megasquirt
ok, i have a local who is trying to bring me to the dark side. he says he can assemble and help tune, those who are running this what all do i need to know?
spoon feed me plz, ill either go ms2 or ms3 havent decided yet.
megasquirt forums have some hyundai folk that I don't recognise from here
Nothing revolutionary, I think half the battle is picking your hardware and sensors. The other two halves are 'y won't it run right tho'
Currently running MS1 dont have alot of info for you on MS2 or 3 as far as software setup is concerned, MS2&3 are a whole different beast when it comes to setting, however you really dont need anything other then the MS itself, the rest is wiring up and getting you sensor values correct with easytherm. I have tried to upgrade to Ms 2 but had bad CKP signal errors and no time to mess with it so I stepped back to Ms1 and a good running tune. Once its up and running it will be life changing. Join the dark side ==== "plays imperial march as back ground music".
