Dyno Vid
Stock rods with bolts? You might consider replacing the bolts with ARP's. I'm gonna get the measurments on them soon. In your case, you can do it without pulling the motor. Just pull off the oil pan and replace one at a time.
Yep stock bolts Jon. There was nothing else available when i was doing the motor build.
I would defienlty consider replacing the bolts with some ARP's if you can get ARP to match them up to our oem specs.
