Gt28r
Gt28r
hey im wondering since the gt28r has a t25 flange style, and i have the alpine's turbo kit. i wonder if i can buy a gt28r and bolt it right up to the tdo4h manifold that alpine gives you... any help will be highly appreciated.
Garrett GT28R Ball Bearing Turbocharger Assembly with Integral Wastegate
SPECIFICATIONS:
SPECIFICATIONS:
- [*]Displacement range: 1.6-2.5L. [*]Output Range 200-280 horsepower. [*]Compressor Wheel Diameters – 1.83” inducer/ 2.37” exducer [*]Compressor Wheel Trim – 60 [*]Compressor Housing A/R – .60 [*]Compressor Hsg. Attachments: Inlet: 2-bolt flange
Outlet: 3-bolt flange [*]Max Compressor Flow – 31 lbs/min @ 2.5:1 pressure ratio [*]Turbine Wheel Diameters – 2.09” inducer/ 1.64” exducer [*]Turbine Wheel Trim – 62 [*]Turbine Housing A/R – .64 [*]Turbine Hsg. Attachments: Inlet: Standard 4-bolt T25 flange,
Outlet: Standard OEM 5-bolt T25 flange [*]Oil Inlet – Inverted Flare 7/16-24 thread [*]Oil Drain – Standard 2-bolt T25 flange[/list]
