DIY Turbo price list
I was thinking of turbo and compiled a list of parts needed for a low boost setup and prices:
Garret T3 (rebuild)-$600
Champion turbo manifold-$400
440 RCEngineering high ohm saturated-$359
Front mount generic intercooler(new)-$375
XS engineering BOV-$99
2nd gen turbo Talon/Eclipse fuel pump (walbro)-$175
S-AFC - $350
Piping (various from jc whitney)-$150
Msd boost timing module-$179
total=$2608
Dayum.... Can anybody help in lowering some of this cost. If I missed anything add please. I didn't even add new pistons cause I said it was a low boost setup, less than 10 psi.
S-AFC - $350
total=$2608
When buying new equipment, you basically have the price dead-on. The "savings" is when you start buying stuff used.
FYI, you can get a set of Lucas 550's from Ballistic Racing for $240 + shipping from South Africa. Good price, good parts, and good service (I have ordered a set for myself)
Ebay. So far here's what I have and what I paid:
Garrett T25 - $100
12:1 Powerdyne Fuel Management Unit - $60
1G DSM intercooler pipe with flange for BOV - $20
1G DSM fuel pump - $20
I also got a copy of Onpol's exhaust manifold with used Turbonetics Mk II wastegate for $350 (manifold is new).
Still shopping for:
intercooler - $100 or less
BOV - 1G DSM, $40 or less
Gauges
After that it's just piping, fittings, installation, and gaskets. All in all, I should get around 200 crank HP tuned for under $2000
Trick is to know exactly what you want, watch e-bay, and find auctions for those parts that seem to go "under the radar". I've been buying stuff for over two months now, and don't anticipate being done for at least another two.
good luck,
ac
Garrett T25 - $100
Still shopping for:
Gauges
good luck,
ac
inobird, according to onpol
"..these injectors can only be use if you have an aftermarket computer like Haltech or Motec.Our cars use saturated type of injectors and the OEM ECU drivers can't use peak and hold ones. "
so, not they won't work with stock ecu and s-afc.
Guest
Posts: n/a
Indobird - here our list...
T3 Garrett cosworth spec (cozzy turbine housing) - $400.00 Rebuild with std T3 shaft, and 50 trim comp wheel - good for 200plus HP
Turbo manifold - $300.00 to fit T3 or T3/T4 hybrids
Front mount cooler designed and used in ballistic Racing stage 1&2 kits (core is 650mm by 200mm by 50 or 60mm) - $350.00
Ballistic Racing BOV 40PSI stable - $115
Fuel pump - $170.00
550cc 16 ohm injectors - $60.00 each
ALL COMPONENTS ARE BRAND NEW EXCEPT THE TURBOCHARGER WHICH IS REBUILT WITH NEW GARRETT ORIGINAL PARTS.
Beat that guys..... :-)
Fuel pump - $170.00
Guest
Posts: n/a
Sorry guys I forgot to mention that I will also do the charge piping for the T3 turbo to and from the cooler aswell - $100.00
BTW the charge piping comes with the option for the BOV to be installed on it or not.... pics of the piping with BOV can be seen on the MSN communities site along with all the other components.
This is WAY under our normal cost, so if you are serious you best jump for it! Normal cooler cost with C/piping is $515.00
[ April 08, 2002, 02:47 PM: Message edited by: UFB ]
I might as well add my 2 cents.
The Champion manifold is a solid cast iron 4 - 1 manifold to fit Garrett T3 type exhaust housing for $300 + shipping... usually $330 delivered.
A picture is here... www.geocities.com/killnme/turbomanifold.html
The price difference with the Champion manifold and UFB's manifold is minimal. The design is a little different. Our's is a 4-1 so theortically it is a better design but UFB's log type may give you a little extra room for mounting the turbo and getting your hands and tools in there to work on it.
Just giving other options.
But UFB's intercooler price and injector prices will be hard to beat even from the cheapest US wholesaler.
indobird:
S-AFC - $350
total=$2608
Well, like my prior post... $100 off of the manifold. You could be the first to try the Split second ARC1-002 on the tibby. It is around $100 cheaper than the S AFC. You might be able to get by without the MSD unit with low boost and good fuel.
S-AFC - $350
total=$2608
