If You Have Pauter Rods........!
Old Jun 11, 2008 | 03:03 PM
  #21
Regit's Avatar
Vehicle: 2000 tib
Thanks!!, I'm trying to make sure I do everything right.
Old Jun 12, 2008 | 09:44 PM
  #22
Denisst99's Avatar
John,
just checked a new set of pauter rods and they have the same shiny spot you have on yours
so it's not hitting,it's the spot made when they final hone them,
when they hit the block they hit much lower on the rod (toward the big end)
Old Jun 12, 2008 | 09:55 PM
  #23
Regit's Avatar
Vehicle: 2000 tib
I'll have to check mine when they arrive for honing ding. , so I should be fine with a 1/4 inch then?
Old Jun 12, 2008 | 11:29 PM
  #24
Denisst99's Avatar
you need 1/16" (0.0625") of clearance
if you have 1/4" you grinded way to omuch out of the bottom of the cylinders
Old Jun 13, 2008 | 03:23 AM
  #25
Regit's Avatar
Vehicle: 2000 tib
Old Jun 14, 2008 | 07:29 PM
  #26
2uniq's Avatar
If im not mistaken i think mine was about a 1/4 inch and i have no issues.
Old Jun 14, 2008 | 08:46 PM
  #27
Denisst99's Avatar
i never came acrosa bloc wich gave 14" of clearance without machine work...
Pauter ask for 1/16" of clearance wich is the norm when using aftermarket stuff
removing to omuch material from the lower part of the cylinder can make you break in the water jackets
and if you make the notch too long and high wil leave a nice spot in the piston itself after running a while
Old Jun 14, 2008 | 10:10 PM
  #28
Regit's Avatar
Vehicle: 2000 tib
Pauter is having my rods rifle drilled,so I should have em in about 2 weeks fing02.gif .
Old Jun 17, 2008 | 09:19 AM
  #29
David Dickson's Avatar
You mean 1/4" not 14" of clearence right? lol
Mine have about 1/4" of clearence on my Beta2 block so I'm good to go!!
John did you ever plastigague your rod bearing journals? Maybe you have too much clearence and that is the cause of your spun bearing?
Old Jun 18, 2008 | 12:25 AM
  #30
Denisst99's Avatar
yeah it's a typo
1/4" of clearance should have been writen
but anyway
1/16" is safe enough,no need to over grind the lower part of the cylinders
