Help with connecting boost Gauge
Hello all,
I have just finished doing some work on my 2K1 Accent GL(put turbo in) and need to know where in the world do I hook up the boost gauge????? I have tried to T it into the compressor housing with no pressure reading. And also tried the small vacuum line inbetween the intake and the valve cover also got no results. I'm afraid to tach the engine to high, worried about over boosting the engine. I had it to atleast 4k RPM. This should be high enough don't you think? Well that's enough questions for this post smile.gif <VBG>. Thanks in advance for your help |
Nobody has an idea of how to help me with figuring out how to connect a boost gauge???????????????????? smile.gif smile.gif smile.gif wink
t in between the manifold and FPR.
if you dont have that..hmm.. drill a hole tongue.gif j/k besdies it does not matter what the compressor pressure is, you wanna see the amount of pressure actually getting into the manifold, cause intercooler and such can cause pressure drops. |
So basically any vacuum line coming off of the intake?
Yes "t" into the vacuum line in the intake mainfold. The one in the back of the intake manifold.
<div class='quotetop'>QUOTE</div><div class='quotemain'>Lobert:
So basically any vacuum line coming off of the intake?</div>Any line coming off the intake manifold That should be the vacuum/Boost line. |
Thanks for the replies folks. As soon as I get this thing totally put together I will take some pics and post them here for ya'll.
