I need Alpine Turbo install instructions.
I bought a used kit and it doesn't have instructions. If some one could copy them and mail them to me I would be ver happy. I have asked Alpine 4 times and they say they are sending them...... |
Open hood
install turbo close hood lol.gif Seriously dude, it's a long complicated process. I can give you the basics though. Raise hood Jack up car, put up on jack stands Remove stock intake manifold/1st cat Remove front bumper (going to be easier without this on the car.) remove intake system Install turbocharger manifold and turbo. Install charge piping to intercooler install intercooler remove Injectors/Fuel rail Remove intake manifold Remove head Install decompression plate Re-install head re-install intake manifold re-install fuel rail/injectors install charge piping to throttle body re-install front bumper Close hood. Now the fun stuff starts. Wiring in the unichip and the 5th injector! I've got the wiring diagrams around somewhere. Drop me an email and I'll send them to you. |
Should be Remove Exhaust Manifold and 1st Cat. Random if you edit it I'll delete this. Didn't want to go editing your posts for you.... laugh.gif
also.. you might want to install the decompression plate BEFORE you install the turbo header..
lol tongue.gif |
Thanks for the GREAT and HELPFULL replies guys. I should expect no less from the top guys on this site.
Seriously, I need the actual instructions. I know where everything goes but have some questions. I am not using the decomp plate, unichip or fifth injector |
what questions do you have? what are you using in place of those items? email alpine. |
I already emailed alpine for instructions 4 times....... They tell me they are mailing me instructions every time. I still have not recieved any months later
In place of the fifth injector and unichip, I am using rc engineering 440cc injectors, Walbro fuel pump, and safc (all already installed) I need to know how to hook up the lines to the FPR and how to run the oil return line. I got the kit used and am not sure what I DON'T have. I like to read instructions multiple times before I do something, especially some thing like this. I don't see how I am going about this in the complete oppisite way. I emailed alpine and everyone I could find that has an alpine. No one seems to have the instructions. I though I would ask here. While randoms post vaugly explains a turbo install, I need specific info so I know exactly what I am doing before I start. I do not want to get half way into the install and realize I don't know how to do some thing. Any one that has them Please help |
Well man, they probably DID email them to you but your email account sent it off as spam. Have them email it to ME or someone else for you. Got a Gmail account?
or probably their instruction email is too big for your email box :unsure:
Good catch guys, let's try this again....
Raise hood Jack up car, put up on jack stands Remove stock exhaust manifold manifold/1st cat Remove front bumper (going to be easier without this on the car.) remove intake system remove Injectors/Fuel rail Remove intake manifold Remove oil Remove oil pan Drain coolant Remove head Install decompression plate Re-install head Cut rubber fuel line and install "T" fitting Run "T" to 5th injector and back to stock fuel rail Remove stock FPR and replace with block off plate Install Alpine RRFPR on firewall re-install intake manifold re-install fuel rail/injectors connect fuel rail to new RRFPR and RRFPR to return line Install turbocharger manifold and turbo Install charge piping to intercooler install intercooler install charge piping to throttle body Install 5th injector and fuel line for 5th injector (see T fitting above) Tap head for oil feed for turbo (remove resessed hex bolt) Run oil feed line to top of turbo center section Tap oil pan for turbo oil return line Reinstall oil pan hook oil return line to bottom of turbo center section and oil pan Add oil add coolant re-install front bumper Close hood. Now the fun stuff starts. Wiring in the unichip and the 5th injector! I've got the wiring diagrams around somewhere. Drop me an email and I'll send them to you. If you're not using the unichip, 5th injector or decompresson plate. Raise hood Jack up car, put up on jack stands Remove stock exhaust manifold manifold/1st cat Remove front bumper (going to be easier without this on the car.) remove intake system Remove oil Remove oil pan Install turbocharger manifold and turbo. Install charge piping to intercooler install intercooler install charge piping to throttle body Tap head for oil feed for turbo (remove resessed hex bolt) Run line to turbo Tap oil pan for turbo oil return line Reinstall oil pan hook oil return line to bottom of turbo and oil pan Tap coolant lines for feed/return (use coolant lines running to/from the underside of the throttle body) Add oil re-install front bumper Close hood |
