.00000 1.10700 0.27100 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
20.100 1941.00000 15.2000 -44.53125 0.00000 1.84800 1.84800 13.00000 1.10700 0.27100 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
20.110 1941.00000 15.2000 -44.53125 0.00000 1.84800 1.84800 13.00000 1.10700 0.27100 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
20.120 1941.00000 15.2000 -44.53125 0.00000 1.84800 1.84800 13.00000 1.10700 0.27100 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
20.130 1941.00000 15.2000 -44.53125 0.00000 1.84800 1.84800 13.00000 1.10700 0.27100 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
20.140 1879.00000 15.2000 -44.53125 0.00000 1.32900 1.32900 13.50000 1.10700 0.27100 4.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
20.150 1879.00000 15.2000 -44.53125 0.00000 1.32900 1.32900 13.50000 1.10700 0.27100 4.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
20.160 1879.00000 15.2000 -44.53125 0.00000 1.32900 1.32900 13.50000 1.10700 0.27100 4.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
20.170 1879.00000 15.2000 -44.53125 0.00000 1.32900 1.32900 13.50000 1.10700 0.27100 4.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
20.180 1879.00000 15.2000 -44.53125 0.00000 1.32900 1.32900 13.50000 1.10700 0.27100 4.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
20.190 1858.00000 15.2000 -44.53125 0.00000 1.26500 1.26500 13.30000 1.10700 0.27100 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
20.200 1858.00000 15.2000 -44.53125 0.00000 1.26500 1.26500 13.30000 1.10700 0.27100 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
20.210 1858.00000 15.2000 -44.53125 0.00000 1.26500 1.26500 13.30000 1.10700 0.27100 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
20.220 1858.00000 15.2000 -44.53125 0.00000 1.26500 1.26500 13.30000 1.10700 0.27100 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
20.230 1858.00000 15.2000 -44.53125 0.00000 1.26500 1.26500 13.30000 1.10700 0.27100 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
20.240 1858.00000 15.2000 -44.53125 0.00000 1.78900 1.78900 13.60000 1.10700 0.27100 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
20.250 1858.00000 15.2000 -44.53125 0.00000 1.78900 1.78900 13.60000 1.10700 0.27100 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
20.260 1858.00000 15.2000 -44.53125 0.00000 1.78900 1.78900 13.60000 1.10700 0.27100 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
20.270 1858.00000 15.2000 -44.53125 0.00000 1.78900 1.78900 13.60000 1.10700 0.27100 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
20.280 1858.00000 15.2000 -44.53125 0.00000 1.78900 1.78900 13.60000 1.10700 0.27100 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
20.290 1826.00000 15.4000 -44.53125 0.00000 1.77800 1.77800 12.20000 1.12300 0.26800 4.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.9000 0.000 0.000 0.000 0.000
20.300 1826.00000 15.4000 -44.53125 0.00000 1.77800 1.77800 12.20000 1.12300 0.26800 4.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.9000 0.000 0.000 0.000 0.000
20.310 1826.00000 15.4000 -44.53125 0.00000 1.77800 1.77800 12.20000 1.12300 0.26800 4.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.9000 0.000 0.000 0.000 0.000
20.320 1826.00000 15.4000 -44.53125 0.00000 1.77800 1.77800 12.20000 1.12300 0.26800 4.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.9000 0.000 0.000 0.000 0.000
20.330 1826.00000 15.4000 -44.53125 0.00000 1.77800 1.77800 12.20000 1.12300 0.26800 4.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.9000 0.000 0.000 0.000 0.000
20.340 1837.00000 15.2000 -44.53125 0.00000 1.57900 1.57900 13.40000 1.12300 0.26800 4.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
20.350 1837.00000 15.2000 -44.53125 0.00000 1.57900 1.57900 13.40000 1.12300 0.26800 4.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
20.360 1837.00000 15.2000 -44.53125 0.00000 1.57900 1.57900 13.40000 1.12300 0.26800 4.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
20.370 1837.00000 15.2000 -44.53125 0.00000 1.57900 1.57900 13.40000 1.12300 0.26800 4.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
20.380 1837.00000 15.2000 -44.53125 0.00000 1.57900 1.57900 13.40000 1.12300 0.26800 4.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
20.390 1772.00000 15.2000 -44.53125 0.00000 1.60300 1.60300 13.20000 1.12300 0.26800 4.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
20.400 1772.00000 15.2000 -44.53125 0.00000 1.60300 1.60300 13.20000 1.12300 0.26800 4.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
20.410 1772.00000 15.2000 -44.53125 0.00000 1.60300 1.60300 13.20000 1.12300 0.26800 4.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
20.420 1772.00000 15.2000 -44.53125 0.00000 1.60300 1.60300 13.20000 1.12300 0.26800 4.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
20.430 1772.00000 15.2000 -44.53125 0.00000 1.60300 1.60300 13.20000 1.12300 0.26800 4.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
20.440 1772.00000 15.2000 -44.53125 0.00000 1.60300 1.60300 13.20000 1.12300 0.26800 4.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
20.450 1745.00000 15.4000 -44.53125 0.00000 1.63800 1.63800 12.60000 1.12300 0.26800 4.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
20.460 1745.00000 15.4000 -44.53125 0.00000 1.63800 1.63800 12.60000 1.12300 0.26800 4.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
20.470 1745.00000 15.4000 -44.53125 0.00000 1.63800 1.63800 12.60000 1.12300 0.26800 4.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
20.480 1745.00000 15.4000 -44.53125 0.00000 1.63800 1.63800 12.60000 1.12300 0.26800 4.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
20.490 1745.00000 15.4000 -44.53125 0.00000 1.63800 1.63800 12.60000 1.12300 0.26800 4.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
20.500 1708.00000 15.2000 -44.53125 0.00000 1.41600 1.41600 13.20000 1.14200 0.27700 4.20000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
20.510 1708.00000 15.2000 -44.53125 0.00000 1.41600 1.41600 13.20000 1.14200 0.27700 4.20000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
20.520 1708.00000 15.2000 -44.53125 0.00000 1.41600 1.41600 13.20000 1.14200 0.27700 4.20000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
20.530 1708.00000 15.2000 -44.53125 0.00000 1.41600 1.41600 13.20000 1.14200 0.27700 4.20000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
20.540 1708.00000 15.2000 -44.53125 0.00000 1.41600 1.41600 13.20000 1.14200 0.27700 4.20000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
20.550 1639.00000 15.2000 -44.53125 0.00000 1.64400 1.64400 13.20000 1.14200 0.27700 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
20.560 1639.00000 15.2000 -44.53125 0.00000 1.64400 1.64400 13.20000 1.14200 0.27700 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
20.570 1639.00000 15.2000 -44.53125 0.00000 1.64400 1.64400 13.20000 1.14200 0.27700 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
20.580 1639.00000 15.2000 -44.53125 0.00000 1.64400 1.64400 13.20000 1.14200 0.27700 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
20.590 1639.00000 15.2000 -44.53125 0.00000 1.64400 1.64400 13.20000 1.14200 0.27700 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
20.600 1486.00000 15.2000 -44.53125 0.00000 1.44500 1.44500 13.20000 1.14200 0.27700 4.20000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
20.610 1486.00000 15.2000 -44.53125 0.00000 1.44500 1.44500 13.20000 1.14200 0.27700 4.20000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
20.620 1486.00000 15.2000 -44.53125 0.00000 1.44500 1.44500 13.20000 1.14200 0.27700 4.20000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
20.630 1486.00000 15.2000 -44.53125 0.00000 1.44500 1.44500 13.20000 1.14200 0.27700 4.20000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
20.640 1486.00000 15.2000 -44.53125 0.00000 1.44500 1.44500 13.20000 1.14200 0.27700 4.20000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
20.650 1486.00000 15.2000 -44.53125 0.00000 1.52700 1.52700 13.30000 1.14200 0.27700 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.2000 0.000 0.000 0.000 0.000
20.660 1486.00000 15.2000 -44.53125 0.00000 1.52700 1.52700 13.30000 1.14200 0.27700 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.2000 0.000 0.000 0.000 0.000
20.670 1486.00000 15.2000 -44.53125 0.00000 1.52700 1.52700 13.30000 1.14200 0.27700 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.2000 0.000 0.000 0.000 0.000
20.680 1486.00000 15.2000 -44.53125 0.00000 1.52700 1.52700 13.30000 1.14200 0.27700 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.2000 0.000 0.000 0.000 0.000
20.690 1486.00000 15.2000 -44.53125 0.00000 1.52700 1.52700 13.30000 1.14200 0.27700 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.2000 0.000 0.000 0.000 0.000
20.700 1357.00000 15.4000 -44.53125 0.00000 1.53900 1.53900 12.00000 1.13900 0.30900 4.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
20.710 1357.00000 15.4000 -44.53125 0.00000 1.53900 1.53900 12.00000 1.13900 0.30900 4.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
20.720 1357.00000 15.4000 -44.53125 0.00000 1.53900 1.53900 12.00000 1.13900 0.30900 4.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
20.730 1357.00000 15.4000 -44.53125 0.00000 1.53900 1.53900 12.00000 1.13900 0.30900 4.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
20.740 1357.00000 15.4000 -44.53125 0.00000 1.53900 1.53900 12.00000 1.13900 0.30900 4.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
20.750 1385.00000 15.2000 -44.53125 0.00000 1.68400 1.68400 13.30000 1.13900 0.30900 4.60000 1.00000 2.00000 2.00000 3.00000 2.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
20.760 1385.00000 15.2000 -44.53125 0.00000 1.68400 1.68400 13.30000 1.13900 0.30900 4.60000 1.00000 2.00000 2.00000 3.00000 2.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
20.770 1385.00000 15.2000 -44.53125 0.00000 1.68400 1.68400 13.30000 1.13900 0.30900 4.60000 1.00000 2.00000 2.00000 3.00000 2.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
20.780 1385.00000 15.2000 -44.53125 0.00000 1.68400 1.68400 13.30000 1.13900 0.30900 4.60000 1.00000 2.00000 2.00000 3.00000 2.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
20.790 1385.00000 15.2000 -44.53125 0.00000 1.68400 1.68400 13.30000 1.13900 0.30900 4.60000 1.00000 2.00000 2.00000 3.00000 2.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
20.800 1355.00000 15.2000 -44.53125 0.00000 1.51500 1.51500 13.20000 1.13900 0.30900 4.50000 1.00000 2.00000 3.00000 3.00000 3.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
20.810 1355.00000 15.2000 -44.53125 0.00000 1.51500 1.51500 13.20000 1.13900 0.30900 4.50000 1.00000 2.00000 3.00000 3.00000 3.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
20.820 1355.00000 15.2000 -44.53125 0.00000 1.51500 1.51500 13.20000 1.13900 0.30900 4.50000 1.00000 2.00000 3.00000 3.00000 3.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
20.830 1355.00000 15.2000 -44.53125 0.00000 1.51500 1.51500 13.20000 1.13900 0.30900 4.50000 1.00000 2.00000 3.00000 3.00000 3.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
20.840 1355.00000 15.2000 -44.53125 0.00000 1.51500 1.51500 13.20000 1.13900 0.30900 4.50000 1.00000 2.00000 3.00000 3.00000 3.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
20.850 1355.00000 15.2000 -44.53125 0.00000 1.48600 1.48600 13.30000 1.13900 0.30900 4.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
20.860 1355.00000 15.2000 -44.53125 0.00000 1.48600 1.48600 13.30000 1.13900 0.30900 4.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
20.870 1355.00000 15.2000 -44.53125 0.00000 1.48600 1.48600 13.30000 1.13900 0.30900 4.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
20.880 1355.00000 15.2000 -44.53125 0.00000 1.48600 1.48600 13.30000 1.13900 0.30900 4.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
20.890 1355.00000 15.2000 -44.53125 0.00000 1.48600 1.48600 13.30000 1.13900 0.30900 4.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
20.900 1247.00000 15.2000 -44.53125 0.00000 1.49200 1.49200 13.50000 0.28000 0.35100 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.6000 0.000 0.000 0.000 0.000
20.910 1247.00000 15.2000 -44.53125 0.00000 1.49200 1.49200 13.50000 0.28000 0.35100 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.6000 0.000 0.000 0.000 0.000
20.920 1247.00000 15.2000 -44.53125 0.00000 1.49200 1.49200 13.50000 0.28000 0.35100 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.6000 0.000 0.000 0.000 0.000
20.930 1247.00000 15.2000 -44.53125 0.00000 1.49200 1.49200 13.50000 0.28000 0.35100 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.6000 0.000 0.000 0.000 0.000
20.940 1247.00000 15.2000 -44.53125 0.00000 1.49200 1.49200 13.50000 0.28000 0.35100 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.6000 0.000 0.000 0.000 0.000
20.950 1247.00000 15.2000 -44.53125 0.00000 1.47400 1.47400 13.20000 0.28000 0.35100 4.60000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
20.960 1247.00000 15.2000 -44.53125 0.00000 1.47400 1.47400 13.20000 0.28000 0.35100 4.60000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
20.970 1247.00000 15.2000 -44.53125 0.00000 1.47400 1.47400 13.20000 0.28000 0.35100 4.60000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
20.980 1247.00000 15.2000 -44.53125 0.00000 1.47400 1.47400 13.20000 0.28000 0.35100 4.60000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
20.990 1247.00000 15.2000 -44.53125 0.00000 1.47400 1.47400 13.20000 0.28000 0.35100 4.60000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
21.000 1086.00000 15.2000 -44.53125 0.00000 1.34600 1.34600 13.60000 0.28000 0.35100 4.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
21.010 1086.00000 15.2000 -44.53125 0.00000 1.34600 1.34600 13.60000 0.28000 0.35100 4.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
21.020 1086.00000 15.2000 -44.53125 0.00000 1.34600 1.34600 13.60000 0.28000 0.35100 4.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
21.030 1086.00000 15.2000 -44.53125 0.00000 1.34600 1.34600 13.60000 0.28000 0.35100 4.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
21.040 1086.00000 15.2000 -44.53125 0.00000 1.34600 1.34600 13.60000 0.28000 0.35100 4.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
21.050 1086.00000 15.2000 -44.53125 0.00000 1.10700 1.10700 12.80000 0.28000 0.35100 5.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 17.5000 0.000 0.000 0.000 0.000
21.060 1086.00000 15.2000 -44.53125 0.00000 1.10700 1.10700 12.80000 0.28000 0.35100 5.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 17.5000 0.000 0.000 0.000 0.000
21.070 1086.00000 15.2000 -44.53125 0.00000 1.10700 1.10700 12.80000 0.28000 0.35100 5.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 17.5000 0.000 0.000 0.000 0.000
21.080 1086.00000 15.2000 -44.53125 0.00000 1.10700 1.10700 12.80000 0.28000 0.35100 5.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 17.5000 0.000 0.000 0.000 0.000
21.090 1086.00000 15.2000 -44.53125 0.00000 1.10700 1.10700 12.80000 0.28000 0.35100 5.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 17.5000 0.000 0.000 0.000 0.000
21.100 921.00000 15.2000 -44.53125 0.00000 1.02600 1.02600 12.90000 0.30000 0.54500 5.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 18.4000 0.000 0.000 0.000 0.000
21.110 921.00000 15.2000 -44.53125 0.00000 1.02600 1.02600 12.90000 0.30000 0.54500 5.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 18.4000 0.000 0.000 0.000 0.000
21.120 921.00000 15.2000 -44.53125 0.00000 1.02600 1.02600 12.90000 0.30000 0.54500 5.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 18.4000 0.000 0.000 0.000 0.000
21.130 921.00000 15.2000 -44.53125 0.00000 1.02600 1.02600 12.90000 0.30000 0.54500 5.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 18.4000 0.000 0.000 0.000 0.000
21.140 921.00000 15.2000 -44.53125 0.00000 1.02600 1.02600 12.90000 0.30000 0.54500 5.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 18.4000 0.000 0.000 0.000 0.000
21.150 921.00000 15.2000 -44.53125 0.00000 0.96100 0.96100 12.80000 0.30000 0.54500 5.80000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
21.160 921.00000 15.2000 -44.53125 0.00000 0.96100 0.96100 12.80000 0.30000 0.54500 5.80000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
21.170 921.00000 15.2000 -44.53125 0.00000 0.96100 0.96100 12.80000 0.30000 0.54500 5.80000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
21.180 921.00000 15.2000 -44.53125 0.00000 0.96100 0.96100 12.80000 0.30000 0.54500 5.80000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
21.190 921.00000 15.2000 -44.53125 0.00000 0.96100 0.96100 12.80000 0.30000 0.54500 5.80000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
21.200 921.00000 15.2000 -44.53125 0.00000 0.93800 0.93800 12.60000 0.30000 0.54500 6.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 18.4000 0.000 0.000 0.000 0.000
21.210 921.00000 15.2000 -44.53125 0.00000 0.93800 0.93800 12.60000 0.30000 0.54500 6.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 18.4000 0.000 0.000 0.000 0.000
21.220 921.00000 15.2000 -44.53125 0.00000 0.93800 0.93800 12.60000 0.30000 0.54500 6.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 18.4000 0.000 0.000 0.000 0.000
21.230 921.00000 15.2000 -44.53125 0.00000 0.93800 0.93800 12.60000 0.30000 0.54500 6.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 18.4000 0.000 0.000 0.000 0.000
21.240 921.00000 15.2000 -44.53125 0.00000 0.93800 0.93800 12.60000 0.30000 0.54500 6.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 18.4000 0.000 0.000 0.000 0.000
21.250 730.00000 15.2000 -44.53125 0.00000 0.93800 0.93800 12.80000 0.30000 0.54500 6.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 18.4000 0.000 0.000 0.000 0.000
21.260 730.00000 15.2000 -44.53125 0.00000 0.93800 0.93800 12.80000 0.30000 0.54500 6.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 18.4000 0.000 0.000 0.000 0.000
21.270 730.00000 15.2000 -44.53125 0.00000 0.93800 0.93800 12.80000 0.30000 0.54500 6.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 18.4000 0.000 0.000 0.000 0.000
21.280 730.00000 15.2000 -44.53125 0.00000 0.93800 0.93800 12.80000 0.30000 0.54500 6.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 18.4000 0.000 0.000 0.000 0.000
21.290 730.00000 15.2000 -44.53125 0.00000 0.93800 0.93800 12.80000 0.30000 0.54500 6.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 18.4000 0.000 0.000 0.000 0.000
21.300 730.00000 15.2000 -44.53125 0.00000 1.02000 1.02000 12.60000 1.05300 0.99500 6.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
21.310 730.00000 15.2000 -44.53125 0.00000 1.02000 1.02000 12.60000 1.05300 0.99500 6.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
21.320 730.00000 15.2000 -44.53125 0.00000 1.02000 1.02000 12.60000 1.05300 0.99500 6.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
21.330 730.00000 15.2000 -44.53125 0.00000 1.02000 1.02000 12.60000 1.05300 0.99500 6.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
21.340 730.00000 15.2000 -44.53125 0.00000 1.02000 1.02000 12.60000 1.05300 0.99500 6.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
21.350 691.00000 15.2000 -44.53125 0.00000 1.00200 1.00200 12.60000 1.05300 0.99500 6.60000 1.00000 1.00000 2.00000 2.00000 2.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
21.360 691.00000 15.2000 -44.53125 0.00000 1.00200 1.00200 12.60000 1.05300 0.99500 6.60000 1.00000 1.00000 2.00000 2.00000 2.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
21.370 691.00000 15.2000 -44.53125 0.00000 1.00200 1.00200 12.60000 1.05300 0.99500 6.60000 1.00000 1.00000 2.00000 2.00000 2.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
21.380 691.00000 15.2000 -44.53125 0.00000 1.00200 1.00200 12.60000 1.05300 0.99500 6.60000 1.00000 1.00000 2.00000 2.00000 2.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
21.390 691.00000 15.2000 -44.53125 0.00000 1.00200 1.00200 12.60000 1.05300 0.99500 6.60000 1.00000 1.00000 2.00000 2.00000 2.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
21.400 691.00000 15.2000 -44.53125 0.00000 1.00800 1.00800 12.00000 1.05300 0.99500 7.10000 1.00000 1.00000 2.00000 1.00000 1.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
21.410 691.00000 15.2000 -44.53125 0.00000 1.00800 1.00800 12.00000 1.05300 0.99500 7.10000 1.00000 1.00000 2.00000 1.00000 1.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
21.420 691.00000 15.2000 -44.53125 0.00000 1.00800 1.00800 12.00000 1.05300 0.99500 7.10000 1.00000 1.00000 2.00000 1.00000 1.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
21.430 691.00000 15.2000 -44.53125 0.00000 1.00800 1.00800 12.00000 1.05300 0.99500 7.10000 1.00000 1.00000 2.00000 1.00000 1.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
21.440 691.00000 15.2000 -44.53125 0.00000 1.00800 1.00800 12.00000 1.05300 0.99500 7.10000 1.00000 1.00000 2.00000 1.00000 1.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
21.450 691.00000 15.2000 -44.53125 0.00000 0.99100 0.99100 12.90000 1.05300 0.99500 6.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
21.460 691.00000 15.2000 -44.53125 0.00000 0.99100 0.99100 12.90000 1.05300 0.99500 6.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
21.470 691.00000 15.2000 -44.53125 0.00000 0.99100 0.99100 12.90000 1.05300 0.99500 6.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
21.480 691.00000 15.2000 -44.53125 0.00000 0.99100 0.99100 12.90000 1.05300 0.99500 6.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
21.490 691.00000 15.2000 -44.53125 0.00000 0.99100 0.99100 12.90000 1.05300 0.99500 6.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
21.500 771.00000 15.2000 -44.53125 0.00000 0.99100 0.99100 13.30000 1.09800 1.06600 6.20000 1.00000 2.00000 2.00000 2.00000 1.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
21.510 771.00000 15.2000 -44.53125 0.00000 0.99100 0.99100 13.30000 1.09800 1.06600 6.20000 1.00000 2.00000 2.00000 2.00000 1.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
21.520 771.00000 15.2000 -44.53125 0.00000 0.99100 0.99100 13.30000 1.09800 1.06600 6.20000 1.00000 2.00000 2.00000 2.00000 1.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
21.530 771.00000 15.2000 -44.53125 0.00000 0.99100 0.99100 13.30000 1.09800 1.06600 6.20000 1.00000 2.00000 2.00000 2.00000 1.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
21.540 771.00000 15.2000 -44.53125 0.00000 0.99100 0.99100 13.30000 1.09800 1.06600 6.20000 1.00000 2.00000 2.00000 2.00000 1.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
21.550 771.00000 15.2000 -44.53125 0.00000 0.99100 0.99100 13.30000 1.09800 1.06600 6.20000 1.00000 2.00000 2.00000 2.00000 1.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
21.560 771.00000 15.2000 -44.53125 0.00000 0.99100 0.99100 13.30000 1.09800 1.06600 6.20000 1.00000 2.00000 2.00000 2.00000 1.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
21.570 771.00000 15.2000 -44.53125 0.00000 0.99100 0.99100 13.30000 1.09800 1.06600 6.20000 1.00000 2.00000 2.00000 2.00000 1.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
21.580 771.00000 15.2000 -44.53125 0.00000 0.99100 0.99100 13.30000 1.09800 1.06600 6.20000 1.00000 2.00000 2.00000 2.00000 1.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
21.590 771.00000 15.2000 -44.53125 0.00000 0.99100 0.99100 13.30000 1.09800 1.06600 6.20000 1.00000 2.00000 2.00000 2.00000 1.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
21.600 930.00000 15.2000 -44.53125 0.00000 0.96100 0.96100 13.20000 1.09800 1.06600 6.10000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
21.610 930.00000 15.2000 -44.53125 0.00000 0.96100 0.96100 13.20000 1.09800 1.06600 6.10000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
21.620 930.00000 15.2000 -44.53125 0.00000 0.96100 0.96100 13.20000 1.09800 1.06600 6.10000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
21.630 930.00000 15.2000 -44.53125 0.00000 0.96100 0.96100 13.20000 1.09800 1.06600 6.10000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
21.640 930.00000 15.2000 -44.53125 0.00000 0.96100 0.96100 13.20000 1.09800 1.06600 6.10000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
21.650 930.00000 15.2000 -44.53125 0.00000 0.93200 0.93200 13.20000 1.09800 1.06600 6.20000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
21.660 930.00000 15.2000 -44.53125 0.00000 0.93200 0.93200 13.20000 1.09800 1.06600 6.20000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
21.670 930.00000 15.2000 -44.53125 0.00000 0.93200 0.93200 13.20000 1.09800 1.06600 6.20000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
21.680 930.00000 15.2000 -44.53125 0.00000 0.93200 0.93200 13.20000 1.09800 1.06600 6.20000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
21.690 930.00000 15.2000 -44.53125 0.00000 0.93200 0.93200 13.20000 1.09800 1.06600 6.20000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
21.700 1040.00000 15.2000 -44.53125 0.00000 0.94400 0.94400 13.50000 1.16800 1.06200 5.80000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
21.710 1040.00000 15.2000 -44.53125 0.00000 0.94400 0.94400 13.50000 1.16800 1.06200 5.80000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
21.720 1040.00000 15.2000 -44.53125 0.00000 0.94400 0.94400 13.50000 1.16800 1.06200 5.80000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
21.730 1040.00000 15.2000 -44.53125 0.00000 0.94400 0.94400 13.50000 1.16800 1.06200 5.80000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
21.740 1040.00000 15.2000 -44.53125 0.00000 0.94400 0.94400 13.50000 1.16800 1.06200 5.80000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
21.750 1040.00000 15.2000 -44.53125 0.00000 0.92600 0.92600 12.60000 1.16800 1.06200 5.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.0000 0.000 0.000 0.000 0.000
21.760 1040.00000 15.2000 -44.53125 0.00000 0.92600 0.92600 12.60000 1.16800 1.06200 5.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.0000 0.000 0.000 0.000 0.000
21.770 1040.00000 15.2000 -44.53125 0.00000 0.92600 0.92600 12.60000 1.16800 1.06200 5.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.0000 0.000 0.000 0.000 0.000
21.780 1040.00000 15.2000 -44.53125 0.00000 0.92600 0.92600 12.60000 1.16800 1.06200 5.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.0000 0.000 0.000 0.000 0.000
21.790 1040.00000 15.2000 -44.53125 0.00000 0.92600 0.92600 12.60000 1.16800 1.06200 5.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.0000 0.000 0.000 0.000 0.000
21.800 1152.00000 15.2000 -44.53125 0.00000 0.92100 0.92100 13.10000 1.16800 1.06200 5.00000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
21.810 1152.00000 15.2000 -44.53125 0.00000 0.92100 0.92100 13.10000 1.16800 1.06200 5.00000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
21.820 1152.00000 15.2000 -44.53125 0.00000 0.92100 0.92100 13.10000 1.16800 1.06200 5.00000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
21.830 1152.00000 15.2000 -44.53125 0.00000 0.92100 0.92100 13.10000 1.16800 1.06200 5.00000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
21.840 1152.00000 15.2000 -44.53125 0.00000 0.92100 0.92100 13.10000 1.16800 1.06200 5.00000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
21.850 1248.00000 15.2000 -44.53125 0.00000 0.99600 0.99600 12.70000 1.16800 1.06200 4.60000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.3000 0.000 0.000 0.000 0.000
21.860 1248.00000 15.2000 -44.53125 0.00000 0.99600 0.99600 12.70000 1.16800 1.06200 4.60000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.3000 0.000 0.000 0.000 0.000
21.870 1248.00000 15.2000 -44.53125 0.00000 0.99600 0.99600 12.70000 1.16800 1.06200 4.60000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.3000 0.000 0.000 0.000 0.000
21.880 1248.00000 15.2000 -44.53125 0.00000 0.99600 0.99600 12.70000 1.16800 1.06200 4.60000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.3000 0.000 0.000 0.000 0.000
21.890 1248.00000 15.2000 -44.53125 0.00000 0.99600 0.99600 12.70000 1.16800 1.06200 4.60000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.3000 0.000 0.000 0.000 0.000
21.900 1248.00000 15.2000 -44.53125 0.00000 1.04300 1.04300 13.00000 1.15500 1.10100 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.3000 0.000 0.000 0.000 0.000
21.910 1248.00000 15.2000 -44.53125 0.00000 1.04300 1.04300 13.00000 1.15500 1.10100 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.3000 0.000 0.000 0.000 0.000
21.920 1248.00000 15.2000 -44.53125 0.00000 1.04300 1.04300 13.00000 1.15500 1.10100 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.3000 0.000 0.000 0.000 0.000
21.930 1248.00000 15.2000 -44.53125 0.00000 1.04300 1.04300 13.00000 1.15500 1.10100 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.3000 0.000 0.000 0.000 0.000
21.940 1248.00000 15.2000 -44.53125 0.00000 1.04300 1.04300 13.00000 1.15500 1.10100 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.3000 0.000 0.000 0.000 0.000
21.950 1266.00000 15.2000 -44.53125 0.00000 1.10700 1.10700 13.30000 1.15500 1.10100 4.60000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.3000 0.000 0.000 0.000 0.000
21.960 1266.00000 15.2000 -44.53125 0.00000 1.10700 1.10700 13.30000 1.15500 1.10100 4.60000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.3000 0.000 0.000 0.000 0.000
21.970 1266.00000 15.2000 -44.53125 0.00000 1.10700 1.10700 13.30000 1.15500 1.10100 4.60000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.3000 0.000 0.000 0.000 0.000
21.980 1266.00000 15.2000 -44.53125 0.00000 1.10700 1.10700 13.30000 1.15500 1.10100 4.60000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.3000 0.000 0.000 0.000 0.000
21.990 1266.00000 15.2000 -44.53125 0.00000 1.10700 1.10700 13.30000 1.15500 1.10100 4.60000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.3000 0.000 0.000 0.000 0.000
22.000 1279.00000 15.2000 -44.53125 0.00000 1.23500 1.23500 13.30000 1.15500 1.10100 4.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
22.010 1279.00000 15.2000 -44.53125 0.00000 1.23500 1.23500 13.30000 1.15500 1.10100 4.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
22.020 1279.00000 15.2000 -44.53125 0.00000 1.23500 1.23500 13.30000 1.15500 1.10100 4.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
22.030 1279.00000 15.2000 -44.53125 0.00000 1.23500 1.23500 13.30000 1.15500 1.10100 4.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
22.040 1279.00000 15.2000 -44.53125 0.00000 1.23500 1.23500 13.30000 1.15500 1.10100 4.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
22.050 1279.00000 15.2000 -44.53125 0.00000 1.19500 1.19500 13.60000 1.15500 1.10100 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
22.060 1279.00000 15.2000 -44.53125 0.00000 1.19500 1.19500 13.60000 1.15500 1.10100 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
22.070 1279.00000 15.2000 -44.53125 0.00000 1.19500 1.19500 13.60000 1.15500 1.10100 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
22.080 1279.00000 15.2000 -44.53125 0.00000 1.19500 1.19500 13.60000 1.15500 1.10100 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
22.090 1279.00000 15.2000 -44.53125 0.00000 1.19500 1.19500 13.60000 1.15500 1.10100 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
22.100 1279.00000 15.2000 -44.53125 0.00000 1.27600 1.27600 12.50000 1.13300 1.10700 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
22.110 1279.00000 15.2000 -44.53125 0.00000 1.27600 1.27600 12.50000 1.13300 1.10700 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
22.120 1279.00000 15.2000 -44.53125 0.00000 1.27600 1.27600 12.50000 1.13300 1.10700 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
22.130 1279.00000 15.2000 -44.53125 0.00000 1.27600 1.27600 12.50000 1.13300 1.10700 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
22.140 1279.00000 15.2000 -44.53125 0.00000 1.27600 1.27600 12.50000 1.13300 1.10700 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
22.150 1275.00000 15.2000 -44.53125 0.00000 1.31100 1.31100 13.40000 1.13300 1.10700 4.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.0000 0.000 0.000 0.000 0.000
22.160 1275.00000 15.2000 -44.53125 0.00000 1.31100 1.31100 13.40000 1.13300 1.10700 4.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.0000 0.000 0.000 0.000 0.000
22.170 1275.00000 15.2000 -44.53125 0.00000 1.31100 1.31100 13.40000 1.13300 1.10700 4.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.0000 0.000 0.000 0.000 0.000
22.180 1275.00000 15.2000 -44.53125 0.00000 1.31100 1.31100 13.40000 1.13300 1.10700 4.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.0000 0.000 0.000 0.000 0.000
22.190 1275.00000 15.2000 -44.53125 0.00000 1.31100 1.31100 13.40000 1.13300 1.10700 4.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.0000 0.000 0.000 0.000 0.000
22.200 1275.00000 15.2000 -44.53125 0.00000 1.54400 1.54400 13.30000 1.13300 1.10700 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
22.210 1275.00000 15.2000 -44.53125 0.00000 1.54400 1.54400 13.30000 1.13300 1.10700 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
22.220 1275.00000 15.2000 -44.53125 0.00000 1.54400 1.54400 13.30000 1.13300 1.10700 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
22.230 1275.00000 15.2000 -44.53125 0.00000 1.54400 1.54400 13.30000 1.13300 1.10700 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
22.240 1275.00000 15.2000 -44.53125 0.00000 1.54400 1.54400 13.30000 1.13300 1.10700 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
22.250 1202.00000 15.2000 -44.53125 0.00000 1.43900 1.43900 13.20000 1.13300 1.10700 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
22.260 1202.00000 15.2000 -44.53125 0.00000 1.43900 1.43900 13.20000 1.13300 1.10700 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
22.270 1202.00000 15.2000 -44.53125 0.00000 1.43900 1.43900 13.20000 1.13300 1.10700 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
22.280 1202.00000 15.2000 -44.53125 0.00000 1.43900 1.43900 13.20000 1.13300 1.10700 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
22.290 1202.00000 15.2000 -44.53125 0.00000 1.43900 1.43900 13.20000 1.13300 1.10700 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
22.300 1202.00000 15.2000 -44.53125 0.00000 1.45700 1.45700 13.20000 1.13600 1.12900 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
22.310 1202.00000 15.2000 -44.53125 0.00000 1.45700 1.45700 13.20000 1.13600 1.12900 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
22.320 1202.00000 15.2000 -44.53125 0.00000 1.45700 1.45700 13.20000 1.13600 1.12900 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
22.330 1202.00000 15.2000 -44.53125 0.00000 1.45700 1.45700 13.20000 1.13600 1.12900 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
22.340 1202.00000 15.2000 -44.53125 0.00000 1.45700 1.45700 13.20000 1.13600 1.12900 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
22.350 1136.00000 15.1000 -44.53125 0.00000 1.38700 1.38700 13.10000 1.13600 1.12900 4.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
22.360 1136.00000 15.1000 -44.53125 0.00000 1.38700 1.38700 13.10000 1.13600 1.12900 4.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
22.370 1136.00000 15.1000 -44.53125 0.00000 1.38700 1.38700 13.10000 1.13600 1.12900 4.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
22.380 1136.00000 15.1000 -44.53125 0.00000 1.38700 1.38700 13.10000 1.13600 1.12900 4.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
22.390 1136.00000 15.1000 -44.53125 0.00000 1.38700 1.38700 13.10000 1.13600 1.12900 4.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
22.400 1136.00000 15.2000 -44.53125 0.00000 1.34600 1.34600 13.60000 1.13600 1.12900 4.60000 1.00000 2.00000 2.00000 3.00000 3.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
22.410 1136.00000 15.2000 -44.53125 0.00000 1.34600 1.34600 13.60000 1.13600 1.12900 4.60000 1.00000 2.00000 2.00000 3.00000 3.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
22.420 1136.00000 15.2000 -44.53125 0.00000 1.34600 1.34600 13.60000 1.13600 1.12900 4.60000 1.00000 2.00000 2.00000 3.00000 3.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
22.430 1136.00000 15.2000 -44.53125 0.00000 1.34600 1.34600 13.60000 1.13600 1.12900 4.60000 1.00000 2.00000 2.00000 3.00000 3.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
22.440 1136.00000 15.2000 -44.53125 0.00000 1.34600 1.34600 13.60000 1.13600 1.12900 4.60000 1.00000 2.00000 2.00000 3.00000 3.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
22.450 1025.00000 15.2000 -44.53125 0.00000 1.31700 1.31700 12.60000 1.13600 1.12900 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
22.460 1025.00000 15.2000 -44.53125 0.00000 1.31700 1.31700 12.60000 1.13600 1.12900 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
22.470 1025.00000 15.2000 -44.53125 0.00000 1.31700 1.31700 12.60000 1.13600 1.12900 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
22.480 1025.00000 15.2000 -44.53125 0.00000 1.31700 1.31700 12.60000 1.13600 1.12900 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
22.490 1025.00000 15.2000 -44.53125 0.00000 1.31700 1.31700 12.60000 1.13600 1.12900 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
22.500 1025.00000 15.2000 -44.53125 0.00000 1.28200 1.28200 13.00000 1.15500 1.14500 4.90000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
22.510 1025.00000 15.2000 -44.53125 0.00000 1.28200 1.28200 13.00000 1.15500 1.14500 4.90000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
22.520 1025.00000 15.2000 -44.53125 0.00000 1.28200 1.28200 13.00000 1.15500 1.14500 4.90000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
22.530 1025.00000 15.2000 -44.53125 0.00000 1.28200 1.28200 13.00000 1.15500 1.14500 4.90000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
22.540 1025.00000 15.2000 -44.53125 0.00000 1.28200 1.28200 13.00000 1.15500 1.14500 4.90000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
22.550 792.00000 15.2000 -44.53125 0.00000 1.12500 1.12500 12.70000 1.15500 1.14500 5.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
22.560 792.00000 15.2000 -44.53125 0.00000 1.12500 1.12500 12.70000 1.15500 1.14500 5.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
22.570 792.00000 15.2000 -44.53125 0.00000 1.12500 1.12500 12.70000 1.15500 1.14500 5.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
22.580 792.00000 15.2000 -44.53125 0.00000 1.12500 1.12500 12.70000 1.15500 1.14500 5.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
22.590 792.00000 15.2000 -44.53125 0.00000 1.12500 1.12500 12.70000 1.15500 1.14500 5.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
22.600 792.00000 15.2000 -44.53125 0.00000 1.03100 1.03100 12.00000 1.15500 1.14500 5.70000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
22.610 792.00000 15.2000 -44.53125 0.00000 1.03100 1.03100 12.00000 1.15500 1.14500 5.70000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
22.620 792.00000 15.2000 -44.53125 0.00000 1.03100 1.03100 12.00000 1.15500 1.14500 5.70000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
22.630 792.00000 15.2000 -44.53125 0.00000 1.03100 1.03100 12.00000 1.15500 1.14500 5.70000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
22.640 792.00000 15.2000 -44.53125 0.00000 1.03100 1.03100 12.00000 1.15500 1.14500 5.70000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
22.650 792.00000 15.4000 -44.53125 0.00000 0.89100 0.89100 12.10000 1.15500 1.14500 6.00000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
22.660 792.00000 15.4000 -44.53125 0.00000 0.89100 0.89100 12.10000 1.15500 1.14500 6.00000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
22.670 792.00000 15.4000 -44.53125 0.00000 0.89100 0.89100 12.10000 1.15500 1.14500 6.00000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
22.680 792.00000 15.4000 -44.53125 0.00000 0.89100 0.89100 12.10000 1.15500 1.14500 6.00000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
22.690 792.00000 15.4000 -44.53125 0.00000 0.89100 0.89100 12.10000 1.15500 1.14500 6.00000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
22.700 578.00000 15.2000 -44.53125 0.00000 0.93200 0.93200 11.90000 1.14200 1.14500 6.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
22.710 578.00000 15.2000 -44.53125 0.00000 0.93200 0.93200 11.90000 1.14200 1.14500 6.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
22.720 578.00000 15.2000 -44.53125 0.00000 0.93200 0.93200 11.90000 1.14200 1.14500 6.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
22.730 578.00000 15.2000 -44.53125 0.00000 0.93200 0.93200 11.90000 1.14200 1.14500 6.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
22.740 578.00000 15.2000 -44.53125 0.00000 0.93200 0.93200 11.90000 1.14200 1.14500 6.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
22.750 578.00000 15.2000 -44.53125 0.00000 0.89700 0.89700 12.20000 1.14200 1.14500 6.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
22.760 578.00000 15.2000 -44.53125 0.00000 0.89700 0.89700 12.20000 1.14200 1.14500 6.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
22.770 578.00000 15.2000 -44.53125 0.00000 0.89700 0.89700 12.20000 1.14200 1.14500 6.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
22.780 578.00000 15.2000 -44.53125 0.00000 0.89700 0.89700 12.20000 1.14200 1.14500 6.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
22.790 578.00000 15.2000 -44.53125 0.00000 0.89700 0.89700 12.20000 1.14200 1.14500 6.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
22.800 578.00000 15.2000 -44.53125 0.00000 0.90300 0.90300 11.60000 1.14200 1.14500 7.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.3000 0.000 0.000 0.000 0.000
22.810 578.00000 15.2000 -44.53125 0.00000 0.90300 0.90300 11.60000 1.14200 1.14500 7.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.3000 0.000 0.000 0.000 0.000
22.820 578.00000 15.2000 -44.53125 0.00000 0.90300 0.90300 11.60000 1.14200 1.14500 7.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.3000 0.000 0.000 0.000 0.000
22.830 578.00000 15.2000 -44.53125 0.00000 0.90300 0.90300 11.60000 1.14200 1.14500 7.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.3000 0.000 0.000 0.000 0.000
22.840 578.00000 15.2000 -44.53125 0.00000 0.90300 0.90300 11.60000 1.14200 1.14500 7.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.3000 0.000 0.000 0.000 0.000
22.850 578.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 12.00000 1.14200 1.14500 7.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.3000 0.000 0.000 0.000 0.000
22.860 578.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 12.00000 1.14200 1.14500 7.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.3000 0.000 0.000 0.000 0.000
22.870 578.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 12.00000 1.14200 1.14500 7.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.3000 0.000 0.000 0.000 0.000
22.880 578.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 12.00000 1.14200 1.14500 7.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.3000 0.000 0.000 0.000 0.000
22.890 578.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 12.00000 1.14200 1.14500 7.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.3000 0.000 0.000 0.000 0.000
22.900 520.00000 15.2000 -44.53125 0.00000 0.94400 0.94400 11.90000 1.06900 1.15200 7.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.3000 0.000 0.000 0.000 0.000
22.910 520.00000 15.2000 -44.53125 0.00000 0.94400 0.94400 11.90000 1.06900 1.15200 7.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.3000 0.000 0.000 0.000 0.000
22.920 520.00000 15.2000 -44.53125 0.00000 0.94400 0.94400 11.90000 1.06900 1.15200 7.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.3000 0.000 0.000 0.000 0.000
22.930 520.00000 15.2000 -44.53125 0.00000 0.94400 0.94400 11.90000 1.06900 1.15200 7.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.3000 0.000 0.000 0.000 0.000
22.940 520.00000 15.2000 -44.53125 0.00000 0.94400 0.94400 11.90000 1.06900 1.15200 7.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.3000 0.000 0.000 0.000 0.000
22.950 520.00000 15.4000 -44.53125 0.00000 0.90900 0.90900 12.00000 1.06900 1.15200 7.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.0000 0.000 0.000 0.000 0.000
22.960 520.00000 15.4000 -44.53125 0.00000 0.90900 0.90900 12.00000 1.06900 1.15200 7.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.0000 0.000 0.000 0.000 0.000
22.970 520.00000 15.4000 -44.53125 0.00000 0.90900 0.90900 12.00000 1.06900 1.15200 7.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.0000 0.000 0.000 0.000 0.000
22.980 520.00000 15.4000 -44.53125 0.00000 0.90900 0.90900 12.00000 1.06900 1.15200 7.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.0000 0.000 0.000 0.000 0.000
22.990 520.00000 15.4000 -44.53125 0.00000 0.90900 0.90900 12.00000 1.06900 1.15200 7.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.0000 0.000 0.000 0.000 0.000
23.000 520.00000 15.2000 -44.53125 0.00000 0.92100 0.92100 12.20000 1.06900 1.15200 7.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
23.010 520.00000 15.2000 -44.53125 0.00000 0.92100 0.92100 12.20000 1.06900 1.15200 7.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
23.020 520.00000 15.2000 -44.53125 0.00000 0.92100 0.92100 12.20000 1.06900 1.15200 7.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
23.030 520.00000 15.2000 -44.53125 0.00000 0.92100 0.92100 12.20000 1.06900 1.15200 7.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
23.040 520.00000 15.2000 -44.53125 0.00000 0.92100 0.92100 12.20000 1.06900 1.15200 7.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
23.050 627.00000 15.2000 -44.53125 0.00000 0.95600 0.95600 12.60000 1.06900 1.15200 7.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.0000 0.000 0.000 0.000 0.000
23.060 627.00000 15.2000 -44.53125 0.00000 0.95600 0.95600 12.60000 1.06900 1.15200 7.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.0000 0.000 0.000 0.000 0.000
23.070 627.00000 15.2000 -44.53125 0.00000 0.95600 0.95600 12.60000 1.06900 1.15200 7.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.0000 0.000 0.000 0.000 0.000
23.080 627.00000 15.2000 -44.53125 0.00000 0.95600 0.95600 12.60000 1.06900 1.15200 7.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.0000 0.000 0.000 0.000 0.000
23.090 627.00000 15.2000 -44.53125 0.00000 0.95600 0.95600 12.60000 1.06900 1.15200 7.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.0000 0.000 0.000 0.000 0.000
23.100 627.00000 15.4000 -44.53125 0.00000 0.92600 0.92600 12.10000 1.11300 1.15500 6.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
23.110 627.00000 15.4000 -44.53125 0.00000 0.92600 0.92600 12.10000 1.11300 1.15500 6.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
23.120 627.00000 15.4000 -44.53125 0.00000 0.92600 0.92600 12.10000 1.11300 1.15500 6.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
23.130 627.00000 15.4000 -44.53125 0.00000 0.92600 0.92600 12.10000 1.11300 1.15500 6.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
23.140 627.00000 15.4000 -44.53125 0.00000 0.92600 0.92600 12.10000 1.11300 1.15500 6.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
23.150 627.00000 15.2000 -44.53125 0.00000 0.89100 0.89100 12.70000 1.11300 1.15500 6.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
23.160 627.00000 15.2000 -44.53125 0.00000 0.89100 0.89100 12.70000 1.11300 1.15500 6.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
23.170 627.00000 15.2000 -44.53125 0.00000 0.89100 0.89100 12.70000 1.11300 1.15500 6.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
23.180 627.00000 15.2000 -44.53125 0.00000 0.89100 0.89100 12.70000 1.11300 1.15500 6.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
23.190 627.00000 15.2000 -44.53125 0.00000 0.89100 0.89100 12.70000 1.11300 1.15500 6.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
23.200 835.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 13.30000 1.11300 1.15500 6.30000 1.00000 1.00000 2.00000 1.00000 2.00000 0.00000 0.00000 12.2000 0.000 0.000 0.000 0.000
23.210 835.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 13.30000 1.11300 1.15500 6.30000 1.00000 1.00000 2.00000 1.00000 2.00000 0.00000 0.00000 12.2000 0.000 0.000 0.000 0.000
23.220 835.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 13.30000 1.11300 1.15500 6.30000 1.00000 1.00000 2.00000 1.00000 2.00000 0.00000 0.00000 12.2000 0.000 0.000 0.000 0.000
23.230 835.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 13.30000 1.11300 1.15500 6.30000 1.00000 1.00000 2.00000 1.00000 2.00000 0.00000 0.00000 12.2000 0.000 0.000 0.000 0.000
23.240 835.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 13.30000 1.11300 1.15500 6.30000 1.00000 1.00000 2.00000 1.00000 2.00000 0.00000 0.00000 12.2000 0.000 0.000 0.000 0.000
23.250 835.00000 15.2000 -44.53125 0.00000 0.81000 0.81000 13.50000 1.11300 1.15500 5.70000 1.00000 1.00000 2.00000 1.00000 1.00000 0.00000 0.00000 11.5000 0.000 0.000 0.000 0.000
23.260 835.00000 15.2000 -44.53125 0.00000 0.81000 0.81000 13.50000 1.11300 1.15500 5.70000 1.00000 1.00000 2.00000 1.00000 1.00000 0.00000 0.00000 11.5000 0.000 0.000 0.000 0.000
23.270 835.00000 15.2000 -44.53125 0.00000 0.81000 0.81000 13.50000 1.11300 1.15500 5.70000 1.00000 1.00000 2.00000 1.00000 1.00000 0.00000 0.00000 11.5000 0.000 0.000 0.000 0.000
23.280 981.00000 15.4000 -44.53125 0.00000 0.83300 0.83300 12.60000 1.17100 1.15200 5.30000 1.00000 1.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.4000 0.000 0.000 0.000 0.000
23.290 981.00000 15.4000 -44.53125 0.00000 0.83300 0.83300 12.60000 1.17100 1.15200 5.30000 1.00000 1.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.4000 0.000 0.000 0.000 0.000
23.300 981.00000 15.4000 -44.53125 0.00000 0.83300 0.83300 12.60000 1.17100 1.15200 5.30000 1.00000 1.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.4000 0.000 0.000 0.000 0.000
23.310 981.00000 15.4000 -44.53125 0.00000 0.83300 0.83300 12.60000 1.17100 1.15200 5.30000 1.00000 1.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.4000 0.000 0.000 0.000 0.000
23.320 981.00000 15.4000 -44.53125 0.00000 0.83300 0.83300 12.60000 1.17100 1.15200 5.30000 1.00000 1.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.4000 0.000 0.000 0.000 0.000
23.330 981.00000 15.4000 -44.53125 0.00000 0.83300 0.83300 12.60000 1.17100 1.15200 5.30000 1.00000 1.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.4000 0.000 0.000 0.000 0.000
23.340 981.00000 15.4000 -44.53125 0.00000 0.83300 0.83300 12.60000 1.17100 1.15200 5.30000 1.00000 1.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.4000 0.000 0.000 0.000 0.000
23.350 1087.00000 15.4000 -44.53125 0.00000 0.89700 0.89700 12.20000 1.17100 1.15200 4.70000 1.00000 1.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.4000 0.000 0.000 0.000 0.000
23.360 1087.00000 15.4000 -44.53125 0.00000 0.89700 0.89700 12.20000 1.17100 1.15200 4.70000 1.00000 1.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.4000 0.000 0.000 0.000 0.000
23.370 1087.00000 15.4000 -44.53125 0.00000 0.89700 0.89700 12.20000 1.17100 1.15200 4.70000 1.00000 1.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.4000 0.000 0.000 0.000 0.000
23.380 1087.00000 15.4000 -44.53125 0.00000 0.89700 0.89700 12.20000 1.17100 1.15200 4.70000 1.00000 1.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.4000 0.000 0.000 0.000 0.000
23.390 1087.00000 15.4000 -44.53125 0.00000 0.89700 0.89700 12.20000 1.17100 1.15200 4.70000 1.00000 1.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.4000 0.000 0.000 0.000 0.000
23.400 1177.00000 15.2000 -44.53125 0.00000 0.96100 0.96100 13.20000 1.15800 1.15200 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.4000 0.000 0.000 0.000 0.000
23.410 1177.00000 15.2000 -44.53125 0.00000 0.96100 0.96100 13.20000 1.15800 1.15200 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.4000 0.000 0.000 0.000 0.000
23.420 1177.00000 15.2000 -44.53125 0.00000 0.96100 0.96100 13.20000 1.15800 1.15200 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.4000 0.000 0.000 0.000 0.000
23.430 1177.00000 15.2000 -44.53125 0.00000 0.96100 0.96100 13.20000 1.15800 1.15200 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.4000 0.000 0.000 0.000 0.000
23.440 1177.00000 15.2000 -44.53125 0.00000 0.96100 0.96100 13.20000 1.15800 1.15200 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.4000 0.000 0.000 0.000 0.000
23.450 1176.00000 15.2000 -44.53125 0.00000 1.02000 1.02000 13.30000 1.15800 1.15200 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.9000 0.000 0.000 0.000 0.000
23.460 1176.00000 15.2000 -44.53125 0.00000 1.02000 1.02000 13.30000 1.15800 1.15200 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.9000 0.000 0.000 0.000 0.000
23.470 1176.00000 15.2000 -44.53125 0.00000 1.02000 1.02000 13.30000 1.15800 1.15200 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.9000 0.000 0.000 0.000 0.000
23.480 1176.00000 15.2000 -44.53125 0.00000 1.02000 1.02000 13.30000 1.15800 1.15200 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.9000 0.000 0.000 0.000 0.000
23.490 1176.00000 15.2000 -44.53125 0.00000 1.02000 1.02000 13.30000 1.15800 1.15200 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.9000 0.000 0.000 0.000 0.000
23.500 1176.00000 15.2000 -44.53125 0.00000 1.02000 1.02000 13.30000 1.15800 1.15200 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.9000 0.000 0.000 0.000 0.000
23.510 1176.00000 15.2000 -44.53125 0.00000 1.02000 1.02000 13.30000 1.15800 1.15200 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.9000 0.000 0.000 0.000 0.000
23.520 1176.00000 15.2000 -44.53125 0.00000 1.02000 1.02000 13.30000 1.15800 1.15200 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.9000 0.000 0.000 0.000 0.000
23.530 1176.00000 15.2000 -44.53125 0.00000 1.02000 1.02000 13.30000 1.15800 1.15200 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.9000 0.000 0.000 0.000 0.000
23.540 1176.00000 15.2000 -44.53125 0.00000 1.02000 1.02000 13.30000 1.15800 1.15200 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.9000 0.000 0.000 0.000 0.000
23.550 1161.00000 15.2000 -44.53125 0.00000 0.97900 0.97900 13.40000 1.15800 1.15200 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.9000 0.000 0.000 0.000 0.000
23.560 1161.00000 15.2000 -44.53125 0.00000 0.97900 0.97900 13.40000 1.15800 1.15200 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.9000 0.000 0.000 0.000 0.000
23.570 1161.00000 15.2000 -44.53125 0.00000 0.97900 0.97900 13.40000 1.15800 1.15200 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.9000 0.000 0.000 0.000 0.000
23.580 1161.00000 15.2000 -44.53125 0.00000 0.97900 0.97900 13.40000 1.15800 1.15200 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.9000 0.000 0.000 0.000 0.000
23.590 1161.00000 15.2000 -44.53125 0.00000 0.97900 0.97900 13.40000 1.15800 1.15200 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.9000 0.000 0.000 0.000 0.000
23.600 1161.00000 15.2000 -44.53125 0.00000 0.97900 0.97900 13.40000 1.15800 1.15200 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.9000 0.000 0.000 0.000 0.000
23.610 1161.00000 15.2000 -44.53125 0.00000 0.97900 0.97900 13.40000 1.15800 1.15200 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.9000 0.000 0.000 0.000 0.000
23.620 1161.00000 15.2000 -44.53125 0.00000 0.97900 0.97900 13.40000 1.15800 1.15200 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.9000 0.000 0.000 0.000 0.000
23.630 1161.00000 15.2000 -44.53125 0.00000 0.97900 0.97900 13.40000 1.15800 1.15200 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.9000 0.000 0.000 0.000 0.000
23.640 1161.00000 15.2000 -44.53125 0.00000 0.97900 0.97900 13.40000 1.15800 1.15200 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.9000 0.000 0.000 0.000 0.000
23.650 1161.00000 15.2000 -44.53125 0.00000 1.10100 1.10100 13.30000 1.15800 1.15200 4.60000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.9000 0.000 0.000 0.000 0.000
23.660 1161.00000 15.2000 -44.53125 0.00000 1.10100 1.10100 13.30000 1.15800 1.15200 4.60000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.9000 0.000 0.000 0.000 0.000
23.670 1161.00000 15.2000 -44.53125 0.00000 1.10100 1.10100 13.30000 1.15800 1.15200 4.60000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.9000 0.000 0.000 0.000 0.000
23.680 1161.00000 15.2000 -44.53125 0.00000 1.10100 1.10100 13.30000 1.15800 1.15200 4.60000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.9000 0.000 0.000 0.000 0.000
23.690 1161.00000 15.2000 -44.53125 0.00000 1.10100 1.10100 13.30000 1.15800 1.15200 4.60000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.9000 0.000 0.000 0.000 0.000
23.700 1163.00000 15.2000 -44.53125 0.00000 1.09600 1.09600 13.30000 1.12900 1.14500 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.6000 0.000 0.000 0.000 0.000
23.710 1163.00000 15.2000 -44.53125 0.00000 1.09600 1.09600 13.30000 1.12900 1.14500 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.6000 0.000 0.000 0.000 0.000
23.720 1163.00000 15.2000 -44.53125 0.00000 1.09600 1.09600 13.30000 1.12900 1.14500 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.6000 0.000 0.000 0.000 0.000
23.730 1163.00000 15.2000 -44.53125 0.00000 1.09600 1.09600 13.30000 1.12900 1.14500 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.6000 0.000 0.000 0.000 0.000
23.740 1163.00000 15.2000 -44.53125 0.00000 1.09600 1.09600 13.30000 1.12900 1.14500 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.6000 0.000 0.000 0.000 0.000
23.750 1163.00000 15.2000 -44.53125 0.00000 1.09600 1.09600 13.20000 1.12900 1.14500 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.5000 0.000 0.000 0.000 0.000
23.760 1163.00000 15.2000 -44.53125 0.00000 1.09600 1.09600 13.20000 1.12900 1.14500 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.5000 0.000 0.000 0.000 0.000
23.770 1163.00000 15.2000 -44.53125 0.00000 1.09600 1.09600 13.20000 1.12900 1.14500 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.5000 0.000 0.000 0.000 0.000
23.780 1163.00000 15.2000 -44.53125 0.00000 1.09600 1.09600 13.20000 1.12900 1.14500 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.5000 0.000 0.000 0.000 0.000
23.790 1163.00000 15.2000 -44.53125 0.00000 1.09600 1.09600 13.20000 1.12900 1.14500 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.5000 0.000 0.000 0.000 0.000
23.800 1115.00000 15.2000 -44.53125 0.00000 1.09600 1.09600 13.30000 1.12900 1.14500 4.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.6000 0.000 0.000 0.000 0.000
23.810 1115.00000 15.2000 -44.53125 0.00000 1.09600 1.09600 13.30000 1.12900 1.14500 4.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.6000 0.000 0.000 0.000 0.000
23.820 1115.00000 15.2000 -44.53125 0.00000 1.09600 1.09600 13.30000 1.12900 1.14500 4.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.6000 0.000 0.000 0.000 0.000
23.830 1115.00000 15.2000 -44.53125 0.00000 1.09600 1.09600 13.30000 1.12900 1.14500 4.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.6000 0.000 0.000 0.000 0.000
23.840 1115.00000 15.2000 -44.53125 0.00000 1.09600 1.09600 13.30000 1.12900 1.14500 4.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.6000 0.000 0.000 0.000 0.000
23.850 1115.00000 15.1000 -44.53125 0.00000 1.16000 1.16000 13.20000 1.12900 1.14500 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.2000 0.000 0.000 0.000 0.000
23.860 1115.00000 15.1000 -44.53125 0.00000 1.16000 1.16000 13.20000 1.12900 1.14500 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.2000 0.000 0.000 0.000 0.000
23.870 1115.00000 15.1000 -44.53125 0.00000 1.16000 1.16000 13.20000 1.12900 1.14500 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.2000 0.000 0.000 0.000 0.000
23.880 1115.00000 15.1000 -44.53125 0.00000 1.16000 1.16000 13.20000 1.12900 1.14500 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.2000 0.000 0.000 0.000 0.000
23.890 1115.00000 15.1000 -44.53125 0.00000 1.16000 1.16000 13.20000 1.12900 1.14500 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.2000 0.000 0.000 0.000 0.000
23.900 1115.00000 15.1000 -44.53125 0.00000 1.16000 1.16000 13.20000 1.12900 1.14500 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.2000 0.000 0.000 0.000 0.000
23.910 1084.00000 15.2000 -44.53125 0.00000 1.14800 1.14800 13.50000 1.08800 1.14900 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.3000 0.000 0.000 0.000 0.000
23.920 1084.00000 15.2000 -44.53125 0.00000 1.14800 1.14800 13.50000 1.08800 1.14900 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.3000 0.000 0.000 0.000 0.000
23.930 1084.00000 15.2000 -44.53125 0.00000 1.14800 1.14800 13.50000 1.08800 1.14900 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.3000 0.000 0.000 0.000 0.000
23.940 1084.00000 15.2000 -44.53125 0.00000 1.14800 1.14800 13.50000 1.08800 1.14900 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.3000 0.000 0.000 0.000 0.000
23.950 1084.00000 15.2000 -44.53125 0.00000 1.14800 1.14800 13.50000 1.08800 1.14900 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.3000 0.000 0.000 0.000 0.000
23.960 1084.00000 15.2000 -44.53125 0.00000 1.14800 1.14800 13.50000 1.08800 1.14900 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.3000 0.000 0.000 0.000 0.000
23.970 1048.00000 15.2000 -44.53125 0.00000 1.11900 1.11900 13.40000 1.08800 1.14900 4.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.3000 0.000 0.000 0.000 0.000
23.980 1048.00000 15.2000 -44.53125 0.00000 1.11900 1.11900 13.40000 1.08800 1.14900 4.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.3000 0.000 0.000 0.000 0.000
23.990 1048.00000 15.2000 -44.53125 0.00000 1.11900 1.11900 13.40000 1.08800 1.14900 4.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.3000 0.000 0.000 0.000 0.000
24.000 1048.00000 15.2000 -44.53125 0.00000 1.11900 1.11900 13.40000 1.08800 1.14900 4.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.3000 0.000 0.000 0.000 0.000
24.010 1048.00000 15.2000 -44.53125 0.00000 1.11900 1.11900 13.40000 1.08800 1.14900 4.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.3000 0.000 0.000 0.000 0.000
24.020 1048.00000 15.2000 -44.53125 0.00000 1.11900 1.11900 13.40000 1.08800 1.14900 4.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.3000 0.000 0.000 0.000 0.000
24.030 999.00000 15.2000 -44.53125 0.00000 1.16000 1.16000 13.00000 1.09800 1.15200 4.60000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.1000 0.000 0.000 0.000 0.000
24.040 999.00000 15.2000 -44.53125 0.00000 1.16000 1.16000 13.00000 1.09800 1.15200 4.60000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.1000 0.000 0.000 0.000 0.000
24.050 999.00000 15.2000 -44.53125 0.00000 1.16000 1.16000 13.00000 1.09800 1.15200 4.60000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.1000 0.000 0.000 0.000 0.000
24.060 999.00000 15.2000 -44.53125 0.00000 1.16000 1.16000 13.00000 1.09800 1.15200 4.60000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.1000 0.000 0.000 0.000 0.000
24.070 999.00000 15.2000 -44.53125 0.00000 1.16000 1.16000 13.00000 1.09800 1.15200 4.60000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.1000 0.000 0.000 0.000 0.000
24.080 999.00000 15.1000 -44.53125 0.00000 1.14200 1.14200 13.40000 1.09800 1.15200 4.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.2000 0.000 0.000 0.000 0.000
24.090 999.00000 15.1000 -44.53125 0.00000 1.14200 1.14200 13.40000 1.09800 1.15200 4.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.2000 0.000 0.000 0.000 0.000
24.100 999.00000 15.1000 -44.53125 0.00000 1.14200 1.14200 13.40000 1.09800 1.15200 4.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.2000 0.000 0.000 0.000 0.000
24.110 999.00000 15.1000 -44.53125 0.00000 1.14200 1.14200 13.40000 1.09800 1.15200 4.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.2000 0.000 0.000 0.000 0.000
24.120 999.00000 15.1000 -44.53125 0.00000 1.14200 1.14200 13.40000 1.09800 1.15200 4.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.2000 0.000 0.000 0.000 0.000
24.130 921.00000 15.2000 -44.53125 0.00000 1.07200 1.07200 13.30000 1.09800 1.15200 4.60000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
24.140 921.00000 15.2000 -44.53125 0.00000 1.07200 1.07200 13.30000 1.09800 1.15200 4.60000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
24.150 921.00000 15.2000 -44.53125 0.00000 1.07200 1.07200 13.30000 1.09800 1.15200 4.60000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
24.160 921.00000 15.2000 -44.53125 0.00000 1.07200 1.07200 13.30000 1.09800 1.15200 4.60000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
24.170 921.00000 15.2000 -44.53125 0.00000 1.07200 1.07200 13.30000 1.09800 1.15200 4.60000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
24.180 921.00000 15.2000 -44.53125 0.00000 1.02600 1.02600 13.50000 1.09800 1.15200 4.70000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.4000 0.000 0.000 0.000 0.000
24.190 921.00000 15.2000 -44.53125 0.00000 1.02600 1.02600 13.50000 1.09800 1.15200 4.70000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.4000 0.000 0.000 0.000 0.000
24.200 921.00000 15.2000 -44.53125 0.00000 1.02600 1.02600 13.50000 1.09800 1.15200 4.70000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.4000 0.000 0.000 0.000 0.000
24.210 921.00000 15.2000 -44.53125 0.00000 1.02600 1.02600 13.50000 1.09800 1.15200 4.70000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.4000 0.000 0.000 0.000 0.000
24.220 921.00000 15.2000 -44.53125 0.00000 1.02600 1.02600 13.50000 1.09800 1.15200 4.70000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.4000 0.000 0.000 0.000 0.000
24.230 840.00000 15.2000 -44.53125 0.00000 1.08400 1.08400 13.20000 1.13600 1.15500 5.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
24.240 840.00000 15.2000 -44.53125 0.00000 1.08400 1.08400 13.20000 1.13600 1.15500 5.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
24.250 840.00000 15.2000 -44.53125 0.00000 1.08400 1.08400 13.20000 1.13600 1.15500 5.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
24.260 840.00000 15.2000 -44.53125 0.00000 1.08400 1.08400 13.20000 1.13600 1.15500 5.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
24.270 840.00000 15.2000 -44.53125 0.00000 1.08400 1.08400 13.20000 1.13600 1.15500 5.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
24.280 840.00000 15.2000 -44.53125 0.00000 0.98500 0.98500 13.20000 1.13600 1.15500 4.80000 1.00000 1.00000 1.00000 1.00000 2.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
24.290 840.00000 15.2000 -44.53125 0.00000 0.98500 0.98500 13.20000 1.13600 1.15500 4.80000 1.00000 1.00000 1.00000 1.00000 2.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
24.300 840.00000 15.2000 -44.53125 0.00000 0.98500 0.98500 13.20000 1.13600 1.15500 4.80000 1.00000 1.00000 1.00000 1.00000 2.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
24.310 840.00000 15.2000 -44.53125 0.00000 0.98500 0.98500 13.20000 1.13600 1.15500 4.80000 1.00000 1.00000 1.00000 1.00000 2.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
24.320 840.00000 15.2000 -44.53125 0.00000 0.98500 0.98500 13.20000 1.13600 1.15500 4.80000 1.00000 1.00000 1.00000 1.00000 2.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
24.330 840.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 13.20000 1.13600 1.15500 5.10000 1.00000 1.00000 2.00000 1.00000 2.00000 0.00000 0.00000 13.4000 0.000 0.000 0.000 0.000
24.340 840.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 13.20000 1.13600 1.15500 5.10000 1.00000 1.00000 2.00000 1.00000 2.00000 0.00000 0.00000 13.4000 0.000 0.000 0.000 0.000
24.350 840.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 13.20000 1.13600 1.15500 5.10000 1.00000 1.00000 2.00000 1.00000 2.00000 0.00000 0.00000 13.4000 0.000 0.000 0.000 0.000
24.360 840.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 13.20000 1.13600 1.15500 5.10000 1.00000 1.00000 2.00000 1.00000 2.00000 0.00000 0.00000 13.4000 0.000 0.000 0.000 0.000
24.370 840.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 13.20000 1.13600 1.15500 5.10000 1.00000 1.00000 2.00000 1.00000 2.00000 0.00000 0.00000 13.4000 0.000 0.000 0.000 0.000
24.380 840.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 13.20000 1.13600 1.15500 5.10000 1.00000 1.00000 2.00000 1.00000 2.00000 0.00000 0.00000 13.4000 0.000 0.000 0.000 0.000
24.390 840.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 13.20000 1.13600 1.15500 5.10000 1.00000 1.00000 2.00000 1.00000 2.00000 0.00000 0.00000 13.4000 0.000 0.000 0.000 0.000
24.400 840.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 13.20000 1.13600 1.15500 5.10000 1.00000 1.00000 2.00000 1.00000 2.00000 0.00000 0.00000 13.4000 0.000 0.000 0.000 0.000
24.410 840.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 13.20000 1.13600 1.15500 5.10000 1.00000 1.00000 2.00000 1.00000 2.00000 0.00000 0.00000 13.4000 0.000 0.000 0.000 0.000
24.420 840.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 13.20000 1.13600 1.15500 5.10000 1.00000 1.00000 2.00000 1.00000 2.00000 0.00000 0.00000 13.4000 0.000 0.000 0.000 0.000
24.430 758.00000 15.2000 -44.53125 0.00000 0.94400 0.94400 12.60000 1.13600 1.15500 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
24.440 758.00000 15.2000 -44.53125 0.00000 0.94400 0.94400 12.60000 1.13600 1.15500 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
24.450 758.00000 15.2000 -44.53125 0.00000 0.94400 0.94400 12.60000 1.13600 1.15500 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
24.460 758.00000 15.2000 -44.53125 0.00000 0.94400 0.94400 12.60000 1.13600 1.15500 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
24.470 758.00000 15.2000 -44.53125 0.00000 0.94400 0.94400 12.60000 1.13600 1.15500 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
24.480 758.00000 15.2000 -44.53125 0.00000 0.94400 0.94400 12.60000 1.13600 1.15500 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
24.490 758.00000 15.2000 -44.53125 0.00000 0.93800 0.93800 12.30000 1.15500 1.14900 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
24.500 758.00000 15.2000 -44.53125 0.00000 0.93800 0.93800 12.30000 1.15500 1.14900 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
24.510 758.00000 15.2000 -44.53125 0.00000 0.93800 0.93800 12.30000 1.15500 1.14900 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
24.520 758.00000 15.2000 -44.53125 0.00000 0.93800 0.93800 12.30000 1.15500 1.14900 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
24.530 758.00000 15.2000 -44.53125 0.00000 0.93800 0.93800 12.30000 1.15500 1.14900 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
24.540 758.00000 15.2000 -44.53125 0.00000 0.93800 0.93800 12.30000 1.15500 1.14900 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
24.550 745.00000 15.2000 -44.53125 0.00000 0.92600 0.92600 12.50000 1.15500 1.14900 5.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
24.560 745.00000 15.2000 -44.53125 0.00000 0.92600 0.92600 12.50000 1.15500 1.14900 5.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
24.570 745.00000 15.2000 -44.53125 0.00000 0.92600 0.92600 12.50000 1.15500 1.14900 5.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
24.580 745.00000 15.2000 -44.53125 0.00000 0.92600 0.92600 12.50000 1.15500 1.14900 5.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
24.590 745.00000 15.2000 -44.53125 0.00000 0.92600 0.92600 12.50000 1.15500 1.14900 5.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
24.600 745.00000 15.2000 -44.53125 0.00000 0.92600 0.92600 12.50000 1.15500 1.14900 5.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
24.610 745.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 12.70000 1.15500 1.14900 5.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
24.620 745.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 12.70000 1.15500 1.14900 5.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
24.630 745.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 12.70000 1.15500 1.14900 5.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
24.640 745.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 12.70000 1.15500 1.14900 5.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
24.650 745.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 12.70000 1.15500 1.14900 5.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
24.660 745.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 12.70000 1.15500 1.14900 5.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
24.670 754.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 13.20000 1.16800 1.15200 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
24.680 754.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 13.20000 1.16800 1.15200 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
24.690 754.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 13.20000 1.16800 1.15200 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
24.700 754.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 13.20000 1.16800 1.15200 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
24.710 754.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 13.20000 1.16800 1.15200 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
24.720 754.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 13.10000 1.16800 1.15200 5.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
24.730 754.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 13.10000 1.16800 1.15200 5.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
24.740 754.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 13.10000 1.16800 1.15200 5.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
24.750 754.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 13.10000 1.16800 1.15200 5.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
24.760 754.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 13.10000 1.16800 1.15200 5.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
24.770 815.00000 15.2000 -44.53125 0.00000 0.85600 0.85600 13.30000 1.16800 1.15200 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
24.780 815.00000 15.2000 -44.53125 0.00000 0.85600 0.85600 13.30000 1.16800 1.15200 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
24.790 815.00000 15.2000 -44.53125 0.00000 0.85600 0.85600 13.30000 1.16800 1.15200 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
24.800 815.00000 15.2000 -44.53125 0.00000 0.85600 0.85600 13.30000 1.16800 1.15200 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
24.810 815.00000 15.2000 -44.53125 0.00000 0.85600 0.85600 13.30000 1.16800 1.15200 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
24.820 815.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 13.10000 1.16800 1.15200 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
24.830 815.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 13.10000 1.16800 1.15200 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
24.840 815.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 13.10000 1.16800 1.15200 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
24.850 815.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 13.10000 1.16800 1.15200 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
24.860 815.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 13.10000 1.16800 1.15200 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
24.870 815.00000 15.4000 -44.53125 0.00000 0.86800 0.86800 12.70000 1.16800 1.14500 5.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
24.880 815.00000 15.4000 -44.53125 0.00000 0.86800 0.86800 12.70000 1.16800 1.14500 5.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
24.890 815.00000 15.4000 -44.53125 0.00000 0.86800 0.86800 12.70000 1.16800 1.14500 5.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
24.900 815.00000 15.4000 -44.53125 0.00000 0.86800 0.86800 12.70000 1.16800 1.14500 5.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
24.910 815.00000 15.4000 -44.53125 0.00000 0.86800 0.86800 12.70000 1.16800 1.14500 5.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
24.920 900.00000 15.2000 -44.53125 0.00000 0.82700 0.82700 13.30000 1.16800 1.14500 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
24.930 900.00000 15.2000 -44.53125 0.00000 0.82700 0.82700 13.30000 1.16800 1.14500 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
24.940 900.00000 15.2000 -44.53125 0.00000 0.82700 0.82700 13.30000 1.16800 1.14500 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
24.950 900.00000 15.2000 -44.53125 0.00000 0.82700 0.82700 13.30000 1.16800 1.14500 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
24.960 900.00000 15.2000 -44.53125 0.00000 0.82700 0.82700 13.30000 1.16800 1.14500 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
24.970 900.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 13.50000 1.16800 1.14500 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.3000 0.000 0.000 0.000 0.000
24.980 900.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 13.50000 1.16800 1.14500 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.3000 0.000 0.000 0.000 0.000
24.990 900.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 13.50000 1.16800 1.14500 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.3000 0.000 0.000 0.000 0.000
25.000 900.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 13.50000 1.16800 1.14500 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.3000 0.000 0.000 0.000 0.000
25.010 900.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 13.50000 1.16800 1.14500 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.3000 0.000 0.000 0.000 0.000
25.020 941.00000 15.4000 -44.53125 0.00000 0.90900 0.90900 12.20000 1.16800 1.14500 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.3000 0.000 0.000 0.000 0.000
25.030 941.00000 15.4000 -44.53125 0.00000 0.90900 0.90900 12.20000 1.16800 1.14500 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.3000 0.000 0.000 0.000 0.000
25.040 941.00000 15.4000 -44.53125 0.00000 0.90900 0.90900 12.20000 1.16800 1.14500 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.3000 0.000 0.000 0.000 0.000
25.050 941.00000 15.4000 -44.53125 0.00000 0.90900 0.90900 12.20000 1.16800 1.14500 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.3000 0.000 0.000 0.000 0.000
25.060 941.00000 15.4000 -44.53125 0.00000 0.90900 0.90900 12.20000 1.16800 1.14500 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.3000 0.000 0.000 0.000 0.000
25.070 941.00000 15.2000 -44.53125 0.00000 0.92600 0.92600 13.20000 1.15500 1.14200 4.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.3000 0.000 0.000 0.000 0.000
25.080 941.00000 15.2000 -44.53125 0.00000 0.92600 0.92600 13.20000 1.15500 1.14200 4.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.3000 0.000 0.000 0.000 0.000
25.090 941.00000 15.2000 -44.53125 0.00000 0.92600 0.92600 13.20000 1.15500 1.14200 4.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.3000 0.000 0.000 0.000 0.000
25.100 941.00000 15.2000 -44.53125 0.00000 0.92600 0.92600 13.20000 1.15500 1.14200 4.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.3000 0.000 0.000 0.000 0.000
25.110 941.00000 15.2000 -44.53125 0.00000 0.92600 0.92600 13.20000 1.15500 1.14200 4.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.3000 0.000 0.000 0.000 0.000
25.120 973.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 13.40000 1.15500 1.14200 5.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.3000 0.000 0.000 0.000 0.000
25.130 973.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 13.40000 1.15500 1.14200 5.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.3000 0.000 0.000 0.000 0.000
25.140 973.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 13.40000 1.15500 1.14200 5.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.3000 0.000 0.000 0.000 0.000
25.150 973.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 13.40000 1.15500 1.14200 5.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.3000 0.000 0.000 0.000 0.000
25.160 973.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 13.40000 1.15500 1.14200 5.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.3000 0.000 0.000 0.000 0.000
25.170 973.00000 15.2000 -44.53125 0.00000 0.93200 0.93200 13.20000 1.15500 1.14200 4.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.3000 0.000 0.000 0.000 0.000
25.180 973.00000 15.2000 -44.53125 0.00000 0.93200 0.93200 13.20000 1.15500 1.14200 4.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.3000 0.000 0.000 0.000 0.000
25.190 973.00000 15.2000 -44.53125 0.00000 0.93200 0.93200 13.20000 1.15500 1.14200 4.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.3000 0.000 0.000 0.000 0.000
25.200 973.00000 15.2000 -44.53125 0.00000 0.93200 0.93200 13.20000 1.15500 1.14200 4.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.3000 0.000 0.000 0.000 0.000
25.210 973.00000 15.2000 -44.53125 0.00000 0.93200 0.93200 13.20000 1.15500 1.14200 4.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.3000 0.000 0.000 0.000 0.000
25.220 974.00000 15.4000 -44.53125 0.00000 0.93200 0.93200 12.50000 1.15500 1.14200 4.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.3000 0.000 0.000 0.000 0.000
25.230 974.00000 15.4000 -44.53125 0.00000 0.93200 0.93200 12.50000 1.15500 1.14200 4.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.3000 0.000 0.000 0.000 0.000
25.240 974.00000 15.4000 -44.53125 0.00000 0.93200 0.93200 12.50000 1.15500 1.14200 4.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.3000 0.000 0.000 0.000 0.000
25.250 974.00000 15.4000 -44.53125 0.00000 0.93200 0.93200 12.50000 1.15500 1.14200 4.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.3000 0.000 0.000 0.000 0.000
25.260 974.00000 15.4000 -44.53125 0.00000 0.93200 0.93200 12.50000 1.15500 1.14200 4.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.3000 0.000 0.000 0.000 0.000
25.270 974.00000 15.2000 -44.53125 0.00000 0.97900 0.97900 13.30000 1.14200 1.14900 4.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.6000 0.000 0.000 0.000 0.000
25.280 974.00000 15.2000 -44.53125 0.00000 0.97900 0.97900 13.30000 1.14200 1.14900 4.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.6000 0.000 0.000 0.000 0.000
25.290 974.00000 15.2000 -44.53125 0.00000 0.97900 0.97900 13.30000 1.14200 1.14900 4.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.6000 0.000 0.000 0.000 0.000
25.300 974.00000 15.2000 -44.53125 0.00000 0.97900 0.97900 13.30000 1.14200 1.14900 4.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.6000 0.000 0.000 0.000 0.000
25.310 974.00000 15.2000 -44.53125 0.00000 0.97900 0.97900 13.30000 1.14200 1.14900 4.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.6000 0.000 0.000 0.000 0.000
25.320 974.00000 15.2000 -44.53125 0.00000 0.97900 0.97900 13.30000 1.14200 1.14900 4.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.6000 0.000 0.000 0.000 0.000
25.330 990.00000 15.2000 -44.53125 0.00000 0.90300 0.90300 13.30000 1.14200 1.14900 4.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.6000 0.000 0.000 0.000 0.000
25.340 990.00000 15.2000 -44.53125 0.00000 0.90300 0.90300 13.30000 1.14200 1.14900 4.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.6000 0.000 0.000 0.000 0.000
25.350 990.00000 15.2000 -44.53125 0.00000 0.90300 0.90300 13.30000 1.14200 1.14900 4.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.6000 0.000 0.000 0.000 0.000
25.360 990.00000 15.2000 -44.53125 0.00000 0.90300 0.90300 13.30000 1.14200 1.14900 4.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.6000 0.000 0.000 0.000 0.000
25.370 990.00000 15.2000 -44.53125 0.00000 0.90300 0.90300 13.30000 1.14200 1.14900 4.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.6000 0.000 0.000 0.000 0.000
25.380 990.00000 15.2000 -44.53125 0.00000 0.90300 0.90300 13.30000 1.14200 1.14900 4.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.6000 0.000 0.000 0.000 0.000
25.390 956.00000 15.2000 -44.53125 0.00000 0.93200 0.93200 13.20000 1.14200 1.14900 4.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.6000 0.000 0.000 0.000 0.000
25.400 956.00000 15.2000 -44.53125 0.00000 0.93200 0.93200 13.20000 1.14200 1.14900 4.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.6000 0.000 0.000 0.000 0.000
25.410 956.00000 15.2000 -44.53125 0.00000 0.93200 0.93200 13.20000 1.14200 1.14900 4.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.6000 0.000 0.000 0.000 0.000
25.420 956.00000 15.2000 -44.53125 0.00000 0.93200 0.93200 13.20000 1.14200 1.14900 4.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.6000 0.000 0.000 0.000 0.000
25.430 956.00000 15.2000 -44.53125 0.00000 0.93200 0.93200 13.20000 1.14200 1.14900 4.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.6000 0.000 0.000 0.000 0.000
25.440 956.00000 15.2000 -44.53125 0.00000 0.93200 0.93200 13.20000 1.14200 1.14900 4.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.6000 0.000 0.000 0.000 0.000
25.450 956.00000 15.2000 -44.53125 0.00000 0.89100 0.89100 13.40000 1.14200 1.14900 4.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.0000 0.000 0.000 0.000 0.000
25.460 934.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 13.00000 1.12300 1.16500 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.0000 0.000 0.000 0.000 0.000
25.470 934.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 13.00000 1.12300 1.16500 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.0000 0.000 0.000 0.000 0.000
25.480 934.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 13.00000 1.12300 1.16500 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.0000 0.000 0.000 0.000 0.000
25.490 934.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 13.00000 1.12300 1.16500 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.0000 0.000 0.000 0.000 0.000
25.500 934.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 13.00000 1.12300 1.16500 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.0000 0.000 0.000 0.000 0.000
25.510 934.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 13.00000 1.12300 1.16500 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.0000 0.000 0.000 0.000 0.000
25.520 934.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 13.00000 1.12300 1.16500 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.0000 0.000 0.000 0.000 0.000
25.530 934.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 13.00000 1.12300 1.16500 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.0000 0.000 0.000 0.000 0.000
25.540 934.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 13.00000 1.12300 1.16500 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.0000 0.000 0.000 0.000 0.000
25.550 934.00000 15.2000 -44.53125 0.00000 0.95600 0.95600 13.20000 1.12300 1.16500 4.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
25.560 934.00000 15.2000 -44.53125 0.00000 0.95600 0.95600 13.20000 1.12300 1.16500 4.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
25.570 934.00000 15.2000 -44.53125 0.00000 0.95600 0.95600 13.20000 1.12300 1.16500 4.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
25.580 934.00000 15.2000 -44.53125 0.00000 0.95600 0.95600 13.20000 1.12300 1.16500 4.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
25.590 934.00000 15.2000 -44.53125 0.00000 0.95600 0.95600 13.20000 1.12300 1.16500 4.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
25.600 909.00000 15.2000 -44.53125 0.00000 0.95000 0.95000 12.70000 1.12300 1.16500 4.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
25.610 909.00000 15.2000 -44.53125 0.00000 0.95000 0.95000 12.70000 1.12300 1.16500 4.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
25.620 909.00000 15.2000 -44.53125 0.00000 0.95000 0.95000 12.70000 1.12300 1.16500 4.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
25.630 909.00000 15.2000 -44.53125 0.00000 0.95000 0.95000 12.70000 1.12300 1.16500 4.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
25.640 909.00000 15.2000 -44.53125 0.00000 0.95000 0.95000 12.70000 1.12300 1.16500 4.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
25.650 909.00000 15.2000 -44.53125 0.00000 0.97300 0.97300 13.20000 1.12300 1.16500 4.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
25.660 909.00000 15.2000 -44.53125 0.00000 0.97300 0.97300 13.20000 1.12300 1.16500 4.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
25.670 909.00000 15.2000 -44.53125 0.00000 0.97300 0.97300 13.20000 1.12300 1.16500 4.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
25.680 909.00000 15.2000 -44.53125 0.00000 0.97300 0.97300 13.20000 1.12300 1.16500 4.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
25.690 909.00000 15.2000 -44.53125 0.00000 0.97300 0.97300 13.20000 1.12300 1.16500 4.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
25.700 909.00000 15.2000 -44.53125 0.00000 0.92100 0.92100 13.30000 1.09400 1.15800 4.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
25.710 909.00000 15.2000 -44.53125 0.00000 0.92100 0.92100 13.30000 1.09400 1.15800 4.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
25.720 909.00000 15.2000 -44.53125 0.00000 0.92100 0.92100 13.30000 1.09400 1.15800 4.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
25.730 909.00000 15.2000 -44.53125 0.00000 0.92100 0.92100 13.30000 1.09400 1.15800 4.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
25.740 909.00000 15.2000 -44.53125 0.00000 0.92100 0.92100 13.30000 1.09400 1.15800 4.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
25.750 852.00000 15.2000 -44.53125 0.00000 0.92100 0.92100 13.40000 1.09400 1.15800 4.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
25.760 852.00000 15.2000 -44.53125 0.00000 0.92100 0.92100 13.40000 1.09400 1.15800 4.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
25.770 852.00000 15.2000 -44.53125 0.00000 0.92100 0.92100 13.40000 1.09400 1.15800 4.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
25.780 852.00000 15.2000 -44.53125 0.00000 0.92100 0.92100 13.40000 1.09400 1.15800 4.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
25.790 852.00000 15.2000 -44.53125 0.00000 0.92100 0.92100 13.40000 1.09400 1.15800 4.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
25.801 852.00000 15.2000 -44.53125 0.00000 0.87400 0.87400 13.50000 1.09400 1.15800 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
25.811 852.00000 15.2000 -44.53125 0.00000 0.87400 0.87400 13.50000 1.09400 1.15800 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
25.821 852.00000 15.2000 -44.53125 0.00000 0.87400 0.87400 13.50000 1.09400 1.15800 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
25.831 852.00000 15.2000 -44.53125 0.00000 0.87400 0.87400 13.50000 1.09400 1.15800 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
25.841 852.00000 15.2000 -44.53125 0.00000 0.87400 0.87400 13.50000 1.09400 1.15800 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
25.851 828.00000 15.1000 -44.53125 0.00000 0.90900 0.90900 13.20000 1.09400 1.15800 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
25.861 828.00000 15.1000 -44.53125 0.00000 0.90900 0.90900 13.20000 1.09400 1.15800 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
25.871 828.00000 15.1000 -44.53125 0.00000 0.90900 0.90900 13.20000 1.09400 1.15800 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
25.881 828.00000 15.1000 -44.53125 0.00000 0.90900 0.90900 13.20000 1.09400 1.15800 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
25.891 828.00000 15.1000 -44.53125 0.00000 0.90900 0.90900 13.20000 1.09400 1.15800 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
25.901 828.00000 15.2000 -44.53125 0.00000 0.92100 0.92100 13.50000 1.09800 1.15500 5.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
25.911 828.00000 15.2000 -44.53125 0.00000 0.92100 0.92100 13.50000 1.09800 1.15500 5.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
25.921 828.00000 15.2000 -44.53125 0.00000 0.92100 0.92100 13.50000 1.09800 1.15500 5.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
25.931 828.00000 15.2000 -44.53125 0.00000 0.92100 0.92100 13.50000 1.09800 1.15500 5.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
25.941 828.00000 15.2000 -44.53125 0.00000 0.92100 0.92100 13.50000 1.09800 1.15500 5.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
25.951 826.00000 15.4000 -44.53125 0.00000 0.95000 0.95000 12.20000 1.09800 1.15500 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.4000 0.000 0.000 0.000 0.000
25.961 826.00000 15.4000 -44.53125 0.00000 0.95000 0.95000 12.20000 1.09800 1.15500 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.4000 0.000 0.000 0.000 0.000
25.971 826.00000 15.4000 -44.53125 0.00000 0.95000 0.95000 12.20000 1.09800 1.15500 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.4000 0.000 0.000 0.000 0.000
25.981 826.00000 15.4000 -44.53125 0.00000 0.95000 0.95000 12.20000 1.09800 1.15500 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.4000 0.000 0.000 0.000 0.000
25.991 826.00000 15.4000 -44.53125 0.00000 0.95000 0.95000 12.20000 1.09800 1.15500 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.4000 0.000 0.000 0.000 0.000
26.001 826.00000 15.2000 -44.53125 0.00000 0.96100 0.96100 13.30000 1.09800 1.15500 5.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
26.011 826.00000 15.2000 -44.53125 0.00000 0.96100 0.96100 13.30000 1.09800 1.15500 5.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
26.021 826.00000 15.2000 -44.53125 0.00000 0.96100 0.96100 13.30000 1.09800 1.15500 5.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
26.031 826.00000 15.2000 -44.53125 0.00000 0.96100 0.96100 13.30000 1.09800 1.15500 5.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
26.041 826.00000 15.2000 -44.53125 0.00000 0.96100 0.96100 13.30000 1.09800 1.15500 5.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
26.051 826.00000 15.2000 -44.53125 0.00000 0.89700 0.89700 13.10000 1.09800 1.15500 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.6000 0.000 0.000 0.000 0.000
26.061 826.00000 15.2000 -44.53125 0.00000 0.89700 0.89700 13.10000 1.09800 1.15500 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.6000 0.000 0.000 0.000 0.000
26.071 826.00000 15.2000 -44.53125 0.00000 0.89700 0.89700 13.10000 1.09800 1.15500 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.6000 0.000 0.000 0.000 0.000
26.081 826.00000 15.2000 -44.53125 0.00000 0.89700 0.89700 13.10000 1.09800 1.15500 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.6000 0.000 0.000 0.000 0.000
26.091 826.00000 15.2000 -44.53125 0.00000 0.89700 0.89700 13.10000 1.09800 1.15500 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.6000 0.000 0.000 0.000 0.000
26.101 824.00000 15.2000 -44.53125 0.00000 0.86800 0.86800 13.40000 1.10100 1.16100 5.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
26.111 824.00000 15.2000 -44.53125 0.00000 0.86800 0.86800 13.40000 1.10100 1.16100 5.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
26.121 824.00000 15.2000 -44.53125 0.00000 0.86800 0.86800 13.40000 1.10100 1.16100 5.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
26.131 824.00000 15.2000 -44.53125 0.00000 0.86800 0.86800 13.40000 1.10100 1.16100 5.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
26.141 824.00000 15.2000 -44.53125 0.00000 0.86800 0.86800 13.40000 1.10100 1.16100 5.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
26.151 824.00000 15.2000 -44.53125 0.00000 0.89700 0.89700 13.30000 1.10100 1.16100 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
26.161 824.00000 15.2000 -44.53125 0.00000 0.89700 0.89700 13.30000 1.10100 1.16100 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
26.171 824.00000 15.2000 -44.53125 0.00000 0.89700 0.89700 13.30000 1.10100 1.16100 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
26.181 824.00000 15.2000 -44.53125 0.00000 0.89700 0.89700 13.30000 1.10100 1.16100 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
26.191 824.00000 15.2000 -44.53125 0.00000 0.89700 0.89700 13.30000 1.10100 1.16100 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
26.201 803.00000 15.2000 -44.53125 0.00000 0.87400 0.87400 13.20000 1.10100 1.16100 5.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.6000 0.000 0.000 0.000 0.000
26.211 803.00000 15.2000 -44.53125 0.00000 0.87400 0.87400 13.20000 1.10100 1.16100 5.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.6000 0.000 0.000 0.000 0.000
26.221 803.00000 15.2000 -44.53125 0.00000 0.87400 0.87400 13.20000 1.10100 1.16100 5.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.6000 0.000 0.000 0.000 0.000
26.231 803.00000 15.2000 -44.53125 0.00000 0.87400 0.87400 13.20000 1.10100 1.16100 5.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.6000 0.000 0.000 0.000 0.000
26.241 803.00000 15.2000 -44.53125 0.00000 0.87400 0.87400 13.20000 1.10100 1.16100 5.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.6000 0.000 0.000 0.000 0.000
26.251 803.00000 15.2000 -44.53125 0.00000 0.92600 0.92600 13.60000 1.10100 1.16100 5.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.6000 0.000 0.000 0.000 0.000
26.261 803.00000 15.2000 -44.53125 0.00000 0.92600 0.92600 13.60000 1.10100 1.16100 5.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.6000 0.000 0.000 0.000 0.000
26.271 803.00000 15.2000 -44.53125 0.00000 0.92600 0.92600 13.60000 1.10100 1.16100 5.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.6000 0.000 0.000 0.000 0.000
26.281 803.00000 15.2000 -44.53125 0.00000 0.92600 0.92600 13.60000 1.10100 1.16100 5.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.6000 0.000 0.000 0.000 0.000
26.291 803.00000 15.2000 -44.53125 0.00000 0.92600 0.92600 13.60000 1.10100 1.16100 5.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.6000 0.000 0.000 0.000 0.000
26.301 803.00000 15.2000 -44.53125 0.00000 0.89700 0.89700 12.80000 1.10400 1.15500 5.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
26.311 803.00000 15.2000 -44.53125 0.00000 0.89700 0.89700 12.80000 1.10400 1.15500 5.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
26.321 803.00000 15.2000 -44.53125 0.00000 0.89700 0.89700 12.80000 1.10400 1.15500 5.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
26.331 803.00000 15.2000 -44.53125 0.00000 0.89700 0.89700 12.80000 1.10400 1.15500 5.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
26.341 803.00000 15.2000 -44.53125 0.00000 0.89700 0.89700 12.80000 1.10400 1.15500 5.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
26.351 808.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 13.00000 1.10400 1.15500 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
26.361 808.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 13.00000 1.10400 1.15500 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
26.371 808.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 13.00000 1.10400 1.15500 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
26.381 808.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 13.00000 1.10400 1.15500 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
26.391 808.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 13.00000 1.10400 1.15500 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
26.401 808.00000 15.2000 -44.53125 0.00000 0.93200 0.93200 13.00000 1.10400 1.15500 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
26.411 808.00000 15.2000 -44.53125 0.00000 0.93200 0.93200 13.00000 1.10400 1.15500 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
26.421 808.00000 15.2000 -44.53125 0.00000 0.93200 0.93200 13.00000 1.10400 1.15500 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
26.431 808.00000 15.2000 -44.53125 0.00000 0.93200 0.93200 13.00000 1.10400 1.15500 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
26.441 808.00000 15.2000 -44.53125 0.00000 0.93200 0.93200 13.00000 1.10400 1.15500 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
26.451 819.00000 15.2000 -44.53125 0.00000 0.92100 0.92100 13.40000 1.10400 1.15500 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.6000 0.000 0.000 0.000 0.000
26.461 819.00000 15.2000 -44.53125 0.00000 0.92100 0.92100 13.40000 1.10400 1.15500 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.6000 0.000 0.000 0.000 0.000
26.471 819.00000 15.2000 -44.53125 0.00000 0.92100 0.92100 13.40000 1.10400 1.15500 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.6000 0.000 0.000 0.000 0.000
26.481 819.00000 15.2000 -44.53125 0.00000 0.92100 0.92100 13.40000 1.10400 1.15500 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.6000 0.000 0.000 0.000 0.000
26.491 819.00000 15.2000 -44.53125 0.00000 0.92100 0.92100 13.40000 1.10400 1.15500 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.6000 0.000 0.000 0.000 0.000
26.501 819.00000 15.2000 -44.53125 0.00000 0.92100 0.92100 13.40000 1.10400 1.15500 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.6000 0.000 0.000 0.000 0.000
26.511 819.00000 15.2000 -44.53125 0.00000 0.92600 0.92600 13.20000 1.10700 1.14900 5.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
26.521 819.00000 15.2000 -44.53125 0.00000 0.92600 0.92600 13.20000 1.10700 1.14900 5.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
26.531 819.00000 15.2000 -44.53125 0.00000 0.92600 0.92600 13.20000 1.10700 1.14900 5.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
26.541 819.00000 15.2000 -44.53125 0.00000 0.92600 0.92600 13.20000 1.10700 1.14900 5.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
26.551 819.00000 15.2000 -44.53125 0.00000 0.92600 0.92600 13.20000 1.10700 1.14900 5.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
26.561 819.00000 15.2000 -44.53125 0.00000 0.92600 0.92600 13.20000 1.10700 1.14900 5.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
26.571 848.00000 15.4000 -44.53125 0.00000 0.89100 0.89100 12.60000 1.10700 1.14900 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
26.581 848.00000 15.4000 -44.53125 0.00000 0.89100 0.89100 12.60000 1.10700 1.14900 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
26.591 848.00000 15.4000 -44.53125 0.00000 0.89100 0.89100 12.60000 1.10700 1.14900 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
26.601 848.00000 15.4000 -44.53125 0.00000 0.89100 0.89100 12.60000 1.10700 1.14900 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
26.611 848.00000 15.4000 -44.53125 0.00000 0.89100 0.89100 12.60000 1.10700 1.14900 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
26.621 848.00000 15.4000 -44.53125 0.00000 0.89100 0.89100 12.60000 1.10700 1.14900 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
26.631 840.00000 15.2000 -44.53125 0.00000 0.93800 0.93800 13.00000 1.10400 1.14200 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
26.641 840.00000 15.2000 -44.53125 0.00000 0.93800 0.93800 13.00000 1.10400 1.14200 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
26.651 840.00000 15.2000 -44.53125 0.00000 0.93800 0.93800 13.00000 1.10400 1.14200 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
26.661 840.00000 15.2000 -44.53125 0.00000 0.93800 0.93800 13.00000 1.10400 1.14200 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
26.671 840.00000 15.2000 -44.53125 0.00000 0.93800 0.93800 13.00000 1.10400 1.14200 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
26.681 849.00000 15.2000 -44.53125 0.00000 0.91500 0.91500 13.40000 1.10400 1.14200 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
26.691 849.00000 15.2000 -44.53125 0.00000 0.91500 0.91500 13.40000 1.10400 1.14200 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
26.701 849.00000 15.2000 -44.53125 0.00000 0.91500 0.91500 13.40000 1.10400 1.14200 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
26.711 849.00000 15.2000 -44.53125 0.00000 0.91500 0.91500 13.40000 1.10400 1.14200 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
26.721 849.00000 15.2000 -44.53125 0.00000 0.91500 0.91500 13.40000 1.10400 1.14200 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
26.731 849.00000 15.2000 -44.53125 0.00000 0.91500 0.91500 13.40000 1.10400 1.14200 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
26.741 849.00000 15.2000 -44.53125 0.00000 0.91500 0.91500 13.40000 1.10400 1.14200 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
26.751 849.00000 15.2000 -44.53125 0.00000 0.91500 0.91500 13.40000 1.10400 1.14200 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
26.761 849.00000 15.2000 -44.53125 0.00000 0.91500 0.91500 13.40000 1.10400 1.14200 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
26.771 849.00000 15.2000 -44.53125 0.00000 0.91500 0.91500 13.40000 1.10400 1.14200 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
26.781 849.00000 15.2000 -44.53125 0.00000 0.91500 0.91500 13.40000 1.10400 1.14200 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
26.791 849.00000 15.2000 -44.53125 0.00000 0.91500 0.91500 13.40000 1.10400 1.14200 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
26.801 849.00000 15.2000 -44.53125 0.00000 0.91500 0.91500 13.40000 1.10400 1.14200 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
26.811 849.00000 15.2000 -44.53125 0.00000 0.91500 0.91500 13.40000 1.10400 1.14200 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
26.821 849.00000 15.2000 -44.53125 0.00000 0.91500 0.91500 13.40000 1.10400 1.14200 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
26.831 849.00000 15.2000 -44.53125 0.00000 0.91500 0.91500 13.40000 1.10400 1.14200 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
26.841 849.00000 15.2000 -44.53125 0.00000 0.91500 0.91500 13.40000 1.10400 1.14200 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
26.851 849.00000 15.2000 -44.53125 0.00000 0.91500 0.91500 13.40000 1.10400 1.14200 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
26.861 849.00000 15.2000 -44.53125 0.00000 0.91500 0.91500 13.40000 1.10400 1.14200 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
26.871 849.00000 15.2000 -44.53125 0.00000 0.91500 0.91500 13.40000 1.10400 1.14200 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
26.881 864.00000 15.1000 -44.53125 0.00000 0.94400 0.94400 13.00000 1.09800 1.14200 5.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.6000 0.000 0.000 0.000 0.000
26.891 864.00000 15.1000 -44.53125 0.00000 0.94400 0.94400 13.00000 1.09800 1.14200 5.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.6000 0.000 0.000 0.000 0.000
26.901 864.00000 15.1000 -44.53125 0.00000 0.94400 0.94400 13.00000 1.09800 1.14200 5.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.6000 0.000 0.000 0.000 0.000
26.911 864.00000 15.1000 -44.53125 0.00000 0.94400 0.94400 13.00000 1.09800 1.14200 5.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.6000 0.000 0.000 0.000 0.000
26.921 864.00000 15.1000 -44.53125 0.00000 0.94400 0.94400 13.00000 1.09800 1.14200 5.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.6000 0.000 0.000 0.000 0.000
26.931 864.00000 15.2000 -44.53125 0.00000 0.92600 0.92600 13.40000 1.09800 1.14200 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.6000 0.000 0.000 0.000 0.000
26.941 864.00000 15.2000 -44.53125 0.00000 0.92600 0.92600 13.40000 1.09800 1.14200 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.6000 0.000 0.000 0.000 0.000
26.951 864.00000 15.2000 -44.53125 0.00000 0.92600 0.92600 13.40000 1.09800 1.14200 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.6000 0.000 0.000 0.000 0.000
26.961 864.00000 15.2000 -44.53125 0.00000 0.92600 0.92600 13.40000 1.09800 1.14200 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.6000 0.000 0.000 0.000 0.000
26.971 864.00000 15.2000 -44.53125 0.00000 0.92600 0.92600 13.40000 1.09800 1.14200 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.6000 0.000 0.000 0.000 0.000
26.981 864.00000 15.2000 -44.53125 0.00000 0.92600 0.92600 13.00000 1.09800 1.14200 5.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.8000 0.000 0.000 0.000 0.000
26.991 864.00000 15.2000 -44.53125 0.00000 0.92600 0.92600 13.00000 1.09800 1.14200 5.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.8000 0.000 0.000 0.000 0.000
27.001 864.00000 15.2000 -44.53125 0.00000 0.92600 0.92600 13.00000 1.09800 1.14200 5.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.8000 0.000 0.000 0.000 0.000
27.011 864.00000 15.2000 -44.53125 0.00000 0.92600 0.92600 13.00000 1.09800 1.14200 5.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.8000 0.000 0.000 0.000 0.000
27.021 864.00000 15.2000 -44.53125 0.00000 0.92600 0.92600 13.00000 1.09800 1.14200 5.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.8000 0.000 0.000 0.000 0.000
27.031 842.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 13.60000 1.09800 1.14200 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.8000 0.000 0.000 0.000 0.000
27.041 842.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 13.60000 1.09800 1.14200 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.8000 0.000 0.000 0.000 0.000
27.051 842.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 13.60000 1.09800 1.14200 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.8000 0.000 0.000 0.000 0.000
27.061 842.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 13.60000 1.09800 1.14200 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.8000 0.000 0.000 0.000 0.000
27.071 842.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 13.60000 1.09800 1.14200 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.8000 0.000 0.000 0.000 0.000
27.081 842.00000 15.2000 -44.53125 0.00000 0.89100 0.89100 13.40000 1.07500 1.13300 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
27.091 842.00000 15.2000 -44.53125 0.00000 0.89100 0.89100 13.40000 1.07500 1.13300 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
27.101 842.00000 15.2000 -44.53125 0.00000 0.89100 0.89100 13.40000 1.07500 1.13300 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
27.111 842.00000 15.2000 -44.53125 0.00000 0.89100 0.89100 13.40000 1.07500 1.13300 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
27.121 842.00000 15.2000 -44.53125 0.00000 0.89100 0.89100 13.40000 1.07500 1.13300 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
27.131 829.00000 15.2000 -44.53125 0.00000 0.93200 0.93200 13.10000 1.07500 1.13300 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
27.141 829.00000 15.2000 -44.53125 0.00000 0.93200 0.93200 13.10000 1.07500 1.13300 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
27.151 829.00000 15.2000 -44.53125 0.00000 0.93200 0.93200 13.10000 1.07500 1.13300 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
27.161 829.00000 15.2000 -44.53125 0.00000 0.93200 0.93200 13.10000 1.07500 1.13300 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
27.171 829.00000 15.2000 -44.53125 0.00000 0.93200 0.93200 13.10000 1.07500 1.13300 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
27.181 829.00000 15.2000 -44.53125 0.00000 0.92100 0.92100 13.20000 1.07500 1.13300 5.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.0000 0.000 0.000 0.000 0.000
27.191 829.00000 15.2000 -44.53125 0.00000 0.92100 0.92100 13.20000 1.07500 1.13300 5.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.0000 0.000 0.000 0.000 0.000
27.201 829.00000 15.2000 -44.53125 0.00000 0.92100 0.92100 13.20000 1.07500 1.13300 5.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.0000 0.000 0.000 0.000 0.000
27.211 829.00000 15.2000 -44.53125 0.00000 0.92100 0.92100 13.20000 1.07500 1.13300 5.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.0000 0.000 0.000 0.000 0.000
27.221 829.00000 15.2000 -44.53125 0.00000 0.92100 0.92100 13.20000 1.07500 1.13300 5.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.0000 0.000 0.000 0.000 0.000
27.231 837.00000 15.2000 -44.53125 0.00000 0.89100 0.89100 13.10000 1.07500 1.13300 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
27.241 837.00000 15.2000 -44.53125 0.00000 0.89100 0.89100 13.10000 1.07500 1.13300 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
27.251 837.00000 15.2000 -44.53125 0.00000 0.89100 0.89100 13.10000 1.07500 1.13300 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
27.261 837.00000 15.2000 -44.53125 0.00000 0.89100 0.89100 13.10000 1.07500 1.13300 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
27.271 837.00000 15.2000 -44.53125 0.00000 0.89100 0.89100 13.10000 1.07500 1.13300 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
27.281 837.00000 15.2000 -44.53125 0.00000 0.90300 0.90300 13.50000 1.07500 1.12900 5.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
27.291 837.00000 15.2000 -44.53125 0.00000 0.90300 0.90300 13.50000 1.07500 1.12900 5.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
27.301 837.00000 15.2000 -44.53125 0.00000 0.90300 0.90300 13.50000 1.07500 1.12900 5.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
27.311 837.00000 15.2000 -44.53125 0.00000 0.90300 0.90300 13.50000 1.07500 1.12900 5.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
27.321 837.00000 15.2000 -44.53125 0.00000 0.90300 0.90300 13.50000 1.07500 1.12900 5.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
27.331 837.00000 15.2000 -44.53125 0.00000 0.92100 0.92100 13.20000 1.07500 1.12900 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.0000 0.000 0.000 0.000 0.000
27.341 837.00000 15.2000 -44.53125 0.00000 0.92100 0.92100 13.20000 1.07500 1.12900 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.0000 0.000 0.000 0.000 0.000
27.351 837.00000 15.2000 -44.53125 0.00000 0.92100 0.92100 13.20000 1.07500 1.12900 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.0000 0.000 0.000 0.000 0.000
27.361 837.00000 15.2000 -44.53125 0.00000 0.92100 0.92100 13.20000 1.07500 1.12900 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.0000 0.000 0.000 0.000 0.000
27.371 837.00000 15.2000 -44.53125 0.00000 0.92100 0.92100 13.20000 1.07500 1.12900 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.0000 0.000 0.000 0.000 0.000
27.381 854.00000 15.2000 -44.53125 0.00000 0.89700 0.89700 13.30000 1.07500 1.12900 5.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.0000 0.000 0.000 0.000 0.000
27.391 854.00000 15.2000 -44.53125 0.00000 0.89700 0.89700 13.30000 1.07500 1.12900 5.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.0000 0.000 0.000 0.000 0.000
27.401 854.00000 15.2000 -44.53125 0.00000 0.89700 0.89700 13.30000 1.07500 1.12900 5.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.0000 0.000 0.000 0.000 0.000
27.411 854.00000 15.2000 -44.53125 0.00000 0.89700 0.89700 13.30000 1.07500 1.12900 5.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.0000 0.000 0.000 0.000 0.000
27.421 854.00000 15.2000 -44.53125 0.00000 0.89700 0.89700 13.30000 1.07500 1.12900 5.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.0000 0.000 0.000 0.000 0.000
27.431 854.00000 15.2000 -44.53125 0.00000 0.91500 0.91500 13.50000 1.07500 1.12900 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
27.441 854.00000 15.2000 -44.53125 0.00000 0.91500 0.91500 13.50000 1.07500 1.12900 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
27.451 854.00000 15.2000 -44.53125 0.00000 0.91500 0.91500 13.50000 1.07500 1.12900 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
27.461 854.00000 15.2000 -44.53125 0.00000 0.91500 0.91500 13.50000 1.07500 1.12900 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
27.471 854.00000 15.2000 -44.53125 0.00000 0.91500 0.91500 13.50000 1.07500 1.12900 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
27.481 837.00000 15.1000 -44.53125 0.00000 0.92600 0.92600 12.90000 1.06200 1.12600 5.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.0000 0.000 0.000 0.000 0.000
27.491 837.00000 15.1000 -44.53125 0.00000 0.92600 0.92600 12.90000 1.06200 1.12600 5.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.0000 0.000 0.000 0.000 0.000
27.501 837.00000 15.1000 -44.53125 0.00000 0.92600 0.92600 12.90000 1.06200 1.12600 5.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.0000 0.000 0.000 0.000 0.000
27.511 837.00000 15.1000 -44.53125 0.00000 0.92600 0.92600 12.90000 1.06200 1.12600 5.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.0000 0.000 0.000 0.000 0.000
27.521 837.00000 15.1000 -44.53125 0.00000 0.92600 0.92600 12.90000 1.06200 1.12600 5.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.0000 0.000 0.000 0.000 0.000
27.531 837.00000 15.2000 -44.53125 0.00000 0.92100 0.92100 13.30000 1.06200 1.12600 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
27.541 837.00000 15.2000 -44.53125 0.00000 0.92100 0.92100 13.30000 1.06200 1.12600 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
27.551 837.00000 15.2000 -44.53125 0.00000 0.92100 0.92100 13.30000 1.06200 1.12600 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
27.561 837.00000 15.2000 -44.53125 0.00000 0.92100 0.92100 13.30000 1.06200 1.12600 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
27.571 837.00000 15.2000 -44.53125 0.00000 0.92100 0.92100 13.30000 1.06200 1.12600 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
27.581 833.00000 15.2000 -44.53125 0.00000 0.89700 0.89700 13.30000 1.06200 1.12600 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.1000 0.000 0.000 0.000 0.000
27.591 833.00000 15.2000 -44.53125 0.00000 0.89700 0.89700 13.30000 1.06200 1.12600 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.1000 0.000 0.000 0.000 0.000
27.601 833.00000 15.2000 -44.53125 0.00000 0.89700 0.89700 13.30000 1.06200 1.12600 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.1000 0.000 0.000 0.000 0.000
27.611 833.00000 15.2000 -44.53125 0.00000 0.89700 0.89700 13.30000 1.06200 1.12600 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.1000 0.000 0.000 0.000 0.000
27.621 833.00000 15.2000 -44.53125 0.00000 0.89700 0.89700 13.30000 1.06200 1.12600 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.1000 0.000 0.000 0.000 0.000
27.631 833.00000 15.2000 -44.53125 0.00000 0.91500 0.91500 13.60000 1.06200 1.12600 5.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.1000 0.000 0.000 0.000 0.000
27.641 833.00000 15.2000 -44.53125 0.00000 0.91500 0.91500 13.60000 1.06200 1.12600 5.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.1000 0.000 0.000 0.000 0.000
27.651 833.00000 15.2000 -44.53125 0.00000 0.91500 0.91500 13.60000 1.06200 1.12600 5.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.1000 0.000 0.000 0.000 0.000
27.661 833.00000 15.2000 -44.53125 0.00000 0.91500 0.91500 13.60000 1.06200 1.12600 5.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.1000 0.000 0.000 0.000 0.000
27.671 833.00000 15.2000 -44.53125 0.00000 0.91500 0.91500 13.60000 1.06200 1.12600 5.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.1000 0.000 0.000 0.000 0.000
27.681 833.00000 15.2000 -44.53125 0.00000 0.93800 0.93800 13.30000 1.04000 1.12300 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
27.691 833.00000 15.2000 -44.53125 0.00000 0.93800 0.93800 13.30000 1.04000 1.12300 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
27.701 833.00000 15.2000 -44.53125 0.00000 0.93800 0.93800 13.30000 1.04000 1.12300 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
27.711 833.00000 15.2000 -44.53125 0.00000 0.93800 0.93800 13.30000 1.04000 1.12300 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
27.721 833.00000 15.2000 -44.53125 0.00000 0.93800 0.93800 13.30000 1.04000 1.12300 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
27.731 818.00000 15.2000 -44.53125 0.00000 0.91500 0.91500 13.50000 1.04000 1.12300 5.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
27.741 818.00000 15.2000 -44.53125 0.00000 0.91500 0.91500 13.50000 1.04000 1.12300 5.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
27.751 818.00000 15.2000 -44.53125 0.00000 0.91500 0.91500 13.50000 1.04000 1.12300 5.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
27.761 818.00000 15.2000 -44.53125 0.00000 0.91500 0.91500 13.50000 1.04000 1.12300 5.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
27.771 818.00000 15.2000 -44.53125 0.00000 0.91500 0.91500 13.50000 1.04000 1.12300 5.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
27.781 818.00000 15.2000 -44.53125 0.00000 0.88600 0.88600 13.40000 1.04000 1.12300 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
27.791 818.00000 15.2000 -44.53125 0.00000 0.88600 0.88600 13.40000 1.04000 1.12300 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
27.801 818.00000 15.2000 -44.53125 0.00000 0.88600 0.88600 13.40000 1.04000 1.12300 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
27.811 818.00000 15.2000 -44.53125 0.00000 0.88600 0.88600 13.40000 1.04000 1.12300 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
27.821 818.00000 15.2000 -44.53125 0.00000 0.88600 0.88600 13.40000 1.04000 1.12300 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
27.831 812.00000 15.2000 -44.53125 0.00000 0.92600 0.92600 12.90000 1.04000 1.12300 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
27.841 812.00000 15.2000 -44.53125 0.00000 0.92600 0.92600 12.90000 1.04000 1.12300 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
27.851 812.00000 15.2000 -44.53125 0.00000 0.92600 0.92600 12.90000 1.04000 1.12300 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
27.861 812.00000 15.2000 -44.53125 0.00000 0.92600 0.92600 12.90000 1.04000 1.12300 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
27.871 812.00000 15.2000 -44.53125 0.00000 0.92600 0.92600 12.90000 1.04000 1.12300 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
27.881 812.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 13.10000 0.99500 1.11700 5.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
27.891 812.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 13.10000 0.99500 1.11700 5.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
27.901 812.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 13.10000 0.99500 1.11700 5.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
27.911 812.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 13.10000 0.99500 1.11700 5.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
27.921 812.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 13.10000 0.99500 1.11700 5.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
27.931 812.00000 15.2000 -44.53125 0.00000 0.93200 0.93200 13.40000 0.99500 1.11700 5.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
27.941 812.00000 15.2000 -44.53125 0.00000 0.93200 0.93200 13.40000 0.99500 1.11700 5.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
27.951 812.00000 15.2000 -44.53125 0.00000 0.93200 0.93200 13.40000 0.99500 1.11700 5.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
27.961 812.00000 15.2000 -44.53125 0.00000 0.93200 0.93200 13.40000 0.99500 1.11700 5.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
27.971 812.00000 15.2000 -44.53125 0.00000 0.93200 0.93200 13.40000 0.99500 1.11700 5.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
27.981 776.00000 15.2000 -44.53125 0.00000 0.93200 0.93200 13.00000 0.99500 1.11700 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
27.991 776.00000 15.2000 -44.53125 0.00000 0.93200 0.93200 13.00000 0.99500 1.11700 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
28.001 776.00000 15.2000 -44.53125 0.00000 0.93200 0.93200 13.00000 0.99500 1.11700 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
28.011 776.00000 15.2000 -44.53125 0.00000 0.93200 0.93200 13.00000 0.99500 1.11700 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
28.021 776.00000 15.2000 -44.53125 0.00000 0.93200 0.93200 13.00000 0.99500 1.11700 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
28.031 776.00000 15.2000 -44.53125 0.00000 0.92600 0.92600 12.90000 0.99500 1.11700 5.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.4000 0.000 0.000 0.000 0.000
28.041 776.00000 15.2000 -44.53125 0.00000 0.92600 0.92600 12.90000 0.99500 1.11700 5.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.4000 0.000 0.000 0.000 0.000
28.051 776.00000 15.2000 -44.53125 0.00000 0.92600 0.92600 12.90000 0.99500 1.11700 5.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.4000 0.000 0.000 0.000 0.000
28.061 776.00000 15.2000 -44.53125 0.00000 0.92600 0.92600 12.90000 0.99500 1.11700 5.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.4000 0.000 0.000 0.000 0.000
28.071 776.00000 15.2000 -44.53125 0.00000 0.92600 0.92600 12.90000 0.99500 1.11700 5.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.4000 0.000 0.000 0.000 0.000
28.081 754.00000 15.2000 -44.53125 0.00000 0.88600 0.88600 13.30000 0.95100 1.11300 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.6000 0.000 0.000 0.000 0.000
28.091 754.00000 15.2000 -44.53125 0.00000 0.88600 0.88600 13.30000 0.95100 1.11300 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.6000 0.000 0.000 0.000 0.000
28.101 754.00000 15.2000 -44.53125 0.00000 0.88600 0.88600 13.30000 0.95100 1.11300 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.6000 0.000 0.000 0.000 0.000
28.111 754.00000 15.2000 -44.53125 0.00000 0.88600 0.88600 13.30000 0.95100 1.11300 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.6000 0.000 0.000 0.000 0.000
28.121 754.00000 15.2000 -44.53125 0.00000 0.88600 0.88600 13.30000 0.95100 1.11300 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.6000 0.000 0.000 0.000 0.000
28.131 754.00000 15.2000 -44.53125 0.00000 0.90300 0.90300 13.20000 0.95100 1.11300 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.6000 0.000 0.000 0.000 0.000
28.141 754.00000 15.2000 -44.53125 0.00000 0.90300 0.90300 13.20000 0.95100 1.11300 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.6000 0.000 0.000 0.000 0.000
28.151 754.00000 15.2000 -44.53125 0.00000 0.90300 0.90300 13.20000 0.95100 1.11300 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.6000 0.000 0.000 0.000 0.000
28.161 754.00000 15.2000 -44.53125 0.00000 0.90300 0.90300 13.20000 0.95100 1.11300 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.6000 0.000 0.000 0.000 0.000
28.171 754.00000 15.2000 -44.53125 0.00000 0.90300 0.90300 13.20000 0.95100 1.11300 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.6000 0.000 0.000 0.000 0.000
28.181 754.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 13.10000 0.95100 1.11300 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.5000 0.000 0.000 0.000 0.000
28.191 754.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 13.10000 0.95100 1.11300 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.5000 0.000 0.000 0.000 0.000
28.201 754.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 13.10000 0.95100 1.11300 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.5000 0.000 0.000 0.000 0.000
28.211 754.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 13.10000 0.95100 1.11300 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.5000 0.000 0.000 0.000 0.000
28.221 754.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 13.10000 0.95100 1.11300 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.5000 0.000 0.000 0.000 0.000
28.231 758.00000 15.2000 -44.53125 0.00000 0.90300 0.90300 12.80000 0.95100 1.11300 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
28.241 758.00000 15.2000 -44.53125 0.00000 0.90300 0.90300 12.80000 0.95100 1.11300 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
28.251 758.00000 15.2000 -44.53125 0.00000 0.90300 0.90300 12.80000 0.95100 1.11300 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
28.261 758.00000 15.2000 -44.53125 0.00000 0.90300 0.90300 12.80000 0.95100 1.11300 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
28.271 758.00000 15.2000 -44.53125 0.00000 0.90300 0.90300 12.80000 0.95100 1.11300 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
28.281 758.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 12.90000 0.91200 1.11000 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
28.291 758.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 12.90000 0.91200 1.11000 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
28.301 758.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 12.90000 0.91200 1.11000 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
28.311 758.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 12.90000 0.91200 1.11000 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
28.321 758.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 12.90000 0.91200 1.11000 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
28.331 760.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 13.10000 0.91200 1.11000 5.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
28.341 760.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 13.10000 0.91200 1.11000 5.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
28.351 760.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 13.10000 0.91200 1.11000 5.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
28.361 760.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 13.10000 0.91200 1.11000 5.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
28.371 760.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 13.10000 0.91200 1.11000 5.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
28.381 760.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 13.10000 0.91200 1.11000 5.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
28.391 760.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 13.10000 0.91200 1.11000 5.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
28.401 760.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 13.10000 0.91200 1.11000 5.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
28.411 760.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 13.10000 0.91200 1.11000 5.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
28.421 760.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 13.10000 0.91200 1.11000 5.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
28.431 760.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 13.30000 0.91200 1.11000 5.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
28.441 760.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 13.30000 0.91200 1.11000 5.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
28.451 760.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 13.30000 0.91200 1.11000 5.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
28.461 760.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 13.30000 0.91200 1.11000 5.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
28.471 760.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 13.30000 0.91200 1.11000 5.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
28.481 770.00000 15.2000 -44.53125 0.00000 0.85600 0.85600 13.40000 0.78500 1.10400 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
28.491 770.00000 15.2000 -44.53125 0.00000 0.85600 0.85600 13.40000 0.78500 1.10400 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
28.501 770.00000 15.2000 -44.53125 0.00000 0.85600 0.85600 13.40000 0.78500 1.10400 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
28.511 770.00000 15.2000 -44.53125 0.00000 0.85600 0.85600 13.40000 0.78500 1.10400 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
28.521 770.00000 15.2000 -44.53125 0.00000 0.85600 0.85600 13.40000 0.78500 1.10400 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
28.531 770.00000 15.2000 -44.53125 0.00000 0.86800 0.86800 12.90000 0.78500 1.10400 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
28.541 770.00000 15.2000 -44.53125 0.00000 0.86800 0.86800 12.90000 0.78500 1.10400 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
28.551 770.00000 15.2000 -44.53125 0.00000 0.86800 0.86800 12.90000 0.78500 1.10400 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
28.561 770.00000 15.2000 -44.53125 0.00000 0.86800 0.86800 12.90000 0.78500 1.10400 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
28.571 770.00000 15.2000 -44.53125 0.00000 0.86800 0.86800 12.90000 0.78500 1.10400 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
28.581 768.00000 15.2000 -44.53125 0.00000 0.85100 0.85100 13.20000 0.78500 1.10400 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
28.591 768.00000 15.2000 -44.53125 0.00000 0.85100 0.85100 13.20000 0.78500 1.10400 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
28.601 768.00000 15.2000 -44.53125 0.00000 0.85100 0.85100 13.20000 0.78500 1.10400 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
28.611 768.00000 15.2000 -44.53125 0.00000 0.85100 0.85100 13.20000 0.78500 1.10400 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
28.621 768.00000 15.2000 -44.53125 0.00000 0.85100 0.85100 13.20000 0.78500 1.10400 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
28.631 768.00000 15.4000 -44.53125 0.00000 0.82700 0.82700 12.10000 0.78500 1.10400 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
28.641 768.00000 15.4000 -44.53125 0.00000 0.82700 0.82700 12.10000 0.78500 1.10400 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
28.651 768.00000 15.4000 -44.53125 0.00000 0.82700 0.82700 12.10000 0.78500 1.10400 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
28.661 768.00000 15.4000 -44.53125 0.00000 0.82700 0.82700 12.10000 0.78500 1.10400 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
28.671 768.00000 15.4000 -44.53125 0.00000 0.82700 0.82700 12.10000 0.78500 1.10400 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
28.681 768.00000 15.2000 -44.53125 0.00000 0.85100 0.85100 12.80000 0.46600 1.09400 5.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
28.691 768.00000 15.2000 -44.53125 0.00000 0.85100 0.85100 12.80000 0.46600 1.09400 5.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
28.701 768.00000 15.2000 -44.53125 0.00000 0.85100 0.85100 12.80000 0.46600 1.09400 5.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
28.711 768.00000 15.2000 -44.53125 0.00000 0.85100 0.85100 12.80000 0.46600 1.09400 5.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
28.721 768.00000 15.2000 -44.53125 0.00000 0.85100 0.85100 12.80000 0.46600 1.09400 5.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
28.731 758.00000 15.2000 -44.53125 0.00000 0.86200 0.86200 12.90000 0.46600 1.09400 5.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
28.741 758.00000 15.2000 -44.53125 0.00000 0.86200 0.86200 12.90000 0.46600 1.09400 5.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
28.751 758.00000 15.2000 -44.53125 0.00000 0.86200 0.86200 12.90000 0.46600 1.09400 5.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
28.761 758.00000 15.2000 -44.53125 0.00000 0.86200 0.86200 12.90000 0.46600 1.09400 5.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
28.771 758.00000 15.2000 -44.53125 0.00000 0.86200 0.86200 12.90000 0.46600 1.09400 5.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
28.781 758.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 13.10000 0.46600 1.09400 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
28.791 758.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 13.10000 0.46600 1.09400 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
28.801 758.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 13.10000 0.46600 1.09400 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
28.811 758.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 13.10000 0.46600 1.09400 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
28.821 758.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 13.10000 0.46600 1.09400 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
28.831 758.00000 15.2000 -44.53125 0.00000 0.89100 0.89100 12.20000 0.46600 1.09400 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
28.841 758.00000 15.2000 -44.53125 0.00000 0.89100 0.89100 12.20000 0.46600 1.09400 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
28.851 758.00000 15.2000 -44.53125 0.00000 0.89100 0.89100 12.20000 0.46600 1.09400 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
28.861 758.00000 15.2000 -44.53125 0.00000 0.89100 0.89100 12.20000 0.46600 1.09400 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
28.871 758.00000 15.2000 -44.53125 0.00000 0.89100 0.89100 12.20000 0.46600 1.09400 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
28.881 710.00000 15.2000 -44.53125 0.00000 0.92600 0.92600 13.00000 0.33500 1.09400 6.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
28.891 710.00000 15.2000 -44.53125 0.00000 0.92600 0.92600 13.00000 0.33500 1.09400 6.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
28.901 710.00000 15.2000 -44.53125 0.00000 0.92600 0.92600 13.00000 0.33500 1.09400 6.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
28.911 710.00000 15.2000 -44.53125 0.00000 0.92600 0.92600 13.00000 0.33500 1.09400 6.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
28.921 710.00000 15.2000 -44.53125 0.00000 0.92600 0.92600 13.00000 0.33500 1.09400 6.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
28.931 710.00000 15.2000 -44.53125 0.00000 0.85600 0.85600 13.10000 0.33500 1.09400 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.8000 0.000 0.000 0.000 0.000
28.941 710.00000 15.2000 -44.53125 0.00000 0.85600 0.85600 13.10000 0.33500 1.09400 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.8000 0.000 0.000 0.000 0.000
28.951 710.00000 15.2000 -44.53125 0.00000 0.85600 0.85600 13.10000 0.33500 1.09400 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.8000 0.000 0.000 0.000 0.000
28.961 710.00000 15.2000 -44.53125 0.00000 0.85600 0.85600 13.10000 0.33500 1.09400 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.8000 0.000 0.000 0.000 0.000
28.971 710.00000 15.2000 -44.53125 0.00000 0.85600 0.85600 13.10000 0.33500 1.09400 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.8000 0.000 0.000 0.000 0.000
28.981 715.00000 15.2000 -44.53125 0.00000 0.88600 0.88600 12.60000 0.33500 1.09400 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.9000 0.000 0.000 0.000 0.000
28.991 715.00000 15.2000 -44.53125 0.00000 0.88600 0.88600 12.60000 0.33500 1.09400 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.9000 0.000 0.000 0.000 0.000
29.001 715.00000 15.2000 -44.53125 0.00000 0.88600 0.88600 12.60000 0.33500 1.09400 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.9000 0.000 0.000 0.000 0.000
29.011 715.00000 15.2000 -44.53125 0.00000 0.88600 0.88600 12.60000 0.33500 1.09400 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.9000 0.000 0.000 0.000 0.000
29.021 715.00000 15.2000 -44.53125 0.00000 0.88600 0.88600 12.60000 0.33500 1.09400 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.9000 0.000 0.000 0.000 0.000
29.031 715.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 12.80000 0.33500 1.09400 6.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.8000 0.000 0.000 0.000 0.000
29.041 715.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 12.80000 0.33500 1.09400 6.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.8000 0.000 0.000 0.000 0.000
29.051 715.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 12.80000 0.33500 1.09400 6.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.8000 0.000 0.000 0.000 0.000
29.061 715.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 12.80000 0.33500 1.09400 6.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.8000 0.000 0.000 0.000 0.000
29.071 715.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 12.80000 0.33500 1.09400 6.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.8000 0.000 0.000 0.000 0.000
29.081 715.00000 15.2000 -44.53125 0.00000 0.89700 0.89700 12.90000 0.30900 1.09800 5.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 16.0000 0.000 0.000 0.000 0.000
29.091 715.00000 15.2000 -44.53125 0.00000 0.89700 0.89700 12.90000 0.30900 1.09800 5.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 16.0000 0.000 0.000 0.000 0.000
29.101 715.00000 15.2000 -44.53125 0.00000 0.89700 0.89700 12.90000 0.30900 1.09800 5.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 16.0000 0.000 0.000 0.000 0.000
29.111 715.00000 15.2000 -44.53125 0.00000 0.89700 0.89700 12.90000 0.30900 1.09800 5.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 16.0000 0.000 0.000 0.000 0.000
29.121 715.00000 15.2000 -44.53125 0.00000 0.89700 0.89700 12.90000 0.30900 1.09800 5.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 16.0000 0.000 0.000 0.000 0.000
29.131 725.00000 15.2000 -44.53125 0.00000 0.86800 0.86800 13.20000 0.30900 1.09800 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 16.0000 0.000 0.000 0.000 0.000
29.141 725.00000 15.2000 -44.53125 0.00000 0.86800 0.86800 13.20000 0.30900 1.09800 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 16.0000 0.000 0.000 0.000 0.000
29.151 725.00000 15.2000 -44.53125 0.00000 0.86800 0.86800 13.20000 0.30900 1.09800 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 16.0000 0.000 0.000 0.000 0.000
29.161 725.00000 15.2000 -44.53125 0.00000 0.86800 0.86800 13.20000 0.30900 1.09800 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 16.0000 0.000 0.000 0.000 0.000
29.171 725.00000 15.2000 -44.53125 0.00000 0.86800 0.86800 13.20000 0.30900 1.09800 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 16.0000 0.000 0.000 0.000 0.000
29.181 725.00000 15.2000 -44.53125 0.00000 0.89100 0.89100 12.90000 0.30900 1.09800 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 16.2000 0.000 0.000 0.000 0.000
29.191 725.00000 15.2000 -44.53125 0.00000 0.89100 0.89100 12.90000 0.30900 1.09800 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 16.2000 0.000 0.000 0.000 0.000
29.201 725.00000 15.2000 -44.53125 0.00000 0.89100 0.89100 12.90000 0.30900 1.09800 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 16.2000 0.000 0.000 0.000 0.000
29.211 725.00000 15.2000 -44.53125 0.00000 0.89100 0.89100 12.90000 0.30900 1.09800 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 16.2000 0.000 0.000 0.000 0.000
29.221 725.00000 15.2000 -44.53125 0.00000 0.89100 0.89100 12.90000 0.30900 1.09800 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 16.2000 0.000 0.000 0.000 0.000
29.231 725.00000 15.2000 -44.53125 0.00000 0.86200 0.86200 13.10000 0.30900 1.09800 6.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 16.2000 0.000 0.000 0.000 0.000
29.241 725.00000 15.2000 -44.53125 0.00000 0.86200 0.86200 13.10000 0.30900 1.09800 6.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 16.2000 0.000 0.000 0.000 0.000
29.251 725.00000 15.2000 -44.53125 0.00000 0.86200 0.86200 13.10000 0.30900 1.09800 6.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 16.2000 0.000 0.000 0.000 0.000
29.261 725.00000 15.2000 -44.53125 0.00000 0.86200 0.86200 13.10000 0.30900 1.09800 6.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 16.2000 0.000 0.000 0.000 0.000
29.271 725.00000 15.2000 -44.53125 0.00000 0.86200 0.86200 13.10000 0.30900 1.09800 6.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 16.2000 0.000 0.000 0.000 0.000
29.281 722.00000 15.2000 -44.53125 0.00000 0.83300 0.83300 13.10000 0.31200 1.09800 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 16.3000 0.000 0.000 0.000 0.000
29.291 722.00000 15.2000 -44.53125 0.00000 0.83300 0.83300 13.10000 0.31200 1.09800 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 16.3000 0.000 0.000 0.000 0.000
29.301 722.00000 15.2000 -44.53125 0.00000 0.83300 0.83300 13.10000 0.31200 1.09800 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 16.3000 0.000 0.000 0.000 0.000
29.311 722.00000 15.2000 -44.53125 0.00000 0.83300 0.83300 13.10000 0.31200 1.09800 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 16.3000 0.000 0.000 0.000 0.000
29.321 722.00000 15.2000 -44.53125 0.00000 0.83300 0.83300 13.10000 0.31200 1.09800 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 16.3000 0.000 0.000 0.000 0.000
29.331 722.00000 15.2000 -44.53125 0.00000 0.87400 0.87400 13.00000 0.31200 1.09800 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 16.7000 0.000 0.000 0.000 0.000
29.341 722.00000 15.2000 -44.53125 0.00000 0.87400 0.87400 13.00000 0.31200 1.09800 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 16.7000 0.000 0.000 0.000 0.000
29.351 722.00000 15.2000 -44.53125 0.00000 0.87400 0.87400 13.00000 0.31200 1.09800 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 16.7000 0.000 0.000 0.000 0.000
29.361 722.00000 15.2000 -44.53125 0.00000 0.87400 0.87400 13.00000 0.31200 1.09800 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 16.7000 0.000 0.000 0.000 0.000
29.371 722.00000 15.2000 -44.53125 0.00000 0.87400 0.87400 13.00000 0.31200 1.09800 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 16.7000 0.000 0.000 0.000 0.000
29.381 722.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 13.00000 0.31200 1.09800 6.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 16.7000 0.000 0.000 0.000 0.000
29.391 722.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 13.00000 0.31200 1.09800 6.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 16.7000 0.000 0.000 0.000 0.000
29.401 722.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 13.00000 0.31200 1.09800 6.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 16.7000 0.000 0.000 0.000 0.000
29.411 722.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 13.00000 0.31200 1.09800 6.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 16.7000 0.000 0.000 0.000 0.000
29.421 722.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 13.00000 0.31200 1.09800 6.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 16.7000 0.000 0.000 0.000 0.000
29.431 735.00000 15.2000 -44.53125 0.00000 0.86200 0.86200 13.00000 0.31200 1.09800 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 16.8000 0.000 0.000 0.000 0.000
29.441 735.00000 15.2000 -44.53125 0.00000 0.86200 0.86200 13.00000 0.31200 1.09800 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 16.8000 0.000 0.000 0.000 0.000
29.451 735.00000 15.2000 -44.53125 0.00000 0.86200 0.86200 13.00000 0.31200 1.09800 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 16.8000 0.000 0.000 0.000 0.000
29.461 735.00000 15.2000 -44.53125 0.00000 0.86200 0.86200 13.00000 0.31200 1.09800 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 16.8000 0.000 0.000 0.000 0.000
29.471 735.00000 15.2000 -44.53125 0.00000 0.86200 0.86200 13.00000 0.31200 1.09800 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 16.8000 0.000 0.000 0.000 0.000
29.481 735.00000 15.2000 -44.53125 0.00000 0.89100 0.89100 13.00000 0.29600 1.08200 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 16.9000 0.000 0.000 0.000 0.000
29.491 735.00000 15.2000 -44.53125 0.00000 0.89100 0.89100 13.00000 0.29600 1.08200 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 16.9000 0.000 0.000 0.000 0.000
29.501 735.00000 15.2000 -44.53125 0.00000 0.89100 0.89100 13.00000 0.29600 1.08200 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 16.9000 0.000 0.000 0.000 0.000
29.511 735.00000 15.2000 -44.53125 0.00000 0.89100 0.89100 13.00000 0.29600 1.08200 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 16.9000 0.000 0.000 0.000 0.000
29.521 735.00000 15.2000 -44.53125 0.00000 0.89100 0.89100 13.00000 0.29600 1.08200 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 16.9000 0.000 0.000 0.000 0.000
29.531 759.00000 15.2000 -44.53125 0.00000 0.84500 0.84500 13.10000 0.29600 1.08200 5.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.2000 0.000 0.000 0.000 0.000
29.541 759.00000 15.2000 -44.53125 0.00000 0.84500 0.84500 13.10000 0.29600 1.08200 5.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.2000 0.000 0.000 0.000 0.000
29.551 759.00000 15.2000 -44.53125 0.00000 0.84500 0.84500 13.10000 0.29600 1.08200 5.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.2000 0.000 0.000 0.000 0.000
29.561 759.00000 15.2000 -44.53125 0.00000 0.84500 0.84500 13.10000 0.29600 1.08200 5.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.2000 0.000 0.000 0.000 0.000
29.571 759.00000 15.2000 -44.53125 0.00000 0.84500 0.84500 13.10000 0.29600 1.08200 5.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.2000 0.000 0.000 0.000 0.000
29.581 759.00000 15.1000 -44.53125 0.00000 0.84500 0.84500 13.50000 0.29600 1.08200 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.1000 0.000 0.000 0.000 0.000
29.591 759.00000 15.1000 -44.53125 0.00000 0.84500 0.84500 13.50000 0.29600 1.08200 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.1000 0.000 0.000 0.000 0.000
29.601 759.00000 15.1000 -44.53125 0.00000 0.84500 0.84500 13.50000 0.29600 1.08200 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.1000 0.000 0.000 0.000 0.000
29.611 759.00000 15.1000 -44.53125 0.00000 0.84500 0.84500 13.50000 0.29600 1.08200 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.1000 0.000 0.000 0.000 0.000
29.621 759.00000 15.1000 -44.53125 0.00000 0.84500 0.84500 13.50000 0.29600 1.08200 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.1000 0.000 0.000 0.000 0.000
29.631 759.00000 15.2000 -44.53125 0.00000 0.85100 0.85100 13.60000 0.29600 1.08200 5.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.4000 0.000 0.000 0.000 0.000
29.641 759.00000 15.2000 -44.53125 0.00000 0.85100 0.85100 13.60000 0.29600 1.08200 5.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.4000 0.000 0.000 0.000 0.000
29.651 759.00000 15.2000 -44.53125 0.00000 0.85100 0.85100 13.60000 0.29600 1.08200 5.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.4000 0.000 0.000 0.000 0.000
29.661 759.00000 15.2000 -44.53125 0.00000 0.85100 0.85100 13.60000 0.29600 1.08200 5.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.4000 0.000 0.000 0.000 0.000
29.671 759.00000 15.2000 -44.53125 0.00000 0.85100 0.85100 13.60000 0.29600 1.08200 5.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.4000 0.000 0.000 0.000 0.000
29.681 776.00000 15.2000 -44.53125 0.00000 0.87400 0.87400 13.20000 0.30000 1.07500 5.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.4000 0.000 0.000 0.000 0.000
29.691 776.00000 15.2000 -44.53125 0.00000 0.87400 0.87400 13.20000 0.30000 1.07500 5.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.4000 0.000 0.000 0.000 0.000
29.701 776.00000 15.2000 -44.53125 0.00000 0.87400 0.87400 13.20000 0.30000 1.07500 5.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.4000 0.000 0.000 0.000 0.000
29.711 776.00000 15.2000 -44.53125 0.00000 0.87400 0.87400 13.20000 0.30000 1.07500 5.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.4000 0.000 0.000 0.000 0.000
29.721 776.00000 15.2000 -44.53125 0.00000 0.87400 0.87400 13.20000 0.30000 1.07500 5.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.4000 0.000 0.000 0.000 0.000
29.731 776.00000 15.2000 -44.53125 0.00000 0.87400 0.87400 13.20000 0.30000 1.07500 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.4000 0.000 0.000 0.000 0.000
29.741 776.00000 15.2000 -44.53125 0.00000 0.87400 0.87400 13.20000 0.30000 1.07500 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.4000 0.000 0.000 0.000 0.000
29.751 776.00000 15.2000 -44.53125 0.00000 0.87400 0.87400 13.20000 0.30000 1.07500 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.4000 0.000 0.000 0.000 0.000
29.761 776.00000 15.2000 -44.53125 0.00000 0.87400 0.87400 13.20000 0.30000 1.07500 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.4000 0.000 0.000 0.000 0.000
29.771 776.00000 15.2000 -44.53125 0.00000 0.87400 0.87400 13.20000 0.30000 1.07500 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.4000 0.000 0.000 0.000 0.000
29.781 755.00000 15.2000 -44.53125 0.00000 0.88600 0.88600 12.80000 0.30000 1.07500 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.9000 0.000 0.000 0.000 0.000
29.791 755.00000 15.2000 -44.53125 0.00000 0.88600 0.88600 12.80000 0.30000 1.07500 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.9000 0.000 0.000 0.000 0.000
29.801 755.00000 15.2000 -44.53125 0.00000 0.88600 0.88600 12.80000 0.30000 1.07500 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.9000 0.000 0.000 0.000 0.000
29.811 755.00000 15.2000 -44.53125 0.00000 0.88600 0.88600 12.80000 0.30000 1.07500 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.9000 0.000 0.000 0.000 0.000
29.821 755.00000 15.2000 -44.53125 0.00000 0.88600 0.88600 12.80000 0.30000 1.07500 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.9000 0.000 0.000 0.000 0.000
29.831 755.00000 15.2000 -44.53125 0.00000 0.83900 0.83900 12.70000 0.30000 1.07500 5.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.6000 0.000 0.000 0.000 0.000
29.841 755.00000 15.2000 -44.53125 0.00000 0.83900 0.83900 12.70000 0.30000 1.07500 5.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.6000 0.000 0.000 0.000 0.000
29.851 755.00000 15.2000 -44.53125 0.00000 0.83900 0.83900 12.70000 0.30000 1.07500 5.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.6000 0.000 0.000 0.000 0.000
29.861 755.00000 15.2000 -44.53125 0.00000 0.83900 0.83900 12.70000 0.30000 1.07500 5.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.6000 0.000 0.000 0.000 0.000
29.871 755.00000 15.2000 -44.53125 0.00000 0.83900 0.83900 12.70000 0.30000 1.07500 5.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.6000 0.000 0.000 0.000 0.000
29.881 755.00000 15.2000 -44.53125 0.00000 0.84500 0.84500 13.00000 0.30900 1.07500 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.9000 0.000 0.000 0.000 0.000
29.891 755.00000 15.2000 -44.53125 0.00000 0.84500 0.84500 13.00000 0.30900 1.07500 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.9000 0.000 0.000 0.000 0.000
29.901 755.00000 15.2000 -44.53125 0.00000 0.84500 0.84500 13.00000 0.30900 1.07500 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.9000 0.000 0.000 0.000 0.000
29.911 755.00000 15.2000 -44.53125 0.00000 0.84500 0.84500 13.00000 0.30900 1.07500 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.9000 0.000 0.000 0.000 0.000
29.921 755.00000 15.2000 -44.53125 0.00000 0.84500 0.84500 13.00000 0.30900 1.07500 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.9000 0.000 0.000 0.000 0.000
29.931 720.00000 15.2000 -44.53125 0.00000 0.85100 0.85100 13.10000 0.30900 1.07500 5.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.7000 0.000 0.000 0.000 0.000
29.941 720.00000 15.2000 -44.53125 0.00000 0.85100 0.85100 13.10000 0.30900 1.07500 5.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.7000 0.000 0.000 0.000 0.000
29.951 720.00000 15.2000 -44.53125 0.00000 0.85100 0.85100 13.10000 0.30900 1.07500 5.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.7000 0.000 0.000 0.000 0.000
29.961 720.00000 15.2000 -44.53125 0.00000 0.85100 0.85100 13.10000 0.30900 1.07500 5.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.7000 0.000 0.000 0.000 0.000
29.971 720.00000 15.2000 -44.53125 0.00000 0.85100 0.85100 13.10000 0.30900 1.07500 5.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.7000 0.000 0.000 0.000 0.000
29.981 720.00000 15.2000 -44.53125 0.00000 0.86800 0.86800 13.10000 0.30900 1.07500 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.7000 0.000 0.000 0.000 0.000
29.991 720.00000 15.2000 -44.53125 0.00000 0.86800 0.86800 13.10000 0.30900 1.07500 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.7000 0.000 0.000 0.000 0.000
30.001 720.00000 15.2000 -44.53125 0.00000 0.86800 0.86800 13.10000 0.30900 1.07500 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.7000 0.000 0.000 0.000 0.000
30.011 720.00000 15.2000 -44.53125 0.00000 0.86800 0.86800 13.10000 0.30900 1.07500 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.7000 0.000 0.000 0.000 0.000
30.021 720.00000 15.2000 -44.53125 0.00000 0.86800 0.86800 13.10000 0.30900 1.07500 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.7000 0.000 0.000 0.000 0.000
30.031 720.00000 15.2000 -44.53125 0.00000 0.87400 0.87400 13.00000 0.30900 1.07500 5.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.0000 0.000 0.000 0.000 0.000
30.041 720.00000 15.2000 -44.53125 0.00000 0.87400 0.87400 13.00000 0.30900 1.07500 5.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.0000 0.000 0.000 0.000 0.000
30.051 720.00000 15.2000 -44.53125 0.00000 0.87400 0.87400 13.00000 0.30900 1.07500 5.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.0000 0.000 0.000 0.000 0.000
30.061 720.00000 15.2000 -44.53125 0.00000 0.87400 0.87400 13.00000 0.30900 1.07500 5.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.0000 0.000 0.000 0.000 0.000
30.071 720.00000 15.2000 -44.53125 0.00000 0.87400 0.87400 13.00000 0.30900 1.07500 5.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.0000 0.000 0.000 0.000 0.000
30.081 717.00000 15.2000 -44.53125 0.00000 0.83300 0.83300 13.00000 0.30000 1.05900 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.8000 0.000 0.000 0.000 0.000
30.091 717.00000 15.2000 -44.53125 0.00000 0.83300 0.83300 13.00000 0.30000 1.05900 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.8000 0.000 0.000 0.000 0.000
30.101 717.00000 15.2000 -44.53125 0.00000 0.83300 0.83300 13.00000 0.30000 1.05900 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.8000 0.000 0.000 0.000 0.000
30.111 717.00000 15.2000 -44.53125 0.00000 0.83300 0.83300 13.00000 0.30000 1.05900 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.8000 0.000 0.000 0.000 0.000
30.121 717.00000 15.2000 -44.53125 0.00000 0.83300 0.83300 13.00000 0.30000 1.05900 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.8000 0.000 0.000 0.000 0.000
30.131 717.00000 15.4000 -44.53125 0.00000 0.84500 0.84500 12.00000 0.30000 1.05900 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.9000 0.000 0.000 0.000 0.000
30.141 717.00000 15.4000 -44.53125 0.00000 0.84500 0.84500 12.00000 0.30000 1.05900 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.9000 0.000 0.000 0.000 0.000
30.151 717.00000 15.4000 -44.53125 0.00000 0.84500 0.84500 12.00000 0.30000 1.05900 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.9000 0.000 0.000 0.000 0.000
30.161 717.00000 15.4000 -44.53125 0.00000 0.84500 0.84500 12.00000 0.30000 1.05900 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.9000 0.000 0.000 0.000 0.000
30.171 717.00000 15.4000 -44.53125 0.00000 0.84500 0.84500 12.00000 0.30000 1.05900 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.9000 0.000 0.000 0.000 0.000
30.181 723.00000 15.2000 -44.53125 0.00000 0.82700 0.82700 12.60000 0.30000 1.05900 5.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.6000 0.000 0.000 0.000 0.000
30.191 723.00000 15.2000 -44.53125 0.00000 0.82700 0.82700 12.60000 0.30000 1.05900 5.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.6000 0.000 0.000 0.000 0.000
30.201 723.00000 15.2000 -44.53125 0.00000 0.82700 0.82700 12.60000 0.30000 1.05900 5.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.6000 0.000 0.000 0.000 0.000
30.211 723.00000 15.2000 -44.53125 0.00000 0.82700 0.82700 12.60000 0.30000 1.05900 5.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.6000 0.000 0.000 0.000 0.000
30.221 723.00000 15.2000 -44.53125 0.00000 0.82700 0.82700 12.60000 0.30000 1.05900 5.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.6000 0.000 0.000 0.000 0.000
30.231 723.00000 15.2000 -44.53125 0.00000 0.86200 0.86200 12.70000 0.30000 1.05900 6.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.8000 0.000 0.000 0.000 0.000
30.241 723.00000 15.2000 -44.53125 0.00000 0.86200 0.86200 12.70000 0.30000 1.05900 6.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.8000 0.000 0.000 0.000 0.000
30.251 723.00000 15.2000 -44.53125 0.00000 0.86200 0.86200 12.70000 0.30000 1.05900 6.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.8000 0.000 0.000 0.000 0.000
30.261 723.00000 15.2000 -44.53125 0.00000 0.86200 0.86200 12.70000 0.30000 1.05900 6.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.8000 0.000 0.000 0.000 0.000
30.271 723.00000 15.2000 -44.53125 0.00000 0.86200 0.86200 12.70000 0.30000 1.05900 6.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.8000 0.000 0.000 0.000 0.000
30.281 723.00000 15.2000 -44.53125 0.00000 0.89100 0.89100 12.90000 0.30300 1.05000 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.6000 0.000 0.000 0.000 0.000
30.291 723.00000 15.2000 -44.53125 0.00000 0.89100 0.89100 12.90000 0.30300 1.05000 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.6000 0.000 0.000 0.000 0.000
30.301 723.00000 15.2000 -44.53125 0.00000 0.89100 0.89100 12.90000 0.30300 1.05000 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.6000 0.000 0.000 0.000 0.000
30.311 723.00000 15.2000 -44.53125 0.00000 0.89100 0.89100 12.90000 0.30300 1.05000 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.6000 0.000 0.000 0.000 0.000
30.321 723.00000 15.2000 -44.53125 0.00000 0.89100 0.89100 12.90000 0.30300 1.05000 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.6000 0.000 0.000 0.000 0.000
30.331 716.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 12.80000 0.30300 1.05000 5.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.6000 0.000 0.000 0.000 0.000
30.341 716.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 12.80000 0.30300 1.05000 5.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.6000 0.000 0.000 0.000 0.000
30.351 716.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 12.80000 0.30300 1.05000 5.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.6000 0.000 0.000 0.000 0.000
30.361 716.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 12.80000 0.30300 1.05000 5.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.6000 0.000 0.000 0.000 0.000
30.371 716.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 12.80000 0.30300 1.05000 5.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.6000 0.000 0.000 0.000 0.000
30.381 716.00000 15.2000 -44.53125 0.00000 0.86200 0.86200 12.90000 0.30300 1.05000 6.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.8000 0.000 0.000 0.000 0.000
30.391 716.00000 15.2000 -44.53125 0.00000 0.86200 0.86200 12.90000 0.30300 1.05000 6.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.8000 0.000 0.000 0.000 0.000
30.401 716.00000 15.2000 -44.53125 0.00000 0.86200 0.86200 12.90000 0.30300 1.05000 6.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.8000 0.000 0.000 0.000 0.000
30.411 716.00000 15.2000 -44.53125 0.00000 0.86200 0.86200 12.90000 0.30300 1.05000 6.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.8000 0.000 0.000 0.000 0.000
30.421 716.00000 15.2000 -44.53125 0.00000 0.86200 0.86200 12.90000 0.30300 1.05000 6.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.8000 0.000 0.000 0.000 0.000
30.431 716.00000 15.2000 -44.53125 0.00000 0.84500 0.84500 13.10000 0.30300 1.05000 5.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.7000 0.000 0.000 0.000 0.000
30.441 716.00000 15.2000 -44.53125 0.00000 0.84500 0.84500 13.10000 0.30300 1.05000 5.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.7000 0.000 0.000 0.000 0.000
30.451 716.00000 15.2000 -44.53125 0.00000 0.84500 0.84500 13.10000 0.30300 1.05000 5.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.7000 0.000 0.000 0.000 0.000
30.461 716.00000 15.2000 -44.53125 0.00000 0.84500 0.84500 13.10000 0.30300 1.05000 5.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.7000 0.000 0.000 0.000 0.000
30.471 716.00000 15.2000 -44.53125 0.00000 0.84500 0.84500 13.10000 0.30300 1.05000 5.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.7000 0.000 0.000 0.000 0.000
30.481 743.00000 15.2000 -44.53125 0.00000 0.85600 0.85600 12.60000 0.30000 1.03700 5.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.8000 0.000 0.000 0.000 0.000
30.491 743.00000 15.2000 -44.53125 0.00000 0.85600 0.85600 12.60000 0.30000 1.03700 5.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.8000 0.000 0.000 0.000 0.000
30.501 743.00000 15.2000 -44.53125 0.00000 0.85600 0.85600 12.60000 0.30000 1.03700 5.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.8000 0.000 0.000 0.000 0.000
30.511 743.00000 15.2000 -44.53125 0.00000 0.85600 0.85600 12.60000 0.30000 1.03700 5.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.8000 0.000 0.000 0.000 0.000
30.521 743.00000 15.2000 -44.53125 0.00000 0.85600 0.85600 12.60000 0.30000 1.03700 5.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.8000 0.000 0.000 0.000 0.000
30.531 743.00000 15.2000 -44.53125 0.00000 0.87400 0.87400 12.80000 0.30000 1.03700 6.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.8000 0.000 0.000 0.000 0.000
30.541 743.00000 15.2000 -44.53125 0.00000 0.87400 0.87400 12.80000 0.30000 1.03700 6.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.8000 0.000 0.000 0.000 0.000
30.551 743.00000 15.2000 -44.53125 0.00000 0.87400 0.87400 12.80000 0.30000 1.03700 6.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.8000 0.000 0.000 0.000 0.000
30.561 743.00000 15.2000 -44.53125 0.00000 0.87400 0.87400 12.80000 0.30000 1.03700 6.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.8000 0.000 0.000 0.000 0.000
30.571 743.00000 15.2000 -44.53125 0.00000 0.87400 0.87400 12.80000 0.30000 1.03700 6.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.8000 0.000 0.000 0.000 0.000
30.581 768.00000 15.2000 -44.53125 0.00000 0.84500 0.84500 12.80000 0.30000 1.03700 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.9000 0.000 0.000 0.000 0.000
30.591 768.00000 15.2000 -44.53125 0.00000 0.84500 0.84500 12.80000 0.30000 1.03700 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.9000 0.000 0.000 0.000 0.000
30.601 768.00000 15.2000 -44.53125 0.00000 0.84500 0.84500 12.80000 0.30000 1.03700 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.9000 0.000 0.000 0.000 0.000
30.611 768.00000 15.2000 -44.53125 0.00000 0.84500 0.84500 12.80000 0.30000 1.03700 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.9000 0.000 0.000 0.000 0.000
30.621 768.00000 15.2000 -44.53125 0.00000 0.84500 0.84500 12.80000 0.30000 1.03700 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.9000 0.000 0.000 0.000 0.000
30.631 768.00000 15.2000 -44.53125 0.00000 0.86800 0.86800 13.40000 0.30000 1.03700 5.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.7000 0.000 0.000 0.000 0.000
30.641 768.00000 15.2000 -44.53125 0.00000 0.86800 0.86800 13.40000 0.30000 1.03700 5.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.7000 0.000 0.000 0.000 0.000
30.651 768.00000 15.2000 -44.53125 0.00000 0.86800 0.86800 13.40000 0.30000 1.03700 5.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.7000 0.000 0.000 0.000 0.000
30.661 768.00000 15.2000 -44.53125 0.00000 0.86800 0.86800 13.40000 0.30000 1.03700 5.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.7000 0.000 0.000 0.000 0.000
30.671 768.00000 15.2000 -44.53125 0.00000 0.86800 0.86800 13.40000 0.30000 1.03700 5.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.7000 0.000 0.000 0.000 0.000
30.681 768.00000 15.2000 -44.53125 0.00000 0.87400 0.87400 13.70000 0.30000 1.01500 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.7000 0.000 0.000 0.000 0.000
30.691 768.00000 15.2000 -44.53125 0.00000 0.87400 0.87400 13.70000 0.30000 1.01500 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.7000 0.000 0.000 0.000 0.000
30.701 768.00000 15.2000 -44.53125 0.00000 0.87400 0.87400 13.70000 0.30000 1.01500 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.7000 0.000 0.000 0.000 0.000
30.711 768.00000 15.2000 -44.53125 0.00000 0.87400 0.87400 13.70000 0.30000 1.01500 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.7000 0.000 0.000 0.000 0.000
30.721 768.00000 15.2000 -44.53125 0.00000 0.87400 0.87400 13.70000 0.30000 1.01500 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.7000 0.000 0.000 0.000 0.000
30.731 807.00000 15.2000 -44.53125 0.00000 0.86200 0.86200 13.20000 0.30000 1.01500 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.0000 0.000 0.000 0.000 0.000
30.741 807.00000 15.2000 -44.53125 0.00000 0.86200 0.86200 13.20000 0.30000 1.01500 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.0000 0.000 0.000 0.000 0.000
30.751 807.00000 15.2000 -44.53125 0.00000 0.86200 0.86200 13.20000 0.30000 1.01500 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.0000 0.000 0.000 0.000 0.000
30.761 807.00000 15.2000 -44.53125 0.00000 0.86200 0.86200 13.20000 0.30000 1.01500 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.0000 0.000 0.000 0.000 0.000
30.771 807.00000 15.2000 -44.53125 0.00000 0.86200 0.86200 13.20000 0.30000 1.01500 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.0000 0.000 0.000 0.000 0.000
30.781 807.00000 15.2000 -44.53125 0.00000 0.86200 0.86200 13.40000 0.30000 1.01500 5.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.9000 0.000 0.000 0.000 0.000
30.791 807.00000 15.2000 -44.53125 0.00000 0.86200 0.86200 13.40000 0.30000 1.01500 5.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.9000 0.000 0.000 0.000 0.000
30.801 807.00000 15.2000 -44.53125 0.00000 0.86200 0.86200 13.40000 0.30000 1.01500 5.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.9000 0.000 0.000 0.000 0.000
30.811 807.00000 15.2000 -44.53125 0.00000 0.86200 0.86200 13.40000 0.30000 1.01500 5.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.9000 0.000 0.000 0.000 0.000
30.821 807.00000 15.2000 -44.53125 0.00000 0.86200 0.86200 13.40000 0.30000 1.01500 5.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.9000 0.000 0.000 0.000 0.000
30.831 848.00000 15.2000 -44.53125 0.00000 0.86800 0.86800 13.10000 0.30000 1.01500 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.1000 0.000 0.000 0.000 0.000
30.841 848.00000 15.2000 -44.53125 0.00000 0.86800 0.86800 13.10000 0.30000 1.01500 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.1000 0.000 0.000 0.000 0.000
30.851 848.00000 15.2000 -44.53125 0.00000 0.86800 0.86800 13.10000 0.30000 1.01500 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.1000 0.000 0.000 0.000 0.000
30.861 848.00000 15.2000 -44.53125 0.00000 0.86800 0.86800 13.10000 0.30000 1.01500 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.1000 0.000 0.000 0.000 0.000
30.871 848.00000 15.2000 -44.53125 0.00000 0.86800 0.86800 13.10000 0.30000 1.01500 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.1000 0.000 0.000 0.000 0.000
30.881 848.00000 15.2000 -44.53125 0.00000 0.81600 0.81600 13.10000 0.29300 0.96300 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.3000 0.000 0.000 0.000 0.000
30.891 848.00000 15.2000 -44.53125 0.00000 0.81600 0.81600 13.10000 0.29300 0.96300 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.3000 0.000 0.000 0.000 0.000
30.901 848.00000 15.2000 -44.53125 0.00000 0.81600 0.81600 13.10000 0.29300 0.96300 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.3000 0.000 0.000 0.000 0.000
30.911 848.00000 15.2000 -44.53125 0.00000 0.81600 0.81600 13.10000 0.29300 0.96300 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.3000 0.000 0.000 0.000 0.000
30.921 848.00000 15.2000 -44.53125 0.00000 0.81600 0.81600 13.10000 0.29300 0.96300 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.3000 0.000 0.000 0.000 0.000
30.931 872.00000 15.2000 -44.53125 0.00000 0.84500 0.84500 13.20000 0.29300 0.96300 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
30.941 872.00000 15.2000 -44.53125 0.00000 0.84500 0.84500 13.20000 0.29300 0.96300 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
30.951 872.00000 15.2000 -44.53125 0.00000 0.84500 0.84500 13.20000 0.29300 0.96300 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
30.961 872.00000 15.2000 -44.53125 0.00000 0.84500 0.84500 13.20000 0.29300 0.96300 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
30.971 872.00000 15.2000 -44.53125 0.00000 0.84500 0.84500 13.20000 0.29300 0.96300 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
30.981 872.00000 15.2000 -44.53125 0.00000 0.86800 0.86800 13.50000 0.29300 0.96300 5.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.3000 0.000 0.000 0.000 0.000
30.991 872.00000 15.2000 -44.53125 0.00000 0.86800 0.86800 13.50000 0.29300 0.96300 5.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.3000 0.000 0.000 0.000 0.000
31.001 872.00000 15.2000 -44.53125 0.00000 0.86800 0.86800 13.50000 0.29300 0.96300 5.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.3000 0.000 0.000 0.000 0.000
31.011 872.00000 15.2000 -44.53125 0.00000 0.86800 0.86800 13.50000 0.29300 0.96300 5.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.3000 0.000 0.000 0.000 0.000
31.021 872.00000 15.2000 -44.53125 0.00000 0.86800 0.86800 13.50000 0.29300 0.96300 5.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.3000 0.000 0.000 0.000 0.000
31.031 866.00000 15.2000 -44.53125 0.00000 0.83300 0.83300 13.20000 0.29300 0.96300 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
31.041 866.00000 15.2000 -44.53125 0.00000 0.83300 0.83300 13.20000 0.29300 0.96300 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
31.051 866.00000 15.2000 -44.53125 0.00000 0.83300 0.83300 13.20000 0.29300 0.96300 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
31.061 866.00000 15.2000 -44.53125 0.00000 0.83300 0.83300 13.20000 0.29300 0.96300 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
31.071 866.00000 15.2000 -44.53125 0.00000 0.83300 0.83300 13.20000 0.29300 0.96300 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
31.081 866.00000 15.2000 -44.53125 0.00000 0.85100 0.85100 13.30000 0.29300 0.90300 5.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
31.091 866.00000 15.2000 -44.53125 0.00000 0.85100 0.85100 13.30000 0.29300 0.90300 5.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
31.101 866.00000 15.2000 -44.53125 0.00000 0.85100 0.85100 13.30000 0.29300 0.90300 5.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
31.111 866.00000 15.2000 -44.53125 0.00000 0.85100 0.85100 13.30000 0.29300 0.90300 5.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
31.121 866.00000 15.2000 -44.53125 0.00000 0.85100 0.85100 13.30000 0.29300 0.90300 5.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
31.131 866.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 13.20000 0.29300 0.90300 5.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
31.141 866.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 13.20000 0.29300 0.90300 5.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
31.151 866.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 13.20000 0.29300 0.90300 5.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
31.161 866.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 13.20000 0.29300 0.90300 5.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
31.171 866.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 13.20000 0.29300 0.90300 5.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
31.181 844.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 13.10000 0.29300 0.90300 5.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
31.191 844.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 13.10000 0.29300 0.90300 5.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
31.201 844.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 13.10000 0.29300 0.90300 5.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
31.211 844.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 13.10000 0.29300 0.90300 5.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
31.221 844.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 13.10000 0.29300 0.90300 5.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
31.231 844.00000 15.2000 -44.53125 0.00000 0.86800 0.86800 13.10000 0.29300 0.90300 5.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
31.241 844.00000 15.2000 -44.53125 0.00000 0.86800 0.86800 13.10000 0.29300 0.90300 5.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
31.251 844.00000 15.2000 -44.53125 0.00000 0.86800 0.86800 13.10000 0.29300 0.90300 5.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
31.261 844.00000 15.2000 -44.53125 0.00000 0.86800 0.86800 13.10000 0.29300 0.90300 5.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
31.271 844.00000 15.2000 -44.53125 0.00000 0.86800 0.86800 13.10000 0.29300 0.90300 5.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
31.281 822.00000 15.2000 -44.53125 0.00000 0.89100 0.89100 13.30000 0.29300 0.82900 5.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.7000 0.000 0.000 0.000 0.000
31.291 822.00000 15.2000 -44.53125 0.00000 0.89100 0.89100 13.30000 0.29300 0.82900 5.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.7000 0.000 0.000 0.000 0.000
31.301 822.00000 15.2000 -44.53125 0.00000 0.89100 0.89100 13.30000 0.29300 0.82900 5.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.7000 0.000 0.000 0.000 0.000
31.311 822.00000 15.2000 -44.53125 0.00000 0.89100 0.89100 13.30000 0.29300 0.82900 5.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.7000 0.000 0.000 0.000 0.000
31.321 822.00000 15.2000 -44.53125 0.00000 0.89100 0.89100 13.30000 0.29300 0.82900 5.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.7000 0.000 0.000 0.000 0.000
31.331 822.00000 15.2000 -44.53125 0.00000 0.89100 0.89100 13.40000 0.29300 0.82900 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
31.341 822.00000 15.2000 -44.53125 0.00000 0.89100 0.89100 13.40000 0.29300 0.82900 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
31.351 822.00000 15.2000 -44.53125 0.00000 0.89100 0.89100 13.40000 0.29300 0.82900 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
31.361 822.00000 15.2000 -44.53125 0.00000 0.89100 0.89100 13.40000 0.29300 0.82900 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
31.371 822.00000 15.2000 -44.53125 0.00000 0.89100 0.89100 13.40000 0.29300 0.82900 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
31.381 805.00000 15.2000 -44.53125 0.00000 0.86200 0.86200 13.30000 0.29300 0.82900 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
31.391 805.00000 15.2000 -44.53125 0.00000 0.86200 0.86200 13.30000 0.29300 0.82900 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
31.401 805.00000 15.2000 -44.53125 0.00000 0.86200 0.86200 13.30000 0.29300 0.82900 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
31.411 805.00000 15.2000 -44.53125 0.00000 0.86200 0.86200 13.30000 0.29300 0.82900 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
31.421 805.00000 15.2000 -44.53125 0.00000 0.86200 0.86200 13.30000 0.29300 0.82900 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
31.431 805.00000 15.4000 -44.53125 0.00000 0.90900 0.90900 12.00000 0.29300 0.82900 5.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
31.441 805.00000 15.4000 -44.53125 0.00000 0.90900 0.90900 12.00000 0.29300 0.82900 5.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
31.451 805.00000 15.4000 -44.53125 0.00000 0.90900 0.90900 12.00000 0.29300 0.82900 5.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
31.461 805.00000 15.4000 -44.53125 0.00000 0.90900 0.90900 12.00000 0.29300 0.82900 5.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
31.471 805.00000 15.4000 -44.53125 0.00000 0.90900 0.90900 12.00000 0.29300 0.82900 5.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
31.481 805.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 13.50000 0.29600 0.67000 5.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.4000 0.000 0.000 0.000 0.000
31.491 805.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 13.50000 0.29600 0.67000 5.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.4000 0.000 0.000 0.000 0.000
31.501 805.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 13.50000 0.29600 0.67000 5.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.4000 0.000 0.000 0.000 0.000
31.511 805.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 13.50000 0.29600 0.67000 5.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.4000 0.000 0.000 0.000 0.000
31.521 805.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 13.50000 0.29600 0.67000 5.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.4000 0.000 0.000 0.000 0.000
31.531 819.00000 15.2000 -44.53125 0.00000 0.92100 0.92100 13.10000 0.29600 0.67000 5.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
31.541 819.00000 15.2000 -44.53125 0.00000 0.92100 0.92100 13.10000 0.29600 0.67000 5.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
31.551 819.00000 15.2000 -44.53125 0.00000 0.92100 0.92100 13.10000 0.29600 0.67000 5.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
31.561 819.00000 15.2000 -44.53125 0.00000 0.92100 0.92100 13.10000 0.29600 0.67000 5.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
31.571 819.00000 15.2000 -44.53125 0.00000 0.92100 0.92100 13.10000 0.29600 0.67000 5.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
31.581 819.00000 15.2000 -44.53125 0.00000 0.92100 0.92100 13.20000 0.29600 0.67000 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
31.591 819.00000 15.2000 -44.53125 0.00000 0.92100 0.92100 13.20000 0.29600 0.67000 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
31.601 819.00000 15.2000 -44.53125 0.00000 0.92100 0.92100 13.20000 0.29600 0.67000 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
31.611 819.00000 15.2000 -44.53125 0.00000 0.92100 0.92100 13.20000 0.29600 0.67000 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
31.621 819.00000 15.2000 -44.53125 0.00000 0.92100 0.92100 13.20000 0.29600 0.67000 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
31.631 807.00000 15.2000 -44.53125 0.00000 0.89700 0.89700 13.40000 0.29600 0.67000 5.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
31.641 807.00000 15.2000 -44.53125 0.00000 0.89700 0.89700 13.40000 0.29600 0.67000 5.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
31.651 807.00000 15.2000 -44.53125 0.00000 0.89700 0.89700 13.40000 0.29600 0.67000 5.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
31.661 807.00000 15.2000 -44.53125 0.00000 0.89700 0.89700 13.40000 0.29600 0.67000 5.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
31.671 807.00000 15.2000 -44.53125 0.00000 0.89700 0.89700 13.40000 0.29600 0.67000 5.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
31.681 807.00000 15.2000 -44.53125 0.00000 0.88600 0.88600 13.20000 0.30000 0.44300 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.4000 0.000 0.000 0.000 0.000
31.691 807.00000 15.2000 -44.53125 0.00000 0.88600 0.88600 13.20000 0.30000 0.44300 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.4000 0.000 0.000 0.000 0.000
31.701 807.00000 15.2000 -44.53125 0.00000 0.88600 0.88600 13.20000 0.30000 0.44300 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.4000 0.000 0.000 0.000 0.000
31.711 807.00000 15.2000 -44.53125 0.00000 0.88600 0.88600 13.20000 0.30000 0.44300 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.4000 0.000 0.000 0.000 0.000
31.721 807.00000 15.2000 -44.53125 0.00000 0.88600 0.88600 13.20000 0.30000 0.44300 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.4000 0.000 0.000 0.000 0.000
31.731 807.00000 15.2000 -44.53125 0.00000 0.85600 0.85600 13.20000 0.30000 0.44300 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
31.741 807.00000 15.2000 -44.53125 0.00000 0.85600 0.85600 13.20000 0.30000 0.44300 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
31.751 807.00000 15.2000 -44.53125 0.00000 0.85600 0.85600 13.20000 0.30000 0.44300 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
