eclipse stock turbo
I TRIED THE CALCULATOR
these are the results
tibby was measured at
engine capacity 2000cc (there wasnt 1975cc)
Maximum RPM 6600 (there wasnt 6750)
for 6psi i got this
T25
60 compressor trim
.49 turbine HSG A/R
BHP=190.59
Air flow LB/per min= 17.54
for 8psi
T25
60 compressor trim
.63 HSG a/r
BHP 201
A/R 18.554
its funny, once i adjusted the rpm to 6800. The calculator recommended the T3 with a 40 compressor trim and .49 trim for an extra 6 BHP.
they are retailing the Gt25 with a .65 trim for $2885 AU which is about 1500US eek.gif
are these numbers about correct???
[ December 05, 2001: Message edited by: JAWS 021 ]
for 6psi i got this
T25
60 compressor trim
.49 turbine HSG A/R
BHP=190.59
for 8psi
T25
60 compressor trim
.63 HSG a/r
BHP 201
A/R 18.554
Yep!!! You got it right! Ok, You can get the GT turbos but they are expensive. I think you can get a T3 with ball bearings for around $800 new. I just bought some and I know this guy has some deals.
Try him and see what you can get: Ola Lysenstoen [ola@innovativeturbo.com]
I also saw some T3 on Ebay just type "garret t3" but they are used and do not show the trim or the a/r spec.
And by the way, you can set up your boost at say 10 psi which is quite safe, you can always switch to say 15 if needed for a while without problems. All you need is a boost regulator valve.
The T028 are good to around 20 psi... but usually we set them for 15 psi but I have seen them spun to 28 psi... of course with a much shorter life.
A T028 or T3 are great turbos... the best for street application is the new Garrett FULL ball bearing GT 25xx turbos... expensive but they spin up quick and have good top end.
Kool
kool
kool
lol
Wow, 15psi,... thats should be my high limit with high octane.
ill guess ill stick to a t25 with a 60 compressor trim.
it will spool up real quick, and put me around 7-10 psi.
does any one know where i can start looking??? i tried ebay, and all they have is a T3 cold air intake,..lol
hey chuek,... how much does the gt sell for???
kool
kool
lol
The name and address I posted before has T25 on sale, $595 to $695. T25 with ballbearings $895. All of them new! I think if you search the web you might find used or rebuilt units for a lot less!
This the place he works at:http://www.innovativeturbo.com/
[ December 05, 2001: Message edited by: Mario ]
wow,... your good at this
Prices eint bad either.
i still need to do some reaserch on intercoolers, so i can get the right size. Plus a water cooled intercooler seems attractive, but i still need to reaserch it.
but thanx,... ill i need to do is locate a retailer for the rrfrr.
hopefully by summer, this project will be completed.
Prices eint bad either.i still need to do some reaserch on intercoolers, so i can get the right size. Plus a water cooled intercooler seems attractive, but i still need to reaserch it.
