Haltech E8 Base Map
Old May 24, 2007 | 08:28 AM
tibbytib's Avatar
Basically what the title says. I will be running a Haltech E8 for my turbo setup and was just wondering if anyone has any base maps for this ECM that they wouldn't mind sharing. fing02.gif
Thanks!
Old Jun 2, 2007 | 09:29 PM
tibbytib's Avatar
1. What are people using for ignitors?
2. What about the A/C dilemma? How do we retain the use of the A/C?
And of course, I still am looking for a base map for my Haltech. The turbo goes in next weekend so I am really looking forward to getting a map that will at least get me pointed in the right direction.
Thanks!
Old Jun 2, 2007 | 10:14 PM
peter_2150's Avatar
I got a Ek6 so I can not help you out in map department.
With the AC tho I still have mine but its not hooked up. If you hook it up it just needs to be tuned little bit more give the added power need to run the AC unit.
What turbo did you go with.
Old Jun 3, 2007 | 07:31 AM
tibbytib's Avatar
How are you running the A/c off the haltech?? We're a little stumped cause our ecu's control multiple stages of the A/C when its on. Since I am going to a standalone, all those functions that the stock ecu did will not be available. My tuner has an idea of how to rig it to work, but I was curious as to what other members have come up with to get their A/C to work with their Haltech.
EDIT:
Peter, I could really use that e6k map if you have it. It should import into the E8 software.
Thanks man!