31.761 807.00000 15.2000 -44.53125 0.00000 0.85600 0.85600 13.20000 0.30000 0.44300 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
31.771 807.00000 15.2000 -44.53125 0.00000 0.85600 0.85600 13.20000 0.30000 0.44300 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
31.781 816.00000 15.2000 -44.53125 0.00000 0.89700 0.89700 13.10000 0.30000 0.44300 5.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.3000 0.000 0.000 0.000 0.000
31.791 816.00000 15.2000 -44.53125 0.00000 0.89700 0.89700 13.10000 0.30000 0.44300 5.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.3000 0.000 0.000 0.000 0.000
31.801 816.00000 15.2000 -44.53125 0.00000 0.89700 0.89700 13.10000 0.30000 0.44300 5.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.3000 0.000 0.000 0.000 0.000
31.811 816.00000 15.2000 -44.53125 0.00000 0.89700 0.89700 13.10000 0.30000 0.44300 5.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.3000 0.000 0.000 0.000 0.000
31.821 816.00000 15.2000 -44.53125 0.00000 0.89700 0.89700 13.10000 0.30000 0.44300 5.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.3000 0.000 0.000 0.000 0.000
31.831 816.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 13.50000 0.30000 0.44300 5.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.3000 0.000 0.000 0.000 0.000
31.841 816.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 13.50000 0.30000 0.44300 5.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.3000 0.000 0.000 0.000 0.000
31.851 816.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 13.50000 0.30000 0.44300 5.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.3000 0.000 0.000 0.000 0.000
31.861 816.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 13.50000 0.30000 0.44300 5.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.3000 0.000 0.000 0.000 0.000
31.871 816.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 13.50000 0.30000 0.44300 5.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.3000 0.000 0.000 0.000 0.000
31.881 873.00000 15.2000 -44.53125 0.00000 0.93200 0.93200 13.10000 0.30000 0.32800 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.4000 0.000 0.000 0.000 0.000
31.891 873.00000 15.2000 -44.53125 0.00000 0.93200 0.93200 13.10000 0.30000 0.32800 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.4000 0.000 0.000 0.000 0.000
31.901 873.00000 15.2000 -44.53125 0.00000 0.93200 0.93200 13.10000 0.30000 0.32800 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.4000 0.000 0.000 0.000 0.000
31.911 873.00000 15.2000 -44.53125 0.00000 0.93200 0.93200 13.10000 0.30000 0.32800 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.4000 0.000 0.000 0.000 0.000
31.921 873.00000 15.2000 -44.53125 0.00000 0.93200 0.93200 13.10000 0.30000 0.32800 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.4000 0.000 0.000 0.000 0.000
31.931 873.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 13.50000 0.30000 0.32800 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.4000 0.000 0.000 0.000 0.000
31.941 873.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 13.50000 0.30000 0.32800 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.4000 0.000 0.000 0.000 0.000
31.951 873.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 13.50000 0.30000 0.32800 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.4000 0.000 0.000 0.000 0.000
31.961 873.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 13.50000 0.30000 0.32800 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.4000 0.000 0.000 0.000 0.000
31.971 873.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 13.50000 0.30000 0.32800 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.4000 0.000 0.000 0.000 0.000
31.981 912.00000 15.2000 -44.53125 0.00000 0.93800 0.93800 12.80000 0.30000 0.32800 5.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
31.991 912.00000 15.2000 -44.53125 0.00000 0.93800 0.93800 12.80000 0.30000 0.32800 5.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
32.001 912.00000 15.2000 -44.53125 0.00000 0.93800 0.93800 12.80000 0.30000 0.32800 5.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
32.011 912.00000 15.2000 -44.53125 0.00000 0.93800 0.93800 12.80000 0.30000 0.32800 5.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
32.021 912.00000 15.2000 -44.53125 0.00000 0.93800 0.93800 12.80000 0.30000 0.32800 5.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
32.031 912.00000 15.2000 -44.53125 0.00000 0.88600 0.88600 13.30000 0.30000 0.32800 5.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.3000 0.000 0.000 0.000 0.000
32.041 912.00000 15.2000 -44.53125 0.00000 0.88600 0.88600 13.30000 0.30000 0.32800 5.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.3000 0.000 0.000 0.000 0.000
32.051 912.00000 15.2000 -44.53125 0.00000 0.88600 0.88600 13.30000 0.30000 0.32800 5.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.3000 0.000 0.000 0.000 0.000
32.061 912.00000 15.2000 -44.53125 0.00000 0.88600 0.88600 13.30000 0.30000 0.32800 5.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.3000 0.000 0.000 0.000 0.000
32.071 912.00000 15.2000 -44.53125 0.00000 0.88600 0.88600 13.30000 0.30000 0.32800 5.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.3000 0.000 0.000 0.000 0.000
32.081 981.00000 15.2000 -44.53125 0.00000 0.92100 0.92100 13.30000 0.30300 0.31900 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.3000 0.000 0.000 0.000 0.000
32.091 981.00000 15.2000 -44.53125 0.00000 0.92100 0.92100 13.30000 0.30300 0.31900 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.3000 0.000 0.000 0.000 0.000
32.101 981.00000 15.2000 -44.53125 0.00000 0.92100 0.92100 13.30000 0.30300 0.31900 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.3000 0.000 0.000 0.000 0.000
32.111 981.00000 15.2000 -44.53125 0.00000 0.92100 0.92100 13.30000 0.30300 0.31900 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.3000 0.000 0.000 0.000 0.000
32.121 981.00000 15.2000 -44.53125 0.00000 0.92100 0.92100 13.30000 0.30300 0.31900 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.3000 0.000 0.000 0.000 0.000
32.131 981.00000 15.2000 -44.53125 0.00000 0.92600 0.92600 13.30000 0.30300 0.31900 4.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.3000 0.000 0.000 0.000 0.000
32.141 981.00000 15.2000 -44.53125 0.00000 0.92600 0.92600 13.30000 0.30300 0.31900 4.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.3000 0.000 0.000 0.000 0.000
32.151 981.00000 15.2000 -44.53125 0.00000 0.92600 0.92600 13.30000 0.30300 0.31900 4.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.3000 0.000 0.000 0.000 0.000
32.161 981.00000 15.2000 -44.53125 0.00000 0.92600 0.92600 13.30000 0.30300 0.31900 4.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.3000 0.000 0.000 0.000 0.000
32.171 981.00000 15.2000 -44.53125 0.00000 0.92600 0.92600 13.30000 0.30300 0.31900 4.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.3000 0.000 0.000 0.000 0.000
32.181 1059.00000 15.2000 -44.53125 0.00000 0.93200 0.93200 13.50000 0.30300 0.31900 4.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.1000 0.000 0.000 0.000 0.000
32.191 1059.00000 15.2000 -44.53125 0.00000 0.93200 0.93200 13.50000 0.30300 0.31900 4.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.1000 0.000 0.000 0.000 0.000
32.201 1059.00000 15.2000 -44.53125 0.00000 0.93200 0.93200 13.50000 0.30300 0.31900 4.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.1000 0.000 0.000 0.000 0.000
32.211 1059.00000 15.2000 -44.53125 0.00000 0.93200 0.93200 13.50000 0.30300 0.31900 4.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.1000 0.000 0.000 0.000 0.000
32.221 1059.00000 15.2000 -44.53125 0.00000 0.93200 0.93200 13.50000 0.30300 0.31900 4.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.1000 0.000 0.000 0.000 0.000
32.231 1218.00000 15.2000 -44.53125 0.00000 0.95600 0.95600 13.20000 0.30300 0.31900 4.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 18.3000 0.000 0.000 0.000 0.000
32.241 1218.00000 15.2000 -44.53125 0.00000 0.95600 0.95600 13.20000 0.30300 0.31900 4.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 18.3000 0.000 0.000 0.000 0.000
32.251 1218.00000 15.2000 -44.53125 0.00000 0.95600 0.95600 13.20000 0.30300 0.31900 4.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 18.3000 0.000 0.000 0.000 0.000
32.261 1218.00000 15.2000 -44.53125 0.00000 0.95600 0.95600 13.20000 0.30300 0.31900 4.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 18.3000 0.000 0.000 0.000 0.000
32.271 1218.00000 15.2000 -44.53125 0.00000 0.95600 0.95600 13.20000 0.30300 0.31900 4.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 18.3000 0.000 0.000 0.000 0.000
32.281 1218.00000 15.2000 -44.53125 0.00000 0.96100 0.96100 13.60000 0.28700 0.31200 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 17.6000 0.000 0.000 0.000 0.000
32.291 1218.00000 15.2000 -44.53125 0.00000 0.96100 0.96100 13.60000 0.28700 0.31200 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 17.6000 0.000 0.000 0.000 0.000
32.301 1218.00000 15.2000 -44.53125 0.00000 0.96100 0.96100 13.60000 0.28700 0.31200 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 17.6000 0.000 0.000 0.000 0.000
32.311 1218.00000 15.2000 -44.53125 0.00000 0.96100 0.96100 13.60000 0.28700 0.31200 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 17.6000 0.000 0.000 0.000 0.000
32.321 1218.00000 15.2000 -44.53125 0.00000 0.96100 0.96100 13.60000 0.28700 0.31200 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 17.6000 0.000 0.000 0.000 0.000
32.331 1348.00000 15.2000 -44.53125 0.00000 0.96100 0.96100 12.90000 0.28700 0.31200 4.10000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 17.6000 0.000 0.000 0.000 0.000
32.341 1348.00000 15.2000 -44.53125 0.00000 0.96100 0.96100 12.90000 0.28700 0.31200 4.10000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 17.6000 0.000 0.000 0.000 0.000
32.351 1348.00000 15.2000 -44.53125 0.00000 0.96100 0.96100 12.90000 0.28700 0.31200 4.10000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 17.6000 0.000 0.000 0.000 0.000
32.361 1348.00000 15.2000 -44.53125 0.00000 0.96100 0.96100 12.90000 0.28700 0.31200 4.10000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 17.6000 0.000 0.000 0.000 0.000
32.371 1348.00000 15.2000 -44.53125 0.00000 0.96100 0.96100 12.90000 0.28700 0.31200 4.10000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 17.6000 0.000 0.000 0.000 0.000
32.381 1476.00000 15.4000 -44.53125 0.00000 0.99600 0.99600 12.50000 0.28700 0.31200 4.10000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 17.6000 0.000 0.000 0.000 0.000
32.391 1476.00000 15.4000 -44.53125 0.00000 0.99600 0.99600 12.50000 0.28700 0.31200 4.10000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 17.6000 0.000 0.000 0.000 0.000
32.401 1476.00000 15.4000 -44.53125 0.00000 0.99600 0.99600 12.50000 0.28700 0.31200 4.10000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 17.6000 0.000 0.000 0.000 0.000
32.411 1476.00000 15.4000 -44.53125 0.00000 0.99600 0.99600 12.50000 0.28700 0.31200 4.10000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 17.6000 0.000 0.000 0.000 0.000
32.421 1476.00000 15.4000 -44.53125 0.00000 0.99600 0.99600 12.50000 0.28700 0.31200 4.10000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 17.6000 0.000 0.000 0.000 0.000
32.431 1624.00000 16.0000 -44.53125 0.00000 1.04900 1.04900 13.30000 0.28700 0.31200 4.20000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 17.1000 0.000 0.000 0.000 0.000
32.441 1624.00000 16.0000 -44.53125 0.00000 1.04900 1.04900 13.30000 0.28700 0.31200 4.20000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 17.1000 0.000 0.000 0.000 0.000
32.451 1624.00000 16.0000 -44.53125 0.00000 1.04900 1.04900 13.30000 0.28700 0.31200 4.20000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 17.1000 0.000 0.000 0.000 0.000
32.461 1624.00000 16.0000 -44.53125 0.00000 1.04900 1.04900 13.30000 0.28700 0.31200 4.20000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 17.1000 0.000 0.000 0.000 0.000
32.471 1624.00000 16.0000 -44.53125 0.00000 1.04900 1.04900 13.30000 0.28700 0.31200 4.20000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 17.1000 0.000 0.000 0.000 0.000
32.481 1624.00000 16.5000 -44.53125 0.00000 1.15400 1.15400 12.70000 0.32200 0.31500 4.20000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 17.2000 0.000 0.000 0.000 0.000
32.491 1624.00000 16.5000 -44.53125 0.00000 1.15400 1.15400 12.70000 0.32200 0.31500 4.20000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 17.2000 0.000 0.000 0.000 0.000
32.501 1624.00000 16.5000 -44.53125 0.00000 1.15400 1.15400 12.70000 0.32200 0.31500 4.20000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 17.2000 0.000 0.000 0.000 0.000
32.511 1624.00000 16.5000 -44.53125 0.00000 1.15400 1.15400 12.70000 0.32200 0.31500 4.20000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 17.2000 0.000 0.000 0.000 0.000
32.521 1624.00000 16.5000 -44.53125 0.00000 1.15400 1.15400 12.70000 0.32200 0.31500 4.20000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 17.2000 0.000 0.000 0.000 0.000
32.531 1694.00000 17.8000 -44.53125 0.00000 1.25300 1.25300 13.20000 0.32200 0.31500 4.10000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 17.0000 0.000 0.000 0.000 0.000
32.541 1694.00000 17.8000 -44.53125 0.00000 1.25300 1.25300 13.20000 0.32200 0.31500 4.10000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 17.0000 0.000 0.000 0.000 0.000
32.551 1694.00000 17.8000 -44.53125 0.00000 1.25300 1.25300 13.20000 0.32200 0.31500 4.10000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 17.0000 0.000 0.000 0.000 0.000
32.561 1694.00000 17.8000 -44.53125 0.00000 1.25300 1.25300 13.20000 0.32200 0.31500 4.10000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 17.0000 0.000 0.000 0.000 0.000
32.571 1694.00000 17.8000 -44.53125 0.00000 1.25300 1.25300 13.20000 0.32200 0.31500 4.10000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 17.0000 0.000 0.000 0.000 0.000
32.581 1805.00000 19.5000 -44.53125 0.00000 1.37500 1.37500 13.20000 0.32200 0.31500 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 16.8000 0.000 0.000 0.000 0.000
32.591 1805.00000 19.5000 -44.53125 0.00000 1.37500 1.37500 13.20000 0.32200 0.31500 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 16.8000 0.000 0.000 0.000 0.000
32.601 1805.00000 19.5000 -44.53125 0.00000 1.37500 1.37500 13.20000 0.32200 0.31500 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 16.8000 0.000 0.000 0.000 0.000
32.611 1805.00000 19.5000 -44.53125 0.00000 1.37500 1.37500 13.20000 0.32200 0.31500 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 16.8000 0.000 0.000 0.000 0.000
32.621 1805.00000 19.5000 -44.53125 0.00000 1.37500 1.37500 13.20000 0.32200 0.31500 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 16.8000 0.000 0.000 0.000 0.000
32.631 1862.00000 20.3000 -44.53125 0.00000 1.39300 1.39300 13.50000 0.32200 0.31500 4.70000 1.00000 3.00000 3.00000 2.00000 3.00000 0.00000 0.00000 16.8000 0.000 0.000 0.000 0.000
32.641 1862.00000 20.3000 -44.53125 0.00000 1.39300 1.39300 13.50000 0.32200 0.31500 4.70000 1.00000 3.00000 3.00000 2.00000 3.00000 0.00000 0.00000 16.8000 0.000 0.000 0.000 0.000
32.651 1862.00000 20.3000 -44.53125 0.00000 1.39300 1.39300 13.50000 0.32200 0.31500 4.70000 1.00000 3.00000 3.00000 2.00000 3.00000 0.00000 0.00000 16.8000 0.000 0.000 0.000 0.000
32.661 1862.00000 20.3000 -44.53125 0.00000 1.39300 1.39300 13.50000 0.32200 0.31500 4.70000 1.00000 3.00000 3.00000 2.00000 3.00000 0.00000 0.00000 16.8000 0.000 0.000 0.000 0.000
32.671 1862.00000 20.3000 -44.53125 0.00000 1.39300 1.39300 13.50000 0.32200 0.31500 4.70000 1.00000 3.00000 3.00000 2.00000 3.00000 0.00000 0.00000 16.8000 0.000 0.000 0.000 0.000
32.681 1848.00000 20.1000 -44.53125 0.00000 1.41600 1.41600 12.70000 0.30600 0.31200 5.00000 1.00000 3.00000 2.00000 3.00000 3.00000 0.00000 0.00000 16.7000 0.000 0.000 0.000 0.000
32.691 1848.00000 20.1000 -44.53125 0.00000 1.41600 1.41600 12.70000 0.30600 0.31200 5.00000 1.00000 3.00000 2.00000 3.00000 3.00000 0.00000 0.00000 16.7000 0.000 0.000 0.000 0.000
32.701 1848.00000 20.1000 -44.53125 0.00000 1.41600 1.41600 12.70000 0.30600 0.31200 5.00000 1.00000 3.00000 2.00000 3.00000 3.00000 0.00000 0.00000 16.7000 0.000 0.000 0.000 0.000
32.711 1848.00000 20.1000 -44.53125 0.00000 1.41600 1.41600 12.70000 0.30600 0.31200 5.00000 1.00000 3.00000 2.00000 3.00000 3.00000 0.00000 0.00000 16.7000 0.000 0.000 0.000 0.000
32.721 1848.00000 20.1000 -44.53125 0.00000 1.41600 1.41600 12.70000 0.30600 0.31200 5.00000 1.00000 3.00000 2.00000 3.00000 3.00000 0.00000 0.00000 16.7000 0.000 0.000 0.000 0.000
32.731 1763.00000 20.7000 -44.53125 0.00000 1.46300 1.46300 12.60000 0.30600 0.31200 5.10000 1.00000 3.00000 3.00000 3.00000 2.00000 0.00000 0.00000 16.5000 0.000 0.000 0.000 0.000
32.741 1763.00000 20.7000 -44.53125 0.00000 1.46300 1.46300 12.60000 0.30600 0.31200 5.10000 1.00000 3.00000 3.00000 3.00000 2.00000 0.00000 0.00000 16.5000 0.000 0.000 0.000 0.000
32.751 1763.00000 20.7000 -44.53125 0.00000 1.46300 1.46300 12.60000 0.30600 0.31200 5.10000 1.00000 3.00000 3.00000 3.00000 2.00000 0.00000 0.00000 16.5000 0.000 0.000 0.000 0.000
32.761 1763.00000 20.7000 -44.53125 0.00000 1.46300 1.46300 12.60000 0.30600 0.31200 5.10000 1.00000 3.00000 3.00000 3.00000 2.00000 0.00000 0.00000 16.5000 0.000 0.000 0.000 0.000
32.771 1763.00000 20.7000 -44.53125 0.00000 1.46300 1.46300 12.60000 0.30600 0.31200 5.10000 1.00000 3.00000 3.00000 3.00000 2.00000 0.00000 0.00000 16.5000 0.000 0.000 0.000 0.000
32.781 1804.00000 20.4000 -44.53125 0.00000 1.47400 1.47400 13.30000 0.30600 0.31200 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 16.5000 0.000 0.000 0.000 0.000
32.791 1804.00000 20.4000 -44.53125 0.00000 1.47400 1.47400 13.30000 0.30600 0.31200 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 16.5000 0.000 0.000 0.000 0.000
32.801 1804.00000 20.4000 -44.53125 0.00000 1.47400 1.47400 13.30000 0.30600 0.31200 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 16.5000 0.000 0.000 0.000 0.000
32.811 1804.00000 20.4000 -44.53125 0.00000 1.47400 1.47400 13.30000 0.30600 0.31200 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 16.5000 0.000 0.000 0.000 0.000
32.821 1804.00000 20.4000 -44.53125 0.00000 1.47400 1.47400 13.30000 0.30600 0.31200 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 16.5000 0.000 0.000 0.000 0.000
32.831 1855.00000 20.4000 -44.53125 0.00000 1.47400 1.47400 13.10000 0.30600 0.31200 5.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 16.5000 0.000 0.000 0.000 0.000
32.841 1855.00000 20.4000 -44.53125 0.00000 1.47400 1.47400 13.10000 0.30600 0.31200 5.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 16.5000 0.000 0.000 0.000 0.000
32.850 1855.00000 20.4000 -44.53125 0.00000 1.47400 1.47400 13.10000 0.30600 0.31200 5.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 16.5000 0.000 0.000 0.000 0.000
32.860 1855.00000 20.4000 -44.53125 0.00000 1.47400 1.47400 13.10000 0.30600 0.31200 5.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 16.5000 0.000 0.000 0.000 0.000
32.870 1855.00000 20.4000 -44.53125 0.00000 1.47400 1.47400 13.10000 0.30600 0.31200 5.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 16.5000 0.000 0.000 0.000 0.000
32.880 1905.00000 20.4000 -44.53125 0.00000 1.47400 1.47400 12.50000 0.30300 0.31500 5.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 17.7000 0.000 0.000 0.000 0.000
32.890 1905.00000 20.4000 -44.53125 0.00000 1.47400 1.47400 12.50000 0.30300 0.31500 5.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 17.7000 0.000 0.000 0.000 0.000
32.900 1905.00000 20.4000 -44.53125 0.00000 1.47400 1.47400 12.50000 0.30300 0.31500 5.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 17.7000 0.000 0.000 0.000 0.000
32.910 1905.00000 20.4000 -44.53125 0.00000 1.47400 1.47400 12.50000 0.30300 0.31500 5.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 17.7000 0.000 0.000 0.000 0.000
32.920 1905.00000 20.4000 -44.53125 0.00000 1.47400 1.47400 12.50000 0.30300 0.31500 5.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 17.7000 0.000 0.000 0.000 0.000
32.930 1874.00000 21.3000 -44.53125 0.00000 1.55600 1.55600 13.20000 0.30300 0.31500 5.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.0000 0.000 0.000 0.000 0.000
32.940 1874.00000 21.3000 -44.53125 0.00000 1.55600 1.55600 13.20000 0.30300 0.31500 5.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.0000 0.000 0.000 0.000 0.000
32.950 1874.00000 21.3000 -44.53125 0.00000 1.55600 1.55600 13.20000 0.30300 0.31500 5.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.0000 0.000 0.000 0.000 0.000
32.960 1874.00000 21.3000 -44.53125 0.00000 1.55600 1.55600 13.20000 0.30300 0.31500 5.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.0000 0.000 0.000 0.000 0.000
32.970 1874.00000 21.3000 -44.53125 0.00000 1.55600 1.55600 13.20000 0.30300 0.31500 5.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.0000 0.000 0.000 0.000 0.000
32.980 1787.00000 21.0000 -44.53125 0.00000 1.55600 1.55600 13.40000 0.30300 0.31500 5.70000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 17.8000 0.000 0.000 0.000 0.000
32.990 1787.00000 21.0000 -44.53125 0.00000 1.55600 1.55600 13.40000 0.30300 0.31500 5.70000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 17.8000 0.000 0.000 0.000 0.000
33.000 1787.00000 21.0000 -44.53125 0.00000 1.55600 1.55600 13.40000 0.30300 0.31500 5.70000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 17.8000 0.000 0.000 0.000 0.000
33.010 1787.00000 21.0000 -44.53125 0.00000 1.55600 1.55600 13.40000 0.30300 0.31500 5.70000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 17.8000 0.000 0.000 0.000 0.000
33.020 1787.00000 21.0000 -44.53125 0.00000 1.55600 1.55600 13.40000 0.30300 0.31500 5.70000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 17.8000 0.000 0.000 0.000 0.000
33.030 1798.00000 20.4000 -44.53125 0.00000 1.50400 1.50400 12.80000 0.30300 0.31500 5.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 17.4000 0.000 0.000 0.000 0.000
33.040 1798.00000 20.4000 -44.53125 0.00000 1.50400 1.50400 12.80000 0.30300 0.31500 5.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 17.4000 0.000 0.000 0.000 0.000
33.050 1798.00000 20.4000 -44.53125 0.00000 1.50400 1.50400 12.80000 0.30300 0.31500 5.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 17.4000 0.000 0.000 0.000 0.000
33.060 1798.00000 20.4000 -44.53125 0.00000 1.50400 1.50400 12.80000 0.30300 0.31500 5.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 17.4000 0.000 0.000 0.000 0.000
33.070 1798.00000 20.4000 -44.53125 0.00000 1.50400 1.50400 12.80000 0.30300 0.31500 5.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 17.4000 0.000 0.000 0.000 0.000
33.080 1833.00000 21.2000 -44.53125 0.00000 1.50900 1.50900 13.00000 0.32200 0.32200 5.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 17.5000 0.000 0.000 0.000 0.000
33.090 1833.00000 21.2000 -44.53125 0.00000 1.50900 1.50900 13.00000 0.32200 0.32200 5.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 17.5000 0.000 0.000 0.000 0.000
33.100 1833.00000 21.2000 -44.53125 0.00000 1.50900 1.50900 13.00000 0.32200 0.32200 5.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 17.5000 0.000 0.000 0.000 0.000
33.110 1833.00000 21.2000 -44.53125 0.00000 1.50900 1.50900 13.00000 0.32200 0.32200 5.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 17.5000 0.000 0.000 0.000 0.000
33.120 1833.00000 21.2000 -44.53125 0.00000 1.50900 1.50900 13.00000 0.32200 0.32200 5.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 17.5000 0.000 0.000 0.000 0.000
33.130 1840.00000 22.7000 -44.53125 0.00000 1.64900 1.64900 13.40000 0.32200 0.32200 6.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 17.5000 0.000 0.000 0.000 0.000
33.140 1840.00000 22.7000 -44.53125 0.00000 1.64900 1.64900 13.40000 0.32200 0.32200 6.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 17.5000 0.000 0.000 0.000 0.000
33.150 1840.00000 22.7000 -44.53125 0.00000 1.64900 1.64900 13.40000 0.32200 0.32200 6.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 17.5000 0.000 0.000 0.000 0.000
33.160 1840.00000 22.7000 -44.53125 0.00000 1.64900 1.64900 13.40000 0.32200 0.32200 6.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 17.5000 0.000 0.000 0.000 0.000
33.170 1840.00000 22.7000 -44.53125 0.00000 1.64900 1.64900 13.40000 0.32200 0.32200 6.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 17.5000 0.000 0.000 0.000 0.000
33.180 1767.00000 22.9000 -44.53125 0.00000 1.71900 1.71900 13.30000 0.32200 0.32200 6.30000 1.00000 3.00000 3.00000 4.00000 3.00000 0.00000 0.00000 16.3000 0.000 0.000 0.000 0.000
33.190 1767.00000 22.9000 -44.53125 0.00000 1.71900 1.71900 13.30000 0.32200 0.32200 6.30000 1.00000 3.00000 3.00000 4.00000 3.00000 0.00000 0.00000 16.3000 0.000 0.000 0.000 0.000
33.200 1767.00000 22.9000 -44.53125 0.00000 1.71900 1.71900 13.30000 0.32200 0.32200 6.30000 1.00000 3.00000 3.00000 4.00000 3.00000 0.00000 0.00000 16.3000 0.000 0.000 0.000 0.000
33.210 1767.00000 22.9000 -44.53125 0.00000 1.71900 1.71900 13.30000 0.32200 0.32200 6.30000 1.00000 3.00000 3.00000 4.00000 3.00000 0.00000 0.00000 16.3000 0.000 0.000 0.000 0.000
33.220 1767.00000 22.9000 -44.53125 0.00000 1.71900 1.71900 13.30000 0.32200 0.32200 6.30000 1.00000 3.00000 3.00000 4.00000 3.00000 0.00000 0.00000 16.3000 0.000 0.000 0.000 0.000
33.230 1825.00000 23.5000 -44.53125 0.00000 1.76600 1.76600 13.10000 0.32200 0.32200 6.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 16.1000 0.000 0.000 0.000 0.000
33.240 1825.00000 23.5000 -44.53125 0.00000 1.76600 1.76600 13.10000 0.32200 0.32200 6.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 16.1000 0.000 0.000 0.000 0.000
33.250 1825.00000 23.5000 -44.53125 0.00000 1.76600 1.76600 13.10000 0.32200 0.32200 6.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 16.1000 0.000 0.000 0.000 0.000
33.260 1825.00000 23.5000 -44.53125 0.00000 1.76600 1.76600 13.10000 0.32200 0.32200 6.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 16.1000 0.000 0.000 0.000 0.000
33.270 1825.00000 23.5000 -44.53125 0.00000 1.76600 1.76600 13.10000 0.32200 0.32200 6.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 16.1000 0.000 0.000 0.000 0.000
33.280 1877.00000 27.5000 -44.53125 0.00000 2.10400 2.10400 13.10000 0.96300 0.31900 8.30000 1.00000 4.00000 4.00000 5.00000 4.00000 0.00000 0.00000 16.3000 0.000 0.000 0.000 0.000
33.290 1877.00000 27.5000 -44.53125 0.00000 2.10400 2.10400 13.10000 0.96300 0.31900 8.30000 1.00000 4.00000 4.00000 5.00000 4.00000 0.00000 0.00000 16.3000 0.000 0.000 0.000 0.000
33.300 1877.00000 27.5000 -44.53125 0.00000 2.10400 2.10400 13.10000 0.96300 0.31900 8.30000 1.00000 4.00000 4.00000 5.00000 4.00000 0.00000 0.00000 16.3000 0.000 0.000 0.000 0.000
33.310 1877.00000 27.5000 -44.53125 0.00000 2.10400 2.10400 13.10000 0.96300 0.31900 8.30000 1.00000 4.00000 4.00000 5.00000 4.00000 0.00000 0.00000 16.3000 0.000 0.000 0.000 0.000
33.320 1877.00000 27.5000 -44.53125 0.00000 2.10400 2.10400 13.10000 0.96300 0.31900 8.30000 1.00000 4.00000 4.00000 5.00000 4.00000 0.00000 0.00000 16.3000 0.000 0.000 0.000 0.000
33.330 1877.00000 28.8000 -44.53125 0.00000 2.29100 2.29100 12.60000 0.96300 0.31900 9.30000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
33.340 1877.00000 28.8000 -44.53125 0.00000 2.29100 2.29100 12.60000 0.96300 0.31900 9.30000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
33.350 1877.00000 28.8000 -44.53125 0.00000 2.29100 2.29100 12.60000 0.96300 0.31900 9.30000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
33.360 1877.00000 28.8000 -44.53125 0.00000 2.29100 2.29100 12.60000 0.96300 0.31900 9.30000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
33.370 1877.00000 28.8000 -44.53125 0.00000 2.29100 2.29100 12.60000 0.96300 0.31900 9.30000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
33.380 1860.00000 29.1000 -44.53125 0.00000 2.24400 2.24400 12.90000 0.96300 0.31900 10.10000 1.00000 5.00000 6.00000 2.00000 6.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
33.390 1860.00000 29.1000 -44.53125 0.00000 2.24400 2.24400 12.90000 0.96300 0.31900 10.10000 1.00000 5.00000 6.00000 2.00000 6.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
33.400 1860.00000 29.1000 -44.53125 0.00000 2.24400 2.24400 12.90000 0.96300 0.31900 10.10000 1.00000 5.00000 6.00000 2.00000 6.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
33.410 1860.00000 29.1000 -44.53125 0.00000 2.24400 2.24400 12.90000 0.96300 0.31900 10.10000 1.00000 5.00000 6.00000 2.00000 6.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
33.420 1860.00000 29.1000 -44.53125 0.00000 2.24400 2.24400 12.90000 0.96300 0.31900 10.10000 1.00000 5.00000 6.00000 2.00000 6.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
33.430 1784.00000 29.6000 -44.53125 0.00000 2.20300 2.20300 13.20000 0.96300 0.31900 10.80000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
33.440 1784.00000 29.6000 -44.53125 0.00000 2.20300 2.20300 13.20000 0.96300 0.31900 10.80000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
33.450 1784.00000 29.6000 -44.53125 0.00000 2.20300 2.20300 13.20000 0.96300 0.31900 10.80000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
33.460 1784.00000 29.6000 -44.53125 0.00000 2.20300 2.20300 13.20000 0.96300 0.31900 10.80000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
33.470 1784.00000 29.6000 -44.53125 0.00000 2.20300 2.20300 13.20000 0.96300 0.31900 10.80000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
33.480 1876.00000 30.1000 -44.53125 0.00000 2.21500 2.21500 13.50000 0.96000 0.34100 11.60000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
33.490 1876.00000 30.1000 -44.53125 0.00000 2.21500 2.21500 13.50000 0.96000 0.34100 11.60000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
33.500 1876.00000 30.1000 -44.53125 0.00000 2.21500 2.21500 13.50000 0.96000 0.34100 11.60000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
33.510 1876.00000 30.1000 -44.53125 0.00000 2.21500 2.21500 13.50000 0.96000 0.34100 11.60000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
33.520 1876.00000 30.1000 -44.53125 0.00000 2.21500 2.21500 13.50000 0.96000 0.34100 11.60000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
33.530 1930.00000 31.0000 -44.53125 0.00000 2.28500 2.28500 13.30000 0.96000 0.34100 11.30000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
33.540 1930.00000 31.0000 -44.53125 0.00000 2.28500 2.28500 13.30000 0.96000 0.34100 11.30000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
33.550 1930.00000 31.0000 -44.53125 0.00000 2.28500 2.28500 13.30000 0.96000 0.34100 11.30000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
33.560 1930.00000 31.0000 -44.53125 0.00000 2.28500 2.28500 13.30000 0.96000 0.34100 11.30000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
33.570 1930.00000 31.0000 -44.53125 0.00000 2.28500 2.28500 13.30000 0.96000 0.34100 11.30000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
33.580 1889.00000 31.0000 -44.53125 0.00000 2.22100 2.22100 13.00000 0.96000 0.34100 12.50000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
33.590 1889.00000 31.0000 -44.53125 0.00000 2.22100 2.22100 13.00000 0.96000 0.34100 12.50000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
33.600 1889.00000 31.0000 -44.53125 0.00000 2.22100 2.22100 13.00000 0.96000 0.34100 12.50000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
33.610 1889.00000 31.0000 -44.53125 0.00000 2.22100 2.22100 13.00000 0.96000 0.34100 12.50000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
33.620 1889.00000 31.0000 -44.53125 0.00000 2.22100 2.22100 13.00000 0.96000 0.34100 12.50000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
33.630 1854.00000 32.7000 -44.53125 0.00000 2.31400 2.31400 13.00000 0.96000 0.34100 12.70000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
33.640 1854.00000 32.7000 -44.53125 0.00000 2.31400 2.31400 13.00000 0.96000 0.34100 12.70000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
33.650 1854.00000 32.7000 -44.53125 0.00000 2.31400 2.31400 13.00000 0.96000 0.34100 12.70000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
33.660 1854.00000 32.7000 -44.53125 0.00000 2.31400 2.31400 13.00000 0.96000 0.34100 12.70000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
33.670 1854.00000 32.7000 -44.53125 0.00000 2.31400 2.31400 13.00000 0.96000 0.34100 12.70000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
33.680 1884.00000 34.5000 -44.53125 0.00000 2.35500 2.35500 13.60000 0.44000 0.36300 12.20000 1.00000 7.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
33.690 1884.00000 34.5000 -44.53125 0.00000 2.35500 2.35500 13.60000 0.44000 0.36300 12.20000 1.00000 7.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
33.700 1884.00000 34.5000 -44.53125 0.00000 2.35500 2.35500 13.60000 0.44000 0.36300 12.20000 1.00000 7.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
33.710 1884.00000 34.5000 -44.53125 0.00000 2.35500 2.35500 13.60000 0.44000 0.36300 12.20000 1.00000 7.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
33.720 1884.00000 34.5000 -44.53125 0.00000 2.35500 2.35500 13.60000 0.44000 0.36300 12.20000 1.00000 7.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
33.730 1963.00000 37.4000 -44.53125 0.00000 2.48300 2.48300 12.90000 0.44000 0.36300 13.70000 1.00000 2.00000 2.00000 7.00000 7.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
33.740 1963.00000 37.4000 -44.53125 0.00000 2.48300 2.48300 12.90000 0.44000 0.36300 13.70000 1.00000 2.00000 2.00000 7.00000 7.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
33.750 1963.00000 37.4000 -44.53125 0.00000 2.48300 2.48300 12.90000 0.44000 0.36300 13.70000 1.00000 2.00000 2.00000 7.00000 7.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
33.760 1963.00000 37.4000 -44.53125 0.00000 2.48300 2.48300 12.90000 0.44000 0.36300 13.70000 1.00000 2.00000 2.00000 7.00000 7.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
33.770 1963.00000 37.4000 -44.53125 0.00000 2.48300 2.48300 12.90000 0.44000 0.36300 13.70000 1.00000 2.00000 2.00000 7.00000 7.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
33.780 1911.00000 38.5000 -44.53125 0.00000 2.47100 2.47100 13.70000 0.44000 0.36300 13.40000 1.00000 8.00000 2.00000 7.00000 7.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
33.790 1911.00000 38.5000 -44.53125 0.00000 2.47100 2.47100 13.70000 0.44000 0.36300 13.40000 1.00000 8.00000 2.00000 7.00000 7.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
33.800 1911.00000 38.5000 -44.53125 0.00000 2.47100 2.47100 13.70000 0.44000 0.36300 13.40000 1.00000 8.00000 2.00000 7.00000 7.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
33.810 1911.00000 38.5000 -44.53125 0.00000 2.47100 2.47100 13.70000 0.44000 0.36300 13.40000 1.00000 8.00000 2.00000 7.00000 7.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
33.820 1911.00000 38.5000 -44.53125 0.00000 2.47100 2.47100 13.70000 0.44000 0.36300 13.40000 1.00000 8.00000 2.00000 7.00000 7.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
33.830 1947.00000 39.5000 -44.53125 0.00000 2.39600 2.39600 13.50000 0.44000 0.36300 14.50000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
33.840 1947.00000 39.5000 -44.53125 0.00000 2.39600 2.39600 13.50000 0.44000 0.36300 14.50000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
33.850 1947.00000 39.5000 -44.53125 0.00000 2.39600 2.39600 13.50000 0.44000 0.36300 14.50000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
33.860 1947.00000 39.5000 -44.53125 0.00000 2.39600 2.39600 13.50000 0.44000 0.36300 14.50000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
33.870 1947.00000 39.5000 -44.53125 0.00000 2.39600 2.39600 13.50000 0.44000 0.36300 14.50000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
33.880 1956.00000 39.8000 -44.53125 0.00000 2.50600 2.50600 12.10000 0.52300 0.33500 13.80000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
33.890 1956.00000 39.8000 -44.53125 0.00000 2.50600 2.50600 12.10000 0.52300 0.33500 13.80000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
33.900 1956.00000 39.8000 -44.53125 0.00000 2.50600 2.50600 12.10000 0.52300 0.33500 13.80000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
33.910 1956.00000 39.8000 -44.53125 0.00000 2.50600 2.50600 12.10000 0.52300 0.33500 13.80000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
33.920 1956.00000 39.8000 -44.53125 0.00000 2.50600 2.50600 12.10000 0.52300 0.33500 13.80000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
33.930 1972.00000 40.3000 -44.53125 0.00000 2.39000 2.39000 13.30000 0.52300 0.33500 14.70000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
33.940 1972.00000 40.3000 -44.53125 0.00000 2.39000 2.39000 13.30000 0.52300 0.33500 14.70000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
33.950 1972.00000 40.3000 -44.53125 0.00000 2.39000 2.39000 13.30000 0.52300 0.33500 14.70000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
33.960 1972.00000 40.3000 -44.53125 0.00000 2.39000 2.39000 13.30000 0.52300 0.33500 14.70000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
33.970 1972.00000 40.3000 -44.53125 0.00000 2.39000 2.39000 13.30000 0.52300 0.33500 14.70000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
33.980 1975.00000 40.9000 -44.53125 0.00000 2.48900 2.48900 12.40000 0.52300 0.33500 14.00000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
33.990 1975.00000 40.9000 -44.53125 0.00000 2.48900 2.48900 12.40000 0.52300 0.33500 14.00000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
34.000 1975.00000 40.9000 -44.53125 0.00000 2.48900 2.48900 12.40000 0.52300 0.33500 14.00000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
34.010 1975.00000 40.9000 -44.53125 0.00000 2.48900 2.48900 12.40000 0.52300 0.33500 14.00000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
34.020 1975.00000 40.9000 -44.53125 0.00000 2.48900 2.48900 12.40000 0.52300 0.33500 14.00000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
34.030 1946.00000 42.3000 -44.53125 0.00000 2.47700 2.47700 13.50000 0.52300 0.33500 14.70000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
34.040 1946.00000 42.3000 -44.53125 0.00000 2.47700 2.47700 13.50000 0.52300 0.33500 14.70000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
34.050 1946.00000 42.3000 -44.53125 0.00000 2.47700 2.47700 13.50000 0.52300 0.33500 14.70000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
34.060 1946.00000 42.3000 -44.53125 0.00000 2.47700 2.47700 13.50000 0.52300 0.33500 14.70000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
34.070 1946.00000 42.3000 -44.53125 0.00000 2.47700 2.47700 13.50000 0.52300 0.33500 14.70000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
34.080 1987.00000 43.5000 -44.53125 0.00000 2.56500 2.56500 12.30000 0.99900 0.35400 14.20000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
34.090 1987.00000 43.5000 -44.53125 0.00000 2.56500 2.56500 12.30000 0.99900 0.35400 14.20000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
34.100 1987.00000 43.5000 -44.53125 0.00000 2.56500 2.56500 12.30000 0.99900 0.35400 14.20000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
34.110 1987.00000 43.5000 -44.53125 0.00000 2.56500 2.56500 12.30000 0.99900 0.35400 14.20000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
34.120 1987.00000 43.5000 -44.53125 0.00000 2.56500 2.56500 12.30000 0.99900 0.35400 14.20000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
34.130 1994.00000 44.0000 -44.53125 0.00000 2.48900 2.48900 13.40000 0.99900 0.35400 15.00000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
34.140 1994.00000 44.0000 -44.53125 0.00000 2.48900 2.48900 13.40000 0.99900 0.35400 15.00000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
34.150 1994.00000 44.0000 -44.53125 0.00000 2.48900 2.48900 13.40000 0.99900 0.35400 15.00000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
34.160 1994.00000 44.0000 -44.53125 0.00000 2.48900 2.48900 13.40000 0.99900 0.35400 15.00000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
34.170 1994.00000 44.0000 -44.53125 0.00000 2.48900 2.48900 13.40000 0.99900 0.35400 15.00000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
34.180 2031.00000 44.1000 -44.53125 0.00000 2.50000 2.50000 13.20000 0.99900 0.35400 13.90000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
34.190 2031.00000 44.1000 -44.53125 0.00000 2.50000 2.50000 13.20000 0.99900 0.35400 13.90000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
34.200 2031.00000 44.1000 -44.53125 0.00000 2.50000 2.50000 13.20000 0.99900 0.35400 13.90000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
34.210 2031.00000 44.1000 -44.53125 0.00000 2.50000 2.50000 13.20000 0.99900 0.35400 13.90000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
34.220 2031.00000 44.1000 -44.53125 0.00000 2.50000 2.50000 13.20000 0.99900 0.35400 13.90000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
34.230 2007.00000 44.3000 -44.53125 0.00000 2.57000 2.57000 13.40000 0.99900 0.35400 14.70000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
34.240 2007.00000 44.3000 -44.53125 0.00000 2.57000 2.57000 13.40000 0.99900 0.35400 14.70000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
34.250 2007.00000 44.3000 -44.53125 0.00000 2.57000 2.57000 13.40000 0.99900 0.35400 14.70000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
34.260 2007.00000 44.3000 -44.53125 0.00000 2.57000 2.57000 13.40000 0.99900 0.35400 14.70000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
34.270 2007.00000 44.3000 -44.53125 0.00000 2.57000 2.57000 13.40000 0.99900 0.35400 14.70000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
34.280 2023.00000 45.2000 -44.53125 0.00000 2.43600 2.43600 13.20000 1.05900 0.40800 14.30000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 14.4000 0.000 0.000 0.000 0.000
34.290 2023.00000 45.2000 -44.53125 0.00000 2.43600 2.43600 13.20000 1.05900 0.40800 14.30000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 14.4000 0.000 0.000 0.000 0.000
34.300 2023.00000 45.2000 -44.53125 0.00000 2.43600 2.43600 13.20000 1.05900 0.40800 14.30000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 14.4000 0.000 0.000 0.000 0.000
34.310 2023.00000 45.2000 -44.53125 0.00000 2.43600 2.43600 13.20000 1.05900 0.40800 14.30000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 14.4000 0.000 0.000 0.000 0.000
34.320 2023.00000 45.2000 -44.53125 0.00000 2.43600 2.43600 13.20000 1.05900 0.40800 14.30000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 14.4000 0.000 0.000 0.000 0.000
34.330 2105.00000 46.9000 -44.53125 0.00000 2.64600 2.64600 12.20000 1.05900 0.40800 14.40000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 14.5000 0.000 0.000 0.000 0.000
34.340 2105.00000 46.9000 -44.53125 0.00000 2.64600 2.64600 12.20000 1.05900 0.40800 14.40000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 14.5000 0.000 0.000 0.000 0.000
34.350 2105.00000 46.9000 -44.53125 0.00000 2.64600 2.64600 12.20000 1.05900 0.40800 14.40000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 14.5000 0.000 0.000 0.000 0.000
34.360 2105.00000 46.9000 -44.53125 0.00000 2.64600 2.64600 12.20000 1.05900 0.40800 14.40000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 14.5000 0.000 0.000 0.000 0.000
34.370 2105.00000 46.9000 -44.53125 0.00000 2.64600 2.64600 12.20000 1.05900 0.40800 14.40000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 14.5000 0.000 0.000 0.000 0.000
34.380 2054.00000 48.1000 -44.53125 0.00000 2.55900 2.55900 13.20000 1.05900 0.40800 15.20000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 14.4000 0.000 0.000 0.000 0.000
34.390 2054.00000 48.1000 -44.53125 0.00000 2.55900 2.55900 13.20000 1.05900 0.40800 15.20000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 14.4000 0.000 0.000 0.000 0.000
34.400 2054.00000 48.1000 -44.53125 0.00000 2.55900 2.55900 13.20000 1.05900 0.40800 15.20000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 14.4000 0.000 0.000 0.000 0.000
34.410 2054.00000 48.1000 -44.53125 0.00000 2.55900 2.55900 13.20000 1.05900 0.40800 15.20000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 14.4000 0.000 0.000 0.000 0.000
34.420 2054.00000 48.1000 -44.53125 0.00000 2.55900 2.55900 13.20000 1.05900 0.40800 15.20000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 14.4000 0.000 0.000 0.000 0.000
34.430 2060.00000 48.2000 -44.53125 0.00000 2.46600 2.46600 12.90000 1.05900 0.40800 14.60000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 14.0000 0.000 0.000 0.000 0.000
34.440 2060.00000 48.2000 -44.53125 0.00000 2.46600 2.46600 12.90000 1.05900 0.40800 14.60000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 14.0000 0.000 0.000 0.000 0.000
34.450 2060.00000 48.2000 -44.53125 0.00000 2.46600 2.46600 12.90000 1.05900 0.40800 14.60000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 14.0000 0.000 0.000 0.000 0.000
34.460 2060.00000 48.2000 -44.53125 0.00000 2.46600 2.46600 12.90000 1.05900 0.40800 14.60000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 14.0000 0.000 0.000 0.000 0.000
34.470 2060.00000 48.2000 -44.53125 0.00000 2.46600 2.46600 12.90000 1.05900 0.40800 14.60000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 14.0000 0.000 0.000 0.000 0.000
34.480 2136.00000 48.4000 -44.53125 0.00000 2.67500 2.67500 13.40000 1.05600 0.93800 14.50000 1.00000 8.00000 9.00000 8.00000 9.00000 0.00000 0.00000 14.1000 0.000 0.000 0.000 0.000
34.490 2136.00000 48.4000 -44.53125 0.00000 2.67500 2.67500 13.40000 1.05600 0.93800 14.50000 1.00000 8.00000 9.00000 8.00000 9.00000 0.00000 0.00000 14.1000 0.000 0.000 0.000 0.000
34.500 2136.00000 48.4000 -44.53125 0.00000 2.67500 2.67500 13.40000 1.05600 0.93800 14.50000 1.00000 8.00000 9.00000 8.00000 9.00000 0.00000 0.00000 14.1000 0.000 0.000 0.000 0.000
34.510 2136.00000 48.4000 -44.53125 0.00000 2.67500 2.67500 13.40000 1.05600 0.93800 14.50000 1.00000 8.00000 9.00000 8.00000 9.00000 0.00000 0.00000 14.1000 0.000 0.000 0.000 0.000
34.520 2136.00000 48.4000 -44.53125 0.00000 2.67500 2.67500 13.40000 1.05600 0.93800 14.50000 1.00000 8.00000 9.00000 8.00000 9.00000 0.00000 0.00000 14.1000 0.000 0.000 0.000 0.000
34.530 2124.00000 49.9000 -44.53125 0.00000 2.65800 2.65800 12.90000 1.05600 0.93800 14.90000 1.00000 9.00000 8.00000 9.00000 8.00000 0.00000 0.00000 14.0000 0.000 0.000 0.000 0.000
34.540 2124.00000 49.9000 -44.53125 0.00000 2.65800 2.65800 12.90000 1.05600 0.93800 14.90000 1.00000 9.00000 8.00000 9.00000 8.00000 0.00000 0.00000 14.0000 0.000 0.000 0.000 0.000
34.550 2124.00000 49.9000 -44.53125 0.00000 2.65800 2.65800 12.90000 1.05600 0.93800 14.90000 1.00000 9.00000 8.00000 9.00000 8.00000 0.00000 0.00000 14.0000 0.000 0.000 0.000 0.000
34.560 2124.00000 49.9000 -44.53125 0.00000 2.65800 2.65800 12.90000 1.05600 0.93800 14.90000 1.00000 9.00000 8.00000 9.00000 8.00000 0.00000 0.00000 14.0000 0.000 0.000 0.000 0.000
34.570 2124.00000 49.9000 -44.53125 0.00000 2.65800 2.65800 12.90000 1.05600 0.93800 14.90000 1.00000 9.00000 8.00000 9.00000 8.00000 0.00000 0.00000 14.0000 0.000 0.000 0.000 0.000
34.580 2119.00000 49.9000 -44.53125 0.00000 2.68100 2.68100 13.10000 1.05600 0.93800 15.20000 1.00000 8.00000 8.00000 9.00000 9.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
34.590 2119.00000 49.9000 -44.53125 0.00000 2.68100 2.68100 13.10000 1.05600 0.93800 15.20000 1.00000 8.00000 8.00000 9.00000 9.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
34.600 2119.00000 49.9000 -44.53125 0.00000 2.68100 2.68100 13.10000 1.05600 0.93800 15.20000 1.00000 8.00000 8.00000 9.00000 9.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
34.610 2119.00000 49.9000 -44.53125 0.00000 2.68100 2.68100 13.10000 1.05600 0.93800 15.20000 1.00000 8.00000 8.00000 9.00000 9.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
34.620 2119.00000 49.9000 -44.53125 0.00000 2.68100 2.68100 13.10000 1.05600 0.93800 15.20000 1.00000 8.00000 8.00000 9.00000 9.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
34.630 2111.00000 50.1000 -44.53125 0.00000 2.47100 2.47100 13.30000 1.05600 0.93800 15.10000 1.00000 9.00000 9.00000 8.00000 9.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
34.640 2111.00000 50.1000 -44.53125 0.00000 2.47100 2.47100 13.30000 1.05600 0.93800 15.10000 1.00000 9.00000 9.00000 8.00000 9.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
34.650 2111.00000 50.1000 -44.53125 0.00000 2.47100 2.47100 13.30000 1.05600 0.93800 15.10000 1.00000 9.00000 9.00000 8.00000 9.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
34.660 2111.00000 50.1000 -44.53125 0.00000 2.47100 2.47100 13.30000 1.05600 0.93800 15.10000 1.00000 9.00000 9.00000 8.00000 9.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
34.670 2111.00000 50.1000 -44.53125 0.00000 2.47100 2.47100 13.30000 1.05600 0.93800 15.10000 1.00000 9.00000 9.00000 8.00000 9.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
34.680 2177.00000 51.0000 -44.53125 0.00000 2.64600 2.64600 13.20000 1.05300 0.98900 14.30000 1.00000 9.00000 9.00000 9.00000 9.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
34.690 2177.00000 51.0000 -44.53125 0.00000 2.64600 2.64600 13.20000 1.05300 0.98900 14.30000 1.00000 9.00000 9.00000 9.00000 9.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
34.700 2177.00000 51.0000 -44.53125 0.00000 2.64600 2.64600 13.20000 1.05300 0.98900 14.30000 1.00000 9.00000 9.00000 9.00000 9.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
34.710 2177.00000 51.0000 -44.53125 0.00000 2.64600 2.64600 13.20000 1.05300 0.98900 14.30000 1.00000 9.00000 9.00000 9.00000 9.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
34.720 2177.00000 51.0000 -44.53125 0.00000 2.64600 2.64600 13.20000 1.05300 0.98900 14.30000 1.00000 9.00000 9.00000 9.00000 9.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
34.730 2164.00000 52.7000 -44.53125 0.00000 2.71600 2.71600 13.30000 1.05300 0.98900 14.70000 1.00000 9.00000 9.00000 9.00000 9.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
34.740 2164.00000 52.7000 -44.53125 0.00000 2.71600 2.71600 13.30000 1.05300 0.98900 14.70000 1.00000 9.00000 9.00000 9.00000 9.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
34.750 2164.00000 52.7000 -44.53125 0.00000 2.71600 2.71600 13.30000 1.05300 0.98900 14.70000 1.00000 9.00000 9.00000 9.00000 9.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
34.760 2164.00000 52.7000 -44.53125 0.00000 2.71600 2.71600 13.30000 1.05300 0.98900 14.70000 1.00000 9.00000 9.00000 9.00000 9.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
34.770 2164.00000 52.7000 -44.53125 0.00000 2.71600 2.71600 13.30000 1.05300 0.98900 14.70000 1.00000 9.00000 9.00000 9.00000 9.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
34.780 2170.00000 53.4000 -43.75000 0.00000 2.84400 2.84400 12.50000 1.05300 0.98900 15.40000 1.00000 9.00000 9.00000 9.00000 9.00000 0.00000 0.00000 14.1000 0.000 0.000 0.000 0.000
34.790 2170.00000 53.4000 -43.75000 0.00000 2.84400 2.84400 12.50000 1.05300 0.98900 15.40000 1.00000 9.00000 9.00000 9.00000 9.00000 0.00000 0.00000 14.1000 0.000 0.000 0.000 0.000
34.800 2170.00000 53.4000 -43.75000 0.00000 2.84400 2.84400 12.50000 1.05300 0.98900 15.40000 1.00000 9.00000 9.00000 9.00000 9.00000 0.00000 0.00000 14.1000 0.000 0.000 0.000 0.000
34.810 2170.00000 53.4000 -43.75000 0.00000 2.84400 2.84400 12.50000 1.05300 0.98900 15.40000 1.00000 9.00000 9.00000 9.00000 9.00000 0.00000 0.00000 14.1000 0.000 0.000 0.000 0.000
34.820 2170.00000 53.4000 -43.75000 0.00000 2.84400 2.84400 12.50000 1.05300 0.98900 15.40000 1.00000 9.00000 9.00000 9.00000 9.00000 0.00000 0.00000 14.1000 0.000 0.000 0.000 0.000
34.830 2170.00000 53.4000 -43.75000 0.00000 2.84400 2.84400 12.50000 1.05300 0.98900 15.40000 1.00000 9.00000 9.00000 9.00000 9.00000 0.00000 0.00000 14.1000 0.000 0.000 0.000 0.000
34.840 2219.00000 53.6000 -41.40625 -0.12500 2.65800 2.65800 13.40000 1.05300 0.98900 16.00000 1.00000 10.00000 10.00000 9.00000 9.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
34.850 2219.00000 53.6000 -41.40625 -0.12500 2.65800 2.65800 13.40000 1.05300 0.98900 16.00000 1.00000 10.00000 10.00000 9.00000 9.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
34.860 2219.00000 53.6000 -41.40625 -0.12500 2.65800 2.65800 13.40000 1.05300 0.98900 16.00000 1.00000 10.00000 10.00000 9.00000 9.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
34.870 2219.00000 53.6000 -41.40625 -0.12500 2.65800 2.65800 13.40000 1.05300 0.98900 16.00000 1.00000 10.00000 10.00000 9.00000 9.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
34.880 2219.00000 53.6000 -41.40625 -0.12500 2.65800 2.65800 13.40000 1.05300 0.98900 16.00000 1.00000 10.00000 10.00000 9.00000 9.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
34.890 2222.00000 56.0000 -40.62500 -0.12500 2.68100 2.68100 13.30000 1.04000 1.00500 16.20000 1.00000 10.00000 10.00000 10.00000 10.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
34.900 2222.00000 56.0000 -40.62500 -0.12500 2.68100 2.68100 13.30000 1.04000 1.00500 16.20000 1.00000 10.00000 10.00000 10.00000 10.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
34.910 2222.00000 56.0000 -40.62500 -0.12500 2.68100 2.68100 13.30000 1.04000 1.00500 16.20000 1.00000 10.00000 10.00000 10.00000 10.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
34.920 2222.00000 56.0000 -40.62500 -0.12500 2.68100 2.68100 13.30000 1.04000 1.00500 16.20000 1.00000 10.00000 10.00000 10.00000 10.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
34.930 2222.00000 56.0000 -40.62500 -0.12500 2.68100 2.68100 13.30000 1.04000 1.00500 16.20000 1.00000 10.00000 10.00000 10.00000 10.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
34.940 2229.00000 57.4000 -39.06250 -0.12500 2.65800 2.65800 13.20000 1.04000 1.00500 16.60000 1.00000 11.00000 10.00000 10.00000 10.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
34.950 2229.00000 57.4000 -39.06250 -0.12500 2.65800 2.65800 13.20000 1.04000 1.00500 16.60000 1.00000 11.00000 10.00000 10.00000 10.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
34.960 2229.00000 57.4000 -39.06250 -0.12500 2.65800 2.65800 13.20000 1.04000 1.00500 16.60000 1.00000 11.00000 10.00000 10.00000 10.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
34.970 2229.00000 57.4000 -39.06250 -0.12500 2.65800 2.65800 13.20000 1.04000 1.00500 16.60000 1.00000 11.00000 10.00000 10.00000 10.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
34.980 2229.00000 57.4000 -39.06250 -0.12500 2.65800 2.65800 13.20000 1.04000 1.00500 16.60000 1.00000 11.00000 10.00000 10.00000 10.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
34.990 2264.00000 58.2000 -39.84375 -0.12500 2.67500 2.67500 13.30000 1.04000 1.00500 16.40000 1.00000 11.00000 11.00000 11.00000 11.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
35.000 2264.00000 58.2000 -39.84375 -0.12500 2.67500 2.67500 13.30000 1.04000 1.00500 16.40000 1.00000 11.00000 11.00000 11.00000 11.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
35.010 2264.00000 58.2000 -39.84375 -0.12500 2.67500 2.67500 13.30000 1.04000 1.00500 16.40000 1.00000 11.00000 11.00000 11.00000 11.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
35.020 2264.00000 58.2000 -39.84375 -0.12500 2.67500 2.67500 13.30000 1.04000 1.00500 16.40000 1.00000 11.00000 11.00000 11.00000 11.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
35.030 2264.00000 58.2000 -39.84375 -0.12500 2.67500 2.67500 13.30000 1.04000 1.00500 16.40000 1.00000 11.00000 11.00000 11.00000 11.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
35.040 2228.00000 58.9000 -39.84375 -0.12500 2.64000 2.64000 13.30000 1.04000 1.00500 16.40000 1.00000 11.00000 11.00000 11.00000 11.00000 0.00000 0.00000 13.6000 0.000 0.000 0.000 0.000
35.050 2228.00000 58.9000 -39.84375 -0.12500 2.64000 2.64000 13.30000 1.04000 1.00500 16.40000 1.00000 11.00000 11.00000 11.00000 11.00000 0.00000 0.00000 13.6000 0.000 0.000 0.000 0.000
35.060 2228.00000 58.9000 -39.84375 -0.12500 2.64000 2.64000 13.30000 1.04000 1.00500 16.40000 1.00000 11.00000 11.00000 11.00000 11.00000 0.00000 0.00000 13.6000 0.000 0.000 0.000 0.000
35.070 2228.00000 58.9000 -39.84375 -0.12500 2.64000 2.64000 13.30000 1.04000 1.00500 16.40000 1.00000 11.00000 11.00000 11.00000 11.00000 0.00000 0.00000 13.6000 0.000 0.000 0.000 0.000
35.080 2228.00000 58.9000 -39.84375 -0.12500 2.64000 2.64000 13.30000 1.04000 1.00500 16.40000 1.00000 11.00000 11.00000 11.00000 11.00000 0.00000 0.00000 13.6000 0.000 0.000 0.000 0.000
35.090 2266.00000 60.3000 -39.06250 -0.12500 2.79200 2.79200 13.30000 1.10400 1.01800 16.60000 1.00000 11.00000 11.00000 11.00000 11.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
35.100 2266.00000 60.3000 -39.06250 -0.12500 2.79200 2.79200 13.30000 1.10400 1.01800 16.60000 1.00000 11.00000 11.00000 11.00000 11.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
35.110 2266.00000 60.3000 -39.06250 -0.12500 2.79200 2.79200 13.30000 1.10400 1.01800 16.60000 1.00000 11.00000 11.00000 11.00000 11.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
35.120 2266.00000 60.3000 -39.06250 -0.12500 2.79200 2.79200 13.30000 1.10400 1.01800 16.60000 1.00000 11.00000 11.00000 11.00000 11.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
35.130 2266.00000 60.3000 -39.06250 -0.12500 2.79200 2.79200 13.30000 1.10400 1.01800 16.60000 1.00000 11.00000 11.00000 11.00000 11.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
35.140 2326.00000 60.0000 -39.06250 -0.12500 2.82100 2.82100 13.50000 1.10400 1.01800 16.50000 1.00000 11.00000 12.00000 11.00000 11.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
35.150 2326.00000 60.0000 -39.06250 -0.12500 2.82100 2.82100 13.50000 1.10400 1.01800 16.50000 1.00000 11.00000 12.00000 11.00000 11.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
35.160 2326.00000 60.0000 -39.06250 -0.12500 2.82100 2.82100 13.50000 1.10400 1.01800 16.50000 1.00000 11.00000 12.00000 11.00000 11.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
35.170 2326.00000 60.0000 -39.06250 -0.12500 2.82100 2.82100 13.50000 1.10400 1.01800 16.50000 1.00000 11.00000 12.00000 11.00000 11.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
35.180 2326.00000 60.0000 -39.06250 -0.12500 2.82100 2.82100 13.50000 1.10400 1.01800 16.50000 1.00000 11.00000 12.00000 11.00000 11.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
35.190 2283.00000 59.9000 -39.84375 -0.12500 2.88500 2.88500 13.00000 1.10400 1.01800 16.30000 1.00000 10.00000 11.00000 11.00000 11.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
35.200 2283.00000 59.9000 -39.84375 -0.12500 2.88500 2.88500 13.00000 1.10400 1.01800 16.30000 1.00000 10.00000 11.00000 11.00000 11.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
35.210 2283.00000 59.9000 -39.84375 -0.12500 2.88500 2.88500 13.00000 1.10400 1.01800 16.30000 1.00000 10.00000 11.00000 11.00000 11.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
35.220 2283.00000 59.9000 -39.84375 -0.12500 2.88500 2.88500 13.00000 1.10400 1.01800 16.30000 1.00000 10.00000 11.00000 11.00000 11.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
35.230 2283.00000 59.9000 -39.84375 -0.12500 2.88500 2.88500 13.00000 1.10400 1.01800 16.30000 1.00000 10.00000 11.00000 11.00000 11.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
35.240 2325.00000 60.3000 -43.75000 0.00000 3.04300 3.04300 12.80000 1.10400 1.01800 15.40000 1.00000 11.00000 11.00000 11.00000 11.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
35.250 2325.00000 60.3000 -43.75000 0.00000 3.04300 3.04300 12.80000 1.10400 1.01800 15.40000 1.00000 11.00000 11.00000 11.00000 11.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
35.260 2325.00000 60.3000 -43.75000 0.00000 3.04300 3.04300 12.80000 1.10400 1.01800 15.40000 1.00000 11.00000 11.00000 11.00000 11.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
35.270 2325.00000 60.3000 -43.75000 0.00000 3.04300 3.04300 12.80000 1.10400 1.01800 15.40000 1.00000 11.00000 11.00000 11.00000 11.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
35.280 2325.00000 60.3000 -43.75000 0.00000 3.04300 3.04300 12.80000 1.10400 1.01800 15.40000 1.00000 11.00000 11.00000 11.00000 11.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
35.290 2392.00000 60.5000 -42.96875 0.00000 3.08300 3.08300 13.70000 1.11000 1.07200 15.40000 1.00000 11.00000 11.00000 11.00000 12.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
35.300 2392.00000 60.5000 -42.96875 0.00000 3.08300 3.08300 13.70000 1.11000 1.07200 15.40000 1.00000 11.00000 11.00000 11.00000 12.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
35.310 2392.00000 60.5000 -42.96875 0.00000 3.08300 3.08300 13.70000 1.11000 1.07200 15.40000 1.00000 11.00000 11.00000 11.00000 12.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
35.320 2392.00000 60.5000 -42.96875 0.00000 3.08300 3.08300 13.70000 1.11000 1.07200 15.40000 1.00000 11.00000 11.00000 11.00000 12.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
35.330 2392.00000 60.5000 -42.96875 0.00000 3.08300 3.08300 13.70000 1.11000 1.07200 15.40000 1.00000 11.00000 11.00000 11.00000 12.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
35.340 2343.00000 60.0000 -42.96875 -0.12500 3.01400 3.01400 13.30000 1.11000 1.07200 15.60000 1.00000 11.00000 11.00000 11.00000 11.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
35.350 2343.00000 60.0000 -42.96875 -0.12500 3.01400 3.01400 13.30000 1.11000 1.07200 15.60000 1.00000 11.00000 11.00000 11.00000 11.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
35.360 2343.00000 60.0000 -42.96875 -0.12500 3.01400 3.01400 13.30000 1.11000 1.07200 15.60000 1.00000 11.00000 11.00000 11.00000 11.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
35.370 2343.00000 60.0000 -42.96875 -0.12500 3.01400 3.01400 13.30000 1.11000 1.07200 15.60000 1.00000 11.00000 11.00000 11.00000 11.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
35.380 2343.00000 60.0000 -42.96875 -0.12500 3.01400 3.01400 13.30000 1.11000 1.07200 15.60000 1.00000 11.00000 11.00000 11.00000 11.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
35.390 2366.00000 60.6000 -42.18750 -0.12500 2.95500 2.95500 13.20000 1.11000 1.07200 15.80000 1.00000 11.00000 11.00000 11.00000 11.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
35.400 2366.00000 60.6000 -42.18750 -0.12500 2.95500 2.95500 13.20000 1.11000 1.07200 15.80000 1.00000 11.00000 11.00000 11.00000 11.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
35.410 2366.00000 60.6000 -42.18750 -0.12500 2.95500 2.95500 13.20000 1.11000 1.07200 15.80000 1.00000 11.00000 11.00000 11.00000 11.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
35.420 2366.00000 60.6000 -42.18750 -0.12500 2.95500 2.95500 13.20000 1.11000 1.07200 15.80000 1.00000 11.00000 11.00000 11.00000 11.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
35.430 2366.00000 60.6000 -42.18750 -0.12500 2.95500 2.95500 13.20000 1.11000 1.07200 15.80000 1.00000 11.00000 11.00000 11.00000 11.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
35.440 2447.00000 61.2000 -38.28125 -0.25000 2.94400 2.94400 13.10000 1.11000 1.07200 16.80000 1.00000 11.00000 12.00000 11.00000 11.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
35.450 2447.00000 61.2000 -38.28125 -0.25000 2.94400 2.94400 13.10000 1.11000 1.07200 16.80000 1.00000 11.00000 12.00000 11.00000 11.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
35.460 2447.00000 61.2000 -38.28125 -0.25000 2.94400 2.94400 13.10000 1.11000 1.07200 16.80000 1.00000 11.00000 12.00000 11.00000 11.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
35.470 2447.00000 61.2000 -38.28125 -0.25000 2.94400 2.94400 13.10000 1.11000 1.07200 16.80000 1.00000 11.00000 12.00000 11.00000 11.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
35.480 2447.00000 61.2000 -38.28125 -0.25000 2.94400 2.94400 13.10000 1.11000 1.07200 16.80000 1.00000 11.00000 12.00000 11.00000 11.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
35.490 2397.00000 61.4000 -42.96875 -0.12500 3.14200 3.14200 12.40000 1.11300 1.09100 15.60000 1.00000 11.00000 11.00000 11.00000 11.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
35.500 2397.00000 61.4000 -42.96875 -0.12500 3.14200 3.14200 12.40000 1.11300 1.09100 15.60000 1.00000 11.00000 11.00000 11.00000 11.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
35.510 2397.00000 61.4000 -42.96875 -0.12500 3.14200 3.14200 12.40000 1.11300 1.09100 15.60000 1.00000 11.00000 11.00000 11.00000 11.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
35.520 2397.00000 61.4000 -42.96875 -0.12500 3.14200 3.14200 12.40000 1.11300 1.09100 15.60000 1.00000 11.00000 11.00000 11.00000 11.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
35.530 2397.00000 61.4000 -42.96875 -0.12500 3.14200 3.14200 12.40000 1.11300 1.09100 15.60000 1.00000 11.00000 11.00000 11.00000 11.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
35.540 2411.00000 61.2000 -42.18750 -0.12500 3.07200 3.07200 13.40000 1.11300 1.09100 15.70000 1.00000 11.00000 11.00000 11.00000 11.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
35.550 2411.00000 61.2000 -42.18750 -0.12500 3.07200 3.07200 13.40000 1.11300 1.09100 15.70000 1.00000 11.00000 11.00000 11.00000 11.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
35.560 2411.00000 61.2000 -42.18750 -0.12500 3.07200 3.07200 13.40000 1.11300 1.09100 15.70000 1.00000 11.00000 11.00000 11.00000 11.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
35.570 2411.00000 61.2000 -42.18750 -0.12500 3.07200 3.07200 13.40000 1.11300 1.09100 15.70000 1.00000 11.00000 11.00000 11.00000 11.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
35.580 2411.00000 61.2000 -42.18750 -0.12500 3.07200 3.07200 13.40000 1.11300 1.09100 15.70000 1.00000 11.00000 11.00000 11.00000 11.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
35.590 2494.00000 62.0000 -37.50000 -0.25000 2.89700 2.89700 13.40000 1.11300 1.09100 17.10000 1.00000 12.00000 12.00000 11.00000 12.00000 0.00000 0.00000 12.0000 0.000 0.000 0.000 0.000
35.600 2494.00000 62.0000 -37.50000 -0.25000 2.89700 2.89700 13.40000 1.11300 1.09100 17.10000 1.00000 12.00000 12.00000 11.00000 12.00000 0.00000 0.00000 12.0000 0.000 0.000 0.000 0.000
35.610 2494.00000 62.0000 -37.50000 -0.25000 2.89700 2.89700 13.40000 1.11300 1.09100 17.10000 1.00000 12.00000 12.00000 11.00000 12.00000 0.00000 0.00000 12.0000 0.000 0.000 0.000 0.000
35.620 2494.00000 62.0000 -37.50000 -0.25000 2.89700 2.89700 13.40000 1.11300 1.09100 17.10000 1.00000 12.00000 12.00000 11.00000 12.00000 0.00000 0.00000 12.0000 0.000 0.000 0.000 0.000
35.630 2494.00000 62.0000 -37.50000 -0.25000 2.89700 2.89700 13.40000 1.11300 1.09100 17.10000 1.00000 12.00000 12.00000 11.00000 12.00000 0.00000 0.00000 12.0000 0.000 0.000 0.000 0.000
35.640 2461.00000 62.2000 -41.40625 -0.25000 3.14800 3.14800 13.80000 1.11300 1.09100 15.90000 1.00000 11.00000 12.00000 11.00000 12.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
35.650 2461.00000 62.2000 -41.40625 -0.25000 3.14800 3.14800 13.80000 1.11300 1.09100 15.90000 1.00000 11.00000 12.00000 11.00000 12.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
35.660 2461.00000 62.2000 -41.40625 -0.25000 3.14800 3.14800 13.80000 1.11300 1.09100 15.90000 1.00000 11.00000 12.00000 11.00000 12.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
35.670 2461.00000 62.2000 -41.40625 -0.25000 3.14800 3.14800 13.80000 1.11300 1.09100 15.90000 1.00000 11.00000 12.00000 11.00000 12.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
35.680 2461.00000 62.2000 -41.40625 -0.25000 3.14800 3.14800 13.80000 1.11300 1.09100 15.90000 1.00000 11.00000 12.00000 11.00000 12.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
35.690 2474.00000 62.5000 -41.40625 -0.12500 2.92600 2.92600 13.00000 1.09400 1.09400 15.90000 1.00000 11.00000 11.00000 11.00000 12.00000 0.00000 0.00000 12.3000 0.000 0.000 0.000 0.000
35.700 2474.00000 62.5000 -41.40625 -0.12500 2.92600 2.92600 13.00000 1.09400 1.09400 15.90000 1.00000 11.00000 11.00000 11.00000 12.00000 0.00000 0.00000 12.3000 0.000 0.000 0.000 0.000
35.710 2474.00000 62.5000 -41.40625 -0.12500 2.92600 2.92600 13.00000 1.09400 1.09400 15.90000 1.00000 11.00000 11.00000 11.00000 12.00000 0.00000 0.00000 12.3000 0.000 0.000 0.000 0.000
35.720 2474.00000 62.5000 -41.40625 -0.12500 2.92600 2.92600 13.00000 1.09400 1.09400 15.90000 1.00000 11.00000 11.00000 11.00000 12.00000 0.00000 0.00000 12.3000 0.000 0.000 0.000 0.000
35.730 2474.00000 62.5000 -41.40625 -0.12500 2.92600 2.92600 13.00000 1.09400 1.09400 15.90000 1.00000 11.00000 11.00000 11.00000 12.00000 0.00000 0.00000 12.3000 0.000 0.000 0.000 0.000
35.740 2499.00000 63.1000 -40.62500 -0.25000 3.13000 3.13000 12.70000 1.09400 1.09400 16.20000 1.00000 11.00000 11.00000 12.00000 12.00000 0.00000 0.00000 12.3000 0.000 0.000 0.000 0.000
35.750 2499.00000 63.1000 -40.62500 -0.25000 3.13000 3.13000 12.70000 1.09400 1.09400 16.20000 1.00000 11.00000 11.00000 12.00000 12.00000 0.00000 0.00000 12.3000 0.000 0.000 0.000 0.000
35.760 2499.00000 63.1000 -40.62500 -0.25000 3.13000 3.13000 12.70000 1.09400 1.09400 16.20000 1.00000 11.00000 11.00000 12.00000 12.00000 0.00000 0.00000 12.3000 0.000 0.000 0.000 0.000
35.770 2499.00000 63.1000 -40.62500 -0.25000 3.13000 3.13000 12.70000 1.09400 1.09400 16.20000 1.00000 11.00000 11.00000 12.00000 12.00000 0.00000 0.00000 12.3000 0.000 0.000 0.000 0.000
35.780 2499.00000 63.1000 -40.62500 -0.25000 3.13000 3.13000 12.70000 1.09400 1.09400 16.20000 1.00000 11.00000 11.00000 12.00000 12.00000 0.00000 0.00000 12.3000 0.000 0.000 0.000 0.000
35.790 2517.00000 63.5000 -41.40625 -0.25000 3.00200 3.00200 12.60000 1.09400 1.09400 16.00000 1.00000 11.00000 12.00000 12.00000 12.00000 0.00000 0.00000 12.3000 0.000 0.000 0.000 0.000
35.800 2517.00000 63.5000 -41.40625 -0.25000 3.00200 3.00200 12.60000 1.09400 1.09400 16.00000 1.00000 11.00000 12.00000 12.00000 12.00000 0.00000 0.00000 12.3000 0.000 0.000 0.000 0.000
35.810 2517.00000 63.5000 -41.40625 -0.25000 3.00200 3.00200 12.60000 1.09400 1.09400 16.00000 1.00000 11.00000 12.00000 12.00000 12.00000 0.00000 0.00000 12.3000 0.000 0.000 0.000 0.000
35.820 2517.00000 63.5000 -41.40625 -0.25000 3.00200 3.00200 12.60000 1.09400 1.09400 16.00000 1.00000 11.00000 12.00000 12.00000 12.00000 0.00000 0.00000 12.3000 0.000 0.000 0.000 0.000
35.830 2517.00000 63.5000 -41.40625 -0.25000 3.00200 3.00200 12.60000 1.09400 1.09400 16.00000 1.00000 11.00000 12.00000 12.00000 12.00000 0.00000 0.00000 12.3000 0.000 0.000 0.000 0.000
35.840 2518.00000 64.4000 -39.84375 -0.25000 3.11800 3.11800 12.70000 1.09400 1.09400 16.50000 1.00000 11.00000 12.00000 12.00000 12.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
35.850 2518.00000 64.4000 -39.84375 -0.25000 3.11800 3.11800 12.70000 1.09400 1.09400 16.50000 1.00000 11.00000 12.00000 12.00000 12.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
35.860 2518.00000 64.4000 -39.84375 -0.25000 3.11800 3.11800 12.70000 1.09400 1.09400 16.50000 1.00000 11.00000 12.00000 12.00000 12.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
35.870 2518.00000 64.4000 -39.84375 -0.25000 3.11800 3.11800 12.70000 1.09400 1.09400 16.50000 1.00000 11.00000 12.00000 12.00000 12.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
35.880 2518.00000 64.4000 -39.84375 -0.25000 3.11800 3.11800 12.70000 1.09400 1.09400 16.50000 1.00000 11.00000 12.00000 12.00000 12.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
35.890 2610.00000 64.6000 -39.84375 -0.25000 3.01400 3.01400 13.40000 1.09400 1.08800 16.30000 1.00000 13.00000 12.00000 12.00000 13.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
35.900 2610.00000 64.6000 -39.84375 -0.25000 3.01400 3.01400 13.40000 1.09400 1.08800 16.30000 1.00000 13.00000 12.00000 12.00000 13.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
35.910 2610.00000 64.6000 -39.84375 -0.25000 3.01400 3.01400 13.40000 1.09400 1.08800 16.30000 1.00000 13.00000 12.00000 12.00000 13.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
35.920 2610.00000 64.6000 -39.84375 -0.25000 3.01400 3.01400 13.40000 1.09400 1.08800 16.30000 1.00000 13.00000 12.00000 12.00000 13.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
35.930 2610.00000 64.6000 -39.84375 -0.25000 3.01400 3.01400 13.40000 1.09400 1.08800 16.30000 1.00000 13.00000 12.00000 12.00000 13.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
35.940 2597.00000 64.6000 -39.84375 -0.37500 3.27600 3.27600 13.60000 1.09400 1.08800 16.30000 1.00000 12.00000 12.00000 12.00000 12.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
35.950 2597.00000 64.6000 -39.84375 -0.37500 3.27600 3.27600 13.60000 1.09400 1.08800 16.30000 1.00000 12.00000 12.00000 12.00000 12.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
35.960 2597.00000 64.6000 -39.84375 -0.37500 3.27600 3.27600 13.60000 1.09400 1.08800 16.30000 1.00000 12.00000 12.00000 12.00000 12.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
35.970 2597.00000 64.6000 -39.84375 -0.37500 3.27600 3.27600 13.60000 1.09400 1.08800 16.30000 1.00000 12.00000 12.00000 12.00000 12.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
35.980 2597.00000 64.6000 -39.84375 -0.37500 3.27600 3.27600 13.60000 1.09400 1.08800 16.30000 1.00000 12.00000 12.00000 12.00000 12.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
35.990 2579.00000 64.0000 -36.71875 -0.50000 3.06600 3.06600 13.60000 1.09400 1.08800 17.30000 1.00000 12.00000 12.00000 12.00000 12.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
36.000 2579.00000 64.0000 -36.71875 -0.50000 3.06600 3.06600 13.60000 1.09400 1.08800 17.30000 1.00000 12.00000 12.00000 12.00000 12.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
36.010 2579.00000 64.0000 -36.71875 -0.50000 3.06600 3.06600 13.60000 1.09400 1.08800 17.30000 1.00000 12.00000 12.00000 12.00000 12.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
36.020 2579.00000 64.0000 -36.71875 -0.50000 3.06600 3.06600 13.60000 1.09400 1.08800 17.30000 1.00000 12.00000 12.00000 12.00000 12.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
36.030 2579.00000 64.0000 -36.71875 -0.50000 3.06600 3.06600 13.60000 1.09400 1.08800 17.30000 1.00000 12.00000 12.00000 12.00000 12.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
36.040 2579.00000 64.0000 -36.71875 -0.50000 3.06600 3.06600 13.60000 1.09400 1.08800 17.30000 1.00000 12.00000 12.00000 12.00000 12.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
36.050 2631.00000 64.3000 -39.06250 -0.37500 3.18300 3.18300 13.40000 1.09400 1.08800 16.60000 1.00000 12.00000 12.00000 13.00000 12.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
36.060 2631.00000 64.3000 -39.06250 -0.37500 3.18300 3.18300 13.40000 1.09400 1.08800 16.60000 1.00000 12.00000 12.00000 13.00000 12.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
36.070 2631.00000 64.3000 -39.06250 -0.37500 3.18300 3.18300 13.40000 1.09400 1.08800 16.60000 1.00000 12.00000 12.00000 13.00000 12.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
36.080 2631.00000 64.3000 -39.06250 -0.37500 3.18300 3.18300 13.40000 1.09400 1.08800 16.60000 1.00000 12.00000 12.00000 13.00000 12.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
36.090 2631.00000 64.3000 -39.06250 -0.37500 3.18300 3.18300 13.40000 1.09400 1.08800 16.60000 1.00000 12.00000 12.00000 13.00000 12.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
36.100 2635.00000 64.0000 -39.84375 -0.37500 3.32200 3.32200 13.20000 1.10100 1.09400 16.40000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
36.110 2635.00000 64.0000 -39.84375 -0.37500 3.32200 3.32200 13.20000 1.10100 1.09400 16.40000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
36.120 2635.00000 64.0000 -39.84375 -0.37500 3.32200 3.32200 13.20000 1.10100 1.09400 16.40000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
36.130 2635.00000 64.0000 -39.84375 -0.37500 3.32200 3.32200 13.20000 1.10100 1.09400 16.40000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
36.140 2635.00000 64.0000 -39.84375 -0.37500 3.32200 3.32200 13.20000 1.10100 1.09400 16.40000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
36.150 2647.00000 63.8000 -35.93750 -0.50000 3.11800 3.11800 13.30000 1.10100 1.09400 17.60000 1.00000 12.00000 12.00000 13.00000 12.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
36.160 2647.00000 63.8000 -35.93750 -0.50000 3.11800 3.11800 13.30000 1.10100 1.09400 17.60000 1.00000 12.00000 12.00000 13.00000 12.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
36.170 2647.00000 63.8000 -35.93750 -0.50000 3.11800 3.11800 13.30000 1.10100 1.09400 17.60000 1.00000 12.00000 12.00000 13.00000 12.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
36.180 2647.00000 63.8000 -35.93750 -0.50000 3.11800 3.11800 13.30000 1.10100 1.09400 17.60000 1.00000 12.00000 12.00000 13.00000 12.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
36.190 2647.00000 63.8000 -35.93750 -0.50000 3.11800 3.11800 13.30000 1.10100 1.09400 17.60000 1.00000 12.00000 12.00000 13.00000 12.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
36.200 2675.00000 64.1000 -39.06250 -0.37500 3.09500 3.09500 13.40000 1.10100 1.09400 16.70000 1.00000 13.00000 13.00000 13.00000 12.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
36.210 2675.00000 64.1000 -39.06250 -0.37500 3.09500 3.09500 13.40000 1.10100 1.09400 16.70000 1.00000 13.00000 13.00000 13.00000 12.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
36.220 2675.00000 64.1000 -39.06250 -0.37500 3.09500 3.09500 13.40000 1.10100 1.09400 16.70000 1.00000 13.00000 13.00000 13.00000 12.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
36.230 2675.00000 64.1000 -39.06250 -0.37500 3.09500 3.09500 13.40000 1.10100 1.09400 16.70000 1.00000 13.00000 13.00000 13.00000 12.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
36.240 2675.00000 64.1000 -39.06250 -0.37500 3.09500 3.09500 13.40000 1.10100 1.09400 16.70000 1.00000 13.00000 13.00000 13.00000 12.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
36.250 2677.00000 64.4000 -39.06250 -0.37500 3.31700 3.31700 13.10000 1.10100 1.09400 16.50000 1.00000 12.00000 12.00000 12.00000 13.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
36.260 2677.00000 64.4000 -39.06250 -0.37500 3.31700 3.31700 13.10000 1.10100 1.09400 16.50000 1.00000 12.00000 12.00000 12.00000 13.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
36.270 2677.00000 64.4000 -39.06250 -0.37500 3.31700 3.31700 13.10000 1.10100 1.09400 16.50000 1.00000 12.00000 12.00000 12.00000 13.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
36.280 2677.00000 64.4000 -39.06250 -0.37500 3.31700 3.31700 13.10000 1.10100 1.09400 16.50000 1.00000 12.00000 12.00000 12.00000 13.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
36.290 2677.00000 64.4000 -39.06250 -0.37500 3.31700 3.31700 13.10000 1.10100 1.09400 16.50000 1.00000 12.00000 12.00000 12.00000 13.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
36.300 2721.00000 64.1000 -38.28125 -0.37500 3.32800 3.32800 13.20000 1.09800 1.09800 16.80000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 12.7000 0.000 0.000 0.000 0.000
36.310 2721.00000 64.1000 -38.28125 -0.37500 3.32800 3.32800 13.20000 1.09800 1.09800 16.80000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 12.7000 0.000 0.000 0.000 0.000
36.320 2721.00000 64.1000 -38.28125 -0.37500 3.32800 3.32800 13.20000 1.09800 1.09800 16.80000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 12.7000 0.000 0.000 0.000 0.000
36.330 2721.00000 64.1000 -38.28125 -0.37500 3.32800 3.32800 13.20000 1.09800 1.09800 16.80000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 12.7000 0.000 0.000 0.000 0.000
36.340 2721.00000 64.1000 -38.28125 -0.37500 3.32800 3.32800 13.20000 1.09800 1.09800 16.80000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 12.7000 0.000 0.000 0.000 0.000
36.350 2760.00000 64.4000 -38.28125 -0.37500 3.39200 3.39200 13.40000 1.09800 1.09800 16.90000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 12.8000 0.000 0.000 0.000 0.000
36.360 2760.00000 64.4000 -38.28125 -0.37500 3.39200 3.39200 13.40000 1.09800 1.09800 16.90000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 12.8000 0.000 0.000 0.000 0.000
36.370 2760.00000 64.4000 -38.28125 -0.37500 3.39200 3.39200 13.40000 1.09800 1.09800 16.90000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 12.8000 0.000 0.000 0.000 0.000
36.380 2760.00000 64.4000 -38.28125 -0.37500 3.39200 3.39200 13.40000 1.09800 1.09800 16.90000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 12.8000 0.000 0.000 0.000 0.000
36.390 2760.00000 64.4000 -38.28125 -0.37500 3.39200 3.39200 13.40000 1.09800 1.09800 16.90000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 12.8000 0.000 0.000 0.000 0.000
36.400 2769.00000 64.0000 -36.71875 -0.50000 3.35200 3.35200 12.40000 1.09800 1.09800 17.30000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 12.7000 0.000 0.000 0.000 0.000
36.410 2769.00000 64.0000 -36.71875 -0.50000 3.35200 3.35200 12.40000 1.09800 1.09800 17.30000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 12.7000 0.000 0.000 0.000 0.000
36.420 2769.00000 64.0000 -36.71875 -0.50000 3.35200 3.35200 12.40000 1.09800 1.09800 17.30000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 12.7000 0.000 0.000 0.000 0.000
36.430 2769.00000 64.0000 -36.71875 -0.50000 3.35200 3.35200 12.40000 1.09800 1.09800 17.30000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 12.7000 0.000 0.000 0.000 0.000
36.440 2769.00000 64.0000 -36.71875 -0.50000 3.35200 3.35200 12.40000 1.09800 1.09800 17.30000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 12.7000 0.000 0.000 0.000 0.000
36.450 2779.00000 63.4000 -37.50000 -0.50000 3.35700 3.35700 12.50000 1.09800 1.09800 17.20000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 12.8000 0.000 0.000 0.000 0.000
36.460 2779.00000 63.4000 -37.50000 -0.50000 3.35700 3.35700 12.50000 1.09800 1.09800 17.20000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 12.8000 0.000 0.000 0.000 0.000
36.470 2779.00000 63.4000 -37.50000 -0.50000 3.35700 3.35700 12.50000 1.09800 1.09800 17.20000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 12.8000 0.000 0.000 0.000 0.000
36.480 2779.00000 63.4000 -37.50000 -0.50000 3.35700 3.35700 12.50000 1.09800 1.09800 17.20000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 12.8000 0.000 0.000 0.000 0.000
36.490 2779.00000 63.4000 -37.50000 -0.50000 3.35700 3.35700 12.50000 1.09800 1.09800 17.20000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 12.8000 0.000 0.000 0.000 0.000
36.500 2792.00000 62.6000 -36.71875 -0.50000 3.38100 3.38100 12.40000 1.06900 1.08500 17.30000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 12.9000 0.000 0.000 0.000 0.000
36.510 2792.00000 62.6000 -36.71875 -0.50000 3.38100 3.38100 12.40000 1.06900 1.08500 17.30000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 12.9000 0.000 0.000 0.000 0.000
36.520 2792.00000 62.6000 -36.71875 -0.50000 3.38100 3.38100 12.40000 1.06900 1.08500 17.30000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 12.9000 0.000 0.000 0.000 0.000
36.530 2792.00000 62.6000 -36.71875 -0.50000 3.38100 3.38100 12.40000 1.06900 1.08500 17.30000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 12.9000 0.000 0.000 0.000 0.000
36.540 2792.00000 62.6000 -36.71875 -0.50000 3.38100 3.38100 12.40000 1.06900 1.08500 17.30000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 12.9000 0.000 0.000 0.000 0.000
36.550 2848.00000 63.5000 -36.71875 -0.50000 3.42200 3.42200 13.80000 1.06900 1.08500 17.40000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 12.9000 0.000 0.000 0.000 0.000
36.560 2848.00000 63.5000 -36.71875 -0.50000 3.42200 3.42200 13.80000 1.06900 1.08500 17.40000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 12.9000 0.000 0.000 0.000 0.000
36.570 2848.00000 63.5000 -36.71875 -0.50000 3.42200 3.42200 13.80000 1.06900 1.08500 17.40000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 12.9000 0.000 0.000 0.000 0.000
36.580 2848.00000 63.5000 -36.71875 -0.50000 3.42200 3.42200 13.80000 1.06900 1.08500 17.40000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 12.9000 0.000 0.000 0.000 0.000
36.590 2848.00000 63.5000 -36.71875 -0.50000 3.42200 3.42200 13.80000 1.06900 1.08500 17.40000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 12.9000 0.000 0.000 0.000 0.000
36.600 2835.00000 64.6000 -35.93750 -0.62500 3.41000 3.41000 12.10000 1.06900 1.08500 17.60000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
36.610 2835.00000 64.6000 -35.93750 -0.62500 3.41000 3.41000 12.10000 1.06900 1.08500 17.60000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
36.620 2835.00000 64.6000 -35.93750 -0.62500 3.41000 3.41000 12.10000 1.06900 1.08500 17.60000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
36.630 2835.00000 64.6000 -35.93750 -0.62500 3.41000 3.41000 12.10000 1.06900 1.08500 17.60000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
36.640 2835.00000 64.6000 -35.93750 -0.62500 3.41000 3.41000 12.10000 1.06900 1.08500 17.60000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
36.650 2878.00000 65.7000 -35.93750 -0.62500 3.43300 3.43300 13.60000 1.06900 1.08500 17.50000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 13.2000 0.000 0.000 0.000 0.000
36.660 2878.00000 65.7000 -35.93750 -0.62500 3.43300 3.43300 13.60000 1.06900 1.08500 17.50000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 13.2000 0.000 0.000 0.000 0.000
36.670 2878.00000 65.7000 -35.93750 -0.62500 3.43300 3.43300 13.60000 1.06900 1.08500 17.50000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 13.2000 0.000 0.000 0.000 0.000
36.680 2878.00000 65.7000 -35.93750 -0.62500 3.43300 3.43300 13.60000 1.06900 1.08500 17.50000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 13.2000 0.000 0.000 0.000 0.000
36.690 2878.00000 65.7000 -35.93750 -0.62500 3.43300 3.43300 13.60000 1.06900 1.08500 17.50000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 13.2000 0.000 0.000 0.000 0.000
36.700 2878.00000 66.9000 -36.71875 -0.62500 3.50900 3.50900 13.50000 1.06900 1.07200 17.40000 1.00000 13.00000 14.00000 14.00000 14.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
36.710 2878.00000 66.9000 -36.71875 -0.62500 3.50900 3.50900 13.50000 1.06900 1.07200 17.40000 1.00000 13.00000 14.00000 14.00000 14.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
36.720 2878.00000 66.9000 -36.71875 -0.62500 3.50900 3.50900 13.50000 1.06900 1.07200 17.40000 1.00000 13.00000 14.00000 14.00000 14.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
36.730 2878.00000 66.9000 -36.71875 -0.62500 3.50900 3.50900 13.50000 1.06900 1.07200 17.40000 1.00000 13.00000 14.00000 14.00000 14.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
36.740 2878.00000 66.9000 -36.71875 -0.62500 3.50900 3.50900 13.50000 1.06900 1.07200 17.40000 1.00000 13.00000 14.00000 14.00000 14.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
36.750 3020.00000 66.1000 -35.15625 -0.62500 3.42200 3.42200 13.70000 1.06900 1.07200 18.00000 1.00000 14.00000 14.00000 14.00000 14.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
36.760 3020.00000 66.1000 -35.15625 -0.62500 3.42200 3.42200 13.70000 1.06900 1.07200 18.00000 1.00000 14.00000 14.00000 14.00000 14.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
36.770 3020.00000 66.1000 -35.15625 -0.62500 3.42200 3.42200 13.70000 1.06900 1.07200 18.00000 1.00000 14.00000 14.00000 14.00000 14.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
36.780 3020.00000 66.1000 -35.15625 -0.62500 3.42200 3.42200 13.70000 1.06900 1.07200 18.00000 1.00000 14.00000 14.00000 14.00000 14.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
36.790 3020.00000 66.1000 -35.15625 -0.62500 3.42200 3.42200 13.70000 1.06900 1.07200 18.00000 1.00000 14.00000 14.00000 14.00000 14.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
36.800 2972.00000 65.8000 -32.81250 -0.75000 3.42700 3.42700 12.70000 1.06900 1.07200 18.70000 1.00000 14.00000 14.00000 14.00000 14.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
36.810 2972.00000 65.8000 -32.81250 -0.75000 3.42700 3.42700 12.70000 1.06900 1.07200 18.70000 1.00000 14.00000 14.00000 14.00000 14.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
36.820 2972.00000 65.8000 -32.81250 -0.75000 3.42700 3.42700 12.70000 1.06900 1.07200 18.70000 1.00000 14.00000 14.00000 14.00000 14.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
36.830 2972.00000 65.8000 -32.81250 -0.75000 3.42700 3.42700 12.70000 1.06900 1.07200 18.70000 1.00000 14.00000 14.00000 14.00000 14.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
36.840 2972.00000 65.8000 -32.81250 -0.75000 3.42700 3.42700 12.70000 1.06900 1.07200 18.70000 1.00000 14.00000 14.00000 14.00000 14.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
36.850 2968.00000 65.2000 -35.93750 -0.62500 3.53800 3.53800 12.90000 1.06900 1.07200 17.70000 1.00000 14.00000 14.00000 14.00000 14.00000 0.00000 0.00000 13.6000 0.000 0.000 0.000 0.000
36.860 2968.00000 65.2000 -35.93750 -0.62500 3.53800 3.53800 12.90000 1.06900 1.07200 17.70000 1.00000 14.00000 14.00000 14.00000 14.00000 0.00000 0.00000 13.6000 0.000 0.000 0.000 0.000
36.870 2968.00000 65.2000 -35.93750 -0.62500 3.53800 3.53800 12.90000 1.06900 1.07200 17.70000 1.00000 14.00000 14.00000 14.00000 14.00000 0.00000 0.00000 13.6000 0.000 0.000 0.000 0.000
36.880 2968.00000 65.2000 -35.93750 -0.62500 3.53800 3.53800 12.90000 1.06900 1.07200 17.70000 1.00000 14.00000 14.00000 14.00000 14.00000 0.00000 0.00000 13.6000 0.000 0.000 0.000 0.000
36.890 2968.00000 65.2000 -35.93750 -0.62500 3.53800 3.53800 12.90000 1.06900 1.07200 17.70000 1.00000 14.00000 14.00000 14.00000 14.00000 0.00000 0.00000 13.6000 0.000 0.000 0.000 0.000
36.900 3055.00000 65.2000 -35.15625 -0.62500 3.47400 3.47400 12.60000 1.05000 1.05600 18.00000 1.00000 15.00000 15.00000 14.00000 15.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
36.910 3055.00000 65.2000 -35.15625 -0.62500 3.47400 3.47400 12.60000 1.05000 1.05600 18.00000 1.00000 15.00000 15.00000 14.00000 15.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
36.920 3055.00000 65.2000 -35.15625 -0.62500 3.47400 3.47400 12.60000 1.05000 1.05600 18.00000 1.00000 15.00000 15.00000 14.00000 15.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
36.930 3055.00000 65.2000 -35.15625 -0.62500 3.47400 3.47400 12.60000 1.05000 1.05600 18.00000 1.00000 15.00000 15.00000 14.00000 15.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
36.940 3055.00000 65.2000 -35.15625 -0.62500 3.47400 3.47400 12.60000 1.05000 1.05600 18.00000 1.00000 15.00000 15.00000 14.00000 15.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
36.950 3004.00000 64.9000 -32.03125 -0.75000 3.46800 3.46800 13.10000 1.05000 1.05600 19.20000 1.00000 14.00000 14.00000 14.00000 14.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
36.960 3004.00000 64.9000 -32.03125 -0.75000 3.46800 3.46800 13.10000 1.05000 1.05600 19.20000 1.00000 14.00000 14.00000 14.00000 14.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
36.970 3004.00000 64.9000 -32.03125 -0.75000 3.46800 3.46800 13.10000 1.05000 1.05600 19.20000 1.00000 14.00000 14.00000 14.00000 14.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
36.980 3004.00000 64.9000 -32.03125 -0.75000 3.46800 3.46800 13.10000 1.05000 1.05600 19.20000 1.00000 14.00000 14.00000 14.00000 14.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
36.990 3004.00000 64.9000 -32.03125 -0.75000 3.46800 3.46800 13.10000 1.05000 1.05600 19.20000 1.00000 14.00000 14.00000 14.00000 14.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
37.000 3078.00000 65.4000 -35.15625 -0.62500 3.60800 3.60800 13.10000 1.05000 1.05600 17.80000 1.00000 15.00000 15.00000 14.00000 15.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
37.010 3078.00000 65.4000 -35.15625 -0.62500 3.60800 3.60800 13.10000 1.05000 1.05600 17.80000 1.00000 15.00000 15.00000 14.00000 15.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
37.020 3078.00000 65.4000 -35.15625 -0.62500 3.60800 3.60800 13.10000 1.05000 1.05600 17.80000 1.00000 15.00000 15.00000 14.00000 15.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
37.030 3078.00000 65.4000 -35.15625 -0.62500 3.60800 3.60800 13.10000 1.05000 1.05600 17.80000 1.00000 15.00000 15.00000 14.00000 15.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
37.040 3078.00000 65.4000 -35.15625 -0.62500 3.60800 3.60800 13.10000 1.05000 1.05600 17.80000 1.00000 15.00000 15.00000 14.00000 15.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
37.050 3030.00000 65.7000 -32.81250 -0.87500 3.43900 3.43900 13.40000 1.05000 1.05600 18.70000 1.00000 15.00000 15.00000 14.00000 15.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
37.060 3030.00000 65.7000 -32.81250 -0.87500 3.43900 3.43900 13.40000 1.05000 1.05600 18.70000 1.00000 15.00000 15.00000 14.00000 15.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
37.070 3030.00000 65.7000 -32.81250 -0.87500 3.43900 3.43900 13.40000 1.05000 1.05600 18.70000 1.00000 15.00000 15.00000 14.00000 15.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
37.080 3030.00000 65.7000 -32.81250 -0.87500 3.43900 3.43900 13.40000 1.05000 1.05600 18.70000 1.00000 15.00000 15.00000 14.00000 15.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
37.090 3030.00000 65.7000 -32.81250 -0.87500 3.43900 3.43900 13.40000 1.05000 1.05600 18.70000 1.00000 15.00000 15.00000 14.00000 15.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
37.100 3130.00000 65.5000 -34.37500 -0.75000 3.63100 3.63100 13.80000 1.04300 1.04300 18.20000 1.00000 15.00000 15.00000 15.00000 15.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
37.110 3130.00000 65.5000 -34.37500 -0.75000 3.63100 3.63100 13.80000 1.04300 1.04300 18.20000 1.00000 15.00000 15.00000 15.00000 15.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
37.120 3130.00000 65.5000 -34.37500 -0.75000 3.63100 3.63100 13.80000 1.04300 1.04300 18.20000 1.00000 15.00000 15.00000 15.00000 15.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
37.130 3130.00000 65.5000 -34.37500 -0.75000 3.63100 3.63100 13.80000 1.04300 1.04300 18.20000 1.00000 15.00000 15.00000 15.00000 15.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
37.140 3130.00000 65.5000 -34.37500 -0.75000 3.63100 3.63100 13.80000 1.04300 1.04300 18.20000 1.00000 15.00000 15.00000 15.00000 15.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
37.150 3093.00000 65.5000 -32.81250 -0.87500 3.53800 3.53800 13.00000 1.04300 1.04300 18.60000 1.00000 15.00000 15.00000 15.00000 15.00000 0.00000 0.00000 13.8000 0.000 0.000 0.000 0.000
37.160 3093.00000 65.5000 -32.81250 -0.87500 3.53800 3.53800 13.00000 1.04300 1.04300 18.60000 1.00000 15.00000 15.00000 15.00000 15.00000 0.00000 0.00000 13.8000 0.000 0.000 0.000 0.000
37.170 3093.00000 65.5000 -32.81250 -0.87500 3.53800 3.53800 13.00000 1.04300 1.04300 18.60000 1.00000 15.00000 15.00000 15.00000 15.00000 0.00000 0.00000 13.8000 0.000 0.000 0.000 0.000
37.180 3093.00000 65.5000 -32.81250 -0.87500 3.53800 3.53800 13.00000 1.04300 1.04300 18.60000 1.00000 15.00000 15.00000 15.00000 15.00000 0.00000 0.00000 13.8000 0.000 0.000 0.000 0.000
37.190 3093.00000 65.5000 -32.81250 -0.87500 3.53800 3.53800 13.00000 1.04300 1.04300 18.60000 1.00000 15.00000 15.00000 15.00000 15.00000 0.00000 0.00000 13.8000 0.000 0.000 0.000 0.000
37.200 3134.00000 65.8000 -33.59375 -0.87500 3.65500 3.65500 13.60000 1.04300 1.04300 18.50000 1.00000 19.00000 19.00000 19.00000 19.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
37.210 3134.00000 65.8000 -33.59375 -0.87500 3.65500 3.65500 13.60000 1.04300 1.04300 18.50000 1.00000 19.00000 19.00000 19.00000 19.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
37.220 3134.00000 65.8000 -33.59375 -0.87500 3.65500 3.65500 13.60000 1.04300 1.04300 18.50000 1.00000 19.00000 19.00000 19.00000 19.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
37.230 3134.00000 65.8000 -33.59375 -0.87500 3.65500 3.65500 13.60000 1.04300 1.04300 18.50000 1.00000 19.00000 19.00000 19.00000 19.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
37.240 3134.00000 65.8000 -33.59375 -0.87500 3.65500 3.65500 13.60000 1.04300 1.04300 18.50000 1.00000 19.00000 19.00000 19.00000 19.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
37.250 3121.00000 64.6000 -32.03125 -0.87500 3.54400 3.54400 12.60000 1.04300 1.04300 19.10000 1.00000 20.00000 19.00000 19.00000 19.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
37.260 3121.00000 64.6000 -32.03125 -0.87500 3.54400 3.54400 12.60000 1.04300 1.04300 19.10000 1.00000 20.00000 19.00000 19.00000 19.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
37.270 3121.00000 64.6000 -32.03125 -0.87500 3.54400 3.54400 12.60000 1.04300 1.04300 19.10000 1.00000 20.00000 19.00000 19.00000 19.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
37.280 3121.00000 64.6000 -32.03125 -0.87500 3.54400 3.54400 12.60000 1.04300 1.04300 19.10000 1.00000 20.00000 19.00000 19.00000 19.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
37.290 3121.00000 64.6000 -32.03125 -0.87500 3.54400 3.54400 12.60000 1.04300 1.04300 19.10000 1.00000 20.00000 19.00000 19.00000 19.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
37.300 3222.00000 65.8000 -33.59375 -0.87500 3.71300 3.71300 13.10000 1.04600 1.02400 18.60000 1.00000 20.00000 19.00000 20.00000 20.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
37.310 3222.00000 65.8000 -33.59375 -0.87500 3.71300 3.71300 13.10000 1.04600 1.02400 18.60000 1.00000 20.00000 19.00000 20.00000 20.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
37.320 3222.00000 65.8000 -33.59375 -0.87500 3.71300 3.71300 13.10000 1.04600 1.02400 18.60000 1.00000 20.00000 19.00000 20.00000 20.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
37.330 3222.00000 65.8000 -33.59375 -0.87500 3.71300 3.71300 13.10000 1.04600 1.02400 18.60000 1.00000 20.00000 19.00000 20.00000 20.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
37.340 3222.00000 65.8000 -33.59375 -0.87500 3.71300 3.71300 13.10000 1.04600 1.02400 18.60000 1.00000 20.00000 19.00000 20.00000 20.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
37.350 3248.00000 66.1000 -32.81250 -0.87500 3.74200 3.74200 12.90000 1.04600 1.02400 18.70000 1.00000 20.00000 20.00000 20.00000 20.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
37.360 3248.00000 66.1000 -32.81250 -0.87500 3.74200 3.74200 12.90000 1.04600 1.02400 18.70000 1.00000 20.00000 20.00000 20.00000 20.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
37.370 3248.00000 66.1000 -32.81250 -0.87500 3.74200 3.74200 12.90000 1.04600 1.02400 18.70000 1.00000 20.00000 20.00000 20.00000 20.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
37.380 3248.00000 66.1000 -32.81250 -0.87500 3.74200 3.74200 12.90000 1.04600 1.02400 18.70000 1.00000 20.00000 20.00000 20.00000 20.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
37.390 3248.00000 66.1000 -32.81250 -0.87500 3.74200 3.74200 12.90000 1.04600 1.02400 18.70000 1.00000 20.00000 20.00000 20.00000 20.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
37.400 3212.00000 66.6000 -30.46875 -1.00000 3.73100 3.73100 12.10000 1.04600 1.02400 19.60000 1.00000 21.00000 20.00000 20.00000 20.00000 0.00000 0.00000 12.9000 0.000 0.000 0.000 0.000
37.410 3212.00000 66.6000 -30.46875 -1.00000 3.73100 3.73100 12.10000 1.04600 1.02400 19.60000 1.00000 21.00000 20.00000 20.00000 20.00000 0.00000 0.00000 12.9000 0.000 0.000 0.000 0.000
37.420 3212.00000 66.6000 -30.46875 -1.00000 3.73100 3.73100 12.10000 1.04600 1.02400 19.60000 1.00000 21.00000 20.00000 20.00000 20.00000 0.00000 0.00000 12.9000 0.000 0.000 0.000 0.000
37.430 3212.00000 66.6000 -30.46875 -1.00000 3.73100 3.73100 12.10000 1.04600 1.02400 19.60000 1.00000 21.00000 20.00000 20.00000 20.00000 0.00000 0.00000 12.9000 0.000 0.000 0.000 0.000
37.440 3212.00000 66.6000 -30.46875 -1.00000 3.73100 3.73100 12.10000 1.04600 1.02400 19.60000 1.00000 21.00000 20.00000 20.00000 20.00000 0.00000 0.00000 12.9000 0.000 0.000 0.000 0.000
37.450 3288.00000 66.0000 -29.68750 -1.12500 3.60800 3.60800 13.10000 1.04600 1.02400 19.70000 1.00000 21.00000 20.00000 20.00000 20.00000 0.00000 0.00000 12.9000 0.000 0.000 0.000 0.000
37.460 3288.00000 66.0000 -29.68750 -1.12500 3.60800 3.60800 13.10000 1.04600 1.02400 19.70000 1.00000 21.00000 20.00000 20.00000 20.00000 0.00000 0.00000 12.9000 0.000 0.000 0.000 0.000
37.470 3288.00000 66.0000 -29.68750 -1.12500 3.60800 3.60800 13.10000 1.04600 1.02400 19.70000 1.00000 21.00000 20.00000 20.00000 20.00000 0.00000 0.00000 12.9000 0.000 0.000 0.000 0.000
37.480 3288.00000 66.0000 -29.68750 -1.12500 3.60800 3.60800 13.10000 1.04600 1.02400 19.70000 1.00000 21.00000 20.00000 20.00000 20.00000 0.00000 0.00000 12.9000 0.000 0.000 0.000 0.000
37.490 3288.00000 66.0000 -29.68750 -1.12500 3.60800 3.60800 13.10000 1.04600 1.02400 19.70000 1.00000 21.00000 20.00000 20.00000 20.00000 0.00000 0.00000 12.9000 0.000 0.000 0.000 0.000
37.500 3287.00000 66.1000 -32.03125 -0.87500 3.78900 3.78900 13.00000 1.10700 1.07200 19.00000 1.00000 20.00000 21.00000 20.00000 20.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
37.510 3287.00000 66.1000 -32.03125 -0.87500 3.78900 3.78900 13.00000 1.10700 1.07200 19.00000 1.00000 20.00000 21.00000 20.00000 20.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
37.520 3287.00000 66.1000 -32.03125 -0.87500 3.78900 3.78900 13.00000 1.10700 1.07200 19.00000 1.00000 20.00000 21.00000 20.00000 20.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
37.530 3287.00000 66.1000 -32.03125 -0.87500 3.78900 3.78900 13.00000 1.10700 1.07200 19.00000 1.00000 20.00000 21.00000 20.00000 20.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
37.540 3287.00000 66.1000 -32.03125 -0.87500 3.78900 3.78900 13.00000 1.10700 1.07200 19.00000 1.00000 20.00000 21.00000 20.00000 20.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
37.550 3391.00000 66.1000 -32.03125 -1.00000 3.79500 3.79500 13.10000 1.10700 1.07200 19.10000 1.00000 21.00000 21.00000 21.00000 22.00000 0.00000 0.00000 11.7000 0.000 0.000 0.000 0.000
37.560 3391.00000 66.1000 -32.03125 -1.00000 3.79500 3.79500 13.10000 1.10700 1.07200 19.10000 1.00000 21.00000 21.00000 21.00000 22.00000 0.00000 0.00000 11.7000 0.000 0.000 0.000 0.000
37.570 3391.00000 66.1000 -32.03125 -1.00000 3.79500 3.79500 13.10000 1.10700 1.07200 19.10000 1.00000 21.00000 21.00000 21.00000 22.00000 0.00000 0.00000 11.7000 0.000 0.000 0.000 0.000
37.580 3391.00000 66.1000 -32.03125 -1.00000 3.79500 3.79500 13.10000 1.10700 1.07200 19.10000 1.00000 21.00000 21.00000 21.00000 22.00000 0.00000 0.00000 11.7000 0.000 0.000 0.000 0.000
37.590 3391.00000 66.1000 -32.03125 -1.00000 3.79500 3.79500 13.10000 1.10700 1.07200 19.10000 1.00000 21.00000 21.00000 21.00000 22.00000 0.00000 0.00000 11.7000 0.000 0.000 0.000 0.000
37.600 3323.00000 65.8000 -32.03125 -1.00000 3.77700 3.77700 12.30000 1.10700 1.07200 19.20000 1.00000 21.00000 21.00000 22.00000 21.00000 0.00000 0.00000 11.7000 0.000 0.000 0.000 0.000
37.610 3323.00000 65.8000 -32.03125 -1.00000 3.77700 3.77700 12.30000 1.10700 1.07200 19.20000 1.00000 21.00000 21.00000 22.00000 21.00000 0.00000 0.00000 11.7000 0.000 0.000 0.000 0.000
37.620 3323.00000 65.8000 -32.03125 -1.00000 3.77700 3.77700 12.30000 1.10700 1.07200 19.20000 1.00000 21.00000 21.00000 22.00000 21.00000 0.00000 0.00000 11.7000 0.000 0.000 0.000 0.000
37.630 3323.00000 65.8000 -32.03125 -1.00000 3.77700 3.77700 12.30000 1.10700 1.07200 19.20000 1.00000 21.00000 21.00000 22.00000 21.00000 0.00000 0.00000 11.7000 0.000 0.000 0.000 0.000
37.640 3323.00000 65.8000 -32.03125 -1.00000 3.77700 3.77700 12.30000 1.10700 1.07200 19.20000 1.00000 21.00000 21.00000 22.00000 21.00000 0.00000 0.00000 11.7000 0.000 0.000 0.000 0.000
37.650 3423.00000 65.8000 -32.03125 -1.00000 3.90000 3.90000 13.10000 1.10700 1.07200 18.90000 1.00000 22.00000 22.00000 21.00000 21.00000 0.00000 0.00000 11.7000 0.000 0.000 0.000 0.000
37.660 3423.00000 65.8000 -32.03125 -1.00000 3.90000 3.90000 13.10000 1.10700 1.07200 18.90000 1.00000 22.00000 22.00000 21.00000 21.00000 0.00000 0.00000 11.7000 0.000 0.000 0.000 0.000
37.670 3423.00000 65.8000 -32.03125 -1.00000 3.90000 3.90000 13.10000 1.10700 1.07200 18.90000 1.00000 22.00000 22.00000 21.00000 21.00000 0.00000 0.00000 11.7000 0.000 0.000 0.000 0.000
37.680 3423.00000 65.8000 -32.03125 -1.00000 3.90000 3.90000 13.10000 1.10700 1.07200 18.90000 1.00000 22.00000 22.00000 21.00000 21.00000 0.00000 0.00000 11.7000 0.000 0.000 0.000 0.000
37.690 3423.00000 65.8000 -32.03125 -1.00000 3.90000 3.90000 13.10000 1.10700 1.07200 18.90000 1.00000 22.00000 22.00000 21.00000 21.00000 0.00000 0.00000 11.7000 0.000 0.000 0.000 0.000
37.700 3400.00000 66.0000 -31.25000 -1.00000 3.85900 3.85900 12.80000 1.11000 1.09100 19.40000 1.00000 21.00000 21.00000 22.00000 22.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
37.710 3400.00000 66.0000 -31.25000 -1.00000 3.85900 3.85900 12.80000 1.11000 1.09100 19.40000 1.00000 21.00000 21.00000 22.00000 22.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
37.720 3400.00000 66.0000 -31.25000 -1.00000 3.85900 3.85900 12.80000 1.11000 1.09100 19.40000 1.00000 21.00000 21.00000 22.00000 22.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
37.730 3400.00000 66.0000 -31.25000 -1.00000 3.85900 3.85900 12.80000 1.11000 1.09100 19.40000 1.00000 21.00000 21.00000 22.00000 22.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
37.740 3400.00000 66.0000 -31.25000 -1.00000 3.85900 3.85900 12.80000 1.11000 1.09100 19.40000 1.00000 21.00000 21.00000 22.00000 22.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
37.750 3508.00000 66.1000 -29.68750 -1.12500 3.84700 3.84700 13.60000 1.11000 1.09100 19.70000 1.00000 22.00000 23.00000 22.00000 22.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
37.760 3508.00000 66.1000 -29.68750 -1.12500 3.84700 3.84700 13.60000 1.11000 1.09100 19.70000 1.00000 22.00000 23.00000 22.00000 22.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
37.770 3508.00000 66.1000 -29.68750 -1.12500 3.84700 3.84700 13.60000 1.11000 1.09100 19.70000 1.00000 22.00000 23.00000 22.00000 22.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
37.780 3508.00000 66.1000 -29.68750 -1.12500 3.84700 3.84700 13.60000 1.11000 1.09100 19.70000 1.00000 22.00000 23.00000 22.00000 22.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
37.790 3508.00000 66.1000 -29.68750 -1.12500 3.84700 3.84700 13.60000 1.11000 1.09100 19.70000 1.00000 22.00000 23.00000 22.00000 22.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
37.800 3451.00000 66.1000 -26.56250 -1.25000 3.80100 3.80100 13.40000 1.11000 1.09100 20.40000 1.00000 22.00000 23.00000 22.00000 22.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
37.810 3451.00000 66.1000 -26.56250 -1.25000 3.80100 3.80100 13.40000 1.11000 1.09100 20.40000 1.00000 22.00000 23.00000 22.00000 22.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
37.820 3451.00000 66.1000 -26.56250 -1.25000 3.80100 3.80100 13.40000 1.11000 1.09100 20.40000 1.00000 22.00000 23.00000 22.00000 22.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
37.830 3451.00000 66.1000 -26.56250 -1.25000 3.80100 3.80100 13.40000 1.11000 1.09100 20.40000 1.00000 22.00000 23.00000 22.00000 22.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
37.840 3451.00000 66.1000 -26.56250 -1.25000 3.80100 3.80100 13.40000 1.11000 1.09100 20.40000 1.00000 22.00000 23.00000 22.00000 22.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
37.850 3477.00000 66.4000 -23.43750 -1.25000 3.90500 3.90500 12.20000 1.11000 1.09100 21.00000 1.00000 23.00000 22.00000 22.00000 22.00000 0.00000 0.00000 11.4000 0.000 0.000 0.000 0.000
37.860 3477.00000 66.4000 -23.43750 -1.25000 3.90500 3.90500 12.20000 1.11000 1.09100 21.00000 1.00000 23.00000 22.00000 22.00000 22.00000 0.00000 0.00000 11.4000 0.000 0.000 0.000 0.000
37.870 3477.00000 66.4000 -23.43750 -1.25000 3.90500 3.90500 12.20000 1.11000 1.09100 21.00000 1.00000 23.00000 22.00000 22.00000 22.00000 0.00000 0.00000 11.4000 0.000 0.000 0.000 0.000
37.880 3477.00000 66.4000 -23.43750 -1.25000 3.90500 3.90500 12.20000 1.11000 1.09100 21.00000 1.00000 23.00000 22.00000 22.00000 22.00000 0.00000 0.00000 11.4000 0.000 0.000 0.000 0.000
37.890 3477.00000 66.4000 -23.43750 -1.25000 3.90500 3.90500 12.20000 1.11000 1.09100 21.00000 1.00000 23.00000 22.00000 22.00000 22.00000 0.00000 0.00000 11.4000 0.000 0.000 0.000 0.000
37.900 3495.00000 66.9000 -27.34375 -1.25000 3.96400 3.96400 13.70000 1.12000 1.10100 20.30000 1.00000 24.00000 22.00000 23.00000 23.00000 0.00000 0.00000 11.5000 0.000 0.000 0.000 0.000
37.910 3495.00000 66.9000 -27.34375 -1.25000 3.96400 3.96400 13.70000 1.12000 1.10100 20.30000 1.00000 24.00000 22.00000 23.00000 23.00000 0.00000 0.00000 11.5000 0.000 0.000 0.000 0.000
37.920 3495.00000 66.9000 -27.34375 -1.25000 3.96400 3.96400 13.70000 1.12000 1.10100 20.30000 1.00000 24.00000 22.00000 23.00000 23.00000 0.00000 0.00000 11.5000 0.000 0.000 0.000 0.000
37.930 3495.00000 66.9000 -27.34375 -1.25000 3.96400 3.96400 13.70000 1.12000 1.10100 20.30000 1.00000 24.00000 22.00000 23.00000 23.00000 0.00000 0.00000 11.5000 0.000 0.000 0.000 0.000
37.940 3495.00000 66.9000 -27.34375 -1.25000 3.96400 3.96400 13.70000 1.12000 1.10100 20.30000 1.00000 24.00000 22.00000 23.00000 23.00000 0.00000 0.00000 11.5000 0.000 0.000 0.000 0.000
37.950 3577.00000 66.4000 -28.90625 -1.25000 4.05700 4.05700 12.70000 1.12000 1.10100 19.90000 1.00000 23.00000 23.00000 25.00000 24.00000 0.00000 0.00000 11.4000 0.000 0.000 0.000 0.000
37.960 3577.00000 66.4000 -28.90625 -1.25000 4.05700 4.05700 12.70000 1.12000 1.10100 19.90000 1.00000 23.00000 23.00000 25.00000 24.00000 0.00000 0.00000 11.4000 0.000 0.000 0.000 0.000
37.970 3577.00000 66.4000 -28.90625 -1.25000 4.05700 4.05700 12.70000 1.12000 1.10100 19.90000 1.00000 23.00000 23.00000 25.00000 24.00000 0.00000 0.00000 11.4000 0.000 0.000 0.000 0.000
37.980 3577.00000 66.4000 -28.90625 -1.25000 4.05700 4.05700 12.70000 1.12000 1.10100 19.90000 1.00000 23.00000 23.00000 25.00000 24.00000 0.00000 0.00000 11.4000 0.000 0.000 0.000 0.000
37.990 3577.00000 66.4000 -28.90625 -1.25000 4.05700 4.05700 12.70000 1.12000 1.10100 19.90000 1.00000 23.00000 23.00000 25.00000 24.00000 0.00000 0.00000 11.4000 0.000 0.000 0.000 0.000
38.000 3572.00000 67.2000 -25.00000 -1.37500 3.97500 3.97500 13.20000 1.12000 1.10100 20.70000 1.00000 24.00000 24.00000 24.00000 25.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
38.010 3572.00000 67.2000 -25.00000 -1.37500 3.97500 3.97500 13.20000 1.12000 1.10100 20.70000 1.00000 24.00000 24.00000 24.00000 25.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
38.020 3572.00000 67.2000 -25.00000 -1.37500 3.97500 3.97500 13.20000 1.12000 1.10100 20.70000 1.00000 24.00000 24.00000 24.00000 25.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
38.030 3572.00000 67.2000 -25.00000 -1.37500 3.97500 3.97500 13.20000 1.12000 1.10100 20.70000 1.00000 24.00000 24.00000 24.00000 25.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
38.040 3572.00000 67.2000 -25.00000 -1.37500 3.97500 3.97500 13.20000 1.12000 1.10100 20.70000 1.00000 24.00000 24.00000 24.00000 25.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
38.050 3588.00000 66.9000 -25.00000 -1.37500 4.07500 4.07500 12.90000 1.12000 1.10100 20.70000 1.00000 24.00000 25.00000 26.00000 24.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
38.060 3588.00000 66.9000 -25.00000 -1.37500 4.07500 4.07500 12.90000 1.12000 1.10100 20.70000 1.00000 24.00000 25.00000 26.00000 24.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
38.070 3588.00000 66.9000 -25.00000 -1.37500 4.07500 4.07500 12.90000 1.12000 1.10100 20.70000 1.00000 24.00000 25.00000 26.00000 24.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
38.080 3588.00000 66.9000 -25.00000 -1.37500 4.07500 4.07500 12.90000 1.12000 1.10100 20.70000 1.00000 24.00000 25.00000 26.00000 24.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
38.090 3588.00000 66.9000 -25.00000 -1.37500 4.07500 4.07500 12.90000 1.12000 1.10100 20.70000 1.00000 24.00000 25.00000 26.00000 24.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
38.100 3618.00000 67.2000 -25.78125 -1.37500 4.09800 4.09800 13.30000 1.12900 1.11300 20.60000 1.00000 26.00000 25.00000 25.00000 25.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
38.110 3618.00000 67.2000 -25.78125 -1.37500 4.09800 4.09800 13.30000 1.12900 1.11300 20.60000 1.00000 26.00000 25.00000 25.00000 25.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
38.120 3618.00000 67.2000 -25.78125 -1.37500 4.09800 4.09800 13.30000 1.12900 1.11300 20.60000 1.00000 26.00000 25.00000 25.00000 25.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
38.130 3618.00000 67.2000 -25.78125 -1.37500 4.09800 4.09800 13.30000 1.12900 1.11300 20.60000 1.00000 26.00000 25.00000 25.00000 25.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
38.140 3618.00000 67.2000 -25.78125 -1.37500 4.09800 4.09800 13.30000 1.12900 1.11300 20.60000 1.00000 26.00000 25.00000 25.00000 25.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
38.150 3705.00000 67.3000 -21.09375 -1.50000 4.15600 4.15600 12.20000 1.12900 1.11300 21.60000 1.00000 26.00000 25.00000 25.00000 26.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
38.160 3705.00000 67.3000 -21.09375 -1.50000 4.15600 4.15600 12.20000 1.12900 1.11300 21.60000 1.00000 26.00000 25.00000 25.00000 26.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
38.170 3705.00000 67.3000 -21.09375 -1.50000 4.15600 4.15600 12.20000 1.12900 1.11300 21.60000 1.00000 26.00000 25.00000 25.00000 26.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
38.180 3705.00000 67.3000 -21.09375 -1.50000 4.15600 4.15600 12.20000 1.12900 1.11300 21.60000 1.00000 26.00000 25.00000 25.00000 26.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
38.190 3705.00000 67.3000 -21.09375 -1.50000 4.15600 4.15600 12.20000 1.12900 1.11300 21.60000 1.00000 26.00000 25.00000 25.00000 26.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
38.200 3652.00000 67.5000 -24.21875 -1.50000 4.16800 4.16800 12.50000 1.12900 1.11300 20.90000 1.00000 25.00000 26.00000 26.00000 25.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
38.210 3652.00000 67.5000 -24.21875 -1.50000 4.16800 4.16800 12.50000 1.12900 1.11300 20.90000 1.00000 25.00000 26.00000 26.00000 25.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
38.220 3652.00000 67.5000 -24.21875 -1.50000 4.16800 4.16800 12.50000 1.12900 1.11300 20.90000 1.00000 25.00000 26.00000 26.00000 25.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
38.230 3652.00000 67.5000 -24.21875 -1.50000 4.16800 4.16800 12.50000 1.12900 1.11300 20.90000 1.00000 25.00000 26.00000 26.00000 25.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
38.240 3652.00000 67.5000 -24.21875 -1.50000 4.16800 4.16800 12.50000 1.12900 1.11300 20.90000 1.00000 25.00000 26.00000 26.00000 25.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
38.250 3757.00000 66.9000 -21.09375 -1.62500 4.20300 4.20300 13.80000 1.12900 1.11300 21.60000 1.00000 26.00000 27.00000 28.00000 26.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
38.260 3757.00000 66.9000 -21.09375 -1.62500 4.20300 4.20300 13.80000 1.12900 1.11300 21.60000 1.00000 26.00000 27.00000 28.00000 26.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
38.270 3757.00000 66.9000 -21.09375 -1.62500 4.20300 4.20300 13.80000 1.12900 1.11300 21.60000 1.00000 26.00000 27.00000 28.00000 26.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
38.280 3757.00000 66.9000 -21.09375 -1.62500 4.20300 4.20300 13.80000 1.12900 1.11300 21.60000 1.00000 26.00000 27.00000 28.00000 26.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
38.290 3757.00000 66.9000 -21.09375 -1.62500 4.20300 4.20300 13.80000 1.12900 1.11300 21.60000 1.00000 26.00000 27.00000 28.00000 26.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
38.300 3719.00000 67.0000 -18.75000 -1.75000 4.17400 4.17400 12.30000 1.12900 1.11000 22.00000 1.00000 27.00000 28.00000 27.00000 27.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
38.310 3719.00000 67.0000 -18.75000 -1.75000 4.17400 4.17400 12.30000 1.12900 1.11000 22.00000 1.00000 27.00000 28.00000 27.00000 27.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
38.320 3719.00000 67.0000 -18.75000 -1.75000 4.17400 4.17400 12.30000 1.12900 1.11000 22.00000 1.00000 27.00000 28.00000 27.00000 27.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
38.330 3719.00000 67.0000 -18.75000 -1.75000 4.17400 4.17400 12.30000 1.12900 1.11000 22.00000 1.00000 27.00000 28.00000 27.00000 27.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
38.340 3719.00000 67.0000 -18.75000 -1.75000 4.17400 4.17400 12.30000 1.12900 1.11000 22.00000 1.00000 27.00000 28.00000 27.00000 27.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
38.350 3815.00000 66.4000 -21.09375 -1.75000 4.23800 4.23800 12.80000 1.12900 1.11000 21.60000 1.00000 28.00000 28.00000 28.00000 28.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
38.360 3815.00000 66.4000 -21.09375 -1.75000 4.23800 4.23800 12.80000 1.12900 1.11000 21.60000 1.00000 28.00000 28.00000 28.00000 28.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
38.370 3815.00000 66.4000 -21.09375 -1.75000 4.23800 4.23800 12.80000 1.12900 1.11000 21.60000 1.00000 28.00000 28.00000 28.00000 28.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
38.380 3815.00000 66.4000 -21.09375 -1.75000 4.23800 4.23800 12.80000 1.12900 1.11000 21.60000 1.00000 28.00000 28.00000 28.00000 28.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
38.390 3815.00000 66.4000 -21.09375 -1.75000 4.23800 4.23800 12.80000 1.12900 1.11000 21.60000 1.00000 28.00000 28.00000 28.00000 28.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
38.400 3774.00000 66.3000 -17.96875 -1.75000 4.23200 4.23200 12.90000 1.12900 1.11000 22.30000 1.00000 28.00000 29.00000 28.00000 28.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
38.410 3774.00000 66.3000 -17.96875 -1.75000 4.23200 4.23200 12.90000 1.12900 1.11000 22.30000 1.00000 28.00000 29.00000 28.00000 28.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
38.420 3774.00000 66.3000 -17.96875 -1.75000 4.23200 4.23200 12.90000 1.12900 1.11000 22.30000 1.00000 28.00000 29.00000 28.00000 28.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
38.430 3774.00000 66.3000 -17.96875 -1.75000 4.23200 4.23200 12.90000 1.12900 1.11000 22.30000 1.00000 28.00000 29.00000 28.00000 28.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
38.440 3774.00000 66.3000 -17.96875 -1.75000 4.23200 4.23200 12.90000 1.12900 1.11000 22.30000 1.00000 28.00000 29.00000 28.00000 28.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
38.450 3792.00000 66.4000 -13.28125 -1.87500 4.25500 4.25500 12.60000 1.12900 1.11000 23.30000 1.00000 28.00000 29.00000 29.00000 28.00000 0.00000 0.00000 11.0000 0.000 0.000 0.000 0.000
38.460 3792.00000 66.4000 -13.28125 -1.87500 4.25500 4.25500 12.60000 1.12900 1.11000 23.30000 1.00000 28.00000 29.00000 29.00000 28.00000 0.00000 0.00000 11.0000 0.000 0.000 0.000 0.000
38.470 3792.00000 66.4000 -13.28125 -1.87500 4.25500 4.25500 12.60000 1.12900 1.11000 23.30000 1.00000 28.00000 29.00000 29.00000 28.00000 0.00000 0.00000 11.0000 0.000 0.000 0.000 0.000
38.480 3792.00000 66.4000 -13.28125 -1.87500 4.25500 4.25500 12.60000 1.12900 1.11000 23.30000 1.00000 28.00000 29.00000 29.00000 28.00000 0.00000 0.00000 11.0000 0.000 0.000 0.000 0.000
38.490 3792.00000 66.4000 -13.28125 -1.87500 4.25500 4.25500 12.60000 1.12900 1.11000 23.30000 1.00000 28.00000 29.00000 29.00000 28.00000 0.00000 0.00000 11.0000 0.000 0.000 0.000 0.000
38.500 3814.00000 66.0000 -17.96875 -1.75000 4.31400 4.31400 13.70000 1.12900 1.11300 22.20000 1.00000 29.00000 30.00000 31.00000 28.00000 0.00000 0.00000 10.9000 0.000 0.000 0.000 0.000
38.510 3814.00000 66.0000 -17.96875 -1.75000 4.31400 4.31400 13.70000 1.12900 1.11300 22.20000 1.00000 29.00000 30.00000 31.00000 28.00000 0.00000 0.00000 10.9000 0.000 0.000 0.000 0.000
38.520 3814.00000 66.0000 -17.96875 -1.75000 4.31400 4.31400 13.70000 1.12900 1.11300 22.20000 1.00000 29.00000 30.00000 31.00000 28.00000 0.00000 0.00000 10.9000 0.000 0.000 0.000 0.000
38.530 3814.00000 66.0000 -17.96875 -1.75000 4.31400 4.31400 13.70000 1.12900 1.11300 22.20000 1.00000 29.00000 30.00000 31.00000 28.00000 0.00000 0.00000 10.9000 0.000 0.000 0.000 0.000
38.540 3814.00000 66.0000 -17.96875 -1.75000 4.31400 4.31400 13.70000 1.12900 1.11300 22.20000 1.00000 29.00000 30.00000 31.00000 28.00000 0.00000 0.00000 10.9000 0.000 0.000 0.000 0.000
38.550 3859.00000 66.7000 -18.75000 -1.87500 4.43000 4.43000 13.30000 1.12900 1.11300 22.10000 1.00000 30.00000 31.00000 30.00000 30.00000 0.00000 0.00000 10.9000 0.000 0.000 0.000 0.000
38.560 3859.00000 66.7000 -18.75000 -1.87500 4.43000 4.43000 13.30000 1.12900 1.11300 22.10000 1.00000 30.00000 31.00000 30.00000 30.00000 0.00000 0.00000 10.9000 0.000 0.000 0.000 0.000
38.570 3859.00000 66.7000 -18.75000 -1.87500 4.43000 4.43000 13.30000 1.12900 1.11300 22.10000 1.00000 30.00000 31.00000 30.00000 30.00000 0.00000 0.00000 10.9000 0.000 0.000 0.000 0.000
38.580 3859.00000 66.7000 -18.75000 -1.87500 4.43000 4.43000 13.30000 1.12900 1.11300 22.10000 1.00000 30.00000 31.00000 30.00000 30.00000 0.00000 0.00000 10.9000 0.000 0.000 0.000 0.000
38.590 3859.00000 66.7000 -18.75000 -1.87500 4.43000 4.43000 13.30000 1.12900 1.11300 22.10000 1.00000 30.00000 31.00000 30.00000 30.00000 0.00000 0.00000 10.9000 0.000 0.000 0.000 0.000
38.600 3859.00000 66.9000 -18.75000 -1.75000 4.45300 4.45000 13.70000 1.12900 1.11300 22.00000 1.00000 27.00000 24.00000 24.00000 27.00000 0.00000 0.00000 10.9000 0.000 0.000 0.000 0.000
38.610 3859.00000 66.9000 -18.75000 -1.75000 4.45300 4.45000 13.70000 1.12900 1.11300 22.00000 1.00000 27.00000 24.00000 24.00000 27.00000 0.00000 0.00000 10.9000 0.000 0.000 0.000 0.000
38.620 3859.00000 66.9000 -18.75000 -1.75000 4.45300 4.45000 13.70000 1.12900 1.11300 22.00000 1.00000 27.00000 24.00000 24.00000 27.00000 0.00000 0.00000 10.9000 0.000 0.000 0.000 0.000
38.630 3859.00000 66.9000 -18.75000 -1.75000 4.45300 4.45000 13.70000 1.12900 1.11300 22.00000 1.00000 27.00000 24.00000 24.00000 27.00000 0.00000 0.00000 10.9000 0.000 0.000 0.000 0.000
38.640 3859.00000 66.9000 -18.75000 -1.75000 4.45300 4.45000 13.70000 1.12900 1.11300 22.00000 1.00000 27.00000 24.00000 24.00000 27.00000 0.00000 0.00000 10.9000 0.000 0.000 0.000 0.000
38.650 3922.00000 66.7000 -17.96875 -1.75000 4.48300 4.45000 13.30000 1.12900 1.11300 22.20000 1.00000 26.00000 28.00000 27.00000 25.00000 0.00000 0.00000 10.7000 0.000 0.000 0.000 0.000
38.660 3922.00000 66.7000 -17.96875 -1.75000 4.48300 4.45000 13.30000 1.12900 1.11300 22.20000 1.00000 26.00000 28.00000 27.00000 25.00000 0.00000 0.00000 10.7000 0.000 0.000 0.000 0.000
38.670 3922.00000 66.7000 -17.96875 -1.75000 4.48300 4.45000 13.30000 1.12900 1.11300 22.20000 1.00000 26.00000 28.00000 27.00000 25.00000 0.00000 0.00000 10.7000 0.000 0.000 0.000 0.000
38.680 3922.00000 66.7000 -17.96875 -1.75000 4.48300 4.45000 13.30000 1.12900 1.11300 22.20000 1.00000 26.00000 28.00000 27.00000 25.00000 0.00000 0.00000 10.7000 0.000 0.000 0.000 0.000
38.690 3922.00000 66.7000 -17.96875 -1.75000 4.48300 4.45000 13.30000 1.12900 1.11300 22.20000 1.00000 26.00000 28.00000 27.00000 25.00000 0.00000 0.00000 10.7000 0.000 0.000 0.000 0.000
38.700 4064.00000 67.3000 -17.96875 -1.75000 4.51200 4.45000 13.60000 1.12000 1.11300 22.20000 1.00000 29.00000 27.00000 26.00000 30.00000 0.00000 0.00000 10.8000 0.000 0.000 0.000 0.000
38.710 4064.00000 67.3000 -17.96875 -1.75000 4.51200 4.45000 13.60000 1.12000 1.11300 22.20000 1.00000 29.00000 27.00000 26.00000 30.00000 0.00000 0.00000 10.8000 0.000 0.000 0.000 0.000
38.720 4064.00000 67.3000 -17.96875 -1.75000 4.51200 4.45000 13.60000 1.12000 1.11300 22.20000 1.00000 29.00000 27.00000 26.00000 30.00000 0.00000 0.00000 10.8000 0.000 0.000 0.000 0.000
38.730 4064.00000 67.3000 -17.96875 -1.75000 4.51200 4.45000 13.60000 1.12000 1.11300 22.20000 1.00000 29.00000 27.00000 26.00000 30.00000 0.00000 0.00000 10.8000 0.000 0.000 0.000 0.000
38.740 4064.00000 67.3000 -17.96875 -1.75000 4.51200 4.45000 13.60000 1.12000 1.11300 22.20000 1.00000 29.00000 27.00000 26.00000 30.00000 0.00000 0.00000 10.8000 0.000 0.000 0.000 0.000
38.750 3999.00000 67.7000 -17.96875 -1.87500 4.53500 4.45000 13.70000 1.12000 1.11300 22.30000 1.00000 26.00000 29.00000 28.00000 26.00000 0.00000 0.00000 10.7000 0.000 0.000 0.000 0.000
38.760 3999.00000 67.7000 -17.96875 -1.87500 4.53500 4.45000 13.70000 1.12000 1.11300 22.30000 1.00000 26.00000 29.00000 28.00000 26.00000 0.00000 0.00000 10.7000 0.000 0.000 0.000 0.000
38.770 3999.00000 67.7000 -17.96875 -1.87500 4.53500 4.45000 13.70000 1.12000 1.11300 22.30000 1.00000 26.00000 29.00000 28.00000 26.00000 0.00000 0.00000 10.7000 0.000 0.000 0.000 0.000
38.780 3999.00000 67.7000 -17.96875 -1.87500 4.53500 4.45000 13.70000 1.12000 1.11300 22.30000 1.00000 26.00000 29.00000 28.00000 26.00000 0.00000 0.00000 10.7000 0.000 0.000 0.000 0.000
38.790 3999.00000 67.7000 -17.96875 -1.87500 4.53500 4.45000 13.70000 1.12000 1.11300 22.30000 1.00000 26.00000 29.00000 28.00000 26.00000 0.00000 0.00000 10.7000 0.000 0.000 0.000 0.000
38.800 4107.00000 67.3000 -15.62500 -1.87500 4.43000 4.43000 12.60000 1.12000 1.11300 22.80000 1.00000 27.00000 29.00000 30.00000 29.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
38.809 4107.00000 67.3000 -15.62500 -1.87500 4.43000 4.43000 12.60000 1.12000 1.11300 22.80000 1.00000 27.00000 29.00000 30.00000 29.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
38.819 4107.00000 67.3000 -15.62500 -1.87500 4.43000 4.43000 12.60000 1.12000 1.11300 22.80000 1.00000 27.00000 29.00000 30.00000 29.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
38.829 4107.00000 67.3000 -15.62500 -1.87500 4.43000 4.43000 12.60000 1.12000 1.11300 22.80000 1.00000 27.00000 29.00000 30.00000 29.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
38.839 4107.00000 67.3000 -15.62500 -1.87500 4.43000 4.43000 12.60000 1.12000 1.11300 22.80000 1.00000 27.00000 29.00000 30.00000 29.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
38.849 4042.00000 67.5000 -8.59375 -2.00000 4.50000 4.45000 12.70000 1.12000 1.11300 24.30000 1.00000 28.00000 27.00000 26.00000 30.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
38.859 4042.00000 67.5000 -8.59375 -2.00000 4.50000 4.45000 12.70000 1.12000 1.11300 24.30000 1.00000 28.00000 27.00000 26.00000 30.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
38.869 4042.00000 67.5000 -8.59375 -2.00000 4.50000 4.45000 12.70000 1.12000 1.11300 24.30000 1.00000 28.00000 27.00000 26.00000 30.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
38.879 4042.00000 67.5000 -8.59375 -2.00000 4.50000 4.45000 12.70000 1.12000 1.11300 24.30000 1.00000 28.00000 27.00000 26.00000 30.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
38.889 4042.00000 67.5000 -8.59375 -2.00000 4.50000 4.45000 12.70000 1.12000 1.11300 24.30000 1.00000 28.00000 27.00000 26.00000 30.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
38.899 4067.00000 67.0000 -6.25000 -2.00000 4.53500 4.45000 13.70000 1.11000 1.11000 24.80000 1.00000 28.00000 26.00000 26.00000 30.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
38.909 4067.00000 67.0000 -6.25000 -2.00000 4.53500 4.45000 13.70000 1.11000 1.11000 24.80000 1.00000 28.00000 26.00000 26.00000 30.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
38.919 4067.00000 67.0000 -6.25000 -2.00000 4.53500 4.45000 13.70000 1.11000 1.11000 24.80000 1.00000 28.00000 26.00000 26.00000 30.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
38.929 4067.00000 67.0000 -6.25000 -2.00000 4.53500 4.45000 13.70000 1.11000 1.11000 24.80000 1.00000 28.00000 26.00000 26.00000 30.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
38.939 4067.00000 67.0000 -6.25000 -2.00000 4.53500 4.45000 13.70000 1.11000 1.11000 24.80000 1.00000 28.00000 26.00000 26.00000 30.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
38.949 4118.00000 67.3000 -17.18750 -1.87500 4.59300 4.45000 14.00000 1.11000 1.11000 22.40000 1.00000 28.00000 30.00000 27.00000 31.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
38.959 4118.00000 67.3000 -17.18750 -1.87500 4.59300 4.45000 14.00000 1.11000 1.11000 22.40000 1.00000 28.00000 30.00000 27.00000 31.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
38.969 4118.00000 67.3000 -17.18750 -1.87500 4.59300 4.45000 14.00000 1.11000 1.11000 22.40000 1.00000 28.00000 30.00000 27.00000 31.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
38.979 4118.00000 67.3000 -17.18750 -1.87500 4.59300 4.45000 14.00000 1.11000 1.11000 22.40000 1.00000 28.00000 30.00000 27.00000 31.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
38.989 4118.00000 67.3000 -17.18750 -1.87500 4.59300 4.45000 14.00000 1.11000 1.11000 22.40000 1.00000 28.00000 30.00000 27.00000 31.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
38.999 4136.00000 67.5000 -8.59375 -2.12500 4.50600 4.45000 13.00000 1.11000 1.11000 24.20000 1.00000 30.00000 30.00000 28.00000 31.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
39.009 4136.00000 67.5000 -8.59375 -2.12500 4.50600 4.45000 13.00000 1.11000 1.11000 24.20000 1.00000 30.00000 30.00000 28.00000 31.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
39.019 4136.00000 67.5000 -8.59375 -2.12500 4.50600 4.45000 13.00000 1.11000 1.11000 24.20000 1.00000 30.00000 30.00000 28.00000 31.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
39.029 4136.00000 67.5000 -8.59375 -2.12500 4.50600 4.45000 13.00000 1.11000 1.11000 24.20000 1.00000 30.00000 30.00000 28.00000 31.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
39.039 4136.00000 67.5000 -8.59375 -2.12500 4.50600 4.45000 13.00000 1.11000 1.11000 24.20000 1.00000 30.00000 30.00000 28.00000 31.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
39.049 4265.00000 67.0000 -10.93750 -2.00000 4.68100 4.45000 13.00000 1.11000 1.11000 23.70000 1.00000 4.00000 28.00000 29.00000 30.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
39.059 4265.00000 67.0000 -10.93750 -2.00000 4.68100 4.45000 13.00000 1.11000 1.11000 23.70000 1.00000 4.00000 28.00000 29.00000 30.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
39.069 4265.00000 67.0000 -10.93750 -2.00000 4.68100 4.45000 13.00000 1.11000 1.11000 23.70000 1.00000 4.00000 28.00000 29.00000 30.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
39.079 4265.00000 67.0000 -10.93750 -2.00000 4.68100 4.45000 13.00000 1.11000 1.11000 23.70000 1.00000 4.00000 28.00000 29.00000 30.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
39.089 4265.00000 67.0000 -10.93750 -2.00000 4.68100 4.45000 13.00000 1.11000 1.11000 23.70000 1.00000 4.00000 28.00000 29.00000 30.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
39.099 4185.00000 66.9000 -15.62500 -2.00000 4.54700 4.45000 12.70000 1.11000 1.10100 22.80000 1.00000 28.00000 28.00000 31.00000 26.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
39.109 4185.00000 66.9000 -15.62500 -2.00000 4.54700 4.45000 12.70000 1.11000 1.10100 22.80000 1.00000 28.00000 28.00000 31.00000 26.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
39.119 4185.00000 66.9000 -15.62500 -2.00000 4.54700 4.45000 12.70000 1.11000 1.10100 22.80000 1.00000 28.00000 28.00000 31.00000 26.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
39.129 4185.00000 66.9000 -15.62500 -2.00000 4.54700 4.45000 12.70000 1.11000 1.10100 22.80000 1.00000 28.00000 28.00000 31.00000 26.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
39.139 4185.00000 66.9000 -15.62500 -2.00000 4.54700 4.45000 12.70000 1.11000 1.10100 22.80000 1.00000 28.00000 28.00000 31.00000 26.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
39.149 4238.00000 67.2000 -9.37500 -2.00000 4.69300 4.45000 13.40000 1.11000 1.10100 24.10000 1.00000 28.00000 32.00000 28.00000 28.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
39.159 4238.00000 67.2000 -9.37500 -2.00000 4.69300 4.45000 13.40000 1.11000 1.10100 24.10000 1.00000 28.00000 32.00000 28.00000 28.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
39.169 4238.00000 67.2000 -9.37500 -2.00000 4.69300 4.45000 13.40000 1.11000 1.10100 24.10000 1.00000 28.00000 32.00000 28.00000 28.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
39.179 4238.00000 67.2000 -9.37500 -2.00000 4.69300 4.45000 13.40000 1.11000 1.10100 24.10000 1.00000 28.00000 32.00000 28.00000 28.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
39.189 4238.00000 67.2000 -9.37500 -2.00000 4.69300 4.45000 13.40000 1.11000 1.10100 24.10000 1.00000 28.00000 32.00000 28.00000 28.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
39.199 4275.00000 67.7000 -10.93750 -2.12500 4.63400 4.45000 12.90000 1.11000 1.10100 23.80000 1.00000 4.00000 28.00000 27.00000 30.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
39.209 4275.00000 67.7000 -10.93750 -2.12500 4.63400 4.45000 12.90000 1.11000 1.10100 23.80000 1.00000 4.00000 28.00000 27.00000 30.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
39.219 4275.00000 67.7000 -10.93750 -2.12500 4.63400 4.45000 12.90000 1.11000 1.10100 23.80000 1.00000 4.00000 28.00000 27.00000 30.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
39.229 4275.00000 67.7000 -10.93750 -2.12500 4.63400 4.45000 12.90000 1.11000 1.10100 23.80000 1.00000 4.00000 28.00000 27.00000 30.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
39.239 4275.00000 67.7000 -10.93750 -2.12500 4.63400 4.45000 12.90000 1.11000 1.10100 23.80000 1.00000 4.00000 28.00000 27.00000 30.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
39.249 4237.00000 66.3000 -16.40625 -1.87500 4.71600 4.45000 13.50000 1.11000 1.10100 22.60000 1.00000 30.00000 31.00000 28.00000 31.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
39.259 4237.00000 66.3000 -16.40625 -1.87500 4.71600 4.45000 13.50000 1.11000 1.10100 22.60000 1.00000 30.00000 31.00000 28.00000 31.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
39.269 4237.00000 66.3000 -16.40625 -1.87500 4.71600 4.45000 13.50000 1.11000 1.10100 22.60000 1.00000 30.00000 31.00000 28.00000 31.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
39.279 4237.00000 66.3000 -16.40625 -1.87500 4.71600 4.45000 13.50000 1.11000 1.10100 22.60000 1.00000 30.00000 31.00000 28.00000 31.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
39.289 4237.00000 66.3000 -16.40625 -1.87500 4.71600 4.45000 13.50000 1.11000 1.10100 22.60000 1.00000 30.00000 31.00000 28.00000 31.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
39.299 4428.00000 66.6000 -100.00000 -2.12500 4.71000 4.45000 13.30000 1.07500 1.07800 25.90000 1.00000 33.00000 29.00000 33.00000 29.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
39.309 4428.00000 66.6000 -100.00000 -2.12500 4.71000 4.45000 13.30000 1.07500 1.07800 25.90000 1.00000 33.00000 29.00000 33.00000 29.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
39.319 4428.00000 66.6000 -100.00000 -2.12500 4.71000 4.45000 13.30000 1.07500 1.07800 25.90000 1.00000 33.00000 29.00000 33.00000 29.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
39.329 4428.00000 66.6000 -100.00000 -2.12500 4.71000 4.45000 13.30000 1.07500 1.07800 25.90000 1.00000 33.00000 29.00000 33.00000 29.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
39.339 4428.00000 66.6000 -100.00000 -2.12500 4.71000 4.45000 13.30000 1.07500 1.07800 25.90000 1.00000 33.00000 29.00000 33.00000 29.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
39.349 4417.00000 67.5000 -12.50000 -2.12500 4.71000 4.45000 12.90000 1.07500 1.07800 23.40000 1.00000 33.00000 4.00000 29.00000 29.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
39.359 4417.00000 67.5000 -12.50000 -2.12500 4.71000 4.45000 12.90000 1.07500 1.07800 23.40000 1.00000 33.00000 4.00000 29.00000 29.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
39.369 4417.00000 67.5000 -12.50000 -2.12500 4.71000 4.45000 12.90000 1.07500 1.07800 23.40000 1.00000 33.00000 4.00000 29.00000 29.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
39.379 4417.00000 67.5000 -12.50000 -2.12500 4.71000 4.45000 12.90000 1.07500 1.07800 23.40000 1.00000 33.00000 4.00000 29.00000 29.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
39.389 4417.00000 67.5000 -12.50000 -2.12500 4.71000 4.45000 12.90000 1.07500 1.07800 23.40000 1.00000 33.00000 4.00000 29.00000 29.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
39.399 4354.00000 65.8000 -16.40625 -2.00000 4.69300 4.45000 12.90000 1.07500 1.07800 22.50000 1.00000 29.00000 30.00000 28.00000 33.00000 0.00000 0.00000 12.8000 0.000 0.000 0.000 0.000
39.409 4354.00000 65.8000 -16.40625 -2.00000 4.69300 4.45000 12.90000 1.07500 1.07800 22.50000 1.00000 29.00000 30.00000 28.00000 33.00000 0.00000 0.00000 12.8000 0.000 0.000 0.000 0.000
39.419 4354.00000 65.8000 -16.40625 -2.00000 4.69300 4.45000 12.90000 1.07500 1.07800 22.50000 1.00000 29.00000 30.00000 28.00000 33.00000 0.00000 0.00000 12.8000 0.000 0.000 0.000 0.000
39.429 4354.00000 65.8000 -16.40625 -2.00000 4.69300 4.45000 12.90000 1.07500 1.07800 22.50000 1.00000 29.00000 30.00000 28.00000 33.00000 0.00000 0.00000 12.8000 0.000 0.000 0.000 0.000
39.439 4354.00000 65.8000 -16.40625 -2.00000 4.69300 4.45000 12.90000 1.07500 1.07800 22.50000 1.00000 29.00000 30.00000 28.00000 33.00000 0.00000 0.00000 12.8000 0.000 0.000 0.000 0.000
39.449 4376.00000 66.0000 -15.62500 -1.87500 4.79700 4.45000 13.10000 1.07500 1.07800 22.80000 1.00000 29.00000 29.00000 33.00000 30.00000 0.00000 0.00000 12.8000 0.000 0.000 0.000 0.000
39.459 4376.00000 66.0000 -15.62500 -1.87500 4.79700 4.45000 13.10000 1.07500 1.07800 22.80000 1.00000 29.00000 29.00000 33.00000 30.00000 0.00000 0.00000 12.8000 0.000 0.000 0.000 0.000
39.469 4376.00000 66.0000 -15.62500 -1.87500 4.79700 4.45000 13.10000 1.07500 1.07800 22.80000 1.00000 29.00000 29.00000 33.00000 30.00000 0.00000 0.00000 12.8000 0.000 0.000 0.000 0.000
39.479 4376.00000 66.0000 -15.62500 -1.87500 4.79700 4.45000 13.10000 1.07500 1.07800 22.80000 1.00000 29.00000 29.00000 33.00000 30.00000 0.00000 0.00000 12.8000 0.000 0.000 0.000 0.000
39.489 4376.00000 66.0000 -15.62500 -1.87500 4.79700 4.45000 13.10000 1.07500 1.07800 22.80000 1.00000 29.00000 29.00000 33.00000 30.00000 0.00000 0.00000 12.8000 0.000 0.000 0.000 0.000
39.499 4499.00000 49.0000 -13.28125 -2.00000 4.68100 4.45000 12.50000 1.09800 1.06600 23.30000 1.00000 32.00000 30.00000 33.00000 30.00000 0.00000 0.00000 12.8000 0.000 0.000 0.000 0.000
39.509 4499.00000 49.0000 -13.28125 -2.00000 4.68100 4.45000 12.50000 1.09800 1.06600 23.30000 1.00000 32.00000 30.00000 33.00000 30.00000 0.00000 0.00000 12.8000 0.000 0.000 0.000 0.000
39.519 4499.00000 49.0000 -13.28125 -2.00000 4.68100 4.45000 12.50000 1.09800 1.06600 23.30000 1.00000 32.00000 30.00000 33.00000 30.00000 0.00000 0.00000 12.8000 0.000 0.000 0.000 0.000
39.529 4499.00000 49.0000 -13.28125 -2.00000 4.68100 4.45000 12.50000 1.09800 1.06600 23.30000 1.00000 32.00000 30.00000 33.00000 30.00000 0.00000 0.00000 12.8000 0.000 0.000 0.000 0.000
39.539 4499.00000 49.0000 -13.28125 -2.00000 4.68100 4.45000 12.50000 1.09800 1.06600 23.30000 1.00000 32.00000 30.00000 33.00000 30.00000 0.00000 0.00000 12.8000 0.000 0.000 0.000 0.000
39.549 4446.00000 15.2000 -44.53125 -1.00000 2.20300 2.20300 13.50000 1.09800 1.06600 11.70000 1.00000 10.00000 6.00000 7.00000 6.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
39.559 4446.00000 15.2000 -44.53125 -1.00000 2.20300 2.20300 13.50000 1.09800 1.06600 11.70000 1.00000 10.00000 6.00000 7.00000 6.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
39.569 4446.00000 15.2000 -44.53125 -1.00000 2.20300 2.20300 13.50000 1.09800 1.06600 11.70000 1.00000 10.00000 6.00000 7.00000 6.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
39.579 4446.00000 15.2000 -44.53125 -1.00000 2.20300 2.20300 13.50000 1.09800 1.06600 11.70000 1.00000 10.00000 6.00000 7.00000 6.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
39.589 4446.00000 15.2000 -44.53125 -1.00000 2.20300 2.20300 13.50000 1.09800 1.06600 11.70000 1.00000 10.00000 6.00000 7.00000 6.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
39.599 3993.00000 15.1000 -44.53125 0.00000 1.66700 1.66700 12.70000 1.09800 1.06600 7.90000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
39.609 3993.00000 15.1000 -44.53125 0.00000 1.66700 1.66700 12.70000 1.09800 1.06600 7.90000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
39.619 3993.00000 15.1000 -44.53125 0.00000 1.66700 1.66700 12.70000 1.09800 1.06600 7.90000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
39.629 3993.00000 15.1000 -44.53125 0.00000 1.66700 1.66700 12.70000 1.09800 1.06600 7.90000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
39.639 3993.00000 15.1000 -44.53125 0.00000 1.66700 1.66700 12.70000 1.09800 1.06600 7.90000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
39.649 3872.00000 15.1000 -44.53125 0.00000 1.80100 1.80100 12.70000 1.09800 1.06600 6.50000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
39.659 3872.00000 15.1000 -44.53125 0.00000 1.80100 1.80100 12.70000 1.09800 1.06600 6.50000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
39.669 3872.00000 15.1000 -44.53125 0.00000 1.80100 1.80100 12.70000 1.09800 1.06600 6.50000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
39.679 3872.00000 15.1000 -44.53125 0.00000 1.80100 1.80100 12.70000 1.09800 1.06600 6.50000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
39.689 3872.00000 15.1000 -44.53125 0.00000 1.80100 1.80100 12.70000 1.09800 1.06600 6.50000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
39.699 3746.00000 15.1000 -44.53125 0.00000 3.46800 3.46800 13.00000 0.90300 1.08500 6.40000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 13.2000 0.000 0.000 0.000 0.000
39.709 3746.00000 15.1000 -44.53125 0.00000 3.46800 3.46800 13.00000 0.90300 1.08500 6.40000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 13.2000 0.000 0.000 0.000 0.000
39.719 3746.00000 15.1000 -44.53125 0.00000 3.46800 3.46800 13.00000 0.90300 1.08500 6.40000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 13.2000 0.000 0.000 0.000 0.000
39.729 3746.00000 15.1000 -44.53125 0.00000 3.46800 3.46800 13.00000 0.90300 1.08500 6.40000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 13.2000 0.000 0.000 0.000 0.000
39.739 3746.00000 15.1000 -44.53125 0.00000 3.46800 3.46800 13.00000 0.90300 1.08500 6.40000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 13.2000 0.000 0.000 0.000 0.000
39.749 3629.00000 15.2000 -44.53125 0.00000 2.50600 2.50600 13.30000 0.90300 1.08500 5.10000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
39.759 3629.00000 15.2000 -44.53125 0.00000 2.50600 2.50600 13.30000 0.90300 1.08500 5.10000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
39.769 3629.00000 15.2000 -44.53125 0.00000 2.50600 2.50600 13.30000 0.90300 1.08500 5.10000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
39.779 3629.00000 15.2000 -44.53125 0.00000 2.50600 2.50600 13.30000 0.90300 1.08500 5.10000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
39.789 3629.00000 15.2000 -44.53125 0.00000 2.50600 2.50600 13.30000 0.90300 1.08500 5.10000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
39.799 3596.00000 15.4000 -44.53125 0.00000 2.53500 2.53500 12.80000 0.90300 1.08500 5.00000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
39.809 3596.00000 15.4000 -44.53125 0.00000 2.53500 2.53500 12.80000 0.90300 1.08500 5.00000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
39.819 3596.00000 15.4000 -44.53125 0.00000 2.53500 2.53500 12.80000 0.90300 1.08500 5.00000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
39.829 3596.00000 15.4000 -44.53125 0.00000 2.53500 2.53500 12.80000 0.90300 1.08500 5.00000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
39.839 3596.00000 15.4000 -44.53125 0.00000 2.53500 2.53500 12.80000 0.90300 1.08500 5.00000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
39.849 3466.00000 15.4000 -44.53125 0.00000 2.27900 2.27900 11.90000 0.90300 1.08500 5.10000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 14.6000 0.000 0.000 0.000 0.000
39.859 3466.00000 15.4000 -44.53125 0.00000 2.27900 2.27900 11.90000 0.90300 1.08500 5.10000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 14.6000 0.000 0.000 0.000 0.000
39.869 3466.00000 15.4000 -44.53125 0.00000 2.27900 2.27900 11.90000 0.90300 1.08500 5.10000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 14.6000 0.000 0.000 0.000 0.000
39.879 3466.00000 15.4000 -44.53125 0.00000 2.27900 2.27900 11.90000 0.90300 1.08500 5.10000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 14.6000 0.000 0.000 0.000 0.000
39.889 3466.00000 15.4000 -44.53125 0.00000 2.27900 2.27900 11.90000 0.90300 1.08500 5.10000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 14.6000 0.000 0.000 0.000 0.000
39.899 3366.00000 15.4000 -44.53125 0.00000 2.23800 2.23800 12.80000 0.92800 1.05900 4.90000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 16.2000 0.000 0.000 0.000 0.000
39.909 3366.00000 15.4000 -44.53125 0.00000 2.23800 2.23800 12.80000 0.92800 1.05900 4.90000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 16.2000 0.000 0.000 0.000 0.000
39.919 3366.00000 15.4000 -44.53125 0.00000 2.23800 2.23800 12.80000 0.92800 1.05900 4.90000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 16.2000 0.000 0.000 0.000 0.000
39.929 3366.00000 15.4000 -44.53125 0.00000 2.23800 2.23800 12.80000 0.92800 1.05900 4.90000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 16.2000 0.000 0.000 0.000 0.000
39.939 3366.00000 15.4000 -44.53125 0.00000 2.23800 2.23800 12.80000 0.92800 1.05900 4.90000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 16.2000 0.000 0.000 0.000 0.000
39.949 3281.00000 15.4000 -44.53125 0.00000 2.59400 2.59400 13.00000 0.92800 1.05900 4.50000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 16.1000 0.000 0.000 0.000 0.000
39.959 3281.00000 15.4000 -44.53125 0.00000 2.59400 2.59400 13.00000 0.92800 1.05900 4.50000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 16.1000 0.000 0.000 0.000 0.000
39.969 3281.00000 15.4000 -44.53125 0.00000 2.59400 2.59400 13.00000 0.92800 1.05900 4.50000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 16.1000 0.000 0.000 0.000 0.000
39.979 3281.00000 15.4000 -44.53125 0.00000 2.59400 2.59400 13.00000 0.92800 1.05900 4.50000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 16.1000 0.000 0.000 0.000 0.000
39.989 3281.00000 15.4000 -44.53125 0.00000 2.59400 2.59400 13.00000 0.92800 1.05900 4.50000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 16.1000 0.000 0.000 0.000 0.000
39.999 3245.00000 15.1000 -44.53125 0.00000 2.53000 2.53000 13.20000 0.92800 1.05900 4.50000 1.00000 5.00000 5.00000 4.00000 5.00000 0.00000 0.00000 16.2000 0.000 0.000 0.000 0.000
40.009 3245.00000 15.1000 -44.53125 0.00000 2.53000 2.53000 13.20000 0.92800 1.05900 4.50000 1.00000 5.00000 5.00000 4.00000 5.00000 0.00000 0.00000 16.2000 0.000 0.000 0.000 0.000
40.019 3245.00000 15.1000 -44.53125 0.00000 2.53000 2.53000 13.20000 0.92800 1.05900 4.50000 1.00000 5.00000 5.00000 4.00000 5.00000 0.00000 0.00000 16.2000 0.000 0.000 0.000 0.000
40.029 3245.00000 15.1000 -44.53125 0.00000 2.53000 2.53000 13.20000 0.92800 1.05900 4.50000 1.00000 5.00000 5.00000 4.00000 5.00000 0.00000 0.00000 16.2000 0.000 0.000 0.000 0.000
40.039 3245.00000 15.1000 -44.53125 0.00000 2.53000 2.53000 13.20000 0.92800 1.05900 4.50000 1.00000 5.00000 5.00000 4.00000 5.00000 0.00000 0.00000 16.2000 0.000 0.000 0.000 0.000
40.049 3232.00000 15.1000 -44.53125 0.00000 2.16800 2.16800 13.40000 0.92800 1.05900 4.50000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
40.059 3232.00000 15.1000 -44.53125 0.00000 2.16800 2.16800 13.40000 0.92800 1.05900 4.50000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
40.069 3232.00000 15.1000 -44.53125 0.00000 2.16800 2.16800 13.40000 0.92800 1.05900 4.50000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
40.079 3232.00000 15.1000 -44.53125 0.00000 2.16800 2.16800 13.40000 0.92800 1.05900 4.50000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
40.089 3232.00000 15.1000 -44.53125 0.00000 2.16800 2.16800 13.40000 0.92800 1.05900 4.50000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
40.099 3117.00000 15.2000 -44.53125 0.00000 2.32600 2.32600 13.40000 1.04300 0.99900 4.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
40.109 3117.00000 15.2000 -44.53125 0.00000 2.32600 2.32600 13.40000 1.04300 0.99900 4.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
40.119 3117.00000 15.2000 -44.53125 0.00000 2.32600 2.32600 13.40000 1.04300 0.99900 4.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
40.129 3117.00000 15.2000 -44.53125 0.00000 2.32600 2.32600 13.40000 1.04300 0.99900 4.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
40.139 3117.00000 15.2000 -44.53125 0.00000 2.32600 2.32600 13.40000 1.04300 0.99900 4.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
40.149 3159.00000 15.1000 -44.53125 0.00000 1.74800 1.74800 13.70000 1.04300 0.99900 4.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
40.159 3159.00000 15.1000 -44.53125 0.00000 1.74800 1.74800 13.70000 1.04300 0.99900 4.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
40.169 3159.00000 15.1000 -44.53125 0.00000 1.74800 1.74800 13.70000 1.04300 0.99900 4.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
40.179 3159.00000 15.1000 -44.53125 0.00000 1.74800 1.74800 13.70000 1.04300 0.99900 4.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
40.189 3159.00000 15.1000 -44.53125 0.00000 1.74800 1.74800 13.70000 1.04300 0.99900 4.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
40.199 3064.00000 15.1000 -44.53125 0.00000 1.95200 1.95200 13.50000 1.04300 0.99900 4.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
40.209 3064.00000 15.1000 -44.53125 0.00000 1.95200 1.95200 13.50000 1.04300 0.99900 4.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
40.219 3064.00000 15.1000 -44.53125 0.00000 1.95200 1.95200 13.50000 1.04300 0.99900 4.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
40.229 3064.00000 15.1000 -44.53125 0.00000 1.95200 1.95200 13.50000 1.04300 0.99900 4.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
40.239 3064.00000 15.1000 -44.53125 0.00000 1.95200 1.95200 13.50000 1.04300 0.99900 4.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
40.249 3042.00000 15.4000 -44.53125 0.00000 1.52100 1.52100 12.30000 1.04300 0.99900 4.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
40.259 3042.00000 15.4000 -44.53125 0.00000 1.52100 1.52100 12.30000 1.04300 0.99900 4.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
40.269 3042.00000 15.4000 -44.53125 0.00000 1.52100 1.52100 12.30000 1.04300 0.99900 4.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
40.279 3042.00000 15.4000 -44.53125 0.00000 1.52100 1.52100 12.30000 1.04300 0.99900 4.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
40.289 3042.00000 15.4000 -44.53125 0.00000 1.52100 1.52100 12.30000 1.04300 0.99900 4.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
40.299 2992.00000 15.1000 -44.53125 0.00000 1.64900 1.64900 13.40000 1.14500 1.00800 4.10000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
40.309 2992.00000 15.1000 -44.53125 0.00000 1.64900 1.64900 13.40000 1.14500 1.00800 4.10000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
40.319 2992.00000 15.1000 -44.53125 0.00000 1.64900 1.64900 13.40000 1.14500 1.00800 4.10000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
40.329 2992.00000 15.1000 -44.53125 0.00000 1.64900 1.64900 13.40000 1.14500 1.00800 4.10000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
40.339 2992.00000 15.1000 -44.53125 0.00000 1.64900 1.64900 13.40000 1.14500 1.00800 4.10000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
40.349 2949.00000 15.1000 -44.53125 0.00000 1.55000 1.55000 13.40000 1.14500 1.00800 4.10000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 10.7000 0.000 0.000 0.000 0.000
40.359 2949.00000 15.1000 -44.53125 0.00000 1.55000 1.55000 13.40000 1.14500 1.00800 4.10000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 10.7000 0.000 0.000 0.000 0.000
40.369 2949.00000 15.1000 -44.53125 0.00000 1.55000 1.55000 13.40000 1.14500 1.00800 4.10000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 10.7000 0.000 0.000 0.000 0.000
40.379 2949.00000 15.1000 -44.53125 0.00000 1.55000 1.55000 13.40000 1.14500 1.00800 4.10000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 10.7000 0.000 0.000 0.000 0.000
40.389 2949.00000 15.1000 -44.53125 0.00000 1.55000 1.55000 13.40000 1.14500 1.00800 4.10000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 10.7000 0.000 0.000 0.000 0.000
40.399 2949.00000 15.1000 -44.53125 0.00000 1.55000 1.55000 13.40000 1.14500 1.00800 4.10000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 10.7000 0.000 0.000 0.000 0.000
40.409 2801.00000 15.2000 -44.53125 0.00000 1.83600 1.83600 13.30000 1.14500 1.00800 4.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 10.8000 0.000 0.000 0.000 0.000
40.419 2801.00000 15.2000 -44.53125 0.00000 1.83600 1.83600 13.30000 1.14500 1.00800 4.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 10.8000 0.000 0.000 0.000 0.000
40.429 2801.00000 15.2000 -44.53125 0.00000 1.83600 1.83600 13.30000 1.14500 1.00800 4.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 10.8000 0.000 0.000 0.000 0.000
40.439 2801.00000 15.2000 -44.53125 0.00000 1.83600 1.83600 13.30000 1.14500 1.00800 4.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 10.8000 0.000 0.000 0.000 0.000
40.449 2801.00000 15.2000 -44.53125 0.00000 1.83600 1.83600 13.30000 1.14500 1.00800 4.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 10.8000 0.000 0.000 0.000 0.000
40.459 2643.00000 15.1000 -44.53125 0.00000 2.31400 2.31400 13.50000 1.08800 1.04600 4.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 10.7000 0.000 0.000 0.000 0.000
40.469 2643.00000 15.1000 -44.53125 0.00000 2.31400 2.31400 13.50000 1.08800 1.04600 4.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 10.7000 0.000 0.000 0.000 0.000
40.479 2643.00000 15.1000 -44.53125 0.00000 2.31400 2.31400 13.50000 1.08800 1.04600 4.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 10.7000 0.000 0.000 0.000 0.000
40.489 2643.00000 15.1000 -44.53125 0.00000 2.31400 2.31400 13.50000 1.08800 1.04600 4.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 10.7000 0.000 0.000 0.000 0.000
40.499 2643.00000 15.1000 -44.53125 0.00000 2.31400 2.31400 13.50000 1.08800 1.04600 4.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 10.7000 0.000 0.000 0.000 0.000
40.509 2615.00000 15.1000 -44.53125 0.00000 1.52100 1.52100 13.60000 1.08800 1.04600 4.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 10.7000 0.000 0.000 0.000 0.000
40.519 2615.00000 15.1000 -44.53125 0.00000 1.52100 1.52100 13.60000 1.08800 1.04600 4.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 10.7000 0.000 0.000 0.000 0.000
40.529 2615.00000 15.1000 -44.53125 0.00000 1.52100 1.52100 13.60000 1.08800 1.04600 4.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 10.7000 0.000 0.000 0.000 0.000
40.539 2615.00000 15.1000 -44.53125 0.00000 1.52100 1.52100 13.60000 1.08800 1.04600 4.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 10.7000 0.000 0.000 0.000 0.000
40.549 2615.00000 15.1000 -44.53125 0.00000 1.52100 1.52100 13.60000 1.08800 1.04600 4.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 10.7000 0.000 0.000 0.000 0.000
40.559 2478.00000 15.2000 -44.53125 0.00000 2.13300 2.13300 12.70000 1.08800 1.04600 4.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 10.7000 0.000 0.000 0.000 0.000
40.569 2478.00000 15.2000 -44.53125 0.00000 2.13300 2.13300 12.70000 1.08800 1.04600 4.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 10.7000 0.000 0.000 0.000 0.000
40.579 2478.00000 15.2000 -44.53125 0.00000 2.13300 2.13300 12.70000 1.08800 1.04600 4.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 10.7000 0.000 0.000 0.000 0.000
40.589 2478.00000 15.2000 -44.53125 0.00000 2.13300 2.13300 12.70000 1.08800 1.04600 4.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 10.7000 0.000 0.000 0.000 0.000
40.599 2478.00000 15.2000 -44.53125 0.00000 2.13300 2.13300 12.70000 1.08800 1.04600 4.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 10.7000 0.000 0.000 0.000 0.000
40.609 2391.00000 15.1000 -44.53125 0.00000 2.18000 2.18000 13.30000 1.08800 1.04600 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 10.7000 0.000 0.000 0.000 0.000
40.619 2391.00000 15.1000 -44.53125 0.00000 2.18000 2.18000 13.30000 1.08800 1.04600 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 10.7000 0.000 0.000 0.000 0.000
40.629 2391.00000 15.1000 -44.53125 0.00000 2.18000 2.18000 13.30000 1.08800 1.04600 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 10.7000 0.000 0.000 0.000 0.000
40.639 2391.00000 15.1000 -44.53125 0.00000 2.18000 2.18000 13.30000 1.08800 1.04600 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 10.7000 0.000 0.000 0.000 0.000
40.649 2391.00000 15.1000 -44.53125 0.00000 2.18000 2.18000 13.30000 1.08800 1.04600 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 10.7000 0.000 0.000 0.000 0.000
40.659 2303.00000 15.4000 -44.53125 0.00000 2.12700 2.12700 13.30000 0.25800 1.09400 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
40.669 2303.00000 15.4000 -44.53125 0.00000 2.12700 2.12700 13.30000 0.25800 1.09400 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
40.679 2303.00000 15.4000 -44.53125 0.00000 2.12700 2.12700 13.30000 0.25800 1.09400 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
40.689 2303.00000 15.4000 -44.53125 0.00000 2.12700 2.12700 13.30000 0.25800 1.09400 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
40.699 2303.00000 15.4000 -44.53125 0.00000 2.12700 2.12700 13.30000 0.25800 1.09400 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
40.709 2118.00000 15.2000 -44.53125 0.00000 1.55000 1.55000 12.90000 0.25800 1.09400 4.70000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
40.719 2118.00000 15.2000 -44.53125 0.00000 1.55000 1.55000 12.90000 0.25800 1.09400 4.70000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
40.729 2118.00000 15.2000 -44.53125 0.00000 1.55000 1.55000 12.90000 0.25800 1.09400 4.70000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
40.739 2118.00000 15.2000 -44.53125 0.00000 1.55000 1.55000 12.90000 0.25800 1.09400 4.70000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
40.749 2118.00000 15.2000 -44.53125 0.00000 1.55000 1.55000 12.90000 0.25800 1.09400 4.70000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
40.759 2013.00000 15.2000 -44.53125 0.00000 1.53900 1.53900 13.30000 0.25800 1.09400 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
40.769 2013.00000 15.2000 -44.53125 0.00000 1.53900 1.53900 13.30000 0.25800 1.09400 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
40.779 2013.00000 15.2000 -44.53125 0.00000 1.53900 1.53900 13.30000 0.25800 1.09400 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
40.789 2013.00000 15.2000 -44.53125 0.00000 1.53900 1.53900 13.30000 0.25800 1.09400 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
40.799 2013.00000 15.2000 -44.53125 0.00000 1.53900 1.53900 13.30000 0.25800 1.09400 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
40.809 1984.00000 15.1000 -44.53125 0.00000 1.43400 1.43400 13.40000 0.25800 1.09400 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
40.819 1984.00000 15.1000 -44.53125 0.00000 1.43400 1.43400 13.40000 0.25800 1.09400 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
40.829 1984.00000 15.1000 -44.53125 0.00000 1.43400 1.43400 13.40000 0.25800 1.09400 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
40.839 1984.00000 15.1000 -44.53125 0.00000 1.43400 1.43400 13.40000 0.25800 1.09400 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
40.849 1984.00000 15.1000 -44.53125 0.00000 1.43400 1.43400 13.40000 0.25800 1.09400 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
40.859 1974.00000 15.2000 -44.53125 0.00000 2.01700 2.01700 13.50000 0.25500 1.10700 4.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.4000 0.000 0.000 0.000 0.000
40.869 1974.00000 15.2000 -44.53125 0.00000 2.01700 2.01700 13.50000 0.25500 1.10700 4.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.4000 0.000 0.000 0.000 0.000
40.879 1974.00000 15.2000 -44.53125 0.00000 2.01700 2.01700 13.50000 0.25500 1.10700 4.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.4000 0.000 0.000 0.000 0.000
40.889 1974.00000 15.2000 -44.53125 0.00000 2.01700 2.01700 13.50000 0.25500 1.10700 4.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.4000 0.000 0.000 0.000 0.000
40.899 1974.00000 15.2000 -44.53125 0.00000 2.01700 2.01700 13.50000 0.25500 1.10700 4.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.4000 0.000 0.000 0.000 0.000
40.909 1997.00000 15.2000 -44.53125 0.00000 1.95800 1.95800 12.70000 0.25500 1.10700 4.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
40.919 1997.00000 15.2000 -44.53125 0.00000 1.95800 1.95800 12.70000 0.25500 1.10700 4.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
40.929 1997.00000 15.2000 -44.53125 0.00000 1.95800 1.95800 12.70000 0.25500 1.10700 4.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
40.939 1997.00000 15.2000 -44.53125 0.00000 1.95800 1.95800 12.70000 0.25500 1.10700 4.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
40.949 1997.00000 15.2000 -44.53125 0.00000 1.95800 1.95800 12.70000 0.25500 1.10700 4.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
40.959 2004.00000 15.1000 -44.53125 0.00000 1.69600 1.69600 13.20000 0.25500 1.10700 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
40.969 2004.00000 15.1000 -44.53125 0.00000 1.69600 1.69600 13.20000 0.25500 1.10700 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
40.979 2004.00000 15.1000 -44.53125 0.00000 1.69600 1.69600 13.20000 0.25500 1.10700 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
40.989 2004.00000 15.1000 -44.53125 0.00000 1.69600 1.69600 13.20000 0.25500 1.10700 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
40.999 2004.00000 15.1000 -44.53125 0.00000 1.69600 1.69600 13.20000 0.25500 1.10700 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
41.009 2046.00000 15.2000 -44.53125 0.00000 1.87700 1.87700 13.40000 0.25500 1.10700 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.7000 0.000 0.000 0.000 0.000
41.019 2046.00000 15.2000 -44.53125 0.00000 1.87700 1.87700 13.40000 0.25500 1.10700 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.7000 0.000 0.000 0.000 0.000
41.029 2046.00000 15.2000 -44.53125 0.00000 1.87700 1.87700 13.40000 0.25500 1.10700 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.7000 0.000 0.000 0.000 0.000
41.039 2046.00000 15.2000 -44.53125 0.00000 1.87700 1.87700 13.40000 0.25500 1.10700 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.7000 0.000 0.000 0.000 0.000
41.049 2046.00000 15.2000 -44.53125 0.00000 1.87700 1.87700 13.40000 0.25500 1.10700 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.7000 0.000 0.000 0.000 0.000
41.059 2000.00000 15.2000 -44.53125 0.00000 1.85900 1.85900 13.30000 0.67000 1.06200 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
41.069 2000.00000 15.2000 -44.53125 0.00000 1.85900 1.85900 13.30000 0.67000 1.06200 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
41.079 2000.00000 15.2000 -44.53125 0.00000 1.85900 1.85900 13.30000 0.67000 1.06200 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
41.089 2000.00000 15.2000 -44.53125 0.00000 1.85900 1.85900 13.30000 0.67000 1.06200 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
41.099 2000.00000 15.2000 -44.53125 0.00000 1.85900 1.85900 13.30000 0.67000 1.06200 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
41.109 1996.00000 15.2000 -44.53125 0.00000 1.88300 1.88300 13.40000 0.67000 1.06200 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.4000 0.000 0.000 0.000 0.000
41.119 1996.00000 15.2000 -44.53125 0.00000 1.88300 1.88300 13.40000 0.67000 1.06200 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.4000 0.000 0.000 0.000 0.000
41.129 1996.00000 15.2000 -44.53125 0.00000 1.88300 1.88300 13.40000 0.67000 1.06200 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.4000 0.000 0.000 0.000 0.000
41.139 1996.00000 15.2000 -44.53125 0.00000 1.88300 1.88300 13.40000 0.67000 1.06200 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.4000 0.000 0.000 0.000 0.000
41.149 1996.00000 15.2000 -44.53125 0.00000 1.88300 1.88300 13.40000 0.67000 1.06200 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.4000 0.000 0.000 0.000 0.000
41.159 1992.00000 15.1000 -44.53125 0.00000 1.57400 1.57400 13.20000 0.67000 1.06200 4.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
41.169 1992.00000 15.1000 -44.53125 0.00000 1.57400 1.57400 13.20000 0.67000 1.06200 4.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
41.179 1992.00000 15.1000 -44.53125 0.00000 1.57400 1.57400 13.20000 0.67000 1.06200 4.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
41.189 1992.00000 15.1000 -44.53125 0.00000 1.57400 1.57400 13.20000 0.67000 1.06200 4.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
41.199 1992.00000 15.1000 -44.53125 0.00000 1.57400 1.57400 13.20000 0.67000 1.06200 4.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
41.209 2012.00000 15.1000 -44.53125 0.00000 1.50400 1.50400 13.50000 0.67000 1.06200 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.4000 0.000 0.000 0.000 0.000
41.219 2012.00000 15.1000 -44.53125 0.00000 1.50400 1.50400 13.50000 0.67000 1.06200 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.4000 0.000 0.000 0.000 0.000
41.229 2012.00000 15.1000 -44.53125 0.00000 1.50400 1.50400 13.50000 0.67000 1.06200 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.4000 0.000 0.000 0.000 0.000
41.239 2012.00000 15.1000 -44.53125 0.00000 1.50400 1.50400 13.50000 0.67000 1.06200 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.4000 0.000 0.000 0.000 0.000
41.249 2012.00000 15.1000 -44.53125 0.00000 1.50400 1.50400 13.50000 0.67000 1.06200 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.4000 0.000 0.000 0.000 0.000
41.259 1966.00000 15.1000 -44.53125 0.00000 1.30000 1.30000 13.50000 1.12000 0.35700 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.1000 0.000 0.000 0.000 0.000
41.269 1966.00000 15.1000 -44.53125 0.00000 1.30000 1.30000 13.50000 1.12000 0.35700 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.1000 0.000 0.000 0.000 0.000
41.279 1966.00000 15.1000 -44.53125 0.00000 1.30000 1.30000 13.50000 1.12000 0.35700 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.1000 0.000 0.000 0.000 0.000
41.289 1966.00000 15.1000 -44.53125 0.00000 1.30000 1.30000 13.50000 1.12000 0.35700 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.1000 0.000 0.000 0.000 0.000
41.299 1966.00000 15.1000 -44.53125 0.00000 1.30000 1.30000 13.50000 1.12000 0.35700 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.1000 0.000 0.000 0.000 0.000
41.309 1944.00000 15.1000 -44.53125 0.00000 1.44500 1.44500 13.40000 1.12000 0.35700 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 13.8000 0.000 0.000 0.000 0.000
41.319 1944.00000 15.1000 -44.53125 0.00000 1.44500 1.44500 13.40000 1.12000 0.35700 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 13.8000 0.000 0.000 0.000 0.000
41.329 1944.00000 15.1000 -44.53125 0.00000 1.44500 1.44500 13.40000 1.12000 0.35700 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 13.8000 0.000 0.000 0.000 0.000
41.339 1944.00000 15.1000 -44.53125 0.00000 1.44500 1.44500 13.40000 1.12000 0.35700 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 13.8000 0.000 0.000 0.000 0.000
41.349 1944.00000 15.1000 -44.53125 0.00000 1.44500 1.44500 13.40000 1.12000 0.35700 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 13.8000 0.000 0.000 0.000 0.000
41.359 1964.00000 15.1000 -44.53125 0.00000 1.89400 1.89400 13.60000 1.12000 0.35700 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
41.369 1964.00000 15.1000 -44.53125 0.00000 1.89400 1.89400 13.60000 1.12000 0.35700 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
41.379 1964.00000 15.1000 -44.53125 0.00000 1.89400 1.89400 13.60000 1.12000 0.35700 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
41.389 1964.00000 15.1000 -44.53125 0.00000 1.89400 1.89400 13.60000 1.12000 0.35700 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
41.399 1964.00000 15.1000 -44.53125 0.00000 1.89400 1.89400 13.60000 1.12000 0.35700 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
41.409 1901.00000 15.2000 -44.53125 0.00000 1.88300 1.88300 12.30000 1.12000 0.35700 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
41.419 1901.00000 15.2000 -44.53125 0.00000 1.88300 1.88300 12.30000 1.12000 0.35700 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
41.429 1901.00000 15.2000 -44.53125 0.00000 1.88300 1.88300 12.30000 1.12000 0.35700 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
41.439 1901.00000 15.2000 -44.53125 0.00000 1.88300 1.88300 12.30000 1.12000 0.35700 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
41.449 1901.00000 15.2000 -44.53125 0.00000 1.88300 1.88300 12.30000 1.12000 0.35700 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
41.459 1888.00000 15.2000 -44.53125 0.00000 1.18300 1.18300 13.10000 1.14500 0.27400 4.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.9000 0.000 0.000 0.000 0.000
41.469 1888.00000 15.2000 -44.53125 0.00000 1.18300 1.18300 13.10000 1.14500 0.27400 4.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.9000 0.000 0.000 0.000 0.000
41.479 1888.00000 15.2000 -44.53125 0.00000 1.18300 1.18300 13.10000 1.14500 0.27400 4.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.9000 0.000 0.000 0.000 0.000
41.489 1888.00000 15.2000 -44.53125 0.00000 1.18300 1.18300 13.10000 1.14500 0.27400 4.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.9000 0.000 0.000 0.000 0.000
41.499 1888.00000 15.2000 -44.53125 0.00000 1.18300 1.18300 13.10000 1.14500 0.27400 4.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.9000 0.000 0.000 0.000 0.000
41.509 1862.00000 15.1000 -44.53125 0.00000 1.74800 1.74800 13.10000 1.14500 0.27400 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.9000 0.000 0.000 0.000 0.000
41.519 1862.00000 15.1000 -44.53125 0.00000 1.74800 1.74800 13.10000 1.14500 0.27400 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.9000 0.000 0.000 0.000 0.000
41.529 1862.00000 15.1000 -44.53125 0.00000 1.74800 1.74800 13.10000 1.14500 0.27400 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.9000 0.000 0.000 0.000 0.000
41.539 1862.00000 15.1000 -44.53125 0.00000 1.74800 1.74800 13.10000 1.14500 0.27400 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.9000 0.000 0.000 0.000 0.000
41.549 1862.00000 15.1000 -44.53125 0.00000 1.74800 1.74800 13.10000 1.14500 0.27400 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.9000 0.000 0.000 0.000 0.000
41.559 1872.00000 15.1000 -44.53125 0.00000 1.45100 1.45100 13.60000 1.14500 0.27400 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.7000 0.000 0.000 0.000 0.000
41.569 1872.00000 15.1000 -44.53125 0.00000 1.45100 1.45100 13.60000 1.14500 0.27400 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.7000 0.000 0.000 0.000 0.000
41.579 1872.00000 15.1000 -44.53125 0.00000 1.45100 1.45100 13.60000 1.14500 0.27400 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.7000 0.000 0.000 0.000 0.000
41.589 1872.00000 15.1000 -44.53125 0.00000 1.45100 1.45100 13.60000 1.14500 0.27400 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.7000 0.000 0.000 0.000 0.000
41.599 1872.00000 15.1000 -44.53125 0.00000 1.45100 1.45100 13.60000 1.14500 0.27400 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.7000 0.000 0.000 0.000 0.000
41.609 1808.00000 15.2000 -44.53125 0.00000 1.13600 1.13600 13.80000 1.14500 0.27400 4.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
41.619 1808.00000 15.2000 -44.53125 0.00000 1.13600 1.13600 13.80000 1.14500 0.27400 4.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
41.629 1808.00000 15.2000 -44.53125 0.00000 1.13600 1.13600 13.80000 1.14500 0.27400 4.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
41.639 1808.00000 15.2000 -44.53125 0.00000 1.13600 1.13600 13.80000 1.14500 0.27400 4.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
41.649 1808.00000 15.2000 -44.53125 0.00000 1.13600 1.13600 13.80000 1.14500 0.27400 4.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
41.659 1763.00000 15.1000 -44.53125 0.00000 1.85300 1.85300 13.20000 1.14500 0.30600 4.10000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
41.669 1763.00000 15.1000 -44.53125 0.00000 1.85300 1.85300 13.20000 1.14500 0.30600 4.10000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
41.679 1763.00000 15.1000 -44.53125 0.00000 1.85300 1.85300 13.20000 1.14500 0.30600 4.10000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
41.689 1763.00000 15.1000 -44.53125 0.00000 1.85300 1.85300 13.20000 1.14500 0.30600 4.10000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
41.699 1763.00000 15.1000 -44.53125 0.00000 1.85300 1.85300 13.20000 1.14500 0.30600 4.10000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
41.709 1763.00000 15.1000 -44.53125 0.00000 1.24100 1.24100 13.50000 1.14500 0.30600 4.10000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
41.719 1763.00000 15.1000 -44.53125 0.00000 1.24100 1.24100 13.50000 1.14500 0.30600 4.10000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
41.729 1763.00000 15.1000 -44.53125 0.00000 1.24100 1.24100 13.50000 1.14500 0.30600 4.10000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
41.739 1763.00000 15.1000 -44.53125 0.00000 1.24100 1.24100 13.50000 1.14500 0.30600 4.10000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
41.749 1763.00000 15.1000 -44.53125 0.00000 1.24100 1.24100 13.50000 1.14500 0.30600 4.10000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
41.759 1688.00000 15.2000 -44.53125 0.00000 1.31100 1.31100 13.10000 1.14500 0.30600 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.2000 0.000 0.000 0.000 0.000
41.769 1688.00000 15.2000 -44.53125 0.00000 1.31100 1.31100 13.10000 1.14500 0.30600 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.2000 0.000 0.000 0.000 0.000
41.779 1688.00000 15.2000 -44.53125 0.00000 1.31100 1.31100 13.10000 1.14500 0.30600 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.2000 0.000 0.000 0.000 0.000
41.789 1688.00000 15.2000 -44.53125 0.00000 1.31100 1.31100 13.10000 1.14500 0.30600 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.2000 0.000 0.000 0.000 0.000
41.799 1688.00000 15.2000 -44.53125 0.00000 1.31100 1.31100 13.10000 1.14500 0.30600 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.2000 0.000 0.000 0.000 0.000
41.809 1519.00000 15.2000 -44.53125 0.00000 1.42800 1.42800 13.40000 1.14500 0.30600 4.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.3000 0.000 0.000 0.000 0.000
41.819 1519.00000 15.2000 -44.53125 0.00000 1.42800 1.42800 13.40000 1.14500 0.30600 4.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.3000 0.000 0.000 0.000 0.000
41.829 1519.00000 15.2000 -44.53125 0.00000 1.42800 1.42800 13.40000 1.14500 0.30600 4.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.3000 0.000 0.000 0.000 0.000
41.839 1519.00000 15.2000 -44.53125 0.00000 1.42800 1.42800 13.40000 1.14500 0.30600 4.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.3000 0.000 0.000 0.000 0.000
41.849 1519.00000 15.2000 -44.53125 0.00000 1.42800 1.42800 13.40000 1.14500 0.30600 4.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.3000 0.000 0.000 0.000 0.000
41.859 1392.00000 15.2000 -44.53125 0.00000 1.70200 1.70200 13.20000 1.12600 0.34400 4.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.3000 0.000 0.000 0.000 0.000
41.869 1392.00000 15.2000 -44.53125 0.00000 1.70200 1.70200 13.20000 1.12600 0.34400 4.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.3000 0.000 0.000 0.000 0.000
41.879 1392.00000 15.2000 -44.53125 0.00000 1.70200 1.70200 13.20000 1.12600 0.34400 4.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.3000 0.000 0.000 0.000 0.000
41.889 1392.00000 15.2000 -44.53125 0.00000 1.70200 1.70200 13.20000 1.12600 0.34400 4.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.3000 0.000 0.000 0.000 0.000
41.899 1392.00000 15.2000 -44.53125 0.00000 1.70200 1.70200 13.20000 1.12600 0.34400 4.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.3000 0.000 0.000 0.000 0.000
41.909 1392.00000 15.2000 -44.53125 0.00000 1.74300 1.74300 13.40000 1.12600 0.34400 4.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
41.919 1392.00000 15.2000 -44.53125 0.00000 1.74300 1.74300 13.40000 1.12600 0.34400 4.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
41.929 1392.00000 15.2000 -44.53125 0.00000 1.74300 1.74300 13.40000 1.12600 0.34400 4.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
41.939 1392.00000 15.2000 -44.53125 0.00000 1.74300 1.74300 13.40000 1.12600 0.34400 4.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
41.949 1392.00000 15.2000 -44.53125 0.00000 1.74300 1.74300 13.40000 1.12600 0.34400 4.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
41.959 1401.00000 15.2000 -44.53125 0.00000 1.64900 1.64900 13.30000 1.12600 0.34400 4.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
41.969 1401.00000 15.2000 -44.53125 0.00000 1.64900 1.64900 13.30000 1.12600 0.34400 4.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
41.979 1401.00000 15.2000 -44.53125 0.00000 1.64900 1.64900 13.30000 1.12600 0.34400 4.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
41.989 1401.00000 15.2000 -44.53125 0.00000 1.64900 1.64900 13.30000 1.12600 0.34400 4.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
41.999 1401.00000 15.2000 -44.53125 0.00000 1.64900 1.64900 13.30000 1.12600 0.34400 4.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
42.009 1427.00000 15.1000 -44.53125 0.00000 1.44500 1.44500 13.30000 1.12600 0.34400 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
42.019 1427.00000 15.1000 -44.53125 0.00000 1.44500 1.44500 13.30000 1.12600 0.34400 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
42.029 1427.00000 15.1000 -44.53125 0.00000 1.44500 1.44500 13.30000 1.12600 0.34400 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
42.039 1427.00000 15.1000 -44.53125 0.00000 1.44500 1.44500 13.30000 1.12600 0.34400 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
42.049 1427.00000 15.1000 -44.53125 0.00000 1.44500 1.44500 13.30000 1.12600 0.34400 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
42.059 1381.00000 15.1000 -44.53125 0.00000 1.58500 1.58500 13.50000 0.29000 0.71100 4.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 14.0000 0.000 0.000 0.000 0.000
42.069 1381.00000 15.1000 -44.53125 0.00000 1.58500 1.58500 13.50000 0.29000 0.71100 4.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 14.0000 0.000 0.000 0.000 0.000
42.079 1381.00000 15.1000 -44.53125 0.00000 1.58500 1.58500 13.50000 0.29000 0.71100 4.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 14.0000 0.000 0.000 0.000 0.000
42.089 1381.00000 15.1000 -44.53125 0.00000 1.58500 1.58500 13.50000 0.29000 0.71100 4.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 14.0000 0.000 0.000 0.000 0.000
42.099 1381.00000 15.1000 -44.53125 0.00000 1.58500 1.58500 13.50000 0.29000 0.71100 4.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 14.0000 0.000 0.000 0.000 0.000
42.109 1381.00000 15.2000 -44.53125 0.00000 1.62000 1.62000 13.10000 0.29000 0.71100 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
42.119 1381.00000 15.2000 -44.53125 0.00000 1.62000 1.62000 13.10000 0.29000 0.71100 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
42.129 1381.00000 15.2000 -44.53125 0.00000 1.62000 1.62000 13.10000 0.29000 0.71100 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
42.139 1381.00000 15.2000 -44.53125 0.00000 1.62000 1.62000 13.10000 0.29000 0.71100 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
42.149 1381.00000 15.2000 -44.53125 0.00000 1.62000 1.62000 13.10000 0.29000 0.71100 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
42.159 1365.00000 15.2000 -44.53125 0.00000 1.30000 1.30000 13.30000 0.29000 0.71100 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
42.169 1365.00000 15.2000 -44.53125 0.00000 1.30000 1.30000 13.30000 0.29000 0.71100 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
42.179 1365.00000 15.2000 -44.53125 0.00000 1.30000 1.30000 13.30000 0.29000 0.71100 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
42.189 1365.00000 15.2000 -44.53125 0.00000 1.30000 1.30000 13.30000 0.29000 0.71100 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
42.199 1365.00000 15.2000 -44.53125 0.00000 1.30000 1.30000 13.30000 0.29000 0.71100 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
42.209 1336.00000 15.4000 -44.53125 0.00000 1.39900 1.39900 12.50000 0.29000 0.71100 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
42.219 1336.00000 15.4000 -44.53125 0.00000 1.39900 1.39900 12.50000 0.29000 0.71100 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
42.229 1336.00000 15.4000 -44.53125 0.00000 1.39900 1.39900 12.50000 0.29000 0.71100 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
42.239 1336.00000 15.4000 -44.53125 0.00000 1.39900 1.39900 12.50000 0.29000 0.71100 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
42.249 1336.00000 15.4000 -44.53125 0.00000 1.39900 1.39900 12.50000 0.29000 0.71100 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
42.259 1336.00000 15.1000 -44.53125 0.00000 1.43900 1.43900 13.20000 1.12900 1.04300 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
42.269 1336.00000 15.1000 -44.53125 0.00000 1.43900 1.43900 13.20000 1.12900 1.04300 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
42.279 1336.00000 15.1000 -44.53125 0.00000 1.43900 1.43900 13.20000 1.12900 1.04300 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
42.289 1336.00000 15.1000 -44.53125 0.00000 1.43900 1.43900 13.20000 1.12900 1.04300 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
42.299 1336.00000 15.1000 -44.53125 0.00000 1.43900 1.43900 13.20000 1.12900 1.04300 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
42.309 1339.00000 15.1000 -44.53125 0.00000 1.41600 1.41600 13.20000 1.12900 1.04300 4.50000 1.00000 2.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
42.319 1339.00000 15.1000 -44.53125 0.00000 1.41600 1.41600 13.20000 1.12900 1.04300 4.50000 1.00000 2.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
