Hyundai Aftermarket
-   Turbo & Supercharge (Forced Induction) (https://www.hyundaiaftermarket.org/forum/turbo-supercharge-forced-induction-29/)
-   -   Arp Head/Main/Wheel Studs (https://www.hyundaiaftermarket.org/forum/turbo-supercharge-forced-induction-29/arp-head-main-wheel-studs-29577/)
Ericy321 Nov 14, 2007 11:18 AM
Theres no way I would put it all together without these. Im very glad we got a "set" figured out for us
tdonnell Jan 27, 2008 08:34 PM
Hey guys, I don't know exactly why Jon has said front studs only for the evo 8 studs. I just installed them all the way around and they all pressed in tightly. You can definately install these on the rear as well. I am very particular and if these didn't press in tightly I would not have installed them. Are the rear ones supposed to be too tight or too loose? I read the stock and arp knurl diameters once but forgot and am lazy right now sorry.
Ericy321 Jan 28, 2008 03:08 PM
I think the splines are just a little different or something? I dont remember exactly. Ill be doing mine all around also most likely.
tdonnell Jan 28, 2008 03:49 PM
The splines are the same, I think the knurl diameter on the rear studs are slightly smaller, but you can press them in no problem. If you run into issues you could always bore out the stud holes a bit as well, just make sure you use a caliper to measure the drill bit size and make sure to leave the holes few thousandths smaller than the knurl diameter of .565".
Ericy321 Jan 28, 2008 05:43 PM
Good to know. I think thats what it was but I believe it was said that it could still be done with a little more work
tdonnell Feb 11, 2008 09:34 AM
So are we okay to purchase the 'packages' from atomic speedware? Do their packages come with nuts/washers as well?
Thanks guys.
Mad_john Feb 11, 2008 09:48 AM
yes and no... he got everyting right for me but the 2 m12 head bolts. jongtr saved my ass on that one.. but if you do make sure you call and remind him
just in case. but in the end. atomic did send me the right ones... jon was faster baby hail.gif
Ericy321 Mar 12, 2008 07:13 PM
Does anyone know off hand what size our flywheel bolts are? Im thinking about getting ARP flywheel bolts and just was looking for a size to see which ones we can use. Or is it completely unnecesary?
JonGTR Mar 13, 2008 11:22 AM
I'm pretty sure after having 5 grenaded clutches and as much abuse I've put the flywheel/clutch system through, there's no need for having them if they're still holding fine for me.
tdonnell Mar 13, 2008 02:43 PM
Good point, lol.
