HKS Super AFR with Turbo
the stock ecu cannot controll even the 440cc injectors, but with the S-AFC the 440's can be used. 550's can only be run if you are using a different ECU. the stocker just cant cut it, with the help of the S-AFC.
I have run larger injectors in many ecu's, why are the Hyundai ecus limited on injector size. The over size injector draws the same current, just flow more fuel for less dwell and your not over currenting the quad driver.
from what i understand you can hook them up to the stock ECU, as long as they are not peak and hold ones... but how the hell are you going to TUNE it? tongue.gif
i can get you a damn good deal on a haltech from australia if your interested.
2 UNIQ,
Just give Matt at www.hitman.hm an email. He can get it for you fairly cheap or try www.rpmperformancecentre.com.au. The thing is either of these guys will have to ship it to someone in Australia first and then have them ship it to the US. US Haltech controls the pricing in the US eventhough the unit is in reality much cheaper... the MOTEC boys are even worse.
I would recommend Matt because, he absolutely knows his sh*t and gives great info and after sales service. Also, he has been involved in multiple Tiburon installs and will provide a good base map to start with.