42.329 1339.00000 15.1000 -44.53125 0.00000 1.41600 1.41600 13.20000 1.12900 1.04300 4.50000 1.00000 2.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
42.339 1339.00000 15.1000 -44.53125 0.00000 1.41600 1.41600 13.20000 1.12900 1.04300 4.50000 1.00000 2.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
42.349 1339.00000 15.1000 -44.53125 0.00000 1.41600 1.41600 13.20000 1.12900 1.04300 4.50000 1.00000 2.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
42.359 1238.00000 15.2000 -44.53125 0.00000 1.27000 1.27000 13.10000 1.12900 1.04300 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.1000 0.000 0.000 0.000 0.000
42.369 1238.00000 15.2000 -44.53125 0.00000 1.27000 1.27000 13.10000 1.12900 1.04300 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.1000 0.000 0.000 0.000 0.000
42.379 1238.00000 15.2000 -44.53125 0.00000 1.27000 1.27000 13.10000 1.12900 1.04300 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.1000 0.000 0.000 0.000 0.000
42.389 1238.00000 15.2000 -44.53125 0.00000 1.27000 1.27000 13.10000 1.12900 1.04300 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.1000 0.000 0.000 0.000 0.000
42.399 1238.00000 15.2000 -44.53125 0.00000 1.27000 1.27000 13.10000 1.12900 1.04300 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.1000 0.000 0.000 0.000 0.000
42.409 1238.00000 15.2000 -44.53125 0.00000 1.30500 1.30500 13.50000 1.12900 1.04300 4.60000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.1000 0.000 0.000 0.000 0.000
42.419 1238.00000 15.2000 -44.53125 0.00000 1.30500 1.30500 13.50000 1.12900 1.04300 4.60000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.1000 0.000 0.000 0.000 0.000
42.429 1238.00000 15.2000 -44.53125 0.00000 1.30500 1.30500 13.50000 1.12900 1.04300 4.60000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.1000 0.000 0.000 0.000 0.000
42.439 1238.00000 15.2000 -44.53125 0.00000 1.30500 1.30500 13.50000 1.12900 1.04300 4.60000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.1000 0.000 0.000 0.000 0.000
42.449 1238.00000 15.2000 -44.53125 0.00000 1.30500 1.30500 13.50000 1.12900 1.04300 4.60000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.1000 0.000 0.000 0.000 0.000
42.459 1061.00000 15.2000 -44.53125 0.00000 1.39300 1.39300 13.20000 1.15500 1.06200 5.00000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 14.1000 0.000 0.000 0.000 0.000
42.469 1061.00000 15.2000 -44.53125 0.00000 1.39300 1.39300 13.20000 1.15500 1.06200 5.00000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 14.1000 0.000 0.000 0.000 0.000
42.479 1061.00000 15.2000 -44.53125 0.00000 1.39300 1.39300 13.20000 1.15500 1.06200 5.00000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 14.1000 0.000 0.000 0.000 0.000
42.489 1061.00000 15.2000 -44.53125 0.00000 1.39300 1.39300 13.20000 1.15500 1.06200 5.00000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 14.1000 0.000 0.000 0.000 0.000
42.499 1061.00000 15.2000 -44.53125 0.00000 1.39300 1.39300 13.20000 1.15500 1.06200 5.00000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 14.1000 0.000 0.000 0.000 0.000
42.509 1061.00000 15.2000 -44.53125 0.00000 1.27000 1.27000 12.80000 1.15500 1.06200 4.90000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
42.519 1061.00000 15.2000 -44.53125 0.00000 1.27000 1.27000 12.80000 1.15500 1.06200 4.90000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
42.529 1061.00000 15.2000 -44.53125 0.00000 1.27000 1.27000 12.80000 1.15500 1.06200 4.90000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
42.539 1061.00000 15.2000 -44.53125 0.00000 1.27000 1.27000 12.80000 1.15500 1.06200 4.90000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
42.549 1061.00000 15.2000 -44.53125 0.00000 1.27000 1.27000 12.80000 1.15500 1.06200 4.90000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
42.559 1061.00000 15.2000 -44.53125 0.00000 1.27000 1.27000 12.80000 1.15500 1.06200 4.90000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
42.569 858.00000 15.2000 -44.53125 0.00000 1.12500 1.12500 12.60000 1.15500 1.06200 5.70000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
42.579 858.00000 15.2000 -44.53125 0.00000 1.12500 1.12500 12.60000 1.15500 1.06200 5.70000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
42.589 858.00000 15.2000 -44.53125 0.00000 1.12500 1.12500 12.60000 1.15500 1.06200 5.70000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
42.599 858.00000 15.2000 -44.53125 0.00000 1.12500 1.12500 12.60000 1.15500 1.06200 5.70000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
42.609 858.00000 15.2000 -44.53125 0.00000 0.99100 0.99100 12.80000 1.15500 1.06200 5.60000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.3000 0.000 0.000 0.000 0.000
42.619 858.00000 15.2000 -44.53125 0.00000 0.99100 0.99100 12.80000 1.15500 1.06200 5.60000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.3000 0.000 0.000 0.000 0.000
42.629 858.00000 15.2000 -44.53125 0.00000 0.99100 0.99100 12.80000 1.15500 1.06200 5.60000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.3000 0.000 0.000 0.000 0.000
42.639 858.00000 15.2000 -44.53125 0.00000 0.99100 0.99100 12.80000 1.15500 1.06200 5.60000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.3000 0.000 0.000 0.000 0.000
42.649 858.00000 15.2000 -44.53125 0.00000 0.99100 0.99100 12.80000 1.15500 1.06200 5.60000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.3000 0.000 0.000 0.000 0.000
42.659 858.00000 15.2000 -44.53125 0.00000 0.91500 0.91500 12.70000 1.10400 1.06200 5.80000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
42.669 858.00000 15.2000 -44.53125 0.00000 0.91500 0.91500 12.70000 1.10400 1.06200 5.80000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
42.679 858.00000 15.2000 -44.53125 0.00000 0.91500 0.91500 12.70000 1.10400 1.06200 5.80000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
42.689 858.00000 15.2000 -44.53125 0.00000 0.91500 0.91500 12.70000 1.10400 1.06200 5.80000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
42.699 858.00000 15.2000 -44.53125 0.00000 0.91500 0.91500 12.70000 1.10400 1.06200 5.80000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
42.709 707.00000 15.2000 -44.53125 0.00000 0.92600 0.92600 12.50000 1.10400 1.06200 6.10000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.7000 0.000 0.000 0.000 0.000
42.719 707.00000 15.2000 -44.53125 0.00000 0.92600 0.92600 12.50000 1.10400 1.06200 6.10000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.7000 0.000 0.000 0.000 0.000
42.729 707.00000 15.2000 -44.53125 0.00000 0.92600 0.92600 12.50000 1.10400 1.06200 6.10000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.7000 0.000 0.000 0.000 0.000
42.739 707.00000 15.2000 -44.53125 0.00000 0.92600 0.92600 12.50000 1.10400 1.06200 6.10000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.7000 0.000 0.000 0.000 0.000
42.749 707.00000 15.2000 -44.53125 0.00000 0.92600 0.92600 12.50000 1.10400 1.06200 6.10000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.7000 0.000 0.000 0.000 0.000
42.759 707.00000 15.2000 -44.53125 0.00000 0.94400 0.94400 12.40000 1.10400 1.06200 6.70000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.7000 0.000 0.000 0.000 0.000
42.769 707.00000 15.2000 -44.53125 0.00000 0.94400 0.94400 12.40000 1.10400 1.06200 6.70000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.7000 0.000 0.000 0.000 0.000
42.779 707.00000 15.2000 -44.53125 0.00000 0.94400 0.94400 12.40000 1.10400 1.06200 6.70000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.7000 0.000 0.000 0.000 0.000
42.789 707.00000 15.2000 -44.53125 0.00000 0.94400 0.94400 12.40000 1.10400 1.06200 6.70000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.7000 0.000 0.000 0.000 0.000
42.799 707.00000 15.2000 -44.53125 0.00000 0.94400 0.94400 12.40000 1.10400 1.06200 6.70000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.7000 0.000 0.000 0.000 0.000
42.809 707.00000 15.2000 -44.53125 0.00000 0.89700 0.89700 12.30000 1.10400 1.06200 6.80000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
42.819 707.00000 15.2000 -44.53125 0.00000 0.89700 0.89700 12.30000 1.10400 1.06200 6.80000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
42.829 707.00000 15.2000 -44.53125 0.00000 0.89700 0.89700 12.30000 1.10400 1.06200 6.80000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
42.839 707.00000 15.2000 -44.53125 0.00000 0.89700 0.89700 12.30000 1.10400 1.06200 6.80000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
42.849 707.00000 15.2000 -44.53125 0.00000 0.89700 0.89700 12.30000 1.10400 1.06200 6.80000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
42.859 662.00000 15.2000 -44.53125 0.00000 0.94400 0.94400 12.70000 1.08500 1.05600 6.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
42.869 662.00000 15.2000 -44.53125 0.00000 0.94400 0.94400 12.70000 1.08500 1.05600 6.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
42.879 662.00000 15.2000 -44.53125 0.00000 0.94400 0.94400 12.70000 1.08500 1.05600 6.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
42.889 662.00000 15.2000 -44.53125 0.00000 0.94400 0.94400 12.70000 1.08500 1.05600 6.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
42.899 662.00000 15.2000 -44.53125 0.00000 0.94400 0.94400 12.70000 1.08500 1.05600 6.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
42.909 662.00000 15.2000 -44.53125 0.00000 0.98500 0.98500 12.40000 1.08500 1.05600 6.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
42.919 662.00000 15.2000 -44.53125 0.00000 0.98500 0.98500 12.40000 1.08500 1.05600 6.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
42.929 662.00000 15.2000 -44.53125 0.00000 0.98500 0.98500 12.40000 1.08500 1.05600 6.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
42.939 662.00000 15.2000 -44.53125 0.00000 0.98500 0.98500 12.40000 1.08500 1.05600 6.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
42.949 662.00000 15.2000 -44.53125 0.00000 0.98500 0.98500 12.40000 1.08500 1.05600 6.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
42.959 662.00000 15.2000 -44.53125 0.00000 1.00200 1.00200 12.70000 1.08500 1.05600 7.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
42.969 662.00000 15.2000 -44.53125 0.00000 1.00200 1.00200 12.70000 1.08500 1.05600 7.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
42.979 662.00000 15.2000 -44.53125 0.00000 1.00200 1.00200 12.70000 1.08500 1.05600 7.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
42.989 662.00000 15.2000 -44.53125 0.00000 1.00200 1.00200 12.70000 1.08500 1.05600 7.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
42.999 662.00000 15.2000 -44.53125 0.00000 1.00200 1.00200 12.70000 1.08500 1.05600 7.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
43.009 738.00000 15.1000 -44.53125 0.00000 0.95600 0.95600 13.00000 1.08500 1.05600 6.40000 1.00000 2.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.3000 0.000 0.000 0.000 0.000
43.019 738.00000 15.1000 -44.53125 0.00000 0.95600 0.95600 13.00000 1.08500 1.05600 6.40000 1.00000 2.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.3000 0.000 0.000 0.000 0.000
43.029 738.00000 15.1000 -44.53125 0.00000 0.95600 0.95600 13.00000 1.08500 1.05600 6.40000 1.00000 2.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.3000 0.000 0.000 0.000 0.000
43.039 738.00000 15.1000 -44.53125 0.00000 0.95600 0.95600 13.00000 1.08500 1.05600 6.40000 1.00000 2.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.3000 0.000 0.000 0.000 0.000
43.049 738.00000 15.1000 -44.53125 0.00000 0.95600 0.95600 13.00000 1.08500 1.05600 6.40000 1.00000 2.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.3000 0.000 0.000 0.000 0.000
43.059 738.00000 15.1000 -44.53125 0.00000 0.93200 0.93200 13.30000 1.16800 1.06600 6.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.2000 0.000 0.000 0.000 0.000
43.069 738.00000 15.1000 -44.53125 0.00000 0.93200 0.93200 13.30000 1.16800 1.06600 6.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.2000 0.000 0.000 0.000 0.000
43.079 738.00000 15.1000 -44.53125 0.00000 0.93200 0.93200 13.30000 1.16800 1.06600 6.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.2000 0.000 0.000 0.000 0.000
43.089 738.00000 15.1000 -44.53125 0.00000 0.93200 0.93200 13.30000 1.16800 1.06600 6.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.2000 0.000 0.000 0.000 0.000
43.099 738.00000 15.1000 -44.53125 0.00000 0.93200 0.93200 13.30000 1.16800 1.06600 6.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.2000 0.000 0.000 0.000 0.000
43.109 908.00000 15.1000 -44.53125 0.00000 0.96700 0.96700 13.60000 1.16800 1.06600 5.90000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.2000 0.000 0.000 0.000 0.000
43.119 908.00000 15.1000 -44.53125 0.00000 0.96700 0.96700 13.60000 1.16800 1.06600 5.90000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.2000 0.000 0.000 0.000 0.000
43.129 908.00000 15.1000 -44.53125 0.00000 0.96700 0.96700 13.60000 1.16800 1.06600 5.90000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.2000 0.000 0.000 0.000 0.000
43.139 908.00000 15.1000 -44.53125 0.00000 0.96700 0.96700 13.60000 1.16800 1.06600 5.90000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.2000 0.000 0.000 0.000 0.000
43.149 908.00000 15.1000 -44.53125 0.00000 0.96700 0.96700 13.60000 1.16800 1.06600 5.90000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.2000 0.000 0.000 0.000 0.000
43.159 908.00000 15.1000 -44.53125 0.00000 0.91500 0.91500 13.10000 1.16800 1.06600 5.60000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.0000 0.000 0.000 0.000 0.000
43.169 908.00000 15.1000 -44.53125 0.00000 0.91500 0.91500 13.10000 1.16800 1.06600 5.60000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.0000 0.000 0.000 0.000 0.000
43.179 908.00000 15.1000 -44.53125 0.00000 0.91500 0.91500 13.10000 1.16800 1.06600 5.60000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.0000 0.000 0.000 0.000 0.000
43.189 908.00000 15.1000 -44.53125 0.00000 0.91500 0.91500 13.10000 1.16800 1.06600 5.60000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.0000 0.000 0.000 0.000 0.000
43.199 908.00000 15.1000 -44.53125 0.00000 0.91500 0.91500 13.10000 1.16800 1.06600 5.60000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.0000 0.000 0.000 0.000 0.000
43.209 1026.00000 15.2000 -44.53125 0.00000 0.88600 0.88600 13.40000 1.16800 1.06600 5.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.0000 0.000 0.000 0.000 0.000
43.219 1026.00000 15.2000 -44.53125 0.00000 0.88600 0.88600 13.40000 1.16800 1.06600 5.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.0000 0.000 0.000 0.000 0.000
43.229 1026.00000 15.2000 -44.53125 0.00000 0.88600 0.88600 13.40000 1.16800 1.06600 5.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.0000 0.000 0.000 0.000 0.000
43.239 1026.00000 15.2000 -44.53125 0.00000 0.88600 0.88600 13.40000 1.16800 1.06600 5.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.0000 0.000 0.000 0.000 0.000
43.249 1026.00000 15.2000 -44.53125 0.00000 0.88600 0.88600 13.40000 1.16800 1.06600 5.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.0000 0.000 0.000 0.000 0.000
43.259 1026.00000 15.1000 -44.53125 0.00000 0.87400 0.87400 12.70000 1.16800 1.09800 5.00000 1.00000 1.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.0000 0.000 0.000 0.000 0.000
43.269 1026.00000 15.1000 -44.53125 0.00000 0.87400 0.87400 12.70000 1.16800 1.09800 5.00000 1.00000 1.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.0000 0.000 0.000 0.000 0.000
43.279 1026.00000 15.1000 -44.53125 0.00000 0.87400 0.87400 12.70000 1.16800 1.09800 5.00000 1.00000 1.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.0000 0.000 0.000 0.000 0.000
43.289 1026.00000 15.1000 -44.53125 0.00000 0.87400 0.87400 12.70000 1.16800 1.09800 5.00000 1.00000 1.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.0000 0.000 0.000 0.000 0.000
43.299 1026.00000 15.1000 -44.53125 0.00000 0.87400 0.87400 12.70000 1.16800 1.09800 5.00000 1.00000 1.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.0000 0.000 0.000 0.000 0.000
43.309 1135.00000 15.2000 -44.53125 0.00000 0.95600 0.95600 13.30000 1.16800 1.09800 4.80000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.3000 0.000 0.000 0.000 0.000
43.319 1135.00000 15.2000 -44.53125 0.00000 0.95600 0.95600 13.30000 1.16800 1.09800 4.80000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.3000 0.000 0.000 0.000 0.000
43.329 1135.00000 15.2000 -44.53125 0.00000 0.95600 0.95600 13.30000 1.16800 1.09800 4.80000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.3000 0.000 0.000 0.000 0.000
43.339 1135.00000 15.2000 -44.53125 0.00000 0.95600 0.95600 13.30000 1.16800 1.09800 4.80000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.3000 0.000 0.000 0.000 0.000
43.349 1135.00000 15.2000 -44.53125 0.00000 0.95600 0.95600 13.30000 1.16800 1.09800 4.80000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.3000 0.000 0.000 0.000 0.000
43.359 1193.00000 15.2000 -44.53125 0.00000 0.99600 0.99600 13.30000 1.16800 1.09800 4.60000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.3000 0.000 0.000 0.000 0.000
43.369 1193.00000 15.2000 -44.53125 0.00000 0.99600 0.99600 13.30000 1.16800 1.09800 4.60000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.3000 0.000 0.000 0.000 0.000
43.379 1193.00000 15.2000 -44.53125 0.00000 0.99600 0.99600 13.30000 1.16800 1.09800 4.60000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.3000 0.000 0.000 0.000 0.000
43.389 1193.00000 15.2000 -44.53125 0.00000 0.99600 0.99600 13.30000 1.16800 1.09800 4.60000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.3000 0.000 0.000 0.000 0.000
43.399 1193.00000 15.2000 -44.53125 0.00000 0.99600 0.99600 13.30000 1.16800 1.09800 4.60000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.3000 0.000 0.000 0.000 0.000
43.409 1193.00000 15.2000 -44.53125 0.00000 0.96100 0.96100 13.10000 1.16800 1.09800 4.70000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.3000 0.000 0.000 0.000 0.000
43.419 1193.00000 15.2000 -44.53125 0.00000 0.96100 0.96100 13.10000 1.16800 1.09800 4.70000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.3000 0.000 0.000 0.000 0.000
43.429 1193.00000 15.2000 -44.53125 0.00000 0.96100 0.96100 13.10000 1.16800 1.09800 4.70000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.3000 0.000 0.000 0.000 0.000
43.439 1193.00000 15.2000 -44.53125 0.00000 0.96100 0.96100 13.10000 1.16800 1.09800 4.70000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.3000 0.000 0.000 0.000 0.000
43.449 1193.00000 15.2000 -44.53125 0.00000 0.96100 0.96100 13.10000 1.16800 1.09800 4.70000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.3000 0.000 0.000 0.000 0.000
43.459 1240.00000 15.1000 -44.53125 0.00000 1.06600 1.06600 13.20000 1.14500 1.11000 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.9000 0.000 0.000 0.000 0.000
43.469 1240.00000 15.1000 -44.53125 0.00000 1.06600 1.06600 13.20000 1.14500 1.11000 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.9000 0.000 0.000 0.000 0.000
43.479 1240.00000 15.1000 -44.53125 0.00000 1.06600 1.06600 13.20000 1.14500 1.11000 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.9000 0.000 0.000 0.000 0.000
43.489 1240.00000 15.1000 -44.53125 0.00000 1.06600 1.06600 13.20000 1.14500 1.11000 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.9000 0.000 0.000 0.000 0.000
43.499 1240.00000 15.1000 -44.53125 0.00000 1.06600 1.06600 13.20000 1.14500 1.11000 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.9000 0.000 0.000 0.000 0.000
43.509 1223.00000 15.1000 -44.53125 0.00000 1.23500 1.23500 13.30000 1.14500 1.11000 4.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.9000 0.000 0.000 0.000 0.000
43.519 1223.00000 15.1000 -44.53125 0.00000 1.23500 1.23500 13.30000 1.14500 1.11000 4.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.9000 0.000 0.000 0.000 0.000
43.529 1223.00000 15.1000 -44.53125 0.00000 1.23500 1.23500 13.30000 1.14500 1.11000 4.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.9000 0.000 0.000 0.000 0.000
43.539 1223.00000 15.1000 -44.53125 0.00000 1.23500 1.23500 13.30000 1.14500 1.11000 4.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.9000 0.000 0.000 0.000 0.000
43.549 1223.00000 15.1000 -44.53125 0.00000 1.23500 1.23500 13.30000 1.14500 1.11000 4.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.9000 0.000 0.000 0.000 0.000
43.559 1223.00000 15.2000 -44.53125 0.00000 1.26500 1.26500 13.40000 1.14500 1.11000 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.9000 0.000 0.000 0.000 0.000
43.569 1223.00000 15.2000 -44.53125 0.00000 1.26500 1.26500 13.40000 1.14500 1.11000 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.9000 0.000 0.000 0.000 0.000
43.579 1223.00000 15.2000 -44.53125 0.00000 1.26500 1.26500 13.40000 1.14500 1.11000 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.9000 0.000 0.000 0.000 0.000
43.589 1223.00000 15.2000 -44.53125 0.00000 1.26500 1.26500 13.40000 1.14500 1.11000 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.9000 0.000 0.000 0.000 0.000
43.599 1223.00000 15.2000 -44.53125 0.00000 1.26500 1.26500 13.40000 1.14500 1.11000 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.9000 0.000 0.000 0.000 0.000
43.609 1218.00000 15.4000 -44.53125 0.00000 1.31100 1.31100 11.80000 1.14500 1.11000 4.20000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
43.619 1218.00000 15.4000 -44.53125 0.00000 1.31100 1.31100 11.80000 1.14500 1.11000 4.20000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
43.629 1218.00000 15.4000 -44.53125 0.00000 1.31100 1.31100 11.80000 1.14500 1.11000 4.20000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
43.639 1218.00000 15.4000 -44.53125 0.00000 1.31100 1.31100 11.80000 1.14500 1.11000 4.20000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
43.649 1218.00000 15.4000 -44.53125 0.00000 1.31100 1.31100 11.80000 1.14500 1.11000 4.20000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
43.659 1218.00000 15.2000 -44.53125 0.00000 1.49800 1.49800 13.00000 1.12300 1.12300 4.20000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.7000 0.000 0.000 0.000 0.000
43.669 1218.00000 15.2000 -44.53125 0.00000 1.49800 1.49800 13.00000 1.12300 1.12300 4.20000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.7000 0.000 0.000 0.000 0.000
43.679 1218.00000 15.2000 -44.53125 0.00000 1.49800 1.49800 13.00000 1.12300 1.12300 4.20000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.7000 0.000 0.000 0.000 0.000
43.689 1218.00000 15.2000 -44.53125 0.00000 1.49800 1.49800 13.00000 1.12300 1.12300 4.20000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.7000 0.000 0.000 0.000 0.000
43.699 1218.00000 15.2000 -44.53125 0.00000 1.49800 1.49800 13.00000 1.12300 1.12300 4.20000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.7000 0.000 0.000 0.000 0.000
43.709 1216.00000 15.1000 -44.53125 0.00000 1.14200 1.14200 13.20000 1.12300 1.12300 4.20000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
43.719 1216.00000 15.1000 -44.53125 0.00000 1.14200 1.14200 13.20000 1.12300 1.12300 4.20000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
43.729 1216.00000 15.1000 -44.53125 0.00000 1.14200 1.14200 13.20000 1.12300 1.12300 4.20000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
43.739 1216.00000 15.1000 -44.53125 0.00000 1.14200 1.14200 13.20000 1.12300 1.12300 4.20000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
43.749 1216.00000 15.1000 -44.53125 0.00000 1.14200 1.14200 13.20000 1.12300 1.12300 4.20000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
43.759 1148.00000 15.1000 -44.53125 0.00000 1.13000 1.13000 13.10000 1.12300 1.12300 4.20000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
43.769 1148.00000 15.1000 -44.53125 0.00000 1.13000 1.13000 13.10000 1.12300 1.12300 4.20000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
43.779 1148.00000 15.1000 -44.53125 0.00000 1.13000 1.13000 13.10000 1.12300 1.12300 4.20000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
43.789 1148.00000 15.1000 -44.53125 0.00000 1.13000 1.13000 13.10000 1.12300 1.12300 4.20000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
43.799 1148.00000 15.1000 -44.53125 0.00000 1.13000 1.13000 13.10000 1.12300 1.12300 4.20000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
43.809 1148.00000 15.1000 -44.53125 0.00000 1.23500 1.23500 13.30000 1.12300 1.12300 4.20000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
43.819 1148.00000 15.1000 -44.53125 0.00000 1.23500 1.23500 13.30000 1.12300 1.12300 4.20000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
43.829 1148.00000 15.1000 -44.53125 0.00000 1.23500 1.23500 13.30000 1.12300 1.12300 4.20000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
43.839 1148.00000 15.1000 -44.53125 0.00000 1.23500 1.23500 13.30000 1.12300 1.12300 4.20000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
43.849 1148.00000 15.1000 -44.53125 0.00000 1.23500 1.23500 13.30000 1.12300 1.12300 4.20000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
43.859 1046.00000 15.1000 -44.53125 0.00000 1.27000 1.27000 13.20000 1.12000 1.12900 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
43.869 1046.00000 15.1000 -44.53125 0.00000 1.27000 1.27000 13.20000 1.12000 1.12900 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
43.879 1046.00000 15.1000 -44.53125 0.00000 1.27000 1.27000 13.20000 1.12000 1.12900 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
43.889 1046.00000 15.1000 -44.53125 0.00000 1.27000 1.27000 13.20000 1.12000 1.12900 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
43.899 1046.00000 15.1000 -44.53125 0.00000 1.27000 1.27000 13.20000 1.12000 1.12900 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
43.909 1046.00000 15.1000 -44.53125 0.00000 1.15400 1.15400 13.50000 1.12000 1.12900 4.70000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.1000 0.000 0.000 0.000 0.000
43.919 1046.00000 15.1000 -44.53125 0.00000 1.15400 1.15400 13.50000 1.12000 1.12900 4.70000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.1000 0.000 0.000 0.000 0.000
43.929 1046.00000 15.1000 -44.53125 0.00000 1.15400 1.15400 13.50000 1.12000 1.12900 4.70000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.1000 0.000 0.000 0.000 0.000
43.939 1046.00000 15.1000 -44.53125 0.00000 1.15400 1.15400 13.50000 1.12000 1.12900 4.70000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.1000 0.000 0.000 0.000 0.000
43.949 1046.00000 15.1000 -44.53125 0.00000 1.15400 1.15400 13.50000 1.12000 1.12900 4.70000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.1000 0.000 0.000 0.000 0.000
43.959 897.00000 15.2000 -44.53125 0.00000 1.15400 1.15400 12.40000 1.12000 1.12900 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.1000 0.000 0.000 0.000 0.000
43.969 897.00000 15.2000 -44.53125 0.00000 1.15400 1.15400 12.40000 1.12000 1.12900 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.1000 0.000 0.000 0.000 0.000
43.979 897.00000 15.2000 -44.53125 0.00000 1.15400 1.15400 12.40000 1.12000 1.12900 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.1000 0.000 0.000 0.000 0.000
43.989 897.00000 15.2000 -44.53125 0.00000 1.15400 1.15400 12.40000 1.12000 1.12900 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.1000 0.000 0.000 0.000 0.000
43.999 897.00000 15.2000 -44.53125 0.00000 1.15400 1.15400 12.40000 1.12000 1.12900 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.1000 0.000 0.000 0.000 0.000
44.009 897.00000 15.1000 -44.53125 0.00000 1.17700 1.17700 13.10000 1.12000 1.12900 5.00000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.1000 0.000 0.000 0.000 0.000
44.019 897.00000 15.1000 -44.53125 0.00000 1.17700 1.17700 13.10000 1.12000 1.12900 5.00000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.1000 0.000 0.000 0.000 0.000
44.029 897.00000 15.1000 -44.53125 0.00000 1.17700 1.17700 13.10000 1.12000 1.12900 5.00000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.1000 0.000 0.000 0.000 0.000
44.039 897.00000 15.1000 -44.53125 0.00000 1.17700 1.17700 13.10000 1.12000 1.12900 5.00000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.1000 0.000 0.000 0.000 0.000
44.049 897.00000 15.1000 -44.53125 0.00000 1.17700 1.17700 13.10000 1.12000 1.12900 5.00000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.1000 0.000 0.000 0.000 0.000
44.059 897.00000 15.2000 -44.53125 0.00000 1.16500 1.16500 13.00000 1.12600 1.13300 4.90000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.2000 0.000 0.000 0.000 0.000
44.069 897.00000 15.2000 -44.53125 0.00000 1.16500 1.16500 13.00000 1.12600 1.13300 4.90000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.2000 0.000 0.000 0.000 0.000
44.079 897.00000 15.2000 -44.53125 0.00000 1.16500 1.16500 13.00000 1.12600 1.13300 4.90000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.2000 0.000 0.000 0.000 0.000
44.089 897.00000 15.2000 -44.53125 0.00000 1.16500 1.16500 13.00000 1.12600 1.13300 4.90000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.2000 0.000 0.000 0.000 0.000
44.099 897.00000 15.2000 -44.53125 0.00000 1.16500 1.16500 13.00000 1.12600 1.13300 4.90000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.2000 0.000 0.000 0.000 0.000
44.109 794.00000 15.2000 -44.53125 0.00000 1.04900 1.04900 12.20000 1.12600 1.13300 5.00000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.1000 0.000 0.000 0.000 0.000
44.119 794.00000 15.2000 -44.53125 0.00000 1.04900 1.04900 12.20000 1.12600 1.13300 5.00000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.1000 0.000 0.000 0.000 0.000
44.129 794.00000 15.2000 -44.53125 0.00000 1.04900 1.04900 12.20000 1.12600 1.13300 5.00000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.1000 0.000 0.000 0.000 0.000
44.139 794.00000 15.2000 -44.53125 0.00000 1.04900 1.04900 12.20000 1.12600 1.13300 5.00000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.1000 0.000 0.000 0.000 0.000
44.149 794.00000 15.2000 -44.53125 0.00000 1.04900 1.04900 12.20000 1.12600 1.13300 5.00000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.1000 0.000 0.000 0.000 0.000
44.159 794.00000 15.2000 -44.53125 0.00000 0.97300 0.97300 12.40000 1.12600 1.13300 5.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.1000 0.000 0.000 0.000 0.000
44.169 794.00000 15.2000 -44.53125 0.00000 0.97300 0.97300 12.40000 1.12600 1.13300 5.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.1000 0.000 0.000 0.000 0.000
44.179 794.00000 15.2000 -44.53125 0.00000 0.97300 0.97300 12.40000 1.12600 1.13300 5.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.1000 0.000 0.000 0.000 0.000
44.189 794.00000 15.2000 -44.53125 0.00000 0.97300 0.97300 12.40000 1.12600 1.13300 5.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.1000 0.000 0.000 0.000 0.000
44.199 794.00000 15.2000 -44.53125 0.00000 0.97300 0.97300 12.40000 1.12600 1.13300 5.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.1000 0.000 0.000 0.000 0.000
44.209 794.00000 15.2000 -44.53125 0.00000 0.89100 0.89100 12.20000 1.12600 1.13300 5.90000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.9000 0.000 0.000 0.000 0.000
44.219 794.00000 15.2000 -44.53125 0.00000 0.89100 0.89100 12.20000 1.12600 1.13300 5.90000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.9000 0.000 0.000 0.000 0.000
44.229 794.00000 15.2000 -44.53125 0.00000 0.89100 0.89100 12.20000 1.12600 1.13300 5.90000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.9000 0.000 0.000 0.000 0.000
44.239 794.00000 15.2000 -44.53125 0.00000 0.89100 0.89100 12.20000 1.12600 1.13300 5.90000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.9000 0.000 0.000 0.000 0.000
44.249 794.00000 15.2000 -44.53125 0.00000 0.89100 0.89100 12.20000 1.12600 1.13300 5.90000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.9000 0.000 0.000 0.000 0.000
44.259 655.00000 15.2000 -44.53125 0.00000 0.85100 0.85100 12.50000 1.12900 1.13900 6.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.8000 0.000 0.000 0.000 0.000
44.269 655.00000 15.2000 -44.53125 0.00000 0.85100 0.85100 12.50000 1.12900 1.13900 6.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.8000 0.000 0.000 0.000 0.000
44.279 655.00000 15.2000 -44.53125 0.00000 0.85100 0.85100 12.50000 1.12900 1.13900 6.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.8000 0.000 0.000 0.000 0.000
44.289 655.00000 15.2000 -44.53125 0.00000 0.85100 0.85100 12.50000 1.12900 1.13900 6.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.8000 0.000 0.000 0.000 0.000
44.299 655.00000 15.2000 -44.53125 0.00000 0.85100 0.85100 12.50000 1.12900 1.13900 6.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.8000 0.000 0.000 0.000 0.000
44.309 655.00000 15.2000 -44.53125 0.00000 0.91500 0.91500 12.00000 1.12900 1.13900 6.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.9000 0.000 0.000 0.000 0.000
44.319 655.00000 15.2000 -44.53125 0.00000 0.91500 0.91500 12.00000 1.12900 1.13900 6.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.9000 0.000 0.000 0.000 0.000
44.329 655.00000 15.2000 -44.53125 0.00000 0.91500 0.91500 12.00000 1.12900 1.13900 6.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.9000 0.000 0.000 0.000 0.000
44.339 655.00000 15.2000 -44.53125 0.00000 0.91500 0.91500 12.00000 1.12900 1.13900 6.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.9000 0.000 0.000 0.000 0.000
44.349 655.00000 15.2000 -44.53125 0.00000 0.91500 0.91500 12.00000 1.12900 1.13900 6.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.9000 0.000 0.000 0.000 0.000
44.359 655.00000 15.2000 -44.53125 0.00000 0.90300 0.90300 12.30000 1.12900 1.13900 6.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
44.369 655.00000 15.2000 -44.53125 0.00000 0.90300 0.90300 12.30000 1.12900 1.13900 6.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
44.379 655.00000 15.2000 -44.53125 0.00000 0.90300 0.90300 12.30000 1.12900 1.13900 6.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
44.389 655.00000 15.2000 -44.53125 0.00000 0.90300 0.90300 12.30000 1.12900 1.13900 6.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
44.399 655.00000 15.2000 -44.53125 0.00000 0.90300 0.90300 12.30000 1.12900 1.13900 6.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
44.409 639.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 12.70000 1.12900 1.13900 6.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
44.419 639.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 12.70000 1.12900 1.13900 6.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
44.429 639.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 12.70000 1.12900 1.13900 6.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
44.439 639.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 12.70000 1.12900 1.13900 6.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
44.449 639.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 12.70000 1.12900 1.13900 6.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
44.459 639.00000 15.2000 -44.53125 0.00000 0.87400 0.87400 12.50000 1.17100 1.15500 6.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
44.469 639.00000 15.2000 -44.53125 0.00000 0.87400 0.87400 12.50000 1.17100 1.15500 6.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
44.479 639.00000 15.2000 -44.53125 0.00000 0.87400 0.87400 12.50000 1.17100 1.15500 6.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
44.489 639.00000 15.2000 -44.53125 0.00000 0.87400 0.87400 12.50000 1.17100 1.15500 6.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
44.499 639.00000 15.2000 -44.53125 0.00000 0.87400 0.87400 12.50000 1.17100 1.15500 6.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
44.509 729.00000 15.2000 -44.53125 0.00000 0.84500 0.84500 12.70000 1.17100 1.15500 6.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
44.519 729.00000 15.2000 -44.53125 0.00000 0.84500 0.84500 12.70000 1.17100 1.15500 6.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
44.529 729.00000 15.2000 -44.53125 0.00000 0.84500 0.84500 12.70000 1.17100 1.15500 6.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
44.539 729.00000 15.2000 -44.53125 0.00000 0.84500 0.84500 12.70000 1.17100 1.15500 6.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
44.549 729.00000 15.2000 -44.53125 0.00000 0.84500 0.84500 12.70000 1.17100 1.15500 6.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
44.559 729.00000 15.1000 -44.53125 0.00000 0.90300 0.90300 12.90000 1.17100 1.15500 5.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.0000 0.000 0.000 0.000 0.000
44.569 729.00000 15.1000 -44.53125 0.00000 0.90300 0.90300 12.90000 1.17100 1.15500 5.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.0000 0.000 0.000 0.000 0.000
44.579 729.00000 15.1000 -44.53125 0.00000 0.90300 0.90300 12.90000 1.17100 1.15500 5.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.0000 0.000 0.000 0.000 0.000
44.589 729.00000 15.1000 -44.53125 0.00000 0.90300 0.90300 12.90000 1.17100 1.15500 5.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.0000 0.000 0.000 0.000 0.000
44.599 729.00000 15.1000 -44.53125 0.00000 0.90300 0.90300 12.90000 1.17100 1.15500 5.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.0000 0.000 0.000 0.000 0.000
44.609 729.00000 15.1000 -44.53125 0.00000 0.87400 0.87400 13.50000 1.17100 1.15500 6.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
44.619 729.00000 15.1000 -44.53125 0.00000 0.87400 0.87400 13.50000 1.17100 1.15500 6.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
44.629 729.00000 15.1000 -44.53125 0.00000 0.87400 0.87400 13.50000 1.17100 1.15500 6.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
44.639 729.00000 15.1000 -44.53125 0.00000 0.87400 0.87400 13.50000 1.17100 1.15500 6.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
44.649 729.00000 15.1000 -44.53125 0.00000 0.87400 0.87400 13.50000 1.17100 1.15500 6.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
44.659 846.00000 15.1000 -44.53125 0.00000 0.79200 0.79200 13.10000 1.18100 1.14900 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.0000 0.000 0.000 0.000 0.000
44.669 846.00000 15.1000 -44.53125 0.00000 0.79200 0.79200 13.10000 1.18100 1.14900 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.0000 0.000 0.000 0.000 0.000
44.679 846.00000 15.1000 -44.53125 0.00000 0.79200 0.79200 13.10000 1.18100 1.14900 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.0000 0.000 0.000 0.000 0.000
44.689 846.00000 15.1000 -44.53125 0.00000 0.79200 0.79200 13.10000 1.18100 1.14900 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.0000 0.000 0.000 0.000 0.000
44.699 846.00000 15.1000 -44.53125 0.00000 0.79200 0.79200 13.10000 1.18100 1.14900 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.0000 0.000 0.000 0.000 0.000
44.709 846.00000 15.1000 -44.53125 0.00000 0.79200 0.79200 13.10000 1.18100 1.14900 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.0000 0.000 0.000 0.000 0.000
44.719 846.00000 15.2000 -44.53125 0.00000 0.78700 0.78700 13.40000 1.18100 1.14900 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
44.729 846.00000 15.2000 -44.53125 0.00000 0.78700 0.78700 13.40000 1.18100 1.14900 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
44.739 846.00000 15.2000 -44.53125 0.00000 0.78700 0.78700 13.40000 1.18100 1.14900 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
44.749 846.00000 15.2000 -44.53125 0.00000 0.78700 0.78700 13.40000 1.18100 1.14900 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
44.759 846.00000 15.2000 -44.53125 0.00000 0.78700 0.78700 13.40000 1.18100 1.14900 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
44.768 846.00000 15.2000 -44.53125 0.00000 0.78700 0.78700 13.40000 1.18100 1.14900 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
44.778 958.00000 15.2000 -44.53125 0.00000 0.82200 0.82200 13.20000 1.18100 1.14900 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
44.788 958.00000 15.2000 -44.53125 0.00000 0.82200 0.82200 13.20000 1.18100 1.14900 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
44.798 958.00000 15.2000 -44.53125 0.00000 0.82200 0.82200 13.20000 1.18100 1.14900 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
44.808 958.00000 15.2000 -44.53125 0.00000 0.82200 0.82200 13.20000 1.18100 1.14900 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
44.818 958.00000 15.2000 -44.53125 0.00000 0.82200 0.82200 13.20000 1.18100 1.14900 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
44.828 958.00000 15.2000 -44.53125 0.00000 0.82200 0.82200 13.20000 1.18100 1.14900 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
44.838 1032.00000 15.1000 -44.53125 0.00000 0.88600 0.88600 13.20000 1.18100 1.14900 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 10.7000 0.000 0.000 0.000 0.000
44.848 1032.00000 15.1000 -44.53125 0.00000 0.88600 0.88600 13.20000 1.18100 1.14900 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 10.7000 0.000 0.000 0.000 0.000
44.858 1032.00000 15.1000 -44.53125 0.00000 0.88600 0.88600 13.20000 1.18100 1.14900 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 10.7000 0.000 0.000 0.000 0.000
44.868 1032.00000 15.1000 -44.53125 0.00000 0.88600 0.88600 13.20000 1.18100 1.14900 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 10.7000 0.000 0.000 0.000 0.000
44.878 1032.00000 15.1000 -44.53125 0.00000 0.88600 0.88600 13.20000 1.18100 1.14900 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 10.7000 0.000 0.000 0.000 0.000
44.888 1032.00000 15.1000 -44.53125 0.00000 0.92100 0.92100 13.10000 1.15800 1.13600 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 10.7000 0.000 0.000 0.000 0.000
44.898 1032.00000 15.1000 -44.53125 0.00000 0.92100 0.92100 13.10000 1.15800 1.13600 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 10.7000 0.000 0.000 0.000 0.000
44.908 1032.00000 15.1000 -44.53125 0.00000 0.92100 0.92100 13.10000 1.15800 1.13600 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 10.7000 0.000 0.000 0.000 0.000
44.918 1032.00000 15.1000 -44.53125 0.00000 0.92100 0.92100 13.10000 1.15800 1.13600 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 10.7000 0.000 0.000 0.000 0.000
44.928 1032.00000 15.1000 -44.53125 0.00000 0.92100 0.92100 13.10000 1.15800 1.13600 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 10.7000 0.000 0.000 0.000 0.000
44.938 1067.00000 15.2000 -44.53125 0.00000 0.92100 0.92100 13.10000 1.15800 1.13600 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 10.6000 0.000 0.000 0.000 0.000
44.948 1067.00000 15.2000 -44.53125 0.00000 0.92100 0.92100 13.10000 1.15800 1.13600 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 10.6000 0.000 0.000 0.000 0.000
44.958 1067.00000 15.2000 -44.53125 0.00000 0.92100 0.92100 13.10000 1.15800 1.13600 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 10.6000 0.000 0.000 0.000 0.000
44.968 1067.00000 15.2000 -44.53125 0.00000 0.92100 0.92100 13.10000 1.15800 1.13600 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 10.6000 0.000 0.000 0.000 0.000
44.978 1067.00000 15.2000 -44.53125 0.00000 0.92100 0.92100 13.10000 1.15800 1.13600 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 10.6000 0.000 0.000 0.000 0.000
44.988 1067.00000 15.2000 -44.53125 0.00000 0.91500 0.91500 13.20000 1.15800 1.13600 4.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.0000 0.000 0.000 0.000 0.000
44.998 1067.00000 15.2000 -44.53125 0.00000 0.91500 0.91500 13.20000 1.15800 1.13600 4.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.0000 0.000 0.000 0.000 0.000
45.008 1067.00000 15.2000 -44.53125 0.00000 0.91500 0.91500 13.20000 1.15800 1.13600 4.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.0000 0.000 0.000 0.000 0.000
45.018 1067.00000 15.2000 -44.53125 0.00000 0.91500 0.91500 13.20000 1.15800 1.13600 4.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.0000 0.000 0.000 0.000 0.000
45.028 1067.00000 15.2000 -44.53125 0.00000 0.91500 0.91500 13.20000 1.15800 1.13600 4.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.0000 0.000 0.000 0.000 0.000
45.038 1039.00000 15.4000 -44.53125 0.00000 0.98500 0.98500 12.60000 1.15800 1.13600 4.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.0000 0.000 0.000 0.000 0.000
45.048 1039.00000 15.4000 -44.53125 0.00000 0.98500 0.98500 12.60000 1.15800 1.13600 4.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.0000 0.000 0.000 0.000 0.000
45.058 1039.00000 15.4000 -44.53125 0.00000 0.98500 0.98500 12.60000 1.15800 1.13600 4.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.0000 0.000 0.000 0.000 0.000
45.068 1039.00000 15.4000 -44.53125 0.00000 0.98500 0.98500 12.60000 1.15800 1.13600 4.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.0000 0.000 0.000 0.000 0.000
45.078 1039.00000 15.4000 -44.53125 0.00000 0.98500 0.98500 12.60000 1.15800 1.13600 4.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.0000 0.000 0.000 0.000 0.000
45.088 1039.00000 15.2000 -44.53125 0.00000 1.02600 1.02600 13.50000 1.13300 1.13900 4.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.0000 0.000 0.000 0.000 0.000
45.098 1039.00000 15.2000 -44.53125 0.00000 1.02600 1.02600 13.50000 1.13300 1.13900 4.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.0000 0.000 0.000 0.000 0.000
45.108 1039.00000 15.2000 -44.53125 0.00000 1.02600 1.02600 13.50000 1.13300 1.13900 4.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.0000 0.000 0.000 0.000 0.000
45.118 1039.00000 15.2000 -44.53125 0.00000 1.02600 1.02600 13.50000 1.13300 1.13900 4.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.0000 0.000 0.000 0.000 0.000
45.128 1039.00000 15.2000 -44.53125 0.00000 1.02600 1.02600 13.50000 1.13300 1.13900 4.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.0000 0.000 0.000 0.000 0.000
45.138 993.00000 15.1000 -44.53125 0.00000 1.09600 1.09600 13.30000 1.13300 1.13900 4.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.6000 0.000 0.000 0.000 0.000
45.148 993.00000 15.1000 -44.53125 0.00000 1.09600 1.09600 13.30000 1.13300 1.13900 4.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.6000 0.000 0.000 0.000 0.000
45.158 993.00000 15.1000 -44.53125 0.00000 1.09600 1.09600 13.30000 1.13300 1.13900 4.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.6000 0.000 0.000 0.000 0.000
45.168 993.00000 15.1000 -44.53125 0.00000 1.09600 1.09600 13.30000 1.13300 1.13900 4.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.6000 0.000 0.000 0.000 0.000
45.178 993.00000 15.1000 -44.53125 0.00000 1.09600 1.09600 13.30000 1.13300 1.13900 4.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.6000 0.000 0.000 0.000 0.000
45.188 993.00000 15.1000 -44.53125 0.00000 1.04300 1.04300 13.20000 1.13300 1.13900 4.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.7000 0.000 0.000 0.000 0.000
45.198 993.00000 15.1000 -44.53125 0.00000 1.04300 1.04300 13.20000 1.13300 1.13900 4.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.7000 0.000 0.000 0.000 0.000
45.208 993.00000 15.1000 -44.53125 0.00000 1.04300 1.04300 13.20000 1.13300 1.13900 4.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.7000 0.000 0.000 0.000 0.000
45.218 993.00000 15.1000 -44.53125 0.00000 1.04300 1.04300 13.20000 1.13300 1.13900 4.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.7000 0.000 0.000 0.000 0.000
45.228 993.00000 15.1000 -44.53125 0.00000 1.04300 1.04300 13.20000 1.13300 1.13900 4.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.7000 0.000 0.000 0.000 0.000
45.238 959.00000 15.2000 -44.53125 0.00000 1.03100 1.03100 13.20000 1.13300 1.13900 4.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.7000 0.000 0.000 0.000 0.000
45.248 959.00000 15.2000 -44.53125 0.00000 1.03100 1.03100 13.20000 1.13300 1.13900 4.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.7000 0.000 0.000 0.000 0.000
45.258 959.00000 15.2000 -44.53125 0.00000 1.03100 1.03100 13.20000 1.13300 1.13900 4.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.7000 0.000 0.000 0.000 0.000
45.268 959.00000 15.2000 -44.53125 0.00000 1.03100 1.03100 13.20000 1.13300 1.13900 4.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.7000 0.000 0.000 0.000 0.000
45.278 959.00000 15.2000 -44.53125 0.00000 1.03100 1.03100 13.20000 1.13300 1.13900 4.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.7000 0.000 0.000 0.000 0.000
45.288 959.00000 15.1000 -44.53125 0.00000 1.11300 1.11300 13.10000 1.09800 1.15500 4.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
45.298 959.00000 15.1000 -44.53125 0.00000 1.11300 1.11300 13.10000 1.09800 1.15500 4.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
45.308 959.00000 15.1000 -44.53125 0.00000 1.11300 1.11300 13.10000 1.09800 1.15500 4.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
45.318 959.00000 15.1000 -44.53125 0.00000 1.11300 1.11300 13.10000 1.09800 1.15500 4.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
45.328 959.00000 15.1000 -44.53125 0.00000 1.11300 1.11300 13.10000 1.09800 1.15500 4.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
45.338 939.00000 15.2000 -44.53125 0.00000 1.13000 1.13000 13.20000 1.09800 1.15500 4.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
45.348 939.00000 15.2000 -44.53125 0.00000 1.13000 1.13000 13.20000 1.09800 1.15500 4.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
45.358 939.00000 15.2000 -44.53125 0.00000 1.13000 1.13000 13.20000 1.09800 1.15500 4.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
45.368 939.00000 15.2000 -44.53125 0.00000 1.13000 1.13000 13.20000 1.09800 1.15500 4.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
45.378 939.00000 15.2000 -44.53125 0.00000 1.13000 1.13000 13.20000 1.09800 1.15500 4.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
45.388 939.00000 15.2000 -44.53125 0.00000 1.07200 1.07200 13.50000 1.09800 1.15500 4.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
45.398 939.00000 15.2000 -44.53125 0.00000 1.07200 1.07200 13.50000 1.09800 1.15500 4.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
45.408 939.00000 15.2000 -44.53125 0.00000 1.07200 1.07200 13.50000 1.09800 1.15500 4.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
45.418 939.00000 15.2000 -44.53125 0.00000 1.07200 1.07200 13.50000 1.09800 1.15500 4.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
45.428 939.00000 15.2000 -44.53125 0.00000 1.07200 1.07200 13.50000 1.09800 1.15500 4.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
45.438 867.00000 15.1000 -44.53125 0.00000 1.07200 1.07200 13.60000 1.09800 1.15500 4.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
45.448 867.00000 15.1000 -44.53125 0.00000 1.07200 1.07200 13.60000 1.09800 1.15500 4.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
45.458 867.00000 15.1000 -44.53125 0.00000 1.07200 1.07200 13.60000 1.09800 1.15500 4.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
45.468 867.00000 15.1000 -44.53125 0.00000 1.07200 1.07200 13.60000 1.09800 1.15500 4.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
45.478 867.00000 15.1000 -44.53125 0.00000 1.07200 1.07200 13.60000 1.09800 1.15500 4.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
45.488 867.00000 15.2000 -44.53125 0.00000 1.02000 1.02000 13.30000 1.06200 1.15500 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.2000 0.000 0.000 0.000 0.000
45.498 867.00000 15.2000 -44.53125 0.00000 1.02000 1.02000 13.30000 1.06200 1.15500 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.2000 0.000 0.000 0.000 0.000
45.508 867.00000 15.2000 -44.53125 0.00000 1.02000 1.02000 13.30000 1.06200 1.15500 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.2000 0.000 0.000 0.000 0.000
45.518 867.00000 15.2000 -44.53125 0.00000 1.02000 1.02000 13.30000 1.06200 1.15500 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.2000 0.000 0.000 0.000 0.000
45.528 867.00000 15.2000 -44.53125 0.00000 1.02000 1.02000 13.30000 1.06200 1.15500 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.2000 0.000 0.000 0.000 0.000
45.538 809.00000 15.2000 -44.53125 0.00000 1.02000 1.02000 13.10000 1.06200 1.15500 4.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.2000 0.000 0.000 0.000 0.000
45.548 809.00000 15.2000 -44.53125 0.00000 1.02000 1.02000 13.10000 1.06200 1.15500 4.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.2000 0.000 0.000 0.000 0.000
45.558 809.00000 15.2000 -44.53125 0.00000 1.02000 1.02000 13.10000 1.06200 1.15500 4.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.2000 0.000 0.000 0.000 0.000
45.568 809.00000 15.2000 -44.53125 0.00000 1.02000 1.02000 13.10000 1.06200 1.15500 4.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.2000 0.000 0.000 0.000 0.000
45.578 809.00000 15.2000 -44.53125 0.00000 1.02000 1.02000 13.10000 1.06200 1.15500 4.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.2000 0.000 0.000 0.000 0.000
45.588 809.00000 15.2000 -44.53125 0.00000 0.96100 0.96100 13.00000 1.06200 1.15500 5.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.2000 0.000 0.000 0.000 0.000
45.598 809.00000 15.2000 -44.53125 0.00000 0.96100 0.96100 13.00000 1.06200 1.15500 5.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.2000 0.000 0.000 0.000 0.000
45.608 809.00000 15.2000 -44.53125 0.00000 0.96100 0.96100 13.00000 1.06200 1.15500 5.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.2000 0.000 0.000 0.000 0.000
45.618 809.00000 15.2000 -44.53125 0.00000 0.96100 0.96100 13.00000 1.06200 1.15500 5.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.2000 0.000 0.000 0.000 0.000
45.628 809.00000 15.2000 -44.53125 0.00000 0.96100 0.96100 13.00000 1.06200 1.15500 5.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.2000 0.000 0.000 0.000 0.000
45.638 809.00000 15.2000 -44.53125 0.00000 0.93800 0.93800 13.00000 1.06200 1.15500 5.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.6000 0.000 0.000 0.000 0.000
45.648 809.00000 15.2000 -44.53125 0.00000 0.93800 0.93800 13.00000 1.06200 1.15500 5.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.6000 0.000 0.000 0.000 0.000
45.658 809.00000 15.2000 -44.53125 0.00000 0.93800 0.93800 13.00000 1.06200 1.15500 5.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.6000 0.000 0.000 0.000 0.000
45.668 809.00000 15.2000 -44.53125 0.00000 0.93800 0.93800 13.00000 1.06200 1.15500 5.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.6000 0.000 0.000 0.000 0.000
45.678 809.00000 15.2000 -44.53125 0.00000 0.93800 0.93800 13.00000 1.06200 1.15500 5.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.6000 0.000 0.000 0.000 0.000
45.688 773.00000 15.2000 -44.53125 0.00000 0.86800 0.86800 12.30000 1.09400 1.15800 5.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
45.698 773.00000 15.2000 -44.53125 0.00000 0.86800 0.86800 12.30000 1.09400 1.15800 5.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
45.708 773.00000 15.2000 -44.53125 0.00000 0.86800 0.86800 12.30000 1.09400 1.15800 5.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
45.718 773.00000 15.2000 -44.53125 0.00000 0.86800 0.86800 12.30000 1.09400 1.15800 5.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
45.728 773.00000 15.2000 -44.53125 0.00000 0.86800 0.86800 12.30000 1.09400 1.15800 5.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
45.738 773.00000 15.2000 -44.53125 0.00000 0.85100 0.85100 13.10000 1.09400 1.15800 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
45.748 773.00000 15.2000 -44.53125 0.00000 0.85100 0.85100 13.10000 1.09400 1.15800 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
45.758 773.00000 15.2000 -44.53125 0.00000 0.85100 0.85100 13.10000 1.09400 1.15800 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
45.768 773.00000 15.2000 -44.53125 0.00000 0.85100 0.85100 13.10000 1.09400 1.15800 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
45.778 773.00000 15.2000 -44.53125 0.00000 0.85100 0.85100 13.10000 1.09400 1.15800 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
45.788 773.00000 15.1000 -44.53125 0.00000 0.86800 0.86800 13.10000 1.09400 1.15800 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.8000 0.000 0.000 0.000 0.000
45.798 773.00000 15.1000 -44.53125 0.00000 0.86800 0.86800 13.10000 1.09400 1.15800 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.8000 0.000 0.000 0.000 0.000
45.808 773.00000 15.1000 -44.53125 0.00000 0.86800 0.86800 13.10000 1.09400 1.15800 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.8000 0.000 0.000 0.000 0.000
45.818 773.00000 15.1000 -44.53125 0.00000 0.86800 0.86800 13.10000 1.09400 1.15800 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.8000 0.000 0.000 0.000 0.000
45.828 773.00000 15.1000 -44.53125 0.00000 0.86800 0.86800 13.10000 1.09400 1.15800 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.8000 0.000 0.000 0.000 0.000
45.838 747.00000 15.4000 -44.53125 0.00000 0.95000 0.95000 12.10000 1.09400 1.15800 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
45.848 747.00000 15.4000 -44.53125 0.00000 0.95000 0.95000 12.10000 1.09400 1.15800 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
45.858 747.00000 15.4000 -44.53125 0.00000 0.95000 0.95000 12.10000 1.09400 1.15800 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
45.868 747.00000 15.4000 -44.53125 0.00000 0.95000 0.95000 12.10000 1.09400 1.15800 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
45.878 747.00000 15.4000 -44.53125 0.00000 0.95000 0.95000 12.10000 1.09400 1.15800 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
45.888 747.00000 15.2000 -44.53125 0.00000 0.95600 0.95600 13.10000 1.13300 1.15800 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
45.898 747.00000 15.2000 -44.53125 0.00000 0.95600 0.95600 13.10000 1.13300 1.15800 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
45.908 747.00000 15.2000 -44.53125 0.00000 0.95600 0.95600 13.10000 1.13300 1.15800 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
45.918 747.00000 15.2000 -44.53125 0.00000 0.95600 0.95600 13.10000 1.13300 1.15800 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
45.928 747.00000 15.2000 -44.53125 0.00000 0.95600 0.95600 13.10000 1.13300 1.15800 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
45.938 765.00000 15.2000 -44.53125 0.00000 0.90300 0.90300 12.90000 1.13300 1.15800 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
45.948 765.00000 15.2000 -44.53125 0.00000 0.90300 0.90300 12.90000 1.13300 1.15800 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
45.958 765.00000 15.2000 -44.53125 0.00000 0.90300 0.90300 12.90000 1.13300 1.15800 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
45.968 765.00000 15.2000 -44.53125 0.00000 0.90300 0.90300 12.90000 1.13300 1.15800 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
45.978 765.00000 15.2000 -44.53125 0.00000 0.90300 0.90300 12.90000 1.13300 1.15800 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
45.988 765.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 13.20000 1.13300 1.15800 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
45.998 765.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 13.20000 1.13300 1.15800 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
46.008 765.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 13.20000 1.13300 1.15800 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
46.018 765.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 13.20000 1.13300 1.15800 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
46.028 765.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 13.20000 1.13300 1.15800 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
46.038 765.00000 15.2000 -44.53125 0.00000 0.85600 0.85600 13.10000 1.13300 1.15800 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
46.048 765.00000 15.2000 -44.53125 0.00000 0.85600 0.85600 13.10000 1.13300 1.15800 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
46.058 765.00000 15.2000 -44.53125 0.00000 0.85600 0.85600 13.10000 1.13300 1.15800 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
46.068 765.00000 15.2000 -44.53125 0.00000 0.85600 0.85600 13.10000 1.13300 1.15800 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
46.078 765.00000 15.2000 -44.53125 0.00000 0.85600 0.85600 13.10000 1.13300 1.15800 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
46.088 813.00000 15.1000 -44.53125 0.00000 0.85600 0.85600 13.50000 1.15500 1.15500 5.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
46.098 813.00000 15.1000 -44.53125 0.00000 0.85600 0.85600 13.50000 1.15500 1.15500 5.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
46.108 813.00000 15.1000 -44.53125 0.00000 0.85600 0.85600 13.50000 1.15500 1.15500 5.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
46.118 813.00000 15.1000 -44.53125 0.00000 0.85600 0.85600 13.50000 1.15500 1.15500 5.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
46.128 813.00000 15.1000 -44.53125 0.00000 0.85600 0.85600 13.50000 1.15500 1.15500 5.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
46.138 813.00000 15.2000 -44.53125 0.00000 0.88600 0.88600 13.40000 1.15500 1.15500 5.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.1000 0.000 0.000 0.000 0.000
46.148 813.00000 15.2000 -44.53125 0.00000 0.88600 0.88600 13.40000 1.15500 1.15500 5.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.1000 0.000 0.000 0.000 0.000
46.158 813.00000 15.2000 -44.53125 0.00000 0.88600 0.88600 13.40000 1.15500 1.15500 5.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.1000 0.000 0.000 0.000 0.000
46.168 813.00000 15.2000 -44.53125 0.00000 0.88600 0.88600 13.40000 1.15500 1.15500 5.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.1000 0.000 0.000 0.000 0.000
46.178 813.00000 15.2000 -44.53125 0.00000 0.88600 0.88600 13.40000 1.15500 1.15500 5.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.1000 0.000 0.000 0.000 0.000
46.188 877.00000 15.1000 -44.53125 0.00000 0.90300 0.90300 13.30000 1.15500 1.15500 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.1000 0.000 0.000 0.000 0.000
46.198 877.00000 15.1000 -44.53125 0.00000 0.90300 0.90300 13.30000 1.15500 1.15500 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.1000 0.000 0.000 0.000 0.000
46.208 877.00000 15.1000 -44.53125 0.00000 0.90300 0.90300 13.30000 1.15500 1.15500 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.1000 0.000 0.000 0.000 0.000
46.218 877.00000 15.1000 -44.53125 0.00000 0.90300 0.90300 13.30000 1.15500 1.15500 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.1000 0.000 0.000 0.000 0.000
46.228 877.00000 15.1000 -44.53125 0.00000 0.90300 0.90300 13.30000 1.15500 1.15500 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.1000 0.000 0.000 0.000 0.000
46.238 877.00000 15.2000 -44.53125 0.00000 0.91500 0.91500 13.50000 1.15500 1.15500 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
46.248 877.00000 15.2000 -44.53125 0.00000 0.91500 0.91500 13.50000 1.15500 1.15500 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
46.258 877.00000 15.2000 -44.53125 0.00000 0.91500 0.91500 13.50000 1.15500 1.15500 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
46.268 877.00000 15.2000 -44.53125 0.00000 0.91500 0.91500 13.50000 1.15500 1.15500 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
46.278 877.00000 15.2000 -44.53125 0.00000 0.91500 0.91500 13.50000 1.15500 1.15500 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
46.288 877.00000 15.2000 -44.53125 0.00000 0.91500 0.91500 13.50000 1.15500 1.15500 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
46.298 908.00000 15.1000 -44.53125 0.00000 0.90300 0.90300 13.10000 1.15200 1.14900 4.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
46.308 908.00000 15.1000 -44.53125 0.00000 0.90300 0.90300 13.10000 1.15200 1.14900 4.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
46.318 908.00000 15.1000 -44.53125 0.00000 0.90300 0.90300 13.10000 1.15200 1.14900 4.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
46.328 908.00000 15.1000 -44.53125 0.00000 0.90300 0.90300 13.10000 1.15200 1.14900 4.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
46.338 908.00000 15.1000 -44.53125 0.00000 0.90300 0.90300 13.10000 1.15200 1.14900 4.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
46.348 908.00000 15.1000 -44.53125 0.00000 0.90300 0.90300 13.10000 1.15200 1.14900 4.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
46.358 908.00000 15.2000 -44.53125 0.00000 0.90300 0.90300 13.30000 1.15200 1.14900 4.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
46.368 908.00000 15.2000 -44.53125 0.00000 0.90300 0.90300 13.30000 1.15200 1.14900 4.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
46.378 908.00000 15.2000 -44.53125 0.00000 0.90300 0.90300 13.30000 1.15200 1.14900 4.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
46.388 908.00000 15.2000 -44.53125 0.00000 0.90300 0.90300 13.30000 1.15200 1.14900 4.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
46.398 908.00000 15.2000 -44.53125 0.00000 0.90300 0.90300 13.30000 1.15200 1.14900 4.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
46.408 908.00000 15.2000 -44.53125 0.00000 0.90300 0.90300 13.30000 1.15200 1.14900 4.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
46.418 934.00000 15.1000 -44.53125 0.00000 0.91500 0.91500 13.30000 1.15200 1.14900 4.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
46.428 934.00000 15.1000 -44.53125 0.00000 0.91500 0.91500 13.30000 1.15200 1.14900 4.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
46.438 934.00000 15.1000 -44.53125 0.00000 0.91500 0.91500 13.30000 1.15200 1.14900 4.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
46.448 934.00000 15.1000 -44.53125 0.00000 0.91500 0.91500 13.30000 1.15200 1.14900 4.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
46.458 934.00000 15.1000 -44.53125 0.00000 0.91500 0.91500 13.30000 1.15200 1.14900 4.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
46.468 934.00000 15.1000 -44.53125 0.00000 0.91500 0.91500 13.30000 1.15200 1.14900 4.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
46.478 931.00000 15.1000 -44.53125 0.00000 0.86200 0.86200 13.60000 1.13600 1.14500 4.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
46.488 931.00000 15.1000 -44.53125 0.00000 0.86200 0.86200 13.60000 1.13600 1.14500 4.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
46.498 931.00000 15.1000 -44.53125 0.00000 0.86200 0.86200 13.60000 1.13600 1.14500 4.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
46.508 931.00000 15.1000 -44.53125 0.00000 0.86200 0.86200 13.60000 1.13600 1.14500 4.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
46.518 931.00000 15.1000 -44.53125 0.00000 0.86200 0.86200 13.60000 1.13600 1.14500 4.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
46.528 931.00000 15.1000 -44.53125 0.00000 0.93200 0.93200 13.70000 1.13600 1.14500 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.2000 0.000 0.000 0.000 0.000
46.538 931.00000 15.1000 -44.53125 0.00000 0.93200 0.93200 13.70000 1.13600 1.14500 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.2000 0.000 0.000 0.000 0.000
46.548 931.00000 15.1000 -44.53125 0.00000 0.93200 0.93200 13.70000 1.13600 1.14500 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.2000 0.000 0.000 0.000 0.000
46.558 931.00000 15.1000 -44.53125 0.00000 0.93200 0.93200 13.70000 1.13600 1.14500 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.2000 0.000 0.000 0.000 0.000
46.568 931.00000 15.1000 -44.53125 0.00000 0.93200 0.93200 13.70000 1.13600 1.14500 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.2000 0.000 0.000 0.000 0.000
46.578 927.00000 15.2000 -44.53125 0.00000 0.92100 0.92100 13.10000 1.13600 1.14500 4.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
46.588 927.00000 15.2000 -44.53125 0.00000 0.92100 0.92100 13.10000 1.13600 1.14500 4.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
46.598 927.00000 15.2000 -44.53125 0.00000 0.92100 0.92100 13.10000 1.13600 1.14500 4.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
46.608 927.00000 15.2000 -44.53125 0.00000 0.92100 0.92100 13.10000 1.13600 1.14500 4.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
46.618 927.00000 15.2000 -44.53125 0.00000 0.92100 0.92100 13.10000 1.13600 1.14500 4.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
46.628 927.00000 15.2000 -44.53125 0.00000 0.91500 0.91500 13.50000 1.13600 1.14500 4.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
46.638 927.00000 15.2000 -44.53125 0.00000 0.91500 0.91500 13.50000 1.13600 1.14500 4.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
46.648 927.00000 15.2000 -44.53125 0.00000 0.91500 0.91500 13.50000 1.13600 1.14500 4.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
46.658 927.00000 15.2000 -44.53125 0.00000 0.91500 0.91500 13.50000 1.13600 1.14500 4.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
46.668 927.00000 15.2000 -44.53125 0.00000 0.91500 0.91500 13.50000 1.13600 1.14500 4.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
46.678 927.00000 15.1000 -44.53125 0.00000 0.81600 0.81600 12.90000 1.11700 1.14200 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
46.688 927.00000 15.1000 -44.53125 0.00000 0.81600 0.81600 12.90000 1.11700 1.14200 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
46.698 927.00000 15.1000 -44.53125 0.00000 0.81600 0.81600 12.90000 1.11700 1.14200 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
46.708 927.00000 15.1000 -44.53125 0.00000 0.81600 0.81600 12.90000 1.11700 1.14200 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
46.718 927.00000 15.1000 -44.53125 0.00000 0.81600 0.81600 12.90000 1.11700 1.14200 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
46.728 885.00000 15.2000 -44.53125 0.00000 0.90300 0.90300 13.30000 1.11700 1.14200 4.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.7000 0.000 0.000 0.000 0.000
46.738 885.00000 15.2000 -44.53125 0.00000 0.90300 0.90300 13.30000 1.11700 1.14200 4.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.7000 0.000 0.000 0.000 0.000
46.748 885.00000 15.2000 -44.53125 0.00000 0.90300 0.90300 13.30000 1.11700 1.14200 4.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.7000 0.000 0.000 0.000 0.000
46.758 885.00000 15.2000 -44.53125 0.00000 0.90300 0.90300 13.30000 1.11700 1.14200 4.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.7000 0.000 0.000 0.000 0.000
46.768 885.00000 15.2000 -44.53125 0.00000 0.90300 0.90300 13.30000 1.11700 1.14200 4.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.7000 0.000 0.000 0.000 0.000
46.778 885.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 13.20000 1.11700 1.14200 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.8000 0.000 0.000 0.000 0.000
46.788 885.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 13.20000 1.11700 1.14200 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.8000 0.000 0.000 0.000 0.000
46.798 885.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 13.20000 1.11700 1.14200 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.8000 0.000 0.000 0.000 0.000
46.808 885.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 13.20000 1.11700 1.14200 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.8000 0.000 0.000 0.000 0.000
46.818 885.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 13.20000 1.11700 1.14200 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.8000 0.000 0.000 0.000 0.000
46.828 855.00000 15.1000 -44.53125 0.00000 0.95000 0.95000 13.50000 1.11700 1.14200 4.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.7000 0.000 0.000 0.000 0.000
46.838 855.00000 15.1000 -44.53125 0.00000 0.95000 0.95000 13.50000 1.11700 1.14200 4.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.7000 0.000 0.000 0.000 0.000
46.848 855.00000 15.1000 -44.53125 0.00000 0.95000 0.95000 13.50000 1.11700 1.14200 4.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.7000 0.000 0.000 0.000 0.000
46.858 855.00000 15.1000 -44.53125 0.00000 0.95000 0.95000 13.50000 1.11700 1.14200 4.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.7000 0.000 0.000 0.000 0.000
46.868 855.00000 15.1000 -44.53125 0.00000 0.95000 0.95000 13.50000 1.11700 1.14200 4.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.7000 0.000 0.000 0.000 0.000
46.878 855.00000 15.2000 -44.53125 0.00000 0.90300 0.90300 13.10000 1.10100 1.14500 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
46.888 855.00000 15.2000 -44.53125 0.00000 0.90300 0.90300 13.10000 1.10100 1.14500 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
46.898 855.00000 15.2000 -44.53125 0.00000 0.90300 0.90300 13.10000 1.10100 1.14500 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
46.908 855.00000 15.2000 -44.53125 0.00000 0.90300 0.90300 13.10000 1.10100 1.14500 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
46.918 855.00000 15.2000 -44.53125 0.00000 0.90300 0.90300 13.10000 1.10100 1.14500 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
46.928 842.00000 15.1000 -44.53125 0.00000 0.97300 0.97300 13.20000 1.10100 1.14500 4.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
46.938 842.00000 15.1000 -44.53125 0.00000 0.97300 0.97300 13.20000 1.10100 1.14500 4.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
46.948 842.00000 15.1000 -44.53125 0.00000 0.97300 0.97300 13.20000 1.10100 1.14500 4.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
46.958 842.00000 15.1000 -44.53125 0.00000 0.97300 0.97300 13.20000 1.10100 1.14500 4.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
46.968 842.00000 15.1000 -44.53125 0.00000 0.97300 0.97300 13.20000 1.10100 1.14500 4.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
46.978 842.00000 15.2000 -44.53125 0.00000 0.93800 0.93800 13.30000 1.10100 1.14500 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
46.988 842.00000 15.2000 -44.53125 0.00000 0.93800 0.93800 13.30000 1.10100 1.14500 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
46.998 842.00000 15.2000 -44.53125 0.00000 0.93800 0.93800 13.30000 1.10100 1.14500 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
47.008 842.00000 15.2000 -44.53125 0.00000 0.93800 0.93800 13.30000 1.10100 1.14500 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
47.018 842.00000 15.2000 -44.53125 0.00000 0.93800 0.93800 13.30000 1.10100 1.14500 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
47.028 842.00000 15.2000 -44.53125 0.00000 0.89700 0.89700 13.10000 1.10100 1.14500 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.4000 0.000 0.000 0.000 0.000
47.038 842.00000 15.2000 -44.53125 0.00000 0.89700 0.89700 13.10000 1.10100 1.14500 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.4000 0.000 0.000 0.000 0.000
47.048 842.00000 15.2000 -44.53125 0.00000 0.89700 0.89700 13.10000 1.10100 1.14500 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.4000 0.000 0.000 0.000 0.000
47.058 842.00000 15.2000 -44.53125 0.00000 0.89700 0.89700 13.10000 1.10100 1.14500 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.4000 0.000 0.000 0.000 0.000
47.068 842.00000 15.2000 -44.53125 0.00000 0.89700 0.89700 13.10000 1.10100 1.14500 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.4000 0.000 0.000 0.000 0.000
47.078 797.00000 15.2000 -44.53125 0.00000 0.86800 0.86800 12.60000 1.09100 1.14200 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
47.088 797.00000 15.2000 -44.53125 0.00000 0.86800 0.86800 12.60000 1.09100 1.14200 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
47.098 797.00000 15.2000 -44.53125 0.00000 0.86800 0.86800 12.60000 1.09100 1.14200 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
47.108 797.00000 15.2000 -44.53125 0.00000 0.86800 0.86800 12.60000 1.09100 1.14200 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
47.118 797.00000 15.2000 -44.53125 0.00000 0.86800 0.86800 12.60000 1.09100 1.14200 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
47.128 797.00000 15.2000 -44.53125 0.00000 0.86800 0.86800 13.10000 1.09100 1.14200 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.4000 0.000 0.000 0.000 0.000
47.138 797.00000 15.2000 -44.53125 0.00000 0.86800 0.86800 13.10000 1.09100 1.14200 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.4000 0.000 0.000 0.000 0.000
47.148 797.00000 15.2000 -44.53125 0.00000 0.86800 0.86800 13.10000 1.09100 1.14200 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.4000 0.000 0.000 0.000 0.000
47.158 797.00000 15.2000 -44.53125 0.00000 0.86800 0.86800 13.10000 1.09100 1.14200 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.4000 0.000 0.000 0.000 0.000
47.168 797.00000 15.2000 -44.53125 0.00000 0.86800 0.86800 13.10000 1.09100 1.14200 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.4000 0.000 0.000 0.000 0.000
47.178 780.00000 15.2000 -44.53125 0.00000 0.84500 0.84500 13.40000 1.09100 1.14200 5.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
47.188 780.00000 15.2000 -44.53125 0.00000 0.84500 0.84500 13.40000 1.09100 1.14200 5.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
47.198 780.00000 15.2000 -44.53125 0.00000 0.84500 0.84500 13.40000 1.09100 1.14200 5.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
47.208 780.00000 15.2000 -44.53125 0.00000 0.84500 0.84500 13.40000 1.09100 1.14200 5.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
47.218 780.00000 15.2000 -44.53125 0.00000 0.84500 0.84500 13.40000 1.09100 1.14200 5.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
47.228 780.00000 15.1000 -44.53125 0.00000 0.88600 0.88600 13.20000 1.09100 1.14200 5.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
47.238 780.00000 15.1000 -44.53125 0.00000 0.88600 0.88600 13.20000 1.09100 1.14200 5.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
47.248 780.00000 15.1000 -44.53125 0.00000 0.88600 0.88600 13.20000 1.09100 1.14200 5.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
47.258 780.00000 15.1000 -44.53125 0.00000 0.88600 0.88600 13.20000 1.09100 1.14200 5.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
47.268 780.00000 15.1000 -44.53125 0.00000 0.88600 0.88600 13.20000 1.09100 1.14200 5.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
47.278 780.00000 15.2000 -44.53125 0.00000 0.89700 0.89700 13.00000 1.08200 1.15200 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
47.288 780.00000 15.2000 -44.53125 0.00000 0.89700 0.89700 13.00000 1.08200 1.15200 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
47.298 780.00000 15.2000 -44.53125 0.00000 0.89700 0.89700 13.00000 1.08200 1.15200 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
47.308 780.00000 15.2000 -44.53125 0.00000 0.89700 0.89700 13.00000 1.08200 1.15200 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
47.318 780.00000 15.2000 -44.53125 0.00000 0.89700 0.89700 13.00000 1.08200 1.15200 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
47.328 761.00000 15.1000 -44.53125 0.00000 0.88000 0.88000 13.20000 1.08200 1.15200 5.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.4000 0.000 0.000 0.000 0.000
47.338 761.00000 15.1000 -44.53125 0.00000 0.88000 0.88000 13.20000 1.08200 1.15200 5.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.4000 0.000 0.000 0.000 0.000
47.348 761.00000 15.1000 -44.53125 0.00000 0.88000 0.88000 13.20000 1.08200 1.15200 5.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.4000 0.000 0.000 0.000 0.000
47.358 761.00000 15.1000 -44.53125 0.00000 0.88000 0.88000 13.20000 1.08200 1.15200 5.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.4000 0.000 0.000 0.000 0.000
47.368 761.00000 15.1000 -44.53125 0.00000 0.88000 0.88000 13.20000 1.08200 1.15200 5.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.4000 0.000 0.000 0.000 0.000
47.378 761.00000 15.1000 -44.53125 0.00000 0.89100 0.89100 12.90000 1.08200 1.15200 5.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.4000 0.000 0.000 0.000 0.000
47.388 761.00000 15.1000 -44.53125 0.00000 0.89100 0.89100 12.90000 1.08200 1.15200 5.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.4000 0.000 0.000 0.000 0.000
47.398 761.00000 15.1000 -44.53125 0.00000 0.89100 0.89100 12.90000 1.08200 1.15200 5.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.4000 0.000 0.000 0.000 0.000
47.408 761.00000 15.1000 -44.53125 0.00000 0.89100 0.89100 12.90000 1.08200 1.15200 5.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.4000 0.000 0.000 0.000 0.000
47.418 761.00000 15.1000 -44.53125 0.00000 0.89100 0.89100 12.90000 1.08200 1.15200 5.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.4000 0.000 0.000 0.000 0.000
47.428 766.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 13.00000 1.08200 1.15200 5.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.4000 0.000 0.000 0.000 0.000
47.438 766.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 13.00000 1.08200 1.15200 5.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.4000 0.000 0.000 0.000 0.000
47.448 766.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 13.00000 1.08200 1.15200 5.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.4000 0.000 0.000 0.000 0.000
47.458 766.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 13.00000 1.08200 1.15200 5.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.4000 0.000 0.000 0.000 0.000
47.468 766.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 13.00000 1.08200 1.15200 5.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.4000 0.000 0.000 0.000 0.000
47.478 766.00000 15.2000 -44.53125 0.00000 0.88600 0.88600 12.90000 1.07500 1.14500 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
47.488 766.00000 15.2000 -44.53125 0.00000 0.88600 0.88600 12.90000 1.07500 1.14500 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
47.498 766.00000 15.2000 -44.53125 0.00000 0.88600 0.88600 12.90000 1.07500 1.14500 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
47.508 766.00000 15.2000 -44.53125 0.00000 0.88600 0.88600 12.90000 1.07500 1.14500 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
47.518 766.00000 15.2000 -44.53125 0.00000 0.88600 0.88600 12.90000 1.07500 1.14500 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
47.528 766.00000 15.2000 -44.53125 0.00000 0.86200 0.86200 12.60000 1.07500 1.14500 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.8000 0.000 0.000 0.000 0.000
47.538 766.00000 15.2000 -44.53125 0.00000 0.86200 0.86200 12.60000 1.07500 1.14500 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.8000 0.000 0.000 0.000 0.000
47.548 766.00000 15.2000 -44.53125 0.00000 0.86200 0.86200 12.60000 1.07500 1.14500 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.8000 0.000 0.000 0.000 0.000
47.558 766.00000 15.2000 -44.53125 0.00000 0.86200 0.86200 12.60000 1.07500 1.14500 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.8000 0.000 0.000 0.000 0.000
47.568 766.00000 15.2000 -44.53125 0.00000 0.86200 0.86200 12.60000 1.07500 1.14500 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.8000 0.000 0.000 0.000 0.000
47.578 741.00000 15.2000 -44.53125 0.00000 0.88600 0.88600 12.60000 1.07500 1.14500 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
47.588 741.00000 15.2000 -44.53125 0.00000 0.88600 0.88600 12.60000 1.07500 1.14500 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
47.598 741.00000 15.2000 -44.53125 0.00000 0.88600 0.88600 12.60000 1.07500 1.14500 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
47.608 741.00000 15.2000 -44.53125 0.00000 0.88600 0.88600 12.60000 1.07500 1.14500 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
47.618 741.00000 15.2000 -44.53125 0.00000 0.88600 0.88600 12.60000 1.07500 1.14500 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
47.628 741.00000 15.2000 -44.53125 0.00000 0.85100 0.85100 13.00000 1.07500 1.14500 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
47.638 741.00000 15.2000 -44.53125 0.00000 0.85100 0.85100 13.00000 1.07500 1.14500 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
47.648 741.00000 15.2000 -44.53125 0.00000 0.85100 0.85100 13.00000 1.07500 1.14500 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
47.658 741.00000 15.2000 -44.53125 0.00000 0.85100 0.85100 13.00000 1.07500 1.14500 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
47.668 741.00000 15.2000 -44.53125 0.00000 0.85100 0.85100 13.00000 1.07500 1.14500 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
47.678 756.00000 15.2000 -44.53125 0.00000 0.89100 0.89100 13.20000 1.05300 1.14200 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.8000 0.000 0.000 0.000 0.000
47.688 756.00000 15.2000 -44.53125 0.00000 0.89100 0.89100 13.20000 1.05300 1.14200 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.8000 0.000 0.000 0.000 0.000
47.698 756.00000 15.2000 -44.53125 0.00000 0.89100 0.89100 13.20000 1.05300 1.14200 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.8000 0.000 0.000 0.000 0.000
47.708 756.00000 15.2000 -44.53125 0.00000 0.89100 0.89100 13.20000 1.05300 1.14200 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.8000 0.000 0.000 0.000 0.000
47.718 756.00000 15.2000 -44.53125 0.00000 0.89100 0.89100 13.20000 1.05300 1.14200 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.8000 0.000 0.000 0.000 0.000
47.728 756.00000 15.2000 -44.53125 0.00000 0.91500 0.91500 12.80000 1.05300 1.14200 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
47.738 756.00000 15.2000 -44.53125 0.00000 0.91500 0.91500 12.80000 1.05300 1.14200 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
47.748 756.00000 15.2000 -44.53125 0.00000 0.91500 0.91500 12.80000 1.05300 1.14200 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
47.758 756.00000 15.2000 -44.53125 0.00000 0.91500 0.91500 12.80000 1.05300 1.14200 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
47.768 756.00000 15.2000 -44.53125 0.00000 0.91500 0.91500 12.80000 1.05300 1.14200 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
47.778 756.00000 15.2000 -44.53125 0.00000 0.86200 0.86200 13.00000 1.05300 1.14200 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.0000 0.000 0.000 0.000 0.000
47.788 756.00000 15.2000 -44.53125 0.00000 0.86200 0.86200 13.00000 1.05300 1.14200 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.0000 0.000 0.000 0.000 0.000
47.798 756.00000 15.2000 -44.53125 0.00000 0.86200 0.86200 13.00000 1.05300 1.14200 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.0000 0.000 0.000 0.000 0.000
47.808 756.00000 15.2000 -44.53125 0.00000 0.86200 0.86200 13.00000 1.05300 1.14200 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.0000 0.000 0.000 0.000 0.000
47.818 756.00000 15.2000 -44.53125 0.00000 0.86200 0.86200 13.00000 1.05300 1.14200 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.0000 0.000 0.000 0.000 0.000
47.828 778.00000 15.2000 -44.53125 0.00000 0.85100 0.85100 12.70000 1.05300 1.14200 5.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.1000 0.000 0.000 0.000 0.000
47.838 778.00000 15.2000 -44.53125 0.00000 0.85100 0.85100 12.70000 1.05300 1.14200 5.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.1000 0.000 0.000 0.000 0.000
47.848 778.00000 15.2000 -44.53125 0.00000 0.85100 0.85100 12.70000 1.05300 1.14200 5.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.1000 0.000 0.000 0.000 0.000
47.858 778.00000 15.2000 -44.53125 0.00000 0.85100 0.85100 12.70000 1.05300 1.14200 5.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.1000 0.000 0.000 0.000 0.000
47.868 778.00000 15.2000 -44.53125 0.00000 0.85100 0.85100 12.70000 1.05300 1.14200 5.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.1000 0.000 0.000 0.000 0.000
47.878 778.00000 15.2000 -44.53125 0.00000 0.87400 0.87400 13.10000 0.96700 1.13900 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.0000 0.000 0.000 0.000 0.000
47.888 778.00000 15.2000 -44.53125 0.00000 0.87400 0.87400 13.10000 0.96700 1.13900 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.0000 0.000 0.000 0.000 0.000
47.898 778.00000 15.2000 -44.53125 0.00000 0.87400 0.87400 13.10000 0.96700 1.13900 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.0000 0.000 0.000 0.000 0.000
47.908 778.00000 15.2000 -44.53125 0.00000 0.87400 0.87400 13.10000 0.96700 1.13900 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.0000 0.000 0.000 0.000 0.000
47.918 778.00000 15.2000 -44.53125 0.00000 0.87400 0.87400 13.10000 0.96700 1.13900 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.0000 0.000 0.000 0.000 0.000
47.928 774.00000 15.2000 -44.53125 0.00000 0.85600 0.85600 12.70000 0.96700 1.13900 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.0000 0.000 0.000 0.000 0.000
47.938 774.00000 15.2000 -44.53125 0.00000 0.85600 0.85600 12.70000 0.96700 1.13900 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.0000 0.000 0.000 0.000 0.000
47.948 774.00000 15.2000 -44.53125 0.00000 0.85600 0.85600 12.70000 0.96700 1.13900 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.0000 0.000 0.000 0.000 0.000
47.958 774.00000 15.2000 -44.53125 0.00000 0.85600 0.85600 12.70000 0.96700 1.13900 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.0000 0.000 0.000 0.000 0.000
47.968 774.00000 15.2000 -44.53125 0.00000 0.85600 0.85600 12.70000 0.96700 1.13900 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.0000 0.000 0.000 0.000 0.000
47.978 774.00000 15.1000 -44.53125 0.00000 0.86800 0.86800 12.80000 0.96700 1.13900 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
47.988 774.00000 15.1000 -44.53125 0.00000 0.86800 0.86800 12.80000 0.96700 1.13900 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
47.998 774.00000 15.1000 -44.53125 0.00000 0.86800 0.86800 12.80000 0.96700 1.13900 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
48.008 774.00000 15.1000 -44.53125 0.00000 0.86800 0.86800 12.80000 0.96700 1.13900 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
48.018 774.00000 15.1000 -44.53125 0.00000 0.86800 0.86800 12.80000 0.96700 1.13900 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
48.028 774.00000 15.1000 -44.53125 0.00000 0.83900 0.83900 13.20000 0.96700 1.13900 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
48.038 774.00000 15.1000 -44.53125 0.00000 0.83900 0.83900 13.20000 0.96700 1.13900 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
48.048 774.00000 15.1000 -44.53125 0.00000 0.83900 0.83900 13.20000 0.96700 1.13900 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
48.058 774.00000 15.1000 -44.53125 0.00000 0.83900 0.83900 13.20000 0.96700 1.13900 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
48.068 774.00000 15.1000 -44.53125 0.00000 0.83900 0.83900 13.20000 0.96700 1.13900 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
48.078 748.00000 15.1000 -44.53125 0.00000 0.88000 0.88000 12.70000 0.82900 1.13300 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
48.088 748.00000 15.1000 -44.53125 0.00000 0.88000 0.88000 12.70000 0.82900 1.13300 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
48.098 748.00000 15.1000 -44.53125 0.00000 0.88000 0.88000 12.70000 0.82900 1.13300 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
48.108 748.00000 15.1000 -44.53125 0.00000 0.88000 0.88000 12.70000 0.82900 1.13300 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
48.118 748.00000 15.1000 -44.53125 0.00000 0.88000 0.88000 12.70000 0.82900 1.13300 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
48.128 748.00000 15.2000 -44.53125 0.00000 0.84500 0.84500 13.00000 0.82900 1.13300 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.6000 0.000 0.000 0.000 0.000
48.138 748.00000 15.2000 -44.53125 0.00000 0.84500 0.84500 13.00000 0.82900 1.13300 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.6000 0.000 0.000 0.000 0.000
48.148 748.00000 15.2000 -44.53125 0.00000 0.84500 0.84500 13.00000 0.82900 1.13300 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.6000 0.000 0.000 0.000 0.000
48.158 748.00000 15.2000 -44.53125 0.00000 0.84500 0.84500 13.00000 0.82900 1.13300 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.6000 0.000 0.000 0.000 0.000
48.168 748.00000 15.2000 -44.53125 0.00000 0.84500 0.84500 13.00000 0.82900 1.13300 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.6000 0.000 0.000 0.000 0.000
48.178 748.00000 15.2000 -44.53125 0.00000 0.85100 0.85100 12.00000 0.82900 1.13300 5.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.6000 0.000 0.000 0.000 0.000
48.188 748.00000 15.2000 -44.53125 0.00000 0.85100 0.85100 12.00000 0.82900 1.13300 5.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.6000 0.000 0.000 0.000 0.000
48.198 748.00000 15.2000 -44.53125 0.00000 0.85100 0.85100 12.00000 0.82900 1.13300 5.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.6000 0.000 0.000 0.000 0.000
48.208 748.00000 15.2000 -44.53125 0.00000 0.85100 0.85100 12.00000 0.82900 1.13300 5.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.6000 0.000 0.000 0.000 0.000
48.218 748.00000 15.2000 -44.53125 0.00000 0.85100 0.85100 12.00000 0.82900 1.13300 5.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.6000 0.000 0.000 0.000 0.000
48.228 717.00000 15.2000 -44.53125 0.00000 0.83900 0.83900 12.60000 0.82900 1.13300 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.6000 0.000 0.000 0.000 0.000
48.238 717.00000 15.2000 -44.53125 0.00000 0.83900 0.83900 12.60000 0.82900 1.13300 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.6000 0.000 0.000 0.000 0.000
48.248 717.00000 15.2000 -44.53125 0.00000 0.83900 0.83900 12.60000 0.82900 1.13300 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.6000 0.000 0.000 0.000 0.000
48.258 717.00000 15.2000 -44.53125 0.00000 0.83900 0.83900 12.60000 0.82900 1.13300 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.6000 0.000 0.000 0.000 0.000
48.268 717.00000 15.2000 -44.53125 0.00000 0.83900 0.83900 12.60000 0.82900 1.13300 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.6000 0.000 0.000 0.000 0.000
48.278 717.00000 15.2000 -44.53125 0.00000 0.88600 0.88600 12.50000 0.52900 1.11700 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
48.288 717.00000 15.2000 -44.53125 0.00000 0.88600 0.88600 12.50000 0.52900 1.11700 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
48.298 717.00000 15.2000 -44.53125 0.00000 0.88600 0.88600 12.50000 0.52900 1.11700 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
48.308 717.00000 15.2000 -44.53125 0.00000 0.88600 0.88600 12.50000 0.52900 1.11700 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
48.318 717.00000 15.2000 -44.53125 0.00000 0.88600 0.88600 12.50000 0.52900 1.11700 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
48.328 701.00000 15.2000 -44.53125 0.00000 0.88600 0.88600 12.20000 0.52900 1.11700 5.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
48.338 701.00000 15.2000 -44.53125 0.00000 0.88600 0.88600 12.20000 0.52900 1.11700 5.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
48.348 701.00000 15.2000 -44.53125 0.00000 0.88600 0.88600 12.20000 0.52900 1.11700 5.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
48.358 701.00000 15.2000 -44.53125 0.00000 0.88600 0.88600 12.20000 0.52900 1.11700 5.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
48.368 701.00000 15.2000 -44.53125 0.00000 0.88600 0.88600 12.20000 0.52900 1.11700 5.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
48.378 701.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 12.60000 0.52900 1.11700 6.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
48.388 701.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 12.60000 0.52900 1.11700 6.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
48.398 701.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 12.60000 0.52900 1.11700 6.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
48.408 701.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 12.60000 0.52900 1.11700 6.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
48.418 701.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 12.60000 0.52900 1.11700 6.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
48.428 701.00000 15.1000 -44.53125 0.00000 0.83300 0.83300 12.30000 0.52900 1.11700 5.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
48.438 701.00000 15.1000 -44.53125 0.00000 0.83300 0.83300 12.30000 0.52900 1.11700 5.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
48.448 701.00000 15.1000 -44.53125 0.00000 0.83300 0.83300 12.30000 0.52900 1.11700 5.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
48.458 701.00000 15.1000 -44.53125 0.00000 0.83300 0.83300 12.30000 0.52900 1.11700 5.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
48.468 701.00000 15.1000 -44.53125 0.00000 0.83300 0.83300 12.30000 0.52900 1.11700 5.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
48.478 682.00000 15.2000 -44.53125 0.00000 0.88600 0.88600 12.50000 0.34700 1.12300 5.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
48.488 682.00000 15.2000 -44.53125 0.00000 0.88600 0.88600 12.50000 0.34700 1.12300 5.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
48.498 682.00000 15.2000 -44.53125 0.00000 0.88600 0.88600 12.50000 0.34700 1.12300 5.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
48.508 682.00000 15.2000 -44.53125 0.00000 0.88600 0.88600 12.50000 0.34700 1.12300 5.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
48.518 682.00000 15.2000 -44.53125 0.00000 0.88600 0.88600 12.50000 0.34700 1.12300 5.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
48.528 682.00000 15.2000 -44.53125 0.00000 0.86800 0.86800 12.40000 0.34700 1.12300 5.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
48.538 682.00000 15.2000 -44.53125 0.00000 0.86800 0.86800 12.40000 0.34700 1.12300 5.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
48.548 682.00000 15.2000 -44.53125 0.00000 0.86800 0.86800 12.40000 0.34700 1.12300 5.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
48.558 682.00000 15.2000 -44.53125 0.00000 0.86800 0.86800 12.40000 0.34700 1.12300 5.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
48.568 682.00000 15.2000 -44.53125 0.00000 0.86800 0.86800 12.40000 0.34700 1.12300 5.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
48.578 682.00000 15.2000 -44.53125 0.00000 0.83900 0.83900 12.20000 0.34700 1.12300 6.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
48.588 682.00000 15.2000 -44.53125 0.00000 0.83900 0.83900 12.20000 0.34700 1.12300 6.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
48.598 682.00000 15.2000 -44.53125 0.00000 0.83900 0.83900 12.20000 0.34700 1.12300 6.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
48.608 682.00000 15.2000 -44.53125 0.00000 0.83900 0.83900 12.20000 0.34700 1.12300 6.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
48.618 682.00000 15.2000 -44.53125 0.00000 0.83900 0.83900 12.20000 0.34700 1.12300 6.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
48.628 703.00000 15.2000 -44.53125 0.00000 0.86800 0.86800 12.60000 0.34700 1.12300 5.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
48.638 703.00000 15.2000 -44.53125 0.00000 0.86800 0.86800 12.60000 0.34700 1.12300 5.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
48.648 703.00000 15.2000 -44.53125 0.00000 0.86800 0.86800 12.60000 0.34700 1.12300 5.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
48.658 703.00000 15.2000 -44.53125 0.00000 0.86800 0.86800 12.60000 0.34700 1.12300 5.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
48.668 703.00000 15.2000 -44.53125 0.00000 0.86800 0.86800 12.60000 0.34700 1.12300 5.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
48.678 703.00000 15.2000 -44.53125 0.00000 0.87400 0.87400 12.50000 0.31200 1.11700 5.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
48.688 703.00000 15.2000 -44.53125 0.00000 0.87400 0.87400 12.50000 0.31200 1.11700 5.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
48.698 703.00000 15.2000 -44.53125 0.00000 0.87400 0.87400 12.50000 0.31200 1.11700 5.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
48.708 703.00000 15.2000 -44.53125 0.00000 0.87400 0.87400 12.50000 0.31200 1.11700 5.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
48.718 703.00000 15.2000 -44.53125 0.00000 0.87400 0.87400 12.50000 0.31200 1.11700 5.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
48.728 703.00000 15.2000 -44.53125 0.00000 0.90300 0.90300 12.40000 0.31200 1.11700 6.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.9000 0.000 0.000 0.000 0.000
48.738 703.00000 15.2000 -44.53125 0.00000 0.90300 0.90300 12.40000 0.31200 1.11700 6.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.9000 0.000 0.000 0.000 0.000
48.748 703.00000 15.2000 -44.53125 0.00000 0.90300 0.90300 12.40000 0.31200 1.11700 6.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.9000 0.000 0.000 0.000 0.000
48.758 703.00000 15.2000 -44.53125 0.00000 0.90300 0.90300 12.40000 0.31200 1.11700 6.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.9000 0.000 0.000 0.000 0.000
48.768 703.00000 15.2000 -44.53125 0.00000 0.90300 0.90300 12.40000 0.31200 1.11700 6.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.9000 0.000 0.000 0.000 0.000
48.778 693.00000 15.2000 -44.53125 0.00000 0.86800 0.86800 12.50000 0.31200 1.11700 6.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 16.1000 0.000 0.000 0.000 0.000
48.788 693.00000 15.2000 -44.53125 0.00000 0.86800 0.86800 12.50000 0.31200 1.11700 6.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 16.1000 0.000 0.000 0.000 0.000
48.798 693.00000 15.2000 -44.53125 0.00000 0.86800 0.86800 12.50000 0.31200 1.11700 6.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 16.1000 0.000 0.000 0.000 0.000
48.808 693.00000 15.2000 -44.53125 0.00000 0.86800 0.86800 12.50000 0.31200 1.11700 6.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 16.1000 0.000 0.000 0.000 0.000
48.818 693.00000 15.2000 -44.53125 0.00000 0.86800 0.86800 12.50000 0.31200 1.11700 6.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 16.1000 0.000 0.000 0.000 0.000
48.828 693.00000 15.2000 -44.53125 0.00000 0.86200 0.86200 12.90000 0.31200 1.11700 6.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 16.0000 0.000 0.000 0.000 0.000
48.838 693.00000 15.2000 -44.53125 0.00000 0.86200 0.86200 12.90000 0.31200 1.11700 6.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 16.0000 0.000 0.000 0.000 0.000
48.848 693.00000 15.2000 -44.53125 0.00000 0.86200 0.86200 12.90000 0.31200 1.11700 6.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 16.0000 0.000 0.000 0.000 0.000
48.858 693.00000 15.2000 -44.53125 0.00000 0.86200 0.86200 12.90000 0.31200 1.11700 6.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 16.0000 0.000 0.000 0.000 0.000
48.868 693.00000 15.2000 -44.53125 0.00000 0.86200 0.86200 12.90000 0.31200 1.11700 6.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 16.0000 0.000 0.000 0.000 0.000
48.878 693.00000 15.2000 -44.53125 0.00000 0.85100 0.85100 12.30000 0.30600 1.10700 5.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 16.4000 0.000 0.000 0.000 0.000
48.888 693.00000 15.2000 -44.53125 0.00000 0.85100 0.85100 12.30000 0.30600 1.10700 5.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 16.4000 0.000 0.000 0.000 0.000
48.898 693.00000 15.2000 -44.53125 0.00000 0.85100 0.85100 12.30000 0.30600 1.10700 5.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 16.4000 0.000 0.000 0.000 0.000
48.908 693.00000 15.2000 -44.53125 0.00000 0.85100 0.85100 12.30000 0.30600 1.10700 5.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 16.4000 0.000 0.000 0.000 0.000
48.918 693.00000 15.2000 -44.53125 0.00000 0.85100 0.85100 12.30000 0.30600 1.10700 5.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 16.4000 0.000 0.000 0.000 0.000
48.928 729.00000 15.2000 -44.53125 0.00000 0.85600 0.85600 12.70000 0.30600 1.10700 6.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 16.6000 0.000 0.000 0.000 0.000
48.938 729.00000 15.2000 -44.53125 0.00000 0.85600 0.85600 12.70000 0.30600 1.10700 6.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 16.6000 0.000 0.000 0.000 0.000
48.948 729.00000 15.2000 -44.53125 0.00000 0.85600 0.85600 12.70000 0.30600 1.10700 6.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 16.6000 0.000 0.000 0.000 0.000
48.958 729.00000 15.2000 -44.53125 0.00000 0.85600 0.85600 12.70000 0.30600 1.10700 6.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 16.6000 0.000 0.000 0.000 0.000
48.968 729.00000 15.2000 -44.53125 0.00000 0.85600 0.85600 12.70000 0.30600 1.10700 6.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 16.6000 0.000 0.000 0.000 0.000
48.978 729.00000 15.2000 -44.53125 0.00000 0.83300 0.83300 12.70000 0.30600 1.10700 6.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 16.5000 0.000 0.000 0.000 0.000
48.988 729.00000 15.2000 -44.53125 0.00000 0.83300 0.83300 12.70000 0.30600 1.10700 6.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 16.5000 0.000 0.000 0.000 0.000
48.998 729.00000 15.2000 -44.53125 0.00000 0.83300 0.83300 12.70000 0.30600 1.10700 6.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 16.5000 0.000 0.000 0.000 0.000
49.008 729.00000 15.2000 -44.53125 0.00000 0.83300 0.83300 12.70000 0.30600 1.10700 6.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 16.5000 0.000 0.000 0.000 0.000
49.018 729.00000 15.2000 -44.53125 0.00000 0.83300 0.83300 12.70000 0.30600 1.10700 6.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 16.5000 0.000 0.000 0.000 0.000
49.028 732.00000 15.1000 -44.53125 0.00000 0.86200 0.86200 12.80000 0.30600 1.10700 5.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.2000 0.000 0.000 0.000 0.000
49.038 732.00000 15.1000 -44.53125 0.00000 0.86200 0.86200 12.80000 0.30600 1.10700 5.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.2000 0.000 0.000 0.000 0.000
49.048 732.00000 15.1000 -44.53125 0.00000 0.86200 0.86200 12.80000 0.30600 1.10700 5.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.2000 0.000 0.000 0.000 0.000
49.058 732.00000 15.1000 -44.53125 0.00000 0.86200 0.86200 12.80000 0.30600 1.10700 5.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.2000 0.000 0.000 0.000 0.000
49.068 732.00000 15.1000 -44.53125 0.00000 0.86200 0.86200 12.80000 0.30600 1.10700 5.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.2000 0.000 0.000 0.000 0.000
49.078 732.00000 15.1000 -44.53125 0.00000 0.89100 0.89100 12.90000 0.30300 1.10100 5.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.0000 0.000 0.000 0.000 0.000
49.088 732.00000 15.1000 -44.53125 0.00000 0.89100 0.89100 12.90000 0.30300 1.10100 5.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.0000 0.000 0.000 0.000 0.000
49.098 732.00000 15.1000 -44.53125 0.00000 0.89100 0.89100 12.90000 0.30300 1.10100 5.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.0000 0.000 0.000 0.000 0.000
49.108 732.00000 15.1000 -44.53125 0.00000 0.89100 0.89100 12.90000 0.30300 1.10100 5.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.0000 0.000 0.000 0.000 0.000
49.118 732.00000 15.1000 -44.53125 0.00000 0.89100 0.89100 12.90000 0.30300 1.10100 5.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.0000 0.000 0.000 0.000 0.000
49.128 732.00000 15.2000 -44.53125 0.00000 0.86200 0.86200 12.80000 0.30300 1.10100 6.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.2000 0.000 0.000 0.000 0.000
49.138 732.00000 15.2000 -44.53125 0.00000 0.86200 0.86200 12.80000 0.30300 1.10100 6.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.2000 0.000 0.000 0.000 0.000
49.148 732.00000 15.2000 -44.53125 0.00000 0.86200 0.86200 12.80000 0.30300 1.10100 6.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.2000 0.000 0.000 0.000 0.000
49.158 732.00000 15.2000 -44.53125 0.00000 0.86200 0.86200 12.80000 0.30300 1.10100 6.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.2000 0.000 0.000 0.000 0.000
49.168 732.00000 15.2000 -44.53125 0.00000 0.86200 0.86200 12.80000 0.30300 1.10100 6.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.2000 0.000 0.000 0.000 0.000
49.178 745.00000 15.2000 -44.53125 0.00000 0.87400 0.87400 13.00000 0.30300 1.10100 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.3000 0.000 0.000 0.000 0.000
49.188 745.00000 15.2000 -44.53125 0.00000 0.87400 0.87400 13.00000 0.30300 1.10100 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.3000 0.000 0.000 0.000 0.000
49.198 745.00000 15.2000 -44.53125 0.00000 0.87400 0.87400 13.00000 0.30300 1.10100 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.3000 0.000 0.000 0.000 0.000
49.208 745.00000 15.2000 -44.53125 0.00000 0.87400 0.87400 13.00000 0.30300 1.10100 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.3000 0.000 0.000 0.000 0.000
49.218 745.00000 15.2000 -44.53125 0.00000 0.87400 0.87400 13.00000 0.30300 1.10100 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.3000 0.000 0.000 0.000 0.000
49.228 745.00000 15.2000 -44.53125 0.00000 0.85600 0.85600 12.80000 0.30300 1.10100 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.4000 0.000 0.000 0.000 0.000
49.238 745.00000 15.2000 -44.53125 0.00000 0.85600 0.85600 12.80000 0.30300 1.10100 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.4000 0.000 0.000 0.000 0.000
49.248 745.00000 15.2000 -44.53125 0.00000 0.85600 0.85600 12.80000 0.30300 1.10100 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.4000 0.000 0.000 0.000 0.000
49.258 745.00000 15.2000 -44.53125 0.00000 0.85600 0.85600 12.80000 0.30300 1.10100 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.4000 0.000 0.000 0.000 0.000
49.268 745.00000 15.2000 -44.53125 0.00000 0.85600 0.85600 12.80000 0.30300 1.10100 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.4000 0.000 0.000 0.000 0.000
49.278 759.00000 15.2000 -44.53125 0.00000 0.89700 0.89700 13.00000 0.30300 1.09800 6.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.6000 0.000 0.000 0.000 0.000
49.288 759.00000 15.2000 -44.53125 0.00000 0.89700 0.89700 13.00000 0.30300 1.09800 6.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.6000 0.000 0.000 0.000 0.000
49.298 759.00000 15.2000 -44.53125 0.00000 0.89700 0.89700 13.00000 0.30300 1.09800 6.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.6000 0.000 0.000 0.000 0.000
49.308 759.00000 15.2000 -44.53125 0.00000 0.89700 0.89700 13.00000 0.30300 1.09800 6.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.6000 0.000 0.000 0.000 0.000
49.318 759.00000 15.2000 -44.53125 0.00000 0.89700 0.89700 13.00000 0.30300 1.09800 6.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.6000 0.000 0.000 0.000 0.000
49.328 759.00000 15.8000 -44.53125 0.00000 0.90900 0.90900 13.20000 0.30300 1.09800 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.6000 0.000 0.000 0.000 0.000
49.338 759.00000 15.8000 -44.53125 0.00000 0.90900 0.90900 13.20000 0.30300 1.09800 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.6000 0.000 0.000 0.000 0.000
49.348 759.00000 15.8000 -44.53125 0.00000 0.90900 0.90900 13.20000 0.30300 1.09800 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.6000 0.000 0.000 0.000 0.000
49.358 759.00000 15.8000 -44.53125 0.00000 0.90900 0.90900 13.20000 0.30300 1.09800 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.6000 0.000 0.000 0.000 0.000
49.368 759.00000 15.8000 -44.53125 0.00000 0.90900 0.90900 13.20000 0.30300 1.09800 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.6000 0.000 0.000 0.000 0.000
49.378 759.00000 15.4000 -44.53125 0.00000 0.90300 0.90300 13.10000 0.30300 1.09800 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.8000 0.000 0.000 0.000 0.000
49.388 759.00000 15.4000 -44.53125 0.00000 0.90300 0.90300 13.10000 0.30300 1.09800 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.8000 0.000 0.000 0.000 0.000
49.398 759.00000 15.4000 -44.53125 0.00000 0.90300 0.90300 13.10000 0.30300 1.09800 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.8000 0.000 0.000 0.000 0.000
49.408 759.00000 15.4000 -44.53125 0.00000 0.90300 0.90300 13.10000 0.30300 1.09800 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.8000 0.000 0.000 0.000 0.000
49.418 759.00000 15.4000 -44.53125 0.00000 0.90300 0.90300 13.10000 0.30300 1.09800 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.8000 0.000 0.000 0.000 0.000
49.428 758.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 13.10000 0.30300 1.09800 6.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.6000 0.000 0.000 0.000 0.000
49.438 758.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 13.10000 0.30300 1.09800 6.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.6000 0.000 0.000 0.000 0.000
49.448 758.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 13.10000 0.30300 1.09800 6.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.6000 0.000 0.000 0.000 0.000
49.458 758.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 13.10000 0.30300 1.09800 6.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.6000 0.000 0.000 0.000 0.000
49.468 758.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 13.10000 0.30300 1.09800 6.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.6000 0.000 0.000 0.000 0.000
49.478 758.00000 15.8000 -44.53125 0.00000 0.86800 0.86800 13.20000 0.30300 1.09100 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.8000 0.000 0.000 0.000 0.000
49.488 758.00000 15.8000 -44.53125 0.00000 0.86800 0.86800 13.20000 0.30300 1.09100 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.8000 0.000 0.000 0.000 0.000
49.498 758.00000 15.8000 -44.53125 0.00000 0.86800 0.86800 13.20000 0.30300 1.09100 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.8000 0.000 0.000 0.000 0.000
49.508 758.00000 15.8000 -44.53125 0.00000 0.86800 0.86800 13.20000 0.30300 1.09100 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.8000 0.000 0.000 0.000 0.000
49.518 758.00000 15.8000 -44.53125 0.00000 0.86800 0.86800 13.20000 0.30300 1.09100 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.8000 0.000 0.000 0.000 0.000
49.528 784.00000 15.4000 -44.53125 0.00000 0.88600 0.88600 13.60000 0.30300 1.09100 6.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.8000 0.000 0.000 0.000 0.000
49.538 784.00000 15.4000 -44.53125 0.00000 0.88600 0.88600 13.60000 0.30300 1.09100 6.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.8000 0.000 0.000 0.000 0.000
49.548 784.00000 15.4000 -44.53125 0.00000 0.88600 0.88600 13.60000 0.30300 1.09100 6.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.8000 0.000 0.000 0.000 0.000
49.558 784.00000 15.4000 -44.53125 0.00000 0.88600 0.88600 13.60000 0.30300 1.09100 6.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.8000 0.000 0.000 0.000 0.000
49.568 784.00000 15.4000 -44.53125 0.00000 0.88600 0.88600 13.60000 0.30300 1.09100 6.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.8000 0.000 0.000 0.000 0.000
49.578 784.00000 16.0000 -44.53125 0.00000 0.95600 0.95600 13.00000 0.30300 1.09100 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.8000 0.000 0.000 0.000 0.000
49.588 784.00000 16.0000 -44.53125 0.00000 0.95600 0.95600 13.00000 0.30300 1.09100 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.8000 0.000 0.000 0.000 0.000
49.598 784.00000 16.0000 -44.53125 0.00000 0.95600 0.95600 13.00000 0.30300 1.09100 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.8000 0.000 0.000 0.000 0.000
49.608 784.00000 16.0000 -44.53125 0.00000 0.95600 0.95600 13.00000 0.30300 1.09100 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.8000 0.000 0.000 0.000 0.000
49.618 784.00000 16.0000 -44.53125 0.00000 0.95600 0.95600 13.00000 0.30300 1.09100 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.8000 0.000 0.000 0.000 0.000
49.628 981.00000 17.8000 -44.53125 0.00000 1.09000 1.09000 13.40000 0.30300 1.09100 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.9000 0.000 0.000 0.000 0.000
49.638 981.00000 17.8000 -44.53125 0.00000 1.09000 1.09000 13.40000 0.30300 1.09100 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.9000 0.000 0.000 0.000 0.000
49.648 981.00000 17.8000 -44.53125 0.00000 1.09000 1.09000 13.40000 0.30300 1.09100 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.9000 0.000 0.000 0.000 0.000
49.658 981.00000 17.8000 -44.53125 0.00000 1.09000 1.09000 13.40000 0.30300 1.09100 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.9000 0.000 0.000 0.000 0.000
49.668 981.00000 17.8000 -44.53125 0.00000 1.09000 1.09000 13.40000 0.30300 1.09100 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.9000 0.000 0.000 0.000 0.000
49.678 981.00000 19.2000 -44.53125 0.00000 1.20600 1.20600 13.70000 0.30300 1.07800 5.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.0000 0.000 0.000 0.000 0.000
49.688 981.00000 19.2000 -44.53125 0.00000 1.20600 1.20600 13.70000 0.30300 1.07800 5.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.0000 0.000 0.000 0.000 0.000
49.698 981.00000 19.2000 -44.53125 0.00000 1.20600 1.20600 13.70000 0.30300 1.07800 5.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.0000 0.000 0.000 0.000 0.000
49.708 981.00000 19.2000 -44.53125 0.00000 1.20600 1.20600 13.70000 0.30300 1.07800 5.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.0000 0.000 0.000 0.000 0.000
49.718 981.00000 19.2000 -44.53125 0.00000 1.20600 1.20600 13.70000 0.30300 1.07800 5.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.0000 0.000 0.000 0.000 0.000
49.728 1320.00000 20.9000 -44.53125 0.00000 1.39300 1.39300 13.40000 0.30300 1.07800 5.90000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 18.1000 0.000 0.000 0.000 0.000
49.738 1320.00000 20.9000 -44.53125 0.00000 1.39300 1.39300 13.40000 0.30300 1.07800 5.90000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 18.1000 0.000 0.000 0.000 0.000
49.748 1320.00000 20.9000 -44.53125 0.00000 1.39300 1.39300 13.40000 0.30300 1.07800 5.90000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 18.1000 0.000 0.000 0.000 0.000
49.758 1320.00000 20.9000 -44.53125 0.00000 1.39300 1.39300 13.40000 0.30300 1.07800 5.90000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 18.1000 0.000 0.000 0.000 0.000
49.768 1320.00000 20.9000 -44.53125 0.00000 1.39300 1.39300 13.40000 0.30300 1.07800 5.90000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 18.1000 0.000 0.000 0.000 0.000
49.778 1402.00000 21.8000 -44.53125 0.00000 1.59100 1.59100 12.50000 0.30300 1.07800 5.90000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 18.0000 0.000 0.000 0.000 0.000
49.788 1402.00000 21.8000 -44.53125 0.00000 1.59100 1.59100 12.50000 0.30300 1.07800 5.90000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 18.0000 0.000 0.000 0.000 0.000
49.798 1402.00000 21.8000 -44.53125 0.00000 1.59100 1.59100 12.50000 0.30300 1.07800 5.90000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 18.0000 0.000 0.000 0.000 0.000
49.808 1402.00000 21.8000 -44.53125 0.00000 1.59100 1.59100 12.50000 0.30300 1.07800 5.90000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 18.0000 0.000 0.000 0.000 0.000
49.818 1402.00000 21.8000 -44.53125 0.00000 1.59100 1.59100 12.50000 0.30300 1.07800 5.90000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 18.0000 0.000 0.000 0.000 0.000
49.828 1402.00000 21.7000 -44.53125 0.00000 1.55600 1.55600 13.30000 0.30300 1.07800 7.00000 1.00000 2.00000 3.00000 2.00000 2.00000 0.00000 0.00000 18.0000 0.000 0.000 0.000 0.000
49.838 1402.00000 21.7000 -44.53125 0.00000 1.55600 1.55600 13.30000 0.30300 1.07800 7.00000 1.00000 2.00000 3.00000 2.00000 2.00000 0.00000 0.00000 18.0000 0.000 0.000 0.000 0.000
49.848 1402.00000 21.7000 -44.53125 0.00000 1.55600 1.55600 13.30000 0.30300 1.07800 7.00000 1.00000 2.00000 3.00000 2.00000 2.00000 0.00000 0.00000 18.0000 0.000 0.000 0.000 0.000
49.858 1402.00000 21.7000 -44.53125 0.00000 1.55600 1.55600 13.30000 0.30300 1.07800 7.00000 1.00000 2.00000 3.00000 2.00000 2.00000 0.00000 0.00000 18.0000 0.000 0.000 0.000 0.000
49.868 1402.00000 21.7000 -44.53125 0.00000 1.55600 1.55600 13.30000 0.30300 1.07800 7.00000 1.00000 2.00000 3.00000 2.00000 2.00000 0.00000 0.00000 18.0000 0.000 0.000 0.000 0.000
49.878 1314.00000 22.0000 -44.53125 0.00000 1.63200 1.63200 13.40000 0.30300 1.04300 7.60000 1.00000 2.00000 2.00000 3.00000 3.00000 0.00000 0.00000 17.8000 0.000 0.000 0.000 0.000
49.888 1314.00000 22.0000 -44.53125 0.00000 1.63200 1.63200 13.40000 0.30300 1.04300 7.60000 1.00000 2.00000 2.00000 3.00000 3.00000 0.00000 0.00000 17.8000 0.000 0.000 0.000 0.000
49.898 1314.00000 22.0000 -44.53125 0.00000 1.63200 1.63200 13.40000 0.30300 1.04300 7.60000 1.00000 2.00000 2.00000 3.00000 3.00000 0.00000 0.00000 17.8000 0.000 0.000 0.000 0.000
49.908 1314.00000 22.0000 -44.53125 0.00000 1.63200 1.63200 13.40000 0.30300 1.04300 7.60000 1.00000 2.00000 2.00000 3.00000 3.00000 0.00000 0.00000 17.8000 0.000 0.000 0.000 0.000
49.918 1314.00000 22.0000 -44.53125 0.00000 1.63200 1.63200 13.40000 0.30300 1.04300 7.60000 1.00000 2.00000 2.00000 3.00000 3.00000 0.00000 0.00000 17.8000 0.000 0.000 0.000 0.000
49.928 1311.00000 22.7000 -44.53125 0.00000 1.67300 1.67300 13.30000 0.30300 1.04300 7.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 17.8000 0.000 0.000 0.000 0.000
49.938 1311.00000 22.7000 -44.53125 0.00000 1.67300 1.67300 13.30000 0.30300 1.04300 7.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 17.8000 0.000 0.000 0.000 0.000
49.948 1311.00000 22.7000 -44.53125 0.00000 1.67300 1.67300 13.30000 0.30300 1.04300 7.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 17.8000 0.000 0.000 0.000 0.000
49.958 1311.00000 22.7000 -44.53125 0.00000 1.67300 1.67300 13.30000 0.30300 1.04300 7.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 17.8000 0.000 0.000 0.000 0.000
49.968 1311.00000 22.7000 -44.53125 0.00000 1.67300 1.67300 13.30000 0.30300 1.04300 7.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 17.8000 0.000 0.000 0.000 0.000
49.978 1311.00000 26.8000 -44.53125 0.00000 1.97000 1.97000 13.40000 0.30300 1.04300 8.90000 1.00000 3.00000 1.00000 3.00000 3.00000 0.00000 0.00000 17.9000 0.000 0.000 0.000 0.000
49.988 1311.00000 26.8000 -44.53125 0.00000 1.97000 1.97000 13.40000 0.30300 1.04300 8.90000 1.00000 3.00000 1.00000 3.00000 3.00000 0.00000 0.00000 17.9000 0.000 0.000 0.000 0.000
49.998 1311.00000 26.8000 -44.53125 0.00000 1.97000 1.97000 13.40000 0.30300 1.04300 8.90000 1.00000 3.00000 1.00000 3.00000 3.00000 0.00000 0.00000 17.9000 0.000 0.000 0.000 0.000
50.008 1311.00000 26.8000 -44.53125 0.00000 1.97000 1.97000 13.40000 0.30300 1.04300 8.90000 1.00000 3.00000 1.00000 3.00000 3.00000 0.00000 0.00000 17.9000 0.000 0.000 0.000 0.000
50.018 1311.00000 26.8000 -44.53125 0.00000 1.97000 1.97000 13.40000 0.30300 1.04300 8.90000 1.00000 3.00000 1.00000 3.00000 3.00000 0.00000 0.00000 17.9000 0.000 0.000 0.000 0.000
50.028 1501.00000 28.5000 -44.53125 0.00000 2.21500 2.21500 13.50000 0.30300 1.04300 10.10000 1.00000 1.00000 2.00000 4.00000 4.00000 0.00000 0.00000 17.8000 0.000 0.000 0.000 0.000
50.038 1501.00000 28.5000 -44.53125 0.00000 2.21500 2.21500 13.50000 0.30300 1.04300 10.10000 1.00000 1.00000 2.00000 4.00000 4.00000 0.00000 0.00000 17.8000 0.000 0.000 0.000 0.000
50.048 1501.00000 28.5000 -44.53125 0.00000 2.21500 2.21500 13.50000 0.30300 1.04300 10.10000 1.00000 1.00000 2.00000 4.00000 4.00000 0.00000 0.00000 17.8000 0.000 0.000 0.000 0.000
50.058 1501.00000 28.5000 -44.53125 0.00000 2.21500 2.21500 13.50000 0.30300 1.04300 10.10000 1.00000 1.00000 2.00000 4.00000 4.00000 0.00000 0.00000 17.8000 0.000 0.000 0.000 0.000
50.068 1501.00000 28.5000 -44.53125 0.00000 2.21500 2.21500 13.50000 0.30300 1.04300 10.10000 1.00000 1.00000 2.00000 4.00000 4.00000 0.00000 0.00000 17.8000 0.000 0.000 0.000 0.000
50.078 1501.00000 28.5000 -44.53125 0.00000 2.21500 2.21500 13.50000 0.30300 1.04300 10.10000 1.00000 1.00000 2.00000 4.00000 4.00000 0.00000 0.00000 17.8000 0.000 0.000 0.000 0.000
50.088 1412.00000 30.5000 -44.53125 0.00000 2.18600 2.18600 13.20000 0.30300 0.84500 11.40000 1.00000 5.00000 2.00000 5.00000 1.00000 0.00000 0.00000 17.8000 0.000 0.000 0.000 0.000
50.098 1336.00000 36.3000 -44.53125 0.00000 2.33700 2.33700 13.20000 0.30300 0.84500 14.30000 1.00000 5.00000 6.00000 2.00000 1.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
50.108 1336.00000 36.3000 -44.53125 0.00000 2.33700 2.33700 13.20000 0.30300 0.84500 14.30000 1.00000 5.00000 6.00000 2.00000 1.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
50.118 1336.00000 36.3000 -44.53125 0.00000 2.33700 2.33700 13.20000 0.30300 0.84500 14.30000 1.00000 5.00000 6.00000 2.00000 1.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
50.128 1336.00000 36.3000 -44.53125 0.00000 2.33700 2.33700 13.20000 0.30300 0.84500 14.30000 1.00000 5.00000 6.00000 2.00000 1.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
50.138 1336.00000 36.3000 -44.53125 0.00000 2.33700 2.33700 13.20000 0.30300 0.84500 14.30000 1.00000 5.00000 6.00000 2.00000 1.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
50.148 1336.00000 36.3000 -44.53125 0.00000 2.33700 2.33700 13.20000 0.30300 0.84500 14.30000 1.00000 5.00000 6.00000 2.00000 1.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
50.158 1336.00000 36.3000 -44.53125 0.00000 2.33700 2.33700 13.20000 0.30300 0.84500 14.30000 1.00000 5.00000 6.00000 2.00000 1.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
50.168 1336.00000 36.3000 -44.53125 0.00000 2.33700 2.33700 13.20000 0.30300 0.84500 14.30000 1.00000 5.00000 6.00000 2.00000 1.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
50.178 1336.00000 36.3000 -44.53125 0.00000 2.33700 2.33700 13.20000 0.30300 0.84500 14.30000 1.00000 5.00000 6.00000 2.00000 1.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
50.188 1336.00000 36.3000 -44.53125 0.00000 2.33700 2.33700 13.20000 0.30300 0.84500 14.30000 1.00000 5.00000 6.00000 2.00000 1.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
50.198 1420.00000 41.2000 -44.53125 0.00000 2.17400 2.17400 13.00000 0.30300 0.84500 15.10000 1.00000 6.00000 6.00000 1.00000 6.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
50.208 1420.00000 41.2000 -44.53125 0.00000 2.17400 2.17400 13.00000 0.30300 0.84500 15.10000 1.00000 6.00000 6.00000 1.00000 6.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
50.218 1420.00000 41.2000 -44.53125 0.00000 2.17400 2.17400 13.00000 0.30300 0.84500 15.10000 1.00000 6.00000 6.00000 1.00000 6.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
50.228 1420.00000 41.2000 -44.53125 0.00000 2.17400 2.17400 13.00000 0.30300 0.84500 15.10000 1.00000 6.00000 6.00000 1.00000 6.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
50.238 1420.00000 41.2000 -44.53125 0.00000 2.17400 2.17400 13.00000 0.30300 0.84500 15.10000 1.00000 6.00000 6.00000 1.00000 6.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
50.248 1420.00000 41.2000 -44.53125 0.00000 2.17400 2.17400 13.00000 0.30300 0.84500 15.10000 1.00000 6.00000 6.00000 1.00000 6.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
50.258 1420.00000 41.1000 -44.53125 0.00000 2.09800 2.09800 13.40000 0.32800 0.37300 15.20000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 18.2000 0.000 0.000 0.000 0.000
50.268 1420.00000 41.1000 -44.53125 0.00000 2.09800 2.09800 13.40000 0.32800 0.37300 15.20000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 18.2000 0.000 0.000 0.000 0.000
50.278 1420.00000 41.1000 -44.53125 0.00000 2.09800 2.09800 13.40000 0.32800 0.37300 15.20000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 18.2000 0.000 0.000 0.000 0.000
50.288 1420.00000 41.1000 -44.53125 0.00000 2.09800 2.09800 13.40000 0.32800 0.37300 15.20000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 18.2000 0.000 0.000 0.000 0.000
50.298 1420.00000 41.1000 -44.53125 0.00000 2.09800 2.09800 13.40000 0.32800 0.37300 15.20000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 18.2000 0.000 0.000 0.000 0.000
50.308 1420.00000 41.1000 -44.53125 0.00000 2.09800 2.09800 13.40000 0.32800 0.37300 15.20000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 18.2000 0.000 0.000 0.000 0.000
50.318 1393.00000 40.9000 -43.75000 0.00000 2.02800 2.02800 12.10000 0.32800 0.37300 15.30000 1.00000 5.00000 6.00000 6.00000 6.00000 0.00000 0.00000 17.2000 0.000 0.000 0.000 0.000
50.328 1393.00000 40.9000 -43.75000 0.00000 2.02800 2.02800 12.10000 0.32800 0.37300 15.30000 1.00000 5.00000 6.00000 6.00000 6.00000 0.00000 0.00000 17.2000 0.000 0.000 0.000 0.000
50.338 1393.00000 40.9000 -43.75000 0.00000 2.02800 2.02800 12.10000 0.32800 0.37300 15.30000 1.00000 5.00000 6.00000 6.00000 6.00000 0.00000 0.00000 17.2000 0.000 0.000 0.000 0.000
50.348 1393.00000 40.9000 -43.75000 0.00000 2.02800 2.02800 12.10000 0.32800 0.37300 15.30000 1.00000 5.00000 6.00000 6.00000 6.00000 0.00000 0.00000 17.2000 0.000 0.000 0.000 0.000
50.358 1393.00000 40.9000 -43.75000 0.00000 2.02800 2.02800 12.10000 0.32800 0.37300 15.30000 1.00000 5.00000 6.00000 6.00000 6.00000 0.00000 0.00000 17.2000 0.000 0.000 0.000 0.000
50.368 1384.00000 41.5000 -44.53125 0.00000 2.15100 2.15100 13.20000 0.32800 0.37300 13.90000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 17.4000 0.000 0.000 0.000 0.000
50.378 1384.00000 41.5000 -44.53125 0.00000 2.15100 2.15100 13.20000 0.32800 0.37300 13.90000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 17.4000 0.000 0.000 0.000 0.000
50.388 1384.00000 41.5000 -44.53125 0.00000 2.15100 2.15100 13.20000 0.32800 0.37300 13.90000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 17.4000 0.000 0.000 0.000 0.000
50.398 1384.00000 41.5000 -44.53125 0.00000 2.15100 2.15100 13.20000 0.32800 0.37300 13.90000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 17.4000 0.000 0.000 0.000 0.000
50.408 1384.00000 41.5000 -44.53125 0.00000 2.15100 2.15100 13.20000 0.32800 0.37300 13.90000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 17.4000 0.000 0.000 0.000 0.000
50.418 1389.00000 41.4000 -43.75000 0.00000 2.06900 2.06900 13.30000 0.32800 0.37300 15.30000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 16.0000 0.000 0.000 0.000 0.000
50.428 1389.00000 41.4000 -43.75000 0.00000 2.06900 2.06900 13.30000 0.32800 0.37300 15.30000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 16.0000 0.000 0.000 0.000 0.000
50.438 1389.00000 41.4000 -43.75000 0.00000 2.06900 2.06900 13.30000 0.32800 0.37300 15.30000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 16.0000 0.000 0.000 0.000 0.000
50.448 1389.00000 41.4000 -43.75000 0.00000 2.06900 2.06900 13.30000 0.32800 0.37300 15.30000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 16.0000 0.000 0.000 0.000 0.000
50.458 1389.00000 41.4000 -43.75000 0.00000 2.06900 2.06900 13.30000 0.32800 0.37300 15.30000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 16.0000 0.000 0.000 0.000 0.000
50.468 1389.00000 42.4000 -44.53125 0.00000 2.25000 2.25000 13.10000 0.39800 0.34700 14.00000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
50.478 1389.00000 42.4000 -44.53125 0.00000 2.25000 2.25000 13.10000 0.39800 0.34700 14.00000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
50.488 1389.00000 42.4000 -44.53125 0.00000 2.25000 2.25000 13.10000 0.39800 0.34700 14.00000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
50.498 1389.00000 42.4000 -44.53125 0.00000 2.25000 2.25000 13.10000 0.39800 0.34700 14.00000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
50.508 1389.00000 42.4000 -44.53125 0.00000 2.25000 2.25000 13.10000 0.39800 0.34700 14.00000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
50.518 1464.00000 43.0000 -44.53125 0.00000 2.13900 2.13900 13.20000 0.39800 0.34700 15.20000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
50.528 1464.00000 43.0000 -44.53125 0.00000 2.13900 2.13900 13.20000 0.39800 0.34700 15.20000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
50.538 1464.00000 43.0000 -44.53125 0.00000 2.13900 2.13900 13.20000 0.39800 0.34700 15.20000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
50.548 1464.00000 43.0000 -44.53125 0.00000 2.13900 2.13900 13.20000 0.39800 0.34700 15.20000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
50.558 1464.00000 43.0000 -44.53125 0.00000 2.13900 2.13900 13.20000 0.39800 0.34700 15.20000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
50.568 1442.00000 42.4000 -44.53125 0.00000 2.19200 2.19200 13.20000 0.39800 0.34700 14.00000 1.00000 5.00000 5.00000 6.00000 5.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
50.578 1442.00000 42.4000 -44.53125 0.00000 2.19200 2.19200 13.20000 0.39800 0.34700 14.00000 1.00000 5.00000 5.00000 6.00000 5.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
50.588 1442.00000 42.4000 -44.53125 0.00000 2.19200 2.19200 13.20000 0.39800 0.34700 14.00000 1.00000 5.00000 5.00000 6.00000 5.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
50.598 1442.00000 42.4000 -44.53125 0.00000 2.19200 2.19200 13.20000 0.39800 0.34700 14.00000 1.00000 5.00000 5.00000 6.00000 5.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
50.608 1442.00000 42.4000 -44.53125 0.00000 2.19200 2.19200 13.20000 0.39800 0.34700 14.00000 1.00000 5.00000 5.00000 6.00000 5.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
50.618 1443.00000 43.2000 -44.53125 0.00000 2.24400 2.24400 13.30000 0.39800 0.34700 15.00000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
50.628 1443.00000 43.2000 -44.53125 0.00000 2.24400 2.24400 13.30000 0.39800 0.34700 15.00000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
50.638 1443.00000 43.2000 -44.53125 0.00000 2.24400 2.24400 13.30000 0.39800 0.34700 15.00000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
50.648 1443.00000 43.2000 -44.53125 0.00000 2.24400 2.24400 13.30000 0.39800 0.34700 15.00000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
50.658 1443.00000 43.2000 -44.53125 0.00000 2.24400 2.24400 13.30000 0.39800 0.34700 15.00000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
50.668 1443.00000 44.4000 -44.53125 0.00000 2.10400 2.10400 13.30000 0.32200 0.36000 15.00000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
50.678 1443.00000 44.4000 -44.53125 0.00000 2.10400 2.10400 13.30000 0.32200 0.36000 15.00000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
50.688 1443.00000 44.4000 -44.53125 0.00000 2.10400 2.10400 13.30000 0.32200 0.36000 15.00000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
50.698 1443.00000 44.4000 -44.53125 0.00000 2.10400 2.10400 13.30000 0.32200 0.36000 15.00000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
50.708 1443.00000 44.4000 -44.53125 0.00000 2.10400 2.10400 13.30000 0.32200 0.36000 15.00000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
50.717 1510.00000 47.8000 -44.53125 0.00000 2.25000 2.25000 13.00000 0.32200 0.36000 14.30000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
50.727 1510.00000 47.8000 -44.53125 0.00000 2.25000 2.25000 13.00000 0.32200 0.36000 14.30000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
50.737 1510.00000 47.8000 -44.53125 0.00000 2.25000 2.25000 13.00000 0.32200 0.36000 14.30000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
50.747 1510.00000 47.8000 -44.53125 0.00000 2.25000 2.25000 13.00000 0.32200 0.36000 14.30000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
50.757 1510.00000 47.8000 -44.53125 0.00000 2.25000 2.25000 13.00000 0.32200 0.36000 14.30000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
50.767 1490.00000 49.0000 -44.53125 0.00000 2.19700 2.19700 13.40000 0.32200 0.36000 14.90000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
50.777 1490.00000 49.0000 -44.53125 0.00000 2.19700 2.19700 13.40000 0.32200 0.36000 14.90000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
50.787 1490.00000 49.0000 -44.53125 0.00000 2.19700 2.19700 13.40000 0.32200 0.36000 14.90000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
50.797 1490.00000 49.0000 -44.53125 0.00000 2.19700 2.19700 13.40000 0.32200 0.36000 14.90000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
50.807 1490.00000 49.0000 -44.53125 0.00000 2.19700 2.19700 13.40000 0.32200 0.36000 14.90000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
50.817 1488.00000 49.9000 -44.53125 0.00000 2.12200 2.12200 13.30000 0.32200 0.36000 15.20000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.8000 0.000 0.000 0.000 0.000
50.827 1488.00000 49.9000 -44.53125 0.00000 2.12200 2.12200 13.30000 0.32200 0.36000 15.20000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.8000 0.000 0.000 0.000 0.000
50.837 1488.00000 49.9000 -44.53125 0.00000 2.12200 2.12200 13.30000 0.32200 0.36000 15.20000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.8000 0.000 0.000 0.000 0.000
50.847 1488.00000 49.9000 -44.53125 0.00000 2.12200 2.12200 13.30000 0.32200 0.36000 15.20000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.8000 0.000 0.000 0.000 0.000
50.857 1488.00000 49.9000 -44.53125 0.00000 2.12200 2.12200 13.30000 0.32200 0.36000 15.20000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.8000 0.000 0.000 0.000 0.000
50.867 1524.00000 50.7000 -44.53125 0.00000 2.34900 2.34900 12.70000 0.39500 0.33500 14.40000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
50.877 1524.00000 50.7000 -44.53125 0.00000 2.34900 2.34900 12.70000 0.39500 0.33500 14.40000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
50.887 1524.00000 50.7000 -44.53125 0.00000 2.34900 2.34900 12.70000 0.39500 0.33500 14.40000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
50.897 1524.00000 50.7000 -44.53125 0.00000 2.34900 2.34900 12.70000 0.39500 0.33500 14.40000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
50.907 1524.00000 50.7000 -44.53125 0.00000 2.34900 2.34900 12.70000 0.39500 0.33500 14.40000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
50.917 1524.00000 51.6000 -44.53125 0.00000 2.30200 2.30200 13.30000 0.39500 0.33500 14.70000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
50.927 1524.00000 51.6000 -44.53125 0.00000 2.30200 2.30200 13.30000 0.39500 0.33500 14.70000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
50.937 1524.00000 51.6000 -44.53125 0.00000 2.30200 2.30200 13.30000 0.39500 0.33500 14.70000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
50.947 1524.00000 51.6000 -44.53125 0.00000 2.30200 2.30200 13.30000 0.39500 0.33500 14.70000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
50.957 1524.00000 51.6000 -44.53125 0.00000 2.30200 2.30200 13.30000 0.39500 0.33500 14.70000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
50.967 1585.00000 52.7000 -43.75000 0.00000 2.24400 2.24400 13.30000 0.39500 0.33500 15.30000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
50.977 1585.00000 52.7000 -43.75000 0.00000 2.24400 2.24400 13.30000 0.39500 0.33500 15.30000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
50.987 1585.00000 52.7000 -43.75000 0.00000 2.24400 2.24400 13.30000 0.39500 0.33500 15.30000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
50.997 1585.00000 52.7000 -43.75000 0.00000 2.24400 2.24400 13.30000 0.39500 0.33500 15.30000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
51.007 1585.00000 52.7000 -43.75000 0.00000 2.24400 2.24400 13.30000 0.39500 0.33500 15.30000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
51.017 1556.00000 52.2000 -43.75000 0.00000 2.06900 2.06900 13.00000 0.39500 0.33500 15.40000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
51.027 1556.00000 52.2000 -43.75000 0.00000 2.06900 2.06900 13.00000 0.39500 0.33500 15.40000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
51.037 1556.00000 52.2000 -43.75000 0.00000 2.06900 2.06900 13.00000 0.39500 0.33500 15.40000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
51.047 1556.00000 52.2000 -43.75000 0.00000 2.06900 2.06900 13.00000 0.39500 0.33500 15.40000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
51.057 1556.00000 52.2000 -43.75000 0.00000 2.06900 2.06900 13.00000 0.39500 0.33500 15.40000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
51.067 1565.00000 52.2000 -44.53125 0.00000 2.29100 2.29100 13.50000 1.01500 0.35400 14.50000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
51.077 1565.00000 52.2000 -44.53125 0.00000 2.29100 2.29100 13.50000 1.01500 0.35400 14.50000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
51.087 1565.00000 52.2000 -44.53125 0.00000 2.29100 2.29100 13.50000 1.01500 0.35400 14.50000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
51.097 1565.00000 52.2000 -44.53125 0.00000 2.29100 2.29100 13.50000 1.01500 0.35400 14.50000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
51.107 1565.00000 52.2000 -44.53125 0.00000 2.29100 2.29100 13.50000 1.01500 0.35400 14.50000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
51.117 1595.00000 52.2000 -44.53125 0.00000 2.35500 2.35500 13.10000 1.01500 0.35400 14.30000 1.00000 7.00000 7.00000 7.00000 7.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
51.127 1595.00000 52.2000 -44.53125 0.00000 2.35500 2.35500 13.10000 1.01500 0.35400 14.30000 1.00000 7.00000 7.00000 7.00000 7.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
51.137 1595.00000 52.2000 -44.53125 0.00000 2.35500 2.35500 13.10000 1.01500 0.35400 14.30000 1.00000 7.00000 7.00000 7.00000 7.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
51.147 1595.00000 52.2000 -44.53125 0.00000 2.35500 2.35500 13.10000 1.01500 0.35400 14.30000 1.00000 7.00000 7.00000 7.00000 7.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
51.157 1595.00000 52.2000 -44.53125 0.00000 2.35500 2.35500 13.10000 1.01500 0.35400 14.30000 1.00000 7.00000 7.00000 7.00000 7.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
51.167 1595.00000 51.8000 -44.53125 0.00000 2.39000 2.39000 13.30000 1.01500 0.35400 14.50000 1.00000 7.00000 7.00000 6.00000 7.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
51.177 1595.00000 51.8000 -44.53125 0.00000 2.39000 2.39000 13.30000 1.01500 0.35400 14.50000 1.00000 7.00000 7.00000 6.00000 7.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
51.187 1595.00000 51.8000 -44.53125 0.00000 2.39000 2.39000 13.30000 1.01500 0.35400 14.50000 1.00000 7.00000 7.00000 6.00000 7.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
51.197 1595.00000 51.8000 -44.53125 0.00000 2.39000 2.39000 13.30000 1.01500 0.35400 14.50000 1.00000 7.00000 7.00000 6.00000 7.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
51.207 1595.00000 51.8000 -44.53125 0.00000 2.39000 2.39000 13.30000 1.01500 0.35400 14.50000 1.00000 7.00000 7.00000 6.00000 7.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
51.217 1649.00000 51.8000 -44.53125 0.00000 2.39600 2.39600 13.10000 1.01500 0.35400 15.10000 1.00000 7.00000 7.00000 7.00000 7.00000 0.00000 0.00000 14.4000 0.000 0.000 0.000 0.000
51.227 1649.00000 51.8000 -44.53125 0.00000 2.39600 2.39600 13.10000 1.01500 0.35400 15.10000 1.00000 7.00000 7.00000 7.00000 7.00000 0.00000 0.00000 14.4000 0.000 0.000 0.000 0.000
51.237 1649.00000 51.8000 -44.53125 0.00000 2.39600 2.39600 13.10000 1.01500 0.35400 15.10000 1.00000 7.00000 7.00000 7.00000 7.00000 0.00000 0.00000 14.4000 0.000 0.000 0.000 0.000
51.247 1649.00000 51.8000 -44.53125 0.00000 2.39600 2.39600 13.10000 1.01500 0.35400 15.10000 1.00000 7.00000 7.00000 7.00000 7.00000 0.00000 0.00000 14.4000 0.000 0.000 0.000 0.000
51.257 1649.00000 51.8000 -44.53125 0.00000 2.39600 2.39600 13.10000 1.01500 0.35400 15.10000 1.00000 7.00000 7.00000 7.00000 7.00000 0.00000 0.00000 14.4000 0.000 0.000 0.000 0.000
51.267 1609.00000 52.2000 -43.75000 0.00000 2.34900 2.34900 13.30000 1.05900 0.46200 15.30000 1.00000 7.00000 7.00000 7.00000 7.00000 0.00000 0.00000 14.4000 0.000 0.000 0.000 0.000
51.277 1609.00000 52.2000 -43.75000 0.00000 2.34900 2.34900 13.30000 1.05900 0.46200 15.30000 1.00000 7.00000 7.00000 7.00000 7.00000 0.00000 0.00000 14.4000 0.000 0.000 0.000 0.000
51.287 1609.00000 52.2000 -43.75000 0.00000 2.34900 2.34900 13.30000 1.05900 0.46200 15.30000 1.00000 7.00000 7.00000 7.00000 7.00000 0.00000 0.00000 14.4000 0.000 0.000 0.000 0.000
51.297 1609.00000 52.2000 -43.75000 0.00000 2.34900 2.34900 13.30000 1.05900 0.46200 15.30000 1.00000 7.00000 7.00000 7.00000 7.00000 0.00000 0.00000 14.4000 0.000 0.000 0.000 0.000
51.307 1609.00000 52.2000 -43.75000 0.00000 2.34900 2.34900 13.30000 1.05900 0.46200 15.30000 1.00000 7.00000 7.00000 7.00000 7.00000 0.00000 0.00000 14.4000 0.000 0.000 0.000 0.000
51.317 1632.00000 52.5000 -42.18750 -0.12500 2.33100 2.33100 13.20000 1.05900 0.46200 15.80000 1.00000 7.00000 7.00000 7.00000 7.00000 0.00000 0.00000 14.4000 0.000 0.000 0.000 0.000
51.327 1632.00000 52.5000 -42.18750 -0.12500 2.33100 2.33100 13.20000 1.05900 0.46200 15.80000 1.00000 7.00000 7.00000 7.00000 7.00000 0.00000 0.00000 14.4000 0.000 0.000 0.000 0.000
51.337 1632.00000 52.5000 -42.18750 -0.12500 2.33100 2.33100 13.20000 1.05900 0.46200 15.80000 1.00000 7.00000 7.00000 7.00000 7.00000 0.00000 0.00000 14.4000 0.000 0.000 0.000 0.000
51.347 1632.00000 52.5000 -42.18750 -0.12500 2.33100 2.33100 13.20000 1.05900 0.46200 15.80000 1.00000 7.00000 7.00000 7.00000 7.00000 0.00000 0.00000 14.4000 0.000 0.000 0.000 0.000
51.357 1632.00000 52.5000 -42.18750 -0.12500 2.33100 2.33100 13.20000 1.05900 0.46200 15.80000 1.00000 7.00000 7.00000 7.00000 7.00000 0.00000 0.00000 14.4000 0.000 0.000 0.000 0.000
51.367 1692.00000 52.5000 -42.18750 -0.12500 2.26700 2.26700 13.30000 1.05900 0.46200 15.80000 1.00000 7.00000 7.00000 7.00000 7.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
51.377 1692.00000 52.5000 -42.18750 -0.12500 2.26700 2.26700 13.30000 1.05900 0.46200 15.80000 1.00000 7.00000 7.00000 7.00000 7.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
51.387 1692.00000 52.5000 -42.18750 -0.12500 2.26700 2.26700 13.30000 1.05900 0.46200 15.80000 1.00000 7.00000 7.00000 7.00000 7.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
51.397 1692.00000 52.5000 -42.18750 -0.12500 2.26700 2.26700 13.30000 1.05900 0.46200 15.80000 1.00000 7.00000 7.00000 7.00000 7.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
51.407 1692.00000 52.5000 -42.18750 -0.12500 2.26700 2.26700 13.30000 1.05900 0.46200 15.80000 1.00000 7.00000 7.00000 7.00000 7.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
51.417 1674.00000 53.0000 -42.18750 -0.12500 2.30200 2.30200 13.40000 1.05900 0.46200 15.80000 1.00000 7.00000 7.00000 7.00000 7.00000 0.00000 0.00000 14.0000 0.000 0.000 0.000 0.000
51.427 1674.00000 53.0000 -42.18750 -0.12500 2.30200 2.30200 13.40000 1.05900 0.46200 15.80000 1.00000 7.00000 7.00000 7.00000 7.00000 0.00000 0.00000 14.0000 0.000 0.000 0.000 0.000
51.437 1674.00000 53.0000 -42.18750 -0.12500 2.30200 2.30200 13.40000 1.05900 0.46200 15.80000 1.00000 7.00000 7.00000 7.00000 7.00000 0.00000 0.00000 14.0000 0.000 0.000 0.000 0.000
51.447 1674.00000 53.0000 -42.18750 -0.12500 2.30200 2.30200 13.40000 1.05900 0.46200 15.80000 1.00000 7.00000 7.00000 7.00000 7.00000 0.00000 0.00000 14.0000 0.000 0.000 0.000 0.000
51.457 1674.00000 53.0000 -42.18750 -0.12500 2.30200 2.30200 13.40000 1.05900 0.46200 15.80000 1.00000 7.00000 7.00000 7.00000 7.00000 0.00000 0.00000 14.0000 0.000 0.000 0.000 0.000
51.467 1678.00000 52.8000 -41.40625 -0.12500 2.30200 2.30200 13.50000 1.08200 0.96300 15.90000 1.00000 7.00000 7.00000 7.00000 7.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
51.477 1678.00000 52.8000 -41.40625 -0.12500 2.30200 2.30200 13.50000 1.08200 0.96300 15.90000 1.00000 7.00000 7.00000 7.00000 7.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
51.487 1678.00000 52.8000 -41.40625 -0.12500 2.30200 2.30200 13.50000 1.08200 0.96300 15.90000 1.00000 7.00000 7.00000 7.00000 7.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
51.497 1678.00000 52.8000 -41.40625 -0.12500 2.30200 2.30200 13.50000 1.08200 0.96300 15.90000 1.00000 7.00000 7.00000 7.00000 7.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
51.507 1678.00000 52.8000 -41.40625 -0.12500 2.30200 2.30200 13.50000 1.08200 0.96300 15.90000 1.00000 7.00000 7.00000 7.00000 7.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
51.517 1678.00000 52.8000 -42.18750 -0.12500 2.30200 2.30200 13.40000 1.08200 0.96300 15.80000 1.00000 7.00000 7.00000 7.00000 7.00000 0.00000 0.00000 13.8000 0.000 0.000 0.000 0.000
51.527 1678.00000 52.8000 -42.18750 -0.12500 2.30200 2.30200 13.40000 1.08200 0.96300 15.80000 1.00000 7.00000 7.00000 7.00000 7.00000 0.00000 0.00000 13.8000 0.000 0.000 0.000 0.000
51.537 1678.00000 52.8000 -42.18750 -0.12500 2.30200 2.30200 13.40000 1.08200 0.96300 15.80000 1.00000 7.00000 7.00000 7.00000 7.00000 0.00000 0.00000 13.8000 0.000 0.000 0.000 0.000
51.547 1678.00000 52.8000 -42.18750 -0.12500 2.30200 2.30200 13.40000 1.08200 0.96300 15.80000 1.00000 7.00000 7.00000 7.00000 7.00000 0.00000 0.00000 13.8000 0.000 0.000 0.000 0.000
51.557 1678.00000 52.8000 -42.18750 -0.12500 2.30200 2.30200 13.40000 1.08200 0.96300 15.80000 1.00000 7.00000 7.00000 7.00000 7.00000 0.00000 0.00000 13.8000 0.000 0.000 0.000 0.000
51.567 1691.00000 52.5000 -42.18750 -0.12500 2.43100 2.43100 13.30000 1.08200 0.96300 15.80000 1.00000 7.00000 7.00000 7.00000 7.00000 0.00000 0.00000 13.8000 0.000 0.000 0.000 0.000
51.577 1691.00000 52.5000 -42.18750 -0.12500 2.43100 2.43100 13.30000 1.08200 0.96300 15.80000 1.00000 7.00000 7.00000 7.00000 7.00000 0.00000 0.00000 13.8000 0.000 0.000 0.000 0.000
51.587 1691.00000 52.5000 -42.18750 -0.12500 2.43100 2.43100 13.30000 1.08200 0.96300 15.80000 1.00000 7.00000 7.00000 7.00000 7.00000 0.00000 0.00000 13.8000 0.000 0.000 0.000 0.000
51.597 1691.00000 52.5000 -42.18750 -0.12500 2.43100 2.43100 13.30000 1.08200 0.96300 15.80000 1.00000 7.00000 7.00000 7.00000 7.00000 0.00000 0.00000 13.8000 0.000 0.000 0.000 0.000
51.607 1691.00000 52.5000 -42.18750 -0.12500 2.43100 2.43100 13.30000 1.08200 0.96300 15.80000 1.00000 7.00000 7.00000 7.00000 7.00000 0.00000 0.00000 13.8000 0.000 0.000 0.000 0.000
51.617 1773.00000 52.8000 -43.75000 0.00000 2.52400 2.52400 13.10000 1.08200 0.96300 15.20000 1.00000 7.00000 7.00000 7.00000 7.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
51.627 1773.00000 52.8000 -43.75000 0.00000 2.52400 2.52400 13.10000 1.08200 0.96300 15.20000 1.00000 7.00000 7.00000 7.00000 7.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
51.637 1773.00000 52.8000 -43.75000 0.00000 2.52400 2.52400 13.10000 1.08200 0.96300 15.20000 1.00000 7.00000 7.00000 7.00000 7.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
51.647 1773.00000 52.8000 -43.75000 0.00000 2.52400 2.52400 13.10000 1.08200 0.96300 15.20000 1.00000 7.00000 7.00000 7.00000 7.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
51.657 1773.00000 52.8000 -43.75000 0.00000 2.52400 2.52400 13.10000 1.08200 0.96300 15.20000 1.00000 7.00000 7.00000 7.00000 7.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
51.667 1750.00000 52.8000 -44.53125 0.00000 2.53500 2.53500 13.20000 1.09100 1.02100 15.20000 1.00000 7.00000 7.00000 7.00000 7.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
51.677 1750.00000 52.8000 -44.53125 0.00000 2.53500 2.53500 13.20000 1.09100 1.02100 15.20000 1.00000 7.00000 7.00000 7.00000 7.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
51.687 1750.00000 52.8000 -44.53125 0.00000 2.53500 2.53500 13.20000 1.09100 1.02100 15.20000 1.00000 7.00000 7.00000 7.00000 7.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
51.697 1750.00000 52.8000 -44.53125 0.00000 2.53500 2.53500 13.20000 1.09100 1.02100 15.20000 1.00000 7.00000 7.00000 7.00000 7.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
51.707 1750.00000 52.8000 -44.53125 0.00000 2.53500 2.53500 13.20000 1.09100 1.02100 15.20000 1.00000 7.00000 7.00000 7.00000 7.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
51.717 1752.00000 53.1000 -44.53125 0.00000 2.52400 2.52400 12.80000 1.09100 1.02100 14.80000 1.00000 7.00000 7.00000 7.00000 7.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
51.727 1752.00000 53.1000 -44.53125 0.00000 2.52400 2.52400 12.80000 1.09100 1.02100 14.80000 1.00000 7.00000 7.00000 7.00000 7.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
51.737 1752.00000 53.1000 -44.53125 0.00000 2.52400 2.52400 12.80000 1.09100 1.02100 14.80000 1.00000 7.00000 7.00000 7.00000 7.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
51.747 1752.00000 53.1000 -44.53125 0.00000 2.52400 2.52400 12.80000 1.09100 1.02100 14.80000 1.00000 7.00000 7.00000 7.00000 7.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
51.757 1752.00000 53.1000 -44.53125 0.00000 2.52400 2.52400 12.80000 1.09100 1.02100 14.80000 1.00000 7.00000 7.00000 7.00000 7.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
51.767 1752.00000 53.1000 -44.53125 0.00000 2.52400 2.52400 12.80000 1.09100 1.02100 14.80000 1.00000 7.00000 7.00000 7.00000 7.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
51.777 1762.00000 53.4000 -43.75000 0.00000 2.55300 2.55300 13.30000 1.09100 1.02100 15.40000 1.00000 7.00000 7.00000 7.00000 7.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
51.787 1762.00000 53.4000 -43.75000 0.00000 2.55300 2.55300 13.30000 1.09100 1.02100 15.40000 1.00000 7.00000 7.00000 7.00000 7.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
51.797 1762.00000 53.4000 -43.75000 0.00000 2.55300 2.55300 13.30000 1.09100 1.02100 15.40000 1.00000 7.00000 7.00000 7.00000 7.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
51.807 1762.00000 53.4000 -43.75000 0.00000 2.55300 2.55300 13.30000 1.09100 1.02100 15.40000 1.00000 7.00000 7.00000 7.00000 7.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
51.817 1762.00000 53.4000 -43.75000 0.00000 2.55300 2.55300 13.30000 1.09100 1.02100 15.40000 1.00000 7.00000 7.00000 7.00000 7.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
51.827 1831.00000 53.6000 -44.53125 0.00000 2.60500 2.60500 12.40000 1.09100 1.02100 14.90000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
51.837 1831.00000 53.6000 -44.53125 0.00000 2.60500 2.60500 12.40000 1.09100 1.02100 14.90000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
51.847 1831.00000 53.6000 -44.53125 0.00000 2.60500 2.60500 12.40000 1.09100 1.02100 14.90000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
51.857 1831.00000 53.6000 -44.53125 0.00000 2.60500 2.60500 12.40000 1.09100 1.02100 14.90000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
51.867 1831.00000 53.6000 -44.53125 0.00000 2.60500 2.60500 12.40000 1.09100 1.02100 14.90000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
51.877 1831.00000 53.6000 -44.53125 0.00000 2.60500 2.60500 12.40000 1.09100 1.02100 14.90000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
51.887 1819.00000 54.1000 -44.53125 0.00000 2.61700 2.61700 13.00000 1.09100 1.04300 14.90000 1.00000 8.00000 8.00000 8.00000 7.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
51.897 1819.00000 54.1000 -44.53125 0.00000 2.61700 2.61700 13.00000 1.09100 1.04300 14.90000 1.00000 8.00000 8.00000 8.00000 7.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
51.907 1819.00000 54.1000 -44.53125 0.00000 2.61700 2.61700 13.00000 1.09100 1.04300 14.90000 1.00000 8.00000 8.00000 8.00000 7.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
51.917 1819.00000 54.1000 -44.53125 0.00000 2.61700 2.61700 13.00000 1.09100 1.04300 14.90000 1.00000 8.00000 8.00000 8.00000 7.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
51.927 1819.00000 54.1000 -44.53125 0.00000 2.61700 2.61700 13.00000 1.09100 1.04300 14.90000 1.00000 8.00000 8.00000 8.00000 7.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
51.937 1819.00000 54.1000 -44.53125 0.00000 2.61700 2.61700 13.00000 1.09100 1.04300 14.90000 1.00000 8.00000 8.00000 8.00000 7.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
51.947 1834.00000 53.9000 -43.75000 0.00000 2.58800 2.58800 13.30000 1.09100 1.04300 15.30000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
51.957 1834.00000 53.9000 -43.75000 0.00000 2.58800 2.58800 13.30000 1.09100 1.04300 15.30000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
51.967 1834.00000 53.9000 -43.75000 0.00000 2.58800 2.58800 13.30000 1.09100 1.04300 15.30000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
51.977 1834.00000 53.9000 -43.75000 0.00000 2.58800 2.58800 13.30000 1.09100 1.04300 15.30000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
51.987 1834.00000 53.9000 -43.75000 0.00000 2.58800 2.58800 13.30000 1.09100 1.04300 15.30000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
51.997 1834.00000 53.9000 -43.75000 0.00000 2.58800 2.58800 13.30000 1.09100 1.04300 15.30000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
52.007 1852.00000 53.4000 -43.75000 0.00000 2.60500 2.60500 13.10000 1.09100 1.04300 15.40000 1.00000 9.00000 9.00000 8.00000 9.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
52.017 1852.00000 53.9000 -44.53125 0.00000 2.65200 2.65200 13.30000 1.10100 1.06600 14.70000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
52.027 1852.00000 53.9000 -44.53125 0.00000 2.65200 2.65200 13.30000 1.10100 1.06600 14.70000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
52.037 1852.00000 53.9000 -44.53125 0.00000 2.65200 2.65200 13.30000 1.10100 1.06600 14.70000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
52.047 1852.00000 53.9000 -44.53125 0.00000 2.65200 2.65200 13.30000 1.10100 1.06600 14.70000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
52.057 1852.00000 53.9000 -44.53125 0.00000 2.65200 2.65200 13.30000 1.10100 1.06600 14.70000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
52.067 1852.00000 53.9000 -44.53125 0.00000 2.65200 2.65200 13.30000 1.10100 1.06600 14.70000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
52.077 1852.00000 53.9000 -44.53125 0.00000 2.65200 2.65200 13.30000 1.10100 1.06600 14.70000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
52.087 1852.00000 53.9000 -44.53125 0.00000 2.65200 2.65200 13.30000 1.10100 1.06600 14.70000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
52.097 1852.00000 53.9000 -44.53125 0.00000 2.65200 2.65200 13.30000 1.10100 1.06600 14.70000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
52.107 1898.00000 54.7000 -41.40625 -0.12500 2.48300 2.48300 13.30000 1.10100 1.06600 16.10000 1.00000 9.00000 8.00000 8.00000 8.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
52.117 1898.00000 54.7000 -41.40625 -0.12500 2.48300 2.48300 13.30000 1.10100 1.06600 16.10000 1.00000 9.00000 8.00000 8.00000 8.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
52.127 1898.00000 54.7000 -41.40625 -0.12500 2.48300 2.48300 13.30000 1.10100 1.06600 16.10000 1.00000 9.00000 8.00000 8.00000 8.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
52.137 1898.00000 54.7000 -41.40625 -0.12500 2.48300 2.48300 13.30000 1.10100 1.06600 16.10000 1.00000 9.00000 8.00000 8.00000 8.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
52.147 1898.00000 54.7000 -41.40625 -0.12500 2.48300 2.48300 13.30000 1.10100 1.06600 16.10000 1.00000 9.00000 8.00000 8.00000 8.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
52.157 1902.00000 53.9000 -42.96875 -0.12500 2.68700 2.68700 13.40000 1.10100 1.06600 15.50000 1.00000 9.00000 9.00000 9.00000 9.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
52.167 1902.00000 53.9000 -42.96875 -0.12500 2.68700 2.68700 13.40000 1.10100 1.06600 15.50000 1.00000 9.00000 9.00000 9.00000 9.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
52.177 1902.00000 53.9000 -42.96875 -0.12500 2.68700 2.68700 13.40000 1.10100 1.06600 15.50000 1.00000 9.00000 9.00000 9.00000 9.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
52.187 1902.00000 53.9000 -42.96875 -0.12500 2.68700 2.68700 13.40000 1.10100 1.06600 15.50000 1.00000 9.00000 9.00000 9.00000 9.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
52.197 1902.00000 53.9000 -42.96875 -0.12500 2.68700 2.68700 13.40000 1.10100 1.06600 15.50000 1.00000 9.00000 9.00000 9.00000 9.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
52.207 1901.00000 53.6000 -42.18750 -0.12500 2.68100 2.68100 13.20000 1.11000 1.08200 15.60000 1.00000 8.00000 9.00000 8.00000 8.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
52.217 1901.00000 53.6000 -42.18750 -0.12500 2.68100 2.68100 13.20000 1.11000 1.08200 15.60000 1.00000 8.00000 9.00000 8.00000 8.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
52.227 1901.00000 53.6000 -42.18750 -0.12500 2.68100 2.68100 13.20000 1.11000 1.08200 15.60000 1.00000 8.00000 9.00000 8.00000 8.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
52.237 1901.00000 53.6000 -42.18750 -0.12500 2.68100 2.68100 13.20000 1.11000 1.08200 15.60000 1.00000 8.00000 9.00000 8.00000 8.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
52.247 1901.00000 53.6000 -42.18750 -0.12500 2.68100 2.68100 13.20000 1.11000 1.08200 15.60000 1.00000 8.00000 9.00000 8.00000 8.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
52.257 1901.00000 53.6000 -42.18750 -0.12500 2.68100 2.68100 13.20000 1.11000 1.08200 15.60000 1.00000 8.00000 9.00000 8.00000 8.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
52.267 1901.00000 53.6000 -42.18750 -0.12500 2.68100 2.68100 13.20000 1.11000 1.08200 15.60000 1.00000 8.00000 9.00000 8.00000 8.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
52.277 1901.00000 53.6000 -42.18750 -0.12500 2.68100 2.68100 13.20000 1.11000 1.08200 15.60000 1.00000 8.00000 9.00000 8.00000 8.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
52.287 1901.00000 53.6000 -42.18750 -0.12500 2.68100 2.68100 13.20000 1.11000 1.08200 15.60000 1.00000 8.00000 9.00000 8.00000 8.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
52.297 1901.00000 53.6000 -42.18750 -0.12500 2.68100 2.68100 13.20000 1.11000 1.08200 15.60000 1.00000 8.00000 9.00000 8.00000 8.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
52.307 1955.00000 53.9000 -43.75000 0.00000 2.67500 2.67500 13.30000 1.11000 1.08200 15.30000 1.00000 9.00000 9.00000 9.00000 9.00000 0.00000 0.00000 12.7000 0.000 0.000 0.000 0.000
52.317 1955.00000 53.9000 -43.75000 0.00000 2.67500 2.67500 13.30000 1.11000 1.08200 15.30000 1.00000 9.00000 9.00000 9.00000 9.00000 0.00000 0.00000 12.7000 0.000 0.000 0.000 0.000
52.327 1955.00000 53.9000 -43.75000 0.00000 2.67500 2.67500 13.30000 1.11000 1.08200 15.30000 1.00000 9.00000 9.00000 9.00000 9.00000 0.00000 0.00000 12.7000 0.000 0.000 0.000 0.000
52.337 1955.00000 53.9000 -43.75000 0.00000 2.67500 2.67500 13.30000 1.11000 1.08200 15.30000 1.00000 9.00000 9.00000 9.00000 9.00000 0.00000 0.00000 12.7000 0.000 0.000 0.000 0.000
52.347 1955.00000 53.9000 -43.75000 0.00000 2.67500 2.67500 13.30000 1.11000 1.08200 15.30000 1.00000 9.00000 9.00000 9.00000 9.00000 0.00000 0.00000 12.7000 0.000 0.000 0.000 0.000
52.357 2005.00000 53.9000 -42.18750 -0.12500 2.69300 2.69300 12.90000 1.11000 1.08200 15.80000 1.00000 9.00000 9.00000 9.00000 9.00000 0.00000 0.00000 12.7000 0.000 0.000 0.000 0.000
52.367 2005.00000 53.9000 -42.18750 -0.12500 2.69300 2.69300 12.90000 1.11000 1.08200 15.80000 1.00000 9.00000 9.00000 9.00000 9.00000 0.00000 0.00000 12.7000 0.000 0.000 0.000 0.000
52.377 2005.00000 53.9000 -42.18750 -0.12500 2.69300 2.69300 12.90000 1.11000 1.08200 15.80000 1.00000 9.00000 9.00000 9.00000 9.00000 0.00000 0.00000 12.7000 0.000 0.000 0.000 0.000
52.387 2005.00000 53.9000 -42.18750 -0.12500 2.69300 2.69300 12.90000 1.11000 1.08200 15.80000 1.00000 9.00000 9.00000 9.00000 9.00000 0.00000 0.00000 12.7000 0.000 0.000 0.000 0.000
52.397 2005.00000 53.9000 -42.18750 -0.12500 2.69300 2.69300 12.90000 1.11000 1.08200 15.80000 1.00000 9.00000 9.00000 9.00000 9.00000 0.00000 0.00000 12.7000 0.000 0.000 0.000 0.000
52.407 1959.00000 53.3000 -43.75000 0.00000 2.66400 2.66400 13.40000 1.11000 1.08200 15.30000 1.00000 9.00000 9.00000 9.00000 9.00000 0.00000 0.00000 12.7000 0.000 0.000 0.000 0.000
52.417 1959.00000 53.3000 -43.75000 0.00000 2.66400 2.66400 13.40000 1.11000 1.08200 15.30000 1.00000 9.00000 9.00000 9.00000 9.00000 0.00000 0.00000 12.7000 0.000 0.000 0.000 0.000
52.427 1959.00000 53.3000 -43.75000 0.00000 2.66400 2.66400 13.40000 1.11000 1.08200 15.30000 1.00000 9.00000 9.00000 9.00000 9.00000 0.00000 0.00000 12.7000 0.000 0.000 0.000 0.000
52.437 1959.00000 53.3000 -43.75000 0.00000 2.66400 2.66400 13.40000 1.11000 1.08200 15.30000 1.00000 9.00000 9.00000 9.00000 9.00000 0.00000 0.00000 12.7000 0.000 0.000 0.000 0.000
52.447 1959.00000 53.3000 -43.75000 0.00000 2.66400 2.66400 13.40000 1.11000 1.08200 15.30000 1.00000 9.00000 9.00000 9.00000 9.00000 0.00000 0.00000 12.7000 0.000 0.000 0.000 0.000
52.457 2012.00000 53.4000 -42.96875 -0.12500 2.75100 2.75100 13.30000 1.10400 1.09400 15.60000 1.00000 9.00000 9.00000 9.00000 9.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
52.467 2012.00000 53.4000 -42.96875 -0.12500 2.75100 2.75100 13.30000 1.10400 1.09400 15.60000 1.00000 9.00000 9.00000 9.00000 9.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
52.477 2012.00000 53.4000 -42.96875 -0.12500 2.75100 2.75100 13.30000 1.10400 1.09400 15.60000 1.00000 9.00000 9.00000 9.00000 9.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
52.487 2012.00000 53.4000 -42.96875 -0.12500 2.75100 2.75100 13.30000 1.10400 1.09400 15.60000 1.00000 9.00000 9.00000 9.00000 9.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
52.497 2012.00000 53.4000 -42.96875 -0.12500 2.75100 2.75100 13.30000 1.10400 1.09400 15.60000 1.00000 9.00000 9.00000 9.00000 9.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
52.507 2080.00000 54.4000 -40.62500 -0.12500 2.50600 2.50600 13.20000 1.10400 1.09400 16.30000 1.00000 9.00000 9.00000 9.00000 9.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
52.517 2080.00000 54.4000 -40.62500 -0.12500 2.50600 2.50600 13.20000 1.10400 1.09400 16.30000 1.00000 9.00000 9.00000 9.00000 9.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
52.527 2080.00000 54.4000 -40.62500 -0.12500 2.50600 2.50600 13.20000 1.10400 1.09400 16.30000 1.00000 9.00000 9.00000 9.00000 9.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
52.537 2080.00000 54.4000 -40.62500 -0.12500 2.50600 2.50600 13.20000 1.10400 1.09400 16.30000 1.00000 9.00000 9.00000 9.00000 9.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
52.547 2080.00000 54.4000 -40.62500 -0.12500 2.50600 2.50600 13.20000 1.10400 1.09400 16.30000 1.00000 9.00000 9.00000 9.00000 9.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
52.557 2031.00000 54.7000 -43.75000 -0.12500 2.80900 2.80900 12.50000 1.10400 1.09400 15.30000 1.00000 9.00000 9.00000 9.00000 9.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
52.567 2031.00000 54.7000 -43.75000 -0.12500 2.80900 2.80900 12.50000 1.10400 1.09400 15.30000 1.00000 9.00000 9.00000 9.00000 9.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
52.577 2031.00000 54.7000 -43.75000 -0.12500 2.80900 2.80900 12.50000 1.10400 1.09400 15.30000 1.00000 9.00000 9.00000 9.00000 9.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
52.587 2031.00000 54.7000 -43.75000 -0.12500 2.80900 2.80900 12.50000 1.10400 1.09400 15.30000 1.00000 9.00000 9.00000 9.00000 9.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
52.597 2031.00000 54.7000 -43.75000 -0.12500 2.80900 2.80900 12.50000 1.10400 1.09400 15.30000 1.00000 9.00000 9.00000 9.00000 9.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
52.607 2037.00000 54.8000 -39.84375 -0.25000 2.68700 2.68700 13.40000 1.10400 1.09400 16.40000 1.00000 9.00000 9.00000 9.00000 9.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
52.617 2037.00000 54.8000 -39.84375 -0.25000 2.68700 2.68700 13.40000 1.10400 1.09400 16.40000 1.00000 9.00000 9.00000 9.00000 9.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
52.627 2037.00000 54.8000 -39.84375 -0.25000 2.68700 2.68700 13.40000 1.10400 1.09400 16.40000 1.00000 9.00000 9.00000 9.00000 9.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
52.637 2037.00000 54.8000 -39.84375 -0.25000 2.68700 2.68700 13.40000 1.10400 1.09400 16.40000 1.00000 9.00000 9.00000 9.00000 9.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
52.647 2037.00000 54.8000 -39.84375 -0.25000 2.68700 2.68700 13.40000 1.10400 1.09400 16.40000 1.00000 9.00000 9.00000 9.00000 9.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
52.657 2062.00000 54.4000 -42.18750 -0.12500 2.65200 2.65200 13.30000 1.04600 1.02400 15.70000 1.00000 9.00000 9.00000 9.00000 9.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
52.667 2062.00000 54.4000 -42.18750 -0.12500 2.65200 2.65200 13.30000 1.04600 1.02400 15.70000 1.00000 9.00000 9.00000 9.00000 9.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
52.677 2062.00000 54.4000 -42.18750 -0.12500 2.65200 2.65200 13.30000 1.04600 1.02400 15.70000 1.00000 9.00000 9.00000 9.00000 9.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
52.687 2062.00000 54.4000 -42.18750 -0.12500 2.65200 2.65200 13.30000 1.04600 1.02400 15.70000 1.00000 9.00000 9.00000 9.00000 9.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
52.697 2062.00000 54.4000 -42.18750 -0.12500 2.65200 2.65200 13.30000 1.04600 1.02400 15.70000 1.00000 9.00000 9.00000 9.00000 9.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
52.707 2143.00000 54.4000 -42.96875 -0.12500 2.87900 2.87900 13.20000 1.04600 1.02400 15.40000 1.00000 10.00000 9.00000 9.00000 9.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
52.717 2143.00000 54.4000 -42.96875 -0.12500 2.87900 2.87900 13.20000 1.04600 1.02400 15.40000 1.00000 10.00000 9.00000 9.00000 9.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
52.727 2143.00000 54.4000 -42.96875 -0.12500 2.87900 2.87900 13.20000 1.04600 1.02400 15.40000 1.00000 10.00000 9.00000 9.00000 9.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
52.737 2143.00000 54.4000 -42.96875 -0.12500 2.87900 2.87900 13.20000 1.04600 1.02400 15.40000 1.00000 10.00000 9.00000 9.00000 9.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
52.747 2143.00000 54.4000 -42.96875 -0.12500 2.87900 2.87900 13.20000 1.04600 1.02400 15.40000 1.00000 10.00000 9.00000 9.00000 9.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
52.757 2108.00000 54.8000 -42.18750 -0.12500 2.88500 2.88500 13.10000 1.04600 1.02400 15.80000 1.00000 9.00000 10.00000 9.00000 10.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
52.767 2108.00000 54.8000 -42.18750 -0.12500 2.88500 2.88500 13.10000 1.04600 1.02400 15.80000 1.00000 9.00000 10.00000 9.00000 10.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
52.777 2108.00000 54.8000 -42.18750 -0.12500 2.88500 2.88500 13.10000 1.04600 1.02400 15.80000 1.00000 9.00000 10.00000 9.00000 10.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
52.787 2108.00000 54.8000 -42.18750 -0.12500 2.88500 2.88500 13.10000 1.04600 1.02400 15.80000 1.00000 9.00000 10.00000 9.00000 10.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
52.797 2108.00000 54.8000 -42.18750 -0.12500 2.88500 2.88500 13.10000 1.04600 1.02400 15.80000 1.00000 9.00000 10.00000 9.00000 10.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
52.807 2113.00000 55.1000 -39.84375 -0.12500 2.70500 2.70500 13.20000 1.04600 1.02400 16.50000 1.00000 9.00000 9.00000 10.00000 9.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
52.817 2113.00000 55.1000 -39.84375 -0.12500 2.70500 2.70500 13.20000 1.04600 1.02400 16.50000 1.00000 9.00000 9.00000 10.00000 9.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
52.827 2113.00000 55.1000 -39.84375 -0.12500 2.70500 2.70500 13.20000 1.04600 1.02400 16.50000 1.00000 9.00000 9.00000 10.00000 9.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
52.837 2113.00000 55.1000 -39.84375 -0.12500 2.70500 2.70500 13.20000 1.04600 1.02400 16.50000 1.00000 9.00000 9.00000 10.00000 9.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
52.847 2113.00000 55.1000 -39.84375 -0.12500 2.70500 2.70500 13.20000 1.04600 1.02400 16.50000 1.00000 9.00000 9.00000 10.00000 9.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
52.857 2166.00000 54.7000 -40.62500 -0.12500 2.64600 2.64600 13.40000 1.09800 1.08500 16.30000 1.00000 10.00000 9.00000 10.00000 10.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
52.867 2166.00000 54.7000 -40.62500 -0.12500 2.64600 2.64600 13.40000 1.09800 1.08500 16.30000 1.00000 10.00000 9.00000 10.00000 10.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
52.877 2166.00000 54.7000 -40.62500 -0.12500 2.64600 2.64600 13.40000 1.09800 1.08500 16.30000 1.00000 10.00000 9.00000 10.00000 10.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
52.887 2166.00000 54.7000 -40.62500 -0.12500 2.64600 2.64600 13.40000 1.09800 1.08500 16.30000 1.00000 10.00000 9.00000 10.00000 10.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
52.897 2166.00000 54.7000 -40.62500 -0.12500 2.64600 2.64600 13.40000 1.09800 1.08500 16.30000 1.00000 10.00000 9.00000 10.00000 10.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
52.907 2158.00000 54.7000 -43.75000 0.00000 2.77400 2.77400 13.60000 1.09800 1.08500 15.40000 1.00000 10.00000 9.00000 10.00000 9.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
52.917 2158.00000 54.7000 -43.75000 0.00000 2.77400 2.77400 13.60000 1.09800 1.08500 15.40000 1.00000 10.00000 9.00000 10.00000 9.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
52.927 2158.00000 54.7000 -43.75000 0.00000 2.77400 2.77400 13.60000 1.09800 1.08500 15.40000 1.00000 10.00000 9.00000 10.00000 9.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
52.937 2158.00000 54.7000 -43.75000 0.00000 2.77400 2.77400 13.60000 1.09800 1.08500 15.40000 1.00000 10.00000 9.00000 10.00000 9.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
52.947 2158.00000 54.7000 -43.75000 0.00000 2.77400 2.77400 13.60000 1.09800 1.08500 15.40000 1.00000 10.00000 9.00000 10.00000 9.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
52.957 2159.00000 54.4000 -42.96875 -0.12500 2.91400 2.91400 13.40000 1.09800 1.08500 15.60000 1.00000 9.00000 10.00000 10.00000 9.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
52.967 2159.00000 54.4000 -42.96875 -0.12500 2.91400 2.91400 13.40000 1.09800 1.08500 15.60000 1.00000 9.00000 10.00000 10.00000 9.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
52.977 2159.00000 54.4000 -42.96875 -0.12500 2.91400 2.91400 13.40000 1.09800 1.08500 15.60000 1.00000 9.00000 10.00000 10.00000 9.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
52.987 2159.00000 54.4000 -42.96875 -0.12500 2.91400 2.91400 13.40000 1.09800 1.08500 15.60000 1.00000 9.00000 10.00000 10.00000 9.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
52.997 2159.00000 54.4000 -42.96875 -0.12500 2.91400 2.91400 13.40000 1.09800 1.08500 15.60000 1.00000 9.00000 10.00000 10.00000 9.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
53.007 2161.00000 54.7000 -41.40625 -0.12500 2.97900 2.97900 12.40000 1.09800 1.08500 15.90000 1.00000 10.00000 9.00000 9.00000 9.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
53.017 2161.00000 54.7000 -41.40625 -0.12500 2.97900 2.97900 12.40000 1.09800 1.08500 15.90000 1.00000 10.00000 9.00000 9.00000 9.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
53.027 2161.00000 54.7000 -41.40625 -0.12500 2.97900 2.97900 12.40000 1.09800 1.08500 15.90000 1.00000 10.00000 9.00000 9.00000 9.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
53.037 2161.00000 54.7000 -41.40625 -0.12500 2.97900 2.97900 12.40000 1.09800 1.08500 15.90000 1.00000 10.00000 9.00000 9.00000 9.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
53.047 2161.00000 54.7000 -41.40625 -0.12500 2.97900 2.97900 12.40000 1.09800 1.08500 15.90000 1.00000 10.00000 9.00000 9.00000 9.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
53.057 2222.00000 54.8000 -41.40625 -0.12500 3.00800 3.00800 12.10000 1.09100 1.09100 16.00000 1.00000 10.00000 10.00000 10.00000 10.00000 0.00000 0.00000 12.7000 0.000 0.000 0.000 0.000
53.067 2222.00000 54.8000 -41.40625 -0.12500 3.00800 3.00800 12.10000 1.09100 1.09100 16.00000 1.00000 10.00000 10.00000 10.00000 10.00000 0.00000 0.00000 12.7000 0.000 0.000 0.000 0.000
53.077 2222.00000 54.8000 -41.40625 -0.12500 3.00800 3.00800 12.10000 1.09100 1.09100 16.00000 1.00000 10.00000 10.00000 10.00000 10.00000 0.00000 0.00000 12.7000 0.000 0.000 0.000 0.000
53.087 2222.00000 54.8000 -41.40625 -0.12500 3.00800 3.00800 12.10000 1.09100 1.09100 16.00000 1.00000 10.00000 10.00000 10.00000 10.00000 0.00000 0.00000 12.7000 0.000 0.000 0.000 0.000
53.097 2222.00000 54.8000 -41.40625 -0.12500 3.00800 3.00800 12.10000 1.09100 1.09100 16.00000 1.00000 10.00000 10.00000 10.00000 10.00000 0.00000 0.00000 12.7000 0.000 0.000 0.000 0.000
53.107 2237.00000 55.1000 -41.40625 -0.12500 2.98400 2.98400 12.30000 1.09100 1.09100 15.90000 1.00000 10.00000 10.00000 10.00000 10.00000 0.00000 0.00000 12.9000 0.000 0.000 0.000 0.000
53.117 2237.00000 55.1000 -41.40625 -0.12500 2.98400 2.98400 12.30000 1.09100 1.09100 15.90000 1.00000 10.00000 10.00000 10.00000 10.00000 0.00000 0.00000 12.9000 0.000 0.000 0.000 0.000
53.127 2237.00000 55.1000 -41.40625 -0.12500 2.98400 2.98400 12.30000 1.09100 1.09100 15.90000 1.00000 10.00000 10.00000 10.00000 10.00000 0.00000 0.00000 12.9000 0.000 0.000 0.000 0.000
53.137 2237.00000 55.1000 -41.40625 -0.12500 2.98400 2.98400 12.30000 1.09100 1.09100 15.90000 1.00000 10.00000 10.00000 10.00000 10.00000 0.00000 0.00000 12.9000 0.000 0.000 0.000 0.000
53.147 2237.00000 55.1000 -41.40625 -0.12500 2.98400 2.98400 12.30000 1.09100 1.09100 15.90000 1.00000 10.00000 10.00000 10.00000 10.00000 0.00000 0.00000 12.9000 0.000 0.000 0.000 0.000
53.157 2232.00000 55.1000 -42.18750 -0.12500 3.01400 3.01400 12.70000 1.09100 1.09100 15.80000 1.00000 10.00000 10.00000 10.00000 10.00000 0.00000 0.00000 12.8000 0.000 0.000 0.000 0.000
53.167 2232.00000 55.1000 -42.18750 -0.12500 3.01400 3.01400 12.70000 1.09100 1.09100 15.80000 1.00000 10.00000 10.00000 10.00000 10.00000 0.00000 0.00000 12.8000 0.000 0.000 0.000 0.000
53.177 2232.00000 55.1000 -42.18750 -0.12500 3.01400 3.01400 12.70000 1.09100 1.09100 15.80000 1.00000 10.00000 10.00000 10.00000 10.00000 0.00000 0.00000 12.8000 0.000 0.000 0.000 0.000
53.187 2232.00000 55.1000 -42.18750 -0.12500 3.01400 3.01400 12.70000 1.09100 1.09100 15.80000 1.00000 10.00000 10.00000 10.00000 10.00000 0.00000 0.00000 12.8000 0.000 0.000 0.000 0.000
53.197 2232.00000 55.1000 -42.18750 -0.12500 3.01400 3.01400 12.70000 1.09100 1.09100 15.80000 1.00000 10.00000 10.00000 10.00000 10.00000 0.00000 0.00000 12.8000 0.000 0.000 0.000 0.000
53.207 2285.00000 55.0000 -41.40625 -0.12500 2.99600 2.99600 12.60000 1.09100 1.09100 15.90000 1.00000 10.00000 10.00000 10.00000 10.00000 0.00000 0.00000 12.8000 0.000 0.000 0.000 0.000
53.217 2285.00000 55.0000 -41.40625 -0.12500 2.99600 2.99600 12.60000 1.09100 1.09100 15.90000 1.00000 10.00000 10.00000 10.00000 10.00000 0.00000 0.00000 12.8000 0.000 0.000 0.000 0.000
53.227 2285.00000 55.0000 -41.40625 -0.12500 2.99600 2.99600 12.60000 1.09100 1.09100 15.90000 1.00000 10.00000 10.00000 10.00000 10.00000 0.00000 0.00000 12.8000 0.000 0.000 0.000 0.000
53.237 2285.00000 55.0000 -41.40625 -0.12500 2.99600 2.99600 12.60000 1.09100 1.09100 15.90000 1.00000 10.00000 10.00000 10.00000 10.00000 0.00000 0.00000 12.8000 0.000 0.000 0.000 0.000
53.247 2285.00000 55.0000 -41.40625 -0.12500 2.99600 2.99600 12.60000 1.09100 1.09100 15.90000 1.00000 10.00000 10.00000 10.00000 10.00000 0.00000 0.00000 12.8000 0.000 0.000 0.000 0.000
53.257 2284.00000 55.3000 -41.40625 -0.25000 3.04800 3.04800 13.30000 1.09800 1.08800 16.00000 1.00000 11.00000 10.00000 10.00000 10.00000 0.00000 0.00000 12.8000 0.000 0.000 0.000 0.000
53.267 2284.00000 55.3000 -41.40625 -0.25000 3.04800 3.04800 13.30000 1.09800 1.08800 16.00000 1.00000 11.00000 10.00000 10.00000 10.00000 0.00000 0.00000 12.8000 0.000 0.000 0.000 0.000
53.277 2284.00000 55.3000 -41.40625 -0.25000 3.04800 3.04800 13.30000 1.09800 1.08800 16.00000 1.00000 11.00000 10.00000 10.00000 10.00000 0.00000 0.00000 12.8000 0.000 0.000 0.000 0.000
53.287 2284.00000 55.3000 -41.40625 -0.25000 3.04800 3.04800 13.30000 1.09800 1.08800 16.00000 1.00000 11.00000 10.00000 10.00000 10.00000 0.00000 0.00000 12.8000 0.000 0.000 0.000 0.000
53.297 2284.00000 55.3000 -41.40625 -0.25000 3.04800 3.04800 13.30000 1.09800 1.08800 16.00000 1.00000 11.00000 10.00000 10.00000 10.00000 0.00000 0.00000 12.8000 0.000 0.000 0.000 0.000
53.307 2316.00000 55.1000 -41.40625 -0.12500 3.02500 3.02500 13.00000 1.09800 1.08800 16.00000 1.00000 11.00000 10.00000 10.00000 11.00000 0.00000 0.00000 12.8000 0.000 0.000 0.000 0.000
53.317 2316.00000 55.1000 -41.40625 -0.12500 3.02500 3.02500 13.00000 1.09800 1.08800 16.00000 1.00000 11.00000 10.00000 10.00000 11.00000 0.00000 0.00000 12.8000 0.000 0.000 0.000 0.000
53.327 2316.00000 55.1000 -41.40625 -0.12500 3.02500 3.02500 13.00000 1.09800 1.08800 16.00000 1.00000 11.00000 10.00000 10.00000 11.00000 0.00000 0.00000 12.8000 0.000 0.000 0.000 0.000
53.337 2316.00000 55.1000 -41.40625 -0.12500 3.02500 3.02500 13.00000 1.09800 1.08800 16.00000 1.00000 11.00000 10.00000 10.00000 11.00000 0.00000 0.00000 12.8000 0.000 0.000 0.000 0.000
53.347 2316.00000 55.1000 -41.40625 -0.12500 3.02500 3.02500 13.00000 1.09800 1.08800 16.00000 1.00000 11.00000 10.00000 10.00000 11.00000 0.00000 0.00000 12.8000 0.000 0.000 0.000 0.000
53.357 2297.00000 54.7000 -41.40625 -0.12500 2.96700 2.96700 13.40000 1.09800 1.08800 15.90000 1.00000 10.00000 10.00000 11.00000 10.00000 0.00000 0.00000 12.8000 0.000 0.000 0.000 0.000
53.367 2297.00000 54.7000 -41.40625 -0.12500 2.96700 2.96700 13.40000 1.09800 1.08800 15.90000 1.00000 10.00000 10.00000 11.00000 10.00000 0.00000 0.00000 12.8000 0.000 0.000 0.000 0.000
53.377 2297.00000 54.7000 -41.40625 -0.12500 2.96700 2.96700 13.40000 1.09800 1.08800 15.90000 1.00000 10.00000 10.00000 11.00000 10.00000 0.00000 0.00000 12.8000 0.000 0.000 0.000 0.000
53.387 2297.00000 54.7000 -41.40625 -0.12500 2.96700 2.96700 13.40000 1.09800 1.08800 15.90000 1.00000 10.00000 10.00000 11.00000 10.00000 0.00000 0.00000 12.8000 0.000 0.000 0.000 0.000
53.397 2297.00000 54.7000 -41.40625 -0.12500 2.96700 2.96700 13.40000 1.09800 1.08800 15.90000 1.00000 10.00000 10.00000 11.00000 10.00000 0.00000 0.00000 12.8000 0.000 0.000 0.000 0.000
53.407 2342.00000 55.6000 -40.62500 -0.25000 2.79800 2.79800 13.00000 1.09800 1.08800 16.30000 1.00000 10.00000 11.00000 11.00000 11.00000 0.00000 0.00000 12.8000 0.000 0.000 0.000 0.000
53.417 2342.00000 55.6000 -40.62500 -0.25000 2.79800 2.79800 13.00000 1.09800 1.08800 16.30000 1.00000 10.00000 11.00000 11.00000 11.00000 0.00000 0.00000 12.8000 0.000 0.000 0.000 0.000
53.427 2342.00000 55.6000 -40.62500 -0.25000 2.79800 2.79800 13.00000 1.09800 1.08800 16.30000 1.00000 10.00000 11.00000 11.00000 11.00000 0.00000 0.00000 12.8000 0.000 0.000 0.000 0.000
53.437 2342.00000 55.6000 -40.62500 -0.25000 2.79800 2.79800 13.00000 1.09800 1.08800 16.30000 1.00000 10.00000 11.00000 11.00000 11.00000 0.00000 0.00000 12.8000 0.000 0.000 0.000 0.000
53.447 2342.00000 55.6000 -40.62500 -0.25000 2.79800 2.79800 13.00000 1.09800 1.08800 16.30000 1.00000 10.00000 11.00000 11.00000 11.00000 0.00000 0.00000 12.8000 0.000 0.000 0.000 0.000
53.457 2355.00000 55.4000 -36.71875 -0.37500 2.88500 2.88500 13.30000 1.09800 1.06900 17.40000 1.00000 11.00000 11.00000 10.00000 11.00000 0.00000 0.00000 12.8000 0.000 0.000 0.000 0.000
53.467 2355.00000 55.4000 -36.71875 -0.37500 2.88500 2.88500 13.30000 1.09800 1.06900 17.40000 1.00000 11.00000 11.00000 10.00000 11.00000 0.00000 0.00000 12.8000 0.000 0.000 0.000 0.000
53.477 2355.00000 55.4000 -36.71875 -0.37500 2.88500 2.88500 13.30000 1.09800 1.06900 17.40000 1.00000 11.00000 11.00000 10.00000 11.00000 0.00000 0.00000 12.8000 0.000 0.000 0.000 0.000
