Can somebody explain to me in n00b talk how the 5th injector setup works?
Vehicle: 2K Tib
Ive read alot of threads about people doing a 5th injector setup with the old alpine turbo kits. I dont understand how this done. Can someone explain this in laymens terms to me? Thanks.
Vehicle: 2003 Hyundai Accent 22PSI Boost
usually done by spraying more fuel into the intake before the throttle body, not very safe though, best way i have seen is having 2 extra injectors on a seperate rail and having the spray directly into the plenum chamber. This is very oldschool performance mods. The work on a wide open throttle switch or rpm switch calibrated with an aftermarket ECU. It is the same principles as secondary injectors on a rotory motor.
Cheers Ryan
Cheers Ryan
