Map Ecu
Has anyone tried on of these on a tiburon before, I read up on it and seems most people that use it love it but they say that about the emanage to and I'm not having much luck with that thing, I really don't wanna run the extra injectors anymore and the MAP ECU looks like it might work good plus it eliminates the MAF, what do think, should I give it a shot
MAP ECU
MAP ECU
^^ I thought about that but if you make any modifications to your car you have to send it back for a reflash again or add on the piggy back ecu for extra tuning ability, the map ecu converts your car to MAP and you can tune it whenever you want, I'm just not sure how it will work on the tib.
no, only if you make any MAJOR modifications. It's just another stock ecu basically...meaning if you get a CAI, reset it and it will relearn and adjust itself a little. Get headers, same thing. But if you want to add nitrous or boost or something....well then of course you'll need a reflash. Same if you get cams or do something wild.