53.487 2355.00000 55.4000 -36.71875 -0.37500 2.88500 2.88500 13.30000 1.09800 1.06900 17.40000 1.00000 11.00000 11.00000 10.00000 11.00000 0.00000 0.00000 12.8000 0.000 0.000 0.000 0.000
53.497 2355.00000 55.4000 -36.71875 -0.37500 2.88500 2.88500 13.30000 1.09800 1.06900 17.40000 1.00000 11.00000 11.00000 10.00000 11.00000 0.00000 0.00000 12.8000 0.000 0.000 0.000 0.000
53.507 2406.00000 55.6000 -39.06250 -0.37500 3.07200 3.07200 13.00000 1.09800 1.06900 16.60000 1.00000 11.00000 11.00000 11.00000 11.00000 0.00000 0.00000 12.8000 0.000 0.000 0.000 0.000
53.517 2406.00000 55.6000 -39.06250 -0.37500 3.07200 3.07200 13.00000 1.09800 1.06900 16.60000 1.00000 11.00000 11.00000 11.00000 11.00000 0.00000 0.00000 12.8000 0.000 0.000 0.000 0.000
53.527 2406.00000 55.6000 -39.06250 -0.37500 3.07200 3.07200 13.00000 1.09800 1.06900 16.60000 1.00000 11.00000 11.00000 11.00000 11.00000 0.00000 0.00000 12.8000 0.000 0.000 0.000 0.000
53.537 2406.00000 55.6000 -39.06250 -0.37500 3.07200 3.07200 13.00000 1.09800 1.06900 16.60000 1.00000 11.00000 11.00000 11.00000 11.00000 0.00000 0.00000 12.8000 0.000 0.000 0.000 0.000
53.547 2406.00000 55.6000 -39.06250 -0.37500 3.07200 3.07200 13.00000 1.09800 1.06900 16.60000 1.00000 11.00000 11.00000 11.00000 11.00000 0.00000 0.00000 12.8000 0.000 0.000 0.000 0.000
53.557 2390.00000 55.4000 -40.62500 -0.25000 3.10700 3.10700 13.20000 1.09800 1.06900 16.20000 1.00000 11.00000 11.00000 11.00000 11.00000 0.00000 0.00000 12.7000 0.000 0.000 0.000 0.000
53.567 2390.00000 55.4000 -40.62500 -0.25000 3.10700 3.10700 13.20000 1.09800 1.06900 16.20000 1.00000 11.00000 11.00000 11.00000 11.00000 0.00000 0.00000 12.7000 0.000 0.000 0.000 0.000
53.577 2390.00000 55.4000 -40.62500 -0.25000 3.10700 3.10700 13.20000 1.09800 1.06900 16.20000 1.00000 11.00000 11.00000 11.00000 11.00000 0.00000 0.00000 12.7000 0.000 0.000 0.000 0.000
53.587 2390.00000 55.4000 -40.62500 -0.25000 3.10700 3.10700 13.20000 1.09800 1.06900 16.20000 1.00000 11.00000 11.00000 11.00000 11.00000 0.00000 0.00000 12.7000 0.000 0.000 0.000 0.000
53.597 2390.00000 55.4000 -40.62500 -0.25000 3.10700 3.10700 13.20000 1.09800 1.06900 16.20000 1.00000 11.00000 11.00000 11.00000 11.00000 0.00000 0.00000 12.7000 0.000 0.000 0.000 0.000
53.607 2453.00000 56.0000 -41.40625 -0.25000 2.93200 2.93200 13.20000 1.09800 1.06900 16.00000 1.00000 11.00000 11.00000 11.00000 12.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
53.617 2453.00000 56.0000 -41.40625 -0.25000 2.93200 2.93200 13.20000 1.09800 1.06900 16.00000 1.00000 11.00000 11.00000 11.00000 12.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
53.627 2453.00000 56.0000 -41.40625 -0.25000 2.93200 2.93200 13.20000 1.09800 1.06900 16.00000 1.00000 11.00000 11.00000 11.00000 12.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
53.637 2453.00000 56.0000 -41.40625 -0.25000 2.93200 2.93200 13.20000 1.09800 1.06900 16.00000 1.00000 11.00000 11.00000 11.00000 12.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
53.647 2453.00000 56.0000 -41.40625 -0.25000 2.93200 2.93200 13.20000 1.09800 1.06900 16.00000 1.00000 11.00000 11.00000 11.00000 12.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
53.657 2423.00000 56.5000 -36.71875 -0.37500 2.93800 2.93800 13.40000 1.10100 1.09100 17.40000 1.00000 11.00000 11.00000 12.00000 11.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
53.667 2423.00000 56.5000 -36.71875 -0.37500 2.93800 2.93800 13.40000 1.10100 1.09100 17.40000 1.00000 11.00000 11.00000 12.00000 11.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
53.677 2423.00000 56.5000 -36.71875 -0.37500 2.93800 2.93800 13.40000 1.10100 1.09100 17.40000 1.00000 11.00000 11.00000 12.00000 11.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
53.687 2423.00000 56.5000 -36.71875 -0.37500 2.93800 2.93800 13.40000 1.10100 1.09100 17.40000 1.00000 11.00000 11.00000 12.00000 11.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
53.697 2423.00000 56.5000 -36.71875 -0.37500 2.93800 2.93800 13.40000 1.10100 1.09100 17.40000 1.00000 11.00000 11.00000 12.00000 11.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
53.707 2439.00000 56.5000 -39.84375 -0.25000 3.13600 3.13600 13.50000 1.10100 1.09100 16.40000 1.00000 12.00000 12.00000 12.00000 11.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
53.717 2439.00000 56.5000 -39.84375 -0.25000 3.13600 3.13600 13.50000 1.10100 1.09100 16.40000 1.00000 12.00000 12.00000 12.00000 11.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
53.727 2439.00000 56.5000 -39.84375 -0.25000 3.13600 3.13600 13.50000 1.10100 1.09100 16.40000 1.00000 12.00000 12.00000 12.00000 11.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
53.737 2439.00000 56.5000 -39.84375 -0.25000 3.13600 3.13600 13.50000 1.10100 1.09100 16.40000 1.00000 12.00000 12.00000 12.00000 11.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
53.747 2439.00000 56.5000 -39.84375 -0.25000 3.13600 3.13600 13.50000 1.10100 1.09100 16.40000 1.00000 12.00000 12.00000 12.00000 11.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
53.757 2528.00000 56.8000 -39.06250 -0.37500 2.87400 2.87400 13.20000 1.10100 1.09100 16.50000 1.00000 12.00000 12.00000 12.00000 12.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
53.767 2528.00000 56.8000 -39.06250 -0.37500 2.87400 2.87400 13.20000 1.10100 1.09100 16.50000 1.00000 12.00000 12.00000 12.00000 12.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
53.777 2528.00000 56.8000 -39.06250 -0.37500 2.87400 2.87400 13.20000 1.10100 1.09100 16.50000 1.00000 12.00000 12.00000 12.00000 12.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
53.787 2528.00000 56.8000 -39.06250 -0.37500 2.87400 2.87400 13.20000 1.10100 1.09100 16.50000 1.00000 12.00000 12.00000 12.00000 12.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
53.797 2528.00000 56.8000 -39.06250 -0.37500 2.87400 2.87400 13.20000 1.10100 1.09100 16.50000 1.00000 12.00000 12.00000 12.00000 12.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
53.807 2488.00000 56.2000 -39.06250 -0.37500 3.10700 3.10700 12.60000 1.10100 1.09100 16.50000 1.00000 12.00000 12.00000 11.00000 12.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
53.817 2488.00000 56.2000 -39.06250 -0.37500 3.10700 3.10700 12.60000 1.10100 1.09100 16.50000 1.00000 12.00000 12.00000 11.00000 12.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
53.827 2488.00000 56.2000 -39.06250 -0.37500 3.10700 3.10700 12.60000 1.10100 1.09100 16.50000 1.00000 12.00000 12.00000 11.00000 12.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
53.837 2488.00000 56.2000 -39.06250 -0.37500 3.10700 3.10700 12.60000 1.10100 1.09100 16.50000 1.00000 12.00000 12.00000 11.00000 12.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
53.847 2488.00000 56.2000 -39.06250 -0.37500 3.10700 3.10700 12.60000 1.10100 1.09100 16.50000 1.00000 12.00000 12.00000 11.00000 12.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
53.857 2492.00000 55.9000 -39.84375 -0.25000 2.99000 2.99000 13.10000 1.11700 1.10400 16.40000 1.00000 12.00000 12.00000 11.00000 12.00000 0.00000 0.00000 12.2000 0.000 0.000 0.000 0.000
53.867 2492.00000 55.9000 -39.84375 -0.25000 2.99000 2.99000 13.10000 1.11700 1.10400 16.40000 1.00000 12.00000 12.00000 11.00000 12.00000 0.00000 0.00000 12.2000 0.000 0.000 0.000 0.000
53.877 2492.00000 55.9000 -39.84375 -0.25000 2.99000 2.99000 13.10000 1.11700 1.10400 16.40000 1.00000 12.00000 12.00000 11.00000 12.00000 0.00000 0.00000 12.2000 0.000 0.000 0.000 0.000
53.887 2492.00000 55.9000 -39.84375 -0.25000 2.99000 2.99000 13.10000 1.11700 1.10400 16.40000 1.00000 12.00000 12.00000 11.00000 12.00000 0.00000 0.00000 12.2000 0.000 0.000 0.000 0.000
53.897 2492.00000 55.9000 -39.84375 -0.25000 2.99000 2.99000 13.10000 1.11700 1.10400 16.40000 1.00000 12.00000 12.00000 11.00000 12.00000 0.00000 0.00000 12.2000 0.000 0.000 0.000 0.000
53.907 2500.00000 56.2000 -36.71875 -0.37500 3.13000 3.13000 12.90000 1.11700 1.10400 17.30000 1.00000 12.00000 12.00000 11.00000 12.00000 0.00000 0.00000 12.2000 0.000 0.000 0.000 0.000
53.917 2500.00000 56.2000 -36.71875 -0.37500 3.13000 3.13000 12.90000 1.11700 1.10400 17.30000 1.00000 12.00000 12.00000 11.00000 12.00000 0.00000 0.00000 12.2000 0.000 0.000 0.000 0.000
53.927 2500.00000 56.2000 -36.71875 -0.37500 3.13000 3.13000 12.90000 1.11700 1.10400 17.30000 1.00000 12.00000 12.00000 11.00000 12.00000 0.00000 0.00000 12.2000 0.000 0.000 0.000 0.000
53.937 2500.00000 56.2000 -36.71875 -0.37500 3.13000 3.13000 12.90000 1.11700 1.10400 17.30000 1.00000 12.00000 12.00000 11.00000 12.00000 0.00000 0.00000 12.2000 0.000 0.000 0.000 0.000
53.947 2500.00000 56.2000 -36.71875 -0.37500 3.13000 3.13000 12.90000 1.11700 1.10400 17.30000 1.00000 12.00000 12.00000 11.00000 12.00000 0.00000 0.00000 12.2000 0.000 0.000 0.000 0.000
53.957 2544.00000 56.8000 -39.06250 -0.37500 3.10700 3.10700 13.30000 1.11700 1.10400 16.50000 1.00000 12.00000 12.00000 12.00000 12.00000 0.00000 0.00000 12.2000 0.000 0.000 0.000 0.000
53.967 2544.00000 56.8000 -39.06250 -0.37500 3.10700 3.10700 13.30000 1.11700 1.10400 16.50000 1.00000 12.00000 12.00000 12.00000 12.00000 0.00000 0.00000 12.2000 0.000 0.000 0.000 0.000
53.977 2544.00000 56.8000 -39.06250 -0.37500 3.10700 3.10700 13.30000 1.11700 1.10400 16.50000 1.00000 12.00000 12.00000 12.00000 12.00000 0.00000 0.00000 12.2000 0.000 0.000 0.000 0.000
53.987 2544.00000 56.8000 -39.06250 -0.37500 3.10700 3.10700 13.30000 1.11700 1.10400 16.50000 1.00000 12.00000 12.00000 12.00000 12.00000 0.00000 0.00000 12.2000 0.000 0.000 0.000 0.000
53.997 2544.00000 56.8000 -39.06250 -0.37500 3.10700 3.10700 13.30000 1.11700 1.10400 16.50000 1.00000 12.00000 12.00000 12.00000 12.00000 0.00000 0.00000 12.2000 0.000 0.000 0.000 0.000
54.007 2552.00000 57.1000 -38.28125 -0.37500 3.17100 3.17100 12.40000 1.11700 1.10400 16.90000 1.00000 12.00000 12.00000 12.00000 12.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
54.017 2552.00000 57.1000 -38.28125 -0.37500 3.17100 3.17100 12.40000 1.11700 1.10400 16.90000 1.00000 12.00000 12.00000 12.00000 12.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
54.027 2552.00000 57.1000 -38.28125 -0.37500 3.17100 3.17100 12.40000 1.11700 1.10400 16.90000 1.00000 12.00000 12.00000 12.00000 12.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
54.037 2552.00000 57.1000 -38.28125 -0.37500 3.17100 3.17100 12.40000 1.11700 1.10400 16.90000 1.00000 12.00000 12.00000 12.00000 12.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
54.047 2552.00000 57.1000 -38.28125 -0.37500 3.17100 3.17100 12.40000 1.11700 1.10400 16.90000 1.00000 12.00000 12.00000 12.00000 12.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
54.057 2610.00000 56.7000 -38.28125 -0.37500 3.03100 3.03100 13.40000 1.10700 1.09800 16.90000 1.00000 12.00000 13.00000 13.00000 13.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
54.067 2610.00000 56.7000 -38.28125 -0.37500 3.03100 3.03100 13.40000 1.10700 1.09800 16.90000 1.00000 12.00000 13.00000 13.00000 13.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
54.077 2610.00000 56.7000 -38.28125 -0.37500 3.03100 3.03100 13.40000 1.10700 1.09800 16.90000 1.00000 12.00000 13.00000 13.00000 13.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
54.087 2610.00000 56.7000 -38.28125 -0.37500 3.03100 3.03100 13.40000 1.10700 1.09800 16.90000 1.00000 12.00000 13.00000 13.00000 13.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
54.097 2610.00000 56.7000 -38.28125 -0.37500 3.03100 3.03100 13.40000 1.10700 1.09800 16.90000 1.00000 12.00000 13.00000 13.00000 13.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
54.107 2614.00000 56.5000 -39.06250 -0.50000 3.24700 3.24700 13.10000 1.10700 1.09800 16.70000 1.00000 15.00000 16.00000 16.00000 16.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
54.117 2614.00000 56.5000 -39.06250 -0.50000 3.24700 3.24700 13.10000 1.10700 1.09800 16.70000 1.00000 15.00000 16.00000 16.00000 16.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
54.127 2614.00000 56.5000 -39.06250 -0.50000 3.24700 3.24700 13.10000 1.10700 1.09800 16.70000 1.00000 15.00000 16.00000 16.00000 16.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
54.137 2614.00000 56.5000 -39.06250 -0.50000 3.24700 3.24700 13.10000 1.10700 1.09800 16.70000 1.00000 15.00000 16.00000 16.00000 16.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
54.147 2614.00000 56.5000 -39.06250 -0.50000 3.24700 3.24700 13.10000 1.10700 1.09800 16.70000 1.00000 15.00000 16.00000 16.00000 16.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
54.157 2609.00000 56.5000 -35.15625 -0.62500 3.17700 3.17700 13.20000 1.10700 1.09800 17.90000 1.00000 16.00000 15.00000 16.00000 15.00000 0.00000 0.00000 12.3000 0.000 0.000 0.000 0.000
54.167 2609.00000 56.5000 -35.15625 -0.62500 3.17700 3.17700 13.20000 1.10700 1.09800 17.90000 1.00000 16.00000 15.00000 16.00000 15.00000 0.00000 0.00000 12.3000 0.000 0.000 0.000 0.000
54.177 2609.00000 56.5000 -35.15625 -0.62500 3.17700 3.17700 13.20000 1.10700 1.09800 17.90000 1.00000 16.00000 15.00000 16.00000 15.00000 0.00000 0.00000 12.3000 0.000 0.000 0.000 0.000
54.187 2609.00000 56.5000 -35.15625 -0.62500 3.17700 3.17700 13.20000 1.10700 1.09800 17.90000 1.00000 16.00000 15.00000 16.00000 15.00000 0.00000 0.00000 12.3000 0.000 0.000 0.000 0.000
54.197 2609.00000 56.5000 -35.15625 -0.62500 3.17700 3.17700 13.20000 1.10700 1.09800 17.90000 1.00000 16.00000 15.00000 16.00000 15.00000 0.00000 0.00000 12.3000 0.000 0.000 0.000 0.000
54.207 2634.00000 55.4000 -37.50000 -0.50000 3.05400 3.05400 13.70000 1.10700 1.09800 17.10000 1.00000 16.00000 16.00000 15.00000 16.00000 0.00000 0.00000 12.3000 0.000 0.000 0.000 0.000
54.217 2634.00000 55.4000 -37.50000 -0.50000 3.05400 3.05400 13.70000 1.10700 1.09800 17.10000 1.00000 16.00000 16.00000 15.00000 16.00000 0.00000 0.00000 12.3000 0.000 0.000 0.000 0.000
54.227 2634.00000 55.4000 -37.50000 -0.50000 3.05400 3.05400 13.70000 1.10700 1.09800 17.10000 1.00000 16.00000 16.00000 15.00000 16.00000 0.00000 0.00000 12.3000 0.000 0.000 0.000 0.000
54.237 2634.00000 55.4000 -37.50000 -0.50000 3.05400 3.05400 13.70000 1.10700 1.09800 17.10000 1.00000 16.00000 16.00000 15.00000 16.00000 0.00000 0.00000 12.3000 0.000 0.000 0.000 0.000
54.247 2634.00000 55.4000 -37.50000 -0.50000 3.05400 3.05400 13.70000 1.10700 1.09800 17.10000 1.00000 16.00000 16.00000 15.00000 16.00000 0.00000 0.00000 12.3000 0.000 0.000 0.000 0.000
54.257 2657.00000 56.0000 -38.28125 -0.50000 3.26400 3.26400 13.40000 1.14200 1.11300 16.80000 1.00000 16.00000 16.00000 16.00000 16.00000 0.00000 0.00000 12.3000 0.000 0.000 0.000 0.000
54.267 2657.00000 56.0000 -38.28125 -0.50000 3.26400 3.26400 13.40000 1.14200 1.11300 16.80000 1.00000 16.00000 16.00000 16.00000 16.00000 0.00000 0.00000 12.3000 0.000 0.000 0.000 0.000
54.277 2657.00000 56.0000 -38.28125 -0.50000 3.26400 3.26400 13.40000 1.14200 1.11300 16.80000 1.00000 16.00000 16.00000 16.00000 16.00000 0.00000 0.00000 12.3000 0.000 0.000 0.000 0.000
54.287 2657.00000 56.0000 -38.28125 -0.50000 3.26400 3.26400 13.40000 1.14200 1.11300 16.80000 1.00000 16.00000 16.00000 16.00000 16.00000 0.00000 0.00000 12.3000 0.000 0.000 0.000 0.000
54.297 2657.00000 56.0000 -38.28125 -0.50000 3.26400 3.26400 13.40000 1.14200 1.11300 16.80000 1.00000 16.00000 16.00000 16.00000 16.00000 0.00000 0.00000 12.3000 0.000 0.000 0.000 0.000
54.307 2688.00000 56.8000 -36.71875 -0.50000 3.33400 3.33400 12.70000 1.14200 1.11300 17.50000 1.00000 16.00000 17.00000 16.00000 16.00000 0.00000 0.00000 10.5000 0.000 0.000 0.000 0.000
54.317 2688.00000 56.8000 -36.71875 -0.50000 3.33400 3.33400 12.70000 1.14200 1.11300 17.50000 1.00000 16.00000 17.00000 16.00000 16.00000 0.00000 0.00000 10.5000 0.000 0.000 0.000 0.000
54.327 2688.00000 56.8000 -36.71875 -0.50000 3.33400 3.33400 12.70000 1.14200 1.11300 17.50000 1.00000 16.00000 17.00000 16.00000 16.00000 0.00000 0.00000 10.5000 0.000 0.000 0.000 0.000
54.337 2688.00000 56.8000 -36.71875 -0.50000 3.33400 3.33400 12.70000 1.14200 1.11300 17.50000 1.00000 16.00000 17.00000 16.00000 16.00000 0.00000 0.00000 10.5000 0.000 0.000 0.000 0.000
54.347 2688.00000 56.8000 -36.71875 -0.50000 3.33400 3.33400 12.70000 1.14200 1.11300 17.50000 1.00000 16.00000 17.00000 16.00000 16.00000 0.00000 0.00000 10.5000 0.000 0.000 0.000 0.000
54.357 2678.00000 55.9000 -33.59375 -0.62500 3.15300 3.15300 13.00000 1.14200 1.11300 18.50000 1.00000 16.00000 16.00000 16.00000 16.00000 0.00000 0.00000 10.4000 0.000 0.000 0.000 0.000
54.367 2678.00000 55.9000 -33.59375 -0.62500 3.15300 3.15300 13.00000 1.14200 1.11300 18.50000 1.00000 16.00000 16.00000 16.00000 16.00000 0.00000 0.00000 10.4000 0.000 0.000 0.000 0.000
54.377 2678.00000 55.9000 -33.59375 -0.62500 3.15300 3.15300 13.00000 1.14200 1.11300 18.50000 1.00000 16.00000 16.00000 16.00000 16.00000 0.00000 0.00000 10.4000 0.000 0.000 0.000 0.000
54.387 2678.00000 55.9000 -33.59375 -0.62500 3.15300 3.15300 13.00000 1.14200 1.11300 18.50000 1.00000 16.00000 16.00000 16.00000 16.00000 0.00000 0.00000 10.4000 0.000 0.000 0.000 0.000
54.397 2678.00000 55.9000 -33.59375 -0.62500 3.15300 3.15300 13.00000 1.14200 1.11300 18.50000 1.00000 16.00000 16.00000 16.00000 16.00000 0.00000 0.00000 10.4000 0.000 0.000 0.000 0.000
54.407 2678.00000 55.9000 -33.59375 -0.62500 3.15300 3.15300 13.00000 1.14200 1.11300 18.50000 1.00000 16.00000 16.00000 16.00000 16.00000 0.00000 0.00000 10.4000 0.000 0.000 0.000 0.000
54.417 2685.00000 56.2000 -36.71875 -0.50000 3.16500 3.16500 13.30000 1.14200 1.11300 17.50000 1.00000 16.00000 16.00000 16.00000 16.00000 0.00000 0.00000 10.3000 0.000 0.000 0.000 0.000
54.427 2685.00000 56.2000 -36.71875 -0.50000 3.16500 3.16500 13.30000 1.14200 1.11300 17.50000 1.00000 16.00000 16.00000 16.00000 16.00000 0.00000 0.00000 10.3000 0.000 0.000 0.000 0.000
54.437 2685.00000 56.2000 -36.71875 -0.50000 3.16500 3.16500 13.30000 1.14200 1.11300 17.50000 1.00000 16.00000 16.00000 16.00000 16.00000 0.00000 0.00000 10.3000 0.000 0.000 0.000 0.000
54.447 2685.00000 56.2000 -36.71875 -0.50000 3.16500 3.16500 13.30000 1.14200 1.11300 17.50000 1.00000 16.00000 16.00000 16.00000 16.00000 0.00000 0.00000 10.3000 0.000 0.000 0.000 0.000
54.457 2685.00000 56.2000 -36.71875 -0.50000 3.16500 3.16500 13.30000 1.14200 1.11300 17.50000 1.00000 16.00000 16.00000 16.00000 16.00000 0.00000 0.00000 10.3000 0.000 0.000 0.000 0.000
54.467 2721.00000 56.8000 -37.50000 -0.50000 3.31700 3.31700 13.30000 1.14900 1.14500 17.20000 1.00000 17.00000 16.00000 17.00000 17.00000 0.00000 0.00000 10.3000 0.000 0.000 0.000 0.000
54.477 2721.00000 56.8000 -37.50000 -0.50000 3.31700 3.31700 13.30000 1.14900 1.14500 17.20000 1.00000 17.00000 16.00000 17.00000 17.00000 0.00000 0.00000 10.3000 0.000 0.000 0.000 0.000
54.487 2721.00000 56.8000 -37.50000 -0.50000 3.31700 3.31700 13.30000 1.14900 1.14500 17.20000 1.00000 17.00000 16.00000 17.00000 17.00000 0.00000 0.00000 10.3000 0.000 0.000 0.000 0.000
54.497 2721.00000 56.8000 -37.50000 -0.50000 3.31700 3.31700 13.30000 1.14900 1.14500 17.20000 1.00000 17.00000 16.00000 17.00000 17.00000 0.00000 0.00000 10.3000 0.000 0.000 0.000 0.000
54.507 2721.00000 56.8000 -37.50000 -0.50000 3.31700 3.31700 13.30000 1.14900 1.14500 17.20000 1.00000 17.00000 16.00000 17.00000 17.00000 0.00000 0.00000 10.3000 0.000 0.000 0.000 0.000
54.517 2721.00000 56.8000 -37.50000 -0.50000 3.31700 3.31700 13.30000 1.14900 1.14500 17.20000 1.00000 17.00000 16.00000 17.00000 17.00000 0.00000 0.00000 10.3000 0.000 0.000 0.000 0.000
54.527 2752.00000 57.1000 -36.71875 -0.50000 3.38100 3.38100 13.40000 1.14900 1.14500 17.40000 1.00000 17.00000 17.00000 17.00000 17.00000 0.00000 0.00000 10.3000 0.000 0.000 0.000 0.000
54.537 2752.00000 57.1000 -36.71875 -0.50000 3.38100 3.38100 13.40000 1.14900 1.14500 17.40000 1.00000 17.00000 17.00000 17.00000 17.00000 0.00000 0.00000 10.3000 0.000 0.000 0.000 0.000
54.547 2752.00000 57.1000 -36.71875 -0.50000 3.38100 3.38100 13.40000 1.14900 1.14500 17.40000 1.00000 17.00000 17.00000 17.00000 17.00000 0.00000 0.00000 10.3000 0.000 0.000 0.000 0.000
54.557 2752.00000 57.1000 -36.71875 -0.50000 3.38100 3.38100 13.40000 1.14900 1.14500 17.40000 1.00000 17.00000 17.00000 17.00000 17.00000 0.00000 0.00000 10.3000 0.000 0.000 0.000 0.000
54.567 2752.00000 57.1000 -36.71875 -0.50000 3.38100 3.38100 13.40000 1.14900 1.14500 17.40000 1.00000 17.00000 17.00000 17.00000 17.00000 0.00000 0.00000 10.3000 0.000 0.000 0.000 0.000
54.577 2752.00000 57.1000 -36.71875 -0.50000 3.38100 3.38100 13.40000 1.14900 1.14500 17.40000 1.00000 17.00000 17.00000 17.00000 17.00000 0.00000 0.00000 10.3000 0.000 0.000 0.000 0.000
54.587 2828.00000 56.8000 -37.50000 -0.50000 3.40400 3.40400 13.00000 1.14900 1.14500 17.20000 1.00000 17.00000 17.00000 17.00000 18.00000 0.00000 0.00000 10.3000 0.000 0.000 0.000 0.000
54.597 2828.00000 56.8000 -37.50000 -0.50000 3.40400 3.40400 13.00000 1.14900 1.14500 17.20000 1.00000 17.00000 17.00000 17.00000 18.00000 0.00000 0.00000 10.3000 0.000 0.000 0.000 0.000
54.607 2828.00000 56.8000 -37.50000 -0.50000 3.40400 3.40400 13.00000 1.14900 1.14500 17.20000 1.00000 17.00000 17.00000 17.00000 18.00000 0.00000 0.00000 10.3000 0.000 0.000 0.000 0.000
54.617 2828.00000 56.8000 -37.50000 -0.50000 3.40400 3.40400 13.00000 1.14900 1.14500 17.20000 1.00000 17.00000 17.00000 17.00000 18.00000 0.00000 0.00000 10.3000 0.000 0.000 0.000 0.000
54.627 2828.00000 56.8000 -37.50000 -0.50000 3.40400 3.40400 13.00000 1.14900 1.14500 17.20000 1.00000 17.00000 17.00000 17.00000 18.00000 0.00000 0.00000 10.3000 0.000 0.000 0.000 0.000
54.637 2828.00000 56.8000 -37.50000 -0.50000 3.40400 3.40400 13.00000 1.14900 1.14500 17.20000 1.00000 17.00000 17.00000 17.00000 18.00000 0.00000 0.00000 10.3000 0.000 0.000 0.000 0.000
54.647 2795.00000 56.7000 -36.71875 -0.50000 3.48000 3.48000 13.60000 1.14900 1.14500 17.50000 1.00000 17.00000 17.00000 17.00000 17.00000 0.00000 0.00000 10.3000 0.000 0.000 0.000 0.000
54.657 2795.00000 56.7000 -36.71875 -0.50000 3.48000 3.48000 13.60000 1.14900 1.14500 17.50000 1.00000 17.00000 17.00000 17.00000 17.00000 0.00000 0.00000 10.3000 0.000 0.000 0.000 0.000
54.667 2795.00000 56.7000 -36.71875 -0.50000 3.48000 3.48000 13.60000 1.14900 1.14500 17.50000 1.00000 17.00000 17.00000 17.00000 17.00000 0.00000 0.00000 10.3000 0.000 0.000 0.000 0.000
54.677 2795.00000 56.7000 -36.71875 -0.50000 3.48000 3.48000 13.60000 1.14900 1.14500 17.50000 1.00000 17.00000 17.00000 17.00000 17.00000 0.00000 0.00000 10.3000 0.000 0.000 0.000 0.000
54.687 2795.00000 56.7000 -36.71875 -0.50000 3.48000 3.48000 13.60000 1.14900 1.14500 17.50000 1.00000 17.00000 17.00000 17.00000 17.00000 0.00000 0.00000 10.3000 0.000 0.000 0.000 0.000
54.697 2854.00000 56.7000 -35.93750 -0.62500 3.42200 3.42200 13.60000 1.13600 1.12900 17.50000 1.00000 17.00000 17.00000 17.00000 17.00000 0.00000 0.00000 10.2000 0.000 0.000 0.000 0.000
54.707 2854.00000 56.7000 -35.93750 -0.62500 3.42200 3.42200 13.60000 1.13600 1.12900 17.50000 1.00000 17.00000 17.00000 17.00000 17.00000 0.00000 0.00000 10.2000 0.000 0.000 0.000 0.000
54.717 2854.00000 56.7000 -35.93750 -0.62500 3.42200 3.42200 13.60000 1.13600 1.12900 17.50000 1.00000 17.00000 17.00000 17.00000 17.00000 0.00000 0.00000 10.2000 0.000 0.000 0.000 0.000
54.727 2854.00000 56.7000 -35.93750 -0.62500 3.42200 3.42200 13.60000 1.13600 1.12900 17.50000 1.00000 17.00000 17.00000 17.00000 17.00000 0.00000 0.00000 10.2000 0.000 0.000 0.000 0.000
54.737 2854.00000 56.7000 -35.93750 -0.62500 3.42200 3.42200 13.60000 1.13600 1.12900 17.50000 1.00000 17.00000 17.00000 17.00000 17.00000 0.00000 0.00000 10.2000 0.000 0.000 0.000 0.000
54.747 2862.00000 57.3000 -36.71875 -0.62500 3.42700 3.42700 13.50000 1.13600 1.12900 17.30000 1.00000 17.00000 17.00000 18.00000 17.00000 0.00000 0.00000 10.3000 0.000 0.000 0.000 0.000
54.757 2862.00000 57.3000 -36.71875 -0.62500 3.42700 3.42700 13.50000 1.13600 1.12900 17.30000 1.00000 17.00000 17.00000 18.00000 17.00000 0.00000 0.00000 10.3000 0.000 0.000 0.000 0.000
54.767 2862.00000 57.3000 -36.71875 -0.62500 3.42700 3.42700 13.50000 1.13600 1.12900 17.30000 1.00000 17.00000 17.00000 18.00000 17.00000 0.00000 0.00000 10.3000 0.000 0.000 0.000 0.000
54.777 2862.00000 57.3000 -36.71875 -0.62500 3.42700 3.42700 13.50000 1.13600 1.12900 17.30000 1.00000 17.00000 17.00000 18.00000 17.00000 0.00000 0.00000 10.3000 0.000 0.000 0.000 0.000
54.787 2862.00000 57.3000 -36.71875 -0.62500 3.42700 3.42700 13.50000 1.13600 1.12900 17.30000 1.00000 17.00000 17.00000 18.00000 17.00000 0.00000 0.00000 10.3000 0.000 0.000 0.000 0.000
54.797 2865.00000 57.3000 -35.93750 -0.62500 3.48000 3.48000 13.70000 1.13600 1.12900 17.60000 1.00000 18.00000 18.00000 18.00000 17.00000 0.00000 0.00000 10.5000 0.000 0.000 0.000 0.000
54.807 2865.00000 57.3000 -35.93750 -0.62500 3.48000 3.48000 13.70000 1.13600 1.12900 17.60000 1.00000 18.00000 18.00000 18.00000 17.00000 0.00000 0.00000 10.5000 0.000 0.000 0.000 0.000
54.817 2865.00000 57.3000 -35.93750 -0.62500 3.48000 3.48000 13.70000 1.13600 1.12900 17.60000 1.00000 18.00000 18.00000 18.00000 17.00000 0.00000 0.00000 10.5000 0.000 0.000 0.000 0.000
54.827 2865.00000 57.3000 -35.93750 -0.62500 3.48000 3.48000 13.70000 1.13600 1.12900 17.60000 1.00000 18.00000 18.00000 18.00000 17.00000 0.00000 0.00000 10.5000 0.000 0.000 0.000 0.000
54.837 2865.00000 57.3000 -35.93750 -0.62500 3.48000 3.48000 13.70000 1.13600 1.12900 17.60000 1.00000 18.00000 18.00000 18.00000 17.00000 0.00000 0.00000 10.5000 0.000 0.000 0.000 0.000
54.847 2867.00000 57.3000 -35.15625 -0.62500 3.45100 3.45100 13.10000 1.13600 1.12900 17.80000 1.00000 18.00000 17.00000 17.00000 18.00000 0.00000 0.00000 10.5000 0.000 0.000 0.000 0.000
54.857 2867.00000 57.3000 -35.15625 -0.62500 3.45100 3.45100 13.10000 1.13600 1.12900 17.80000 1.00000 18.00000 17.00000 17.00000 18.00000 0.00000 0.00000 10.5000 0.000 0.000 0.000 0.000
54.867 2867.00000 57.3000 -35.15625 -0.62500 3.45100 3.45100 13.10000 1.13600 1.12900 17.80000 1.00000 18.00000 17.00000 17.00000 18.00000 0.00000 0.00000 10.5000 0.000 0.000 0.000 0.000
54.877 2867.00000 57.3000 -35.15625 -0.62500 3.45100 3.45100 13.10000 1.13600 1.12900 17.80000 1.00000 18.00000 17.00000 17.00000 18.00000 0.00000 0.00000 10.5000 0.000 0.000 0.000 0.000
54.887 2867.00000 57.3000 -35.15625 -0.62500 3.45100 3.45100 13.10000 1.13600 1.12900 17.80000 1.00000 18.00000 17.00000 17.00000 18.00000 0.00000 0.00000 10.5000 0.000 0.000 0.000 0.000
54.897 2892.00000 57.1000 -34.37500 -0.75000 3.36300 3.36300 13.40000 1.14500 1.12900 18.20000 1.00000 17.00000 17.00000 17.00000 17.00000 0.00000 0.00000 10.5000 0.000 0.000 0.000 0.000
54.907 2892.00000 57.1000 -34.37500 -0.75000 3.36300 3.36300 13.40000 1.14500 1.12900 18.20000 1.00000 17.00000 17.00000 17.00000 17.00000 0.00000 0.00000 10.5000 0.000 0.000 0.000 0.000
54.917 2892.00000 57.1000 -34.37500 -0.75000 3.36300 3.36300 13.40000 1.14500 1.12900 18.20000 1.00000 17.00000 17.00000 17.00000 17.00000 0.00000 0.00000 10.5000 0.000 0.000 0.000 0.000
54.927 2892.00000 57.1000 -34.37500 -0.75000 3.36300 3.36300 13.40000 1.14500 1.12900 18.20000 1.00000 17.00000 17.00000 17.00000 17.00000 0.00000 0.00000 10.5000 0.000 0.000 0.000 0.000
54.937 2892.00000 57.1000 -34.37500 -0.75000 3.36300 3.36300 13.40000 1.14500 1.12900 18.20000 1.00000 17.00000 17.00000 17.00000 17.00000 0.00000 0.00000 10.5000 0.000 0.000 0.000 0.000
54.947 2995.00000 57.4000 -31.25000 -0.75000 3.45100 3.45100 13.50000 1.14500 1.12900 19.20000 1.00000 18.00000 18.00000 18.00000 18.00000 0.00000 0.00000 10.6000 0.000 0.000 0.000 0.000
54.957 2995.00000 57.4000 -31.25000 -0.75000 3.45100 3.45100 13.50000 1.14500 1.12900 19.20000 1.00000 18.00000 18.00000 18.00000 18.00000 0.00000 0.00000 10.6000 0.000 0.000 0.000 0.000
54.967 2995.00000 57.4000 -31.25000 -0.75000 3.45100 3.45100 13.50000 1.14500 1.12900 19.20000 1.00000 18.00000 18.00000 18.00000 18.00000 0.00000 0.00000 10.6000 0.000 0.000 0.000 0.000
54.977 2995.00000 57.4000 -31.25000 -0.75000 3.45100 3.45100 13.50000 1.14500 1.12900 19.20000 1.00000 18.00000 18.00000 18.00000 18.00000 0.00000 0.00000 10.6000 0.000 0.000 0.000 0.000
54.987 2995.00000 57.4000 -31.25000 -0.75000 3.45100 3.45100 13.50000 1.14500 1.12900 19.20000 1.00000 18.00000 18.00000 18.00000 18.00000 0.00000 0.00000 10.6000 0.000 0.000 0.000 0.000
54.997 2954.00000 57.7000 -34.37500 -0.75000 3.53800 3.53800 12.10000 1.14500 1.12900 18.00000 1.00000 18.00000 18.00000 18.00000 18.00000 0.00000 0.00000 10.6000 0.000 0.000 0.000 0.000
55.007 2954.00000 57.7000 -34.37500 -0.75000 3.53800 3.53800 12.10000 1.14500 1.12900 18.00000 1.00000 18.00000 18.00000 18.00000 18.00000 0.00000 0.00000 10.6000 0.000 0.000 0.000 0.000
55.017 2954.00000 57.7000 -34.37500 -0.75000 3.53800 3.53800 12.10000 1.14500 1.12900 18.00000 1.00000 18.00000 18.00000 18.00000 18.00000 0.00000 0.00000 10.6000 0.000 0.000 0.000 0.000
55.027 2954.00000 57.7000 -34.37500 -0.75000 3.53800 3.53800 12.10000 1.14500 1.12900 18.00000 1.00000 18.00000 18.00000 18.00000 18.00000 0.00000 0.00000 10.6000 0.000 0.000 0.000 0.000
55.037 2954.00000 57.7000 -34.37500 -0.75000 3.53800 3.53800 12.10000 1.14500 1.12900 18.00000 1.00000 18.00000 18.00000 18.00000 18.00000 0.00000 0.00000 10.6000 0.000 0.000 0.000 0.000
55.047 3022.00000 57.0000 -35.15625 -0.62500 3.52100 3.52100 13.40000 1.14500 1.12900 18.00000 1.00000 19.00000 18.00000 18.00000 18.00000 0.00000 0.00000 10.6000 0.000 0.000 0.000 0.000
55.057 3022.00000 57.0000 -35.15625 -0.62500 3.52100 3.52100 13.40000 1.14500 1.12900 18.00000 1.00000 19.00000 18.00000 18.00000 18.00000 0.00000 0.00000 10.6000 0.000 0.000 0.000 0.000
55.067 3022.00000 57.0000 -35.15625 -0.62500 3.52100 3.52100 13.40000 1.14500 1.12900 18.00000 1.00000 19.00000 18.00000 18.00000 18.00000 0.00000 0.00000 10.6000 0.000 0.000 0.000 0.000
55.077 3022.00000 57.0000 -35.15625 -0.62500 3.52100 3.52100 13.40000 1.14500 1.12900 18.00000 1.00000 19.00000 18.00000 18.00000 18.00000 0.00000 0.00000 10.6000 0.000 0.000 0.000 0.000
55.087 3022.00000 57.0000 -35.15625 -0.62500 3.52100 3.52100 13.40000 1.14500 1.12900 18.00000 1.00000 19.00000 18.00000 18.00000 18.00000 0.00000 0.00000 10.6000 0.000 0.000 0.000 0.000
55.097 2983.00000 57.4000 -33.59375 -0.75000 3.36300 3.36300 13.10000 1.12900 1.13600 18.50000 1.00000 18.00000 18.00000 18.00000 18.00000 0.00000 0.00000 10.9000 0.000 0.000 0.000 0.000
55.107 2983.00000 57.4000 -33.59375 -0.75000 3.36300 3.36300 13.10000 1.12900 1.13600 18.50000 1.00000 18.00000 18.00000 18.00000 18.00000 0.00000 0.00000 10.9000 0.000 0.000 0.000 0.000
55.117 2983.00000 57.4000 -33.59375 -0.75000 3.36300 3.36300 13.10000 1.12900 1.13600 18.50000 1.00000 18.00000 18.00000 18.00000 18.00000 0.00000 0.00000 10.9000 0.000 0.000 0.000 0.000
55.127 2983.00000 57.4000 -33.59375 -0.75000 3.36300 3.36300 13.10000 1.12900 1.13600 18.50000 1.00000 18.00000 18.00000 18.00000 18.00000 0.00000 0.00000 10.9000 0.000 0.000 0.000 0.000
55.137 2983.00000 57.4000 -33.59375 -0.75000 3.36300 3.36300 13.10000 1.12900 1.13600 18.50000 1.00000 18.00000 18.00000 18.00000 18.00000 0.00000 0.00000 10.9000 0.000 0.000 0.000 0.000
55.147 3007.00000 57.4000 -33.59375 -0.87500 3.56200 3.56200 12.30000 1.12900 1.13600 18.60000 1.00000 18.00000 18.00000 18.00000 18.00000 0.00000 0.00000 10.9000 0.000 0.000 0.000 0.000
55.157 3007.00000 57.4000 -33.59375 -0.87500 3.56200 3.56200 12.30000 1.12900 1.13600 18.60000 1.00000 18.00000 18.00000 18.00000 18.00000 0.00000 0.00000 10.9000 0.000 0.000 0.000 0.000
55.167 3007.00000 57.4000 -33.59375 -0.87500 3.56200 3.56200 12.30000 1.12900 1.13600 18.60000 1.00000 18.00000 18.00000 18.00000 18.00000 0.00000 0.00000 10.9000 0.000 0.000 0.000 0.000
55.177 3007.00000 57.4000 -33.59375 -0.87500 3.56200 3.56200 12.30000 1.12900 1.13600 18.60000 1.00000 18.00000 18.00000 18.00000 18.00000 0.00000 0.00000 10.9000 0.000 0.000 0.000 0.000
55.187 3007.00000 57.4000 -33.59375 -0.87500 3.56200 3.56200 12.30000 1.12900 1.13600 18.60000 1.00000 18.00000 18.00000 18.00000 18.00000 0.00000 0.00000 10.9000 0.000 0.000 0.000 0.000
55.197 3079.00000 57.3000 -34.37500 -0.75000 3.57300 3.57300 13.50000 1.12900 1.13600 18.20000 1.00000 19.00000 19.00000 18.00000 18.00000 0.00000 0.00000 10.9000 0.000 0.000 0.000 0.000
55.207 3079.00000 57.3000 -34.37500 -0.75000 3.57300 3.57300 13.50000 1.12900 1.13600 18.20000 1.00000 19.00000 19.00000 18.00000 18.00000 0.00000 0.00000 10.9000 0.000 0.000 0.000 0.000
55.217 3079.00000 57.3000 -34.37500 -0.75000 3.57300 3.57300 13.50000 1.12900 1.13600 18.20000 1.00000 19.00000 19.00000 18.00000 18.00000 0.00000 0.00000 10.9000 0.000 0.000 0.000 0.000
55.227 3079.00000 57.3000 -34.37500 -0.75000 3.57300 3.57300 13.50000 1.12900 1.13600 18.20000 1.00000 19.00000 19.00000 18.00000 18.00000 0.00000 0.00000 10.9000 0.000 0.000 0.000 0.000
55.237 3079.00000 57.3000 -34.37500 -0.75000 3.57300 3.57300 13.50000 1.12900 1.13600 18.20000 1.00000 19.00000 19.00000 18.00000 18.00000 0.00000 0.00000 10.9000 0.000 0.000 0.000 0.000
55.247 3076.00000 57.9000 -31.25000 -0.87500 3.57300 3.57300 13.00000 1.12900 1.13600 19.20000 1.00000 18.00000 18.00000 19.00000 19.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
55.257 3076.00000 57.9000 -31.25000 -0.87500 3.57300 3.57300 13.00000 1.12900 1.13600 19.20000 1.00000 18.00000 18.00000 19.00000 19.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
55.267 3076.00000 57.9000 -31.25000 -0.87500 3.57300 3.57300 13.00000 1.12900 1.13600 19.20000 1.00000 18.00000 18.00000 19.00000 19.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
55.277 3076.00000 57.9000 -31.25000 -0.87500 3.57300 3.57300 13.00000 1.12900 1.13600 19.20000 1.00000 18.00000 18.00000 19.00000 19.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
55.287 3076.00000 57.9000 -31.25000 -0.87500 3.57300 3.57300 13.00000 1.12900 1.13600 19.20000 1.00000 18.00000 18.00000 19.00000 19.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
55.297 3160.00000 57.9000 -33.59375 -0.75000 3.59100 3.59100 13.60000 1.12600 1.12000 18.40000 1.00000 19.00000 20.00000 19.00000 19.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
55.307 3160.00000 57.9000 -33.59375 -0.75000 3.59100 3.59100 13.60000 1.12600 1.12000 18.40000 1.00000 19.00000 20.00000 19.00000 19.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
55.317 3160.00000 57.9000 -33.59375 -0.75000 3.59100 3.59100 13.60000 1.12600 1.12000 18.40000 1.00000 19.00000 20.00000 19.00000 19.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
55.327 3160.00000 57.9000 -33.59375 -0.75000 3.59100 3.59100 13.60000 1.12600 1.12000 18.40000 1.00000 19.00000 20.00000 19.00000 19.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
55.337 3160.00000 57.9000 -33.59375 -0.75000 3.59100 3.59100 13.60000 1.12600 1.12000 18.40000 1.00000 19.00000 20.00000 19.00000 19.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
55.347 3106.00000 57.9000 -32.03125 -0.87500 3.60800 3.60800 12.10000 1.12600 1.12000 19.20000 1.00000 19.00000 19.00000 19.00000 19.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
55.357 3106.00000 57.9000 -32.03125 -0.87500 3.60800 3.60800 12.10000 1.12600 1.12000 19.20000 1.00000 19.00000 19.00000 19.00000 19.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
55.367 3106.00000 57.9000 -32.03125 -0.87500 3.60800 3.60800 12.10000 1.12600 1.12000 19.20000 1.00000 19.00000 19.00000 19.00000 19.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
55.377 3106.00000 57.9000 -32.03125 -0.87500 3.60800 3.60800 12.10000 1.12600 1.12000 19.20000 1.00000 19.00000 19.00000 19.00000 19.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
55.387 3106.00000 57.9000 -32.03125 -0.87500 3.60800 3.60800 12.10000 1.12600 1.12000 19.20000 1.00000 19.00000 19.00000 19.00000 19.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
55.397 3192.00000 57.6000 -33.59375 -0.75000 3.61400 3.61400 12.80000 1.12600 1.12000 18.50000 1.00000 19.00000 19.00000 19.00000 19.00000 0.00000 0.00000 11.3000 0.000 0.000 0.000 0.000
55.407 3192.00000 57.6000 -33.59375 -0.75000 3.61400 3.61400 12.80000 1.12600 1.12000 18.50000 1.00000 19.00000 19.00000 19.00000 19.00000 0.00000 0.00000 11.3000 0.000 0.000 0.000 0.000
55.417 3192.00000 57.6000 -33.59375 -0.75000 3.61400 3.61400 12.80000 1.12600 1.12000 18.50000 1.00000 19.00000 19.00000 19.00000 19.00000 0.00000 0.00000 11.3000 0.000 0.000 0.000 0.000
55.427 3192.00000 57.6000 -33.59375 -0.75000 3.61400 3.61400 12.80000 1.12600 1.12000 18.50000 1.00000 19.00000 19.00000 19.00000 19.00000 0.00000 0.00000 11.3000 0.000 0.000 0.000 0.000
55.437 3192.00000 57.6000 -33.59375 -0.75000 3.61400 3.61400 12.80000 1.12600 1.12000 18.50000 1.00000 19.00000 19.00000 19.00000 19.00000 0.00000 0.00000 11.3000 0.000 0.000 0.000 0.000
55.447 3148.00000 57.4000 -32.81250 -0.87500 3.71300 3.71300 13.40000 1.12600 1.12000 18.60000 1.00000 19.00000 19.00000 19.00000 20.00000 0.00000 0.00000 11.3000 0.000 0.000 0.000 0.000
55.457 3148.00000 57.4000 -32.81250 -0.87500 3.71300 3.71300 13.40000 1.12600 1.12000 18.60000 1.00000 19.00000 19.00000 19.00000 20.00000 0.00000 0.00000 11.3000 0.000 0.000 0.000 0.000
55.467 3148.00000 57.4000 -32.81250 -0.87500 3.71300 3.71300 13.40000 1.12600 1.12000 18.60000 1.00000 19.00000 19.00000 19.00000 20.00000 0.00000 0.00000 11.3000 0.000 0.000 0.000 0.000
55.477 3148.00000 57.4000 -32.81250 -0.87500 3.71300 3.71300 13.40000 1.12600 1.12000 18.60000 1.00000 19.00000 19.00000 19.00000 20.00000 0.00000 0.00000 11.3000 0.000 0.000 0.000 0.000
55.487 3148.00000 57.4000 -32.81250 -0.87500 3.71300 3.71300 13.40000 1.12600 1.12000 18.60000 1.00000 19.00000 19.00000 19.00000 20.00000 0.00000 0.00000 11.3000 0.000 0.000 0.000 0.000
55.497 3194.00000 57.7000 -29.68750 -1.00000 3.63700 3.63700 13.00000 1.13300 1.12300 19.70000 1.00000 20.00000 20.00000 19.00000 20.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
55.507 3194.00000 57.7000 -29.68750 -1.00000 3.63700 3.63700 13.00000 1.13300 1.12300 19.70000 1.00000 20.00000 20.00000 19.00000 20.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
55.517 3194.00000 57.7000 -29.68750 -1.00000 3.63700 3.63700 13.00000 1.13300 1.12300 19.70000 1.00000 20.00000 20.00000 19.00000 20.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
55.527 3194.00000 57.7000 -29.68750 -1.00000 3.63700 3.63700 13.00000 1.13300 1.12300 19.70000 1.00000 20.00000 20.00000 19.00000 20.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
55.537 3194.00000 57.7000 -29.68750 -1.00000 3.63700 3.63700 13.00000 1.13300 1.12300 19.70000 1.00000 20.00000 20.00000 19.00000 20.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
55.547 3199.00000 57.7000 -32.81250 -0.87500 3.67200 3.67200 13.20000 1.13300 1.12300 18.60000 1.00000 20.00000 20.00000 19.00000 20.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
55.557 3199.00000 57.7000 -32.81250 -0.87500 3.67200 3.67200 13.20000 1.13300 1.12300 18.60000 1.00000 20.00000 20.00000 19.00000 20.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
55.567 3199.00000 57.7000 -32.81250 -0.87500 3.67200 3.67200 13.20000 1.13300 1.12300 18.60000 1.00000 20.00000 20.00000 19.00000 20.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
55.577 3199.00000 57.7000 -32.81250 -0.87500 3.67200 3.67200 13.20000 1.13300 1.12300 18.60000 1.00000 20.00000 20.00000 19.00000 20.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
55.587 3199.00000 57.7000 -32.81250 -0.87500 3.67200 3.67200 13.20000 1.13300 1.12300 18.60000 1.00000 20.00000 20.00000 19.00000 20.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
55.597 3215.00000 57.7000 -33.59375 -0.87500 3.81200 3.81200 13.20000 1.13300 1.12300 18.60000 1.00000 20.00000 20.00000 20.00000 20.00000 0.00000 0.00000 11.3000 0.000 0.000 0.000 0.000
55.607 3215.00000 57.7000 -33.59375 -0.87500 3.81200 3.81200 13.20000 1.13300 1.12300 18.60000 1.00000 20.00000 20.00000 20.00000 20.00000 0.00000 0.00000 11.3000 0.000 0.000 0.000 0.000
55.617 3215.00000 57.7000 -33.59375 -0.87500 3.81200 3.81200 13.20000 1.13300 1.12300 18.60000 1.00000 20.00000 20.00000 20.00000 20.00000 0.00000 0.00000 11.3000 0.000 0.000 0.000 0.000
55.627 3215.00000 57.7000 -33.59375 -0.87500 3.81200 3.81200 13.20000 1.13300 1.12300 18.60000 1.00000 20.00000 20.00000 20.00000 20.00000 0.00000 0.00000 11.3000 0.000 0.000 0.000 0.000
55.637 3215.00000 57.7000 -33.59375 -0.87500 3.81200 3.81200 13.20000 1.13300 1.12300 18.60000 1.00000 20.00000 20.00000 20.00000 20.00000 0.00000 0.00000 11.3000 0.000 0.000 0.000 0.000
55.647 3285.00000 58.2000 -32.81250 -0.87500 3.82400 3.82400 13.30000 1.13300 1.12300 18.80000 1.00000 20.00000 20.00000 20.00000 21.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
55.657 3285.00000 58.2000 -32.81250 -0.87500 3.82400 3.82400 13.30000 1.13300 1.12300 18.80000 1.00000 20.00000 20.00000 20.00000 21.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
55.667 3285.00000 58.2000 -32.81250 -0.87500 3.82400 3.82400 13.30000 1.13300 1.12300 18.80000 1.00000 20.00000 20.00000 20.00000 21.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
55.677 3285.00000 58.2000 -32.81250 -0.87500 3.82400 3.82400 13.30000 1.13300 1.12300 18.80000 1.00000 20.00000 20.00000 20.00000 21.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
55.687 3285.00000 58.2000 -32.81250 -0.87500 3.82400 3.82400 13.30000 1.13300 1.12300 18.80000 1.00000 20.00000 20.00000 20.00000 21.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
55.697 3293.00000 58.0000 -29.68750 -1.12500 3.74200 3.74200 11.90000 1.12300 1.12300 19.70000 1.00000 20.00000 20.00000 21.00000 20.00000 0.00000 0.00000 11.3000 0.000 0.000 0.000 0.000
55.707 3293.00000 58.0000 -29.68750 -1.12500 3.74200 3.74200 11.90000 1.12300 1.12300 19.70000 1.00000 20.00000 20.00000 21.00000 20.00000 0.00000 0.00000 11.3000 0.000 0.000 0.000 0.000
55.717 3293.00000 58.0000 -29.68750 -1.12500 3.74200 3.74200 11.90000 1.12300 1.12300 19.70000 1.00000 20.00000 20.00000 21.00000 20.00000 0.00000 0.00000 11.3000 0.000 0.000 0.000 0.000
55.727 3293.00000 58.0000 -29.68750 -1.12500 3.74200 3.74200 11.90000 1.12300 1.12300 19.70000 1.00000 20.00000 20.00000 21.00000 20.00000 0.00000 0.00000 11.3000 0.000 0.000 0.000 0.000
55.737 3293.00000 58.0000 -29.68750 -1.12500 3.74200 3.74200 11.90000 1.12300 1.12300 19.70000 1.00000 20.00000 20.00000 21.00000 20.00000 0.00000 0.00000 11.3000 0.000 0.000 0.000 0.000
55.747 3314.00000 58.2000 -28.12500 -1.12500 3.76600 3.76600 12.70000 1.12300 1.12300 20.10000 1.00000 21.00000 21.00000 21.00000 20.00000 0.00000 0.00000 11.3000 0.000 0.000 0.000 0.000
55.757 3314.00000 58.2000 -28.12500 -1.12500 3.76600 3.76600 12.70000 1.12300 1.12300 20.10000 1.00000 21.00000 21.00000 21.00000 20.00000 0.00000 0.00000 11.3000 0.000 0.000 0.000 0.000
55.767 3314.00000 58.2000 -28.12500 -1.12500 3.76600 3.76600 12.70000 1.12300 1.12300 20.10000 1.00000 21.00000 21.00000 21.00000 20.00000 0.00000 0.00000 11.3000 0.000 0.000 0.000 0.000
55.777 3314.00000 58.2000 -28.12500 -1.12500 3.76600 3.76600 12.70000 1.12300 1.12300 20.10000 1.00000 21.00000 21.00000 21.00000 20.00000 0.00000 0.00000 11.3000 0.000 0.000 0.000 0.000
55.787 3314.00000 58.2000 -28.12500 -1.12500 3.76600 3.76600 12.70000 1.12300 1.12300 20.10000 1.00000 21.00000 21.00000 21.00000 20.00000 0.00000 0.00000 11.3000 0.000 0.000 0.000 0.000
55.797 3337.00000 57.7000 -28.12500 -1.12500 3.76600 3.76600 12.90000 1.12300 1.12300 20.00000 1.00000 21.00000 21.00000 21.00000 21.00000 0.00000 0.00000 11.3000 0.000 0.000 0.000 0.000
55.807 3337.00000 57.7000 -28.12500 -1.12500 3.76600 3.76600 12.90000 1.12300 1.12300 20.00000 1.00000 21.00000 21.00000 21.00000 21.00000 0.00000 0.00000 11.3000 0.000 0.000 0.000 0.000
55.817 3337.00000 57.7000 -28.12500 -1.12500 3.76600 3.76600 12.90000 1.12300 1.12300 20.00000 1.00000 21.00000 21.00000 21.00000 21.00000 0.00000 0.00000 11.3000 0.000 0.000 0.000 0.000
55.827 3337.00000 57.7000 -28.12500 -1.12500 3.76600 3.76600 12.90000 1.12300 1.12300 20.00000 1.00000 21.00000 21.00000 21.00000 21.00000 0.00000 0.00000 11.3000 0.000 0.000 0.000 0.000
55.837 3337.00000 57.7000 -28.12500 -1.12500 3.76600 3.76600 12.90000 1.12300 1.12300 20.00000 1.00000 21.00000 21.00000 21.00000 21.00000 0.00000 0.00000 11.3000 0.000 0.000 0.000 0.000
55.847 3440.00000 57.9000 -24.21875 -1.12500 3.80100 3.80100 12.30000 1.12300 1.12300 20.90000 1.00000 21.00000 21.00000 22.00000 21.00000 0.00000 0.00000 11.3000 0.000 0.000 0.000 0.000
55.857 3440.00000 57.9000 -24.21875 -1.12500 3.80100 3.80100 12.30000 1.12300 1.12300 20.90000 1.00000 21.00000 21.00000 22.00000 21.00000 0.00000 0.00000 11.3000 0.000 0.000 0.000 0.000
55.867 3440.00000 57.9000 -24.21875 -1.12500 3.80100 3.80100 12.30000 1.12300 1.12300 20.90000 1.00000 21.00000 21.00000 22.00000 21.00000 0.00000 0.00000 11.3000 0.000 0.000 0.000 0.000
55.877 3440.00000 57.9000 -24.21875 -1.12500 3.80100 3.80100 12.30000 1.12300 1.12300 20.90000 1.00000 21.00000 21.00000 22.00000 21.00000 0.00000 0.00000 11.3000 0.000 0.000 0.000 0.000
55.887 3440.00000 57.9000 -24.21875 -1.12500 3.80100 3.80100 12.30000 1.12300 1.12300 20.90000 1.00000 21.00000 21.00000 22.00000 21.00000 0.00000 0.00000 11.3000 0.000 0.000 0.000 0.000
55.897 3387.00000 57.9000 -28.12500 -1.25000 3.81800 3.81800 12.10000 1.12300 1.11700 20.10000 1.00000 21.00000 22.00000 21.00000 21.00000 0.00000 0.00000 11.3000 0.000 0.000 0.000 0.000
55.907 3387.00000 57.9000 -28.12500 -1.25000 3.81800 3.81800 12.10000 1.12300 1.11700 20.10000 1.00000 21.00000 22.00000 21.00000 21.00000 0.00000 0.00000 11.3000 0.000 0.000 0.000 0.000
55.917 3387.00000 57.9000 -28.12500 -1.25000 3.81800 3.81800 12.10000 1.12300 1.11700 20.10000 1.00000 21.00000 22.00000 21.00000 21.00000 0.00000 0.00000 11.3000 0.000 0.000 0.000 0.000
55.927 3387.00000 57.9000 -28.12500 -1.25000 3.81800 3.81800 12.10000 1.12300 1.11700 20.10000 1.00000 21.00000 22.00000 21.00000 21.00000 0.00000 0.00000 11.3000 0.000 0.000 0.000 0.000
55.937 3387.00000 57.9000 -28.12500 -1.25000 3.81800 3.81800 12.10000 1.12300 1.11700 20.10000 1.00000 21.00000 22.00000 21.00000 21.00000 0.00000 0.00000 11.3000 0.000 0.000 0.000 0.000
55.947 3435.00000 58.2000 -28.12500 -1.25000 3.86500 3.86500 12.70000 1.12300 1.11700 20.00000 1.00000 22.00000 22.00000 22.00000 21.00000 0.00000 0.00000 11.3000 0.000 0.000 0.000 0.000
55.957 3435.00000 58.2000 -28.12500 -1.25000 3.86500 3.86500 12.70000 1.12300 1.11700 20.00000 1.00000 22.00000 22.00000 22.00000 21.00000 0.00000 0.00000 11.3000 0.000 0.000 0.000 0.000
55.967 3435.00000 58.2000 -28.12500 -1.25000 3.86500 3.86500 12.70000 1.12300 1.11700 20.00000 1.00000 22.00000 22.00000 22.00000 21.00000 0.00000 0.00000 11.3000 0.000 0.000 0.000 0.000
55.977 3435.00000 58.2000 -28.12500 -1.25000 3.86500 3.86500 12.70000 1.12300 1.11700 20.00000 1.00000 22.00000 22.00000 22.00000 21.00000 0.00000 0.00000 11.3000 0.000 0.000 0.000 0.000
55.987 3435.00000 58.2000 -28.12500 -1.25000 3.86500 3.86500 12.70000 1.12300 1.11700 20.00000 1.00000 22.00000 22.00000 22.00000 21.00000 0.00000 0.00000 11.3000 0.000 0.000 0.000 0.000
55.997 3456.00000 57.9000 -29.68750 -1.12500 3.95200 3.95200 13.70000 1.12300 1.11700 19.80000 1.00000 22.00000 22.00000 22.00000 23.00000 0.00000 0.00000 11.3000 0.000 0.000 0.000 0.000
56.007 3456.00000 57.9000 -29.68750 -1.12500 3.95200 3.95200 13.70000 1.12300 1.11700 19.80000 1.00000 22.00000 22.00000 22.00000 23.00000 0.00000 0.00000 11.3000 0.000 0.000 0.000 0.000
56.017 3456.00000 57.9000 -29.68750 -1.12500 3.95200 3.95200 13.70000 1.12300 1.11700 19.80000 1.00000 22.00000 22.00000 22.00000 23.00000 0.00000 0.00000 11.3000 0.000 0.000 0.000 0.000
56.027 3456.00000 57.9000 -29.68750 -1.12500 3.95200 3.95200 13.70000 1.12300 1.11700 19.80000 1.00000 22.00000 22.00000 22.00000 23.00000 0.00000 0.00000 11.3000 0.000 0.000 0.000 0.000
56.037 3456.00000 57.9000 -29.68750 -1.12500 3.95200 3.95200 13.70000 1.12300 1.11700 19.80000 1.00000 22.00000 22.00000 22.00000 23.00000 0.00000 0.00000 11.3000 0.000 0.000 0.000 0.000
56.047 3533.00000 57.6000 -31.25000 -1.25000 3.94000 3.94000 13.40000 1.12300 1.11700 19.50000 1.00000 22.00000 23.00000 22.00000 24.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
56.057 3533.00000 57.6000 -31.25000 -1.25000 3.94000 3.94000 13.40000 1.12300 1.11700 19.50000 1.00000 22.00000 23.00000 22.00000 24.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
56.067 3533.00000 57.6000 -31.25000 -1.25000 3.94000 3.94000 13.40000 1.12300 1.11700 19.50000 1.00000 22.00000 23.00000 22.00000 24.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
56.077 3533.00000 57.6000 -31.25000 -1.25000 3.94000 3.94000 13.40000 1.12300 1.11700 19.50000 1.00000 22.00000 23.00000 22.00000 24.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
56.087 3533.00000 57.6000 -31.25000 -1.25000 3.94000 3.94000 13.40000 1.12300 1.11700 19.50000 1.00000 22.00000 23.00000 22.00000 24.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
56.097 3507.00000 57.3000 -28.12500 -1.25000 3.96400 3.96400 13.20000 1.12000 1.11300 20.00000 1.00000 22.00000 24.00000 22.00000 23.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
56.107 3507.00000 57.3000 -28.12500 -1.25000 3.96400 3.96400 13.20000 1.12000 1.11300 20.00000 1.00000 22.00000 24.00000 22.00000 23.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
56.117 3507.00000 57.3000 -28.12500 -1.25000 3.96400 3.96400 13.20000 1.12000 1.11300 20.00000 1.00000 22.00000 24.00000 22.00000 23.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
56.127 3507.00000 57.3000 -28.12500 -1.25000 3.96400 3.96400 13.20000 1.12000 1.11300 20.00000 1.00000 22.00000 24.00000 22.00000 23.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
56.137 3507.00000 57.3000 -28.12500 -1.25000 3.96400 3.96400 13.20000 1.12000 1.11300 20.00000 1.00000 22.00000 24.00000 22.00000 23.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
56.147 3611.00000 57.4000 -21.87500 -1.25000 3.92300 3.92300 12.50000 1.12000 1.11300 21.40000 1.00000 23.00000 23.00000 23.00000 24.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
56.157 3611.00000 57.4000 -21.87500 -1.25000 3.92300 3.92300 12.50000 1.12000 1.11300 21.40000 1.00000 23.00000 23.00000 23.00000 24.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
56.167 3611.00000 57.4000 -21.87500 -1.25000 3.92300 3.92300 12.50000 1.12000 1.11300 21.40000 1.00000 23.00000 23.00000 23.00000 24.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
56.177 3611.00000 57.4000 -21.87500 -1.25000 3.92300 3.92300 12.50000 1.12000 1.11300 21.40000 1.00000 23.00000 23.00000 23.00000 24.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
56.187 3611.00000 57.4000 -21.87500 -1.25000 3.92300 3.92300 12.50000 1.12000 1.11300 21.40000 1.00000 23.00000 23.00000 23.00000 24.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
56.197 3555.00000 57.4000 -28.12500 -1.25000 4.01600 4.01600 13.40000 1.12000 1.11300 20.10000 1.00000 23.00000 24.00000 23.00000 24.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
56.207 3555.00000 57.4000 -28.12500 -1.25000 4.01600 4.01600 13.40000 1.12000 1.11300 20.10000 1.00000 23.00000 24.00000 23.00000 24.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
56.217 3555.00000 57.4000 -28.12500 -1.25000 4.01600 4.01600 13.40000 1.12000 1.11300 20.10000 1.00000 23.00000 24.00000 23.00000 24.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
56.227 3555.00000 57.4000 -28.12500 -1.25000 4.01600 4.01600 13.40000 1.12000 1.11300 20.10000 1.00000 23.00000 24.00000 23.00000 24.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
56.237 3555.00000 57.4000 -28.12500 -1.25000 4.01600 4.01600 13.40000 1.12000 1.11300 20.10000 1.00000 23.00000 24.00000 23.00000 24.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
56.247 3639.00000 38.8000 -29.68750 -1.12500 3.82400 3.82400 13.60000 1.12000 1.11300 19.70000 1.00000 24.00000 23.00000 24.00000 24.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
56.257 3639.00000 38.8000 -29.68750 -1.12500 3.82400 3.82400 13.60000 1.12000 1.11300 19.70000 1.00000 24.00000 23.00000 24.00000 24.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
56.267 3639.00000 38.8000 -29.68750 -1.12500 3.82400 3.82400 13.60000 1.12000 1.11300 19.70000 1.00000 24.00000 23.00000 24.00000 24.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
56.277 3639.00000 38.8000 -29.68750 -1.12500 3.82400 3.82400 13.60000 1.12000 1.11300 19.70000 1.00000 24.00000 23.00000 24.00000 24.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
56.287 3639.00000 38.8000 -29.68750 -1.12500 3.82400 3.82400 13.60000 1.12000 1.11300 19.70000 1.00000 24.00000 23.00000 24.00000 24.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
56.297 3594.00000 15.4000 -44.53125 -0.12500 1.94100 1.94100 12.40000 1.12900 1.11300 12.80000 1.00000 9.00000 4.00000 4.00000 4.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
56.307 3594.00000 15.4000 -44.53125 -0.12500 1.94100 1.94100 12.40000 1.12900 1.11300 12.80000 1.00000 9.00000 4.00000 4.00000 4.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
56.317 3594.00000 15.4000 -44.53125 -0.12500 1.94100 1.94100 12.40000 1.12900 1.11300 12.80000 1.00000 9.00000 4.00000 4.00000 4.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
56.327 3594.00000 15.4000 -44.53125 -0.12500 1.94100 1.94100 12.40000 1.12900 1.11300 12.80000 1.00000 9.00000 4.00000 4.00000 4.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
56.337 3594.00000 15.4000 -44.53125 -0.12500 1.94100 1.94100 12.40000 1.12900 1.11300 12.80000 1.00000 9.00000 4.00000 4.00000 4.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
56.347 3341.00000 15.2000 -44.53125 0.00000 1.69000 1.69000 12.60000 1.12900 1.11300 8.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 11.0000 0.000 0.000 0.000 0.000
56.357 3341.00000 15.2000 -44.53125 0.00000 1.69000 1.69000 12.60000 1.12900 1.11300 8.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 11.0000 0.000 0.000 0.000 0.000
56.367 3341.00000 15.2000 -44.53125 0.00000 1.69000 1.69000 12.60000 1.12900 1.11300 8.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 11.0000 0.000 0.000 0.000 0.000
56.377 3341.00000 15.2000 -44.53125 0.00000 1.69000 1.69000 12.60000 1.12900 1.11300 8.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 11.0000 0.000 0.000 0.000 0.000
56.387 3341.00000 15.2000 -44.53125 0.00000 1.69000 1.69000 12.60000 1.12900 1.11300 8.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 11.0000 0.000 0.000 0.000 0.000
56.397 3417.00000 15.2000 -44.53125 0.00000 1.66100 1.66100 12.10000 1.12900 1.11300 6.90000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
56.407 3417.00000 15.2000 -44.53125 0.00000 1.66100 1.66100 12.10000 1.12900 1.11300 6.90000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
56.417 3417.00000 15.2000 -44.53125 0.00000 1.66100 1.66100 12.10000 1.12900 1.11300 6.90000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
56.427 3417.00000 15.2000 -44.53125 0.00000 1.66100 1.66100 12.10000 1.12900 1.11300 6.90000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
56.437 3417.00000 15.2000 -44.53125 0.00000 1.66100 1.66100 12.10000 1.12900 1.11300 6.90000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
56.447 3399.00000 15.2000 -44.53125 0.00000 2.53000 2.53000 12.70000 1.12900 1.11300 5.90000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
56.457 3399.00000 15.2000 -44.53125 0.00000 2.53000 2.53000 12.70000 1.12900 1.11300 5.90000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
56.467 3399.00000 15.2000 -44.53125 0.00000 2.53000 2.53000 12.70000 1.12900 1.11300 5.90000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
56.477 3399.00000 15.2000 -44.53125 0.00000 2.53000 2.53000 12.70000 1.12900 1.11300 5.90000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
56.487 3399.00000 15.2000 -44.53125 0.00000 2.53000 2.53000 12.70000 1.12900 1.11300 5.90000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
56.497 3376.00000 15.2000 -44.53125 0.00000 2.66400 2.66400 12.20000 1.12300 1.11700 5.50000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 10.5000 0.000 0.000 0.000 0.000
56.507 3376.00000 15.2000 -44.53125 0.00000 2.66400 2.66400 12.20000 1.12300 1.11700 5.50000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 10.5000 0.000 0.000 0.000 0.000
56.517 3376.00000 15.2000 -44.53125 0.00000 2.66400 2.66400 12.20000 1.12300 1.11700 5.50000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 10.5000 0.000 0.000 0.000 0.000
56.527 3376.00000 15.2000 -44.53125 0.00000 2.66400 2.66400 12.20000 1.12300 1.11700 5.50000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 10.5000 0.000 0.000 0.000 0.000
56.537 3376.00000 15.2000 -44.53125 0.00000 2.66400 2.66400 12.20000 1.12300 1.11700 5.50000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 10.5000 0.000 0.000 0.000 0.000
56.547 3362.00000 15.2000 -44.53125 0.00000 2.76900 2.76900 12.30000 1.12300 1.11700 4.80000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 10.5000 0.000 0.000 0.000 0.000
56.557 3362.00000 15.2000 -44.53125 0.00000 2.76900 2.76900 12.30000 1.12300 1.11700 4.80000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 10.5000 0.000 0.000 0.000 0.000
56.567 3362.00000 15.2000 -44.53125 0.00000 2.76900 2.76900 12.30000 1.12300 1.11700 4.80000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 10.5000 0.000 0.000 0.000 0.000
56.577 3362.00000 15.2000 -44.53125 0.00000 2.76900 2.76900 12.30000 1.12300 1.11700 4.80000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 10.5000 0.000 0.000 0.000 0.000
56.587 3362.00000 15.2000 -44.53125 0.00000 2.76900 2.76900 12.30000 1.12300 1.11700 4.80000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 10.5000 0.000 0.000 0.000 0.000
56.597 3210.00000 15.1000 -44.53125 0.00000 2.45400 2.45400 12.70000 1.12300 1.11700 4.50000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 10.5000 0.000 0.000 0.000 0.000
56.607 3210.00000 15.1000 -44.53125 0.00000 2.45400 2.45400 12.70000 1.12300 1.11700 4.50000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 10.5000 0.000 0.000 0.000 0.000
56.617 3210.00000 15.1000 -44.53125 0.00000 2.45400 2.45400 12.70000 1.12300 1.11700 4.50000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 10.5000 0.000 0.000 0.000 0.000
56.627 3210.00000 15.1000 -44.53125 0.00000 2.45400 2.45400 12.70000 1.12300 1.11700 4.50000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 10.5000 0.000 0.000 0.000 0.000
56.637 3210.00000 15.1000 -44.53125 0.00000 2.45400 2.45400 12.70000 1.12300 1.11700 4.50000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 10.5000 0.000 0.000 0.000 0.000
56.647 3189.00000 15.1000 -44.53125 0.00000 1.78300 1.78300 13.30000 1.12300 1.11700 4.40000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
56.657 3189.00000 15.1000 -44.53125 0.00000 1.78300 1.78300 13.30000 1.12300 1.11700 4.40000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
56.667 3189.00000 15.1000 -44.53125 0.00000 1.78300 1.78300 13.30000 1.12300 1.11700 4.40000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
56.676 3189.00000 15.1000 -44.53125 0.00000 1.78300 1.78300 13.30000 1.12300 1.11700 4.40000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
56.686 3189.00000 15.1000 -44.53125 0.00000 1.78300 1.78300 13.30000 1.12300 1.11700 4.40000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
56.696 3139.00000 15.2000 -44.53125 0.00000 2.04600 2.04600 13.30000 1.10100 1.11700 4.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
56.706 3139.00000 15.2000 -44.53125 0.00000 2.04600 2.04600 13.30000 1.10100 1.11700 4.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
56.716 3139.00000 15.2000 -44.53125 0.00000 2.04600 2.04600 13.30000 1.10100 1.11700 4.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
56.726 3139.00000 15.2000 -44.53125 0.00000 2.04600 2.04600 13.30000 1.10100 1.11700 4.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
56.736 3139.00000 15.2000 -44.53125 0.00000 2.04600 2.04600 13.30000 1.10100 1.11700 4.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
56.746 3111.00000 15.1000 -44.53125 0.00000 1.84800 1.84800 13.10000 1.10100 1.11700 4.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
56.756 3111.00000 15.1000 -44.53125 0.00000 1.84800 1.84800 13.10000 1.10100 1.11700 4.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
56.766 3111.00000 15.1000 -44.53125 0.00000 1.84800 1.84800 13.10000 1.10100 1.11700 4.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
56.776 3111.00000 15.1000 -44.53125 0.00000 1.84800 1.84800 13.10000 1.10100 1.11700 4.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
56.786 3111.00000 15.1000 -44.53125 0.00000 1.84800 1.84800 13.10000 1.10100 1.11700 4.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
56.796 3058.00000 15.2000 -44.53125 0.00000 1.86500 1.86500 13.50000 1.10100 1.11700 4.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 11.3000 0.000 0.000 0.000 0.000
56.806 3058.00000 15.2000 -44.53125 0.00000 1.86500 1.86500 13.50000 1.10100 1.11700 4.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 11.3000 0.000 0.000 0.000 0.000
56.816 3058.00000 15.2000 -44.53125 0.00000 1.86500 1.86500 13.50000 1.10100 1.11700 4.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 11.3000 0.000 0.000 0.000 0.000
56.826 3058.00000 15.2000 -44.53125 0.00000 1.86500 1.86500 13.50000 1.10100 1.11700 4.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 11.3000 0.000 0.000 0.000 0.000
56.836 3058.00000 15.2000 -44.53125 0.00000 1.86500 1.86500 13.50000 1.10100 1.11700 4.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 11.3000 0.000 0.000 0.000 0.000
56.846 3010.00000 15.2000 -44.53125 0.00000 2.31400 2.31400 13.10000 1.10100 1.11700 4.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
56.856 3010.00000 15.2000 -44.53125 0.00000 2.31400 2.31400 13.10000 1.10100 1.11700 4.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
56.866 3010.00000 15.2000 -44.53125 0.00000 2.31400 2.31400 13.10000 1.10100 1.11700 4.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
56.876 3010.00000 15.2000 -44.53125 0.00000 2.31400 2.31400 13.10000 1.10100 1.11700 4.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
56.886 3010.00000 15.2000 -44.53125 0.00000 2.31400 2.31400 13.10000 1.10100 1.11700 4.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
56.896 3045.00000 15.1000 -44.53125 0.00000 2.04000 2.04000 13.10000 1.10100 1.08800 4.10000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 11.3000 0.000 0.000 0.000 0.000
56.906 3045.00000 15.1000 -44.53125 0.00000 2.04000 2.04000 13.10000 1.10100 1.08800 4.10000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 11.3000 0.000 0.000 0.000 0.000
56.916 3045.00000 15.1000 -44.53125 0.00000 2.04000 2.04000 13.10000 1.10100 1.08800 4.10000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 11.3000 0.000 0.000 0.000 0.000
56.926 3045.00000 15.1000 -44.53125 0.00000 2.04000 2.04000 13.10000 1.10100 1.08800 4.10000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 11.3000 0.000 0.000 0.000 0.000
56.936 3045.00000 15.1000 -44.53125 0.00000 2.04000 2.04000 13.10000 1.10100 1.08800 4.10000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 11.3000 0.000 0.000 0.000 0.000
56.946 2937.00000 15.1000 -44.53125 0.00000 1.87700 1.87700 13.00000 1.10100 1.08800 4.10000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 11.6000 0.000 0.000 0.000 0.000
56.956 2937.00000 15.1000 -44.53125 0.00000 1.87700 1.87700 13.00000 1.10100 1.08800 4.10000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 11.6000 0.000 0.000 0.000 0.000
56.966 2937.00000 15.1000 -44.53125 0.00000 1.87700 1.87700 13.00000 1.10100 1.08800 4.10000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 11.6000 0.000 0.000 0.000 0.000
56.976 2937.00000 15.1000 -44.53125 0.00000 1.87700 1.87700 13.00000 1.10100 1.08800 4.10000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 11.6000 0.000 0.000 0.000 0.000
56.986 2937.00000 15.1000 -44.53125 0.00000 1.87700 1.87700 13.00000 1.10100 1.08800 4.10000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 11.6000 0.000 0.000 0.000 0.000
56.996 2912.00000 15.2000 -44.53125 0.00000 1.95200 1.95200 13.40000 1.10100 1.08800 4.10000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 11.6000 0.000 0.000 0.000 0.000
57.006 2912.00000 15.2000 -44.53125 0.00000 1.95200 1.95200 13.40000 1.10100 1.08800 4.10000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 11.6000 0.000 0.000 0.000 0.000
57.016 2912.00000 15.2000 -44.53125 0.00000 1.95200 1.95200 13.40000 1.10100 1.08800 4.10000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 11.6000 0.000 0.000 0.000 0.000
57.026 2912.00000 15.2000 -44.53125 0.00000 1.95200 1.95200 13.40000 1.10100 1.08800 4.10000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 11.6000 0.000 0.000 0.000 0.000
57.036 2912.00000 15.2000 -44.53125 0.00000 1.95200 1.95200 13.40000 1.10100 1.08800 4.10000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 11.6000 0.000 0.000 0.000 0.000
57.046 2851.00000 15.2000 -44.53125 0.00000 1.83000 1.83000 13.00000 1.10100 1.08800 4.20000 1.00000 4.00000 3.00000 4.00000 4.00000 0.00000 0.00000 11.6000 0.000 0.000 0.000 0.000
57.056 2851.00000 15.2000 -44.53125 0.00000 1.83000 1.83000 13.00000 1.10100 1.08800 4.20000 1.00000 4.00000 3.00000 4.00000 4.00000 0.00000 0.00000 11.6000 0.000 0.000 0.000 0.000
57.066 2851.00000 15.2000 -44.53125 0.00000 1.83000 1.83000 13.00000 1.10100 1.08800 4.20000 1.00000 4.00000 3.00000 4.00000 4.00000 0.00000 0.00000 11.6000 0.000 0.000 0.000 0.000
57.076 2851.00000 15.2000 -44.53125 0.00000 1.83000 1.83000 13.00000 1.10100 1.08800 4.20000 1.00000 4.00000 3.00000 4.00000 4.00000 0.00000 0.00000 11.6000 0.000 0.000 0.000 0.000
57.086 2851.00000 15.2000 -44.53125 0.00000 1.83000 1.83000 13.00000 1.10100 1.08800 4.20000 1.00000 4.00000 3.00000 4.00000 4.00000 0.00000 0.00000 11.6000 0.000 0.000 0.000 0.000
57.096 2779.00000 15.1000 -44.53125 0.00000 2.13300 2.13300 13.60000 1.13300 1.07500 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 11.6000 0.000 0.000 0.000 0.000
57.106 2779.00000 15.1000 -44.53125 0.00000 2.13300 2.13300 13.60000 1.13300 1.07500 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 11.6000 0.000 0.000 0.000 0.000
57.116 2779.00000 15.1000 -44.53125 0.00000 2.13300 2.13300 13.60000 1.13300 1.07500 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 11.6000 0.000 0.000 0.000 0.000
57.126 2779.00000 15.1000 -44.53125 0.00000 2.13300 2.13300 13.60000 1.13300 1.07500 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 11.6000 0.000 0.000 0.000 0.000
57.136 2779.00000 15.1000 -44.53125 0.00000 2.13300 2.13300 13.60000 1.13300 1.07500 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 11.6000 0.000 0.000 0.000 0.000
57.146 2755.00000 15.1000 -44.53125 0.00000 1.37500 1.37500 13.10000 1.13300 1.07500 4.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 11.7000 0.000 0.000 0.000 0.000
57.156 2755.00000 15.1000 -44.53125 0.00000 1.37500 1.37500 13.10000 1.13300 1.07500 4.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 11.7000 0.000 0.000 0.000 0.000
57.166 2755.00000 15.1000 -44.53125 0.00000 1.37500 1.37500 13.10000 1.13300 1.07500 4.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 11.7000 0.000 0.000 0.000 0.000
57.176 2755.00000 15.1000 -44.53125 0.00000 1.37500 1.37500 13.10000 1.13300 1.07500 4.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 11.7000 0.000 0.000 0.000 0.000
57.186 2755.00000 15.1000 -44.53125 0.00000 1.37500 1.37500 13.10000 1.13300 1.07500 4.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 11.7000 0.000 0.000 0.000 0.000
57.196 2529.00000 15.2000 -44.53125 0.00000 1.81300 1.81300 12.60000 1.13300 1.07500 4.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 11.6000 0.000 0.000 0.000 0.000
57.206 2529.00000 15.2000 -44.53125 0.00000 1.81300 1.81300 12.60000 1.13300 1.07500 4.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 11.6000 0.000 0.000 0.000 0.000
57.216 2529.00000 15.2000 -44.53125 0.00000 1.81300 1.81300 12.60000 1.13300 1.07500 4.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 11.6000 0.000 0.000 0.000 0.000
57.226 2529.00000 15.2000 -44.53125 0.00000 1.81300 1.81300 12.60000 1.13300 1.07500 4.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 11.6000 0.000 0.000 0.000 0.000
57.236 2529.00000 15.2000 -44.53125 0.00000 1.81300 1.81300 12.60000 1.13300 1.07500 4.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 11.6000 0.000 0.000 0.000 0.000
57.246 2438.00000 15.1000 -44.53125 0.00000 1.70800 1.70800 13.20000 1.13300 1.07500 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 11.7000 0.000 0.000 0.000 0.000
57.256 2438.00000 15.1000 -44.53125 0.00000 1.70800 1.70800 13.20000 1.13300 1.07500 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 11.7000 0.000 0.000 0.000 0.000
57.266 2438.00000 15.1000 -44.53125 0.00000 1.70800 1.70800 13.20000 1.13300 1.07500 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 11.7000 0.000 0.000 0.000 0.000
57.276 2438.00000 15.1000 -44.53125 0.00000 1.70800 1.70800 13.20000 1.13300 1.07500 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 11.7000 0.000 0.000 0.000 0.000
57.286 2438.00000 15.1000 -44.53125 0.00000 1.70800 1.70800 13.20000 1.13300 1.07500 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 11.7000 0.000 0.000 0.000 0.000
57.296 2393.00000 15.1000 -44.53125 0.00000 1.54400 1.54400 13.30000 0.64100 1.07500 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
57.306 2393.00000 15.1000 -44.53125 0.00000 1.54400 1.54400 13.30000 0.64100 1.07500 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
57.316 2393.00000 15.1000 -44.53125 0.00000 1.54400 1.54400 13.30000 0.64100 1.07500 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
57.326 2393.00000 15.1000 -44.53125 0.00000 1.54400 1.54400 13.30000 0.64100 1.07500 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
57.336 2393.00000 15.1000 -44.53125 0.00000 1.54400 1.54400 13.30000 0.64100 1.07500 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
57.346 2254.00000 15.1000 -44.53125 0.00000 1.46300 1.46300 13.50000 0.64100 1.07500 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
57.356 2254.00000 15.1000 -44.53125 0.00000 1.46300 1.46300 13.50000 0.64100 1.07500 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
57.366 2254.00000 15.1000 -44.53125 0.00000 1.46300 1.46300 13.50000 0.64100 1.07500 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
57.376 2254.00000 15.1000 -44.53125 0.00000 1.46300 1.46300 13.50000 0.64100 1.07500 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
57.386 2254.00000 15.1000 -44.53125 0.00000 1.46300 1.46300 13.50000 0.64100 1.07500 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
57.396 2154.00000 15.2000 -44.53125 0.00000 1.63800 1.63800 13.00000 0.64100 1.07500 4.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
57.406 2154.00000 15.2000 -44.53125 0.00000 1.63800 1.63800 13.00000 0.64100 1.07500 4.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
57.416 2154.00000 15.2000 -44.53125 0.00000 1.63800 1.63800 13.00000 0.64100 1.07500 4.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
57.426 2154.00000 15.2000 -44.53125 0.00000 1.63800 1.63800 13.00000 0.64100 1.07500 4.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
57.436 2154.00000 15.2000 -44.53125 0.00000 1.63800 1.63800 13.00000 0.64100 1.07500 4.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
57.446 2097.00000 15.1000 -44.53125 0.00000 1.63800 1.63800 13.20000 0.64100 1.07500 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.3000 0.000 0.000 0.000 0.000
57.456 2097.00000 15.1000 -44.53125 0.00000 1.63800 1.63800 13.20000 0.64100 1.07500 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.3000 0.000 0.000 0.000 0.000
57.466 2097.00000 15.1000 -44.53125 0.00000 1.63800 1.63800 13.20000 0.64100 1.07500 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.3000 0.000 0.000 0.000 0.000
57.476 2097.00000 15.1000 -44.53125 0.00000 1.63800 1.63800 13.20000 0.64100 1.07500 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.3000 0.000 0.000 0.000 0.000
57.486 2097.00000 15.1000 -44.53125 0.00000 1.63800 1.63800 13.20000 0.64100 1.07500 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.3000 0.000 0.000 0.000 0.000
57.496 1949.00000 15.2000 -44.53125 0.00000 1.42800 1.42800 13.50000 0.26100 1.07800 4.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.3000 0.000 0.000 0.000 0.000
57.506 1949.00000 15.2000 -44.53125 0.00000 1.42800 1.42800 13.50000 0.26100 1.07800 4.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.3000 0.000 0.000 0.000 0.000
57.516 1949.00000 15.2000 -44.53125 0.00000 1.42800 1.42800 13.50000 0.26100 1.07800 4.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.3000 0.000 0.000 0.000 0.000
57.526 1949.00000 15.2000 -44.53125 0.00000 1.42800 1.42800 13.50000 0.26100 1.07800 4.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.3000 0.000 0.000 0.000 0.000
57.536 1949.00000 15.2000 -44.53125 0.00000 1.42800 1.42800 13.50000 0.26100 1.07800 4.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.3000 0.000 0.000 0.000 0.000
57.546 1938.00000 15.1000 -44.53125 0.00000 1.66100 1.66100 13.40000 0.26100 1.07800 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.3000 0.000 0.000 0.000 0.000
57.556 1938.00000 15.1000 -44.53125 0.00000 1.66100 1.66100 13.40000 0.26100 1.07800 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.3000 0.000 0.000 0.000 0.000
57.566 1938.00000 15.1000 -44.53125 0.00000 1.66100 1.66100 13.40000 0.26100 1.07800 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.3000 0.000 0.000 0.000 0.000
57.576 1938.00000 15.1000 -44.53125 0.00000 1.66100 1.66100 13.40000 0.26100 1.07800 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.3000 0.000 0.000 0.000 0.000
57.586 1938.00000 15.1000 -44.53125 0.00000 1.66100 1.66100 13.40000 0.26100 1.07800 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.3000 0.000 0.000 0.000 0.000
57.596 1944.00000 15.1000 -44.53125 0.00000 1.43400 1.43400 13.30000 0.26100 1.07800 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.7000 0.000 0.000 0.000 0.000
57.606 1944.00000 15.1000 -44.53125 0.00000 1.43400 1.43400 13.30000 0.26100 1.07800 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.7000 0.000 0.000 0.000 0.000
57.616 1944.00000 15.1000 -44.53125 0.00000 1.43400 1.43400 13.30000 0.26100 1.07800 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.7000 0.000 0.000 0.000 0.000
57.626 1944.00000 15.1000 -44.53125 0.00000 1.43400 1.43400 13.30000 0.26100 1.07800 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.7000 0.000 0.000 0.000 0.000
57.636 1944.00000 15.1000 -44.53125 0.00000 1.43400 1.43400 13.30000 0.26100 1.07800 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.7000 0.000 0.000 0.000 0.000
57.646 1984.00000 15.1000 -44.53125 0.00000 1.43900 1.43900 12.80000 0.26100 1.07800 4.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
57.656 1984.00000 15.1000 -44.53125 0.00000 1.43900 1.43900 12.80000 0.26100 1.07800 4.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
57.666 1984.00000 15.1000 -44.53125 0.00000 1.43900 1.43900 12.80000 0.26100 1.07800 4.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
57.676 1984.00000 15.1000 -44.53125 0.00000 1.43900 1.43900 12.80000 0.26100 1.07800 4.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
57.686 1984.00000 15.1000 -44.53125 0.00000 1.43900 1.43900 12.80000 0.26100 1.07800 4.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
57.696 1937.00000 15.2000 -44.53125 0.00000 1.80700 1.80700 13.20000 0.27100 1.06200 4.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.4000 0.000 0.000 0.000 0.000
57.706 1937.00000 15.2000 -44.53125 0.00000 1.80700 1.80700 13.20000 0.27100 1.06200 4.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.4000 0.000 0.000 0.000 0.000
57.716 1937.00000 15.2000 -44.53125 0.00000 1.80700 1.80700 13.20000 0.27100 1.06200 4.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.4000 0.000 0.000 0.000 0.000
57.726 1937.00000 15.2000 -44.53125 0.00000 1.80700 1.80700 13.20000 0.27100 1.06200 4.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.4000 0.000 0.000 0.000 0.000
57.736 1937.00000 15.2000 -44.53125 0.00000 1.80700 1.80700 13.20000 0.27100 1.06200 4.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.4000 0.000 0.000 0.000 0.000
57.746 1927.00000 15.4000 -44.53125 0.00000 1.24100 1.24100 12.20000 0.27100 1.06200 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
57.756 1927.00000 15.4000 -44.53125 0.00000 1.24100 1.24100 12.20000 0.27100 1.06200 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
57.766 1927.00000 15.4000 -44.53125 0.00000 1.24100 1.24100 12.20000 0.27100 1.06200 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
57.776 1927.00000 15.4000 -44.53125 0.00000 1.24100 1.24100 12.20000 0.27100 1.06200 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
57.786 1927.00000 15.4000 -44.53125 0.00000 1.24100 1.24100 12.20000 0.27100 1.06200 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
57.796 1916.00000 15.2000 -44.53125 0.00000 1.63200 1.63200 13.50000 0.27100 1.06200 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
57.806 1916.00000 15.2000 -44.53125 0.00000 1.63200 1.63200 13.50000 0.27100 1.06200 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
57.816 1916.00000 15.2000 -44.53125 0.00000 1.63200 1.63200 13.50000 0.27100 1.06200 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
57.826 1916.00000 15.2000 -44.53125 0.00000 1.63200 1.63200 13.50000 0.27100 1.06200 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
57.836 1916.00000 15.2000 -44.53125 0.00000 1.63200 1.63200 13.50000 0.27100 1.06200 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
57.846 1945.00000 15.2000 -44.53125 0.00000 1.64900 1.64900 13.50000 0.27100 1.06200 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
57.856 1945.00000 15.2000 -44.53125 0.00000 1.64900 1.64900 13.50000 0.27100 1.06200 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
57.866 1945.00000 15.2000 -44.53125 0.00000 1.64900 1.64900 13.50000 0.27100 1.06200 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
57.876 1945.00000 15.2000 -44.53125 0.00000 1.64900 1.64900 13.50000 0.27100 1.06200 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
57.886 1945.00000 15.2000 -44.53125 0.00000 1.64900 1.64900 13.50000 0.27100 1.06200 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
57.896 1888.00000 15.1000 -44.53125 0.00000 1.92300 1.92300 13.20000 1.10100 0.93200 4.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 17.5000 0.000 0.000 0.000 0.000
57.906 1888.00000 15.1000 -44.53125 0.00000 1.92300 1.92300 13.20000 1.10100 0.93200 4.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 17.5000 0.000 0.000 0.000 0.000
57.916 1888.00000 15.1000 -44.53125 0.00000 1.92300 1.92300 13.20000 1.10100 0.93200 4.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 17.5000 0.000 0.000 0.000 0.000
57.926 1888.00000 15.1000 -44.53125 0.00000 1.92300 1.92300 13.20000 1.10100 0.93200 4.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 17.5000 0.000 0.000 0.000 0.000
57.936 1888.00000 15.1000 -44.53125 0.00000 1.92300 1.92300 13.20000 1.10100 0.93200 4.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 17.5000 0.000 0.000 0.000 0.000
57.946 1871.00000 15.1000 -44.53125 0.00000 1.58500 1.58500 13.50000 1.10100 0.93200 4.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 17.6000 0.000 0.000 0.000 0.000
57.956 1871.00000 15.1000 -44.53125 0.00000 1.58500 1.58500 13.50000 1.10100 0.93200 4.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 17.6000 0.000 0.000 0.000 0.000
57.966 1871.00000 15.1000 -44.53125 0.00000 1.58500 1.58500 13.50000 1.10100 0.93200 4.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 17.6000 0.000 0.000 0.000 0.000
57.976 1871.00000 15.1000 -44.53125 0.00000 1.58500 1.58500 13.50000 1.10100 0.93200 4.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 17.6000 0.000 0.000 0.000 0.000
57.986 1871.00000 15.1000 -44.53125 0.00000 1.58500 1.58500 13.50000 1.10100 0.93200 4.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 17.6000 0.000 0.000 0.000 0.000
57.996 1831.00000 15.2000 -44.53125 0.00000 1.43400 1.43400 12.60000 1.10100 0.93200 4.20000 1.00000 3.00000 3.00000 2.00000 3.00000 0.00000 0.00000 13.4000 0.000 0.000 0.000 0.000
58.006 1831.00000 15.2000 -44.53125 0.00000 1.43400 1.43400 12.60000 1.10100 0.93200 4.20000 1.00000 3.00000 3.00000 2.00000 3.00000 0.00000 0.00000 13.4000 0.000 0.000 0.000 0.000
58.016 1831.00000 15.2000 -44.53125 0.00000 1.43400 1.43400 12.60000 1.10100 0.93200 4.20000 1.00000 3.00000 3.00000 2.00000 3.00000 0.00000 0.00000 13.4000 0.000 0.000 0.000 0.000
58.026 1831.00000 15.2000 -44.53125 0.00000 1.43400 1.43400 12.60000 1.10100 0.93200 4.20000 1.00000 3.00000 3.00000 2.00000 3.00000 0.00000 0.00000 13.4000 0.000 0.000 0.000 0.000
58.036 1831.00000 15.2000 -44.53125 0.00000 1.43400 1.43400 12.60000 1.10100 0.93200 4.20000 1.00000 3.00000 3.00000 2.00000 3.00000 0.00000 0.00000 13.4000 0.000 0.000 0.000 0.000
58.046 1831.00000 15.2000 -44.53125 0.00000 1.43400 1.43400 12.60000 1.10100 0.93200 4.20000 1.00000 3.00000 3.00000 2.00000 3.00000 0.00000 0.00000 13.4000 0.000 0.000 0.000 0.000
58.056 1831.00000 15.2000 -44.53125 0.00000 1.43400 1.43400 12.60000 1.10100 0.93200 4.20000 1.00000 3.00000 3.00000 2.00000 3.00000 0.00000 0.00000 13.4000 0.000 0.000 0.000 0.000
58.066 1831.00000 15.2000 -44.53125 0.00000 1.43400 1.43400 12.60000 1.10100 0.93200 4.20000 1.00000 3.00000 3.00000 2.00000 3.00000 0.00000 0.00000 13.4000 0.000 0.000 0.000 0.000
58.076 1831.00000 15.2000 -44.53125 0.00000 1.43400 1.43400 12.60000 1.10100 0.93200 4.20000 1.00000 3.00000 3.00000 2.00000 3.00000 0.00000 0.00000 13.4000 0.000 0.000 0.000 0.000
58.086 1831.00000 15.2000 -44.53125 0.00000 1.43400 1.43400 12.60000 1.10100 0.93200 4.20000 1.00000 3.00000 3.00000 2.00000 3.00000 0.00000 0.00000 13.4000 0.000 0.000 0.000 0.000
58.096 1808.00000 15.1000 -44.53125 0.00000 1.82400 1.82400 13.40000 1.12600 0.28700 4.00000 1.00000 3.00000 2.00000 2.00000 3.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
58.106 1808.00000 15.1000 -44.53125 0.00000 1.82400 1.82400 13.40000 1.12600 0.28700 4.00000 1.00000 3.00000 2.00000 2.00000 3.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
58.116 1808.00000 15.1000 -44.53125 0.00000 1.82400 1.82400 13.40000 1.12600 0.28700 4.00000 1.00000 3.00000 2.00000 2.00000 3.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
58.126 1808.00000 15.1000 -44.53125 0.00000 1.82400 1.82400 13.40000 1.12600 0.28700 4.00000 1.00000 3.00000 2.00000 2.00000 3.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
58.136 1808.00000 15.1000 -44.53125 0.00000 1.82400 1.82400 13.40000 1.12600 0.28700 4.00000 1.00000 3.00000 2.00000 2.00000 3.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
58.146 1787.00000 15.1000 -44.53125 0.00000 1.25900 1.25900 13.40000 1.12600 0.28700 4.10000 1.00000 3.00000 3.00000 2.00000 2.00000 0.00000 0.00000 13.4000 0.000 0.000 0.000 0.000
58.156 1787.00000 15.1000 -44.53125 0.00000 1.25900 1.25900 13.40000 1.12600 0.28700 4.10000 1.00000 3.00000 3.00000 2.00000 2.00000 0.00000 0.00000 13.4000 0.000 0.000 0.000 0.000
58.166 1787.00000 15.1000 -44.53125 0.00000 1.25900 1.25900 13.40000 1.12600 0.28700 4.10000 1.00000 3.00000 3.00000 2.00000 2.00000 0.00000 0.00000 13.4000 0.000 0.000 0.000 0.000
58.176 1787.00000 15.1000 -44.53125 0.00000 1.25900 1.25900 13.40000 1.12600 0.28700 4.10000 1.00000 3.00000 3.00000 2.00000 2.00000 0.00000 0.00000 13.4000 0.000 0.000 0.000 0.000
58.186 1787.00000 15.1000 -44.53125 0.00000 1.25900 1.25900 13.40000 1.12600 0.28700 4.10000 1.00000 3.00000 3.00000 2.00000 2.00000 0.00000 0.00000 13.4000 0.000 0.000 0.000 0.000
58.196 1794.00000 15.1000 -44.53125 0.00000 1.43900 1.43900 13.20000 1.12600 0.28700 4.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.8000 0.000 0.000 0.000 0.000
58.206 1794.00000 15.1000 -44.53125 0.00000 1.43900 1.43900 13.20000 1.12600 0.28700 4.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.8000 0.000 0.000 0.000 0.000
58.216 1794.00000 15.1000 -44.53125 0.00000 1.43900 1.43900 13.20000 1.12600 0.28700 4.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.8000 0.000 0.000 0.000 0.000
58.226 1794.00000 15.1000 -44.53125 0.00000 1.43900 1.43900 13.20000 1.12600 0.28700 4.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.8000 0.000 0.000 0.000 0.000
58.236 1794.00000 15.1000 -44.53125 0.00000 1.43900 1.43900 13.20000 1.12600 0.28700 4.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.8000 0.000 0.000 0.000 0.000
58.246 1724.00000 15.1000 -44.53125 0.00000 1.34600 1.34600 13.20000 1.12600 0.28700 4.10000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.8000 0.000 0.000 0.000 0.000
58.256 1724.00000 15.1000 -44.53125 0.00000 1.34600 1.34600 13.20000 1.12600 0.28700 4.10000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.8000 0.000 0.000 0.000 0.000
58.266 1724.00000 15.1000 -44.53125 0.00000 1.34600 1.34600 13.20000 1.12600 0.28700 4.10000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.8000 0.000 0.000 0.000 0.000
58.276 1724.00000 15.1000 -44.53125 0.00000 1.34600 1.34600 13.20000 1.12600 0.28700 4.10000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.8000 0.000 0.000 0.000 0.000
58.286 1724.00000 15.1000 -44.53125 0.00000 1.34600 1.34600 13.20000 1.12600 0.28700 4.10000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.8000 0.000 0.000 0.000 0.000
58.296 1681.00000 15.1000 -44.53125 0.00000 1.28800 1.28800 13.60000 1.13900 0.28400 4.10000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.8000 0.000 0.000 0.000 0.000
58.306 1681.00000 15.1000 -44.53125 0.00000 1.28800 1.28800 13.60000 1.13900 0.28400 4.10000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.8000 0.000 0.000 0.000 0.000
58.316 1681.00000 15.1000 -44.53125 0.00000 1.28800 1.28800 13.60000 1.13900 0.28400 4.10000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.8000 0.000 0.000 0.000 0.000
58.326 1681.00000 15.1000 -44.53125 0.00000 1.28800 1.28800 13.60000 1.13900 0.28400 4.10000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.8000 0.000 0.000 0.000 0.000
58.336 1681.00000 15.1000 -44.53125 0.00000 1.28800 1.28800 13.60000 1.13900 0.28400 4.10000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.8000 0.000 0.000 0.000 0.000
58.346 1681.00000 15.2000 -44.53125 0.00000 1.59700 1.59700 13.20000 1.13900 0.28400 4.10000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
58.356 1681.00000 15.2000 -44.53125 0.00000 1.59700 1.59700 13.20000 1.13900 0.28400 4.10000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
58.366 1681.00000 15.2000 -44.53125 0.00000 1.59700 1.59700 13.20000 1.13900 0.28400 4.10000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
58.376 1681.00000 15.2000 -44.53125 0.00000 1.59700 1.59700 13.20000 1.13900 0.28400 4.10000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
58.386 1681.00000 15.2000 -44.53125 0.00000 1.59700 1.59700 13.20000 1.13900 0.28400 4.10000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
58.396 1636.00000 15.2000 -44.53125 0.00000 1.07200 1.07200 13.30000 1.13900 0.28400 4.10000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
58.406 1636.00000 15.2000 -44.53125 0.00000 1.07200 1.07200 13.30000 1.13900 0.28400 4.10000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
58.416 1636.00000 15.2000 -44.53125 0.00000 1.07200 1.07200 13.30000 1.13900 0.28400 4.10000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
58.426 1636.00000 15.2000 -44.53125 0.00000 1.07200 1.07200 13.30000 1.13900 0.28400 4.10000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
58.436 1636.00000 15.2000 -44.53125 0.00000 1.07200 1.07200 13.30000 1.13900 0.28400 4.10000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
58.446 1567.00000 15.2000 -44.53125 0.00000 1.52700 1.52700 13.10000 1.13900 0.28400 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
58.456 1567.00000 15.2000 -44.53125 0.00000 1.52700 1.52700 13.10000 1.13900 0.28400 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
58.466 1567.00000 15.2000 -44.53125 0.00000 1.52700 1.52700 13.10000 1.13900 0.28400 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
58.476 1567.00000 15.2000 -44.53125 0.00000 1.52700 1.52700 13.10000 1.13900 0.28400 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
58.486 1567.00000 15.2000 -44.53125 0.00000 1.52700 1.52700 13.10000 1.13900 0.28400 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
58.496 1400.00000 15.1000 -44.53125 0.00000 1.79500 1.79500 13.60000 1.15800 0.31500 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.2000 0.000 0.000 0.000 0.000
58.506 1400.00000 15.1000 -44.53125 0.00000 1.79500 1.79500 13.60000 1.15800 0.31500 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.2000 0.000 0.000 0.000 0.000
58.516 1400.00000 15.1000 -44.53125 0.00000 1.79500 1.79500 13.60000 1.15800 0.31500 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.2000 0.000 0.000 0.000 0.000
58.526 1400.00000 15.1000 -44.53125 0.00000 1.79500 1.79500 13.60000 1.15800 0.31500 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.2000 0.000 0.000 0.000 0.000
58.536 1400.00000 15.1000 -44.53125 0.00000 1.79500 1.79500 13.60000 1.15800 0.31500 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.2000 0.000 0.000 0.000 0.000
58.546 1400.00000 15.1000 -44.53125 0.00000 1.56200 1.56200 13.30000 1.15800 0.31500 4.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
58.556 1400.00000 15.1000 -44.53125 0.00000 1.56200 1.56200 13.30000 1.15800 0.31500 4.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
58.566 1400.00000 15.1000 -44.53125 0.00000 1.56200 1.56200 13.30000 1.15800 0.31500 4.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
58.576 1400.00000 15.1000 -44.53125 0.00000 1.56200 1.56200 13.30000 1.15800 0.31500 4.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
58.586 1400.00000 15.1000 -44.53125 0.00000 1.56200 1.56200 13.30000 1.15800 0.31500 4.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
58.596 1268.00000 15.1000 -44.53125 0.00000 1.41600 1.41600 13.20000 1.15800 0.31500 4.70000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
58.606 1268.00000 15.1000 -44.53125 0.00000 1.41600 1.41600 13.20000 1.15800 0.31500 4.70000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
58.616 1268.00000 15.1000 -44.53125 0.00000 1.41600 1.41600 13.20000 1.15800 0.31500 4.70000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
58.626 1268.00000 15.1000 -44.53125 0.00000 1.41600 1.41600 13.20000 1.15800 0.31500 4.70000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
58.636 1268.00000 15.1000 -44.53125 0.00000 1.41600 1.41600 13.20000 1.15800 0.31500 4.70000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
58.646 1316.00000 15.1000 -44.53125 0.00000 1.47400 1.47400 13.30000 1.15800 0.31500 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.2000 0.000 0.000 0.000 0.000
58.656 1316.00000 15.1000 -44.53125 0.00000 1.47400 1.47400 13.30000 1.15800 0.31500 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.2000 0.000 0.000 0.000 0.000
58.666 1316.00000 15.1000 -44.53125 0.00000 1.47400 1.47400 13.30000 1.15800 0.31500 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.2000 0.000 0.000 0.000 0.000
58.676 1316.00000 15.1000 -44.53125 0.00000 1.47400 1.47400 13.30000 1.15800 0.31500 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.2000 0.000 0.000 0.000 0.000
58.686 1316.00000 15.1000 -44.53125 0.00000 1.47400 1.47400 13.30000 1.15800 0.31500 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.2000 0.000 0.000 0.000 0.000
58.696 1316.00000 15.2000 -44.53125 0.00000 1.42200 1.42200 13.10000 0.69200 0.34100 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
58.706 1316.00000 15.2000 -44.53125 0.00000 1.42200 1.42200 13.10000 0.69200 0.34100 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
58.716 1316.00000 15.2000 -44.53125 0.00000 1.42200 1.42200 13.10000 0.69200 0.34100 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
58.726 1316.00000 15.2000 -44.53125 0.00000 1.42200 1.42200 13.10000 0.69200 0.34100 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
58.736 1316.00000 15.2000 -44.53125 0.00000 1.42200 1.42200 13.10000 0.69200 0.34100 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
58.746 1279.00000 15.1000 -44.53125 0.00000 1.39300 1.39300 13.30000 0.69200 0.34100 4.80000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
58.756 1279.00000 15.1000 -44.53125 0.00000 1.39300 1.39300 13.30000 0.69200 0.34100 4.80000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
58.766 1279.00000 15.1000 -44.53125 0.00000 1.39300 1.39300 13.30000 0.69200 0.34100 4.80000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
58.776 1279.00000 15.1000 -44.53125 0.00000 1.39300 1.39300 13.30000 0.69200 0.34100 4.80000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
58.786 1279.00000 15.1000 -44.53125 0.00000 1.39300 1.39300 13.30000 0.69200 0.34100 4.80000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
58.796 1282.00000 15.1000 -44.53125 0.00000 1.39300 1.39300 13.10000 0.69200 0.34100 4.60000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.0000 0.000 0.000 0.000 0.000
58.806 1282.00000 15.1000 -44.53125 0.00000 1.39300 1.39300 13.10000 0.69200 0.34100 4.60000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.0000 0.000 0.000 0.000 0.000
58.816 1282.00000 15.1000 -44.53125 0.00000 1.39300 1.39300 13.10000 0.69200 0.34100 4.60000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.0000 0.000 0.000 0.000 0.000
58.826 1282.00000 15.1000 -44.53125 0.00000 1.39300 1.39300 13.10000 0.69200 0.34100 4.60000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.0000 0.000 0.000 0.000 0.000
58.836 1282.00000 15.1000 -44.53125 0.00000 1.39300 1.39300 13.10000 0.69200 0.34100 4.60000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.0000 0.000 0.000 0.000 0.000
58.846 1282.00000 15.4000 -44.53125 0.00000 1.34600 1.34600 12.20000 0.69200 0.34100 4.40000 1.00000 2.00000 3.00000 2.00000 2.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
58.856 1282.00000 15.4000 -44.53125 0.00000 1.34600 1.34600 12.20000 0.69200 0.34100 4.40000 1.00000 2.00000 3.00000 2.00000 2.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
58.866 1282.00000 15.4000 -44.53125 0.00000 1.34600 1.34600 12.20000 0.69200 0.34100 4.40000 1.00000 2.00000 3.00000 2.00000 2.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
58.876 1282.00000 15.4000 -44.53125 0.00000 1.34600 1.34600 12.20000 0.69200 0.34100 4.40000 1.00000 2.00000 3.00000 2.00000 2.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
58.886 1282.00000 15.4000 -44.53125 0.00000 1.34600 1.34600 12.20000 0.69200 0.34100 4.40000 1.00000 2.00000 3.00000 2.00000 2.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
58.896 1282.00000 15.1000 -44.53125 0.00000 1.31100 1.31100 13.20000 0.76200 0.59300 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
58.906 1282.00000 15.1000 -44.53125 0.00000 1.31100 1.31100 13.20000 0.76200 0.59300 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
58.916 1282.00000 15.1000 -44.53125 0.00000 1.31100 1.31100 13.20000 0.76200 0.59300 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
58.926 1282.00000 15.1000 -44.53125 0.00000 1.31100 1.31100 13.20000 0.76200 0.59300 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
58.936 1282.00000 15.1000 -44.53125 0.00000 1.31100 1.31100 13.20000 0.76200 0.59300 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
58.946 1239.00000 15.2000 -44.53125 0.00000 1.36400 1.36400 13.40000 0.76200 0.59300 4.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
58.956 1239.00000 15.2000 -44.53125 0.00000 1.36400 1.36400 13.40000 0.76200 0.59300 4.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
58.966 1239.00000 15.2000 -44.53125 0.00000 1.36400 1.36400 13.40000 0.76200 0.59300 4.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
58.976 1239.00000 15.2000 -44.53125 0.00000 1.36400 1.36400 13.40000 0.76200 0.59300 4.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
58.986 1239.00000 15.2000 -44.53125 0.00000 1.36400 1.36400 13.40000 0.76200 0.59300 4.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
58.996 1239.00000 15.2000 -44.53125 0.00000 1.37000 1.37000 13.40000 0.76200 0.59300 4.70000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 16.0000 0.000 0.000 0.000 0.000
59.006 1239.00000 15.2000 -44.53125 0.00000 1.37000 1.37000 13.40000 0.76200 0.59300 4.70000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 16.0000 0.000 0.000 0.000 0.000
59.016 1239.00000 15.2000 -44.53125 0.00000 1.37000 1.37000 13.40000 0.76200 0.59300 4.70000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 16.0000 0.000 0.000 0.000 0.000
59.026 1239.00000 15.2000 -44.53125 0.00000 1.37000 1.37000 13.40000 0.76200 0.59300 4.70000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 16.0000 0.000 0.000 0.000 0.000
59.036 1239.00000 15.2000 -44.53125 0.00000 1.37000 1.37000 13.40000 0.76200 0.59300 4.70000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 16.0000 0.000 0.000 0.000 0.000
59.046 1042.00000 15.2000 -44.53125 0.00000 1.38700 1.38700 12.50000 0.76200 0.59300 4.70000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 16.2000 0.000 0.000 0.000 0.000
59.056 1042.00000 15.2000 -44.53125 0.00000 1.38700 1.38700 12.50000 0.76200 0.59300 4.70000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 16.2000 0.000 0.000 0.000 0.000
59.066 1042.00000 15.2000 -44.53125 0.00000 1.38700 1.38700 12.50000 0.76200 0.59300 4.70000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 16.2000 0.000 0.000 0.000 0.000
59.076 1042.00000 15.2000 -44.53125 0.00000 1.38700 1.38700 12.50000 0.76200 0.59300 4.70000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 16.2000 0.000 0.000 0.000 0.000
59.086 1042.00000 15.2000 -44.53125 0.00000 1.38700 1.38700 12.50000 0.76200 0.59300 4.70000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 16.2000 0.000 0.000 0.000 0.000
59.096 1042.00000 15.1000 -44.53125 0.00000 1.27600 1.27600 13.30000 1.14200 1.03000 5.10000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 16.1000 0.000 0.000 0.000 0.000
59.106 1042.00000 15.1000 -44.53125 0.00000 1.27600 1.27600 13.30000 1.14200 1.03000 5.10000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 16.1000 0.000 0.000 0.000 0.000
59.116 1042.00000 15.1000 -44.53125 0.00000 1.27600 1.27600 13.30000 1.14200 1.03000 5.10000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 16.1000 0.000 0.000 0.000 0.000
59.126 1042.00000 15.1000 -44.53125 0.00000 1.27600 1.27600 13.30000 1.14200 1.03000 5.10000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 16.1000 0.000 0.000 0.000 0.000
59.136 1042.00000 15.1000 -44.53125 0.00000 1.27600 1.27600 13.30000 1.14200 1.03000 5.10000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 16.1000 0.000 0.000 0.000 0.000
59.146 908.00000 15.1000 -44.53125 0.00000 1.22400 1.22400 13.30000 1.14200 1.03000 5.20000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 14.0000 0.000 0.000 0.000 0.000
59.156 908.00000 15.1000 -44.53125 0.00000 1.22400 1.22400 13.30000 1.14200 1.03000 5.20000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 14.0000 0.000 0.000 0.000 0.000
59.166 908.00000 15.1000 -44.53125 0.00000 1.22400 1.22400 13.30000 1.14200 1.03000 5.20000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 14.0000 0.000 0.000 0.000 0.000
59.176 908.00000 15.1000 -44.53125 0.00000 1.22400 1.22400 13.30000 1.14200 1.03000 5.20000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 14.0000 0.000 0.000 0.000 0.000
59.186 908.00000 15.1000 -44.53125 0.00000 1.22400 1.22400 13.30000 1.14200 1.03000 5.20000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 14.0000 0.000 0.000 0.000 0.000
59.196 908.00000 15.1000 -44.53125 0.00000 1.07200 1.07200 13.30000 1.14200 1.03000 5.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
59.206 908.00000 15.1000 -44.53125 0.00000 1.07200 1.07200 13.30000 1.14200 1.03000 5.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
59.216 908.00000 15.1000 -44.53125 0.00000 1.07200 1.07200 13.30000 1.14200 1.03000 5.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
59.226 908.00000 15.1000 -44.53125 0.00000 1.07200 1.07200 13.30000 1.14200 1.03000 5.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
59.236 908.00000 15.1000 -44.53125 0.00000 1.07200 1.07200 13.30000 1.14200 1.03000 5.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
59.246 908.00000 15.1000 -44.53125 0.00000 0.95600 0.95600 12.90000 1.14200 1.03000 5.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
59.256 908.00000 15.1000 -44.53125 0.00000 0.95600 0.95600 12.90000 1.14200 1.03000 5.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
59.266 908.00000 15.1000 -44.53125 0.00000 0.95600 0.95600 12.90000 1.14200 1.03000 5.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
59.276 908.00000 15.1000 -44.53125 0.00000 0.95600 0.95600 12.90000 1.14200 1.03000 5.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
59.286 908.00000 15.1000 -44.53125 0.00000 0.95600 0.95600 12.90000 1.14200 1.03000 5.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
59.296 794.00000 15.2000 -44.53125 0.00000 0.97900 0.97900 12.70000 1.09100 1.05900 5.90000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.7000 0.000 0.000 0.000 0.000
59.306 794.00000 15.2000 -44.53125 0.00000 0.97900 0.97900 12.70000 1.09100 1.05900 5.90000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.7000 0.000 0.000 0.000 0.000
59.316 794.00000 15.2000 -44.53125 0.00000 0.97900 0.97900 12.70000 1.09100 1.05900 5.90000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.7000 0.000 0.000 0.000 0.000
59.326 794.00000 15.2000 -44.53125 0.00000 0.97900 0.97900 12.70000 1.09100 1.05900 5.90000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.7000 0.000 0.000 0.000 0.000
59.336 794.00000 15.2000 -44.53125 0.00000 0.97900 0.97900 12.70000 1.09100 1.05900 5.90000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.7000 0.000 0.000 0.000 0.000
59.346 794.00000 15.2000 -44.53125 0.00000 0.97300 0.97300 12.60000 1.09100 1.05900 6.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.7000 0.000 0.000 0.000 0.000
59.356 794.00000 15.2000 -44.53125 0.00000 0.97300 0.97300 12.60000 1.09100 1.05900 6.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.7000 0.000 0.000 0.000 0.000
59.366 794.00000 15.2000 -44.53125 0.00000 0.97300 0.97300 12.60000 1.09100 1.05900 6.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.7000 0.000 0.000 0.000 0.000
59.376 794.00000 15.2000 -44.53125 0.00000 0.97300 0.97300 12.60000 1.09100 1.05900 6.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.7000 0.000 0.000 0.000 0.000
59.386 794.00000 15.2000 -44.53125 0.00000 0.97300 0.97300 12.60000 1.09100 1.05900 6.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.7000 0.000 0.000 0.000 0.000
59.396 794.00000 15.2000 -44.53125 0.00000 0.92100 0.92100 12.10000 1.09100 1.05900 6.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.9000 0.000 0.000 0.000 0.000
59.406 794.00000 15.2000 -44.53125 0.00000 0.92100 0.92100 12.10000 1.09100 1.05900 6.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.9000 0.000 0.000 0.000 0.000
59.416 794.00000 15.2000 -44.53125 0.00000 0.92100 0.92100 12.10000 1.09100 1.05900 6.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.9000 0.000 0.000 0.000 0.000
59.426 794.00000 15.2000 -44.53125 0.00000 0.92100 0.92100 12.10000 1.09100 1.05900 6.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.9000 0.000 0.000 0.000 0.000
59.436 794.00000 15.2000 -44.53125 0.00000 0.92100 0.92100 12.10000 1.09100 1.05900 6.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.9000 0.000 0.000 0.000 0.000
59.446 661.00000 15.1000 -44.53125 0.00000 0.92100 0.92100 12.40000 1.09100 1.05900 6.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
59.456 661.00000 15.1000 -44.53125 0.00000 0.92100 0.92100 12.40000 1.09100 1.05900 6.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
59.466 661.00000 15.1000 -44.53125 0.00000 0.92100 0.92100 12.40000 1.09100 1.05900 6.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
59.476 661.00000 15.1000 -44.53125 0.00000 0.92100 0.92100 12.40000 1.09100 1.05900 6.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
59.486 661.00000 15.1000 -44.53125 0.00000 0.92100 0.92100 12.40000 1.09100 1.05900 6.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
59.496 661.00000 15.2000 -44.53125 0.00000 0.98500 0.98500 11.70000 1.13900 1.05600 6.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
59.506 661.00000 15.2000 -44.53125 0.00000 0.98500 0.98500 11.70000 1.13900 1.05600 6.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
59.516 661.00000 15.2000 -44.53125 0.00000 0.98500 0.98500 11.70000 1.13900 1.05600 6.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
59.526 661.00000 15.2000 -44.53125 0.00000 0.98500 0.98500 11.70000 1.13900 1.05600 6.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
59.536 661.00000 15.2000 -44.53125 0.00000 0.98500 0.98500 11.70000 1.13900 1.05600 6.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
59.546 727.00000 15.2000 -44.53125 0.00000 1.00800 1.00800 12.80000 1.13900 1.05600 6.90000 1.00000 1.00000 1.00000 1.00000 2.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
59.556 727.00000 15.2000 -44.53125 0.00000 1.00800 1.00800 12.80000 1.13900 1.05600 6.90000 1.00000 1.00000 1.00000 1.00000 2.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
59.566 727.00000 15.2000 -44.53125 0.00000 1.00800 1.00800 12.80000 1.13900 1.05600 6.90000 1.00000 1.00000 1.00000 1.00000 2.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
59.576 727.00000 15.2000 -44.53125 0.00000 1.00800 1.00800 12.80000 1.13900 1.05600 6.90000 1.00000 1.00000 1.00000 1.00000 2.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
59.586 727.00000 15.2000 -44.53125 0.00000 1.00800 1.00800 12.80000 1.13900 1.05600 6.90000 1.00000 1.00000 1.00000 1.00000 2.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
59.596 727.00000 15.1000 -44.53125 0.00000 0.89700 0.89700 13.10000 1.13900 1.05600 6.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
59.606 727.00000 15.1000 -44.53125 0.00000 0.89700 0.89700 13.10000 1.13900 1.05600 6.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
59.616 727.00000 15.1000 -44.53125 0.00000 0.89700 0.89700 13.10000 1.13900 1.05600 6.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
59.626 727.00000 15.1000 -44.53125 0.00000 0.89700 0.89700 13.10000 1.13900 1.05600 6.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
59.636 727.00000 15.1000 -44.53125 0.00000 0.89700 0.89700 13.10000 1.13900 1.05600 6.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
59.646 727.00000 15.1000 -44.53125 0.00000 0.97900 0.97900 13.00000 1.13900 1.05600 6.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
59.656 727.00000 15.1000 -44.53125 0.00000 0.97900 0.97900 13.00000 1.13900 1.05600 6.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
59.666 727.00000 15.1000 -44.53125 0.00000 0.97900 0.97900 13.00000 1.13900 1.05600 6.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
59.676 727.00000 15.1000 -44.53125 0.00000 0.97900 0.97900 13.00000 1.13900 1.05600 6.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
59.686 727.00000 15.1000 -44.53125 0.00000 0.97900 0.97900 13.00000 1.13900 1.05600 6.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
59.696 863.00000 15.1000 -44.53125 0.00000 0.90900 0.90900 13.40000 1.17700 1.05900 5.90000 1.00000 2.00000 2.00000 1.00000 2.00000 0.00000 0.00000 11.7000 0.000 0.000 0.000 0.000
59.706 863.00000 15.1000 -44.53125 0.00000 0.90900 0.90900 13.40000 1.17700 1.05900 5.90000 1.00000 2.00000 2.00000 1.00000 2.00000 0.00000 0.00000 11.7000 0.000 0.000 0.000 0.000
59.716 863.00000 15.1000 -44.53125 0.00000 0.90900 0.90900 13.40000 1.17700 1.05900 5.90000 1.00000 2.00000 2.00000 1.00000 2.00000 0.00000 0.00000 11.7000 0.000 0.000 0.000 0.000
59.726 863.00000 15.1000 -44.53125 0.00000 0.90900 0.90900 13.40000 1.17700 1.05900 5.90000 1.00000 2.00000 2.00000 1.00000 2.00000 0.00000 0.00000 11.7000 0.000 0.000 0.000 0.000
59.736 863.00000 15.1000 -44.53125 0.00000 0.90900 0.90900 13.40000 1.17700 1.05900 5.90000 1.00000 2.00000 2.00000 1.00000 2.00000 0.00000 0.00000 11.7000 0.000 0.000 0.000 0.000
59.746 863.00000 15.1000 -44.53125 0.00000 0.91500 0.91500 13.00000 1.17700 1.05900 5.50000 1.00000 2.00000 1.00000 1.00000 1.00000 0.00000 0.00000 10.6000 0.000 0.000 0.000 0.000
59.756 863.00000 15.1000 -44.53125 0.00000 0.91500 0.91500 13.00000 1.17700 1.05900 5.50000 1.00000 2.00000 1.00000 1.00000 1.00000 0.00000 0.00000 10.6000 0.000 0.000 0.000 0.000
59.766 863.00000 15.1000 -44.53125 0.00000 0.91500 0.91500 13.00000 1.17700 1.05900 5.50000 1.00000 2.00000 1.00000 1.00000 1.00000 0.00000 0.00000 10.6000 0.000 0.000 0.000 0.000
59.776 863.00000 15.1000 -44.53125 0.00000 0.91500 0.91500 13.00000 1.17700 1.05900 5.50000 1.00000 2.00000 1.00000 1.00000 1.00000 0.00000 0.00000 10.6000 0.000 0.000 0.000 0.000
59.786 863.00000 15.1000 -44.53125 0.00000 0.91500 0.91500 13.00000 1.17700 1.05900 5.50000 1.00000 2.00000 1.00000 1.00000 1.00000 0.00000 0.00000 10.6000 0.000 0.000 0.000 0.000
59.796 1011.00000 15.1000 -44.53125 0.00000 0.88600 0.88600 13.60000 1.17700 1.05900 5.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.7000 0.000 0.000 0.000 0.000
59.806 1011.00000 15.1000 -44.53125 0.00000 0.88600 0.88600 13.60000 1.17700 1.05900 5.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.7000 0.000 0.000 0.000 0.000
59.816 1011.00000 15.1000 -44.53125 0.00000 0.88600 0.88600 13.60000 1.17700 1.05900 5.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.7000 0.000 0.000 0.000 0.000
59.826 1011.00000 15.1000 -44.53125 0.00000 0.88600 0.88600 13.60000 1.17700 1.05900 5.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.7000 0.000 0.000 0.000 0.000
59.836 1011.00000 15.1000 -44.53125 0.00000 0.88600 0.88600 13.60000 1.17700 1.05900 5.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.7000 0.000 0.000 0.000 0.000
59.846 1098.00000 15.1000 -44.53125 0.00000 0.83900 0.83900 13.40000 1.17700 1.05900 5.00000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.7000 0.000 0.000 0.000 0.000
59.856 1098.00000 15.1000 -44.53125 0.00000 0.83900 0.83900 13.40000 1.17700 1.05900 5.00000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.7000 0.000 0.000 0.000 0.000
59.866 1098.00000 15.1000 -44.53125 0.00000 0.83900 0.83900 13.40000 1.17700 1.05900 5.00000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.7000 0.000 0.000 0.000 0.000
59.876 1098.00000 15.1000 -44.53125 0.00000 0.83900 0.83900 13.40000 1.17700 1.05900 5.00000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.7000 0.000 0.000 0.000 0.000
59.886 1098.00000 15.1000 -44.53125 0.00000 0.83900 0.83900 13.40000 1.17700 1.05900 5.00000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.7000 0.000 0.000 0.000 0.000
59.896 1098.00000 15.1000 -44.53125 0.00000 0.94400 0.94400 12.70000 1.16800 1.09400 4.80000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.5000 0.000 0.000 0.000 0.000
59.906 1098.00000 15.1000 -44.53125 0.00000 0.94400 0.94400 12.70000 1.16800 1.09400 4.80000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.5000 0.000 0.000 0.000 0.000
59.916 1098.00000 15.1000 -44.53125 0.00000 0.94400 0.94400 12.70000 1.16800 1.09400 4.80000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.5000 0.000 0.000 0.000 0.000
59.926 1098.00000 15.1000 -44.53125 0.00000 0.94400 0.94400 12.70000 1.16800 1.09400 4.80000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.5000 0.000 0.000 0.000 0.000
59.936 1098.00000 15.1000 -44.53125 0.00000 0.94400 0.94400 12.70000 1.16800 1.09400 4.80000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.5000 0.000 0.000 0.000 0.000
59.946 1172.00000 15.1000 -44.53125 0.00000 0.96700 0.96700 13.20000 1.16800 1.09400 4.60000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.6000 0.000 0.000 0.000 0.000
59.956 1172.00000 15.1000 -44.53125 0.00000 0.96700 0.96700 13.20000 1.16800 1.09400 4.60000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.6000 0.000 0.000 0.000 0.000
59.966 1172.00000 15.1000 -44.53125 0.00000 0.96700 0.96700 13.20000 1.16800 1.09400 4.60000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.6000 0.000 0.000 0.000 0.000
59.976 1172.00000 15.1000 -44.53125 0.00000 0.96700 0.96700 13.20000 1.16800 1.09400 4.60000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.6000 0.000 0.000 0.000 0.000
59.986 1172.00000 15.1000 -44.53125 0.00000 0.96700 0.96700 13.20000 1.16800 1.09400 4.60000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.6000 0.000 0.000 0.000 0.000
59.996 1172.00000 15.1000 -44.53125 0.00000 1.00200 1.00200 13.10000 1.16800 1.09400 4.60000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.6000 0.000 0.000 0.000 0.000
60.006 1172.00000 15.1000 -44.53125 0.00000 1.00200 1.00200 13.10000 1.16800 1.09400 4.60000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.6000 0.000 0.000 0.000 0.000
60.016 1172.00000 15.1000 -44.53125 0.00000 1.00200 1.00200 13.10000 1.16800 1.09400 4.60000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.6000 0.000 0.000 0.000 0.000
60.026 1172.00000 15.1000 -44.53125 0.00000 1.00200 1.00200 13.10000 1.16800 1.09400 4.60000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.6000 0.000 0.000 0.000 0.000
60.036 1172.00000 15.1000 -44.53125 0.00000 1.00200 1.00200 13.10000 1.16800 1.09400 4.60000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.6000 0.000 0.000 0.000 0.000
60.046 1198.00000 15.2000 -44.53125 0.00000 1.03700 1.03700 13.40000 1.16800 1.09400 4.80000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.5000 0.000 0.000 0.000 0.000
60.056 1198.00000 15.2000 -44.53125 0.00000 1.03700 1.03700 13.40000 1.16800 1.09400 4.80000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.5000 0.000 0.000 0.000 0.000
60.066 1198.00000 15.2000 -44.53125 0.00000 1.03700 1.03700 13.40000 1.16800 1.09400 4.80000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.5000 0.000 0.000 0.000 0.000
60.076 1198.00000 15.2000 -44.53125 0.00000 1.03700 1.03700 13.40000 1.16800 1.09400 4.80000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.5000 0.000 0.000 0.000 0.000
60.086 1198.00000 15.2000 -44.53125 0.00000 1.03700 1.03700 13.40000 1.16800 1.09400 4.80000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.5000 0.000 0.000 0.000 0.000
60.096 1233.00000 15.1000 -44.53125 0.00000 1.11900 1.11900 13.20000 1.13900 1.11700 4.70000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
60.106 1233.00000 15.1000 -44.53125 0.00000 1.11900 1.11900 13.20000 1.13900 1.11700 4.70000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
60.116 1233.00000 15.1000 -44.53125 0.00000 1.11900 1.11900 13.20000 1.13900 1.11700 4.70000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
60.126 1233.00000 15.1000 -44.53125 0.00000 1.11900 1.11900 13.20000 1.13900 1.11700 4.70000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
60.136 1233.00000 15.1000 -44.53125 0.00000 1.11900 1.11900 13.20000 1.13900 1.11700 4.70000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
60.146 1233.00000 15.2000 -44.53125 0.00000 1.20000 1.20000 13.50000 1.13900 1.11700 4.60000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.3000 0.000 0.000 0.000 0.000
60.156 1233.00000 15.2000 -44.53125 0.00000 1.20000 1.20000 13.50000 1.13900 1.11700 4.60000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.3000 0.000 0.000 0.000 0.000
60.166 1233.00000 15.2000 -44.53125 0.00000 1.20000 1.20000 13.50000 1.13900 1.11700 4.60000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.3000 0.000 0.000 0.000 0.000
60.176 1233.00000 15.2000 -44.53125 0.00000 1.20000 1.20000 13.50000 1.13900 1.11700 4.60000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.3000 0.000 0.000 0.000 0.000
60.186 1233.00000 15.2000 -44.53125 0.00000 1.20000 1.20000 13.50000 1.13900 1.11700 4.60000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.3000 0.000 0.000 0.000 0.000
60.196 1201.00000 15.1000 -44.53125 0.00000 1.21800 1.21800 13.20000 1.13900 1.11700 4.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.5000 0.000 0.000 0.000 0.000
60.206 1201.00000 15.1000 -44.53125 0.00000 1.21800 1.21800 13.20000 1.13900 1.11700 4.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.5000 0.000 0.000 0.000 0.000
60.216 1201.00000 15.1000 -44.53125 0.00000 1.21800 1.21800 13.20000 1.13900 1.11700 4.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.5000 0.000 0.000 0.000 0.000
60.226 1201.00000 15.1000 -44.53125 0.00000 1.21800 1.21800 13.20000 1.13900 1.11700 4.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.5000 0.000 0.000 0.000 0.000
60.236 1201.00000 15.1000 -44.53125 0.00000 1.21800 1.21800 13.20000 1.13900 1.11700 4.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.5000 0.000 0.000 0.000 0.000
60.246 1201.00000 15.1000 -44.53125 0.00000 1.23000 1.23000 13.00000 1.13900 1.11700 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
60.256 1201.00000 15.1000 -44.53125 0.00000 1.23000 1.23000 13.00000 1.13900 1.11700 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
60.266 1201.00000 15.1000 -44.53125 0.00000 1.23000 1.23000 13.00000 1.13900 1.11700 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
60.276 1201.00000 15.1000 -44.53125 0.00000 1.23000 1.23000 13.00000 1.13900 1.11700 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
60.286 1201.00000 15.1000 -44.53125 0.00000 1.23000 1.23000 13.00000 1.13900 1.11700 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
60.296 1195.00000 15.2000 -44.53125 0.00000 1.27600 1.27600 11.90000 1.08800 1.12900 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
60.306 1195.00000 15.2000 -44.53125 0.00000 1.27600 1.27600 11.90000 1.08800 1.12900 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
60.316 1195.00000 15.2000 -44.53125 0.00000 1.27600 1.27600 11.90000 1.08800 1.12900 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
60.326 1195.00000 15.2000 -44.53125 0.00000 1.27600 1.27600 11.90000 1.08800 1.12900 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
60.336 1195.00000 15.2000 -44.53125 0.00000 1.27600 1.27600 11.90000 1.08800 1.12900 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
60.346 1212.00000 15.1000 -44.53125 0.00000 1.31700 1.31700 13.20000 1.08800 1.12900 4.20000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
60.356 1212.00000 15.1000 -44.53125 0.00000 1.31700 1.31700 13.20000 1.08800 1.12900 4.20000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
60.366 1212.00000 15.1000 -44.53125 0.00000 1.31700 1.31700 13.20000 1.08800 1.12900 4.20000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
60.376 1212.00000 15.1000 -44.53125 0.00000 1.31700 1.31700 13.20000 1.08800 1.12900 4.20000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
60.386 1212.00000 15.1000 -44.53125 0.00000 1.31700 1.31700 13.20000 1.08800 1.12900 4.20000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
60.396 1212.00000 15.1000 -44.53125 0.00000 1.38700 1.38700 13.20000 1.08800 1.12900 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
60.406 1212.00000 15.1000 -44.53125 0.00000 1.38700 1.38700 13.20000 1.08800 1.12900 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
60.416 1212.00000 15.1000 -44.53125 0.00000 1.38700 1.38700 13.20000 1.08800 1.12900 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
60.426 1212.00000 15.1000 -44.53125 0.00000 1.38700 1.38700 13.20000 1.08800 1.12900 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
60.436 1212.00000 15.1000 -44.53125 0.00000 1.38700 1.38700 13.20000 1.08800 1.12900 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
60.446 1160.00000 15.1000 -44.53125 0.00000 1.26500 1.26500 13.30000 1.08800 1.12900 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
60.456 1160.00000 15.1000 -44.53125 0.00000 1.26500 1.26500 13.30000 1.08800 1.12900 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
60.466 1160.00000 15.1000 -44.53125 0.00000 1.26500 1.26500 13.30000 1.08800 1.12900 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
60.476 1160.00000 15.1000 -44.53125 0.00000 1.26500 1.26500 13.30000 1.08800 1.12900 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
60.486 1160.00000 15.1000 -44.53125 0.00000 1.26500 1.26500 13.30000 1.08800 1.12900 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
60.496 1160.00000 15.2000 -44.53125 0.00000 1.28800 1.28800 13.70000 1.08500 1.14200 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.4000 0.000 0.000 0.000 0.000
60.506 1160.00000 15.2000 -44.53125 0.00000 1.28800 1.28800 13.70000 1.08500 1.14200 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.4000 0.000 0.000 0.000 0.000
60.516 1160.00000 15.2000 -44.53125 0.00000 1.28800 1.28800 13.70000 1.08500 1.14200 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.4000 0.000 0.000 0.000 0.000
60.526 1160.00000 15.2000 -44.53125 0.00000 1.28800 1.28800 13.70000 1.08500 1.14200 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.4000 0.000 0.000 0.000 0.000
60.536 1160.00000 15.2000 -44.53125 0.00000 1.28800 1.28800 13.70000 1.08500 1.14200 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.4000 0.000 0.000 0.000 0.000
60.546 1106.00000 16.2000 -44.53125 0.00000 1.38700 1.38700 12.10000 1.08500 1.14200 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
60.556 1106.00000 16.2000 -44.53125 0.00000 1.38700 1.38700 12.10000 1.08500 1.14200 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
60.566 1106.00000 16.2000 -44.53125 0.00000 1.38700 1.38700 12.10000 1.08500 1.14200 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
60.576 1106.00000 16.2000 -44.53125 0.00000 1.38700 1.38700 12.10000 1.08500 1.14200 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
60.586 1106.00000 16.2000 -44.53125 0.00000 1.38700 1.38700 12.10000 1.08500 1.14200 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
60.596 1010.00000 16.3000 -44.53125 0.00000 1.32900 1.32900 13.00000 1.08500 1.14200 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
60.606 1010.00000 16.3000 -44.53125 0.00000 1.32900 1.32900 13.00000 1.08500 1.14200 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
60.616 1010.00000 16.3000 -44.53125 0.00000 1.32900 1.32900 13.00000 1.08500 1.14200 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
60.626 1010.00000 16.3000 -44.53125 0.00000 1.32900 1.32900 13.00000 1.08500 1.14200 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
60.636 1010.00000 16.3000 -44.53125 0.00000 1.32900 1.32900 13.00000 1.08500 1.14200 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
60.646 1010.00000 16.6000 -44.53125 0.00000 1.27000 1.27000 13.10000 1.08500 1.14200 5.00000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
60.656 1010.00000 16.6000 -44.53125 0.00000 1.27000 1.27000 13.10000 1.08500 1.14200 5.00000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
60.666 1010.00000 16.6000 -44.53125 0.00000 1.27000 1.27000 13.10000 1.08500 1.14200 5.00000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
60.676 1010.00000 16.6000 -44.53125 0.00000 1.27000 1.27000 13.10000 1.08500 1.14200 5.00000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
60.686 1010.00000 16.6000 -44.53125 0.00000 1.27000 1.27000 13.10000 1.08500 1.14200 5.00000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
60.696 1010.00000 16.6000 -44.53125 0.00000 1.27000 1.27000 13.10000 1.08500 1.14200 5.00000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
60.706 1010.00000 16.8000 -44.53125 0.00000 1.21800 1.21800 13.30000 1.13300 1.14900 5.10000 1.00000 1.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.8000 0.000 0.000 0.000 0.000
60.716 1010.00000 16.8000 -44.53125 0.00000 1.21800 1.21800 13.30000 1.13300 1.14900 5.10000 1.00000 1.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.8000 0.000 0.000 0.000 0.000
60.726 1010.00000 16.8000 -44.53125 0.00000 1.21800 1.21800 13.30000 1.13300 1.14900 5.10000 1.00000 1.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.8000 0.000 0.000 0.000 0.000
60.736 1010.00000 16.8000 -44.53125 0.00000 1.21800 1.21800 13.30000 1.13300 1.14900 5.10000 1.00000 1.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.8000 0.000 0.000 0.000 0.000
60.746 1010.00000 16.8000 -44.53125 0.00000 1.21800 1.21800 13.30000 1.13300 1.14900 5.10000 1.00000 1.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.8000 0.000 0.000 0.000 0.000
60.756 1010.00000 16.8000 -44.53125 0.00000 1.21800 1.21800 13.30000 1.13300 1.14900 5.10000 1.00000 1.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.8000 0.000 0.000 0.000 0.000
60.766 872.00000 16.5000 -44.53125 0.00000 1.04900 1.04900 13.10000 1.13300 1.14900 5.40000 1.00000 1.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
60.776 872.00000 16.5000 -44.53125 0.00000 1.04900 1.04900 13.10000 1.13300 1.14900 5.40000 1.00000 1.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
60.786 872.00000 16.5000 -44.53125 0.00000 1.04900 1.04900 13.10000 1.13300 1.14900 5.40000 1.00000 1.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
60.796 872.00000 16.5000 -44.53125 0.00000 1.04900 1.04900 13.10000 1.13300 1.14900 5.40000 1.00000 1.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
60.806 872.00000 16.5000 -44.53125 0.00000 1.04900 1.04900 13.10000 1.13300 1.14900 5.40000 1.00000 1.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
60.816 872.00000 16.5000 -44.53125 0.00000 1.04900 1.04900 13.10000 1.13300 1.14900 5.40000 1.00000 1.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
60.826 872.00000 16.3000 -44.53125 0.00000 1.01400 1.01400 12.90000 1.13300 1.14900 6.00000 1.00000 1.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.6000 0.000 0.000 0.000 0.000
60.836 872.00000 16.3000 -44.53125 0.00000 1.01400 1.01400 12.90000 1.13300 1.14900 6.00000 1.00000 1.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.6000 0.000 0.000 0.000 0.000
60.846 872.00000 16.3000 -44.53125 0.00000 1.01400 1.01400 12.90000 1.13300 1.14900 6.00000 1.00000 1.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.6000 0.000 0.000 0.000 0.000
60.856 872.00000 16.3000 -44.53125 0.00000 1.01400 1.01400 12.90000 1.13300 1.14900 6.00000 1.00000 1.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.6000 0.000 0.000 0.000 0.000
60.866 872.00000 16.3000 -44.53125 0.00000 1.01400 1.01400 12.90000 1.13300 1.14900 6.00000 1.00000 1.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.6000 0.000 0.000 0.000 0.000
60.876 715.00000 16.3000 -44.53125 0.00000 1.01400 1.01400 12.00000 1.13600 1.15500 6.70000 1.00000 1.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.6000 0.000 0.000 0.000 0.000
60.886 715.00000 16.3000 -44.53125 0.00000 1.01400 1.01400 12.00000 1.13600 1.15500 6.70000 1.00000 1.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.6000 0.000 0.000 0.000 0.000
60.896 715.00000 16.3000 -44.53125 0.00000 1.01400 1.01400 12.00000 1.13600 1.15500 6.70000 1.00000 1.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.6000 0.000 0.000 0.000 0.000
60.906 715.00000 16.3000 -44.53125 0.00000 1.01400 1.01400 12.00000 1.13600 1.15500 6.70000 1.00000 1.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.6000 0.000 0.000 0.000 0.000
60.916 715.00000 16.3000 -44.53125 0.00000 1.01400 1.01400 12.00000 1.13600 1.15500 6.70000 1.00000 1.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.6000 0.000 0.000 0.000 0.000
60.926 715.00000 16.0000 -44.53125 0.00000 0.99100 0.99100 12.80000 1.13600 1.15500 7.00000 1.00000 1.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.6000 0.000 0.000 0.000 0.000
60.936 715.00000 16.0000 -44.53125 0.00000 0.99100 0.99100 12.80000 1.13600 1.15500 7.00000 1.00000 1.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.6000 0.000 0.000 0.000 0.000
60.946 715.00000 16.0000 -44.53125 0.00000 0.99100 0.99100 12.80000 1.13600 1.15500 7.00000 1.00000 1.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.6000 0.000 0.000 0.000 0.000
60.956 715.00000 16.0000 -44.53125 0.00000 0.99100 0.99100 12.80000 1.13600 1.15500 7.00000 1.00000 1.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.6000 0.000 0.000 0.000 0.000
60.966 715.00000 16.0000 -44.53125 0.00000 0.99100 0.99100 12.80000 1.13600 1.15500 7.00000 1.00000 1.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.6000 0.000 0.000 0.000 0.000
60.976 715.00000 16.5000 -44.53125 0.00000 1.03100 1.03100 13.00000 1.13600 1.15500 6.80000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
60.986 715.00000 16.5000 -44.53125 0.00000 1.03100 1.03100 13.00000 1.13600 1.15500 6.80000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
60.996 715.00000 16.5000 -44.53125 0.00000 1.03100 1.03100 13.00000 1.13600 1.15500 6.80000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
61.006 715.00000 16.5000 -44.53125 0.00000 1.03100 1.03100 13.00000 1.13600 1.15500 6.80000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
61.016 715.00000 16.5000 -44.53125 0.00000 1.03100 1.03100 13.00000 1.13600 1.15500 6.80000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
61.026 669.00000 16.2000 -44.53125 0.00000 1.06100 1.06100 12.90000 1.13600 1.15500 7.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.8000 0.000 0.000 0.000 0.000
61.036 669.00000 16.2000 -44.53125 0.00000 1.06100 1.06100 12.90000 1.13600 1.15500 7.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.8000 0.000 0.000 0.000 0.000
61.046 669.00000 16.2000 -44.53125 0.00000 1.06100 1.06100 12.90000 1.13600 1.15500 7.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.8000 0.000 0.000 0.000 0.000
61.056 669.00000 16.2000 -44.53125 0.00000 1.06100 1.06100 12.90000 1.13600 1.15500 7.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.8000 0.000 0.000 0.000 0.000
61.066 669.00000 16.2000 -44.53125 0.00000 1.06100 1.06100 12.90000 1.13600 1.15500 7.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.8000 0.000 0.000 0.000 0.000
61.076 669.00000 16.2000 -44.53125 0.00000 1.06100 1.06100 12.90000 1.13600 1.15500 7.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.8000 0.000 0.000 0.000 0.000
61.086 669.00000 15.2000 -44.53125 0.00000 0.91500 0.91500 13.40000 1.13900 1.14900 6.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.9000 0.000 0.000 0.000 0.000
61.096 669.00000 15.2000 -44.53125 0.00000 0.91500 0.91500 13.40000 1.13900 1.14900 6.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.9000 0.000 0.000 0.000 0.000
61.106 669.00000 15.2000 -44.53125 0.00000 0.91500 0.91500 13.40000 1.13900 1.14900 6.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.9000 0.000 0.000 0.000 0.000
61.116 669.00000 15.2000 -44.53125 0.00000 0.91500 0.91500 13.40000 1.13900 1.14900 6.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.9000 0.000 0.000 0.000 0.000
61.126 669.00000 15.2000 -44.53125 0.00000 0.91500 0.91500 13.40000 1.13900 1.14900 6.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.9000 0.000 0.000 0.000 0.000
61.136 669.00000 15.2000 -44.53125 0.00000 0.91500 0.91500 13.40000 1.13900 1.14900 6.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.9000 0.000 0.000 0.000 0.000
61.146 920.00000 16.0000 -44.53125 0.00000 0.87400 0.87400 12.60000 1.13900 1.14900 5.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
61.156 920.00000 16.0000 -44.53125 0.00000 0.87400 0.87400 12.60000 1.13900 1.14900 5.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
61.166 920.00000 16.0000 -44.53125 0.00000 0.87400 0.87400 12.60000 1.13900 1.14900 5.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
61.176 920.00000 16.0000 -44.53125 0.00000 0.87400 0.87400 12.60000 1.13900 1.14900 5.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
61.186 920.00000 16.0000 -44.53125 0.00000 0.87400 0.87400 12.60000 1.13900 1.14900 5.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
61.196 920.00000 16.0000 -44.53125 0.00000 0.87400 0.87400 12.60000 1.13900 1.14900 5.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
61.206 1409.00000 16.0000 -44.53125 0.00000 0.94400 0.94400 13.40000 1.13900 1.14900 5.20000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.0000 0.000 0.000 0.000 0.000
61.216 1409.00000 16.0000 -44.53125 0.00000 0.94400 0.94400 13.40000 1.13900 1.14900 5.20000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.0000 0.000 0.000 0.000 0.000
61.226 1409.00000 16.0000 -44.53125 0.00000 0.94400 0.94400 13.40000 1.13900 1.14900 5.20000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.0000 0.000 0.000 0.000 0.000
61.236 1409.00000 16.0000 -44.53125 0.00000 0.94400 0.94400 13.40000 1.13900 1.14900 5.20000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.0000 0.000 0.000 0.000 0.000
61.246 1409.00000 16.0000 -44.53125 0.00000 0.94400 0.94400 13.40000 1.13900 1.14900 5.20000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.0000 0.000 0.000 0.000 0.000
61.256 1409.00000 16.0000 -44.53125 0.00000 0.94400 0.94400 13.40000 1.13900 1.14900 5.20000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.0000 0.000 0.000 0.000 0.000
61.266 1747.00000 16.9000 -44.53125 0.00000 1.07200 1.07200 13.10000 1.16800 1.14200 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
61.276 1747.00000 16.9000 -44.53125 0.00000 1.07200 1.07200 13.10000 1.16800 1.14200 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
61.286 1747.00000 16.9000 -44.53125 0.00000 1.07200 1.07200 13.10000 1.16800 1.14200 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
61.296 1747.00000 16.9000 -44.53125 0.00000 1.07200 1.07200 13.10000 1.16800 1.14200 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
61.306 1747.00000 16.9000 -44.53125 0.00000 1.07200 1.07200 13.10000 1.16800 1.14200 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
61.316 1973.00000 17.7000 -44.53125 0.00000 1.34000 1.34000 13.30000 1.16800 1.14200 4.20000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.7000 0.000 0.000 0.000 0.000
61.326 1973.00000 17.7000 -44.53125 0.00000 1.34000 1.34000 13.30000 1.16800 1.14200 4.20000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.7000 0.000 0.000 0.000 0.000
61.336 1973.00000 17.7000 -44.53125 0.00000 1.34000 1.34000 13.30000 1.16800 1.14200 4.20000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.7000 0.000 0.000 0.000 0.000
61.346 1973.00000 17.7000 -44.53125 0.00000 1.34000 1.34000 13.30000 1.16800 1.14200 4.20000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.7000 0.000 0.000 0.000 0.000
61.356 1973.00000 17.7000 -44.53125 0.00000 1.34000 1.34000 13.30000 1.16800 1.14200 4.20000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.7000 0.000 0.000 0.000 0.000
61.366 2024.00000 17.2000 -44.53125 0.00000 1.23000 1.23000 13.30000 1.16800 1.14200 4.40000 1.00000 3.00000 3.00000 3.00000 2.00000 0.00000 0.00000 10.8000 0.000 0.000 0.000 0.000
61.376 2024.00000 17.2000 -44.53125 0.00000 1.23000 1.23000 13.30000 1.16800 1.14200 4.40000 1.00000 3.00000 3.00000 3.00000 2.00000 0.00000 0.00000 10.8000 0.000 0.000 0.000 0.000
61.386 2024.00000 17.2000 -44.53125 0.00000 1.23000 1.23000 13.30000 1.16800 1.14200 4.40000 1.00000 3.00000 3.00000 3.00000 2.00000 0.00000 0.00000 10.8000 0.000 0.000 0.000 0.000
61.396 2024.00000 17.2000 -44.53125 0.00000 1.23000 1.23000 13.30000 1.16800 1.14200 4.40000 1.00000 3.00000 3.00000 3.00000 2.00000 0.00000 0.00000 10.8000 0.000 0.000 0.000 0.000
61.406 2024.00000 17.2000 -44.53125 0.00000 1.23000 1.23000 13.30000 1.16800 1.14200 4.40000 1.00000 3.00000 3.00000 3.00000 2.00000 0.00000 0.00000 10.8000 0.000 0.000 0.000 0.000
61.416 1899.00000 17.1000 -44.53125 0.00000 1.30500 1.30500 12.30000 1.16800 1.14200 4.40000 1.00000 3.00000 3.00000 2.00000 2.00000 0.00000 0.00000 10.7000 0.000 0.000 0.000 0.000
61.426 1899.00000 17.1000 -44.53125 0.00000 1.30500 1.30500 12.30000 1.16800 1.14200 4.40000 1.00000 3.00000 3.00000 2.00000 2.00000 0.00000 0.00000 10.7000 0.000 0.000 0.000 0.000
61.436 1899.00000 17.1000 -44.53125 0.00000 1.30500 1.30500 12.30000 1.16800 1.14200 4.40000 1.00000 3.00000 3.00000 2.00000 2.00000 0.00000 0.00000 10.7000 0.000 0.000 0.000 0.000
61.446 1899.00000 17.1000 -44.53125 0.00000 1.30500 1.30500 12.30000 1.16800 1.14200 4.40000 1.00000 3.00000 3.00000 2.00000 2.00000 0.00000 0.00000 10.7000 0.000 0.000 0.000 0.000
61.456 1899.00000 17.1000 -44.53125 0.00000 1.30500 1.30500 12.30000 1.16800 1.14200 4.40000 1.00000 3.00000 3.00000 2.00000 2.00000 0.00000 0.00000 10.7000 0.000 0.000 0.000 0.000
61.466 1868.00000 17.5000 -44.53125 0.00000 1.35200 1.35200 13.60000 1.11000 1.14200 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 11.4000 0.000 0.000 0.000 0.000
61.476 1868.00000 17.5000 -44.53125 0.00000 1.35200 1.35200 13.60000 1.11000 1.14200 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 11.4000 0.000 0.000 0.000 0.000
61.486 1868.00000 17.5000 -44.53125 0.00000 1.35200 1.35200 13.60000 1.11000 1.14200 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 11.4000 0.000 0.000 0.000 0.000
61.496 1868.00000 17.5000 -44.53125 0.00000 1.35200 1.35200 13.60000 1.11000 1.14200 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 11.4000 0.000 0.000 0.000 0.000
61.506 1868.00000 17.5000 -44.53125 0.00000 1.35200 1.35200 13.60000 1.11000 1.14200 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 11.4000 0.000 0.000 0.000 0.000
61.516 1868.00000 17.5000 -44.53125 0.00000 1.35200 1.35200 13.60000 1.11000 1.14200 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 11.4000 0.000 0.000 0.000 0.000
61.526 1868.00000 17.5000 -44.53125 0.00000 1.35200 1.35200 13.60000 1.11000 1.14200 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 11.4000 0.000 0.000 0.000 0.000
61.536 1868.00000 17.5000 -44.53125 0.00000 1.35200 1.35200 13.60000 1.11000 1.14200 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 11.4000 0.000 0.000 0.000 0.000
61.546 1868.00000 17.5000 -44.53125 0.00000 1.35200 1.35200 13.60000 1.11000 1.14200 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 11.4000 0.000 0.000 0.000 0.000
61.556 1868.00000 17.5000 -44.53125 0.00000 1.35200 1.35200 13.60000 1.11000 1.14200 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 11.4000 0.000 0.000 0.000 0.000
61.566 1868.00000 17.5000 -44.53125 0.00000 1.35200 1.35200 13.60000 1.11000 1.14200 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 11.4000 0.000 0.000 0.000 0.000
61.576 1868.00000 17.5000 -44.53125 0.00000 1.35200 1.35200 13.60000 1.11000 1.14200 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 11.4000 0.000 0.000 0.000 0.000
61.586 1868.00000 17.5000 -44.53125 0.00000 1.35200 1.35200 13.60000 1.11000 1.14200 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 11.4000 0.000 0.000 0.000 0.000
61.596 1868.00000 17.5000 -44.53125 0.00000 1.35200 1.35200 13.60000 1.11000 1.14200 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 11.4000 0.000 0.000 0.000 0.000
61.606 1868.00000 17.5000 -44.53125 0.00000 1.35200 1.35200 13.60000 1.11000 1.14200 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 11.4000 0.000 0.000 0.000 0.000
61.616 1883.00000 18.3000 -44.53125 0.00000 1.36400 1.36400 13.40000 1.11000 1.14200 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.8000 0.000 0.000 0.000 0.000
61.626 1883.00000 18.3000 -44.53125 0.00000 1.36400 1.36400 13.40000 1.11000 1.14200 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.8000 0.000 0.000 0.000 0.000
61.636 1883.00000 18.3000 -44.53125 0.00000 1.36400 1.36400 13.40000 1.11000 1.14200 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.8000 0.000 0.000 0.000 0.000
61.646 1883.00000 18.3000 -44.53125 0.00000 1.36400 1.36400 13.40000 1.11000 1.14200 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.8000 0.000 0.000 0.000 0.000
61.656 1883.00000 18.3000 -44.53125 0.00000 1.36400 1.36400 13.40000 1.11000 1.14200 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.8000 0.000 0.000 0.000 0.000
61.666 1899.00000 18.1000 -44.53125 0.00000 1.37500 1.37500 13.40000 1.05900 1.14500 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.8000 0.000 0.000 0.000 0.000
61.676 1899.00000 18.1000 -44.53125 0.00000 1.37500 1.37500 13.40000 1.05900 1.14500 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.8000 0.000 0.000 0.000 0.000
61.686 1899.00000 18.1000 -44.53125 0.00000 1.37500 1.37500 13.40000 1.05900 1.14500 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.8000 0.000 0.000 0.000 0.000
61.696 1899.00000 18.1000 -44.53125 0.00000 1.37500 1.37500 13.40000 1.05900 1.14500 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.8000 0.000 0.000 0.000 0.000
61.706 1899.00000 18.1000 -44.53125 0.00000 1.37500 1.37500 13.40000 1.05900 1.14500 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.8000 0.000 0.000 0.000 0.000
61.716 1948.00000 19.5000 -44.53125 0.00000 1.40400 1.40400 12.90000 1.05900 1.14500 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.8000 0.000 0.000 0.000 0.000
61.726 1948.00000 19.5000 -44.53125 0.00000 1.40400 1.40400 12.90000 1.05900 1.14500 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.8000 0.000 0.000 0.000 0.000
61.736 1948.00000 19.5000 -44.53125 0.00000 1.40400 1.40400 12.90000 1.05900 1.14500 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.8000 0.000 0.000 0.000 0.000
61.746 1948.00000 19.5000 -44.53125 0.00000 1.40400 1.40400 12.90000 1.05900 1.14500 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.8000 0.000 0.000 0.000 0.000
61.756 1948.00000 19.5000 -44.53125 0.00000 1.40400 1.40400 12.90000 1.05900 1.14500 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.8000 0.000 0.000 0.000 0.000
61.766 1862.00000 19.4000 -44.53125 0.00000 1.38100 1.38100 13.30000 1.05900 1.14500 4.60000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 13.8000 0.000 0.000 0.000 0.000
61.776 1862.00000 19.4000 -44.53125 0.00000 1.38100 1.38100 13.30000 1.05900 1.14500 4.60000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 13.8000 0.000 0.000 0.000 0.000
61.786 1862.00000 19.4000 -44.53125 0.00000 1.38100 1.38100 13.30000 1.05900 1.14500 4.60000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 13.8000 0.000 0.000 0.000 0.000
61.796 1862.00000 19.4000 -44.53125 0.00000 1.38100 1.38100 13.30000 1.05900 1.14500 4.60000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 13.8000 0.000 0.000 0.000 0.000
61.806 1862.00000 19.4000 -44.53125 0.00000 1.38100 1.38100 13.30000 1.05900 1.14500 4.60000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 13.8000 0.000 0.000 0.000 0.000
61.816 1804.00000 20.1000 -44.53125 0.00000 1.44500 1.44500 13.20000 1.05900 1.14500 4.70000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
61.826 1804.00000 20.1000 -44.53125 0.00000 1.44500 1.44500 13.20000 1.05900 1.14500 4.70000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
61.836 1804.00000 20.1000 -44.53125 0.00000 1.44500 1.44500 13.20000 1.05900 1.14500 4.70000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
61.846 1804.00000 20.1000 -44.53125 0.00000 1.44500 1.44500 13.20000 1.05900 1.14500 4.70000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
61.856 1804.00000 20.1000 -44.53125 0.00000 1.44500 1.44500 13.20000 1.05900 1.14500 4.70000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
61.866 1829.00000 21.3000 -44.53125 0.00000 1.55600 1.55600 13.20000 1.13600 1.14200 5.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
61.876 1829.00000 21.3000 -44.53125 0.00000 1.55600 1.55600 13.20000 1.13600 1.14200 5.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
61.886 1829.00000 21.3000 -44.53125 0.00000 1.55600 1.55600 13.20000 1.13600 1.14200 5.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
61.896 1829.00000 21.3000 -44.53125 0.00000 1.55600 1.55600 13.20000 1.13600 1.14200 5.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
61.906 1829.00000 21.3000 -44.53125 0.00000 1.55600 1.55600 13.20000 1.13600 1.14200 5.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
61.916 1916.00000 24.9000 -44.53125 0.00000 1.86500 1.86500 13.10000 1.13600 1.14200 6.10000 1.00000 4.00000 3.00000 2.00000 3.00000 0.00000 0.00000 13.2000 0.000 0.000 0.000 0.000
61.926 1916.00000 24.9000 -44.53125 0.00000 1.86500 1.86500 13.10000 1.13600 1.14200 6.10000 1.00000 4.00000 3.00000 2.00000 3.00000 0.00000 0.00000 13.2000 0.000 0.000 0.000 0.000
61.936 1916.00000 24.9000 -44.53125 0.00000 1.86500 1.86500 13.10000 1.13600 1.14200 6.10000 1.00000 4.00000 3.00000 2.00000 3.00000 0.00000 0.00000 13.2000 0.000 0.000 0.000 0.000
61.946 1916.00000 24.9000 -44.53125 0.00000 1.86500 1.86500 13.10000 1.13600 1.14200 6.10000 1.00000 4.00000 3.00000 2.00000 3.00000 0.00000 0.00000 13.2000 0.000 0.000 0.000 0.000
61.956 1916.00000 24.9000 -44.53125 0.00000 1.86500 1.86500 13.10000 1.13600 1.14200 6.10000 1.00000 4.00000 3.00000 2.00000 3.00000 0.00000 0.00000 13.2000 0.000 0.000 0.000 0.000
61.966 1890.00000 25.6000 -44.53125 0.00000 1.99300 1.99300 13.10000 1.13600 1.14200 7.10000 1.00000 4.00000 4.00000 2.00000 4.00000 0.00000 0.00000 13.1000 0.000 0.000 0.000 0.000
61.976 1890.00000 25.6000 -44.53125 0.00000 1.99300 1.99300 13.10000 1.13600 1.14200 7.10000 1.00000 4.00000 4.00000 2.00000 4.00000 0.00000 0.00000 13.1000 0.000 0.000 0.000 0.000
61.986 1890.00000 25.6000 -44.53125 0.00000 1.99300 1.99300 13.10000 1.13600 1.14200 7.10000 1.00000 4.00000 4.00000 2.00000 4.00000 0.00000 0.00000 13.1000 0.000 0.000 0.000 0.000
61.996 1890.00000 25.6000 -44.53125 0.00000 1.99300 1.99300 13.10000 1.13600 1.14200 7.10000 1.00000 4.00000 4.00000 2.00000 4.00000 0.00000 0.00000 13.1000 0.000 0.000 0.000 0.000
62.006 1890.00000 25.6000 -44.53125 0.00000 1.99300 1.99300 13.10000 1.13600 1.14200 7.10000 1.00000 4.00000 4.00000 2.00000 4.00000 0.00000 0.00000 13.1000 0.000 0.000 0.000 0.000
62.016 1849.00000 25.9000 -44.53125 0.00000 2.03400 2.03400 13.40000 1.13600 1.14200 8.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 13.1000 0.000 0.000 0.000 0.000
62.026 1849.00000 25.9000 -44.53125 0.00000 2.03400 2.03400 13.40000 1.13600 1.14200 8.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 13.1000 0.000 0.000 0.000 0.000
62.036 1849.00000 25.9000 -44.53125 0.00000 2.03400 2.03400 13.40000 1.13600 1.14200 8.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 13.1000 0.000 0.000 0.000 0.000
62.046 1849.00000 25.9000 -44.53125 0.00000 2.03400 2.03400 13.40000 1.13600 1.14200 8.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 13.1000 0.000 0.000 0.000 0.000
62.056 1849.00000 25.9000 -44.53125 0.00000 2.03400 2.03400 13.40000 1.13600 1.14200 8.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 13.1000 0.000 0.000 0.000 0.000
62.066 1846.00000 27.0000 -44.53125 0.00000 2.06900 2.06900 13.50000 1.08500 1.13300 9.30000 1.00000 4.00000 5.00000 4.00000 5.00000 0.00000 0.00000 13.1000 0.000 0.000 0.000 0.000
62.076 1846.00000 27.0000 -44.53125 0.00000 2.06900 2.06900 13.50000 1.08500 1.13300 9.30000 1.00000 4.00000 5.00000 4.00000 5.00000 0.00000 0.00000 13.1000 0.000 0.000 0.000 0.000
62.086 1846.00000 27.0000 -44.53125 0.00000 2.06900 2.06900 13.50000 1.08500 1.13300 9.30000 1.00000 4.00000 5.00000 4.00000 5.00000 0.00000 0.00000 13.1000 0.000 0.000 0.000 0.000
62.096 1846.00000 27.0000 -44.53125 0.00000 2.06900 2.06900 13.50000 1.08500 1.13300 9.30000 1.00000 4.00000 5.00000 4.00000 5.00000 0.00000 0.00000 13.1000 0.000 0.000 0.000 0.000
62.106 1846.00000 27.0000 -44.53125 0.00000 2.06900 2.06900 13.50000 1.08500 1.13300 9.30000 1.00000 4.00000 5.00000 4.00000 5.00000 0.00000 0.00000 13.1000 0.000 0.000 0.000 0.000
62.116 1911.00000 28.5000 -44.53125 0.00000 2.16800 2.16800 13.20000 1.08500 1.13300 9.40000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
62.126 1911.00000 28.5000 -44.53125 0.00000 2.16800 2.16800 13.20000 1.08500 1.13300 9.40000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
62.136 1911.00000 28.5000 -44.53125 0.00000 2.16800 2.16800 13.20000 1.08500 1.13300 9.40000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
62.146 1911.00000 28.5000 -44.53125 0.00000 2.16800 2.16800 13.20000 1.08500 1.13300 9.40000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
62.156 1911.00000 28.5000 -44.53125 0.00000 2.16800 2.16800 13.20000 1.08500 1.13300 9.40000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
62.166 1919.00000 30.8000 -44.53125 0.00000 2.35500 2.35500 13.30000 1.08500 1.13300 11.20000 1.00000 6.00000 5.00000 6.00000 6.00000 0.00000 0.00000 13.1000 0.000 0.000 0.000 0.000
62.176 1919.00000 30.8000 -44.53125 0.00000 2.35500 2.35500 13.30000 1.08500 1.13300 11.20000 1.00000 6.00000 5.00000 6.00000 6.00000 0.00000 0.00000 13.1000 0.000 0.000 0.000 0.000
62.186 1919.00000 30.8000 -44.53125 0.00000 2.35500 2.35500 13.30000 1.08500 1.13300 11.20000 1.00000 6.00000 5.00000 6.00000 6.00000 0.00000 0.00000 13.1000 0.000 0.000 0.000 0.000
62.196 1919.00000 30.8000 -44.53125 0.00000 2.35500 2.35500 13.30000 1.08500 1.13300 11.20000 1.00000 6.00000 5.00000 6.00000 6.00000 0.00000 0.00000 13.1000 0.000 0.000 0.000 0.000
62.206 1919.00000 30.8000 -44.53125 0.00000 2.35500 2.35500 13.30000 1.08500 1.13300 11.20000 1.00000 6.00000 5.00000 6.00000 6.00000 0.00000 0.00000 13.1000 0.000 0.000 0.000 0.000
62.216 1901.00000 32.2000 -44.53125 0.00000 2.36600 2.36600 12.60000 1.08500 1.13300 12.00000 1.00000 2.00000 6.00000 7.00000 6.00000 0.00000 0.00000 13.1000 0.000 0.000 0.000 0.000
62.226 1901.00000 32.2000 -44.53125 0.00000 2.36600 2.36600 12.60000 1.08500 1.13300 12.00000 1.00000 2.00000 6.00000 7.00000 6.00000 0.00000 0.00000 13.1000 0.000 0.000 0.000 0.000
62.236 1901.00000 32.2000 -44.53125 0.00000 2.36600 2.36600 12.60000 1.08500 1.13300 12.00000 1.00000 2.00000 6.00000 7.00000 6.00000 0.00000 0.00000 13.1000 0.000 0.000 0.000 0.000
62.246 1901.00000 32.2000 -44.53125 0.00000 2.36600 2.36600 12.60000 1.08500 1.13300 12.00000 1.00000 2.00000 6.00000 7.00000 6.00000 0.00000 0.00000 13.1000 0.000 0.000 0.000 0.000
62.256 1901.00000 32.2000 -44.53125 0.00000 2.36600 2.36600 12.60000 1.08500 1.13300 12.00000 1.00000 2.00000 6.00000 7.00000 6.00000 0.00000 0.00000 13.1000 0.000 0.000 0.000 0.000
62.266 1903.00000 33.1000 -44.53125 0.00000 2.33700 2.33700 13.00000 0.74600 1.11300 12.20000 1.00000 2.00000 7.00000 7.00000 2.00000 0.00000 0.00000 14.6000 0.000 0.000 0.000 0.000
62.276 1903.00000 33.1000 -44.53125 0.00000 2.33700 2.33700 13.00000 0.74600 1.11300 12.20000 1.00000 2.00000 7.00000 7.00000 2.00000 0.00000 0.00000 14.6000 0.000 0.000 0.000 0.000
62.286 1903.00000 33.1000 -44.53125 0.00000 2.33700 2.33700 13.00000 0.74600 1.11300 12.20000 1.00000 2.00000 7.00000 7.00000 2.00000 0.00000 0.00000 14.6000 0.000 0.000 0.000 0.000
62.296 1903.00000 33.1000 -44.53125 0.00000 2.33700 2.33700 13.00000 0.74600 1.11300 12.20000 1.00000 2.00000 7.00000 7.00000 2.00000 0.00000 0.00000 14.6000 0.000 0.000 0.000 0.000
62.306 1903.00000 33.1000 -44.53125 0.00000 2.33700 2.33700 13.00000 0.74600 1.11300 12.20000 1.00000 2.00000 7.00000 7.00000 2.00000 0.00000 0.00000 14.6000 0.000 0.000 0.000 0.000
62.316 1895.00000 35.6000 -44.53125 0.00000 2.36100 2.36100 13.40000 0.74600 1.11300 13.60000 1.00000 7.00000 7.00000 7.00000 6.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
62.326 1895.00000 35.6000 -44.53125 0.00000 2.36100 2.36100 13.40000 0.74600 1.11300 13.60000 1.00000 7.00000 7.00000 7.00000 6.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
62.336 1895.00000 35.6000 -44.53125 0.00000 2.36100 2.36100 13.40000 0.74600 1.11300 13.60000 1.00000 7.00000 7.00000 7.00000 6.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
62.346 1895.00000 35.6000 -44.53125 0.00000 2.36100 2.36100 13.40000 0.74600 1.11300 13.60000 1.00000 7.00000 7.00000 7.00000 6.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
62.356 1895.00000 35.6000 -44.53125 0.00000 2.36100 2.36100 13.40000 0.74600 1.11300 13.60000 1.00000 7.00000 7.00000 7.00000 6.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
62.366 1919.00000 38.8000 -44.53125 0.00000 2.55300 2.55300 13.60000 0.74600 1.11300 13.40000 1.00000 7.00000 7.00000 7.00000 2.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
62.376 1919.00000 38.8000 -44.53125 0.00000 2.55300 2.55300 13.60000 0.74600 1.11300 13.40000 1.00000 7.00000 7.00000 7.00000 2.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
62.386 1919.00000 38.8000 -44.53125 0.00000 2.55300 2.55300 13.60000 0.74600 1.11300 13.40000 1.00000 7.00000 7.00000 7.00000 2.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
62.396 1919.00000 38.8000 -44.53125 0.00000 2.55300 2.55300 13.60000 0.74600 1.11300 13.40000 1.00000 7.00000 7.00000 7.00000 2.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
62.406 1919.00000 38.8000 -44.53125 0.00000 2.55300 2.55300 13.60000 0.74600 1.11300 13.40000 1.00000 7.00000 7.00000 7.00000 2.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
62.416 1945.00000 40.5000 -44.53125 0.00000 2.41900 2.41900 13.60000 0.74600 1.11300 14.90000 1.00000 7.00000 8.00000 7.00000 7.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
62.426 1945.00000 40.5000 -44.53125 0.00000 2.41900 2.41900 13.60000 0.74600 1.11300 14.90000 1.00000 7.00000 8.00000 7.00000 7.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
62.436 1945.00000 40.5000 -44.53125 0.00000 2.41900 2.41900 13.60000 0.74600 1.11300 14.90000 1.00000 7.00000 8.00000 7.00000 7.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
62.446 1945.00000 40.5000 -44.53125 0.00000 2.41900 2.41900 13.60000 0.74600 1.11300 14.90000 1.00000 7.00000 8.00000 7.00000 7.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
62.456 1945.00000 40.5000 -44.53125 0.00000 2.41900 2.41900 13.60000 0.74600 1.11300 14.90000 1.00000 7.00000 8.00000 7.00000 7.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
62.466 1963.00000 40.6000 -44.53125 0.00000 2.48900 2.48900 12.70000 0.87100 1.05000 14.10000 1.00000 7.00000 8.00000 7.00000 7.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
62.476 1963.00000 40.6000 -44.53125 0.00000 2.48900 2.48900 12.70000 0.87100 1.05000 14.10000 1.00000 7.00000 8.00000 7.00000 7.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
62.486 1963.00000 40.6000 -44.53125 0.00000 2.48900 2.48900 12.70000 0.87100 1.05000 14.10000 1.00000 7.00000 8.00000 7.00000 7.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
62.496 1963.00000 40.6000 -44.53125 0.00000 2.48900 2.48900 12.70000 0.87100 1.05000 14.10000 1.00000 7.00000 8.00000 7.00000 7.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
62.506 1963.00000 40.6000 -44.53125 0.00000 2.48900 2.48900 12.70000 0.87100 1.05000 14.10000 1.00000 7.00000 8.00000 7.00000 7.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
62.516 1936.00000 40.8000 -44.53125 0.00000 2.40100 2.40100 13.30000 0.87100 1.05000 14.40000 1.00000 7.00000 7.00000 7.00000 7.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
62.526 1936.00000 40.8000 -44.53125 0.00000 2.40100 2.40100 13.30000 0.87100 1.05000 14.40000 1.00000 7.00000 7.00000 7.00000 7.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
62.536 1936.00000 40.8000 -44.53125 0.00000 2.40100 2.40100 13.30000 0.87100 1.05000 14.40000 1.00000 7.00000 7.00000 7.00000 7.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
62.546 1936.00000 40.8000 -44.53125 0.00000 2.40100 2.40100 13.30000 0.87100 1.05000 14.40000 1.00000 7.00000 7.00000 7.00000 7.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
62.556 1936.00000 40.8000 -44.53125 0.00000 2.40100 2.40100 13.30000 0.87100 1.05000 14.40000 1.00000 7.00000 7.00000 7.00000 7.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
62.566 1967.00000 40.3000 -44.53125 0.00000 2.44200 2.44200 12.80000 0.87100 1.05000 14.20000 1.00000 7.00000 7.00000 7.00000 7.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
62.576 1967.00000 40.3000 -44.53125 0.00000 2.44200 2.44200 12.80000 0.87100 1.05000 14.20000 1.00000 7.00000 7.00000 7.00000 7.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
62.586 1967.00000 40.3000 -44.53125 0.00000 2.44200 2.44200 12.80000 0.87100 1.05000 14.20000 1.00000 7.00000 7.00000 7.00000 7.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
62.596 1967.00000 40.3000 -44.53125 0.00000 2.44200 2.44200 12.80000 0.87100 1.05000 14.20000 1.00000 7.00000 7.00000 7.00000 7.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
62.606 1967.00000 40.3000 -44.53125 0.00000 2.44200 2.44200 12.80000 0.87100 1.05000 14.20000 1.00000 7.00000 7.00000 7.00000 7.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
62.616 1983.00000 40.3000 -44.53125 0.00000 2.43100 2.43100 13.20000 0.87100 1.05000 14.70000 1.00000 7.00000 7.00000 7.00000 7.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
62.626 1983.00000 40.3000 -44.53125 0.00000 2.43100 2.43100 13.20000 0.87100 1.05000 14.70000 1.00000 7.00000 7.00000 7.00000 7.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
62.635 1983.00000 40.3000 -44.53125 0.00000 2.43100 2.43100 13.20000 0.87100 1.05000 14.70000 1.00000 7.00000 7.00000 7.00000 7.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
62.645 1983.00000 40.3000 -44.53125 0.00000 2.43100 2.43100 13.20000 0.87100 1.05000 14.70000 1.00000 7.00000 7.00000 7.00000 7.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
62.655 1983.00000 40.3000 -44.53125 0.00000 2.43100 2.43100 13.20000 0.87100 1.05000 14.70000 1.00000 7.00000 7.00000 7.00000 7.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
62.665 2022.00000 40.3000 -44.53125 0.00000 2.46600 2.46600 12.40000 0.37000 0.97300 14.00000 1.00000 7.00000 7.00000 7.00000 7.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
62.675 2022.00000 40.3000 -44.53125 0.00000 2.46600 2.46600 12.40000 0.37000 0.97300 14.00000 1.00000 7.00000 7.00000 7.00000 7.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
62.685 2022.00000 40.3000 -44.53125 0.00000 2.46600 2.46600 12.40000 0.37000 0.97300 14.00000 1.00000 7.00000 7.00000 7.00000 7.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
62.695 2022.00000 40.3000 -44.53125 0.00000 2.46600 2.46600 12.40000 0.37000 0.97300 14.00000 1.00000 7.00000 7.00000 7.00000 7.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
62.705 2022.00000 40.3000 -44.53125 0.00000 2.46600 2.46600 12.40000 0.37000 0.97300 14.00000 1.00000 7.00000 7.00000 7.00000 7.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
62.715 1983.00000 40.3000 -44.53125 0.00000 2.46600 2.46600 13.30000 0.37000 0.97300 14.70000 1.00000 7.00000 7.00000 7.00000 7.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
62.725 1983.00000 40.3000 -44.53125 0.00000 2.46600 2.46600 13.30000 0.37000 0.97300 14.70000 1.00000 7.00000 7.00000 7.00000 7.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
62.735 1983.00000 40.3000 -44.53125 0.00000 2.46600 2.46600 13.30000 0.37000 0.97300 14.70000 1.00000 7.00000 7.00000 7.00000 7.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
62.745 1983.00000 40.3000 -44.53125 0.00000 2.46600 2.46600 13.30000 0.37000 0.97300 14.70000 1.00000 7.00000 7.00000 7.00000 7.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
62.755 1983.00000 40.3000 -44.53125 0.00000 2.46600 2.46600 13.30000 0.37000 0.97300 14.70000 1.00000 7.00000 7.00000 7.00000 7.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
62.765 2001.00000 40.3000 -44.53125 0.00000 2.55300 2.55300 13.70000 0.37000 0.97300 13.90000 1.00000 7.00000 7.00000 7.00000 7.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
62.775 2001.00000 40.3000 -44.53125 0.00000 2.55300 2.55300 13.70000 0.37000 0.97300 13.90000 1.00000 7.00000 7.00000 7.00000 7.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
62.785 2001.00000 40.3000 -44.53125 0.00000 2.55300 2.55300 13.70000 0.37000 0.97300 13.90000 1.00000 7.00000 7.00000 7.00000 7.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
62.795 2001.00000 40.3000 -44.53125 0.00000 2.55300 2.55300 13.70000 0.37000 0.97300 13.90000 1.00000 7.00000 7.00000 7.00000 7.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
62.805 2001.00000 40.3000 -44.53125 0.00000 2.55300 2.55300 13.70000 0.37000 0.97300 13.90000 1.00000 7.00000 7.00000 7.00000 7.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
62.815 2055.00000 40.5000 -44.53125 0.00000 2.54100 2.54100 13.40000 0.37000 0.97300 14.50000 1.00000 7.00000 7.00000 7.00000 7.00000 0.00000 0.00000 15.8000 0.000 0.000 0.000 0.000
62.825 2055.00000 40.5000 -44.53125 0.00000 2.54100 2.54100 13.40000 0.37000 0.97300 14.50000 1.00000 7.00000 7.00000 7.00000 7.00000 0.00000 0.00000 15.8000 0.000 0.000 0.000 0.000
62.835 2055.00000 40.5000 -44.53125 0.00000 2.54100 2.54100 13.40000 0.37000 0.97300 14.50000 1.00000 7.00000 7.00000 7.00000 7.00000 0.00000 0.00000 15.8000 0.000 0.000 0.000 0.000
62.845 2055.00000 40.5000 -44.53125 0.00000 2.54100 2.54100 13.40000 0.37000 0.97300 14.50000 1.00000 7.00000 7.00000 7.00000 7.00000 0.00000 0.00000 15.8000 0.000 0.000 0.000 0.000
62.855 2055.00000 40.5000 -44.53125 0.00000 2.54100 2.54100 13.40000 0.37000 0.97300 14.50000 1.00000 7.00000 7.00000 7.00000 7.00000 0.00000 0.00000 15.8000 0.000 0.000 0.000 0.000
62.865 2043.00000 40.6000 -44.53125 0.00000 2.41300 2.41300 13.30000 0.32800 0.84200 14.10000 1.00000 7.00000 7.00000 7.00000 7.00000 0.00000 0.00000 16.0000 0.000 0.000 0.000 0.000
62.875 2043.00000 40.6000 -44.53125 0.00000 2.41300 2.41300 13.30000 0.32800 0.84200 14.10000 1.00000 7.00000 7.00000 7.00000 7.00000 0.00000 0.00000 16.0000 0.000 0.000 0.000 0.000
62.885 2043.00000 40.6000 -44.53125 0.00000 2.41300 2.41300 13.30000 0.32800 0.84200 14.10000 1.00000 7.00000 7.00000 7.00000 7.00000 0.00000 0.00000 16.0000 0.000 0.000 0.000 0.000
62.895 2043.00000 40.6000 -44.53125 0.00000 2.41300 2.41300 13.30000 0.32800 0.84200 14.10000 1.00000 7.00000 7.00000 7.00000 7.00000 0.00000 0.00000 16.0000 0.000 0.000 0.000 0.000
62.905 2043.00000 40.6000 -44.53125 0.00000 2.41300 2.41300 13.30000 0.32800 0.84200 14.10000 1.00000 7.00000 7.00000 7.00000 7.00000 0.00000 0.00000 16.0000 0.000 0.000 0.000 0.000
62.915 2045.00000 40.3000 -44.53125 0.00000 2.55900 2.55900 12.30000 0.32800 0.84200 14.30000 1.00000 7.00000 7.00000 7.00000 7.00000 0.00000 0.00000 16.0000 0.000 0.000 0.000 0.000
62.925 2045.00000 40.3000 -44.53125 0.00000 2.55900 2.55900 12.30000 0.32800 0.84200 14.30000 1.00000 7.00000 7.00000 7.00000 7.00000 0.00000 0.00000 16.0000 0.000 0.000 0.000 0.000
62.935 2045.00000 40.3000 -44.53125 0.00000 2.55900 2.55900 12.30000 0.32800 0.84200 14.30000 1.00000 7.00000 7.00000 7.00000 7.00000 0.00000 0.00000 16.0000 0.000 0.000 0.000 0.000
62.945 2045.00000 40.3000 -44.53125 0.00000 2.55900 2.55900 12.30000 0.32800 0.84200 14.30000 1.00000 7.00000 7.00000 7.00000 7.00000 0.00000 0.00000 16.0000 0.000 0.000 0.000 0.000
62.955 2045.00000 40.3000 -44.53125 0.00000 2.55900 2.55900 12.30000 0.32800 0.84200 14.30000 1.00000 7.00000 7.00000 7.00000 7.00000 0.00000 0.00000 16.0000 0.000 0.000 0.000 0.000
62.965 2039.00000 40.1000 -44.53125 0.00000 2.52400 2.52400 13.20000 0.32800 0.84200 14.90000 1.00000 7.00000 7.00000 7.00000 7.00000 0.00000 0.00000 15.8000 0.000 0.000 0.000 0.000
62.975 2039.00000 40.1000 -44.53125 0.00000 2.52400 2.52400 13.20000 0.32800 0.84200 14.90000 1.00000 7.00000 7.00000 7.00000 7.00000 0.00000 0.00000 15.8000 0.000 0.000 0.000 0.000
62.985 2039.00000 40.1000 -44.53125 0.00000 2.52400 2.52400 13.20000 0.32800 0.84200 14.90000 1.00000 7.00000 7.00000 7.00000 7.00000 0.00000 0.00000 15.8000 0.000 0.000 0.000 0.000
62.995 2039.00000 40.1000 -44.53125 0.00000 2.52400 2.52400 13.20000 0.32800 0.84200 14.90000 1.00000 7.00000 7.00000 7.00000 7.00000 0.00000 0.00000 15.8000 0.000 0.000 0.000 0.000
63.005 2039.00000 40.1000 -44.53125 0.00000 2.52400 2.52400 13.20000 0.32800 0.84200 14.90000 1.00000 7.00000 7.00000 7.00000 7.00000 0.00000 0.00000 15.8000 0.000 0.000 0.000 0.000
63.015 2086.00000 39.8000 -44.53125 0.00000 2.50000 2.50000 13.20000 0.32800 0.84200 14.30000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 15.9000 0.000 0.000 0.000 0.000
63.025 2086.00000 39.8000 -44.53125 0.00000 2.50000 2.50000 13.20000 0.32800 0.84200 14.30000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 15.9000 0.000 0.000 0.000 0.000
63.035 2086.00000 39.8000 -44.53125 0.00000 2.50000 2.50000 13.20000 0.32800 0.84200 14.30000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 15.9000 0.000 0.000 0.000 0.000
63.045 2086.00000 39.8000 -44.53125 0.00000 2.50000 2.50000 13.20000 0.32800 0.84200 14.30000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 15.9000 0.000 0.000 0.000 0.000
63.055 2086.00000 39.8000 -44.53125 0.00000 2.50000 2.50000 13.20000 0.32800 0.84200 14.30000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 15.9000 0.000 0.000 0.000 0.000
63.065 2109.00000 40.0000 -44.53125 0.00000 2.61700 2.61700 13.60000 0.33100 0.63500 14.30000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 15.9000 0.000 0.000 0.000 0.000
63.075 2109.00000 40.0000 -44.53125 0.00000 2.61700 2.61700 13.60000 0.33100 0.63500 14.30000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 15.9000 0.000 0.000 0.000 0.000
63.085 2109.00000 40.0000 -44.53125 0.00000 2.61700 2.61700 13.60000 0.33100 0.63500 14.30000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 15.9000 0.000 0.000 0.000 0.000
63.095 2109.00000 40.0000 -44.53125 0.00000 2.61700 2.61700 13.60000 0.33100 0.63500 14.30000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 15.9000 0.000 0.000 0.000 0.000
63.105 2109.00000 40.0000 -44.53125 0.00000 2.61700 2.61700 13.60000 0.33100 0.63500 14.30000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 15.9000 0.000 0.000 0.000 0.000
63.115 2106.00000 39.7000 -44.53125 0.00000 2.57000 2.57000 13.60000 0.33100 0.63500 14.40000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
63.125 2106.00000 39.7000 -44.53125 0.00000 2.57000 2.57000 13.60000 0.33100 0.63500 14.40000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
63.135 2106.00000 39.7000 -44.53125 0.00000 2.57000 2.57000 13.60000 0.33100 0.63500 14.40000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
63.145 2106.00000 39.7000 -44.53125 0.00000 2.57000 2.57000 13.60000 0.33100 0.63500 14.40000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
63.155 2106.00000 39.7000 -44.53125 0.00000 2.57000 2.57000 13.60000 0.33100 0.63500 14.40000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
63.165 2120.00000 39.4000 -43.75000 0.00000 2.39600 2.39600 13.10000 0.33100 0.63500 15.30000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
63.175 2120.00000 39.4000 -43.75000 0.00000 2.39600 2.39600 13.10000 0.33100 0.63500 15.30000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
63.185 2120.00000 39.4000 -43.75000 0.00000 2.39600 2.39600 13.10000 0.33100 0.63500 15.30000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
63.195 2120.00000 39.4000 -43.75000 0.00000 2.39600 2.39600 13.10000 0.33100 0.63500 15.30000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
63.205 2120.00000 39.4000 -43.75000 0.00000 2.39600 2.39600 13.10000 0.33100 0.63500 15.30000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
63.215 2137.00000 39.7000 -44.53125 0.00000 2.55900 2.55900 13.20000 0.33100 0.63500 14.30000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
63.225 2137.00000 39.7000 -44.53125 0.00000 2.55900 2.55900 13.20000 0.33100 0.63500 14.30000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
63.235 2137.00000 39.7000 -44.53125 0.00000 2.55900 2.55900 13.20000 0.33100 0.63500 14.30000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
63.245 2137.00000 39.7000 -44.53125 0.00000 2.55900 2.55900 13.20000 0.33100 0.63500 14.30000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
63.255 2137.00000 39.7000 -44.53125 0.00000 2.55900 2.55900 13.20000 0.33100 0.63500 14.30000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
63.265 2136.00000 39.5000 -44.53125 0.00000 2.55300 2.55300 13.30000 0.33100 0.45300 14.30000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
63.275 2136.00000 39.5000 -44.53125 0.00000 2.55300 2.55300 13.30000 0.33100 0.45300 14.30000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
63.285 2136.00000 39.5000 -44.53125 0.00000 2.55300 2.55300 13.30000 0.33100 0.45300 14.30000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
63.295 2136.00000 39.5000 -44.53125 0.00000 2.55300 2.55300 13.30000 0.33100 0.45300 14.30000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
63.305 2136.00000 39.5000 -44.53125 0.00000 2.55300 2.55300 13.30000 0.33100 0.45300 14.30000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
63.315 2182.00000 34.8000 -44.53125 0.00000 2.47100 2.47100 12.60000 0.33100 0.45300 14.60000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
63.325 2182.00000 34.8000 -44.53125 0.00000 2.47100 2.47100 12.60000 0.33100 0.45300 14.60000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
63.335 2182.00000 34.8000 -44.53125 0.00000 2.47100 2.47100 12.60000 0.33100 0.45300 14.60000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
63.345 2182.00000 34.8000 -44.53125 0.00000 2.47100 2.47100 12.60000 0.33100 0.45300 14.60000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
63.355 2182.00000 34.8000 -44.53125 0.00000 2.47100 2.47100 12.60000 0.33100 0.45300 14.60000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
63.365 2161.00000 30.1000 -44.53125 0.00000 2.32000 2.32000 13.00000 0.33100 0.45300 13.00000 1.00000 7.00000 7.00000 8.00000 7.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
63.375 2161.00000 30.1000 -44.53125 0.00000 2.32000 2.32000 13.00000 0.33100 0.45300 13.00000 1.00000 7.00000 7.00000 8.00000 7.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
63.385 2161.00000 30.1000 -44.53125 0.00000 2.32000 2.32000 13.00000 0.33100 0.45300 13.00000 1.00000 7.00000 7.00000 8.00000 7.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
63.395 2161.00000 30.1000 -44.53125 0.00000 2.32000 2.32000 13.00000 0.33100 0.45300 13.00000 1.00000 7.00000 7.00000 8.00000 7.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
63.405 2161.00000 30.1000 -44.53125 0.00000 2.32000 2.32000 13.00000 0.33100 0.45300 13.00000 1.00000 7.00000 7.00000 8.00000 7.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
63.415 2191.00000 29.1000 -44.53125 0.00000 2.27300 2.27300 13.40000 0.33100 0.45300 12.50000 1.00000 6.00000 7.00000 7.00000 7.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
63.425 2191.00000 29.1000 -44.53125 0.00000 2.27300 2.27300 13.40000 0.33100 0.45300 12.50000 1.00000 6.00000 7.00000 7.00000 7.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
63.435 2191.00000 29.1000 -44.53125 0.00000 2.27300 2.27300 13.40000 0.33100 0.45300 12.50000 1.00000 6.00000 7.00000 7.00000 7.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
63.445 2191.00000 29.1000 -44.53125 0.00000 2.27300 2.27300 13.40000 0.33100 0.45300 12.50000 1.00000 6.00000 7.00000 7.00000 7.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
63.455 2191.00000 29.1000 -44.53125 0.00000 2.27300 2.27300 13.40000 0.33100 0.45300 12.50000 1.00000 6.00000 7.00000 7.00000 7.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
63.465 2160.00000 28.5000 -44.53125 0.00000 2.22100 2.22100 13.50000 0.90000 0.33500 12.60000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
63.475 2160.00000 28.5000 -44.53125 0.00000 2.22100 2.22100 13.50000 0.90000 0.33500 12.60000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
63.485 2160.00000 28.5000 -44.53125 0.00000 2.22100 2.22100 13.50000 0.90000 0.33500 12.60000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
63.495 2160.00000 28.5000 -44.53125 0.00000 2.22100 2.22100 13.50000 0.90000 0.33500 12.60000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
63.505 2160.00000 28.5000 -44.53125 0.00000 2.22100 2.22100 13.50000 0.90000 0.33500 12.60000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
63.515 2198.00000 27.9000 -44.53125 0.00000 2.26700 2.26700 13.40000 0.90000 0.33500 11.40000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
63.525 2198.00000 27.9000 -44.53125 0.00000 2.26700 2.26700 13.40000 0.90000 0.33500 11.40000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
63.535 2198.00000 27.9000 -44.53125 0.00000 2.26700 2.26700 13.40000 0.90000 0.33500 11.40000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
63.545 2198.00000 27.9000 -44.53125 0.00000 2.26700 2.26700 13.40000 0.90000 0.33500 11.40000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
63.555 2198.00000 27.9000 -44.53125 0.00000 2.26700 2.26700 13.40000 0.90000 0.33500 11.40000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
63.565 2210.00000 27.8000 -44.53125 0.00000 2.25600 2.25600 13.60000 0.90000 0.33500 10.90000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
63.575 2210.00000 27.8000 -44.53125 0.00000 2.25600 2.25600 13.60000 0.90000 0.33500 10.90000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
63.585 2210.00000 27.8000 -44.53125 0.00000 2.25600 2.25600 13.60000 0.90000 0.33500 10.90000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
63.595 2210.00000 27.8000 -44.53125 0.00000 2.25600 2.25600 13.60000 0.90000 0.33500 10.90000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
63.605 2210.00000 27.8000 -44.53125 0.00000 2.25600 2.25600 13.60000 0.90000 0.33500 10.90000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
63.615 2257.00000 26.1000 -44.53125 0.00000 2.17400 2.17400 13.00000 0.90000 0.33500 10.40000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
63.625 2257.00000 26.1000 -44.53125 0.00000 2.17400 2.17400 13.00000 0.90000 0.33500 10.40000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
63.635 2257.00000 26.1000 -44.53125 0.00000 2.17400 2.17400 13.00000 0.90000 0.33500 10.40000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
63.645 2257.00000 26.1000 -44.53125 0.00000 2.17400 2.17400 13.00000 0.90000 0.33500 10.40000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
63.655 2257.00000 26.1000 -44.53125 0.00000 2.17400 2.17400 13.00000 0.90000 0.33500 10.40000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
63.665 2202.00000 22.6000 -44.53125 0.00000 1.88800 1.88800 13.30000 0.90300 0.38900 9.40000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 14.5000 0.000 0.000 0.000 0.000
63.675 2202.00000 22.6000 -44.53125 0.00000 1.88800 1.88800 13.30000 0.90300 0.38900 9.40000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 14.5000 0.000 0.000 0.000 0.000
63.685 2202.00000 22.6000 -44.53125 0.00000 1.88800 1.88800 13.30000 0.90300 0.38900 9.40000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 14.5000 0.000 0.000 0.000 0.000
63.695 2202.00000 22.6000 -44.53125 0.00000 1.88800 1.88800 13.30000 0.90300 0.38900 9.40000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 14.5000 0.000 0.000 0.000 0.000
63.705 2202.00000 22.6000 -44.53125 0.00000 1.88800 1.88800 13.30000 0.90300 0.38900 9.40000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 14.5000 0.000 0.000 0.000 0.000
63.715 2218.00000 20.6000 -44.53125 0.00000 1.71900 1.71900 13.00000 0.90300 0.38900 8.30000 1.00000 4.00000 4.00000 5.00000 4.00000 0.00000 0.00000 14.6000 0.000 0.000 0.000 0.000
63.725 2218.00000 20.6000 -44.53125 0.00000 1.71900 1.71900 13.00000 0.90300 0.38900 8.30000 1.00000 4.00000 4.00000 5.00000 4.00000 0.00000 0.00000 14.6000 0.000 0.000 0.000 0.000
63.735 2218.00000 20.6000 -44.53125 0.00000 1.71900 1.71900 13.00000 0.90300 0.38900 8.30000 1.00000 4.00000 4.00000 5.00000 4.00000 0.00000 0.00000 14.6000 0.000 0.000 0.000 0.000
63.745 2218.00000 20.6000 -44.53125 0.00000 1.71900 1.71900 13.00000 0.90300 0.38900 8.30000 1.00000 4.00000 4.00000 5.00000 4.00000 0.00000 0.00000 14.6000 0.000 0.000 0.000 0.000
63.755 2218.00000 20.6000 -44.53125 0.00000 1.71900 1.71900 13.00000 0.90300 0.38900 8.30000 1.00000 4.00000 4.00000 5.00000 4.00000 0.00000 0.00000 14.6000 0.000 0.000 0.000 0.000
63.765 2231.00000 19.5000 -44.53125 0.00000 1.55600 1.55600 13.30000 0.90300 0.38900 7.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.5000 0.000 0.000 0.000 0.000
63.775 2231.00000 19.5000 -44.53125 0.00000 1.55600 1.55600 13.30000 0.90300 0.38900 7.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.5000 0.000 0.000 0.000 0.000
63.785 2231.00000 19.5000 -44.53125 0.00000 1.55600 1.55600 13.30000 0.90300 0.38900 7.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.5000 0.000 0.000 0.000 0.000
63.795 2231.00000 19.5000 -44.53125 0.00000 1.55600 1.55600 13.30000 0.90300 0.38900 7.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.5000 0.000 0.000 0.000 0.000
63.805 2231.00000 19.5000 -44.53125 0.00000 1.55600 1.55600 13.30000 0.90300 0.38900 7.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.5000 0.000 0.000 0.000 0.000
63.815 2276.00000 17.1000 -44.53125 0.00000 1.39300 1.39300 13.30000 0.90300 0.38900 6.40000 1.00000 4.00000 3.00000 4.00000 4.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
63.825 2276.00000 17.1000 -44.53125 0.00000 1.39300 1.39300 13.30000 0.90300 0.38900 6.40000 1.00000 4.00000 3.00000 4.00000 4.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
63.835 2276.00000 17.1000 -44.53125 0.00000 1.39300 1.39300 13.30000 0.90300 0.38900 6.40000 1.00000 4.00000 3.00000 4.00000 4.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
63.845 2276.00000 17.1000 -44.53125 0.00000 1.39300 1.39300 13.30000 0.90300 0.38900 6.40000 1.00000 4.00000 3.00000 4.00000 4.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
63.855 2276.00000 17.1000 -44.53125 0.00000 1.39300 1.39300 13.30000 0.90300 0.38900 6.40000 1.00000 4.00000 3.00000 4.00000 4.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
63.865 2225.00000 15.2000 -44.53125 0.00000 1.19500 1.19500 13.30000 1.09100 0.49100 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
63.875 2225.00000 15.2000 -44.53125 0.00000 1.19500 1.19500 13.30000 1.09100 0.49100 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
63.885 2225.00000 15.2000 -44.53125 0.00000 1.19500 1.19500 13.30000 1.09100 0.49100 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
63.895 2225.00000 15.2000 -44.53125 0.00000 1.19500 1.19500 13.30000 1.09100 0.49100 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
63.905 2225.00000 15.2000 -44.53125 0.00000 1.19500 1.19500 13.30000 1.09100 0.49100 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
63.915 2215.00000 15.2000 -44.53125 0.00000 1.04900 1.04900 13.60000 1.09100 0.49100 4.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
63.925 2215.00000 15.2000 -44.53125 0.00000 1.04900 1.04900 13.60000 1.09100 0.49100 4.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
63.935 2215.00000 15.2000 -44.53125 0.00000 1.04900 1.04900 13.60000 1.09100 0.49100 4.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
63.945 2215.00000 15.2000 -44.53125 0.00000 1.04900 1.04900 13.60000 1.09100 0.49100 4.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
63.955 2215.00000 15.2000 -44.53125 0.00000 1.04900 1.04900 13.60000 1.09100 0.49100 4.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
63.965 2243.00000 15.2000 -44.53125 0.00000 1.38700 1.38700 11.70000 1.09100 0.49100 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
63.975 2243.00000 15.2000 -44.53125 0.00000 1.38700 1.38700 11.70000 1.09100 0.49100 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
63.985 2243.00000 15.2000 -44.53125 0.00000 1.38700 1.38700 11.70000 1.09100 0.49100 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
63.995 2243.00000 15.2000 -44.53125 0.00000 1.38700 1.38700 11.70000 1.09100 0.49100 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
64.005 2243.00000 15.2000 -44.53125 0.00000 1.38700 1.38700 11.70000 1.09100 0.49100 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
64.015 2189.00000 15.4000 -44.53125 0.00000 1.78300 1.78300 12.80000 1.09100 0.49100 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
64.025 2189.00000 15.4000 -44.53125 0.00000 1.78300 1.78300 12.80000 1.09100 0.49100 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
64.035 2189.00000 15.4000 -44.53125 0.00000 1.78300 1.78300 12.80000 1.09100 0.49100 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
64.045 2189.00000 15.4000 -44.53125 0.00000 1.78300 1.78300 12.80000 1.09100 0.49100 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
64.055 2189.00000 15.4000 -44.53125 0.00000 1.78300 1.78300 12.80000 1.09100 0.49100 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
64.065 2168.00000 15.2000 -44.53125 0.00000 2.13300 2.13300 13.30000 1.15200 0.61200 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.0000 0.000 0.000 0.000 0.000
64.075 2168.00000 15.2000 -44.53125 0.00000 2.13300 2.13300 13.30000 1.15200 0.61200 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.0000 0.000 0.000 0.000 0.000
64.085 2168.00000 15.2000 -44.53125 0.00000 2.13300 2.13300 13.30000 1.15200 0.61200 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.0000 0.000 0.000 0.000 0.000
64.095 2168.00000 15.2000 -44.53125 0.00000 2.13300 2.13300 13.30000 1.15200 0.61200 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.0000 0.000 0.000 0.000 0.000
64.105 2168.00000 15.2000 -44.53125 0.00000 2.13300 2.13300 13.30000 1.15200 0.61200 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.0000 0.000 0.000 0.000 0.000
64.115 2219.00000 15.2000 -44.53125 0.00000 1.02600 1.02600 13.10000 1.15200 0.61200 4.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 12.7000 0.000 0.000 0.000 0.000
64.125 2219.00000 15.2000 -44.53125 0.00000 1.02600 1.02600 13.10000 1.15200 0.61200 4.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 12.7000 0.000 0.000 0.000 0.000
64.135 2219.00000 15.2000 -44.53125 0.00000 1.02600 1.02600 13.10000 1.15200 0.61200 4.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 12.7000 0.000 0.000 0.000 0.000
64.145 2219.00000 15.2000 -44.53125 0.00000 1.02600 1.02600 13.10000 1.15200 0.61200 4.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 12.7000 0.000 0.000 0.000 0.000
64.155 2219.00000 15.2000 -44.53125 0.00000 1.02600 1.02600 13.10000 1.15200 0.61200 4.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 12.7000 0.000 0.000 0.000 0.000
64.165 2215.00000 15.2000 -44.53125 0.00000 1.46900 1.46900 13.30000 1.15200 0.61200 4.20000 1.00000 4.00000 3.00000 4.00000 4.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
64.175 2215.00000 15.2000 -44.53125 0.00000 1.46900 1.46900 13.30000 1.15200 0.61200 4.20000 1.00000 4.00000 3.00000 4.00000 4.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
64.185 2215.00000 15.2000 -44.53125 0.00000 1.46900 1.46900 13.30000 1.15200 0.61200 4.20000 1.00000 4.00000 3.00000 4.00000 4.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
64.195 2215.00000 15.2000 -44.53125 0.00000 1.46900 1.46900 13.30000 1.15200 0.61200 4.20000 1.00000 4.00000 3.00000 4.00000 4.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
