Eaton Supercharger M45 Vs M62
Old Nov 1, 2007 | 03:02 PM
balbains324's Avatar
Vehicle: 1998 Hyundai Coupe
I am trying to make the most of my alpine supercharger kit as I have already spent shit loads of money on it. I was thinking of replacing the M45 supercharger with an M62.
What I wanted to know was, would the discharge area be the same for both? e.g would it be a direct replacement on the alpine inlet manifold?
Old Nov 1, 2007 | 03:45 PM
funkypc's Avatar
I posted a topic on this - do a search.
Look at your manifold and look at the pictures of the M62s. I doubt it will be a direct replacement, but it is definitelly doable.
http://www.rdtiburon.com/index.php?showtopic=23555&hl= is the link.
Chances are the M62 will be wider.
Old Nov 1, 2007 | 07:08 PM
the M62 has a larger opening because it is moving more air. Roots style Superchargers do not make boost in their housing, they simply push a LOT of air into your intake, where it builds up pressure and makes boost.
I would go with the M62 over putting a smaller pulley on the M45. Spin a roots compressor too fast and all it does is make heat. The larger M62 will push more air at the same RPMs than the M45.. this making more boost without the heat
Old Nov 2, 2007 | 04:02 AM
hmmm.....I think im going to try it, I can pick a M62 up for £200 whick isn't too bad and the dimensions of both are the same. I will post up my progress fing02.gif
