ECM E-Mange Stuff
Old Apr 1, 2005 | 01:04 PM
UltraTibby's Avatar
Default ECM E-Mange Stuff
Figured I would post all of the information I have been gathering so that it makes other peoples lives a bit easier.
Injectors
#1 = Pin 3
#2 = Pin 32
#3 = Pin 31
#4 = Pin 4
Knock Sensor
Sensor 1 Power = Pin 70
Sensor 1 Ground = Pin 71
ECU
ECU Power = Pin 58
ECU Ground = Pin 55
MAF
MAF = Pin 41
RPM
Signal = Pin 47
Throttle Position Sensor
TPS = Pin 73
Ignition
#2 & #3 = Pin 52
#1 & #4 = Pin 25
Here is the ECU PinOut:
Once I get the wiring done for the EManage I will draw up a wiring schematic.