64.205 2215.00000 15.2000 -44.53125 0.00000 1.46900 1.46900 13.30000 1.15200 0.61200 4.20000 1.00000 4.00000 3.00000 4.00000 4.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
64.215 2229.00000 15.2000 -44.53125 0.00000 1.81800 1.81800 12.90000 1.15200 0.61200 4.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.7000 0.000 0.000 0.000 0.000
64.225 2229.00000 15.2000 -44.53125 0.00000 1.81800 1.81800 12.90000 1.15200 0.61200 4.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.7000 0.000 0.000 0.000 0.000
64.235 2229.00000 15.2000 -44.53125 0.00000 1.81800 1.81800 12.90000 1.15200 0.61200 4.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.7000 0.000 0.000 0.000 0.000
64.245 2229.00000 15.2000 -44.53125 0.00000 1.81800 1.81800 12.90000 1.15200 0.61200 4.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.7000 0.000 0.000 0.000 0.000
64.255 2229.00000 15.2000 -44.53125 0.00000 1.81800 1.81800 12.90000 1.15200 0.61200 4.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.7000 0.000 0.000 0.000 0.000
64.265 2207.00000 15.2000 -44.53125 0.00000 1.42200 1.42200 13.60000 1.15200 0.98900 4.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 11.6000 0.000 0.000 0.000 0.000
64.275 2207.00000 15.2000 -44.53125 0.00000 1.42200 1.42200 13.60000 1.15200 0.98900 4.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 11.6000 0.000 0.000 0.000 0.000
64.285 2207.00000 15.2000 -44.53125 0.00000 1.42200 1.42200 13.60000 1.15200 0.98900 4.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 11.6000 0.000 0.000 0.000 0.000
64.295 2207.00000 15.2000 -44.53125 0.00000 1.42200 1.42200 13.60000 1.15200 0.98900 4.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 11.6000 0.000 0.000 0.000 0.000
64.305 2207.00000 15.2000 -44.53125 0.00000 1.42200 1.42200 13.60000 1.15200 0.98900 4.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 11.6000 0.000 0.000 0.000 0.000
64.315 2230.00000 15.2000 -44.53125 0.00000 1.10100 1.10100 13.30000 1.15200 0.98900 4.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 11.7000 0.000 0.000 0.000 0.000
64.325 2230.00000 15.2000 -44.53125 0.00000 1.10100 1.10100 13.30000 1.15200 0.98900 4.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 11.7000 0.000 0.000 0.000 0.000
64.335 2230.00000 15.2000 -44.53125 0.00000 1.10100 1.10100 13.30000 1.15200 0.98900 4.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 11.7000 0.000 0.000 0.000 0.000
64.345 2230.00000 15.2000 -44.53125 0.00000 1.10100 1.10100 13.30000 1.15200 0.98900 4.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 11.7000 0.000 0.000 0.000 0.000
64.355 2230.00000 15.2000 -44.53125 0.00000 1.10100 1.10100 13.30000 1.15200 0.98900 4.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 11.7000 0.000 0.000 0.000 0.000
64.365 2188.00000 15.2000 -44.53125 0.00000 1.47400 1.47400 13.30000 1.15200 0.98900 3.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 11.7000 0.000 0.000 0.000 0.000
64.375 2188.00000 15.2000 -44.53125 0.00000 1.47400 1.47400 13.30000 1.15200 0.98900 3.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 11.7000 0.000 0.000 0.000 0.000
64.385 2188.00000 15.2000 -44.53125 0.00000 1.47400 1.47400 13.30000 1.15200 0.98900 3.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 11.7000 0.000 0.000 0.000 0.000
64.395 2188.00000 15.2000 -44.53125 0.00000 1.47400 1.47400 13.30000 1.15200 0.98900 3.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 11.7000 0.000 0.000 0.000 0.000
64.405 2188.00000 15.2000 -44.53125 0.00000 1.47400 1.47400 13.30000 1.15200 0.98900 3.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 11.7000 0.000 0.000 0.000 0.000
64.415 2232.00000 15.2000 -44.53125 0.00000 1.70800 1.70800 12.90000 1.15200 0.98900 3.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
64.425 2232.00000 15.2000 -44.53125 0.00000 1.70800 1.70800 12.90000 1.15200 0.98900 3.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
64.435 2232.00000 15.2000 -44.53125 0.00000 1.70800 1.70800 12.90000 1.15200 0.98900 3.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
64.445 2232.00000 15.2000 -44.53125 0.00000 1.70800 1.70800 12.90000 1.15200 0.98900 3.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
64.455 2232.00000 15.2000 -44.53125 0.00000 1.70800 1.70800 12.90000 1.15200 0.98900 3.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
64.465 2171.00000 15.1000 -44.53125 0.00000 1.50400 1.50400 13.20000 0.99900 1.05600 4.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
64.475 2171.00000 15.1000 -44.53125 0.00000 1.50400 1.50400 13.20000 0.99900 1.05600 4.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
64.485 2171.00000 15.1000 -44.53125 0.00000 1.50400 1.50400 13.20000 0.99900 1.05600 4.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
64.495 2171.00000 15.1000 -44.53125 0.00000 1.50400 1.50400 13.20000 0.99900 1.05600 4.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
64.505 2171.00000 15.1000 -44.53125 0.00000 1.50400 1.50400 13.20000 0.99900 1.05600 4.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
64.515 2166.00000 15.2000 -44.53125 0.00000 1.73700 1.73700 12.70000 0.99900 1.05600 4.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.0000 0.000 0.000 0.000 0.000
64.525 2166.00000 15.2000 -44.53125 0.00000 1.73700 1.73700 12.70000 0.99900 1.05600 4.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.0000 0.000 0.000 0.000 0.000
64.535 2166.00000 15.2000 -44.53125 0.00000 1.73700 1.73700 12.70000 0.99900 1.05600 4.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.0000 0.000 0.000 0.000 0.000
64.545 2166.00000 15.2000 -44.53125 0.00000 1.73700 1.73700 12.70000 0.99900 1.05600 4.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.0000 0.000 0.000 0.000 0.000
64.555 2166.00000 15.2000 -44.53125 0.00000 1.73700 1.73700 12.70000 0.99900 1.05600 4.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.0000 0.000 0.000 0.000 0.000
64.565 2148.00000 15.2000 -44.53125 0.00000 1.38700 1.38700 13.30000 0.99900 1.05600 4.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 13.4000 0.000 0.000 0.000 0.000
64.575 2148.00000 15.2000 -44.53125 0.00000 1.38700 1.38700 13.30000 0.99900 1.05600 4.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 13.4000 0.000 0.000 0.000 0.000
64.585 2148.00000 15.2000 -44.53125 0.00000 1.38700 1.38700 13.30000 0.99900 1.05600 4.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 13.4000 0.000 0.000 0.000 0.000
64.595 2148.00000 15.2000 -44.53125 0.00000 1.38700 1.38700 13.30000 0.99900 1.05600 4.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 13.4000 0.000 0.000 0.000 0.000
64.605 2148.00000 15.2000 -44.53125 0.00000 1.38700 1.38700 13.30000 0.99900 1.05600 4.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 13.4000 0.000 0.000 0.000 0.000
64.615 2187.00000 15.1000 -44.53125 0.00000 1.55600 1.55600 13.60000 0.99900 1.05600 4.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 13.2000 0.000 0.000 0.000 0.000
64.625 2187.00000 15.1000 -44.53125 0.00000 1.55600 1.55600 13.60000 0.99900 1.05600 4.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 13.2000 0.000 0.000 0.000 0.000
64.635 2187.00000 15.1000 -44.53125 0.00000 1.55600 1.55600 13.60000 0.99900 1.05600 4.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 13.2000 0.000 0.000 0.000 0.000
64.645 2187.00000 15.1000 -44.53125 0.00000 1.55600 1.55600 13.60000 0.99900 1.05600 4.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 13.2000 0.000 0.000 0.000 0.000
64.655 2187.00000 15.1000 -44.53125 0.00000 1.55600 1.55600 13.60000 0.99900 1.05600 4.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 13.2000 0.000 0.000 0.000 0.000
64.665 2158.00000 15.2000 -44.53125 0.00000 1.56200 1.56200 13.30000 1.05600 1.09800 3.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 13.4000 0.000 0.000 0.000 0.000
64.675 2158.00000 15.2000 -44.53125 0.00000 1.56200 1.56200 13.30000 1.05600 1.09800 3.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 13.4000 0.000 0.000 0.000 0.000
64.685 2158.00000 15.2000 -44.53125 0.00000 1.56200 1.56200 13.30000 1.05600 1.09800 3.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 13.4000 0.000 0.000 0.000 0.000
64.695 2158.00000 15.2000 -44.53125 0.00000 1.56200 1.56200 13.30000 1.05600 1.09800 3.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 13.4000 0.000 0.000 0.000 0.000
64.705 2158.00000 15.2000 -44.53125 0.00000 1.56200 1.56200 13.30000 1.05600 1.09800 3.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 13.4000 0.000 0.000 0.000 0.000
64.715 2195.00000 15.2000 -44.53125 0.00000 1.28200 1.28200 13.70000 1.05600 1.09800 3.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.8000 0.000 0.000 0.000 0.000
64.725 2195.00000 15.2000 -44.53125 0.00000 1.28200 1.28200 13.70000 1.05600 1.09800 3.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.8000 0.000 0.000 0.000 0.000
64.735 2195.00000 15.2000 -44.53125 0.00000 1.28200 1.28200 13.70000 1.05600 1.09800 3.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.8000 0.000 0.000 0.000 0.000
64.745 2195.00000 15.2000 -44.53125 0.00000 1.28200 1.28200 13.70000 1.05600 1.09800 3.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.8000 0.000 0.000 0.000 0.000
64.755 2195.00000 15.2000 -44.53125 0.00000 1.28200 1.28200 13.70000 1.05600 1.09800 3.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.8000 0.000 0.000 0.000 0.000
64.765 2131.00000 15.2000 -44.53125 0.00000 1.45700 1.45700 12.10000 1.05600 1.09800 4.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.7000 0.000 0.000 0.000 0.000
64.775 2131.00000 15.2000 -44.53125 0.00000 1.45700 1.45700 12.10000 1.05600 1.09800 4.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.7000 0.000 0.000 0.000 0.000
64.785 2131.00000 15.2000 -44.53125 0.00000 1.45700 1.45700 12.10000 1.05600 1.09800 4.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.7000 0.000 0.000 0.000 0.000
64.795 2131.00000 15.2000 -44.53125 0.00000 1.45700 1.45700 12.10000 1.05600 1.09800 4.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.7000 0.000 0.000 0.000 0.000
64.805 2131.00000 15.2000 -44.53125 0.00000 1.45700 1.45700 12.10000 1.05600 1.09800 4.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.7000 0.000 0.000 0.000 0.000
64.815 2100.00000 15.1000 -44.53125 0.00000 1.63800 1.63800 13.10000 1.05600 1.09800 4.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.7000 0.000 0.000 0.000 0.000
64.825 2100.00000 15.1000 -44.53125 0.00000 1.63800 1.63800 13.10000 1.05600 1.09800 4.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.7000 0.000 0.000 0.000 0.000
64.835 2100.00000 15.1000 -44.53125 0.00000 1.63800 1.63800 13.10000 1.05600 1.09800 4.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.7000 0.000 0.000 0.000 0.000
64.845 2100.00000 15.1000 -44.53125 0.00000 1.63800 1.63800 13.10000 1.05600 1.09800 4.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.7000 0.000 0.000 0.000 0.000
64.855 2100.00000 15.1000 -44.53125 0.00000 1.63800 1.63800 13.10000 1.05600 1.09800 4.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.7000 0.000 0.000 0.000 0.000
64.865 2163.00000 15.2000 -44.53125 0.00000 1.30500 1.30500 13.10000 0.99200 1.13300 3.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
64.875 2163.00000 15.2000 -44.53125 0.00000 1.30500 1.30500 13.10000 0.99200 1.13300 3.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
64.885 2163.00000 15.2000 -44.53125 0.00000 1.30500 1.30500 13.10000 0.99200 1.13300 3.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
64.895 2163.00000 15.2000 -44.53125 0.00000 1.30500 1.30500 13.10000 0.99200 1.13300 3.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
64.905 2163.00000 15.2000 -44.53125 0.00000 1.30500 1.30500 13.10000 0.99200 1.13300 3.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
64.915 2194.00000 15.2000 -44.53125 0.00000 1.91800 1.91800 13.40000 0.99200 1.13300 3.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
64.925 2194.00000 15.2000 -44.53125 0.00000 1.91800 1.91800 13.40000 0.99200 1.13300 3.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
64.935 2194.00000 15.2000 -44.53125 0.00000 1.91800 1.91800 13.40000 0.99200 1.13300 3.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
64.945 2194.00000 15.2000 -44.53125 0.00000 1.91800 1.91800 13.40000 0.99200 1.13300 3.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
64.955 2194.00000 15.2000 -44.53125 0.00000 1.91800 1.91800 13.40000 0.99200 1.13300 3.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
64.965 2083.00000 15.4000 -44.53125 0.00000 1.45700 1.45700 12.70000 0.99200 1.13300 4.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
64.975 2083.00000 15.4000 -44.53125 0.00000 1.45700 1.45700 12.70000 0.99200 1.13300 4.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
64.985 2083.00000 15.4000 -44.53125 0.00000 1.45700 1.45700 12.70000 0.99200 1.13300 4.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
64.995 2083.00000 15.4000 -44.53125 0.00000 1.45700 1.45700 12.70000 0.99200 1.13300 4.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
65.005 2083.00000 15.4000 -44.53125 0.00000 1.45700 1.45700 12.70000 0.99200 1.13300 4.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
65.015 2071.00000 15.1000 -44.53125 0.00000 1.78300 1.78300 13.30000 0.99200 1.13300 4.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
65.025 2071.00000 15.1000 -44.53125 0.00000 1.78300 1.78300 13.30000 0.99200 1.13300 4.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
65.035 2071.00000 15.1000 -44.53125 0.00000 1.78300 1.78300 13.30000 0.99200 1.13300 4.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
65.045 2071.00000 15.1000 -44.53125 0.00000 1.78300 1.78300 13.30000 0.99200 1.13300 4.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
65.055 2071.00000 15.1000 -44.53125 0.00000 1.78300 1.78300 13.30000 0.99200 1.13300 4.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
65.065 2117.00000 15.1000 -44.53125 0.00000 1.31700 1.31700 13.50000 0.28700 1.11700 3.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
65.075 2117.00000 15.1000 -44.53125 0.00000 1.31700 1.31700 13.50000 0.28700 1.11700 3.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
65.085 2117.00000 15.1000 -44.53125 0.00000 1.31700 1.31700 13.50000 0.28700 1.11700 3.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
65.096 2117.00000 15.1000 -44.53125 0.00000 1.31700 1.31700 13.50000 0.28700 1.11700 3.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
65.106 2117.00000 15.1000 -44.53125 0.00000 1.31700 1.31700 13.50000 0.28700 1.11700 3.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
65.116 2167.00000 15.2000 -44.53125 0.00000 1.20000 1.20000 12.70000 0.28700 1.11700 3.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
65.126 2167.00000 15.2000 -44.53125 0.00000 1.20000 1.20000 12.70000 0.28700 1.11700 3.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
65.136 2167.00000 15.2000 -44.53125 0.00000 1.20000 1.20000 12.70000 0.28700 1.11700 3.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
65.146 2167.00000 15.2000 -44.53125 0.00000 1.20000 1.20000 12.70000 0.28700 1.11700 3.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
65.156 2167.00000 15.2000 -44.53125 0.00000 1.20000 1.20000 12.70000 0.28700 1.11700 3.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
65.166 2069.00000 15.2000 -44.53125 0.00000 1.11300 1.11300 13.10000 0.28700 1.11700 3.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
65.176 2069.00000 15.2000 -44.53125 0.00000 1.11300 1.11300 13.10000 0.28700 1.11700 3.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
65.186 2069.00000 15.2000 -44.53125 0.00000 1.11300 1.11300 13.10000 0.28700 1.11700 3.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
65.196 2069.00000 15.2000 -44.53125 0.00000 1.11300 1.11300 13.10000 0.28700 1.11700 3.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
65.206 2069.00000 15.2000 -44.53125 0.00000 1.11300 1.11300 13.10000 0.28700 1.11700 3.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
65.216 2026.00000 15.1000 -44.53125 0.00000 1.55000 1.55000 13.10000 0.28700 1.11700 3.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.7000 0.000 0.000 0.000 0.000
65.226 2026.00000 15.1000 -44.53125 0.00000 1.55000 1.55000 13.10000 0.28700 1.11700 3.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.7000 0.000 0.000 0.000 0.000
65.236 2026.00000 15.1000 -44.53125 0.00000 1.55000 1.55000 13.10000 0.28700 1.11700 3.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.7000 0.000 0.000 0.000 0.000
65.246 2026.00000 15.1000 -44.53125 0.00000 1.55000 1.55000 13.10000 0.28700 1.11700 3.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.7000 0.000 0.000 0.000 0.000
65.256 2026.00000 15.1000 -44.53125 0.00000 1.55000 1.55000 13.10000 0.28700 1.11700 3.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.7000 0.000 0.000 0.000 0.000
65.266 2053.00000 15.1000 -44.53125 0.00000 1.71300 1.71300 13.30000 0.27100 1.10400 3.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
65.276 2053.00000 15.1000 -44.53125 0.00000 1.71300 1.71300 13.30000 0.27100 1.10400 3.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
65.286 2053.00000 15.1000 -44.53125 0.00000 1.71300 1.71300 13.30000 0.27100 1.10400 3.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
65.296 2053.00000 15.1000 -44.53125 0.00000 1.71300 1.71300 13.30000 0.27100 1.10400 3.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
65.306 2053.00000 15.1000 -44.53125 0.00000 1.71300 1.71300 13.30000 0.27100 1.10400 3.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
65.316 2111.00000 15.2000 -44.53125 0.00000 1.53900 1.53900 13.00000 0.27100 1.10400 4.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
65.326 2111.00000 15.2000 -44.53125 0.00000 1.53900 1.53900 13.00000 0.27100 1.10400 4.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
65.336 2111.00000 15.2000 -44.53125 0.00000 1.53900 1.53900 13.00000 0.27100 1.10400 4.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
65.346 2111.00000 15.2000 -44.53125 0.00000 1.53900 1.53900 13.00000 0.27100 1.10400 4.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
65.356 2111.00000 15.2000 -44.53125 0.00000 1.53900 1.53900 13.00000 0.27100 1.10400 4.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
65.366 2043.00000 15.1000 -44.53125 0.00000 1.68400 1.68400 13.00000 0.27100 1.10400 3.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
65.376 2043.00000 15.1000 -44.53125 0.00000 1.68400 1.68400 13.00000 0.27100 1.10400 3.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
65.386 2043.00000 15.1000 -44.53125 0.00000 1.68400 1.68400 13.00000 0.27100 1.10400 3.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
65.396 2043.00000 15.1000 -44.53125 0.00000 1.68400 1.68400 13.00000 0.27100 1.10400 3.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
65.406 2043.00000 15.1000 -44.53125 0.00000 1.68400 1.68400 13.00000 0.27100 1.10400 3.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
65.416 2005.00000 15.4000 -44.53125 0.00000 1.37500 1.37500 12.50000 0.27100 1.10400 3.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.7000 0.000 0.000 0.000 0.000
65.426 2005.00000 15.4000 -44.53125 0.00000 1.37500 1.37500 12.50000 0.27100 1.10400 3.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.7000 0.000 0.000 0.000 0.000
65.436 2005.00000 15.4000 -44.53125 0.00000 1.37500 1.37500 12.50000 0.27100 1.10400 3.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.7000 0.000 0.000 0.000 0.000
65.446 2005.00000 15.4000 -44.53125 0.00000 1.37500 1.37500 12.50000 0.27100 1.10400 3.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.7000 0.000 0.000 0.000 0.000
65.456 2005.00000 15.4000 -44.53125 0.00000 1.37500 1.37500 12.50000 0.27100 1.10400 3.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.7000 0.000 0.000 0.000 0.000
65.466 2069.00000 15.2000 -44.53125 0.00000 1.66700 1.66700 12.60000 0.27100 1.07800 4.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
65.476 2069.00000 15.2000 -44.53125 0.00000 1.66700 1.66700 12.60000 0.27100 1.07800 4.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
65.486 2069.00000 15.2000 -44.53125 0.00000 1.66700 1.66700 12.60000 0.27100 1.07800 4.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
65.496 2069.00000 15.2000 -44.53125 0.00000 1.66700 1.66700 12.60000 0.27100 1.07800 4.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
65.506 2069.00000 15.2000 -44.53125 0.00000 1.66700 1.66700 12.60000 0.27100 1.07800 4.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
65.516 2020.00000 15.2000 -44.53125 0.00000 1.36400 1.36400 13.30000 0.27100 1.07800 3.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.8000 0.000 0.000 0.000 0.000
65.526 2020.00000 15.2000 -44.53125 0.00000 1.36400 1.36400 13.30000 0.27100 1.07800 3.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.8000 0.000 0.000 0.000 0.000
65.536 2020.00000 15.2000 -44.53125 0.00000 1.36400 1.36400 13.30000 0.27100 1.07800 3.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.8000 0.000 0.000 0.000 0.000
65.546 2020.00000 15.2000 -44.53125 0.00000 1.36400 1.36400 13.30000 0.27100 1.07800 3.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.8000 0.000 0.000 0.000 0.000
65.556 2020.00000 15.2000 -44.53125 0.00000 1.36400 1.36400 13.30000 0.27100 1.07800 3.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.8000 0.000 0.000 0.000 0.000
65.566 1985.00000 15.2000 -44.53125 0.00000 1.35800 1.35800 13.30000 0.27100 1.07800 3.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.7000 0.000 0.000 0.000 0.000
65.576 1985.00000 15.2000 -44.53125 0.00000 1.35800 1.35800 13.30000 0.27100 1.07800 3.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.7000 0.000 0.000 0.000 0.000
65.586 1985.00000 15.2000 -44.53125 0.00000 1.35800 1.35800 13.30000 0.27100 1.07800 3.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.7000 0.000 0.000 0.000 0.000
65.596 1985.00000 15.2000 -44.53125 0.00000 1.35800 1.35800 13.30000 0.27100 1.07800 3.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.7000 0.000 0.000 0.000 0.000
65.606 1985.00000 15.2000 -44.53125 0.00000 1.35800 1.35800 13.30000 0.27100 1.07800 3.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.7000 0.000 0.000 0.000 0.000
65.616 2035.00000 15.1000 -44.53125 0.00000 1.53900 1.53900 13.30000 0.27100 1.07800 3.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
65.626 2035.00000 15.1000 -44.53125 0.00000 1.53900 1.53900 13.30000 0.27100 1.07800 3.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
65.636 2035.00000 15.1000 -44.53125 0.00000 1.53900 1.53900 13.30000 0.27100 1.07800 3.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
65.646 2035.00000 15.1000 -44.53125 0.00000 1.53900 1.53900 13.30000 0.27100 1.07800 3.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
65.656 2035.00000 15.1000 -44.53125 0.00000 1.53900 1.53900 13.30000 0.27100 1.07800 3.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
65.666 2012.00000 15.2000 -44.53125 0.00000 1.34600 1.34600 12.70000 0.27400 1.07800 3.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
65.676 2012.00000 15.2000 -44.53125 0.00000 1.34600 1.34600 12.70000 0.27400 1.07800 3.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
65.686 2012.00000 15.2000 -44.53125 0.00000 1.34600 1.34600 12.70000 0.27400 1.07800 3.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
65.696 2012.00000 15.2000 -44.53125 0.00000 1.34600 1.34600 12.70000 0.27400 1.07800 3.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
65.706 2012.00000 15.2000 -44.53125 0.00000 1.34600 1.34600 12.70000 0.27400 1.07800 3.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
65.716 1981.00000 15.1000 -44.53125 0.00000 1.68400 1.68400 13.30000 0.27400 1.07800 3.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
65.726 1981.00000 15.1000 -44.53125 0.00000 1.68400 1.68400 13.30000 0.27400 1.07800 3.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
65.736 1981.00000 15.1000 -44.53125 0.00000 1.68400 1.68400 13.30000 0.27400 1.07800 3.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
65.746 1981.00000 15.1000 -44.53125 0.00000 1.68400 1.68400 13.30000 0.27400 1.07800 3.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
65.756 1981.00000 15.1000 -44.53125 0.00000 1.68400 1.68400 13.30000 0.27400 1.07800 3.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
65.766 1993.00000 15.2000 -44.53125 0.00000 1.42800 1.42800 13.10000 0.27400 1.07800 3.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.7000 0.000 0.000 0.000 0.000
65.776 1993.00000 15.2000 -44.53125 0.00000 1.42800 1.42800 13.10000 0.27400 1.07800 3.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.7000 0.000 0.000 0.000 0.000
65.786 1993.00000 15.2000 -44.53125 0.00000 1.42800 1.42800 13.10000 0.27400 1.07800 3.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.7000 0.000 0.000 0.000 0.000
65.796 1993.00000 15.2000 -44.53125 0.00000 1.42800 1.42800 13.10000 0.27400 1.07800 3.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.7000 0.000 0.000 0.000 0.000
65.806 1993.00000 15.2000 -44.53125 0.00000 1.42800 1.42800 13.10000 0.27400 1.07800 3.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.7000 0.000 0.000 0.000 0.000
65.816 1962.00000 15.2000 -44.53125 0.00000 1.85900 1.85900 12.50000 0.27400 1.07800 3.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
65.826 1962.00000 15.2000 -44.53125 0.00000 1.85900 1.85900 12.50000 0.27400 1.07800 3.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
65.836 1962.00000 15.2000 -44.53125 0.00000 1.85900 1.85900 12.50000 0.27400 1.07800 3.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
65.846 1962.00000 15.2000 -44.53125 0.00000 1.85900 1.85900 12.50000 0.27400 1.07800 3.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
65.856 1962.00000 15.2000 -44.53125 0.00000 1.85900 1.85900 12.50000 0.27400 1.07800 3.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
65.866 1980.00000 15.8000 -44.53125 0.00000 1.30500 1.30500 12.50000 0.27400 1.00200 4.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
65.876 1980.00000 15.8000 -44.53125 0.00000 1.30500 1.30500 12.50000 0.27400 1.00200 4.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
65.886 1980.00000 15.8000 -44.53125 0.00000 1.30500 1.30500 12.50000 0.27400 1.00200 4.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
65.896 1980.00000 15.8000 -44.53125 0.00000 1.30500 1.30500 12.50000 0.27400 1.00200 4.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
65.906 1980.00000 15.8000 -44.53125 0.00000 1.30500 1.30500 12.50000 0.27400 1.00200 4.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
65.916 1946.00000 15.8000 -44.53125 0.00000 1.43400 1.43400 13.10000 0.27400 1.00200 3.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.7000 0.000 0.000 0.000 0.000
65.926 1946.00000 15.8000 -44.53125 0.00000 1.43400 1.43400 13.10000 0.27400 1.00200 3.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.7000 0.000 0.000 0.000 0.000
65.936 1946.00000 15.8000 -44.53125 0.00000 1.43400 1.43400 13.10000 0.27400 1.00200 3.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.7000 0.000 0.000 0.000 0.000
65.946 1946.00000 15.8000 -44.53125 0.00000 1.43400 1.43400 13.10000 0.27400 1.00200 3.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.7000 0.000 0.000 0.000 0.000
65.956 1946.00000 15.8000 -44.53125 0.00000 1.43400 1.43400 13.10000 0.27400 1.00200 3.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.7000 0.000 0.000 0.000 0.000
65.966 1960.00000 16.0000 -44.53125 0.00000 1.52700 1.52700 13.30000 0.27400 1.00200 4.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
65.976 1960.00000 16.0000 -44.53125 0.00000 1.52700 1.52700 13.30000 0.27400 1.00200 4.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
65.986 1960.00000 16.0000 -44.53125 0.00000 1.52700 1.52700 13.30000 0.27400 1.00200 4.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
65.996 1960.00000 16.0000 -44.53125 0.00000 1.52700 1.52700 13.30000 0.27400 1.00200 4.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
66.006 1960.00000 16.0000 -44.53125 0.00000 1.52700 1.52700 13.30000 0.27400 1.00200 4.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
66.016 1939.00000 16.2000 -44.53125 0.00000 1.39900 1.39900 13.30000 0.27400 1.00200 3.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
66.026 1939.00000 16.2000 -44.53125 0.00000 1.39900 1.39900 13.30000 0.27400 1.00200 3.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
66.036 1939.00000 16.2000 -44.53125 0.00000 1.39900 1.39900 13.30000 0.27400 1.00200 3.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
66.046 1939.00000 16.2000 -44.53125 0.00000 1.39900 1.39900 13.30000 0.27400 1.00200 3.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
66.056 1939.00000 16.2000 -44.53125 0.00000 1.39900 1.39900 13.30000 0.27400 1.00200 3.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
66.066 1950.00000 16.8000 -44.53125 0.00000 1.53300 1.53300 13.20000 0.26800 0.30300 4.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
66.076 1950.00000 16.8000 -44.53125 0.00000 1.53300 1.53300 13.20000 0.26800 0.30300 4.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
66.086 1950.00000 16.8000 -44.53125 0.00000 1.53300 1.53300 13.20000 0.26800 0.30300 4.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
66.096 1950.00000 16.8000 -44.53125 0.00000 1.53300 1.53300 13.20000 0.26800 0.30300 4.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
66.106 1950.00000 16.8000 -44.53125 0.00000 1.53300 1.53300 13.20000 0.26800 0.30300 4.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
66.116 1915.00000 16.6000 -44.53125 0.00000 1.48000 1.48000 13.50000 0.26800 0.30300 4.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
66.126 1915.00000 16.6000 -44.53125 0.00000 1.48000 1.48000 13.50000 0.26800 0.30300 4.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
66.136 1915.00000 16.6000 -44.53125 0.00000 1.48000 1.48000 13.50000 0.26800 0.30300 4.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
66.146 1915.00000 16.6000 -44.53125 0.00000 1.48000 1.48000 13.50000 0.26800 0.30300 4.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
66.156 1915.00000 16.6000 -44.53125 0.00000 1.48000 1.48000 13.50000 0.26800 0.30300 4.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
66.166 1946.00000 16.6000 -44.53125 0.00000 1.72500 1.72500 12.70000 0.26800 0.30300 4.20000 1.00000 4.00000 4.00000 4.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
66.176 1946.00000 16.6000 -44.53125 0.00000 1.72500 1.72500 12.70000 0.26800 0.30300 4.20000 1.00000 4.00000 4.00000 4.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
66.186 1946.00000 16.6000 -44.53125 0.00000 1.72500 1.72500 12.70000 0.26800 0.30300 4.20000 1.00000 4.00000 4.00000 4.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
66.196 1946.00000 16.6000 -44.53125 0.00000 1.72500 1.72500 12.70000 0.26800 0.30300 4.20000 1.00000 4.00000 4.00000 4.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
66.206 1946.00000 16.6000 -44.53125 0.00000 1.72500 1.72500 12.70000 0.26800 0.30300 4.20000 1.00000 4.00000 4.00000 4.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
66.216 1989.00000 17.2000 -44.53125 0.00000 1.48600 1.48600 13.30000 0.26800 0.30300 4.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
66.226 1989.00000 17.2000 -44.53125 0.00000 1.48600 1.48600 13.30000 0.26800 0.30300 4.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
66.236 1989.00000 17.2000 -44.53125 0.00000 1.48600 1.48600 13.30000 0.26800 0.30300 4.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
66.246 1989.00000 17.2000 -44.53125 0.00000 1.48600 1.48600 13.30000 0.26800 0.30300 4.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
66.256 1989.00000 17.2000 -44.53125 0.00000 1.48600 1.48600 13.30000 0.26800 0.30300 4.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
66.266 1952.00000 17.1000 -44.53125 0.00000 1.49800 1.49800 13.60000 0.26800 0.27400 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.7000 0.000 0.000 0.000 0.000
66.276 1952.00000 17.1000 -44.53125 0.00000 1.49800 1.49800 13.60000 0.26800 0.27400 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.7000 0.000 0.000 0.000 0.000
66.286 1952.00000 17.1000 -44.53125 0.00000 1.49800 1.49800 13.60000 0.26800 0.27400 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.7000 0.000 0.000 0.000 0.000
66.296 1952.00000 17.1000 -44.53125 0.00000 1.49800 1.49800 13.60000 0.26800 0.27400 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.7000 0.000 0.000 0.000 0.000
66.306 1952.00000 17.1000 -44.53125 0.00000 1.49800 1.49800 13.60000 0.26800 0.27400 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.7000 0.000 0.000 0.000 0.000
66.316 1972.00000 17.2000 -44.53125 0.00000 1.53300 1.53300 13.40000 0.26800 0.27400 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
66.326 1972.00000 17.2000 -44.53125 0.00000 1.53300 1.53300 13.40000 0.26800 0.27400 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
66.336 1972.00000 17.2000 -44.53125 0.00000 1.53300 1.53300 13.40000 0.26800 0.27400 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
66.346 1972.00000 17.2000 -44.53125 0.00000 1.53300 1.53300 13.40000 0.26800 0.27400 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
66.356 1972.00000 17.2000 -44.53125 0.00000 1.53300 1.53300 13.40000 0.26800 0.27400 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
66.366 1887.00000 17.4000 -44.53125 0.00000 1.50400 1.50400 13.30000 0.26800 0.27400 4.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
66.376 1887.00000 17.4000 -44.53125 0.00000 1.50400 1.50400 13.30000 0.26800 0.27400 4.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
66.386 1887.00000 17.4000 -44.53125 0.00000 1.50400 1.50400 13.30000 0.26800 0.27400 4.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
66.396 1887.00000 17.4000 -44.53125 0.00000 1.50400 1.50400 13.30000 0.26800 0.27400 4.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
66.406 1887.00000 17.4000 -44.53125 0.00000 1.50400 1.50400 13.30000 0.26800 0.27400 4.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
66.416 1856.00000 16.9000 -44.53125 0.00000 1.52700 1.52700 13.00000 0.26800 0.27400 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.7000 0.000 0.000 0.000 0.000
66.426 1856.00000 16.9000 -44.53125 0.00000 1.52700 1.52700 13.00000 0.26800 0.27400 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.7000 0.000 0.000 0.000 0.000
66.436 1856.00000 16.9000 -44.53125 0.00000 1.52700 1.52700 13.00000 0.26800 0.27400 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.7000 0.000 0.000 0.000 0.000
66.446 1856.00000 16.9000 -44.53125 0.00000 1.52700 1.52700 13.00000 0.26800 0.27400 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.7000 0.000 0.000 0.000 0.000
66.456 1856.00000 16.9000 -44.53125 0.00000 1.52700 1.52700 13.00000 0.26800 0.27400 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.7000 0.000 0.000 0.000 0.000
66.466 1844.00000 17.4000 -44.53125 0.00000 1.61400 1.61400 12.40000 1.04000 0.27100 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
66.476 1844.00000 17.4000 -44.53125 0.00000 1.61400 1.61400 12.40000 1.04000 0.27100 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
66.486 1844.00000 17.4000 -44.53125 0.00000 1.61400 1.61400 12.40000 1.04000 0.27100 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
66.496 1844.00000 17.4000 -44.53125 0.00000 1.61400 1.61400 12.40000 1.04000 0.27100 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
66.506 1844.00000 17.4000 -44.53125 0.00000 1.61400 1.61400 12.40000 1.04000 0.27100 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
66.516 1895.00000 17.1000 -44.53125 0.00000 1.50900 1.50900 12.80000 1.04000 0.27100 4.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
66.526 1895.00000 17.1000 -44.53125 0.00000 1.50900 1.50900 12.80000 1.04000 0.27100 4.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
66.536 1895.00000 17.1000 -44.53125 0.00000 1.50900 1.50900 12.80000 1.04000 0.27100 4.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
66.546 1895.00000 17.1000 -44.53125 0.00000 1.50900 1.50900 12.80000 1.04000 0.27100 4.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
66.556 1895.00000 17.1000 -44.53125 0.00000 1.50900 1.50900 12.80000 1.04000 0.27100 4.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
66.566 1895.00000 17.1000 -44.53125 0.00000 1.31100 1.31100 13.50000 1.04000 0.27100 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.7000 0.000 0.000 0.000 0.000
66.576 1895.00000 17.1000 -44.53125 0.00000 1.31100 1.31100 13.50000 1.04000 0.27100 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.7000 0.000 0.000 0.000 0.000
66.586 1895.00000 17.1000 -44.53125 0.00000 1.31100 1.31100 13.50000 1.04000 0.27100 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.7000 0.000 0.000 0.000 0.000
66.596 1895.00000 17.1000 -44.53125 0.00000 1.31100 1.31100 13.50000 1.04000 0.27100 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.7000 0.000 0.000 0.000 0.000
66.606 1895.00000 17.1000 -44.53125 0.00000 1.31100 1.31100 13.50000 1.04000 0.27100 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.7000 0.000 0.000 0.000 0.000
66.616 1904.00000 15.4000 -44.53125 0.00000 1.50900 1.50900 13.50000 1.04000 0.27100 4.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
66.626 1904.00000 15.4000 -44.53125 0.00000 1.50900 1.50900 13.50000 1.04000 0.27100 4.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
66.636 1904.00000 15.4000 -44.53125 0.00000 1.50900 1.50900 13.50000 1.04000 0.27100 4.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
66.646 1904.00000 15.4000 -44.53125 0.00000 1.50900 1.50900 13.50000 1.04000 0.27100 4.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
66.656 1904.00000 15.4000 -44.53125 0.00000 1.50900 1.50900 13.50000 1.04000 0.27100 4.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
66.666 1920.00000 15.2000 -44.53125 0.00000 1.39900 1.39900 13.30000 1.17400 0.27400 4.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
66.676 1920.00000 15.2000 -44.53125 0.00000 1.39900 1.39900 13.30000 1.17400 0.27400 4.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
66.686 1920.00000 15.2000 -44.53125 0.00000 1.39900 1.39900 13.30000 1.17400 0.27400 4.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
66.696 1920.00000 15.2000 -44.53125 0.00000 1.39900 1.39900 13.30000 1.17400 0.27400 4.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
66.706 1920.00000 15.2000 -44.53125 0.00000 1.39900 1.39900 13.30000 1.17400 0.27400 4.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
66.716 1899.00000 15.2000 -44.53125 0.00000 1.39300 1.39300 13.20000 1.17400 0.27400 4.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
66.726 1899.00000 15.2000 -44.53125 0.00000 1.39300 1.39300 13.20000 1.17400 0.27400 4.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
66.736 1899.00000 15.2000 -44.53125 0.00000 1.39300 1.39300 13.20000 1.17400 0.27400 4.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
66.746 1899.00000 15.2000 -44.53125 0.00000 1.39300 1.39300 13.20000 1.17400 0.27400 4.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
66.756 1899.00000 15.2000 -44.53125 0.00000 1.39300 1.39300 13.20000 1.17400 0.27400 4.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
66.766 1858.00000 15.2000 -44.53125 0.00000 1.39300 1.39300 13.10000 1.17400 0.27400 4.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.0000 0.000 0.000 0.000 0.000
66.776 1858.00000 15.2000 -44.53125 0.00000 1.39300 1.39300 13.10000 1.17400 0.27400 4.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.0000 0.000 0.000 0.000 0.000
66.786 1858.00000 15.2000 -44.53125 0.00000 1.39300 1.39300 13.10000 1.17400 0.27400 4.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.0000 0.000 0.000 0.000 0.000
66.796 1858.00000 15.2000 -44.53125 0.00000 1.39300 1.39300 13.10000 1.17400 0.27400 4.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.0000 0.000 0.000 0.000 0.000
66.806 1858.00000 15.2000 -44.53125 0.00000 1.39300 1.39300 13.10000 1.17400 0.27400 4.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.0000 0.000 0.000 0.000 0.000
66.816 1781.00000 15.2000 -44.53125 0.00000 1.03700 1.03700 13.60000 1.17400 0.27400 3.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
66.826 1781.00000 15.2000 -44.53125 0.00000 1.03700 1.03700 13.60000 1.17400 0.27400 3.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
66.836 1781.00000 15.2000 -44.53125 0.00000 1.03700 1.03700 13.60000 1.17400 0.27400 3.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
66.846 1781.00000 15.2000 -44.53125 0.00000 1.03700 1.03700 13.60000 1.17400 0.27400 3.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
66.856 1781.00000 15.2000 -44.53125 0.00000 1.03700 1.03700 13.60000 1.17400 0.27400 3.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
66.866 1867.00000 15.1000 -44.53125 0.00000 1.14200 1.14200 13.30000 1.17700 0.28700 3.90000 1.00000 3.00000 3.00000 2.00000 3.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
66.876 1867.00000 15.1000 -44.53125 0.00000 1.14200 1.14200 13.30000 1.17700 0.28700 3.90000 1.00000 3.00000 3.00000 2.00000 3.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
66.886 1867.00000 15.1000 -44.53125 0.00000 1.14200 1.14200 13.30000 1.17700 0.28700 3.90000 1.00000 3.00000 3.00000 2.00000 3.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
66.896 1867.00000 15.1000 -44.53125 0.00000 1.14200 1.14200 13.30000 1.17700 0.28700 3.90000 1.00000 3.00000 3.00000 2.00000 3.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
66.906 1867.00000 15.1000 -44.53125 0.00000 1.14200 1.14200 13.30000 1.17700 0.28700 3.90000 1.00000 3.00000 3.00000 2.00000 3.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
66.916 1957.00000 15.2000 -44.53125 0.00000 1.38700 1.38700 12.90000 1.17700 0.28700 4.00000 1.00000 2.00000 2.00000 3.00000 3.00000 0.00000 0.00000 10.9000 0.000 0.000 0.000 0.000
66.926 1957.00000 15.2000 -44.53125 0.00000 1.38700 1.38700 12.90000 1.17700 0.28700 4.00000 1.00000 2.00000 2.00000 3.00000 3.00000 0.00000 0.00000 10.9000 0.000 0.000 0.000 0.000
66.936 1957.00000 15.2000 -44.53125 0.00000 1.38700 1.38700 12.90000 1.17700 0.28700 4.00000 1.00000 2.00000 2.00000 3.00000 3.00000 0.00000 0.00000 10.9000 0.000 0.000 0.000 0.000
66.946 1957.00000 15.2000 -44.53125 0.00000 1.38700 1.38700 12.90000 1.17700 0.28700 4.00000 1.00000 2.00000 2.00000 3.00000 3.00000 0.00000 0.00000 10.9000 0.000 0.000 0.000 0.000
66.956 1957.00000 15.2000 -44.53125 0.00000 1.38700 1.38700 12.90000 1.17700 0.28700 4.00000 1.00000 2.00000 2.00000 3.00000 3.00000 0.00000 0.00000 10.9000 0.000 0.000 0.000 0.000
66.966 1856.00000 15.2000 -44.53125 0.00000 1.47400 1.47400 13.70000 1.17700 0.28700 3.90000 1.00000 2.00000 3.00000 2.00000 2.00000 0.00000 0.00000 11.0000 0.000 0.000 0.000 0.000
66.976 1856.00000 15.2000 -44.53125 0.00000 1.47400 1.47400 13.70000 1.17700 0.28700 3.90000 1.00000 2.00000 3.00000 2.00000 2.00000 0.00000 0.00000 11.0000 0.000 0.000 0.000 0.000
66.986 1856.00000 15.2000 -44.53125 0.00000 1.47400 1.47400 13.70000 1.17700 0.28700 3.90000 1.00000 2.00000 3.00000 2.00000 2.00000 0.00000 0.00000 11.0000 0.000 0.000 0.000 0.000
66.996 1856.00000 15.2000 -44.53125 0.00000 1.47400 1.47400 13.70000 1.17700 0.28700 3.90000 1.00000 2.00000 3.00000 2.00000 2.00000 0.00000 0.00000 11.0000 0.000 0.000 0.000 0.000
67.006 1856.00000 15.2000 -44.53125 0.00000 1.47400 1.47400 13.70000 1.17700 0.28700 3.90000 1.00000 2.00000 3.00000 2.00000 2.00000 0.00000 0.00000 11.0000 0.000 0.000 0.000 0.000
67.016 1803.00000 15.2000 -44.53125 0.00000 1.55000 1.55000 13.30000 1.17700 0.28700 3.80000 1.00000 2.00000 3.00000 2.00000 3.00000 0.00000 0.00000 11.0000 0.000 0.000 0.000 0.000
67.026 1803.00000 15.2000 -44.53125 0.00000 1.55000 1.55000 13.30000 1.17700 0.28700 3.80000 1.00000 2.00000 3.00000 2.00000 3.00000 0.00000 0.00000 11.0000 0.000 0.000 0.000 0.000
67.036 1803.00000 15.2000 -44.53125 0.00000 1.55000 1.55000 13.30000 1.17700 0.28700 3.80000 1.00000 2.00000 3.00000 2.00000 3.00000 0.00000 0.00000 11.0000 0.000 0.000 0.000 0.000
67.046 1803.00000 15.2000 -44.53125 0.00000 1.55000 1.55000 13.30000 1.17700 0.28700 3.80000 1.00000 2.00000 3.00000 2.00000 3.00000 0.00000 0.00000 11.0000 0.000 0.000 0.000 0.000
67.056 1803.00000 15.2000 -44.53125 0.00000 1.55000 1.55000 13.30000 1.17700 0.28700 3.80000 1.00000 2.00000 3.00000 2.00000 3.00000 0.00000 0.00000 11.0000 0.000 0.000 0.000 0.000
67.066 1798.00000 15.2000 -44.53125 0.00000 1.23500 1.23500 13.30000 1.06200 0.31500 4.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 10.9000 0.000 0.000 0.000 0.000
67.076 1798.00000 15.2000 -44.53125 0.00000 1.23500 1.23500 13.30000 1.06200 0.31500 4.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 10.9000 0.000 0.000 0.000 0.000
67.086 1798.00000 15.2000 -44.53125 0.00000 1.23500 1.23500 13.30000 1.06200 0.31500 4.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 10.9000 0.000 0.000 0.000 0.000
67.096 1798.00000 15.2000 -44.53125 0.00000 1.23500 1.23500 13.30000 1.06200 0.31500 4.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 10.9000 0.000 0.000 0.000 0.000
67.106 1798.00000 15.2000 -44.53125 0.00000 1.23500 1.23500 13.30000 1.06200 0.31500 4.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 10.9000 0.000 0.000 0.000 0.000
67.116 1875.00000 15.2000 -44.53125 0.00000 1.23000 1.23000 13.20000 1.06200 0.31500 3.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 10.9000 0.000 0.000 0.000 0.000
67.126 1875.00000 15.2000 -44.53125 0.00000 1.23000 1.23000 13.20000 1.06200 0.31500 3.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 10.9000 0.000 0.000 0.000 0.000
67.136 1875.00000 15.2000 -44.53125 0.00000 1.23000 1.23000 13.20000 1.06200 0.31500 3.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 10.9000 0.000 0.000 0.000 0.000
67.146 1875.00000 15.2000 -44.53125 0.00000 1.23000 1.23000 13.20000 1.06200 0.31500 3.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 10.9000 0.000 0.000 0.000 0.000
67.156 1875.00000 15.2000 -44.53125 0.00000 1.23000 1.23000 13.20000 1.06200 0.31500 3.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 10.9000 0.000 0.000 0.000 0.000
67.166 1835.00000 15.2000 -44.53125 0.00000 1.39300 1.39300 13.20000 1.06200 0.31500 3.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 10.9000 0.000 0.000 0.000 0.000
67.176 1835.00000 15.2000 -44.53125 0.00000 1.39300 1.39300 13.20000 1.06200 0.31500 3.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 10.9000 0.000 0.000 0.000 0.000
67.186 1835.00000 15.2000 -44.53125 0.00000 1.39300 1.39300 13.20000 1.06200 0.31500 3.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 10.9000 0.000 0.000 0.000 0.000
67.196 1835.00000 15.2000 -44.53125 0.00000 1.39300 1.39300 13.20000 1.06200 0.31500 3.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 10.9000 0.000 0.000 0.000 0.000
67.206 1835.00000 15.2000 -44.53125 0.00000 1.39300 1.39300 13.20000 1.06200 0.31500 3.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 10.9000 0.000 0.000 0.000 0.000
67.216 1785.00000 15.2000 -44.53125 0.00000 1.27600 1.27600 13.30000 1.06200 0.31500 3.90000 1.00000 3.00000 3.00000 2.00000 2.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
67.226 1785.00000 15.2000 -44.53125 0.00000 1.27600 1.27600 13.30000 1.06200 0.31500 3.90000 1.00000 3.00000 3.00000 2.00000 2.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
67.236 1785.00000 15.2000 -44.53125 0.00000 1.27600 1.27600 13.30000 1.06200 0.31500 3.90000 1.00000 3.00000 3.00000 2.00000 2.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
67.246 1785.00000 15.2000 -44.53125 0.00000 1.27600 1.27600 13.30000 1.06200 0.31500 3.90000 1.00000 3.00000 3.00000 2.00000 2.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
67.256 1785.00000 15.2000 -44.53125 0.00000 1.27600 1.27600 13.30000 1.06200 0.31500 3.90000 1.00000 3.00000 3.00000 2.00000 2.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
67.266 1826.00000 15.1000 -44.53125 0.00000 1.09000 1.09000 13.50000 1.09800 0.49700 3.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.0000 0.000 0.000 0.000 0.000
67.276 1826.00000 15.1000 -44.53125 0.00000 1.09000 1.09000 13.50000 1.09800 0.49700 3.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.0000 0.000 0.000 0.000 0.000
67.286 1826.00000 15.1000 -44.53125 0.00000 1.09000 1.09000 13.50000 1.09800 0.49700 3.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.0000 0.000 0.000 0.000 0.000
67.296 1826.00000 15.1000 -44.53125 0.00000 1.09000 1.09000 13.50000 1.09800 0.49700 3.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.0000 0.000 0.000 0.000 0.000
67.306 1826.00000 15.1000 -44.53125 0.00000 1.09000 1.09000 13.50000 1.09800 0.49700 3.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.0000 0.000 0.000 0.000 0.000
67.316 1813.00000 15.2000 -44.53125 0.00000 1.27600 1.27600 13.30000 1.09800 0.49700 4.00000 1.00000 3.00000 3.00000 2.00000 2.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
67.326 1813.00000 15.2000 -44.53125 0.00000 1.27600 1.27600 13.30000 1.09800 0.49700 4.00000 1.00000 3.00000 3.00000 2.00000 2.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
67.336 1813.00000 15.2000 -44.53125 0.00000 1.27600 1.27600 13.30000 1.09800 0.49700 4.00000 1.00000 3.00000 3.00000 2.00000 2.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
67.346 1813.00000 15.2000 -44.53125 0.00000 1.27600 1.27600 13.30000 1.09800 0.49700 4.00000 1.00000 3.00000 3.00000 2.00000 2.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
67.356 1813.00000 15.2000 -44.53125 0.00000 1.27600 1.27600 13.30000 1.09800 0.49700 4.00000 1.00000 3.00000 3.00000 2.00000 2.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
67.366 1787.00000 15.1000 -44.53125 0.00000 1.02000 1.02000 13.30000 1.09800 0.49700 3.90000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.0000 0.000 0.000 0.000 0.000
67.376 1787.00000 15.1000 -44.53125 0.00000 1.02000 1.02000 13.30000 1.09800 0.49700 3.90000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.0000 0.000 0.000 0.000 0.000
67.386 1787.00000 15.1000 -44.53125 0.00000 1.02000 1.02000 13.30000 1.09800 0.49700 3.90000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.0000 0.000 0.000 0.000 0.000
67.396 1787.00000 15.1000 -44.53125 0.00000 1.02000 1.02000 13.30000 1.09800 0.49700 3.90000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.0000 0.000 0.000 0.000 0.000
67.406 1787.00000 15.1000 -44.53125 0.00000 1.02000 1.02000 13.30000 1.09800 0.49700 3.90000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.0000 0.000 0.000 0.000 0.000
67.416 1758.00000 15.2000 -44.53125 0.00000 1.33500 1.33500 12.60000 1.09800 0.49700 3.90000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
67.426 1758.00000 15.2000 -44.53125 0.00000 1.33500 1.33500 12.60000 1.09800 0.49700 3.90000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
67.436 1758.00000 15.2000 -44.53125 0.00000 1.33500 1.33500 12.60000 1.09800 0.49700 3.90000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
67.446 1758.00000 15.2000 -44.53125 0.00000 1.33500 1.33500 12.60000 1.09800 0.49700 3.90000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
67.456 1758.00000 15.2000 -44.53125 0.00000 1.33500 1.33500 12.60000 1.09800 0.49700 3.90000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
67.466 1758.00000 15.2000 -44.53125 0.00000 1.54400 1.54400 13.40000 1.05600 1.10100 3.90000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
67.476 1758.00000 15.2000 -44.53125 0.00000 1.54400 1.54400 13.40000 1.05600 1.10100 3.90000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
67.486 1758.00000 15.2000 -44.53125 0.00000 1.54400 1.54400 13.40000 1.05600 1.10100 3.90000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
67.496 1758.00000 15.2000 -44.53125 0.00000 1.54400 1.54400 13.40000 1.05600 1.10100 3.90000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
67.506 1758.00000 15.2000 -44.53125 0.00000 1.54400 1.54400 13.40000 1.05600 1.10100 3.90000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
67.516 1794.00000 15.2000 -44.53125 0.00000 1.23500 1.23500 13.20000 1.05600 1.10100 3.90000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
67.526 1794.00000 15.2000 -44.53125 0.00000 1.23500 1.23500 13.20000 1.05600 1.10100 3.90000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
67.536 1794.00000 15.2000 -44.53125 0.00000 1.23500 1.23500 13.20000 1.05600 1.10100 3.90000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
67.546 1794.00000 15.2000 -44.53125 0.00000 1.23500 1.23500 13.20000 1.05600 1.10100 3.90000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
67.556 1794.00000 15.2000 -44.53125 0.00000 1.23500 1.23500 13.20000 1.05600 1.10100 3.90000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
67.566 1761.00000 15.2000 -44.53125 0.00000 1.22400 1.22400 13.10000 1.05600 1.10100 3.90000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
67.576 1761.00000 15.2000 -44.53125 0.00000 1.22400 1.22400 13.10000 1.05600 1.10100 3.90000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
67.586 1761.00000 15.2000 -44.53125 0.00000 1.22400 1.22400 13.10000 1.05600 1.10100 3.90000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
67.596 1761.00000 15.2000 -44.53125 0.00000 1.22400 1.22400 13.10000 1.05600 1.10100 3.90000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
67.606 1761.00000 15.2000 -44.53125 0.00000 1.22400 1.22400 13.10000 1.05600 1.10100 3.90000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
67.616 1734.00000 15.2000 -44.53125 0.00000 1.25900 1.25900 13.40000 1.05600 1.10100 3.90000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.2000 0.000 0.000 0.000 0.000
67.626 1734.00000 15.2000 -44.53125 0.00000 1.25900 1.25900 13.40000 1.05600 1.10100 3.90000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.2000 0.000 0.000 0.000 0.000
67.636 1734.00000 15.2000 -44.53125 0.00000 1.25900 1.25900 13.40000 1.05600 1.10100 3.90000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.2000 0.000 0.000 0.000 0.000
67.646 1734.00000 15.2000 -44.53125 0.00000 1.25900 1.25900 13.40000 1.05600 1.10100 3.90000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.2000 0.000 0.000 0.000 0.000
67.656 1734.00000 15.2000 -44.53125 0.00000 1.25900 1.25900 13.40000 1.05600 1.10100 3.90000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.2000 0.000 0.000 0.000 0.000
67.666 1710.00000 15.2000 -44.53125 0.00000 1.41600 1.41600 13.50000 1.05600 1.13600 3.90000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.3000 0.000 0.000 0.000 0.000
67.676 1710.00000 15.2000 -44.53125 0.00000 1.41600 1.41600 13.50000 1.05600 1.13600 3.90000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.3000 0.000 0.000 0.000 0.000
67.686 1710.00000 15.2000 -44.53125 0.00000 1.41600 1.41600 13.50000 1.05600 1.13600 3.90000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.3000 0.000 0.000 0.000 0.000
67.696 1710.00000 15.2000 -44.53125 0.00000 1.41600 1.41600 13.50000 1.05600 1.13600 3.90000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.3000 0.000 0.000 0.000 0.000
67.706 1710.00000 15.2000 -44.53125 0.00000 1.41600 1.41600 13.50000 1.05600 1.13600 3.90000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.3000 0.000 0.000 0.000 0.000
67.716 1735.00000 15.2000 -44.53125 0.00000 1.30500 1.30500 13.10000 1.05600 1.13600 3.90000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
67.726 1735.00000 15.2000 -44.53125 0.00000 1.30500 1.30500 13.10000 1.05600 1.13600 3.90000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
67.736 1735.00000 15.2000 -44.53125 0.00000 1.30500 1.30500 13.10000 1.05600 1.13600 3.90000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
67.746 1735.00000 15.2000 -44.53125 0.00000 1.30500 1.30500 13.10000 1.05600 1.13600 3.90000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
67.756 1735.00000 15.2000 -44.53125 0.00000 1.30500 1.30500 13.10000 1.05600 1.13600 3.90000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
if i scale the injectors to the proper size, the car wont even turn over so here is one with as close as i can figure it out to be, usually at approx 3200 rpm it will buck a few times for some odd reason
its a whole lot of text so ill put it in a spoiler tag so its not all huge post is huge
Spoiler
Time/s Engine Speed Throttle Fuel trim Ignition trim Maf in Maf out Battery O2 bank1 O2 bank2 Engine Load Sw 12Vdc Inj1 % Inj2 % Inj3 % Inj4 % Inj5 % Inj6 % AFR AnalogA in AnalogB in AnalogA out AnalogB out
0.000 2061.00000 20.0000 -44.53125 0.00000 1.55600 1.55600 12.90000 1.06600 0.97900 5.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.6000 0.000 0.000 0.000 0.000
0.010 2061.00000 20.0000 -44.53125 0.00000 1.55600 1.55600 12.90000 1.06600 0.97900 5.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.6000 0.000 0.000 0.000 0.000
0.020 2087.00000 20.3000 -44.53125 0.00000 1.58500 1.58500 13.40000 0.90600 1.01100 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
0.030 2087.00000 20.3000 -44.53125 0.00000 1.58500 1.58500 13.40000 0.90600 1.01100 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
0.040 2087.00000 20.3000 -44.53125 0.00000 1.58500 1.58500 13.40000 0.90600 1.01100 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
0.050 2087.00000 20.3000 -44.53125 0.00000 1.58500 1.58500 13.40000 0.90600 1.01100 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
0.060 2087.00000 20.3000 -44.53125 0.00000 1.58500 1.58500 13.40000 0.90600 1.01100 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
0.070 2076.00000 20.1000 -44.53125 0.00000 1.54400 1.54400 12.70000 0.90600 1.01100 5.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
0.080 2076.00000 20.1000 -44.53125 0.00000 1.54400 1.54400 12.70000 0.90600 1.01100 5.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
0.090 2076.00000 20.1000 -44.53125 0.00000 1.54400 1.54400 12.70000 0.90600 1.01100 5.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
0.100 2076.00000 20.1000 -44.53125 0.00000 1.54400 1.54400 12.70000 0.90600 1.01100 5.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
0.110 2076.00000 20.1000 -44.53125 0.00000 1.54400 1.54400 12.70000 0.90600 1.01100 5.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
0.120 2101.00000 19.8000 -44.53125 0.00000 1.54400 1.54400 13.50000 0.90600 1.01100 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
0.130 2101.00000 19.8000 -44.53125 0.00000 1.54400 1.54400 13.50000 0.90600 1.01100 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
0.140 2101.00000 19.8000 -44.53125 0.00000 1.54400 1.54400 13.50000 0.90600 1.01100 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
0.150 2101.00000 19.8000 -44.53125 0.00000 1.54400 1.54400 13.50000 0.90600 1.01100 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
0.160 2101.00000 19.8000 -44.53125 0.00000 1.54400 1.54400 13.50000 0.90600 1.01100 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
0.170 2101.00000 19.8000 -44.53125 0.00000 1.54400 1.54400 13.50000 0.90600 1.01100 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
0.180 2101.00000 19.8000 -44.53125 0.00000 1.54400 1.54400 13.50000 0.90600 1.01100 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
0.190 2101.00000 19.8000 -44.53125 0.00000 1.54400 1.54400 13.50000 0.90600 1.01100 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
0.200 2101.00000 19.8000 -44.53125 0.00000 1.54400 1.54400 13.50000 0.90600 1.01100 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
0.210 2101.00000 19.8000 -44.53125 0.00000 1.54400 1.54400 13.50000 0.90600 1.01100 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
0.220 2090.00000 19.8000 -44.53125 0.00000 1.54400 1.54400 12.90000 0.93200 0.98900 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
0.230 2090.00000 19.8000 -44.53125 0.00000 1.54400 1.54400 12.90000 0.93200 0.98900 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
0.240 2090.00000 19.8000 -44.53125 0.00000 1.54400 1.54400 12.90000 0.93200 0.98900 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
0.250 2090.00000 19.8000 -44.53125 0.00000 1.54400 1.54400 12.90000 0.93200 0.98900 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
0.260 2090.00000 19.8000 -44.53125 0.00000 1.54400 1.54400 12.90000 0.93200 0.98900 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
0.270 2090.00000 19.8000 -44.53125 0.00000 1.54400 1.54400 12.90000 0.93200 0.98900 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
0.280 2090.00000 19.8000 -44.53125 0.00000 1.54400 1.54400 12.90000 0.93200 0.98900 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
0.290 2090.00000 19.8000 -44.53125 0.00000 1.54400 1.54400 12.90000 0.93200 0.98900 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
0.300 2090.00000 19.8000 -44.53125 0.00000 1.54400 1.54400 12.90000 0.93200 0.98900 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
0.310 2090.00000 19.8000 -44.53125 0.00000 1.54400 1.54400 12.90000 0.93200 0.98900 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
0.320 2085.00000 20.3000 -44.53125 0.00000 1.57900 1.57900 12.40000 0.93200 0.98900 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
0.330 2085.00000 20.3000 -44.53125 0.00000 1.57900 1.57900 12.40000 0.93200 0.98900 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
0.340 2085.00000 20.3000 -44.53125 0.00000 1.57900 1.57900 12.40000 0.93200 0.98900 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
0.350 2085.00000 20.3000 -44.53125 0.00000 1.57900 1.57900 12.40000 0.93200 0.98900 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
0.360 2085.00000 20.3000 -44.53125 0.00000 1.57900 1.57900 12.40000 0.93200 0.98900 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
0.370 2103.00000 20.0000 -44.53125 0.00000 1.57900 1.57900 13.50000 0.93200 0.98900 5.60000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
0.380 2103.00000 20.0000 -44.53125 0.00000 1.57900 1.57900 13.50000 0.93200 0.98900 5.60000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
0.390 2103.00000 20.0000 -44.53125 0.00000 1.57900 1.57900 13.50000 0.93200 0.98900 5.60000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
0.400 2103.00000 20.0000 -44.53125 0.00000 1.57900 1.57900 13.50000 0.93200 0.98900 5.60000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
0.410 2103.00000 20.0000 -44.53125 0.00000 1.57900 1.57900 13.50000 0.93200 0.98900 5.60000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
0.420 2066.00000 20.0000 -44.53125 0.00000 1.53900 1.53900 13.30000 0.93200 0.98900 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
0.430 2066.00000 20.0000 -44.53125 0.00000 1.53900 1.53900 13.30000 0.93200 0.98900 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
0.440 2066.00000 20.0000 -44.53125 0.00000 1.53900 1.53900 13.30000 0.93200 0.98900 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
0.450 2066.00000 20.0000 -44.53125 0.00000 1.53900 1.53900 13.30000 0.93200 0.98900 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
0.460 2066.00000 20.0000 -44.53125 0.00000 1.53900 1.53900 13.30000 0.93200 0.98900 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
0.470 2066.00000 20.0000 -44.53125 0.00000 1.53900 1.53900 13.30000 0.93200 0.98900 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
0.480 2066.00000 20.0000 -44.53125 0.00000 1.53900 1.53900 13.30000 0.93200 0.98900 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
0.490 2066.00000 20.0000 -44.53125 0.00000 1.53900 1.53900 13.30000 0.93200 0.98900 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
0.500 2066.00000 20.0000 -44.53125 0.00000 1.53900 1.53900 13.30000 0.93200 0.98900 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
0.510 2066.00000 20.0000 -44.53125 0.00000 1.53900 1.53900 13.30000 0.93200 0.98900 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
0.520 2066.00000 20.0000 -44.53125 0.00000 1.53900 1.53900 13.30000 0.93200 0.98900 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
0.530 2066.00000 20.0000 -44.53125 0.00000 1.53900 1.53900 13.30000 0.93200 0.98900 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
0.540 2066.00000 20.0000 -44.53125 0.00000 1.53900 1.53900 13.30000 0.93200 0.98900 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
0.550 2066.00000 20.0000 -44.53125 0.00000 1.53900 1.53900 13.30000 0.93200 0.98900 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
0.560 2066.00000 20.0000 -44.53125 0.00000 1.53900 1.53900 13.30000 0.93200 0.98900 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
0.570 2066.00000 20.0000 -44.53125 0.00000 1.53900 1.53900 13.30000 0.93200 0.98900 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
0.580 2066.00000 20.0000 -44.53125 0.00000 1.53900 1.53900 13.30000 0.93200 0.98900 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
0.590 2066.00000 20.0000 -44.53125 0.00000 1.53900 1.53900 13.30000 0.93200 0.98900 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
0.600 2066.00000 20.0000 -44.53125 0.00000 1.53900 1.53900 13.30000 0.93200 0.98900 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
0.610 2066.00000 20.0000 -44.53125 0.00000 1.53900 1.53900 13.30000 0.93200 0.98900 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
0.620 2066.00000 20.0000 -44.53125 0.00000 1.53900 1.53900 13.30000 0.93200 0.98900 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
0.630 2066.00000 20.0000 -44.53125 0.00000 1.53900 1.53900 13.30000 0.93200 0.98900 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
0.640 2066.00000 20.0000 -44.53125 0.00000 1.53900 1.53900 13.30000 0.93200 0.98900 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
0.650 2066.00000 20.0000 -44.53125 0.00000 1.53900 1.53900 13.30000 0.93200 0.98900 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
0.660 2066.00000 20.0000 -44.53125 0.00000 1.53900 1.53900 13.30000 0.93200 0.98900 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
0.670 2081.00000 20.1000 -44.53125 0.00000 1.52100 1.52100 13.20000 0.34100 0.98600 5.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
0.680 2081.00000 20.1000 -44.53125 0.00000 1.52100 1.52100 13.20000 0.34100 0.98600 5.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
0.690 2081.00000 20.1000 -44.53125 0.00000 1.52100 1.52100 13.20000 0.34100 0.98600 5.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
0.700 2081.00000 20.1000 -44.53125 0.00000 1.52100 1.52100 13.20000 0.34100 0.98600 5.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
0.710 2081.00000 20.1000 -44.53125 0.00000 1.52100 1.52100 13.20000 0.34100 0.98600 5.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
0.720 2081.00000 20.1000 -44.53125 0.00000 1.52100 1.52100 13.20000 0.34100 0.98600 5.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
0.730 2081.00000 20.1000 -44.53125 0.00000 1.52100 1.52100 13.20000 0.34100 0.98600 5.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
0.740 2081.00000 20.1000 -44.53125 0.00000 1.52100 1.52100 13.20000 0.34100 0.98600 5.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
0.750 2081.00000 20.1000 -44.53125 0.00000 1.52100 1.52100 13.20000 0.34100 0.98600 5.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
0.760 2081.00000 20.1000 -44.53125 0.00000 1.52100 1.52100 13.20000 0.34100 0.98600 5.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
0.770 2081.00000 20.1000 -44.53125 0.00000 1.52100 1.52100 13.20000 0.34100 0.98600 5.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
0.780 2081.00000 20.1000 -44.53125 0.00000 1.52100 1.52100 13.20000 0.34100 0.98600 5.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
0.790 2081.00000 20.1000 -44.53125 0.00000 1.52100 1.52100 13.20000 0.34100 0.98600 5.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
0.800 2081.00000 20.1000 -44.53125 0.00000 1.52100 1.52100 13.20000 0.34100 0.98600 5.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
0.810 2081.00000 20.1000 -44.53125 0.00000 1.52100 1.52100 13.20000 0.34100 0.98600 5.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
0.820 2081.00000 20.1000 -44.53125 0.00000 1.52100 1.52100 13.20000 0.34100 0.98600 5.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
0.830 2081.00000 20.1000 -44.53125 0.00000 1.52100 1.52100 13.20000 0.34100 0.98600 5.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
0.840 2081.00000 20.1000 -44.53125 0.00000 1.52100 1.52100 13.20000 0.34100 0.98600 5.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
0.850 2081.00000 20.1000 -44.53125 0.00000 1.52100 1.52100 13.20000 0.34100 0.98600 5.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
0.860 2081.00000 20.1000 -44.53125 0.00000 1.52100 1.52100 13.20000 0.34100 0.98600 5.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
0.870 2081.00000 20.1000 -44.53125 0.00000 1.52100 1.52100 13.20000 0.34100 0.98600 5.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
0.880 2081.00000 20.1000 -44.53125 0.00000 1.52100 1.52100 13.20000 0.34100 0.98600 5.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
0.890 2081.00000 20.1000 -44.53125 0.00000 1.52100 1.52100 13.20000 0.34100 0.98600 5.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
0.900 2081.00000 20.1000 -44.53125 0.00000 1.52100 1.52100 13.20000 0.34100 0.98600 5.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
0.910 2081.00000 20.1000 -44.53125 0.00000 1.52100 1.52100 13.20000 0.34100 0.98600 5.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
0.920 2128.00000 20.3000 -44.53125 0.00000 1.57400 1.57400 13.10000 0.34100 0.98600 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
0.930 2128.00000 20.3000 -44.53125 0.00000 1.57400 1.57400 13.10000 0.34100 0.98600 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
0.940 2128.00000 20.3000 -44.53125 0.00000 1.57400 1.57400 13.10000 0.34100 0.98600 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
0.950 2128.00000 20.3000 -44.53125 0.00000 1.57400 1.57400 13.10000 0.34100 0.98600 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
0.960 2128.00000 20.3000 -44.53125 0.00000 1.57400 1.57400 13.10000 0.34100 0.98600 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
0.970 2068.00000 20.1000 -44.53125 0.00000 1.57400 1.57400 13.40000 0.34100 0.98600 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
0.980 2068.00000 20.1000 -44.53125 0.00000 1.57400 1.57400 13.40000 0.34100 0.98600 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
0.990 2068.00000 20.1000 -44.53125 0.00000 1.57400 1.57400 13.40000 0.34100 0.98600 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
1.000 2068.00000 20.1000 -44.53125 0.00000 1.57400 1.57400 13.40000 0.34100 0.98600 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
1.010 2068.00000 20.1000 -44.53125 0.00000 1.57400 1.57400 13.40000 0.34100 0.98600 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
1.020 2067.00000 19.8000 -44.53125 0.00000 1.56200 1.56200 13.00000 0.34100 0.98600 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
1.030 2067.00000 19.8000 -44.53125 0.00000 1.56200 1.56200 13.00000 0.34100 0.98600 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
1.040 2067.00000 19.8000 -44.53125 0.00000 1.56200 1.56200 13.00000 0.34100 0.98600 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
1.050 2067.00000 19.8000 -44.53125 0.00000 1.56200 1.56200 13.00000 0.34100 0.98600 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
1.060 2067.00000 19.8000 -44.53125 0.00000 1.56200 1.56200 13.00000 0.34100 0.98600 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
1.070 2093.00000 20.0000 -44.53125 0.00000 1.57400 1.57400 12.60000 0.34700 0.96000 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
1.080 2093.00000 20.0000 -44.53125 0.00000 1.57400 1.57400 12.60000 0.34700 0.96000 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
1.090 2093.00000 20.0000 -44.53125 0.00000 1.57400 1.57400 12.60000 0.34700 0.96000 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
1.100 2093.00000 20.0000 -44.53125 0.00000 1.57400 1.57400 12.60000 0.34700 0.96000 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
1.110 2093.00000 20.0000 -44.53125 0.00000 1.57400 1.57400 12.60000 0.34700 0.96000 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
1.120 2135.00000 20.0000 -44.53125 0.00000 1.56800 1.56800 13.30000 0.34700 0.96000 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
1.130 2135.00000 20.0000 -44.53125 0.00000 1.56800 1.56800 13.30000 0.34700 0.96000 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
1.140 2135.00000 20.0000 -44.53125 0.00000 1.56800 1.56800 13.30000 0.34700 0.96000 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
1.150 2135.00000 20.0000 -44.53125 0.00000 1.56800 1.56800 13.30000 0.34700 0.96000 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
1.160 2135.00000 20.0000 -44.53125 0.00000 1.56800 1.56800 13.30000 0.34700 0.96000 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
1.170 2066.00000 19.7000 -44.53125 0.00000 1.52700 1.52700 13.20000 0.34700 0.96000 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
1.180 2066.00000 19.7000 -44.53125 0.00000 1.52700 1.52700 13.20000 0.34700 0.96000 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
1.190 2066.00000 19.7000 -44.53125 0.00000 1.52700 1.52700 13.20000 0.34700 0.96000 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
1.200 2066.00000 19.7000 -44.53125 0.00000 1.52700 1.52700 13.20000 0.34700 0.96000 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
1.210 2066.00000 19.7000 -44.53125 0.00000 1.52700 1.52700 13.20000 0.34700 0.96000 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
1.220 2065.00000 20.3000 -44.53125 0.00000 1.55600 1.55600 12.70000 0.34700 0.96000 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
1.230 2065.00000 20.3000 -44.53125 0.00000 1.55600 1.55600 12.70000 0.34700 0.96000 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
1.240 2065.00000 20.3000 -44.53125 0.00000 1.55600 1.55600 12.70000 0.34700 0.96000 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
1.250 2065.00000 20.3000 -44.53125 0.00000 1.55600 1.55600 12.70000 0.34700 0.96000 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
1.260 2065.00000 20.3000 -44.53125 0.00000 1.55600 1.55600 12.70000 0.34700 0.96000 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
1.270 2134.00000 20.1000 -44.53125 0.00000 1.58500 1.58500 13.20000 0.56800 0.88700 5.60000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
1.280 2134.00000 20.1000 -44.53125 0.00000 1.58500 1.58500 13.20000 0.56800 0.88700 5.60000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
1.290 2134.00000 20.1000 -44.53125 0.00000 1.58500 1.58500 13.20000 0.56800 0.88700 5.60000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
1.300 2134.00000 20.1000 -44.53125 0.00000 1.58500 1.58500 13.20000 0.56800 0.88700 5.60000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
1.310 2134.00000 20.1000 -44.53125 0.00000 1.58500 1.58500 13.20000 0.56800 0.88700 5.60000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
1.320 2088.00000 20.3000 -44.53125 0.00000 1.56800 1.56800 13.60000 0.56800 0.88700 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
1.330 2088.00000 20.3000 -44.53125 0.00000 1.56800 1.56800 13.60000 0.56800 0.88700 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
1.340 2088.00000 20.3000 -44.53125 0.00000 1.56800 1.56800 13.60000 0.56800 0.88700 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
1.350 2088.00000 20.3000 -44.53125 0.00000 1.56800 1.56800 13.60000 0.56800 0.88700 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
1.360 2088.00000 20.3000 -44.53125 0.00000 1.56800 1.56800 13.60000 0.56800 0.88700 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
1.370 2064.00000 20.0000 -44.53125 0.00000 1.53900 1.53900 12.80000 0.56800 0.88700 5.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
1.380 2064.00000 20.0000 -44.53125 0.00000 1.53900 1.53900 12.80000 0.56800 0.88700 5.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
1.390 2064.00000 20.0000 -44.53125 0.00000 1.53900 1.53900 12.80000 0.56800 0.88700 5.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
1.400 2064.00000 20.0000 -44.53125 0.00000 1.53900 1.53900 12.80000 0.56800 0.88700 5.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
1.410 2064.00000 20.0000 -44.53125 0.00000 1.53900 1.53900 12.80000 0.56800 0.88700 5.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
1.420 2138.00000 19.8000 -44.53125 0.00000 1.55600 1.55600 13.30000 0.56800 0.88700 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
1.430 2138.00000 19.8000 -44.53125 0.00000 1.55600 1.55600 13.30000 0.56800 0.88700 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
1.440 2138.00000 19.8000 -44.53125 0.00000 1.55600 1.55600 13.30000 0.56800 0.88700 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
1.450 2138.00000 19.8000 -44.53125 0.00000 1.55600 1.55600 13.30000 0.56800 0.88700 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
1.460 2138.00000 19.8000 -44.53125 0.00000 1.55600 1.55600 13.30000 0.56800 0.88700 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
1.470 2097.00000 20.3000 -44.53125 0.00000 1.56800 1.56800 13.30000 1.04000 0.75600 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
1.480 2097.00000 20.3000 -44.53125 0.00000 1.56800 1.56800 13.30000 1.04000 0.75600 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
1.490 2097.00000 20.3000 -44.53125 0.00000 1.56800 1.56800 13.30000 1.04000 0.75600 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
1.500 2097.00000 20.3000 -44.53125 0.00000 1.56800 1.56800 13.30000 1.04000 0.75600 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
1.510 2097.00000 20.3000 -44.53125 0.00000 1.56800 1.56800 13.30000 1.04000 0.75600 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
1.520 2075.00000 20.1000 -44.53125 0.00000 1.55600 1.55600 13.40000 1.04000 0.75600 5.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
1.530 2075.00000 20.1000 -44.53125 0.00000 1.55600 1.55600 13.40000 1.04000 0.75600 5.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
1.540 2075.00000 20.1000 -44.53125 0.00000 1.55600 1.55600 13.40000 1.04000 0.75600 5.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
1.550 2075.00000 20.1000 -44.53125 0.00000 1.55600 1.55600 13.40000 1.04000 0.75600 5.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
1.560 2075.00000 20.1000 -44.53125 0.00000 1.55600 1.55600 13.40000 1.04000 0.75600 5.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
1.570 2070.00000 20.0000 -44.53125 0.00000 1.53300 1.53300 12.90000 1.04000 0.75600 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.6000 0.000 0.000 0.000 0.000
1.580 2070.00000 20.0000 -44.53125 0.00000 1.53300 1.53300 12.90000 1.04000 0.75600 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.6000 0.000 0.000 0.000 0.000
1.590 2070.00000 20.0000 -44.53125 0.00000 1.53300 1.53300 12.90000 1.04000 0.75600 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.6000 0.000 0.000 0.000 0.000
1.600 2070.00000 20.0000 -44.53125 0.00000 1.53300 1.53300 12.90000 1.04000 0.75600 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.6000 0.000 0.000 0.000 0.000
1.610 2070.00000 20.0000 -44.53125 0.00000 1.53300 1.53300 12.90000 1.04000 0.75600 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.6000 0.000 0.000 0.000 0.000
1.620 2132.00000 19.7000 -44.53125 0.00000 1.56200 1.56200 13.30000 1.04000 0.75600 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
1.630 2132.00000 19.7000 -44.53125 0.00000 1.56200 1.56200 13.30000 1.04000 0.75600 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
1.640 2132.00000 19.7000 -44.53125 0.00000 1.56200 1.56200 13.30000 1.04000 0.75600 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
1.650 2132.00000 19.7000 -44.53125 0.00000 1.56200 1.56200 13.30000 1.04000 0.75600 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
1.660 2132.00000 19.7000 -44.53125 0.00000 1.56200 1.56200 13.30000 1.04000 0.75600 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
1.670 2103.00000 20.1000 -44.53125 0.00000 1.57900 1.57900 13.50000 1.05300 0.72400 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
1.680 2103.00000 20.1000 -44.53125 0.00000 1.57900 1.57900 13.50000 1.05300 0.72400 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
1.690 2103.00000 20.1000 -44.53125 0.00000 1.57900 1.57900 13.50000 1.05300 0.72400 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
1.700 2103.00000 20.1000 -44.53125 0.00000 1.57900 1.57900 13.50000 1.05300 0.72400 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
1.710 2103.00000 20.1000 -44.53125 0.00000 1.57900 1.57900 13.50000 1.05300 0.72400 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
1.720 2077.00000 20.1000 -44.53125 0.00000 1.59700 1.59700 13.50000 1.05300 0.72400 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
1.730 2077.00000 20.1000 -44.53125 0.00000 1.59700 1.59700 13.50000 1.05300 0.72400 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
1.740 2077.00000 20.1000 -44.53125 0.00000 1.59700 1.59700 13.50000 1.05300 0.72400 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
1.750 2077.00000 20.1000 -44.53125 0.00000 1.59700 1.59700 13.50000 1.05300 0.72400 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
1.760 2077.00000 20.1000 -44.53125 0.00000 1.59700 1.59700 13.50000 1.05300 0.72400 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
1.770 2109.00000 19.8000 -44.53125 0.00000 1.51500 1.51500 13.40000 1.05300 0.72400 5.70000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
1.780 2109.00000 19.8000 -44.53125 0.00000 1.51500 1.51500 13.40000 1.05300 0.72400 5.70000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
1.790 2109.00000 19.8000 -44.53125 0.00000 1.51500 1.51500 13.40000 1.05300 0.72400 5.70000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
1.800 2109.00000 19.8000 -44.53125 0.00000 1.51500 1.51500 13.40000 1.05300 0.72400 5.70000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
1.810 2109.00000 19.8000 -44.53125 0.00000 1.51500 1.51500 13.40000 1.05300 0.72400 5.70000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
1.820 2089.00000 19.8000 -44.53125 0.00000 1.54400 1.54400 13.60000 1.05300 0.72400 5.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
1.830 2089.00000 19.8000 -44.53125 0.00000 1.54400 1.54400 13.60000 1.05300 0.72400 5.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
1.840 2089.00000 19.8000 -44.53125 0.00000 1.54400 1.54400 13.60000 1.05300 0.72400 5.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
1.850 2089.00000 19.8000 -44.53125 0.00000 1.54400 1.54400 13.60000 1.05300 0.72400 5.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
1.860 2089.00000 19.8000 -44.53125 0.00000 1.54400 1.54400 13.60000 1.05300 0.72400 5.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
1.870 2108.00000 20.1000 -44.53125 0.00000 1.58500 1.58500 13.40000 1.01800 0.92800 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
1.880 2108.00000 20.1000 -44.53125 0.00000 1.58500 1.58500 13.40000 1.01800 0.92800 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
1.890 2108.00000 20.1000 -44.53125 0.00000 1.58500 1.58500 13.40000 1.01800 0.92800 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
1.900 2108.00000 20.1000 -44.53125 0.00000 1.58500 1.58500 13.40000 1.01800 0.92800 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
1.910 2108.00000 20.1000 -44.53125 0.00000 1.58500 1.58500 13.40000 1.01800 0.92800 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
1.920 2088.00000 20.1000 -44.53125 0.00000 1.56200 1.56200 12.20000 1.01800 0.92800 5.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
1.930 2088.00000 20.1000 -44.53125 0.00000 1.56200 1.56200 12.20000 1.01800 0.92800 5.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
1.940 2088.00000 20.1000 -44.53125 0.00000 1.56200 1.56200 12.20000 1.01800 0.92800 5.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
1.950 2088.00000 20.1000 -44.53125 0.00000 1.56200 1.56200 12.20000 1.01800 0.92800 5.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
1.960 2088.00000 20.1000 -44.53125 0.00000 1.56200 1.56200 12.20000 1.01800 0.92800 5.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
1.970 2109.00000 20.0000 -44.53125 0.00000 1.56800 1.56800 13.20000 1.01800 0.92800 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
1.980 2109.00000 20.0000 -44.53125 0.00000 1.56800 1.56800 13.20000 1.01800 0.92800 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
1.990 2109.00000 20.0000 -44.53125 0.00000 1.56800 1.56800 13.20000 1.01800 0.92800 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
2.000 2109.00000 20.0000 -44.53125 0.00000 1.56800 1.56800 13.20000 1.01800 0.92800 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
2.010 2109.00000 20.0000 -44.53125 0.00000 1.56800 1.56800 13.20000 1.01800 0.92800 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
2.020 2117.00000 20.0000 -44.53125 0.00000 1.56800 1.56800 13.50000 1.01800 0.92800 5.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
2.030 2117.00000 20.0000 -44.53125 0.00000 1.56800 1.56800 13.50000 1.01800 0.92800 5.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
2.040 2117.00000 20.0000 -44.53125 0.00000 1.56800 1.56800 13.50000 1.01800 0.92800 5.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
2.050 2117.00000 20.0000 -44.53125 0.00000 1.56800 1.56800 13.50000 1.01800 0.92800 5.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
2.060 2117.00000 20.0000 -44.53125 0.00000 1.56800 1.56800 13.50000 1.01800 0.92800 5.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
2.070 2100.00000 20.1000 -44.53125 0.00000 1.57400 1.57400 13.10000 0.98600 0.98300 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
2.080 2100.00000 20.1000 -44.53125 0.00000 1.57400 1.57400 13.10000 0.98600 0.98300 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
2.090 2100.00000 20.1000 -44.53125 0.00000 1.57400 1.57400 13.10000 0.98600 0.98300 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
2.100 2100.00000 20.1000 -44.53125 0.00000 1.57400 1.57400 13.10000 0.98600 0.98300 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
2.110 2100.00000 20.1000 -44.53125 0.00000 1.57400 1.57400 13.10000 0.98600 0.98300 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
2.120 2112.00000 20.1000 -44.53125 0.00000 1.59100 1.59100 13.40000 0.98600 0.98300 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
2.130 2112.00000 20.1000 -44.53125 0.00000 1.59100 1.59100 13.40000 0.98600 0.98300 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
2.140 2112.00000 20.1000 -44.53125 0.00000 1.59100 1.59100 13.40000 0.98600 0.98300 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
2.150 2112.00000 20.1000 -44.53125 0.00000 1.59100 1.59100 13.40000 0.98600 0.98300 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
2.160 2112.00000 20.1000 -44.53125 0.00000 1.59100 1.59100 13.40000 0.98600 0.98300 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
2.170 2087.00000 19.8000 -44.53125 0.00000 1.54400 1.54400 13.10000 0.98600 0.98300 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
2.180 2087.00000 19.8000 -44.53125 0.00000 1.54400 1.54400 13.10000 0.98600 0.98300 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
2.190 2087.00000 19.8000 -44.53125 0.00000 1.54400 1.54400 13.10000 0.98600 0.98300 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
2.200 2087.00000 19.8000 -44.53125 0.00000 1.54400 1.54400 13.10000 0.98600 0.98300 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
2.210 2087.00000 19.8000 -44.53125 0.00000 1.54400 1.54400 13.10000 0.98600 0.98300 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
2.220 2091.00000 20.0000 -44.53125 0.00000 1.56800 1.56800 13.20000 0.98600 0.98300 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
2.230 2091.00000 20.0000 -44.53125 0.00000 1.56800 1.56800 13.20000 0.98600 0.98300 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
2.240 2091.00000 20.0000 -44.53125 0.00000 1.56800 1.56800 13.20000 0.98600 0.98300 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
2.250 2091.00000 20.0000 -44.53125 0.00000 1.56800 1.56800 13.20000 0.98600 0.98300 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
2.260 2091.00000 20.0000 -44.53125 0.00000 1.56800 1.56800 13.20000 0.98600 0.98300 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
2.270 2159.00000 20.1000 -44.53125 0.00000 1.59700 1.59700 12.10000 0.95100 0.99900 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
2.280 2159.00000 20.1000 -44.53125 0.00000 1.59700 1.59700 12.10000 0.95100 0.99900 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
2.290 2159.00000 20.1000 -44.53125 0.00000 1.59700 1.59700 12.10000 0.95100 0.99900 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
2.300 2159.00000 20.1000 -44.53125 0.00000 1.59700 1.59700 12.10000 0.95100 0.99900 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
2.310 2159.00000 20.1000 -44.53125 0.00000 1.59700 1.59700 12.10000 0.95100 0.99900 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
2.320 2094.00000 20.1000 -44.53125 0.00000 1.55600 1.55600 13.20000 0.95100 0.99900 5.70000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
2.330 2094.00000 20.1000 -44.53125 0.00000 1.55600 1.55600 13.20000 0.95100 0.99900 5.70000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
2.340 2094.00000 20.1000 -44.53125 0.00000 1.55600 1.55600 13.20000 0.95100 0.99900 5.70000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
2.350 2094.00000 20.1000 -44.53125 0.00000 1.55600 1.55600 13.20000 0.95100 0.99900 5.70000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
2.360 2094.00000 20.1000 -44.53125 0.00000 1.55600 1.55600 13.20000 0.95100 0.99900 5.70000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
2.370 2077.00000 19.8000 -44.53125 0.00000 1.58500 1.58500 13.60000 0.95100 0.99900 5.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
2.380 2077.00000 19.8000 -44.53125 0.00000 1.58500 1.58500 13.60000 0.95100 0.99900 5.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
2.390 2077.00000 19.8000 -44.53125 0.00000 1.58500 1.58500 13.60000 0.95100 0.99900 5.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
2.400 2077.00000 19.8000 -44.53125 0.00000 1.58500 1.58500 13.60000 0.95100 0.99900 5.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
2.410 2077.00000 19.8000 -44.53125 0.00000 1.58500 1.58500 13.60000 0.95100 0.99900 5.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
2.420 2097.00000 20.0000 -44.53125 0.00000 1.57400 1.57400 13.10000 0.95100 0.99900 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
2.430 2097.00000 20.0000 -44.53125 0.00000 1.57400 1.57400 13.10000 0.95100 0.99900 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
2.440 2097.00000 20.0000 -44.53125 0.00000 1.57400 1.57400 13.10000 0.95100 0.99900 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
2.450 2097.00000 20.0000 -44.53125 0.00000 1.57400 1.57400 13.10000 0.95100 0.99900 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
2.460 2097.00000 20.0000 -44.53125 0.00000 1.57400 1.57400 13.10000 0.95100 0.99900 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
2.470 2152.00000 20.3000 -44.53125 0.00000 1.56800 1.56800 12.70000 0.43000 0.97300 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
2.480 2152.00000 20.3000 -44.53125 0.00000 1.56800 1.56800 12.70000 0.43000 0.97300 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
2.490 2152.00000 20.3000 -44.53125 0.00000 1.56800 1.56800 12.70000 0.43000 0.97300 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
2.500 2152.00000 20.3000 -44.53125 0.00000 1.56800 1.56800 12.70000 0.43000 0.97300 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
2.510 2152.00000 20.3000 -44.53125 0.00000 1.56800 1.56800 12.70000 0.43000 0.97300 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
2.520 2098.00000 20.1000 -44.53125 0.00000 1.56800 1.56800 13.50000 0.43000 0.97300 5.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
2.530 2098.00000 20.1000 -44.53125 0.00000 1.56800 1.56800 13.50000 0.43000 0.97300 5.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
2.540 2098.00000 20.1000 -44.53125 0.00000 1.56800 1.56800 13.50000 0.43000 0.97300 5.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
2.550 2098.00000 20.1000 -44.53125 0.00000 1.56800 1.56800 13.50000 0.43000 0.97300 5.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
2.560 2098.00000 20.1000 -44.53125 0.00000 1.56800 1.56800 13.50000 0.43000 0.97300 5.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
2.570 2086.00000 19.8000 -44.53125 0.00000 1.53300 1.53300 13.20000 0.43000 0.97300 5.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
2.580 2086.00000 19.8000 -44.53125 0.00000 1.53300 1.53300 13.20000 0.43000 0.97300 5.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
2.590 2086.00000 19.8000 -44.53125 0.00000 1.53300 1.53300 13.20000 0.43000 0.97300 5.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
2.600 2086.00000 19.8000 -44.53125 0.00000 1.53300 1.53300 13.20000 0.43000 0.97300 5.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
2.610 2086.00000 19.8000 -44.53125 0.00000 1.53300 1.53300 13.20000 0.43000 0.97300 5.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
2.620 2107.00000 20.1000 -44.53125 0.00000 1.55600 1.55600 13.30000 0.43000 0.97300 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
2.630 2107.00000 20.1000 -44.53125 0.00000 1.55600 1.55600 13.30000 0.43000 0.97300 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
2.640 2107.00000 20.1000 -44.53125 0.00000 1.55600 1.55600 13.30000 0.43000 0.97300 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
2.650 2107.00000 20.1000 -44.53125 0.00000 1.55600 1.55600 13.30000 0.43000 0.97300 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
2.660 2107.00000 20.1000 -44.53125 0.00000 1.55600 1.55600 13.30000 0.43000 0.97300 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
2.670 2098.00000 20.3000 -44.53125 0.00000 1.60900 1.60900 13.00000 0.34100 0.93500 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
2.680 2098.00000 20.3000 -44.53125 0.00000 1.60900 1.60900 13.00000 0.34100 0.93500 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
2.690 2098.00000 20.3000 -44.53125 0.00000 1.60900 1.60900 13.00000 0.34100 0.93500 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
2.700 2098.00000 20.3000 -44.53125 0.00000 1.60900 1.60900 13.00000 0.34100 0.93500 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
2.710 2098.00000 20.3000 -44.53125 0.00000 1.60900 1.60900 13.00000 0.34100 0.93500 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
2.720 2086.00000 20.0000 -44.53125 0.00000 1.55000 1.55000 13.40000 0.34100 0.93500 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
2.730 2086.00000 20.0000 -44.53125 0.00000 1.55000 1.55000 13.40000 0.34100 0.93500 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
2.740 2086.00000 20.0000 -44.53125 0.00000 1.55000 1.55000 13.40000 0.34100 0.93500 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
2.750 2086.00000 20.0000 -44.53125 0.00000 1.55000 1.55000 13.40000 0.34100 0.93500 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
2.760 2086.00000 20.0000 -44.53125 0.00000 1.55000 1.55000 13.40000 0.34100 0.93500 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
2.770 2150.00000 19.8000 -44.53125 0.00000 1.53900 1.53900 13.30000 0.34100 0.93500 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
2.780 2150.00000 19.8000 -44.53125 0.00000 1.53900 1.53900 13.30000 0.34100 0.93500 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
2.790 2150.00000 19.8000 -44.53125 0.00000 1.53900 1.53900 13.30000 0.34100 0.93500 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
2.800 2150.00000 19.8000 -44.53125 0.00000 1.53900 1.53900 13.30000 0.34100 0.93500 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
2.810 2150.00000 19.8000 -44.53125 0.00000 1.53900 1.53900 13.30000 0.34100 0.93500 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
2.820 2117.00000 20.3000 -44.53125 0.00000 1.56800 1.56800 13.50000 0.34100 0.93500 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
2.830 2117.00000 20.3000 -44.53125 0.00000 1.56800 1.56800 13.50000 0.34100 0.93500 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
2.840 2117.00000 20.3000 -44.53125 0.00000 1.56800 1.56800 13.50000 0.34100 0.93500 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
2.850 2117.00000 20.3000 -44.53125 0.00000 1.56800 1.56800 13.50000 0.34100 0.93500 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
2.860 2117.00000 20.3000 -44.53125 0.00000 1.56800 1.56800 13.50000 0.34100 0.93500 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
2.870 2094.00000 20.1000 -44.53125 0.00000 1.55000 1.55000 13.20000 0.40200 0.77800 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
2.880 2094.00000 20.1000 -44.53125 0.00000 1.55000 1.55000 13.20000 0.40200 0.77800 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
2.890 2094.00000 20.1000 -44.53125 0.00000 1.55000 1.55000 13.20000 0.40200 0.77800 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
2.900 2094.00000 20.1000 -44.53125 0.00000 1.55000 1.55000 13.20000 0.40200 0.77800 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
2.910 2094.00000 20.1000 -44.53125 0.00000 1.55000 1.55000 13.20000 0.40200 0.77800 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
2.920 2087.00000 19.8000 -44.53125 0.00000 1.53900 1.53900 13.40000 0.40200 0.77800 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
2.930 2087.00000 19.8000 -44.53125 0.00000 1.53900 1.53900 13.40000 0.40200 0.77800 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
2.940 2087.00000 19.8000 -44.53125 0.00000 1.53900 1.53900 13.40000 0.40200 0.77800 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
2.950 2087.00000 19.8000 -44.53125 0.00000 1.53900 1.53900 13.40000 0.40200 0.77800 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
2.960 2087.00000 19.8000 -44.53125 0.00000 1.53900 1.53900 13.40000 0.40200 0.77800 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
2.970 2151.00000 20.0000 -44.53125 0.00000 1.51500 1.51500 12.90000 0.40200 0.77800 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
2.980 2151.00000 20.0000 -44.53125 0.00000 1.51500 1.51500 12.90000 0.40200 0.77800 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
2.990 2151.00000 20.0000 -44.53125 0.00000 1.51500 1.51500 12.90000 0.40200 0.77800 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
3.000 2151.00000 20.0000 -44.53125 0.00000 1.51500 1.51500 12.90000 0.40200 0.77800 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
3.010 2151.00000 20.0000 -44.53125 0.00000 1.51500 1.51500 12.90000 0.40200 0.77800 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
3.020 2120.00000 20.1000 -44.53125 0.00000 1.57400 1.57400 13.40000 0.40200 0.77800 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
3.030 2120.00000 20.1000 -44.53125 0.00000 1.57400 1.57400 13.40000 0.40200 0.77800 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
3.040 2120.00000 20.1000 -44.53125 0.00000 1.57400 1.57400 13.40000 0.40200 0.77800 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
3.050 2120.00000 20.1000 -44.53125 0.00000 1.57400 1.57400 13.40000 0.40200 0.77800 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
3.060 2120.00000 20.1000 -44.53125 0.00000 1.57400 1.57400 13.40000 0.40200 0.77800 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
3.070 2099.00000 20.0000 -44.53125 0.00000 1.56800 1.56800 13.00000 0.99500 0.59000 5.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
3.080 2099.00000 20.0000 -44.53125 0.00000 1.56800 1.56800 13.00000 0.99500 0.59000 5.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
3.090 2099.00000 20.0000 -44.53125 0.00000 1.56800 1.56800 13.00000 0.99500 0.59000 5.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
3.100 2099.00000 20.0000 -44.53125 0.00000 1.56800 1.56800 13.00000 0.99500 0.59000 5.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
3.110 2099.00000 20.0000 -44.53125 0.00000 1.56800 1.56800 13.00000 0.99500 0.59000 5.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
3.120 2133.00000 19.8000 -44.53125 0.00000 1.53300 1.53300 13.00000 0.99500 0.59000 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
3.130 2133.00000 19.8000 -44.53125 0.00000 1.53300 1.53300 13.00000 0.99500 0.59000 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
3.140 2133.00000 19.8000 -44.53125 0.00000 1.53300 1.53300 13.00000 0.99500 0.59000 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
3.150 2133.00000 19.8000 -44.53125 0.00000 1.53300 1.53300 13.00000 0.99500 0.59000 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
3.160 2133.00000 19.8000 -44.53125 0.00000 1.53300 1.53300 13.00000 0.99500 0.59000 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
3.170 2107.00000 19.8000 -44.53125 0.00000 1.55000 1.55000 13.20000 0.99500 0.59000 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
3.180 2107.00000 19.8000 -44.53125 0.00000 1.55000 1.55000 13.20000 0.99500 0.59000 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
3.190 2107.00000 19.8000 -44.53125 0.00000 1.55000 1.55000 13.20000 0.99500 0.59000 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
3.200 2107.00000 19.8000 -44.53125 0.00000 1.55000 1.55000 13.20000 0.99500 0.59000 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
3.210 2107.00000 19.8000 -44.53125 0.00000 1.55000 1.55000 13.20000 0.99500 0.59000 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
3.220 2100.00000 20.3000 -44.53125 0.00000 1.57400 1.57400 13.10000 0.99500 0.59000 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
3.230 2100.00000 20.3000 -44.53125 0.00000 1.57400 1.57400 13.10000 0.99500 0.59000 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
3.240 2100.00000 20.3000 -44.53125 0.00000 1.57400 1.57400 13.10000 0.99500 0.59000 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
3.250 2100.00000 20.3000 -44.53125 0.00000 1.57400 1.57400 13.10000 0.99500 0.59000 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
3.260 2100.00000 20.3000 -44.53125 0.00000 1.57400 1.57400 13.10000 0.99500 0.59000 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
3.270 2129.00000 19.8000 -44.53125 0.00000 1.55600 1.55600 13.30000 1.04300 0.49100 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
3.280 2129.00000 19.8000 -44.53125 0.00000 1.55600 1.55600 13.30000 1.04300 0.49100 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
3.290 2129.00000 19.8000 -44.53125 0.00000 1.55600 1.55600 13.30000 1.04300 0.49100 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
3.300 2129.00000 19.8000 -44.53125 0.00000 1.55600 1.55600 13.30000 1.04300 0.49100 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
3.310 2129.00000 19.8000 -44.53125 0.00000 1.55600 1.55600 13.30000 1.04300 0.49100 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
3.320 2113.00000 19.8000 -44.53125 0.00000 1.57400 1.57400 13.30000 1.04300 0.49100 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
3.330 2113.00000 19.8000 -44.53125 0.00000 1.57400 1.57400 13.30000 1.04300 0.49100 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
3.340 2113.00000 19.8000 -44.53125 0.00000 1.57400 1.57400 13.30000 1.04300 0.49100 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
3.350 2113.00000 19.8000 -44.53125 0.00000 1.57400 1.57400 13.30000 1.04300 0.49100 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
3.360 2113.00000 19.8000 -44.53125 0.00000 1.57400 1.57400 13.30000 1.04300 0.49100 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
3.370 2127.00000 20.4000 -44.53125 0.00000 1.60300 1.60300 12.90000 1.04300 0.49100 5.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
3.380 2127.00000 20.4000 -44.53125 0.00000 1.60300 1.60300 12.90000 1.04300 0.49100 5.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
3.390 2127.00000 20.4000 -44.53125 0.00000 1.60300 1.60300 12.90000 1.04300 0.49100 5.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
3.400 2127.00000 20.4000 -44.53125 0.00000 1.60300 1.60300 12.90000 1.04300 0.49100 5.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
3.410 2127.00000 20.4000 -44.53125 0.00000 1.60300 1.60300 12.90000 1.04300 0.49100 5.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
3.420 2107.00000 20.4000 -44.53125 0.00000 1.61400 1.61400 12.90000 1.04300 0.49100 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
3.430 2107.00000 20.4000 -44.53125 0.00000 1.61400 1.61400 12.90000 1.04300 0.49100 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
3.440 2107.00000 20.4000 -44.53125 0.00000 1.61400 1.61400 12.90000 1.04300 0.49100 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
3.450 2107.00000 20.4000 -44.53125 0.00000 1.61400 1.61400 12.90000 1.04300 0.49100 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
3.460 2107.00000 20.4000 -44.53125 0.00000 1.61400 1.61400 12.90000 1.04300 0.49100 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
3.470 2132.00000 19.7000 -44.53125 0.00000 1.53900 1.53900 13.00000 0.99900 0.49100 5.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
3.480 2132.00000 19.7000 -44.53125 0.00000 1.53900 1.53900 13.00000 0.99900 0.49100 5.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
3.490 2132.00000 19.7000 -44.53125 0.00000 1.53900 1.53900 13.00000 0.99900 0.49100 5.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
3.500 2132.00000 19.7000 -44.53125 0.00000 1.53900 1.53900 13.00000 0.99900 0.49100 5.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
3.510 2132.00000 19.7000 -44.53125 0.00000 1.53900 1.53900 13.00000 0.99900 0.49100 5.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
3.520 2111.00000 19.7000 -44.53125 0.00000 1.53300 1.53300 13.50000 0.99900 0.49100 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
3.530 2111.00000 19.7000 -44.53125 0.00000 1.53300 1.53300 13.50000 0.99900 0.49100 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
3.540 2111.00000 19.7000 -44.53125 0.00000 1.53300 1.53300 13.50000 0.99900 0.49100 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
3.550 2111.00000 19.7000 -44.53125 0.00000 1.53300 1.53300 13.50000 0.99900 0.49100 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
3.560 2111.00000 19.7000 -44.53125 0.00000 1.53300 1.53300 13.50000 0.99900 0.49100 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
3.570 2132.00000 20.3000 -44.53125 0.00000 1.58500 1.58500 13.00000 0.99900 0.49100 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
3.580 2132.00000 20.3000 -44.53125 0.00000 1.58500 1.58500 13.00000 0.99900 0.49100 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
3.590 2132.00000 20.3000 -44.53125 0.00000 1.58500 1.58500 13.00000 0.99900 0.49100 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
3.600 2132.00000 20.3000 -44.53125 0.00000 1.58500 1.58500 13.00000 0.99900 0.49100 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
3.610 2132.00000 20.3000 -44.53125 0.00000 1.58500 1.58500 13.00000 0.99900 0.49100 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
3.620 2154.00000 20.0000 -44.53125 0.00000 1.57900 1.57900 13.40000 0.99900 0.49100 5.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
3.630 2154.00000 20.0000 -44.53125 0.00000 1.57900 1.57900 13.40000 0.99900 0.49100 5.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
3.640 2154.00000 20.0000 -44.53125 0.00000 1.57900 1.57900 13.40000 0.99900 0.49100 5.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
3.650 2154.00000 20.0000 -44.53125 0.00000 1.57900 1.57900 13.40000 0.99900 0.49100 5.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
3.660 2154.00000 20.0000 -44.53125 0.00000 1.57900 1.57900 13.40000 0.99900 0.49100 5.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
3.670 2081.00000 19.4000 -44.53125 0.00000 1.51500 1.51500 13.60000 0.54500 0.53600 5.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
3.680 2081.00000 19.4000 -44.53125 0.00000 1.51500 1.51500 13.60000 0.54500 0.53600 5.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
3.690 2081.00000 19.4000 -44.53125 0.00000 1.51500 1.51500 13.60000 0.54500 0.53600 5.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
3.700 2081.00000 19.4000 -44.53125 0.00000 1.51500 1.51500 13.60000 0.54500 0.53600 5.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
3.710 2081.00000 19.4000 -44.53125 0.00000 1.51500 1.51500 13.60000 0.54500 0.53600 5.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
3.720 2100.00000 19.4000 -44.53125 0.00000 1.50400 1.50400 12.90000 0.54500 0.53600 5.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
3.730 2100.00000 19.4000 -44.53125 0.00000 1.50400 1.50400 12.90000 0.54500 0.53600 5.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
3.740 2100.00000 19.4000 -44.53125 0.00000 1.50400 1.50400 12.90000 0.54500 0.53600 5.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
3.750 2100.00000 19.4000 -44.53125 0.00000 1.50400 1.50400 12.90000 0.54500 0.53600 5.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
3.760 2100.00000 19.4000 -44.53125 0.00000 1.50400 1.50400 12.90000 0.54500 0.53600 5.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
3.770 2149.00000 19.5000 -44.53125 0.00000 1.50900 1.50900 13.00000 0.54500 0.53600 4.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
3.780 2149.00000 19.5000 -44.53125 0.00000 1.50900 1.50900 13.00000 0.54500 0.53600 4.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
3.790 2149.00000 19.5000 -44.53125 0.00000 1.50900 1.50900 13.00000 0.54500 0.53600 4.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
3.800 2149.00000 19.5000 -44.53125 0.00000 1.50900 1.50900 13.00000 0.54500 0.53600 4.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
3.810 2149.00000 19.5000 -44.53125 0.00000 1.50900 1.50900 13.00000 0.54500 0.53600 4.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
3.820 2082.00000 19.5000 -44.53125 0.00000 1.52700 1.52700 13.20000 0.54500 0.53600 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
3.830 2082.00000 19.5000 -44.53125 0.00000 1.52700 1.52700 13.20000 0.54500 0.53600 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
3.840 2082.00000 19.5000 -44.53125 0.00000 1.52700 1.52700 13.20000 0.54500 0.53600 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
3.850 2082.00000 19.5000 -44.53125 0.00000 1.52700 1.52700 13.20000 0.54500 0.53600 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
3.860 2082.00000 19.5000 -44.53125 0.00000 1.52700 1.52700 13.20000 0.54500 0.53600 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
3.870 2090.00000 19.2000 -44.53125 0.00000 1.54400 1.54400 13.50000 0.75600 0.59600 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
3.880 2090.00000 19.2000 -44.53125 0.00000 1.54400 1.54400 13.50000 0.75600 0.59600 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
3.890 2090.00000 19.2000 -44.53125 0.00000 1.54400 1.54400 13.50000 0.75600 0.59600 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
3.900 2090.00000 19.2000 -44.53125 0.00000 1.54400 1.54400 13.50000 0.75600 0.59600 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
3.910 2090.00000 19.2000 -44.53125 0.00000 1.54400 1.54400 13.50000 0.75600 0.59600 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
3.920 2165.00000 19.2000 -44.53125 0.00000 1.48600 1.48600 13.00000 0.75600 0.59600 4.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
3.930 2165.00000 19.2000 -44.53125 0.00000 1.48600 1.48600 13.00000 0.75600 0.59600 4.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
3.940 2165.00000 19.2000 -44.53125 0.00000 1.48600 1.48600 13.00000 0.75600 0.59600 4.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
3.950 2165.00000 19.2000 -44.53125 0.00000 1.48600 1.48600 13.00000 0.75600 0.59600 4.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
3.960 2165.00000 19.2000 -44.53125 0.00000 1.48600 1.48600 13.00000 0.75600 0.59600 4.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
3.970 2117.00000 19.4000 -44.53125 0.00000 1.51500 1.51500 13.40000 0.75600 0.59600 4.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
3.980 2117.00000 19.4000 -44.53125 0.00000 1.51500 1.51500 13.40000 0.75600 0.59600 4.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
3.990 2117.00000 19.4000 -44.53125 0.00000 1.51500 1.51500 13.40000 0.75600 0.59600 4.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
4.000 2117.00000 19.4000 -44.53125 0.00000 1.51500 1.51500 13.40000 0.75600 0.59600 4.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
4.010 2117.00000 19.4000 -44.53125 0.00000 1.51500 1.51500 13.40000 0.75600 0.59600 4.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
4.020 2089.00000 19.4000 -44.53125 0.00000 1.51500 1.51500 12.60000 0.75600 0.59600 4.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
4.030 2089.00000 19.4000 -44.53125 0.00000 1.51500 1.51500 12.60000 0.75600 0.59600 4.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
4.040 2089.00000 19.4000 -44.53125 0.00000 1.51500 1.51500 12.60000 0.75600 0.59600 4.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
4.050 2089.00000 19.4000 -44.53125 0.00000 1.51500 1.51500 12.60000 0.75600 0.59600 4.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
4.060 2089.00000 19.4000 -44.53125 0.00000 1.51500 1.51500 12.60000 0.75600 0.59600 4.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
4.070 2089.00000 19.2000 -44.53125 0.00000 1.50900 1.50900 13.00000 1.06200 0.53300 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
4.080 2089.00000 19.2000 -44.53125 0.00000 1.50900 1.50900 13.00000 1.06200 0.53300 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
4.090 2089.00000 19.2000 -44.53125 0.00000 1.50900 1.50900 13.00000 1.06200 0.53300 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
4.100 2089.00000 19.2000 -44.53125 0.00000 1.50900 1.50900 13.00000 1.06200 0.53300 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
4.110 2089.00000 19.2000 -44.53125 0.00000 1.50900 1.50900 13.00000 1.06200 0.53300 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
4.120 2161.00000 19.4000 -44.53125 0.00000 1.50400 1.50400 13.20000 1.06200 0.53300 4.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
4.130 2161.00000 19.4000 -44.53125 0.00000 1.50400 1.50400 13.20000 1.06200 0.53300 4.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
4.140 2161.00000 19.4000 -44.53125 0.00000 1.50400 1.50400 13.20000 1.06200 0.53300 4.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
4.150 2161.00000 19.4000 -44.53125 0.00000 1.50400 1.50400 13.20000 1.06200 0.53300 4.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
4.160 2161.00000 19.4000 -44.53125 0.00000 1.50400 1.50400 13.20000 1.06200 0.53300 4.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
4.170 2120.00000 19.4000 -44.53125 0.00000 1.52700 1.52700 13.40000 1.06200 0.53300 4.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
4.180 2120.00000 19.4000 -44.53125 0.00000 1.52700 1.52700 13.40000 1.06200 0.53300 4.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
4.190 2120.00000 19.4000 -44.53125 0.00000 1.52700 1.52700 13.40000 1.06200 0.53300 4.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
4.200 2120.00000 19.4000 -44.53125 0.00000 1.52700 1.52700 13.40000 1.06200 0.53300 4.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
4.210 2120.00000 19.4000 -44.53125 0.00000 1.52700 1.52700 13.40000 1.06200 0.53300 4.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
4.220 2089.00000 19.2000 -44.53125 0.00000 1.49800 1.49800 12.50000 1.06200 0.53300 4.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
4.230 2089.00000 19.2000 -44.53125 0.00000 1.49800 1.49800 12.50000 1.06200 0.53300 4.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
4.240 2089.00000 19.2000 -44.53125 0.00000 1.49800 1.49800 12.50000 1.06200 0.53300 4.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
4.250 2089.00000 19.2000 -44.53125 0.00000 1.49800 1.49800 12.50000 1.06200 0.53300 4.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
4.260 2089.00000 19.2000 -44.53125 0.00000 1.49800 1.49800 12.50000 1.06200 0.53300 4.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
4.270 2082.00000 18.9000 -44.53125 0.00000 1.46900 1.46900 13.30000 1.09400 0.44000 5.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
4.280 2082.00000 18.9000 -44.53125 0.00000 1.46900 1.46900 13.30000 1.09400 0.44000 5.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
4.290 2082.00000 18.9000 -44.53125 0.00000 1.46900 1.46900 13.30000 1.09400 0.44000 5.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
4.300 2082.00000 18.9000 -44.53125 0.00000 1.46900 1.46900 13.30000 1.09400 0.44000 5.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
4.310 2082.00000 18.9000 -44.53125 0.00000 1.46900 1.46900 13.30000 1.09400 0.44000 5.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
4.320 2146.00000 18.9000 -44.53125 0.00000 1.48600 1.48600 13.20000 1.09400 0.44000 4.60000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
4.330 2146.00000 18.9000 -44.53125 0.00000 1.48600 1.48600 13.20000 1.09400 0.44000 4.60000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
4.340 2146.00000 18.9000 -44.53125 0.00000 1.48600 1.48600 13.20000 1.09400 0.44000 4.60000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
4.350 2146.00000 18.9000 -44.53125 0.00000 1.48600 1.48600 13.20000 1.09400 0.44000 4.60000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
4.360 2146.00000 18.9000 -44.53125 0.00000 1.48600 1.48600 13.20000 1.09400 0.44000 4.60000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
4.370 2092.00000 19.1000 -44.53125 0.00000 1.48600 1.48600 13.30000 1.09400 0.44000 4.70000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.4000 0.000 0.000 0.000 0.000
4.380 2092.00000 19.1000 -44.53125 0.00000 1.48600 1.48600 13.30000 1.09400 0.44000 4.70000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.4000 0.000 0.000 0.000 0.000
4.390 2092.00000 19.1000 -44.53125 0.00000 1.48600 1.48600 13.30000 1.09400 0.44000 4.70000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.4000 0.000 0.000 0.000 0.000
4.400 2092.00000 19.1000 -44.53125 0.00000 1.48600 1.48600 13.30000 1.09400 0.44000 4.70000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.4000 0.000 0.000 0.000 0.000
4.410 2092.00000 19.1000 -44.53125 0.00000 1.48600 1.48600 13.30000 1.09400 0.44000 4.70000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.4000 0.000 0.000 0.000 0.000
4.420 2123.00000 19.1000 -44.53125 0.00000 1.42800 1.42800 12.50000 1.09400 0.44000 5.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
4.430 2123.00000 19.1000 -44.53125 0.00000 1.42800 1.42800 12.50000 1.09400 0.44000 5.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
4.440 2123.00000 19.1000 -44.53125 0.00000 1.42800 1.42800 12.50000 1.09400 0.44000 5.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
4.450 2123.00000 19.1000 -44.53125 0.00000 1.42800 1.42800 12.50000 1.09400 0.44000 5.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
4.460 2123.00000 19.1000 -44.53125 0.00000 1.42800 1.42800 12.50000 1.09400 0.44000 5.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
4.470 2094.00000 18.7000 -44.53125 0.00000 1.45700 1.45700 13.20000 1.09100 0.52300 4.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
4.480 2094.00000 18.7000 -44.53125 0.00000 1.45700 1.45700 13.20000 1.09100 0.52300 4.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
4.490 2094.00000 18.7000 -44.53125 0.00000 1.45700 1.45700 13.20000 1.09100 0.52300 4.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
4.500 2094.00000 18.7000 -44.53125 0.00000 1.45700 1.45700 13.20000 1.09100 0.52300 4.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
4.510 2094.00000 18.7000 -44.53125 0.00000 1.45700 1.45700 13.20000 1.09100 0.52300 4.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
4.520 2107.00000 18.7000 -44.53125 0.00000 1.43400 1.43400 12.90000 1.09100 0.52300 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
4.530 2107.00000 18.7000 -44.53125 0.00000 1.43400 1.43400 12.90000 1.09100 0.52300 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
4.540 2107.00000 18.7000 -44.53125 0.00000 1.43400 1.43400 12.90000 1.09100 0.52300 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
4.550 2107.00000 18.7000 -44.53125 0.00000 1.43400 1.43400 12.90000 1.09100 0.52300 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
4.560 2107.00000 18.7000 -44.53125 0.00000 1.43400 1.43400 12.90000 1.09100 0.52300 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
4.570 2089.00000 18.7000 -44.53125 0.00000 1.45700 1.45700 13.00000 1.09100 0.52300 4.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
4.580 2089.00000 18.7000 -44.53125 0.00000 1.45700 1.45700 13.00000 1.09100 0.52300 4.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
4.590 2089.00000 18.7000 -44.53125 0.00000 1.45700 1.45700 13.00000 1.09100 0.52300 4.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
4.600 2089.00000 18.7000 -44.53125 0.00000 1.45700 1.45700 13.00000 1.09100 0.52300 4.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
4.610 2089.00000 18.7000 -44.53125 0.00000 1.45700 1.45700 13.00000 1.09100 0.52300 4.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
4.620 2118.00000 18.7000 -44.53125 0.00000 1.44500 1.44500 13.10000 1.09100 0.52300 4.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.1000 0.000 0.000 0.000 0.000
4.630 2118.00000 18.7000 -44.53125 0.00000 1.44500 1.44500 13.10000 1.09100 0.52300 4.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.1000 0.000 0.000 0.000 0.000
4.640 2118.00000 18.7000 -44.53125 0.00000 1.44500 1.44500 13.10000 1.09100 0.52300 4.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.1000 0.000 0.000 0.000 0.000
4.650 2118.00000 18.7000 -44.53125 0.00000 1.44500 1.44500 13.10000 1.09100 0.52300 4.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.1000 0.000 0.000 0.000 0.000
4.660 2118.00000 18.7000 -44.53125 0.00000 1.44500 1.44500 13.10000 1.09100 0.52300 4.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.1000 0.000 0.000 0.000 0.000
4.670 2085.00000 18.6000 -44.53125 0.00000 1.42200 1.42200 13.30000 1.05900 0.95400 4.60000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
4.680 2085.00000 18.6000 -44.53125 0.00000 1.42200 1.42200 13.30000 1.05900 0.95400 4.60000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
4.690 2085.00000 18.6000 -44.53125 0.00000 1.42200 1.42200 13.30000 1.05900 0.95400 4.60000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
4.700 2085.00000 18.6000 -44.53125 0.00000 1.42200 1.42200 13.30000 1.05900 0.95400 4.60000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
4.710 2085.00000 18.6000 -44.53125 0.00000 1.42200 1.42200 13.30000 1.05900 0.95400 4.60000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
4.720 2099.00000 18.7000 -44.53125 0.00000 1.42200 1.42200 13.60000 1.05900 0.95400 4.60000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
4.730 2099.00000 18.7000 -44.53125 0.00000 1.42200 1.42200 13.60000 1.05900 0.95400 4.60000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
4.740 2099.00000 18.7000 -44.53125 0.00000 1.42200 1.42200 13.60000 1.05900 0.95400 4.60000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
4.750 2099.00000 18.7000 -44.53125 0.00000 1.42200 1.42200 13.60000 1.05900 0.95400 4.60000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
4.760 2099.00000 18.7000 -44.53125 0.00000 1.42200 1.42200 13.60000 1.05900 0.95400 4.60000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
4.770 2093.00000 18.9000 -44.53125 0.00000 1.46300 1.46300 12.00000 1.05900 0.95400 4.60000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
4.780 2093.00000 18.9000 -44.53125 0.00000 1.46300 1.46300 12.00000 1.05900 0.95400 4.60000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
4.790 2093.00000 18.9000 -44.53125 0.00000 1.46300 1.46300 12.00000 1.05900 0.95400 4.60000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
4.800 2093.00000 18.9000 -44.53125 0.00000 1.46300 1.46300 12.00000 1.05900 0.95400 4.60000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
4.810 2093.00000 18.9000 -44.53125 0.00000 1.46300 1.46300 12.00000 1.05900 0.95400 4.60000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
4.820 2108.00000 18.6000 -44.53125 0.00000 1.42800 1.42800 13.40000 1.05900 0.95400 4.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.4000 0.000 0.000 0.000 0.000
4.830 2108.00000 18.6000 -44.53125 0.00000 1.42800 1.42800 13.40000 1.05900 0.95400 4.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.4000 0.000 0.000 0.000 0.000
4.840 2108.00000 18.6000 -44.53125 0.00000 1.42800 1.42800 13.40000 1.05900 0.95400 4.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.4000 0.000 0.000 0.000 0.000
4.850 2108.00000 18.6000 -44.53125 0.00000 1.42800 1.42800 13.40000 1.05900 0.95400 4.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.4000 0.000 0.000 0.000 0.000
4.860 2108.00000 18.6000 -44.53125 0.00000 1.42800 1.42800 13.40000 1.05900 0.95400 4.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.4000 0.000 0.000 0.000 0.000
4.870 2078.00000 18.6000 -44.53125 0.00000 1.43400 1.43400 13.20000 0.92800 1.02700 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.4000 0.000 0.000 0.000 0.000
4.880 2078.00000 18.6000 -44.53125 0.00000 1.43400 1.43400 13.20000 0.92800 1.02700 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.4000 0.000 0.000 0.000 0.000
4.890 2078.00000 18.6000 -44.53125 0.00000 1.43400 1.43400 13.20000 0.92800 1.02700 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.4000 0.000 0.000 0.000 0.000
4.900 2078.00000 18.6000 -44.53125 0.00000 1.43400 1.43400 13.20000 0.92800 1.02700 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.4000 0.000 0.000 0.000 0.000
4.910 2078.00000 18.6000 -44.53125 0.00000 1.43400 1.43400 13.20000 0.92800 1.02700 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.4000 0.000 0.000 0.000 0.000
4.920 2087.00000 18.6000 -44.53125 0.00000 1.45100 1.45100 13.20000 0.92800 1.02700 4.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
4.930 2087.00000 18.6000 -44.53125 0.00000 1.45100 1.45100 13.20000 0.92800 1.02700 4.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
4.940 2087.00000 18.6000 -44.53125 0.00000 1.45100 1.45100 13.20000 0.92800 1.02700 4.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
4.950 2087.00000 18.6000 -44.53125 0.00000 1.45100 1.45100 13.20000 0.92800 1.02700 4.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
4.960 2087.00000 18.6000 -44.53125 0.00000 1.45100 1.45100 13.20000 0.92800 1.02700 4.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
4.970 2132.00000 18.7000 -44.53125 0.00000 1.43400 1.43400 13.30000 0.92800 1.02700 4.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
4.980 2132.00000 18.7000 -44.53125 0.00000 1.43400 1.43400 13.30000 0.92800 1.02700 4.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
4.990 2132.00000 18.7000 -44.53125 0.00000 1.43400 1.43400 13.30000 0.92800 1.02700 4.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
5.000 2132.00000 18.7000 -44.53125 0.00000 1.43400 1.43400 13.30000 0.92800 1.02700 4.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
5.010 2132.00000 18.7000 -44.53125 0.00000 1.43400 1.43400 13.30000 0.92800 1.02700 4.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
5.020 2061.00000 18.6000 -44.53125 0.00000 1.38700 1.38700 13.40000 0.92800 1.02700 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
5.030 2061.00000 18.6000 -44.53125 0.00000 1.38700 1.38700 13.40000 0.92800 1.02700 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
5.040 2061.00000 18.6000 -44.53125 0.00000 1.38700 1.38700 13.40000 0.92800 1.02700 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
5.050 2061.00000 18.6000 -44.53125 0.00000 1.38700 1.38700 13.40000 0.92800 1.02700 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
5.060 2061.00000 18.6000 -44.53125 0.00000 1.38700 1.38700 13.40000 0.92800 1.02700 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
5.070 2070.00000 18.6000 -44.53125 0.00000 1.38100 1.38100 13.40000 0.43400 1.03700 4.70000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
5.080 2070.00000 18.6000 -44.53125 0.00000 1.38100 1.38100 13.40000 0.43400 1.03700 4.70000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
5.090 2070.00000 18.6000 -44.53125 0.00000 1.38100 1.38100 13.40000 0.43400 1.03700 4.70000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
5.100 2070.00000 18.6000 -44.53125 0.00000 1.38100 1.38100 13.40000 0.43400 1.03700 4.70000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
5.110 2070.00000 18.6000 -44.53125 0.00000 1.38100 1.38100 13.40000 0.43400 1.03700 4.70000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
5.120 2118.00000 18.6000 -44.53125 0.00000 1.40400 1.40400 13.20000 0.43400 1.03700 4.70000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
5.130 2118.00000 18.6000 -44.53125 0.00000 1.40400 1.40400 13.20000 0.43400 1.03700 4.70000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
5.140 2118.00000 18.6000 -44.53125 0.00000 1.40400 1.40400 13.20000 0.43400 1.03700 4.70000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
5.150 2118.00000 18.6000 -44.53125 0.00000 1.40400 1.40400 13.20000 0.43400 1.03700 4.70000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
5.160 2118.00000 18.6000 -44.53125 0.00000 1.40400 1.40400 13.20000 0.43400 1.03700 4.70000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
5.170 2071.00000 18.6000 -44.53125 0.00000 1.40400 1.40400 13.50000 0.43400 1.03700 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
5.180 2071.00000 18.6000 -44.53125 0.00000 1.40400 1.40400 13.50000 0.43400 1.03700 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
5.190 2071.00000 18.6000 -44.53125 0.00000 1.40400 1.40400 13.50000 0.43400 1.03700 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
5.200 2071.00000 18.6000 -44.53125 0.00000 1.40400 1.40400 13.50000 0.43400 1.03700 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
5.210 2071.00000 18.6000 -44.53125 0.00000 1.40400 1.40400 13.50000 0.43400 1.03700 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
5.220 2057.00000 18.6000 -44.53125 0.00000 1.44500 1.44500 13.00000 0.43400 1.03700 4.60000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
5.230 2057.00000 18.6000 -44.53125 0.00000 1.44500 1.44500 13.00000 0.43400 1.03700 4.60000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
5.240 2057.00000 18.6000 -44.53125 0.00000 1.44500 1.44500 13.00000 0.43400 1.03700 4.60000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
5.250 2057.00000 18.6000 -44.53125 0.00000 1.44500 1.44500 13.00000 0.43400 1.03700 4.60000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
5.260 2057.00000 18.6000 -44.53125 0.00000 1.44500 1.44500 13.00000 0.43400 1.03700 4.60000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
5.270 2102.00000 18.6000 -44.53125 0.00000 1.43400 1.43400 12.70000 0.33100 1.01500 4.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
5.280 2102.00000 18.6000 -44.53125 0.00000 1.43400 1.43400 12.70000 0.33100 1.01500 4.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
5.290 2102.00000 18.6000 -44.53125 0.00000 1.43400 1.43400 12.70000 0.33100 1.01500 4.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
5.300 2102.00000 18.6000 -44.53125 0.00000 1.43400 1.43400 12.70000 0.33100 1.01500 4.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
5.310 2102.00000 18.6000 -44.53125 0.00000 1.43400 1.43400 12.70000 0.33100 1.01500 4.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
5.320 2065.00000 18.6000 -44.53125 0.00000 1.41000 1.41000 13.20000 0.33100 1.01500 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
5.330 2065.00000 18.6000 -44.53125 0.00000 1.41000 1.41000 13.20000 0.33100 1.01500 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
5.340 2065.00000 18.6000 -44.53125 0.00000 1.41000 1.41000 13.20000 0.33100 1.01500 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
5.350 2065.00000 18.6000 -44.53125 0.00000 1.41000 1.41000 13.20000 0.33100 1.01500 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
5.360 2065.00000 18.6000 -44.53125 0.00000 1.41000 1.41000 13.20000 0.33100 1.01500 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
5.370 2064.00000 18.7000 -44.53125 0.00000 1.43900 1.43900 13.10000 0.33100 1.01500 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
5.380 2064.00000 18.7000 -44.53125 0.00000 1.43900 1.43900 13.10000 0.33100 1.01500 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
5.390 2064.00000 18.7000 -44.53125 0.00000 1.43900 1.43900 13.10000 0.33100 1.01500 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
5.400 2064.00000 18.7000 -44.53125 0.00000 1.43900 1.43900 13.10000 0.33100 1.01500 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
5.410 2064.00000 18.7000 -44.53125 0.00000 1.43900 1.43900 13.10000 0.33100 1.01500 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
5.420 2054.00000 19.1000 -44.53125 0.00000 1.44500 1.44500 13.30000 0.33100 1.01500 4.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
5.430 2054.00000 19.1000 -44.53125 0.00000 1.44500 1.44500 13.30000 0.33100 1.01500 4.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
5.440 2054.00000 19.1000 -44.53125 0.00000 1.44500 1.44500 13.30000 0.33100 1.01500 4.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
5.450 2054.00000 19.1000 -44.53125 0.00000 1.44500 1.44500 13.30000 0.33100 1.01500 4.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
5.460 2054.00000 19.1000 -44.53125 0.00000 1.44500 1.44500 13.30000 0.33100 1.01500 4.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
5.470 2090.00000 18.9000 -44.53125 0.00000 1.46300 1.46300 13.10000 0.35400 0.97300 4.60000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
5.480 2090.00000 18.9000 -44.53125 0.00000 1.46300 1.46300 13.10000 0.35400 0.97300 4.60000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
5.490 2090.00000 18.9000 -44.53125 0.00000 1.46300 1.46300 13.10000 0.35400 0.97300 4.60000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
5.500 2090.00000 18.9000 -44.53125 0.00000 1.46300 1.46300 13.10000 0.35400 0.97300 4.60000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
5.510 2090.00000 18.9000 -44.53125 0.00000 1.46300 1.46300 13.10000 0.35400 0.97300 4.60000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
5.520 2042.00000 18.9000 -44.53125 0.00000 1.45100 1.45100 13.60000 0.35400 0.97300 4.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
5.530 2042.00000 18.9000 -44.53125 0.00000 1.45100 1.45100 13.60000 0.35400 0.97300 4.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
5.540 2042.00000 18.9000 -44.53125 0.00000 1.45100 1.45100 13.60000 0.35400 0.97300 4.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
5.550 2042.00000 18.9000 -44.53125 0.00000 1.45100 1.45100 13.60000 0.35400 0.97300 4.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
5.560 2042.00000 18.9000 -44.53125 0.00000 1.45100 1.45100 13.60000 0.35400 0.97300 4.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
5.570 2062.00000 18.9000 -44.53125 0.00000 1.41000 1.41000 12.50000 0.35400 0.97300 4.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
5.580 2062.00000 18.9000 -44.53125 0.00000 1.41000 1.41000 12.50000 0.35400 0.97300 4.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
5.590 2062.00000 18.9000 -44.53125 0.00000 1.41000 1.41000 12.50000 0.35400 0.97300 4.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
5.600 2062.00000 18.9000 -44.53125 0.00000 1.41000 1.41000 12.50000 0.35400 0.97300 4.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
5.610 2062.00000 18.9000 -44.53125 0.00000 1.41000 1.41000 12.50000 0.35400 0.97300 4.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
5.620 2074.00000 18.7000 -44.53125 0.00000 1.45100 1.45100 13.10000 0.35400 0.97300 4.60000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
5.630 2074.00000 18.7000 -44.53125 0.00000 1.45100 1.45100 13.10000 0.35400 0.97300 4.60000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
5.640 2074.00000 18.7000 -44.53125 0.00000 1.45100 1.45100 13.10000 0.35400 0.97300 4.60000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
5.650 2074.00000 18.7000 -44.53125 0.00000 1.45100 1.45100 13.10000 0.35400 0.97300 4.60000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
5.660 2074.00000 18.7000 -44.53125 0.00000 1.45100 1.45100 13.10000 0.35400 0.97300 4.60000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
5.670 2094.00000 18.7000 -44.53125 0.00000 1.45700 1.45700 13.40000 0.67300 0.88400 4.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
5.680 2094.00000 18.7000 -44.53125 0.00000 1.45700 1.45700 13.40000 0.67300 0.88400 4.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
5.690 2094.00000 18.7000 -44.53125 0.00000 1.45700 1.45700 13.40000 0.67300 0.88400 4.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
5.700 2094.00000 18.7000 -44.53125 0.00000 1.45700 1.45700 13.40000 0.67300 0.88400 4.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
5.710 2094.00000 18.7000 -44.53125 0.00000 1.45700 1.45700 13.40000 0.67300 0.88400 4.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
5.720 2036.00000 18.7000 -44.53125 0.00000 1.45100 1.45100 13.60000 0.67300 0.88400 4.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
5.730 2036.00000 18.7000 -44.53125 0.00000 1.45100 1.45100 13.60000 0.67300 0.88400 4.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
5.740 2036.00000 18.7000 -44.53125 0.00000 1.45100 1.45100 13.60000 0.67300 0.88400 4.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
5.750 2036.00000 18.7000 -44.53125 0.00000 1.45100 1.45100 13.60000 0.67300 0.88400 4.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
5.760 2036.00000 18.7000 -44.53125 0.00000 1.45100 1.45100 13.60000 0.67300 0.88400 4.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
5.770 2036.00000 19.5000 -44.53125 0.00000 1.46300 1.46300 13.40000 0.67300 0.88400 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
5.780 2036.00000 19.5000 -44.53125 0.00000 1.46300 1.46300 13.40000 0.67300 0.88400 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
5.790 2036.00000 19.5000 -44.53125 0.00000 1.46300 1.46300 13.40000 0.67300 0.88400 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
5.800 2036.00000 19.5000 -44.53125 0.00000 1.46300 1.46300 13.40000 0.67300 0.88400 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
5.810 2036.00000 19.5000 -44.53125 0.00000 1.46300 1.46300 13.40000 0.67300 0.88400 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
5.820 2061.00000 20.1000 -44.53125 0.00000 1.53900 1.53900 13.10000 0.67300 0.88400 5.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
5.830 2061.00000 20.1000 -44.53125 0.00000 1.53900 1.53900 13.10000 0.67300 0.88400 5.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
5.840 2061.00000 20.1000 -44.53125 0.00000 1.53900 1.53900 13.10000 0.67300 0.88400 5.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
5.850 2061.00000 20.1000 -44.53125 0.00000 1.53900 1.53900 13.10000 0.67300 0.88400 5.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
5.860 2061.00000 20.1000 -44.53125 0.00000 1.53900 1.53900 13.10000 0.67300 0.88400 5.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
5.870 2041.00000 20.1000 -44.53125 0.00000 1.56800 1.56800 13.60000 1.06900 0.70500 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
5.880 2041.00000 20.1000 -44.53125 0.00000 1.56800 1.56800 13.60000 1.06900 0.70500 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
5.890 2041.00000 20.1000 -44.53125 0.00000 1.56800 1.56800 13.60000 1.06900 0.70500 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
5.900 2041.00000 20.1000 -44.53125 0.00000 1.56800 1.56800 13.60000 1.06900 0.70500 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
5.910 2041.00000 20.1000 -44.53125 0.00000 1.56800 1.56800 13.60000 1.06900 0.70500 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
5.920 2026.00000 20.1000 -44.53125 0.00000 1.54400 1.54400 13.10000 1.06900 0.70500 5.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
5.930 2026.00000 20.1000 -44.53125 0.00000 1.54400 1.54400 13.10000 1.06900 0.70500 5.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
5.940 2026.00000 20.1000 -44.53125 0.00000 1.54400 1.54400 13.10000 1.06900 0.70500 5.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
5.950 2026.00000 20.1000 -44.53125 0.00000 1.54400 1.54400 13.10000 1.06900 0.70500 5.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
5.960 2026.00000 20.1000 -44.53125 0.00000 1.54400 1.54400 13.10000 1.06900 0.70500 5.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
5.970 2092.00000 20.4000 -44.53125 0.00000 1.55600 1.55600 12.40000 1.06900 0.70500 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
5.980 2092.00000 20.4000 -44.53125 0.00000 1.55600 1.55600 12.40000 1.06900 0.70500 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
5.990 2092.00000 20.4000 -44.53125 0.00000 1.55600 1.55600 12.40000 1.06900 0.70500 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
6.000 2092.00000 20.4000 -44.53125 0.00000 1.55600 1.55600 12.40000 1.06900 0.70500 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
6.010 2092.00000 20.4000 -44.53125 0.00000 1.55600 1.55600 12.40000 1.06900 0.70500 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
6.020 2077.00000 20.4000 -44.53125 0.00000 1.57400 1.57400 13.30000 1.06900 0.70500 5.70000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
6.030 2077.00000 20.4000 -44.53125 0.00000 1.57400 1.57400 13.30000 1.06900 0.70500 5.70000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
6.040 2077.00000 20.4000 -44.53125 0.00000 1.57400 1.57400 13.30000 1.06900 0.70500 5.70000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
6.050 2077.00000 20.4000 -44.53125 0.00000 1.57400 1.57400 13.30000 1.06900 0.70500 5.70000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
6.060 2077.00000 20.4000 -44.53125 0.00000 1.57400 1.57400 13.30000 1.06900 0.70500 5.70000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
6.070 2064.00000 20.4000 -44.53125 0.00000 1.57900 1.57900 13.50000 0.93800 0.64100 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.6000 0.000 0.000 0.000 0.000
6.080 2064.00000 20.4000 -44.53125 0.00000 1.57900 1.57900 13.50000 0.93800 0.64100 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.6000 0.000 0.000 0.000 0.000
6.090 2064.00000 20.4000 -44.53125 0.00000 1.57900 1.57900 13.50000 0.93800 0.64100 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.6000 0.000 0.000 0.000 0.000
6.100 2064.00000 20.4000 -44.53125 0.00000 1.57900 1.57900 13.50000 0.93800 0.64100 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.6000 0.000 0.000 0.000 0.000
6.110 2064.00000 20.4000 -44.53125 0.00000 1.57900 1.57900 13.50000 0.93800 0.64100 5.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.6000 0.000 0.000 0.000 0.000
6.120 2030.00000 20.4000 -44.53125 0.00000 1.58500 1.58500 12.50000 0.93800 0.64100 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
6.130 2030.00000 20.4000 -44.53125 0.00000 1.58500 1.58500 12.50000 0.93800 0.64100 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
6.140 2030.00000 20.4000 -44.53125 0.00000 1.58500 1.58500 12.50000 0.93800 0.64100 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
6.150 2030.00000 20.4000 -44.53125 0.00000 1.58500 1.58500 12.50000 0.93800 0.64100 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
6.160 2030.00000 20.4000 -44.53125 0.00000 1.58500 1.58500 12.50000 0.93800 0.64100 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
6.170 2070.00000 20.4000 -44.53125 0.00000 1.58500 1.58500 13.30000 0.93800 0.64100 5.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
6.180 2070.00000 20.4000 -44.53125 0.00000 1.58500 1.58500 13.30000 0.93800 0.64100 5.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
6.190 2070.00000 20.4000 -44.53125 0.00000 1.58500 1.58500 13.30000 0.93800 0.64100 5.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
6.200 2070.00000 20.4000 -44.53125 0.00000 1.58500 1.58500 13.30000 0.93800 0.64100 5.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
6.210 2070.00000 20.4000 -44.53125 0.00000 1.58500 1.58500 13.30000 0.93800 0.64100 5.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
6.220 2052.00000 20.9000 -44.53125 0.00000 1.60300 1.60300 13.10000 0.93800 0.64100 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
6.230 2052.00000 20.9000 -44.53125 0.00000 1.60300 1.60300 13.10000 0.93800 0.64100 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
6.240 2052.00000 20.9000 -44.53125 0.00000 1.60300 1.60300 13.10000 0.93800 0.64100 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
6.250 2052.00000 20.9000 -44.53125 0.00000 1.60300 1.60300 13.10000 0.93800 0.64100 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
6.260 2052.00000 20.9000 -44.53125 0.00000 1.60300 1.60300 13.10000 0.93800 0.64100 5.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
6.270 2059.00000 20.9000 -44.53125 0.00000 1.58500 1.58500 12.60000 0.31900 0.80400 5.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
6.280 2059.00000 20.9000 -44.53125 0.00000 1.58500 1.58500 12.60000 0.31900 0.80400 5.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
6.290 2059.00000 20.9000 -44.53125 0.00000 1.58500 1.58500 12.60000 0.31900 0.80400 5.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
6.300 2059.00000 20.9000 -44.53125 0.00000 1.58500 1.58500 12.60000 0.31900 0.80400 5.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
6.310 2059.00000 20.9000 -44.53125 0.00000 1.58500 1.58500 12.60000 0.31900 0.80400 5.80000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
6.320 2080.00000 20.7000 -44.53125 0.00000 1.59100 1.59100 12.90000 0.31900 0.80400 5.50000 1.00000 4.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
6.330 2080.00000 20.7000 -44.53125 0.00000 1.59100 1.59100 12.90000 0.31900 0.80400 5.50000 1.00000 4.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
6.340 2080.00000 20.7000 -44.53125 0.00000 1.59100 1.59100 12.90000 0.31900 0.80400 5.50000 1.00000 4.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
6.350 2080.00000 20.7000 -44.53125 0.00000 1.59100 1.59100 12.90000 0.31900 0.80400 5.50000 1.00000 4.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
6.360 2080.00000 20.7000 -44.53125 0.00000 1.59100 1.59100 12.90000 0.31900 0.80400 5.50000 1.00000 4.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
6.370 2023.00000 21.0000 -44.53125 0.00000 1.56200 1.56200 12.90000 0.31900 0.80400 5.70000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
6.380 2023.00000 21.0000 -44.53125 0.00000 1.56200 1.56200 12.90000 0.31900 0.80400 5.70000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
6.390 2023.00000 21.0000 -44.53125 0.00000 1.56200 1.56200 12.90000 0.31900 0.80400 5.70000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
6.400 2023.00000 21.0000 -44.53125 0.00000 1.56200 1.56200 12.90000 0.31900 0.80400 5.70000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
6.410 2023.00000 21.0000 -44.53125 0.00000 1.56200 1.56200 12.90000 0.31900 0.80400 5.70000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
6.420 2046.00000 21.3000 -44.53125 0.00000 1.62600 1.62600 13.30000 0.31900 0.80400 5.90000 1.00000 3.00000 3.00000 3.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
6.430 2046.00000 21.3000 -44.53125 0.00000 1.62600 1.62600 13.30000 0.31900 0.80400 5.90000 1.00000 3.00000 3.00000 3.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
6.440 2046.00000 21.3000 -44.53125 0.00000 1.62600 1.62600 13.30000 0.31900 0.80400 5.90000 1.00000 3.00000 3.00000 3.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
6.450 2046.00000 21.3000 -44.53125 0.00000 1.62600 1.62600 13.30000 0.31900 0.80400 5.90000 1.00000 3.00000 3.00000 3.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
6.460 2046.00000 21.3000 -44.53125 0.00000 1.62600 1.62600 13.30000 0.31900 0.80400 5.90000 1.00000 3.00000 3.00000 3.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
6.470 2065.00000 21.3000 -44.53125 0.00000 1.64900 1.64900 13.00000 0.30900 0.93200 5.70000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
6.480 2065.00000 21.3000 -44.53125 0.00000 1.64900 1.64900 13.00000 0.30900 0.93200 5.70000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
6.490 2065.00000 21.3000 -44.53125 0.00000 1.64900 1.64900 13.00000 0.30900 0.93200 5.70000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
6.500 2065.00000 21.3000 -44.53125 0.00000 1.64900 1.64900 13.00000 0.30900 0.93200 5.70000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
6.510 2065.00000 21.3000 -44.53125 0.00000 1.64900 1.64900 13.00000 0.30900 0.93200 5.70000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
6.520 2088.00000 21.2000 -44.53125 0.00000 1.64400 1.64400 13.20000 0.30900 0.93200 6.10000 1.00000 3.00000 4.00000 3.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
6.530 2088.00000 21.2000 -44.53125 0.00000 1.64400 1.64400 13.20000 0.30900 0.93200 6.10000 1.00000 3.00000 4.00000 3.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
6.540 2088.00000 21.2000 -44.53125 0.00000 1.64400 1.64400 13.20000 0.30900 0.93200 6.10000 1.00000 3.00000 4.00000 3.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
6.550 2088.00000 21.2000 -44.53125 0.00000 1.64400 1.64400 13.20000 0.30900 0.93200 6.10000 1.00000 3.00000 4.00000 3.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
6.560 2088.00000 21.2000 -44.53125 0.00000 1.64400 1.64400 13.20000 0.30900 0.93200 6.10000 1.00000 3.00000 4.00000 3.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
6.570 2031.00000 21.2000 -44.53125 0.00000 1.64400 1.64400 13.40000 0.30900 0.93200 6.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
6.580 2031.00000 21.2000 -44.53125 0.00000 1.64400 1.64400 13.40000 0.30900 0.93200 6.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
6.590 2031.00000 21.2000 -44.53125 0.00000 1.64400 1.64400 13.40000 0.30900 0.93200 6.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
6.600 2031.00000 21.2000 -44.53125 0.00000 1.64400 1.64400 13.40000 0.30900 0.93200 6.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
6.610 2031.00000 21.2000 -44.53125 0.00000 1.64400 1.64400 13.40000 0.30900 0.93200 6.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
6.620 2047.00000 21.5000 -44.53125 0.00000 1.60900 1.60900 12.50000 0.30900 0.93200 5.60000 1.00000 4.00000 3.00000 4.00000 3.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
6.630 2047.00000 21.5000 -44.53125 0.00000 1.60900 1.60900 12.50000 0.30900 0.93200 5.60000 1.00000 4.00000 3.00000 4.00000 3.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
6.640 2047.00000 21.5000 -44.53125 0.00000 1.60900 1.60900 12.50000 0.30900 0.93200 5.60000 1.00000 4.00000 3.00000 4.00000 3.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
6.650 2047.00000 21.5000 -44.53125 0.00000 1.60900 1.60900 12.50000 0.30900 0.93200 5.60000 1.00000 4.00000 3.00000 4.00000 3.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
6.660 2047.00000 21.5000 -44.53125 0.00000 1.60900 1.60900 12.50000 0.30900 0.93200 5.60000 1.00000 4.00000 3.00000 4.00000 3.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
6.670 2044.00000 21.5000 -44.53125 0.00000 1.63800 1.63800 11.90000 0.32500 0.51700 6.00000 1.00000 4.00000 4.00000 3.00000 4.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
6.680 2044.00000 21.5000 -44.53125 0.00000 1.63800 1.63800 11.90000 0.32500 0.51700 6.00000 1.00000 4.00000 4.00000 3.00000 4.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
6.690 2044.00000 21.5000 -44.53125 0.00000 1.63800 1.63800 11.90000 0.32500 0.51700 6.00000 1.00000 4.00000 4.00000 3.00000 4.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
6.700 2044.00000 21.5000 -44.53125 0.00000 1.63800 1.63800 11.90000 0.32500 0.51700 6.00000 1.00000 4.00000 4.00000 3.00000 4.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
6.710 2044.00000 21.5000 -44.53125 0.00000 1.63800 1.63800 11.90000 0.32500 0.51700 6.00000 1.00000 4.00000 4.00000 3.00000 4.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
6.720 2028.00000 21.0000 -44.53125 0.00000 1.62600 1.62600 13.40000 0.32500 0.51700 6.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
6.730 2028.00000 21.0000 -44.53125 0.00000 1.62600 1.62600 13.40000 0.32500 0.51700 6.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
6.740 2028.00000 21.0000 -44.53125 0.00000 1.62600 1.62600 13.40000 0.32500 0.51700 6.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
6.750 2028.00000 21.0000 -44.53125 0.00000 1.62600 1.62600 13.40000 0.32500 0.51700 6.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
6.760 2028.00000 21.0000 -44.53125 0.00000 1.62600 1.62600 13.40000 0.32500 0.51700 6.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
6.770 2041.00000 21.3000 -44.53125 0.00000 1.64400 1.64400 13.00000 0.32500 0.51700 5.90000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
6.780 2041.00000 21.3000 -44.53125 0.00000 1.64400 1.64400 13.00000 0.32500 0.51700 5.90000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
6.790 2041.00000 21.3000 -44.53125 0.00000 1.64400 1.64400 13.00000 0.32500 0.51700 5.90000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
6.800 2041.00000 21.3000 -44.53125 0.00000 1.64400 1.64400 13.00000 0.32500 0.51700 5.90000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
6.810 2041.00000 21.3000 -44.53125 0.00000 1.64400 1.64400 13.00000 0.32500 0.51700 5.90000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
6.820 2111.00000 21.8000 -44.53125 0.00000 1.64900 1.64900 12.10000 0.32500 0.51700 6.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.8000 0.000 0.000 0.000 0.000
6.830 2111.00000 21.8000 -44.53125 0.00000 1.64900 1.64900 12.10000 0.32500 0.51700 6.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.8000 0.000 0.000 0.000 0.000
6.840 2111.00000 21.8000 -44.53125 0.00000 1.64900 1.64900 12.10000 0.32500 0.51700 6.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.8000 0.000 0.000 0.000 0.000
6.850 2111.00000 21.8000 -44.53125 0.00000 1.64900 1.64900 12.10000 0.32500 0.51700 6.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.8000 0.000 0.000 0.000 0.000
6.860 2111.00000 21.8000 -44.53125 0.00000 1.64900 1.64900 12.10000 0.32500 0.51700 6.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.8000 0.000 0.000 0.000 0.000
6.870 2049.00000 21.5000 -44.53125 0.00000 1.62000 1.62000 13.10000 0.32800 0.34100 5.90000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
6.880 2049.00000 21.5000 -44.53125 0.00000 1.62000 1.62000 13.10000 0.32800 0.34100 5.90000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
6.890 2049.00000 21.5000 -44.53125 0.00000 1.62000 1.62000 13.10000 0.32800 0.34100 5.90000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
6.900 2049.00000 21.5000 -44.53125 0.00000 1.62000 1.62000 13.10000 0.32800 0.34100 5.90000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
6.910 2049.00000 21.5000 -44.53125 0.00000 1.62000 1.62000 13.10000 0.32800 0.34100 5.90000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
6.920 2020.00000 21.3000 -44.53125 0.00000 1.57900 1.57900 13.40000 0.32800 0.34100 6.00000 1.00000 3.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
6.930 2020.00000 21.3000 -44.53125 0.00000 1.57900 1.57900 13.40000 0.32800 0.34100 6.00000 1.00000 3.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
6.940 2020.00000 21.3000 -44.53125 0.00000 1.57900 1.57900 13.40000 0.32800 0.34100 6.00000 1.00000 3.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
6.950 2020.00000 21.3000 -44.53125 0.00000 1.57900 1.57900 13.40000 0.32800 0.34100 6.00000 1.00000 3.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
6.960 2020.00000 21.3000 -44.53125 0.00000 1.57900 1.57900 13.40000 0.32800 0.34100 6.00000 1.00000 3.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
6.970 2035.00000 21.7000 -44.53125 0.00000 1.63800 1.63800 13.10000 0.32800 0.34100 6.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
6.980 2035.00000 21.7000 -44.53125 0.00000 1.63800 1.63800 13.10000 0.32800 0.34100 6.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
6.990 2035.00000 21.7000 -44.53125 0.00000 1.63800 1.63800 13.10000 0.32800 0.34100 6.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
7.000 2035.00000 21.7000 -44.53125 0.00000 1.63800 1.63800 13.10000 0.32800 0.34100 6.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
7.010 2035.00000 21.7000 -44.53125 0.00000 1.63800 1.63800 13.10000 0.32800 0.34100 6.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
7.020 2105.00000 22.0000 -44.53125 0.00000 1.72500 1.72500 13.20000 0.32800 0.34100 6.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
7.030 2105.00000 22.0000 -44.53125 0.00000 1.72500 1.72500 13.20000 0.32800 0.34100 6.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
7.040 2105.00000 22.0000 -44.53125 0.00000 1.72500 1.72500 13.20000 0.32800 0.34100 6.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
7.050 2105.00000 22.0000 -44.53125 0.00000 1.72500 1.72500 13.20000 0.32800 0.34100 6.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
7.060 2105.00000 22.0000 -44.53125 0.00000 1.72500 1.72500 13.20000 0.32800 0.34100 6.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
7.070 2053.00000 22.0000 -44.53125 0.00000 1.68400 1.68400 13.50000 0.33500 0.33500 6.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
7.080 2053.00000 22.0000 -44.53125 0.00000 1.68400 1.68400 13.50000 0.33500 0.33500 6.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
7.090 2053.00000 22.0000 -44.53125 0.00000 1.68400 1.68400 13.50000 0.33500 0.33500 6.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
7.100 2053.00000 22.0000 -44.53125 0.00000 1.68400 1.68400 13.50000 0.33500 0.33500 6.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
7.110 2053.00000 22.0000 -44.53125 0.00000 1.68400 1.68400 13.50000 0.33500 0.33500 6.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
7.120 2022.00000 22.0000 -44.53125 0.00000 1.66100 1.66100 13.30000 0.33500 0.33500 6.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
7.130 2022.00000 22.0000 -44.53125 0.00000 1.66100 1.66100 13.30000 0.33500 0.33500 6.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
7.140 2022.00000 22.0000 -44.53125 0.00000 1.66100 1.66100 13.30000 0.33500 0.33500 6.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
7.150 2022.00000 22.0000 -44.53125 0.00000 1.66100 1.66100 13.30000 0.33500 0.33500 6.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
7.160 2022.00000 22.0000 -44.53125 0.00000 1.66100 1.66100 13.30000 0.33500 0.33500 6.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
7.170 2077.00000 22.0000 -44.53125 0.00000 1.73100 1.73100 12.90000 0.33500 0.33500 6.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
7.180 2077.00000 22.0000 -44.53125 0.00000 1.73100 1.73100 12.90000 0.33500 0.33500 6.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
7.190 2077.00000 22.0000 -44.53125 0.00000 1.73100 1.73100 12.90000 0.33500 0.33500 6.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
7.200 2077.00000 22.0000 -44.53125 0.00000 1.73100 1.73100 12.90000 0.33500 0.33500 6.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
7.210 2077.00000 22.0000 -44.53125 0.00000 1.73100 1.73100 12.90000 0.33500 0.33500 6.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
7.220 2072.00000 22.1000 -44.53125 0.00000 1.70200 1.70200 13.40000 0.33500 0.33500 6.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
7.230 2072.00000 22.1000 -44.53125 0.00000 1.70200 1.70200 13.40000 0.33500 0.33500 6.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
7.240 2072.00000 22.1000 -44.53125 0.00000 1.70200 1.70200 13.40000 0.33500 0.33500 6.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
7.250 2072.00000 22.1000 -44.53125 0.00000 1.70200 1.70200 13.40000 0.33500 0.33500 6.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
7.260 2072.00000 22.1000 -44.53125 0.00000 1.70200 1.70200 13.40000 0.33500 0.33500 6.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
7.270 2067.00000 21.8000 -44.53125 0.00000 1.67800 1.67800 13.50000 0.40500 0.34100 6.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
7.280 2067.00000 21.8000 -44.53125 0.00000 1.67800 1.67800 13.50000 0.40500 0.34100 6.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
7.290 2067.00000 21.8000 -44.53125 0.00000 1.67800 1.67800 13.50000 0.40500 0.34100 6.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
7.300 2067.00000 21.8000 -44.53125 0.00000 1.67800 1.67800 13.50000 0.40500 0.34100 6.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
7.310 2067.00000 21.8000 -44.53125 0.00000 1.67800 1.67800 13.50000 0.40500 0.34100 6.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
7.320 2034.00000 21.7000 -44.53125 0.00000 1.67300 1.67300 12.90000 0.40500 0.34100 6.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
7.330 2034.00000 21.7000 -44.53125 0.00000 1.67300 1.67300 12.90000 0.40500 0.34100 6.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
7.340 2034.00000 21.7000 -44.53125 0.00000 1.67300 1.67300 12.90000 0.40500 0.34100 6.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
7.350 2034.00000 21.7000 -44.53125 0.00000 1.67300 1.67300 12.90000 0.40500 0.34100 6.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
7.360 2034.00000 21.7000 -44.53125 0.00000 1.67300 1.67300 12.90000 0.40500 0.34100 6.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
7.370 2075.00000 22.1000 -44.53125 0.00000 1.69600 1.69600 12.50000 0.40500 0.34100 6.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
7.380 2075.00000 22.1000 -44.53125 0.00000 1.69600 1.69600 12.50000 0.40500 0.34100 6.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
7.390 2075.00000 22.1000 -44.53125 0.00000 1.69600 1.69600 12.50000 0.40500 0.34100 6.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
7.400 2075.00000 22.1000 -44.53125 0.00000 1.69600 1.69600 12.50000 0.40500 0.34100 6.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
7.410 2075.00000 22.1000 -44.53125 0.00000 1.69600 1.69600 12.50000 0.40500 0.34100 6.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
7.420 2057.00000 22.6000 -44.53125 0.00000 1.73100 1.73100 13.50000 0.40500 0.34100 6.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
7.430 2057.00000 22.6000 -44.53125 0.00000 1.73100 1.73100 13.50000 0.40500 0.34100 6.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
7.440 2057.00000 22.6000 -44.53125 0.00000 1.73100 1.73100 13.50000 0.40500 0.34100 6.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
7.450 2057.00000 22.6000 -44.53125 0.00000 1.73100 1.73100 13.50000 0.40500 0.34100 6.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
7.460 2057.00000 22.6000 -44.53125 0.00000 1.73100 1.73100 13.50000 0.40500 0.34100 6.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
7.470 2057.00000 22.4000 -44.53125 0.00000 1.70200 1.70200 12.90000 1.02100 0.34700 6.40000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
7.480 2057.00000 22.4000 -44.53125 0.00000 1.70200 1.70200 12.90000 1.02100 0.34700 6.40000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
7.490 2057.00000 22.4000 -44.53125 0.00000 1.70200 1.70200 12.90000 1.02100 0.34700 6.40000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
7.500 2057.00000 22.4000 -44.53125 0.00000 1.70200 1.70200 12.90000 1.02100 0.34700 6.40000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
7.510 2057.00000 22.4000 -44.53125 0.00000 1.70200 1.70200 12.90000 1.02100 0.34700 6.40000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
7.520 2032.00000 22.4000 -44.53125 0.00000 1.71300 1.71300 13.00000 1.02100 0.34700 6.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
7.530 2032.00000 22.4000 -44.53125 0.00000 1.71300 1.71300 13.00000 1.02100 0.34700 6.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
7.540 2032.00000 22.4000 -44.53125 0.00000 1.71300 1.71300 13.00000 1.02100 0.34700 6.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
7.550 2032.00000 22.4000 -44.53125 0.00000 1.71300 1.71300 13.00000 1.02100 0.34700 6.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
7.560 2032.00000 22.4000 -44.53125 0.00000 1.71300 1.71300 13.00000 1.02100 0.34700 6.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
7.570 2066.00000 22.1000 -44.53125 0.00000 1.72500 1.72500 13.40000 1.02100 0.34700 6.40000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
7.580 2066.00000 22.1000 -44.53125 0.00000 1.72500 1.72500 13.40000 1.02100 0.34700 6.40000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
7.590 2066.00000 22.1000 -44.53125 0.00000 1.72500 1.72500 13.40000 1.02100 0.34700 6.40000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
7.600 2066.00000 22.1000 -44.53125 0.00000 1.72500 1.72500 13.40000 1.02100 0.34700 6.40000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
7.610 2066.00000 22.1000 -44.53125 0.00000 1.72500 1.72500 13.40000 1.02100 0.34700 6.40000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
7.620 2061.00000 22.4000 -44.53125 0.00000 1.72500 1.72500 12.80000 1.02100 0.34700 6.40000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
7.630 2061.00000 22.4000 -44.53125 0.00000 1.72500 1.72500 12.80000 1.02100 0.34700 6.40000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
7.640 2061.00000 22.4000 -44.53125 0.00000 1.72500 1.72500 12.80000 1.02100 0.34700 6.40000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
7.650 2061.00000 22.4000 -44.53125 0.00000 1.72500 1.72500 12.80000 1.02100 0.34700 6.40000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
7.660 2061.00000 22.4000 -44.53125 0.00000 1.72500 1.72500 12.80000 1.02100 0.34700 6.40000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
7.670 2082.00000 22.3000 -44.53125 0.00000 1.73700 1.73700 13.20000 1.02700 0.37000 6.90000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
7.680 2082.00000 22.3000 -44.53125 0.00000 1.73700 1.73700 13.20000 1.02700 0.37000 6.90000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
7.690 2082.00000 22.3000 -44.53125 0.00000 1.73700 1.73700 13.20000 1.02700 0.37000 6.90000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
7.700 2082.00000 22.3000 -44.53125 0.00000 1.73700 1.73700 13.20000 1.02700 0.37000 6.90000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
7.710 2082.00000 22.3000 -44.53125 0.00000 1.73700 1.73700 13.20000 1.02700 0.37000 6.90000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
7.720 2035.00000 22.6000 -44.53125 0.00000 1.76000 1.76000 13.50000 1.02700 0.37000 6.40000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
7.730 2035.00000 22.6000 -44.53125 0.00000 1.76000 1.76000 13.50000 1.02700 0.37000 6.40000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
7.740 2035.00000 22.6000 -44.53125 0.00000 1.76000 1.76000 13.50000 1.02700 0.37000 6.40000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
7.750 2035.00000 22.6000 -44.53125 0.00000 1.76000 1.76000 13.50000 1.02700 0.37000 6.40000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
7.760 2035.00000 22.6000 -44.53125 0.00000 1.76000 1.76000 13.50000 1.02700 0.37000 6.40000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
7.770 2059.00000 22.3000 -44.53125 0.00000 1.71900 1.71900 13.70000 1.02700 0.37000 6.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
7.780 2059.00000 22.3000 -44.53125 0.00000 1.71900 1.71900 13.70000 1.02700 0.37000 6.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
7.790 2059.00000 22.3000 -44.53125 0.00000 1.71900 1.71900 13.70000 1.02700 0.37000 6.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
7.800 2059.00000 22.3000 -44.53125 0.00000 1.71900 1.71900 13.70000 1.02700 0.37000 6.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
7.810 2059.00000 22.3000 -44.53125 0.00000 1.71900 1.71900 13.70000 1.02700 0.37000 6.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
7.820 2067.00000 22.6000 -44.53125 0.00000 1.74800 1.74800 13.40000 1.02700 0.37000 6.80000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
7.830 2067.00000 22.6000 -44.53125 0.00000 1.74800 1.74800 13.40000 1.02700 0.37000 6.80000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
7.840 2067.00000 22.6000 -44.53125 0.00000 1.74800 1.74800 13.40000 1.02700 0.37000 6.80000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
7.850 2067.00000 22.6000 -44.53125 0.00000 1.74800 1.74800 13.40000 1.02700 0.37000 6.80000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
7.860 2067.00000 22.6000 -44.53125 0.00000 1.74800 1.74800 13.40000 1.02700 0.37000 6.80000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
7.870 2081.00000 22.7000 -44.53125 0.00000 1.78300 1.78300 13.10000 0.96000 0.41800 6.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
7.880 2081.00000 22.7000 -44.53125 0.00000 1.78300 1.78300 13.10000 0.96000 0.41800 6.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
7.890 2081.00000 22.7000 -44.53125 0.00000 1.78300 1.78300 13.10000 0.96000 0.41800 6.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
7.900 2081.00000 22.7000 -44.53125 0.00000 1.78300 1.78300 13.10000 0.96000 0.41800 6.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
7.910 2081.00000 22.7000 -44.53125 0.00000 1.78300 1.78300 13.10000 0.96000 0.41800 6.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
7.920 2036.00000 22.7000 -44.53125 0.00000 1.80100 1.80100 13.20000 0.96000 0.41800 7.10000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
7.930 2036.00000 22.7000 -44.53125 0.00000 1.80100 1.80100 13.20000 0.96000 0.41800 7.10000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
7.940 2036.00000 22.7000 -44.53125 0.00000 1.80100 1.80100 13.20000 0.96000 0.41800 7.10000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
7.950 2036.00000 22.7000 -44.53125 0.00000 1.80100 1.80100 13.20000 0.96000 0.41800 7.10000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
7.960 2036.00000 22.7000 -44.53125 0.00000 1.80100 1.80100 13.20000 0.96000 0.41800 7.10000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
7.970 2064.00000 23.3000 -44.53125 0.00000 1.78900 1.78900 13.30000 0.96000 0.41800 7.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
7.980 2064.00000 23.3000 -44.53125 0.00000 1.78900 1.78900 13.30000 0.96000 0.41800 7.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
7.990 2064.00000 23.3000 -44.53125 0.00000 1.78900 1.78900 13.30000 0.96000 0.41800 7.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
8.000 2064.00000 23.3000 -44.53125 0.00000 1.78900 1.78900 13.30000 0.96000 0.41800 7.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
8.010 2064.00000 23.3000 -44.53125 0.00000 1.78900 1.78900 13.30000 0.96000 0.41800 7.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
8.020 2119.00000 23.6000 -44.53125 0.00000 1.88300 1.88300 12.80000 0.96000 0.41800 6.90000 1.00000 5.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
8.030 2119.00000 23.6000 -44.53125 0.00000 1.88300 1.88300 12.80000 0.96000 0.41800 6.90000 1.00000 5.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
8.040 2119.00000 23.6000 -44.53125 0.00000 1.88300 1.88300 12.80000 0.96000 0.41800 6.90000 1.00000 5.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
8.050 2119.00000 23.6000 -44.53125 0.00000 1.88300 1.88300 12.80000 0.96000 0.41800 6.90000 1.00000 5.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
8.060 2119.00000 23.6000 -44.53125 0.00000 1.88300 1.88300 12.80000 0.96000 0.41800 6.90000 1.00000 5.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
8.070 2061.00000 23.2000 -44.53125 0.00000 1.82400 1.82400 13.70000 0.46600 0.45000 7.40000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
8.080 2061.00000 23.2000 -44.53125 0.00000 1.82400 1.82400 13.70000 0.46600 0.45000 7.40000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
8.090 2061.00000 23.2000 -44.53125 0.00000 1.82400 1.82400 13.70000 0.46600 0.45000 7.40000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
8.100 2061.00000 23.2000 -44.53125 0.00000 1.82400 1.82400 13.70000 0.46600 0.45000 7.40000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
8.110 2061.00000 23.2000 -44.53125 0.00000 1.82400 1.82400 13.70000 0.46600 0.45000 7.40000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
8.120 2058.00000 23.2000 -44.53125 0.00000 1.81300 1.81300 13.60000 0.46600 0.45000 7.40000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
8.130 2058.00000 23.2000 -44.53125 0.00000 1.81300 1.81300 13.60000 0.46600 0.45000 7.40000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
8.140 2058.00000 23.2000 -44.53125 0.00000 1.81300 1.81300 13.60000 0.46600 0.45000 7.40000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
8.150 2058.00000 23.2000 -44.53125 0.00000 1.81300 1.81300 13.60000 0.46600 0.45000 7.40000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
8.160 2058.00000 23.2000 -44.53125 0.00000 1.81300 1.81300 13.60000 0.46600 0.45000 7.40000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
8.170 2075.00000 23.3000 -44.53125 0.00000 1.79500 1.79500 13.10000 0.46600 0.45000 7.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
8.180 2075.00000 23.3000 -44.53125 0.00000 1.79500 1.79500 13.10000 0.46600 0.45000 7.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
8.190 2075.00000 23.3000 -44.53125 0.00000 1.79500 1.79500 13.10000 0.46600 0.45000 7.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
8.200 2075.00000 23.3000 -44.53125 0.00000 1.79500 1.79500 13.10000 0.46600 0.45000 7.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
8.210 2075.00000 23.3000 -44.53125 0.00000 1.79500 1.79500 13.10000 0.46600 0.45000 7.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
8.220 2131.00000 23.9000 -44.53125 0.00000 1.86500 1.86500 13.50000 0.46600 0.45000 7.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
8.230 2131.00000 23.9000 -44.53125 0.00000 1.86500 1.86500 13.50000 0.46600 0.45000 7.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
8.240 2131.00000 23.9000 -44.53125 0.00000 1.86500 1.86500 13.50000 0.46600 0.45000 7.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
8.250 2131.00000 23.9000 -44.53125 0.00000 1.86500 1.86500 13.50000 0.46600 0.45000 7.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
8.260 2131.00000 23.9000 -44.53125 0.00000 1.86500 1.86500 13.50000 0.46600 0.45000 7.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
8.270 2070.00000 23.5000 -44.53125 0.00000 1.90000 1.90000 13.00000 0.40800 0.41400 7.90000 1.00000 4.00000 4.00000 5.00000 5.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
8.280 2070.00000 23.5000 -44.53125 0.00000 1.90000 1.90000 13.00000 0.40800 0.41400 7.90000 1.00000 4.00000 4.00000 5.00000 5.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
8.290 2070.00000 23.5000 -44.53125 0.00000 1.90000 1.90000 13.00000 0.40800 0.41400 7.90000 1.00000 4.00000 4.00000 5.00000 5.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
8.300 2070.00000 23.5000 -44.53125 0.00000 1.90000 1.90000 13.00000 0.40800 0.41400 7.90000 1.00000 4.00000 4.00000 5.00000 5.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
8.310 2070.00000 23.5000 -44.53125 0.00000 1.90000 1.90000 13.00000 0.40800 0.41400 7.90000 1.00000 4.00000 4.00000 5.00000 5.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
8.320 2053.00000 23.3000 -44.53125 0.00000 1.82400 1.82400 12.90000 0.40800 0.41400 7.40000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
8.330 2053.00000 23.3000 -44.53125 0.00000 1.82400 1.82400 12.90000 0.40800 0.41400 7.40000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
8.340 2053.00000 23.3000 -44.53125 0.00000 1.82400 1.82400 12.90000 0.40800 0.41400 7.40000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
8.350 2053.00000 23.3000 -44.53125 0.00000 1.82400 1.82400 12.90000 0.40800 0.41400 7.40000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
8.360 2053.00000 23.3000 -44.53125 0.00000 1.82400 1.82400 12.90000 0.40800 0.41400 7.40000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
8.370 2139.00000 23.3000 -44.53125 0.00000 1.82400 1.82400 12.90000 0.40800 0.41400 7.30000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
8.380 2139.00000 23.3000 -44.53125 0.00000 1.82400 1.82400 12.90000 0.40800 0.41400 7.30000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
8.390 2139.00000 23.3000 -44.53125 0.00000 1.82400 1.82400 12.90000 0.40800 0.41400 7.30000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
8.400 2139.00000 23.3000 -44.53125 0.00000 1.82400 1.82400 12.90000 0.40800 0.41400 7.30000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
8.410 2139.00000 23.3000 -44.53125 0.00000 1.82400 1.82400 12.90000 0.40800 0.41400 7.30000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
8.420 2081.00000 24.1000 -44.53125 0.00000 1.95800 1.95800 12.60000 0.40800 0.41400 7.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
8.430 2081.00000 24.1000 -44.53125 0.00000 1.95800 1.95800 12.60000 0.40800 0.41400 7.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
8.440 2081.00000 24.1000 -44.53125 0.00000 1.95800 1.95800 12.60000 0.40800 0.41400 7.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
8.450 2081.00000 24.1000 -44.53125 0.00000 1.95800 1.95800 12.60000 0.40800 0.41400 7.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
8.460 2081.00000 24.1000 -44.53125 0.00000 1.95800 1.95800 12.60000 0.40800 0.41400 7.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
8.470 2056.00000 23.5000 -44.53125 0.00000 1.88300 1.88300 13.30000 1.05000 0.35400 8.00000 1.00000 4.00000 4.00000 4.00000 5.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
8.480 2056.00000 23.5000 -44.53125 0.00000 1.88300 1.88300 13.30000 1.05000 0.35400 8.00000 1.00000 4.00000 4.00000 4.00000 5.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
8.490 2056.00000 23.5000 -44.53125 0.00000 1.88300 1.88300 13.30000 1.05000 0.35400 8.00000 1.00000 4.00000 4.00000 4.00000 5.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
8.500 2056.00000 23.5000 -44.53125 0.00000 1.88300 1.88300 13.30000 1.05000 0.35400 8.00000 1.00000 4.00000 4.00000 4.00000 5.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
8.510 2056.00000 23.5000 -44.53125 0.00000 1.88300 1.88300 13.30000 1.05000 0.35400 8.00000 1.00000 4.00000 4.00000 4.00000 5.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
8.520 2113.00000 23.2000 -44.53125 0.00000 1.78300 1.78300 12.70000 1.05000 0.35400 7.30000 1.00000 5.00000 4.00000 4.00000 5.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
8.530 2113.00000 23.2000 -44.53125 0.00000 1.78300 1.78300 12.70000 1.05000 0.35400 7.30000 1.00000 5.00000 4.00000 4.00000 5.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
8.540 2113.00000 23.2000 -44.53125 0.00000 1.78300 1.78300 12.70000 1.05000 0.35400 7.30000 1.00000 5.00000 4.00000 4.00000 5.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
8.550 2113.00000 23.2000 -44.53125 0.00000 1.78300 1.78300 12.70000 1.05000 0.35400 7.30000 1.00000 5.00000 4.00000 4.00000 5.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
8.560 2113.00000 23.2000 -44.53125 0.00000 1.78300 1.78300 12.70000 1.05000 0.35400 7.30000 1.00000 5.00000 4.00000 4.00000 5.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
8.570 2094.00000 23.6000 -44.53125 0.00000 1.86500 1.86500 13.50000 1.05000 0.35400 7.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
8.580 2094.00000 23.6000 -44.53125 0.00000 1.86500 1.86500 13.50000 1.05000 0.35400 7.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
8.590 2094.00000 23.6000 -44.53125 0.00000 1.86500 1.86500 13.50000 1.05000 0.35400 7.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
8.600 2094.00000 23.6000 -44.53125 0.00000 1.86500 1.86500 13.50000 1.05000 0.35400 7.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
8.610 2094.00000 23.6000 -44.53125 0.00000 1.86500 1.86500 13.50000 1.05000 0.35400 7.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
8.620 2082.00000 24.3000 -44.53125 0.00000 1.94700 1.94700 12.70000 1.05000 0.35400 8.10000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.5000 0.000 0.000 0.000 0.000
8.630 2082.00000 24.3000 -44.53125 0.00000 1.94700 1.94700 12.70000 1.05000 0.35400 8.10000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.5000 0.000 0.000 0.000 0.000
8.640 2082.00000 24.3000 -44.53125 0.00000 1.94700 1.94700 12.70000 1.05000 0.35400 8.10000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.5000 0.000 0.000 0.000 0.000
8.650 2082.00000 24.3000 -44.53125 0.00000 1.94700 1.94700 12.70000 1.05000 0.35400 8.10000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.5000 0.000 0.000 0.000 0.000
8.660 2082.00000 24.3000 -44.53125 0.00000 1.94700 1.94700 12.70000 1.05000 0.35400 8.10000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.5000 0.000 0.000 0.000 0.000
8.670 2056.00000 23.6000 -44.53125 0.00000 1.89400 1.89400 13.20000 1.04000 0.39500 7.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.5000 0.000 0.000 0.000 0.000
8.680 2056.00000 23.6000 -44.53125 0.00000 1.89400 1.89400 13.20000 1.04000 0.39500 7.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.5000 0.000 0.000 0.000 0.000
8.690 2056.00000 23.6000 -44.53125 0.00000 1.89400 1.89400 13.20000 1.04000 0.39500 7.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.5000 0.000 0.000 0.000 0.000
8.700 2056.00000 23.6000 -44.53125 0.00000 1.89400 1.89400 13.20000 1.04000 0.39500 7.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.5000 0.000 0.000 0.000 0.000
8.710 2056.00000 23.6000 -44.53125 0.00000 1.89400 1.89400 13.20000 1.04000 0.39500 7.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.5000 0.000 0.000 0.000 0.000
8.720 2116.00000 23.5000 -44.53125 0.00000 1.81300 1.81300 12.70000 1.04000 0.39500 7.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.6000 0.000 0.000 0.000 0.000
8.730 2116.00000 23.5000 -44.53125 0.00000 1.81300 1.81300 12.70000 1.04000 0.39500 7.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.6000 0.000 0.000 0.000 0.000
8.740 2116.00000 23.5000 -44.53125 0.00000 1.81300 1.81300 12.70000 1.04000 0.39500 7.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.6000 0.000 0.000 0.000 0.000
8.750 2116.00000 23.5000 -44.53125 0.00000 1.81300 1.81300 12.70000 1.04000 0.39500 7.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.6000 0.000 0.000 0.000 0.000
8.760 2116.00000 23.5000 -44.53125 0.00000 1.81300 1.81300 12.70000 1.04000 0.39500 7.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.6000 0.000 0.000 0.000 0.000
