Run on Aluminum as a front mount, and use 3m Window weld on the back, then run your Trq dampner!
Works well and it is cheap, just the way you like! |
I heard someone else have a solid mount setup too and said the vibration is crazy! I also hear complains about mount bushing popping out. Ughh I'll go ahead and order kspec mounts...
My old k-spec mounts broke after about 50,000 miles and I ended up filling the insides completely with polyeurathane. The new k-spec mounts appear to be solid polyeurathane. Be prepared for steering wheel vibration @ idle, but after idle the vibration completely stops. I even have brand new oem rubber mounts on both upper mounts to see if that would help with the vibration but that only helped a little.
I drive my car hard and it's worth the vibration when your shifting at full throttle and if I was to do it all over again I would still use poly motor mounts. |
i have had the kspecs for about 2 months... they don't vibrate that bad
I use k spec on both bottoms,new oems for the sides and have no vibes...
So do people have just as many problems with Kspec as shark racing or evofusion? There are some parts I would like but haven't ordered cause I wasn't sure I would ever get them.
I've purchased from Kspec recently and received the item quickly. But it seems hit or miss. Or it could be that they sell sooo many products around the world, that you only hear a very small percent of those people complaining.
I bought the front and rear mounts several years ago. The vibration was insignificant to the better feel of shifting. These bushings help more with the added amount of power you have. The more power, the more twisting. Personally, I'm ready to get solid mounts. |
