FMU question
Vehicle: 2004 Acura TL
By my understanding you need to have both. The FMU will increase fuel pressure and the piggy-back will tell the injectors to use that extra fuel.
If you have the extra pressure you need something to control the injectors.
Thanx.
So as I understand FMU can be much easier to use on MAF based Tib.
CEL=bad, so I deffinitely need MAP change. And since new MAP (2 bar) piggy-back deffinitely should be used, cause ECU will not understand new MAP correctly.
So I think I'll go this way for fuel management:
-piggy back
-bigger injectors
-fuel pump
(without FMU)
-piggy back
-bigger injectors
-fuel pump
(without FMU)