8.770 2107.00000 23.8000 -44.53125 0.00000 1.79500 1.79500 13.00000 1.04000 0.39500 7.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.5000 0.000 0.000 0.000 0.000
8.780 2107.00000 23.8000 -44.53125 0.00000 1.79500 1.79500 13.00000 1.04000 0.39500 7.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.5000 0.000 0.000 0.000 0.000
8.790 2107.00000 23.8000 -44.53125 0.00000 1.79500 1.79500 13.00000 1.04000 0.39500 7.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.5000 0.000 0.000 0.000 0.000
8.800 2107.00000 23.8000 -44.53125 0.00000 1.79500 1.79500 13.00000 1.04000 0.39500 7.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.5000 0.000 0.000 0.000 0.000
8.810 2107.00000 23.8000 -44.53125 0.00000 1.79500 1.79500 13.00000 1.04000 0.39500 7.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.5000 0.000 0.000 0.000 0.000
8.820 2107.00000 23.8000 -44.53125 0.00000 1.83000 1.83000 12.90000 1.04000 0.39500 7.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
8.830 2107.00000 23.8000 -44.53125 0.00000 1.83000 1.83000 12.90000 1.04000 0.39500 7.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
8.840 2107.00000 23.8000 -44.53125 0.00000 1.83000 1.83000 12.90000 1.04000 0.39500 7.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
8.850 2107.00000 23.8000 -44.53125 0.00000 1.83000 1.83000 12.90000 1.04000 0.39500 7.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
8.860 2107.00000 23.8000 -44.53125 0.00000 1.83000 1.83000 12.90000 1.04000 0.39500 7.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
8.870 2103.00000 23.2000 -44.53125 0.00000 1.84800 1.84800 12.80000 0.65400 0.59300 7.10000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
8.880 2103.00000 23.2000 -44.53125 0.00000 1.84800 1.84800 12.80000 0.65400 0.59300 7.10000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
8.890 2103.00000 23.2000 -44.53125 0.00000 1.84800 1.84800 12.80000 0.65400 0.59300 7.10000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
8.900 2103.00000 23.2000 -44.53125 0.00000 1.84800 1.84800 12.80000 0.65400 0.59300 7.10000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
8.910 2103.00000 23.2000 -44.53125 0.00000 1.84800 1.84800 12.80000 0.65400 0.59300 7.10000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
8.920 2146.00000 23.2000 -44.53125 0.00000 1.82400 1.82400 13.60000 0.65400 0.59300 7.50000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
8.930 2146.00000 23.2000 -44.53125 0.00000 1.82400 1.82400 13.60000 0.65400 0.59300 7.50000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
8.940 2146.00000 23.2000 -44.53125 0.00000 1.82400 1.82400 13.60000 0.65400 0.59300 7.50000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
8.950 2146.00000 23.2000 -44.53125 0.00000 1.82400 1.82400 13.60000 0.65400 0.59300 7.50000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
8.960 2146.00000 23.2000 -44.53125 0.00000 1.82400 1.82400 13.60000 0.65400 0.59300 7.50000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
8.970 2126.00000 23.5000 -44.53125 0.00000 1.83000 1.83000 12.10000 0.65400 0.59300 7.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
8.980 2126.00000 23.5000 -44.53125 0.00000 1.83000 1.83000 12.10000 0.65400 0.59300 7.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
8.990 2126.00000 23.5000 -44.53125 0.00000 1.83000 1.83000 12.10000 0.65400 0.59300 7.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
9.000 2126.00000 23.5000 -44.53125 0.00000 1.83000 1.83000 12.10000 0.65400 0.59300 7.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
9.010 2126.00000 23.5000 -44.53125 0.00000 1.83000 1.83000 12.10000 0.65400 0.59300 7.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
9.020 2177.00000 23.2000 -44.53125 0.00000 1.81800 1.81800 12.80000 0.65400 0.59300 7.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
9.030 2177.00000 23.2000 -44.53125 0.00000 1.81800 1.81800 12.80000 0.65400 0.59300 7.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
9.040 2177.00000 23.2000 -44.53125 0.00000 1.81800 1.81800 12.80000 0.65400 0.59300 7.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
9.050 2177.00000 23.2000 -44.53125 0.00000 1.81800 1.81800 12.80000 0.65400 0.59300 7.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
9.060 2177.00000 23.2000 -44.53125 0.00000 1.81800 1.81800 12.80000 0.65400 0.59300 7.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
9.070 2123.00000 23.0000 -44.53125 0.00000 1.84800 1.84800 13.40000 0.44300 0.83300 7.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
9.080 2123.00000 23.0000 -44.53125 0.00000 1.84800 1.84800 13.40000 0.44300 0.83300 7.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
9.090 2123.00000 23.0000 -44.53125 0.00000 1.84800 1.84800 13.40000 0.44300 0.83300 7.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
9.100 2123.00000 23.0000 -44.53125 0.00000 1.84800 1.84800 13.40000 0.44300 0.83300 7.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
9.110 2123.00000 23.0000 -44.53125 0.00000 1.84800 1.84800 13.40000 0.44300 0.83300 7.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
9.120 2138.00000 22.9000 -44.53125 0.00000 1.80700 1.80700 13.50000 0.44300 0.83300 7.10000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
9.130 2138.00000 22.9000 -44.53125 0.00000 1.80700 1.80700 13.50000 0.44300 0.83300 7.10000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
9.140 2138.00000 22.9000 -44.53125 0.00000 1.80700 1.80700 13.50000 0.44300 0.83300 7.10000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
9.150 2138.00000 22.9000 -44.53125 0.00000 1.80700 1.80700 13.50000 0.44300 0.83300 7.10000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
9.160 2138.00000 22.9000 -44.53125 0.00000 1.80700 1.80700 13.50000 0.44300 0.83300 7.10000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
9.170 2162.00000 23.2000 -44.53125 0.00000 1.83000 1.83000 13.00000 0.44300 0.83300 7.10000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
9.180 2162.00000 23.2000 -44.53125 0.00000 1.83000 1.83000 13.00000 0.44300 0.83300 7.10000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
9.190 2162.00000 23.2000 -44.53125 0.00000 1.83000 1.83000 13.00000 0.44300 0.83300 7.10000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
9.200 2162.00000 23.2000 -44.53125 0.00000 1.83000 1.83000 13.00000 0.44300 0.83300 7.10000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
9.210 2162.00000 23.2000 -44.53125 0.00000 1.83000 1.83000 13.00000 0.44300 0.83300 7.10000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
9.220 2201.00000 23.2000 -44.53125 0.00000 1.88800 1.88800 13.20000 0.44300 0.83300 7.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
9.230 2201.00000 23.2000 -44.53125 0.00000 1.88800 1.88800 13.20000 0.44300 0.83300 7.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
9.240 2201.00000 23.2000 -44.53125 0.00000 1.88800 1.88800 13.20000 0.44300 0.83300 7.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
9.250 2201.00000 23.2000 -44.53125 0.00000 1.88800 1.88800 13.20000 0.44300 0.83300 7.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
9.260 2201.00000 23.2000 -44.53125 0.00000 1.88800 1.88800 13.20000 0.44300 0.83300 7.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
9.270 2134.00000 23.0000 -44.53125 0.00000 1.81800 1.81800 13.20000 0.93200 0.67000 7.50000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
9.280 2134.00000 23.0000 -44.53125 0.00000 1.81800 1.81800 13.20000 0.93200 0.67000 7.50000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
9.290 2134.00000 23.0000 -44.53125 0.00000 1.81800 1.81800 13.20000 0.93200 0.67000 7.50000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
9.300 2134.00000 23.0000 -44.53125 0.00000 1.81800 1.81800 13.20000 0.93200 0.67000 7.50000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
9.310 2134.00000 23.0000 -44.53125 0.00000 1.81800 1.81800 13.20000 0.93200 0.67000 7.50000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
9.320 2137.00000 23.5000 -44.53125 0.00000 1.85300 1.85300 13.30000 0.93200 0.67000 7.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
9.330 2137.00000 23.5000 -44.53125 0.00000 1.85300 1.85300 13.30000 0.93200 0.67000 7.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
9.340 2137.00000 23.5000 -44.53125 0.00000 1.85300 1.85300 13.30000 0.93200 0.67000 7.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
9.350 2137.00000 23.5000 -44.53125 0.00000 1.85300 1.85300 13.30000 0.93200 0.67000 7.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
9.360 2137.00000 23.5000 -44.53125 0.00000 1.85300 1.85300 13.30000 0.93200 0.67000 7.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
9.370 2216.00000 24.3000 -44.53125 0.00000 1.91200 1.91200 13.10000 0.93200 0.67000 7.40000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
9.380 2216.00000 24.3000 -44.53125 0.00000 1.91200 1.91200 13.10000 0.93200 0.67000 7.40000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
9.390 2216.00000 24.3000 -44.53125 0.00000 1.91200 1.91200 13.10000 0.93200 0.67000 7.40000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
9.400 2216.00000 24.3000 -44.53125 0.00000 1.91200 1.91200 13.10000 0.93200 0.67000 7.40000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
9.410 2216.00000 24.3000 -44.53125 0.00000 1.91200 1.91200 13.10000 0.93200 0.67000 7.40000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
9.420 2186.00000 24.3000 -44.53125 0.00000 2.01100 2.01100 13.30000 0.93200 0.67000 7.40000 1.00000 5.00000 4.00000 5.00000 5.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
9.430 2186.00000 24.3000 -44.53125 0.00000 2.01100 2.01100 13.30000 0.93200 0.67000 7.40000 1.00000 5.00000 4.00000 5.00000 5.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
9.440 2186.00000 24.3000 -44.53125 0.00000 2.01100 2.01100 13.30000 0.93200 0.67000 7.40000 1.00000 5.00000 4.00000 5.00000 5.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
9.450 2186.00000 24.3000 -44.53125 0.00000 2.01100 2.01100 13.30000 0.93200 0.67000 7.40000 1.00000 5.00000 4.00000 5.00000 5.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
9.460 2186.00000 24.3000 -44.53125 0.00000 2.01100 2.01100 13.30000 0.93200 0.67000 7.40000 1.00000 5.00000 4.00000 5.00000 5.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
9.470 2160.00000 22.9000 -44.53125 0.00000 1.88300 1.88300 12.70000 0.97600 0.57700 7.60000 1.00000 4.00000 4.00000 5.00000 4.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
9.480 2160.00000 22.9000 -44.53125 0.00000 1.88300 1.88300 12.70000 0.97600 0.57700 7.60000 1.00000 4.00000 4.00000 5.00000 4.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
9.490 2160.00000 22.9000 -44.53125 0.00000 1.88300 1.88300 12.70000 0.97600 0.57700 7.60000 1.00000 4.00000 4.00000 5.00000 4.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
9.500 2160.00000 22.9000 -44.53125 0.00000 1.88300 1.88300 12.70000 0.97600 0.57700 7.60000 1.00000 4.00000 4.00000 5.00000 4.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
9.510 2160.00000 22.9000 -44.53125 0.00000 1.88300 1.88300 12.70000 0.97600 0.57700 7.60000 1.00000 4.00000 4.00000 5.00000 4.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
9.520 2243.00000 22.6000 -44.53125 0.00000 1.80100 1.80100 13.20000 0.97600 0.57700 7.40000 1.00000 5.00000 5.00000 5.00000 4.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
9.530 2243.00000 22.6000 -44.53125 0.00000 1.80100 1.80100 13.20000 0.97600 0.57700 7.40000 1.00000 5.00000 5.00000 5.00000 4.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
9.540 2243.00000 22.6000 -44.53125 0.00000 1.80100 1.80100 13.20000 0.97600 0.57700 7.40000 1.00000 5.00000 5.00000 5.00000 4.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
9.550 2243.00000 22.6000 -44.53125 0.00000 1.80100 1.80100 13.20000 0.97600 0.57700 7.40000 1.00000 5.00000 5.00000 5.00000 4.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
9.560 2243.00000 22.6000 -44.53125 0.00000 1.80100 1.80100 13.20000 0.97600 0.57700 7.40000 1.00000 5.00000 5.00000 5.00000 4.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
9.570 2215.00000 22.4000 -44.53125 0.00000 1.74800 1.74800 13.40000 0.97600 0.57700 7.10000 1.00000 4.00000 4.00000 5.00000 5.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
9.580 2215.00000 22.4000 -44.53125 0.00000 1.74800 1.74800 13.40000 0.97600 0.57700 7.10000 1.00000 4.00000 4.00000 5.00000 5.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
9.590 2215.00000 22.4000 -44.53125 0.00000 1.74800 1.74800 13.40000 0.97600 0.57700 7.10000 1.00000 4.00000 4.00000 5.00000 5.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
9.600 2215.00000 22.4000 -44.53125 0.00000 1.74800 1.74800 13.40000 0.97600 0.57700 7.10000 1.00000 4.00000 4.00000 5.00000 5.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
9.610 2215.00000 22.4000 -44.53125 0.00000 1.74800 1.74800 13.40000 0.97600 0.57700 7.10000 1.00000 4.00000 4.00000 5.00000 5.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
9.620 2191.00000 22.6000 -44.53125 0.00000 1.76600 1.76600 12.20000 0.97600 0.57700 6.90000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
9.630 2191.00000 22.6000 -44.53125 0.00000 1.76600 1.76600 12.20000 0.97600 0.57700 6.90000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
9.640 2191.00000 22.6000 -44.53125 0.00000 1.76600 1.76600 12.20000 0.97600 0.57700 6.90000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
9.650 2191.00000 22.6000 -44.53125 0.00000 1.76600 1.76600 12.20000 0.97600 0.57700 6.90000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
9.660 2191.00000 22.6000 -44.53125 0.00000 1.76600 1.76600 12.20000 0.97600 0.57700 6.90000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
9.670 2191.00000 22.6000 -44.53125 0.00000 1.76600 1.76600 12.20000 0.97600 0.57700 6.90000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
9.680 2173.00000 21.3000 -44.53125 0.00000 1.65500 1.65500 13.30000 0.42700 0.57700 6.80000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
9.690 2173.00000 21.3000 -44.53125 0.00000 1.65500 1.65500 13.30000 0.42700 0.57700 6.80000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
9.700 2173.00000 21.3000 -44.53125 0.00000 1.65500 1.65500 13.30000 0.42700 0.57700 6.80000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
9.710 2173.00000 21.3000 -44.53125 0.00000 1.65500 1.65500 13.30000 0.42700 0.57700 6.80000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
9.720 2173.00000 21.3000 -44.53125 0.00000 1.65500 1.65500 13.30000 0.42700 0.57700 6.80000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
9.730 2228.00000 21.5000 -44.53125 0.00000 1.60900 1.60900 13.20000 0.42700 0.57700 6.40000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
9.740 2228.00000 21.5000 -44.53125 0.00000 1.60900 1.60900 13.20000 0.42700 0.57700 6.40000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
9.750 2228.00000 21.5000 -44.53125 0.00000 1.60900 1.60900 13.20000 0.42700 0.57700 6.40000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
9.760 2228.00000 21.5000 -44.53125 0.00000 1.60900 1.60900 13.20000 0.42700 0.57700 6.40000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
9.770 2228.00000 21.5000 -44.53125 0.00000 1.60900 1.60900 13.20000 0.42700 0.57700 6.40000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
9.780 2206.00000 21.5000 -44.53125 0.00000 1.69000 1.69000 13.20000 0.42700 0.57700 6.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
9.790 2206.00000 21.5000 -44.53125 0.00000 1.69000 1.69000 13.20000 0.42700 0.57700 6.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
9.800 2206.00000 21.5000 -44.53125 0.00000 1.69000 1.69000 13.20000 0.42700 0.57700 6.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
9.810 2206.00000 21.5000 -44.53125 0.00000 1.69000 1.69000 13.20000 0.42700 0.57700 6.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
9.820 2206.00000 21.5000 -44.53125 0.00000 1.69000 1.69000 13.20000 0.42700 0.57700 6.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
9.830 2225.00000 21.0000 -44.53125 0.00000 1.60900 1.60900 13.10000 0.42700 0.57700 5.90000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
9.840 2225.00000 21.0000 -44.53125 0.00000 1.60900 1.60900 13.10000 0.42700 0.57700 5.90000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
9.850 2225.00000 21.0000 -44.53125 0.00000 1.60900 1.60900 13.10000 0.42700 0.57700 5.90000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
9.860 2225.00000 21.0000 -44.53125 0.00000 1.60900 1.60900 13.10000 0.42700 0.57700 5.90000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
9.870 2225.00000 21.0000 -44.53125 0.00000 1.60900 1.60900 13.10000 0.42700 0.57700 5.90000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
9.880 2204.00000 20.9000 -44.53125 0.00000 1.53900 1.53900 13.30000 1.06900 0.44000 5.80000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
9.890 2204.00000 20.9000 -44.53125 0.00000 1.53900 1.53900 13.30000 1.06900 0.44000 5.80000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
9.900 2204.00000 20.9000 -44.53125 0.00000 1.53900 1.53900 13.30000 1.06900 0.44000 5.80000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
9.910 2204.00000 20.9000 -44.53125 0.00000 1.53900 1.53900 13.30000 1.06900 0.44000 5.80000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
9.920 2204.00000 20.9000 -44.53125 0.00000 1.53900 1.53900 13.30000 1.06900 0.44000 5.80000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
9.930 2249.00000 21.2000 -44.53125 0.00000 1.62000 1.62000 12.80000 1.06900 0.44000 5.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
9.940 2249.00000 21.2000 -44.53125 0.00000 1.62000 1.62000 12.80000 1.06900 0.44000 5.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
9.950 2249.00000 21.2000 -44.53125 0.00000 1.62000 1.62000 12.80000 1.06900 0.44000 5.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
9.960 2249.00000 21.2000 -44.53125 0.00000 1.62000 1.62000 12.80000 1.06900 0.44000 5.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
9.970 2249.00000 21.2000 -44.53125 0.00000 1.62000 1.62000 12.80000 1.06900 0.44000 5.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
9.980 2242.00000 21.2000 -44.53125 0.00000 1.67300 1.67300 13.10000 1.06900 0.44000 5.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
9.990 2242.00000 21.2000 -44.53125 0.00000 1.67300 1.67300 13.10000 1.06900 0.44000 5.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
10.000 2242.00000 21.2000 -44.53125 0.00000 1.67300 1.67300 13.10000 1.06900 0.44000 5.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
10.010 2242.00000 21.2000 -44.53125 0.00000 1.67300 1.67300 13.10000 1.06900 0.44000 5.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
10.020 2242.00000 21.2000 -44.53125 0.00000 1.67300 1.67300 13.10000 1.06900 0.44000 5.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
10.030 2253.00000 20.9000 -44.53125 0.00000 1.63200 1.63200 13.50000 1.06900 0.44000 5.80000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
10.040 2253.00000 20.9000 -44.53125 0.00000 1.63200 1.63200 13.50000 1.06900 0.44000 5.80000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
10.050 2253.00000 20.9000 -44.53125 0.00000 1.63200 1.63200 13.50000 1.06900 0.44000 5.80000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
10.060 2253.00000 20.9000 -44.53125 0.00000 1.63200 1.63200 13.50000 1.06900 0.44000 5.80000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
10.070 2253.00000 20.9000 -44.53125 0.00000 1.63200 1.63200 13.50000 1.06900 0.44000 5.80000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
10.080 2254.00000 21.0000 -44.53125 0.00000 1.64400 1.64400 13.00000 0.84500 0.42100 5.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
10.090 2254.00000 21.0000 -44.53125 0.00000 1.64400 1.64400 13.00000 0.84500 0.42100 5.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
10.100 2254.00000 21.0000 -44.53125 0.00000 1.64400 1.64400 13.00000 0.84500 0.42100 5.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
10.110 2254.00000 21.0000 -44.53125 0.00000 1.64400 1.64400 13.00000 0.84500 0.42100 5.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
10.120 2254.00000 21.0000 -44.53125 0.00000 1.64400 1.64400 13.00000 0.84500 0.42100 5.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
10.130 2268.00000 21.2000 -44.53125 0.00000 1.63800 1.63800 13.30000 0.84500 0.42100 5.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
10.140 2268.00000 21.2000 -44.53125 0.00000 1.63800 1.63800 13.30000 0.84500 0.42100 5.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
10.150 2268.00000 21.2000 -44.53125 0.00000 1.63800 1.63800 13.30000 0.84500 0.42100 5.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
10.160 2268.00000 21.2000 -44.53125 0.00000 1.63800 1.63800 13.30000 0.84500 0.42100 5.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
10.170 2268.00000 21.2000 -44.53125 0.00000 1.63800 1.63800 13.30000 0.84500 0.42100 5.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
10.180 2280.00000 21.0000 -44.53125 0.00000 1.63200 1.63200 13.10000 0.84500 0.42100 5.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
10.190 2280.00000 21.0000 -44.53125 0.00000 1.63200 1.63200 13.10000 0.84500 0.42100 5.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
10.200 2280.00000 21.0000 -44.53125 0.00000 1.63200 1.63200 13.10000 0.84500 0.42100 5.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
10.210 2280.00000 21.0000 -44.53125 0.00000 1.63200 1.63200 13.10000 0.84500 0.42100 5.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
10.220 2280.00000 21.0000 -44.53125 0.00000 1.63200 1.63200 13.10000 0.84500 0.42100 5.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
10.230 2219.00000 21.0000 -44.53125 0.00000 1.61400 1.61400 13.40000 0.84500 0.42100 5.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
10.240 2219.00000 21.0000 -44.53125 0.00000 1.61400 1.61400 13.40000 0.84500 0.42100 5.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
10.250 2219.00000 21.0000 -44.53125 0.00000 1.61400 1.61400 13.40000 0.84500 0.42100 5.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
10.260 2219.00000 21.0000 -44.53125 0.00000 1.61400 1.61400 13.40000 0.84500 0.42100 5.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
10.270 2219.00000 21.0000 -44.53125 0.00000 1.61400 1.61400 13.40000 0.84500 0.42100 5.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
10.280 2243.00000 21.0000 -44.53125 0.00000 1.62000 1.62000 12.60000 0.33800 0.53600 5.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
10.290 2243.00000 21.0000 -44.53125 0.00000 1.62000 1.62000 12.60000 0.33800 0.53600 5.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
10.300 2243.00000 21.0000 -44.53125 0.00000 1.62000 1.62000 12.60000 0.33800 0.53600 5.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
10.310 2243.00000 21.0000 -44.53125 0.00000 1.62000 1.62000 12.60000 0.33800 0.53600 5.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
10.320 2243.00000 21.0000 -44.53125 0.00000 1.62000 1.62000 12.60000 0.33800 0.53600 5.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
10.330 2315.00000 21.3000 -44.53125 0.00000 1.66100 1.66100 13.20000 0.33800 0.53600 5.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
10.340 2315.00000 21.3000 -44.53125 0.00000 1.66100 1.66100 13.20000 0.33800 0.53600 5.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
10.350 2315.00000 21.3000 -44.53125 0.00000 1.66100 1.66100 13.20000 0.33800 0.53600 5.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
10.360 2315.00000 21.3000 -44.53125 0.00000 1.66100 1.66100 13.20000 0.33800 0.53600 5.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
10.370 2315.00000 21.3000 -44.53125 0.00000 1.66100 1.66100 13.20000 0.33800 0.53600 5.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
10.380 2252.00000 21.0000 -44.53125 0.00000 1.64400 1.64400 13.60000 0.33800 0.53600 5.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
10.390 2252.00000 21.0000 -44.53125 0.00000 1.64400 1.64400 13.60000 0.33800 0.53600 5.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
10.400 2252.00000 21.0000 -44.53125 0.00000 1.64400 1.64400 13.60000 0.33800 0.53600 5.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
10.410 2252.00000 21.0000 -44.53125 0.00000 1.64400 1.64400 13.60000 0.33800 0.53600 5.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
10.420 2252.00000 21.0000 -44.53125 0.00000 1.64400 1.64400 13.60000 0.33800 0.53600 5.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
10.430 2246.00000 21.2000 -44.53125 0.00000 1.65500 1.65500 13.20000 0.33800 0.53600 5.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
10.440 2246.00000 21.2000 -44.53125 0.00000 1.65500 1.65500 13.20000 0.33800 0.53600 5.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
10.450 2246.00000 21.2000 -44.53125 0.00000 1.65500 1.65500 13.20000 0.33800 0.53600 5.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
10.460 2246.00000 21.2000 -44.53125 0.00000 1.65500 1.65500 13.20000 0.33800 0.53600 5.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
10.470 2246.00000 21.2000 -44.53125 0.00000 1.65500 1.65500 13.20000 0.33800 0.53600 5.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
10.480 2319.00000 21.3000 -44.53125 0.00000 1.63200 1.63200 13.40000 0.34100 0.47200 5.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
10.490 2319.00000 21.3000 -44.53125 0.00000 1.63200 1.63200 13.40000 0.34100 0.47200 5.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
10.500 2319.00000 21.3000 -44.53125 0.00000 1.63200 1.63200 13.40000 0.34100 0.47200 5.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
10.510 2319.00000 21.3000 -44.53125 0.00000 1.63200 1.63200 13.40000 0.34100 0.47200 5.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
10.520 2319.00000 21.3000 -44.53125 0.00000 1.63200 1.63200 13.40000 0.34100 0.47200 5.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
10.530 2270.00000 21.3000 -44.53125 0.00000 1.66100 1.66100 13.20000 0.34100 0.47200 5.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
10.540 2270.00000 21.3000 -44.53125 0.00000 1.66100 1.66100 13.20000 0.34100 0.47200 5.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
10.550 2270.00000 21.3000 -44.53125 0.00000 1.66100 1.66100 13.20000 0.34100 0.47200 5.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
10.560 2270.00000 21.3000 -44.53125 0.00000 1.66100 1.66100 13.20000 0.34100 0.47200 5.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
10.570 2270.00000 21.3000 -44.53125 0.00000 1.66100 1.66100 13.20000 0.34100 0.47200 5.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
10.580 2249.00000 21.3000 -44.53125 0.00000 1.68400 1.68400 12.90000 0.34100 0.47200 5.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
10.590 2249.00000 21.3000 -44.53125 0.00000 1.68400 1.68400 12.90000 0.34100 0.47200 5.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
10.600 2249.00000 21.3000 -44.53125 0.00000 1.68400 1.68400 12.90000 0.34100 0.47200 5.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
10.610 2249.00000 21.3000 -44.53125 0.00000 1.68400 1.68400 12.90000 0.34100 0.47200 5.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
10.620 2249.00000 21.3000 -44.53125 0.00000 1.68400 1.68400 12.90000 0.34100 0.47200 5.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
10.630 2299.00000 21.3000 -44.53125 0.00000 1.67300 1.67300 12.90000 0.34100 0.47200 5.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
10.640 2299.00000 21.3000 -44.53125 0.00000 1.67300 1.67300 12.90000 0.34100 0.47200 5.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
10.650 2299.00000 21.3000 -44.53125 0.00000 1.67300 1.67300 12.90000 0.34100 0.47200 5.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
10.660 2299.00000 21.3000 -44.53125 0.00000 1.67300 1.67300 12.90000 0.34100 0.47200 5.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
10.670 2299.00000 21.3000 -44.53125 0.00000 1.67300 1.67300 12.90000 0.34100 0.47200 5.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
10.680 2275.00000 21.5000 -44.53125 0.00000 1.66100 1.66100 13.40000 0.33800 0.35100 5.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
10.690 2275.00000 21.5000 -44.53125 0.00000 1.66100 1.66100 13.40000 0.33800 0.35100 5.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
10.700 2275.00000 21.5000 -44.53125 0.00000 1.66100 1.66100 13.40000 0.33800 0.35100 5.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
10.710 2275.00000 21.5000 -44.53125 0.00000 1.66100 1.66100 13.40000 0.33800 0.35100 5.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
10.720 2275.00000 21.5000 -44.53125 0.00000 1.66100 1.66100 13.40000 0.33800 0.35100 5.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
10.730 2257.00000 21.3000 -44.53125 0.00000 1.67800 1.67800 13.40000 0.33800 0.35100 5.50000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
10.740 2257.00000 21.3000 -44.53125 0.00000 1.67800 1.67800 13.40000 0.33800 0.35100 5.50000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
10.750 2257.00000 21.3000 -44.53125 0.00000 1.67800 1.67800 13.40000 0.33800 0.35100 5.50000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
10.760 2257.00000 21.3000 -44.53125 0.00000 1.67800 1.67800 13.40000 0.33800 0.35100 5.50000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
10.770 2257.00000 21.3000 -44.53125 0.00000 1.67800 1.67800 13.40000 0.33800 0.35100 5.50000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
10.780 2306.00000 21.5000 -44.53125 0.00000 1.71300 1.71300 13.30000 0.33800 0.35100 5.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
10.790 2306.00000 21.5000 -44.53125 0.00000 1.71300 1.71300 13.30000 0.33800 0.35100 5.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
10.800 2306.00000 21.5000 -44.53125 0.00000 1.71300 1.71300 13.30000 0.33800 0.35100 5.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
10.810 2306.00000 21.5000 -44.53125 0.00000 1.71300 1.71300 13.30000 0.33800 0.35100 5.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
10.820 2306.00000 21.5000 -44.53125 0.00000 1.71300 1.71300 13.30000 0.33800 0.35100 5.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
10.830 2284.00000 21.5000 -44.53125 0.00000 1.67800 1.67800 13.20000 0.33800 0.35100 5.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
10.840 2284.00000 21.5000 -44.53125 0.00000 1.67800 1.67800 13.20000 0.33800 0.35100 5.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
10.850 2284.00000 21.5000 -44.53125 0.00000 1.67800 1.67800 13.20000 0.33800 0.35100 5.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
10.860 2284.00000 21.5000 -44.53125 0.00000 1.67800 1.67800 13.20000 0.33800 0.35100 5.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
10.870 2284.00000 21.5000 -44.53125 0.00000 1.67800 1.67800 13.20000 0.33800 0.35100 5.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
10.880 2287.00000 21.5000 -44.53125 0.00000 1.65500 1.65500 13.20000 0.47800 0.34400 5.90000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
10.890 2287.00000 21.5000 -44.53125 0.00000 1.65500 1.65500 13.20000 0.47800 0.34400 5.90000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
10.900 2287.00000 21.5000 -44.53125 0.00000 1.65500 1.65500 13.20000 0.47800 0.34400 5.90000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
10.910 2287.00000 21.5000 -44.53125 0.00000 1.65500 1.65500 13.20000 0.47800 0.34400 5.90000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
10.920 2287.00000 21.5000 -44.53125 0.00000 1.65500 1.65500 13.20000 0.47800 0.34400 5.90000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
10.930 2277.00000 21.5000 -44.53125 0.00000 1.70800 1.70800 13.30000 0.47800 0.34400 6.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
10.940 2277.00000 21.5000 -44.53125 0.00000 1.70800 1.70800 13.30000 0.47800 0.34400 6.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
10.950 2277.00000 21.5000 -44.53125 0.00000 1.70800 1.70800 13.30000 0.47800 0.34400 6.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
10.960 2277.00000 21.5000 -44.53125 0.00000 1.70800 1.70800 13.30000 0.47800 0.34400 6.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
10.970 2277.00000 21.5000 -44.53125 0.00000 1.70800 1.70800 13.30000 0.47800 0.34400 6.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
10.980 2288.00000 21.3000 -44.53125 0.00000 1.66700 1.66700 13.30000 0.47800 0.34400 6.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
10.990 2288.00000 21.3000 -44.53125 0.00000 1.66700 1.66700 13.30000 0.47800 0.34400 6.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
11.000 2288.00000 21.3000 -44.53125 0.00000 1.66700 1.66700 13.30000 0.47800 0.34400 6.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
11.010 2288.00000 21.3000 -44.53125 0.00000 1.66700 1.66700 13.30000 0.47800 0.34400 6.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
11.020 2288.00000 21.3000 -44.53125 0.00000 1.66700 1.66700 13.30000 0.47800 0.34400 6.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
11.030 2284.00000 21.5000 -44.53125 0.00000 1.69600 1.69600 13.00000 0.47800 0.34400 6.10000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
11.040 2284.00000 21.5000 -44.53125 0.00000 1.69600 1.69600 13.00000 0.47800 0.34400 6.10000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
11.050 2284.00000 21.5000 -44.53125 0.00000 1.69600 1.69600 13.00000 0.47800 0.34400 6.10000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
11.060 2284.00000 21.5000 -44.53125 0.00000 1.69600 1.69600 13.00000 0.47800 0.34400 6.10000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
11.070 2284.00000 21.5000 -44.53125 0.00000 1.69600 1.69600 13.00000 0.47800 0.34400 6.10000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
11.080 2284.00000 21.5000 -44.53125 0.00000 1.69600 1.69600 13.00000 0.47800 0.34400 6.10000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
11.090 2321.00000 21.5000 -44.53125 0.00000 1.67300 1.67300 13.00000 0.95100 0.36300 6.10000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
11.100 2321.00000 21.5000 -44.53125 0.00000 1.67300 1.67300 13.00000 0.95100 0.36300 6.10000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
11.110 2321.00000 21.5000 -44.53125 0.00000 1.67300 1.67300 13.00000 0.95100 0.36300 6.10000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
11.120 2321.00000 21.5000 -44.53125 0.00000 1.67300 1.67300 13.00000 0.95100 0.36300 6.10000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
11.130 2321.00000 21.5000 -44.53125 0.00000 1.67300 1.67300 13.00000 0.95100 0.36300 6.10000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
11.140 2277.00000 21.3000 -44.53125 0.00000 1.67300 1.67300 13.60000 0.95100 0.36300 6.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
11.150 2277.00000 21.3000 -44.53125 0.00000 1.67300 1.67300 13.60000 0.95100 0.36300 6.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
11.160 2277.00000 21.3000 -44.53125 0.00000 1.67300 1.67300 13.60000 0.95100 0.36300 6.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
11.170 2277.00000 21.3000 -44.53125 0.00000 1.67300 1.67300 13.60000 0.95100 0.36300 6.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
11.180 2277.00000 21.3000 -44.53125 0.00000 1.67300 1.67300 13.60000 0.95100 0.36300 6.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
11.190 2277.00000 21.3000 -44.53125 0.00000 1.67300 1.67300 13.60000 0.95100 0.36300 6.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
11.200 2324.00000 21.3000 -44.53125 0.00000 1.70200 1.70200 12.40000 0.95100 0.36300 6.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
11.210 2324.00000 21.3000 -44.53125 0.00000 1.70200 1.70200 12.40000 0.95100 0.36300 6.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
11.220 2324.00000 21.3000 -44.53125 0.00000 1.70200 1.70200 12.40000 0.95100 0.36300 6.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
11.230 2324.00000 21.3000 -44.53125 0.00000 1.70200 1.70200 12.40000 0.95100 0.36300 6.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
11.240 2324.00000 21.3000 -44.53125 0.00000 1.70200 1.70200 12.40000 0.95100 0.36300 6.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
11.250 2324.00000 21.3000 -44.53125 0.00000 1.70200 1.70200 12.40000 0.95100 0.36300 6.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
11.260 2324.00000 21.3000 -44.53125 0.00000 1.70200 1.70200 12.40000 0.95100 0.36300 6.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
11.270 2324.00000 21.3000 -44.53125 0.00000 1.70200 1.70200 12.40000 0.95100 0.36300 6.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
11.280 2324.00000 21.3000 -44.53125 0.00000 1.70200 1.70200 12.40000 0.95100 0.36300 6.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
11.290 2324.00000 21.3000 -44.53125 0.00000 1.70200 1.70200 12.40000 0.95100 0.36300 6.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
11.300 2282.00000 21.8000 -44.53125 0.00000 1.73700 1.73700 12.90000 1.05300 0.36700 6.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
11.310 2282.00000 21.8000 -44.53125 0.00000 1.73700 1.73700 12.90000 1.05300 0.36700 6.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
11.320 2282.00000 21.8000 -44.53125 0.00000 1.73700 1.73700 12.90000 1.05300 0.36700 6.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
11.330 2282.00000 21.8000 -44.53125 0.00000 1.73700 1.73700 12.90000 1.05300 0.36700 6.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
11.340 2282.00000 21.8000 -44.53125 0.00000 1.73700 1.73700 12.90000 1.05300 0.36700 6.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
11.350 2305.00000 22.1000 -44.53125 0.00000 1.67300 1.67300 12.40000 1.05300 0.36700 6.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
11.360 2305.00000 22.1000 -44.53125 0.00000 1.67300 1.67300 12.40000 1.05300 0.36700 6.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
11.370 2305.00000 22.1000 -44.53125 0.00000 1.67300 1.67300 12.40000 1.05300 0.36700 6.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
11.380 2305.00000 22.1000 -44.53125 0.00000 1.67300 1.67300 12.40000 1.05300 0.36700 6.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
11.390 2305.00000 22.1000 -44.53125 0.00000 1.67300 1.67300 12.40000 1.05300 0.36700 6.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
11.400 2308.00000 22.0000 -44.53125 0.00000 1.73100 1.73100 11.80000 1.05300 0.36700 6.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
11.410 2308.00000 22.0000 -44.53125 0.00000 1.73100 1.73100 11.80000 1.05300 0.36700 6.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
11.420 2308.00000 22.0000 -44.53125 0.00000 1.73100 1.73100 11.80000 1.05300 0.36700 6.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
11.430 2308.00000 22.0000 -44.53125 0.00000 1.73100 1.73100 11.80000 1.05300 0.36700 6.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
11.440 2308.00000 22.0000 -44.53125 0.00000 1.73100 1.73100 11.80000 1.05300 0.36700 6.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
11.450 2287.00000 21.5000 -44.53125 0.00000 1.64900 1.64900 13.00000 1.05300 0.36700 5.90000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
11.460 2287.00000 21.5000 -44.53125 0.00000 1.64900 1.64900 13.00000 1.05300 0.36700 5.90000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
11.470 2287.00000 21.5000 -44.53125 0.00000 1.64900 1.64900 13.00000 1.05300 0.36700 5.90000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
11.480 2287.00000 21.5000 -44.53125 0.00000 1.64900 1.64900 13.00000 1.05300 0.36700 5.90000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
11.490 2287.00000 21.5000 -44.53125 0.00000 1.64900 1.64900 13.00000 1.05300 0.36700 5.90000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
11.500 2300.00000 21.5000 -44.53125 0.00000 1.64400 1.64400 12.60000 0.96700 0.40500 6.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
11.510 2300.00000 21.5000 -44.53125 0.00000 1.64400 1.64400 12.60000 0.96700 0.40500 6.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
11.520 2300.00000 21.5000 -44.53125 0.00000 1.64400 1.64400 12.60000 0.96700 0.40500 6.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
11.530 2300.00000 21.5000 -44.53125 0.00000 1.64400 1.64400 12.60000 0.96700 0.40500 6.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
11.540 2300.00000 21.5000 -44.53125 0.00000 1.64400 1.64400 12.60000 0.96700 0.40500 6.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
11.550 2350.00000 22.0000 -44.53125 0.00000 1.67800 1.67800 13.60000 0.96700 0.40500 6.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
11.560 2350.00000 22.0000 -44.53125 0.00000 1.67800 1.67800 13.60000 0.96700 0.40500 6.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
11.570 2350.00000 22.0000 -44.53125 0.00000 1.67800 1.67800 13.60000 0.96700 0.40500 6.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
11.580 2350.00000 22.0000 -44.53125 0.00000 1.67800 1.67800 13.60000 0.96700 0.40500 6.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
11.590 2350.00000 22.0000 -44.53125 0.00000 1.67800 1.67800 13.60000 0.96700 0.40500 6.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
11.600 2285.00000 22.0000 -44.53125 0.00000 1.72500 1.72500 13.10000 0.96700 0.40500 5.90000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
11.610 2285.00000 22.0000 -44.53125 0.00000 1.72500 1.72500 13.10000 0.96700 0.40500 5.90000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
11.620 2285.00000 22.0000 -44.53125 0.00000 1.72500 1.72500 13.10000 0.96700 0.40500 5.90000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
11.630 2285.00000 22.0000 -44.53125 0.00000 1.72500 1.72500 13.10000 0.96700 0.40500 5.90000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
11.640 2285.00000 22.0000 -44.53125 0.00000 1.72500 1.72500 13.10000 0.96700 0.40500 5.90000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
11.650 2276.00000 22.1000 -44.53125 0.00000 1.71900 1.71900 13.00000 0.96700 0.40500 6.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
11.660 2276.00000 22.1000 -44.53125 0.00000 1.71900 1.71900 13.00000 0.96700 0.40500 6.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
11.670 2276.00000 22.1000 -44.53125 0.00000 1.71900 1.71900 13.00000 0.96700 0.40500 6.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
11.680 2276.00000 22.1000 -44.53125 0.00000 1.71900 1.71900 13.00000 0.96700 0.40500 6.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
11.690 2276.00000 22.1000 -44.53125 0.00000 1.71900 1.71900 13.00000 0.96700 0.40500 6.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
11.700 2348.00000 22.1000 -44.53125 0.00000 1.71300 1.71300 13.00000 0.90900 0.47200 5.90000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
11.710 2348.00000 22.1000 -44.53125 0.00000 1.71300 1.71300 13.00000 0.90900 0.47200 5.90000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
11.720 2348.00000 22.1000 -44.53125 0.00000 1.71300 1.71300 13.00000 0.90900 0.47200 5.90000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
11.730 2348.00000 22.1000 -44.53125 0.00000 1.71300 1.71300 13.00000 0.90900 0.47200 5.90000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
11.740 2348.00000 22.1000 -44.53125 0.00000 1.71300 1.71300 13.00000 0.90900 0.47200 5.90000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
11.750 2289.00000 22.0000 -44.53125 0.00000 1.74300 1.74300 12.90000 0.90900 0.47200 5.90000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
11.760 2289.00000 22.0000 -44.53125 0.00000 1.74300 1.74300 12.90000 0.90900 0.47200 5.90000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
11.770 2289.00000 22.0000 -44.53125 0.00000 1.74300 1.74300 12.90000 0.90900 0.47200 5.90000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
11.780 2289.00000 22.0000 -44.53125 0.00000 1.74300 1.74300 12.90000 0.90900 0.47200 5.90000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
11.790 2289.00000 22.0000 -44.53125 0.00000 1.74300 1.74300 12.90000 0.90900 0.47200 5.90000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
11.800 2278.00000 22.0000 -44.53125 0.00000 1.73100 1.73100 13.20000 0.90900 0.47200 6.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
11.810 2278.00000 22.0000 -44.53125 0.00000 1.73100 1.73100 13.20000 0.90900 0.47200 6.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
11.820 2278.00000 22.0000 -44.53125 0.00000 1.73100 1.73100 13.20000 0.90900 0.47200 6.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
11.830 2278.00000 22.0000 -44.53125 0.00000 1.73100 1.73100 13.20000 0.90900 0.47200 6.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
11.840 2278.00000 22.0000 -44.53125 0.00000 1.73100 1.73100 13.20000 0.90900 0.47200 6.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
11.850 2343.00000 22.0000 -44.53125 0.00000 1.73700 1.73700 13.20000 0.90900 0.47200 6.40000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
11.860 2343.00000 22.0000 -44.53125 0.00000 1.73700 1.73700 13.20000 0.90900 0.47200 6.40000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
11.870 2343.00000 22.0000 -44.53125 0.00000 1.73700 1.73700 13.20000 0.90900 0.47200 6.40000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
11.880 2343.00000 22.0000 -44.53125 0.00000 1.73700 1.73700 13.20000 0.90900 0.47200 6.40000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
11.890 2343.00000 22.0000 -44.53125 0.00000 1.73700 1.73700 13.20000 0.90900 0.47200 6.40000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
11.900 2343.00000 22.0000 -44.53125 0.00000 1.73700 1.73700 13.20000 0.90900 0.47200 6.40000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
11.910 2295.00000 22.0000 -44.53125 0.00000 1.73700 1.73700 13.00000 0.32200 0.49400 6.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
11.920 2295.00000 22.0000 -44.53125 0.00000 1.73700 1.73700 13.00000 0.32200 0.49400 6.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
11.930 2295.00000 22.0000 -44.53125 0.00000 1.73700 1.73700 13.00000 0.32200 0.49400 6.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
11.940 2295.00000 22.0000 -44.53125 0.00000 1.73700 1.73700 13.00000 0.32200 0.49400 6.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
11.950 2295.00000 22.0000 -44.53125 0.00000 1.73700 1.73700 13.00000 0.32200 0.49400 6.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
11.960 2275.00000 22.0000 -44.53125 0.00000 1.69600 1.69600 12.70000 0.32200 0.49400 6.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
11.970 2275.00000 22.0000 -44.53125 0.00000 1.69600 1.69600 12.70000 0.32200 0.49400 6.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
11.980 2275.00000 22.0000 -44.53125 0.00000 1.69600 1.69600 12.70000 0.32200 0.49400 6.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
11.990 2275.00000 22.0000 -44.53125 0.00000 1.69600 1.69600 12.70000 0.32200 0.49400 6.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
12.000 2275.00000 22.0000 -44.53125 0.00000 1.69600 1.69600 12.70000 0.32200 0.49400 6.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
12.010 2334.00000 21.8000 -44.53125 0.00000 1.70200 1.70200 13.40000 0.32200 0.49400 6.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
12.020 2334.00000 21.8000 -44.53125 0.00000 1.70200 1.70200 13.40000 0.32200 0.49400 6.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
12.030 2334.00000 21.8000 -44.53125 0.00000 1.70200 1.70200 13.40000 0.32200 0.49400 6.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
12.040 2334.00000 21.8000 -44.53125 0.00000 1.70200 1.70200 13.40000 0.32200 0.49400 6.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
12.050 2334.00000 21.8000 -44.53125 0.00000 1.70200 1.70200 13.40000 0.32200 0.49400 6.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
12.060 2307.00000 22.0000 -44.53125 0.00000 1.74800 1.74800 12.90000 0.33800 0.36000 6.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
12.070 2307.00000 22.0000 -44.53125 0.00000 1.74800 1.74800 12.90000 0.33800 0.36000 6.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
12.080 2307.00000 22.0000 -44.53125 0.00000 1.74800 1.74800 12.90000 0.33800 0.36000 6.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
12.090 2307.00000 22.0000 -44.53125 0.00000 1.74800 1.74800 12.90000 0.33800 0.36000 6.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
12.100 2307.00000 22.0000 -44.53125 0.00000 1.74800 1.74800 12.90000 0.33800 0.36000 6.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
12.110 2299.00000 22.1000 -44.53125 0.00000 1.67800 1.67800 12.60000 0.33800 0.36000 6.40000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
12.120 2299.00000 22.1000 -44.53125 0.00000 1.67800 1.67800 12.60000 0.33800 0.36000 6.40000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
12.130 2299.00000 22.1000 -44.53125 0.00000 1.67800 1.67800 12.60000 0.33800 0.36000 6.40000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
12.140 2299.00000 22.1000 -44.53125 0.00000 1.67800 1.67800 12.60000 0.33800 0.36000 6.40000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
12.150 2299.00000 22.1000 -44.53125 0.00000 1.67800 1.67800 12.60000 0.33800 0.36000 6.40000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
12.160 2280.00000 22.1000 -44.53125 0.00000 1.76000 1.76000 12.20000 0.33800 0.36000 6.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
12.170 2280.00000 22.1000 -44.53125 0.00000 1.76000 1.76000 12.20000 0.33800 0.36000 6.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
12.180 2280.00000 22.1000 -44.53125 0.00000 1.76000 1.76000 12.20000 0.33800 0.36000 6.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
12.190 2280.00000 22.1000 -44.53125 0.00000 1.76000 1.76000 12.20000 0.33800 0.36000 6.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
12.200 2280.00000 22.1000 -44.53125 0.00000 1.76000 1.76000 12.20000 0.33800 0.36000 6.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
12.210 2311.00000 22.0000 -44.53125 0.00000 1.70800 1.70800 13.60000 0.33800 0.36000 6.10000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
12.220 2311.00000 22.0000 -44.53125 0.00000 1.70800 1.70800 13.60000 0.33800 0.36000 6.10000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
12.230 2311.00000 22.0000 -44.53125 0.00000 1.70800 1.70800 13.60000 0.33800 0.36000 6.10000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
12.240 2311.00000 22.0000 -44.53125 0.00000 1.70800 1.70800 13.60000 0.33800 0.36000 6.10000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
12.250 2311.00000 22.0000 -44.53125 0.00000 1.70800 1.70800 13.60000 0.33800 0.36000 6.10000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
12.260 2314.00000 22.3000 -44.53125 0.00000 1.74800 1.74800 13.20000 0.37600 0.35100 6.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
12.270 2314.00000 22.3000 -44.53125 0.00000 1.74800 1.74800 13.20000 0.37600 0.35100 6.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
12.280 2314.00000 22.3000 -44.53125 0.00000 1.74800 1.74800 13.20000 0.37600 0.35100 6.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
12.290 2314.00000 22.3000 -44.53125 0.00000 1.74800 1.74800 13.20000 0.37600 0.35100 6.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
12.300 2314.00000 22.3000 -44.53125 0.00000 1.74800 1.74800 13.20000 0.37600 0.35100 6.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
12.310 2347.00000 22.4000 -44.53125 0.00000 1.76600 1.76600 13.50000 0.37600 0.35100 6.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
12.320 2347.00000 22.4000 -44.53125 0.00000 1.76600 1.76600 13.50000 0.37600 0.35100 6.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
12.330 2347.00000 22.4000 -44.53125 0.00000 1.76600 1.76600 13.50000 0.37600 0.35100 6.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
12.340 2347.00000 22.4000 -44.53125 0.00000 1.76600 1.76600 13.50000 0.37600 0.35100 6.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
12.350 2347.00000 22.4000 -44.53125 0.00000 1.76600 1.76600 13.50000 0.37600 0.35100 6.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
12.360 2297.00000 22.3000 -44.53125 0.00000 1.75400 1.75400 13.00000 0.37600 0.35100 6.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
12.370 2297.00000 22.3000 -44.53125 0.00000 1.75400 1.75400 13.00000 0.37600 0.35100 6.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
12.380 2297.00000 22.3000 -44.53125 0.00000 1.75400 1.75400 13.00000 0.37600 0.35100 6.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
12.390 2297.00000 22.3000 -44.53125 0.00000 1.75400 1.75400 13.00000 0.37600 0.35100 6.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
12.400 2297.00000 22.3000 -44.53125 0.00000 1.75400 1.75400 13.00000 0.37600 0.35100 6.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
12.410 2320.00000 22.4000 -44.53125 0.00000 1.78300 1.78300 13.40000 0.37600 0.35100 6.10000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
12.420 2320.00000 22.4000 -44.53125 0.00000 1.78300 1.78300 13.40000 0.37600 0.35100 6.10000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
12.430 2320.00000 22.4000 -44.53125 0.00000 1.78300 1.78300 13.40000 0.37600 0.35100 6.10000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
12.440 2320.00000 22.4000 -44.53125 0.00000 1.78300 1.78300 13.40000 0.37600 0.35100 6.10000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
12.450 2320.00000 22.4000 -44.53125 0.00000 1.78300 1.78300 13.40000 0.37600 0.35100 6.10000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
12.460 2361.00000 22.6000 -44.53125 0.00000 1.78300 1.78300 13.50000 0.57400 0.34700 6.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
12.470 2361.00000 22.6000 -44.53125 0.00000 1.78300 1.78300 13.50000 0.57400 0.34700 6.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
12.480 2361.00000 22.6000 -44.53125 0.00000 1.78300 1.78300 13.50000 0.57400 0.34700 6.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
12.490 2361.00000 22.6000 -44.53125 0.00000 1.78300 1.78300 13.50000 0.57400 0.34700 6.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
12.500 2361.00000 22.6000 -44.53125 0.00000 1.78300 1.78300 13.50000 0.57400 0.34700 6.60000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
12.510 2308.00000 23.0000 -44.53125 0.00000 1.84200 1.84200 12.80000 0.57400 0.34700 6.90000 1.00000 4.00000 4.00000 4.00000 5.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
12.520 2308.00000 23.0000 -44.53125 0.00000 1.84200 1.84200 12.80000 0.57400 0.34700 6.90000 1.00000 4.00000 4.00000 4.00000 5.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
12.530 2308.00000 23.0000 -44.53125 0.00000 1.84200 1.84200 12.80000 0.57400 0.34700 6.90000 1.00000 4.00000 4.00000 4.00000 5.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
12.540 2308.00000 23.0000 -44.53125 0.00000 1.84200 1.84200 12.80000 0.57400 0.34700 6.90000 1.00000 4.00000 4.00000 4.00000 5.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
12.550 2308.00000 23.0000 -44.53125 0.00000 1.84200 1.84200 12.80000 0.57400 0.34700 6.90000 1.00000 4.00000 4.00000 4.00000 5.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
12.560 2318.00000 23.3000 -44.53125 0.00000 1.85900 1.85900 12.30000 0.57400 0.34700 6.90000 1.00000 4.00000 4.00000 4.00000 5.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
12.570 2318.00000 23.3000 -44.53125 0.00000 1.85900 1.85900 12.30000 0.57400 0.34700 6.90000 1.00000 4.00000 4.00000 4.00000 5.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
12.580 2318.00000 23.3000 -44.53125 0.00000 1.85900 1.85900 12.30000 0.57400 0.34700 6.90000 1.00000 4.00000 4.00000 4.00000 5.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
12.590 2318.00000 23.3000 -44.53125 0.00000 1.85900 1.85900 12.30000 0.57400 0.34700 6.90000 1.00000 4.00000 4.00000 4.00000 5.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
12.600 2318.00000 23.3000 -44.53125 0.00000 1.85900 1.85900 12.30000 0.57400 0.34700 6.90000 1.00000 4.00000 4.00000 4.00000 5.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
12.610 2324.00000 23.9000 -44.53125 0.00000 1.92300 1.92300 12.90000 0.57400 0.34700 6.90000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
12.620 2324.00000 23.9000 -44.53125 0.00000 1.92300 1.92300 12.90000 0.57400 0.34700 6.90000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
12.630 2324.00000 23.9000 -44.53125 0.00000 1.92300 1.92300 12.90000 0.57400 0.34700 6.90000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
12.640 2324.00000 23.9000 -44.53125 0.00000 1.92300 1.92300 12.90000 0.57400 0.34700 6.90000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
12.650 2324.00000 23.9000 -44.53125 0.00000 1.92300 1.92300 12.90000 0.57400 0.34700 6.90000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
12.660 2354.00000 25.2000 -44.53125 0.00000 2.04000 2.04000 13.30000 1.04000 0.36700 7.50000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
12.670 2354.00000 25.2000 -44.53125 0.00000 2.04000 2.04000 13.30000 1.04000 0.36700 7.50000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
12.680 2354.00000 25.2000 -44.53125 0.00000 2.04000 2.04000 13.30000 1.04000 0.36700 7.50000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
12.690 2354.00000 25.2000 -44.53125 0.00000 2.04000 2.04000 13.30000 1.04000 0.36700 7.50000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
12.700 2354.00000 25.2000 -44.53125 0.00000 2.04000 2.04000 13.30000 1.04000 0.36700 7.50000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
12.710 2333.00000 26.2000 -44.53125 0.00000 2.12700 2.12700 13.10000 1.04000 0.36700 7.90000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
12.720 2333.00000 26.2000 -44.53125 0.00000 2.12700 2.12700 13.10000 1.04000 0.36700 7.90000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
12.730 2333.00000 26.2000 -44.53125 0.00000 2.12700 2.12700 13.10000 1.04000 0.36700 7.90000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
12.740 2333.00000 26.2000 -44.53125 0.00000 2.12700 2.12700 13.10000 1.04000 0.36700 7.90000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
12.750 2333.00000 26.2000 -44.53125 0.00000 2.12700 2.12700 13.10000 1.04000 0.36700 7.90000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
12.760 2398.00000 27.3000 -44.53125 0.00000 2.22600 2.22600 13.00000 1.04000 0.36700 8.30000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
12.770 2398.00000 27.3000 -44.53125 0.00000 2.22600 2.22600 13.00000 1.04000 0.36700 8.30000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
12.780 2398.00000 27.3000 -44.53125 0.00000 2.22600 2.22600 13.00000 1.04000 0.36700 8.30000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
12.790 2398.00000 27.3000 -44.53125 0.00000 2.22600 2.22600 13.00000 1.04000 0.36700 8.30000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
12.800 2398.00000 27.3000 -44.53125 0.00000 2.22600 2.22600 13.00000 1.04000 0.36700 8.30000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
12.810 2332.00000 29.0000 -44.53125 0.00000 2.34900 2.34900 13.10000 1.04000 0.36700 9.40000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
12.820 2332.00000 29.0000 -44.53125 0.00000 2.34900 2.34900 13.10000 1.04000 0.36700 9.40000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
12.830 2332.00000 29.0000 -44.53125 0.00000 2.34900 2.34900 13.10000 1.04000 0.36700 9.40000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
12.840 2332.00000 29.0000 -44.53125 0.00000 2.34900 2.34900 13.10000 1.04000 0.36700 9.40000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
12.850 2332.00000 29.0000 -44.53125 0.00000 2.34900 2.34900 13.10000 1.04000 0.36700 9.40000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
12.860 2323.00000 31.7000 -44.53125 0.00000 2.44800 2.44800 13.10000 0.47200 0.40500 10.70000 1.00000 7.00000 7.00000 6.00000 2.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
12.870 2323.00000 31.7000 -44.53125 0.00000 2.44800 2.44800 13.10000 0.47200 0.40500 10.70000 1.00000 7.00000 7.00000 6.00000 2.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
12.880 2323.00000 31.7000 -44.53125 0.00000 2.44800 2.44800 13.10000 0.47200 0.40500 10.70000 1.00000 7.00000 7.00000 6.00000 2.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
12.890 2323.00000 31.7000 -44.53125 0.00000 2.44800 2.44800 13.10000 0.47200 0.40500 10.70000 1.00000 7.00000 7.00000 6.00000 2.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
12.900 2323.00000 31.7000 -44.53125 0.00000 2.44800 2.44800 13.10000 0.47200 0.40500 10.70000 1.00000 7.00000 7.00000 6.00000 2.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
12.910 2349.00000 35.9000 -44.53125 0.00000 2.71000 2.71000 12.30000 0.47200 0.40500 11.90000 1.00000 2.00000 9.00000 8.00000 2.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
12.920 2349.00000 35.9000 -44.53125 0.00000 2.71000 2.71000 12.30000 0.47200 0.40500 11.90000 1.00000 2.00000 9.00000 8.00000 2.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
12.930 2349.00000 35.9000 -44.53125 0.00000 2.71000 2.71000 12.30000 0.47200 0.40500 11.90000 1.00000 2.00000 9.00000 8.00000 2.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
12.940 2349.00000 35.9000 -44.53125 0.00000 2.71000 2.71000 12.30000 0.47200 0.40500 11.90000 1.00000 2.00000 9.00000 8.00000 2.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
12.950 2349.00000 35.9000 -44.53125 0.00000 2.71000 2.71000 12.30000 0.47200 0.40500 11.90000 1.00000 2.00000 9.00000 8.00000 2.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
12.960 2408.00000 38.2000 -44.53125 0.00000 2.73400 2.73400 12.90000 0.47200 0.40500 13.00000 1.00000 8.00000 10.00000 2.00000 2.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
12.970 2408.00000 38.2000 -44.53125 0.00000 2.73400 2.73400 12.90000 0.47200 0.40500 13.00000 1.00000 8.00000 10.00000 2.00000 2.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
12.980 2408.00000 38.2000 -44.53125 0.00000 2.73400 2.73400 12.90000 0.47200 0.40500 13.00000 1.00000 8.00000 10.00000 2.00000 2.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
12.990 2408.00000 38.2000 -44.53125 0.00000 2.73400 2.73400 12.90000 0.47200 0.40500 13.00000 1.00000 8.00000 10.00000 2.00000 2.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
13.000 2408.00000 38.2000 -44.53125 0.00000 2.73400 2.73400 12.90000 0.47200 0.40500 13.00000 1.00000 8.00000 10.00000 2.00000 2.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
13.010 2377.00000 38.5000 -44.53125 0.00000 2.60500 2.60500 13.30000 0.47200 0.40500 13.00000 1.00000 10.00000 10.00000 2.00000 10.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
13.020 2377.00000 38.5000 -44.53125 0.00000 2.60500 2.60500 13.30000 0.47200 0.40500 13.00000 1.00000 10.00000 10.00000 2.00000 10.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
13.030 2377.00000 38.5000 -44.53125 0.00000 2.60500 2.60500 13.30000 0.47200 0.40500 13.00000 1.00000 10.00000 10.00000 2.00000 10.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
13.040 2377.00000 38.5000 -44.53125 0.00000 2.60500 2.60500 13.30000 0.47200 0.40500 13.00000 1.00000 10.00000 10.00000 2.00000 10.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
13.050 2377.00000 38.5000 -44.53125 0.00000 2.60500 2.60500 13.30000 0.47200 0.40500 13.00000 1.00000 10.00000 10.00000 2.00000 10.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
13.060 2405.00000 38.8000 -44.53125 0.00000 2.60500 2.60500 13.60000 1.08200 0.37300 14.30000 1.00000 10.00000 10.00000 10.00000 10.00000 0.00000 0.00000 15.8000 0.000 0.000 0.000 0.000
13.070 2405.00000 38.8000 -44.53125 0.00000 2.60500 2.60500 13.60000 1.08200 0.37300 14.30000 1.00000 10.00000 10.00000 10.00000 10.00000 0.00000 0.00000 15.8000 0.000 0.000 0.000 0.000
13.080 2405.00000 38.8000 -44.53125 0.00000 2.60500 2.60500 13.60000 1.08200 0.37300 14.30000 1.00000 10.00000 10.00000 10.00000 10.00000 0.00000 0.00000 15.8000 0.000 0.000 0.000 0.000
13.090 2405.00000 38.8000 -44.53125 0.00000 2.60500 2.60500 13.60000 1.08200 0.37300 14.30000 1.00000 10.00000 10.00000 10.00000 10.00000 0.00000 0.00000 15.8000 0.000 0.000 0.000 0.000
13.100 2405.00000 38.8000 -44.53125 0.00000 2.60500 2.60500 13.60000 1.08200 0.37300 14.30000 1.00000 10.00000 10.00000 10.00000 10.00000 0.00000 0.00000 15.8000 0.000 0.000 0.000 0.000
13.110 2385.00000 38.8000 -44.53125 0.00000 2.59400 2.59400 12.90000 1.08200 0.37300 13.60000 1.00000 9.00000 9.00000 9.00000 9.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
13.120 2385.00000 38.8000 -44.53125 0.00000 2.59400 2.59400 12.90000 1.08200 0.37300 13.60000 1.00000 9.00000 9.00000 9.00000 9.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
13.130 2385.00000 38.8000 -44.53125 0.00000 2.59400 2.59400 12.90000 1.08200 0.37300 13.60000 1.00000 9.00000 9.00000 9.00000 9.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
13.140 2385.00000 38.8000 -44.53125 0.00000 2.59400 2.59400 12.90000 1.08200 0.37300 13.60000 1.00000 9.00000 9.00000 9.00000 9.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
13.150 2385.00000 38.8000 -44.53125 0.00000 2.59400 2.59400 12.90000 1.08200 0.37300 13.60000 1.00000 9.00000 9.00000 9.00000 9.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
13.160 2421.00000 38.6000 -44.53125 0.00000 2.72800 2.72800 13.50000 1.08200 0.37300 13.60000 1.00000 9.00000 9.00000 10.00000 9.00000 0.00000 0.00000 13.1000 0.000 0.000 0.000 0.000
13.170 2421.00000 38.6000 -44.53125 0.00000 2.72800 2.72800 13.50000 1.08200 0.37300 13.60000 1.00000 9.00000 9.00000 10.00000 9.00000 0.00000 0.00000 13.1000 0.000 0.000 0.000 0.000
13.180 2421.00000 38.6000 -44.53125 0.00000 2.72800 2.72800 13.50000 1.08200 0.37300 13.60000 1.00000 9.00000 9.00000 10.00000 9.00000 0.00000 0.00000 13.1000 0.000 0.000 0.000 0.000
13.190 2421.00000 38.6000 -44.53125 0.00000 2.72800 2.72800 13.50000 1.08200 0.37300 13.60000 1.00000 9.00000 9.00000 10.00000 9.00000 0.00000 0.00000 13.1000 0.000 0.000 0.000 0.000
13.200 2421.00000 38.6000 -44.53125 0.00000 2.72800 2.72800 13.50000 1.08200 0.37300 13.60000 1.00000 9.00000 9.00000 10.00000 9.00000 0.00000 0.00000 13.1000 0.000 0.000 0.000 0.000
13.210 2470.00000 38.9000 -44.53125 0.00000 2.57600 2.57600 13.20000 1.08200 0.37300 14.00000 1.00000 10.00000 10.00000 10.00000 9.00000 0.00000 0.00000 13.1000 0.000 0.000 0.000 0.000
13.220 2470.00000 38.9000 -44.53125 0.00000 2.57600 2.57600 13.20000 1.08200 0.37300 14.00000 1.00000 10.00000 10.00000 10.00000 9.00000 0.00000 0.00000 13.1000 0.000 0.000 0.000 0.000
13.230 2470.00000 38.9000 -44.53125 0.00000 2.57600 2.57600 13.20000 1.08200 0.37300 14.00000 1.00000 10.00000 10.00000 10.00000 9.00000 0.00000 0.00000 13.1000 0.000 0.000 0.000 0.000
13.240 2470.00000 38.9000 -44.53125 0.00000 2.57600 2.57600 13.20000 1.08200 0.37300 14.00000 1.00000 10.00000 10.00000 10.00000 9.00000 0.00000 0.00000 13.1000 0.000 0.000 0.000 0.000
13.250 2470.00000 38.9000 -44.53125 0.00000 2.57600 2.57600 13.20000 1.08200 0.37300 14.00000 1.00000 10.00000 10.00000 10.00000 9.00000 0.00000 0.00000 13.1000 0.000 0.000 0.000 0.000
13.260 2427.00000 39.7000 -44.53125 0.00000 2.73400 2.73400 12.70000 1.07200 0.97900 14.30000 1.00000 9.00000 9.00000 10.00000 9.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
13.270 2427.00000 39.7000 -44.53125 0.00000 2.73400 2.73400 12.70000 1.07200 0.97900 14.30000 1.00000 9.00000 9.00000 10.00000 9.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
13.280 2427.00000 39.7000 -44.53125 0.00000 2.73400 2.73400 12.70000 1.07200 0.97900 14.30000 1.00000 9.00000 9.00000 10.00000 9.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
13.290 2427.00000 39.7000 -44.53125 0.00000 2.73400 2.73400 12.70000 1.07200 0.97900 14.30000 1.00000 9.00000 9.00000 10.00000 9.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
13.300 2427.00000 39.7000 -44.53125 0.00000 2.73400 2.73400 12.70000 1.07200 0.97900 14.30000 1.00000 9.00000 9.00000 10.00000 9.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
13.310 2439.00000 41.1000 -44.53125 0.00000 2.71600 2.71600 13.00000 1.07200 0.97900 14.00000 1.00000 9.00000 9.00000 10.00000 9.00000 0.00000 0.00000 13.4000 0.000 0.000 0.000 0.000
13.320 2439.00000 41.1000 -44.53125 0.00000 2.71600 2.71600 13.00000 1.07200 0.97900 14.00000 1.00000 9.00000 9.00000 10.00000 9.00000 0.00000 0.00000 13.4000 0.000 0.000 0.000 0.000
13.330 2439.00000 41.1000 -44.53125 0.00000 2.71600 2.71600 13.00000 1.07200 0.97900 14.00000 1.00000 9.00000 9.00000 10.00000 9.00000 0.00000 0.00000 13.4000 0.000 0.000 0.000 0.000
13.340 2439.00000 41.1000 -44.53125 0.00000 2.71600 2.71600 13.00000 1.07200 0.97900 14.00000 1.00000 9.00000 9.00000 10.00000 9.00000 0.00000 0.00000 13.4000 0.000 0.000 0.000 0.000
13.350 2439.00000 41.1000 -44.53125 0.00000 2.71600 2.71600 13.00000 1.07200 0.97900 14.00000 1.00000 9.00000 9.00000 10.00000 9.00000 0.00000 0.00000 13.4000 0.000 0.000 0.000 0.000
13.360 2533.00000 43.8000 -44.53125 0.00000 2.67500 2.67500 13.70000 1.07200 0.97900 15.10000 1.00000 10.00000 10.00000 10.00000 10.00000 0.00000 0.00000 13.4000 0.000 0.000 0.000 0.000
13.370 2533.00000 43.8000 -44.53125 0.00000 2.67500 2.67500 13.70000 1.07200 0.97900 15.10000 1.00000 10.00000 10.00000 10.00000 10.00000 0.00000 0.00000 13.4000 0.000 0.000 0.000 0.000
13.380 2533.00000 43.8000 -44.53125 0.00000 2.67500 2.67500 13.70000 1.07200 0.97900 15.10000 1.00000 10.00000 10.00000 10.00000 10.00000 0.00000 0.00000 13.4000 0.000 0.000 0.000 0.000
13.390 2533.00000 43.8000 -44.53125 0.00000 2.67500 2.67500 13.70000 1.07200 0.97900 15.10000 1.00000 10.00000 10.00000 10.00000 10.00000 0.00000 0.00000 13.4000 0.000 0.000 0.000 0.000
13.400 2533.00000 43.8000 -44.53125 0.00000 2.67500 2.67500 13.70000 1.07200 0.97900 15.10000 1.00000 10.00000 10.00000 10.00000 10.00000 0.00000 0.00000 13.4000 0.000 0.000 0.000 0.000
13.410 2487.00000 44.7000 -44.53125 0.00000 2.81500 2.81500 13.60000 1.07200 0.97900 14.60000 1.00000 10.00000 9.00000 9.00000 10.00000 0.00000 0.00000 13.4000 0.000 0.000 0.000 0.000
13.420 2487.00000 44.7000 -44.53125 0.00000 2.81500 2.81500 13.60000 1.07200 0.97900 14.60000 1.00000 10.00000 9.00000 9.00000 10.00000 0.00000 0.00000 13.4000 0.000 0.000 0.000 0.000
13.430 2487.00000 44.7000 -44.53125 0.00000 2.81500 2.81500 13.60000 1.07200 0.97900 14.60000 1.00000 10.00000 9.00000 9.00000 10.00000 0.00000 0.00000 13.4000 0.000 0.000 0.000 0.000
13.440 2487.00000 44.7000 -44.53125 0.00000 2.81500 2.81500 13.60000 1.07200 0.97900 14.60000 1.00000 10.00000 9.00000 9.00000 10.00000 0.00000 0.00000 13.4000 0.000 0.000 0.000 0.000
13.450 2487.00000 44.7000 -44.53125 0.00000 2.81500 2.81500 13.60000 1.07200 0.97900 14.60000 1.00000 10.00000 9.00000 9.00000 10.00000 0.00000 0.00000 13.4000 0.000 0.000 0.000 0.000
13.460 2478.00000 44.9000 -44.53125 0.00000 2.79200 2.79200 13.50000 1.06900 1.02400 14.30000 1.00000 10.00000 10.00000 10.00000 10.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
13.470 2478.00000 44.9000 -44.53125 0.00000 2.79200 2.79200 13.50000 1.06900 1.02400 14.30000 1.00000 10.00000 10.00000 10.00000 10.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
13.480 2478.00000 44.9000 -44.53125 0.00000 2.79200 2.79200 13.50000 1.06900 1.02400 14.30000 1.00000 10.00000 10.00000 10.00000 10.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
13.490 2478.00000 44.9000 -44.53125 0.00000 2.79200 2.79200 13.50000 1.06900 1.02400 14.30000 1.00000 10.00000 10.00000 10.00000 10.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
13.500 2478.00000 44.9000 -44.53125 0.00000 2.79200 2.79200 13.50000 1.06900 1.02400 14.30000 1.00000 10.00000 10.00000 10.00000 10.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
13.510 2506.00000 45.3000 -44.53125 0.00000 2.84400 2.84400 12.80000 1.06900 1.02400 14.50000 1.00000 10.00000 10.00000 10.00000 10.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
13.520 2506.00000 45.3000 -44.53125 0.00000 2.84400 2.84400 12.80000 1.06900 1.02400 14.50000 1.00000 10.00000 10.00000 10.00000 10.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
13.530 2506.00000 45.3000 -44.53125 0.00000 2.84400 2.84400 12.80000 1.06900 1.02400 14.50000 1.00000 10.00000 10.00000 10.00000 10.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
13.540 2506.00000 45.3000 -44.53125 0.00000 2.84400 2.84400 12.80000 1.06900 1.02400 14.50000 1.00000 10.00000 10.00000 10.00000 10.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
13.550 2506.00000 45.3000 -44.53125 0.00000 2.84400 2.84400 12.80000 1.06900 1.02400 14.50000 1.00000 10.00000 10.00000 10.00000 10.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
13.560 2525.00000 45.8000 -44.53125 0.00000 2.75100 2.75100 13.40000 1.06900 1.02400 14.30000 1.00000 10.00000 10.00000 10.00000 10.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
13.570 2525.00000 45.8000 -44.53125 0.00000 2.75100 2.75100 13.40000 1.06900 1.02400 14.30000 1.00000 10.00000 10.00000 10.00000 10.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
13.580 2525.00000 45.8000 -44.53125 0.00000 2.75100 2.75100 13.40000 1.06900 1.02400 14.30000 1.00000 10.00000 10.00000 10.00000 10.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
13.590 2525.00000 45.8000 -44.53125 0.00000 2.75100 2.75100 13.40000 1.06900 1.02400 14.30000 1.00000 10.00000 10.00000 10.00000 10.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
13.600 2525.00000 45.8000 -44.53125 0.00000 2.75100 2.75100 13.40000 1.06900 1.02400 14.30000 1.00000 10.00000 10.00000 10.00000 10.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
13.610 2531.00000 46.6000 -44.53125 0.00000 2.84400 2.84400 12.80000 1.06900 1.02400 14.50000 1.00000 10.00000 10.00000 10.00000 10.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
13.620 2531.00000 46.6000 -44.53125 0.00000 2.84400 2.84400 12.80000 1.06900 1.02400 14.50000 1.00000 10.00000 10.00000 10.00000 10.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
13.630 2531.00000 46.6000 -44.53125 0.00000 2.84400 2.84400 12.80000 1.06900 1.02400 14.50000 1.00000 10.00000 10.00000 10.00000 10.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
13.640 2531.00000 46.6000 -44.53125 0.00000 2.84400 2.84400 12.80000 1.06900 1.02400 14.50000 1.00000 10.00000 10.00000 10.00000 10.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
13.650 2531.00000 46.6000 -44.53125 0.00000 2.84400 2.84400 12.80000 1.06900 1.02400 14.50000 1.00000 10.00000 10.00000 10.00000 10.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
13.660 2562.00000 46.4000 -44.53125 0.00000 2.81500 2.81500 13.30000 1.07500 1.03700 14.60000 1.00000 10.00000 10.00000 10.00000 10.00000 0.00000 0.00000 13.8000 0.000 0.000 0.000 0.000
13.670 2562.00000 46.4000 -44.53125 0.00000 2.81500 2.81500 13.30000 1.07500 1.03700 14.60000 1.00000 10.00000 10.00000 10.00000 10.00000 0.00000 0.00000 13.8000 0.000 0.000 0.000 0.000
13.680 2562.00000 46.4000 -44.53125 0.00000 2.81500 2.81500 13.30000 1.07500 1.03700 14.60000 1.00000 10.00000 10.00000 10.00000 10.00000 0.00000 0.00000 13.8000 0.000 0.000 0.000 0.000
13.690 2562.00000 46.4000 -44.53125 0.00000 2.81500 2.81500 13.30000 1.07500 1.03700 14.60000 1.00000 10.00000 10.00000 10.00000 10.00000 0.00000 0.00000 13.8000 0.000 0.000 0.000 0.000
13.700 2562.00000 46.4000 -44.53125 0.00000 2.81500 2.81500 13.30000 1.07500 1.03700 14.60000 1.00000 10.00000 10.00000 10.00000 10.00000 0.00000 0.00000 13.8000 0.000 0.000 0.000 0.000
13.710 2539.00000 47.2000 -44.53125 0.00000 2.92000 2.92000 13.20000 1.07500 1.03700 15.00000 1.00000 10.00000 10.00000 10.00000 10.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
13.720 2539.00000 47.2000 -44.53125 0.00000 2.92000 2.92000 13.20000 1.07500 1.03700 15.00000 1.00000 10.00000 10.00000 10.00000 10.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
13.730 2539.00000 47.2000 -44.53125 0.00000 2.92000 2.92000 13.20000 1.07500 1.03700 15.00000 1.00000 10.00000 10.00000 10.00000 10.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
13.740 2539.00000 47.2000 -44.53125 0.00000 2.92000 2.92000 13.20000 1.07500 1.03700 15.00000 1.00000 10.00000 10.00000 10.00000 10.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
13.750 2539.00000 47.2000 -44.53125 0.00000 2.92000 2.92000 13.20000 1.07500 1.03700 15.00000 1.00000 10.00000 10.00000 10.00000 10.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
13.760 2565.00000 48.1000 -44.53125 0.00000 2.83300 2.83300 13.40000 1.07500 1.03700 14.60000 1.00000 10.00000 10.00000 10.00000 10.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
13.770 2565.00000 48.1000 -44.53125 0.00000 2.83300 2.83300 13.40000 1.07500 1.03700 14.60000 1.00000 10.00000 10.00000 10.00000 10.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
13.780 2565.00000 48.1000 -44.53125 0.00000 2.83300 2.83300 13.40000 1.07500 1.03700 14.60000 1.00000 10.00000 10.00000 10.00000 10.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
13.790 2565.00000 48.1000 -44.53125 0.00000 2.83300 2.83300 13.40000 1.07500 1.03700 14.60000 1.00000 10.00000 10.00000 10.00000 10.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
13.800 2565.00000 48.1000 -44.53125 0.00000 2.83300 2.83300 13.40000 1.07500 1.03700 14.60000 1.00000 10.00000 10.00000 10.00000 10.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
13.810 2614.00000 48.2000 -44.53125 0.00000 2.95500 2.95500 13.20000 1.07500 1.03700 15.00000 1.00000 11.00000 10.00000 11.00000 11.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
13.820 2614.00000 48.2000 -44.53125 0.00000 2.95500 2.95500 13.20000 1.07500 1.03700 15.00000 1.00000 11.00000 10.00000 11.00000 11.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
13.830 2614.00000 48.2000 -44.53125 0.00000 2.95500 2.95500 13.20000 1.07500 1.03700 15.00000 1.00000 11.00000 10.00000 11.00000 11.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
13.840 2614.00000 48.2000 -44.53125 0.00000 2.95500 2.95500 13.20000 1.07500 1.03700 15.00000 1.00000 11.00000 10.00000 11.00000 11.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
13.850 2614.00000 48.2000 -44.53125 0.00000 2.95500 2.95500 13.20000 1.07500 1.03700 15.00000 1.00000 11.00000 10.00000 11.00000 11.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
13.860 2614.00000 48.2000 -44.53125 0.00000 2.95500 2.95500 13.20000 1.07500 1.03700 15.00000 1.00000 11.00000 10.00000 11.00000 11.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
13.870 2614.00000 48.2000 -44.53125 0.00000 2.95500 2.95500 13.20000 1.07500 1.03700 15.00000 1.00000 11.00000 10.00000 11.00000 11.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
13.880 2583.00000 48.7000 -44.53125 0.00000 2.87400 2.87400 13.00000 1.07500 1.03400 14.90000 1.00000 12.00000 11.00000 11.00000 11.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
13.890 2583.00000 48.7000 -44.53125 0.00000 2.87400 2.87400 13.00000 1.07500 1.03400 14.90000 1.00000 12.00000 11.00000 11.00000 11.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
13.900 2583.00000 48.7000 -44.53125 0.00000 2.87400 2.87400 13.00000 1.07500 1.03400 14.90000 1.00000 12.00000 11.00000 11.00000 11.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
13.910 2583.00000 48.7000 -44.53125 0.00000 2.87400 2.87400 13.00000 1.07500 1.03400 14.90000 1.00000 12.00000 11.00000 11.00000 11.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
13.920 2583.00000 48.7000 -44.53125 0.00000 2.87400 2.87400 13.00000 1.07500 1.03400 14.90000 1.00000 12.00000 11.00000 11.00000 11.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
13.930 2602.00000 48.7000 -44.53125 0.00000 2.93200 2.93200 13.40000 1.07500 1.03400 15.10000 1.00000 12.00000 12.00000 12.00000 11.00000 0.00000 0.00000 13.8000 0.000 0.000 0.000 0.000
13.940 2602.00000 48.7000 -44.53125 0.00000 2.93200 2.93200 13.40000 1.07500 1.03400 15.10000 1.00000 12.00000 12.00000 12.00000 11.00000 0.00000 0.00000 13.8000 0.000 0.000 0.000 0.000
13.950 2602.00000 48.7000 -44.53125 0.00000 2.93200 2.93200 13.40000 1.07500 1.03400 15.10000 1.00000 12.00000 12.00000 12.00000 11.00000 0.00000 0.00000 13.8000 0.000 0.000 0.000 0.000
13.960 2602.00000 48.7000 -44.53125 0.00000 2.93200 2.93200 13.40000 1.07500 1.03400 15.10000 1.00000 12.00000 12.00000 12.00000 11.00000 0.00000 0.00000 13.8000 0.000 0.000 0.000 0.000
13.970 2602.00000 48.7000 -44.53125 0.00000 2.93200 2.93200 13.40000 1.07500 1.03400 15.10000 1.00000 12.00000 12.00000 12.00000 11.00000 0.00000 0.00000 13.8000 0.000 0.000 0.000 0.000
13.980 2618.00000 48.6000 -42.18750 -0.12500 2.96700 2.96700 12.70000 1.07500 1.03400 15.70000 1.00000 11.00000 11.00000 12.00000 11.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
13.990 2618.00000 48.6000 -42.18750 -0.12500 2.96700 2.96700 12.70000 1.07500 1.03400 15.70000 1.00000 11.00000 11.00000 12.00000 11.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
14.000 2618.00000 48.6000 -42.18750 -0.12500 2.96700 2.96700 12.70000 1.07500 1.03400 15.70000 1.00000 11.00000 11.00000 12.00000 11.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
14.010 2618.00000 48.6000 -42.18750 -0.12500 2.96700 2.96700 12.70000 1.07500 1.03400 15.70000 1.00000 11.00000 11.00000 12.00000 11.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
14.020 2618.00000 48.6000 -42.18750 -0.12500 2.96700 2.96700 12.70000 1.07500 1.03400 15.70000 1.00000 11.00000 11.00000 12.00000 11.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
14.030 2626.00000 49.0000 -44.53125 0.00000 2.94900 2.94900 12.80000 1.07500 1.03400 15.10000 1.00000 12.00000 12.00000 12.00000 12.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
14.040 2626.00000 49.0000 -44.53125 0.00000 2.94900 2.94900 12.80000 1.07500 1.03400 15.10000 1.00000 12.00000 12.00000 12.00000 12.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
14.050 2626.00000 49.0000 -44.53125 0.00000 2.94900 2.94900 12.80000 1.07500 1.03400 15.10000 1.00000 12.00000 12.00000 12.00000 12.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
14.060 2626.00000 49.0000 -44.53125 0.00000 2.94900 2.94900 12.80000 1.07500 1.03400 15.10000 1.00000 12.00000 12.00000 12.00000 12.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
14.070 2626.00000 49.0000 -44.53125 0.00000 2.94900 2.94900 12.80000 1.07500 1.03400 15.10000 1.00000 12.00000 12.00000 12.00000 12.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
14.080 2630.00000 49.0000 -43.75000 0.00000 3.02500 3.02500 13.80000 1.09800 1.06900 15.40000 1.00000 12.00000 12.00000 12.00000 12.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
14.090 2630.00000 49.0000 -43.75000 0.00000 3.02500 3.02500 13.80000 1.09800 1.06900 15.40000 1.00000 12.00000 12.00000 12.00000 12.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
14.100 2630.00000 49.0000 -43.75000 0.00000 3.02500 3.02500 13.80000 1.09800 1.06900 15.40000 1.00000 12.00000 12.00000 12.00000 12.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
14.110 2630.00000 49.0000 -43.75000 0.00000 3.02500 3.02500 13.80000 1.09800 1.06900 15.40000 1.00000 12.00000 12.00000 12.00000 12.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
14.120 2630.00000 49.0000 -43.75000 0.00000 3.02500 3.02500 13.80000 1.09800 1.06900 15.40000 1.00000 12.00000 12.00000 12.00000 12.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
14.130 2635.00000 49.2000 -42.18750 -0.12500 3.08300 3.08300 13.30000 1.09800 1.06900 15.80000 1.00000 12.00000 12.00000 13.00000 12.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
14.140 2635.00000 49.2000 -42.18750 -0.12500 3.08300 3.08300 13.30000 1.09800 1.06900 15.80000 1.00000 12.00000 12.00000 13.00000 12.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
14.150 2635.00000 49.2000 -42.18750 -0.12500 3.08300 3.08300 13.30000 1.09800 1.06900 15.80000 1.00000 12.00000 12.00000 13.00000 12.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
14.160 2635.00000 49.2000 -42.18750 -0.12500 3.08300 3.08300 13.30000 1.09800 1.06900 15.80000 1.00000 12.00000 12.00000 13.00000 12.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
14.170 2635.00000 49.2000 -42.18750 -0.12500 3.08300 3.08300 13.30000 1.09800 1.06900 15.80000 1.00000 12.00000 12.00000 13.00000 12.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
14.180 2715.00000 49.6000 -39.06250 -0.12500 2.98400 2.98400 13.50000 1.09800 1.06900 16.60000 1.00000 13.00000 12.00000 13.00000 13.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
14.190 2715.00000 49.6000 -39.06250 -0.12500 2.98400 2.98400 13.50000 1.09800 1.06900 16.60000 1.00000 13.00000 12.00000 13.00000 13.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
14.200 2715.00000 49.6000 -39.06250 -0.12500 2.98400 2.98400 13.50000 1.09800 1.06900 16.60000 1.00000 13.00000 12.00000 13.00000 13.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
14.210 2715.00000 49.6000 -39.06250 -0.12500 2.98400 2.98400 13.50000 1.09800 1.06900 16.60000 1.00000 13.00000 12.00000 13.00000 13.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
14.220 2715.00000 49.6000 -39.06250 -0.12500 2.98400 2.98400 13.50000 1.09800 1.06900 16.60000 1.00000 13.00000 12.00000 13.00000 13.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
14.230 2705.00000 50.5000 -42.18750 -0.12500 2.99000 2.99000 12.90000 1.09800 1.06900 15.60000 1.00000 12.00000 13.00000 12.00000 13.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
14.240 2705.00000 50.5000 -42.18750 -0.12500 2.99000 2.99000 12.90000 1.09800 1.06900 15.60000 1.00000 12.00000 13.00000 12.00000 13.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
14.250 2705.00000 50.5000 -42.18750 -0.12500 2.99000 2.99000 12.90000 1.09800 1.06900 15.60000 1.00000 12.00000 13.00000 12.00000 13.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
14.260 2705.00000 50.5000 -42.18750 -0.12500 2.99000 2.99000 12.90000 1.09800 1.06900 15.60000 1.00000 12.00000 13.00000 12.00000 13.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
14.270 2705.00000 50.5000 -42.18750 -0.12500 2.99000 2.99000 12.90000 1.09800 1.06900 15.60000 1.00000 12.00000 13.00000 12.00000 13.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
14.280 2700.00000 49.9000 -42.96875 -0.12500 3.04300 3.04300 13.20000 1.11000 1.09400 15.50000 1.00000 12.00000 13.00000 13.00000 12.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
14.290 2700.00000 49.9000 -42.96875 -0.12500 3.04300 3.04300 13.20000 1.11000 1.09400 15.50000 1.00000 12.00000 13.00000 13.00000 12.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
14.300 2700.00000 49.9000 -42.96875 -0.12500 3.04300 3.04300 13.20000 1.11000 1.09400 15.50000 1.00000 12.00000 13.00000 13.00000 12.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
14.310 2700.00000 49.9000 -42.96875 -0.12500 3.04300 3.04300 13.20000 1.11000 1.09400 15.50000 1.00000 12.00000 13.00000 13.00000 12.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
14.320 2700.00000 49.9000 -42.96875 -0.12500 3.04300 3.04300 13.20000 1.11000 1.09400 15.50000 1.00000 12.00000 13.00000 13.00000 12.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
14.330 2744.00000 50.1000 -42.18750 -0.12500 3.17700 3.17700 13.40000 1.11000 1.09400 15.70000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 12.0000 0.000 0.000 0.000 0.000
14.340 2744.00000 50.1000 -42.18750 -0.12500 3.17700 3.17700 13.40000 1.11000 1.09400 15.70000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 12.0000 0.000 0.000 0.000 0.000
14.350 2744.00000 50.1000 -42.18750 -0.12500 3.17700 3.17700 13.40000 1.11000 1.09400 15.70000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 12.0000 0.000 0.000 0.000 0.000
14.360 2744.00000 50.1000 -42.18750 -0.12500 3.17700 3.17700 13.40000 1.11000 1.09400 15.70000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 12.0000 0.000 0.000 0.000 0.000
14.370 2744.00000 50.1000 -42.18750 -0.12500 3.17700 3.17700 13.40000 1.11000 1.09400 15.70000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 12.0000 0.000 0.000 0.000 0.000
14.380 2756.00000 49.6000 -42.18750 -0.12500 3.20000 3.20000 13.40000 1.11000 1.09400 15.70000 1.00000 12.00000 13.00000 13.00000 13.00000 0.00000 0.00000 12.2000 0.000 0.000 0.000 0.000
14.390 2756.00000 49.6000 -42.18750 -0.12500 3.20000 3.20000 13.40000 1.11000 1.09400 15.70000 1.00000 12.00000 13.00000 13.00000 13.00000 0.00000 0.00000 12.2000 0.000 0.000 0.000 0.000
14.400 2756.00000 49.6000 -42.18750 -0.12500 3.20000 3.20000 13.40000 1.11000 1.09400 15.70000 1.00000 12.00000 13.00000 13.00000 13.00000 0.00000 0.00000 12.2000 0.000 0.000 0.000 0.000
14.410 2756.00000 49.6000 -42.18750 -0.12500 3.20000 3.20000 13.40000 1.11000 1.09400 15.70000 1.00000 12.00000 13.00000 13.00000 13.00000 0.00000 0.00000 12.2000 0.000 0.000 0.000 0.000
14.420 2756.00000 49.6000 -42.18750 -0.12500 3.20000 3.20000 13.40000 1.11000 1.09400 15.70000 1.00000 12.00000 13.00000 13.00000 13.00000 0.00000 0.00000 12.2000 0.000 0.000 0.000 0.000
14.430 2751.00000 50.1000 -41.40625 -0.25000 3.20600 3.20600 12.40000 1.11000 1.09400 16.10000 1.00000 12.00000 12.00000 12.00000 12.00000 0.00000 0.00000 12.0000 0.000 0.000 0.000 0.000
14.440 2751.00000 50.1000 -41.40625 -0.25000 3.20600 3.20600 12.40000 1.11000 1.09400 16.10000 1.00000 12.00000 12.00000 12.00000 12.00000 0.00000 0.00000 12.0000 0.000 0.000 0.000 0.000
14.450 2751.00000 50.1000 -41.40625 -0.25000 3.20600 3.20600 12.40000 1.11000 1.09400 16.10000 1.00000 12.00000 12.00000 12.00000 12.00000 0.00000 0.00000 12.0000 0.000 0.000 0.000 0.000
14.460 2751.00000 50.1000 -41.40625 -0.25000 3.20600 3.20600 12.40000 1.11000 1.09400 16.10000 1.00000 12.00000 12.00000 12.00000 12.00000 0.00000 0.00000 12.0000 0.000 0.000 0.000 0.000
14.470 2751.00000 50.1000 -41.40625 -0.25000 3.20600 3.20600 12.40000 1.11000 1.09400 16.10000 1.00000 12.00000 12.00000 12.00000 12.00000 0.00000 0.00000 12.0000 0.000 0.000 0.000 0.000
14.480 2767.00000 50.1000 -40.62500 -0.25000 3.19400 3.19400 12.90000 1.08500 1.08200 16.10000 1.00000 12.00000 12.00000 12.00000 12.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
14.490 2767.00000 50.1000 -40.62500 -0.25000 3.19400 3.19400 12.90000 1.08500 1.08200 16.10000 1.00000 12.00000 12.00000 12.00000 12.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
14.500 2767.00000 50.1000 -40.62500 -0.25000 3.19400 3.19400 12.90000 1.08500 1.08200 16.10000 1.00000 12.00000 12.00000 12.00000 12.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
14.510 2767.00000 50.1000 -40.62500 -0.25000 3.19400 3.19400 12.90000 1.08500 1.08200 16.10000 1.00000 12.00000 12.00000 12.00000 12.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
14.520 2767.00000 50.1000 -40.62500 -0.25000 3.19400 3.19400 12.90000 1.08500 1.08200 16.10000 1.00000 12.00000 12.00000 12.00000 12.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
14.530 2777.00000 49.8000 -39.84375 -0.25000 3.20000 3.20000 12.00000 1.08500 1.08200 16.50000 1.00000 12.00000 13.00000 12.00000 12.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
14.540 2777.00000 49.8000 -39.84375 -0.25000 3.20000 3.20000 12.00000 1.08500 1.08200 16.50000 1.00000 12.00000 13.00000 12.00000 12.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
14.550 2777.00000 49.8000 -39.84375 -0.25000 3.20000 3.20000 12.00000 1.08500 1.08200 16.50000 1.00000 12.00000 13.00000 12.00000 12.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
14.560 2777.00000 49.8000 -39.84375 -0.25000 3.20000 3.20000 12.00000 1.08500 1.08200 16.50000 1.00000 12.00000 13.00000 12.00000 12.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
14.570 2777.00000 49.8000 -39.84375 -0.25000 3.20000 3.20000 12.00000 1.08500 1.08200 16.50000 1.00000 12.00000 13.00000 12.00000 12.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
14.580 2813.00000 49.9000 -39.84375 -0.25000 3.21800 3.21800 12.80000 1.08500 1.08200 16.40000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
14.590 2813.00000 49.9000 -39.84375 -0.25000 3.21800 3.21800 12.80000 1.08500 1.08200 16.40000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
14.600 2813.00000 49.9000 -39.84375 -0.25000 3.21800 3.21800 12.80000 1.08500 1.08200 16.40000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
14.610 2813.00000 49.9000 -39.84375 -0.25000 3.21800 3.21800 12.80000 1.08500 1.08200 16.40000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
14.620 2813.00000 49.9000 -39.84375 -0.25000 3.21800 3.21800 12.80000 1.08500 1.08200 16.40000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
14.630 2829.00000 49.9000 -39.84375 -0.25000 3.26400 3.26400 12.50000 1.08500 1.08200 16.50000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
14.640 2829.00000 49.9000 -39.84375 -0.25000 3.26400 3.26400 12.50000 1.08500 1.08200 16.50000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
14.650 2829.00000 49.9000 -39.84375 -0.25000 3.26400 3.26400 12.50000 1.08500 1.08200 16.50000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
14.660 2829.00000 49.9000 -39.84375 -0.25000 3.26400 3.26400 12.50000 1.08500 1.08200 16.50000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
14.670 2829.00000 49.9000 -39.84375 -0.25000 3.26400 3.26400 12.50000 1.08500 1.08200 16.50000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
14.680 2889.00000 49.5000 -40.62500 -0.25000 3.25300 3.25300 12.50000 1.07200 1.06600 16.20000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 12.9000 0.000 0.000 0.000 0.000
14.690 2889.00000 49.5000 -40.62500 -0.25000 3.25300 3.25300 12.50000 1.07200 1.06600 16.20000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 12.9000 0.000 0.000 0.000 0.000
14.700 2889.00000 49.5000 -40.62500 -0.25000 3.25300 3.25300 12.50000 1.07200 1.06600 16.20000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 12.9000 0.000 0.000 0.000 0.000
14.710 2889.00000 49.5000 -40.62500 -0.25000 3.25300 3.25300 12.50000 1.07200 1.06600 16.20000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 12.9000 0.000 0.000 0.000 0.000
14.720 2889.00000 49.5000 -40.62500 -0.25000 3.25300 3.25300 12.50000 1.07200 1.06600 16.20000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 12.9000 0.000 0.000 0.000 0.000
14.730 2838.00000 49.2000 -40.62500 -0.25000 3.27600 3.27600 12.80000 1.07200 1.06600 16.30000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
14.740 2838.00000 49.2000 -40.62500 -0.25000 3.27600 3.27600 12.80000 1.07200 1.06600 16.30000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
14.750 2838.00000 49.2000 -40.62500 -0.25000 3.27600 3.27600 12.80000 1.07200 1.06600 16.30000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
14.760 2838.00000 49.2000 -40.62500 -0.25000 3.27600 3.27600 12.80000 1.07200 1.06600 16.30000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
14.770 2838.00000 49.2000 -40.62500 -0.25000 3.27600 3.27600 12.80000 1.07200 1.06600 16.30000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
14.780 2892.00000 49.8000 -40.62500 -0.25000 3.36300 3.36300 13.70000 1.07200 1.06600 16.10000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
14.790 2892.00000 49.8000 -40.62500 -0.25000 3.36300 3.36300 13.70000 1.07200 1.06600 16.10000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
14.800 2892.00000 49.8000 -40.62500 -0.25000 3.36300 3.36300 13.70000 1.07200 1.06600 16.10000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
14.810 2892.00000 49.8000 -40.62500 -0.25000 3.36300 3.36300 13.70000 1.07200 1.06600 16.10000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
14.820 2892.00000 49.8000 -40.62500 -0.25000 3.36300 3.36300 13.70000 1.07200 1.06600 16.10000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
14.830 2953.00000 49.5000 -39.84375 -0.25000 3.27600 3.27600 13.00000 1.07200 1.06600 16.40000 1.00000 14.00000 14.00000 14.00000 14.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
14.840 2953.00000 49.5000 -39.84375 -0.25000 3.27600 3.27600 13.00000 1.07200 1.06600 16.40000 1.00000 14.00000 14.00000 14.00000 14.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
14.850 2953.00000 49.5000 -39.84375 -0.25000 3.27600 3.27600 13.00000 1.07200 1.06600 16.40000 1.00000 14.00000 14.00000 14.00000 14.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
14.860 2953.00000 49.5000 -39.84375 -0.25000 3.27600 3.27600 13.00000 1.07200 1.06600 16.40000 1.00000 14.00000 14.00000 14.00000 14.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
14.870 2953.00000 49.5000 -39.84375 -0.25000 3.27600 3.27600 13.00000 1.07200 1.06600 16.40000 1.00000 14.00000 14.00000 14.00000 14.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
14.880 2901.00000 49.6000 -39.06250 -0.37500 3.24100 3.24100 13.20000 1.08800 1.05300 16.60000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
14.890 2901.00000 49.6000 -39.06250 -0.37500 3.24100 3.24100 13.20000 1.08800 1.05300 16.60000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
14.900 2901.00000 49.6000 -39.06250 -0.37500 3.24100 3.24100 13.20000 1.08800 1.05300 16.60000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
14.910 2901.00000 49.6000 -39.06250 -0.37500 3.24100 3.24100 13.20000 1.08800 1.05300 16.60000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
14.920 2901.00000 49.6000 -39.06250 -0.37500 3.24100 3.24100 13.20000 1.08800 1.05300 16.60000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
14.930 2993.00000 50.5000 -37.50000 -0.37500 3.31100 3.31100 13.70000 1.08800 1.05300 17.20000 1.00000 14.00000 14.00000 14.00000 14.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
14.940 2993.00000 50.5000 -37.50000 -0.37500 3.31100 3.31100 13.70000 1.08800 1.05300 17.20000 1.00000 14.00000 14.00000 14.00000 14.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
14.950 2993.00000 50.5000 -37.50000 -0.37500 3.31100 3.31100 13.70000 1.08800 1.05300 17.20000 1.00000 14.00000 14.00000 14.00000 14.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
14.960 2993.00000 50.5000 -37.50000 -0.37500 3.31100 3.31100 13.70000 1.08800 1.05300 17.20000 1.00000 14.00000 14.00000 14.00000 14.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
14.970 2993.00000 50.5000 -37.50000 -0.37500 3.31100 3.31100 13.70000 1.08800 1.05300 17.20000 1.00000 14.00000 14.00000 14.00000 14.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
14.980 2953.00000 49.8000 -38.28125 -0.37500 3.38700 3.38700 11.60000 1.08800 1.05300 16.90000 1.00000 14.00000 14.00000 13.00000 14.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
14.990 2953.00000 49.8000 -38.28125 -0.37500 3.38700 3.38700 11.60000 1.08800 1.05300 16.90000 1.00000 14.00000 14.00000 13.00000 14.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
15.000 2953.00000 49.8000 -38.28125 -0.37500 3.38700 3.38700 11.60000 1.08800 1.05300 16.90000 1.00000 14.00000 14.00000 13.00000 14.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
15.010 2953.00000 49.8000 -38.28125 -0.37500 3.38700 3.38700 11.60000 1.08800 1.05300 16.90000 1.00000 14.00000 14.00000 13.00000 14.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
15.020 2953.00000 49.8000 -38.28125 -0.37500 3.38700 3.38700 11.60000 1.08800 1.05300 16.90000 1.00000 14.00000 14.00000 13.00000 14.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
15.030 2961.00000 49.5000 -39.06250 -0.37500 3.37500 3.37500 12.80000 1.08800 1.05300 16.60000 1.00000 13.00000 13.00000 13.00000 14.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
15.040 2961.00000 49.5000 -39.06250 -0.37500 3.37500 3.37500 12.80000 1.08800 1.05300 16.60000 1.00000 13.00000 13.00000 13.00000 14.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
15.050 2961.00000 49.5000 -39.06250 -0.37500 3.37500 3.37500 12.80000 1.08800 1.05300 16.60000 1.00000 13.00000 13.00000 13.00000 14.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
15.060 2961.00000 49.5000 -39.06250 -0.37500 3.37500 3.37500 12.80000 1.08800 1.05300 16.60000 1.00000 13.00000 13.00000 13.00000 14.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
15.070 2961.00000 49.5000 -39.06250 -0.37500 3.37500 3.37500 12.80000 1.08800 1.05300 16.60000 1.00000 13.00000 13.00000 13.00000 14.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
15.080 2973.00000 49.5000 -38.28125 -0.37500 3.26400 3.26400 13.30000 1.05600 1.05300 17.00000 1.00000 13.00000 13.00000 14.00000 13.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
15.090 2973.00000 49.5000 -38.28125 -0.37500 3.26400 3.26400 13.30000 1.05600 1.05300 17.00000 1.00000 13.00000 13.00000 14.00000 13.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
15.100 2973.00000 49.5000 -38.28125 -0.37500 3.26400 3.26400 13.30000 1.05600 1.05300 17.00000 1.00000 13.00000 13.00000 14.00000 13.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
15.110 2973.00000 49.5000 -38.28125 -0.37500 3.26400 3.26400 13.30000 1.05600 1.05300 17.00000 1.00000 13.00000 13.00000 14.00000 13.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
15.120 2973.00000 49.5000 -38.28125 -0.37500 3.26400 3.26400 13.30000 1.05600 1.05300 17.00000 1.00000 13.00000 13.00000 14.00000 13.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
15.130 2989.00000 49.2000 -36.71875 -0.50000 3.35700 3.35700 11.80000 1.05600 1.05300 17.30000 1.00000 14.00000 14.00000 14.00000 14.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
15.140 2989.00000 49.2000 -36.71875 -0.50000 3.35700 3.35700 11.80000 1.05600 1.05300 17.30000 1.00000 14.00000 14.00000 14.00000 14.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
15.150 2989.00000 49.2000 -36.71875 -0.50000 3.35700 3.35700 11.80000 1.05600 1.05300 17.30000 1.00000 14.00000 14.00000 14.00000 14.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
15.160 2989.00000 49.2000 -36.71875 -0.50000 3.35700 3.35700 11.80000 1.05600 1.05300 17.30000 1.00000 14.00000 14.00000 14.00000 14.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
15.170 2989.00000 49.2000 -36.71875 -0.50000 3.35700 3.35700 11.80000 1.05600 1.05300 17.30000 1.00000 14.00000 14.00000 14.00000 14.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
15.180 3008.00000 49.3000 -38.28125 -0.37500 3.35700 3.35700 12.90000 1.05600 1.05300 16.90000 1.00000 14.00000 14.00000 14.00000 14.00000 0.00000 0.00000 13.4000 0.000 0.000 0.000 0.000
15.190 3008.00000 49.3000 -38.28125 -0.37500 3.35700 3.35700 12.90000 1.05600 1.05300 16.90000 1.00000 14.00000 14.00000 14.00000 14.00000 0.00000 0.00000 13.4000 0.000 0.000 0.000 0.000
15.200 3008.00000 49.3000 -38.28125 -0.37500 3.35700 3.35700 12.90000 1.05600 1.05300 16.90000 1.00000 14.00000 14.00000 14.00000 14.00000 0.00000 0.00000 13.4000 0.000 0.000 0.000 0.000
15.210 3008.00000 49.3000 -38.28125 -0.37500 3.35700 3.35700 12.90000 1.05600 1.05300 16.90000 1.00000 14.00000 14.00000 14.00000 14.00000 0.00000 0.00000 13.4000 0.000 0.000 0.000 0.000
15.220 3008.00000 49.3000 -38.28125 -0.37500 3.35700 3.35700 12.90000 1.05600 1.05300 16.90000 1.00000 14.00000 14.00000 14.00000 14.00000 0.00000 0.00000 13.4000 0.000 0.000 0.000 0.000
15.230 3026.00000 49.8000 -35.93750 -0.50000 3.42200 3.42200 12.60000 1.05600 1.05300 17.60000 1.00000 14.00000 13.00000 14.00000 14.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
15.240 3026.00000 49.8000 -35.93750 -0.50000 3.42200 3.42200 12.60000 1.05600 1.05300 17.60000 1.00000 14.00000 13.00000 14.00000 14.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
15.250 3026.00000 49.8000 -35.93750 -0.50000 3.42200 3.42200 12.60000 1.05600 1.05300 17.60000 1.00000 14.00000 13.00000 14.00000 14.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
15.260 3026.00000 49.8000 -35.93750 -0.50000 3.42200 3.42200 12.60000 1.05600 1.05300 17.60000 1.00000 14.00000 13.00000 14.00000 14.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
15.270 3026.00000 49.8000 -35.93750 -0.50000 3.42200 3.42200 12.60000 1.05600 1.05300 17.60000 1.00000 14.00000 13.00000 14.00000 14.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
15.280 3116.00000 49.5000 -38.28125 -0.37500 3.48600 3.48600 13.80000 1.04300 1.05000 17.00000 1.00000 15.00000 15.00000 14.00000 14.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
15.290 3116.00000 49.5000 -38.28125 -0.37500 3.48600 3.48600 13.80000 1.04300 1.05000 17.00000 1.00000 15.00000 15.00000 14.00000 14.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
15.300 3116.00000 49.5000 -38.28125 -0.37500 3.48600 3.48600 13.80000 1.04300 1.05000 17.00000 1.00000 15.00000 15.00000 14.00000 14.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
15.310 3116.00000 49.5000 -38.28125 -0.37500 3.48600 3.48600 13.80000 1.04300 1.05000 17.00000 1.00000 15.00000 15.00000 14.00000 14.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
15.320 3116.00000 49.5000 -38.28125 -0.37500 3.48600 3.48600 13.80000 1.04300 1.05000 17.00000 1.00000 15.00000 15.00000 14.00000 14.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
15.330 3077.00000 49.8000 -36.71875 -0.50000 3.43300 3.43300 12.70000 1.04300 1.05000 17.50000 1.00000 14.00000 14.00000 14.00000 14.00000 0.00000 0.00000 13.6000 0.000 0.000 0.000 0.000
15.340 3077.00000 49.8000 -36.71875 -0.50000 3.43300 3.43300 12.70000 1.04300 1.05000 17.50000 1.00000 14.00000 14.00000 14.00000 14.00000 0.00000 0.00000 13.6000 0.000 0.000 0.000 0.000
15.350 3077.00000 49.8000 -36.71875 -0.50000 3.43300 3.43300 12.70000 1.04300 1.05000 17.50000 1.00000 14.00000 14.00000 14.00000 14.00000 0.00000 0.00000 13.6000 0.000 0.000 0.000 0.000
15.360 3077.00000 49.8000 -36.71875 -0.50000 3.43300 3.43300 12.70000 1.04300 1.05000 17.50000 1.00000 14.00000 14.00000 14.00000 14.00000 0.00000 0.00000 13.6000 0.000 0.000 0.000 0.000
15.370 3077.00000 49.8000 -36.71875 -0.50000 3.43300 3.43300 12.70000 1.04300 1.05000 17.50000 1.00000 14.00000 14.00000 14.00000 14.00000 0.00000 0.00000 13.6000 0.000 0.000 0.000 0.000
15.380 3087.00000 49.6000 -37.50000 -0.50000 3.46200 3.46200 13.20000 1.04300 1.05000 17.00000 1.00000 14.00000 14.00000 14.00000 14.00000 0.00000 0.00000 13.6000 0.000 0.000 0.000 0.000
15.390 3087.00000 49.6000 -37.50000 -0.50000 3.46200 3.46200 13.20000 1.04300 1.05000 17.00000 1.00000 14.00000 14.00000 14.00000 14.00000 0.00000 0.00000 13.6000 0.000 0.000 0.000 0.000
15.400 3087.00000 49.6000 -37.50000 -0.50000 3.46200 3.46200 13.20000 1.04300 1.05000 17.00000 1.00000 14.00000 14.00000 14.00000 14.00000 0.00000 0.00000 13.6000 0.000 0.000 0.000 0.000
15.410 3087.00000 49.6000 -37.50000 -0.50000 3.46200 3.46200 13.20000 1.04300 1.05000 17.00000 1.00000 14.00000 14.00000 14.00000 14.00000 0.00000 0.00000 13.6000 0.000 0.000 0.000 0.000
15.420 3087.00000 49.6000 -37.50000 -0.50000 3.46200 3.46200 13.20000 1.04300 1.05000 17.00000 1.00000 14.00000 14.00000 14.00000 14.00000 0.00000 0.00000 13.6000 0.000 0.000 0.000 0.000
15.430 3131.00000 49.9000 -35.15625 -0.62500 3.50900 3.50900 12.90000 1.04300 1.05000 17.80000 1.00000 14.00000 15.00000 14.00000 14.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
15.440 3131.00000 49.9000 -35.15625 -0.62500 3.50900 3.50900 12.90000 1.04300 1.05000 17.80000 1.00000 14.00000 15.00000 14.00000 14.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
15.450 3131.00000 49.9000 -35.15625 -0.62500 3.50900 3.50900 12.90000 1.04300 1.05000 17.80000 1.00000 14.00000 15.00000 14.00000 14.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
15.460 3131.00000 49.9000 -35.15625 -0.62500 3.50900 3.50900 12.90000 1.04300 1.05000 17.80000 1.00000 14.00000 15.00000 14.00000 14.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
15.470 3131.00000 49.9000 -35.15625 -0.62500 3.50900 3.50900 12.90000 1.04300 1.05000 17.80000 1.00000 14.00000 15.00000 14.00000 14.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
15.480 3139.00000 49.8000 -37.50000 -0.50000 3.60200 3.60200 13.20000 1.03400 1.03400 17.20000 1.00000 15.00000 14.00000 15.00000 14.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
15.490 3139.00000 49.8000 -37.50000 -0.50000 3.60200 3.60200 13.20000 1.03400 1.03400 17.20000 1.00000 15.00000 14.00000 15.00000 14.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
15.500 3139.00000 49.8000 -37.50000 -0.50000 3.60200 3.60200 13.20000 1.03400 1.03400 17.20000 1.00000 15.00000 14.00000 15.00000 14.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
15.510 3139.00000 49.8000 -37.50000 -0.50000 3.60200 3.60200 13.20000 1.03400 1.03400 17.20000 1.00000 15.00000 14.00000 15.00000 14.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
15.520 3139.00000 49.8000 -37.50000 -0.50000 3.60200 3.60200 13.20000 1.03400 1.03400 17.20000 1.00000 15.00000 14.00000 15.00000 14.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
15.530 3156.00000 49.6000 -34.37500 -0.62500 3.57900 3.57900 12.70000 1.03400 1.03400 18.20000 1.00000 15.00000 14.00000 15.00000 15.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
15.540 3156.00000 49.6000 -34.37500 -0.62500 3.57900 3.57900 12.70000 1.03400 1.03400 18.20000 1.00000 15.00000 14.00000 15.00000 15.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
15.550 3156.00000 49.6000 -34.37500 -0.62500 3.57900 3.57900 12.70000 1.03400 1.03400 18.20000 1.00000 15.00000 14.00000 15.00000 15.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
15.560 3156.00000 49.6000 -34.37500 -0.62500 3.57900 3.57900 12.70000 1.03400 1.03400 18.20000 1.00000 15.00000 14.00000 15.00000 15.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
15.570 3156.00000 49.6000 -34.37500 -0.62500 3.57900 3.57900 12.70000 1.03400 1.03400 18.20000 1.00000 15.00000 14.00000 15.00000 15.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
15.580 3184.00000 49.3000 -35.15625 -0.62500 3.50900 3.50900 13.40000 1.03400 1.03400 17.80000 1.00000 15.00000 15.00000 15.00000 15.00000 0.00000 0.00000 14.0000 0.000 0.000 0.000 0.000
15.590 3184.00000 49.3000 -35.15625 -0.62500 3.50900 3.50900 13.40000 1.03400 1.03400 17.80000 1.00000 15.00000 15.00000 15.00000 15.00000 0.00000 0.00000 14.0000 0.000 0.000 0.000 0.000
15.600 3184.00000 49.3000 -35.15625 -0.62500 3.50900 3.50900 13.40000 1.03400 1.03400 17.80000 1.00000 15.00000 15.00000 15.00000 15.00000 0.00000 0.00000 14.0000 0.000 0.000 0.000 0.000
15.610 3184.00000 49.3000 -35.15625 -0.62500 3.50900 3.50900 13.40000 1.03400 1.03400 17.80000 1.00000 15.00000 15.00000 15.00000 15.00000 0.00000 0.00000 14.0000 0.000 0.000 0.000 0.000
15.620 3184.00000 49.3000 -35.15625 -0.62500 3.50900 3.50900 13.40000 1.03400 1.03400 17.80000 1.00000 15.00000 15.00000 15.00000 15.00000 0.00000 0.00000 14.0000 0.000 0.000 0.000 0.000
15.630 3254.00000 49.2000 -36.71875 -0.50000 3.60800 3.60800 13.40000 1.03400 1.03400 17.50000 1.00000 15.00000 15.00000 15.00000 15.00000 0.00000 0.00000 14.0000 0.000 0.000 0.000 0.000
15.640 3254.00000 49.2000 -36.71875 -0.50000 3.60800 3.60800 13.40000 1.03400 1.03400 17.50000 1.00000 15.00000 15.00000 15.00000 15.00000 0.00000 0.00000 14.0000 0.000 0.000 0.000 0.000
15.650 3254.00000 49.2000 -36.71875 -0.50000 3.60800 3.60800 13.40000 1.03400 1.03400 17.50000 1.00000 15.00000 15.00000 15.00000 15.00000 0.00000 0.00000 14.0000 0.000 0.000 0.000 0.000
15.660 3254.00000 49.2000 -36.71875 -0.50000 3.60800 3.60800 13.40000 1.03400 1.03400 17.50000 1.00000 15.00000 15.00000 15.00000 15.00000 0.00000 0.00000 14.0000 0.000 0.000 0.000 0.000
15.670 3254.00000 49.2000 -36.71875 -0.50000 3.60800 3.60800 13.40000 1.03400 1.03400 17.50000 1.00000 15.00000 15.00000 15.00000 15.00000 0.00000 0.00000 14.0000 0.000 0.000 0.000 0.000
15.680 3221.00000 49.6000 -34.37500 -0.75000 3.63100 3.63100 12.40000 1.02100 1.02400 18.20000 1.00000 15.00000 15.00000 15.00000 15.00000 0.00000 0.00000 14.1000 0.000 0.000 0.000 0.000
15.690 3221.00000 49.6000 -34.37500 -0.75000 3.63100 3.63100 12.40000 1.02100 1.02400 18.20000 1.00000 15.00000 15.00000 15.00000 15.00000 0.00000 0.00000 14.1000 0.000 0.000 0.000 0.000
15.700 3221.00000 49.6000 -34.37500 -0.75000 3.63100 3.63100 12.40000 1.02100 1.02400 18.20000 1.00000 15.00000 15.00000 15.00000 15.00000 0.00000 0.00000 14.1000 0.000 0.000 0.000 0.000
15.710 3221.00000 49.6000 -34.37500 -0.75000 3.63100 3.63100 12.40000 1.02100 1.02400 18.20000 1.00000 15.00000 15.00000 15.00000 15.00000 0.00000 0.00000 14.1000 0.000 0.000 0.000 0.000
15.720 3221.00000 49.6000 -34.37500 -0.75000 3.63100 3.63100 12.40000 1.02100 1.02400 18.20000 1.00000 15.00000 15.00000 15.00000 15.00000 0.00000 0.00000 14.1000 0.000 0.000 0.000 0.000
15.730 3295.00000 49.5000 -32.03125 -0.75000 3.59700 3.59700 12.70000 1.02100 1.02400 19.00000 1.00000 15.00000 15.00000 16.00000 15.00000 0.00000 0.00000 14.0000 0.000 0.000 0.000 0.000
15.740 3295.00000 49.5000 -32.03125 -0.75000 3.59700 3.59700 12.70000 1.02100 1.02400 19.00000 1.00000 15.00000 15.00000 16.00000 15.00000 0.00000 0.00000 14.0000 0.000 0.000 0.000 0.000
15.750 3295.00000 49.5000 -32.03125 -0.75000 3.59700 3.59700 12.70000 1.02100 1.02400 19.00000 1.00000 15.00000 15.00000 16.00000 15.00000 0.00000 0.00000 14.0000 0.000 0.000 0.000 0.000
15.760 3295.00000 49.5000 -32.03125 -0.75000 3.59700 3.59700 12.70000 1.02100 1.02400 19.00000 1.00000 15.00000 15.00000 16.00000 15.00000 0.00000 0.00000 14.0000 0.000 0.000 0.000 0.000
15.770 3295.00000 49.5000 -32.03125 -0.75000 3.59700 3.59700 12.70000 1.02100 1.02400 19.00000 1.00000 15.00000 15.00000 16.00000 15.00000 0.00000 0.00000 14.0000 0.000 0.000 0.000 0.000
15.780 3239.00000 48.9000 -35.15625 -0.62500 3.59100 3.59100 12.10000 1.02100 1.02400 18.00000 1.00000 15.00000 15.00000 15.00000 15.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
15.790 3239.00000 48.9000 -35.15625 -0.62500 3.59100 3.59100 12.10000 1.02100 1.02400 18.00000 1.00000 15.00000 15.00000 15.00000 15.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
15.800 3239.00000 48.9000 -35.15625 -0.62500 3.59100 3.59100 12.10000 1.02100 1.02400 18.00000 1.00000 15.00000 15.00000 15.00000 15.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
15.810 3239.00000 48.9000 -35.15625 -0.62500 3.59100 3.59100 12.10000 1.02100 1.02400 18.00000 1.00000 15.00000 15.00000 15.00000 15.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
15.820 3239.00000 48.9000 -35.15625 -0.62500 3.59100 3.59100 12.10000 1.02100 1.02400 18.00000 1.00000 15.00000 15.00000 15.00000 15.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
15.830 3350.00000 49.3000 -34.37500 -0.75000 3.67200 3.67200 12.90000 1.02100 1.02400 18.10000 1.00000 16.00000 16.00000 16.00000 16.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
15.840 3350.00000 49.3000 -34.37500 -0.75000 3.67200 3.67200 12.90000 1.02100 1.02400 18.10000 1.00000 16.00000 16.00000 16.00000 16.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
15.850 3350.00000 49.3000 -34.37500 -0.75000 3.67200 3.67200 12.90000 1.02100 1.02400 18.10000 1.00000 16.00000 16.00000 16.00000 16.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
15.860 3350.00000 49.3000 -34.37500 -0.75000 3.67200 3.67200 12.90000 1.02100 1.02400 18.10000 1.00000 16.00000 16.00000 16.00000 16.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
15.870 3350.00000 49.3000 -34.37500 -0.75000 3.67200 3.67200 12.90000 1.02100 1.02400 18.10000 1.00000 16.00000 16.00000 16.00000 16.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
15.880 3294.00000 48.7000 -35.15625 -0.75000 3.66600 3.66600 12.20000 0.99900 1.00500 17.80000 1.00000 16.00000 16.00000 15.00000 15.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
15.890 3294.00000 48.7000 -35.15625 -0.75000 3.66600 3.66600 12.20000 0.99900 1.00500 17.80000 1.00000 16.00000 16.00000 15.00000 15.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
15.900 3294.00000 48.7000 -35.15625 -0.75000 3.66600 3.66600 12.20000 0.99900 1.00500 17.80000 1.00000 16.00000 16.00000 15.00000 15.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
15.910 3294.00000 48.7000 -35.15625 -0.75000 3.66600 3.66600 12.20000 0.99900 1.00500 17.80000 1.00000 16.00000 16.00000 15.00000 15.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
15.920 3294.00000 48.7000 -35.15625 -0.75000 3.66600 3.66600 12.20000 0.99900 1.00500 17.80000 1.00000 16.00000 16.00000 15.00000 15.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
15.930 3410.00000 49.5000 -34.37500 -0.75000 3.77700 3.77700 12.50000 0.99900 1.00500 18.00000 1.00000 16.00000 16.00000 16.00000 16.00000 0.00000 0.00000 14.5000 0.000 0.000 0.000 0.000
15.940 3410.00000 49.5000 -34.37500 -0.75000 3.77700 3.77700 12.50000 0.99900 1.00500 18.00000 1.00000 16.00000 16.00000 16.00000 16.00000 0.00000 0.00000 14.5000 0.000 0.000 0.000 0.000
15.950 3410.00000 49.5000 -34.37500 -0.75000 3.77700 3.77700 12.50000 0.99900 1.00500 18.00000 1.00000 16.00000 16.00000 16.00000 16.00000 0.00000 0.00000 14.5000 0.000 0.000 0.000 0.000
15.960 3410.00000 49.5000 -34.37500 -0.75000 3.77700 3.77700 12.50000 0.99900 1.00500 18.00000 1.00000 16.00000 16.00000 16.00000 16.00000 0.00000 0.00000 14.5000 0.000 0.000 0.000 0.000
15.970 3410.00000 49.5000 -34.37500 -0.75000 3.77700 3.77700 12.50000 0.99900 1.00500 18.00000 1.00000 16.00000 16.00000 16.00000 16.00000 0.00000 0.00000 14.5000 0.000 0.000 0.000 0.000
15.980 3348.00000 48.9000 -33.59375 -0.75000 3.72500 3.72500 12.80000 0.99900 1.00500 18.40000 1.00000 16.00000 16.00000 16.00000 16.00000 0.00000 0.00000 14.4000 0.000 0.000 0.000 0.000
15.990 3348.00000 48.9000 -33.59375 -0.75000 3.72500 3.72500 12.80000 0.99900 1.00500 18.40000 1.00000 16.00000 16.00000 16.00000 16.00000 0.00000 0.00000 14.4000 0.000 0.000 0.000 0.000
16.000 3348.00000 48.9000 -33.59375 -0.75000 3.72500 3.72500 12.80000 0.99900 1.00500 18.40000 1.00000 16.00000 16.00000 16.00000 16.00000 0.00000 0.00000 14.4000 0.000 0.000 0.000 0.000
16.010 3348.00000 48.9000 -33.59375 -0.75000 3.72500 3.72500 12.80000 0.99900 1.00500 18.40000 1.00000 16.00000 16.00000 16.00000 16.00000 0.00000 0.00000 14.4000 0.000 0.000 0.000 0.000
16.020 3348.00000 48.9000 -33.59375 -0.75000 3.72500 3.72500 12.80000 0.99900 1.00500 18.40000 1.00000 16.00000 16.00000 16.00000 16.00000 0.00000 0.00000 14.4000 0.000 0.000 0.000 0.000
16.030 3431.00000 48.7000 -34.37500 -0.75000 3.81200 3.81200 13.00000 0.99900 1.00500 18.00000 1.00000 16.00000 16.00000 16.00000 17.00000 0.00000 0.00000 14.6000 0.000 0.000 0.000 0.000
16.040 3431.00000 48.7000 -34.37500 -0.75000 3.81200 3.81200 13.00000 0.99900 1.00500 18.00000 1.00000 16.00000 16.00000 16.00000 17.00000 0.00000 0.00000 14.6000 0.000 0.000 0.000 0.000
16.050 3431.00000 48.7000 -34.37500 -0.75000 3.81200 3.81200 13.00000 0.99900 1.00500 18.00000 1.00000 16.00000 16.00000 16.00000 17.00000 0.00000 0.00000 14.6000 0.000 0.000 0.000 0.000
16.060 3431.00000 48.7000 -34.37500 -0.75000 3.81200 3.81200 13.00000 0.99900 1.00500 18.00000 1.00000 16.00000 16.00000 16.00000 17.00000 0.00000 0.00000 14.6000 0.000 0.000 0.000 0.000
16.070 3431.00000 48.7000 -34.37500 -0.75000 3.81200 3.81200 13.00000 0.99900 1.00500 18.00000 1.00000 16.00000 16.00000 16.00000 17.00000 0.00000 0.00000 14.6000 0.000 0.000 0.000 0.000
16.080 3384.00000 48.6000 -33.59375 -0.87500 3.84100 3.84100 12.40000 0.98900 0.99500 18.60000 1.00000 16.00000 16.00000 16.00000 16.00000 0.00000 0.00000 14.4000 0.000 0.000 0.000 0.000
16.090 3384.00000 48.6000 -33.59375 -0.87500 3.84100 3.84100 12.40000 0.98900 0.99500 18.60000 1.00000 16.00000 16.00000 16.00000 16.00000 0.00000 0.00000 14.4000 0.000 0.000 0.000 0.000
16.100 3384.00000 48.6000 -33.59375 -0.87500 3.84100 3.84100 12.40000 0.98900 0.99500 18.60000 1.00000 16.00000 16.00000 16.00000 16.00000 0.00000 0.00000 14.4000 0.000 0.000 0.000 0.000
16.110 3384.00000 48.6000 -33.59375 -0.87500 3.84100 3.84100 12.40000 0.98900 0.99500 18.60000 1.00000 16.00000 16.00000 16.00000 16.00000 0.00000 0.00000 14.4000 0.000 0.000 0.000 0.000
16.120 3384.00000 48.6000 -33.59375 -0.87500 3.84100 3.84100 12.40000 0.98900 0.99500 18.60000 1.00000 16.00000 16.00000 16.00000 16.00000 0.00000 0.00000 14.4000 0.000 0.000 0.000 0.000
16.130 3476.00000 48.9000 -33.59375 -0.75000 3.82400 3.82400 11.40000 0.98900 0.99500 18.40000 1.00000 16.00000 17.00000 16.00000 17.00000 0.00000 0.00000 14.5000 0.000 0.000 0.000 0.000
16.140 3476.00000 48.9000 -33.59375 -0.75000 3.82400 3.82400 11.40000 0.98900 0.99500 18.40000 1.00000 16.00000 17.00000 16.00000 17.00000 0.00000 0.00000 14.5000 0.000 0.000 0.000 0.000
16.150 3476.00000 48.9000 -33.59375 -0.75000 3.82400 3.82400 11.40000 0.98900 0.99500 18.40000 1.00000 16.00000 17.00000 16.00000 17.00000 0.00000 0.00000 14.5000 0.000 0.000 0.000 0.000
16.160 3476.00000 48.9000 -33.59375 -0.75000 3.82400 3.82400 11.40000 0.98900 0.99500 18.40000 1.00000 16.00000 17.00000 16.00000 17.00000 0.00000 0.00000 14.5000 0.000 0.000 0.000 0.000
16.170 3476.00000 48.9000 -33.59375 -0.75000 3.82400 3.82400 11.40000 0.98900 0.99500 18.40000 1.00000 16.00000 17.00000 16.00000 17.00000 0.00000 0.00000 14.5000 0.000 0.000 0.000 0.000
16.180 3424.00000 49.0000 -33.59375 -0.87500 3.81800 3.81800 12.60000 0.98900 0.99500 18.50000 1.00000 17.00000 16.00000 16.00000 16.00000 0.00000 0.00000 14.5000 0.000 0.000 0.000 0.000
16.190 3424.00000 49.0000 -33.59375 -0.87500 3.81800 3.81800 12.60000 0.98900 0.99500 18.50000 1.00000 17.00000 16.00000 16.00000 16.00000 0.00000 0.00000 14.5000 0.000 0.000 0.000 0.000
16.200 3424.00000 49.0000 -33.59375 -0.87500 3.81800 3.81800 12.60000 0.98900 0.99500 18.50000 1.00000 17.00000 16.00000 16.00000 16.00000 0.00000 0.00000 14.5000 0.000 0.000 0.000 0.000
16.210 3424.00000 49.0000 -33.59375 -0.87500 3.81800 3.81800 12.60000 0.98900 0.99500 18.50000 1.00000 17.00000 16.00000 16.00000 16.00000 0.00000 0.00000 14.5000 0.000 0.000 0.000 0.000
16.220 3424.00000 49.0000 -33.59375 -0.87500 3.81800 3.81800 12.60000 0.98900 0.99500 18.50000 1.00000 17.00000 16.00000 16.00000 16.00000 0.00000 0.00000 14.5000 0.000 0.000 0.000 0.000
16.230 3414.00000 48.2000 -33.59375 -0.87500 3.74800 3.74800 12.60000 0.98900 0.99500 18.50000 1.00000 21.00000 21.00000 22.00000 21.00000 0.00000 0.00000 14.6000 0.000 0.000 0.000 0.000
16.240 3414.00000 48.2000 -33.59375 -0.87500 3.74800 3.74800 12.60000 0.98900 0.99500 18.50000 1.00000 21.00000 21.00000 22.00000 21.00000 0.00000 0.00000 14.6000 0.000 0.000 0.000 0.000
16.250 3414.00000 48.2000 -33.59375 -0.87500 3.74800 3.74800 12.60000 0.98900 0.99500 18.50000 1.00000 21.00000 21.00000 22.00000 21.00000 0.00000 0.00000 14.6000 0.000 0.000 0.000 0.000
16.260 3414.00000 48.2000 -33.59375 -0.87500 3.74800 3.74800 12.60000 0.98900 0.99500 18.50000 1.00000 21.00000 21.00000 22.00000 21.00000 0.00000 0.00000 14.6000 0.000 0.000 0.000 0.000
16.270 3414.00000 48.2000 -33.59375 -0.87500 3.74800 3.74800 12.60000 0.98900 0.99500 18.50000 1.00000 21.00000 21.00000 22.00000 21.00000 0.00000 0.00000 14.6000 0.000 0.000 0.000 0.000
16.280 3473.00000 47.2000 -32.81250 -0.87500 3.77700 3.77700 13.70000 0.82000 0.95100 18.80000 1.00000 21.00000 22.00000 21.00000 21.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
16.290 3473.00000 47.2000 -32.81250 -0.87500 3.77700 3.77700 13.70000 0.82000 0.95100 18.80000 1.00000 21.00000 22.00000 21.00000 21.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
16.300 3473.00000 47.2000 -32.81250 -0.87500 3.77700 3.77700 13.70000 0.82000 0.95100 18.80000 1.00000 21.00000 22.00000 21.00000 21.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
16.310 3473.00000 47.2000 -32.81250 -0.87500 3.77700 3.77700 13.70000 0.82000 0.95100 18.80000 1.00000 21.00000 22.00000 21.00000 21.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
16.320 3473.00000 47.2000 -32.81250 -0.87500 3.77700 3.77700 13.70000 0.82000 0.95100 18.80000 1.00000 21.00000 22.00000 21.00000 21.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
16.330 3646.00000 50.5000 -28.90625 -1.00000 3.91100 3.91100 13.10000 0.82000 0.95100 19.90000 1.00000 22.00000 22.00000 22.00000 22.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
16.340 3646.00000 50.5000 -28.90625 -1.00000 3.91100 3.91100 13.10000 0.82000 0.95100 19.90000 1.00000 22.00000 22.00000 22.00000 22.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
16.350 3646.00000 50.5000 -28.90625 -1.00000 3.91100 3.91100 13.10000 0.82000 0.95100 19.90000 1.00000 22.00000 22.00000 22.00000 22.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
16.360 3646.00000 50.5000 -28.90625 -1.00000 3.91100 3.91100 13.10000 0.82000 0.95100 19.90000 1.00000 22.00000 22.00000 22.00000 22.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
16.370 3646.00000 50.5000 -28.90625 -1.00000 3.91100 3.91100 13.10000 0.82000 0.95100 19.90000 1.00000 22.00000 22.00000 22.00000 22.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
16.380 3555.00000 49.2000 -32.03125 -1.00000 3.91100 3.91100 12.50000 0.82000 0.95100 19.10000 1.00000 22.00000 23.00000 22.00000 22.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
16.390 3555.00000 49.2000 -32.03125 -1.00000 3.91100 3.91100 12.50000 0.82000 0.95100 19.10000 1.00000 22.00000 23.00000 22.00000 22.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
16.400 3555.00000 49.2000 -32.03125 -1.00000 3.91100 3.91100 12.50000 0.82000 0.95100 19.10000 1.00000 22.00000 23.00000 22.00000 22.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
16.410 3555.00000 49.2000 -32.03125 -1.00000 3.91100 3.91100 12.50000 0.82000 0.95100 19.10000 1.00000 22.00000 23.00000 22.00000 22.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
16.420 3555.00000 49.2000 -32.03125 -1.00000 3.91100 3.91100 12.50000 0.82000 0.95100 19.10000 1.00000 22.00000 23.00000 22.00000 22.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
16.430 3503.00000 48.7000 -31.25000 -1.00000 3.86500 3.86500 12.60000 0.82000 0.95100 19.30000 1.00000 22.00000 22.00000 22.00000 22.00000 0.00000 0.00000 13.2000 0.000 0.000 0.000 0.000
16.440 3503.00000 48.7000 -31.25000 -1.00000 3.86500 3.86500 12.60000 0.82000 0.95100 19.30000 1.00000 22.00000 22.00000 22.00000 22.00000 0.00000 0.00000 13.2000 0.000 0.000 0.000 0.000
16.450 3503.00000 48.7000 -31.25000 -1.00000 3.86500 3.86500 12.60000 0.82000 0.95100 19.30000 1.00000 22.00000 22.00000 22.00000 22.00000 0.00000 0.00000 13.2000 0.000 0.000 0.000 0.000
16.460 3503.00000 48.7000 -31.25000 -1.00000 3.86500 3.86500 12.60000 0.82000 0.95100 19.30000 1.00000 22.00000 22.00000 22.00000 22.00000 0.00000 0.00000 13.2000 0.000 0.000 0.000 0.000
16.470 3503.00000 48.7000 -31.25000 -1.00000 3.86500 3.86500 12.60000 0.82000 0.95100 19.30000 1.00000 22.00000 22.00000 22.00000 22.00000 0.00000 0.00000 13.2000 0.000 0.000 0.000 0.000
16.480 3540.00000 48.6000 -28.12500 -1.25000 3.84700 3.84700 12.80000 1.08500 1.03700 20.00000 1.00000 23.00000 22.00000 22.00000 23.00000 0.00000 0.00000 13.2000 0.000 0.000 0.000 0.000
16.490 3540.00000 48.6000 -28.12500 -1.25000 3.84700 3.84700 12.80000 1.08500 1.03700 20.00000 1.00000 23.00000 22.00000 22.00000 23.00000 0.00000 0.00000 13.2000 0.000 0.000 0.000 0.000
16.500 3540.00000 48.6000 -28.12500 -1.25000 3.84700 3.84700 12.80000 1.08500 1.03700 20.00000 1.00000 23.00000 22.00000 22.00000 23.00000 0.00000 0.00000 13.2000 0.000 0.000 0.000 0.000
16.510 3540.00000 48.6000 -28.12500 -1.25000 3.84700 3.84700 12.80000 1.08500 1.03700 20.00000 1.00000 23.00000 22.00000 22.00000 23.00000 0.00000 0.00000 13.2000 0.000 0.000 0.000 0.000
16.520 3540.00000 48.6000 -28.12500 -1.25000 3.84700 3.84700 12.80000 1.08500 1.03700 20.00000 1.00000 23.00000 22.00000 22.00000 23.00000 0.00000 0.00000 13.2000 0.000 0.000 0.000 0.000
16.530 3599.00000 48.9000 -30.46875 -1.12500 3.95200 3.95200 13.40000 1.08500 1.03700 19.50000 1.00000 23.00000 23.00000 24.00000 23.00000 0.00000 0.00000 13.2000 0.000 0.000 0.000 0.000
16.540 3599.00000 48.9000 -30.46875 -1.12500 3.95200 3.95200 13.40000 1.08500 1.03700 19.50000 1.00000 23.00000 23.00000 24.00000 23.00000 0.00000 0.00000 13.2000 0.000 0.000 0.000 0.000
16.550 3599.00000 48.9000 -30.46875 -1.12500 3.95200 3.95200 13.40000 1.08500 1.03700 19.50000 1.00000 23.00000 23.00000 24.00000 23.00000 0.00000 0.00000 13.2000 0.000 0.000 0.000 0.000
16.560 3599.00000 48.9000 -30.46875 -1.12500 3.95200 3.95200 13.40000 1.08500 1.03700 19.50000 1.00000 23.00000 23.00000 24.00000 23.00000 0.00000 0.00000 13.2000 0.000 0.000 0.000 0.000
16.570 3599.00000 48.9000 -30.46875 -1.12500 3.95200 3.95200 13.40000 1.08500 1.03700 19.50000 1.00000 23.00000 23.00000 24.00000 23.00000 0.00000 0.00000 13.2000 0.000 0.000 0.000 0.000
16.580 3688.00000 48.7000 -29.68750 -1.12500 4.01600 4.01600 12.80000 1.08500 1.03700 19.70000 1.00000 25.00000 23.00000 23.00000 24.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
16.590 3688.00000 48.7000 -29.68750 -1.12500 4.01600 4.01600 12.80000 1.08500 1.03700 19.70000 1.00000 25.00000 23.00000 23.00000 24.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
16.600 3688.00000 48.7000 -29.68750 -1.12500 4.01600 4.01600 12.80000 1.08500 1.03700 19.70000 1.00000 25.00000 23.00000 23.00000 24.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
16.610 3650.00000 48.1000 -29.68750 -1.12500 3.97500 3.97500 12.90000 1.10700 1.08800 19.70000 1.00000 23.00000 25.00000 24.00000 23.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
16.620 3650.00000 48.1000 -29.68750 -1.12500 3.97500 3.97500 12.90000 1.10700 1.08800 19.70000 1.00000 23.00000 25.00000 24.00000 23.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
16.630 3650.00000 48.1000 -29.68750 -1.12500 3.97500 3.97500 12.90000 1.10700 1.08800 19.70000 1.00000 23.00000 25.00000 24.00000 23.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
16.640 3650.00000 48.1000 -29.68750 -1.12500 3.97500 3.97500 12.90000 1.10700 1.08800 19.70000 1.00000 23.00000 25.00000 24.00000 23.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
16.650 3650.00000 48.1000 -29.68750 -1.12500 3.97500 3.97500 12.90000 1.10700 1.08800 19.70000 1.00000 23.00000 25.00000 24.00000 23.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
16.660 3650.00000 48.1000 -29.68750 -1.12500 3.97500 3.97500 12.90000 1.10700 1.08800 19.70000 1.00000 23.00000 25.00000 24.00000 23.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
16.670 3650.00000 48.1000 -29.68750 -1.12500 3.97500 3.97500 12.90000 1.10700 1.08800 19.70000 1.00000 23.00000 25.00000 24.00000 23.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
16.680 3676.00000 48.7000 -28.90625 -1.12500 4.07500 4.07500 12.80000 1.10700 1.08800 19.90000 1.00000 24.00000 25.00000 24.00000 23.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
16.690 3676.00000 48.7000 -28.90625 -1.12500 4.07500 4.07500 12.80000 1.10700 1.08800 19.90000 1.00000 24.00000 25.00000 24.00000 23.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
16.700 3676.00000 48.7000 -28.90625 -1.12500 4.07500 4.07500 12.80000 1.10700 1.08800 19.90000 1.00000 24.00000 25.00000 24.00000 23.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
16.710 3676.00000 48.7000 -28.90625 -1.12500 4.07500 4.07500 12.80000 1.10700 1.08800 19.90000 1.00000 24.00000 25.00000 24.00000 23.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
16.720 3676.00000 48.7000 -28.90625 -1.12500 4.07500 4.07500 12.80000 1.10700 1.08800 19.90000 1.00000 24.00000 25.00000 24.00000 23.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
16.730 3708.00000 48.7000 -25.00000 -1.37500 4.05100 4.05100 12.70000 1.10700 1.08800 20.70000 1.00000 25.00000 25.00000 25.00000 25.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
16.740 3708.00000 48.7000 -25.00000 -1.37500 4.05100 4.05100 12.70000 1.10700 1.08800 20.70000 1.00000 25.00000 25.00000 25.00000 25.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
16.750 3708.00000 48.7000 -25.00000 -1.37500 4.05100 4.05100 12.70000 1.10700 1.08800 20.70000 1.00000 25.00000 25.00000 25.00000 25.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
16.760 3708.00000 48.7000 -25.00000 -1.37500 4.05100 4.05100 12.70000 1.10700 1.08800 20.70000 1.00000 25.00000 25.00000 25.00000 25.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
16.770 3708.00000 48.7000 -25.00000 -1.37500 4.05100 4.05100 12.70000 1.10700 1.08800 20.70000 1.00000 25.00000 25.00000 25.00000 25.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
16.780 3708.00000 48.7000 -25.00000 -1.37500 4.05100 4.05100 12.70000 1.10700 1.08800 20.70000 1.00000 25.00000 25.00000 25.00000 25.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
16.790 3708.00000 48.7000 -25.00000 -1.37500 4.05100 4.05100 12.70000 1.10700 1.08800 20.70000 1.00000 25.00000 25.00000 25.00000 25.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
16.800 3708.00000 48.7000 -25.00000 -1.37500 4.05100 4.05100 12.70000 1.10700 1.08800 20.70000 1.00000 25.00000 25.00000 25.00000 25.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
16.810 3708.00000 48.7000 -25.00000 -1.37500 4.05100 4.05100 12.70000 1.10700 1.08800 20.70000 1.00000 25.00000 25.00000 25.00000 25.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
16.820 3708.00000 48.7000 -25.00000 -1.37500 4.05100 4.05100 12.70000 1.10700 1.08800 20.70000 1.00000 25.00000 25.00000 25.00000 25.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
16.830 3774.00000 48.4000 -28.12500 -1.25000 4.06900 4.06900 11.90000 1.10700 1.08800 20.10000 1.00000 20.00000 17.00000 25.00000 26.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
16.840 3774.00000 48.4000 -28.12500 -1.25000 4.06900 4.06900 11.90000 1.10700 1.08800 20.10000 1.00000 20.00000 17.00000 25.00000 26.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
16.850 3774.00000 48.4000 -28.12500 -1.25000 4.06900 4.06900 11.90000 1.10700 1.08800 20.10000 1.00000 20.00000 17.00000 25.00000 26.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
16.860 3774.00000 48.4000 -28.12500 -1.25000 4.06900 4.06900 11.90000 1.10700 1.08800 20.10000 1.00000 20.00000 17.00000 25.00000 26.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
16.870 3774.00000 48.4000 -28.12500 -1.25000 4.06900 4.06900 11.90000 1.10700 1.08800 20.10000 1.00000 20.00000 17.00000 25.00000 26.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
16.880 3720.00000 49.0000 -17.96875 -1.37500 4.17900 4.17900 11.50000 1.12000 1.10400 22.20000 1.00000 20.00000 18.00000 18.00000 19.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
16.890 3720.00000 49.0000 -17.96875 -1.37500 4.17900 4.17900 11.50000 1.12000 1.10400 22.20000 1.00000 20.00000 18.00000 18.00000 19.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
16.900 3720.00000 49.0000 -17.96875 -1.37500 4.17900 4.17900 11.50000 1.12000 1.10400 22.20000 1.00000 20.00000 18.00000 18.00000 19.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
16.910 3720.00000 49.0000 -17.96875 -1.37500 4.17900 4.17900 11.50000 1.12000 1.10400 22.20000 1.00000 20.00000 18.00000 18.00000 19.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
16.920 3720.00000 49.0000 -17.96875 -1.37500 4.17900 4.17900 11.50000 1.12000 1.10400 22.20000 1.00000 20.00000 18.00000 18.00000 19.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
16.930 3893.00000 49.0000 -23.43750 -1.37500 4.16200 4.16200 13.30000 1.12000 1.10400 21.10000 1.00000 20.00000 19.00000 19.00000 20.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
16.940 3893.00000 49.0000 -23.43750 -1.37500 4.16200 4.16200 13.30000 1.12000 1.10400 21.10000 1.00000 20.00000 19.00000 19.00000 20.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
16.950 3893.00000 49.0000 -23.43750 -1.37500 4.16200 4.16200 13.30000 1.12000 1.10400 21.10000 1.00000 20.00000 19.00000 19.00000 20.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
16.960 3893.00000 49.0000 -23.43750 -1.37500 4.16200 4.16200 13.30000 1.12000 1.10400 21.10000 1.00000 20.00000 19.00000 19.00000 20.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
16.970 3893.00000 49.0000 -23.43750 -1.37500 4.16200 4.16200 13.30000 1.12000 1.10400 21.10000 1.00000 20.00000 19.00000 19.00000 20.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
16.980 3843.00000 48.1000 -28.12500 -1.25000 4.12700 4.12700 12.70000 1.12000 1.10400 20.10000 1.00000 19.00000 20.00000 21.00000 19.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
16.990 3843.00000 48.1000 -28.12500 -1.25000 4.12700 4.12700 12.70000 1.12000 1.10400 20.10000 1.00000 19.00000 20.00000 21.00000 19.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
17.000 3843.00000 48.1000 -28.12500 -1.25000 4.12700 4.12700 12.70000 1.12000 1.10400 20.10000 1.00000 19.00000 20.00000 21.00000 19.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
17.010 3843.00000 48.1000 -28.12500 -1.25000 4.12700 4.12700 12.70000 1.12000 1.10400 20.10000 1.00000 19.00000 20.00000 21.00000 19.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
17.020 3843.00000 48.1000 -28.12500 -1.25000 4.12700 4.12700 12.70000 1.12000 1.10400 20.10000 1.00000 19.00000 20.00000 21.00000 19.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
17.030 3906.00000 47.6000 -27.34375 -1.25000 4.13900 4.13900 13.60000 1.12000 1.10400 20.20000 1.00000 20.00000 20.00000 21.00000 20.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
17.040 3906.00000 47.6000 -27.34375 -1.25000 4.13900 4.13900 13.60000 1.12000 1.10400 20.20000 1.00000 20.00000 20.00000 21.00000 20.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
17.050 3906.00000 47.6000 -27.34375 -1.25000 4.13900 4.13900 13.60000 1.12000 1.10400 20.20000 1.00000 20.00000 20.00000 21.00000 20.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
17.060 3906.00000 47.6000 -27.34375 -1.25000 4.13900 4.13900 13.60000 1.12000 1.10400 20.20000 1.00000 20.00000 20.00000 21.00000 20.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
17.070 3906.00000 47.6000 -27.34375 -1.25000 4.13900 4.13900 13.60000 1.12000 1.10400 20.20000 1.00000 20.00000 20.00000 21.00000 20.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
17.080 3836.00000 46.9000 -27.34375 -1.25000 4.28400 4.28400 13.40000 1.06600 1.09100 20.30000 1.00000 20.00000 19.00000 19.00000 21.00000 0.00000 0.00000 12.2000 0.000 0.000 0.000 0.000
17.090 3836.00000 46.9000 -27.34375 -1.25000 4.28400 4.28400 13.40000 1.06600 1.09100 20.30000 1.00000 20.00000 19.00000 19.00000 21.00000 0.00000 0.00000 12.2000 0.000 0.000 0.000 0.000
17.100 3836.00000 46.9000 -27.34375 -1.25000 4.28400 4.28400 13.40000 1.06600 1.09100 20.30000 1.00000 20.00000 19.00000 19.00000 21.00000 0.00000 0.00000 12.2000 0.000 0.000 0.000 0.000
17.110 3836.00000 46.9000 -27.34375 -1.25000 4.28400 4.28400 13.40000 1.06600 1.09100 20.30000 1.00000 20.00000 19.00000 19.00000 21.00000 0.00000 0.00000 12.2000 0.000 0.000 0.000 0.000
17.120 3836.00000 46.9000 -27.34375 -1.25000 4.28400 4.28400 13.40000 1.06600 1.09100 20.30000 1.00000 20.00000 19.00000 19.00000 21.00000 0.00000 0.00000 12.2000 0.000 0.000 0.000 0.000
17.130 3861.00000 47.0000 -22.65625 -1.50000 4.23800 4.23800 14.00000 1.06600 1.09100 21.30000 1.00000 20.00000 20.00000 20.00000 21.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
17.140 3861.00000 47.0000 -22.65625 -1.50000 4.23800 4.23800 14.00000 1.06600 1.09100 21.30000 1.00000 20.00000 20.00000 20.00000 21.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
17.150 3861.00000 47.0000 -22.65625 -1.50000 4.23800 4.23800 14.00000 1.06600 1.09100 21.30000 1.00000 20.00000 20.00000 20.00000 21.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
17.160 3861.00000 47.0000 -22.65625 -1.50000 4.23800 4.23800 14.00000 1.06600 1.09100 21.30000 1.00000 20.00000 20.00000 20.00000 21.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
17.170 3861.00000 47.0000 -22.65625 -1.50000 4.23800 4.23800 14.00000 1.06600 1.09100 21.30000 1.00000 20.00000 20.00000 20.00000 21.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
17.180 3910.00000 47.6000 -19.53125 -1.37500 4.27900 4.27900 12.40000 1.06600 1.09100 21.80000 1.00000 20.00000 21.00000 21.00000 19.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
17.190 3910.00000 47.6000 -19.53125 -1.37500 4.27900 4.27900 12.40000 1.06600 1.09100 21.80000 1.00000 20.00000 21.00000 21.00000 19.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
17.200 3910.00000 47.6000 -19.53125 -1.37500 4.27900 4.27900 12.40000 1.06600 1.09100 21.80000 1.00000 20.00000 21.00000 21.00000 19.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
17.210 3910.00000 47.6000 -19.53125 -1.37500 4.27900 4.27900 12.40000 1.06600 1.09100 21.80000 1.00000 20.00000 21.00000 21.00000 19.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
17.220 3910.00000 47.6000 -19.53125 -1.37500 4.27900 4.27900 12.40000 1.06600 1.09100 21.80000 1.00000 20.00000 21.00000 21.00000 19.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
17.230 3901.00000 46.7000 -17.96875 -1.37500 4.31400 4.31400 13.20000 1.06600 1.09100 22.30000 1.00000 21.00000 20.00000 19.00000 22.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
17.240 3901.00000 46.7000 -17.96875 -1.37500 4.31400 4.31400 13.20000 1.06600 1.09100 22.30000 1.00000 21.00000 20.00000 19.00000 22.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
17.250 3901.00000 46.7000 -17.96875 -1.37500 4.31400 4.31400 13.20000 1.06600 1.09100 22.30000 1.00000 21.00000 20.00000 19.00000 22.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
17.260 3901.00000 46.7000 -17.96875 -1.37500 4.31400 4.31400 13.20000 1.06600 1.09100 22.30000 1.00000 21.00000 20.00000 19.00000 22.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
17.270 3901.00000 46.7000 -17.96875 -1.37500 4.31400 4.31400 13.20000 1.06600 1.09100 22.30000 1.00000 21.00000 20.00000 19.00000 22.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
17.280 3916.00000 46.9000 -18.75000 -1.50000 4.28400 4.28400 12.40000 0.96300 1.03700 22.10000 1.00000 19.00000 21.00000 22.00000 20.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
17.290 3916.00000 46.9000 -18.75000 -1.50000 4.28400 4.28400 12.40000 0.96300 1.03700 22.10000 1.00000 19.00000 21.00000 22.00000 20.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
17.300 3916.00000 46.9000 -18.75000 -1.50000 4.28400 4.28400 12.40000 0.96300 1.03700 22.10000 1.00000 19.00000 21.00000 22.00000 20.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
17.310 3916.00000 46.9000 -18.75000 -1.50000 4.28400 4.28400 12.40000 0.96300 1.03700 22.10000 1.00000 19.00000 21.00000 22.00000 20.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
17.320 3916.00000 46.9000 -18.75000 -1.50000 4.28400 4.28400 12.40000 0.96300 1.03700 22.10000 1.00000 19.00000 21.00000 22.00000 20.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
17.330 3980.00000 46.6000 -20.31250 -1.37500 4.33700 4.33700 13.40000 0.96300 1.03700 21.70000 1.00000 22.00000 19.00000 20.00000 21.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
17.340 3980.00000 46.6000 -20.31250 -1.37500 4.33700 4.33700 13.40000 0.96300 1.03700 21.70000 1.00000 22.00000 19.00000 20.00000 21.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
17.350 3980.00000 46.6000 -20.31250 -1.37500 4.33700 4.33700 13.40000 0.96300 1.03700 21.70000 1.00000 22.00000 19.00000 20.00000 21.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
17.360 3980.00000 46.6000 -20.31250 -1.37500 4.33700 4.33700 13.40000 0.96300 1.03700 21.70000 1.00000 22.00000 19.00000 20.00000 21.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
17.370 3980.00000 46.6000 -20.31250 -1.37500 4.33700 4.33700 13.40000 0.96300 1.03700 21.70000 1.00000 22.00000 19.00000 20.00000 21.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
17.380 4091.00000 46.7000 -25.00000 -1.37500 4.40700 4.40700 13.30000 0.96300 1.03700 20.70000 1.00000 21.00000 20.00000 23.00000 21.00000 0.00000 0.00000 14.6000 0.000 0.000 0.000 0.000
17.390 4091.00000 46.7000 -25.00000 -1.37500 4.40700 4.40700 13.30000 0.96300 1.03700 20.70000 1.00000 21.00000 20.00000 23.00000 21.00000 0.00000 0.00000 14.6000 0.000 0.000 0.000 0.000
17.400 4091.00000 46.7000 -25.00000 -1.37500 4.40700 4.40700 13.30000 0.96300 1.03700 20.70000 1.00000 21.00000 20.00000 23.00000 21.00000 0.00000 0.00000 14.6000 0.000 0.000 0.000 0.000
17.410 4091.00000 46.7000 -25.00000 -1.37500 4.40700 4.40700 13.30000 0.96300 1.03700 20.70000 1.00000 21.00000 20.00000 23.00000 21.00000 0.00000 0.00000 14.6000 0.000 0.000 0.000 0.000
17.420 4091.00000 46.7000 -25.00000 -1.37500 4.40700 4.40700 13.30000 0.96300 1.03700 20.70000 1.00000 21.00000 20.00000 23.00000 21.00000 0.00000 0.00000 14.6000 0.000 0.000 0.000 0.000
17.430 3998.00000 46.4000 -27.34375 -1.25000 4.35400 4.35400 13.40000 0.96300 1.03700 20.30000 1.00000 20.00000 21.00000 21.00000 20.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
17.440 3998.00000 46.4000 -27.34375 -1.25000 4.35400 4.35400 13.40000 0.96300 1.03700 20.30000 1.00000 20.00000 21.00000 21.00000 20.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
17.450 3998.00000 46.4000 -27.34375 -1.25000 4.35400 4.35400 13.40000 0.96300 1.03700 20.30000 1.00000 20.00000 21.00000 21.00000 20.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
17.460 3998.00000 46.4000 -27.34375 -1.25000 4.35400 4.35400 13.40000 0.96300 1.03700 20.30000 1.00000 20.00000 21.00000 21.00000 20.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
17.470 3998.00000 46.4000 -27.34375 -1.25000 4.35400 4.35400 13.40000 0.96300 1.03700 20.30000 1.00000 20.00000 21.00000 21.00000 20.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
17.480 4126.00000 46.9000 -27.34375 -1.50000 4.34300 4.34300 13.80000 0.98300 0.98900 20.20000 1.00000 22.00000 22.00000 20.00000 20.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
17.490 4126.00000 46.9000 -27.34375 -1.50000 4.34300 4.34300 13.80000 0.98300 0.98900 20.20000 1.00000 22.00000 22.00000 20.00000 20.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
17.500 4126.00000 46.9000 -27.34375 -1.50000 4.34300 4.34300 13.80000 0.98300 0.98900 20.20000 1.00000 22.00000 22.00000 20.00000 20.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
17.510 4126.00000 46.9000 -27.34375 -1.50000 4.34300 4.34300 13.80000 0.98300 0.98900 20.20000 1.00000 22.00000 22.00000 20.00000 20.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
17.520 4126.00000 46.9000 -27.34375 -1.50000 4.34300 4.34300 13.80000 0.98300 0.98900 20.20000 1.00000 22.00000 22.00000 20.00000 20.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
17.530 4154.00000 46.0000 -19.53125 -1.62500 4.34300 4.34300 12.80000 0.98300 0.98900 21.90000 1.00000 23.00000 20.00000 20.00000 20.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
17.540 4154.00000 46.0000 -19.53125 -1.62500 4.34300 4.34300 12.80000 0.98300 0.98900 21.90000 1.00000 23.00000 20.00000 20.00000 20.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
17.550 4154.00000 46.0000 -19.53125 -1.62500 4.34300 4.34300 12.80000 0.98300 0.98900 21.90000 1.00000 23.00000 20.00000 20.00000 20.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
17.560 4154.00000 46.0000 -19.53125 -1.62500 4.34300 4.34300 12.80000 0.98300 0.98900 21.90000 1.00000 23.00000 20.00000 20.00000 20.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
17.570 4154.00000 46.0000 -19.53125 -1.62500 4.34300 4.34300 12.80000 0.98300 0.98900 21.90000 1.00000 23.00000 20.00000 20.00000 20.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
17.580 4105.00000 46.1000 -17.96875 -1.50000 4.36600 4.36600 13.40000 0.98300 0.98900 22.30000 1.00000 22.00000 20.00000 20.00000 21.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
17.590 4105.00000 46.1000 -17.96875 -1.50000 4.36600 4.36600 13.40000 0.98300 0.98900 22.30000 1.00000 22.00000 20.00000 20.00000 21.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
17.600 4105.00000 46.1000 -17.96875 -1.50000 4.36600 4.36600 13.40000 0.98300 0.98900 22.30000 1.00000 22.00000 20.00000 20.00000 21.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
17.610 4105.00000 46.1000 -17.96875 -1.50000 4.36600 4.36600 13.40000 0.98300 0.98900 22.30000 1.00000 22.00000 20.00000 20.00000 21.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
17.620 4105.00000 46.1000 -17.96875 -1.50000 4.36600 4.36600 13.40000 0.98300 0.98900 22.30000 1.00000 22.00000 20.00000 20.00000 21.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
17.630 4200.00000 46.6000 -25.78125 -1.37500 4.38400 4.38400 13.30000 0.98300 0.98900 20.50000 1.00000 23.00000 20.00000 22.00000 21.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
17.640 4200.00000 46.6000 -25.78125 -1.37500 4.38400 4.38400 13.30000 0.98300 0.98900 20.50000 1.00000 23.00000 20.00000 22.00000 21.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
17.650 4200.00000 46.6000 -25.78125 -1.37500 4.38400 4.38400 13.30000 0.98300 0.98900 20.50000 1.00000 23.00000 20.00000 22.00000 21.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
17.660 4200.00000 46.6000 -25.78125 -1.37500 4.38400 4.38400 13.30000 0.98300 0.98900 20.50000 1.00000 23.00000 20.00000 22.00000 21.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
17.670 4200.00000 46.6000 -25.78125 -1.37500 4.38400 4.38400 13.30000 0.98300 0.98900 20.50000 1.00000 23.00000 20.00000 22.00000 21.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
17.680 4123.00000 46.6000 -21.87500 -1.50000 4.34900 4.34900 13.00000 0.77200 0.90000 21.40000 1.00000 23.00000 20.00000 20.00000 22.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
17.690 4123.00000 46.6000 -21.87500 -1.50000 4.34900 4.34900 13.00000 0.77200 0.90000 21.40000 1.00000 23.00000 20.00000 20.00000 22.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
17.700 4123.00000 46.6000 -21.87500 -1.50000 4.34900 4.34900 13.00000 0.77200 0.90000 21.40000 1.00000 23.00000 20.00000 20.00000 22.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
17.710 4123.00000 46.6000 -21.87500 -1.50000 4.34900 4.34900 13.00000 0.77200 0.90000 21.40000 1.00000 23.00000 20.00000 20.00000 22.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
17.720 4123.00000 46.6000 -21.87500 -1.50000 4.34900 4.34900 13.00000 0.77200 0.90000 21.40000 1.00000 23.00000 20.00000 20.00000 22.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
17.730 4226.00000 46.3000 -18.75000 -1.50000 4.37800 4.37800 12.70000 0.77200 0.90000 22.10000 1.00000 21.00000 20.00000 20.00000 23.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
17.740 4226.00000 46.3000 -18.75000 -1.50000 4.37800 4.37800 12.70000 0.77200 0.90000 22.10000 1.00000 21.00000 20.00000 20.00000 23.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
17.750 4226.00000 46.3000 -18.75000 -1.50000 4.37800 4.37800 12.70000 0.77200 0.90000 22.10000 1.00000 21.00000 20.00000 20.00000 23.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
17.760 4226.00000 46.3000 -18.75000 -1.50000 4.37800 4.37800 12.70000 0.77200 0.90000 22.10000 1.00000 21.00000 20.00000 20.00000 23.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
17.770 4226.00000 46.3000 -18.75000 -1.50000 4.37800 4.37800 12.70000 0.77200 0.90000 22.10000 1.00000 21.00000 20.00000 20.00000 23.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
17.780 4212.00000 46.3000 -27.34375 -1.50000 4.37800 4.37800 13.30000 0.77200 0.90000 20.20000 1.00000 21.00000 22.00000 20.00000 20.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
17.790 4212.00000 46.3000 -27.34375 -1.50000 4.37800 4.37800 13.30000 0.77200 0.90000 20.20000 1.00000 21.00000 22.00000 20.00000 20.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
17.800 4212.00000 46.3000 -27.34375 -1.50000 4.37800 4.37800 13.30000 0.77200 0.90000 20.20000 1.00000 21.00000 22.00000 20.00000 20.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
17.810 4212.00000 46.3000 -27.34375 -1.50000 4.37800 4.37800 13.30000 0.77200 0.90000 20.20000 1.00000 21.00000 22.00000 20.00000 20.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
17.820 4212.00000 46.3000 -27.34375 -1.50000 4.37800 4.37800 13.30000 0.77200 0.90000 20.20000 1.00000 21.00000 22.00000 20.00000 20.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
17.830 4212.00000 46.3000 -27.34375 -1.50000 4.37800 4.37800 13.30000 0.77200 0.90000 20.20000 1.00000 21.00000 22.00000 20.00000 20.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
17.840 4219.00000 46.6000 -26.56250 -1.50000 4.37200 4.37200 13.20000 0.77200 0.90000 20.40000 1.00000 22.00000 21.00000 22.00000 21.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
17.850 4219.00000 46.6000 -26.56250 -1.50000 4.37200 4.37200 13.20000 0.77200 0.90000 20.40000 1.00000 22.00000 21.00000 22.00000 21.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
17.860 4219.00000 46.6000 -26.56250 -1.50000 4.37200 4.37200 13.20000 0.77200 0.90000 20.40000 1.00000 22.00000 21.00000 22.00000 21.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
17.870 4219.00000 46.6000 -26.56250 -1.50000 4.37200 4.37200 13.20000 0.77200 0.90000 20.40000 1.00000 22.00000 21.00000 22.00000 21.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
17.880 4219.00000 46.6000 -26.56250 -1.50000 4.37200 4.37200 13.20000 0.77200 0.90000 20.40000 1.00000 22.00000 21.00000 22.00000 21.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
17.890 4281.00000 46.1000 -16.40625 -1.50000 4.41900 4.41900 13.70000 0.30900 0.75000 22.50000 1.00000 20.00000 21.00000 21.00000 23.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
17.900 4281.00000 46.1000 -16.40625 -1.50000 4.41900 4.41900 13.70000 0.30900 0.75000 22.50000 1.00000 20.00000 21.00000 21.00000 23.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
17.910 4281.00000 46.1000 -16.40625 -1.50000 4.41900 4.41900 13.70000 0.30900 0.75000 22.50000 1.00000 20.00000 21.00000 21.00000 23.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
17.920 4281.00000 46.1000 -16.40625 -1.50000 4.41900 4.41900 13.70000 0.30900 0.75000 22.50000 1.00000 20.00000 21.00000 21.00000 23.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
17.930 4281.00000 46.1000 -16.40625 -1.50000 4.41900 4.41900 13.70000 0.30900 0.75000 22.50000 1.00000 20.00000 21.00000 21.00000 23.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
17.940 4214.00000 46.3000 -28.12500 -1.50000 4.44800 4.44800 13.40000 0.30900 0.75000 20.10000 1.00000 22.00000 22.00000 20.00000 20.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
17.950 4214.00000 46.3000 -28.12500 -1.50000 4.44800 4.44800 13.40000 0.30900 0.75000 20.10000 1.00000 22.00000 22.00000 20.00000 20.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
17.960 4214.00000 46.3000 -28.12500 -1.50000 4.44800 4.44800 13.40000 0.30900 0.75000 20.10000 1.00000 22.00000 22.00000 20.00000 20.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
17.970 4214.00000 46.3000 -28.12500 -1.50000 4.44800 4.44800 13.40000 0.30900 0.75000 20.10000 1.00000 22.00000 22.00000 20.00000 20.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
17.980 4214.00000 46.3000 -28.12500 -1.50000 4.44800 4.44800 13.40000 0.30900 0.75000 20.10000 1.00000 22.00000 22.00000 20.00000 20.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
17.990 4371.00000 47.6000 -21.09375 -1.50000 4.56400 4.45000 13.10000 0.30900 0.75000 21.50000 1.00000 21.00000 21.00000 24.00000 22.00000 0.00000 0.00000 15.9000 0.000 0.000 0.000 0.000
18.000 4371.00000 47.6000 -21.09375 -1.50000 4.56400 4.45000 13.10000 0.30900 0.75000 21.50000 1.00000 21.00000 21.00000 24.00000 22.00000 0.00000 0.00000 15.9000 0.000 0.000 0.000 0.000
18.010 4371.00000 47.6000 -21.09375 -1.50000 4.56400 4.45000 13.10000 0.30900 0.75000 21.50000 1.00000 21.00000 21.00000 24.00000 22.00000 0.00000 0.00000 15.9000 0.000 0.000 0.000 0.000
18.020 4371.00000 47.6000 -21.09375 -1.50000 4.56400 4.45000 13.10000 0.30900 0.75000 21.50000 1.00000 21.00000 21.00000 24.00000 22.00000 0.00000 0.00000 15.9000 0.000 0.000 0.000 0.000
18.030 4371.00000 47.6000 -21.09375 -1.50000 4.56400 4.45000 13.10000 0.30900 0.75000 21.50000 1.00000 21.00000 21.00000 24.00000 22.00000 0.00000 0.00000 15.9000 0.000 0.000 0.000 0.000
18.040 4415.00000 47.5000 -12.50000 -1.62500 4.47700 4.45000 12.70000 0.30900 0.75000 23.40000 1.00000 23.00000 22.00000 21.00000 22.00000 0.00000 0.00000 15.8000 0.000 0.000 0.000 0.000
18.050 4415.00000 47.5000 -12.50000 -1.62500 4.47700 4.45000 12.70000 0.30900 0.75000 23.40000 1.00000 23.00000 22.00000 21.00000 22.00000 0.00000 0.00000 15.8000 0.000 0.000 0.000 0.000
18.060 4415.00000 47.5000 -12.50000 -1.62500 4.47700 4.45000 12.70000 0.30900 0.75000 23.40000 1.00000 23.00000 22.00000 21.00000 22.00000 0.00000 0.00000 15.8000 0.000 0.000 0.000 0.000
18.070 4415.00000 47.5000 -12.50000 -1.62500 4.47700 4.45000 12.70000 0.30900 0.75000 23.40000 1.00000 23.00000 22.00000 21.00000 22.00000 0.00000 0.00000 15.8000 0.000 0.000 0.000 0.000
18.080 4415.00000 47.5000 -12.50000 -1.62500 4.47700 4.45000 12.70000 0.30900 0.75000 23.40000 1.00000 23.00000 22.00000 21.00000 22.00000 0.00000 0.00000 15.8000 0.000 0.000 0.000 0.000
18.090 4331.00000 46.1000 -27.34375 -1.50000 4.40100 4.40100 12.20000 0.27700 0.32200 20.30000 1.00000 21.00000 22.00000 21.00000 23.00000 0.00000 0.00000 15.9000 0.000 0.000 0.000 0.000
18.100 4331.00000 46.1000 -27.34375 -1.50000 4.40100 4.40100 12.20000 0.27700 0.32200 20.30000 1.00000 21.00000 22.00000 21.00000 23.00000 0.00000 0.00000 15.9000 0.000 0.000 0.000 0.000
18.110 4331.00000 46.1000 -27.34375 -1.50000 4.40100 4.40100 12.20000 0.27700 0.32200 20.30000 1.00000 21.00000 22.00000 21.00000 23.00000 0.00000 0.00000 15.9000 0.000 0.000 0.000 0.000
18.120 4331.00000 46.1000 -27.34375 -1.50000 4.40100 4.40100 12.20000 0.27700 0.32200 20.30000 1.00000 21.00000 22.00000 21.00000 23.00000 0.00000 0.00000 15.9000 0.000 0.000 0.000 0.000
18.130 4331.00000 46.1000 -27.34375 -1.50000 4.40100 4.40100 12.20000 0.27700 0.32200 20.30000 1.00000 21.00000 22.00000 21.00000 23.00000 0.00000 0.00000 15.9000 0.000 0.000 0.000 0.000
18.140 4412.00000 44.9000 -25.78125 -1.37500 4.50600 4.45000 13.30000 0.27700 0.32200 20.60000 1.00000 21.00000 21.00000 21.00000 21.00000 0.00000 0.00000 15.9000 0.000 0.000 0.000 0.000
18.150 4412.00000 44.9000 -25.78125 -1.37500 4.50600 4.45000 13.30000 0.27700 0.32200 20.60000 1.00000 21.00000 21.00000 21.00000 21.00000 0.00000 0.00000 15.9000 0.000 0.000 0.000 0.000
18.160 4412.00000 44.9000 -25.78125 -1.37500 4.50600 4.45000 13.30000 0.27700 0.32200 20.60000 1.00000 21.00000 21.00000 21.00000 21.00000 0.00000 0.00000 15.9000 0.000 0.000 0.000 0.000
18.170 4412.00000 44.9000 -25.78125 -1.37500 4.50600 4.45000 13.30000 0.27700 0.32200 20.60000 1.00000 21.00000 21.00000 21.00000 21.00000 0.00000 0.00000 15.9000 0.000 0.000 0.000 0.000
18.180 4412.00000 44.9000 -25.78125 -1.37500 4.50600 4.45000 13.30000 0.27700 0.32200 20.60000 1.00000 21.00000 21.00000 21.00000 21.00000 0.00000 0.00000 15.9000 0.000 0.000 0.000 0.000
18.190 4378.00000 18.0000 -44.53125 -0.62500 2.57000 2.57000 13.40000 0.27700 0.32200 13.70000 1.00000 12.00000 13.00000 11.00000 7.00000 0.00000 0.00000 15.9000 0.000 0.000 0.000 0.000
18.200 4378.00000 18.0000 -44.53125 -0.62500 2.57000 2.57000 13.40000 0.27700 0.32200 13.70000 1.00000 12.00000 13.00000 11.00000 7.00000 0.00000 0.00000 15.9000 0.000 0.000 0.000 0.000
18.210 4378.00000 18.0000 -44.53125 -0.62500 2.57000 2.57000 13.40000 0.27700 0.32200 13.70000 1.00000 12.00000 13.00000 11.00000 7.00000 0.00000 0.00000 15.9000 0.000 0.000 0.000 0.000
18.220 4378.00000 18.0000 -44.53125 -0.62500 2.57000 2.57000 13.40000 0.27700 0.32200 13.70000 1.00000 12.00000 13.00000 11.00000 7.00000 0.00000 0.00000 15.9000 0.000 0.000 0.000 0.000
18.230 4378.00000 18.0000 -44.53125 -0.62500 2.57000 2.57000 13.40000 0.27700 0.32200 13.70000 1.00000 12.00000 13.00000 11.00000 7.00000 0.00000 0.00000 15.9000 0.000 0.000 0.000 0.000
18.240 4357.00000 15.2000 -44.53125 0.00000 1.64900 1.64900 13.80000 0.27700 0.32200 8.00000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 16.0000 0.000 0.000 0.000 0.000
18.250 4357.00000 15.2000 -44.53125 0.00000 1.64900 1.64900 13.80000 0.27700 0.32200 8.00000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 16.0000 0.000 0.000 0.000 0.000
18.260 4357.00000 15.2000 -44.53125 0.00000 1.64900 1.64900 13.80000 0.27700 0.32200 8.00000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 16.0000 0.000 0.000 0.000 0.000
18.270 4357.00000 15.2000 -44.53125 0.00000 1.64900 1.64900 13.80000 0.27700 0.32200 8.00000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 16.0000 0.000 0.000 0.000 0.000
18.280 4357.00000 15.2000 -44.53125 0.00000 1.64900 1.64900 13.80000 0.27700 0.32200 8.00000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 16.0000 0.000 0.000 0.000 0.000
18.290 4146.00000 15.2000 -44.53125 0.00000 1.66100 1.66100 12.10000 1.08200 0.29300 5.60000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
18.300 4146.00000 15.2000 -44.53125 0.00000 1.66100 1.66100 12.10000 1.08200 0.29300 5.60000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
18.310 4146.00000 15.2000 -44.53125 0.00000 1.66100 1.66100 12.10000 1.08200 0.29300 5.60000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
18.320 4146.00000 15.2000 -44.53125 0.00000 1.66100 1.66100 12.10000 1.08200 0.29300 5.60000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
18.330 4146.00000 15.2000 -44.53125 0.00000 1.66100 1.66100 12.10000 1.08200 0.29300 5.60000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
18.340 4010.00000 15.2000 -44.53125 0.00000 2.79200 2.79200 13.20000 1.08200 0.29300 4.70000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
18.350 4010.00000 15.2000 -44.53125 0.00000 2.79200 2.79200 13.20000 1.08200 0.29300 4.70000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
18.360 4010.00000 15.2000 -44.53125 0.00000 2.79200 2.79200 13.20000 1.08200 0.29300 4.70000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
18.370 4010.00000 15.2000 -44.53125 0.00000 2.79200 2.79200 13.20000 1.08200 0.29300 4.70000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
18.380 4010.00000 15.2000 -44.53125 0.00000 2.79200 2.79200 13.20000 1.08200 0.29300 4.70000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
18.390 4350.00000 15.1000 -44.53125 0.00000 2.87400 2.87400 13.60000 1.08200 0.29300 4.70000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
18.400 4350.00000 15.1000 -44.53125 0.00000 2.87400 2.87400 13.60000 1.08200 0.29300 4.70000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
18.410 4350.00000 15.1000 -44.53125 0.00000 2.87400 2.87400 13.60000 1.08200 0.29300 4.70000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
18.420 4350.00000 15.1000 -44.53125 0.00000 2.87400 2.87400 13.60000 1.08200 0.29300 4.70000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
18.430 4350.00000 15.1000 -44.53125 0.00000 2.87400 2.87400 13.60000 1.08200 0.29300 4.70000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
18.440 4180.00000 15.2000 -44.53125 0.00000 2.24400 2.24400 12.80000 1.08200 0.29300 4.30000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 10.8000 0.000 0.000 0.000 0.000
18.450 4180.00000 15.2000 -44.53125 0.00000 2.24400 2.24400 12.80000 1.08200 0.29300 4.30000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 10.8000 0.000 0.000 0.000 0.000
18.460 4180.00000 15.2000 -44.53125 0.00000 2.24400 2.24400 12.80000 1.08200 0.29300 4.30000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 10.8000 0.000 0.000 0.000 0.000
18.470 4180.00000 15.2000 -44.53125 0.00000 2.24400 2.24400 12.80000 1.08200 0.29300 4.30000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 10.8000 0.000 0.000 0.000 0.000
18.480 4180.00000 15.2000 -44.53125 0.00000 2.24400 2.24400 12.80000 1.08200 0.29300 4.30000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 10.8000 0.000 0.000 0.000 0.000
18.490 4085.00000 15.5000 -44.53125 0.00000 2.24400 2.24400 11.90000 0.94400 1.09100 4.10000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 10.7000 0.000 0.000 0.000 0.000
18.500 4085.00000 15.5000 -44.53125 0.00000 2.24400 2.24400 11.90000 0.94400 1.09100 4.10000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 10.7000 0.000 0.000 0.000 0.000
18.510 4085.00000 15.5000 -44.53125 0.00000 2.24400 2.24400 11.90000 0.94400 1.09100 4.10000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 10.7000 0.000 0.000 0.000 0.000
18.520 4085.00000 15.5000 -44.53125 0.00000 2.24400 2.24400 11.90000 0.94400 1.09100 4.10000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 10.7000 0.000 0.000 0.000 0.000
18.530 4085.00000 15.5000 -44.53125 0.00000 2.24400 2.24400 11.90000 0.94400 1.09100 4.10000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 10.7000 0.000 0.000 0.000 0.000
18.540 3996.00000 15.4000 -44.53125 0.00000 2.08100 2.08100 12.50000 0.94400 1.09100 4.10000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 10.7000 0.000 0.000 0.000 0.000
18.550 3996.00000 15.4000 -44.53125 0.00000 2.08100 2.08100 12.50000 0.94400 1.09100 4.10000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 10.7000 0.000 0.000 0.000 0.000
18.560 3996.00000 15.4000 -44.53125 0.00000 2.08100 2.08100 12.50000 0.94400 1.09100 4.10000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 10.7000 0.000 0.000 0.000 0.000
18.570 3996.00000 15.4000 -44.53125 0.00000 2.08100 2.08100 12.50000 0.94400 1.09100 4.10000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 10.7000 0.000 0.000 0.000 0.000
18.580 3996.00000 15.4000 -44.53125 0.00000 2.08100 2.08100 12.50000 0.94400 1.09100 4.10000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 10.7000 0.000 0.000 0.000 0.000
18.590 3915.00000 15.4000 -44.53125 0.00000 1.80100 1.80100 12.80000 0.94400 1.09100 4.00000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
18.600 3915.00000 15.4000 -44.53125 0.00000 1.80100 1.80100 12.80000 0.94400 1.09100 4.00000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
18.610 3915.00000 15.4000 -44.53125 0.00000 1.80100 1.80100 12.80000 0.94400 1.09100 4.00000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
18.620 3915.00000 15.4000 -44.53125 0.00000 1.80100 1.80100 12.80000 0.94400 1.09100 4.00000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
18.630 3915.00000 15.4000 -44.53125 0.00000 1.80100 1.80100 12.80000 0.94400 1.09100 4.00000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
18.640 3841.00000 15.4000 -44.53125 0.00000 1.91200 1.91200 13.10000 0.94400 1.09100 4.00000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
18.650 3841.00000 15.4000 -44.53125 0.00000 1.91200 1.91200 13.10000 0.94400 1.09100 4.00000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
18.660 3841.00000 15.4000 -44.53125 0.00000 1.91200 1.91200 13.10000 0.94400 1.09100 4.00000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
18.670 3841.00000 15.4000 -44.53125 0.00000 1.91200 1.91200 13.10000 0.94400 1.09100 4.00000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
18.680 3841.00000 15.4000 -44.53125 0.00000 1.91200 1.91200 13.10000 0.94400 1.09100 4.00000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
18.690 3752.00000 15.2000 -44.53125 0.00000 1.95200 1.95200 13.40000 0.98600 1.11000 4.10000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
18.700 3752.00000 15.2000 -44.53125 0.00000 1.95200 1.95200 13.40000 0.98600 1.11000 4.10000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
18.710 3752.00000 15.2000 -44.53125 0.00000 1.95200 1.95200 13.40000 0.98600 1.11000 4.10000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
18.720 3752.00000 15.2000 -44.53125 0.00000 1.95200 1.95200 13.40000 0.98600 1.11000 4.10000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
18.730 3752.00000 15.2000 -44.53125 0.00000 1.95200 1.95200 13.40000 0.98600 1.11000 4.10000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
18.740 3744.00000 15.4000 -44.53125 0.00000 2.21500 2.21500 12.50000 0.98600 1.11000 4.00000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
18.750 3744.00000 15.4000 -44.53125 0.00000 2.21500 2.21500 12.50000 0.98600 1.11000 4.00000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
18.760 3744.00000 15.4000 -44.53125 0.00000 2.21500 2.21500 12.50000 0.98600 1.11000 4.00000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
18.770 3744.00000 15.4000 -44.53125 0.00000 2.21500 2.21500 12.50000 0.98600 1.11000 4.00000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
18.780 3744.00000 15.4000 -44.53125 0.00000 2.21500 2.21500 12.50000 0.98600 1.11000 4.00000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
18.790 3602.00000 15.2000 -44.53125 0.00000 2.14500 2.14500 12.90000 0.98600 1.11000 4.10000 1.00000 4.00000 4.00000 4.00000 5.00000 0.00000 0.00000 13.1000 0.000 0.000 0.000 0.000
18.800 3602.00000 15.2000 -44.53125 0.00000 2.14500 2.14500 12.90000 0.98600 1.11000 4.10000 1.00000 4.00000 4.00000 4.00000 5.00000 0.00000 0.00000 13.1000 0.000 0.000 0.000 0.000
18.810 3602.00000 15.2000 -44.53125 0.00000 2.14500 2.14500 12.90000 0.98600 1.11000 4.10000 1.00000 4.00000 4.00000 4.00000 5.00000 0.00000 0.00000 13.1000 0.000 0.000 0.000 0.000
18.820 3602.00000 15.2000 -44.53125 0.00000 2.14500 2.14500 12.90000 0.98600 1.11000 4.10000 1.00000 4.00000 4.00000 4.00000 5.00000 0.00000 0.00000 13.1000 0.000 0.000 0.000 0.000
18.830 3602.00000 15.2000 -44.53125 0.00000 2.14500 2.14500 12.90000 0.98600 1.11000 4.10000 1.00000 4.00000 4.00000 4.00000 5.00000 0.00000 0.00000 13.1000 0.000 0.000 0.000 0.000
18.840 3608.00000 15.2000 -44.53125 0.00000 1.69600 1.69600 13.40000 0.98600 1.11000 4.00000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
18.850 3608.00000 15.2000 -44.53125 0.00000 1.69600 1.69600 13.40000 0.98600 1.11000 4.00000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
18.860 3608.00000 15.2000 -44.53125 0.00000 1.69600 1.69600 13.40000 0.98600 1.11000 4.00000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
18.870 3608.00000 15.2000 -44.53125 0.00000 1.69600 1.69600 13.40000 0.98600 1.11000 4.00000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
18.880 3608.00000 15.2000 -44.53125 0.00000 1.69600 1.69600 13.40000 0.98600 1.11000 4.00000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
18.890 3473.00000 15.2000 -44.53125 0.00000 2.04600 2.04600 13.40000 1.02700 1.05900 4.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 13.1000 0.000 0.000 0.000 0.000
18.900 3473.00000 15.2000 -44.53125 0.00000 2.04600 2.04600 13.40000 1.02700 1.05900 4.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 13.1000 0.000 0.000 0.000 0.000
18.910 3473.00000 15.2000 -44.53125 0.00000 2.04600 2.04600 13.40000 1.02700 1.05900 4.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 13.1000 0.000 0.000 0.000 0.000
18.920 3473.00000 15.2000 -44.53125 0.00000 2.04600 2.04600 13.40000 1.02700 1.05900 4.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 13.1000 0.000 0.000 0.000 0.000
18.930 3473.00000 15.2000 -44.53125 0.00000 2.04600 2.04600 13.40000 1.02700 1.05900 4.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 13.1000 0.000 0.000 0.000 0.000
18.940 3511.00000 15.2000 -44.53125 0.00000 2.06300 2.06300 13.40000 1.02700 1.05900 4.00000 1.00000 4.00000 5.00000 4.00000 5.00000 0.00000 0.00000 13.1000 0.000 0.000 0.000 0.000
18.950 3511.00000 15.2000 -44.53125 0.00000 2.06300 2.06300 13.40000 1.02700 1.05900 4.00000 1.00000 4.00000 5.00000 4.00000 5.00000 0.00000 0.00000 13.1000 0.000 0.000 0.000 0.000
18.960 3511.00000 15.2000 -44.53125 0.00000 2.06300 2.06300 13.40000 1.02700 1.05900 4.00000 1.00000 4.00000 5.00000 4.00000 5.00000 0.00000 0.00000 13.1000 0.000 0.000 0.000 0.000
18.970 3511.00000 15.2000 -44.53125 0.00000 2.06300 2.06300 13.40000 1.02700 1.05900 4.00000 1.00000 4.00000 5.00000 4.00000 5.00000 0.00000 0.00000 13.1000 0.000 0.000 0.000 0.000
18.980 3511.00000 15.2000 -44.53125 0.00000 2.06300 2.06300 13.40000 1.02700 1.05900 4.00000 1.00000 4.00000 5.00000 4.00000 5.00000 0.00000 0.00000 13.1000 0.000 0.000 0.000 0.000
18.990 3374.00000 15.4000 -44.53125 0.00000 1.94700 1.94700 12.70000 1.02700 1.05900 4.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
19.000 3374.00000 15.4000 -44.53125 0.00000 1.94700 1.94700 12.70000 1.02700 1.05900 4.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
19.010 3374.00000 15.4000 -44.53125 0.00000 1.94700 1.94700 12.70000 1.02700 1.05900 4.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
19.020 3374.00000 15.4000 -44.53125 0.00000 1.94700 1.94700 12.70000 1.02700 1.05900 4.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
19.030 3374.00000 15.4000 -44.53125 0.00000 1.94700 1.94700 12.70000 1.02700 1.05900 4.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
19.040 3322.00000 15.2000 -44.53125 0.00000 1.99300 1.99300 13.40000 1.02700 1.05900 4.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 12.7000 0.000 0.000 0.000 0.000
19.050 3322.00000 15.2000 -44.53125 0.00000 1.99300 1.99300 13.40000 1.02700 1.05900 4.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 12.7000 0.000 0.000 0.000 0.000
19.060 3322.00000 15.2000 -44.53125 0.00000 1.99300 1.99300 13.40000 1.02700 1.05900 4.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 12.7000 0.000 0.000 0.000 0.000
19.070 3322.00000 15.2000 -44.53125 0.00000 1.99300 1.99300 13.40000 1.02700 1.05900 4.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 12.7000 0.000 0.000 0.000 0.000
19.080 3322.00000 15.2000 -44.53125 0.00000 1.99300 1.99300 13.40000 1.02700 1.05900 4.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 12.7000 0.000 0.000 0.000 0.000
19.090 3186.00000 15.2000 -44.53125 0.00000 1.76600 1.76600 13.70000 1.07200 1.06600 4.10000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 12.7000 0.000 0.000 0.000 0.000
19.100 3186.00000 15.2000 -44.53125 0.00000 1.76600 1.76600 13.70000 1.07200 1.06600 4.10000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 12.7000 0.000 0.000 0.000 0.000
19.110 3186.00000 15.2000 -44.53125 0.00000 1.76600 1.76600 13.70000 1.07200 1.06600 4.10000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 12.7000 0.000 0.000 0.000 0.000
19.120 3186.00000 15.2000 -44.53125 0.00000 1.76600 1.76600 13.70000 1.07200 1.06600 4.10000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 12.7000 0.000 0.000 0.000 0.000
19.130 3186.00000 15.2000 -44.53125 0.00000 1.76600 1.76600 13.70000 1.07200 1.06600 4.10000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 12.7000 0.000 0.000 0.000 0.000
19.140 3040.00000 15.2000 -44.53125 0.00000 2.44200 2.44200 13.30000 1.07200 1.06600 4.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 12.7000 0.000 0.000 0.000 0.000
19.150 3040.00000 15.2000 -44.53125 0.00000 2.44200 2.44200 13.30000 1.07200 1.06600 4.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 12.7000 0.000 0.000 0.000 0.000
19.160 3040.00000 15.2000 -44.53125 0.00000 2.44200 2.44200 13.30000 1.07200 1.06600 4.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 12.7000 0.000 0.000 0.000 0.000
19.170 3040.00000 15.2000 -44.53125 0.00000 2.44200 2.44200 13.30000 1.07200 1.06600 4.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 12.7000 0.000 0.000 0.000 0.000
19.180 3040.00000 15.2000 -44.53125 0.00000 2.44200 2.44200 13.30000 1.07200 1.06600 4.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 12.7000 0.000 0.000 0.000 0.000
19.190 2890.00000 15.2000 -44.53125 0.00000 1.60300 1.60300 13.20000 1.07200 1.06600 4.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 12.9000 0.000 0.000 0.000 0.000
19.200 2890.00000 15.2000 -44.53125 0.00000 1.60300 1.60300 13.20000 1.07200 1.06600 4.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 12.9000 0.000 0.000 0.000 0.000
19.210 2890.00000 15.2000 -44.53125 0.00000 1.60300 1.60300 13.20000 1.07200 1.06600 4.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 12.9000 0.000 0.000 0.000 0.000
19.220 2890.00000 15.2000 -44.53125 0.00000 1.60300 1.60300 13.20000 1.07200 1.06600 4.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 12.9000 0.000 0.000 0.000 0.000
19.230 2890.00000 15.2000 -44.53125 0.00000 1.60300 1.60300 13.20000 1.07200 1.06600 4.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 12.9000 0.000 0.000 0.000 0.000
19.240 2807.00000 15.2000 -44.53125 0.00000 1.81300 1.81300 13.00000 1.07200 1.06600 4.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 12.9000 0.000 0.000 0.000 0.000
19.250 2807.00000 15.2000 -44.53125 0.00000 1.81300 1.81300 13.00000 1.07200 1.06600 4.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 12.9000 0.000 0.000 0.000 0.000
19.260 2807.00000 15.2000 -44.53125 0.00000 1.81300 1.81300 13.00000 1.07200 1.06600 4.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 12.9000 0.000 0.000 0.000 0.000
19.270 2807.00000 15.2000 -44.53125 0.00000 1.81300 1.81300 13.00000 1.07200 1.06600 4.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 12.9000 0.000 0.000 0.000 0.000
19.280 2807.00000 15.2000 -44.53125 0.00000 1.81300 1.81300 13.00000 1.07200 1.06600 4.00000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 12.9000 0.000 0.000 0.000 0.000
19.290 2787.00000 15.2000 -44.53125 0.00000 1.30500 1.30500 13.30000 0.25500 1.07200 4.10000 1.00000 3.00000 4.00000 3.00000 4.00000 0.00000 0.00000 12.9000 0.000 0.000 0.000 0.000
19.300 2787.00000 15.2000 -44.53125 0.00000 1.30500 1.30500 13.30000 0.25500 1.07200 4.10000 1.00000 3.00000 4.00000 3.00000 4.00000 0.00000 0.00000 12.9000 0.000 0.000 0.000 0.000
19.310 2787.00000 15.2000 -44.53125 0.00000 1.30500 1.30500 13.30000 0.25500 1.07200 4.10000 1.00000 3.00000 4.00000 3.00000 4.00000 0.00000 0.00000 12.9000 0.000 0.000 0.000 0.000
19.320 2787.00000 15.2000 -44.53125 0.00000 1.30500 1.30500 13.30000 0.25500 1.07200 4.10000 1.00000 3.00000 4.00000 3.00000 4.00000 0.00000 0.00000 12.9000 0.000 0.000 0.000 0.000
19.330 2787.00000 15.2000 -44.53125 0.00000 1.30500 1.30500 13.30000 0.25500 1.07200 4.10000 1.00000 3.00000 4.00000 3.00000 4.00000 0.00000 0.00000 12.9000 0.000 0.000 0.000 0.000
19.340 2568.00000 15.4000 -44.53125 0.00000 1.31100 1.31100 12.70000 0.25500 1.07200 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 16.6000 0.000 0.000 0.000 0.000
19.350 2568.00000 15.4000 -44.53125 0.00000 1.31100 1.31100 12.70000 0.25500 1.07200 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 16.6000 0.000 0.000 0.000 0.000
19.360 2568.00000 15.4000 -44.53125 0.00000 1.31100 1.31100 12.70000 0.25500 1.07200 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 16.6000 0.000 0.000 0.000 0.000
19.370 2568.00000 15.4000 -44.53125 0.00000 1.31100 1.31100 12.70000 0.25500 1.07200 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 16.6000 0.000 0.000 0.000 0.000
19.380 2568.00000 15.4000 -44.53125 0.00000 1.31100 1.31100 12.70000 0.25500 1.07200 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 16.6000 0.000 0.000 0.000 0.000
19.390 2479.00000 15.2000 -44.53125 0.00000 1.65500 1.65500 13.50000 0.25500 1.07200 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
19.400 2479.00000 15.2000 -44.53125 0.00000 1.65500 1.65500 13.50000 0.25500 1.07200 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
19.410 2479.00000 15.2000 -44.53125 0.00000 1.65500 1.65500 13.50000 0.25500 1.07200 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
19.420 2479.00000 15.2000 -44.53125 0.00000 1.65500 1.65500 13.50000 0.25500 1.07200 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
19.430 2479.00000 15.2000 -44.53125 0.00000 1.65500 1.65500 13.50000 0.25500 1.07200 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
19.440 2441.00000 15.2000 -44.53125 0.00000 1.76000 1.76000 13.60000 0.25500 1.07200 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
19.450 2441.00000 15.2000 -44.53125 0.00000 1.76000 1.76000 13.60000 0.25500 1.07200 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
19.460 2441.00000 15.2000 -44.53125 0.00000 1.76000 1.76000 13.60000 0.25500 1.07200 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
19.470 2441.00000 15.2000 -44.53125 0.00000 1.76000 1.76000 13.60000 0.25500 1.07200 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
19.480 2441.00000 15.2000 -44.53125 0.00000 1.76000 1.76000 13.60000 0.25500 1.07200 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
19.490 2304.00000 15.2000 -44.53125 0.00000 1.67300 1.67300 12.50000 0.24500 1.07200 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
19.500 2304.00000 15.2000 -44.53125 0.00000 1.67300 1.67300 12.50000 0.24500 1.07200 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
19.510 2304.00000 15.2000 -44.53125 0.00000 1.67300 1.67300 12.50000 0.24500 1.07200 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
19.520 2304.00000 15.2000 -44.53125 0.00000 1.67300 1.67300 12.50000 0.24500 1.07200 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
19.530 2304.00000 15.2000 -44.53125 0.00000 1.67300 1.67300 12.50000 0.24500 1.07200 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
19.540 2209.00000 15.2000 -44.53125 0.00000 1.47400 1.47400 12.80000 0.24500 1.07200 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
19.550 2209.00000 15.2000 -44.53125 0.00000 1.47400 1.47400 12.80000 0.24500 1.07200 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
19.560 2209.00000 15.2000 -44.53125 0.00000 1.47400 1.47400 12.80000 0.24500 1.07200 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
19.570 2209.00000 15.2000 -44.53125 0.00000 1.47400 1.47400 12.80000 0.24500 1.07200 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
19.580 2209.00000 15.2000 -44.53125 0.00000 1.47400 1.47400 12.80000 0.24500 1.07200 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
19.590 2114.00000 15.2000 -44.53125 0.00000 1.63800 1.63800 13.00000 0.24500 1.07200 4.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
19.600 2114.00000 15.2000 -44.53125 0.00000 1.63800 1.63800 13.00000 0.24500 1.07200 4.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
19.610 2114.00000 15.2000 -44.53125 0.00000 1.63800 1.63800 13.00000 0.24500 1.07200 4.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
19.620 2114.00000 15.2000 -44.53125 0.00000 1.63800 1.63800 13.00000 0.24500 1.07200 4.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
19.630 2114.00000 15.2000 -44.53125 0.00000 1.63800 1.63800 13.00000 0.24500 1.07200 4.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
19.640 2075.00000 15.2000 -44.53125 0.00000 2.14500 2.14500 13.20000 0.24500 1.07200 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
19.650 2075.00000 15.2000 -44.53125 0.00000 2.14500 2.14500 13.20000 0.24500 1.07200 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
19.660 2075.00000 15.2000 -44.53125 0.00000 2.14500 2.14500 13.20000 0.24500 1.07200 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
19.670 2075.00000 15.2000 -44.53125 0.00000 2.14500 2.14500 13.20000 0.24500 1.07200 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
19.680 2075.00000 15.2000 -44.53125 0.00000 2.14500 2.14500 13.20000 0.24500 1.07200 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
19.690 2010.00000 15.4000 -44.53125 0.00000 1.53900 1.53900 12.50000 0.24500 1.05900 4.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
19.700 2010.00000 15.4000 -44.53125 0.00000 1.53900 1.53900 12.50000 0.24500 1.05900 4.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
19.710 2010.00000 15.4000 -44.53125 0.00000 1.53900 1.53900 12.50000 0.24500 1.05900 4.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
19.720 2010.00000 15.4000 -44.53125 0.00000 1.53900 1.53900 12.50000 0.24500 1.05900 4.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
