max boost without aftermarket ems
Old Jun 9, 2002 | 06:40 PM
Wolfie's Avatar
Vehicle: 2000 Tiburon
Default max boost without aftermarket ems
Quick question:
What is the Max boost a MAP based 97 tib can take without introducing an engine management system such as haltechs e6k ?
Old Jun 9, 2002 | 07:04 PM
Wolfie's Avatar
can it take 5psi or so?
anyone?
Old Jun 9, 2002 | 07:08 PM
Shadohh's Avatar
I dont think anyone is gonna touch this.
but onpol ran 10psi on his stock system with 440cc and an safc.
Old Jun 9, 2002 | 09:55 PM
Curtas's Avatar
I'm going to attempt 5 to 7 psi with just a rising rate fuel pressure regulator and upgraded fuel pump.
That's about the limit of what I want to do. It is possible; but you have to do it right:
fuel pump must be able to keep a proper A/F ratio under boost conditions.
fuel pressure regulator must be properly tuned.
you must have the right amount of intercooling.
Even with all this, 5 psi is all that is safe. Above that, you start maxing out the ignition timing limits. At around 7 psi, you max out the fuel system (even with an RRFPR and better pump).
I'm hoping to start installation in two months. I'll let you know how it goes.
As always: pick up a copy of Maximum Boost, by Corky Bell. a good turbocharger book.
ac
Old Jun 9, 2002 | 11:02 PM
fastiburon's Avatar
1 bar= how many psi???
Old Jun 10, 2002 | 12:35 AM
Red's Avatar
Red
1 Bar = 14.7psi
Boost isn't what you need to think about, total airflow is what you should be concerned with. Think about this: you are given two straws. The first straw is one of those tiny little red/pink coffee-stir straws, the second one is a frikken huge McDonalds straw.
If you pressurize both of these straws to 10psi, which one will flow more air? Ok, so why does 10psi on a boost gauge relate to much of anything when you're talking about horsepower?
It doesn't.
The dependancy here is the amount of air you're moving; pressure is definately required but isn't the correct measuring tool.
If you just want to strap on a turbo or supercharger without touching ANYTHING else, the most you can probably do is about 150WHP max. If you don't mind strapping on a bigger fuel pump, a set of bigger (440cc or 550cc) injectors and an S-AFC piggyback (that's about $700 in parts altogether) then you can probably run 220-230WHP on the stock computer max.
That's about it. Anything above that is going to require new internal engine parts (pistons anyway) and will require better computer equipment.
Old Jun 10, 2002 | 02:36 AM
JAWS 021's Avatar
Red:
Old Jun 10, 2002 | 02:42 AM
Red's Avatar
Red
I just realized you said MAP based '97 Tiburon. How exactly do you have a 1st Gen Tiburon running a MAP-based computer system? You must not be in North America...
If you truly are not in North America or Puerto Rico, then you likely do have a MAP sensor.
That being the case, there's not many people here who could tell you. The MAP-based Hyundai computers don't like S-AFC piggyback controllers, so you're out of luck with the bigger injector + SAFC fix.
And the very first moment that your computer sees more than about 1-2psi of positive pressure on the manifold, you're going to get a check-engine light.
If you're running MAP, you will HAVE to run all the fuel modifications mechanically instead of electronically. You can bump your injectors to something like 370cc, install an adjustable static fuel pressure regulator set at like 20psi (for idle), then install an adjustable rising-rate fuel pressure regulator for when you're on-bosot (something like a 3:1 or 4:1 setting). Then you'll need the requisite new fuel pump, some method of blocking your MAP sensor from "seeing" boost (but still reading vacuum) and a lot of tuning time on the dyno.
This is all likely more expensive and a little less accurate than the MAF-based options, but it would probably still allow your stock computer + engine to see the 200WHP mark.
Old Jun 10, 2002 | 04:44 AM
Decker's Avatar
so you the engine can handle 220whp or so by just strapping on a turbo and new injectors? (btw i already have a s-afc and fuel pump).
Old Jun 10, 2002 | 04:51 AM
Dixiflatline's Avatar
Curtas:
ac
I assume you are talking about ignightion Retard.
What if he found a way to avoid Det..
Would 7 be doable.
Or am I just reading this wrong.
