Definitive Quaife Lsd Thread
So who knows the exact quaife part number for the lsd that will work with our cars. According to this thread:
http://www.rdtiburon.com/index.php?showtop...4935&hl=lsd
the quaife lsd we need is the front one from any dsm...awd turbo, fwd turbo, or NA
that doesnt make sense to me, especially when i go to quaife's website and see different part numbers for all three of them. 1st, 2nd, and 4th on this page:
http://www.quaife.co.uk/MITSUBISHI-ATB-DIFFERENTIAL
apparently we need to get hyundai oem lsd bearings and the speedometer drive gear too. is that correct?
so whats up...does anybody know which one we need? for those of you that have them in your possession and KNOW they work in your car can you get a part number off the unit?
I just got an email from them yesterday with the proper part number we need, I will PM you when I get home in the morning with the proper part number. Don't quote me but i do beleave it is the same one as used in the front wheel drive mitisbishi cars. I will get you the part number and the price the gave me ASAP.
I contacted Quaife a few weeks ago regarding an LSD for the RD2 and this is the response I got from them.
I quote
Thank you for your inquiry. As I recall, the Tiburon with the 5 speed uses the same gearbox as the 2WD Mitsubishi Eclipse from 95-00. Our part number for that unit is 48.309.140. This unit currently sells for $1295.00.
Installation requires removal of the gearbox from the vehicle. You must then split the case and remove the stock differential. You then transfer the ring gear over to the Quaife differential and re-install into the gearbox. A service manual for your vehicle should cover the procedure.
Hope this helps
I quote
Hope this helps
thanks a lot guys. would you mind doing me another favor and see if you can get them to specify between turbo or non-turbo FWD eclipses?
i was pretty certain the diff would be different between fwd and awd, but i really dont have a clue if they used a different one in the turbo eclipse.