19.730 2010.00000 15.4000 -44.53125 0.00000 1.53900 1.53900 12.50000 0.24500 1.05900 4.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
19.740 2050.00000 15.2000 -44.53125 0.00000 1.61400 1.61400 13.50000 0.24500 1.05900 4.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
19.750 2050.00000 15.2000 -44.53125 0.00000 1.61400 1.61400 13.50000 0.24500 1.05900 4.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
19.760 2050.00000 15.2000 -44.53125 0.00000 1.61400 1.61400 13.50000 0.24500 1.05900 4.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
19.770 2050.00000 15.2000 -44.53125 0.00000 1.61400 1.61400 13.50000 0.24500 1.05900 4.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
19.780 2050.00000 15.2000 -44.53125 0.00000 1.61400 1.61400 13.50000 0.24500 1.05900 4.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
19.790 1997.00000 15.2000 -44.53125 0.00000 1.92900 1.92900 13.70000 0.24500 1.05900 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
19.800 1997.00000 15.2000 -44.53125 0.00000 1.92900 1.92900 13.70000 0.24500 1.05900 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
19.810 1997.00000 15.2000 -44.53125 0.00000 1.92900 1.92900 13.70000 0.24500 1.05900 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
19.820 1997.00000 15.2000 -44.53125 0.00000 1.92900 1.92900 13.70000 0.24500 1.05900 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
19.830 1997.00000 15.2000 -44.53125 0.00000 1.92900 1.92900 13.70000 0.24500 1.05900 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
19.840 1989.00000 15.2000 -44.53125 0.00000 1.18300 1.18300 13.00000 0.24500 1.05900 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
19.850 1989.00000 15.2000 -44.53125 0.00000 1.18300 1.18300 13.00000 0.24500 1.05900 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
19.860 1989.00000 15.2000 -44.53125 0.00000 1.18300 1.18300 13.00000 0.24500 1.05900 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
19.870 1989.00000 15.2000 -44.53125 0.00000 1.18300 1.18300 13.00000 0.24500 1.05900 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
19.880 1989.00000 15.2000 -44.53125 0.00000 1.18300 1.18300 13.00000 0.24500 1.05900 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
19.890 1976.00000 15.2000 -44.53125 0.00000 1.81300 1.81300 13.50000 0.26800 0.57100 4.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
19.900 1976.00000 15.2000 -44.53125 0.00000 1.81300 1.81300 13.50000 0.26800 0.57100 4.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
19.910 1976.00000 15.2000 -44.53125 0.00000 1.81300 1.81300 13.50000 0.26800 0.57100 4.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
19.920 1976.00000 15.2000 -44.53125 0.00000 1.81300 1.81300 13.50000 0.26800 0.57100 4.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
19.930 1976.00000 15.2000 -44.53125 0.00000 1.81300 1.81300 13.50000 0.26800 0.57100 4.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
19.940 2004.00000 15.2000 -44.53125 0.00000 1.49800 1.49800 12.80000 0.26800 0.57100 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
19.950 2004.00000 15.2000 -44.53125 0.00000 1.49800 1.49800 12.80000 0.26800 0.57100 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
19.960 2004.00000 15.2000 -44.53125 0.00000 1.49800 1.49800 12.80000 0.26800 0.57100 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
19.970 2004.00000 15.2000 -44.53125 0.00000 1.49800 1.49800 12.80000 0.26800 0.57100 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
19.980 2004.00000 15.2000 -44.53125 0.00000 1.49800 1.49800 12.80000 0.26800 0.57100 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
19.990 1947.00000 15.2000 -44.53125 0.00000 1.71900 1.71900 13.30000 0.26800 0.57100 4.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
20.000 1947.00000 15.2000 -44.53125 0.00000 1.71900 1.71900 13.30000 0.26800 0.57100 4.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
20.010 1947.00000 15.2000 -44.53125 0.00000 1.71900 1.71900 13.30000 0.26800 0.57100 4.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
20.020 1947.00000 15.2000 -44.53125 0.00000 1.71900 1.71900 13.30000 0.26800 0.57100 4.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
20.030 1947.00000 15.2000 -44.53125 0.00000 1.71900 1.71900 13.30000 0.26800 0.57100 4.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
20.040 1923.00000 15.1000 -44.53125 0.00000 1.50400 1.50400 13.10000 0.26800 0.57100 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
20.050 1923.00000 15.1000 -44.53125 0.00000 1.50400 1.50400 13.10000 0.26800 0.57100 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
20.060 1923.00000 15.1000 -44.53125 0.00000 1.50400 1.50400 13.10000 0.26800 0.57100 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
20.070 1923.00000 15.1000 -44.53125 0.00000 1.50400 1.50400 13.10000 0.26800 0.57100 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
20.080 1923.00000 15.1000 -44.53125 0.00000 1.50400 1.50400 13.10000 0.26800 0.57100 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
20.090 1941.00000 15.2000 -44.53125 0.00000 1.84800 1.84800 13.00000 1.10700 0.27100 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
20.100 1941.00000 15.2000 -44.53125 0.00000 1.84800 1.84800 13.00000 1.10700 0.27100 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
20.110 1941.00000 15.2000 -44.53125 0.00000 1.84800 1.84800 13.00000 1.10700 0.27100 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
20.120 1941.00000 15.2000 -44.53125 0.00000 1.84800 1.84800 13.00000 1.10700 0.27100 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
20.130 1941.00000 15.2000 -44.53125 0.00000 1.84800 1.84800 13.00000 1.10700 0.27100 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
20.140 1879.00000 15.2000 -44.53125 0.00000 1.32900 1.32900 13.50000 1.10700 0.27100 4.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
20.150 1879.00000 15.2000 -44.53125 0.00000 1.32900 1.32900 13.50000 1.10700 0.27100 4.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
20.160 1879.00000 15.2000 -44.53125 0.00000 1.32900 1.32900 13.50000 1.10700 0.27100 4.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
20.170 1879.00000 15.2000 -44.53125 0.00000 1.32900 1.32900 13.50000 1.10700 0.27100 4.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
20.180 1879.00000 15.2000 -44.53125 0.00000 1.32900 1.32900 13.50000 1.10700 0.27100 4.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
20.190 1858.00000 15.2000 -44.53125 0.00000 1.26500 1.26500 13.30000 1.10700 0.27100 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
20.200 1858.00000 15.2000 -44.53125 0.00000 1.26500 1.26500 13.30000 1.10700 0.27100 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
20.210 1858.00000 15.2000 -44.53125 0.00000 1.26500 1.26500 13.30000 1.10700 0.27100 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
20.220 1858.00000 15.2000 -44.53125 0.00000 1.26500 1.26500 13.30000 1.10700 0.27100 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
20.230 1858.00000 15.2000 -44.53125 0.00000 1.26500 1.26500 13.30000 1.10700 0.27100 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
20.240 1858.00000 15.2000 -44.53125 0.00000 1.78900 1.78900 13.60000 1.10700 0.27100 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
20.250 1858.00000 15.2000 -44.53125 0.00000 1.78900 1.78900 13.60000 1.10700 0.27100 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
20.260 1858.00000 15.2000 -44.53125 0.00000 1.78900 1.78900 13.60000 1.10700 0.27100 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
20.270 1858.00000 15.2000 -44.53125 0.00000 1.78900 1.78900 13.60000 1.10700 0.27100 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
20.280 1858.00000 15.2000 -44.53125 0.00000 1.78900 1.78900 13.60000 1.10700 0.27100 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
20.290 1826.00000 15.4000 -44.53125 0.00000 1.77800 1.77800 12.20000 1.12300 0.26800 4.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.9000 0.000 0.000 0.000 0.000
20.300 1826.00000 15.4000 -44.53125 0.00000 1.77800 1.77800 12.20000 1.12300 0.26800 4.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.9000 0.000 0.000 0.000 0.000
20.310 1826.00000 15.4000 -44.53125 0.00000 1.77800 1.77800 12.20000 1.12300 0.26800 4.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.9000 0.000 0.000 0.000 0.000
20.320 1826.00000 15.4000 -44.53125 0.00000 1.77800 1.77800 12.20000 1.12300 0.26800 4.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.9000 0.000 0.000 0.000 0.000
20.330 1826.00000 15.4000 -44.53125 0.00000 1.77800 1.77800 12.20000 1.12300 0.26800 4.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.9000 0.000 0.000 0.000 0.000
20.340 1837.00000 15.2000 -44.53125 0.00000 1.57900 1.57900 13.40000 1.12300 0.26800 4.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
20.350 1837.00000 15.2000 -44.53125 0.00000 1.57900 1.57900 13.40000 1.12300 0.26800 4.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
20.360 1837.00000 15.2000 -44.53125 0.00000 1.57900 1.57900 13.40000 1.12300 0.26800 4.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
20.370 1837.00000 15.2000 -44.53125 0.00000 1.57900 1.57900 13.40000 1.12300 0.26800 4.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
20.380 1837.00000 15.2000 -44.53125 0.00000 1.57900 1.57900 13.40000 1.12300 0.26800 4.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
20.390 1772.00000 15.2000 -44.53125 0.00000 1.60300 1.60300 13.20000 1.12300 0.26800 4.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
20.400 1772.00000 15.2000 -44.53125 0.00000 1.60300 1.60300 13.20000 1.12300 0.26800 4.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
20.410 1772.00000 15.2000 -44.53125 0.00000 1.60300 1.60300 13.20000 1.12300 0.26800 4.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
20.420 1772.00000 15.2000 -44.53125 0.00000 1.60300 1.60300 13.20000 1.12300 0.26800 4.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
20.430 1772.00000 15.2000 -44.53125 0.00000 1.60300 1.60300 13.20000 1.12300 0.26800 4.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
20.440 1772.00000 15.2000 -44.53125 0.00000 1.60300 1.60300 13.20000 1.12300 0.26800 4.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
20.450 1745.00000 15.4000 -44.53125 0.00000 1.63800 1.63800 12.60000 1.12300 0.26800 4.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
20.460 1745.00000 15.4000 -44.53125 0.00000 1.63800 1.63800 12.60000 1.12300 0.26800 4.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
20.470 1745.00000 15.4000 -44.53125 0.00000 1.63800 1.63800 12.60000 1.12300 0.26800 4.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
20.480 1745.00000 15.4000 -44.53125 0.00000 1.63800 1.63800 12.60000 1.12300 0.26800 4.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
20.490 1745.00000 15.4000 -44.53125 0.00000 1.63800 1.63800 12.60000 1.12300 0.26800 4.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
20.500 1708.00000 15.2000 -44.53125 0.00000 1.41600 1.41600 13.20000 1.14200 0.27700 4.20000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
20.510 1708.00000 15.2000 -44.53125 0.00000 1.41600 1.41600 13.20000 1.14200 0.27700 4.20000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
20.520 1708.00000 15.2000 -44.53125 0.00000 1.41600 1.41600 13.20000 1.14200 0.27700 4.20000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
20.530 1708.00000 15.2000 -44.53125 0.00000 1.41600 1.41600 13.20000 1.14200 0.27700 4.20000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
20.540 1708.00000 15.2000 -44.53125 0.00000 1.41600 1.41600 13.20000 1.14200 0.27700 4.20000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
20.550 1639.00000 15.2000 -44.53125 0.00000 1.64400 1.64400 13.20000 1.14200 0.27700 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
20.560 1639.00000 15.2000 -44.53125 0.00000 1.64400 1.64400 13.20000 1.14200 0.27700 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
20.570 1639.00000 15.2000 -44.53125 0.00000 1.64400 1.64400 13.20000 1.14200 0.27700 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
20.580 1639.00000 15.2000 -44.53125 0.00000 1.64400 1.64400 13.20000 1.14200 0.27700 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
20.590 1639.00000 15.2000 -44.53125 0.00000 1.64400 1.64400 13.20000 1.14200 0.27700 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
20.600 1486.00000 15.2000 -44.53125 0.00000 1.44500 1.44500 13.20000 1.14200 0.27700 4.20000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
20.610 1486.00000 15.2000 -44.53125 0.00000 1.44500 1.44500 13.20000 1.14200 0.27700 4.20000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
20.620 1486.00000 15.2000 -44.53125 0.00000 1.44500 1.44500 13.20000 1.14200 0.27700 4.20000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
20.630 1486.00000 15.2000 -44.53125 0.00000 1.44500 1.44500 13.20000 1.14200 0.27700 4.20000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
20.640 1486.00000 15.2000 -44.53125 0.00000 1.44500 1.44500 13.20000 1.14200 0.27700 4.20000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
20.650 1486.00000 15.2000 -44.53125 0.00000 1.52700 1.52700 13.30000 1.14200 0.27700 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.2000 0.000 0.000 0.000 0.000
20.660 1486.00000 15.2000 -44.53125 0.00000 1.52700 1.52700 13.30000 1.14200 0.27700 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.2000 0.000 0.000 0.000 0.000
20.670 1486.00000 15.2000 -44.53125 0.00000 1.52700 1.52700 13.30000 1.14200 0.27700 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.2000 0.000 0.000 0.000 0.000
20.680 1486.00000 15.2000 -44.53125 0.00000 1.52700 1.52700 13.30000 1.14200 0.27700 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.2000 0.000 0.000 0.000 0.000
20.690 1486.00000 15.2000 -44.53125 0.00000 1.52700 1.52700 13.30000 1.14200 0.27700 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.2000 0.000 0.000 0.000 0.000
20.700 1357.00000 15.4000 -44.53125 0.00000 1.53900 1.53900 12.00000 1.13900 0.30900 4.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
20.710 1357.00000 15.4000 -44.53125 0.00000 1.53900 1.53900 12.00000 1.13900 0.30900 4.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
20.720 1357.00000 15.4000 -44.53125 0.00000 1.53900 1.53900 12.00000 1.13900 0.30900 4.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
20.730 1357.00000 15.4000 -44.53125 0.00000 1.53900 1.53900 12.00000 1.13900 0.30900 4.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
20.740 1357.00000 15.4000 -44.53125 0.00000 1.53900 1.53900 12.00000 1.13900 0.30900 4.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
20.750 1385.00000 15.2000 -44.53125 0.00000 1.68400 1.68400 13.30000 1.13900 0.30900 4.60000 1.00000 2.00000 2.00000 3.00000 2.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
20.760 1385.00000 15.2000 -44.53125 0.00000 1.68400 1.68400 13.30000 1.13900 0.30900 4.60000 1.00000 2.00000 2.00000 3.00000 2.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
20.770 1385.00000 15.2000 -44.53125 0.00000 1.68400 1.68400 13.30000 1.13900 0.30900 4.60000 1.00000 2.00000 2.00000 3.00000 2.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
20.780 1385.00000 15.2000 -44.53125 0.00000 1.68400 1.68400 13.30000 1.13900 0.30900 4.60000 1.00000 2.00000 2.00000 3.00000 2.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
20.790 1385.00000 15.2000 -44.53125 0.00000 1.68400 1.68400 13.30000 1.13900 0.30900 4.60000 1.00000 2.00000 2.00000 3.00000 2.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
20.800 1355.00000 15.2000 -44.53125 0.00000 1.51500 1.51500 13.20000 1.13900 0.30900 4.50000 1.00000 2.00000 3.00000 3.00000 3.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
20.810 1355.00000 15.2000 -44.53125 0.00000 1.51500 1.51500 13.20000 1.13900 0.30900 4.50000 1.00000 2.00000 3.00000 3.00000 3.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
20.820 1355.00000 15.2000 -44.53125 0.00000 1.51500 1.51500 13.20000 1.13900 0.30900 4.50000 1.00000 2.00000 3.00000 3.00000 3.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
20.830 1355.00000 15.2000 -44.53125 0.00000 1.51500 1.51500 13.20000 1.13900 0.30900 4.50000 1.00000 2.00000 3.00000 3.00000 3.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
20.840 1355.00000 15.2000 -44.53125 0.00000 1.51500 1.51500 13.20000 1.13900 0.30900 4.50000 1.00000 2.00000 3.00000 3.00000 3.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
20.850 1355.00000 15.2000 -44.53125 0.00000 1.48600 1.48600 13.30000 1.13900 0.30900 4.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
20.860 1355.00000 15.2000 -44.53125 0.00000 1.48600 1.48600 13.30000 1.13900 0.30900 4.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
20.870 1355.00000 15.2000 -44.53125 0.00000 1.48600 1.48600 13.30000 1.13900 0.30900 4.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
20.880 1355.00000 15.2000 -44.53125 0.00000 1.48600 1.48600 13.30000 1.13900 0.30900 4.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
20.890 1355.00000 15.2000 -44.53125 0.00000 1.48600 1.48600 13.30000 1.13900 0.30900 4.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
20.900 1247.00000 15.2000 -44.53125 0.00000 1.49200 1.49200 13.50000 0.28000 0.35100 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.6000 0.000 0.000 0.000 0.000
20.910 1247.00000 15.2000 -44.53125 0.00000 1.49200 1.49200 13.50000 0.28000 0.35100 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.6000 0.000 0.000 0.000 0.000
20.920 1247.00000 15.2000 -44.53125 0.00000 1.49200 1.49200 13.50000 0.28000 0.35100 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.6000 0.000 0.000 0.000 0.000
20.930 1247.00000 15.2000 -44.53125 0.00000 1.49200 1.49200 13.50000 0.28000 0.35100 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.6000 0.000 0.000 0.000 0.000
20.940 1247.00000 15.2000 -44.53125 0.00000 1.49200 1.49200 13.50000 0.28000 0.35100 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.6000 0.000 0.000 0.000 0.000
20.950 1247.00000 15.2000 -44.53125 0.00000 1.47400 1.47400 13.20000 0.28000 0.35100 4.60000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
20.960 1247.00000 15.2000 -44.53125 0.00000 1.47400 1.47400 13.20000 0.28000 0.35100 4.60000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
20.970 1247.00000 15.2000 -44.53125 0.00000 1.47400 1.47400 13.20000 0.28000 0.35100 4.60000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
20.980 1247.00000 15.2000 -44.53125 0.00000 1.47400 1.47400 13.20000 0.28000 0.35100 4.60000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
20.990 1247.00000 15.2000 -44.53125 0.00000 1.47400 1.47400 13.20000 0.28000 0.35100 4.60000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
21.000 1086.00000 15.2000 -44.53125 0.00000 1.34600 1.34600 13.60000 0.28000 0.35100 4.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
21.010 1086.00000 15.2000 -44.53125 0.00000 1.34600 1.34600 13.60000 0.28000 0.35100 4.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
21.020 1086.00000 15.2000 -44.53125 0.00000 1.34600 1.34600 13.60000 0.28000 0.35100 4.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
21.030 1086.00000 15.2000 -44.53125 0.00000 1.34600 1.34600 13.60000 0.28000 0.35100 4.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
21.040 1086.00000 15.2000 -44.53125 0.00000 1.34600 1.34600 13.60000 0.28000 0.35100 4.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
21.050 1086.00000 15.2000 -44.53125 0.00000 1.10700 1.10700 12.80000 0.28000 0.35100 5.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 17.5000 0.000 0.000 0.000 0.000
21.060 1086.00000 15.2000 -44.53125 0.00000 1.10700 1.10700 12.80000 0.28000 0.35100 5.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 17.5000 0.000 0.000 0.000 0.000
21.070 1086.00000 15.2000 -44.53125 0.00000 1.10700 1.10700 12.80000 0.28000 0.35100 5.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 17.5000 0.000 0.000 0.000 0.000
21.080 1086.00000 15.2000 -44.53125 0.00000 1.10700 1.10700 12.80000 0.28000 0.35100 5.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 17.5000 0.000 0.000 0.000 0.000
21.090 1086.00000 15.2000 -44.53125 0.00000 1.10700 1.10700 12.80000 0.28000 0.35100 5.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 17.5000 0.000 0.000 0.000 0.000
21.100 921.00000 15.2000 -44.53125 0.00000 1.02600 1.02600 12.90000 0.30000 0.54500 5.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 18.4000 0.000 0.000 0.000 0.000
21.110 921.00000 15.2000 -44.53125 0.00000 1.02600 1.02600 12.90000 0.30000 0.54500 5.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 18.4000 0.000 0.000 0.000 0.000
21.120 921.00000 15.2000 -44.53125 0.00000 1.02600 1.02600 12.90000 0.30000 0.54500 5.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 18.4000 0.000 0.000 0.000 0.000
21.130 921.00000 15.2000 -44.53125 0.00000 1.02600 1.02600 12.90000 0.30000 0.54500 5.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 18.4000 0.000 0.000 0.000 0.000
21.140 921.00000 15.2000 -44.53125 0.00000 1.02600 1.02600 12.90000 0.30000 0.54500 5.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 18.4000 0.000 0.000 0.000 0.000
21.150 921.00000 15.2000 -44.53125 0.00000 0.96100 0.96100 12.80000 0.30000 0.54500 5.80000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
21.160 921.00000 15.2000 -44.53125 0.00000 0.96100 0.96100 12.80000 0.30000 0.54500 5.80000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
21.170 921.00000 15.2000 -44.53125 0.00000 0.96100 0.96100 12.80000 0.30000 0.54500 5.80000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
21.180 921.00000 15.2000 -44.53125 0.00000 0.96100 0.96100 12.80000 0.30000 0.54500 5.80000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
21.190 921.00000 15.2000 -44.53125 0.00000 0.96100 0.96100 12.80000 0.30000 0.54500 5.80000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
21.200 921.00000 15.2000 -44.53125 0.00000 0.93800 0.93800 12.60000 0.30000 0.54500 6.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 18.4000 0.000 0.000 0.000 0.000
21.210 921.00000 15.2000 -44.53125 0.00000 0.93800 0.93800 12.60000 0.30000 0.54500 6.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 18.4000 0.000 0.000 0.000 0.000
21.220 921.00000 15.2000 -44.53125 0.00000 0.93800 0.93800 12.60000 0.30000 0.54500 6.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 18.4000 0.000 0.000 0.000 0.000
21.230 921.00000 15.2000 -44.53125 0.00000 0.93800 0.93800 12.60000 0.30000 0.54500 6.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 18.4000 0.000 0.000 0.000 0.000
21.240 921.00000 15.2000 -44.53125 0.00000 0.93800 0.93800 12.60000 0.30000 0.54500 6.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 18.4000 0.000 0.000 0.000 0.000
21.250 730.00000 15.2000 -44.53125 0.00000 0.93800 0.93800 12.80000 0.30000 0.54500 6.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 18.4000 0.000 0.000 0.000 0.000
21.260 730.00000 15.2000 -44.53125 0.00000 0.93800 0.93800 12.80000 0.30000 0.54500 6.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 18.4000 0.000 0.000 0.000 0.000
21.270 730.00000 15.2000 -44.53125 0.00000 0.93800 0.93800 12.80000 0.30000 0.54500 6.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 18.4000 0.000 0.000 0.000 0.000
21.280 730.00000 15.2000 -44.53125 0.00000 0.93800 0.93800 12.80000 0.30000 0.54500 6.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 18.4000 0.000 0.000 0.000 0.000
21.290 730.00000 15.2000 -44.53125 0.00000 0.93800 0.93800 12.80000 0.30000 0.54500 6.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 18.4000 0.000 0.000 0.000 0.000
21.300 730.00000 15.2000 -44.53125 0.00000 1.02000 1.02000 12.60000 1.05300 0.99500 6.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
21.310 730.00000 15.2000 -44.53125 0.00000 1.02000 1.02000 12.60000 1.05300 0.99500 6.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
21.320 730.00000 15.2000 -44.53125 0.00000 1.02000 1.02000 12.60000 1.05300 0.99500 6.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
21.330 730.00000 15.2000 -44.53125 0.00000 1.02000 1.02000 12.60000 1.05300 0.99500 6.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
21.340 730.00000 15.2000 -44.53125 0.00000 1.02000 1.02000 12.60000 1.05300 0.99500 6.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
21.350 691.00000 15.2000 -44.53125 0.00000 1.00200 1.00200 12.60000 1.05300 0.99500 6.60000 1.00000 1.00000 2.00000 2.00000 2.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
21.360 691.00000 15.2000 -44.53125 0.00000 1.00200 1.00200 12.60000 1.05300 0.99500 6.60000 1.00000 1.00000 2.00000 2.00000 2.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
21.370 691.00000 15.2000 -44.53125 0.00000 1.00200 1.00200 12.60000 1.05300 0.99500 6.60000 1.00000 1.00000 2.00000 2.00000 2.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
21.380 691.00000 15.2000 -44.53125 0.00000 1.00200 1.00200 12.60000 1.05300 0.99500 6.60000 1.00000 1.00000 2.00000 2.00000 2.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
21.390 691.00000 15.2000 -44.53125 0.00000 1.00200 1.00200 12.60000 1.05300 0.99500 6.60000 1.00000 1.00000 2.00000 2.00000 2.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
21.400 691.00000 15.2000 -44.53125 0.00000 1.00800 1.00800 12.00000 1.05300 0.99500 7.10000 1.00000 1.00000 2.00000 1.00000 1.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
21.410 691.00000 15.2000 -44.53125 0.00000 1.00800 1.00800 12.00000 1.05300 0.99500 7.10000 1.00000 1.00000 2.00000 1.00000 1.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
21.420 691.00000 15.2000 -44.53125 0.00000 1.00800 1.00800 12.00000 1.05300 0.99500 7.10000 1.00000 1.00000 2.00000 1.00000 1.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
21.430 691.00000 15.2000 -44.53125 0.00000 1.00800 1.00800 12.00000 1.05300 0.99500 7.10000 1.00000 1.00000 2.00000 1.00000 1.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
21.440 691.00000 15.2000 -44.53125 0.00000 1.00800 1.00800 12.00000 1.05300 0.99500 7.10000 1.00000 1.00000 2.00000 1.00000 1.00000 0.00000 0.00000 14.7000 0.000 0.000 0.000 0.000
21.450 691.00000 15.2000 -44.53125 0.00000 0.99100 0.99100 12.90000 1.05300 0.99500 6.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
21.460 691.00000 15.2000 -44.53125 0.00000 0.99100 0.99100 12.90000 1.05300 0.99500 6.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
21.470 691.00000 15.2000 -44.53125 0.00000 0.99100 0.99100 12.90000 1.05300 0.99500 6.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
21.480 691.00000 15.2000 -44.53125 0.00000 0.99100 0.99100 12.90000 1.05300 0.99500 6.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
21.490 691.00000 15.2000 -44.53125 0.00000 0.99100 0.99100 12.90000 1.05300 0.99500 6.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
21.500 771.00000 15.2000 -44.53125 0.00000 0.99100 0.99100 13.30000 1.09800 1.06600 6.20000 1.00000 2.00000 2.00000 2.00000 1.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
21.510 771.00000 15.2000 -44.53125 0.00000 0.99100 0.99100 13.30000 1.09800 1.06600 6.20000 1.00000 2.00000 2.00000 2.00000 1.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
21.520 771.00000 15.2000 -44.53125 0.00000 0.99100 0.99100 13.30000 1.09800 1.06600 6.20000 1.00000 2.00000 2.00000 2.00000 1.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
21.530 771.00000 15.2000 -44.53125 0.00000 0.99100 0.99100 13.30000 1.09800 1.06600 6.20000 1.00000 2.00000 2.00000 2.00000 1.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
21.540 771.00000 15.2000 -44.53125 0.00000 0.99100 0.99100 13.30000 1.09800 1.06600 6.20000 1.00000 2.00000 2.00000 2.00000 1.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
21.550 771.00000 15.2000 -44.53125 0.00000 0.99100 0.99100 13.30000 1.09800 1.06600 6.20000 1.00000 2.00000 2.00000 2.00000 1.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
21.560 771.00000 15.2000 -44.53125 0.00000 0.99100 0.99100 13.30000 1.09800 1.06600 6.20000 1.00000 2.00000 2.00000 2.00000 1.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
21.570 771.00000 15.2000 -44.53125 0.00000 0.99100 0.99100 13.30000 1.09800 1.06600 6.20000 1.00000 2.00000 2.00000 2.00000 1.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
21.580 771.00000 15.2000 -44.53125 0.00000 0.99100 0.99100 13.30000 1.09800 1.06600 6.20000 1.00000 2.00000 2.00000 2.00000 1.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
21.590 771.00000 15.2000 -44.53125 0.00000 0.99100 0.99100 13.30000 1.09800 1.06600 6.20000 1.00000 2.00000 2.00000 2.00000 1.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
21.600 930.00000 15.2000 -44.53125 0.00000 0.96100 0.96100 13.20000 1.09800 1.06600 6.10000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
21.610 930.00000 15.2000 -44.53125 0.00000 0.96100 0.96100 13.20000 1.09800 1.06600 6.10000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
21.620 930.00000 15.2000 -44.53125 0.00000 0.96100 0.96100 13.20000 1.09800 1.06600 6.10000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
21.630 930.00000 15.2000 -44.53125 0.00000 0.96100 0.96100 13.20000 1.09800 1.06600 6.10000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
21.640 930.00000 15.2000 -44.53125 0.00000 0.96100 0.96100 13.20000 1.09800 1.06600 6.10000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
21.650 930.00000 15.2000 -44.53125 0.00000 0.93200 0.93200 13.20000 1.09800 1.06600 6.20000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
21.660 930.00000 15.2000 -44.53125 0.00000 0.93200 0.93200 13.20000 1.09800 1.06600 6.20000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
21.670 930.00000 15.2000 -44.53125 0.00000 0.93200 0.93200 13.20000 1.09800 1.06600 6.20000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
21.680 930.00000 15.2000 -44.53125 0.00000 0.93200 0.93200 13.20000 1.09800 1.06600 6.20000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
21.690 930.00000 15.2000 -44.53125 0.00000 0.93200 0.93200 13.20000 1.09800 1.06600 6.20000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
21.700 1040.00000 15.2000 -44.53125 0.00000 0.94400 0.94400 13.50000 1.16800 1.06200 5.80000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
21.710 1040.00000 15.2000 -44.53125 0.00000 0.94400 0.94400 13.50000 1.16800 1.06200 5.80000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
21.720 1040.00000 15.2000 -44.53125 0.00000 0.94400 0.94400 13.50000 1.16800 1.06200 5.80000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
21.730 1040.00000 15.2000 -44.53125 0.00000 0.94400 0.94400 13.50000 1.16800 1.06200 5.80000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
21.740 1040.00000 15.2000 -44.53125 0.00000 0.94400 0.94400 13.50000 1.16800 1.06200 5.80000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
21.750 1040.00000 15.2000 -44.53125 0.00000 0.92600 0.92600 12.60000 1.16800 1.06200 5.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.0000 0.000 0.000 0.000 0.000
21.760 1040.00000 15.2000 -44.53125 0.00000 0.92600 0.92600 12.60000 1.16800 1.06200 5.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.0000 0.000 0.000 0.000 0.000
21.770 1040.00000 15.2000 -44.53125 0.00000 0.92600 0.92600 12.60000 1.16800 1.06200 5.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.0000 0.000 0.000 0.000 0.000
21.780 1040.00000 15.2000 -44.53125 0.00000 0.92600 0.92600 12.60000 1.16800 1.06200 5.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.0000 0.000 0.000 0.000 0.000
21.790 1040.00000 15.2000 -44.53125 0.00000 0.92600 0.92600 12.60000 1.16800 1.06200 5.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.0000 0.000 0.000 0.000 0.000
21.800 1152.00000 15.2000 -44.53125 0.00000 0.92100 0.92100 13.10000 1.16800 1.06200 5.00000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
21.810 1152.00000 15.2000 -44.53125 0.00000 0.92100 0.92100 13.10000 1.16800 1.06200 5.00000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
21.820 1152.00000 15.2000 -44.53125 0.00000 0.92100 0.92100 13.10000 1.16800 1.06200 5.00000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
21.830 1152.00000 15.2000 -44.53125 0.00000 0.92100 0.92100 13.10000 1.16800 1.06200 5.00000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
21.840 1152.00000 15.2000 -44.53125 0.00000 0.92100 0.92100 13.10000 1.16800 1.06200 5.00000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
21.850 1248.00000 15.2000 -44.53125 0.00000 0.99600 0.99600 12.70000 1.16800 1.06200 4.60000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.3000 0.000 0.000 0.000 0.000
21.860 1248.00000 15.2000 -44.53125 0.00000 0.99600 0.99600 12.70000 1.16800 1.06200 4.60000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.3000 0.000 0.000 0.000 0.000
21.870 1248.00000 15.2000 -44.53125 0.00000 0.99600 0.99600 12.70000 1.16800 1.06200 4.60000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.3000 0.000 0.000 0.000 0.000
21.880 1248.00000 15.2000 -44.53125 0.00000 0.99600 0.99600 12.70000 1.16800 1.06200 4.60000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.3000 0.000 0.000 0.000 0.000
21.890 1248.00000 15.2000 -44.53125 0.00000 0.99600 0.99600 12.70000 1.16800 1.06200 4.60000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.3000 0.000 0.000 0.000 0.000
21.900 1248.00000 15.2000 -44.53125 0.00000 1.04300 1.04300 13.00000 1.15500 1.10100 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.3000 0.000 0.000 0.000 0.000
21.910 1248.00000 15.2000 -44.53125 0.00000 1.04300 1.04300 13.00000 1.15500 1.10100 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.3000 0.000 0.000 0.000 0.000
21.920 1248.00000 15.2000 -44.53125 0.00000 1.04300 1.04300 13.00000 1.15500 1.10100 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.3000 0.000 0.000 0.000 0.000
21.930 1248.00000 15.2000 -44.53125 0.00000 1.04300 1.04300 13.00000 1.15500 1.10100 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.3000 0.000 0.000 0.000 0.000
21.940 1248.00000 15.2000 -44.53125 0.00000 1.04300 1.04300 13.00000 1.15500 1.10100 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.3000 0.000 0.000 0.000 0.000
21.950 1266.00000 15.2000 -44.53125 0.00000 1.10700 1.10700 13.30000 1.15500 1.10100 4.60000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.3000 0.000 0.000 0.000 0.000
21.960 1266.00000 15.2000 -44.53125 0.00000 1.10700 1.10700 13.30000 1.15500 1.10100 4.60000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.3000 0.000 0.000 0.000 0.000
21.970 1266.00000 15.2000 -44.53125 0.00000 1.10700 1.10700 13.30000 1.15500 1.10100 4.60000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.3000 0.000 0.000 0.000 0.000
21.980 1266.00000 15.2000 -44.53125 0.00000 1.10700 1.10700 13.30000 1.15500 1.10100 4.60000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.3000 0.000 0.000 0.000 0.000
21.990 1266.00000 15.2000 -44.53125 0.00000 1.10700 1.10700 13.30000 1.15500 1.10100 4.60000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.3000 0.000 0.000 0.000 0.000
22.000 1279.00000 15.2000 -44.53125 0.00000 1.23500 1.23500 13.30000 1.15500 1.10100 4.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
22.010 1279.00000 15.2000 -44.53125 0.00000 1.23500 1.23500 13.30000 1.15500 1.10100 4.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
22.020 1279.00000 15.2000 -44.53125 0.00000 1.23500 1.23500 13.30000 1.15500 1.10100 4.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
22.030 1279.00000 15.2000 -44.53125 0.00000 1.23500 1.23500 13.30000 1.15500 1.10100 4.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
22.040 1279.00000 15.2000 -44.53125 0.00000 1.23500 1.23500 13.30000 1.15500 1.10100 4.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
22.050 1279.00000 15.2000 -44.53125 0.00000 1.19500 1.19500 13.60000 1.15500 1.10100 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
22.060 1279.00000 15.2000 -44.53125 0.00000 1.19500 1.19500 13.60000 1.15500 1.10100 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
22.070 1279.00000 15.2000 -44.53125 0.00000 1.19500 1.19500 13.60000 1.15500 1.10100 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
22.080 1279.00000 15.2000 -44.53125 0.00000 1.19500 1.19500 13.60000 1.15500 1.10100 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
22.090 1279.00000 15.2000 -44.53125 0.00000 1.19500 1.19500 13.60000 1.15500 1.10100 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
22.100 1279.00000 15.2000 -44.53125 0.00000 1.27600 1.27600 12.50000 1.13300 1.10700 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
22.110 1279.00000 15.2000 -44.53125 0.00000 1.27600 1.27600 12.50000 1.13300 1.10700 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
22.120 1279.00000 15.2000 -44.53125 0.00000 1.27600 1.27600 12.50000 1.13300 1.10700 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
22.130 1279.00000 15.2000 -44.53125 0.00000 1.27600 1.27600 12.50000 1.13300 1.10700 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
22.140 1279.00000 15.2000 -44.53125 0.00000 1.27600 1.27600 12.50000 1.13300 1.10700 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
22.150 1275.00000 15.2000 -44.53125 0.00000 1.31100 1.31100 13.40000 1.13300 1.10700 4.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.0000 0.000 0.000 0.000 0.000
22.160 1275.00000 15.2000 -44.53125 0.00000 1.31100 1.31100 13.40000 1.13300 1.10700 4.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.0000 0.000 0.000 0.000 0.000
22.170 1275.00000 15.2000 -44.53125 0.00000 1.31100 1.31100 13.40000 1.13300 1.10700 4.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.0000 0.000 0.000 0.000 0.000
22.180 1275.00000 15.2000 -44.53125 0.00000 1.31100 1.31100 13.40000 1.13300 1.10700 4.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.0000 0.000 0.000 0.000 0.000
22.190 1275.00000 15.2000 -44.53125 0.00000 1.31100 1.31100 13.40000 1.13300 1.10700 4.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.0000 0.000 0.000 0.000 0.000
22.200 1275.00000 15.2000 -44.53125 0.00000 1.54400 1.54400 13.30000 1.13300 1.10700 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
22.210 1275.00000 15.2000 -44.53125 0.00000 1.54400 1.54400 13.30000 1.13300 1.10700 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
22.220 1275.00000 15.2000 -44.53125 0.00000 1.54400 1.54400 13.30000 1.13300 1.10700 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
22.230 1275.00000 15.2000 -44.53125 0.00000 1.54400 1.54400 13.30000 1.13300 1.10700 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
22.240 1275.00000 15.2000 -44.53125 0.00000 1.54400 1.54400 13.30000 1.13300 1.10700 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
22.250 1202.00000 15.2000 -44.53125 0.00000 1.43900 1.43900 13.20000 1.13300 1.10700 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
22.260 1202.00000 15.2000 -44.53125 0.00000 1.43900 1.43900 13.20000 1.13300 1.10700 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
22.270 1202.00000 15.2000 -44.53125 0.00000 1.43900 1.43900 13.20000 1.13300 1.10700 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
22.280 1202.00000 15.2000 -44.53125 0.00000 1.43900 1.43900 13.20000 1.13300 1.10700 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
22.290 1202.00000 15.2000 -44.53125 0.00000 1.43900 1.43900 13.20000 1.13300 1.10700 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
22.300 1202.00000 15.2000 -44.53125 0.00000 1.45700 1.45700 13.20000 1.13600 1.12900 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
22.310 1202.00000 15.2000 -44.53125 0.00000 1.45700 1.45700 13.20000 1.13600 1.12900 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
22.320 1202.00000 15.2000 -44.53125 0.00000 1.45700 1.45700 13.20000 1.13600 1.12900 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
22.330 1202.00000 15.2000 -44.53125 0.00000 1.45700 1.45700 13.20000 1.13600 1.12900 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
22.340 1202.00000 15.2000 -44.53125 0.00000 1.45700 1.45700 13.20000 1.13600 1.12900 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
22.350 1136.00000 15.1000 -44.53125 0.00000 1.38700 1.38700 13.10000 1.13600 1.12900 4.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
22.360 1136.00000 15.1000 -44.53125 0.00000 1.38700 1.38700 13.10000 1.13600 1.12900 4.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
22.370 1136.00000 15.1000 -44.53125 0.00000 1.38700 1.38700 13.10000 1.13600 1.12900 4.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
22.380 1136.00000 15.1000 -44.53125 0.00000 1.38700 1.38700 13.10000 1.13600 1.12900 4.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
22.390 1136.00000 15.1000 -44.53125 0.00000 1.38700 1.38700 13.10000 1.13600 1.12900 4.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
22.400 1136.00000 15.2000 -44.53125 0.00000 1.34600 1.34600 13.60000 1.13600 1.12900 4.60000 1.00000 2.00000 2.00000 3.00000 3.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
22.410 1136.00000 15.2000 -44.53125 0.00000 1.34600 1.34600 13.60000 1.13600 1.12900 4.60000 1.00000 2.00000 2.00000 3.00000 3.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
22.420 1136.00000 15.2000 -44.53125 0.00000 1.34600 1.34600 13.60000 1.13600 1.12900 4.60000 1.00000 2.00000 2.00000 3.00000 3.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
22.430 1136.00000 15.2000 -44.53125 0.00000 1.34600 1.34600 13.60000 1.13600 1.12900 4.60000 1.00000 2.00000 2.00000 3.00000 3.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
22.440 1136.00000 15.2000 -44.53125 0.00000 1.34600 1.34600 13.60000 1.13600 1.12900 4.60000 1.00000 2.00000 2.00000 3.00000 3.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
22.450 1025.00000 15.2000 -44.53125 0.00000 1.31700 1.31700 12.60000 1.13600 1.12900 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
22.460 1025.00000 15.2000 -44.53125 0.00000 1.31700 1.31700 12.60000 1.13600 1.12900 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
22.470 1025.00000 15.2000 -44.53125 0.00000 1.31700 1.31700 12.60000 1.13600 1.12900 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
22.480 1025.00000 15.2000 -44.53125 0.00000 1.31700 1.31700 12.60000 1.13600 1.12900 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
22.490 1025.00000 15.2000 -44.53125 0.00000 1.31700 1.31700 12.60000 1.13600 1.12900 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
22.500 1025.00000 15.2000 -44.53125 0.00000 1.28200 1.28200 13.00000 1.15500 1.14500 4.90000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
22.510 1025.00000 15.2000 -44.53125 0.00000 1.28200 1.28200 13.00000 1.15500 1.14500 4.90000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
22.520 1025.00000 15.2000 -44.53125 0.00000 1.28200 1.28200 13.00000 1.15500 1.14500 4.90000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
22.530 1025.00000 15.2000 -44.53125 0.00000 1.28200 1.28200 13.00000 1.15500 1.14500 4.90000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
22.540 1025.00000 15.2000 -44.53125 0.00000 1.28200 1.28200 13.00000 1.15500 1.14500 4.90000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
22.550 792.00000 15.2000 -44.53125 0.00000 1.12500 1.12500 12.70000 1.15500 1.14500 5.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
22.560 792.00000 15.2000 -44.53125 0.00000 1.12500 1.12500 12.70000 1.15500 1.14500 5.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
22.570 792.00000 15.2000 -44.53125 0.00000 1.12500 1.12500 12.70000 1.15500 1.14500 5.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
22.580 792.00000 15.2000 -44.53125 0.00000 1.12500 1.12500 12.70000 1.15500 1.14500 5.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
22.590 792.00000 15.2000 -44.53125 0.00000 1.12500 1.12500 12.70000 1.15500 1.14500 5.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
22.600 792.00000 15.2000 -44.53125 0.00000 1.03100 1.03100 12.00000 1.15500 1.14500 5.70000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
22.610 792.00000 15.2000 -44.53125 0.00000 1.03100 1.03100 12.00000 1.15500 1.14500 5.70000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
22.620 792.00000 15.2000 -44.53125 0.00000 1.03100 1.03100 12.00000 1.15500 1.14500 5.70000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
22.630 792.00000 15.2000 -44.53125 0.00000 1.03100 1.03100 12.00000 1.15500 1.14500 5.70000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
22.640 792.00000 15.2000 -44.53125 0.00000 1.03100 1.03100 12.00000 1.15500 1.14500 5.70000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
22.650 792.00000 15.4000 -44.53125 0.00000 0.89100 0.89100 12.10000 1.15500 1.14500 6.00000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
22.660 792.00000 15.4000 -44.53125 0.00000 0.89100 0.89100 12.10000 1.15500 1.14500 6.00000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
22.670 792.00000 15.4000 -44.53125 0.00000 0.89100 0.89100 12.10000 1.15500 1.14500 6.00000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
22.680 792.00000 15.4000 -44.53125 0.00000 0.89100 0.89100 12.10000 1.15500 1.14500 6.00000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
22.690 792.00000 15.4000 -44.53125 0.00000 0.89100 0.89100 12.10000 1.15500 1.14500 6.00000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
22.700 578.00000 15.2000 -44.53125 0.00000 0.93200 0.93200 11.90000 1.14200 1.14500 6.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
22.710 578.00000 15.2000 -44.53125 0.00000 0.93200 0.93200 11.90000 1.14200 1.14500 6.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
22.720 578.00000 15.2000 -44.53125 0.00000 0.93200 0.93200 11.90000 1.14200 1.14500 6.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
22.730 578.00000 15.2000 -44.53125 0.00000 0.93200 0.93200 11.90000 1.14200 1.14500 6.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
22.740 578.00000 15.2000 -44.53125 0.00000 0.93200 0.93200 11.90000 1.14200 1.14500 6.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
22.750 578.00000 15.2000 -44.53125 0.00000 0.89700 0.89700 12.20000 1.14200 1.14500 6.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
22.760 578.00000 15.2000 -44.53125 0.00000 0.89700 0.89700 12.20000 1.14200 1.14500 6.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
22.770 578.00000 15.2000 -44.53125 0.00000 0.89700 0.89700 12.20000 1.14200 1.14500 6.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
22.780 578.00000 15.2000 -44.53125 0.00000 0.89700 0.89700 12.20000 1.14200 1.14500 6.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
22.790 578.00000 15.2000 -44.53125 0.00000 0.89700 0.89700 12.20000 1.14200 1.14500 6.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
22.800 578.00000 15.2000 -44.53125 0.00000 0.90300 0.90300 11.60000 1.14200 1.14500 7.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.3000 0.000 0.000 0.000 0.000
22.810 578.00000 15.2000 -44.53125 0.00000 0.90300 0.90300 11.60000 1.14200 1.14500 7.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.3000 0.000 0.000 0.000 0.000
22.820 578.00000 15.2000 -44.53125 0.00000 0.90300 0.90300 11.60000 1.14200 1.14500 7.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.3000 0.000 0.000 0.000 0.000
22.830 578.00000 15.2000 -44.53125 0.00000 0.90300 0.90300 11.60000 1.14200 1.14500 7.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.3000 0.000 0.000 0.000 0.000
22.840 578.00000 15.2000 -44.53125 0.00000 0.90300 0.90300 11.60000 1.14200 1.14500 7.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.3000 0.000 0.000 0.000 0.000
22.850 578.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 12.00000 1.14200 1.14500 7.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.3000 0.000 0.000 0.000 0.000
22.860 578.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 12.00000 1.14200 1.14500 7.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.3000 0.000 0.000 0.000 0.000
22.870 578.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 12.00000 1.14200 1.14500 7.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.3000 0.000 0.000 0.000 0.000
22.880 578.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 12.00000 1.14200 1.14500 7.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.3000 0.000 0.000 0.000 0.000
22.890 578.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 12.00000 1.14200 1.14500 7.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.3000 0.000 0.000 0.000 0.000
22.900 520.00000 15.2000 -44.53125 0.00000 0.94400 0.94400 11.90000 1.06900 1.15200 7.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.3000 0.000 0.000 0.000 0.000
22.910 520.00000 15.2000 -44.53125 0.00000 0.94400 0.94400 11.90000 1.06900 1.15200 7.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.3000 0.000 0.000 0.000 0.000
22.920 520.00000 15.2000 -44.53125 0.00000 0.94400 0.94400 11.90000 1.06900 1.15200 7.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.3000 0.000 0.000 0.000 0.000
22.930 520.00000 15.2000 -44.53125 0.00000 0.94400 0.94400 11.90000 1.06900 1.15200 7.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.3000 0.000 0.000 0.000 0.000
22.940 520.00000 15.2000 -44.53125 0.00000 0.94400 0.94400 11.90000 1.06900 1.15200 7.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.3000 0.000 0.000 0.000 0.000
22.950 520.00000 15.4000 -44.53125 0.00000 0.90900 0.90900 12.00000 1.06900 1.15200 7.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.0000 0.000 0.000 0.000 0.000
22.960 520.00000 15.4000 -44.53125 0.00000 0.90900 0.90900 12.00000 1.06900 1.15200 7.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.0000 0.000 0.000 0.000 0.000
22.970 520.00000 15.4000 -44.53125 0.00000 0.90900 0.90900 12.00000 1.06900 1.15200 7.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.0000 0.000 0.000 0.000 0.000
22.980 520.00000 15.4000 -44.53125 0.00000 0.90900 0.90900 12.00000 1.06900 1.15200 7.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.0000 0.000 0.000 0.000 0.000
22.990 520.00000 15.4000 -44.53125 0.00000 0.90900 0.90900 12.00000 1.06900 1.15200 7.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.0000 0.000 0.000 0.000 0.000
23.000 520.00000 15.2000 -44.53125 0.00000 0.92100 0.92100 12.20000 1.06900 1.15200 7.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
23.010 520.00000 15.2000 -44.53125 0.00000 0.92100 0.92100 12.20000 1.06900 1.15200 7.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
23.020 520.00000 15.2000 -44.53125 0.00000 0.92100 0.92100 12.20000 1.06900 1.15200 7.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
23.030 520.00000 15.2000 -44.53125 0.00000 0.92100 0.92100 12.20000 1.06900 1.15200 7.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
23.040 520.00000 15.2000 -44.53125 0.00000 0.92100 0.92100 12.20000 1.06900 1.15200 7.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
23.050 627.00000 15.2000 -44.53125 0.00000 0.95600 0.95600 12.60000 1.06900 1.15200 7.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.0000 0.000 0.000 0.000 0.000
23.060 627.00000 15.2000 -44.53125 0.00000 0.95600 0.95600 12.60000 1.06900 1.15200 7.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.0000 0.000 0.000 0.000 0.000
23.070 627.00000 15.2000 -44.53125 0.00000 0.95600 0.95600 12.60000 1.06900 1.15200 7.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.0000 0.000 0.000 0.000 0.000
23.080 627.00000 15.2000 -44.53125 0.00000 0.95600 0.95600 12.60000 1.06900 1.15200 7.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.0000 0.000 0.000 0.000 0.000
23.090 627.00000 15.2000 -44.53125 0.00000 0.95600 0.95600 12.60000 1.06900 1.15200 7.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.0000 0.000 0.000 0.000 0.000
23.100 627.00000 15.4000 -44.53125 0.00000 0.92600 0.92600 12.10000 1.11300 1.15500 6.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
23.110 627.00000 15.4000 -44.53125 0.00000 0.92600 0.92600 12.10000 1.11300 1.15500 6.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
23.120 627.00000 15.4000 -44.53125 0.00000 0.92600 0.92600 12.10000 1.11300 1.15500 6.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
23.130 627.00000 15.4000 -44.53125 0.00000 0.92600 0.92600 12.10000 1.11300 1.15500 6.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
23.140 627.00000 15.4000 -44.53125 0.00000 0.92600 0.92600 12.10000 1.11300 1.15500 6.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
23.150 627.00000 15.2000 -44.53125 0.00000 0.89100 0.89100 12.70000 1.11300 1.15500 6.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
23.160 627.00000 15.2000 -44.53125 0.00000 0.89100 0.89100 12.70000 1.11300 1.15500 6.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
23.170 627.00000 15.2000 -44.53125 0.00000 0.89100 0.89100 12.70000 1.11300 1.15500 6.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
23.180 627.00000 15.2000 -44.53125 0.00000 0.89100 0.89100 12.70000 1.11300 1.15500 6.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
23.190 627.00000 15.2000 -44.53125 0.00000 0.89100 0.89100 12.70000 1.11300 1.15500 6.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
23.200 835.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 13.30000 1.11300 1.15500 6.30000 1.00000 1.00000 2.00000 1.00000 2.00000 0.00000 0.00000 12.2000 0.000 0.000 0.000 0.000
23.210 835.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 13.30000 1.11300 1.15500 6.30000 1.00000 1.00000 2.00000 1.00000 2.00000 0.00000 0.00000 12.2000 0.000 0.000 0.000 0.000
23.220 835.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 13.30000 1.11300 1.15500 6.30000 1.00000 1.00000 2.00000 1.00000 2.00000 0.00000 0.00000 12.2000 0.000 0.000 0.000 0.000
23.230 835.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 13.30000 1.11300 1.15500 6.30000 1.00000 1.00000 2.00000 1.00000 2.00000 0.00000 0.00000 12.2000 0.000 0.000 0.000 0.000
23.240 835.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 13.30000 1.11300 1.15500 6.30000 1.00000 1.00000 2.00000 1.00000 2.00000 0.00000 0.00000 12.2000 0.000 0.000 0.000 0.000
23.250 835.00000 15.2000 -44.53125 0.00000 0.81000 0.81000 13.50000 1.11300 1.15500 5.70000 1.00000 1.00000 2.00000 1.00000 1.00000 0.00000 0.00000 11.5000 0.000 0.000 0.000 0.000
23.260 835.00000 15.2000 -44.53125 0.00000 0.81000 0.81000 13.50000 1.11300 1.15500 5.70000 1.00000 1.00000 2.00000 1.00000 1.00000 0.00000 0.00000 11.5000 0.000 0.000 0.000 0.000
23.270 835.00000 15.2000 -44.53125 0.00000 0.81000 0.81000 13.50000 1.11300 1.15500 5.70000 1.00000 1.00000 2.00000 1.00000 1.00000 0.00000 0.00000 11.5000 0.000 0.000 0.000 0.000
23.280 981.00000 15.4000 -44.53125 0.00000 0.83300 0.83300 12.60000 1.17100 1.15200 5.30000 1.00000 1.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.4000 0.000 0.000 0.000 0.000
23.290 981.00000 15.4000 -44.53125 0.00000 0.83300 0.83300 12.60000 1.17100 1.15200 5.30000 1.00000 1.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.4000 0.000 0.000 0.000 0.000
23.300 981.00000 15.4000 -44.53125 0.00000 0.83300 0.83300 12.60000 1.17100 1.15200 5.30000 1.00000 1.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.4000 0.000 0.000 0.000 0.000
23.310 981.00000 15.4000 -44.53125 0.00000 0.83300 0.83300 12.60000 1.17100 1.15200 5.30000 1.00000 1.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.4000 0.000 0.000 0.000 0.000
23.320 981.00000 15.4000 -44.53125 0.00000 0.83300 0.83300 12.60000 1.17100 1.15200 5.30000 1.00000 1.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.4000 0.000 0.000 0.000 0.000
23.330 981.00000 15.4000 -44.53125 0.00000 0.83300 0.83300 12.60000 1.17100 1.15200 5.30000 1.00000 1.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.4000 0.000 0.000 0.000 0.000
23.340 981.00000 15.4000 -44.53125 0.00000 0.83300 0.83300 12.60000 1.17100 1.15200 5.30000 1.00000 1.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.4000 0.000 0.000 0.000 0.000
23.350 1087.00000 15.4000 -44.53125 0.00000 0.89700 0.89700 12.20000 1.17100 1.15200 4.70000 1.00000 1.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.4000 0.000 0.000 0.000 0.000
23.360 1087.00000 15.4000 -44.53125 0.00000 0.89700 0.89700 12.20000 1.17100 1.15200 4.70000 1.00000 1.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.4000 0.000 0.000 0.000 0.000
23.370 1087.00000 15.4000 -44.53125 0.00000 0.89700 0.89700 12.20000 1.17100 1.15200 4.70000 1.00000 1.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.4000 0.000 0.000 0.000 0.000
23.380 1087.00000 15.4000 -44.53125 0.00000 0.89700 0.89700 12.20000 1.17100 1.15200 4.70000 1.00000 1.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.4000 0.000 0.000 0.000 0.000
23.390 1087.00000 15.4000 -44.53125 0.00000 0.89700 0.89700 12.20000 1.17100 1.15200 4.70000 1.00000 1.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.4000 0.000 0.000 0.000 0.000
23.400 1177.00000 15.2000 -44.53125 0.00000 0.96100 0.96100 13.20000 1.15800 1.15200 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.4000 0.000 0.000 0.000 0.000
23.410 1177.00000 15.2000 -44.53125 0.00000 0.96100 0.96100 13.20000 1.15800 1.15200 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.4000 0.000 0.000 0.000 0.000
23.420 1177.00000 15.2000 -44.53125 0.00000 0.96100 0.96100 13.20000 1.15800 1.15200 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.4000 0.000 0.000 0.000 0.000
23.430 1177.00000 15.2000 -44.53125 0.00000 0.96100 0.96100 13.20000 1.15800 1.15200 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.4000 0.000 0.000 0.000 0.000
23.440 1177.00000 15.2000 -44.53125 0.00000 0.96100 0.96100 13.20000 1.15800 1.15200 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.4000 0.000 0.000 0.000 0.000
23.450 1176.00000 15.2000 -44.53125 0.00000 1.02000 1.02000 13.30000 1.15800 1.15200 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.9000 0.000 0.000 0.000 0.000
23.460 1176.00000 15.2000 -44.53125 0.00000 1.02000 1.02000 13.30000 1.15800 1.15200 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.9000 0.000 0.000 0.000 0.000
23.470 1176.00000 15.2000 -44.53125 0.00000 1.02000 1.02000 13.30000 1.15800 1.15200 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.9000 0.000 0.000 0.000 0.000
23.480 1176.00000 15.2000 -44.53125 0.00000 1.02000 1.02000 13.30000 1.15800 1.15200 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.9000 0.000 0.000 0.000 0.000
23.490 1176.00000 15.2000 -44.53125 0.00000 1.02000 1.02000 13.30000 1.15800 1.15200 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.9000 0.000 0.000 0.000 0.000
23.500 1176.00000 15.2000 -44.53125 0.00000 1.02000 1.02000 13.30000 1.15800 1.15200 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.9000 0.000 0.000 0.000 0.000
23.510 1176.00000 15.2000 -44.53125 0.00000 1.02000 1.02000 13.30000 1.15800 1.15200 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.9000 0.000 0.000 0.000 0.000
23.520 1176.00000 15.2000 -44.53125 0.00000 1.02000 1.02000 13.30000 1.15800 1.15200 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.9000 0.000 0.000 0.000 0.000
23.530 1176.00000 15.2000 -44.53125 0.00000 1.02000 1.02000 13.30000 1.15800 1.15200 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.9000 0.000 0.000 0.000 0.000
23.540 1176.00000 15.2000 -44.53125 0.00000 1.02000 1.02000 13.30000 1.15800 1.15200 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.9000 0.000 0.000 0.000 0.000
23.550 1161.00000 15.2000 -44.53125 0.00000 0.97900 0.97900 13.40000 1.15800 1.15200 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.9000 0.000 0.000 0.000 0.000
23.560 1161.00000 15.2000 -44.53125 0.00000 0.97900 0.97900 13.40000 1.15800 1.15200 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.9000 0.000 0.000 0.000 0.000
23.570 1161.00000 15.2000 -44.53125 0.00000 0.97900 0.97900 13.40000 1.15800 1.15200 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.9000 0.000 0.000 0.000 0.000
23.580 1161.00000 15.2000 -44.53125 0.00000 0.97900 0.97900 13.40000 1.15800 1.15200 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.9000 0.000 0.000 0.000 0.000
23.590 1161.00000 15.2000 -44.53125 0.00000 0.97900 0.97900 13.40000 1.15800 1.15200 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.9000 0.000 0.000 0.000 0.000
23.600 1161.00000 15.2000 -44.53125 0.00000 0.97900 0.97900 13.40000 1.15800 1.15200 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.9000 0.000 0.000 0.000 0.000
23.610 1161.00000 15.2000 -44.53125 0.00000 0.97900 0.97900 13.40000 1.15800 1.15200 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.9000 0.000 0.000 0.000 0.000
23.620 1161.00000 15.2000 -44.53125 0.00000 0.97900 0.97900 13.40000 1.15800 1.15200 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.9000 0.000 0.000 0.000 0.000
23.630 1161.00000 15.2000 -44.53125 0.00000 0.97900 0.97900 13.40000 1.15800 1.15200 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.9000 0.000 0.000 0.000 0.000
23.640 1161.00000 15.2000 -44.53125 0.00000 0.97900 0.97900 13.40000 1.15800 1.15200 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.9000 0.000 0.000 0.000 0.000
23.650 1161.00000 15.2000 -44.53125 0.00000 1.10100 1.10100 13.30000 1.15800 1.15200 4.60000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.9000 0.000 0.000 0.000 0.000
23.660 1161.00000 15.2000 -44.53125 0.00000 1.10100 1.10100 13.30000 1.15800 1.15200 4.60000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.9000 0.000 0.000 0.000 0.000
23.670 1161.00000 15.2000 -44.53125 0.00000 1.10100 1.10100 13.30000 1.15800 1.15200 4.60000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.9000 0.000 0.000 0.000 0.000
23.680 1161.00000 15.2000 -44.53125 0.00000 1.10100 1.10100 13.30000 1.15800 1.15200 4.60000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.9000 0.000 0.000 0.000 0.000
23.690 1161.00000 15.2000 -44.53125 0.00000 1.10100 1.10100 13.30000 1.15800 1.15200 4.60000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 10.9000 0.000 0.000 0.000 0.000
23.700 1163.00000 15.2000 -44.53125 0.00000 1.09600 1.09600 13.30000 1.12900 1.14500 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.6000 0.000 0.000 0.000 0.000
23.710 1163.00000 15.2000 -44.53125 0.00000 1.09600 1.09600 13.30000 1.12900 1.14500 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.6000 0.000 0.000 0.000 0.000
23.720 1163.00000 15.2000 -44.53125 0.00000 1.09600 1.09600 13.30000 1.12900 1.14500 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.6000 0.000 0.000 0.000 0.000
23.730 1163.00000 15.2000 -44.53125 0.00000 1.09600 1.09600 13.30000 1.12900 1.14500 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.6000 0.000 0.000 0.000 0.000
23.740 1163.00000 15.2000 -44.53125 0.00000 1.09600 1.09600 13.30000 1.12900 1.14500 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.6000 0.000 0.000 0.000 0.000
23.750 1163.00000 15.2000 -44.53125 0.00000 1.09600 1.09600 13.20000 1.12900 1.14500 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.5000 0.000 0.000 0.000 0.000
23.760 1163.00000 15.2000 -44.53125 0.00000 1.09600 1.09600 13.20000 1.12900 1.14500 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.5000 0.000 0.000 0.000 0.000
23.770 1163.00000 15.2000 -44.53125 0.00000 1.09600 1.09600 13.20000 1.12900 1.14500 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.5000 0.000 0.000 0.000 0.000
23.780 1163.00000 15.2000 -44.53125 0.00000 1.09600 1.09600 13.20000 1.12900 1.14500 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.5000 0.000 0.000 0.000 0.000
23.790 1163.00000 15.2000 -44.53125 0.00000 1.09600 1.09600 13.20000 1.12900 1.14500 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.5000 0.000 0.000 0.000 0.000
23.800 1115.00000 15.2000 -44.53125 0.00000 1.09600 1.09600 13.30000 1.12900 1.14500 4.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.6000 0.000 0.000 0.000 0.000
23.810 1115.00000 15.2000 -44.53125 0.00000 1.09600 1.09600 13.30000 1.12900 1.14500 4.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.6000 0.000 0.000 0.000 0.000
23.820 1115.00000 15.2000 -44.53125 0.00000 1.09600 1.09600 13.30000 1.12900 1.14500 4.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.6000 0.000 0.000 0.000 0.000
23.830 1115.00000 15.2000 -44.53125 0.00000 1.09600 1.09600 13.30000 1.12900 1.14500 4.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.6000 0.000 0.000 0.000 0.000
23.840 1115.00000 15.2000 -44.53125 0.00000 1.09600 1.09600 13.30000 1.12900 1.14500 4.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 11.6000 0.000 0.000 0.000 0.000
23.850 1115.00000 15.1000 -44.53125 0.00000 1.16000 1.16000 13.20000 1.12900 1.14500 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.2000 0.000 0.000 0.000 0.000
23.860 1115.00000 15.1000 -44.53125 0.00000 1.16000 1.16000 13.20000 1.12900 1.14500 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.2000 0.000 0.000 0.000 0.000
23.870 1115.00000 15.1000 -44.53125 0.00000 1.16000 1.16000 13.20000 1.12900 1.14500 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.2000 0.000 0.000 0.000 0.000
23.880 1115.00000 15.1000 -44.53125 0.00000 1.16000 1.16000 13.20000 1.12900 1.14500 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.2000 0.000 0.000 0.000 0.000
23.890 1115.00000 15.1000 -44.53125 0.00000 1.16000 1.16000 13.20000 1.12900 1.14500 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.2000 0.000 0.000 0.000 0.000
23.900 1115.00000 15.1000 -44.53125 0.00000 1.16000 1.16000 13.20000 1.12900 1.14500 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.2000 0.000 0.000 0.000 0.000
23.910 1084.00000 15.2000 -44.53125 0.00000 1.14800 1.14800 13.50000 1.08800 1.14900 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.3000 0.000 0.000 0.000 0.000
23.920 1084.00000 15.2000 -44.53125 0.00000 1.14800 1.14800 13.50000 1.08800 1.14900 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.3000 0.000 0.000 0.000 0.000
23.930 1084.00000 15.2000 -44.53125 0.00000 1.14800 1.14800 13.50000 1.08800 1.14900 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.3000 0.000 0.000 0.000 0.000
23.940 1084.00000 15.2000 -44.53125 0.00000 1.14800 1.14800 13.50000 1.08800 1.14900 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.3000 0.000 0.000 0.000 0.000
23.950 1084.00000 15.2000 -44.53125 0.00000 1.14800 1.14800 13.50000 1.08800 1.14900 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.3000 0.000 0.000 0.000 0.000
23.960 1084.00000 15.2000 -44.53125 0.00000 1.14800 1.14800 13.50000 1.08800 1.14900 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.3000 0.000 0.000 0.000 0.000
23.970 1048.00000 15.2000 -44.53125 0.00000 1.11900 1.11900 13.40000 1.08800 1.14900 4.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.3000 0.000 0.000 0.000 0.000
23.980 1048.00000 15.2000 -44.53125 0.00000 1.11900 1.11900 13.40000 1.08800 1.14900 4.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.3000 0.000 0.000 0.000 0.000
23.990 1048.00000 15.2000 -44.53125 0.00000 1.11900 1.11900 13.40000 1.08800 1.14900 4.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.3000 0.000 0.000 0.000 0.000
24.000 1048.00000 15.2000 -44.53125 0.00000 1.11900 1.11900 13.40000 1.08800 1.14900 4.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.3000 0.000 0.000 0.000 0.000
24.010 1048.00000 15.2000 -44.53125 0.00000 1.11900 1.11900 13.40000 1.08800 1.14900 4.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.3000 0.000 0.000 0.000 0.000
24.020 1048.00000 15.2000 -44.53125 0.00000 1.11900 1.11900 13.40000 1.08800 1.14900 4.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.3000 0.000 0.000 0.000 0.000
24.030 999.00000 15.2000 -44.53125 0.00000 1.16000 1.16000 13.00000 1.09800 1.15200 4.60000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.1000 0.000 0.000 0.000 0.000
24.040 999.00000 15.2000 -44.53125 0.00000 1.16000 1.16000 13.00000 1.09800 1.15200 4.60000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.1000 0.000 0.000 0.000 0.000
24.050 999.00000 15.2000 -44.53125 0.00000 1.16000 1.16000 13.00000 1.09800 1.15200 4.60000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.1000 0.000 0.000 0.000 0.000
24.060 999.00000 15.2000 -44.53125 0.00000 1.16000 1.16000 13.00000 1.09800 1.15200 4.60000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.1000 0.000 0.000 0.000 0.000
24.070 999.00000 15.2000 -44.53125 0.00000 1.16000 1.16000 13.00000 1.09800 1.15200 4.60000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.1000 0.000 0.000 0.000 0.000
24.080 999.00000 15.1000 -44.53125 0.00000 1.14200 1.14200 13.40000 1.09800 1.15200 4.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.2000 0.000 0.000 0.000 0.000
24.090 999.00000 15.1000 -44.53125 0.00000 1.14200 1.14200 13.40000 1.09800 1.15200 4.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.2000 0.000 0.000 0.000 0.000
24.100 999.00000 15.1000 -44.53125 0.00000 1.14200 1.14200 13.40000 1.09800 1.15200 4.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.2000 0.000 0.000 0.000 0.000
24.110 999.00000 15.1000 -44.53125 0.00000 1.14200 1.14200 13.40000 1.09800 1.15200 4.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.2000 0.000 0.000 0.000 0.000
24.120 999.00000 15.1000 -44.53125 0.00000 1.14200 1.14200 13.40000 1.09800 1.15200 4.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.2000 0.000 0.000 0.000 0.000
24.130 921.00000 15.2000 -44.53125 0.00000 1.07200 1.07200 13.30000 1.09800 1.15200 4.60000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
24.140 921.00000 15.2000 -44.53125 0.00000 1.07200 1.07200 13.30000 1.09800 1.15200 4.60000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
24.150 921.00000 15.2000 -44.53125 0.00000 1.07200 1.07200 13.30000 1.09800 1.15200 4.60000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
24.160 921.00000 15.2000 -44.53125 0.00000 1.07200 1.07200 13.30000 1.09800 1.15200 4.60000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
24.170 921.00000 15.2000 -44.53125 0.00000 1.07200 1.07200 13.30000 1.09800 1.15200 4.60000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
24.180 921.00000 15.2000 -44.53125 0.00000 1.02600 1.02600 13.50000 1.09800 1.15200 4.70000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.4000 0.000 0.000 0.000 0.000
24.190 921.00000 15.2000 -44.53125 0.00000 1.02600 1.02600 13.50000 1.09800 1.15200 4.70000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.4000 0.000 0.000 0.000 0.000
24.200 921.00000 15.2000 -44.53125 0.00000 1.02600 1.02600 13.50000 1.09800 1.15200 4.70000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.4000 0.000 0.000 0.000 0.000
24.210 921.00000 15.2000 -44.53125 0.00000 1.02600 1.02600 13.50000 1.09800 1.15200 4.70000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.4000 0.000 0.000 0.000 0.000
24.220 921.00000 15.2000 -44.53125 0.00000 1.02600 1.02600 13.50000 1.09800 1.15200 4.70000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 13.4000 0.000 0.000 0.000 0.000
24.230 840.00000 15.2000 -44.53125 0.00000 1.08400 1.08400 13.20000 1.13600 1.15500 5.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
24.240 840.00000 15.2000 -44.53125 0.00000 1.08400 1.08400 13.20000 1.13600 1.15500 5.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
24.250 840.00000 15.2000 -44.53125 0.00000 1.08400 1.08400 13.20000 1.13600 1.15500 5.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
24.260 840.00000 15.2000 -44.53125 0.00000 1.08400 1.08400 13.20000 1.13600 1.15500 5.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
24.270 840.00000 15.2000 -44.53125 0.00000 1.08400 1.08400 13.20000 1.13600 1.15500 5.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
24.280 840.00000 15.2000 -44.53125 0.00000 0.98500 0.98500 13.20000 1.13600 1.15500 4.80000 1.00000 1.00000 1.00000 1.00000 2.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
24.290 840.00000 15.2000 -44.53125 0.00000 0.98500 0.98500 13.20000 1.13600 1.15500 4.80000 1.00000 1.00000 1.00000 1.00000 2.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
24.300 840.00000 15.2000 -44.53125 0.00000 0.98500 0.98500 13.20000 1.13600 1.15500 4.80000 1.00000 1.00000 1.00000 1.00000 2.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
24.310 840.00000 15.2000 -44.53125 0.00000 0.98500 0.98500 13.20000 1.13600 1.15500 4.80000 1.00000 1.00000 1.00000 1.00000 2.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
24.320 840.00000 15.2000 -44.53125 0.00000 0.98500 0.98500 13.20000 1.13600 1.15500 4.80000 1.00000 1.00000 1.00000 1.00000 2.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
24.330 840.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 13.20000 1.13600 1.15500 5.10000 1.00000 1.00000 2.00000 1.00000 2.00000 0.00000 0.00000 13.4000 0.000 0.000 0.000 0.000
24.340 840.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 13.20000 1.13600 1.15500 5.10000 1.00000 1.00000 2.00000 1.00000 2.00000 0.00000 0.00000 13.4000 0.000 0.000 0.000 0.000
24.350 840.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 13.20000 1.13600 1.15500 5.10000 1.00000 1.00000 2.00000 1.00000 2.00000 0.00000 0.00000 13.4000 0.000 0.000 0.000 0.000
24.360 840.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 13.20000 1.13600 1.15500 5.10000 1.00000 1.00000 2.00000 1.00000 2.00000 0.00000 0.00000 13.4000 0.000 0.000 0.000 0.000
24.370 840.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 13.20000 1.13600 1.15500 5.10000 1.00000 1.00000 2.00000 1.00000 2.00000 0.00000 0.00000 13.4000 0.000 0.000 0.000 0.000
24.380 840.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 13.20000 1.13600 1.15500 5.10000 1.00000 1.00000 2.00000 1.00000 2.00000 0.00000 0.00000 13.4000 0.000 0.000 0.000 0.000
24.390 840.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 13.20000 1.13600 1.15500 5.10000 1.00000 1.00000 2.00000 1.00000 2.00000 0.00000 0.00000 13.4000 0.000 0.000 0.000 0.000
24.400 840.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 13.20000 1.13600 1.15500 5.10000 1.00000 1.00000 2.00000 1.00000 2.00000 0.00000 0.00000 13.4000 0.000 0.000 0.000 0.000
24.410 840.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 13.20000 1.13600 1.15500 5.10000 1.00000 1.00000 2.00000 1.00000 2.00000 0.00000 0.00000 13.4000 0.000 0.000 0.000 0.000
24.420 840.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 13.20000 1.13600 1.15500 5.10000 1.00000 1.00000 2.00000 1.00000 2.00000 0.00000 0.00000 13.4000 0.000 0.000 0.000 0.000
24.430 758.00000 15.2000 -44.53125 0.00000 0.94400 0.94400 12.60000 1.13600 1.15500 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
24.440 758.00000 15.2000 -44.53125 0.00000 0.94400 0.94400 12.60000 1.13600 1.15500 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
24.450 758.00000 15.2000 -44.53125 0.00000 0.94400 0.94400 12.60000 1.13600 1.15500 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
24.460 758.00000 15.2000 -44.53125 0.00000 0.94400 0.94400 12.60000 1.13600 1.15500 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
24.470 758.00000 15.2000 -44.53125 0.00000 0.94400 0.94400 12.60000 1.13600 1.15500 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
24.480 758.00000 15.2000 -44.53125 0.00000 0.94400 0.94400 12.60000 1.13600 1.15500 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
24.490 758.00000 15.2000 -44.53125 0.00000 0.93800 0.93800 12.30000 1.15500 1.14900 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
24.500 758.00000 15.2000 -44.53125 0.00000 0.93800 0.93800 12.30000 1.15500 1.14900 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
24.510 758.00000 15.2000 -44.53125 0.00000 0.93800 0.93800 12.30000 1.15500 1.14900 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
24.520 758.00000 15.2000 -44.53125 0.00000 0.93800 0.93800 12.30000 1.15500 1.14900 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
24.530 758.00000 15.2000 -44.53125 0.00000 0.93800 0.93800 12.30000 1.15500 1.14900 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
24.540 758.00000 15.2000 -44.53125 0.00000 0.93800 0.93800 12.30000 1.15500 1.14900 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
24.550 745.00000 15.2000 -44.53125 0.00000 0.92600 0.92600 12.50000 1.15500 1.14900 5.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
24.560 745.00000 15.2000 -44.53125 0.00000 0.92600 0.92600 12.50000 1.15500 1.14900 5.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
24.570 745.00000 15.2000 -44.53125 0.00000 0.92600 0.92600 12.50000 1.15500 1.14900 5.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
24.580 745.00000 15.2000 -44.53125 0.00000 0.92600 0.92600 12.50000 1.15500 1.14900 5.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
24.590 745.00000 15.2000 -44.53125 0.00000 0.92600 0.92600 12.50000 1.15500 1.14900 5.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
24.600 745.00000 15.2000 -44.53125 0.00000 0.92600 0.92600 12.50000 1.15500 1.14900 5.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
24.610 745.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 12.70000 1.15500 1.14900 5.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
24.620 745.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 12.70000 1.15500 1.14900 5.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
24.630 745.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 12.70000 1.15500 1.14900 5.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
24.640 745.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 12.70000 1.15500 1.14900 5.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
24.650 745.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 12.70000 1.15500 1.14900 5.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
24.660 745.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 12.70000 1.15500 1.14900 5.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
24.670 754.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 13.20000 1.16800 1.15200 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
24.680 754.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 13.20000 1.16800 1.15200 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
24.690 754.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 13.20000 1.16800 1.15200 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
24.700 754.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 13.20000 1.16800 1.15200 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
24.710 754.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 13.20000 1.16800 1.15200 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
24.720 754.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 13.10000 1.16800 1.15200 5.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
24.730 754.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 13.10000 1.16800 1.15200 5.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
24.740 754.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 13.10000 1.16800 1.15200 5.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
24.750 754.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 13.10000 1.16800 1.15200 5.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
24.760 754.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 13.10000 1.16800 1.15200 5.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
24.770 815.00000 15.2000 -44.53125 0.00000 0.85600 0.85600 13.30000 1.16800 1.15200 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
24.780 815.00000 15.2000 -44.53125 0.00000 0.85600 0.85600 13.30000 1.16800 1.15200 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
24.790 815.00000 15.2000 -44.53125 0.00000 0.85600 0.85600 13.30000 1.16800 1.15200 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
24.800 815.00000 15.2000 -44.53125 0.00000 0.85600 0.85600 13.30000 1.16800 1.15200 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
24.810 815.00000 15.2000 -44.53125 0.00000 0.85600 0.85600 13.30000 1.16800 1.15200 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
24.820 815.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 13.10000 1.16800 1.15200 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
24.830 815.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 13.10000 1.16800 1.15200 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
24.840 815.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 13.10000 1.16800 1.15200 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
24.850 815.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 13.10000 1.16800 1.15200 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
24.860 815.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 13.10000 1.16800 1.15200 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
24.870 815.00000 15.4000 -44.53125 0.00000 0.86800 0.86800 12.70000 1.16800 1.14500 5.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
24.880 815.00000 15.4000 -44.53125 0.00000 0.86800 0.86800 12.70000 1.16800 1.14500 5.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
24.890 815.00000 15.4000 -44.53125 0.00000 0.86800 0.86800 12.70000 1.16800 1.14500 5.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
24.900 815.00000 15.4000 -44.53125 0.00000 0.86800 0.86800 12.70000 1.16800 1.14500 5.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
24.910 815.00000 15.4000 -44.53125 0.00000 0.86800 0.86800 12.70000 1.16800 1.14500 5.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
24.920 900.00000 15.2000 -44.53125 0.00000 0.82700 0.82700 13.30000 1.16800 1.14500 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
24.930 900.00000 15.2000 -44.53125 0.00000 0.82700 0.82700 13.30000 1.16800 1.14500 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
24.940 900.00000 15.2000 -44.53125 0.00000 0.82700 0.82700 13.30000 1.16800 1.14500 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
24.950 900.00000 15.2000 -44.53125 0.00000 0.82700 0.82700 13.30000 1.16800 1.14500 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
24.960 900.00000 15.2000 -44.53125 0.00000 0.82700 0.82700 13.30000 1.16800 1.14500 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
24.970 900.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 13.50000 1.16800 1.14500 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.3000 0.000 0.000 0.000 0.000
24.980 900.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 13.50000 1.16800 1.14500 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.3000 0.000 0.000 0.000 0.000
24.990 900.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 13.50000 1.16800 1.14500 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.3000 0.000 0.000 0.000 0.000
25.000 900.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 13.50000 1.16800 1.14500 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.3000 0.000 0.000 0.000 0.000
25.010 900.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 13.50000 1.16800 1.14500 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.3000 0.000 0.000 0.000 0.000
25.020 941.00000 15.4000 -44.53125 0.00000 0.90900 0.90900 12.20000 1.16800 1.14500 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.3000 0.000 0.000 0.000 0.000
25.030 941.00000 15.4000 -44.53125 0.00000 0.90900 0.90900 12.20000 1.16800 1.14500 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.3000 0.000 0.000 0.000 0.000
25.040 941.00000 15.4000 -44.53125 0.00000 0.90900 0.90900 12.20000 1.16800 1.14500 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.3000 0.000 0.000 0.000 0.000
25.050 941.00000 15.4000 -44.53125 0.00000 0.90900 0.90900 12.20000 1.16800 1.14500 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.3000 0.000 0.000 0.000 0.000
25.060 941.00000 15.4000 -44.53125 0.00000 0.90900 0.90900 12.20000 1.16800 1.14500 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.3000 0.000 0.000 0.000 0.000
25.070 941.00000 15.2000 -44.53125 0.00000 0.92600 0.92600 13.20000 1.15500 1.14200 4.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.3000 0.000 0.000 0.000 0.000
25.080 941.00000 15.2000 -44.53125 0.00000 0.92600 0.92600 13.20000 1.15500 1.14200 4.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.3000 0.000 0.000 0.000 0.000
25.090 941.00000 15.2000 -44.53125 0.00000 0.92600 0.92600 13.20000 1.15500 1.14200 4.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.3000 0.000 0.000 0.000 0.000
25.100 941.00000 15.2000 -44.53125 0.00000 0.92600 0.92600 13.20000 1.15500 1.14200 4.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.3000 0.000 0.000 0.000 0.000
25.110 941.00000 15.2000 -44.53125 0.00000 0.92600 0.92600 13.20000 1.15500 1.14200 4.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.3000 0.000 0.000 0.000 0.000
25.120 973.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 13.40000 1.15500 1.14200 5.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.3000 0.000 0.000 0.000 0.000
25.130 973.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 13.40000 1.15500 1.14200 5.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.3000 0.000 0.000 0.000 0.000
25.140 973.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 13.40000 1.15500 1.14200 5.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.3000 0.000 0.000 0.000 0.000
25.150 973.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 13.40000 1.15500 1.14200 5.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.3000 0.000 0.000 0.000 0.000
25.160 973.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 13.40000 1.15500 1.14200 5.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.3000 0.000 0.000 0.000 0.000
25.170 973.00000 15.2000 -44.53125 0.00000 0.93200 0.93200 13.20000 1.15500 1.14200 4.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.3000 0.000 0.000 0.000 0.000
25.180 973.00000 15.2000 -44.53125 0.00000 0.93200 0.93200 13.20000 1.15500 1.14200 4.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.3000 0.000 0.000 0.000 0.000
25.190 973.00000 15.2000 -44.53125 0.00000 0.93200 0.93200 13.20000 1.15500 1.14200 4.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.3000 0.000 0.000 0.000 0.000
25.200 973.00000 15.2000 -44.53125 0.00000 0.93200 0.93200 13.20000 1.15500 1.14200 4.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.3000 0.000 0.000 0.000 0.000
25.210 973.00000 15.2000 -44.53125 0.00000 0.93200 0.93200 13.20000 1.15500 1.14200 4.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.3000 0.000 0.000 0.000 0.000
25.220 974.00000 15.4000 -44.53125 0.00000 0.93200 0.93200 12.50000 1.15500 1.14200 4.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.3000 0.000 0.000 0.000 0.000
25.230 974.00000 15.4000 -44.53125 0.00000 0.93200 0.93200 12.50000 1.15500 1.14200 4.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.3000 0.000 0.000 0.000 0.000
25.240 974.00000 15.4000 -44.53125 0.00000 0.93200 0.93200 12.50000 1.15500 1.14200 4.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.3000 0.000 0.000 0.000 0.000
25.250 974.00000 15.4000 -44.53125 0.00000 0.93200 0.93200 12.50000 1.15500 1.14200 4.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.3000 0.000 0.000 0.000 0.000
25.260 974.00000 15.4000 -44.53125 0.00000 0.93200 0.93200 12.50000 1.15500 1.14200 4.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.3000 0.000 0.000 0.000 0.000
25.270 974.00000 15.2000 -44.53125 0.00000 0.97900 0.97900 13.30000 1.14200 1.14900 4.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.6000 0.000 0.000 0.000 0.000
25.280 974.00000 15.2000 -44.53125 0.00000 0.97900 0.97900 13.30000 1.14200 1.14900 4.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.6000 0.000 0.000 0.000 0.000
25.290 974.00000 15.2000 -44.53125 0.00000 0.97900 0.97900 13.30000 1.14200 1.14900 4.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.6000 0.000 0.000 0.000 0.000
25.300 974.00000 15.2000 -44.53125 0.00000 0.97900 0.97900 13.30000 1.14200 1.14900 4.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.6000 0.000 0.000 0.000 0.000
25.310 974.00000 15.2000 -44.53125 0.00000 0.97900 0.97900 13.30000 1.14200 1.14900 4.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.6000 0.000 0.000 0.000 0.000
25.320 974.00000 15.2000 -44.53125 0.00000 0.97900 0.97900 13.30000 1.14200 1.14900 4.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.6000 0.000 0.000 0.000 0.000
25.330 990.00000 15.2000 -44.53125 0.00000 0.90300 0.90300 13.30000 1.14200 1.14900 4.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.6000 0.000 0.000 0.000 0.000
25.340 990.00000 15.2000 -44.53125 0.00000 0.90300 0.90300 13.30000 1.14200 1.14900 4.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.6000 0.000 0.000 0.000 0.000
25.350 990.00000 15.2000 -44.53125 0.00000 0.90300 0.90300 13.30000 1.14200 1.14900 4.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.6000 0.000 0.000 0.000 0.000
25.360 990.00000 15.2000 -44.53125 0.00000 0.90300 0.90300 13.30000 1.14200 1.14900 4.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.6000 0.000 0.000 0.000 0.000
25.370 990.00000 15.2000 -44.53125 0.00000 0.90300 0.90300 13.30000 1.14200 1.14900 4.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.6000 0.000 0.000 0.000 0.000
25.380 990.00000 15.2000 -44.53125 0.00000 0.90300 0.90300 13.30000 1.14200 1.14900 4.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.6000 0.000 0.000 0.000 0.000
25.390 956.00000 15.2000 -44.53125 0.00000 0.93200 0.93200 13.20000 1.14200 1.14900 4.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.6000 0.000 0.000 0.000 0.000
25.400 956.00000 15.2000 -44.53125 0.00000 0.93200 0.93200 13.20000 1.14200 1.14900 4.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.6000 0.000 0.000 0.000 0.000
25.410 956.00000 15.2000 -44.53125 0.00000 0.93200 0.93200 13.20000 1.14200 1.14900 4.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.6000 0.000 0.000 0.000 0.000
25.420 956.00000 15.2000 -44.53125 0.00000 0.93200 0.93200 13.20000 1.14200 1.14900 4.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.6000 0.000 0.000 0.000 0.000
25.430 956.00000 15.2000 -44.53125 0.00000 0.93200 0.93200 13.20000 1.14200 1.14900 4.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.6000 0.000 0.000 0.000 0.000
25.440 956.00000 15.2000 -44.53125 0.00000 0.93200 0.93200 13.20000 1.14200 1.14900 4.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 11.6000 0.000 0.000 0.000 0.000
25.450 956.00000 15.2000 -44.53125 0.00000 0.89100 0.89100 13.40000 1.14200 1.14900 4.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.0000 0.000 0.000 0.000 0.000
25.460 934.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 13.00000 1.12300 1.16500 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.0000 0.000 0.000 0.000 0.000
25.470 934.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 13.00000 1.12300 1.16500 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.0000 0.000 0.000 0.000 0.000
25.480 934.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 13.00000 1.12300 1.16500 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.0000 0.000 0.000 0.000 0.000
25.490 934.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 13.00000 1.12300 1.16500 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.0000 0.000 0.000 0.000 0.000
25.500 934.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 13.00000 1.12300 1.16500 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.0000 0.000 0.000 0.000 0.000
25.510 934.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 13.00000 1.12300 1.16500 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.0000 0.000 0.000 0.000 0.000
25.520 934.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 13.00000 1.12300 1.16500 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.0000 0.000 0.000 0.000 0.000
25.530 934.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 13.00000 1.12300 1.16500 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.0000 0.000 0.000 0.000 0.000
25.540 934.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 13.00000 1.12300 1.16500 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.0000 0.000 0.000 0.000 0.000
25.550 934.00000 15.2000 -44.53125 0.00000 0.95600 0.95600 13.20000 1.12300 1.16500 4.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
25.560 934.00000 15.2000 -44.53125 0.00000 0.95600 0.95600 13.20000 1.12300 1.16500 4.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
25.570 934.00000 15.2000 -44.53125 0.00000 0.95600 0.95600 13.20000 1.12300 1.16500 4.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
25.580 934.00000 15.2000 -44.53125 0.00000 0.95600 0.95600 13.20000 1.12300 1.16500 4.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
25.590 934.00000 15.2000 -44.53125 0.00000 0.95600 0.95600 13.20000 1.12300 1.16500 4.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
25.600 909.00000 15.2000 -44.53125 0.00000 0.95000 0.95000 12.70000 1.12300 1.16500 4.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
25.610 909.00000 15.2000 -44.53125 0.00000 0.95000 0.95000 12.70000 1.12300 1.16500 4.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
25.620 909.00000 15.2000 -44.53125 0.00000 0.95000 0.95000 12.70000 1.12300 1.16500 4.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
25.630 909.00000 15.2000 -44.53125 0.00000 0.95000 0.95000 12.70000 1.12300 1.16500 4.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
25.640 909.00000 15.2000 -44.53125 0.00000 0.95000 0.95000 12.70000 1.12300 1.16500 4.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
25.650 909.00000 15.2000 -44.53125 0.00000 0.97300 0.97300 13.20000 1.12300 1.16500 4.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
25.660 909.00000 15.2000 -44.53125 0.00000 0.97300 0.97300 13.20000 1.12300 1.16500 4.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
25.670 909.00000 15.2000 -44.53125 0.00000 0.97300 0.97300 13.20000 1.12300 1.16500 4.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
25.680 909.00000 15.2000 -44.53125 0.00000 0.97300 0.97300 13.20000 1.12300 1.16500 4.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
25.690 909.00000 15.2000 -44.53125 0.00000 0.97300 0.97300 13.20000 1.12300 1.16500 4.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
25.700 909.00000 15.2000 -44.53125 0.00000 0.92100 0.92100 13.30000 1.09400 1.15800 4.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
25.710 909.00000 15.2000 -44.53125 0.00000 0.92100 0.92100 13.30000 1.09400 1.15800 4.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
25.720 909.00000 15.2000 -44.53125 0.00000 0.92100 0.92100 13.30000 1.09400 1.15800 4.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
25.730 909.00000 15.2000 -44.53125 0.00000 0.92100 0.92100 13.30000 1.09400 1.15800 4.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
25.740 909.00000 15.2000 -44.53125 0.00000 0.92100 0.92100 13.30000 1.09400 1.15800 4.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
25.750 852.00000 15.2000 -44.53125 0.00000 0.92100 0.92100 13.40000 1.09400 1.15800 4.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
25.760 852.00000 15.2000 -44.53125 0.00000 0.92100 0.92100 13.40000 1.09400 1.15800 4.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
25.770 852.00000 15.2000 -44.53125 0.00000 0.92100 0.92100 13.40000 1.09400 1.15800 4.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
25.780 852.00000 15.2000 -44.53125 0.00000 0.92100 0.92100 13.40000 1.09400 1.15800 4.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
25.790 852.00000 15.2000 -44.53125 0.00000 0.92100 0.92100 13.40000 1.09400 1.15800 4.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
25.801 852.00000 15.2000 -44.53125 0.00000 0.87400 0.87400 13.50000 1.09400 1.15800 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
25.811 852.00000 15.2000 -44.53125 0.00000 0.87400 0.87400 13.50000 1.09400 1.15800 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
25.821 852.00000 15.2000 -44.53125 0.00000 0.87400 0.87400 13.50000 1.09400 1.15800 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
25.831 852.00000 15.2000 -44.53125 0.00000 0.87400 0.87400 13.50000 1.09400 1.15800 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
25.841 852.00000 15.2000 -44.53125 0.00000 0.87400 0.87400 13.50000 1.09400 1.15800 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
25.851 828.00000 15.1000 -44.53125 0.00000 0.90900 0.90900 13.20000 1.09400 1.15800 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
25.861 828.00000 15.1000 -44.53125 0.00000 0.90900 0.90900 13.20000 1.09400 1.15800 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
25.871 828.00000 15.1000 -44.53125 0.00000 0.90900 0.90900 13.20000 1.09400 1.15800 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
25.881 828.00000 15.1000 -44.53125 0.00000 0.90900 0.90900 13.20000 1.09400 1.15800 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
25.891 828.00000 15.1000 -44.53125 0.00000 0.90900 0.90900 13.20000 1.09400 1.15800 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
25.901 828.00000 15.2000 -44.53125 0.00000 0.92100 0.92100 13.50000 1.09800 1.15500 5.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
25.911 828.00000 15.2000 -44.53125 0.00000 0.92100 0.92100 13.50000 1.09800 1.15500 5.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
25.921 828.00000 15.2000 -44.53125 0.00000 0.92100 0.92100 13.50000 1.09800 1.15500 5.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
25.931 828.00000 15.2000 -44.53125 0.00000 0.92100 0.92100 13.50000 1.09800 1.15500 5.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
25.941 828.00000 15.2000 -44.53125 0.00000 0.92100 0.92100 13.50000 1.09800 1.15500 5.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
25.951 826.00000 15.4000 -44.53125 0.00000 0.95000 0.95000 12.20000 1.09800 1.15500 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.4000 0.000 0.000 0.000 0.000
25.961 826.00000 15.4000 -44.53125 0.00000 0.95000 0.95000 12.20000 1.09800 1.15500 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.4000 0.000 0.000 0.000 0.000
25.971 826.00000 15.4000 -44.53125 0.00000 0.95000 0.95000 12.20000 1.09800 1.15500 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.4000 0.000 0.000 0.000 0.000
25.981 826.00000 15.4000 -44.53125 0.00000 0.95000 0.95000 12.20000 1.09800 1.15500 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.4000 0.000 0.000 0.000 0.000
25.991 826.00000 15.4000 -44.53125 0.00000 0.95000 0.95000 12.20000 1.09800 1.15500 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.4000 0.000 0.000 0.000 0.000
26.001 826.00000 15.2000 -44.53125 0.00000 0.96100 0.96100 13.30000 1.09800 1.15500 5.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
26.011 826.00000 15.2000 -44.53125 0.00000 0.96100 0.96100 13.30000 1.09800 1.15500 5.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
26.021 826.00000 15.2000 -44.53125 0.00000 0.96100 0.96100 13.30000 1.09800 1.15500 5.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
26.031 826.00000 15.2000 -44.53125 0.00000 0.96100 0.96100 13.30000 1.09800 1.15500 5.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
26.041 826.00000 15.2000 -44.53125 0.00000 0.96100 0.96100 13.30000 1.09800 1.15500 5.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
26.051 826.00000 15.2000 -44.53125 0.00000 0.89700 0.89700 13.10000 1.09800 1.15500 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.6000 0.000 0.000 0.000 0.000
26.061 826.00000 15.2000 -44.53125 0.00000 0.89700 0.89700 13.10000 1.09800 1.15500 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.6000 0.000 0.000 0.000 0.000
26.071 826.00000 15.2000 -44.53125 0.00000 0.89700 0.89700 13.10000 1.09800 1.15500 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.6000 0.000 0.000 0.000 0.000
26.081 826.00000 15.2000 -44.53125 0.00000 0.89700 0.89700 13.10000 1.09800 1.15500 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.6000 0.000 0.000 0.000 0.000
26.091 826.00000 15.2000 -44.53125 0.00000 0.89700 0.89700 13.10000 1.09800 1.15500 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.6000 0.000 0.000 0.000 0.000
26.101 824.00000 15.2000 -44.53125 0.00000 0.86800 0.86800 13.40000 1.10100 1.16100 5.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
26.111 824.00000 15.2000 -44.53125 0.00000 0.86800 0.86800 13.40000 1.10100 1.16100 5.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
26.121 824.00000 15.2000 -44.53125 0.00000 0.86800 0.86800 13.40000 1.10100 1.16100 5.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
26.131 824.00000 15.2000 -44.53125 0.00000 0.86800 0.86800 13.40000 1.10100 1.16100 5.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
26.141 824.00000 15.2000 -44.53125 0.00000 0.86800 0.86800 13.40000 1.10100 1.16100 5.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
26.151 824.00000 15.2000 -44.53125 0.00000 0.89700 0.89700 13.30000 1.10100 1.16100 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
26.161 824.00000 15.2000 -44.53125 0.00000 0.89700 0.89700 13.30000 1.10100 1.16100 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
26.171 824.00000 15.2000 -44.53125 0.00000 0.89700 0.89700 13.30000 1.10100 1.16100 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
26.181 824.00000 15.2000 -44.53125 0.00000 0.89700 0.89700 13.30000 1.10100 1.16100 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
26.191 824.00000 15.2000 -44.53125 0.00000 0.89700 0.89700 13.30000 1.10100 1.16100 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
26.201 803.00000 15.2000 -44.53125 0.00000 0.87400 0.87400 13.20000 1.10100 1.16100 5.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.6000 0.000 0.000 0.000 0.000
26.211 803.00000 15.2000 -44.53125 0.00000 0.87400 0.87400 13.20000 1.10100 1.16100 5.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.6000 0.000 0.000 0.000 0.000
26.221 803.00000 15.2000 -44.53125 0.00000 0.87400 0.87400 13.20000 1.10100 1.16100 5.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.6000 0.000 0.000 0.000 0.000
26.231 803.00000 15.2000 -44.53125 0.00000 0.87400 0.87400 13.20000 1.10100 1.16100 5.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.6000 0.000 0.000 0.000 0.000
26.241 803.00000 15.2000 -44.53125 0.00000 0.87400 0.87400 13.20000 1.10100 1.16100 5.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.6000 0.000 0.000 0.000 0.000
26.251 803.00000 15.2000 -44.53125 0.00000 0.92600 0.92600 13.60000 1.10100 1.16100 5.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.6000 0.000 0.000 0.000 0.000
26.261 803.00000 15.2000 -44.53125 0.00000 0.92600 0.92600 13.60000 1.10100 1.16100 5.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.6000 0.000 0.000 0.000 0.000
26.271 803.00000 15.2000 -44.53125 0.00000 0.92600 0.92600 13.60000 1.10100 1.16100 5.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.6000 0.000 0.000 0.000 0.000
26.281 803.00000 15.2000 -44.53125 0.00000 0.92600 0.92600 13.60000 1.10100 1.16100 5.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.6000 0.000 0.000 0.000 0.000
26.291 803.00000 15.2000 -44.53125 0.00000 0.92600 0.92600 13.60000 1.10100 1.16100 5.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.6000 0.000 0.000 0.000 0.000
26.301 803.00000 15.2000 -44.53125 0.00000 0.89700 0.89700 12.80000 1.10400 1.15500 5.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
26.311 803.00000 15.2000 -44.53125 0.00000 0.89700 0.89700 12.80000 1.10400 1.15500 5.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
26.321 803.00000 15.2000 -44.53125 0.00000 0.89700 0.89700 12.80000 1.10400 1.15500 5.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
26.331 803.00000 15.2000 -44.53125 0.00000 0.89700 0.89700 12.80000 1.10400 1.15500 5.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
26.341 803.00000 15.2000 -44.53125 0.00000 0.89700 0.89700 12.80000 1.10400 1.15500 5.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
26.351 808.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 13.00000 1.10400 1.15500 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
26.361 808.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 13.00000 1.10400 1.15500 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
26.371 808.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 13.00000 1.10400 1.15500 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
26.381 808.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 13.00000 1.10400 1.15500 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
26.391 808.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 13.00000 1.10400 1.15500 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
26.401 808.00000 15.2000 -44.53125 0.00000 0.93200 0.93200 13.00000 1.10400 1.15500 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
26.411 808.00000 15.2000 -44.53125 0.00000 0.93200 0.93200 13.00000 1.10400 1.15500 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
26.421 808.00000 15.2000 -44.53125 0.00000 0.93200 0.93200 13.00000 1.10400 1.15500 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
26.431 808.00000 15.2000 -44.53125 0.00000 0.93200 0.93200 13.00000 1.10400 1.15500 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
26.441 808.00000 15.2000 -44.53125 0.00000 0.93200 0.93200 13.00000 1.10400 1.15500 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
26.451 819.00000 15.2000 -44.53125 0.00000 0.92100 0.92100 13.40000 1.10400 1.15500 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.6000 0.000 0.000 0.000 0.000
26.461 819.00000 15.2000 -44.53125 0.00000 0.92100 0.92100 13.40000 1.10400 1.15500 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.6000 0.000 0.000 0.000 0.000
26.471 819.00000 15.2000 -44.53125 0.00000 0.92100 0.92100 13.40000 1.10400 1.15500 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.6000 0.000 0.000 0.000 0.000
26.481 819.00000 15.2000 -44.53125 0.00000 0.92100 0.92100 13.40000 1.10400 1.15500 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.6000 0.000 0.000 0.000 0.000
26.491 819.00000 15.2000 -44.53125 0.00000 0.92100 0.92100 13.40000 1.10400 1.15500 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.6000 0.000 0.000 0.000 0.000
26.501 819.00000 15.2000 -44.53125 0.00000 0.92100 0.92100 13.40000 1.10400 1.15500 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.6000 0.000 0.000 0.000 0.000
26.511 819.00000 15.2000 -44.53125 0.00000 0.92600 0.92600 13.20000 1.10700 1.14900 5.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
26.521 819.00000 15.2000 -44.53125 0.00000 0.92600 0.92600 13.20000 1.10700 1.14900 5.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
26.531 819.00000 15.2000 -44.53125 0.00000 0.92600 0.92600 13.20000 1.10700 1.14900 5.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
26.541 819.00000 15.2000 -44.53125 0.00000 0.92600 0.92600 13.20000 1.10700 1.14900 5.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
26.551 819.00000 15.2000 -44.53125 0.00000 0.92600 0.92600 13.20000 1.10700 1.14900 5.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
26.561 819.00000 15.2000 -44.53125 0.00000 0.92600 0.92600 13.20000 1.10700 1.14900 5.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
26.571 848.00000 15.4000 -44.53125 0.00000 0.89100 0.89100 12.60000 1.10700 1.14900 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
26.581 848.00000 15.4000 -44.53125 0.00000 0.89100 0.89100 12.60000 1.10700 1.14900 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
26.591 848.00000 15.4000 -44.53125 0.00000 0.89100 0.89100 12.60000 1.10700 1.14900 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
26.601 848.00000 15.4000 -44.53125 0.00000 0.89100 0.89100 12.60000 1.10700 1.14900 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
26.611 848.00000 15.4000 -44.53125 0.00000 0.89100 0.89100 12.60000 1.10700 1.14900 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
26.621 848.00000 15.4000 -44.53125 0.00000 0.89100 0.89100 12.60000 1.10700 1.14900 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
26.631 840.00000 15.2000 -44.53125 0.00000 0.93800 0.93800 13.00000 1.10400 1.14200 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
26.641 840.00000 15.2000 -44.53125 0.00000 0.93800 0.93800 13.00000 1.10400 1.14200 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
26.651 840.00000 15.2000 -44.53125 0.00000 0.93800 0.93800 13.00000 1.10400 1.14200 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
26.661 840.00000 15.2000 -44.53125 0.00000 0.93800 0.93800 13.00000 1.10400 1.14200 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
26.671 840.00000 15.2000 -44.53125 0.00000 0.93800 0.93800 13.00000 1.10400 1.14200 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
26.681 849.00000 15.2000 -44.53125 0.00000 0.91500 0.91500 13.40000 1.10400 1.14200 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
26.691 849.00000 15.2000 -44.53125 0.00000 0.91500 0.91500 13.40000 1.10400 1.14200 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
26.701 849.00000 15.2000 -44.53125 0.00000 0.91500 0.91500 13.40000 1.10400 1.14200 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
26.711 849.00000 15.2000 -44.53125 0.00000 0.91500 0.91500 13.40000 1.10400 1.14200 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
26.721 849.00000 15.2000 -44.53125 0.00000 0.91500 0.91500 13.40000 1.10400 1.14200 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
26.731 849.00000 15.2000 -44.53125 0.00000 0.91500 0.91500 13.40000 1.10400 1.14200 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
26.741 849.00000 15.2000 -44.53125 0.00000 0.91500 0.91500 13.40000 1.10400 1.14200 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
26.751 849.00000 15.2000 -44.53125 0.00000 0.91500 0.91500 13.40000 1.10400 1.14200 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
26.761 849.00000 15.2000 -44.53125 0.00000 0.91500 0.91500 13.40000 1.10400 1.14200 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
26.771 849.00000 15.2000 -44.53125 0.00000 0.91500 0.91500 13.40000 1.10400 1.14200 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
26.781 849.00000 15.2000 -44.53125 0.00000 0.91500 0.91500 13.40000 1.10400 1.14200 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
26.791 849.00000 15.2000 -44.53125 0.00000 0.91500 0.91500 13.40000 1.10400 1.14200 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
26.801 849.00000 15.2000 -44.53125 0.00000 0.91500 0.91500 13.40000 1.10400 1.14200 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
26.811 849.00000 15.2000 -44.53125 0.00000 0.91500 0.91500 13.40000 1.10400 1.14200 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
26.821 849.00000 15.2000 -44.53125 0.00000 0.91500 0.91500 13.40000 1.10400 1.14200 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
26.831 849.00000 15.2000 -44.53125 0.00000 0.91500 0.91500 13.40000 1.10400 1.14200 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
26.841 849.00000 15.2000 -44.53125 0.00000 0.91500 0.91500 13.40000 1.10400 1.14200 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
26.851 849.00000 15.2000 -44.53125 0.00000 0.91500 0.91500 13.40000 1.10400 1.14200 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
26.861 849.00000 15.2000 -44.53125 0.00000 0.91500 0.91500 13.40000 1.10400 1.14200 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
26.871 849.00000 15.2000 -44.53125 0.00000 0.91500 0.91500 13.40000 1.10400 1.14200 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.7000 0.000 0.000 0.000 0.000
26.881 864.00000 15.1000 -44.53125 0.00000 0.94400 0.94400 13.00000 1.09800 1.14200 5.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.6000 0.000 0.000 0.000 0.000
26.891 864.00000 15.1000 -44.53125 0.00000 0.94400 0.94400 13.00000 1.09800 1.14200 5.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.6000 0.000 0.000 0.000 0.000
26.901 864.00000 15.1000 -44.53125 0.00000 0.94400 0.94400 13.00000 1.09800 1.14200 5.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.6000 0.000 0.000 0.000 0.000
26.911 864.00000 15.1000 -44.53125 0.00000 0.94400 0.94400 13.00000 1.09800 1.14200 5.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.6000 0.000 0.000 0.000 0.000
26.921 864.00000 15.1000 -44.53125 0.00000 0.94400 0.94400 13.00000 1.09800 1.14200 5.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.6000 0.000 0.000 0.000 0.000
26.931 864.00000 15.2000 -44.53125 0.00000 0.92600 0.92600 13.40000 1.09800 1.14200 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.6000 0.000 0.000 0.000 0.000
26.941 864.00000 15.2000 -44.53125 0.00000 0.92600 0.92600 13.40000 1.09800 1.14200 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.6000 0.000 0.000 0.000 0.000
26.951 864.00000 15.2000 -44.53125 0.00000 0.92600 0.92600 13.40000 1.09800 1.14200 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.6000 0.000 0.000 0.000 0.000
26.961 864.00000 15.2000 -44.53125 0.00000 0.92600 0.92600 13.40000 1.09800 1.14200 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.6000 0.000 0.000 0.000 0.000
26.971 864.00000 15.2000 -44.53125 0.00000 0.92600 0.92600 13.40000 1.09800 1.14200 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.6000 0.000 0.000 0.000 0.000
26.981 864.00000 15.2000 -44.53125 0.00000 0.92600 0.92600 13.00000 1.09800 1.14200 5.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.8000 0.000 0.000 0.000 0.000
26.991 864.00000 15.2000 -44.53125 0.00000 0.92600 0.92600 13.00000 1.09800 1.14200 5.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.8000 0.000 0.000 0.000 0.000
27.001 864.00000 15.2000 -44.53125 0.00000 0.92600 0.92600 13.00000 1.09800 1.14200 5.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.8000 0.000 0.000 0.000 0.000
27.011 864.00000 15.2000 -44.53125 0.00000 0.92600 0.92600 13.00000 1.09800 1.14200 5.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.8000 0.000 0.000 0.000 0.000
27.021 864.00000 15.2000 -44.53125 0.00000 0.92600 0.92600 13.00000 1.09800 1.14200 5.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.8000 0.000 0.000 0.000 0.000
27.031 842.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 13.60000 1.09800 1.14200 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.8000 0.000 0.000 0.000 0.000
27.041 842.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 13.60000 1.09800 1.14200 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.8000 0.000 0.000 0.000 0.000
27.051 842.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 13.60000 1.09800 1.14200 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.8000 0.000 0.000 0.000 0.000
27.061 842.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 13.60000 1.09800 1.14200 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.8000 0.000 0.000 0.000 0.000
27.071 842.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 13.60000 1.09800 1.14200 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.8000 0.000 0.000 0.000 0.000
27.081 842.00000 15.2000 -44.53125 0.00000 0.89100 0.89100 13.40000 1.07500 1.13300 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
27.091 842.00000 15.2000 -44.53125 0.00000 0.89100 0.89100 13.40000 1.07500 1.13300 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
27.101 842.00000 15.2000 -44.53125 0.00000 0.89100 0.89100 13.40000 1.07500 1.13300 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
27.111 842.00000 15.2000 -44.53125 0.00000 0.89100 0.89100 13.40000 1.07500 1.13300 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
27.121 842.00000 15.2000 -44.53125 0.00000 0.89100 0.89100 13.40000 1.07500 1.13300 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
27.131 829.00000 15.2000 -44.53125 0.00000 0.93200 0.93200 13.10000 1.07500 1.13300 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
27.141 829.00000 15.2000 -44.53125 0.00000 0.93200 0.93200 13.10000 1.07500 1.13300 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
27.151 829.00000 15.2000 -44.53125 0.00000 0.93200 0.93200 13.10000 1.07500 1.13300 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
27.161 829.00000 15.2000 -44.53125 0.00000 0.93200 0.93200 13.10000 1.07500 1.13300 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
27.171 829.00000 15.2000 -44.53125 0.00000 0.93200 0.93200 13.10000 1.07500 1.13300 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
27.181 829.00000 15.2000 -44.53125 0.00000 0.92100 0.92100 13.20000 1.07500 1.13300 5.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.0000 0.000 0.000 0.000 0.000
27.191 829.00000 15.2000 -44.53125 0.00000 0.92100 0.92100 13.20000 1.07500 1.13300 5.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.0000 0.000 0.000 0.000 0.000
27.201 829.00000 15.2000 -44.53125 0.00000 0.92100 0.92100 13.20000 1.07500 1.13300 5.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.0000 0.000 0.000 0.000 0.000
27.211 829.00000 15.2000 -44.53125 0.00000 0.92100 0.92100 13.20000 1.07500 1.13300 5.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.0000 0.000 0.000 0.000 0.000
27.221 829.00000 15.2000 -44.53125 0.00000 0.92100 0.92100 13.20000 1.07500 1.13300 5.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.0000 0.000 0.000 0.000 0.000
27.231 837.00000 15.2000 -44.53125 0.00000 0.89100 0.89100 13.10000 1.07500 1.13300 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
27.241 837.00000 15.2000 -44.53125 0.00000 0.89100 0.89100 13.10000 1.07500 1.13300 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
27.251 837.00000 15.2000 -44.53125 0.00000 0.89100 0.89100 13.10000 1.07500 1.13300 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
27.261 837.00000 15.2000 -44.53125 0.00000 0.89100 0.89100 13.10000 1.07500 1.13300 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
27.271 837.00000 15.2000 -44.53125 0.00000 0.89100 0.89100 13.10000 1.07500 1.13300 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
27.281 837.00000 15.2000 -44.53125 0.00000 0.90300 0.90300 13.50000 1.07500 1.12900 5.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
27.291 837.00000 15.2000 -44.53125 0.00000 0.90300 0.90300 13.50000 1.07500 1.12900 5.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
27.301 837.00000 15.2000 -44.53125 0.00000 0.90300 0.90300 13.50000 1.07500 1.12900 5.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
27.311 837.00000 15.2000 -44.53125 0.00000 0.90300 0.90300 13.50000 1.07500 1.12900 5.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
27.321 837.00000 15.2000 -44.53125 0.00000 0.90300 0.90300 13.50000 1.07500 1.12900 5.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
27.331 837.00000 15.2000 -44.53125 0.00000 0.92100 0.92100 13.20000 1.07500 1.12900 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.0000 0.000 0.000 0.000 0.000
27.341 837.00000 15.2000 -44.53125 0.00000 0.92100 0.92100 13.20000 1.07500 1.12900 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.0000 0.000 0.000 0.000 0.000
27.351 837.00000 15.2000 -44.53125 0.00000 0.92100 0.92100 13.20000 1.07500 1.12900 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.0000 0.000 0.000 0.000 0.000
27.361 837.00000 15.2000 -44.53125 0.00000 0.92100 0.92100 13.20000 1.07500 1.12900 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.0000 0.000 0.000 0.000 0.000
27.371 837.00000 15.2000 -44.53125 0.00000 0.92100 0.92100 13.20000 1.07500 1.12900 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.0000 0.000 0.000 0.000 0.000
27.381 854.00000 15.2000 -44.53125 0.00000 0.89700 0.89700 13.30000 1.07500 1.12900 5.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.0000 0.000 0.000 0.000 0.000
27.391 854.00000 15.2000 -44.53125 0.00000 0.89700 0.89700 13.30000 1.07500 1.12900 5.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.0000 0.000 0.000 0.000 0.000
27.401 854.00000 15.2000 -44.53125 0.00000 0.89700 0.89700 13.30000 1.07500 1.12900 5.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.0000 0.000 0.000 0.000 0.000
27.411 854.00000 15.2000 -44.53125 0.00000 0.89700 0.89700 13.30000 1.07500 1.12900 5.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.0000 0.000 0.000 0.000 0.000
27.421 854.00000 15.2000 -44.53125 0.00000 0.89700 0.89700 13.30000 1.07500 1.12900 5.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.0000 0.000 0.000 0.000 0.000
27.431 854.00000 15.2000 -44.53125 0.00000 0.91500 0.91500 13.50000 1.07500 1.12900 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
27.441 854.00000 15.2000 -44.53125 0.00000 0.91500 0.91500 13.50000 1.07500 1.12900 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
27.451 854.00000 15.2000 -44.53125 0.00000 0.91500 0.91500 13.50000 1.07500 1.12900 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
27.461 854.00000 15.2000 -44.53125 0.00000 0.91500 0.91500 13.50000 1.07500 1.12900 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
27.471 854.00000 15.2000 -44.53125 0.00000 0.91500 0.91500 13.50000 1.07500 1.12900 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
27.481 837.00000 15.1000 -44.53125 0.00000 0.92600 0.92600 12.90000 1.06200 1.12600 5.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.0000 0.000 0.000 0.000 0.000
27.491 837.00000 15.1000 -44.53125 0.00000 0.92600 0.92600 12.90000 1.06200 1.12600 5.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.0000 0.000 0.000 0.000 0.000
27.501 837.00000 15.1000 -44.53125 0.00000 0.92600 0.92600 12.90000 1.06200 1.12600 5.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.0000 0.000 0.000 0.000 0.000
27.511 837.00000 15.1000 -44.53125 0.00000 0.92600 0.92600 12.90000 1.06200 1.12600 5.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.0000 0.000 0.000 0.000 0.000
27.521 837.00000 15.1000 -44.53125 0.00000 0.92600 0.92600 12.90000 1.06200 1.12600 5.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.0000 0.000 0.000 0.000 0.000
27.531 837.00000 15.2000 -44.53125 0.00000 0.92100 0.92100 13.30000 1.06200 1.12600 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
27.541 837.00000 15.2000 -44.53125 0.00000 0.92100 0.92100 13.30000 1.06200 1.12600 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
27.551 837.00000 15.2000 -44.53125 0.00000 0.92100 0.92100 13.30000 1.06200 1.12600 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
27.561 837.00000 15.2000 -44.53125 0.00000 0.92100 0.92100 13.30000 1.06200 1.12600 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
27.571 837.00000 15.2000 -44.53125 0.00000 0.92100 0.92100 13.30000 1.06200 1.12600 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
27.581 833.00000 15.2000 -44.53125 0.00000 0.89700 0.89700 13.30000 1.06200 1.12600 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.1000 0.000 0.000 0.000 0.000
27.591 833.00000 15.2000 -44.53125 0.00000 0.89700 0.89700 13.30000 1.06200 1.12600 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.1000 0.000 0.000 0.000 0.000
27.601 833.00000 15.2000 -44.53125 0.00000 0.89700 0.89700 13.30000 1.06200 1.12600 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.1000 0.000 0.000 0.000 0.000
27.611 833.00000 15.2000 -44.53125 0.00000 0.89700 0.89700 13.30000 1.06200 1.12600 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.1000 0.000 0.000 0.000 0.000
27.621 833.00000 15.2000 -44.53125 0.00000 0.89700 0.89700 13.30000 1.06200 1.12600 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.1000 0.000 0.000 0.000 0.000
27.631 833.00000 15.2000 -44.53125 0.00000 0.91500 0.91500 13.60000 1.06200 1.12600 5.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.1000 0.000 0.000 0.000 0.000
27.641 833.00000 15.2000 -44.53125 0.00000 0.91500 0.91500 13.60000 1.06200 1.12600 5.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.1000 0.000 0.000 0.000 0.000
27.651 833.00000 15.2000 -44.53125 0.00000 0.91500 0.91500 13.60000 1.06200 1.12600 5.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.1000 0.000 0.000 0.000 0.000
27.661 833.00000 15.2000 -44.53125 0.00000 0.91500 0.91500 13.60000 1.06200 1.12600 5.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.1000 0.000 0.000 0.000 0.000
27.671 833.00000 15.2000 -44.53125 0.00000 0.91500 0.91500 13.60000 1.06200 1.12600 5.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.1000 0.000 0.000 0.000 0.000
27.681 833.00000 15.2000 -44.53125 0.00000 0.93800 0.93800 13.30000 1.04000 1.12300 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
27.691 833.00000 15.2000 -44.53125 0.00000 0.93800 0.93800 13.30000 1.04000 1.12300 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
27.701 833.00000 15.2000 -44.53125 0.00000 0.93800 0.93800 13.30000 1.04000 1.12300 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
27.711 833.00000 15.2000 -44.53125 0.00000 0.93800 0.93800 13.30000 1.04000 1.12300 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
27.721 833.00000 15.2000 -44.53125 0.00000 0.93800 0.93800 13.30000 1.04000 1.12300 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
27.731 818.00000 15.2000 -44.53125 0.00000 0.91500 0.91500 13.50000 1.04000 1.12300 5.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
27.741 818.00000 15.2000 -44.53125 0.00000 0.91500 0.91500 13.50000 1.04000 1.12300 5.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
27.751 818.00000 15.2000 -44.53125 0.00000 0.91500 0.91500 13.50000 1.04000 1.12300 5.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
27.761 818.00000 15.2000 -44.53125 0.00000 0.91500 0.91500 13.50000 1.04000 1.12300 5.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
27.771 818.00000 15.2000 -44.53125 0.00000 0.91500 0.91500 13.50000 1.04000 1.12300 5.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
27.781 818.00000 15.2000 -44.53125 0.00000 0.88600 0.88600 13.40000 1.04000 1.12300 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
27.791 818.00000 15.2000 -44.53125 0.00000 0.88600 0.88600 13.40000 1.04000 1.12300 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
27.801 818.00000 15.2000 -44.53125 0.00000 0.88600 0.88600 13.40000 1.04000 1.12300 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
27.811 818.00000 15.2000 -44.53125 0.00000 0.88600 0.88600 13.40000 1.04000 1.12300 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
27.821 818.00000 15.2000 -44.53125 0.00000 0.88600 0.88600 13.40000 1.04000 1.12300 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
27.831 812.00000 15.2000 -44.53125 0.00000 0.92600 0.92600 12.90000 1.04000 1.12300 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
27.841 812.00000 15.2000 -44.53125 0.00000 0.92600 0.92600 12.90000 1.04000 1.12300 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
27.851 812.00000 15.2000 -44.53125 0.00000 0.92600 0.92600 12.90000 1.04000 1.12300 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
27.861 812.00000 15.2000 -44.53125 0.00000 0.92600 0.92600 12.90000 1.04000 1.12300 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
27.871 812.00000 15.2000 -44.53125 0.00000 0.92600 0.92600 12.90000 1.04000 1.12300 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
27.881 812.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 13.10000 0.99500 1.11700 5.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
27.891 812.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 13.10000 0.99500 1.11700 5.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
27.901 812.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 13.10000 0.99500 1.11700 5.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
27.911 812.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 13.10000 0.99500 1.11700 5.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
27.921 812.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 13.10000 0.99500 1.11700 5.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
27.931 812.00000 15.2000 -44.53125 0.00000 0.93200 0.93200 13.40000 0.99500 1.11700 5.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
27.941 812.00000 15.2000 -44.53125 0.00000 0.93200 0.93200 13.40000 0.99500 1.11700 5.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
27.951 812.00000 15.2000 -44.53125 0.00000 0.93200 0.93200 13.40000 0.99500 1.11700 5.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
27.961 812.00000 15.2000 -44.53125 0.00000 0.93200 0.93200 13.40000 0.99500 1.11700 5.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
27.971 812.00000 15.2000 -44.53125 0.00000 0.93200 0.93200 13.40000 0.99500 1.11700 5.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
27.981 776.00000 15.2000 -44.53125 0.00000 0.93200 0.93200 13.00000 0.99500 1.11700 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
27.991 776.00000 15.2000 -44.53125 0.00000 0.93200 0.93200 13.00000 0.99500 1.11700 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
28.001 776.00000 15.2000 -44.53125 0.00000 0.93200 0.93200 13.00000 0.99500 1.11700 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
28.011 776.00000 15.2000 -44.53125 0.00000 0.93200 0.93200 13.00000 0.99500 1.11700 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
28.021 776.00000 15.2000 -44.53125 0.00000 0.93200 0.93200 13.00000 0.99500 1.11700 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
28.031 776.00000 15.2000 -44.53125 0.00000 0.92600 0.92600 12.90000 0.99500 1.11700 5.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.4000 0.000 0.000 0.000 0.000
28.041 776.00000 15.2000 -44.53125 0.00000 0.92600 0.92600 12.90000 0.99500 1.11700 5.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.4000 0.000 0.000 0.000 0.000
28.051 776.00000 15.2000 -44.53125 0.00000 0.92600 0.92600 12.90000 0.99500 1.11700 5.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.4000 0.000 0.000 0.000 0.000
28.061 776.00000 15.2000 -44.53125 0.00000 0.92600 0.92600 12.90000 0.99500 1.11700 5.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.4000 0.000 0.000 0.000 0.000
28.071 776.00000 15.2000 -44.53125 0.00000 0.92600 0.92600 12.90000 0.99500 1.11700 5.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.4000 0.000 0.000 0.000 0.000
28.081 754.00000 15.2000 -44.53125 0.00000 0.88600 0.88600 13.30000 0.95100 1.11300 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.6000 0.000 0.000 0.000 0.000
28.091 754.00000 15.2000 -44.53125 0.00000 0.88600 0.88600 13.30000 0.95100 1.11300 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.6000 0.000 0.000 0.000 0.000
28.101 754.00000 15.2000 -44.53125 0.00000 0.88600 0.88600 13.30000 0.95100 1.11300 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.6000 0.000 0.000 0.000 0.000
28.111 754.00000 15.2000 -44.53125 0.00000 0.88600 0.88600 13.30000 0.95100 1.11300 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.6000 0.000 0.000 0.000 0.000
28.121 754.00000 15.2000 -44.53125 0.00000 0.88600 0.88600 13.30000 0.95100 1.11300 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.6000 0.000 0.000 0.000 0.000
28.131 754.00000 15.2000 -44.53125 0.00000 0.90300 0.90300 13.20000 0.95100 1.11300 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.6000 0.000 0.000 0.000 0.000
28.141 754.00000 15.2000 -44.53125 0.00000 0.90300 0.90300 13.20000 0.95100 1.11300 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.6000 0.000 0.000 0.000 0.000
28.151 754.00000 15.2000 -44.53125 0.00000 0.90300 0.90300 13.20000 0.95100 1.11300 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.6000 0.000 0.000 0.000 0.000
28.161 754.00000 15.2000 -44.53125 0.00000 0.90300 0.90300 13.20000 0.95100 1.11300 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.6000 0.000 0.000 0.000 0.000
28.171 754.00000 15.2000 -44.53125 0.00000 0.90300 0.90300 13.20000 0.95100 1.11300 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.6000 0.000 0.000 0.000 0.000
28.181 754.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 13.10000 0.95100 1.11300 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.5000 0.000 0.000 0.000 0.000
28.191 754.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 13.10000 0.95100 1.11300 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.5000 0.000 0.000 0.000 0.000
28.201 754.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 13.10000 0.95100 1.11300 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.5000 0.000 0.000 0.000 0.000
28.211 754.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 13.10000 0.95100 1.11300 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.5000 0.000 0.000 0.000 0.000
28.221 754.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 13.10000 0.95100 1.11300 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.5000 0.000 0.000 0.000 0.000
28.231 758.00000 15.2000 -44.53125 0.00000 0.90300 0.90300 12.80000 0.95100 1.11300 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
28.241 758.00000 15.2000 -44.53125 0.00000 0.90300 0.90300 12.80000 0.95100 1.11300 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
28.251 758.00000 15.2000 -44.53125 0.00000 0.90300 0.90300 12.80000 0.95100 1.11300 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
28.261 758.00000 15.2000 -44.53125 0.00000 0.90300 0.90300 12.80000 0.95100 1.11300 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
28.271 758.00000 15.2000 -44.53125 0.00000 0.90300 0.90300 12.80000 0.95100 1.11300 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
28.281 758.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 12.90000 0.91200 1.11000 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
28.291 758.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 12.90000 0.91200 1.11000 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
28.301 758.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 12.90000 0.91200 1.11000 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
28.311 758.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 12.90000 0.91200 1.11000 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
28.321 758.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 12.90000 0.91200 1.11000 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
28.331 760.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 13.10000 0.91200 1.11000 5.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
28.341 760.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 13.10000 0.91200 1.11000 5.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
28.351 760.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 13.10000 0.91200 1.11000 5.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
28.361 760.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 13.10000 0.91200 1.11000 5.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
28.371 760.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 13.10000 0.91200 1.11000 5.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
28.381 760.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 13.10000 0.91200 1.11000 5.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
28.391 760.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 13.10000 0.91200 1.11000 5.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
28.401 760.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 13.10000 0.91200 1.11000 5.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
28.411 760.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 13.10000 0.91200 1.11000 5.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
28.421 760.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 13.10000 0.91200 1.11000 5.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
28.431 760.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 13.30000 0.91200 1.11000 5.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
28.441 760.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 13.30000 0.91200 1.11000 5.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
28.451 760.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 13.30000 0.91200 1.11000 5.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
28.461 760.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 13.30000 0.91200 1.11000 5.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
28.471 760.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 13.30000 0.91200 1.11000 5.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
28.481 770.00000 15.2000 -44.53125 0.00000 0.85600 0.85600 13.40000 0.78500 1.10400 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
28.491 770.00000 15.2000 -44.53125 0.00000 0.85600 0.85600 13.40000 0.78500 1.10400 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
28.501 770.00000 15.2000 -44.53125 0.00000 0.85600 0.85600 13.40000 0.78500 1.10400 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
28.511 770.00000 15.2000 -44.53125 0.00000 0.85600 0.85600 13.40000 0.78500 1.10400 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
28.521 770.00000 15.2000 -44.53125 0.00000 0.85600 0.85600 13.40000 0.78500 1.10400 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
28.531 770.00000 15.2000 -44.53125 0.00000 0.86800 0.86800 12.90000 0.78500 1.10400 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
28.541 770.00000 15.2000 -44.53125 0.00000 0.86800 0.86800 12.90000 0.78500 1.10400 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
28.551 770.00000 15.2000 -44.53125 0.00000 0.86800 0.86800 12.90000 0.78500 1.10400 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
28.561 770.00000 15.2000 -44.53125 0.00000 0.86800 0.86800 12.90000 0.78500 1.10400 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
28.571 770.00000 15.2000 -44.53125 0.00000 0.86800 0.86800 12.90000 0.78500 1.10400 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
28.581 768.00000 15.2000 -44.53125 0.00000 0.85100 0.85100 13.20000 0.78500 1.10400 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
28.591 768.00000 15.2000 -44.53125 0.00000 0.85100 0.85100 13.20000 0.78500 1.10400 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
28.601 768.00000 15.2000 -44.53125 0.00000 0.85100 0.85100 13.20000 0.78500 1.10400 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
28.611 768.00000 15.2000 -44.53125 0.00000 0.85100 0.85100 13.20000 0.78500 1.10400 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
28.621 768.00000 15.2000 -44.53125 0.00000 0.85100 0.85100 13.20000 0.78500 1.10400 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
28.631 768.00000 15.4000 -44.53125 0.00000 0.82700 0.82700 12.10000 0.78500 1.10400 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
28.641 768.00000 15.4000 -44.53125 0.00000 0.82700 0.82700 12.10000 0.78500 1.10400 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
28.651 768.00000 15.4000 -44.53125 0.00000 0.82700 0.82700 12.10000 0.78500 1.10400 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
28.661 768.00000 15.4000 -44.53125 0.00000 0.82700 0.82700 12.10000 0.78500 1.10400 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
28.671 768.00000 15.4000 -44.53125 0.00000 0.82700 0.82700 12.10000 0.78500 1.10400 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
28.681 768.00000 15.2000 -44.53125 0.00000 0.85100 0.85100 12.80000 0.46600 1.09400 5.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
28.691 768.00000 15.2000 -44.53125 0.00000 0.85100 0.85100 12.80000 0.46600 1.09400 5.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
28.701 768.00000 15.2000 -44.53125 0.00000 0.85100 0.85100 12.80000 0.46600 1.09400 5.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
28.711 768.00000 15.2000 -44.53125 0.00000 0.85100 0.85100 12.80000 0.46600 1.09400 5.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
28.721 768.00000 15.2000 -44.53125 0.00000 0.85100 0.85100 12.80000 0.46600 1.09400 5.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
28.731 758.00000 15.2000 -44.53125 0.00000 0.86200 0.86200 12.90000 0.46600 1.09400 5.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
28.741 758.00000 15.2000 -44.53125 0.00000 0.86200 0.86200 12.90000 0.46600 1.09400 5.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
28.751 758.00000 15.2000 -44.53125 0.00000 0.86200 0.86200 12.90000 0.46600 1.09400 5.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
28.761 758.00000 15.2000 -44.53125 0.00000 0.86200 0.86200 12.90000 0.46600 1.09400 5.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
28.771 758.00000 15.2000 -44.53125 0.00000 0.86200 0.86200 12.90000 0.46600 1.09400 5.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
28.781 758.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 13.10000 0.46600 1.09400 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
28.791 758.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 13.10000 0.46600 1.09400 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
28.801 758.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 13.10000 0.46600 1.09400 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
28.811 758.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 13.10000 0.46600 1.09400 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
28.821 758.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 13.10000 0.46600 1.09400 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.4000 0.000 0.000 0.000 0.000
28.831 758.00000 15.2000 -44.53125 0.00000 0.89100 0.89100 12.20000 0.46600 1.09400 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
28.841 758.00000 15.2000 -44.53125 0.00000 0.89100 0.89100 12.20000 0.46600 1.09400 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
28.851 758.00000 15.2000 -44.53125 0.00000 0.89100 0.89100 12.20000 0.46600 1.09400 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
28.861 758.00000 15.2000 -44.53125 0.00000 0.89100 0.89100 12.20000 0.46600 1.09400 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
28.871 758.00000 15.2000 -44.53125 0.00000 0.89100 0.89100 12.20000 0.46600 1.09400 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.6000 0.000 0.000 0.000 0.000
28.881 710.00000 15.2000 -44.53125 0.00000 0.92600 0.92600 13.00000 0.33500 1.09400 6.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
28.891 710.00000 15.2000 -44.53125 0.00000 0.92600 0.92600 13.00000 0.33500 1.09400 6.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
28.901 710.00000 15.2000 -44.53125 0.00000 0.92600 0.92600 13.00000 0.33500 1.09400 6.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
28.911 710.00000 15.2000 -44.53125 0.00000 0.92600 0.92600 13.00000 0.33500 1.09400 6.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
28.921 710.00000 15.2000 -44.53125 0.00000 0.92600 0.92600 13.00000 0.33500 1.09400 6.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.7000 0.000 0.000 0.000 0.000
28.931 710.00000 15.2000 -44.53125 0.00000 0.85600 0.85600 13.10000 0.33500 1.09400 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.8000 0.000 0.000 0.000 0.000
28.941 710.00000 15.2000 -44.53125 0.00000 0.85600 0.85600 13.10000 0.33500 1.09400 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.8000 0.000 0.000 0.000 0.000
28.951 710.00000 15.2000 -44.53125 0.00000 0.85600 0.85600 13.10000 0.33500 1.09400 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.8000 0.000 0.000 0.000 0.000
28.961 710.00000 15.2000 -44.53125 0.00000 0.85600 0.85600 13.10000 0.33500 1.09400 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.8000 0.000 0.000 0.000 0.000
28.971 710.00000 15.2000 -44.53125 0.00000 0.85600 0.85600 13.10000 0.33500 1.09400 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.8000 0.000 0.000 0.000 0.000
28.981 715.00000 15.2000 -44.53125 0.00000 0.88600 0.88600 12.60000 0.33500 1.09400 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.9000 0.000 0.000 0.000 0.000
28.991 715.00000 15.2000 -44.53125 0.00000 0.88600 0.88600 12.60000 0.33500 1.09400 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.9000 0.000 0.000 0.000 0.000
29.001 715.00000 15.2000 -44.53125 0.00000 0.88600 0.88600 12.60000 0.33500 1.09400 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.9000 0.000 0.000 0.000 0.000
29.011 715.00000 15.2000 -44.53125 0.00000 0.88600 0.88600 12.60000 0.33500 1.09400 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.9000 0.000 0.000 0.000 0.000
29.021 715.00000 15.2000 -44.53125 0.00000 0.88600 0.88600 12.60000 0.33500 1.09400 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.9000 0.000 0.000 0.000 0.000
29.031 715.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 12.80000 0.33500 1.09400 6.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.8000 0.000 0.000 0.000 0.000
29.041 715.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 12.80000 0.33500 1.09400 6.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.8000 0.000 0.000 0.000 0.000
29.051 715.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 12.80000 0.33500 1.09400 6.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.8000 0.000 0.000 0.000 0.000
29.061 715.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 12.80000 0.33500 1.09400 6.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.8000 0.000 0.000 0.000 0.000
29.071 715.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 12.80000 0.33500 1.09400 6.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 15.8000 0.000 0.000 0.000 0.000
29.081 715.00000 15.2000 -44.53125 0.00000 0.89700 0.89700 12.90000 0.30900 1.09800 5.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 16.0000 0.000 0.000 0.000 0.000
29.091 715.00000 15.2000 -44.53125 0.00000 0.89700 0.89700 12.90000 0.30900 1.09800 5.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 16.0000 0.000 0.000 0.000 0.000
29.101 715.00000 15.2000 -44.53125 0.00000 0.89700 0.89700 12.90000 0.30900 1.09800 5.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 16.0000 0.000 0.000 0.000 0.000
29.111 715.00000 15.2000 -44.53125 0.00000 0.89700 0.89700 12.90000 0.30900 1.09800 5.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 16.0000 0.000 0.000 0.000 0.000
29.121 715.00000 15.2000 -44.53125 0.00000 0.89700 0.89700 12.90000 0.30900 1.09800 5.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 16.0000 0.000 0.000 0.000 0.000
29.131 725.00000 15.2000 -44.53125 0.00000 0.86800 0.86800 13.20000 0.30900 1.09800 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 16.0000 0.000 0.000 0.000 0.000
29.141 725.00000 15.2000 -44.53125 0.00000 0.86800 0.86800 13.20000 0.30900 1.09800 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 16.0000 0.000 0.000 0.000 0.000
29.151 725.00000 15.2000 -44.53125 0.00000 0.86800 0.86800 13.20000 0.30900 1.09800 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 16.0000 0.000 0.000 0.000 0.000
29.161 725.00000 15.2000 -44.53125 0.00000 0.86800 0.86800 13.20000 0.30900 1.09800 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 16.0000 0.000 0.000 0.000 0.000
29.171 725.00000 15.2000 -44.53125 0.00000 0.86800 0.86800 13.20000 0.30900 1.09800 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 16.0000 0.000 0.000 0.000 0.000
29.181 725.00000 15.2000 -44.53125 0.00000 0.89100 0.89100 12.90000 0.30900 1.09800 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 16.2000 0.000 0.000 0.000 0.000
29.191 725.00000 15.2000 -44.53125 0.00000 0.89100 0.89100 12.90000 0.30900 1.09800 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 16.2000 0.000 0.000 0.000 0.000
29.201 725.00000 15.2000 -44.53125 0.00000 0.89100 0.89100 12.90000 0.30900 1.09800 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 16.2000 0.000 0.000 0.000 0.000
29.211 725.00000 15.2000 -44.53125 0.00000 0.89100 0.89100 12.90000 0.30900 1.09800 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 16.2000 0.000 0.000 0.000 0.000
29.221 725.00000 15.2000 -44.53125 0.00000 0.89100 0.89100 12.90000 0.30900 1.09800 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 16.2000 0.000 0.000 0.000 0.000
29.231 725.00000 15.2000 -44.53125 0.00000 0.86200 0.86200 13.10000 0.30900 1.09800 6.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 16.2000 0.000 0.000 0.000 0.000
29.241 725.00000 15.2000 -44.53125 0.00000 0.86200 0.86200 13.10000 0.30900 1.09800 6.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 16.2000 0.000 0.000 0.000 0.000
29.251 725.00000 15.2000 -44.53125 0.00000 0.86200 0.86200 13.10000 0.30900 1.09800 6.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 16.2000 0.000 0.000 0.000 0.000
29.261 725.00000 15.2000 -44.53125 0.00000 0.86200 0.86200 13.10000 0.30900 1.09800 6.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 16.2000 0.000 0.000 0.000 0.000
29.271 725.00000 15.2000 -44.53125 0.00000 0.86200 0.86200 13.10000 0.30900 1.09800 6.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 16.2000 0.000 0.000 0.000 0.000
29.281 722.00000 15.2000 -44.53125 0.00000 0.83300 0.83300 13.10000 0.31200 1.09800 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 16.3000 0.000 0.000 0.000 0.000
29.291 722.00000 15.2000 -44.53125 0.00000 0.83300 0.83300 13.10000 0.31200 1.09800 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 16.3000 0.000 0.000 0.000 0.000
29.301 722.00000 15.2000 -44.53125 0.00000 0.83300 0.83300 13.10000 0.31200 1.09800 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 16.3000 0.000 0.000 0.000 0.000
29.311 722.00000 15.2000 -44.53125 0.00000 0.83300 0.83300 13.10000 0.31200 1.09800 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 16.3000 0.000 0.000 0.000 0.000
29.321 722.00000 15.2000 -44.53125 0.00000 0.83300 0.83300 13.10000 0.31200 1.09800 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 16.3000 0.000 0.000 0.000 0.000
29.331 722.00000 15.2000 -44.53125 0.00000 0.87400 0.87400 13.00000 0.31200 1.09800 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 16.7000 0.000 0.000 0.000 0.000
29.341 722.00000 15.2000 -44.53125 0.00000 0.87400 0.87400 13.00000 0.31200 1.09800 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 16.7000 0.000 0.000 0.000 0.000
29.351 722.00000 15.2000 -44.53125 0.00000 0.87400 0.87400 13.00000 0.31200 1.09800 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 16.7000 0.000 0.000 0.000 0.000
29.361 722.00000 15.2000 -44.53125 0.00000 0.87400 0.87400 13.00000 0.31200 1.09800 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 16.7000 0.000 0.000 0.000 0.000
29.371 722.00000 15.2000 -44.53125 0.00000 0.87400 0.87400 13.00000 0.31200 1.09800 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 16.7000 0.000 0.000 0.000 0.000
29.381 722.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 13.00000 0.31200 1.09800 6.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 16.7000 0.000 0.000 0.000 0.000
29.391 722.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 13.00000 0.31200 1.09800 6.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 16.7000 0.000 0.000 0.000 0.000
29.401 722.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 13.00000 0.31200 1.09800 6.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 16.7000 0.000 0.000 0.000 0.000
29.411 722.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 13.00000 0.31200 1.09800 6.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 16.7000 0.000 0.000 0.000 0.000
29.421 722.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 13.00000 0.31200 1.09800 6.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 16.7000 0.000 0.000 0.000 0.000
29.431 735.00000 15.2000 -44.53125 0.00000 0.86200 0.86200 13.00000 0.31200 1.09800 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 16.8000 0.000 0.000 0.000 0.000
29.441 735.00000 15.2000 -44.53125 0.00000 0.86200 0.86200 13.00000 0.31200 1.09800 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 16.8000 0.000 0.000 0.000 0.000
29.451 735.00000 15.2000 -44.53125 0.00000 0.86200 0.86200 13.00000 0.31200 1.09800 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 16.8000 0.000 0.000 0.000 0.000
29.461 735.00000 15.2000 -44.53125 0.00000 0.86200 0.86200 13.00000 0.31200 1.09800 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 16.8000 0.000 0.000 0.000 0.000
29.471 735.00000 15.2000 -44.53125 0.00000 0.86200 0.86200 13.00000 0.31200 1.09800 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 16.8000 0.000 0.000 0.000 0.000
29.481 735.00000 15.2000 -44.53125 0.00000 0.89100 0.89100 13.00000 0.29600 1.08200 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 16.9000 0.000 0.000 0.000 0.000
29.491 735.00000 15.2000 -44.53125 0.00000 0.89100 0.89100 13.00000 0.29600 1.08200 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 16.9000 0.000 0.000 0.000 0.000
29.501 735.00000 15.2000 -44.53125 0.00000 0.89100 0.89100 13.00000 0.29600 1.08200 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 16.9000 0.000 0.000 0.000 0.000
29.511 735.00000 15.2000 -44.53125 0.00000 0.89100 0.89100 13.00000 0.29600 1.08200 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 16.9000 0.000 0.000 0.000 0.000
29.521 735.00000 15.2000 -44.53125 0.00000 0.89100 0.89100 13.00000 0.29600 1.08200 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 16.9000 0.000 0.000 0.000 0.000
29.531 759.00000 15.2000 -44.53125 0.00000 0.84500 0.84500 13.10000 0.29600 1.08200 5.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.2000 0.000 0.000 0.000 0.000
29.541 759.00000 15.2000 -44.53125 0.00000 0.84500 0.84500 13.10000 0.29600 1.08200 5.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.2000 0.000 0.000 0.000 0.000
29.551 759.00000 15.2000 -44.53125 0.00000 0.84500 0.84500 13.10000 0.29600 1.08200 5.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.2000 0.000 0.000 0.000 0.000
29.561 759.00000 15.2000 -44.53125 0.00000 0.84500 0.84500 13.10000 0.29600 1.08200 5.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.2000 0.000 0.000 0.000 0.000
29.571 759.00000 15.2000 -44.53125 0.00000 0.84500 0.84500 13.10000 0.29600 1.08200 5.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.2000 0.000 0.000 0.000 0.000
29.581 759.00000 15.1000 -44.53125 0.00000 0.84500 0.84500 13.50000 0.29600 1.08200 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.1000 0.000 0.000 0.000 0.000
29.591 759.00000 15.1000 -44.53125 0.00000 0.84500 0.84500 13.50000 0.29600 1.08200 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.1000 0.000 0.000 0.000 0.000
29.601 759.00000 15.1000 -44.53125 0.00000 0.84500 0.84500 13.50000 0.29600 1.08200 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.1000 0.000 0.000 0.000 0.000
29.611 759.00000 15.1000 -44.53125 0.00000 0.84500 0.84500 13.50000 0.29600 1.08200 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.1000 0.000 0.000 0.000 0.000
29.621 759.00000 15.1000 -44.53125 0.00000 0.84500 0.84500 13.50000 0.29600 1.08200 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.1000 0.000 0.000 0.000 0.000
29.631 759.00000 15.2000 -44.53125 0.00000 0.85100 0.85100 13.60000 0.29600 1.08200 5.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.4000 0.000 0.000 0.000 0.000
29.641 759.00000 15.2000 -44.53125 0.00000 0.85100 0.85100 13.60000 0.29600 1.08200 5.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.4000 0.000 0.000 0.000 0.000
29.651 759.00000 15.2000 -44.53125 0.00000 0.85100 0.85100 13.60000 0.29600 1.08200 5.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.4000 0.000 0.000 0.000 0.000
29.661 759.00000 15.2000 -44.53125 0.00000 0.85100 0.85100 13.60000 0.29600 1.08200 5.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.4000 0.000 0.000 0.000 0.000
29.671 759.00000 15.2000 -44.53125 0.00000 0.85100 0.85100 13.60000 0.29600 1.08200 5.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.4000 0.000 0.000 0.000 0.000
29.681 776.00000 15.2000 -44.53125 0.00000 0.87400 0.87400 13.20000 0.30000 1.07500 5.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.4000 0.000 0.000 0.000 0.000
29.691 776.00000 15.2000 -44.53125 0.00000 0.87400 0.87400 13.20000 0.30000 1.07500 5.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.4000 0.000 0.000 0.000 0.000
29.701 776.00000 15.2000 -44.53125 0.00000 0.87400 0.87400 13.20000 0.30000 1.07500 5.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.4000 0.000 0.000 0.000 0.000
29.711 776.00000 15.2000 -44.53125 0.00000 0.87400 0.87400 13.20000 0.30000 1.07500 5.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.4000 0.000 0.000 0.000 0.000
29.721 776.00000 15.2000 -44.53125 0.00000 0.87400 0.87400 13.20000 0.30000 1.07500 5.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.4000 0.000 0.000 0.000 0.000
29.731 776.00000 15.2000 -44.53125 0.00000 0.87400 0.87400 13.20000 0.30000 1.07500 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.4000 0.000 0.000 0.000 0.000
29.741 776.00000 15.2000 -44.53125 0.00000 0.87400 0.87400 13.20000 0.30000 1.07500 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.4000 0.000 0.000 0.000 0.000
29.751 776.00000 15.2000 -44.53125 0.00000 0.87400 0.87400 13.20000 0.30000 1.07500 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.4000 0.000 0.000 0.000 0.000
29.761 776.00000 15.2000 -44.53125 0.00000 0.87400 0.87400 13.20000 0.30000 1.07500 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.4000 0.000 0.000 0.000 0.000
29.771 776.00000 15.2000 -44.53125 0.00000 0.87400 0.87400 13.20000 0.30000 1.07500 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.4000 0.000 0.000 0.000 0.000
29.781 755.00000 15.2000 -44.53125 0.00000 0.88600 0.88600 12.80000 0.30000 1.07500 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.9000 0.000 0.000 0.000 0.000
29.791 755.00000 15.2000 -44.53125 0.00000 0.88600 0.88600 12.80000 0.30000 1.07500 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.9000 0.000 0.000 0.000 0.000
29.801 755.00000 15.2000 -44.53125 0.00000 0.88600 0.88600 12.80000 0.30000 1.07500 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.9000 0.000 0.000 0.000 0.000
29.811 755.00000 15.2000 -44.53125 0.00000 0.88600 0.88600 12.80000 0.30000 1.07500 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.9000 0.000 0.000 0.000 0.000
29.821 755.00000 15.2000 -44.53125 0.00000 0.88600 0.88600 12.80000 0.30000 1.07500 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.9000 0.000 0.000 0.000 0.000
29.831 755.00000 15.2000 -44.53125 0.00000 0.83900 0.83900 12.70000 0.30000 1.07500 5.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.6000 0.000 0.000 0.000 0.000
29.841 755.00000 15.2000 -44.53125 0.00000 0.83900 0.83900 12.70000 0.30000 1.07500 5.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.6000 0.000 0.000 0.000 0.000
29.851 755.00000 15.2000 -44.53125 0.00000 0.83900 0.83900 12.70000 0.30000 1.07500 5.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.6000 0.000 0.000 0.000 0.000
29.861 755.00000 15.2000 -44.53125 0.00000 0.83900 0.83900 12.70000 0.30000 1.07500 5.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.6000 0.000 0.000 0.000 0.000
29.871 755.00000 15.2000 -44.53125 0.00000 0.83900 0.83900 12.70000 0.30000 1.07500 5.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.6000 0.000 0.000 0.000 0.000
29.881 755.00000 15.2000 -44.53125 0.00000 0.84500 0.84500 13.00000 0.30900 1.07500 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.9000 0.000 0.000 0.000 0.000
29.891 755.00000 15.2000 -44.53125 0.00000 0.84500 0.84500 13.00000 0.30900 1.07500 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.9000 0.000 0.000 0.000 0.000
29.901 755.00000 15.2000 -44.53125 0.00000 0.84500 0.84500 13.00000 0.30900 1.07500 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.9000 0.000 0.000 0.000 0.000
29.911 755.00000 15.2000 -44.53125 0.00000 0.84500 0.84500 13.00000 0.30900 1.07500 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.9000 0.000 0.000 0.000 0.000
29.921 755.00000 15.2000 -44.53125 0.00000 0.84500 0.84500 13.00000 0.30900 1.07500 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.9000 0.000 0.000 0.000 0.000
29.931 720.00000 15.2000 -44.53125 0.00000 0.85100 0.85100 13.10000 0.30900 1.07500 5.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.7000 0.000 0.000 0.000 0.000
29.941 720.00000 15.2000 -44.53125 0.00000 0.85100 0.85100 13.10000 0.30900 1.07500 5.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.7000 0.000 0.000 0.000 0.000
29.951 720.00000 15.2000 -44.53125 0.00000 0.85100 0.85100 13.10000 0.30900 1.07500 5.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.7000 0.000 0.000 0.000 0.000
29.961 720.00000 15.2000 -44.53125 0.00000 0.85100 0.85100 13.10000 0.30900 1.07500 5.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.7000 0.000 0.000 0.000 0.000
29.971 720.00000 15.2000 -44.53125 0.00000 0.85100 0.85100 13.10000 0.30900 1.07500 5.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.7000 0.000 0.000 0.000 0.000
29.981 720.00000 15.2000 -44.53125 0.00000 0.86800 0.86800 13.10000 0.30900 1.07500 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.7000 0.000 0.000 0.000 0.000
29.991 720.00000 15.2000 -44.53125 0.00000 0.86800 0.86800 13.10000 0.30900 1.07500 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.7000 0.000 0.000 0.000 0.000
30.001 720.00000 15.2000 -44.53125 0.00000 0.86800 0.86800 13.10000 0.30900 1.07500 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.7000 0.000 0.000 0.000 0.000
30.011 720.00000 15.2000 -44.53125 0.00000 0.86800 0.86800 13.10000 0.30900 1.07500 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.7000 0.000 0.000 0.000 0.000
30.021 720.00000 15.2000 -44.53125 0.00000 0.86800 0.86800 13.10000 0.30900 1.07500 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.7000 0.000 0.000 0.000 0.000
30.031 720.00000 15.2000 -44.53125 0.00000 0.87400 0.87400 13.00000 0.30900 1.07500 5.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.0000 0.000 0.000 0.000 0.000
30.041 720.00000 15.2000 -44.53125 0.00000 0.87400 0.87400 13.00000 0.30900 1.07500 5.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.0000 0.000 0.000 0.000 0.000
30.051 720.00000 15.2000 -44.53125 0.00000 0.87400 0.87400 13.00000 0.30900 1.07500 5.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.0000 0.000 0.000 0.000 0.000
30.061 720.00000 15.2000 -44.53125 0.00000 0.87400 0.87400 13.00000 0.30900 1.07500 5.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.0000 0.000 0.000 0.000 0.000
30.071 720.00000 15.2000 -44.53125 0.00000 0.87400 0.87400 13.00000 0.30900 1.07500 5.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.0000 0.000 0.000 0.000 0.000
30.081 717.00000 15.2000 -44.53125 0.00000 0.83300 0.83300 13.00000 0.30000 1.05900 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.8000 0.000 0.000 0.000 0.000
30.091 717.00000 15.2000 -44.53125 0.00000 0.83300 0.83300 13.00000 0.30000 1.05900 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.8000 0.000 0.000 0.000 0.000
30.101 717.00000 15.2000 -44.53125 0.00000 0.83300 0.83300 13.00000 0.30000 1.05900 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.8000 0.000 0.000 0.000 0.000
30.111 717.00000 15.2000 -44.53125 0.00000 0.83300 0.83300 13.00000 0.30000 1.05900 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.8000 0.000 0.000 0.000 0.000
30.121 717.00000 15.2000 -44.53125 0.00000 0.83300 0.83300 13.00000 0.30000 1.05900 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.8000 0.000 0.000 0.000 0.000
30.131 717.00000 15.4000 -44.53125 0.00000 0.84500 0.84500 12.00000 0.30000 1.05900 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.9000 0.000 0.000 0.000 0.000
30.141 717.00000 15.4000 -44.53125 0.00000 0.84500 0.84500 12.00000 0.30000 1.05900 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.9000 0.000 0.000 0.000 0.000
30.151 717.00000 15.4000 -44.53125 0.00000 0.84500 0.84500 12.00000 0.30000 1.05900 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.9000 0.000 0.000 0.000 0.000
30.161 717.00000 15.4000 -44.53125 0.00000 0.84500 0.84500 12.00000 0.30000 1.05900 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.9000 0.000 0.000 0.000 0.000
30.171 717.00000 15.4000 -44.53125 0.00000 0.84500 0.84500 12.00000 0.30000 1.05900 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.9000 0.000 0.000 0.000 0.000
30.181 723.00000 15.2000 -44.53125 0.00000 0.82700 0.82700 12.60000 0.30000 1.05900 5.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.6000 0.000 0.000 0.000 0.000
30.191 723.00000 15.2000 -44.53125 0.00000 0.82700 0.82700 12.60000 0.30000 1.05900 5.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.6000 0.000 0.000 0.000 0.000
30.201 723.00000 15.2000 -44.53125 0.00000 0.82700 0.82700 12.60000 0.30000 1.05900 5.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.6000 0.000 0.000 0.000 0.000
30.211 723.00000 15.2000 -44.53125 0.00000 0.82700 0.82700 12.60000 0.30000 1.05900 5.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.6000 0.000 0.000 0.000 0.000
30.221 723.00000 15.2000 -44.53125 0.00000 0.82700 0.82700 12.60000 0.30000 1.05900 5.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.6000 0.000 0.000 0.000 0.000
30.231 723.00000 15.2000 -44.53125 0.00000 0.86200 0.86200 12.70000 0.30000 1.05900 6.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.8000 0.000 0.000 0.000 0.000
30.241 723.00000 15.2000 -44.53125 0.00000 0.86200 0.86200 12.70000 0.30000 1.05900 6.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.8000 0.000 0.000 0.000 0.000
30.251 723.00000 15.2000 -44.53125 0.00000 0.86200 0.86200 12.70000 0.30000 1.05900 6.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.8000 0.000 0.000 0.000 0.000
30.261 723.00000 15.2000 -44.53125 0.00000 0.86200 0.86200 12.70000 0.30000 1.05900 6.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.8000 0.000 0.000 0.000 0.000
30.271 723.00000 15.2000 -44.53125 0.00000 0.86200 0.86200 12.70000 0.30000 1.05900 6.00000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.8000 0.000 0.000 0.000 0.000
30.281 723.00000 15.2000 -44.53125 0.00000 0.89100 0.89100 12.90000 0.30300 1.05000 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.6000 0.000 0.000 0.000 0.000
30.291 723.00000 15.2000 -44.53125 0.00000 0.89100 0.89100 12.90000 0.30300 1.05000 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.6000 0.000 0.000 0.000 0.000
30.301 723.00000 15.2000 -44.53125 0.00000 0.89100 0.89100 12.90000 0.30300 1.05000 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.6000 0.000 0.000 0.000 0.000
30.311 723.00000 15.2000 -44.53125 0.00000 0.89100 0.89100 12.90000 0.30300 1.05000 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.6000 0.000 0.000 0.000 0.000
30.321 723.00000 15.2000 -44.53125 0.00000 0.89100 0.89100 12.90000 0.30300 1.05000 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.6000 0.000 0.000 0.000 0.000
30.331 716.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 12.80000 0.30300 1.05000 5.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.6000 0.000 0.000 0.000 0.000
30.341 716.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 12.80000 0.30300 1.05000 5.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.6000 0.000 0.000 0.000 0.000
30.351 716.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 12.80000 0.30300 1.05000 5.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.6000 0.000 0.000 0.000 0.000
30.361 716.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 12.80000 0.30300 1.05000 5.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.6000 0.000 0.000 0.000 0.000
30.371 716.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 12.80000 0.30300 1.05000 5.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.6000 0.000 0.000 0.000 0.000
30.381 716.00000 15.2000 -44.53125 0.00000 0.86200 0.86200 12.90000 0.30300 1.05000 6.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.8000 0.000 0.000 0.000 0.000
30.391 716.00000 15.2000 -44.53125 0.00000 0.86200 0.86200 12.90000 0.30300 1.05000 6.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.8000 0.000 0.000 0.000 0.000
30.401 716.00000 15.2000 -44.53125 0.00000 0.86200 0.86200 12.90000 0.30300 1.05000 6.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.8000 0.000 0.000 0.000 0.000
30.411 716.00000 15.2000 -44.53125 0.00000 0.86200 0.86200 12.90000 0.30300 1.05000 6.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.8000 0.000 0.000 0.000 0.000
30.421 716.00000 15.2000 -44.53125 0.00000 0.86200 0.86200 12.90000 0.30300 1.05000 6.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.8000 0.000 0.000 0.000 0.000
30.431 716.00000 15.2000 -44.53125 0.00000 0.84500 0.84500 13.10000 0.30300 1.05000 5.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.7000 0.000 0.000 0.000 0.000
30.441 716.00000 15.2000 -44.53125 0.00000 0.84500 0.84500 13.10000 0.30300 1.05000 5.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.7000 0.000 0.000 0.000 0.000
30.451 716.00000 15.2000 -44.53125 0.00000 0.84500 0.84500 13.10000 0.30300 1.05000 5.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.7000 0.000 0.000 0.000 0.000
30.461 716.00000 15.2000 -44.53125 0.00000 0.84500 0.84500 13.10000 0.30300 1.05000 5.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.7000 0.000 0.000 0.000 0.000
30.471 716.00000 15.2000 -44.53125 0.00000 0.84500 0.84500 13.10000 0.30300 1.05000 5.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.7000 0.000 0.000 0.000 0.000
30.481 743.00000 15.2000 -44.53125 0.00000 0.85600 0.85600 12.60000 0.30000 1.03700 5.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.8000 0.000 0.000 0.000 0.000
30.491 743.00000 15.2000 -44.53125 0.00000 0.85600 0.85600 12.60000 0.30000 1.03700 5.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.8000 0.000 0.000 0.000 0.000
30.501 743.00000 15.2000 -44.53125 0.00000 0.85600 0.85600 12.60000 0.30000 1.03700 5.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.8000 0.000 0.000 0.000 0.000
30.511 743.00000 15.2000 -44.53125 0.00000 0.85600 0.85600 12.60000 0.30000 1.03700 5.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.8000 0.000 0.000 0.000 0.000
30.521 743.00000 15.2000 -44.53125 0.00000 0.85600 0.85600 12.60000 0.30000 1.03700 5.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.8000 0.000 0.000 0.000 0.000
30.531 743.00000 15.2000 -44.53125 0.00000 0.87400 0.87400 12.80000 0.30000 1.03700 6.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.8000 0.000 0.000 0.000 0.000
30.541 743.00000 15.2000 -44.53125 0.00000 0.87400 0.87400 12.80000 0.30000 1.03700 6.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.8000 0.000 0.000 0.000 0.000
30.551 743.00000 15.2000 -44.53125 0.00000 0.87400 0.87400 12.80000 0.30000 1.03700 6.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.8000 0.000 0.000 0.000 0.000
30.561 743.00000 15.2000 -44.53125 0.00000 0.87400 0.87400 12.80000 0.30000 1.03700 6.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.8000 0.000 0.000 0.000 0.000
30.571 743.00000 15.2000 -44.53125 0.00000 0.87400 0.87400 12.80000 0.30000 1.03700 6.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.8000 0.000 0.000 0.000 0.000
30.581 768.00000 15.2000 -44.53125 0.00000 0.84500 0.84500 12.80000 0.30000 1.03700 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.9000 0.000 0.000 0.000 0.000
30.591 768.00000 15.2000 -44.53125 0.00000 0.84500 0.84500 12.80000 0.30000 1.03700 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.9000 0.000 0.000 0.000 0.000
30.601 768.00000 15.2000 -44.53125 0.00000 0.84500 0.84500 12.80000 0.30000 1.03700 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.9000 0.000 0.000 0.000 0.000
30.611 768.00000 15.2000 -44.53125 0.00000 0.84500 0.84500 12.80000 0.30000 1.03700 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.9000 0.000 0.000 0.000 0.000
30.621 768.00000 15.2000 -44.53125 0.00000 0.84500 0.84500 12.80000 0.30000 1.03700 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.9000 0.000 0.000 0.000 0.000
30.631 768.00000 15.2000 -44.53125 0.00000 0.86800 0.86800 13.40000 0.30000 1.03700 5.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.7000 0.000 0.000 0.000 0.000
30.641 768.00000 15.2000 -44.53125 0.00000 0.86800 0.86800 13.40000 0.30000 1.03700 5.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.7000 0.000 0.000 0.000 0.000
30.651 768.00000 15.2000 -44.53125 0.00000 0.86800 0.86800 13.40000 0.30000 1.03700 5.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.7000 0.000 0.000 0.000 0.000
30.661 768.00000 15.2000 -44.53125 0.00000 0.86800 0.86800 13.40000 0.30000 1.03700 5.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.7000 0.000 0.000 0.000 0.000
30.671 768.00000 15.2000 -44.53125 0.00000 0.86800 0.86800 13.40000 0.30000 1.03700 5.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.7000 0.000 0.000 0.000 0.000
30.681 768.00000 15.2000 -44.53125 0.00000 0.87400 0.87400 13.70000 0.30000 1.01500 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.7000 0.000 0.000 0.000 0.000
30.691 768.00000 15.2000 -44.53125 0.00000 0.87400 0.87400 13.70000 0.30000 1.01500 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.7000 0.000 0.000 0.000 0.000
30.701 768.00000 15.2000 -44.53125 0.00000 0.87400 0.87400 13.70000 0.30000 1.01500 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.7000 0.000 0.000 0.000 0.000
30.711 768.00000 15.2000 -44.53125 0.00000 0.87400 0.87400 13.70000 0.30000 1.01500 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.7000 0.000 0.000 0.000 0.000
30.721 768.00000 15.2000 -44.53125 0.00000 0.87400 0.87400 13.70000 0.30000 1.01500 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.7000 0.000 0.000 0.000 0.000
30.731 807.00000 15.2000 -44.53125 0.00000 0.86200 0.86200 13.20000 0.30000 1.01500 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.0000 0.000 0.000 0.000 0.000
30.741 807.00000 15.2000 -44.53125 0.00000 0.86200 0.86200 13.20000 0.30000 1.01500 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.0000 0.000 0.000 0.000 0.000
30.751 807.00000 15.2000 -44.53125 0.00000 0.86200 0.86200 13.20000 0.30000 1.01500 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.0000 0.000 0.000 0.000 0.000
30.761 807.00000 15.2000 -44.53125 0.00000 0.86200 0.86200 13.20000 0.30000 1.01500 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.0000 0.000 0.000 0.000 0.000
30.771 807.00000 15.2000 -44.53125 0.00000 0.86200 0.86200 13.20000 0.30000 1.01500 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.0000 0.000 0.000 0.000 0.000
30.781 807.00000 15.2000 -44.53125 0.00000 0.86200 0.86200 13.40000 0.30000 1.01500 5.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.9000 0.000 0.000 0.000 0.000
30.791 807.00000 15.2000 -44.53125 0.00000 0.86200 0.86200 13.40000 0.30000 1.01500 5.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.9000 0.000 0.000 0.000 0.000
30.801 807.00000 15.2000 -44.53125 0.00000 0.86200 0.86200 13.40000 0.30000 1.01500 5.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.9000 0.000 0.000 0.000 0.000
30.811 807.00000 15.2000 -44.53125 0.00000 0.86200 0.86200 13.40000 0.30000 1.01500 5.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.9000 0.000 0.000 0.000 0.000
30.821 807.00000 15.2000 -44.53125 0.00000 0.86200 0.86200 13.40000 0.30000 1.01500 5.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 17.9000 0.000 0.000 0.000 0.000
30.831 848.00000 15.2000 -44.53125 0.00000 0.86800 0.86800 13.10000 0.30000 1.01500 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.1000 0.000 0.000 0.000 0.000
30.841 848.00000 15.2000 -44.53125 0.00000 0.86800 0.86800 13.10000 0.30000 1.01500 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.1000 0.000 0.000 0.000 0.000
30.851 848.00000 15.2000 -44.53125 0.00000 0.86800 0.86800 13.10000 0.30000 1.01500 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.1000 0.000 0.000 0.000 0.000
30.861 848.00000 15.2000 -44.53125 0.00000 0.86800 0.86800 13.10000 0.30000 1.01500 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.1000 0.000 0.000 0.000 0.000
30.871 848.00000 15.2000 -44.53125 0.00000 0.86800 0.86800 13.10000 0.30000 1.01500 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.1000 0.000 0.000 0.000 0.000
30.881 848.00000 15.2000 -44.53125 0.00000 0.81600 0.81600 13.10000 0.29300 0.96300 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.3000 0.000 0.000 0.000 0.000
30.891 848.00000 15.2000 -44.53125 0.00000 0.81600 0.81600 13.10000 0.29300 0.96300 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.3000 0.000 0.000 0.000 0.000
30.901 848.00000 15.2000 -44.53125 0.00000 0.81600 0.81600 13.10000 0.29300 0.96300 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.3000 0.000 0.000 0.000 0.000
30.911 848.00000 15.2000 -44.53125 0.00000 0.81600 0.81600 13.10000 0.29300 0.96300 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.3000 0.000 0.000 0.000 0.000
30.921 848.00000 15.2000 -44.53125 0.00000 0.81600 0.81600 13.10000 0.29300 0.96300 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.3000 0.000 0.000 0.000 0.000
30.931 872.00000 15.2000 -44.53125 0.00000 0.84500 0.84500 13.20000 0.29300 0.96300 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
30.941 872.00000 15.2000 -44.53125 0.00000 0.84500 0.84500 13.20000 0.29300 0.96300 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
30.951 872.00000 15.2000 -44.53125 0.00000 0.84500 0.84500 13.20000 0.29300 0.96300 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
30.961 872.00000 15.2000 -44.53125 0.00000 0.84500 0.84500 13.20000 0.29300 0.96300 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
30.971 872.00000 15.2000 -44.53125 0.00000 0.84500 0.84500 13.20000 0.29300 0.96300 5.70000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
30.981 872.00000 15.2000 -44.53125 0.00000 0.86800 0.86800 13.50000 0.29300 0.96300 5.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.3000 0.000 0.000 0.000 0.000
30.991 872.00000 15.2000 -44.53125 0.00000 0.86800 0.86800 13.50000 0.29300 0.96300 5.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.3000 0.000 0.000 0.000 0.000
31.001 872.00000 15.2000 -44.53125 0.00000 0.86800 0.86800 13.50000 0.29300 0.96300 5.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.3000 0.000 0.000 0.000 0.000
31.011 872.00000 15.2000 -44.53125 0.00000 0.86800 0.86800 13.50000 0.29300 0.96300 5.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.3000 0.000 0.000 0.000 0.000
31.021 872.00000 15.2000 -44.53125 0.00000 0.86800 0.86800 13.50000 0.29300 0.96300 5.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.3000 0.000 0.000 0.000 0.000
31.031 866.00000 15.2000 -44.53125 0.00000 0.83300 0.83300 13.20000 0.29300 0.96300 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
31.041 866.00000 15.2000 -44.53125 0.00000 0.83300 0.83300 13.20000 0.29300 0.96300 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
31.051 866.00000 15.2000 -44.53125 0.00000 0.83300 0.83300 13.20000 0.29300 0.96300 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
31.061 866.00000 15.2000 -44.53125 0.00000 0.83300 0.83300 13.20000 0.29300 0.96300 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
31.071 866.00000 15.2000 -44.53125 0.00000 0.83300 0.83300 13.20000 0.29300 0.96300 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
31.081 866.00000 15.2000 -44.53125 0.00000 0.85100 0.85100 13.30000 0.29300 0.90300 5.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
31.091 866.00000 15.2000 -44.53125 0.00000 0.85100 0.85100 13.30000 0.29300 0.90300 5.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
31.101 866.00000 15.2000 -44.53125 0.00000 0.85100 0.85100 13.30000 0.29300 0.90300 5.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
31.111 866.00000 15.2000 -44.53125 0.00000 0.85100 0.85100 13.30000 0.29300 0.90300 5.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
31.121 866.00000 15.2000 -44.53125 0.00000 0.85100 0.85100 13.30000 0.29300 0.90300 5.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
31.131 866.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 13.20000 0.29300 0.90300 5.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
31.141 866.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 13.20000 0.29300 0.90300 5.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
31.151 866.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 13.20000 0.29300 0.90300 5.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
31.161 866.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 13.20000 0.29300 0.90300 5.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
31.171 866.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 13.20000 0.29300 0.90300 5.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
31.181 844.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 13.10000 0.29300 0.90300 5.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
31.191 844.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 13.10000 0.29300 0.90300 5.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
31.201 844.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 13.10000 0.29300 0.90300 5.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
31.211 844.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 13.10000 0.29300 0.90300 5.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
31.221 844.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 13.10000 0.29300 0.90300 5.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
31.231 844.00000 15.2000 -44.53125 0.00000 0.86800 0.86800 13.10000 0.29300 0.90300 5.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
31.241 844.00000 15.2000 -44.53125 0.00000 0.86800 0.86800 13.10000 0.29300 0.90300 5.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
31.251 844.00000 15.2000 -44.53125 0.00000 0.86800 0.86800 13.10000 0.29300 0.90300 5.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
31.261 844.00000 15.2000 -44.53125 0.00000 0.86800 0.86800 13.10000 0.29300 0.90300 5.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
31.271 844.00000 15.2000 -44.53125 0.00000 0.86800 0.86800 13.10000 0.29300 0.90300 5.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
31.281 822.00000 15.2000 -44.53125 0.00000 0.89100 0.89100 13.30000 0.29300 0.82900 5.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.7000 0.000 0.000 0.000 0.000
31.291 822.00000 15.2000 -44.53125 0.00000 0.89100 0.89100 13.30000 0.29300 0.82900 5.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.7000 0.000 0.000 0.000 0.000
31.301 822.00000 15.2000 -44.53125 0.00000 0.89100 0.89100 13.30000 0.29300 0.82900 5.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.7000 0.000 0.000 0.000 0.000
31.311 822.00000 15.2000 -44.53125 0.00000 0.89100 0.89100 13.30000 0.29300 0.82900 5.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.7000 0.000 0.000 0.000 0.000
31.321 822.00000 15.2000 -44.53125 0.00000 0.89100 0.89100 13.30000 0.29300 0.82900 5.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.7000 0.000 0.000 0.000 0.000
31.331 822.00000 15.2000 -44.53125 0.00000 0.89100 0.89100 13.40000 0.29300 0.82900 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
31.341 822.00000 15.2000 -44.53125 0.00000 0.89100 0.89100 13.40000 0.29300 0.82900 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
31.351 822.00000 15.2000 -44.53125 0.00000 0.89100 0.89100 13.40000 0.29300 0.82900 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
31.361 822.00000 15.2000 -44.53125 0.00000 0.89100 0.89100 13.40000 0.29300 0.82900 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
31.371 822.00000 15.2000 -44.53125 0.00000 0.89100 0.89100 13.40000 0.29300 0.82900 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
31.381 805.00000 15.2000 -44.53125 0.00000 0.86200 0.86200 13.30000 0.29300 0.82900 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
31.391 805.00000 15.2000 -44.53125 0.00000 0.86200 0.86200 13.30000 0.29300 0.82900 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
31.401 805.00000 15.2000 -44.53125 0.00000 0.86200 0.86200 13.30000 0.29300 0.82900 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
