Greddy Td04 System
Old Aug 5, 2005 | 06:56 AM
planrforrobert's Avatar
A friend of mine is selling his turbo set up for his civic, and is willing to give me a good deal on all the parts. For $600, he is selling a Greddy TD04 turbo (mounts to a manifold like a T3), intercooler, blitz blowoff valve, turbo timer, boost controller, pipes, and oil lines. I realize that I will probably not be able to use the pipes, but is this kit worth my time? Also, I know I will still need to buy a turbo manifold, new pipes and a boost gauge, but what else am I going to need? Bigger injectors, fuel pump, exhaust? I am only planning on running at 4 psi of boost, maybe pushing it to 6 or 8 for track use. I am really leaning towards pick this up, but want to make sure that I am not going to be wasting my time.
Old Aug 5, 2005 | 07:20 AM
brian01tib's Avatar
4 psi, that would be a waste of time, you can run much more than that safely espically with a intercooler, 4 psi I am not sure if you need bigger injectors but a feul computer stuff is always good so you can tune your feul such as a standalone
Old Aug 5, 2005 | 07:49 AM
JonGTR's Avatar
I would say all that is worth $600. The other parts can be found cheap. And definately go above 4psi.
Old Aug 5, 2005 | 09:47 AM
Jay-M's Avatar
Vehicle: 01 Tiburon
take it!!! that's a good deal for $600 fing02.gif ... it's just too bad that some of the stuff, you can't use.. maybe you can sell those unused stuff to other civic owners... make a lil' cash smile.gif
Old Aug 5, 2005 | 10:38 AM
Thanks for the info guys. 2 last things. First, how much boost can I run with a stock fuel pump and stock injectors, and how much boost could I run with bigger injectors and upgraded fuel pump? Second, what standalone would you guys recommend? I was thinking about the Haltech, but would that mess with the emissions readings (I live in NY)?
Old Aug 5, 2005 | 11:11 AM
TiburonWao's Avatar
With my SAFC2 and OEM injectors & fuel pump... I was boosting 8PSI.....
For a Standalone... check a post of a few days back.... there will be a GB for a Standalone....
Old Aug 5, 2005 | 11:23 AM
Mad_john's Avatar
that's a good deal for $600 it's just too bad that some of the stuff you can't use. on your ride i would get that with the quickness...
Old Aug 5, 2005 | 12:14 PM
QUOTE (TiburonWao @ Aug 5 2005, 05:11 PM)
I was leaning towards Apexi's SAFC-ii, but how hard are they to tune on your own?
Lastly, I just want to thank everyone that posted on this giving me the information I was after. I know now for sure that I will be taking advantage of this deal and get boosting over the next little while laugh.gif
Old Aug 5, 2005 | 02:08 PM
QUOTE (planrforrobert @ Aug 5 2005, 12:38 PM)
i would say somewhere around 8.
around 12.
Old Aug 5, 2005 | 02:45 PM
xxxmonoxidechild's Avatar
thats a decent deal, and u could probably use most of the IC pipes. all you need is a pipe cutter, and a welder.
