Boost spikes
QUOTE (2UNIQ @ Mar 9 2007, 09:22 PM)
external Wastegate will solve your issues i had this problem 4 years ago and since i went with a Tial 38mm External gate my problems were solved.Believe it or not even on Low boost an internal gate can cause a problem....The external rectified it RIGHT AWAY
hey I just got and installed my Tial 38mm wastegate. Man that worked wonders!
Boost is hooked on 15psi! Man Tibbys are sure fast when boosted! Wooohooo!
you need to get a external wastegate .... its spiking because your internal one has formed heat cracks around the flapper valve in the turbo...weld it shut and go external with a 38mm gate.... fixed 4 of the same problems in the last 3 months here... fing02.gif
QUOTE (41willys @ Sep 16 2007, 01:02 PM)
Glad to see the External wastegate fixed your problem..
Like i said i had the same problem and once i went External it was like driving a new car fing02.gif
