Look At This Manifold
Cruising around on Ebay I found this Turbo Manifold. What do you think? I prefer an external waste gate set up but this seems like a cheap option for somebody on a budget. It looks cracked though.
not worth it. the cracks wouldnt be hard to fix, weld wise. but then you would have to have the flange refaced which would probably cot more than you want to go.
yeah, those 'slots' are in there stock, like deniss said.
theres no actual 'cracks' that i can see in that pic.
that manifold looks like it would sit to low for one. also, the stock manifolds were recalled for cracking, and no telling if this was done before or after the problem was fixed.
o, and if your on a budget, that is THAT tight, dont boost. trust me.