31.411 805.00000 15.2000 -44.53125 0.00000 0.86200 0.86200 13.30000 0.29300 0.82900 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
31.421 805.00000 15.2000 -44.53125 0.00000 0.86200 0.86200 13.30000 0.29300 0.82900 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
31.431 805.00000 15.4000 -44.53125 0.00000 0.90900 0.90900 12.00000 0.29300 0.82900 5.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
31.441 805.00000 15.4000 -44.53125 0.00000 0.90900 0.90900 12.00000 0.29300 0.82900 5.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
31.451 805.00000 15.4000 -44.53125 0.00000 0.90900 0.90900 12.00000 0.29300 0.82900 5.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
31.461 805.00000 15.4000 -44.53125 0.00000 0.90900 0.90900 12.00000 0.29300 0.82900 5.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
31.471 805.00000 15.4000 -44.53125 0.00000 0.90900 0.90900 12.00000 0.29300 0.82900 5.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
31.481 805.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 13.50000 0.29600 0.67000 5.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.4000 0.000 0.000 0.000 0.000
31.491 805.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 13.50000 0.29600 0.67000 5.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.4000 0.000 0.000 0.000 0.000
31.501 805.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 13.50000 0.29600 0.67000 5.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.4000 0.000 0.000 0.000 0.000
31.511 805.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 13.50000 0.29600 0.67000 5.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.4000 0.000 0.000 0.000 0.000
31.521 805.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 13.50000 0.29600 0.67000 5.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.4000 0.000 0.000 0.000 0.000
31.531 819.00000 15.2000 -44.53125 0.00000 0.92100 0.92100 13.10000 0.29600 0.67000 5.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
31.541 819.00000 15.2000 -44.53125 0.00000 0.92100 0.92100 13.10000 0.29600 0.67000 5.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
31.551 819.00000 15.2000 -44.53125 0.00000 0.92100 0.92100 13.10000 0.29600 0.67000 5.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
31.561 819.00000 15.2000 -44.53125 0.00000 0.92100 0.92100 13.10000 0.29600 0.67000 5.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
31.571 819.00000 15.2000 -44.53125 0.00000 0.92100 0.92100 13.10000 0.29600 0.67000 5.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
31.581 819.00000 15.2000 -44.53125 0.00000 0.92100 0.92100 13.20000 0.29600 0.67000 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
31.591 819.00000 15.2000 -44.53125 0.00000 0.92100 0.92100 13.20000 0.29600 0.67000 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
31.601 819.00000 15.2000 -44.53125 0.00000 0.92100 0.92100 13.20000 0.29600 0.67000 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
31.611 819.00000 15.2000 -44.53125 0.00000 0.92100 0.92100 13.20000 0.29600 0.67000 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
31.621 819.00000 15.2000 -44.53125 0.00000 0.92100 0.92100 13.20000 0.29600 0.67000 5.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
31.631 807.00000 15.2000 -44.53125 0.00000 0.89700 0.89700 13.40000 0.29600 0.67000 5.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
31.641 807.00000 15.2000 -44.53125 0.00000 0.89700 0.89700 13.40000 0.29600 0.67000 5.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
31.651 807.00000 15.2000 -44.53125 0.00000 0.89700 0.89700 13.40000 0.29600 0.67000 5.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
31.661 807.00000 15.2000 -44.53125 0.00000 0.89700 0.89700 13.40000 0.29600 0.67000 5.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
31.671 807.00000 15.2000 -44.53125 0.00000 0.89700 0.89700 13.40000 0.29600 0.67000 5.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
31.681 807.00000 15.2000 -44.53125 0.00000 0.88600 0.88600 13.20000 0.30000 0.44300 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.4000 0.000 0.000 0.000 0.000
31.691 807.00000 15.2000 -44.53125 0.00000 0.88600 0.88600 13.20000 0.30000 0.44300 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.4000 0.000 0.000 0.000 0.000
31.701 807.00000 15.2000 -44.53125 0.00000 0.88600 0.88600 13.20000 0.30000 0.44300 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.4000 0.000 0.000 0.000 0.000
31.711 807.00000 15.2000 -44.53125 0.00000 0.88600 0.88600 13.20000 0.30000 0.44300 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.4000 0.000 0.000 0.000 0.000
31.721 807.00000 15.2000 -44.53125 0.00000 0.88600 0.88600 13.20000 0.30000 0.44300 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.4000 0.000 0.000 0.000 0.000
31.731 807.00000 15.2000 -44.53125 0.00000 0.85600 0.85600 13.20000 0.30000 0.44300 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
31.741 807.00000 15.2000 -44.53125 0.00000 0.85600 0.85600 13.20000 0.30000 0.44300 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
31.751 807.00000 15.2000 -44.53125 0.00000 0.85600 0.85600 13.20000 0.30000 0.44300 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
31.761 807.00000 15.2000 -44.53125 0.00000 0.85600 0.85600 13.20000 0.30000 0.44300 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
31.771 807.00000 15.2000 -44.53125 0.00000 0.85600 0.85600 13.20000 0.30000 0.44300 5.30000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
31.781 816.00000 15.2000 -44.53125 0.00000 0.89700 0.89700 13.10000 0.30000 0.44300 5.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.3000 0.000 0.000 0.000 0.000
31.791 816.00000 15.2000 -44.53125 0.00000 0.89700 0.89700 13.10000 0.30000 0.44300 5.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.3000 0.000 0.000 0.000 0.000
31.801 816.00000 15.2000 -44.53125 0.00000 0.89700 0.89700 13.10000 0.30000 0.44300 5.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.3000 0.000 0.000 0.000 0.000
31.811 816.00000 15.2000 -44.53125 0.00000 0.89700 0.89700 13.10000 0.30000 0.44300 5.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.3000 0.000 0.000 0.000 0.000
31.821 816.00000 15.2000 -44.53125 0.00000 0.89700 0.89700 13.10000 0.30000 0.44300 5.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.3000 0.000 0.000 0.000 0.000
31.831 816.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 13.50000 0.30000 0.44300 5.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.3000 0.000 0.000 0.000 0.000
31.841 816.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 13.50000 0.30000 0.44300 5.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.3000 0.000 0.000 0.000 0.000
31.851 816.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 13.50000 0.30000 0.44300 5.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.3000 0.000 0.000 0.000 0.000
31.861 816.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 13.50000 0.30000 0.44300 5.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.3000 0.000 0.000 0.000 0.000
31.871 816.00000 15.2000 -44.53125 0.00000 0.88000 0.88000 13.50000 0.30000 0.44300 5.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.3000 0.000 0.000 0.000 0.000
31.881 873.00000 15.2000 -44.53125 0.00000 0.93200 0.93200 13.10000 0.30000 0.32800 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.4000 0.000 0.000 0.000 0.000
31.891 873.00000 15.2000 -44.53125 0.00000 0.93200 0.93200 13.10000 0.30000 0.32800 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.4000 0.000 0.000 0.000 0.000
31.901 873.00000 15.2000 -44.53125 0.00000 0.93200 0.93200 13.10000 0.30000 0.32800 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.4000 0.000 0.000 0.000 0.000
31.911 873.00000 15.2000 -44.53125 0.00000 0.93200 0.93200 13.10000 0.30000 0.32800 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.4000 0.000 0.000 0.000 0.000
31.921 873.00000 15.2000 -44.53125 0.00000 0.93200 0.93200 13.10000 0.30000 0.32800 5.40000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.4000 0.000 0.000 0.000 0.000
31.931 873.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 13.50000 0.30000 0.32800 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.4000 0.000 0.000 0.000 0.000
31.941 873.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 13.50000 0.30000 0.32800 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.4000 0.000 0.000 0.000 0.000
31.951 873.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 13.50000 0.30000 0.32800 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.4000 0.000 0.000 0.000 0.000
31.961 873.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 13.50000 0.30000 0.32800 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.4000 0.000 0.000 0.000 0.000
31.971 873.00000 15.2000 -44.53125 0.00000 0.90900 0.90900 13.50000 0.30000 0.32800 4.90000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.4000 0.000 0.000 0.000 0.000
31.981 912.00000 15.2000 -44.53125 0.00000 0.93800 0.93800 12.80000 0.30000 0.32800 5.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
31.991 912.00000 15.2000 -44.53125 0.00000 0.93800 0.93800 12.80000 0.30000 0.32800 5.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
32.001 912.00000 15.2000 -44.53125 0.00000 0.93800 0.93800 12.80000 0.30000 0.32800 5.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
32.011 912.00000 15.2000 -44.53125 0.00000 0.93800 0.93800 12.80000 0.30000 0.32800 5.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
32.021 912.00000 15.2000 -44.53125 0.00000 0.93800 0.93800 12.80000 0.30000 0.32800 5.10000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
32.031 912.00000 15.2000 -44.53125 0.00000 0.88600 0.88600 13.30000 0.30000 0.32800 5.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.3000 0.000 0.000 0.000 0.000
32.041 912.00000 15.2000 -44.53125 0.00000 0.88600 0.88600 13.30000 0.30000 0.32800 5.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.3000 0.000 0.000 0.000 0.000
32.051 912.00000 15.2000 -44.53125 0.00000 0.88600 0.88600 13.30000 0.30000 0.32800 5.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.3000 0.000 0.000 0.000 0.000
32.061 912.00000 15.2000 -44.53125 0.00000 0.88600 0.88600 13.30000 0.30000 0.32800 5.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.3000 0.000 0.000 0.000 0.000
32.071 912.00000 15.2000 -44.53125 0.00000 0.88600 0.88600 13.30000 0.30000 0.32800 5.20000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.3000 0.000 0.000 0.000 0.000
32.081 981.00000 15.2000 -44.53125 0.00000 0.92100 0.92100 13.30000 0.30300 0.31900 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.3000 0.000 0.000 0.000 0.000
32.091 981.00000 15.2000 -44.53125 0.00000 0.92100 0.92100 13.30000 0.30300 0.31900 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.3000 0.000 0.000 0.000 0.000
32.101 981.00000 15.2000 -44.53125 0.00000 0.92100 0.92100 13.30000 0.30300 0.31900 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.3000 0.000 0.000 0.000 0.000
32.111 981.00000 15.2000 -44.53125 0.00000 0.92100 0.92100 13.30000 0.30300 0.31900 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.3000 0.000 0.000 0.000 0.000
32.121 981.00000 15.2000 -44.53125 0.00000 0.92100 0.92100 13.30000 0.30300 0.31900 4.80000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.3000 0.000 0.000 0.000 0.000
32.131 981.00000 15.2000 -44.53125 0.00000 0.92600 0.92600 13.30000 0.30300 0.31900 4.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.3000 0.000 0.000 0.000 0.000
32.141 981.00000 15.2000 -44.53125 0.00000 0.92600 0.92600 13.30000 0.30300 0.31900 4.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.3000 0.000 0.000 0.000 0.000
32.151 981.00000 15.2000 -44.53125 0.00000 0.92600 0.92600 13.30000 0.30300 0.31900 4.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.3000 0.000 0.000 0.000 0.000
32.161 981.00000 15.2000 -44.53125 0.00000 0.92600 0.92600 13.30000 0.30300 0.31900 4.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.3000 0.000 0.000 0.000 0.000
32.171 981.00000 15.2000 -44.53125 0.00000 0.92600 0.92600 13.30000 0.30300 0.31900 4.60000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.3000 0.000 0.000 0.000 0.000
32.181 1059.00000 15.2000 -44.53125 0.00000 0.93200 0.93200 13.50000 0.30300 0.31900 4.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.1000 0.000 0.000 0.000 0.000
32.191 1059.00000 15.2000 -44.53125 0.00000 0.93200 0.93200 13.50000 0.30300 0.31900 4.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.1000 0.000 0.000 0.000 0.000
32.201 1059.00000 15.2000 -44.53125 0.00000 0.93200 0.93200 13.50000 0.30300 0.31900 4.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.1000 0.000 0.000 0.000 0.000
32.211 1059.00000 15.2000 -44.53125 0.00000 0.93200 0.93200 13.50000 0.30300 0.31900 4.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.1000 0.000 0.000 0.000 0.000
32.221 1059.00000 15.2000 -44.53125 0.00000 0.93200 0.93200 13.50000 0.30300 0.31900 4.50000 1.00000 1.00000 1.00000 1.00000 1.00000 0.00000 0.00000 18.1000 0.000 0.000 0.000 0.000
32.231 1218.00000 15.2000 -44.53125 0.00000 0.95600 0.95600 13.20000 0.30300 0.31900 4.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 18.3000 0.000 0.000 0.000 0.000
32.241 1218.00000 15.2000 -44.53125 0.00000 0.95600 0.95600 13.20000 0.30300 0.31900 4.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 18.3000 0.000 0.000 0.000 0.000
32.251 1218.00000 15.2000 -44.53125 0.00000 0.95600 0.95600 13.20000 0.30300 0.31900 4.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 18.3000 0.000 0.000 0.000 0.000
32.261 1218.00000 15.2000 -44.53125 0.00000 0.95600 0.95600 13.20000 0.30300 0.31900 4.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 18.3000 0.000 0.000 0.000 0.000
32.271 1218.00000 15.2000 -44.53125 0.00000 0.95600 0.95600 13.20000 0.30300 0.31900 4.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 18.3000 0.000 0.000 0.000 0.000
32.281 1218.00000 15.2000 -44.53125 0.00000 0.96100 0.96100 13.60000 0.28700 0.31200 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 17.6000 0.000 0.000 0.000 0.000
32.291 1218.00000 15.2000 -44.53125 0.00000 0.96100 0.96100 13.60000 0.28700 0.31200 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 17.6000 0.000 0.000 0.000 0.000
32.301 1218.00000 15.2000 -44.53125 0.00000 0.96100 0.96100 13.60000 0.28700 0.31200 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 17.6000 0.000 0.000 0.000 0.000
32.311 1218.00000 15.2000 -44.53125 0.00000 0.96100 0.96100 13.60000 0.28700 0.31200 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 17.6000 0.000 0.000 0.000 0.000
32.321 1218.00000 15.2000 -44.53125 0.00000 0.96100 0.96100 13.60000 0.28700 0.31200 4.50000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 17.6000 0.000 0.000 0.000 0.000
32.331 1348.00000 15.2000 -44.53125 0.00000 0.96100 0.96100 12.90000 0.28700 0.31200 4.10000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 17.6000 0.000 0.000 0.000 0.000
32.341 1348.00000 15.2000 -44.53125 0.00000 0.96100 0.96100 12.90000 0.28700 0.31200 4.10000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 17.6000 0.000 0.000 0.000 0.000
32.351 1348.00000 15.2000 -44.53125 0.00000 0.96100 0.96100 12.90000 0.28700 0.31200 4.10000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 17.6000 0.000 0.000 0.000 0.000
32.361 1348.00000 15.2000 -44.53125 0.00000 0.96100 0.96100 12.90000 0.28700 0.31200 4.10000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 17.6000 0.000 0.000 0.000 0.000
32.371 1348.00000 15.2000 -44.53125 0.00000 0.96100 0.96100 12.90000 0.28700 0.31200 4.10000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 17.6000 0.000 0.000 0.000 0.000
32.381 1476.00000 15.4000 -44.53125 0.00000 0.99600 0.99600 12.50000 0.28700 0.31200 4.10000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 17.6000 0.000 0.000 0.000 0.000
32.391 1476.00000 15.4000 -44.53125 0.00000 0.99600 0.99600 12.50000 0.28700 0.31200 4.10000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 17.6000 0.000 0.000 0.000 0.000
32.401 1476.00000 15.4000 -44.53125 0.00000 0.99600 0.99600 12.50000 0.28700 0.31200 4.10000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 17.6000 0.000 0.000 0.000 0.000
32.411 1476.00000 15.4000 -44.53125 0.00000 0.99600 0.99600 12.50000 0.28700 0.31200 4.10000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 17.6000 0.000 0.000 0.000 0.000
32.421 1476.00000 15.4000 -44.53125 0.00000 0.99600 0.99600 12.50000 0.28700 0.31200 4.10000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 17.6000 0.000 0.000 0.000 0.000
32.431 1624.00000 16.0000 -44.53125 0.00000 1.04900 1.04900 13.30000 0.28700 0.31200 4.20000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 17.1000 0.000 0.000 0.000 0.000
32.441 1624.00000 16.0000 -44.53125 0.00000 1.04900 1.04900 13.30000 0.28700 0.31200 4.20000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 17.1000 0.000 0.000 0.000 0.000
32.451 1624.00000 16.0000 -44.53125 0.00000 1.04900 1.04900 13.30000 0.28700 0.31200 4.20000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 17.1000 0.000 0.000 0.000 0.000
32.461 1624.00000 16.0000 -44.53125 0.00000 1.04900 1.04900 13.30000 0.28700 0.31200 4.20000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 17.1000 0.000 0.000 0.000 0.000
32.471 1624.00000 16.0000 -44.53125 0.00000 1.04900 1.04900 13.30000 0.28700 0.31200 4.20000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 17.1000 0.000 0.000 0.000 0.000
32.481 1624.00000 16.5000 -44.53125 0.00000 1.15400 1.15400 12.70000 0.32200 0.31500 4.20000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 17.2000 0.000 0.000 0.000 0.000
32.491 1624.00000 16.5000 -44.53125 0.00000 1.15400 1.15400 12.70000 0.32200 0.31500 4.20000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 17.2000 0.000 0.000 0.000 0.000
32.501 1624.00000 16.5000 -44.53125 0.00000 1.15400 1.15400 12.70000 0.32200 0.31500 4.20000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 17.2000 0.000 0.000 0.000 0.000
32.511 1624.00000 16.5000 -44.53125 0.00000 1.15400 1.15400 12.70000 0.32200 0.31500 4.20000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 17.2000 0.000 0.000 0.000 0.000
32.521 1624.00000 16.5000 -44.53125 0.00000 1.15400 1.15400 12.70000 0.32200 0.31500 4.20000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 17.2000 0.000 0.000 0.000 0.000
32.531 1694.00000 17.8000 -44.53125 0.00000 1.25300 1.25300 13.20000 0.32200 0.31500 4.10000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 17.0000 0.000 0.000 0.000 0.000
32.541 1694.00000 17.8000 -44.53125 0.00000 1.25300 1.25300 13.20000 0.32200 0.31500 4.10000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 17.0000 0.000 0.000 0.000 0.000
32.551 1694.00000 17.8000 -44.53125 0.00000 1.25300 1.25300 13.20000 0.32200 0.31500 4.10000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 17.0000 0.000 0.000 0.000 0.000
32.561 1694.00000 17.8000 -44.53125 0.00000 1.25300 1.25300 13.20000 0.32200 0.31500 4.10000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 17.0000 0.000 0.000 0.000 0.000
32.571 1694.00000 17.8000 -44.53125 0.00000 1.25300 1.25300 13.20000 0.32200 0.31500 4.10000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 17.0000 0.000 0.000 0.000 0.000
32.581 1805.00000 19.5000 -44.53125 0.00000 1.37500 1.37500 13.20000 0.32200 0.31500 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 16.8000 0.000 0.000 0.000 0.000
32.591 1805.00000 19.5000 -44.53125 0.00000 1.37500 1.37500 13.20000 0.32200 0.31500 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 16.8000 0.000 0.000 0.000 0.000
32.601 1805.00000 19.5000 -44.53125 0.00000 1.37500 1.37500 13.20000 0.32200 0.31500 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 16.8000 0.000 0.000 0.000 0.000
32.611 1805.00000 19.5000 -44.53125 0.00000 1.37500 1.37500 13.20000 0.32200 0.31500 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 16.8000 0.000 0.000 0.000 0.000
32.621 1805.00000 19.5000 -44.53125 0.00000 1.37500 1.37500 13.20000 0.32200 0.31500 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 16.8000 0.000 0.000 0.000 0.000
32.631 1862.00000 20.3000 -44.53125 0.00000 1.39300 1.39300 13.50000 0.32200 0.31500 4.70000 1.00000 3.00000 3.00000 2.00000 3.00000 0.00000 0.00000 16.8000 0.000 0.000 0.000 0.000
32.641 1862.00000 20.3000 -44.53125 0.00000 1.39300 1.39300 13.50000 0.32200 0.31500 4.70000 1.00000 3.00000 3.00000 2.00000 3.00000 0.00000 0.00000 16.8000 0.000 0.000 0.000 0.000
32.651 1862.00000 20.3000 -44.53125 0.00000 1.39300 1.39300 13.50000 0.32200 0.31500 4.70000 1.00000 3.00000 3.00000 2.00000 3.00000 0.00000 0.00000 16.8000 0.000 0.000 0.000 0.000
32.661 1862.00000 20.3000 -44.53125 0.00000 1.39300 1.39300 13.50000 0.32200 0.31500 4.70000 1.00000 3.00000 3.00000 2.00000 3.00000 0.00000 0.00000 16.8000 0.000 0.000 0.000 0.000
32.671 1862.00000 20.3000 -44.53125 0.00000 1.39300 1.39300 13.50000 0.32200 0.31500 4.70000 1.00000 3.00000 3.00000 2.00000 3.00000 0.00000 0.00000 16.8000 0.000 0.000 0.000 0.000
32.681 1848.00000 20.1000 -44.53125 0.00000 1.41600 1.41600 12.70000 0.30600 0.31200 5.00000 1.00000 3.00000 2.00000 3.00000 3.00000 0.00000 0.00000 16.7000 0.000 0.000 0.000 0.000
32.691 1848.00000 20.1000 -44.53125 0.00000 1.41600 1.41600 12.70000 0.30600 0.31200 5.00000 1.00000 3.00000 2.00000 3.00000 3.00000 0.00000 0.00000 16.7000 0.000 0.000 0.000 0.000
32.701 1848.00000 20.1000 -44.53125 0.00000 1.41600 1.41600 12.70000 0.30600 0.31200 5.00000 1.00000 3.00000 2.00000 3.00000 3.00000 0.00000 0.00000 16.7000 0.000 0.000 0.000 0.000
32.711 1848.00000 20.1000 -44.53125 0.00000 1.41600 1.41600 12.70000 0.30600 0.31200 5.00000 1.00000 3.00000 2.00000 3.00000 3.00000 0.00000 0.00000 16.7000 0.000 0.000 0.000 0.000
32.721 1848.00000 20.1000 -44.53125 0.00000 1.41600 1.41600 12.70000 0.30600 0.31200 5.00000 1.00000 3.00000 2.00000 3.00000 3.00000 0.00000 0.00000 16.7000 0.000 0.000 0.000 0.000
32.731 1763.00000 20.7000 -44.53125 0.00000 1.46300 1.46300 12.60000 0.30600 0.31200 5.10000 1.00000 3.00000 3.00000 3.00000 2.00000 0.00000 0.00000 16.5000 0.000 0.000 0.000 0.000
32.741 1763.00000 20.7000 -44.53125 0.00000 1.46300 1.46300 12.60000 0.30600 0.31200 5.10000 1.00000 3.00000 3.00000 3.00000 2.00000 0.00000 0.00000 16.5000 0.000 0.000 0.000 0.000
32.751 1763.00000 20.7000 -44.53125 0.00000 1.46300 1.46300 12.60000 0.30600 0.31200 5.10000 1.00000 3.00000 3.00000 3.00000 2.00000 0.00000 0.00000 16.5000 0.000 0.000 0.000 0.000
32.761 1763.00000 20.7000 -44.53125 0.00000 1.46300 1.46300 12.60000 0.30600 0.31200 5.10000 1.00000 3.00000 3.00000 3.00000 2.00000 0.00000 0.00000 16.5000 0.000 0.000 0.000 0.000
32.771 1763.00000 20.7000 -44.53125 0.00000 1.46300 1.46300 12.60000 0.30600 0.31200 5.10000 1.00000 3.00000 3.00000 3.00000 2.00000 0.00000 0.00000 16.5000 0.000 0.000 0.000 0.000
32.781 1804.00000 20.4000 -44.53125 0.00000 1.47400 1.47400 13.30000 0.30600 0.31200 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 16.5000 0.000 0.000 0.000 0.000
32.791 1804.00000 20.4000 -44.53125 0.00000 1.47400 1.47400 13.30000 0.30600 0.31200 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 16.5000 0.000 0.000 0.000 0.000
32.801 1804.00000 20.4000 -44.53125 0.00000 1.47400 1.47400 13.30000 0.30600 0.31200 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 16.5000 0.000 0.000 0.000 0.000
32.811 1804.00000 20.4000 -44.53125 0.00000 1.47400 1.47400 13.30000 0.30600 0.31200 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 16.5000 0.000 0.000 0.000 0.000
32.821 1804.00000 20.4000 -44.53125 0.00000 1.47400 1.47400 13.30000 0.30600 0.31200 5.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 16.5000 0.000 0.000 0.000 0.000
32.831 1855.00000 20.4000 -44.53125 0.00000 1.47400 1.47400 13.10000 0.30600 0.31200 5.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 16.5000 0.000 0.000 0.000 0.000
32.841 1855.00000 20.4000 -44.53125 0.00000 1.47400 1.47400 13.10000 0.30600 0.31200 5.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 16.5000 0.000 0.000 0.000 0.000
32.850 1855.00000 20.4000 -44.53125 0.00000 1.47400 1.47400 13.10000 0.30600 0.31200 5.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 16.5000 0.000 0.000 0.000 0.000
32.860 1855.00000 20.4000 -44.53125 0.00000 1.47400 1.47400 13.10000 0.30600 0.31200 5.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 16.5000 0.000 0.000 0.000 0.000
32.870 1855.00000 20.4000 -44.53125 0.00000 1.47400 1.47400 13.10000 0.30600 0.31200 5.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 16.5000 0.000 0.000 0.000 0.000
32.880 1905.00000 20.4000 -44.53125 0.00000 1.47400 1.47400 12.50000 0.30300 0.31500 5.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 17.7000 0.000 0.000 0.000 0.000
32.890 1905.00000 20.4000 -44.53125 0.00000 1.47400 1.47400 12.50000 0.30300 0.31500 5.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 17.7000 0.000 0.000 0.000 0.000
32.900 1905.00000 20.4000 -44.53125 0.00000 1.47400 1.47400 12.50000 0.30300 0.31500 5.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 17.7000 0.000 0.000 0.000 0.000
32.910 1905.00000 20.4000 -44.53125 0.00000 1.47400 1.47400 12.50000 0.30300 0.31500 5.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 17.7000 0.000 0.000 0.000 0.000
32.920 1905.00000 20.4000 -44.53125 0.00000 1.47400 1.47400 12.50000 0.30300 0.31500 5.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 17.7000 0.000 0.000 0.000 0.000
32.930 1874.00000 21.3000 -44.53125 0.00000 1.55600 1.55600 13.20000 0.30300 0.31500 5.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.0000 0.000 0.000 0.000 0.000
32.940 1874.00000 21.3000 -44.53125 0.00000 1.55600 1.55600 13.20000 0.30300 0.31500 5.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.0000 0.000 0.000 0.000 0.000
32.950 1874.00000 21.3000 -44.53125 0.00000 1.55600 1.55600 13.20000 0.30300 0.31500 5.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.0000 0.000 0.000 0.000 0.000
32.960 1874.00000 21.3000 -44.53125 0.00000 1.55600 1.55600 13.20000 0.30300 0.31500 5.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.0000 0.000 0.000 0.000 0.000
32.970 1874.00000 21.3000 -44.53125 0.00000 1.55600 1.55600 13.20000 0.30300 0.31500 5.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.0000 0.000 0.000 0.000 0.000
32.980 1787.00000 21.0000 -44.53125 0.00000 1.55600 1.55600 13.40000 0.30300 0.31500 5.70000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 17.8000 0.000 0.000 0.000 0.000
32.990 1787.00000 21.0000 -44.53125 0.00000 1.55600 1.55600 13.40000 0.30300 0.31500 5.70000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 17.8000 0.000 0.000 0.000 0.000
33.000 1787.00000 21.0000 -44.53125 0.00000 1.55600 1.55600 13.40000 0.30300 0.31500 5.70000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 17.8000 0.000 0.000 0.000 0.000
33.010 1787.00000 21.0000 -44.53125 0.00000 1.55600 1.55600 13.40000 0.30300 0.31500 5.70000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 17.8000 0.000 0.000 0.000 0.000
33.020 1787.00000 21.0000 -44.53125 0.00000 1.55600 1.55600 13.40000 0.30300 0.31500 5.70000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 17.8000 0.000 0.000 0.000 0.000
33.030 1798.00000 20.4000 -44.53125 0.00000 1.50400 1.50400 12.80000 0.30300 0.31500 5.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 17.4000 0.000 0.000 0.000 0.000
33.040 1798.00000 20.4000 -44.53125 0.00000 1.50400 1.50400 12.80000 0.30300 0.31500 5.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 17.4000 0.000 0.000 0.000 0.000
33.050 1798.00000 20.4000 -44.53125 0.00000 1.50400 1.50400 12.80000 0.30300 0.31500 5.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 17.4000 0.000 0.000 0.000 0.000
33.060 1798.00000 20.4000 -44.53125 0.00000 1.50400 1.50400 12.80000 0.30300 0.31500 5.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 17.4000 0.000 0.000 0.000 0.000
33.070 1798.00000 20.4000 -44.53125 0.00000 1.50400 1.50400 12.80000 0.30300 0.31500 5.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 17.4000 0.000 0.000 0.000 0.000
33.080 1833.00000 21.2000 -44.53125 0.00000 1.50900 1.50900 13.00000 0.32200 0.32200 5.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 17.5000 0.000 0.000 0.000 0.000
33.090 1833.00000 21.2000 -44.53125 0.00000 1.50900 1.50900 13.00000 0.32200 0.32200 5.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 17.5000 0.000 0.000 0.000 0.000
33.100 1833.00000 21.2000 -44.53125 0.00000 1.50900 1.50900 13.00000 0.32200 0.32200 5.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 17.5000 0.000 0.000 0.000 0.000
33.110 1833.00000 21.2000 -44.53125 0.00000 1.50900 1.50900 13.00000 0.32200 0.32200 5.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 17.5000 0.000 0.000 0.000 0.000
33.120 1833.00000 21.2000 -44.53125 0.00000 1.50900 1.50900 13.00000 0.32200 0.32200 5.90000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 17.5000 0.000 0.000 0.000 0.000
33.130 1840.00000 22.7000 -44.53125 0.00000 1.64900 1.64900 13.40000 0.32200 0.32200 6.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 17.5000 0.000 0.000 0.000 0.000
33.140 1840.00000 22.7000 -44.53125 0.00000 1.64900 1.64900 13.40000 0.32200 0.32200 6.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 17.5000 0.000 0.000 0.000 0.000
33.150 1840.00000 22.7000 -44.53125 0.00000 1.64900 1.64900 13.40000 0.32200 0.32200 6.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 17.5000 0.000 0.000 0.000 0.000
33.160 1840.00000 22.7000 -44.53125 0.00000 1.64900 1.64900 13.40000 0.32200 0.32200 6.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 17.5000 0.000 0.000 0.000 0.000
33.170 1840.00000 22.7000 -44.53125 0.00000 1.64900 1.64900 13.40000 0.32200 0.32200 6.00000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 17.5000 0.000 0.000 0.000 0.000
33.180 1767.00000 22.9000 -44.53125 0.00000 1.71900 1.71900 13.30000 0.32200 0.32200 6.30000 1.00000 3.00000 3.00000 4.00000 3.00000 0.00000 0.00000 16.3000 0.000 0.000 0.000 0.000
33.190 1767.00000 22.9000 -44.53125 0.00000 1.71900 1.71900 13.30000 0.32200 0.32200 6.30000 1.00000 3.00000 3.00000 4.00000 3.00000 0.00000 0.00000 16.3000 0.000 0.000 0.000 0.000
33.200 1767.00000 22.9000 -44.53125 0.00000 1.71900 1.71900 13.30000 0.32200 0.32200 6.30000 1.00000 3.00000 3.00000 4.00000 3.00000 0.00000 0.00000 16.3000 0.000 0.000 0.000 0.000
33.210 1767.00000 22.9000 -44.53125 0.00000 1.71900 1.71900 13.30000 0.32200 0.32200 6.30000 1.00000 3.00000 3.00000 4.00000 3.00000 0.00000 0.00000 16.3000 0.000 0.000 0.000 0.000
33.220 1767.00000 22.9000 -44.53125 0.00000 1.71900 1.71900 13.30000 0.32200 0.32200 6.30000 1.00000 3.00000 3.00000 4.00000 3.00000 0.00000 0.00000 16.3000 0.000 0.000 0.000 0.000
33.230 1825.00000 23.5000 -44.53125 0.00000 1.76600 1.76600 13.10000 0.32200 0.32200 6.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 16.1000 0.000 0.000 0.000 0.000
33.240 1825.00000 23.5000 -44.53125 0.00000 1.76600 1.76600 13.10000 0.32200 0.32200 6.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 16.1000 0.000 0.000 0.000 0.000
33.250 1825.00000 23.5000 -44.53125 0.00000 1.76600 1.76600 13.10000 0.32200 0.32200 6.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 16.1000 0.000 0.000 0.000 0.000
33.260 1825.00000 23.5000 -44.53125 0.00000 1.76600 1.76600 13.10000 0.32200 0.32200 6.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 16.1000 0.000 0.000 0.000 0.000
33.270 1825.00000 23.5000 -44.53125 0.00000 1.76600 1.76600 13.10000 0.32200 0.32200 6.70000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 16.1000 0.000 0.000 0.000 0.000
33.280 1877.00000 27.5000 -44.53125 0.00000 2.10400 2.10400 13.10000 0.96300 0.31900 8.30000 1.00000 4.00000 4.00000 5.00000 4.00000 0.00000 0.00000 16.3000 0.000 0.000 0.000 0.000
33.290 1877.00000 27.5000 -44.53125 0.00000 2.10400 2.10400 13.10000 0.96300 0.31900 8.30000 1.00000 4.00000 4.00000 5.00000 4.00000 0.00000 0.00000 16.3000 0.000 0.000 0.000 0.000
33.300 1877.00000 27.5000 -44.53125 0.00000 2.10400 2.10400 13.10000 0.96300 0.31900 8.30000 1.00000 4.00000 4.00000 5.00000 4.00000 0.00000 0.00000 16.3000 0.000 0.000 0.000 0.000
33.310 1877.00000 27.5000 -44.53125 0.00000 2.10400 2.10400 13.10000 0.96300 0.31900 8.30000 1.00000 4.00000 4.00000 5.00000 4.00000 0.00000 0.00000 16.3000 0.000 0.000 0.000 0.000
33.320 1877.00000 27.5000 -44.53125 0.00000 2.10400 2.10400 13.10000 0.96300 0.31900 8.30000 1.00000 4.00000 4.00000 5.00000 4.00000 0.00000 0.00000 16.3000 0.000 0.000 0.000 0.000
33.330 1877.00000 28.8000 -44.53125 0.00000 2.29100 2.29100 12.60000 0.96300 0.31900 9.30000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
33.340 1877.00000 28.8000 -44.53125 0.00000 2.29100 2.29100 12.60000 0.96300 0.31900 9.30000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
33.350 1877.00000 28.8000 -44.53125 0.00000 2.29100 2.29100 12.60000 0.96300 0.31900 9.30000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
33.360 1877.00000 28.8000 -44.53125 0.00000 2.29100 2.29100 12.60000 0.96300 0.31900 9.30000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
33.370 1877.00000 28.8000 -44.53125 0.00000 2.29100 2.29100 12.60000 0.96300 0.31900 9.30000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
33.380 1860.00000 29.1000 -44.53125 0.00000 2.24400 2.24400 12.90000 0.96300 0.31900 10.10000 1.00000 5.00000 6.00000 2.00000 6.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
33.390 1860.00000 29.1000 -44.53125 0.00000 2.24400 2.24400 12.90000 0.96300 0.31900 10.10000 1.00000 5.00000 6.00000 2.00000 6.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
33.400 1860.00000 29.1000 -44.53125 0.00000 2.24400 2.24400 12.90000 0.96300 0.31900 10.10000 1.00000 5.00000 6.00000 2.00000 6.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
33.410 1860.00000 29.1000 -44.53125 0.00000 2.24400 2.24400 12.90000 0.96300 0.31900 10.10000 1.00000 5.00000 6.00000 2.00000 6.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
33.420 1860.00000 29.1000 -44.53125 0.00000 2.24400 2.24400 12.90000 0.96300 0.31900 10.10000 1.00000 5.00000 6.00000 2.00000 6.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
33.430 1784.00000 29.6000 -44.53125 0.00000 2.20300 2.20300 13.20000 0.96300 0.31900 10.80000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
33.440 1784.00000 29.6000 -44.53125 0.00000 2.20300 2.20300 13.20000 0.96300 0.31900 10.80000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
33.450 1784.00000 29.6000 -44.53125 0.00000 2.20300 2.20300 13.20000 0.96300 0.31900 10.80000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
33.460 1784.00000 29.6000 -44.53125 0.00000 2.20300 2.20300 13.20000 0.96300 0.31900 10.80000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
33.470 1784.00000 29.6000 -44.53125 0.00000 2.20300 2.20300 13.20000 0.96300 0.31900 10.80000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
33.480 1876.00000 30.1000 -44.53125 0.00000 2.21500 2.21500 13.50000 0.96000 0.34100 11.60000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
33.490 1876.00000 30.1000 -44.53125 0.00000 2.21500 2.21500 13.50000 0.96000 0.34100 11.60000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
33.500 1876.00000 30.1000 -44.53125 0.00000 2.21500 2.21500 13.50000 0.96000 0.34100 11.60000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
33.510 1876.00000 30.1000 -44.53125 0.00000 2.21500 2.21500 13.50000 0.96000 0.34100 11.60000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
33.520 1876.00000 30.1000 -44.53125 0.00000 2.21500 2.21500 13.50000 0.96000 0.34100 11.60000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
33.530 1930.00000 31.0000 -44.53125 0.00000 2.28500 2.28500 13.30000 0.96000 0.34100 11.30000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
33.540 1930.00000 31.0000 -44.53125 0.00000 2.28500 2.28500 13.30000 0.96000 0.34100 11.30000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
33.550 1930.00000 31.0000 -44.53125 0.00000 2.28500 2.28500 13.30000 0.96000 0.34100 11.30000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
33.560 1930.00000 31.0000 -44.53125 0.00000 2.28500 2.28500 13.30000 0.96000 0.34100 11.30000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
33.570 1930.00000 31.0000 -44.53125 0.00000 2.28500 2.28500 13.30000 0.96000 0.34100 11.30000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
33.580 1889.00000 31.0000 -44.53125 0.00000 2.22100 2.22100 13.00000 0.96000 0.34100 12.50000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
33.590 1889.00000 31.0000 -44.53125 0.00000 2.22100 2.22100 13.00000 0.96000 0.34100 12.50000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
33.600 1889.00000 31.0000 -44.53125 0.00000 2.22100 2.22100 13.00000 0.96000 0.34100 12.50000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
33.610 1889.00000 31.0000 -44.53125 0.00000 2.22100 2.22100 13.00000 0.96000 0.34100 12.50000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
33.620 1889.00000 31.0000 -44.53125 0.00000 2.22100 2.22100 13.00000 0.96000 0.34100 12.50000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
33.630 1854.00000 32.7000 -44.53125 0.00000 2.31400 2.31400 13.00000 0.96000 0.34100 12.70000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
33.640 1854.00000 32.7000 -44.53125 0.00000 2.31400 2.31400 13.00000 0.96000 0.34100 12.70000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
33.650 1854.00000 32.7000 -44.53125 0.00000 2.31400 2.31400 13.00000 0.96000 0.34100 12.70000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
33.660 1854.00000 32.7000 -44.53125 0.00000 2.31400 2.31400 13.00000 0.96000 0.34100 12.70000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
33.670 1854.00000 32.7000 -44.53125 0.00000 2.31400 2.31400 13.00000 0.96000 0.34100 12.70000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
33.680 1884.00000 34.5000 -44.53125 0.00000 2.35500 2.35500 13.60000 0.44000 0.36300 12.20000 1.00000 7.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
33.690 1884.00000 34.5000 -44.53125 0.00000 2.35500 2.35500 13.60000 0.44000 0.36300 12.20000 1.00000 7.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
33.700 1884.00000 34.5000 -44.53125 0.00000 2.35500 2.35500 13.60000 0.44000 0.36300 12.20000 1.00000 7.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
33.710 1884.00000 34.5000 -44.53125 0.00000 2.35500 2.35500 13.60000 0.44000 0.36300 12.20000 1.00000 7.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
33.720 1884.00000 34.5000 -44.53125 0.00000 2.35500 2.35500 13.60000 0.44000 0.36300 12.20000 1.00000 7.00000 6.00000 6.00000 6.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
33.730 1963.00000 37.4000 -44.53125 0.00000 2.48300 2.48300 12.90000 0.44000 0.36300 13.70000 1.00000 2.00000 2.00000 7.00000 7.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
33.740 1963.00000 37.4000 -44.53125 0.00000 2.48300 2.48300 12.90000 0.44000 0.36300 13.70000 1.00000 2.00000 2.00000 7.00000 7.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
33.750 1963.00000 37.4000 -44.53125 0.00000 2.48300 2.48300 12.90000 0.44000 0.36300 13.70000 1.00000 2.00000 2.00000 7.00000 7.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
33.760 1963.00000 37.4000 -44.53125 0.00000 2.48300 2.48300 12.90000 0.44000 0.36300 13.70000 1.00000 2.00000 2.00000 7.00000 7.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
33.770 1963.00000 37.4000 -44.53125 0.00000 2.48300 2.48300 12.90000 0.44000 0.36300 13.70000 1.00000 2.00000 2.00000 7.00000 7.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
33.780 1911.00000 38.5000 -44.53125 0.00000 2.47100 2.47100 13.70000 0.44000 0.36300 13.40000 1.00000 8.00000 2.00000 7.00000 7.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
33.790 1911.00000 38.5000 -44.53125 0.00000 2.47100 2.47100 13.70000 0.44000 0.36300 13.40000 1.00000 8.00000 2.00000 7.00000 7.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
33.800 1911.00000 38.5000 -44.53125 0.00000 2.47100 2.47100 13.70000 0.44000 0.36300 13.40000 1.00000 8.00000 2.00000 7.00000 7.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
33.810 1911.00000 38.5000 -44.53125 0.00000 2.47100 2.47100 13.70000 0.44000 0.36300 13.40000 1.00000 8.00000 2.00000 7.00000 7.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
33.820 1911.00000 38.5000 -44.53125 0.00000 2.47100 2.47100 13.70000 0.44000 0.36300 13.40000 1.00000 8.00000 2.00000 7.00000 7.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
33.830 1947.00000 39.5000 -44.53125 0.00000 2.39600 2.39600 13.50000 0.44000 0.36300 14.50000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
33.840 1947.00000 39.5000 -44.53125 0.00000 2.39600 2.39600 13.50000 0.44000 0.36300 14.50000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
33.850 1947.00000 39.5000 -44.53125 0.00000 2.39600 2.39600 13.50000 0.44000 0.36300 14.50000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
33.860 1947.00000 39.5000 -44.53125 0.00000 2.39600 2.39600 13.50000 0.44000 0.36300 14.50000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
33.870 1947.00000 39.5000 -44.53125 0.00000 2.39600 2.39600 13.50000 0.44000 0.36300 14.50000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
33.880 1956.00000 39.8000 -44.53125 0.00000 2.50600 2.50600 12.10000 0.52300 0.33500 13.80000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
33.890 1956.00000 39.8000 -44.53125 0.00000 2.50600 2.50600 12.10000 0.52300 0.33500 13.80000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
33.900 1956.00000 39.8000 -44.53125 0.00000 2.50600 2.50600 12.10000 0.52300 0.33500 13.80000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
33.910 1956.00000 39.8000 -44.53125 0.00000 2.50600 2.50600 12.10000 0.52300 0.33500 13.80000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
33.920 1956.00000 39.8000 -44.53125 0.00000 2.50600 2.50600 12.10000 0.52300 0.33500 13.80000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
33.930 1972.00000 40.3000 -44.53125 0.00000 2.39000 2.39000 13.30000 0.52300 0.33500 14.70000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
33.940 1972.00000 40.3000 -44.53125 0.00000 2.39000 2.39000 13.30000 0.52300 0.33500 14.70000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
33.950 1972.00000 40.3000 -44.53125 0.00000 2.39000 2.39000 13.30000 0.52300 0.33500 14.70000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
33.960 1972.00000 40.3000 -44.53125 0.00000 2.39000 2.39000 13.30000 0.52300 0.33500 14.70000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
33.970 1972.00000 40.3000 -44.53125 0.00000 2.39000 2.39000 13.30000 0.52300 0.33500 14.70000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 15.5000 0.000 0.000 0.000 0.000
33.980 1975.00000 40.9000 -44.53125 0.00000 2.48900 2.48900 12.40000 0.52300 0.33500 14.00000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
33.990 1975.00000 40.9000 -44.53125 0.00000 2.48900 2.48900 12.40000 0.52300 0.33500 14.00000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
34.000 1975.00000 40.9000 -44.53125 0.00000 2.48900 2.48900 12.40000 0.52300 0.33500 14.00000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
34.010 1975.00000 40.9000 -44.53125 0.00000 2.48900 2.48900 12.40000 0.52300 0.33500 14.00000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
34.020 1975.00000 40.9000 -44.53125 0.00000 2.48900 2.48900 12.40000 0.52300 0.33500 14.00000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
34.030 1946.00000 42.3000 -44.53125 0.00000 2.47700 2.47700 13.50000 0.52300 0.33500 14.70000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
34.040 1946.00000 42.3000 -44.53125 0.00000 2.47700 2.47700 13.50000 0.52300 0.33500 14.70000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
34.050 1946.00000 42.3000 -44.53125 0.00000 2.47700 2.47700 13.50000 0.52300 0.33500 14.70000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
34.060 1946.00000 42.3000 -44.53125 0.00000 2.47700 2.47700 13.50000 0.52300 0.33500 14.70000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
34.070 1946.00000 42.3000 -44.53125 0.00000 2.47700 2.47700 13.50000 0.52300 0.33500 14.70000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 15.1000 0.000 0.000 0.000 0.000
34.080 1987.00000 43.5000 -44.53125 0.00000 2.56500 2.56500 12.30000 0.99900 0.35400 14.20000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
34.090 1987.00000 43.5000 -44.53125 0.00000 2.56500 2.56500 12.30000 0.99900 0.35400 14.20000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
34.100 1987.00000 43.5000 -44.53125 0.00000 2.56500 2.56500 12.30000 0.99900 0.35400 14.20000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
34.110 1987.00000 43.5000 -44.53125 0.00000 2.56500 2.56500 12.30000 0.99900 0.35400 14.20000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
34.120 1987.00000 43.5000 -44.53125 0.00000 2.56500 2.56500 12.30000 0.99900 0.35400 14.20000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 15.0000 0.000 0.000 0.000 0.000
34.130 1994.00000 44.0000 -44.53125 0.00000 2.48900 2.48900 13.40000 0.99900 0.35400 15.00000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
34.140 1994.00000 44.0000 -44.53125 0.00000 2.48900 2.48900 13.40000 0.99900 0.35400 15.00000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
34.150 1994.00000 44.0000 -44.53125 0.00000 2.48900 2.48900 13.40000 0.99900 0.35400 15.00000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
34.160 1994.00000 44.0000 -44.53125 0.00000 2.48900 2.48900 13.40000 0.99900 0.35400 15.00000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
34.170 1994.00000 44.0000 -44.53125 0.00000 2.48900 2.48900 13.40000 0.99900 0.35400 15.00000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
34.180 2031.00000 44.1000 -44.53125 0.00000 2.50000 2.50000 13.20000 0.99900 0.35400 13.90000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
34.190 2031.00000 44.1000 -44.53125 0.00000 2.50000 2.50000 13.20000 0.99900 0.35400 13.90000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
34.200 2031.00000 44.1000 -44.53125 0.00000 2.50000 2.50000 13.20000 0.99900 0.35400 13.90000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
34.210 2031.00000 44.1000 -44.53125 0.00000 2.50000 2.50000 13.20000 0.99900 0.35400 13.90000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
34.220 2031.00000 44.1000 -44.53125 0.00000 2.50000 2.50000 13.20000 0.99900 0.35400 13.90000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 14.8000 0.000 0.000 0.000 0.000
34.230 2007.00000 44.3000 -44.53125 0.00000 2.57000 2.57000 13.40000 0.99900 0.35400 14.70000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
34.240 2007.00000 44.3000 -44.53125 0.00000 2.57000 2.57000 13.40000 0.99900 0.35400 14.70000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
34.250 2007.00000 44.3000 -44.53125 0.00000 2.57000 2.57000 13.40000 0.99900 0.35400 14.70000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
34.260 2007.00000 44.3000 -44.53125 0.00000 2.57000 2.57000 13.40000 0.99900 0.35400 14.70000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
34.270 2007.00000 44.3000 -44.53125 0.00000 2.57000 2.57000 13.40000 0.99900 0.35400 14.70000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 14.9000 0.000 0.000 0.000 0.000
34.280 2023.00000 45.2000 -44.53125 0.00000 2.43600 2.43600 13.20000 1.05900 0.40800 14.30000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 14.4000 0.000 0.000 0.000 0.000
34.290 2023.00000 45.2000 -44.53125 0.00000 2.43600 2.43600 13.20000 1.05900 0.40800 14.30000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 14.4000 0.000 0.000 0.000 0.000
34.300 2023.00000 45.2000 -44.53125 0.00000 2.43600 2.43600 13.20000 1.05900 0.40800 14.30000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 14.4000 0.000 0.000 0.000 0.000
34.310 2023.00000 45.2000 -44.53125 0.00000 2.43600 2.43600 13.20000 1.05900 0.40800 14.30000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 14.4000 0.000 0.000 0.000 0.000
34.320 2023.00000 45.2000 -44.53125 0.00000 2.43600 2.43600 13.20000 1.05900 0.40800 14.30000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 14.4000 0.000 0.000 0.000 0.000
34.330 2105.00000 46.9000 -44.53125 0.00000 2.64600 2.64600 12.20000 1.05900 0.40800 14.40000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 14.5000 0.000 0.000 0.000 0.000
34.340 2105.00000 46.9000 -44.53125 0.00000 2.64600 2.64600 12.20000 1.05900 0.40800 14.40000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 14.5000 0.000 0.000 0.000 0.000
34.350 2105.00000 46.9000 -44.53125 0.00000 2.64600 2.64600 12.20000 1.05900 0.40800 14.40000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 14.5000 0.000 0.000 0.000 0.000
34.360 2105.00000 46.9000 -44.53125 0.00000 2.64600 2.64600 12.20000 1.05900 0.40800 14.40000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 14.5000 0.000 0.000 0.000 0.000
34.370 2105.00000 46.9000 -44.53125 0.00000 2.64600 2.64600 12.20000 1.05900 0.40800 14.40000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 14.5000 0.000 0.000 0.000 0.000
34.380 2054.00000 48.1000 -44.53125 0.00000 2.55900 2.55900 13.20000 1.05900 0.40800 15.20000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 14.4000 0.000 0.000 0.000 0.000
34.390 2054.00000 48.1000 -44.53125 0.00000 2.55900 2.55900 13.20000 1.05900 0.40800 15.20000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 14.4000 0.000 0.000 0.000 0.000
34.400 2054.00000 48.1000 -44.53125 0.00000 2.55900 2.55900 13.20000 1.05900 0.40800 15.20000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 14.4000 0.000 0.000 0.000 0.000
34.410 2054.00000 48.1000 -44.53125 0.00000 2.55900 2.55900 13.20000 1.05900 0.40800 15.20000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 14.4000 0.000 0.000 0.000 0.000
34.420 2054.00000 48.1000 -44.53125 0.00000 2.55900 2.55900 13.20000 1.05900 0.40800 15.20000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 14.4000 0.000 0.000 0.000 0.000
34.430 2060.00000 48.2000 -44.53125 0.00000 2.46600 2.46600 12.90000 1.05900 0.40800 14.60000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 14.0000 0.000 0.000 0.000 0.000
34.440 2060.00000 48.2000 -44.53125 0.00000 2.46600 2.46600 12.90000 1.05900 0.40800 14.60000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 14.0000 0.000 0.000 0.000 0.000
34.450 2060.00000 48.2000 -44.53125 0.00000 2.46600 2.46600 12.90000 1.05900 0.40800 14.60000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 14.0000 0.000 0.000 0.000 0.000
34.460 2060.00000 48.2000 -44.53125 0.00000 2.46600 2.46600 12.90000 1.05900 0.40800 14.60000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 14.0000 0.000 0.000 0.000 0.000
34.470 2060.00000 48.2000 -44.53125 0.00000 2.46600 2.46600 12.90000 1.05900 0.40800 14.60000 1.00000 8.00000 8.00000 8.00000 8.00000 0.00000 0.00000 14.0000 0.000 0.000 0.000 0.000
34.480 2136.00000 48.4000 -44.53125 0.00000 2.67500 2.67500 13.40000 1.05600 0.93800 14.50000 1.00000 8.00000 9.00000 8.00000 9.00000 0.00000 0.00000 14.1000 0.000 0.000 0.000 0.000
34.490 2136.00000 48.4000 -44.53125 0.00000 2.67500 2.67500 13.40000 1.05600 0.93800 14.50000 1.00000 8.00000 9.00000 8.00000 9.00000 0.00000 0.00000 14.1000 0.000 0.000 0.000 0.000
34.500 2136.00000 48.4000 -44.53125 0.00000 2.67500 2.67500 13.40000 1.05600 0.93800 14.50000 1.00000 8.00000 9.00000 8.00000 9.00000 0.00000 0.00000 14.1000 0.000 0.000 0.000 0.000
34.510 2136.00000 48.4000 -44.53125 0.00000 2.67500 2.67500 13.40000 1.05600 0.93800 14.50000 1.00000 8.00000 9.00000 8.00000 9.00000 0.00000 0.00000 14.1000 0.000 0.000 0.000 0.000
34.520 2136.00000 48.4000 -44.53125 0.00000 2.67500 2.67500 13.40000 1.05600 0.93800 14.50000 1.00000 8.00000 9.00000 8.00000 9.00000 0.00000 0.00000 14.1000 0.000 0.000 0.000 0.000
34.530 2124.00000 49.9000 -44.53125 0.00000 2.65800 2.65800 12.90000 1.05600 0.93800 14.90000 1.00000 9.00000 8.00000 9.00000 8.00000 0.00000 0.00000 14.0000 0.000 0.000 0.000 0.000
34.540 2124.00000 49.9000 -44.53125 0.00000 2.65800 2.65800 12.90000 1.05600 0.93800 14.90000 1.00000 9.00000 8.00000 9.00000 8.00000 0.00000 0.00000 14.0000 0.000 0.000 0.000 0.000
34.550 2124.00000 49.9000 -44.53125 0.00000 2.65800 2.65800 12.90000 1.05600 0.93800 14.90000 1.00000 9.00000 8.00000 9.00000 8.00000 0.00000 0.00000 14.0000 0.000 0.000 0.000 0.000
34.560 2124.00000 49.9000 -44.53125 0.00000 2.65800 2.65800 12.90000 1.05600 0.93800 14.90000 1.00000 9.00000 8.00000 9.00000 8.00000 0.00000 0.00000 14.0000 0.000 0.000 0.000 0.000
34.570 2124.00000 49.9000 -44.53125 0.00000 2.65800 2.65800 12.90000 1.05600 0.93800 14.90000 1.00000 9.00000 8.00000 9.00000 8.00000 0.00000 0.00000 14.0000 0.000 0.000 0.000 0.000
34.580 2119.00000 49.9000 -44.53125 0.00000 2.68100 2.68100 13.10000 1.05600 0.93800 15.20000 1.00000 8.00000 8.00000 9.00000 9.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
34.590 2119.00000 49.9000 -44.53125 0.00000 2.68100 2.68100 13.10000 1.05600 0.93800 15.20000 1.00000 8.00000 8.00000 9.00000 9.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
34.600 2119.00000 49.9000 -44.53125 0.00000 2.68100 2.68100 13.10000 1.05600 0.93800 15.20000 1.00000 8.00000 8.00000 9.00000 9.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
34.610 2119.00000 49.9000 -44.53125 0.00000 2.68100 2.68100 13.10000 1.05600 0.93800 15.20000 1.00000 8.00000 8.00000 9.00000 9.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
34.620 2119.00000 49.9000 -44.53125 0.00000 2.68100 2.68100 13.10000 1.05600 0.93800 15.20000 1.00000 8.00000 8.00000 9.00000 9.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
34.630 2111.00000 50.1000 -44.53125 0.00000 2.47100 2.47100 13.30000 1.05600 0.93800 15.10000 1.00000 9.00000 9.00000 8.00000 9.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
34.640 2111.00000 50.1000 -44.53125 0.00000 2.47100 2.47100 13.30000 1.05600 0.93800 15.10000 1.00000 9.00000 9.00000 8.00000 9.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
34.650 2111.00000 50.1000 -44.53125 0.00000 2.47100 2.47100 13.30000 1.05600 0.93800 15.10000 1.00000 9.00000 9.00000 8.00000 9.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
34.660 2111.00000 50.1000 -44.53125 0.00000 2.47100 2.47100 13.30000 1.05600 0.93800 15.10000 1.00000 9.00000 9.00000 8.00000 9.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
34.670 2111.00000 50.1000 -44.53125 0.00000 2.47100 2.47100 13.30000 1.05600 0.93800 15.10000 1.00000 9.00000 9.00000 8.00000 9.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
34.680 2177.00000 51.0000 -44.53125 0.00000 2.64600 2.64600 13.20000 1.05300 0.98900 14.30000 1.00000 9.00000 9.00000 9.00000 9.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
34.690 2177.00000 51.0000 -44.53125 0.00000 2.64600 2.64600 13.20000 1.05300 0.98900 14.30000 1.00000 9.00000 9.00000 9.00000 9.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
34.700 2177.00000 51.0000 -44.53125 0.00000 2.64600 2.64600 13.20000 1.05300 0.98900 14.30000 1.00000 9.00000 9.00000 9.00000 9.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
34.710 2177.00000 51.0000 -44.53125 0.00000 2.64600 2.64600 13.20000 1.05300 0.98900 14.30000 1.00000 9.00000 9.00000 9.00000 9.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
34.720 2177.00000 51.0000 -44.53125 0.00000 2.64600 2.64600 13.20000 1.05300 0.98900 14.30000 1.00000 9.00000 9.00000 9.00000 9.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
34.730 2164.00000 52.7000 -44.53125 0.00000 2.71600 2.71600 13.30000 1.05300 0.98900 14.70000 1.00000 9.00000 9.00000 9.00000 9.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
34.740 2164.00000 52.7000 -44.53125 0.00000 2.71600 2.71600 13.30000 1.05300 0.98900 14.70000 1.00000 9.00000 9.00000 9.00000 9.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
34.750 2164.00000 52.7000 -44.53125 0.00000 2.71600 2.71600 13.30000 1.05300 0.98900 14.70000 1.00000 9.00000 9.00000 9.00000 9.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
34.760 2164.00000 52.7000 -44.53125 0.00000 2.71600 2.71600 13.30000 1.05300 0.98900 14.70000 1.00000 9.00000 9.00000 9.00000 9.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
34.770 2164.00000 52.7000 -44.53125 0.00000 2.71600 2.71600 13.30000 1.05300 0.98900 14.70000 1.00000 9.00000 9.00000 9.00000 9.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
34.780 2170.00000 53.4000 -43.75000 0.00000 2.84400 2.84400 12.50000 1.05300 0.98900 15.40000 1.00000 9.00000 9.00000 9.00000 9.00000 0.00000 0.00000 14.1000 0.000 0.000 0.000 0.000
34.790 2170.00000 53.4000 -43.75000 0.00000 2.84400 2.84400 12.50000 1.05300 0.98900 15.40000 1.00000 9.00000 9.00000 9.00000 9.00000 0.00000 0.00000 14.1000 0.000 0.000 0.000 0.000
34.800 2170.00000 53.4000 -43.75000 0.00000 2.84400 2.84400 12.50000 1.05300 0.98900 15.40000 1.00000 9.00000 9.00000 9.00000 9.00000 0.00000 0.00000 14.1000 0.000 0.000 0.000 0.000
34.810 2170.00000 53.4000 -43.75000 0.00000 2.84400 2.84400 12.50000 1.05300 0.98900 15.40000 1.00000 9.00000 9.00000 9.00000 9.00000 0.00000 0.00000 14.1000 0.000 0.000 0.000 0.000
34.820 2170.00000 53.4000 -43.75000 0.00000 2.84400 2.84400 12.50000 1.05300 0.98900 15.40000 1.00000 9.00000 9.00000 9.00000 9.00000 0.00000 0.00000 14.1000 0.000 0.000 0.000 0.000
34.830 2170.00000 53.4000 -43.75000 0.00000 2.84400 2.84400 12.50000 1.05300 0.98900 15.40000 1.00000 9.00000 9.00000 9.00000 9.00000 0.00000 0.00000 14.1000 0.000 0.000 0.000 0.000
34.840 2219.00000 53.6000 -41.40625 -0.12500 2.65800 2.65800 13.40000 1.05300 0.98900 16.00000 1.00000 10.00000 10.00000 9.00000 9.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
34.850 2219.00000 53.6000 -41.40625 -0.12500 2.65800 2.65800 13.40000 1.05300 0.98900 16.00000 1.00000 10.00000 10.00000 9.00000 9.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
34.860 2219.00000 53.6000 -41.40625 -0.12500 2.65800 2.65800 13.40000 1.05300 0.98900 16.00000 1.00000 10.00000 10.00000 9.00000 9.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
34.870 2219.00000 53.6000 -41.40625 -0.12500 2.65800 2.65800 13.40000 1.05300 0.98900 16.00000 1.00000 10.00000 10.00000 9.00000 9.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
34.880 2219.00000 53.6000 -41.40625 -0.12500 2.65800 2.65800 13.40000 1.05300 0.98900 16.00000 1.00000 10.00000 10.00000 9.00000 9.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
34.890 2222.00000 56.0000 -40.62500 -0.12500 2.68100 2.68100 13.30000 1.04000 1.00500 16.20000 1.00000 10.00000 10.00000 10.00000 10.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
34.900 2222.00000 56.0000 -40.62500 -0.12500 2.68100 2.68100 13.30000 1.04000 1.00500 16.20000 1.00000 10.00000 10.00000 10.00000 10.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
34.910 2222.00000 56.0000 -40.62500 -0.12500 2.68100 2.68100 13.30000 1.04000 1.00500 16.20000 1.00000 10.00000 10.00000 10.00000 10.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
34.920 2222.00000 56.0000 -40.62500 -0.12500 2.68100 2.68100 13.30000 1.04000 1.00500 16.20000 1.00000 10.00000 10.00000 10.00000 10.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
34.930 2222.00000 56.0000 -40.62500 -0.12500 2.68100 2.68100 13.30000 1.04000 1.00500 16.20000 1.00000 10.00000 10.00000 10.00000 10.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
34.940 2229.00000 57.4000 -39.06250 -0.12500 2.65800 2.65800 13.20000 1.04000 1.00500 16.60000 1.00000 11.00000 10.00000 10.00000 10.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
34.950 2229.00000 57.4000 -39.06250 -0.12500 2.65800 2.65800 13.20000 1.04000 1.00500 16.60000 1.00000 11.00000 10.00000 10.00000 10.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
34.960 2229.00000 57.4000 -39.06250 -0.12500 2.65800 2.65800 13.20000 1.04000 1.00500 16.60000 1.00000 11.00000 10.00000 10.00000 10.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
34.970 2229.00000 57.4000 -39.06250 -0.12500 2.65800 2.65800 13.20000 1.04000 1.00500 16.60000 1.00000 11.00000 10.00000 10.00000 10.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
34.980 2229.00000 57.4000 -39.06250 -0.12500 2.65800 2.65800 13.20000 1.04000 1.00500 16.60000 1.00000 11.00000 10.00000 10.00000 10.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
34.990 2264.00000 58.2000 -39.84375 -0.12500 2.67500 2.67500 13.30000 1.04000 1.00500 16.40000 1.00000 11.00000 11.00000 11.00000 11.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
35.000 2264.00000 58.2000 -39.84375 -0.12500 2.67500 2.67500 13.30000 1.04000 1.00500 16.40000 1.00000 11.00000 11.00000 11.00000 11.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
35.010 2264.00000 58.2000 -39.84375 -0.12500 2.67500 2.67500 13.30000 1.04000 1.00500 16.40000 1.00000 11.00000 11.00000 11.00000 11.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
35.020 2264.00000 58.2000 -39.84375 -0.12500 2.67500 2.67500 13.30000 1.04000 1.00500 16.40000 1.00000 11.00000 11.00000 11.00000 11.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
35.030 2264.00000 58.2000 -39.84375 -0.12500 2.67500 2.67500 13.30000 1.04000 1.00500 16.40000 1.00000 11.00000 11.00000 11.00000 11.00000 0.00000 0.00000 14.3000 0.000 0.000 0.000 0.000
35.040 2228.00000 58.9000 -39.84375 -0.12500 2.64000 2.64000 13.30000 1.04000 1.00500 16.40000 1.00000 11.00000 11.00000 11.00000 11.00000 0.00000 0.00000 13.6000 0.000 0.000 0.000 0.000
35.050 2228.00000 58.9000 -39.84375 -0.12500 2.64000 2.64000 13.30000 1.04000 1.00500 16.40000 1.00000 11.00000 11.00000 11.00000 11.00000 0.00000 0.00000 13.6000 0.000 0.000 0.000 0.000
35.060 2228.00000 58.9000 -39.84375 -0.12500 2.64000 2.64000 13.30000 1.04000 1.00500 16.40000 1.00000 11.00000 11.00000 11.00000 11.00000 0.00000 0.00000 13.6000 0.000 0.000 0.000 0.000
35.070 2228.00000 58.9000 -39.84375 -0.12500 2.64000 2.64000 13.30000 1.04000 1.00500 16.40000 1.00000 11.00000 11.00000 11.00000 11.00000 0.00000 0.00000 13.6000 0.000 0.000 0.000 0.000
35.080 2228.00000 58.9000 -39.84375 -0.12500 2.64000 2.64000 13.30000 1.04000 1.00500 16.40000 1.00000 11.00000 11.00000 11.00000 11.00000 0.00000 0.00000 13.6000 0.000 0.000 0.000 0.000
35.090 2266.00000 60.3000 -39.06250 -0.12500 2.79200 2.79200 13.30000 1.10400 1.01800 16.60000 1.00000 11.00000 11.00000 11.00000 11.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
35.100 2266.00000 60.3000 -39.06250 -0.12500 2.79200 2.79200 13.30000 1.10400 1.01800 16.60000 1.00000 11.00000 11.00000 11.00000 11.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
35.110 2266.00000 60.3000 -39.06250 -0.12500 2.79200 2.79200 13.30000 1.10400 1.01800 16.60000 1.00000 11.00000 11.00000 11.00000 11.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
35.120 2266.00000 60.3000 -39.06250 -0.12500 2.79200 2.79200 13.30000 1.10400 1.01800 16.60000 1.00000 11.00000 11.00000 11.00000 11.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
35.130 2266.00000 60.3000 -39.06250 -0.12500 2.79200 2.79200 13.30000 1.10400 1.01800 16.60000 1.00000 11.00000 11.00000 11.00000 11.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
35.140 2326.00000 60.0000 -39.06250 -0.12500 2.82100 2.82100 13.50000 1.10400 1.01800 16.50000 1.00000 11.00000 12.00000 11.00000 11.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
35.150 2326.00000 60.0000 -39.06250 -0.12500 2.82100 2.82100 13.50000 1.10400 1.01800 16.50000 1.00000 11.00000 12.00000 11.00000 11.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
35.160 2326.00000 60.0000 -39.06250 -0.12500 2.82100 2.82100 13.50000 1.10400 1.01800 16.50000 1.00000 11.00000 12.00000 11.00000 11.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
35.170 2326.00000 60.0000 -39.06250 -0.12500 2.82100 2.82100 13.50000 1.10400 1.01800 16.50000 1.00000 11.00000 12.00000 11.00000 11.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
35.180 2326.00000 60.0000 -39.06250 -0.12500 2.82100 2.82100 13.50000 1.10400 1.01800 16.50000 1.00000 11.00000 12.00000 11.00000 11.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
35.190 2283.00000 59.9000 -39.84375 -0.12500 2.88500 2.88500 13.00000 1.10400 1.01800 16.30000 1.00000 10.00000 11.00000 11.00000 11.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
35.200 2283.00000 59.9000 -39.84375 -0.12500 2.88500 2.88500 13.00000 1.10400 1.01800 16.30000 1.00000 10.00000 11.00000 11.00000 11.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
35.210 2283.00000 59.9000 -39.84375 -0.12500 2.88500 2.88500 13.00000 1.10400 1.01800 16.30000 1.00000 10.00000 11.00000 11.00000 11.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
35.220 2283.00000 59.9000 -39.84375 -0.12500 2.88500 2.88500 13.00000 1.10400 1.01800 16.30000 1.00000 10.00000 11.00000 11.00000 11.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
35.230 2283.00000 59.9000 -39.84375 -0.12500 2.88500 2.88500 13.00000 1.10400 1.01800 16.30000 1.00000 10.00000 11.00000 11.00000 11.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
35.240 2325.00000 60.3000 -43.75000 0.00000 3.04300 3.04300 12.80000 1.10400 1.01800 15.40000 1.00000 11.00000 11.00000 11.00000 11.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
35.250 2325.00000 60.3000 -43.75000 0.00000 3.04300 3.04300 12.80000 1.10400 1.01800 15.40000 1.00000 11.00000 11.00000 11.00000 11.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
35.260 2325.00000 60.3000 -43.75000 0.00000 3.04300 3.04300 12.80000 1.10400 1.01800 15.40000 1.00000 11.00000 11.00000 11.00000 11.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
35.270 2325.00000 60.3000 -43.75000 0.00000 3.04300 3.04300 12.80000 1.10400 1.01800 15.40000 1.00000 11.00000 11.00000 11.00000 11.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
35.280 2325.00000 60.3000 -43.75000 0.00000 3.04300 3.04300 12.80000 1.10400 1.01800 15.40000 1.00000 11.00000 11.00000 11.00000 11.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
35.290 2392.00000 60.5000 -42.96875 0.00000 3.08300 3.08300 13.70000 1.11000 1.07200 15.40000 1.00000 11.00000 11.00000 11.00000 12.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
35.300 2392.00000 60.5000 -42.96875 0.00000 3.08300 3.08300 13.70000 1.11000 1.07200 15.40000 1.00000 11.00000 11.00000 11.00000 12.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
35.310 2392.00000 60.5000 -42.96875 0.00000 3.08300 3.08300 13.70000 1.11000 1.07200 15.40000 1.00000 11.00000 11.00000 11.00000 12.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
35.320 2392.00000 60.5000 -42.96875 0.00000 3.08300 3.08300 13.70000 1.11000 1.07200 15.40000 1.00000 11.00000 11.00000 11.00000 12.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
35.330 2392.00000 60.5000 -42.96875 0.00000 3.08300 3.08300 13.70000 1.11000 1.07200 15.40000 1.00000 11.00000 11.00000 11.00000 12.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
35.340 2343.00000 60.0000 -42.96875 -0.12500 3.01400 3.01400 13.30000 1.11000 1.07200 15.60000 1.00000 11.00000 11.00000 11.00000 11.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
35.350 2343.00000 60.0000 -42.96875 -0.12500 3.01400 3.01400 13.30000 1.11000 1.07200 15.60000 1.00000 11.00000 11.00000 11.00000 11.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
35.360 2343.00000 60.0000 -42.96875 -0.12500 3.01400 3.01400 13.30000 1.11000 1.07200 15.60000 1.00000 11.00000 11.00000 11.00000 11.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
35.370 2343.00000 60.0000 -42.96875 -0.12500 3.01400 3.01400 13.30000 1.11000 1.07200 15.60000 1.00000 11.00000 11.00000 11.00000 11.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
35.380 2343.00000 60.0000 -42.96875 -0.12500 3.01400 3.01400 13.30000 1.11000 1.07200 15.60000 1.00000 11.00000 11.00000 11.00000 11.00000 0.00000 0.00000 12.1000 0.000 0.000 0.000 0.000
35.390 2366.00000 60.6000 -42.18750 -0.12500 2.95500 2.95500 13.20000 1.11000 1.07200 15.80000 1.00000 11.00000 11.00000 11.00000 11.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
35.400 2366.00000 60.6000 -42.18750 -0.12500 2.95500 2.95500 13.20000 1.11000 1.07200 15.80000 1.00000 11.00000 11.00000 11.00000 11.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
35.410 2366.00000 60.6000 -42.18750 -0.12500 2.95500 2.95500 13.20000 1.11000 1.07200 15.80000 1.00000 11.00000 11.00000 11.00000 11.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
35.420 2366.00000 60.6000 -42.18750 -0.12500 2.95500 2.95500 13.20000 1.11000 1.07200 15.80000 1.00000 11.00000 11.00000 11.00000 11.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
35.430 2366.00000 60.6000 -42.18750 -0.12500 2.95500 2.95500 13.20000 1.11000 1.07200 15.80000 1.00000 11.00000 11.00000 11.00000 11.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
35.440 2447.00000 61.2000 -38.28125 -0.25000 2.94400 2.94400 13.10000 1.11000 1.07200 16.80000 1.00000 11.00000 12.00000 11.00000 11.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
35.450 2447.00000 61.2000 -38.28125 -0.25000 2.94400 2.94400 13.10000 1.11000 1.07200 16.80000 1.00000 11.00000 12.00000 11.00000 11.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
35.460 2447.00000 61.2000 -38.28125 -0.25000 2.94400 2.94400 13.10000 1.11000 1.07200 16.80000 1.00000 11.00000 12.00000 11.00000 11.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
35.470 2447.00000 61.2000 -38.28125 -0.25000 2.94400 2.94400 13.10000 1.11000 1.07200 16.80000 1.00000 11.00000 12.00000 11.00000 11.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
35.480 2447.00000 61.2000 -38.28125 -0.25000 2.94400 2.94400 13.10000 1.11000 1.07200 16.80000 1.00000 11.00000 12.00000 11.00000 11.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
35.490 2397.00000 61.4000 -42.96875 -0.12500 3.14200 3.14200 12.40000 1.11300 1.09100 15.60000 1.00000 11.00000 11.00000 11.00000 11.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
35.500 2397.00000 61.4000 -42.96875 -0.12500 3.14200 3.14200 12.40000 1.11300 1.09100 15.60000 1.00000 11.00000 11.00000 11.00000 11.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
35.510 2397.00000 61.4000 -42.96875 -0.12500 3.14200 3.14200 12.40000 1.11300 1.09100 15.60000 1.00000 11.00000 11.00000 11.00000 11.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
35.520 2397.00000 61.4000 -42.96875 -0.12500 3.14200 3.14200 12.40000 1.11300 1.09100 15.60000 1.00000 11.00000 11.00000 11.00000 11.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
35.530 2397.00000 61.4000 -42.96875 -0.12500 3.14200 3.14200 12.40000 1.11300 1.09100 15.60000 1.00000 11.00000 11.00000 11.00000 11.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
35.540 2411.00000 61.2000 -42.18750 -0.12500 3.07200 3.07200 13.40000 1.11300 1.09100 15.70000 1.00000 11.00000 11.00000 11.00000 11.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
35.550 2411.00000 61.2000 -42.18750 -0.12500 3.07200 3.07200 13.40000 1.11300 1.09100 15.70000 1.00000 11.00000 11.00000 11.00000 11.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
35.560 2411.00000 61.2000 -42.18750 -0.12500 3.07200 3.07200 13.40000 1.11300 1.09100 15.70000 1.00000 11.00000 11.00000 11.00000 11.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
35.570 2411.00000 61.2000 -42.18750 -0.12500 3.07200 3.07200 13.40000 1.11300 1.09100 15.70000 1.00000 11.00000 11.00000 11.00000 11.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
35.580 2411.00000 61.2000 -42.18750 -0.12500 3.07200 3.07200 13.40000 1.11300 1.09100 15.70000 1.00000 11.00000 11.00000 11.00000 11.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
35.590 2494.00000 62.0000 -37.50000 -0.25000 2.89700 2.89700 13.40000 1.11300 1.09100 17.10000 1.00000 12.00000 12.00000 11.00000 12.00000 0.00000 0.00000 12.0000 0.000 0.000 0.000 0.000
35.600 2494.00000 62.0000 -37.50000 -0.25000 2.89700 2.89700 13.40000 1.11300 1.09100 17.10000 1.00000 12.00000 12.00000 11.00000 12.00000 0.00000 0.00000 12.0000 0.000 0.000 0.000 0.000
35.610 2494.00000 62.0000 -37.50000 -0.25000 2.89700 2.89700 13.40000 1.11300 1.09100 17.10000 1.00000 12.00000 12.00000 11.00000 12.00000 0.00000 0.00000 12.0000 0.000 0.000 0.000 0.000
35.620 2494.00000 62.0000 -37.50000 -0.25000 2.89700 2.89700 13.40000 1.11300 1.09100 17.10000 1.00000 12.00000 12.00000 11.00000 12.00000 0.00000 0.00000 12.0000 0.000 0.000 0.000 0.000
35.630 2494.00000 62.0000 -37.50000 -0.25000 2.89700 2.89700 13.40000 1.11300 1.09100 17.10000 1.00000 12.00000 12.00000 11.00000 12.00000 0.00000 0.00000 12.0000 0.000 0.000 0.000 0.000
35.640 2461.00000 62.2000 -41.40625 -0.25000 3.14800 3.14800 13.80000 1.11300 1.09100 15.90000 1.00000 11.00000 12.00000 11.00000 12.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
35.650 2461.00000 62.2000 -41.40625 -0.25000 3.14800 3.14800 13.80000 1.11300 1.09100 15.90000 1.00000 11.00000 12.00000 11.00000 12.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
35.660 2461.00000 62.2000 -41.40625 -0.25000 3.14800 3.14800 13.80000 1.11300 1.09100 15.90000 1.00000 11.00000 12.00000 11.00000 12.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
35.670 2461.00000 62.2000 -41.40625 -0.25000 3.14800 3.14800 13.80000 1.11300 1.09100 15.90000 1.00000 11.00000 12.00000 11.00000 12.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
35.680 2461.00000 62.2000 -41.40625 -0.25000 3.14800 3.14800 13.80000 1.11300 1.09100 15.90000 1.00000 11.00000 12.00000 11.00000 12.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
35.690 2474.00000 62.5000 -41.40625 -0.12500 2.92600 2.92600 13.00000 1.09400 1.09400 15.90000 1.00000 11.00000 11.00000 11.00000 12.00000 0.00000 0.00000 12.3000 0.000 0.000 0.000 0.000
35.700 2474.00000 62.5000 -41.40625 -0.12500 2.92600 2.92600 13.00000 1.09400 1.09400 15.90000 1.00000 11.00000 11.00000 11.00000 12.00000 0.00000 0.00000 12.3000 0.000 0.000 0.000 0.000
35.710 2474.00000 62.5000 -41.40625 -0.12500 2.92600 2.92600 13.00000 1.09400 1.09400 15.90000 1.00000 11.00000 11.00000 11.00000 12.00000 0.00000 0.00000 12.3000 0.000 0.000 0.000 0.000
35.720 2474.00000 62.5000 -41.40625 -0.12500 2.92600 2.92600 13.00000 1.09400 1.09400 15.90000 1.00000 11.00000 11.00000 11.00000 12.00000 0.00000 0.00000 12.3000 0.000 0.000 0.000 0.000
35.730 2474.00000 62.5000 -41.40625 -0.12500 2.92600 2.92600 13.00000 1.09400 1.09400 15.90000 1.00000 11.00000 11.00000 11.00000 12.00000 0.00000 0.00000 12.3000 0.000 0.000 0.000 0.000
35.740 2499.00000 63.1000 -40.62500 -0.25000 3.13000 3.13000 12.70000 1.09400 1.09400 16.20000 1.00000 11.00000 11.00000 12.00000 12.00000 0.00000 0.00000 12.3000 0.000 0.000 0.000 0.000
35.750 2499.00000 63.1000 -40.62500 -0.25000 3.13000 3.13000 12.70000 1.09400 1.09400 16.20000 1.00000 11.00000 11.00000 12.00000 12.00000 0.00000 0.00000 12.3000 0.000 0.000 0.000 0.000
35.760 2499.00000 63.1000 -40.62500 -0.25000 3.13000 3.13000 12.70000 1.09400 1.09400 16.20000 1.00000 11.00000 11.00000 12.00000 12.00000 0.00000 0.00000 12.3000 0.000 0.000 0.000 0.000
35.770 2499.00000 63.1000 -40.62500 -0.25000 3.13000 3.13000 12.70000 1.09400 1.09400 16.20000 1.00000 11.00000 11.00000 12.00000 12.00000 0.00000 0.00000 12.3000 0.000 0.000 0.000 0.000
35.780 2499.00000 63.1000 -40.62500 -0.25000 3.13000 3.13000 12.70000 1.09400 1.09400 16.20000 1.00000 11.00000 11.00000 12.00000 12.00000 0.00000 0.00000 12.3000 0.000 0.000 0.000 0.000
35.790 2517.00000 63.5000 -41.40625 -0.25000 3.00200 3.00200 12.60000 1.09400 1.09400 16.00000 1.00000 11.00000 12.00000 12.00000 12.00000 0.00000 0.00000 12.3000 0.000 0.000 0.000 0.000
35.800 2517.00000 63.5000 -41.40625 -0.25000 3.00200 3.00200 12.60000 1.09400 1.09400 16.00000 1.00000 11.00000 12.00000 12.00000 12.00000 0.00000 0.00000 12.3000 0.000 0.000 0.000 0.000
35.810 2517.00000 63.5000 -41.40625 -0.25000 3.00200 3.00200 12.60000 1.09400 1.09400 16.00000 1.00000 11.00000 12.00000 12.00000 12.00000 0.00000 0.00000 12.3000 0.000 0.000 0.000 0.000
35.820 2517.00000 63.5000 -41.40625 -0.25000 3.00200 3.00200 12.60000 1.09400 1.09400 16.00000 1.00000 11.00000 12.00000 12.00000 12.00000 0.00000 0.00000 12.3000 0.000 0.000 0.000 0.000
35.830 2517.00000 63.5000 -41.40625 -0.25000 3.00200 3.00200 12.60000 1.09400 1.09400 16.00000 1.00000 11.00000 12.00000 12.00000 12.00000 0.00000 0.00000 12.3000 0.000 0.000 0.000 0.000
35.840 2518.00000 64.4000 -39.84375 -0.25000 3.11800 3.11800 12.70000 1.09400 1.09400 16.50000 1.00000 11.00000 12.00000 12.00000 12.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
35.850 2518.00000 64.4000 -39.84375 -0.25000 3.11800 3.11800 12.70000 1.09400 1.09400 16.50000 1.00000 11.00000 12.00000 12.00000 12.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
35.860 2518.00000 64.4000 -39.84375 -0.25000 3.11800 3.11800 12.70000 1.09400 1.09400 16.50000 1.00000 11.00000 12.00000 12.00000 12.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
35.870 2518.00000 64.4000 -39.84375 -0.25000 3.11800 3.11800 12.70000 1.09400 1.09400 16.50000 1.00000 11.00000 12.00000 12.00000 12.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
35.880 2518.00000 64.4000 -39.84375 -0.25000 3.11800 3.11800 12.70000 1.09400 1.09400 16.50000 1.00000 11.00000 12.00000 12.00000 12.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
35.890 2610.00000 64.6000 -39.84375 -0.25000 3.01400 3.01400 13.40000 1.09400 1.08800 16.30000 1.00000 13.00000 12.00000 12.00000 13.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
35.900 2610.00000 64.6000 -39.84375 -0.25000 3.01400 3.01400 13.40000 1.09400 1.08800 16.30000 1.00000 13.00000 12.00000 12.00000 13.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
35.910 2610.00000 64.6000 -39.84375 -0.25000 3.01400 3.01400 13.40000 1.09400 1.08800 16.30000 1.00000 13.00000 12.00000 12.00000 13.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
35.920 2610.00000 64.6000 -39.84375 -0.25000 3.01400 3.01400 13.40000 1.09400 1.08800 16.30000 1.00000 13.00000 12.00000 12.00000 13.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
35.930 2610.00000 64.6000 -39.84375 -0.25000 3.01400 3.01400 13.40000 1.09400 1.08800 16.30000 1.00000 13.00000 12.00000 12.00000 13.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
35.940 2597.00000 64.6000 -39.84375 -0.37500 3.27600 3.27600 13.60000 1.09400 1.08800 16.30000 1.00000 12.00000 12.00000 12.00000 12.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
35.950 2597.00000 64.6000 -39.84375 -0.37500 3.27600 3.27600 13.60000 1.09400 1.08800 16.30000 1.00000 12.00000 12.00000 12.00000 12.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
35.960 2597.00000 64.6000 -39.84375 -0.37500 3.27600 3.27600 13.60000 1.09400 1.08800 16.30000 1.00000 12.00000 12.00000 12.00000 12.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
35.970 2597.00000 64.6000 -39.84375 -0.37500 3.27600 3.27600 13.60000 1.09400 1.08800 16.30000 1.00000 12.00000 12.00000 12.00000 12.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
35.980 2597.00000 64.6000 -39.84375 -0.37500 3.27600 3.27600 13.60000 1.09400 1.08800 16.30000 1.00000 12.00000 12.00000 12.00000 12.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
35.990 2579.00000 64.0000 -36.71875 -0.50000 3.06600 3.06600 13.60000 1.09400 1.08800 17.30000 1.00000 12.00000 12.00000 12.00000 12.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
36.000 2579.00000 64.0000 -36.71875 -0.50000 3.06600 3.06600 13.60000 1.09400 1.08800 17.30000 1.00000 12.00000 12.00000 12.00000 12.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
36.010 2579.00000 64.0000 -36.71875 -0.50000 3.06600 3.06600 13.60000 1.09400 1.08800 17.30000 1.00000 12.00000 12.00000 12.00000 12.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
36.020 2579.00000 64.0000 -36.71875 -0.50000 3.06600 3.06600 13.60000 1.09400 1.08800 17.30000 1.00000 12.00000 12.00000 12.00000 12.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
36.030 2579.00000 64.0000 -36.71875 -0.50000 3.06600 3.06600 13.60000 1.09400 1.08800 17.30000 1.00000 12.00000 12.00000 12.00000 12.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
36.040 2579.00000 64.0000 -36.71875 -0.50000 3.06600 3.06600 13.60000 1.09400 1.08800 17.30000 1.00000 12.00000 12.00000 12.00000 12.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
36.050 2631.00000 64.3000 -39.06250 -0.37500 3.18300 3.18300 13.40000 1.09400 1.08800 16.60000 1.00000 12.00000 12.00000 13.00000 12.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
36.060 2631.00000 64.3000 -39.06250 -0.37500 3.18300 3.18300 13.40000 1.09400 1.08800 16.60000 1.00000 12.00000 12.00000 13.00000 12.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
36.070 2631.00000 64.3000 -39.06250 -0.37500 3.18300 3.18300 13.40000 1.09400 1.08800 16.60000 1.00000 12.00000 12.00000 13.00000 12.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
36.080 2631.00000 64.3000 -39.06250 -0.37500 3.18300 3.18300 13.40000 1.09400 1.08800 16.60000 1.00000 12.00000 12.00000 13.00000 12.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
36.090 2631.00000 64.3000 -39.06250 -0.37500 3.18300 3.18300 13.40000 1.09400 1.08800 16.60000 1.00000 12.00000 12.00000 13.00000 12.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
36.100 2635.00000 64.0000 -39.84375 -0.37500 3.32200 3.32200 13.20000 1.10100 1.09400 16.40000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
36.110 2635.00000 64.0000 -39.84375 -0.37500 3.32200 3.32200 13.20000 1.10100 1.09400 16.40000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
36.120 2635.00000 64.0000 -39.84375 -0.37500 3.32200 3.32200 13.20000 1.10100 1.09400 16.40000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
36.130 2635.00000 64.0000 -39.84375 -0.37500 3.32200 3.32200 13.20000 1.10100 1.09400 16.40000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
36.140 2635.00000 64.0000 -39.84375 -0.37500 3.32200 3.32200 13.20000 1.10100 1.09400 16.40000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
36.150 2647.00000 63.8000 -35.93750 -0.50000 3.11800 3.11800 13.30000 1.10100 1.09400 17.60000 1.00000 12.00000 12.00000 13.00000 12.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
36.160 2647.00000 63.8000 -35.93750 -0.50000 3.11800 3.11800 13.30000 1.10100 1.09400 17.60000 1.00000 12.00000 12.00000 13.00000 12.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
36.170 2647.00000 63.8000 -35.93750 -0.50000 3.11800 3.11800 13.30000 1.10100 1.09400 17.60000 1.00000 12.00000 12.00000 13.00000 12.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
36.180 2647.00000 63.8000 -35.93750 -0.50000 3.11800 3.11800 13.30000 1.10100 1.09400 17.60000 1.00000 12.00000 12.00000 13.00000 12.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
36.190 2647.00000 63.8000 -35.93750 -0.50000 3.11800 3.11800 13.30000 1.10100 1.09400 17.60000 1.00000 12.00000 12.00000 13.00000 12.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
36.200 2675.00000 64.1000 -39.06250 -0.37500 3.09500 3.09500 13.40000 1.10100 1.09400 16.70000 1.00000 13.00000 13.00000 13.00000 12.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
36.210 2675.00000 64.1000 -39.06250 -0.37500 3.09500 3.09500 13.40000 1.10100 1.09400 16.70000 1.00000 13.00000 13.00000 13.00000 12.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
36.220 2675.00000 64.1000 -39.06250 -0.37500 3.09500 3.09500 13.40000 1.10100 1.09400 16.70000 1.00000 13.00000 13.00000 13.00000 12.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
36.230 2675.00000 64.1000 -39.06250 -0.37500 3.09500 3.09500 13.40000 1.10100 1.09400 16.70000 1.00000 13.00000 13.00000 13.00000 12.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
36.240 2675.00000 64.1000 -39.06250 -0.37500 3.09500 3.09500 13.40000 1.10100 1.09400 16.70000 1.00000 13.00000 13.00000 13.00000 12.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
36.250 2677.00000 64.4000 -39.06250 -0.37500 3.31700 3.31700 13.10000 1.10100 1.09400 16.50000 1.00000 12.00000 12.00000 12.00000 13.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
36.260 2677.00000 64.4000 -39.06250 -0.37500 3.31700 3.31700 13.10000 1.10100 1.09400 16.50000 1.00000 12.00000 12.00000 12.00000 13.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
36.270 2677.00000 64.4000 -39.06250 -0.37500 3.31700 3.31700 13.10000 1.10100 1.09400 16.50000 1.00000 12.00000 12.00000 12.00000 13.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
36.280 2677.00000 64.4000 -39.06250 -0.37500 3.31700 3.31700 13.10000 1.10100 1.09400 16.50000 1.00000 12.00000 12.00000 12.00000 13.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
36.290 2677.00000 64.4000 -39.06250 -0.37500 3.31700 3.31700 13.10000 1.10100 1.09400 16.50000 1.00000 12.00000 12.00000 12.00000 13.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
36.300 2721.00000 64.1000 -38.28125 -0.37500 3.32800 3.32800 13.20000 1.09800 1.09800 16.80000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 12.7000 0.000 0.000 0.000 0.000
36.310 2721.00000 64.1000 -38.28125 -0.37500 3.32800 3.32800 13.20000 1.09800 1.09800 16.80000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 12.7000 0.000 0.000 0.000 0.000
36.320 2721.00000 64.1000 -38.28125 -0.37500 3.32800 3.32800 13.20000 1.09800 1.09800 16.80000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 12.7000 0.000 0.000 0.000 0.000
36.330 2721.00000 64.1000 -38.28125 -0.37500 3.32800 3.32800 13.20000 1.09800 1.09800 16.80000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 12.7000 0.000 0.000 0.000 0.000
36.340 2721.00000 64.1000 -38.28125 -0.37500 3.32800 3.32800 13.20000 1.09800 1.09800 16.80000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 12.7000 0.000 0.000 0.000 0.000
36.350 2760.00000 64.4000 -38.28125 -0.37500 3.39200 3.39200 13.40000 1.09800 1.09800 16.90000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 12.8000 0.000 0.000 0.000 0.000
36.360 2760.00000 64.4000 -38.28125 -0.37500 3.39200 3.39200 13.40000 1.09800 1.09800 16.90000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 12.8000 0.000 0.000 0.000 0.000
36.370 2760.00000 64.4000 -38.28125 -0.37500 3.39200 3.39200 13.40000 1.09800 1.09800 16.90000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 12.8000 0.000 0.000 0.000 0.000
36.380 2760.00000 64.4000 -38.28125 -0.37500 3.39200 3.39200 13.40000 1.09800 1.09800 16.90000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 12.8000 0.000 0.000 0.000 0.000
36.390 2760.00000 64.4000 -38.28125 -0.37500 3.39200 3.39200 13.40000 1.09800 1.09800 16.90000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 12.8000 0.000 0.000 0.000 0.000
36.400 2769.00000 64.0000 -36.71875 -0.50000 3.35200 3.35200 12.40000 1.09800 1.09800 17.30000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 12.7000 0.000 0.000 0.000 0.000
36.410 2769.00000 64.0000 -36.71875 -0.50000 3.35200 3.35200 12.40000 1.09800 1.09800 17.30000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 12.7000 0.000 0.000 0.000 0.000
36.420 2769.00000 64.0000 -36.71875 -0.50000 3.35200 3.35200 12.40000 1.09800 1.09800 17.30000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 12.7000 0.000 0.000 0.000 0.000
36.430 2769.00000 64.0000 -36.71875 -0.50000 3.35200 3.35200 12.40000 1.09800 1.09800 17.30000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 12.7000 0.000 0.000 0.000 0.000
36.440 2769.00000 64.0000 -36.71875 -0.50000 3.35200 3.35200 12.40000 1.09800 1.09800 17.30000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 12.7000 0.000 0.000 0.000 0.000
36.450 2779.00000 63.4000 -37.50000 -0.50000 3.35700 3.35700 12.50000 1.09800 1.09800 17.20000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 12.8000 0.000 0.000 0.000 0.000
36.460 2779.00000 63.4000 -37.50000 -0.50000 3.35700 3.35700 12.50000 1.09800 1.09800 17.20000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 12.8000 0.000 0.000 0.000 0.000
36.470 2779.00000 63.4000 -37.50000 -0.50000 3.35700 3.35700 12.50000 1.09800 1.09800 17.20000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 12.8000 0.000 0.000 0.000 0.000
36.480 2779.00000 63.4000 -37.50000 -0.50000 3.35700 3.35700 12.50000 1.09800 1.09800 17.20000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 12.8000 0.000 0.000 0.000 0.000
36.490 2779.00000 63.4000 -37.50000 -0.50000 3.35700 3.35700 12.50000 1.09800 1.09800 17.20000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 12.8000 0.000 0.000 0.000 0.000
36.500 2792.00000 62.6000 -36.71875 -0.50000 3.38100 3.38100 12.40000 1.06900 1.08500 17.30000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 12.9000 0.000 0.000 0.000 0.000
36.510 2792.00000 62.6000 -36.71875 -0.50000 3.38100 3.38100 12.40000 1.06900 1.08500 17.30000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 12.9000 0.000 0.000 0.000 0.000
36.520 2792.00000 62.6000 -36.71875 -0.50000 3.38100 3.38100 12.40000 1.06900 1.08500 17.30000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 12.9000 0.000 0.000 0.000 0.000
36.530 2792.00000 62.6000 -36.71875 -0.50000 3.38100 3.38100 12.40000 1.06900 1.08500 17.30000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 12.9000 0.000 0.000 0.000 0.000
36.540 2792.00000 62.6000 -36.71875 -0.50000 3.38100 3.38100 12.40000 1.06900 1.08500 17.30000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 12.9000 0.000 0.000 0.000 0.000
36.550 2848.00000 63.5000 -36.71875 -0.50000 3.42200 3.42200 13.80000 1.06900 1.08500 17.40000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 12.9000 0.000 0.000 0.000 0.000
36.560 2848.00000 63.5000 -36.71875 -0.50000 3.42200 3.42200 13.80000 1.06900 1.08500 17.40000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 12.9000 0.000 0.000 0.000 0.000
36.570 2848.00000 63.5000 -36.71875 -0.50000 3.42200 3.42200 13.80000 1.06900 1.08500 17.40000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 12.9000 0.000 0.000 0.000 0.000
36.580 2848.00000 63.5000 -36.71875 -0.50000 3.42200 3.42200 13.80000 1.06900 1.08500 17.40000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 12.9000 0.000 0.000 0.000 0.000
36.590 2848.00000 63.5000 -36.71875 -0.50000 3.42200 3.42200 13.80000 1.06900 1.08500 17.40000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 12.9000 0.000 0.000 0.000 0.000
36.600 2835.00000 64.6000 -35.93750 -0.62500 3.41000 3.41000 12.10000 1.06900 1.08500 17.60000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
36.610 2835.00000 64.6000 -35.93750 -0.62500 3.41000 3.41000 12.10000 1.06900 1.08500 17.60000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
36.620 2835.00000 64.6000 -35.93750 -0.62500 3.41000 3.41000 12.10000 1.06900 1.08500 17.60000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
36.630 2835.00000 64.6000 -35.93750 -0.62500 3.41000 3.41000 12.10000 1.06900 1.08500 17.60000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
36.640 2835.00000 64.6000 -35.93750 -0.62500 3.41000 3.41000 12.10000 1.06900 1.08500 17.60000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
36.650 2878.00000 65.7000 -35.93750 -0.62500 3.43300 3.43300 13.60000 1.06900 1.08500 17.50000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 13.2000 0.000 0.000 0.000 0.000
36.660 2878.00000 65.7000 -35.93750 -0.62500 3.43300 3.43300 13.60000 1.06900 1.08500 17.50000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 13.2000 0.000 0.000 0.000 0.000
36.670 2878.00000 65.7000 -35.93750 -0.62500 3.43300 3.43300 13.60000 1.06900 1.08500 17.50000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 13.2000 0.000 0.000 0.000 0.000
36.680 2878.00000 65.7000 -35.93750 -0.62500 3.43300 3.43300 13.60000 1.06900 1.08500 17.50000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 13.2000 0.000 0.000 0.000 0.000
36.690 2878.00000 65.7000 -35.93750 -0.62500 3.43300 3.43300 13.60000 1.06900 1.08500 17.50000 1.00000 13.00000 13.00000 13.00000 13.00000 0.00000 0.00000 13.2000 0.000 0.000 0.000 0.000
36.700 2878.00000 66.9000 -36.71875 -0.62500 3.50900 3.50900 13.50000 1.06900 1.07200 17.40000 1.00000 13.00000 14.00000 14.00000 14.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
36.710 2878.00000 66.9000 -36.71875 -0.62500 3.50900 3.50900 13.50000 1.06900 1.07200 17.40000 1.00000 13.00000 14.00000 14.00000 14.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
36.720 2878.00000 66.9000 -36.71875 -0.62500 3.50900 3.50900 13.50000 1.06900 1.07200 17.40000 1.00000 13.00000 14.00000 14.00000 14.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
36.730 2878.00000 66.9000 -36.71875 -0.62500 3.50900 3.50900 13.50000 1.06900 1.07200 17.40000 1.00000 13.00000 14.00000 14.00000 14.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
36.740 2878.00000 66.9000 -36.71875 -0.62500 3.50900 3.50900 13.50000 1.06900 1.07200 17.40000 1.00000 13.00000 14.00000 14.00000 14.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
36.750 3020.00000 66.1000 -35.15625 -0.62500 3.42200 3.42200 13.70000 1.06900 1.07200 18.00000 1.00000 14.00000 14.00000 14.00000 14.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
36.760 3020.00000 66.1000 -35.15625 -0.62500 3.42200 3.42200 13.70000 1.06900 1.07200 18.00000 1.00000 14.00000 14.00000 14.00000 14.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
36.770 3020.00000 66.1000 -35.15625 -0.62500 3.42200 3.42200 13.70000 1.06900 1.07200 18.00000 1.00000 14.00000 14.00000 14.00000 14.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
36.780 3020.00000 66.1000 -35.15625 -0.62500 3.42200 3.42200 13.70000 1.06900 1.07200 18.00000 1.00000 14.00000 14.00000 14.00000 14.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
36.790 3020.00000 66.1000 -35.15625 -0.62500 3.42200 3.42200 13.70000 1.06900 1.07200 18.00000 1.00000 14.00000 14.00000 14.00000 14.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
36.800 2972.00000 65.8000 -32.81250 -0.75000 3.42700 3.42700 12.70000 1.06900 1.07200 18.70000 1.00000 14.00000 14.00000 14.00000 14.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
36.810 2972.00000 65.8000 -32.81250 -0.75000 3.42700 3.42700 12.70000 1.06900 1.07200 18.70000 1.00000 14.00000 14.00000 14.00000 14.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
36.820 2972.00000 65.8000 -32.81250 -0.75000 3.42700 3.42700 12.70000 1.06900 1.07200 18.70000 1.00000 14.00000 14.00000 14.00000 14.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
36.830 2972.00000 65.8000 -32.81250 -0.75000 3.42700 3.42700 12.70000 1.06900 1.07200 18.70000 1.00000 14.00000 14.00000 14.00000 14.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
36.840 2972.00000 65.8000 -32.81250 -0.75000 3.42700 3.42700 12.70000 1.06900 1.07200 18.70000 1.00000 14.00000 14.00000 14.00000 14.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
36.850 2968.00000 65.2000 -35.93750 -0.62500 3.53800 3.53800 12.90000 1.06900 1.07200 17.70000 1.00000 14.00000 14.00000 14.00000 14.00000 0.00000 0.00000 13.6000 0.000 0.000 0.000 0.000
36.860 2968.00000 65.2000 -35.93750 -0.62500 3.53800 3.53800 12.90000 1.06900 1.07200 17.70000 1.00000 14.00000 14.00000 14.00000 14.00000 0.00000 0.00000 13.6000 0.000 0.000 0.000 0.000
36.870 2968.00000 65.2000 -35.93750 -0.62500 3.53800 3.53800 12.90000 1.06900 1.07200 17.70000 1.00000 14.00000 14.00000 14.00000 14.00000 0.00000 0.00000 13.6000 0.000 0.000 0.000 0.000
36.880 2968.00000 65.2000 -35.93750 -0.62500 3.53800 3.53800 12.90000 1.06900 1.07200 17.70000 1.00000 14.00000 14.00000 14.00000 14.00000 0.00000 0.00000 13.6000 0.000 0.000 0.000 0.000
36.890 2968.00000 65.2000 -35.93750 -0.62500 3.53800 3.53800 12.90000 1.06900 1.07200 17.70000 1.00000 14.00000 14.00000 14.00000 14.00000 0.00000 0.00000 13.6000 0.000 0.000 0.000 0.000
36.900 3055.00000 65.2000 -35.15625 -0.62500 3.47400 3.47400 12.60000 1.05000 1.05600 18.00000 1.00000 15.00000 15.00000 14.00000 15.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
36.910 3055.00000 65.2000 -35.15625 -0.62500 3.47400 3.47400 12.60000 1.05000 1.05600 18.00000 1.00000 15.00000 15.00000 14.00000 15.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
36.920 3055.00000 65.2000 -35.15625 -0.62500 3.47400 3.47400 12.60000 1.05000 1.05600 18.00000 1.00000 15.00000 15.00000 14.00000 15.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
36.930 3055.00000 65.2000 -35.15625 -0.62500 3.47400 3.47400 12.60000 1.05000 1.05600 18.00000 1.00000 15.00000 15.00000 14.00000 15.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
36.940 3055.00000 65.2000 -35.15625 -0.62500 3.47400 3.47400 12.60000 1.05000 1.05600 18.00000 1.00000 15.00000 15.00000 14.00000 15.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
36.950 3004.00000 64.9000 -32.03125 -0.75000 3.46800 3.46800 13.10000 1.05000 1.05600 19.20000 1.00000 14.00000 14.00000 14.00000 14.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
36.960 3004.00000 64.9000 -32.03125 -0.75000 3.46800 3.46800 13.10000 1.05000 1.05600 19.20000 1.00000 14.00000 14.00000 14.00000 14.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
36.970 3004.00000 64.9000 -32.03125 -0.75000 3.46800 3.46800 13.10000 1.05000 1.05600 19.20000 1.00000 14.00000 14.00000 14.00000 14.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
36.980 3004.00000 64.9000 -32.03125 -0.75000 3.46800 3.46800 13.10000 1.05000 1.05600 19.20000 1.00000 14.00000 14.00000 14.00000 14.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
36.990 3004.00000 64.9000 -32.03125 -0.75000 3.46800 3.46800 13.10000 1.05000 1.05600 19.20000 1.00000 14.00000 14.00000 14.00000 14.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
37.000 3078.00000 65.4000 -35.15625 -0.62500 3.60800 3.60800 13.10000 1.05000 1.05600 17.80000 1.00000 15.00000 15.00000 14.00000 15.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
37.010 3078.00000 65.4000 -35.15625 -0.62500 3.60800 3.60800 13.10000 1.05000 1.05600 17.80000 1.00000 15.00000 15.00000 14.00000 15.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
37.020 3078.00000 65.4000 -35.15625 -0.62500 3.60800 3.60800 13.10000 1.05000 1.05600 17.80000 1.00000 15.00000 15.00000 14.00000 15.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
37.030 3078.00000 65.4000 -35.15625 -0.62500 3.60800 3.60800 13.10000 1.05000 1.05600 17.80000 1.00000 15.00000 15.00000 14.00000 15.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
37.040 3078.00000 65.4000 -35.15625 -0.62500 3.60800 3.60800 13.10000 1.05000 1.05600 17.80000 1.00000 15.00000 15.00000 14.00000 15.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
37.050 3030.00000 65.7000 -32.81250 -0.87500 3.43900 3.43900 13.40000 1.05000 1.05600 18.70000 1.00000 15.00000 15.00000 14.00000 15.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
37.060 3030.00000 65.7000 -32.81250 -0.87500 3.43900 3.43900 13.40000 1.05000 1.05600 18.70000 1.00000 15.00000 15.00000 14.00000 15.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
37.070 3030.00000 65.7000 -32.81250 -0.87500 3.43900 3.43900 13.40000 1.05000 1.05600 18.70000 1.00000 15.00000 15.00000 14.00000 15.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
37.080 3030.00000 65.7000 -32.81250 -0.87500 3.43900 3.43900 13.40000 1.05000 1.05600 18.70000 1.00000 15.00000 15.00000 14.00000 15.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
37.090 3030.00000 65.7000 -32.81250 -0.87500 3.43900 3.43900 13.40000 1.05000 1.05600 18.70000 1.00000 15.00000 15.00000 14.00000 15.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
37.100 3130.00000 65.5000 -34.37500 -0.75000 3.63100 3.63100 13.80000 1.04300 1.04300 18.20000 1.00000 15.00000 15.00000 15.00000 15.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
37.110 3130.00000 65.5000 -34.37500 -0.75000 3.63100 3.63100 13.80000 1.04300 1.04300 18.20000 1.00000 15.00000 15.00000 15.00000 15.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
37.120 3130.00000 65.5000 -34.37500 -0.75000 3.63100 3.63100 13.80000 1.04300 1.04300 18.20000 1.00000 15.00000 15.00000 15.00000 15.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
37.130 3130.00000 65.5000 -34.37500 -0.75000 3.63100 3.63100 13.80000 1.04300 1.04300 18.20000 1.00000 15.00000 15.00000 15.00000 15.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
37.140 3130.00000 65.5000 -34.37500 -0.75000 3.63100 3.63100 13.80000 1.04300 1.04300 18.20000 1.00000 15.00000 15.00000 15.00000 15.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
37.150 3093.00000 65.5000 -32.81250 -0.87500 3.53800 3.53800 13.00000 1.04300 1.04300 18.60000 1.00000 15.00000 15.00000 15.00000 15.00000 0.00000 0.00000 13.8000 0.000 0.000 0.000 0.000
37.160 3093.00000 65.5000 -32.81250 -0.87500 3.53800 3.53800 13.00000 1.04300 1.04300 18.60000 1.00000 15.00000 15.00000 15.00000 15.00000 0.00000 0.00000 13.8000 0.000 0.000 0.000 0.000
37.170 3093.00000 65.5000 -32.81250 -0.87500 3.53800 3.53800 13.00000 1.04300 1.04300 18.60000 1.00000 15.00000 15.00000 15.00000 15.00000 0.00000 0.00000 13.8000 0.000 0.000 0.000 0.000
37.180 3093.00000 65.5000 -32.81250 -0.87500 3.53800 3.53800 13.00000 1.04300 1.04300 18.60000 1.00000 15.00000 15.00000 15.00000 15.00000 0.00000 0.00000 13.8000 0.000 0.000 0.000 0.000
37.190 3093.00000 65.5000 -32.81250 -0.87500 3.53800 3.53800 13.00000 1.04300 1.04300 18.60000 1.00000 15.00000 15.00000 15.00000 15.00000 0.00000 0.00000 13.8000 0.000 0.000 0.000 0.000
37.200 3134.00000 65.8000 -33.59375 -0.87500 3.65500 3.65500 13.60000 1.04300 1.04300 18.50000 1.00000 19.00000 19.00000 19.00000 19.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
37.210 3134.00000 65.8000 -33.59375 -0.87500 3.65500 3.65500 13.60000 1.04300 1.04300 18.50000 1.00000 19.00000 19.00000 19.00000 19.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
37.220 3134.00000 65.8000 -33.59375 -0.87500 3.65500 3.65500 13.60000 1.04300 1.04300 18.50000 1.00000 19.00000 19.00000 19.00000 19.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
37.230 3134.00000 65.8000 -33.59375 -0.87500 3.65500 3.65500 13.60000 1.04300 1.04300 18.50000 1.00000 19.00000 19.00000 19.00000 19.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
37.240 3134.00000 65.8000 -33.59375 -0.87500 3.65500 3.65500 13.60000 1.04300 1.04300 18.50000 1.00000 19.00000 19.00000 19.00000 19.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
37.250 3121.00000 64.6000 -32.03125 -0.87500 3.54400 3.54400 12.60000 1.04300 1.04300 19.10000 1.00000 20.00000 19.00000 19.00000 19.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
37.260 3121.00000 64.6000 -32.03125 -0.87500 3.54400 3.54400 12.60000 1.04300 1.04300 19.10000 1.00000 20.00000 19.00000 19.00000 19.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
37.270 3121.00000 64.6000 -32.03125 -0.87500 3.54400 3.54400 12.60000 1.04300 1.04300 19.10000 1.00000 20.00000 19.00000 19.00000 19.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
37.280 3121.00000 64.6000 -32.03125 -0.87500 3.54400 3.54400 12.60000 1.04300 1.04300 19.10000 1.00000 20.00000 19.00000 19.00000 19.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
37.290 3121.00000 64.6000 -32.03125 -0.87500 3.54400 3.54400 12.60000 1.04300 1.04300 19.10000 1.00000 20.00000 19.00000 19.00000 19.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
37.300 3222.00000 65.8000 -33.59375 -0.87500 3.71300 3.71300 13.10000 1.04600 1.02400 18.60000 1.00000 20.00000 19.00000 20.00000 20.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
37.310 3222.00000 65.8000 -33.59375 -0.87500 3.71300 3.71300 13.10000 1.04600 1.02400 18.60000 1.00000 20.00000 19.00000 20.00000 20.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
37.320 3222.00000 65.8000 -33.59375 -0.87500 3.71300 3.71300 13.10000 1.04600 1.02400 18.60000 1.00000 20.00000 19.00000 20.00000 20.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
37.330 3222.00000 65.8000 -33.59375 -0.87500 3.71300 3.71300 13.10000 1.04600 1.02400 18.60000 1.00000 20.00000 19.00000 20.00000 20.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
37.340 3222.00000 65.8000 -33.59375 -0.87500 3.71300 3.71300 13.10000 1.04600 1.02400 18.60000 1.00000 20.00000 19.00000 20.00000 20.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
37.350 3248.00000 66.1000 -32.81250 -0.87500 3.74200 3.74200 12.90000 1.04600 1.02400 18.70000 1.00000 20.00000 20.00000 20.00000 20.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
37.360 3248.00000 66.1000 -32.81250 -0.87500 3.74200 3.74200 12.90000 1.04600 1.02400 18.70000 1.00000 20.00000 20.00000 20.00000 20.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
37.370 3248.00000 66.1000 -32.81250 -0.87500 3.74200 3.74200 12.90000 1.04600 1.02400 18.70000 1.00000 20.00000 20.00000 20.00000 20.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
37.380 3248.00000 66.1000 -32.81250 -0.87500 3.74200 3.74200 12.90000 1.04600 1.02400 18.70000 1.00000 20.00000 20.00000 20.00000 20.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
37.390 3248.00000 66.1000 -32.81250 -0.87500 3.74200 3.74200 12.90000 1.04600 1.02400 18.70000 1.00000 20.00000 20.00000 20.00000 20.00000 0.00000 0.00000 14.2000 0.000 0.000 0.000 0.000
37.400 3212.00000 66.6000 -30.46875 -1.00000 3.73100 3.73100 12.10000 1.04600 1.02400 19.60000 1.00000 21.00000 20.00000 20.00000 20.00000 0.00000 0.00000 12.9000 0.000 0.000 0.000 0.000
37.410 3212.00000 66.6000 -30.46875 -1.00000 3.73100 3.73100 12.10000 1.04600 1.02400 19.60000 1.00000 21.00000 20.00000 20.00000 20.00000 0.00000 0.00000 12.9000 0.000 0.000 0.000 0.000
37.420 3212.00000 66.6000 -30.46875 -1.00000 3.73100 3.73100 12.10000 1.04600 1.02400 19.60000 1.00000 21.00000 20.00000 20.00000 20.00000 0.00000 0.00000 12.9000 0.000 0.000 0.000 0.000
37.430 3212.00000 66.6000 -30.46875 -1.00000 3.73100 3.73100 12.10000 1.04600 1.02400 19.60000 1.00000 21.00000 20.00000 20.00000 20.00000 0.00000 0.00000 12.9000 0.000 0.000 0.000 0.000
37.440 3212.00000 66.6000 -30.46875 -1.00000 3.73100 3.73100 12.10000 1.04600 1.02400 19.60000 1.00000 21.00000 20.00000 20.00000 20.00000 0.00000 0.00000 12.9000 0.000 0.000 0.000 0.000
37.450 3288.00000 66.0000 -29.68750 -1.12500 3.60800 3.60800 13.10000 1.04600 1.02400 19.70000 1.00000 21.00000 20.00000 20.00000 20.00000 0.00000 0.00000 12.9000 0.000 0.000 0.000 0.000
37.460 3288.00000 66.0000 -29.68750 -1.12500 3.60800 3.60800 13.10000 1.04600 1.02400 19.70000 1.00000 21.00000 20.00000 20.00000 20.00000 0.00000 0.00000 12.9000 0.000 0.000 0.000 0.000
37.470 3288.00000 66.0000 -29.68750 -1.12500 3.60800 3.60800 13.10000 1.04600 1.02400 19.70000 1.00000 21.00000 20.00000 20.00000 20.00000 0.00000 0.00000 12.9000 0.000 0.000 0.000 0.000
37.480 3288.00000 66.0000 -29.68750 -1.12500 3.60800 3.60800 13.10000 1.04600 1.02400 19.70000 1.00000 21.00000 20.00000 20.00000 20.00000 0.00000 0.00000 12.9000 0.000 0.000 0.000 0.000
37.490 3288.00000 66.0000 -29.68750 -1.12500 3.60800 3.60800 13.10000 1.04600 1.02400 19.70000 1.00000 21.00000 20.00000 20.00000 20.00000 0.00000 0.00000 12.9000 0.000 0.000 0.000 0.000
37.500 3287.00000 66.1000 -32.03125 -0.87500 3.78900 3.78900 13.00000 1.10700 1.07200 19.00000 1.00000 20.00000 21.00000 20.00000 20.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
37.510 3287.00000 66.1000 -32.03125 -0.87500 3.78900 3.78900 13.00000 1.10700 1.07200 19.00000 1.00000 20.00000 21.00000 20.00000 20.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
37.520 3287.00000 66.1000 -32.03125 -0.87500 3.78900 3.78900 13.00000 1.10700 1.07200 19.00000 1.00000 20.00000 21.00000 20.00000 20.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
37.530 3287.00000 66.1000 -32.03125 -0.87500 3.78900 3.78900 13.00000 1.10700 1.07200 19.00000 1.00000 20.00000 21.00000 20.00000 20.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
37.540 3287.00000 66.1000 -32.03125 -0.87500 3.78900 3.78900 13.00000 1.10700 1.07200 19.00000 1.00000 20.00000 21.00000 20.00000 20.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
37.550 3391.00000 66.1000 -32.03125 -1.00000 3.79500 3.79500 13.10000 1.10700 1.07200 19.10000 1.00000 21.00000 21.00000 21.00000 22.00000 0.00000 0.00000 11.7000 0.000 0.000 0.000 0.000
37.560 3391.00000 66.1000 -32.03125 -1.00000 3.79500 3.79500 13.10000 1.10700 1.07200 19.10000 1.00000 21.00000 21.00000 21.00000 22.00000 0.00000 0.00000 11.7000 0.000 0.000 0.000 0.000
37.570 3391.00000 66.1000 -32.03125 -1.00000 3.79500 3.79500 13.10000 1.10700 1.07200 19.10000 1.00000 21.00000 21.00000 21.00000 22.00000 0.00000 0.00000 11.7000 0.000 0.000 0.000 0.000
37.580 3391.00000 66.1000 -32.03125 -1.00000 3.79500 3.79500 13.10000 1.10700 1.07200 19.10000 1.00000 21.00000 21.00000 21.00000 22.00000 0.00000 0.00000 11.7000 0.000 0.000 0.000 0.000
37.590 3391.00000 66.1000 -32.03125 -1.00000 3.79500 3.79500 13.10000 1.10700 1.07200 19.10000 1.00000 21.00000 21.00000 21.00000 22.00000 0.00000 0.00000 11.7000 0.000 0.000 0.000 0.000
37.600 3323.00000 65.8000 -32.03125 -1.00000 3.77700 3.77700 12.30000 1.10700 1.07200 19.20000 1.00000 21.00000 21.00000 22.00000 21.00000 0.00000 0.00000 11.7000 0.000 0.000 0.000 0.000
37.610 3323.00000 65.8000 -32.03125 -1.00000 3.77700 3.77700 12.30000 1.10700 1.07200 19.20000 1.00000 21.00000 21.00000 22.00000 21.00000 0.00000 0.00000 11.7000 0.000 0.000 0.000 0.000
37.620 3323.00000 65.8000 -32.03125 -1.00000 3.77700 3.77700 12.30000 1.10700 1.07200 19.20000 1.00000 21.00000 21.00000 22.00000 21.00000 0.00000 0.00000 11.7000 0.000 0.000 0.000 0.000
37.630 3323.00000 65.8000 -32.03125 -1.00000 3.77700 3.77700 12.30000 1.10700 1.07200 19.20000 1.00000 21.00000 21.00000 22.00000 21.00000 0.00000 0.00000 11.7000 0.000 0.000 0.000 0.000
37.640 3323.00000 65.8000 -32.03125 -1.00000 3.77700 3.77700 12.30000 1.10700 1.07200 19.20000 1.00000 21.00000 21.00000 22.00000 21.00000 0.00000 0.00000 11.7000 0.000 0.000 0.000 0.000
37.650 3423.00000 65.8000 -32.03125 -1.00000 3.90000 3.90000 13.10000 1.10700 1.07200 18.90000 1.00000 22.00000 22.00000 21.00000 21.00000 0.00000 0.00000 11.7000 0.000 0.000 0.000 0.000
37.660 3423.00000 65.8000 -32.03125 -1.00000 3.90000 3.90000 13.10000 1.10700 1.07200 18.90000 1.00000 22.00000 22.00000 21.00000 21.00000 0.00000 0.00000 11.7000 0.000 0.000 0.000 0.000
37.670 3423.00000 65.8000 -32.03125 -1.00000 3.90000 3.90000 13.10000 1.10700 1.07200 18.90000 1.00000 22.00000 22.00000 21.00000 21.00000 0.00000 0.00000 11.7000 0.000 0.000 0.000 0.000
37.680 3423.00000 65.8000 -32.03125 -1.00000 3.90000 3.90000 13.10000 1.10700 1.07200 18.90000 1.00000 22.00000 22.00000 21.00000 21.00000 0.00000 0.00000 11.7000 0.000 0.000 0.000 0.000
37.690 3423.00000 65.8000 -32.03125 -1.00000 3.90000 3.90000 13.10000 1.10700 1.07200 18.90000 1.00000 22.00000 22.00000 21.00000 21.00000 0.00000 0.00000 11.7000 0.000 0.000 0.000 0.000
37.700 3400.00000 66.0000 -31.25000 -1.00000 3.85900 3.85900 12.80000 1.11000 1.09100 19.40000 1.00000 21.00000 21.00000 22.00000 22.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
37.710 3400.00000 66.0000 -31.25000 -1.00000 3.85900 3.85900 12.80000 1.11000 1.09100 19.40000 1.00000 21.00000 21.00000 22.00000 22.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
37.720 3400.00000 66.0000 -31.25000 -1.00000 3.85900 3.85900 12.80000 1.11000 1.09100 19.40000 1.00000 21.00000 21.00000 22.00000 22.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
37.730 3400.00000 66.0000 -31.25000 -1.00000 3.85900 3.85900 12.80000 1.11000 1.09100 19.40000 1.00000 21.00000 21.00000 22.00000 22.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
37.740 3400.00000 66.0000 -31.25000 -1.00000 3.85900 3.85900 12.80000 1.11000 1.09100 19.40000 1.00000 21.00000 21.00000 22.00000 22.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
37.750 3508.00000 66.1000 -29.68750 -1.12500 3.84700 3.84700 13.60000 1.11000 1.09100 19.70000 1.00000 22.00000 23.00000 22.00000 22.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
37.760 3508.00000 66.1000 -29.68750 -1.12500 3.84700 3.84700 13.60000 1.11000 1.09100 19.70000 1.00000 22.00000 23.00000 22.00000 22.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
37.770 3508.00000 66.1000 -29.68750 -1.12500 3.84700 3.84700 13.60000 1.11000 1.09100 19.70000 1.00000 22.00000 23.00000 22.00000 22.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
37.780 3508.00000 66.1000 -29.68750 -1.12500 3.84700 3.84700 13.60000 1.11000 1.09100 19.70000 1.00000 22.00000 23.00000 22.00000 22.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
37.790 3508.00000 66.1000 -29.68750 -1.12500 3.84700 3.84700 13.60000 1.11000 1.09100 19.70000 1.00000 22.00000 23.00000 22.00000 22.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
37.800 3451.00000 66.1000 -26.56250 -1.25000 3.80100 3.80100 13.40000 1.11000 1.09100 20.40000 1.00000 22.00000 23.00000 22.00000 22.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
37.810 3451.00000 66.1000 -26.56250 -1.25000 3.80100 3.80100 13.40000 1.11000 1.09100 20.40000 1.00000 22.00000 23.00000 22.00000 22.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
37.820 3451.00000 66.1000 -26.56250 -1.25000 3.80100 3.80100 13.40000 1.11000 1.09100 20.40000 1.00000 22.00000 23.00000 22.00000 22.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
37.830 3451.00000 66.1000 -26.56250 -1.25000 3.80100 3.80100 13.40000 1.11000 1.09100 20.40000 1.00000 22.00000 23.00000 22.00000 22.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
37.840 3451.00000 66.1000 -26.56250 -1.25000 3.80100 3.80100 13.40000 1.11000 1.09100 20.40000 1.00000 22.00000 23.00000 22.00000 22.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
37.850 3477.00000 66.4000 -23.43750 -1.25000 3.90500 3.90500 12.20000 1.11000 1.09100 21.00000 1.00000 23.00000 22.00000 22.00000 22.00000 0.00000 0.00000 11.4000 0.000 0.000 0.000 0.000
37.860 3477.00000 66.4000 -23.43750 -1.25000 3.90500 3.90500 12.20000 1.11000 1.09100 21.00000 1.00000 23.00000 22.00000 22.00000 22.00000 0.00000 0.00000 11.4000 0.000 0.000 0.000 0.000
37.870 3477.00000 66.4000 -23.43750 -1.25000 3.90500 3.90500 12.20000 1.11000 1.09100 21.00000 1.00000 23.00000 22.00000 22.00000 22.00000 0.00000 0.00000 11.4000 0.000 0.000 0.000 0.000
37.880 3477.00000 66.4000 -23.43750 -1.25000 3.90500 3.90500 12.20000 1.11000 1.09100 21.00000 1.00000 23.00000 22.00000 22.00000 22.00000 0.00000 0.00000 11.4000 0.000 0.000 0.000 0.000
37.890 3477.00000 66.4000 -23.43750 -1.25000 3.90500 3.90500 12.20000 1.11000 1.09100 21.00000 1.00000 23.00000 22.00000 22.00000 22.00000 0.00000 0.00000 11.4000 0.000 0.000 0.000 0.000
37.900 3495.00000 66.9000 -27.34375 -1.25000 3.96400 3.96400 13.70000 1.12000 1.10100 20.30000 1.00000 24.00000 22.00000 23.00000 23.00000 0.00000 0.00000 11.5000 0.000 0.000 0.000 0.000
37.910 3495.00000 66.9000 -27.34375 -1.25000 3.96400 3.96400 13.70000 1.12000 1.10100 20.30000 1.00000 24.00000 22.00000 23.00000 23.00000 0.00000 0.00000 11.5000 0.000 0.000 0.000 0.000
37.920 3495.00000 66.9000 -27.34375 -1.25000 3.96400 3.96400 13.70000 1.12000 1.10100 20.30000 1.00000 24.00000 22.00000 23.00000 23.00000 0.00000 0.00000 11.5000 0.000 0.000 0.000 0.000
37.930 3495.00000 66.9000 -27.34375 -1.25000 3.96400 3.96400 13.70000 1.12000 1.10100 20.30000 1.00000 24.00000 22.00000 23.00000 23.00000 0.00000 0.00000 11.5000 0.000 0.000 0.000 0.000
37.940 3495.00000 66.9000 -27.34375 -1.25000 3.96400 3.96400 13.70000 1.12000 1.10100 20.30000 1.00000 24.00000 22.00000 23.00000 23.00000 0.00000 0.00000 11.5000 0.000 0.000 0.000 0.000
37.950 3577.00000 66.4000 -28.90625 -1.25000 4.05700 4.05700 12.70000 1.12000 1.10100 19.90000 1.00000 23.00000 23.00000 25.00000 24.00000 0.00000 0.00000 11.4000 0.000 0.000 0.000 0.000
37.960 3577.00000 66.4000 -28.90625 -1.25000 4.05700 4.05700 12.70000 1.12000 1.10100 19.90000 1.00000 23.00000 23.00000 25.00000 24.00000 0.00000 0.00000 11.4000 0.000 0.000 0.000 0.000
37.970 3577.00000 66.4000 -28.90625 -1.25000 4.05700 4.05700 12.70000 1.12000 1.10100 19.90000 1.00000 23.00000 23.00000 25.00000 24.00000 0.00000 0.00000 11.4000 0.000 0.000 0.000 0.000
37.980 3577.00000 66.4000 -28.90625 -1.25000 4.05700 4.05700 12.70000 1.12000 1.10100 19.90000 1.00000 23.00000 23.00000 25.00000 24.00000 0.00000 0.00000 11.4000 0.000 0.000 0.000 0.000
37.990 3577.00000 66.4000 -28.90625 -1.25000 4.05700 4.05700 12.70000 1.12000 1.10100 19.90000 1.00000 23.00000 23.00000 25.00000 24.00000 0.00000 0.00000 11.4000 0.000 0.000 0.000 0.000
38.000 3572.00000 67.2000 -25.00000 -1.37500 3.97500 3.97500 13.20000 1.12000 1.10100 20.70000 1.00000 24.00000 24.00000 24.00000 25.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
38.010 3572.00000 67.2000 -25.00000 -1.37500 3.97500 3.97500 13.20000 1.12000 1.10100 20.70000 1.00000 24.00000 24.00000 24.00000 25.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
38.020 3572.00000 67.2000 -25.00000 -1.37500 3.97500 3.97500 13.20000 1.12000 1.10100 20.70000 1.00000 24.00000 24.00000 24.00000 25.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
38.030 3572.00000 67.2000 -25.00000 -1.37500 3.97500 3.97500 13.20000 1.12000 1.10100 20.70000 1.00000 24.00000 24.00000 24.00000 25.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
38.040 3572.00000 67.2000 -25.00000 -1.37500 3.97500 3.97500 13.20000 1.12000 1.10100 20.70000 1.00000 24.00000 24.00000 24.00000 25.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
38.050 3588.00000 66.9000 -25.00000 -1.37500 4.07500 4.07500 12.90000 1.12000 1.10100 20.70000 1.00000 24.00000 25.00000 26.00000 24.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
38.060 3588.00000 66.9000 -25.00000 -1.37500 4.07500 4.07500 12.90000 1.12000 1.10100 20.70000 1.00000 24.00000 25.00000 26.00000 24.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
38.070 3588.00000 66.9000 -25.00000 -1.37500 4.07500 4.07500 12.90000 1.12000 1.10100 20.70000 1.00000 24.00000 25.00000 26.00000 24.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
38.080 3588.00000 66.9000 -25.00000 -1.37500 4.07500 4.07500 12.90000 1.12000 1.10100 20.70000 1.00000 24.00000 25.00000 26.00000 24.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
38.090 3588.00000 66.9000 -25.00000 -1.37500 4.07500 4.07500 12.90000 1.12000 1.10100 20.70000 1.00000 24.00000 25.00000 26.00000 24.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
38.100 3618.00000 67.2000 -25.78125 -1.37500 4.09800 4.09800 13.30000 1.12900 1.11300 20.60000 1.00000 26.00000 25.00000 25.00000 25.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
38.110 3618.00000 67.2000 -25.78125 -1.37500 4.09800 4.09800 13.30000 1.12900 1.11300 20.60000 1.00000 26.00000 25.00000 25.00000 25.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
38.120 3618.00000 67.2000 -25.78125 -1.37500 4.09800 4.09800 13.30000 1.12900 1.11300 20.60000 1.00000 26.00000 25.00000 25.00000 25.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
38.130 3618.00000 67.2000 -25.78125 -1.37500 4.09800 4.09800 13.30000 1.12900 1.11300 20.60000 1.00000 26.00000 25.00000 25.00000 25.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
38.140 3618.00000 67.2000 -25.78125 -1.37500 4.09800 4.09800 13.30000 1.12900 1.11300 20.60000 1.00000 26.00000 25.00000 25.00000 25.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
38.150 3705.00000 67.3000 -21.09375 -1.50000 4.15600 4.15600 12.20000 1.12900 1.11300 21.60000 1.00000 26.00000 25.00000 25.00000 26.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
38.160 3705.00000 67.3000 -21.09375 -1.50000 4.15600 4.15600 12.20000 1.12900 1.11300 21.60000 1.00000 26.00000 25.00000 25.00000 26.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
38.170 3705.00000 67.3000 -21.09375 -1.50000 4.15600 4.15600 12.20000 1.12900 1.11300 21.60000 1.00000 26.00000 25.00000 25.00000 26.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
38.180 3705.00000 67.3000 -21.09375 -1.50000 4.15600 4.15600 12.20000 1.12900 1.11300 21.60000 1.00000 26.00000 25.00000 25.00000 26.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
38.190 3705.00000 67.3000 -21.09375 -1.50000 4.15600 4.15600 12.20000 1.12900 1.11300 21.60000 1.00000 26.00000 25.00000 25.00000 26.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
38.200 3652.00000 67.5000 -24.21875 -1.50000 4.16800 4.16800 12.50000 1.12900 1.11300 20.90000 1.00000 25.00000 26.00000 26.00000 25.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
38.210 3652.00000 67.5000 -24.21875 -1.50000 4.16800 4.16800 12.50000 1.12900 1.11300 20.90000 1.00000 25.00000 26.00000 26.00000 25.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
38.220 3652.00000 67.5000 -24.21875 -1.50000 4.16800 4.16800 12.50000 1.12900 1.11300 20.90000 1.00000 25.00000 26.00000 26.00000 25.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
38.230 3652.00000 67.5000 -24.21875 -1.50000 4.16800 4.16800 12.50000 1.12900 1.11300 20.90000 1.00000 25.00000 26.00000 26.00000 25.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
38.240 3652.00000 67.5000 -24.21875 -1.50000 4.16800 4.16800 12.50000 1.12900 1.11300 20.90000 1.00000 25.00000 26.00000 26.00000 25.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
38.250 3757.00000 66.9000 -21.09375 -1.62500 4.20300 4.20300 13.80000 1.12900 1.11300 21.60000 1.00000 26.00000 27.00000 28.00000 26.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
38.260 3757.00000 66.9000 -21.09375 -1.62500 4.20300 4.20300 13.80000 1.12900 1.11300 21.60000 1.00000 26.00000 27.00000 28.00000 26.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
38.270 3757.00000 66.9000 -21.09375 -1.62500 4.20300 4.20300 13.80000 1.12900 1.11300 21.60000 1.00000 26.00000 27.00000 28.00000 26.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
38.280 3757.00000 66.9000 -21.09375 -1.62500 4.20300 4.20300 13.80000 1.12900 1.11300 21.60000 1.00000 26.00000 27.00000 28.00000 26.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
38.290 3757.00000 66.9000 -21.09375 -1.62500 4.20300 4.20300 13.80000 1.12900 1.11300 21.60000 1.00000 26.00000 27.00000 28.00000 26.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
38.300 3719.00000 67.0000 -18.75000 -1.75000 4.17400 4.17400 12.30000 1.12900 1.11000 22.00000 1.00000 27.00000 28.00000 27.00000 27.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
38.310 3719.00000 67.0000 -18.75000 -1.75000 4.17400 4.17400 12.30000 1.12900 1.11000 22.00000 1.00000 27.00000 28.00000 27.00000 27.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
38.320 3719.00000 67.0000 -18.75000 -1.75000 4.17400 4.17400 12.30000 1.12900 1.11000 22.00000 1.00000 27.00000 28.00000 27.00000 27.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
38.330 3719.00000 67.0000 -18.75000 -1.75000 4.17400 4.17400 12.30000 1.12900 1.11000 22.00000 1.00000 27.00000 28.00000 27.00000 27.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
38.340 3719.00000 67.0000 -18.75000 -1.75000 4.17400 4.17400 12.30000 1.12900 1.11000 22.00000 1.00000 27.00000 28.00000 27.00000 27.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
38.350 3815.00000 66.4000 -21.09375 -1.75000 4.23800 4.23800 12.80000 1.12900 1.11000 21.60000 1.00000 28.00000 28.00000 28.00000 28.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
38.360 3815.00000 66.4000 -21.09375 -1.75000 4.23800 4.23800 12.80000 1.12900 1.11000 21.60000 1.00000 28.00000 28.00000 28.00000 28.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
38.370 3815.00000 66.4000 -21.09375 -1.75000 4.23800 4.23800 12.80000 1.12900 1.11000 21.60000 1.00000 28.00000 28.00000 28.00000 28.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
38.380 3815.00000 66.4000 -21.09375 -1.75000 4.23800 4.23800 12.80000 1.12900 1.11000 21.60000 1.00000 28.00000 28.00000 28.00000 28.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
38.390 3815.00000 66.4000 -21.09375 -1.75000 4.23800 4.23800 12.80000 1.12900 1.11000 21.60000 1.00000 28.00000 28.00000 28.00000 28.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
38.400 3774.00000 66.3000 -17.96875 -1.75000 4.23200 4.23200 12.90000 1.12900 1.11000 22.30000 1.00000 28.00000 29.00000 28.00000 28.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
38.410 3774.00000 66.3000 -17.96875 -1.75000 4.23200 4.23200 12.90000 1.12900 1.11000 22.30000 1.00000 28.00000 29.00000 28.00000 28.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
38.420 3774.00000 66.3000 -17.96875 -1.75000 4.23200 4.23200 12.90000 1.12900 1.11000 22.30000 1.00000 28.00000 29.00000 28.00000 28.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
38.430 3774.00000 66.3000 -17.96875 -1.75000 4.23200 4.23200 12.90000 1.12900 1.11000 22.30000 1.00000 28.00000 29.00000 28.00000 28.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
38.440 3774.00000 66.3000 -17.96875 -1.75000 4.23200 4.23200 12.90000 1.12900 1.11000 22.30000 1.00000 28.00000 29.00000 28.00000 28.00000 0.00000 0.00000 11.1000 0.000 0.000 0.000 0.000
38.450 3792.00000 66.4000 -13.28125 -1.87500 4.25500 4.25500 12.60000 1.12900 1.11000 23.30000 1.00000 28.00000 29.00000 29.00000 28.00000 0.00000 0.00000 11.0000 0.000 0.000 0.000 0.000
38.460 3792.00000 66.4000 -13.28125 -1.87500 4.25500 4.25500 12.60000 1.12900 1.11000 23.30000 1.00000 28.00000 29.00000 29.00000 28.00000 0.00000 0.00000 11.0000 0.000 0.000 0.000 0.000
38.470 3792.00000 66.4000 -13.28125 -1.87500 4.25500 4.25500 12.60000 1.12900 1.11000 23.30000 1.00000 28.00000 29.00000 29.00000 28.00000 0.00000 0.00000 11.0000 0.000 0.000 0.000 0.000
38.480 3792.00000 66.4000 -13.28125 -1.87500 4.25500 4.25500 12.60000 1.12900 1.11000 23.30000 1.00000 28.00000 29.00000 29.00000 28.00000 0.00000 0.00000 11.0000 0.000 0.000 0.000 0.000
38.490 3792.00000 66.4000 -13.28125 -1.87500 4.25500 4.25500 12.60000 1.12900 1.11000 23.30000 1.00000 28.00000 29.00000 29.00000 28.00000 0.00000 0.00000 11.0000 0.000 0.000 0.000 0.000
38.500 3814.00000 66.0000 -17.96875 -1.75000 4.31400 4.31400 13.70000 1.12900 1.11300 22.20000 1.00000 29.00000 30.00000 31.00000 28.00000 0.00000 0.00000 10.9000 0.000 0.000 0.000 0.000
38.510 3814.00000 66.0000 -17.96875 -1.75000 4.31400 4.31400 13.70000 1.12900 1.11300 22.20000 1.00000 29.00000 30.00000 31.00000 28.00000 0.00000 0.00000 10.9000 0.000 0.000 0.000 0.000
38.520 3814.00000 66.0000 -17.96875 -1.75000 4.31400 4.31400 13.70000 1.12900 1.11300 22.20000 1.00000 29.00000 30.00000 31.00000 28.00000 0.00000 0.00000 10.9000 0.000 0.000 0.000 0.000
38.530 3814.00000 66.0000 -17.96875 -1.75000 4.31400 4.31400 13.70000 1.12900 1.11300 22.20000 1.00000 29.00000 30.00000 31.00000 28.00000 0.00000 0.00000 10.9000 0.000 0.000 0.000 0.000
38.540 3814.00000 66.0000 -17.96875 -1.75000 4.31400 4.31400 13.70000 1.12900 1.11300 22.20000 1.00000 29.00000 30.00000 31.00000 28.00000 0.00000 0.00000 10.9000 0.000 0.000 0.000 0.000
38.550 3859.00000 66.7000 -18.75000 -1.87500 4.43000 4.43000 13.30000 1.12900 1.11300 22.10000 1.00000 30.00000 31.00000 30.00000 30.00000 0.00000 0.00000 10.9000 0.000 0.000 0.000 0.000
38.560 3859.00000 66.7000 -18.75000 -1.87500 4.43000 4.43000 13.30000 1.12900 1.11300 22.10000 1.00000 30.00000 31.00000 30.00000 30.00000 0.00000 0.00000 10.9000 0.000 0.000 0.000 0.000
38.570 3859.00000 66.7000 -18.75000 -1.87500 4.43000 4.43000 13.30000 1.12900 1.11300 22.10000 1.00000 30.00000 31.00000 30.00000 30.00000 0.00000 0.00000 10.9000 0.000 0.000 0.000 0.000
38.580 3859.00000 66.7000 -18.75000 -1.87500 4.43000 4.43000 13.30000 1.12900 1.11300 22.10000 1.00000 30.00000 31.00000 30.00000 30.00000 0.00000 0.00000 10.9000 0.000 0.000 0.000 0.000
38.590 3859.00000 66.7000 -18.75000 -1.87500 4.43000 4.43000 13.30000 1.12900 1.11300 22.10000 1.00000 30.00000 31.00000 30.00000 30.00000 0.00000 0.00000 10.9000 0.000 0.000 0.000 0.000
38.600 3859.00000 66.9000 -18.75000 -1.75000 4.45300 4.45000 13.70000 1.12900 1.11300 22.00000 1.00000 27.00000 24.00000 24.00000 27.00000 0.00000 0.00000 10.9000 0.000 0.000 0.000 0.000
38.610 3859.00000 66.9000 -18.75000 -1.75000 4.45300 4.45000 13.70000 1.12900 1.11300 22.00000 1.00000 27.00000 24.00000 24.00000 27.00000 0.00000 0.00000 10.9000 0.000 0.000 0.000 0.000
38.620 3859.00000 66.9000 -18.75000 -1.75000 4.45300 4.45000 13.70000 1.12900 1.11300 22.00000 1.00000 27.00000 24.00000 24.00000 27.00000 0.00000 0.00000 10.9000 0.000 0.000 0.000 0.000
38.630 3859.00000 66.9000 -18.75000 -1.75000 4.45300 4.45000 13.70000 1.12900 1.11300 22.00000 1.00000 27.00000 24.00000 24.00000 27.00000 0.00000 0.00000 10.9000 0.000 0.000 0.000 0.000
38.640 3859.00000 66.9000 -18.75000 -1.75000 4.45300 4.45000 13.70000 1.12900 1.11300 22.00000 1.00000 27.00000 24.00000 24.00000 27.00000 0.00000 0.00000 10.9000 0.000 0.000 0.000 0.000
38.650 3922.00000 66.7000 -17.96875 -1.75000 4.48300 4.45000 13.30000 1.12900 1.11300 22.20000 1.00000 26.00000 28.00000 27.00000 25.00000 0.00000 0.00000 10.7000 0.000 0.000 0.000 0.000
38.660 3922.00000 66.7000 -17.96875 -1.75000 4.48300 4.45000 13.30000 1.12900 1.11300 22.20000 1.00000 26.00000 28.00000 27.00000 25.00000 0.00000 0.00000 10.7000 0.000 0.000 0.000 0.000
38.670 3922.00000 66.7000 -17.96875 -1.75000 4.48300 4.45000 13.30000 1.12900 1.11300 22.20000 1.00000 26.00000 28.00000 27.00000 25.00000 0.00000 0.00000 10.7000 0.000 0.000 0.000 0.000
38.680 3922.00000 66.7000 -17.96875 -1.75000 4.48300 4.45000 13.30000 1.12900 1.11300 22.20000 1.00000 26.00000 28.00000 27.00000 25.00000 0.00000 0.00000 10.7000 0.000 0.000 0.000 0.000
38.690 3922.00000 66.7000 -17.96875 -1.75000 4.48300 4.45000 13.30000 1.12900 1.11300 22.20000 1.00000 26.00000 28.00000 27.00000 25.00000 0.00000 0.00000 10.7000 0.000 0.000 0.000 0.000
38.700 4064.00000 67.3000 -17.96875 -1.75000 4.51200 4.45000 13.60000 1.12000 1.11300 22.20000 1.00000 29.00000 27.00000 26.00000 30.00000 0.00000 0.00000 10.8000 0.000 0.000 0.000 0.000
38.710 4064.00000 67.3000 -17.96875 -1.75000 4.51200 4.45000 13.60000 1.12000 1.11300 22.20000 1.00000 29.00000 27.00000 26.00000 30.00000 0.00000 0.00000 10.8000 0.000 0.000 0.000 0.000
38.720 4064.00000 67.3000 -17.96875 -1.75000 4.51200 4.45000 13.60000 1.12000 1.11300 22.20000 1.00000 29.00000 27.00000 26.00000 30.00000 0.00000 0.00000 10.8000 0.000 0.000 0.000 0.000
38.730 4064.00000 67.3000 -17.96875 -1.75000 4.51200 4.45000 13.60000 1.12000 1.11300 22.20000 1.00000 29.00000 27.00000 26.00000 30.00000 0.00000 0.00000 10.8000 0.000 0.000 0.000 0.000
38.740 4064.00000 67.3000 -17.96875 -1.75000 4.51200 4.45000 13.60000 1.12000 1.11300 22.20000 1.00000 29.00000 27.00000 26.00000 30.00000 0.00000 0.00000 10.8000 0.000 0.000 0.000 0.000
38.750 3999.00000 67.7000 -17.96875 -1.87500 4.53500 4.45000 13.70000 1.12000 1.11300 22.30000 1.00000 26.00000 29.00000 28.00000 26.00000 0.00000 0.00000 10.7000 0.000 0.000 0.000 0.000
38.760 3999.00000 67.7000 -17.96875 -1.87500 4.53500 4.45000 13.70000 1.12000 1.11300 22.30000 1.00000 26.00000 29.00000 28.00000 26.00000 0.00000 0.00000 10.7000 0.000 0.000 0.000 0.000
38.770 3999.00000 67.7000 -17.96875 -1.87500 4.53500 4.45000 13.70000 1.12000 1.11300 22.30000 1.00000 26.00000 29.00000 28.00000 26.00000 0.00000 0.00000 10.7000 0.000 0.000 0.000 0.000
38.780 3999.00000 67.7000 -17.96875 -1.87500 4.53500 4.45000 13.70000 1.12000 1.11300 22.30000 1.00000 26.00000 29.00000 28.00000 26.00000 0.00000 0.00000 10.7000 0.000 0.000 0.000 0.000
38.790 3999.00000 67.7000 -17.96875 -1.87500 4.53500 4.45000 13.70000 1.12000 1.11300 22.30000 1.00000 26.00000 29.00000 28.00000 26.00000 0.00000 0.00000 10.7000 0.000 0.000 0.000 0.000
38.800 4107.00000 67.3000 -15.62500 -1.87500 4.43000 4.43000 12.60000 1.12000 1.11300 22.80000 1.00000 27.00000 29.00000 30.00000 29.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
38.809 4107.00000 67.3000 -15.62500 -1.87500 4.43000 4.43000 12.60000 1.12000 1.11300 22.80000 1.00000 27.00000 29.00000 30.00000 29.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
38.819 4107.00000 67.3000 -15.62500 -1.87500 4.43000 4.43000 12.60000 1.12000 1.11300 22.80000 1.00000 27.00000 29.00000 30.00000 29.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
38.829 4107.00000 67.3000 -15.62500 -1.87500 4.43000 4.43000 12.60000 1.12000 1.11300 22.80000 1.00000 27.00000 29.00000 30.00000 29.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
38.839 4107.00000 67.3000 -15.62500 -1.87500 4.43000 4.43000 12.60000 1.12000 1.11300 22.80000 1.00000 27.00000 29.00000 30.00000 29.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
38.849 4042.00000 67.5000 -8.59375 -2.00000 4.50000 4.45000 12.70000 1.12000 1.11300 24.30000 1.00000 28.00000 27.00000 26.00000 30.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
38.859 4042.00000 67.5000 -8.59375 -2.00000 4.50000 4.45000 12.70000 1.12000 1.11300 24.30000 1.00000 28.00000 27.00000 26.00000 30.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
38.869 4042.00000 67.5000 -8.59375 -2.00000 4.50000 4.45000 12.70000 1.12000 1.11300 24.30000 1.00000 28.00000 27.00000 26.00000 30.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
38.879 4042.00000 67.5000 -8.59375 -2.00000 4.50000 4.45000 12.70000 1.12000 1.11300 24.30000 1.00000 28.00000 27.00000 26.00000 30.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
38.889 4042.00000 67.5000 -8.59375 -2.00000 4.50000 4.45000 12.70000 1.12000 1.11300 24.30000 1.00000 28.00000 27.00000 26.00000 30.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
38.899 4067.00000 67.0000 -6.25000 -2.00000 4.53500 4.45000 13.70000 1.11000 1.11000 24.80000 1.00000 28.00000 26.00000 26.00000 30.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
38.909 4067.00000 67.0000 -6.25000 -2.00000 4.53500 4.45000 13.70000 1.11000 1.11000 24.80000 1.00000 28.00000 26.00000 26.00000 30.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
38.919 4067.00000 67.0000 -6.25000 -2.00000 4.53500 4.45000 13.70000 1.11000 1.11000 24.80000 1.00000 28.00000 26.00000 26.00000 30.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
38.929 4067.00000 67.0000 -6.25000 -2.00000 4.53500 4.45000 13.70000 1.11000 1.11000 24.80000 1.00000 28.00000 26.00000 26.00000 30.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
38.939 4067.00000 67.0000 -6.25000 -2.00000 4.53500 4.45000 13.70000 1.11000 1.11000 24.80000 1.00000 28.00000 26.00000 26.00000 30.00000 0.00000 0.00000 11.2000 0.000 0.000 0.000 0.000
38.949 4118.00000 67.3000 -17.18750 -1.87500 4.59300 4.45000 14.00000 1.11000 1.11000 22.40000 1.00000 28.00000 30.00000 27.00000 31.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
38.959 4118.00000 67.3000 -17.18750 -1.87500 4.59300 4.45000 14.00000 1.11000 1.11000 22.40000 1.00000 28.00000 30.00000 27.00000 31.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
38.969 4118.00000 67.3000 -17.18750 -1.87500 4.59300 4.45000 14.00000 1.11000 1.11000 22.40000 1.00000 28.00000 30.00000 27.00000 31.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
38.979 4118.00000 67.3000 -17.18750 -1.87500 4.59300 4.45000 14.00000 1.11000 1.11000 22.40000 1.00000 28.00000 30.00000 27.00000 31.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
38.989 4118.00000 67.3000 -17.18750 -1.87500 4.59300 4.45000 14.00000 1.11000 1.11000 22.40000 1.00000 28.00000 30.00000 27.00000 31.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
38.999 4136.00000 67.5000 -8.59375 -2.12500 4.50600 4.45000 13.00000 1.11000 1.11000 24.20000 1.00000 30.00000 30.00000 28.00000 31.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
39.009 4136.00000 67.5000 -8.59375 -2.12500 4.50600 4.45000 13.00000 1.11000 1.11000 24.20000 1.00000 30.00000 30.00000 28.00000 31.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
39.019 4136.00000 67.5000 -8.59375 -2.12500 4.50600 4.45000 13.00000 1.11000 1.11000 24.20000 1.00000 30.00000 30.00000 28.00000 31.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
39.029 4136.00000 67.5000 -8.59375 -2.12500 4.50600 4.45000 13.00000 1.11000 1.11000 24.20000 1.00000 30.00000 30.00000 28.00000 31.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
39.039 4136.00000 67.5000 -8.59375 -2.12500 4.50600 4.45000 13.00000 1.11000 1.11000 24.20000 1.00000 30.00000 30.00000 28.00000 31.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
39.049 4265.00000 67.0000 -10.93750 -2.00000 4.68100 4.45000 13.00000 1.11000 1.11000 23.70000 1.00000 4.00000 28.00000 29.00000 30.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
39.059 4265.00000 67.0000 -10.93750 -2.00000 4.68100 4.45000 13.00000 1.11000 1.11000 23.70000 1.00000 4.00000 28.00000 29.00000 30.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
39.069 4265.00000 67.0000 -10.93750 -2.00000 4.68100 4.45000 13.00000 1.11000 1.11000 23.70000 1.00000 4.00000 28.00000 29.00000 30.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
39.079 4265.00000 67.0000 -10.93750 -2.00000 4.68100 4.45000 13.00000 1.11000 1.11000 23.70000 1.00000 4.00000 28.00000 29.00000 30.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
39.089 4265.00000 67.0000 -10.93750 -2.00000 4.68100 4.45000 13.00000 1.11000 1.11000 23.70000 1.00000 4.00000 28.00000 29.00000 30.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
39.099 4185.00000 66.9000 -15.62500 -2.00000 4.54700 4.45000 12.70000 1.11000 1.10100 22.80000 1.00000 28.00000 28.00000 31.00000 26.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
39.109 4185.00000 66.9000 -15.62500 -2.00000 4.54700 4.45000 12.70000 1.11000 1.10100 22.80000 1.00000 28.00000 28.00000 31.00000 26.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
39.119 4185.00000 66.9000 -15.62500 -2.00000 4.54700 4.45000 12.70000 1.11000 1.10100 22.80000 1.00000 28.00000 28.00000 31.00000 26.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
39.129 4185.00000 66.9000 -15.62500 -2.00000 4.54700 4.45000 12.70000 1.11000 1.10100 22.80000 1.00000 28.00000 28.00000 31.00000 26.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
39.139 4185.00000 66.9000 -15.62500 -2.00000 4.54700 4.45000 12.70000 1.11000 1.10100 22.80000 1.00000 28.00000 28.00000 31.00000 26.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
39.149 4238.00000 67.2000 -9.37500 -2.00000 4.69300 4.45000 13.40000 1.11000 1.10100 24.10000 1.00000 28.00000 32.00000 28.00000 28.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
39.159 4238.00000 67.2000 -9.37500 -2.00000 4.69300 4.45000 13.40000 1.11000 1.10100 24.10000 1.00000 28.00000 32.00000 28.00000 28.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
39.169 4238.00000 67.2000 -9.37500 -2.00000 4.69300 4.45000 13.40000 1.11000 1.10100 24.10000 1.00000 28.00000 32.00000 28.00000 28.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
39.179 4238.00000 67.2000 -9.37500 -2.00000 4.69300 4.45000 13.40000 1.11000 1.10100 24.10000 1.00000 28.00000 32.00000 28.00000 28.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
39.189 4238.00000 67.2000 -9.37500 -2.00000 4.69300 4.45000 13.40000 1.11000 1.10100 24.10000 1.00000 28.00000 32.00000 28.00000 28.00000 0.00000 0.00000 11.8000 0.000 0.000 0.000 0.000
39.199 4275.00000 67.7000 -10.93750 -2.12500 4.63400 4.45000 12.90000 1.11000 1.10100 23.80000 1.00000 4.00000 28.00000 27.00000 30.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
39.209 4275.00000 67.7000 -10.93750 -2.12500 4.63400 4.45000 12.90000 1.11000 1.10100 23.80000 1.00000 4.00000 28.00000 27.00000 30.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
39.219 4275.00000 67.7000 -10.93750 -2.12500 4.63400 4.45000 12.90000 1.11000 1.10100 23.80000 1.00000 4.00000 28.00000 27.00000 30.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
39.229 4275.00000 67.7000 -10.93750 -2.12500 4.63400 4.45000 12.90000 1.11000 1.10100 23.80000 1.00000 4.00000 28.00000 27.00000 30.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
39.239 4275.00000 67.7000 -10.93750 -2.12500 4.63400 4.45000 12.90000 1.11000 1.10100 23.80000 1.00000 4.00000 28.00000 27.00000 30.00000 0.00000 0.00000 11.9000 0.000 0.000 0.000 0.000
39.249 4237.00000 66.3000 -16.40625 -1.87500 4.71600 4.45000 13.50000 1.11000 1.10100 22.60000 1.00000 30.00000 31.00000 28.00000 31.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
39.259 4237.00000 66.3000 -16.40625 -1.87500 4.71600 4.45000 13.50000 1.11000 1.10100 22.60000 1.00000 30.00000 31.00000 28.00000 31.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
39.269 4237.00000 66.3000 -16.40625 -1.87500 4.71600 4.45000 13.50000 1.11000 1.10100 22.60000 1.00000 30.00000 31.00000 28.00000 31.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
39.279 4237.00000 66.3000 -16.40625 -1.87500 4.71600 4.45000 13.50000 1.11000 1.10100 22.60000 1.00000 30.00000 31.00000 28.00000 31.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
39.289 4237.00000 66.3000 -16.40625 -1.87500 4.71600 4.45000 13.50000 1.11000 1.10100 22.60000 1.00000 30.00000 31.00000 28.00000 31.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
39.299 4428.00000 66.6000 -100.00000 -2.12500 4.71000 4.45000 13.30000 1.07500 1.07800 25.90000 1.00000 33.00000 29.00000 33.00000 29.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
39.309 4428.00000 66.6000 -100.00000 -2.12500 4.71000 4.45000 13.30000 1.07500 1.07800 25.90000 1.00000 33.00000 29.00000 33.00000 29.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
39.319 4428.00000 66.6000 -100.00000 -2.12500 4.71000 4.45000 13.30000 1.07500 1.07800 25.90000 1.00000 33.00000 29.00000 33.00000 29.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
39.329 4428.00000 66.6000 -100.00000 -2.12500 4.71000 4.45000 13.30000 1.07500 1.07800 25.90000 1.00000 33.00000 29.00000 33.00000 29.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
39.339 4428.00000 66.6000 -100.00000 -2.12500 4.71000 4.45000 13.30000 1.07500 1.07800 25.90000 1.00000 33.00000 29.00000 33.00000 29.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
39.349 4417.00000 67.5000 -12.50000 -2.12500 4.71000 4.45000 12.90000 1.07500 1.07800 23.40000 1.00000 33.00000 4.00000 29.00000 29.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
39.359 4417.00000 67.5000 -12.50000 -2.12500 4.71000 4.45000 12.90000 1.07500 1.07800 23.40000 1.00000 33.00000 4.00000 29.00000 29.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
39.369 4417.00000 67.5000 -12.50000 -2.12500 4.71000 4.45000 12.90000 1.07500 1.07800 23.40000 1.00000 33.00000 4.00000 29.00000 29.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
39.379 4417.00000 67.5000 -12.50000 -2.12500 4.71000 4.45000 12.90000 1.07500 1.07800 23.40000 1.00000 33.00000 4.00000 29.00000 29.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
39.389 4417.00000 67.5000 -12.50000 -2.12500 4.71000 4.45000 12.90000 1.07500 1.07800 23.40000 1.00000 33.00000 4.00000 29.00000 29.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
39.399 4354.00000 65.8000 -16.40625 -2.00000 4.69300 4.45000 12.90000 1.07500 1.07800 22.50000 1.00000 29.00000 30.00000 28.00000 33.00000 0.00000 0.00000 12.8000 0.000 0.000 0.000 0.000
39.409 4354.00000 65.8000 -16.40625 -2.00000 4.69300 4.45000 12.90000 1.07500 1.07800 22.50000 1.00000 29.00000 30.00000 28.00000 33.00000 0.00000 0.00000 12.8000 0.000 0.000 0.000 0.000
39.419 4354.00000 65.8000 -16.40625 -2.00000 4.69300 4.45000 12.90000 1.07500 1.07800 22.50000 1.00000 29.00000 30.00000 28.00000 33.00000 0.00000 0.00000 12.8000 0.000 0.000 0.000 0.000
39.429 4354.00000 65.8000 -16.40625 -2.00000 4.69300 4.45000 12.90000 1.07500 1.07800 22.50000 1.00000 29.00000 30.00000 28.00000 33.00000 0.00000 0.00000 12.8000 0.000 0.000 0.000 0.000
39.439 4354.00000 65.8000 -16.40625 -2.00000 4.69300 4.45000 12.90000 1.07500 1.07800 22.50000 1.00000 29.00000 30.00000 28.00000 33.00000 0.00000 0.00000 12.8000 0.000 0.000 0.000 0.000
39.449 4376.00000 66.0000 -15.62500 -1.87500 4.79700 4.45000 13.10000 1.07500 1.07800 22.80000 1.00000 29.00000 29.00000 33.00000 30.00000 0.00000 0.00000 12.8000 0.000 0.000 0.000 0.000
39.459 4376.00000 66.0000 -15.62500 -1.87500 4.79700 4.45000 13.10000 1.07500 1.07800 22.80000 1.00000 29.00000 29.00000 33.00000 30.00000 0.00000 0.00000 12.8000 0.000 0.000 0.000 0.000
39.469 4376.00000 66.0000 -15.62500 -1.87500 4.79700 4.45000 13.10000 1.07500 1.07800 22.80000 1.00000 29.00000 29.00000 33.00000 30.00000 0.00000 0.00000 12.8000 0.000 0.000 0.000 0.000
39.479 4376.00000 66.0000 -15.62500 -1.87500 4.79700 4.45000 13.10000 1.07500 1.07800 22.80000 1.00000 29.00000 29.00000 33.00000 30.00000 0.00000 0.00000 12.8000 0.000 0.000 0.000 0.000
39.489 4376.00000 66.0000 -15.62500 -1.87500 4.79700 4.45000 13.10000 1.07500 1.07800 22.80000 1.00000 29.00000 29.00000 33.00000 30.00000 0.00000 0.00000 12.8000 0.000 0.000 0.000 0.000
39.499 4499.00000 49.0000 -13.28125 -2.00000 4.68100 4.45000 12.50000 1.09800 1.06600 23.30000 1.00000 32.00000 30.00000 33.00000 30.00000 0.00000 0.00000 12.8000 0.000 0.000 0.000 0.000
39.509 4499.00000 49.0000 -13.28125 -2.00000 4.68100 4.45000 12.50000 1.09800 1.06600 23.30000 1.00000 32.00000 30.00000 33.00000 30.00000 0.00000 0.00000 12.8000 0.000 0.000 0.000 0.000
39.519 4499.00000 49.0000 -13.28125 -2.00000 4.68100 4.45000 12.50000 1.09800 1.06600 23.30000 1.00000 32.00000 30.00000 33.00000 30.00000 0.00000 0.00000 12.8000 0.000 0.000 0.000 0.000
39.529 4499.00000 49.0000 -13.28125 -2.00000 4.68100 4.45000 12.50000 1.09800 1.06600 23.30000 1.00000 32.00000 30.00000 33.00000 30.00000 0.00000 0.00000 12.8000 0.000 0.000 0.000 0.000
39.539 4499.00000 49.0000 -13.28125 -2.00000 4.68100 4.45000 12.50000 1.09800 1.06600 23.30000 1.00000 32.00000 30.00000 33.00000 30.00000 0.00000 0.00000 12.8000 0.000 0.000 0.000 0.000
39.549 4446.00000 15.2000 -44.53125 -1.00000 2.20300 2.20300 13.50000 1.09800 1.06600 11.70000 1.00000 10.00000 6.00000 7.00000 6.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
39.559 4446.00000 15.2000 -44.53125 -1.00000 2.20300 2.20300 13.50000 1.09800 1.06600 11.70000 1.00000 10.00000 6.00000 7.00000 6.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
39.569 4446.00000 15.2000 -44.53125 -1.00000 2.20300 2.20300 13.50000 1.09800 1.06600 11.70000 1.00000 10.00000 6.00000 7.00000 6.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
39.579 4446.00000 15.2000 -44.53125 -1.00000 2.20300 2.20300 13.50000 1.09800 1.06600 11.70000 1.00000 10.00000 6.00000 7.00000 6.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
39.589 4446.00000 15.2000 -44.53125 -1.00000 2.20300 2.20300 13.50000 1.09800 1.06600 11.70000 1.00000 10.00000 6.00000 7.00000 6.00000 0.00000 0.00000 12.6000 0.000 0.000 0.000 0.000
39.599 3993.00000 15.1000 -44.53125 0.00000 1.66700 1.66700 12.70000 1.09800 1.06600 7.90000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
39.609 3993.00000 15.1000 -44.53125 0.00000 1.66700 1.66700 12.70000 1.09800 1.06600 7.90000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
39.619 3993.00000 15.1000 -44.53125 0.00000 1.66700 1.66700 12.70000 1.09800 1.06600 7.90000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
39.629 3993.00000 15.1000 -44.53125 0.00000 1.66700 1.66700 12.70000 1.09800 1.06600 7.90000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
39.639 3993.00000 15.1000 -44.53125 0.00000 1.66700 1.66700 12.70000 1.09800 1.06600 7.90000 1.00000 6.00000 6.00000 6.00000 6.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
39.649 3872.00000 15.1000 -44.53125 0.00000 1.80100 1.80100 12.70000 1.09800 1.06600 6.50000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
39.659 3872.00000 15.1000 -44.53125 0.00000 1.80100 1.80100 12.70000 1.09800 1.06600 6.50000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
39.669 3872.00000 15.1000 -44.53125 0.00000 1.80100 1.80100 12.70000 1.09800 1.06600 6.50000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
39.679 3872.00000 15.1000 -44.53125 0.00000 1.80100 1.80100 12.70000 1.09800 1.06600 6.50000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
39.689 3872.00000 15.1000 -44.53125 0.00000 1.80100 1.80100 12.70000 1.09800 1.06600 6.50000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
39.699 3746.00000 15.1000 -44.53125 0.00000 3.46800 3.46800 13.00000 0.90300 1.08500 6.40000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 13.2000 0.000 0.000 0.000 0.000
39.709 3746.00000 15.1000 -44.53125 0.00000 3.46800 3.46800 13.00000 0.90300 1.08500 6.40000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 13.2000 0.000 0.000 0.000 0.000
39.719 3746.00000 15.1000 -44.53125 0.00000 3.46800 3.46800 13.00000 0.90300 1.08500 6.40000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 13.2000 0.000 0.000 0.000 0.000
39.729 3746.00000 15.1000 -44.53125 0.00000 3.46800 3.46800 13.00000 0.90300 1.08500 6.40000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 13.2000 0.000 0.000 0.000 0.000
39.739 3746.00000 15.1000 -44.53125 0.00000 3.46800 3.46800 13.00000 0.90300 1.08500 6.40000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 13.2000 0.000 0.000 0.000 0.000
39.749 3629.00000 15.2000 -44.53125 0.00000 2.50600 2.50600 13.30000 0.90300 1.08500 5.10000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
39.759 3629.00000 15.2000 -44.53125 0.00000 2.50600 2.50600 13.30000 0.90300 1.08500 5.10000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
39.769 3629.00000 15.2000 -44.53125 0.00000 2.50600 2.50600 13.30000 0.90300 1.08500 5.10000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
39.779 3629.00000 15.2000 -44.53125 0.00000 2.50600 2.50600 13.30000 0.90300 1.08500 5.10000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
39.789 3629.00000 15.2000 -44.53125 0.00000 2.50600 2.50600 13.30000 0.90300 1.08500 5.10000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
39.799 3596.00000 15.4000 -44.53125 0.00000 2.53500 2.53500 12.80000 0.90300 1.08500 5.00000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
39.809 3596.00000 15.4000 -44.53125 0.00000 2.53500 2.53500 12.80000 0.90300 1.08500 5.00000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
39.819 3596.00000 15.4000 -44.53125 0.00000 2.53500 2.53500 12.80000 0.90300 1.08500 5.00000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
39.829 3596.00000 15.4000 -44.53125 0.00000 2.53500 2.53500 12.80000 0.90300 1.08500 5.00000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
39.839 3596.00000 15.4000 -44.53125 0.00000 2.53500 2.53500 12.80000 0.90300 1.08500 5.00000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 13.3000 0.000 0.000 0.000 0.000
39.849 3466.00000 15.4000 -44.53125 0.00000 2.27900 2.27900 11.90000 0.90300 1.08500 5.10000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 14.6000 0.000 0.000 0.000 0.000
39.859 3466.00000 15.4000 -44.53125 0.00000 2.27900 2.27900 11.90000 0.90300 1.08500 5.10000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 14.6000 0.000 0.000 0.000 0.000
39.869 3466.00000 15.4000 -44.53125 0.00000 2.27900 2.27900 11.90000 0.90300 1.08500 5.10000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 14.6000 0.000 0.000 0.000 0.000
39.879 3466.00000 15.4000 -44.53125 0.00000 2.27900 2.27900 11.90000 0.90300 1.08500 5.10000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 14.6000 0.000 0.000 0.000 0.000
39.889 3466.00000 15.4000 -44.53125 0.00000 2.27900 2.27900 11.90000 0.90300 1.08500 5.10000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 14.6000 0.000 0.000 0.000 0.000
39.899 3366.00000 15.4000 -44.53125 0.00000 2.23800 2.23800 12.80000 0.92800 1.05900 4.90000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 16.2000 0.000 0.000 0.000 0.000
39.909 3366.00000 15.4000 -44.53125 0.00000 2.23800 2.23800 12.80000 0.92800 1.05900 4.90000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 16.2000 0.000 0.000 0.000 0.000
39.919 3366.00000 15.4000 -44.53125 0.00000 2.23800 2.23800 12.80000 0.92800 1.05900 4.90000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 16.2000 0.000 0.000 0.000 0.000
39.929 3366.00000 15.4000 -44.53125 0.00000 2.23800 2.23800 12.80000 0.92800 1.05900 4.90000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 16.2000 0.000 0.000 0.000 0.000
39.939 3366.00000 15.4000 -44.53125 0.00000 2.23800 2.23800 12.80000 0.92800 1.05900 4.90000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 16.2000 0.000 0.000 0.000 0.000
39.949 3281.00000 15.4000 -44.53125 0.00000 2.59400 2.59400 13.00000 0.92800 1.05900 4.50000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 16.1000 0.000 0.000 0.000 0.000
39.959 3281.00000 15.4000 -44.53125 0.00000 2.59400 2.59400 13.00000 0.92800 1.05900 4.50000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 16.1000 0.000 0.000 0.000 0.000
39.969 3281.00000 15.4000 -44.53125 0.00000 2.59400 2.59400 13.00000 0.92800 1.05900 4.50000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 16.1000 0.000 0.000 0.000 0.000
39.979 3281.00000 15.4000 -44.53125 0.00000 2.59400 2.59400 13.00000 0.92800 1.05900 4.50000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 16.1000 0.000 0.000 0.000 0.000
39.989 3281.00000 15.4000 -44.53125 0.00000 2.59400 2.59400 13.00000 0.92800 1.05900 4.50000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 16.1000 0.000 0.000 0.000 0.000
39.999 3245.00000 15.1000 -44.53125 0.00000 2.53000 2.53000 13.20000 0.92800 1.05900 4.50000 1.00000 5.00000 5.00000 4.00000 5.00000 0.00000 0.00000 16.2000 0.000 0.000 0.000 0.000
40.009 3245.00000 15.1000 -44.53125 0.00000 2.53000 2.53000 13.20000 0.92800 1.05900 4.50000 1.00000 5.00000 5.00000 4.00000 5.00000 0.00000 0.00000 16.2000 0.000 0.000 0.000 0.000
40.019 3245.00000 15.1000 -44.53125 0.00000 2.53000 2.53000 13.20000 0.92800 1.05900 4.50000 1.00000 5.00000 5.00000 4.00000 5.00000 0.00000 0.00000 16.2000 0.000 0.000 0.000 0.000
40.029 3245.00000 15.1000 -44.53125 0.00000 2.53000 2.53000 13.20000 0.92800 1.05900 4.50000 1.00000 5.00000 5.00000 4.00000 5.00000 0.00000 0.00000 16.2000 0.000 0.000 0.000 0.000
40.039 3245.00000 15.1000 -44.53125 0.00000 2.53000 2.53000 13.20000 0.92800 1.05900 4.50000 1.00000 5.00000 5.00000 4.00000 5.00000 0.00000 0.00000 16.2000 0.000 0.000 0.000 0.000
40.049 3232.00000 15.1000 -44.53125 0.00000 2.16800 2.16800 13.40000 0.92800 1.05900 4.50000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
40.059 3232.00000 15.1000 -44.53125 0.00000 2.16800 2.16800 13.40000 0.92800 1.05900 4.50000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
40.069 3232.00000 15.1000 -44.53125 0.00000 2.16800 2.16800 13.40000 0.92800 1.05900 4.50000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
40.079 3232.00000 15.1000 -44.53125 0.00000 2.16800 2.16800 13.40000 0.92800 1.05900 4.50000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
40.089 3232.00000 15.1000 -44.53125 0.00000 2.16800 2.16800 13.40000 0.92800 1.05900 4.50000 1.00000 5.00000 5.00000 5.00000 5.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
40.099 3117.00000 15.2000 -44.53125 0.00000 2.32600 2.32600 13.40000 1.04300 0.99900 4.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
40.109 3117.00000 15.2000 -44.53125 0.00000 2.32600 2.32600 13.40000 1.04300 0.99900 4.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
40.119 3117.00000 15.2000 -44.53125 0.00000 2.32600 2.32600 13.40000 1.04300 0.99900 4.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
40.129 3117.00000 15.2000 -44.53125 0.00000 2.32600 2.32600 13.40000 1.04300 0.99900 4.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
40.139 3117.00000 15.2000 -44.53125 0.00000 2.32600 2.32600 13.40000 1.04300 0.99900 4.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
40.149 3159.00000 15.1000 -44.53125 0.00000 1.74800 1.74800 13.70000 1.04300 0.99900 4.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
40.159 3159.00000 15.1000 -44.53125 0.00000 1.74800 1.74800 13.70000 1.04300 0.99900 4.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
40.169 3159.00000 15.1000 -44.53125 0.00000 1.74800 1.74800 13.70000 1.04300 0.99900 4.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
40.179 3159.00000 15.1000 -44.53125 0.00000 1.74800 1.74800 13.70000 1.04300 0.99900 4.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
40.189 3159.00000 15.1000 -44.53125 0.00000 1.74800 1.74800 13.70000 1.04300 0.99900 4.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 13.5000 0.000 0.000 0.000 0.000
40.199 3064.00000 15.1000 -44.53125 0.00000 1.95200 1.95200 13.50000 1.04300 0.99900 4.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
40.209 3064.00000 15.1000 -44.53125 0.00000 1.95200 1.95200 13.50000 1.04300 0.99900 4.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
40.219 3064.00000 15.1000 -44.53125 0.00000 1.95200 1.95200 13.50000 1.04300 0.99900 4.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
40.229 3064.00000 15.1000 -44.53125 0.00000 1.95200 1.95200 13.50000 1.04300 0.99900 4.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
40.239 3064.00000 15.1000 -44.53125 0.00000 1.95200 1.95200 13.50000 1.04300 0.99900 4.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
40.249 3042.00000 15.4000 -44.53125 0.00000 1.52100 1.52100 12.30000 1.04300 0.99900 4.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
40.259 3042.00000 15.4000 -44.53125 0.00000 1.52100 1.52100 12.30000 1.04300 0.99900 4.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
40.269 3042.00000 15.4000 -44.53125 0.00000 1.52100 1.52100 12.30000 1.04300 0.99900 4.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
40.279 3042.00000 15.4000 -44.53125 0.00000 1.52100 1.52100 12.30000 1.04300 0.99900 4.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
40.289 3042.00000 15.4000 -44.53125 0.00000 1.52100 1.52100 12.30000 1.04300 0.99900 4.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
40.299 2992.00000 15.1000 -44.53125 0.00000 1.64900 1.64900 13.40000 1.14500 1.00800 4.10000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
40.309 2992.00000 15.1000 -44.53125 0.00000 1.64900 1.64900 13.40000 1.14500 1.00800 4.10000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
40.319 2992.00000 15.1000 -44.53125 0.00000 1.64900 1.64900 13.40000 1.14500 1.00800 4.10000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
40.329 2992.00000 15.1000 -44.53125 0.00000 1.64900 1.64900 13.40000 1.14500 1.00800 4.10000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
40.339 2992.00000 15.1000 -44.53125 0.00000 1.64900 1.64900 13.40000 1.14500 1.00800 4.10000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 12.4000 0.000 0.000 0.000 0.000
40.349 2949.00000 15.1000 -44.53125 0.00000 1.55000 1.55000 13.40000 1.14500 1.00800 4.10000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 10.7000 0.000 0.000 0.000 0.000
40.359 2949.00000 15.1000 -44.53125 0.00000 1.55000 1.55000 13.40000 1.14500 1.00800 4.10000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 10.7000 0.000 0.000 0.000 0.000
40.369 2949.00000 15.1000 -44.53125 0.00000 1.55000 1.55000 13.40000 1.14500 1.00800 4.10000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 10.7000 0.000 0.000 0.000 0.000
40.379 2949.00000 15.1000 -44.53125 0.00000 1.55000 1.55000 13.40000 1.14500 1.00800 4.10000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 10.7000 0.000 0.000 0.000 0.000
40.389 2949.00000 15.1000 -44.53125 0.00000 1.55000 1.55000 13.40000 1.14500 1.00800 4.10000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 10.7000 0.000 0.000 0.000 0.000
40.399 2949.00000 15.1000 -44.53125 0.00000 1.55000 1.55000 13.40000 1.14500 1.00800 4.10000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 10.7000 0.000 0.000 0.000 0.000
40.409 2801.00000 15.2000 -44.53125 0.00000 1.83600 1.83600 13.30000 1.14500 1.00800 4.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 10.8000 0.000 0.000 0.000 0.000
40.419 2801.00000 15.2000 -44.53125 0.00000 1.83600 1.83600 13.30000 1.14500 1.00800 4.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 10.8000 0.000 0.000 0.000 0.000
40.429 2801.00000 15.2000 -44.53125 0.00000 1.83600 1.83600 13.30000 1.14500 1.00800 4.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 10.8000 0.000 0.000 0.000 0.000
40.439 2801.00000 15.2000 -44.53125 0.00000 1.83600 1.83600 13.30000 1.14500 1.00800 4.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 10.8000 0.000 0.000 0.000 0.000
40.449 2801.00000 15.2000 -44.53125 0.00000 1.83600 1.83600 13.30000 1.14500 1.00800 4.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 10.8000 0.000 0.000 0.000 0.000
40.459 2643.00000 15.1000 -44.53125 0.00000 2.31400 2.31400 13.50000 1.08800 1.04600 4.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 10.7000 0.000 0.000 0.000 0.000
40.469 2643.00000 15.1000 -44.53125 0.00000 2.31400 2.31400 13.50000 1.08800 1.04600 4.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 10.7000 0.000 0.000 0.000 0.000
40.479 2643.00000 15.1000 -44.53125 0.00000 2.31400 2.31400 13.50000 1.08800 1.04600 4.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 10.7000 0.000 0.000 0.000 0.000
40.489 2643.00000 15.1000 -44.53125 0.00000 2.31400 2.31400 13.50000 1.08800 1.04600 4.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 10.7000 0.000 0.000 0.000 0.000
40.499 2643.00000 15.1000 -44.53125 0.00000 2.31400 2.31400 13.50000 1.08800 1.04600 4.20000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 10.7000 0.000 0.000 0.000 0.000
40.509 2615.00000 15.1000 -44.53125 0.00000 1.52100 1.52100 13.60000 1.08800 1.04600 4.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 10.7000 0.000 0.000 0.000 0.000
40.519 2615.00000 15.1000 -44.53125 0.00000 1.52100 1.52100 13.60000 1.08800 1.04600 4.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 10.7000 0.000 0.000 0.000 0.000
40.529 2615.00000 15.1000 -44.53125 0.00000 1.52100 1.52100 13.60000 1.08800 1.04600 4.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 10.7000 0.000 0.000 0.000 0.000
40.539 2615.00000 15.1000 -44.53125 0.00000 1.52100 1.52100 13.60000 1.08800 1.04600 4.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 10.7000 0.000 0.000 0.000 0.000
40.549 2615.00000 15.1000 -44.53125 0.00000 1.52100 1.52100 13.60000 1.08800 1.04600 4.30000 1.00000 4.00000 4.00000 4.00000 4.00000 0.00000 0.00000 10.7000 0.000 0.000 0.000 0.000
40.559 2478.00000 15.2000 -44.53125 0.00000 2.13300 2.13300 12.70000 1.08800 1.04600 4.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 10.7000 0.000 0.000 0.000 0.000
40.569 2478.00000 15.2000 -44.53125 0.00000 2.13300 2.13300 12.70000 1.08800 1.04600 4.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 10.7000 0.000 0.000 0.000 0.000
40.579 2478.00000 15.2000 -44.53125 0.00000 2.13300 2.13300 12.70000 1.08800 1.04600 4.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 10.7000 0.000 0.000 0.000 0.000
40.589 2478.00000 15.2000 -44.53125 0.00000 2.13300 2.13300 12.70000 1.08800 1.04600 4.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 10.7000 0.000 0.000 0.000 0.000
40.599 2478.00000 15.2000 -44.53125 0.00000 2.13300 2.13300 12.70000 1.08800 1.04600 4.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 10.7000 0.000 0.000 0.000 0.000
40.609 2391.00000 15.1000 -44.53125 0.00000 2.18000 2.18000 13.30000 1.08800 1.04600 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 10.7000 0.000 0.000 0.000 0.000
40.619 2391.00000 15.1000 -44.53125 0.00000 2.18000 2.18000 13.30000 1.08800 1.04600 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 10.7000 0.000 0.000 0.000 0.000
40.629 2391.00000 15.1000 -44.53125 0.00000 2.18000 2.18000 13.30000 1.08800 1.04600 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 10.7000 0.000 0.000 0.000 0.000
40.639 2391.00000 15.1000 -44.53125 0.00000 2.18000 2.18000 13.30000 1.08800 1.04600 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 10.7000 0.000 0.000 0.000 0.000
40.649 2391.00000 15.1000 -44.53125 0.00000 2.18000 2.18000 13.30000 1.08800 1.04600 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 10.7000 0.000 0.000 0.000 0.000
40.659 2303.00000 15.4000 -44.53125 0.00000 2.12700 2.12700 13.30000 0.25800 1.09400 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
40.669 2303.00000 15.4000 -44.53125 0.00000 2.12700 2.12700 13.30000 0.25800 1.09400 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
40.679 2303.00000 15.4000 -44.53125 0.00000 2.12700 2.12700 13.30000 0.25800 1.09400 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
40.689 2303.00000 15.4000 -44.53125 0.00000 2.12700 2.12700 13.30000 0.25800 1.09400 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
40.699 2303.00000 15.4000 -44.53125 0.00000 2.12700 2.12700 13.30000 0.25800 1.09400 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.3000 0.000 0.000 0.000 0.000
40.709 2118.00000 15.2000 -44.53125 0.00000 1.55000 1.55000 12.90000 0.25800 1.09400 4.70000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
40.719 2118.00000 15.2000 -44.53125 0.00000 1.55000 1.55000 12.90000 0.25800 1.09400 4.70000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
40.729 2118.00000 15.2000 -44.53125 0.00000 1.55000 1.55000 12.90000 0.25800 1.09400 4.70000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
40.739 2118.00000 15.2000 -44.53125 0.00000 1.55000 1.55000 12.90000 0.25800 1.09400 4.70000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
40.749 2118.00000 15.2000 -44.53125 0.00000 1.55000 1.55000 12.90000 0.25800 1.09400 4.70000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
40.759 2013.00000 15.2000 -44.53125 0.00000 1.53900 1.53900 13.30000 0.25800 1.09400 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
40.769 2013.00000 15.2000 -44.53125 0.00000 1.53900 1.53900 13.30000 0.25800 1.09400 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
40.779 2013.00000 15.2000 -44.53125 0.00000 1.53900 1.53900 13.30000 0.25800 1.09400 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
40.789 2013.00000 15.2000 -44.53125 0.00000 1.53900 1.53900 13.30000 0.25800 1.09400 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
40.799 2013.00000 15.2000 -44.53125 0.00000 1.53900 1.53900 13.30000 0.25800 1.09400 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 15.2000 0.000 0.000 0.000 0.000
40.809 1984.00000 15.1000 -44.53125 0.00000 1.43400 1.43400 13.40000 0.25800 1.09400 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
40.819 1984.00000 15.1000 -44.53125 0.00000 1.43400 1.43400 13.40000 0.25800 1.09400 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
40.829 1984.00000 15.1000 -44.53125 0.00000 1.43400 1.43400 13.40000 0.25800 1.09400 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
40.839 1984.00000 15.1000 -44.53125 0.00000 1.43400 1.43400 13.40000 0.25800 1.09400 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
40.849 1984.00000 15.1000 -44.53125 0.00000 1.43400 1.43400 13.40000 0.25800 1.09400 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
40.859 1974.00000 15.2000 -44.53125 0.00000 2.01700 2.01700 13.50000 0.25500 1.10700 4.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.4000 0.000 0.000 0.000 0.000
40.869 1974.00000 15.2000 -44.53125 0.00000 2.01700 2.01700 13.50000 0.25500 1.10700 4.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.4000 0.000 0.000 0.000 0.000
40.879 1974.00000 15.2000 -44.53125 0.00000 2.01700 2.01700 13.50000 0.25500 1.10700 4.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.4000 0.000 0.000 0.000 0.000
40.889 1974.00000 15.2000 -44.53125 0.00000 2.01700 2.01700 13.50000 0.25500 1.10700 4.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.4000 0.000 0.000 0.000 0.000
40.899 1974.00000 15.2000 -44.53125 0.00000 2.01700 2.01700 13.50000 0.25500 1.10700 4.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.4000 0.000 0.000 0.000 0.000
40.909 1997.00000 15.2000 -44.53125 0.00000 1.95800 1.95800 12.70000 0.25500 1.10700 4.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
40.919 1997.00000 15.2000 -44.53125 0.00000 1.95800 1.95800 12.70000 0.25500 1.10700 4.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
40.929 1997.00000 15.2000 -44.53125 0.00000 1.95800 1.95800 12.70000 0.25500 1.10700 4.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
40.939 1997.00000 15.2000 -44.53125 0.00000 1.95800 1.95800 12.70000 0.25500 1.10700 4.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
40.949 1997.00000 15.2000 -44.53125 0.00000 1.95800 1.95800 12.70000 0.25500 1.10700 4.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
40.959 2004.00000 15.1000 -44.53125 0.00000 1.69600 1.69600 13.20000 0.25500 1.10700 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
40.969 2004.00000 15.1000 -44.53125 0.00000 1.69600 1.69600 13.20000 0.25500 1.10700 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
40.979 2004.00000 15.1000 -44.53125 0.00000 1.69600 1.69600 13.20000 0.25500 1.10700 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
40.989 2004.00000 15.1000 -44.53125 0.00000 1.69600 1.69600 13.20000 0.25500 1.10700 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
40.999 2004.00000 15.1000 -44.53125 0.00000 1.69600 1.69600 13.20000 0.25500 1.10700 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
41.009 2046.00000 15.2000 -44.53125 0.00000 1.87700 1.87700 13.40000 0.25500 1.10700 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.7000 0.000 0.000 0.000 0.000
41.019 2046.00000 15.2000 -44.53125 0.00000 1.87700 1.87700 13.40000 0.25500 1.10700 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.7000 0.000 0.000 0.000 0.000
41.029 2046.00000 15.2000 -44.53125 0.00000 1.87700 1.87700 13.40000 0.25500 1.10700 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.7000 0.000 0.000 0.000 0.000
41.039 2046.00000 15.2000 -44.53125 0.00000 1.87700 1.87700 13.40000 0.25500 1.10700 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.7000 0.000 0.000 0.000 0.000
41.049 2046.00000 15.2000 -44.53125 0.00000 1.87700 1.87700 13.40000 0.25500 1.10700 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.7000 0.000 0.000 0.000 0.000
41.059 2000.00000 15.2000 -44.53125 0.00000 1.85900 1.85900 13.30000 0.67000 1.06200 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
41.069 2000.00000 15.2000 -44.53125 0.00000 1.85900 1.85900 13.30000 0.67000 1.06200 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
41.079 2000.00000 15.2000 -44.53125 0.00000 1.85900 1.85900 13.30000 0.67000 1.06200 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
41.089 2000.00000 15.2000 -44.53125 0.00000 1.85900 1.85900 13.30000 0.67000 1.06200 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
41.099 2000.00000 15.2000 -44.53125 0.00000 1.85900 1.85900 13.30000 0.67000 1.06200 4.50000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.6000 0.000 0.000 0.000 0.000
41.109 1996.00000 15.2000 -44.53125 0.00000 1.88300 1.88300 13.40000 0.67000 1.06200 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.4000 0.000 0.000 0.000 0.000
41.119 1996.00000 15.2000 -44.53125 0.00000 1.88300 1.88300 13.40000 0.67000 1.06200 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.4000 0.000 0.000 0.000 0.000
41.129 1996.00000 15.2000 -44.53125 0.00000 1.88300 1.88300 13.40000 0.67000 1.06200 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.4000 0.000 0.000 0.000 0.000
41.139 1996.00000 15.2000 -44.53125 0.00000 1.88300 1.88300 13.40000 0.67000 1.06200 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.4000 0.000 0.000 0.000 0.000
41.149 1996.00000 15.2000 -44.53125 0.00000 1.88300 1.88300 13.40000 0.67000 1.06200 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.4000 0.000 0.000 0.000 0.000
41.159 1992.00000 15.1000 -44.53125 0.00000 1.57400 1.57400 13.20000 0.67000 1.06200 4.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
41.169 1992.00000 15.1000 -44.53125 0.00000 1.57400 1.57400 13.20000 0.67000 1.06200 4.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
41.179 1992.00000 15.1000 -44.53125 0.00000 1.57400 1.57400 13.20000 0.67000 1.06200 4.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
41.189 1992.00000 15.1000 -44.53125 0.00000 1.57400 1.57400 13.20000 0.67000 1.06200 4.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
41.199 1992.00000 15.1000 -44.53125 0.00000 1.57400 1.57400 13.20000 0.67000 1.06200 4.40000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.5000 0.000 0.000 0.000 0.000
41.209 2012.00000 15.1000 -44.53125 0.00000 1.50400 1.50400 13.50000 0.67000 1.06200 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.4000 0.000 0.000 0.000 0.000
41.219 2012.00000 15.1000 -44.53125 0.00000 1.50400 1.50400 13.50000 0.67000 1.06200 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.4000 0.000 0.000 0.000 0.000
41.229 2012.00000 15.1000 -44.53125 0.00000 1.50400 1.50400 13.50000 0.67000 1.06200 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.4000 0.000 0.000 0.000 0.000
41.239 2012.00000 15.1000 -44.53125 0.00000 1.50400 1.50400 13.50000 0.67000 1.06200 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.4000 0.000 0.000 0.000 0.000
41.249 2012.00000 15.1000 -44.53125 0.00000 1.50400 1.50400 13.50000 0.67000 1.06200 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 18.4000 0.000 0.000 0.000 0.000
41.259 1966.00000 15.1000 -44.53125 0.00000 1.30000 1.30000 13.50000 1.12000 0.35700 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.1000 0.000 0.000 0.000 0.000
41.269 1966.00000 15.1000 -44.53125 0.00000 1.30000 1.30000 13.50000 1.12000 0.35700 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.1000 0.000 0.000 0.000 0.000
41.279 1966.00000 15.1000 -44.53125 0.00000 1.30000 1.30000 13.50000 1.12000 0.35700 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.1000 0.000 0.000 0.000 0.000
41.289 1966.00000 15.1000 -44.53125 0.00000 1.30000 1.30000 13.50000 1.12000 0.35700 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.1000 0.000 0.000 0.000 0.000
41.299 1966.00000 15.1000 -44.53125 0.00000 1.30000 1.30000 13.50000 1.12000 0.35700 4.30000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 14.1000 0.000 0.000 0.000 0.000
41.309 1944.00000 15.1000 -44.53125 0.00000 1.44500 1.44500 13.40000 1.12000 0.35700 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 13.8000 0.000 0.000 0.000 0.000
41.319 1944.00000 15.1000 -44.53125 0.00000 1.44500 1.44500 13.40000 1.12000 0.35700 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 13.8000 0.000 0.000 0.000 0.000
41.329 1944.00000 15.1000 -44.53125 0.00000 1.44500 1.44500 13.40000 1.12000 0.35700 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 13.8000 0.000 0.000 0.000 0.000
41.339 1944.00000 15.1000 -44.53125 0.00000 1.44500 1.44500 13.40000 1.12000 0.35700 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 13.8000 0.000 0.000 0.000 0.000
41.349 1944.00000 15.1000 -44.53125 0.00000 1.44500 1.44500 13.40000 1.12000 0.35700 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 13.8000 0.000 0.000 0.000 0.000
41.359 1964.00000 15.1000 -44.53125 0.00000 1.89400 1.89400 13.60000 1.12000 0.35700 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
41.369 1964.00000 15.1000 -44.53125 0.00000 1.89400 1.89400 13.60000 1.12000 0.35700 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
41.379 1964.00000 15.1000 -44.53125 0.00000 1.89400 1.89400 13.60000 1.12000 0.35700 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
41.389 1964.00000 15.1000 -44.53125 0.00000 1.89400 1.89400 13.60000 1.12000 0.35700 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
41.399 1964.00000 15.1000 -44.53125 0.00000 1.89400 1.89400 13.60000 1.12000 0.35700 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 13.9000 0.000 0.000 0.000 0.000
41.409 1901.00000 15.2000 -44.53125 0.00000 1.88300 1.88300 12.30000 1.12000 0.35700 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
41.419 1901.00000 15.2000 -44.53125 0.00000 1.88300 1.88300 12.30000 1.12000 0.35700 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
41.429 1901.00000 15.2000 -44.53125 0.00000 1.88300 1.88300 12.30000 1.12000 0.35700 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
41.439 1901.00000 15.2000 -44.53125 0.00000 1.88300 1.88300 12.30000 1.12000 0.35700 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
41.449 1901.00000 15.2000 -44.53125 0.00000 1.88300 1.88300 12.30000 1.12000 0.35700 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 13.0000 0.000 0.000 0.000 0.000
41.459 1888.00000 15.2000 -44.53125 0.00000 1.18300 1.18300 13.10000 1.14500 0.27400 4.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.9000 0.000 0.000 0.000 0.000
41.469 1888.00000 15.2000 -44.53125 0.00000 1.18300 1.18300 13.10000 1.14500 0.27400 4.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.9000 0.000 0.000 0.000 0.000
41.479 1888.00000 15.2000 -44.53125 0.00000 1.18300 1.18300 13.10000 1.14500 0.27400 4.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.9000 0.000 0.000 0.000 0.000
41.489 1888.00000 15.2000 -44.53125 0.00000 1.18300 1.18300 13.10000 1.14500 0.27400 4.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.9000 0.000 0.000 0.000 0.000
41.499 1888.00000 15.2000 -44.53125 0.00000 1.18300 1.18300 13.10000 1.14500 0.27400 4.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.9000 0.000 0.000 0.000 0.000
41.509 1862.00000 15.1000 -44.53125 0.00000 1.74800 1.74800 13.10000 1.14500 0.27400 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.9000 0.000 0.000 0.000 0.000
41.519 1862.00000 15.1000 -44.53125 0.00000 1.74800 1.74800 13.10000 1.14500 0.27400 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.9000 0.000 0.000 0.000 0.000
41.529 1862.00000 15.1000 -44.53125 0.00000 1.74800 1.74800 13.10000 1.14500 0.27400 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.9000 0.000 0.000 0.000 0.000
41.539 1862.00000 15.1000 -44.53125 0.00000 1.74800 1.74800 13.10000 1.14500 0.27400 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.9000 0.000 0.000 0.000 0.000
41.549 1862.00000 15.1000 -44.53125 0.00000 1.74800 1.74800 13.10000 1.14500 0.27400 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.9000 0.000 0.000 0.000 0.000
41.559 1872.00000 15.1000 -44.53125 0.00000 1.45100 1.45100 13.60000 1.14500 0.27400 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.7000 0.000 0.000 0.000 0.000
41.569 1872.00000 15.1000 -44.53125 0.00000 1.45100 1.45100 13.60000 1.14500 0.27400 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.7000 0.000 0.000 0.000 0.000
41.579 1872.00000 15.1000 -44.53125 0.00000 1.45100 1.45100 13.60000 1.14500 0.27400 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.7000 0.000 0.000 0.000 0.000
41.589 1872.00000 15.1000 -44.53125 0.00000 1.45100 1.45100 13.60000 1.14500 0.27400 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.7000 0.000 0.000 0.000 0.000
41.599 1872.00000 15.1000 -44.53125 0.00000 1.45100 1.45100 13.60000 1.14500 0.27400 4.20000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.7000 0.000 0.000 0.000 0.000
41.609 1808.00000 15.2000 -44.53125 0.00000 1.13600 1.13600 13.80000 1.14500 0.27400 4.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
41.619 1808.00000 15.2000 -44.53125 0.00000 1.13600 1.13600 13.80000 1.14500 0.27400 4.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
41.629 1808.00000 15.2000 -44.53125 0.00000 1.13600 1.13600 13.80000 1.14500 0.27400 4.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
41.639 1808.00000 15.2000 -44.53125 0.00000 1.13600 1.13600 13.80000 1.14500 0.27400 4.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
41.649 1808.00000 15.2000 -44.53125 0.00000 1.13600 1.13600 13.80000 1.14500 0.27400 4.10000 1.00000 3.00000 3.00000 3.00000 3.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
41.659 1763.00000 15.1000 -44.53125 0.00000 1.85300 1.85300 13.20000 1.14500 0.30600 4.10000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
41.669 1763.00000 15.1000 -44.53125 0.00000 1.85300 1.85300 13.20000 1.14500 0.30600 4.10000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
41.679 1763.00000 15.1000 -44.53125 0.00000 1.85300 1.85300 13.20000 1.14500 0.30600 4.10000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
41.689 1763.00000 15.1000 -44.53125 0.00000 1.85300 1.85300 13.20000 1.14500 0.30600 4.10000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
41.699 1763.00000 15.1000 -44.53125 0.00000 1.85300 1.85300 13.20000 1.14500 0.30600 4.10000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
41.709 1763.00000 15.1000 -44.53125 0.00000 1.24100 1.24100 13.50000 1.14500 0.30600 4.10000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
41.719 1763.00000 15.1000 -44.53125 0.00000 1.24100 1.24100 13.50000 1.14500 0.30600 4.10000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
41.729 1763.00000 15.1000 -44.53125 0.00000 1.24100 1.24100 13.50000 1.14500 0.30600 4.10000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
41.739 1763.00000 15.1000 -44.53125 0.00000 1.24100 1.24100 13.50000 1.14500 0.30600 4.10000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
41.749 1763.00000 15.1000 -44.53125 0.00000 1.24100 1.24100 13.50000 1.14500 0.30600 4.10000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.5000 0.000 0.000 0.000 0.000
41.759 1688.00000 15.2000 -44.53125 0.00000 1.31100 1.31100 13.10000 1.14500 0.30600 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.2000 0.000 0.000 0.000 0.000
41.769 1688.00000 15.2000 -44.53125 0.00000 1.31100 1.31100 13.10000 1.14500 0.30600 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.2000 0.000 0.000 0.000 0.000
41.779 1688.00000 15.2000 -44.53125 0.00000 1.31100 1.31100 13.10000 1.14500 0.30600 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.2000 0.000 0.000 0.000 0.000
41.789 1688.00000 15.2000 -44.53125 0.00000 1.31100 1.31100 13.10000 1.14500 0.30600 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.2000 0.000 0.000 0.000 0.000
41.799 1688.00000 15.2000 -44.53125 0.00000 1.31100 1.31100 13.10000 1.14500 0.30600 4.30000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.2000 0.000 0.000 0.000 0.000
41.809 1519.00000 15.2000 -44.53125 0.00000 1.42800 1.42800 13.40000 1.14500 0.30600 4.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.3000 0.000 0.000 0.000 0.000
41.819 1519.00000 15.2000 -44.53125 0.00000 1.42800 1.42800 13.40000 1.14500 0.30600 4.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.3000 0.000 0.000 0.000 0.000
41.829 1519.00000 15.2000 -44.53125 0.00000 1.42800 1.42800 13.40000 1.14500 0.30600 4.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.3000 0.000 0.000 0.000 0.000
41.839 1519.00000 15.2000 -44.53125 0.00000 1.42800 1.42800 13.40000 1.14500 0.30600 4.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.3000 0.000 0.000 0.000 0.000
41.849 1519.00000 15.2000 -44.53125 0.00000 1.42800 1.42800 13.40000 1.14500 0.30600 4.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.3000 0.000 0.000 0.000 0.000
41.859 1392.00000 15.2000 -44.53125 0.00000 1.70200 1.70200 13.20000 1.12600 0.34400 4.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.3000 0.000 0.000 0.000 0.000
41.869 1392.00000 15.2000 -44.53125 0.00000 1.70200 1.70200 13.20000 1.12600 0.34400 4.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.3000 0.000 0.000 0.000 0.000
41.879 1392.00000 15.2000 -44.53125 0.00000 1.70200 1.70200 13.20000 1.12600 0.34400 4.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.3000 0.000 0.000 0.000 0.000
41.889 1392.00000 15.2000 -44.53125 0.00000 1.70200 1.70200 13.20000 1.12600 0.34400 4.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.3000 0.000 0.000 0.000 0.000
41.899 1392.00000 15.2000 -44.53125 0.00000 1.70200 1.70200 13.20000 1.12600 0.34400 4.40000 1.00000 2.00000 2.00000 2.00000 2.00000 0.00000 0.00000 12.3000 0.000 0.000 0.000 0.000
41.909 1392.00000 15.2000 -44.53125 0.00000 1.74300 1.74300 13.40000 1.12600 0.34400
